8MPLUSLPD4-EVK Compute Module Footprint Drawing Missing
846 次查看
henryofskallitz
I would like to use the compute module of 8MPLUSLPD4-EVK board in a separate design. However, looking at the design files, I couldn't see any sort of technical drawing of the compute module so I can create the footprint.
Is there such technical drawing showing dimensions and connector footprints that I can use?
824 次查看
JorgeCas
You can refer to the design files and use LAY-46368_A1.brd or REF-46368_A1.pdf.
Best regards.
