rtp/udp streaming data transfer
1) rtp
linux side:
gst-launch mfw_v4lsrc fps-n=30 ! vpuenc codec=6 ! queue ! rtph264pay ! udpsink host=192.168.0.105 port=5000 –v
pc side:
open the attached H264.sdp file using VLC. Then you can find the picture from camera on mx6 board, pls don’t forget to load camera module
2)
Receive Pipeline from Board to PC:
gst-launch -v gstrtpbin name=rtpbin udpsrc caps='application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=96' port=5000 ! rtpbin.recv_rtp_sink_0 rtpbin. ! rtph264depay ! queue ! ffdec_h264 ! queue ! autovideosink sync=false  udpsrc port=5001 ! rtpbin.recv_rtcp_sink_0 sync=false rtpbin.send_rtcp_src_0 ! udpsink port=5005 sync=false async=false
Output:
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstRtpBin:rtpbin.GstGhostPad:send_rtcp_src_0: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpSession:rtpsession0.GstPad:send_rtcp_src: caps = application/x-rtcp
/GstPipeline:pipeline0/GstUDPSink:udpsink0.GstPad:sink: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRtpBin:rtpbin.GstGhostPad:send_rtcp_src_0.GstProxyPad:proxypad2: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpSession:rtpsession0.GstPad:recv_rtp_sink: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
/GstPipeline:pipeline0/GstRtpBin:rtpbin.GstGhostPad:recv_rtp_sink_0: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
/GstPipeline:pipeline0/GstRtpBin:rtpbin.GstGhostPad:recv_rtp_sink_0.GstProxyPad:proxypad1: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpSession:rtpsession0.GstPad:recv_rtp_src: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpSsrcDemux:rtpssrcdemux0.GstPad:sink: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpJitterBuffer:rtpjitterbuffer0.GstPad:src: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpJitterBuffer:rtpjitterbuffer0.GstPad:sink: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpPtDemux:rtpptdemux0.GstPad:sink: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)nal
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:sink: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
/GstPipeline:pipeline0/GstRtpBin:rtpbin.GstGhostPad:recv_rtp_src_0_2621786612_96.GstProxyPad:proxypad4: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)nal
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)nal
/GstPipeline:pipeline0/ffdec_h264:ffdec_h2640.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)nal
/GstPipeline:pipeline0/ffdec_h264:ffdec_h2640.GstPad:src: caps = video/x-raw-yuv, width=(int)352, height=(int)288, framerate=(fraction)25/1, format=(fourcc)I420, interlaced=(boolean)false
/GstPipeline:pipeline0/GstQueue:queue1.GstPad:sink: caps = video/x-raw-yuv, width=(int)352, height=(int)288, framerate=(fraction)25/1, format=(fourcc)I420, interlaced=(boolean)false
/GstPipeline:pipeline0/GstQueue:queue1.GstPad:src: caps = video/x-raw-yuv, width=(int)352, height=(int)288, framerate=(fraction)25/1, format=(fourcc)I420, interlaced=(boolean)false
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstXvImageSink:autovideosink0-actual-sink-xvimage.GstPad:sink: caps = video/x-raw-yuv, width=(int)352, height=(int)288, framerate=(fraction)25/1, format=(fourcc)I420, interlaced=(boolean)false
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0.GstGhostPad:sink: caps = video/x-raw-yuv, width=(int)352, height=(int)288, framerate=(fraction)25/1, format=(fourcc)I420, interlaced=(boolean)false
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-raw-yuv, width=(int)352, height=(int)288, framerate=(fraction)25/1, format=(fourcc)I420, interlaced=(boolean)false
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpSession:rtpsession0.GstPad:sync_src: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpSsrcDemux:rtpssrcdemux0.GstPad:rtcp_sink: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpSsrcDemux:rtpssrcdemux0.GstPad:rtcp_src_-1673180684: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpJitterBuffer:rtpjitterbuffer0.GstPad:sink_rtcp: caps = application/x-rtcp
^CCaught interrupt -- handling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 26282965149 ns.
Setting pipeline to READY ...
/GstPipeline:pipeline0/GstUDPSink:udpsink0.GstPad:sink: caps = NULL
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstXvImageSink:autovideosink0-actual-sink-xvimage.GstPad:sink: caps = NULL
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0.GstGhostPad:sink: caps = NULL
/GstPipeline:pipeline0/GstQueue:queue1.GstPad:src: caps = NULL
/GstPipeline:pipeline0/GstQueue:queue1.GstPad:sink: caps = NULL
/GstPipeline:pipeline0/ffdec_h264:ffdec_h2640.GstPad:src: caps = NULL
/GstPipeline:pipeline0/ffdec_h264:ffdec_h2640.GstPad:sink: caps = NULL
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:src: caps = NULL
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:sink: caps = NULL
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:src: caps = NULL
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:sink: caps = NULL
/GstPipeline:pipeline0/GstRtpBin:rtpbin.GstGhostPad:recv_rtp_src_0_2621786612_96: caps = NULL
/GstPipeline:pipeline0/GstRtpBin:rtpbin.GstGhostPad:send_rtcp_src_0: caps = NULL
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpPtDemux:rtpptdemux0.GstPad:src_96: caps = NULL
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpPtDemux:rtpptdemux0.GstPad:sink: caps = NULL
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpJitterBuffer:rtpjitterbuffer0.GstPad:sink_rtcp: caps = NULL
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpJitterBuffer:rtpjitterbuffer0.GstPad:sink: caps = NULL
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpJitterBuffer:rtpjitterbuffer0.GstPad:src: caps = NULL
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpSsrcDemux:rtpssrcdemux0.GstPad:rtcp_src_-1673180684: caps = NULL
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpSsrcDemux:rtpssrcdemux0.GstPad:src_-1673180684: caps = NULL
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpSsrcDemux:rtpssrcdemux0.GstPad:rtcp_sink: caps = NULL
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpSsrcDemux:rtpssrcdemux0.GstPad:sink: caps = NULL
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpSession:rtpsession0.GstPad:sync_src: caps = NULL
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpSession:rtpsession0.GstPad:send_rtcp_src: caps = NULL
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpSession:rtpsession0.GstPad:recv_rtp_src: caps = NULL
/GstPipeline:pipeline0/GstRtpBin:rtpbin/GstRtpSession:rtpsession0.GstPad:recv_rtp_sink: caps = NULL
/GstPipeline:pipeline0/GstRtpBin:rtpbin.GstGhostPad:recv_rtp_sink_0: caps = NULL
/GstPipeline:pipeline0/GstUDPSrc:udpsrc0.GstPad:src: caps = NULL
Setting pipeline to NULL ...
Freeing pipeline ...
%3CLINGO-SUB%20id%3D%22lingo-sub-1126136%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ertp%2Fudp%20streaming%20data%20transfer%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126136%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E1)%20rtp%3C%2FP%3E%3CP%20class%3D%22western%22%3E%3C%2FP%3E%3CP%20class%3D%22western%22%20style%3D%22margin-left%3A%20.25in%3B%22%3Elinux%20side%3A%3C%2FP%3E%3CP%20class%3D%22western%22%20style%3D%22margin-left%3A%20.25in%3B%22%3Egst-launch%20mfw_v4lsrc%20fps-n%3D30%20!%20vpuenc%20codec%3D6%20!%20queue%20!%20rtph264pay%20!%20udpsink%20host%3D192.168.0.105%20port%3D5000%20%E2%80%93v%3C%2FP%3E%3CP%20class%3D%22western%22%20style%3D%22margin-left%3A%20.25in%3B%22%3Epc%20side%3A%3C%2FP%3E%3CP%20class%3D%22western%22%20style%3D%22margin-left%3A%20.25in%3B%22%3Eopen%20the%20attached%20H264.sdp%20file%20using%20VLC.%20Then%20you%20can%20find%20the%20picture%20from%20camera%20on%20mx6%20board%2C%20pls%20don%E2%80%99t%20forget%20to%20load%20camera%20module%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2)%3C%2FP%3E%3CP%3EReceive%20Pipeline%20from%20Board%20to%20PC%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egst-launch%20-v%20gstrtpbin%20name%3Drtpbin%20udpsrc%20caps%3D'application%2Fx-rtp%2C%20media%3D(string)video%2C%20clock-rate%3D(int)90000%2C%20encoding-name%3D(string)H264%2C%20payload%3D96'%20port%3D5000%20!%20rtpbin.recv_rtp_sink_0%20rtpbin.%20!%20rtph264depay%20!%20queue%20!%20ffdec_h264%20!%20queue%20!%20autovideosink%20sync%3Dfalse%26nbsp%3B%20udpsrc%20port%3D5001%20!%20rtpbin.recv_rtcp_sink_0%20sync%3Dfalse%20rtpbin.send_rtcp_src_0%20!%20udpsink%20port%3D5005%20sync%3Dfalse%20async%3Dfalse%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EOutput%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESetting%20pipeline%20to%20PAUSED%20...%3C%2FP%3E%3CP%3EPipeline%20is%20live%20and%20does%20not%20need%20PREROLL%20...%3C%2FP%3E%3CP%3ESetting%20pipeline%20to%20PLAYING%20...%3C%2FP%3E%3CP%3ENew%20clock%3A%20GstSystemClock%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin.GstGhostPad%3Asend_rtcp_src_0%3A%20caps%20%3D%20application%2Fx-rtcp%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpSession%3Artpsession0.GstPad%3Asend_rtcp_src%3A%20caps%20%3D%20application%2Fx-rtcp%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstUDPSink%3Audpsink0.GstPad%3Asink%3A%20caps%20%3D%20application%2Fx-rtcp%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin.GstGhostPad%3Asend_rtcp_src_0.GstProxyPad%3Aproxypad2%3A%20caps%20%3D%20application%2Fx-rtcp%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpSession%3Artpsession0.GstPad%3Arecv_rtp_sink%3A%20caps%20%3D%20application%2Fx-rtp%2C%20media%3D(string)video%2C%20clock-rate%3D(int)90000%2C%20encoding-name%3D(string)H264%2C%20payload%3D(int)96%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin.GstGhostPad%3Arecv_rtp_sink_0%3A%20caps%20%3D%20application%2Fx-rtp%2C%20media%3D(string)video%2C%20clock-rate%3D(int)90000%2C%20encoding-name%3D(string)H264%2C%20payload%3D(int)96%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin.GstGhostPad%3Arecv_rtp_sink_0.GstProxyPad%3Aproxypad1%3A%20caps%20%3D%20application%2Fx-rtp%2C%20media%3D(string)video%2C%20clock-rate%3D(int)90000%2C%20encoding-name%3D(string)H264%2C%20payload%3D(int)96%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpSession%3Artpsession0.GstPad%3Arecv_rtp_src%3A%20caps%20%3D%20application%2Fx-rtp%2C%20media%3D(string)video%2C%20clock-rate%3D(int)90000%2C%20encoding-name%3D(string)H264%2C%20payload%3D(int)96%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpSsrcDemux%3Artpssrcdemux0.GstPad%3Asink%3A%20caps%20%3D%20application%2Fx-rtp%2C%20media%3D(string)video%2C%20clock-rate%3D(int)90000%2C%20encoding-name%3D(string)H264%2C%20payload%3D(int)96%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpJitterBuffer%3Artpjitterbuffer0.GstPad%3Asrc%3A%20caps%20%3D%20application%2Fx-rtp%2C%20media%3D(string)video%2C%20clock-rate%3D(int)90000%2C%20encoding-name%3D(string)H264%2C%20payload%3D(int)96%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpJitterBuffer%3Artpjitterbuffer0.GstPad%3Asink%3A%20caps%20%3D%20application%2Fx-rtp%2C%20media%3D(string)video%2C%20clock-rate%3D(int)90000%2C%20encoding-name%3D(string)H264%2C%20payload%3D(int)96%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpPtDemux%3Artpptdemux0.GstPad%3Asink%3A%20caps%20%3D%20application%2Fx-rtp%2C%20media%3D(string)video%2C%20clock-rate%3D(int)90000%2C%20encoding-name%3D(string)H264%2C%20payload%3D(int)96%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpH264Depay%3Artph264depay0.GstPad%3Asrc%3A%20caps%20%3D%20video%2Fx-h264%2C%20stream-format%3D(string)byte-stream%2C%20alignment%3D(string)nal%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpH264Depay%3Artph264depay0.GstPad%3Asink%3A%20caps%20%3D%20application%2Fx-rtp%2C%20media%3D(string)video%2C%20clock-rate%3D(int)90000%2C%20encoding-name%3D(string)H264%2C%20payload%3D(int)96%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin.GstGhostPad%3Arecv_rtp_src_0_2621786612_96.GstProxyPad%3Aproxypad4%3A%20caps%20%3D%20application%2Fx-rtp%2C%20media%3D(string)video%2C%20clock-rate%3D(int)90000%2C%20encoding-name%3D(string)H264%2C%20payload%3D(int)96%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstQueue%3Aqueue0.GstPad%3Asink%3A%20caps%20%3D%20video%2Fx-h264%2C%20stream-format%3D(string)byte-stream%2C%20alignment%3D(string)nal%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstQueue%3Aqueue0.GstPad%3Asrc%3A%20caps%20%3D%20video%2Fx-h264%2C%20stream-format%3D(string)byte-stream%2C%20alignment%3D(string)nal%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2Fffdec_h264%3Affdec_h2640.GstPad%3Asink%3A%20caps%20%3D%20video%2Fx-h264%2C%20stream-format%3D(string)byte-stream%2C%20alignment%3D(string)nal%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2Fffdec_h264%3Affdec_h2640.GstPad%3Asrc%3A%20caps%20%3D%20video%2Fx-raw-yuv%2C%20width%3D(int)352%2C%20height%3D(int)288%2C%20framerate%3D(fraction)25%2F1%2C%20format%3D(fourcc)I420%2C%20interlaced%3D(boolean)false%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstQueue%3Aqueue1.GstPad%3Asink%3A%20caps%20%3D%20video%2Fx-raw-yuv%2C%20width%3D(int)352%2C%20height%3D(int)288%2C%20framerate%3D(fraction)25%2F1%2C%20format%3D(fourcc)I420%2C%20interlaced%3D(boolean)false%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstQueue%3Aqueue1.GstPad%3Asrc%3A%20caps%20%3D%20video%2Fx-raw-yuv%2C%20width%3D(int)352%2C%20height%3D(int)288%2C%20framerate%3D(fraction)25%2F1%2C%20format%3D(fourcc)I420%2C%20interlaced%3D(boolean)false%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstAutoVideoSink%3Aautovideosink0%2FGstXvImageSink%3Aautovideosink0-actual-sink-xvimage.GstPad%3Asink%3A%20caps%20%3D%20video%2Fx-raw-yuv%2C%20width%3D(int)352%2C%20height%3D(int)288%2C%20framerate%3D(fraction)25%2F1%2C%20format%3D(fourcc)I420%2C%20interlaced%3D(boolean)false%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstAutoVideoSink%3Aautovideosink0.GstGhostPad%3Asink%3A%20caps%20%3D%20video%2Fx-raw-yuv%2C%20width%3D(int)352%2C%20height%3D(int)288%2C%20framerate%3D(fraction)25%2F1%2C%20format%3D(fourcc)I420%2C%20interlaced%3D(boolean)false%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstAutoVideoSink%3Aautovideosink0.GstGhostPad%3Asink.GstProxyPad%3Aproxypad0%3A%20caps%20%3D%20video%2Fx-raw-yuv%2C%20width%3D(int)352%2C%20height%3D(int)288%2C%20framerate%3D(fraction)25%2F1%2C%20format%3D(fourcc)I420%2C%20interlaced%3D(boolean)false%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpSession%3Artpsession0.GstPad%3Async_src%3A%20caps%20%3D%20application%2Fx-rtcp%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpSsrcDemux%3Artpssrcdemux0.GstPad%3Artcp_sink%3A%20caps%20%3D%20application%2Fx-rtcp%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpSsrcDemux%3Artpssrcdemux0.GstPad%3Artcp_src_-1673180684%3A%20caps%20%3D%20application%2Fx-rtcp%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpJitterBuffer%3Artpjitterbuffer0.GstPad%3Asink_rtcp%3A%20caps%20%3D%20application%2Fx-rtcp%3C%2FP%3E%3CP%3E%5ECCaught%20interrupt%20--%20handling%20interrupt.%3C%2FP%3E%3CP%3EInterrupt%3A%20Stopping%20pipeline%20...%3C%2FP%3E%3CP%3EExecution%20ended%20after%2026282965149%20ns.%3C%2FP%3E%3CP%3ESetting%20pipeline%20to%20PAUSED%20...%3C%2FP%3E%3CP%3ESetting%20pipeline%20to%20READY%20...%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstUDPSink%3Audpsink0.GstPad%3Asink%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstAutoVideoSink%3Aautovideosink0%2FGstXvImageSink%3Aautovideosink0-actual-sink-xvimage.GstPad%3Asink%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstAutoVideoSink%3Aautovideosink0.GstGhostPad%3Asink%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstQueue%3Aqueue1.GstPad%3Asrc%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstQueue%3Aqueue1.GstPad%3Asink%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2Fffdec_h264%3Affdec_h2640.GstPad%3Asrc%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2Fffdec_h264%3Affdec_h2640.GstPad%3Asink%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstQueue%3Aqueue0.GstPad%3Asrc%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstQueue%3Aqueue0.GstPad%3Asink%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpH264Depay%3Artph264depay0.GstPad%3Asrc%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpH264Depay%3Artph264depay0.GstPad%3Asink%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin.GstGhostPad%3Arecv_rtp_src_0_2621786612_96%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin.GstGhostPad%3Asend_rtcp_src_0%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpPtDemux%3Artpptdemux0.GstPad%3Asrc_96%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpPtDemux%3Artpptdemux0.GstPad%3Asink%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpJitterBuffer%3Artpjitterbuffer0.GstPad%3Asink_rtcp%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpJitterBuffer%3Artpjitterbuffer0.GstPad%3Asink%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpJitterBuffer%3Artpjitterbuffer0.GstPad%3Asrc%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpSsrcDemux%3Artpssrcdemux0.GstPad%3Artcp_src_-1673180684%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpSsrcDemux%3Artpssrcdemux0.GstPad%3Asrc_-1673180684%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpSsrcDemux%3Artpssrcdemux0.GstPad%3Artcp_sink%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpSsrcDemux%3Artpssrcdemux0.GstPad%3Asink%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpSession%3Artpsession0.GstPad%3Async_src%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpSession%3Artpsession0.GstPad%3Asend_rtcp_src%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpSession%3Artpsession0.GstPad%3Arecv_rtp_src%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin%2FGstRtpSession%3Artpsession0.GstPad%3Arecv_rtp_sink%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstRtpBin%3Artpbin.GstGhostPad%3Arecv_rtp_sink_0%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3E%2FGstPipeline%3Apipeline0%2FGstUDPSrc%3Audpsrc0.GstPad%3Asrc%3A%20caps%20%3D%20NULL%3C%2FP%3E%3CP%3ESetting%20pipeline%20to%20NULL%20...%3C%2FP%3E%3CP%3EFreeing%20pipeline%20...%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1126136%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎09-28-2015 03:00 AM
Updated by:
