ALSA Volume Control for imx-spdif
carotte
I'm using S/PDIF on imx6ull.
ALSA doesn't show any controls for this device.
Can anyone give advise on how to control volume on imx-spdif ?
Thanks!
Tags (4)
carotte
Hi Igor,
could you please elaborate further ?
amixer doesn't show any controls for this device, neither does alsamixer.
Hi Noel
I asked internally and got below advice:
Please let customer to try "alsamixer" command to check if there is one sound card named "imx-spdif"
carotte
Hi Igor,
Thanks for your reply!
That is indeed what I did, but there are no controls available for this device.
Please find the screenshot attached.
Hi Noel
from team:
Actually, in our release,  we didn't enabled spdif as default on imx6ull.
Could you help to double confirm if customer enable SPDIF correctly and the initialization is successful?
Please upload their patch and SCH if possible
You can provide (if necessary) these materials usung service request.
https://community.nxp.com/t5/HomeTest-Knowledge-Base/How-to-submit-a-new-question-for-NXP-Support/ta...
carotte
Hi Igor,
I think the link is outdated, could you please update it ?
Thanks!
Hi Noel
one can try amixer described in sect.7.5 Audio Mixer (AUDMIX)    i.MX Linux Reference Manual​
https://source.codeaurora.org/external/imx/imx-test/tree/test/mxc_amix_test?h=lf-5.10.y_2.0.0
imx-spdif driver is described in sect.7.4 The Sony/Philips Digital Interface (S/PDIF)
