AN12149 PTP SOUCE CODE PORTING
2,829 次查看
achal980
The folder doesn't contain souce code folder which contains the main fucntion, how to run this pleas help
标记 (1)
2,806 次查看
kerryzhou
Hi @achal980 ,
  Please go to this path:\AN12149SW\AN12149\boards\evkmimxrt1060\demo_apps\lwip_ptpd_freertos
Then in file lwip_ptpd_freertos.c, you can find the main.
Wish it helps you!
Kerry
4 回复数
2,820 次查看
Rita_Wang
Could you tell us which product and which version BSP are you using?
2,818 次查看
achal980
i am targetting evkmimxrt1060.
2,807 次查看
kerryzhou
Hi @achal980 ,
Wish it helps you!
Kerry
2,159 次查看
ViorelDv
Where is AN12149SW available ?
I've been looking for it on the NXP website but I could not find it.
Viorel
