hello NXP :
1 another try to build AOSP (Android 11)has been failed:
2 the follow was the error log file for your reference:
3 failed at location:
[ 99% 136548/137181] Target Java: out/target/common/obj/APPS/Dialer_intermediates/classes-full-debug.jar
FAILED: out/target/common/obj/APPS/Dialer_intermediates/classes-full-debug.jar
4 more detailed please decompress the zip log file to see it .
5 hope to hear from you !
6 thank you for your help.
7 ubuntu20.04.3 LTS +Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz 16Ghz +MemTotal: 16169652 kB
8 cmd :
$source ~/imx-android-11.0.0_2.2.0/imx_android_setup.sh
$cd ~/tools
$git clone https://android.googlesource.com/platform/prebuilts/clang/host/linux-x86 prebuilt-android-clang -b master
$export CLANG_PATH=/home/zsh/tools/prebuilt-android-clang
$export AARCH64_GCC_CROSS_COMPILE=/opt/gcc-arm-8.3-2019.03-x86_64-aarch64-elf/bin/aarch64-elf-
:~/android_build$ source build/envsetup.sh
:~/android_build$ lunch mek_8q-eng
$./imx-make.sh -j16 2>&1 | tee build-log.txt
9 yesterday night it was failed one more time .build-log_4.zip thanks .10.25th,9:19am shenzhen china .thanks .
