enable Bluetooth for Android R13.4.1
Overview
As you know, R13.4.1 doesn't support Bluetooth. These attached patches enable Bluetooth for R13.4.1.
Before applying the patches for MX6 SabreSD, please rework SabreSD. Refer to How to enable BT on board imx6q_sabresd RevC.
Hardware
  • i.MX6Dual/Quad or i.MX6DualLite SabreSD board
Software
  • i.MX6DQ/MX6DL Android ICS R13.4 or R13.4.1 Release
Comments
I need to hard to do  it. if I use BC6888 instead of ar3002, how can I do
%3CLINGO-SUB%20id%3D%22lingo-sub-1126969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eenable%20Bluetooth%20for%20Android%20R13.4.1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH1%20id%3D%22toc-hId-382519607%22%20id%3D%22toc-hId-1297692361%22%3EOverview%3C%2FH1%3E%3CP%3EAs%20you%20know%2C%20R13.4.1%20doesn't%20support%20Bluetooth.%20These%20attached%20patches%20enable%20Bluetooth%20for%20R13.4.1.%3C%2FP%3E%3CP%3EBefore%20applying%20the%20patches%20for%20MX6%20SabreSD%2C%20please%20rework%20SabreSD.%20Refer%20to%20%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222004%22%20data-containertype%3D%2214%22%20data-objectid%3D%2294235%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94235%22%20target%3D%22_blank%22%3EHow%20to%20enable%20BT%20on%20board%20imx6q_sabresd%20RevC.%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1424934856%22%20id%3D%22toc-hId--509762102%22%3EHardware%3C%2FH1%3E%3CUL%3E%3CLI%3Ei.MX6Dual%2FQuad%20or%20i.MX6DualLite%20SabreSD%20board%3C%2FLI%3E%3C%2FUL%3E%3CH1%20id%3D%22toc-hId-1062577977%22%20id%3D%22toc-hId-1977750731%22%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId--744876486%22%20id%3D%22toc-hId-170296268%22%3ESoftware%3C%2FH1%3E%3CUL%3E%3CLI%3Ei.MX6DQ%2FMX6DL%20Android%20ICS%20R13.4%20or%20R13.4.1%20Release%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20enable%20Bluetooth%20for%20Android%20R13.4.1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20need%20to%20hard%20to%20do%26nbsp%3B%20it.%20if%20I%20use%20BC6888%20instead%20of%20ar3002%EF%BC%8C%20how%20can%20I%20do%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎08-05-2013 06:01 AM
Updated by:
