About ddr frequency change
1,181 次查看
MasakiHayakawa
Android version is ICS, NXP patch name is imx-android-13.4.1.
Target platform is custom board of epdc system on i.MX6DualLite.
The configuration is two Micro 1GBx32 LPDDR2 in a dual-channel interleaved, 64-bit wide memory system.
We donwloaded patch files on the following site, files are 0001-Support-LPDDR2-on-6DL-platform_Uboot and 0001-Support-LPDDR2-on-6DL-platform_Kernel, and applied.
https://community.nxp.com/docs/DOC-94922
But after lpddr2 frequency change from 24MHz to 400MHz, kernel frequenctly freeze with dump messages.
We removed CON_REQ bit control of MMDCx_MDSCR register when lpddr2 frequency change entry and ext  (file:arch/arm/mach-mx6/mx6_lpddr_freq.S), and it appears to be stable.
We refered to fsl-yocto-L4.1.15_1.2.0-ga.
Please tell me whether CON_REQ bit control of MMDCx_MDSCR register is need or not.
We think that this control is need...  why did you remove this control on fsl-yocto-L4.1.15_1.2.0-ga ?
Best Regards.
Masaki Hayakawa
标签 (3)
904 次查看
MasakiHayakawa
Hi igor,
Thank you for reply.
We have question about CON_REQ bit.
We refered i.MX6 Solo/DualLIte Applications Processor Reference  Manual.
The CON_REQ bit description in MMDCx_MDSCR field descriptions is the following.
Configuration request/acknowledge mechanism should be used for the following procedures:
changing of timing parameters, during calibration process or driving commands via MDSCR[CMD].
We checked attachment file (arch/arm/mach-imx/lpddr2_freq_imx6q.S).
This file change timing parameters (MMDCx_CFG0,MMDCx_CFG1,MMDCx_CFG2,etc).
The CON_REQ bit control is need, isn't it ?
And please tell me LPDDR2 sequence about frequency change entry/exit.
Best Regards.
904 次查看
igorpadykov
Hi Masaki
recommended to use latest lpddr2 codes, also please check lpddr2 scm patches
SCM-i.MX 6Dual/6Quad Linux Patch not able to bitbake
note, for i.MX6DualLite arch/arm/mach-imx/lpddr2_freq_imx6q.S should be used
linux-2.6-imx.git - Freescale i.MX Linux Tree
