ACM not working acm_bind_config is never called
2,208 次查看
handala
  I have been trying to get ACM to work and enumerate, but it seems I'm missing something. When adding "acm" :
on property:sys.usb.config=mtp,adb,acm
    write /sys/class/android_usb/android0/enable 0
    write /sys/class/android_usb/android0/idVendor 18d1
    write /sys/class/android_usb/android0/idProduct d02
    write /sys/class/android_usb/android0/functions ${sys.usb.config}
    write /sys/class/android_usb/android0/enable 1
    start adbd
    setprop sys.usb.state ${sys.usb.config}
It seems that "acm_bind_config" is never called. Anyone has encountered this issue?
Chafik
标签 (4)
1,360 次查看
prasannakulkarni
Hi,    add the following lines in init.freescale.usb.rc
    write /sys/class/android_usb/android0/functions $sys.usb.config
    write /sys/class/android_usb/android0/f_acm/instances 1
    start adbd
    setprop sys.usb.state $sys.usb.config
along with this it needs one more line in default.prop  i.e   change persist.sys.usb.config=mtp,adb   to  persist.sys.usb.config=mtp,adb,acm  it will work.. i have tested..
