tarball created by Curtis Wald and Leonardo Sandoval containing patches to fix ltib issues for Ubuntu 12.04.
Steps to use this tarball
# go to ltib folder
$ cd <ltib full path>
# untar the tarball
$ tar -xzvf ubuntu-ltib-patch.tgz
# go to untared folder
$ cd ubuntu-ltib-patch
#install patches
$ ./install-patches.sh <ltib full path>
You above steps are contained in this script:
so instead of typing them manually you can execute the following command
curl -L https://community.freescale.com/servlet/JiveServlet/downloadBody/93455-102-2-2825/patch-ltib-ubuntu1... | bash
under your ltib folder.
there are several issues which are patched. Please check all .patch files to see what is being fixed.
