Adding serial support to Qt4.6.0
nishad_kamdar
I have a custom iMX6q board and i am using Ltib with L3.0.35_4.1.0 Kernel.
I have installed QT version 4.6.0 and i am successfully able to run simple applications.
However, i specifically need serial connectivity support for my application.
As 4.6.0 does not by default have serial driver support , it would be very helpful if you could suggest the procedure to add serial connectivity support to the QT 4.6.0.
regards,
nishad
Labels (2)
jimmychan
jimmychan
This may useful for you.
< QtSerialPort | Qt Wiki | Qt Project >
