Hi Jeff
>if linux setup interface to be memory mapped can I access it from the M4?
yes
>can I use SDMA to do a memory-to-memory transfer?
yes. Some sdma examples can be found in unit tests
mxc_sdma_test\test - imx-test - i.MX Driver Test Application Software
Rpmsg driver is described in sect.2.8 Remote Processor Messaging
attached Linux Manual.
