About i.MX6 AV encoding/decoding solution
4,485件の閲覧回数
i386
I am using imx6d platform, running Linux without any GUI(NOT Ubuntu).
I need to implement the audio & video encoding/decoding functions.
As I know, gstreamer is a choice, but it needs Gnome, not for bare Linux. FFmpeg is another choice, but I don't know how to build out the version with imx6 vpu hardware acceleration. Is there any solution for me ?
ラベル(4)
4 返答(返信)
4,257件の閲覧回数
Hi Gary
multimedia recipes should be used for including codecs, please check
attached yocto guide p.4.
4,257件の閲覧回数
i386
Where can I find the related code example which uses the codec lib???
4,257件の閲覧回数
4,257件の閲覧回数
i386
I know and have these examples. The vpu-test code you mentioned contains only video encoding or decoding, without audio part.
I need the code which can encoding and decoding audio & video stream, with audio-video sync.
