Chromium EGL issues with Wayland and Vivante
arslan
I am trying to run hardware accelerated version of Chromium on Imx8MM-Evk board. I built everything with Yocto Hardknott.
When I start Chromium (with and without the option --in-proc-gpu), Chromium says:
[     1] Failed EGL API GetProcAddress: eglLockSurfaceKHR !
[     2] Failed EGL API GetProcAddress: eglUnlockSurfaceKHR !
[     3] Failed EGL API GetProcAddress: eglBindWaylandDisplayWL !
[     4] Failed EGL API GetProcAddress: eglUnbindWaylandDisplayWL !
[     5] Failed EGL API GetProcAddress: eglQueryWaylandBufferWL !
[     6] Failed EGL API GetProcAddress: eglUpdateWaylandBufferWL !
[     7] Failed EGL API GetProcAddress: eglSetDamageRegionKHR !
[     8] Failed EGL API GetProcAddress: eglSwapBuffersWithDamageEXT !
[     9] Failed EGL API GetProcAddress: eglQueryDmaBufFormatsEXT !
[    10] Failed EGL API GetProcAddress: eglQueryDmaBufModifiersEXT !
[    11] Failed EGL API GetProcAddress: eglPatchID !
[    12] Failed ES_Common API GetProcAddress: forward_glActiveTexture !
[    13] Failed ES_Common API GetProcAddress: forward_glBindBuffer !
[    14] Failed ES_Common API GetProcAddress: forward_glBindTexture !
[    15] Failed ES_Common API GetProcAddress: forward_glBlendFunc !
[    16] Failed ES_Common API GetProcAddress: forward_glBufferData !
[    17] Failed ES_Common API GetProcAddress: forward_glBufferSubData !
[    18] Failed ES_Common API GetProcAddress: forward_glClear !
[    19] Failed ES_Common API GetProcAddress: forward_glClearColor !
[    20] Failed ES_Common API GetProcAddress: forward_glClearDepthf !
[    21] Failed ES_Common API GetProcAddress: forward_glClearStencil !
[    22] Failed ES_Common API GetProcAddress: forward_glColorMask !
[    23] Failed ES_Common API GetProcAddress: forward_glCompressedTexImage2D !
This list is very long, I just cut it. Alot of lines later, I get:
EGL: Warning: No default display support on wayland
[569:569:1111/101924.422021:ERROR:gl_surface_egl.cc(1350)] EGL display query failed with error EGL_SUCCESS
[569:569:1111/101924.422627:ERROR:gl_surface_egl.cc(1375)] eglInitialize Default failed with error EGL_BAD_DISPLAY
[569:569:1111/101924.423025:ERROR:gl_ozone_egl.cc(20)] GLSurfaceEGL::InitializeOneOff failed.
[569:569:1111/101924.445521:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
[530:530:1111/101924.507133:ERROR:cursor_loader.cc(115)] Failed to load a platform cursor of type kNull
[584:584:1111/101924.926538:ERROR:gpu_init.cc(453)] Passthrough is not supported, GL is swiftshader, ANGLE is
[530:600:1111/101928.669055:ERROR:chrome_browser_main_extra_parts_metrics.cc(228)] crbug.com/1216328: Checking Bluetooth availability started. Please report if there is no report that this ends.
[530:600:1111/101928.669610:ERROR:chrome_browser_main_extra_parts_metrics.cc(231)] crbug.com/1216328: Checking Bluetooth availability ended.
[530:600:1111/101928.669689:ERROR:chrome_browser_main_extra_parts_metrics.cc(234)] crbug.com/1216328: Checking default browser status started. Please report if there is no report that this ends.
[530:600:1111/101928.690454:ERROR:chrome_browser_main_extra_parts_metrics.cc(238)] crbug.com/1216328: Checking default browser status ended.
[530:530:1111/101932.899099:ERROR:cursor_loader.cc(115)] Failed to load a platform cursor of type kHand
currently this output is from Chromium version 95, but I have this problem in all 9x versions, I didn't try 8x.
Running a OpenGl example from weston (weston-simple-egl) does not show such problems about EGL.
Anyone running Chrome succesfully without these warnings? Or any hints, if something should be modified in Chromium recipes?
Tags (3)
arslan
@Bio_TICFSL , thanks for the reply.
We built a new image for IMX8M Nano, which according to NXP, should have a 3D HW support, but we have also here the same warnings. I think the problem here is caused by something else.
The following snippet is just the half of the warnings.
[    24] Failed ES_Common API GetProcAddress: forward_glCompressedTexSubImage2D !
[    25] Failed ES_Common API GetProcAddress: forward_glCopyTexImage2D !
[    26] Failed ES_Common API GetProcAddress: forward_glCopyTexSubImage2D !
[    27] Failed ES_Common API GetProcAddress: forward_glCullFace !
[    28] Failed ES_Common API GetProcAddress: forward_glDeleteBuffers !
[    29] Failed ES_Common API GetProcAddress: forward_glDeleteTextures !
[    30] Failed ES_Common API GetProcAddress: forward_glDepthFunc !
[    31] Failed ES_Common API GetProcAddress: forward_glDepthMask !
[    32] Failed ES_Common API GetProcAddress: forward_glDepthRangef !
[    33] Failed ES_Common API GetProcAddress: forward_glDisable !
[    34] Failed ES_Common API GetProcAddress: forward_glDrawArrays !
[    35] Failed ES_Common API GetProcAddress: forward_glDrawElements !
[    36] Failed ES_Common API GetProcAddress: forward_glEnable !
[    37] Failed ES_Common API GetProcAddress: forward_glFinish !
[    38] Failed ES_Common API GetProcAddress: forward_glFlush !
[    39] Failed ES_Common API GetProcAddress: forward_glFrontFace !
[    40] Failed ES_Common API GetProcAddress: forward_glGenBuffers !
[    41] Failed ES_Common API GetProcAddress: forward_glGenTextures !
[    42] Failed ES_Common API GetProcAddress: forward_glGetBooleanv !
[    43] Failed ES_Common API GetProcAddress: forward_glGetBufferParameteriv !
[    44] Failed ES_Common API GetProcAddress: forward_glGetError !
[    45] Failed ES_Common API GetProcAddress: forward_glGetFloatv !
[    46] Failed ES_Common API GetProcAddress: forward_glGetIntegerv !
[    47] Failed ES_Common API GetProcAddress: forward_glGetPointerv !
[    48] Failed ES_Common API GetProcAddress: forward_glGetString !
[    49] Failed ES_Common API GetProcAddress: forward_glGetTexParameterfv !
[    50] Failed ES_Common API GetProcAddress: forward_glGetTexParameteriv !
[    51] Failed ES_Common API GetProcAddress: forward_glHint !
[    52] Failed ES_Common API GetProcAddress: forward_glIsBuffer !
[    53] Failed ES_Common API GetProcAddress: forward_glIsEnabled !
[    54] Failed ES_Common API GetProcAddress: forward_glIsTexture !
[    55] Failed ES_Common API GetProcAddress: forward_glLineWidth !
[    56] Failed ES_Common API GetProcAddress: forward_glPixelStorei !
[    57] Failed ES_Common API GetProcAddress: forward_glPolygonOffset !
[    58] Failed ES_Common API GetProcAddress: forward_glReadPixels !
[    59] Failed ES_Common API GetProcAddress: forward_glSampleCoverage !
[    60] Failed ES_Common API GetProcAddress: forward_glScissor !
[    61] Failed ES_Common API GetProcAddress: forward_glStencilFunc !
[    62] Failed ES_Common API GetProcAddress: forward_glStencilMask !
[    63] Failed ES_Common API GetProcAddress: forward_glStencilOp !
[    64] Failed ES_Common API GetProcAddress: forward_glTexImage2D !
[    65] Failed ES_Common API GetProcAddress: forward_glTexParameterf !
[    66] Failed ES_Common API GetProcAddress: forward_glTexParameterfv !
[    67] Failed ES_Common API GetProcAddress: forward_glTexParameteri !
[    68] Failed ES_Common API GetProcAddress: forward_glTexParameteriv !
[    69] Failed ES_Common API GetProcAddress: forward_glTexSubImage2D !
[    70] Failed ES_Common API GetProcAddress: forward_glViewport !
[    71] Failed ES_Common API GetProcAddress: forward_glMapBufferOES !
[    72] Failed ES_Common API GetProcAddress: forward_glUnmapBufferOES !
[    73] Failed ES_Common API GetProcAddress: forward_glEGLImageTargetTexture2DOES !
[    74] Failed ES_Common API GetProcAddress: forward_glEGLImageTargetRenderbufferStorageOES !
[    75] Failed ES_Common API GetProcAddress: forward_glMultiDrawArraysEXT !
[    76] Failed ES_Common API GetProcAddress: forward_glMultiDrawElementsEXT !
[    77] Failed ES_Common API GetProcAddress: forward_glTexDirectVIV !
[    78] Failed ES_Common API GetProcAddress: forward_glTexDirectInvalidateVIV !
[    79] Failed ES_Common API GetProcAddress: forward_glTexDirectVIVMap !
[    80] Failed ES_Common API GetProcAddress: forward_glTexDirectTiledMapVIV !
[    81] Failed GLES32 API GetProcAddress: glMultiDrawArraysEXT !
[    82] Failed GLES32 API GetProcAddress: glMultiDrawElementsEXT !
[    83] Failed GLES32 API GetProcAddress: glTexDirectVIV !
[    84] Failed GLES32 API GetProcAddress: glTexDirectInvalidateVIV !
[    85] Failed GLES32 API GetProcAddress: glTexDirectVIVMap !
[    86] Failed GLES32 API GetProcAddress: glTexDirectTiledMapVIV !
[    87] Failed GLES32 API GetProcAddress: glMultiDrawArraysIndirectEXT !
[    88] Failed GLES32 API GetProcAddress: glMultiDrawElementsIndirectEXT !
[    89] Failed GLES32 API GetProcAddress: glGetTexImage !
[    90] Failed ES Common GLES2X API GetProcAddress: glMultiDrawArraysEXT !
[1400:1433:1125/145416.338088:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.338685:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.338774:ERROR:gpu_info_collector.cc(90)] gl::init::CreateGLContext failed
[1400:1433:1125/145416.338796:ERROR:gpu_info_collector.cc(389)] Could not create context for info collection.
[1400:1433:1125/145416.339986:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.340092:ERROR:gpu_info_collector.cc(90)] gl::init::CreateGLContext failed
[1400:1433:1125/145416.340116:ERROR:gpu_info_collector.cc(389)] Could not create context for info collection.
[1400:1433:1125/145416.352724:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.352859:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.352890:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.352939:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1400:1125/145416.425062:ERROR:cursor_loader.cc(115)] Failed to load a platform cursor of type kNull
[1400:1433:1125/145416.477473:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.477552:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.477581:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.477616:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.480241:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.480325:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.480350:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.480393:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.557511:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.557611:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.557638:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.557681:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.600622:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.600687:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.600711:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.600753:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.602307:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.602377:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.602402:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.602439:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.603803:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.603867:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.603892:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.603932:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.605115:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.605178:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.605202:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.605244:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.606740:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.606807:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.606832:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.606872:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.608876:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.608943:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.608967:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.609010:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.611054:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.611123:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.611148:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.611187:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.613752:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.613815:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.613840:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.613876:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.615256:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.615327:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.615352:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.615393:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.617302:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.617361:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.617385:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.617418:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.620692:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.620768:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.620795:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.620829:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.623011:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.623090:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.623119:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.623154:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.629842:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.629943:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.629971:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.630040:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.635649:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.635719:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.635744:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.635779:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.637499:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.637566:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.637590:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.637625:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.639021:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.639082:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.639107:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.639143:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.640471:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.640531:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.640555:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.640596:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.641909:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.641964:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.641990:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.642026:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.643367:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.643432:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.643456:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.643490:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.644771:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.644827:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.644850:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.644887:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.646151:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.646255:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.646279:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.646315:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.648033:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.648105:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.648129:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.648164:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.649822:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.649902:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.649927:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.649967:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.651881:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.651959:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.651984:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.652020:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.653621:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.653677:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.653705:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.653738:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.656015:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.656077:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.656102:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.656137:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.658127:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.658244:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.658275:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.658312:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.659555:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.659621:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.659648:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.659683:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.660741:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.660830:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.660861:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.660896:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.661831:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.661882:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.661905:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.661938:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.663566:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.663622:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.663644:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.663681:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.665571:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.665620:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.665647:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.665679:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.667357:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.667414:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.667437:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.667475:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.668421:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.668468:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.668495:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.668529:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.669439:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.669490:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.669513:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.669550:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.670515:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.670570:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.670598:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.670631:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.671634:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.671770:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.671800:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.671838:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.672807:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.672860:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.672885:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.672921:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.673845:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.673893:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.673918:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.673951:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.676232:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.676292:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.676317:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.676356:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.679191:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.679250:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.679276:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.679316:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.680907:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.680963:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.680991:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.681025:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.681975:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.682037:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.682061:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.682100:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.683204:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.683271:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.683296:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.683339:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.685567:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.685625:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.685655:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.685690:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.688131:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.688233:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.688260:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.688302:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.690249:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.690326:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.690355:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.690391:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.695370:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.695789:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.696114:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.696437:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.700989:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.701091:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.701118:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.701166:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.703689:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.703763:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.703787:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.703830:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.708758:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.708867:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.708892:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.708934:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.713186:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.713283:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.713308:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.713349:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.721027:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.721172:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.721204:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.721251:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.726055:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.726146:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.726213:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.726254:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.727934:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.728019:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.728048:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.728084:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.731584:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.731688:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.731718:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.731760:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.736398:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.736518:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.736547:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.736599:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.740824:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.740909:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.740940:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.740983:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.742907:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.742979:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.743003:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.743039:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.746056:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.746312:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.746354:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.746411:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.749731:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.749885:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.749922:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.749996:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.753427:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.753580:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.753611:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.753675:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.758899:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.759125:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.759163:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.759240:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.764432:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.764508:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.764533:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.764573:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.770852:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.770955:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.770981:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.771025:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.776776:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.777176:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.777218:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.777310:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.786155:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.786664:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.786718:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.786819:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.793150:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.793249:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.793274:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.793315:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.795809:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.795910:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.795935:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.795978:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.798154:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.798277:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.798302:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.798345:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.804282:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.804391:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.804418:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.804464:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.806349:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.806429:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.806454:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.806497:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.808492:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.808573:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.808596:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.808642:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.813815:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.813960:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.814000:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.814076:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.817679:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.817856:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.817888:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.817943:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.821877:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.822095:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.822137:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.822388:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.832817:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.834479:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.834622:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.834700:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.836204:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.836265:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.836289:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.836328:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.837319:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.837371:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.837394:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.837427:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.838455:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.838511:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.838535:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.838570:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.840770:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.840819:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.840842:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.840876:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.843113:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.843200:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.843226:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.843268:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.845105:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.845163:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.845186:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.845218:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.846277:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.846344:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.846369:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.846404:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.847441:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.847498:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.847523:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.847555:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.848529:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.848585:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.848608:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.848680:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.850245:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.850322:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.850348:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.850386:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.852397:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.852470:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.852495:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.852538:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.854007:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.854080:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.854107:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.854152:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.855663:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.855732:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.855758:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.855798:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.857263:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.857324:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.857347:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.857387:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.859704:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.859836:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.859874:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.859947:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.862978:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.863102:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.863129:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.863192:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.865262:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.865355:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.865382:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.865436:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.867920:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.868105:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.868147:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.868227:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.871804:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.871968:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.872007:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.872088:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.875798:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.875976:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.876012:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.876094:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.877776:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.877831:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.877856:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.877893:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.879212:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.879268:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.879292:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.879332:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.880253:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.880304:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.880328:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.880369:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.881260:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.881313:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.881337:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.881377:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.882451:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.882506:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.882530:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.882563:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.883755:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.883849:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.883877:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.883921:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.892267:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.892353:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.892383:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.892425:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.893930:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.893995:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.894021:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.894064:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.896636:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.896781:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.896817:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.896884:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.899977:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.900126:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.900164:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.900241:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.903136:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.903280:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.903311:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.903372:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.910559:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.910766:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.910802:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.910895:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.918853:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.919024:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.919052:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.919107:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.921775:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.921847:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.921872:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.921918:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.923905:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.923974:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.923998:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.924040:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.925329:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.925394:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.925418:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.925459:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.928389:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.928513:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.928541:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.928599:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.931012:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.931109:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.931137:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.931194:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.933254:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.933391:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.933426:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.933501:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.937784:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.937994:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.938029:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.938119:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.945665:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.945770:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.945798:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.945844:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.950595:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.950678:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.950704:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.950747:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.953395:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.953462:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.953489:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.953534:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.956816:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.956886:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.956911:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.956947:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.960517:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.960639:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.960667:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.960725:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.964036:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
[1400:1433:1125/145416.964152:ERROR:gpu_channel_manager.cc(819)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1400:1433:1125/145416.964187:ERROR:shared_image_stub.cc(524)] SharedImageStub: unable to create context
[1400:1433:1125/145416.964252:ERROR:gpu_channel.cc(568)] GpuChannel: Failed to create SharedImageStub
[1400:1433:1125/145416.967285:ERROR:gl_context_egl.cc(166)] eglBindApi failed with error EGL_BAD_PARAMETER
Bio_TICFSL
Hello arslan,
It look like you need the complete driver form EGL, the MX8MM does not have gpu 3D that the main reason of that error.
