About JPEG decode by gst command.
已解决
跳至解决方案
4,471 次查看
keitanagashima
Senior Contributor I
Dear All,
Device: i.MX 6Q
BSP: L3.14.28_1.0.0
My customer wants to use the below gst command to display the jpeg file.
<Command A>
$ gst-launch-1.0 filesrc location=<jpeg file> ! decodebin ! imxg2dvideosink
But, the "imxvpudec" element has been automatically chosen and the element supports only Baseline profile .
BTW, the below command can display the jpeg file except Baseline profile.
<Command B>
gst-launch-1.0 filesrc location=<jpeg file> ! jpegdec ! imxg2dvideosink
[Question]
Do you know the modification method that "jpegdec" is automatically chosen by the <Command A>?
Keita
标签 (5)
1 解答
4,147 次查看
Yuri
I mean Gst API (C++).
Yuri.
在原帖中查看解决方案
6 回复数
4,147 次查看
Yuri
  Looks like, You need using the API rather than gst-launch.
Yuri
4,147 次查看
keitanagashima
Hi Yuri,
Thank you for your reply.
Is your mentioned API described in i.MX VPU Application Programming Interface Linux Reference Manual?
The VPU looks only supporting the Baseline profile from Release note & below community.
Issues decoding MJPEG with VPUdec
My customer wants to decode the JPEG with Baseline and other profiles.
So, I think that source code of "decodebin" should change.
Keita
4,148 次查看
Yuri
Yuri.
4,147 次查看
keitanagashima
Hi Yuri,
Hello. Sorry I couldn't understand the "Gst API (C++)".
What is it?
Keita
4,147 次查看
keitanagashima
Hi Yuri,
OK. I got it.
Keita
