About BitmapFactory.decode File in Android4.4.3 BSP for i.MX6-SABRE
1,687 次查看
yuuki
Senior Contributor II
Dear all,
We use the Android4.4.3(NXP's BSP) on MX6Q-SABRE-SDB board.
We want to decode JPAG file by using Android's API.
- BitmapFactory.decode File
Does this API use hardware Video Codec(VPU)?
If it does not use VPU, Could you tell me how to use VPU by this API?
Yuuki
标签 (2)
4 回复数
1,478 次查看
joanxie
decoding jpeg uses software decoding in current android bsp, not vpu.
you can referr to the release note to check if software support this or not.
1,478 次查看
yuuki
Dear Guanqiong Xie-san,
Thank you for your support.
Could you tell me how to decode JPEG by hardware?
I understand that JPEG decode of VPU supports only Baseline profile.
Is my understanding is correct?
Yuuki
1,478 次查看
joanxie
current bsp uses software decoding, if you need to use VPU, you need create your own application to call the vpu.
yes, supports baseline.
1,478 次查看
yuuki
For JPEG Decode, what kind of function should we call for?
Yuuki
