i.MX Create NFS Server and Export USB Drive: Yocto Project Distribution
Overview
This document describes the steps for configuring a NFS Server running on an i.MX Application Processor - in this case the evaluation board i.MX28 EVK. Once the NFS server is running, an Ubuntu 12.04 Linux host is then configured to NFS mount the i.MX28EVK exported directory. The Ethernet interface is used for the connection transport.
A block diagram of the connection setup is shown below: An Ethernet switch provided the Ethernet connection between the Linux Host and the i.MX28EVK. A thumb drive was connected to the USB port on the i.MX28EVK which was used for the exported directory.
i.MX28EVK Setup
Build Yocto Project image
Use core-image-minimal and add packages to conf/local.conf to support NFS
MACHINE=imx28evk source setup-environment mx28-evk
echo "CORE_IMAGE_EXTRA_INSTALL += \"bash kernel-modules nfs-utils\" " >> conf/local.conf
bitbake core-image-minimal
When bitbake finishes the images are found in tmp/deploy/images/imx28evk
Create a SDCARD from the Linux Host
sudo dd if=/tmp/deploy/images/imx28evk/core-image-minimal-imx28evk.sdcard of=/dev/sdc bs=4M && sync
Boot i.MX28EVK
Insert the SDCARD into slot 0 on the bottom side of the i.MX28EVK and connect the serial console. Power-on and push the POWER button on the lower conner to turn on. The Login credentials are User Name: root      There is no password configured by default.
Create file system on USB
The USB drive had one partition which was formatted with vfat file system:
mkfs.vfat /dev/sdb1
Create Mount Point and Mount the USB device
mkdir /mnt/usb
mount /dev/sdb1 /mnt/usb
Create 250 MB File
dd if=/dev/zero of=/mnt/usb/file1.txt bs=512K count=500
Create Exports File
echo "/mnt/usb *(rw,sync,no_root_squash,no_subtree_check)" > /etc/exports
Restart NFS Server
/etc/init.d/nfsserver stop
/etc/init.d/nfsserver start
Ubuntu Linux Host Setup
Create Mount Directory
sudo mkdir /mnt/remote
Mount i.MX28EVK Exported Directory
sudo mount -t nfs 10.85.1.10:/mnt/usb /mnt/remote
Access the NFS mounted directory
ls /mnt/remote
%3CLINGO-SUB%20id%3D%22lingo-sub-1105526%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX%20%E5%88%9B%E5%BB%BA%20NFS%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%B9%B6%E5%AF%BC%E5%87%BA%20USB%20%E9%A9%B1%E5%8A%A8%E5%99%A8%EF%BC%9AYocto%20%E9%A1%B9%E7%9B%AE%E5%8F%91%E8%A1%8C%E7%89%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105526%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-Create-NFS-Server-and-Export-USB-Drive-Yocto-Project%2Fta-p%2F1105526%23toc-hId-380638803%22%20target%3D%22_blank%22%3EOverview%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-Create-NFS-Server-and-Export-USB-Drive-Yocto-Project%2Fta-p%2F1105526%23toc-hId--1426815660%22%20target%3D%22_blank%22%3Ei.MX28EVK%20Setup%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-Create-NFS-Server-and-Export-USB-Drive-Yocto-Project%2Fta-p%2F1105526%23toc-hId--736254186%22%20target%3D%22_blank%22%3E%E6%9E%84%E5%BB%BA%20Yocto%20Project%20%E6%98%A0%E5%83%8F%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-Create-NFS-Server-and-Export-USB-Drive-Yocto-Project%2Fta-p%2F1105526%23toc-hId-1751258647%22%20target%3D%22_blank%22%3E%E5%9C%A8%20Linux%20%E4%B8%BB%E6%9C%BA%E4%B8%8A%E5%88%9B%E5%BB%BA%20SDCARD%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-Create-NFS-Server-and-Export-USB-Drive-Yocto-Project%2Fta-p%2F1105526%23toc-hId--56195816%22%20target%3D%22_blank%22%3EBoot%20i.MX28EVK%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-Create-NFS-Server-and-Export-USB-Drive-Yocto-Project%2Fta-p%2F1105526%23toc-hId--1863650279%22%20target%3D%22_blank%22%3E%E5%9C%A8USB%E4%B8%8A%E5%88%9B%E5%BB%BA%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-Create-NFS-Server-and-Export-USB-Drive-Yocto-Project%2Fta-p%2F1105526%23toc-hId-623862554%22%20target%3D%22_blank%22%3E%E5%88%9B%E5%BB%BA%E6%8C%82%E8%BD%BD%E7%82%B9%E5%B9%B6%E6%8C%82%E8%BD%BD%20USB%20%E8%AE%BE%E5%A4%87%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-Create-NFS-Server-and-Export-USB-Drive-Yocto-Project%2Fta-p%2F1105526%23toc-hId--1183591909%22%20target%3D%22_blank%22%3E%E5%88%9B%E5%BB%BA%20250%20MB%20%E6%96%87%E4%BB%B6%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-Create-NFS-Server-and-Export-USB-Drive-Yocto-Project%2Fta-p%2F1105526%23toc-hId-1303920924%22%20target%3D%22_blank%22%3E%E5%88%9B%E5%BB%BA%E5%AF%BC%E5%87%BA%E6%96%87%E4%BB%B6%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-Create-NFS-Server-and-Export-USB-Drive-Yocto-Project%2Fta-p%2F1105526%23toc-hId--503533539%22%20target%3D%22_blank%22%3E%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8NFS%E6%9C%8D%E5%8A%A1%E5%99%A8%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-Create-NFS-Server-and-Export-USB-Drive-Yocto-Project%2Fta-p%2F1105526%23toc-hId--766300982%22%20target%3D%22_blank%22%3EUbuntu%20Linux%20%E4%B8%BB%E6%9C%BA%E8%AE%BE%E7%BD%AE%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-Create-NFS-Server-and-Export-USB-Drive-Yocto-Project%2Fta-p%2F1105526%23toc-hId-1850294570%22%20target%3D%22_blank%22%3E%E5%88%9B%E5%BB%BA%20Mount%20Directory%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-Create-NFS-Server-and-Export-USB-Drive-Yocto-Project%2Fta-p%2F1105526%23toc-hId-42840107%22%20target%3D%22_blank%22%3E%E6%8C%82%E8%BD%BD%20i.MX28EVK%20%E5%AF%BC%E5%87%BA%E7%9A%84%E7%9B%AE%E5%BD%95%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-Create-NFS-Server-and-Export-USB-Drive-Yocto-Project%2Fta-p%2F1105526%23toc-hId--1764614356%22%20target%3D%22_blank%22%3E%E8%AE%BF%E9%97%AE%20NFS%20%E6%8C%82%E8%BD%BD%E7%9A%84%E7%9B%AE%E5%BD%95%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3CH1%20id%3D%22toc-hId-380638803%22%20id%3D%22toc-hId-380638803%22%20id%3D%22toc-hId-1303117183%22%3EOverview%3C%2FH1%3E%3CP%3E%E6%9C%AC%E6%96%87%E6%A1%A3%E4%BB%8B%E7%BB%8D%E4%BA%86%E5%9C%A8%20i.MX%20%E5%BA%94%E7%94%A8%E5%A4%84%E7%90%86%E5%99%A8%EF%BC%88%E6%9C%AC%E7%94%A8%E4%BE%8B%E4%B8%AD%E4%B8%BA%E8%AF%84%E4%BC%B0%E6%9D%BF%20%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DMCIMX28EVKJ%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ei.MX28%20EVK%3C%2FA%3E%EF%BC%89%E4%B8%8A%E9%85%8D%E7%BD%AE%20NFS%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%9A%84%E6%AD%A5%E9%AA%A4%E3%80%82NFS%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%BF%90%E8%A1%8C%E5%90%8E%EF%BC%8C%E9%9C%80%E5%B0%86%E8%BF%90%E8%A1%8C%20Ubuntu%2012.04%20%E7%9A%84%20Linux%20%E4%B8%BB%E6%9C%BA%E9%85%8D%E7%BD%AE%E4%B8%BA%E9%80%9A%E8%BF%87%20NFS%20%E6%8C%82%E8%BD%BD%20i.MX28EVK%20%E5%AF%BC%E5%87%BA%E7%9A%84%E7%9B%AE%E5%BD%95%E3%80%82%E8%BF%9E%E6%8E%A5%E4%BC%A0%E8%BE%93%E4%BD%BF%E7%94%A8%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%8E%A5%E5%8F%A3%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%9E%E6%8E%A5%E8%AE%BE%E7%BD%AE%E7%9A%84%E6%A1%86%E5%9B%BE%E5%A6%82%E4%B8%8B%EF%BC%9A%E4%B8%80%E4%B8%AA%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%BA%A4%E6%8D%A2%E6%9C%BA%E6%8F%90%E4%BE%9B%E4%BA%86%20Linux%20%E4%B8%BB%E6%9C%BA%E4%B8%8E%20i.MX28EVK%20%E4%B9%8B%E9%97%B4%E7%9A%84%E4%BB%A5%E5%A4%AA%E7%BD%91%E8%BF%9E%E6%8E%A5%E3%80%82%E4%B8%80%E4%B8%AA%20U%20%E7%9B%98%E8%BF%9E%E6%8E%A5%E5%88%B0%20i.MX28EVK%20%E7%9A%84%20USB%20%E7%AB%AF%E5%8F%A3%EF%BC%8C%E8%AF%A5%20U%20%E7%9B%98%E7%94%A8%E4%BD%9C%E5%AF%BC%E5%87%BA%E7%9B%AE%E5%BD%95%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22imx28diag.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22imx28diag.png%22%20style%3D%22width%3A%20348px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F43115i6C85AFBCA1312956%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22imx28diag.png%22%20alt%3D%22imx28diag.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eimx28diag.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1426815660%22%20id%3D%22toc-hId--1426815660%22%20id%3D%22toc-hId--504337280%22%3Ei.MX28EVK%20Setup%3C%2FH1%3E%3CH2%20id%3D%22toc-hId--736254186%22%20id%3D%22toc-hId--736254186%22%20id%3D%22toc-hId-186224194%22%3E%E6%9E%84%E5%BB%BA%20Yocto%20Project%20%E6%98%A0%E5%83%8F%3C%2FH2%3E%3CP%3E%E4%BD%BF%E7%94%A8%20core-image-minimal%20%E5%B9%B6%E5%B0%86%E8%BD%AF%E4%BB%B6%E5%8C%85%E6%B7%BB%E5%8A%A0%E5%88%B0%20conf%2Flocal.conf%20%E4%BB%A5%E6%94%AF%E6%8C%81%20NFS%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20_jivemacro_uid_13987992452222252%20jive_macro_code%22%20jivemacro_uid%3D%22_13987992452222252%22%20modifiedtitle%3D%22true%22%3E%0A%3CP%3EMACHINE%3Dimx28evk%20source%20setup-environment%20mx28-evk%3C%2FP%3E%0A%3CP%3Eecho%20%22CORE_IMAGE_EXTRA_INSTALL%20%2B%3D%20%5C%22bash%20kernel-modules%20nfs-utils%5C%22%20%22%20%26gt%3B%26gt%3B%20conf%2Flocal.conf%3C%2FP%3E%0A%3CP%3Ebitbake%20core-image-minimal%3C%2FP%3E%0A%3C%2FPRE%3E%3CP%3E%E5%BD%93%20bitbake%20%E5%AE%8C%E6%88%90%E5%90%8E%EF%BC%8C%E9%95%9C%E5%83%8F%E5%8F%AF%E5%9C%A8%20tmp%2Fdeploy%2Fimages%2Fimx28evk%20%E7%9B%AE%E5%BD%95%E4%B8%AD%E6%89%BE%E5%88%B0%E3%80%82%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1751258647%22%20id%3D%22toc-hId-1751258647%22%20id%3D%22toc-hId--1621230269%22%3E%E5%9C%A8%20Linux%20%E4%B8%BB%E6%9C%BA%E4%B8%8A%E5%88%9B%E5%BB%BA%20SDCARD%3C%2FH2%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20_jivemacro_uid_13987992452189006%20jive_macro_code%22%20jivemacro_uid%3D%22_13987992452189006%22%3E%0A%3CP%3Esudo%20dd%20if%3D%2Ftmp%2Fdeploy%2Fimages%2Fimx28evk%2Fcore-image-minimal-imx28evk.sdcard%20of%3D%2Fdev%2Fsdc%20bs%3D4M%20%26amp%3B%26amp%3B%20sync%3C%2FP%3E%0A%0A%3C%2FPRE%3E%3CH2%20id%3D%22toc-hId--56195816%22%20id%3D%22toc-hId--56195816%22%20id%3D%22toc-hId-866282564%22%3EBoot%20i.MX28EVK%3C%2FH2%3E%3CP%3E%E5%B0%86SD%E5%8D%A1%E6%8F%92%E5%85%A5i.MX28EVK%E5%BA%95%E9%83%A8%E4%BE%A7%E9%9D%A2%E7%9A%84%E6%8F%92%E6%A7%BD0%EF%BC%8C%E5%B9%B6%E8%BF%9E%E6%8E%A5%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E3%80%82%E5%BC%80%E6%9C%BA%E5%90%8E%EF%BC%8C%E6%8C%89%E4%B8%8B%E4%BD%8D%E4%BA%8E%E4%B8%8B%E8%A7%92%E7%9A%84%20POWER%20%E6%8C%89%E9%92%AE%E4%BB%A5%E5%90%AF%E5%8A%A8%E3%80%82%E7%99%BB%E5%BD%95%E5%87%AD%E6%8D%AE%E4%B8%BA%E7%94%A8%E6%88%B7%E5%90%8D%EF%BC%9Aroot%EF%BC%8C%E9%BB%98%E8%AE%A4%E6%9C%AA%E8%AE%BE%E7%BD%AE%E5%AF%86%E7%A0%81%E3%80%82%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1863650279%22%20id%3D%22toc-hId--1863650279%22%20id%3D%22toc-hId--941171899%22%3E%E5%9C%A8USB%E4%B8%8A%E5%88%9B%E5%BB%BA%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3C%2FH2%3E%3CP%3E%E8%AF%A5USB%E9%A9%B1%E5%8A%A8%E5%99%A8%E6%9C%89%E4%B8%80%E4%B8%AA%E5%88%86%E5%8C%BA%EF%BC%8C%E6%A0%BC%E5%BC%8F%E5%8C%96%E4%B8%BAvfat%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%EF%BC%9A%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20jive_macro_code%20_jivemacro_uid_13987992452141487%22%20jivemacro_uid%3D%22_13987992452141487%22%20modifiedtitle%3D%22true%22%3E%0A%3CP%3Emkfs.vfat%20%2Fdev%2Fsdb1%3C%2FP%3E%0A%3C%2FPRE%3E%3CH2%20id%3D%22toc-hId-623862554%22%20id%3D%22toc-hId-623862554%22%20id%3D%22toc-hId-1546340934%22%3E%E5%88%9B%E5%BB%BA%E6%8C%82%E8%BD%BD%E7%82%B9%E5%B9%B6%E6%8C%82%E8%BD%BD%20USB%20%E8%AE%BE%E5%A4%87%3C%2FH2%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20jive_macro_code%20_jivemacro_uid_13987992452117334%22%20jivemacro_uid%3D%22_13987992452117334%22%20modifiedtitle%3D%22true%22%3E%0A%3CP%3Emkdir%20%2Fmnt%2Fusb%3C%2FP%3E%0A%3CP%3Emount%20%2Fdev%2Fsdb1%20%2Fmnt%2Fusb%3C%2FP%3E%0A%3C%2FPRE%3E%3CH2%20id%3D%22toc-hId--1183591909%22%20id%3D%22toc-hId--1183591909%22%20id%3D%22toc-hId--261113529%22%3E%E5%88%9B%E5%BB%BA%20250%20MB%20%E6%96%87%E4%BB%B6%3C%2FH2%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_13987992452071360%20jive_text_macro%20jive_macro_code%22%20jivemacro_uid%3D%22_13987992452071360%22%20modifiedtitle%3D%22true%22%3E%0A%3CP%3Edd%20if%3D%2Fdev%2Fzero%20of%3D%2Fmnt%2Fusb%2Ffile1.txt%20bs%3D512K%20count%3D500%3C%2FP%3E%0A%3C%2FPRE%3E%3CH2%20id%3D%22toc-hId-1303920924%22%20id%3D%22toc-hId-1303920924%22%20id%3D%22toc-hId--2068567992%22%3E%E5%88%9B%E5%BB%BA%E5%AF%BC%E5%87%BA%E6%96%87%E4%BB%B6%3C%2FH2%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20jive_macro_code%20_jivemacro_uid_13987992452034807%22%20jivemacro_uid%3D%22_13987992452034807%22%20modifiedtitle%3D%22true%22%3E%0A%3CP%3Eecho%20%22%2Fmnt%2Fusb%20*%EF%BC%88rw%E3%80%81sync%E3%80%81no_root_squash%E3%80%81no_subtree_check%EF%BC%89%22%20%26gt%3B%20%2Fetc%2Fexports%3C%2FP%3E%0A%3C%2FPRE%3E%3CH2%20id%3D%22toc-hId--503533539%22%20id%3D%22toc-hId--503533539%22%20id%3D%22toc-hId-418944841%22%3E%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8NFS%E6%9C%8D%E5%8A%A1%E5%99%A8%3C%2FH2%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20jive_macro_code%20_jivemacro_uid_13987992451952487%22%20jivemacro_uid%3D%22_13987992451952487%22%3E%0A%3CP%3E%2Fetc%2Finit.d%2Fnfsserver%20%E5%81%9C%E6%AD%A2%3C%2FP%3E%0A%3CP%3E%2Fetc%2Finit.d%2Fnfsserver%20%E5%BC%80%E5%A7%8B%3C%2FP%3E%0A%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--766300982%22%20id%3D%22toc-hId--766300982%22%20id%3D%22toc-hId-156177398%22%3EUbuntu%20Linux%20%E4%B8%BB%E6%9C%BA%E8%AE%BE%E7%BD%AE%3C%2FH1%3E%3CH2%20id%3D%22toc-hId-1850294570%22%20id%3D%22toc-hId-1850294570%22%20id%3D%22toc-hId--1522194346%22%3E%E5%88%9B%E5%BB%BA%20Mount%20Directory%3C%2FH2%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20jive_macro_code%20_jivemacro_uid_13988002106963062%22%20jivemacro_uid%3D%22_13988002106963062%22%20modifiedtitle%3D%22true%22%3E%0A%3CP%3Esudo%20mkdir%20%2Fmnt%2Fremote%3C%2FP%3E%0A%3C%2FPRE%3E%3CH2%20id%3D%22toc-hId-42840107%22%20id%3D%22toc-hId-42840107%22%20id%3D%22toc-hId-965318487%22%3E%E6%8C%82%E8%BD%BD%20i.MX28EVK%20%E5%AF%BC%E5%87%BA%E7%9A%84%E7%9B%AE%E5%BD%95%3C%2FH2%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20_jivemacro_uid_13988002661417971%20jive_macro_code%22%20jivemacro_uid%3D%22_13988002661417971%22%20modifiedtitle%3D%22true%22%3E%0A%3CP%3Esudo%20mount%20-t%20nfs%2010.85.1.10%3A%2Fmnt%2Fusb%20%2Fmnt%2Fremote%3C%2FP%3E%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1764614356%22%20id%3D%22toc-hId--1764614356%22%20id%3D%22toc-hId--842135976%22%3E%E8%AE%BF%E9%97%AE%20NFS%20%E6%8C%82%E8%BD%BD%E7%9A%84%E7%9B%AE%E5%BD%95%3C%2FH2%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_1398800796413998%20jive_text_macro%20jive_macro_code%22%20jivemacro_uid%3D%22_1398800796413998%22%20modifiedtitle%3D%22true%22%3E%0A%3CP%3Els%20%2Fmnt%2Fremote%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3C%2FPRE%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-10-2020 01:56 AM
更新人:
