Abnormal Tamper Behavior
1,610件の閲覧回数
tsung-chihwang
We found this symptom on our target.
It shows different tampered result while boot loader placed into QSPI flash or SD card.
We also found below result on EVK.
Below are our basic information.
1. Chip model? iMX6UL
2. BSP version? 3.14.38 6ul ga
3. how the BSP image is deployed to QSPI ? Using the MFGTool
BR,
carter
タグ(1)
1,389件の閲覧回数
Hi carter
seems problem may be in qspi programming, one can try
to reset board and check if it reboot fine from qspi.
May be recommended to try latest NXP BSPs:
i.MX Software|NXP
