About JPEG decode by gst command.
4,522件の閲覧回数
keitanagashima
Senior Contributor I
Dear All,
Device: i.MX 6Q
BSP: L3.14.28_1.0.0
My customer wants to use the below gst command to display the jpeg file.
<Command A>
$ gst-launch-1.0 filesrc location=<jpeg file> ! decodebin ! imxg2dvideosink
But, the "imxvpudec" element has been automatically chosen and the element supports only Baseline profile .
BTW, the below command can display the jpeg file except Baseline profile.
<Command B>
gst-launch-1.0 filesrc location=<jpeg file> ! jpegdec ! imxg2dvideosink
[Question]
Do you know the modification method that "jpegdec" is automatically chosen by the <Command A>?
Keita
ラベル(5)
4,198件の閲覧回数
Yuri
I mean Gst API (C++).
Yuri.
6 返答(返信)
4,198件の閲覧回数
Yuri
  Looks like, You need using the API rather than gst-launch.
Yuri
4,198件の閲覧回数
keitanagashima
Hi Yuri,
Thank you for your reply.
Is your mentioned API described in i.MX VPU Application Programming Interface Linux Reference Manual?
The VPU looks only supporting the Baseline profile from Release note & below community.
Issues decoding MJPEG with VPUdec
My customer wants to decode the JPEG with Baseline and other profiles.
So, I think that source code of "decodebin" should change.
Keita
4,199件の閲覧回数
Yuri
Yuri.
4,198件の閲覧回数
keitanagashima
Hi Yuri,
Hello. Sorry I couldn't understand the "Gst API (C++)".
What is it?
Keita
4,198件の閲覧回数
keitanagashima
Hi Yuri,
OK. I got it.
Keita
