i.MX27 ADS Board Video GST Video Streaming
Video Streaming over Ethernet
This section shows how to stream a video over Ethernet using UDP and RTP. Be sure to have the newest gst-plugin-good installed to ensure the best streaming quality.
Define the environment variable HOST with the ip address of the receiver machine (that one that will show the video).
$ export HOST=XX.XX.XX.XX
Do you know how to get caps? i.MX 27 Video GST Caps
H264 (MX->PC)
in i.MX27:
gst-launch-0.10 -v mfw_v4lsrc capture-width=640 capture-height=480 ! mfw_vpuencoder width=640 height=480  /
    codec-type=std_avc ! rtph264pay ! udpsink host=$HOST port=5000
in PC:
gst-launch-0.10 -v --gst-debug=2 udpsrc port=5000 /
  caps ="application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, /
  profile-level-id=(string)42001e, sprop-parameter-sets=(string)Z0IAHqaAoD2Q, payload=(int)96, /
  ssrc=(guint)3296222373, clock-base=(guint)2921390826, seqnum-base=(guint)35161" ! /
  rtph264depay  ! ffdec_h264 ! autovideosink
MPEG4 (MX->PC)
in i.MX27
gst-launch-0.10 -v mfw_v4lsrc capture-width=352 capture-height=288 ! mfw_vpuencoder width=352 height=255 bitrate=64 codec-type=std_mpeg4 ! rtpmp4vpay send-config=true /
! udpsink host=10.29.244.32 port=5000
Set send-config to true to send configuration with the video. Ensures better deconding
PC
gst-launch-0.10 -v --gst-debug=2 udpsrc port=5000 caps ="application/x-rtp, media=(string)video, clock-rate=(int)90000, /
encoding-name=(string)MP4V-ES, profile-level-id=(string)2, config=(string)000001b002000001b59113000001000000012000c888800f50b042414103, /
payload=(int)96, ssrc=(guint)4006671474, clock-base=(guint)3714140954, seqnum-base=(guint)29742" /
! rtpmp4vdepay ! ffdec_mpeg4 ! autovideosink
MPEG4 (MX->MX)
Sender
gst-launch-0.10 -v mfw_v4lsrc capture-width=640 capture-height=480 ! mfw_vpuencoder width=640 height=480  codec-type=std_mpeg4 ! rtpmp4vpay send-config=true ! udpsink host=$HOST port=5000
Receiver
gst-launch-0.10 -v udpsrc port=5000 caps= "application/x-rtp, media=(string)video, clock-rate=(int)90000, /
encoding-name=(string)MP4V-ES, profile-level-id=(string)4, config=(string)000001b004000001b59113000001000000012000c888800f514043c14103, /
payload=(int)96, ssrc=(guint)907905085, clock-base=(guint)2029414707, seqnum-base=(guint)22207" ! rtpmp4vdepay ! /
mfw_vpudecoder codec-type= std_mpeg4 min_latency=true ! mfw_v4lsink sync=false
  Setting min_latency true gives the better latency for the streaming
H264 (MX->MX)
Sender
gst-launch-0.10 -v mfw_v4lsrc capture-width=640 capture-height=480 ! mfw_vpuencoder width=640 height=480  codec-type=std_avc ! rtph264pay ! udpsink host=10.29.240.51 port=5000
Receiver
gst-launch-0.10 -v udpsrc port=5000 caps="application/x-rtp, media=(string)video, clock-rate=(int)90000" ! rtph264depay ! mfw_vpudecodr codec-type=std_avc ! mfw_v4lsink sync=false
标记 (2)
评论
I am looking to go to the i.mx6 processor from TI processors.  Could you tell me what kind of latency you are experiencing on your MX board with decoding? I am trying to get an idea of what I might expect from the gstreamer elements provided by Freescale.
Tim
%3CLINGO-SUB%20id%3D%22lingo-sub-1102886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX27%20ADS%20%E5%BC%80%E5%8F%91%E6%9D%BF%E8%A7%86%E9%A2%91%20GST%20%E8%A7%86%E9%A2%91%E6%B5%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-380552499%22%20id%3D%22toc-hId-380552499%22%20id%3D%22toc-hId-1304185784%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%E4%BB%A5%E5%A4%AA%E7%BD%91%E8%A7%86%E9%A2%91%E6%B5%81%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3CSPAN%20class%3D%22mw-headline%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%9C%AC%E8%8A%82%E4%BB%8B%E7%BB%8D%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20UDP%20%E5%92%8C%20RTP%20%E9%80%9A%E8%BF%87%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%BC%A0%E8%BE%93%E8%A7%86%E9%A2%91%E3%80%82%E8%AF%B7%E5%8A%A1%E5%BF%85%E5%AE%89%E8%A3%85%E6%9C%80%E6%96%B0%E7%9A%84%20gst-plugin-good%20%E4%BB%A5%E7%A1%AE%E4%BF%9D%E6%9C%80%E4%BD%B3%E6%B5%81%E5%AA%92%E4%BD%93%E8%B4%A8%E9%87%8F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E6%8E%A5%E6%94%B6%E6%9C%BA%E5%99%A8%EF%BC%88%E5%B0%86%E6%98%BE%E7%A4%BA%E8%A7%86%E9%A2%91%E7%9A%84%E6%9C%BA%E5%99%A8%EF%BC%89%E7%9A%84%20IP%20%E5%9C%B0%E5%9D%80%E5%AE%9A%E4%B9%89%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%20HOST%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%24%20%E5%AF%BC%E5%87%BA%20HOST%3DXX.XX.XX.XX%20%3C%2FPRE%3E%3CP%3E%E4%BD%A0%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E8%8E%B7%E5%BE%97%E5%B8%BD%E5%AD%90%E5%90%97%EF%BC%9F%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-1560%22%20target%3D%22_blank%22%3Ei.MX%2027%20%E8%A7%86%E9%A2%91%20GST%20%E7%94%B5%E5%AE%B9%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1071113973%22%20id%3D%22toc-hId-1071113973%22%20id%3D%22toc-hId-1994747258%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EH264%EF%BC%88MX-%26gt%3BPC%EF%BC%89%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%3CSPAN%20class%3D%22mw-headline%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%9C%A8i.MX27%E4%B8%AD%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Egst-launch-0.10-v%20mfw_v4lsrc%E6%8D%95%E8%8E%B7%E5%AE%BD%E5%BA%A6%3D640%E6%8D%95%E8%8E%B7%E9%AB%98%E5%BA%A6%3D480%EF%BC%81mfw_vpuencoder%E5%AE%BD%E5%BA%A6%3D640%E9%AB%98%E5%BA%A6%3D480%2F%0A%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E7%B1%BB%E5%9E%8B%3Dstd_avc%EF%BC%81rtph264%E6%94%AF%E4%BB%98%EF%BC%81udpsink%20%E4%B8%BB%E6%9C%BA%3D%24HOST%20%E7%AB%AF%E5%8F%A3%3D5000%0A%3C%2FPRE%3E%3CP%3E%E5%9C%A8PC%E4%B8%AD%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Egst-launch-0.10%20-v%20--gst-debug%3D2%20udpsrc%20%E7%AB%AF%E5%8F%A3%3D5000%20%2F%0A%20caps%3D%22application%2Fx-rtp%EF%BC%8Cmedia%3D(string)video%EF%BC%8Cclock-rate%3D(int)90000%EF%BC%8Cencoding-name%3D(string)H264%EF%BC%8C%2F%0A%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E7%BA%A7%E5%88%AB%20ID%20%3D%20%EF%BC%88%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%8942001e%EF%BC%8Csprop%20%E5%8F%82%E6%95%B0%E9%9B%86%20%3D%20%EF%BC%88%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%89Z0IAHqaAoD2Q%EF%BC%8C%E6%9C%89%E6%95%88%E8%BD%BD%E8%8D%B7%20%3D%20%EF%BC%88%E6%95%B4%E6%95%B0%EF%BC%8996%EF%BC%8C%2F%0A%20ssrc%3D(guint)3296222373%EF%BC%8C%E6%97%B6%E9%92%9F%E5%9F%BA%E6%95%B0%3D(guint)2921390826%EF%BC%8Cseqnum%E5%9F%BA%E6%95%B0%3D(guint)35161%E2%80%9D%EF%BC%81%2F%0A%20rtph264depay%EF%BC%81ffdec_h264%EF%BC%81%E8%87%AA%E5%8A%A8%E8%A7%86%E9%A2%91%E6%8E%A5%E6%94%B6%E5%99%A8%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--736340490%22%20id%3D%22toc-hId--736340490%22%20id%3D%22toc-hId-187292795%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EMPEG4%20(MX-%26gt%3BPC)%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%3CSPAN%20class%3D%22mw-headline%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%9C%A8i.MX27%E4%B8%AD%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Egst-launch-0.10-v%20mfw_v4lsrc%E6%8D%95%E8%8E%B7%E5%AE%BD%E5%BA%A6%3D352%E6%8D%95%E8%8E%B7%E9%AB%98%E5%BA%A6%3D288%EF%BC%81mfw_vpuencoder%20%E5%AE%BD%E5%BA%A6%3D352%20%E9%AB%98%E5%BA%A6%3D255%20%E6%AF%94%E7%89%B9%E7%8E%87%3D64%20%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E7%B1%BB%E5%9E%8B%3Dstd_mpeg4%EF%BC%81rtpmp4vpay%20%E5%8F%91%E9%80%81%E9%85%8D%E7%BD%AE%3Dtrue%20%2F%0A%20%EF%BC%81udpsink%20%E4%B8%BB%E6%9C%BA%3D10.29.244.32%20%E7%AB%AF%E5%8F%A3%3D5000%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CDIV%20style%3D%22background-color%3A%20%23ddffdd%3B%20padding-left%3A%2030px%3B%20width%3A%2060%25%3B%20margin-left%3A%2020%25%3B%22%3E%3CP%20class%3D%22tip%22%3E%E5%B0%86%20send-config%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%20true%20%E4%BB%A5%E9%9A%8F%E8%A7%86%E9%A2%91%E5%8F%91%E9%80%81%E9%85%8D%E7%BD%AE%E3%80%82%E7%A1%AE%E4%BF%9D%E6%9B%B4%E5%A5%BD%E7%9A%84%E8%A7%A3%E7%A0%81%3C%2FP%3E%3C%2FDIV%3E%3CP%3E%3C%2FP%3E%3CP%3EPC%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Egst-launch-0.10%20-v%20--gst-debug%3D2%20udpsrc%20port%3D5000%20caps%3D%22application%2Fx-rtp%2C%20media%3D(string)video%2C%20clock-rate%3D(int)90000%2C%20%2F%0A%E7%BC%96%E7%A0%81%E5%90%8D%E7%A7%B0%3D%EF%BC%88%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%89MP4V-ES%EF%BC%8C%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E7%BA%A7%E5%88%ABID%3D%EF%BC%88%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%892%EF%BC%8C%E9%85%8D%E7%BD%AE%3D%EF%BC%88%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%89000001b002000001b59113000001000000012000c888800f50b042414103%EF%BC%8C%2F%0A%E6%9C%89%E6%95%88%E8%BD%BD%E8%8D%B7%3D%EF%BC%88int%EF%BC%8996%EF%BC%8Cssrc%3D%EF%BC%88guint%EF%BC%894006671474%EF%BC%8C%E6%97%B6%E9%92%9F%E5%9F%BA%E6%95%B0%3D%EF%BC%88guint%EF%BC%893714140954%EF%BC%8Cseqnum-base%3D%EF%BC%88guint%EF%BC%8929742%E2%80%9C%2F%0A%20%EF%BC%81rtpmp4vdepay%EF%BC%81ffdec_mpeg4%20%EF%BC%81%E8%87%AA%E5%8A%A8%E8%A7%86%E9%A2%91%E6%8E%A5%E6%94%B6%E5%99%A8%0A%3C%2FPRE%3E%3CH2%20id%3D%22toc-hId-1751172343%22%20id%3D%22toc-hId-1751172343%22%20id%3D%22toc-hId--1620161668%22%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId--56282120%22%20id%3D%22toc-hId--56282120%22%20id%3D%22toc-hId-867351165%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EMPEG4%EF%BC%88MX-%26gt%3BMX%EF%BC%89%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%3CSPAN%20class%3D%22mw-headline%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ESender%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Egst-launch-0.10-v%20mfw_v4lsrc%E6%8D%95%E8%8E%B7%E5%AE%BD%E5%BA%A6%3D640%E6%8D%95%E8%8E%B7%E9%AB%98%E5%BA%A6%3D480%EF%BC%81mfw_vpuencoder%E5%AE%BD%E5%BA%A6%3D640%E9%AB%98%E5%BA%A6%3D480%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E7%B1%BB%E5%9E%8B%3Dstd_mpeg4%EF%BC%81rtpmp4vpay%20%E5%8F%91%E9%80%81%E9%85%8D%E7%BD%AE%3Dtrue%EF%BC%81udpsink%20%E4%B8%BB%E6%9C%BA%3D%24HOST%20%E7%AB%AF%E5%8F%A3%3D5000%20%3C%2FPRE%3E%3CP%3E%E6%8E%A5%E6%94%B6%E5%99%A8%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Egst-launch-0.10%20-v%20udpsrc%20%E7%AB%AF%E5%8F%A3%3D5000%20caps%3D%E2%80%9C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2Fx-rtp%EF%BC%8C%E5%AA%92%E4%BD%93%3D%EF%BC%88%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%89%E8%A7%86%E9%A2%91%EF%BC%8C%E6%97%B6%E9%92%9F%E9%80%9F%E7%8E%87%3D%EF%BC%88int%EF%BC%8990000%EF%BC%8C%2F%0A%E7%BC%96%E7%A0%81%E5%90%8D%E7%A7%B0%3D%EF%BC%88%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%89MP4V-ES%EF%BC%8C%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E7%BA%A7%E5%88%ABID%3D%EF%BC%88%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%894%EF%BC%8C%E9%85%8D%E7%BD%AE%3D%EF%BC%88%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%89000001b004000001b59113000001000000012000c888800f514043c14103%EF%BC%8C%2F%0A%E6%9C%89%E6%95%88%E8%BD%BD%E8%8D%B7%3D%EF%BC%88int%EF%BC%8996%EF%BC%8Cssrc%3D%EF%BC%88guint%EF%BC%89907905085%EF%BC%8C%E6%97%B6%E9%92%9F%E5%9F%BA%E6%95%B0%3D%EF%BC%88guint%EF%BC%892029414707%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%E5%9F%BA%E6%95%B0%3D%EF%BC%88guint%EF%BC%8922207%E2%80%9D%EF%BC%81rtpmp4vdepay%EF%BC%81%2F%0A%20mfw_vpudecoder%20%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E7%B1%BB%E5%9E%8B%3Dstd_mpeg4%20min_latency%3Dtrue%EF%BC%81mfw_v4lsink%20%E5%90%8C%E6%AD%A5%3Dfalse%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CDIV%20style%3D%22background-color%3A%20%23ddffdd%3B%20padding-left%3A%2030px%3B%20width%3A%2060%25%3B%20margin-left%3A%2020%25%3B%22%3E%3CP%20class%3D%22tip%22%3E%E5%B0%86%20min_latency%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%20true%20%E5%8F%AF%E4%BB%A5%E4%B8%BA%E6%B5%81%E5%AA%92%E4%BD%93%E6%8F%90%E4%BE%9B%E6%9B%B4%E5%A5%BD%E7%9A%84%E5%BB%B6%E8%BF%9F%3C%2FP%3E%3C%2FDIV%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1863736583%22%20id%3D%22toc-hId--1863736583%22%20id%3D%22toc-hId--940103298%22%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId-623776250%22%20id%3D%22toc-hId-623776250%22%20id%3D%22toc-hId-1547409535%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EH264%20(MX-%26gt%3BMX)%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3ESender%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Egst-launch-0.10-v%20mfw_v4lsrc%E6%8D%95%E8%8E%B7%E5%AE%BD%E5%BA%A6%3D640%E6%8D%95%E8%8E%B7%E9%AB%98%E5%BA%A6%3D480%EF%BC%81mfw_vpuencoder%E5%AE%BD%E5%BA%A6%3D640%E9%AB%98%E5%BA%A6%3D480%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E7%B1%BB%E5%9E%8B%3Dstd_avc%EF%BC%81rtph264%E6%94%AF%E4%BB%98%EF%BC%81udpsink%20%E4%B8%BB%E6%9C%BA%3D10.29.240.51%20%E7%AB%AF%E5%8F%A3%3D5000%20%3C%2FPRE%3E%3CP%3E%E6%8E%A5%E6%94%B6%E5%99%A8%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Egst-launch-0.10%20-v%20udpsrc%20%E7%AB%AF%E5%8F%A3%3D5000%20caps%3D%22application%2Fx-rtp%EF%BC%8Cmedia%3D(string)video%EF%BC%8Cclock-rate%3D(int)90000%22%EF%BC%81rtph264depay%EF%BC%81mfw_vpudecodr%20%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E7%B1%BB%E5%9E%8B%3Dstd_avc%EF%BC%81mfw_v4lsink%20%E5%90%8C%E6%AD%A5%3Dfalse%3C%2FPRE%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1102886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX2x%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Ai.MX27%20ADS%20%E6%9D%BF%E8%A7%86%E9%A2%91%20GST%20%E8%A7%86%E9%A2%91%E6%B5%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%AF%BB%E6%89%BE%20TI%20%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%AD%E7%9A%84%20i.mx6%20%E5%A4%84%E7%90%86%E5%99%A8%E3%80%82%E6%82%A8%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E6%82%A8%E7%9A%84%20MX%20%E6%9D%BF%E5%9C%A8%E8%A7%A3%E7%A0%81%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E4%BB%80%E4%B9%88%E6%A0%B7%E7%9A%84%E5%BB%B6%E8%BF%9F%E5%90%97%EF%BC%9F%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BA%86%E8%A7%A3%E6%88%91%E5%AF%B9%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E6%8F%90%E4%BE%9B%E7%9A%84%20gstreamer%20%E5%85%83%E7%B4%A0%E7%9A%84%E6%9C%9F%E6%9C%9B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETim%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-10-2020 01:47 AM
更新人:
