Video streaming using I.Mx6
Search instead for
Hi everyone,
Can I stream video at some different resolutions at the same time using I.Mx6?
Thank you.
Labels (3)
Comments
Hello,Generally it is possible - to stream video at different resolutions.
The following (schematic) GST pipeline may be used to get different resulutions :
  v4l2src->capsfilter (if needed)->tee->queue->resizer_1 (if needed)-> encoder _1 ->sink_1
                                                          ->queue->resizer_2->encoder _2 ->sink_2
Yuri
Version history
Revision #:
1 of 1
Last update:
‎10-04-2017 03:00 AM
Updated by:
