ubuntu-ltib-patch.tgz
Search instead for
No ratings
tarball created by Curtis Wald and Leonardo Sandoval containing patches to fix ltib issues for Ubuntu 12.04.
Steps to use this tarball
# go to ltib folder
$ cd <ltib full path>
# untar the tarball
$ tar -xzvf ubuntu-ltib-patch.tgz
# go to untared folder
$ cd ubuntu-ltib-patch
#install patches
$ ./install-patches.sh <ltib full path>
You above steps are contained in this script:
https://community.freescale.com/servlet/JiveServlet/downloadBody/93455-102-2-2825/patch-ltib-ubuntu1...,
so instead of typing them manually you can execute the following command
curl -L https://community.freescale.com/servlet/JiveServlet/downloadBody/93455-102-2-2825/patch-ltib-ubuntu1... | bash
under your ltib folder.
Comments
what issue would be fixed?
there are several issues which are patched. Please check all .patch files to see what is being fixed.
thanks Gonzalez,
           i have try to build ltib on ubuntu 12.04, it woule be failed if didn,t patch this patch.
Version history
Revision #:
1 of 1
Last update:
‎09-28-2012 02:58 PM
Updated by:
