U-Boot Migration Example
1. INTRODUCTION:
     This document explains the general and basic steps to customize U-Boot for your own board. The board used in this document it is a working and stable board, the UDOO board (http://udoo.org).
2. REQUIREMENTS:
3. ADDING i.MX6 CUSTOM BOARD SUPPORT FOR U-BOOT.
    This section follows the steps found in Chapter 1 of the i.MX6 BSP Porting Guide of the Yocto documentation (L3.14.28) https://www.freescale.com/webapp/Download?colCode=L3.14.28_1.0.0_LINUX_DOCS&location=null&fpsp=1&WT_... .
  • Obtain U-Boot Source Code. After having installed Yocto project and generate a valid imx6 image, the U-Boot code should be located at <build directory>/tmp/work/<machine>-poky-linuxgnueabi/u-boot-imx/<version>/git.
  • Prepare the Code. Choose a board as reference, this board should be as similar as possible to your custom board.
    • Copy the board directory :
               $ cp -R board/freescale/mx6sabresd/ board/freescale/mx6_udoo
    • Copy the existing mx6sabresd.h configuration file as mx6_udoo.h
               $ cp include/configs/mx6sabresd.h include/configs/mx6_udoo.h
  • Create one entry in boards.cfg. Add a configuration entry in the boards.cfg file.
Active  arm  armv7  mx6  freescale  mx6_udoo mx6_udoo mx6_udoo:IMX_CONFIG=board/freescale/mx6_udoo/mx6dl_4x_mt41j128.cfg,MX6Q,DEFAULT_FDT_FILE="imx6q-udoo.dtb",DDR_MB=1024
  • Rename <board>.c file. Rename board/freescale/mx6sabresd/mx6sabresd.c   to   board/freescale/mx6_udoo/mx6_udoo.c
  • Modify Makefile. Change the line of COBJS to your custom board at  board/freescale/mx6_udoo/:
     obj-y  := mx6sabresd.o
  • Create a Shell script. Create a script to compile your new configuration. The script for this example is shown below and its name is build_u-boot.sh:
#!/bin/bash
export ARCH=arm
export CROSS_COMPILE=/opt/poky/1.7/sysroots/x86_64-pokysdk-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-
make distclean;
make mx6_udoo_config
make
  • Run the script to verify if the new configuration is correct.
     $./build_u-boot.sh
4. CUSTOMIZING BOARD CODE
  •      The fist part to customize is the DCD table. The DCD table contains configuration data for the DDR controller and memory. The DCD is read by the BootROM code in the iMX family and executed before copying the Uboot image to DDR. The DCD is built in the .cfg file pointed in the new entry we just added in the boards.cfg file (mx6dl_4x_mt41j128.cfg).
    Below you can find an example of the data that can be found in this file:
* Device Configuration Data (DCD)
* Each entry must have the format:
* Addr-type           Address        Value
* where:
*      Addr-type register length (1,2 or 4 bytes)
*      Address   absolute address of the register
*      value     value to be stored in the register
DATA 4, 0x020e0774, 0x000C0000
DATA 4, 0x020e0754, 0x00000000
DATA 4, 0x020e04ac, 0x00000030
DATA 4, 0x020e04b0, 0x00000030
DATA 4, 0x020e0464, 0x00000030
DATA 4, 0x020e0490, 0x00000030
DATA 4, 0x020e074c, 0x00000030
DATA 4, 0x020e0494, 0x00000030
DATA 4, 0x020e04a0, 0x00000000
The .cfg files used in this example were taken from an old U-Boot version (2009) non dtb capable. The used files are found in the attached .zip file.
  • The specific initialization code for each board is found in mx6<customer board>.c in board/freescale/mx6<customer board>.c  in this case board/freescale/mx6_udoo/mx6_udoo.c file. Below it is explained the needed changes to route the serial console to the correct UART module, disable an external watchdog, configure and initialize the Ethernet PHY, change the lvds clock and configure the correct USDHC module.
       U-Boot calls already defined functions from a function pointer array that takes care of the board initialization at different stages. For example the board_early_init_f() is called at an        early phase where we can disable the wdog and initialize the uart pins; board_init() and board_late_init() are called after board_early_init_f().
  • The UDOO board features an external watchdog that needs to be disabled with a GPIO, otherwise U-Boot resets after a few seconds:
         The WDOG pins need to be configured and in the mx6_udoo.c file a global struct configuration for those pins is declared, as well as macros for each pin
#define WDT_EN  IMX_GPIO_NR(5, 4)
#define WDT_TRG IMX_GPIO_NR(3, 19)
iomux_v3_cfg_t const wdog_pads[] = {
        MX6_PAD_EIM_A24__GPIO5_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL),
        MX6_PAD_EIM_D19__GPIO3_IO19,
static void setup_iomux_wdog(void)
        imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads));
        gpio_direction_output(WDT_TRG, 0);
        gpio_direction_output(WDT_EN, 1);
        gpio_direction_input(WDT_TRG);
This configuration needs to be called at some point of the board_early_init_f()
int board_early_init_f(void)
        setup_iomux_wdog();
        This way the board_early_init_f() calls the iomux for the external wdog and disables it.
  • The UART console is routed to UART2, EIM_D26/UART2_TXD and EIM_D27/UART2_RXD. A different structure is defined with the pin configuration for the UART2.
iomux_v3_cfg_t const uart2_pads[] = {
        MX6_PAD_EIM_D26__UART2_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL),
        MX6_PAD_EIM_D27__UART2_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL),
This configuration should be called at early stage too.
static void setup_iomux_uart(void)
        imx_iomux_v3_setup_multiple_pads(uart2_pads, ARRAY_SIZE(uart2_pads));
        setup_iomux_wdog();
        setup_iomux_uart();
Also the UART BASE register has to be defined as well as the console device. This is defined in the include/configs/mx6_udoo.h file.
#define CONFIG_MXC_UART_BASE   UART2_BASE
#define CONFIG_CONSOLE_DEV      "ttymxc1"
  • The UDOO board features only one micro SD slot to boot and U-Boot environment storage. It uses only 4 bits and it has to be configured too. In the include/configs/mx6_udoo.h file the USDHC module has to be defined and the MMC environment device.
#define CONFIG_SYS_FSL_USDHC_NUM   3
#define CONFIG_SYS_MMC_ENV_DEV       0     /* SDHC3 */
         The USDHC3 pin configuration has to be defined:
iomux_v3_cfg_t const usdhc3_pads[] = {
        MX6_PAD_SD3_CLK__SD3_CLK   | MUX_PAD_CTRL(USDHC_PAD_CTRL),
        MX6_PAD_SD3_CMD__SD3_CMD   | MUX_PAD_CTRL(USDHC_PAD_CTRL),
        MX6_PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
        MX6_PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
        MX6_PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
        MX6_PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
        MX6_PAD_NANDF_D0__GPIO2_IO00    | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */
struct fsl_esdhc_cfg usdhc_cfg[1] = {
        {USDHC3_BASE_ADDR, 0, 4},
This must be called and configured from the board_mmc_init() function:
int board_mmc_init(bd_t *bis)
        s32 status = 0;
        usdhc3_pads, ARRAY_SIZE(usdhc3_pads));
        usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK);
                status |= fsl_esdhc_initialize(bis, &usdhc_cfg[0]);
        return status;
  • The Ethernet PHY is configured in the board_eth_init() function. This function should initialize the pins for the external ethernet phy, mdio and phy configuration.  Just a piece of code is shown below:
iomux_v3_cfg_t const enet_pads1[] = {
        MX6_PAD_ENET_MDIO__ENET_MDIO            | MUX_PAD_CTRL(ENET_PAD_CTRL),
        MX6_PAD_ENET_MDC__ENET_MDC              | MUX_PAD_CTRL(ENET_PAD_CTRL),
        MX6_PAD_RGMII_TXC__RGMII_TXC       | MUX_PAD_CTRL(ENET_PAD_CTRL),
        MX6_PAD_RGMII_TD0__RGMII_TD0       | MUX_PAD_CTRL(ENET_PAD_CTRL),
        MX6_PAD_RGMII_TD1__RGMII_TD1       | MUX_PAD_CTRL(ENET_PAD_CTRL),
        MX6_PAD_RGMII_TD2__RGMII_TD2       | MUX_PAD_CTRL(ENET_PAD_CTRL),
        MX6_PAD_RGMII_TD3__RGMII_TD3       | MUX_PAD_CTRL(ENET_PAD_CTRL),
        MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL      | MUX_PAD_CTRL(ENET_PAD_CTRL),
        MX6_PAD_ENET_REF_CLK__ENET_TX_CLK       | MUX_PAD_CTRL(ENET_PAD_CTRL),
        MX6_PAD_RGMII_RXC__RGMII_RXC       | MUX_PAD_CTRL(ENET_PAD_CTRL),
        /* RGMII reset */
        MX6_PAD_EIM_D23__GPIO3_IO23              | MUX_PAD_CTRL(NO_PAD_CTRL),
        /* alimentazione ethernet*/
        MX6_PAD_EIM_EB3__GPIO2_IO31              | MUX_PAD_CTRL(NO_PAD_CTRL),
        /* pin 32 - 1 - (MODE0) all */
        MX6_PAD_RGMII_RD0__GPIO6_IO25            | MUX_PAD_CTRL(NO_PAD_CTRL),
        /* pin 31 - 1 - (MODE1) all */
        MX6_PAD_RGMII_RD1__GPIO6_IO27            | MUX_PAD_CTRL(NO_PAD_CTRL),
        /* pin 28 - 1 - (MODE2) all */
        MX6_PAD_RGMII_RD2__GPIO6_IO28            | MUX_PAD_CTRL(NO_PAD_CTRL),
        /* pin 27 - 1 - (MODE3) all */
        MX6_PAD_RGMII_RD3__GPIO6_IO29            | MUX_PAD_CTRL(NO_PAD_CTRL),
        /* pin 33 - 1 - (CLK125_EN) 125Mhz clockout enabled */
        MX6_PAD_RGMII_RX_CTL__GPIO6_IO24         | MUX_PAD_CTRL(NO_PAD_CTRL),
static iomux_v3_cfg_t const enet_pads2[] = {
        MX6_PAD_RGMII_RD0__RGMII_RD0       | MUX_PAD_CTRL(ENET_PAD_CTRL),
        MX6_PAD_RGMII_RD1__RGMII_RD1       | MUX_PAD_CTRL(ENET_PAD_CTRL),
        MX6_PAD_RGMII_RD2__RGMII_RD2       | MUX_PAD_CTRL(ENET_PAD_CTRL),
        MX6_PAD_RGMII_RD3__RGMII_RD3       | MUX_PAD_CTRL(ENET_PAD_CTRL),
        MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL      | MUX_PAD_CTRL(ENET_PAD_CTRL),
static void setup_iomux_enet(void)
        imx_iomux_v3_setup_multiple_pads(enet_pads1, ARRAY_SIZE(enet_pads1));
        udelay(20);
        gpio_direction_output(IMX_GPIO_NR(2, 31), 1); /* Power on enet */
        gpio_direction_output(IMX_GPIO_NR(3, 23), 0); /* assert PHY rst */
        gpio_direction_output(IMX_GPIO_NR(6, 24), 1);
        gpio_direction_output(IMX_GPIO_NR(6, 25), 1);
        gpio_direction_output(IMX_GPIO_NR(6, 27), 1);
        gpio_direction_output(IMX_GPIO_NR(6, 28), 1);
        gpio_direction_output(IMX_GPIO_NR(6, 29), 1);
        udelay(1000);
        gpio_set_value(IMX_GPIO_NR(3, 23), 1); /* deassert PHY rst */
        /* Need delay 100ms to exit from reset. */
        udelay(1000 * 100);
        gpio_free(IMX_GPIO_NR(6, 24));
        gpio_free(IMX_GPIO_NR(6, 25));
        gpio_free(IMX_GPIO_NR(6, 27));
        gpio_free(IMX_GPIO_NR(6, 28));
        gpio_free(IMX_GPIO_NR(6, 29));
        imx_iomux_v3_setup_multiple_pads(enet_pads2, ARRAY_SIZE(enet_pads2));
          Let's notice that the external PHY is not the same as the SABRESD AR8031. The UDOO features the MICREL KSZ9031 PHY. The latter needs to be defined and the former undefined in the include/configs/mx6_udoo.h file.
#undef  CONFIG_PHY_ATHEROS
#define CONFIG_PHY_MICREL
#define CONFIG_PHY_MICREL_KSZ9031
Besides the PHY address has to be changed.
#define CONFIG_FEC_MXC_PHYADDR  6
  • At this point, the serial console, SD card saving arguments and ethernet should be working. The last point is to configure the LVDS display. The LVDS display of the UDOO board is connected in the same port as the SABRE-SD board, but the operation frequency is different and it has to be modified to work at ~ 33.26MHz for the 7 inches LVDS display.
     The mx6_udoo.c file contains a setup_display function that configures the LDB module. This functions is called in the board_early_init_f(). With the current clock configuration is not possible to get  the 33.2MHz for the LVDS and a different clock source for the LDB module must be chosen. The backlight and lvds power signals must be on.
          The current configuration uses the mmdc_ch1 clock and to get closer to 33.26MHz the PLL2_PFD0 is chosen.
       gpio_direction_output(IMX_GPIO_NR(1, 2), 1); /* LVDS power On */
        gpio_direction_output(IMX_GPIO_NR(1, 4), 1); /* LVDS backlight On */
        imx_iomux_v3_setup_multiple_pads(di0_pads, ARRAY_SIZE(di0_pads));
        enable_ipu_clock();
        imx_setup_hdmi();
        /* Turn on4LDB0, LDB1, IPU,IPU DI0 clocks */
        reg = readl(&mxc_ccm->CCGR3);
        reg |=  MXC_CCM_CCGR3_LDB_DI0_MASK | MXC_CCM_CCGR3_LDB_DI1_MASK;
        writel(reg, &mxc_ccm->CCGR3);
        /* set LDB0, LDB1 clk select to 011/011 */
        reg = readl(&mxc_ccm->cs2cdr);
        reg &= ~(MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_MASK
                 | MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_MASK);
        reg |= (1 << MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_OFFSET)
              | (1 << MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_OFFSET);
        writel(reg, &mxc_ccm->cs2cdr);
With this changes you can compile the new U-Boot image with ./build_u-boot.sh and then just copy the uboot.imx file to your sd:
# sudo cp if=uboot.imx of=/dev/sdX bs=512 seek= 2 && sync
5. TESTING YOUR CHANGES
Inser the sd with the U-Boot image to micro sd slot and power up the board. You should get the U-Boot serial console like shown below.
In the console you can test the ethernet and phy configuration with the PING command:
I hope you find these basic steps useful for different boards.
タグ(1)
添付
コメント
Thank you for this valuable information.
Does the iomux in kernel (from device tree) shall override the iomux in u-boot ?
Ran
Can you give the solution for below screenshots
%3CLINGO-SUB%20id%3D%22lingo-sub-1105739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EU-Boot%20%E3%81%AE%E7%A7%BB%E8%A1%8C%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSTRONG%3E1.%E3%81%AF%E3%81%98%E3%82%81%E3%81%AB%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81U-Boot%20%E3%82%92%E7%8B%AC%E8%87%AA%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AB%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E6%89%8B%E9%A0%86%E3%81%A8%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%E5%8B%95%E4%BD%9C%E5%8F%AF%E8%83%BD%E3%81%A7%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%9F%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%82%E3%82%8BUDOO%E3%83%9C%E3%83%BC%E3%83%89(%3CA%20href%3D%22http%3A%2F%2Fudoo.org%2F%22%20title%3D%22http%3A%2F%2Fudoo.org%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fudoo.org%3C%2FA%3E)%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E2.%20%E5%BF%85%E8%A6%81%E6%9D%A1%E4%BB%B6%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3EYocto%20Project%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%80%8CFreescale%20Yocto%20Project%20User's%20Guide%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLI%3E%3CLI%3E%E3%83%A1%E3%82%BF%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%A6%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222004%22%20data-containertype%3D%2214%22%20data-content-finding%3D%22Community%22%20data-objectid%3D%2294849%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%22%20target%3D%22_blank%22%3EYocto%20%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%20-%20HOME%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2FDownload%3FcolCode%3DL3.14.28_1.0.0_iMX6QDLS_BUNDLE%26amp%3BappType%3Dlicense%26amp%3Blocation%3Dnull%26amp%3BParent_nodeId%3D1276810298241720831102%26amp%3BParent_pageType%3Dproduct%22%20title%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2FDownload%3FcolCode%3DL3.14.28_1.0.0_iMX6QDLS_BUNDLE%26amp%3BappType%3Dlicense%26amp%3Blocation%3Dnull%26amp%3BParent_nodeId%3D1276810298241720831102%26amp%3BParent_pageType%3Dproduct%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.freescale.com%2Fwebapp%2FDownload%3FcolCode%3DL3.14.28_1.0.0_iMX6QDLS_BUNDLE%26amp%3BappType%3Dlicense%26amp%3Blocation%3Dnull%26amp%3BParent_no%20%E3%81%8B%E3%82%89%3C%2FA%3E%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9FFSL%20BSP%E3%81%AEL3.14.28%E3%81%AEcore-image-minimal%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%26nbsp%3B%26nbsp%3B%20%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E3.%20U-BOOT%E7%94%A8%E3%81%AEI.MX6%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%80%82%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSTRONG%3E%E3%81%93%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81Yocto%20%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%20(L3.14.28)%20%E3%81%AE%20i.MX6%20BSP%20Porting%20Guide%20%E3%81%AE%E7%AC%AC%201%20%E7%AB%A0%20%3CA%20href%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2FDownload%3FcolCode%3DL3.14.28_1.0.0_LINUX_DOCS%26amp%3Blocation%3Dnull%26amp%3Bfpsp%3D1%26amp%3BWT_TYPE%3DSupporting%2520Information%26amp%3BWT_VENDOR%3DFREESCALE%26amp%3BWT_FILE_FORMAT%3Dgz%26amp%3BWT_ASSET%3DDocumentation%26amp%3BfileExt%3D.gz%26amp%3BParent_nodeId%3D1337637154535695831062%26amp%3BParent_pageType%3Dproduct%26amp%3BParent_nodeId%3D1337637154535695831062%26amp%3BParent_pageType%3Dproduct%22%20title%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2FDownload%3FcolCode%3DL3.14.28_1.0.0_LINUX_DOCS%26amp%3Blocation%3Dnull%26amp%3Bfpsp%3D1%26amp%3BWT_TYPE%3DSupporting%2520Information%26amp%3BWT_VENDOR%3DFREESCALE%26amp%3BWT_FILE_FORMAT%3Dgz%26amp%3BWT_ASSET%3DDocumentation%26amp%3BfileExt%3D.gz%26amp%3BParent_nodeId%3D1337637154535695831062%26amp%3BParent_pageType%3Dproduct%26amp%3BParent_nodeId%3D1337637154535695831062%26amp%3BParent_pageType%3Dproduct%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.freescale.com%2Fwebapp%2FDownload%3FcolCode%3DL3.14.28_1.0.0_LINUX_DOCS%26amp%3Blocation%3Dnull%26amp%3Bfpsp%3D1%26amp%3BWT_TYPE%3DSupporting%2520In...%3C%2FA%3E%20%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3EU-Boot%20%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%E3%80%82Yocto%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%80%81%E6%9C%89%E5%8A%B9%E3%81%AA%20imx6%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81U-Boot%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%20%3CBUILD%20directory%3D%22%22%3E%2Ftmp%2Fwork%2F%3CMACHINE%3E-poky-linuxgnueabi%2Fu-boot-imx%2F%3CVERSION%3E%2Fgit%20%E3%81%AB%E3%81%82%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FVERSION%3E%3C%2FMACHINE%3E%3C%2FBUILD%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%BA%96%E5%82%99%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSTRONG%3E%E5%8F%82%E7%85%A7%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A0%E3%81%91%E4%BC%BC%E3%81%A6%E3%81%84%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CUL%3E%3CLI%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%24%20cp%20-R%20%E3%83%9C%E3%83%BC%E3%83%89%2F%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%2Fmx6sabresd%2F%20%E3%83%9C%E3%83%BC%E3%83%89%2F%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%2Fmx6_udoo%3C%2FP%3E%3CUL%3E%3CUL%3E%3CLI%3E%E6%97%A2%E5%AD%98%E3%81%AEmx6sabresd.h%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20mx6_udoo.h%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3CP%3E%24%20cp%20include%2Fconfigs%2Fmx6sabresd.hinclude%2Fconfigs%2Fmx6_udoo.h%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3Eboards.cfg%20%E3%81%AB%201%20%E3%81%A4%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSTRONG%3Eboards.cfg%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3EActive%26nbsp%3B%20arm%26nbsp%3B%20armv7%26nbsp%3B%20mx6%26nbsp%3B%20freescale%26nbsp%3B%20mx6_udoo%20mx6_udoo%20mx6_udoo%3AIMX_CONFIG%3Dboard%2Ffreescale%2Fmx6_udoo%2Fmx6dl_4x_mt41j128.cfg%2CMX6Q%2CDEFAULT_FDT_FILE%3D%22imx6q-udoo.dtb%22%2CDDR_MB%3D1024%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%3CBOARD%3E.c%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%90%8D%E5%89%8D%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FBOARD%3E%3C%2FSTRONG%3Eboard%2Ffreescale%2Fmx6sabresd%2Fmx6sabresd.c%20%E3%81%AE%E5%90%8D%E5%89%8D%E3%82%92%20board%2Ffreescale%2Fmx6_udoo%2Fmx6_udoo.c%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3EMakefile%20%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSTRONG%3ECOBJS%E3%81%AE%E8%A1%8C%E3%82%92board%2Ffreescale%2Fmx6_udoo%2F%E3%81%A7%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20obj-y%26nbsp%3B%20%3A%3D%20mx6sabresd.o%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%E3%82%B7%E3%82%A7%E3%83%AB%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSTRONG%3E%E6%96%B0%E3%81%97%E3%81%84%E8%A8%AD%E5%AE%9A%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AF%E3%80%81build_u-boot.sh%20%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%A7%E3%80%81%E6%AC%A1%E3%81%AB%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%23!%2Fbin%2Fbash%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20ARCH%3Darm%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3Eexport%20CROSS_COMPILE%3D%2Fopt%2Fpoky%2F1.7%2Fsysroots%2Fx86_64-pokysdk-linux%2Fusr%2Fbin%2Farm-poky-linux-gnueabi%2Farm-poky-linux-gnueabi-%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3Edistclean%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3Emake%20mx6_udoo_config%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%3CEM%3E%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E6%A7%8B%E6%88%90%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%24.%2Fbuild_u-boot.sh%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E4.%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%81%99%E3%82%8B%E6%9C%80%E5%88%9D%E3%81%AE%E9%83%A8%E5%88%86%E3%81%AFDCD%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82DCD%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81DDR%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%A8%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82DCD%20%E3%81%AF%20iMX%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AE%20BootROM%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%80%81Uboot%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%20DDR%20%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82DCD%20%E3%81%AF%20.cfg%20%E3%81%AB%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99boards.cfg%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB(mx6dl_4x_mt41j128.cfg)%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E3%81%B0%E3%81%8B%E3%82%8A%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%81%A7%E6%8C%87%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%20%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E3%81%AB%E3%80%81%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E4%BE%8B%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%2F*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%20*%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E6%A7%8B%E6%88%90%E3%83%87%E3%83%BC%E3%82%BF(DCD)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%20*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%20*%20%E5%90%84%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%E3%81%AE%E5%BD%A2%E5%BC%8F%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%20*%20Addr%E5%9E%8B%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E5%80%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%20*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%20*%E3%81%A9%E3%81%93%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%20*%20Addr%E5%9E%8B%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E9%95%B7%E3%81%95(1%E3%80%812%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF4%E3%83%90%E3%82%A4%E3%83%88)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%20*%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E7%B5%B6%E5%AF%BE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%20*%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E6%A0%BC%E7%B4%8D%E3%81%95%E3%82%8C%E3%82%8B%E5%80%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EDATA%204%2C%200x020e0774%2C%200x000C0000%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EDATA%204%2C%200x020e0754%2C%200x00000000%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EDATA%204%2C%200x020e04ac%2C%200x00000030%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EDATA%204%2C%200x020e04b0%2C%200x00000030%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EDATA%204%2C%200x020e0464%2C%200x00000030%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EDATA%204%2C%200x020e0490%2C%200x00000030%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EDATA%204%2C%200x020e074c%2C%200x00000030%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EDATA%204%2C%200x020e0494%2C%200x00000030%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EDATA%204%2C%200x020e04a0%2C%200x00000000%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%20.cfg%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81dtb%20%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%8F%A4%E3%81%84%20U-Boot%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20(2009)%20%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%E3%81%95%E3%82%8C%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%B7%BB%E4%BB%98%E3%81%AE.zip%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E5%90%84%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E7%89%B9%E5%AE%9A%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81board%2Ffreescale%2Fmx6%3CCUSTOMER%20board%3D%22%22%3E.c%20%E3%81%AE%20mx6%3CCUSTOMER%20board%3D%22%22%3E.c%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%20board%2Ffreescale%2Fmx6_udoo%2Fmx6_udoo.c%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%82%92%E6%AD%A3%E3%81%97%E3%81%84UART%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%97%E3%80%81%E5%A4%96%E9%83%A8%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%80%81%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88PHY%E3%82%92%E6%A7%8B%E6%88%90%E3%81%8A%E3%82%88%E3%81%B3%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%80%81lvds%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84USDHC%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E5%A4%89%E6%9B%B4%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FCUSTOMER%3E%3C%2FCUSTOMER%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3EU-Boot%20%E3%81%AF%E3%80%81%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E6%AE%B5%E9%9A%8E%E3%81%A7%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%92%E5%87%A6%E7%90%86%E3%81%99%E3%82%8B%E9%96%A2%E6%95%B0%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E9%85%8D%E5%88%97%E3%81%8B%E3%82%89%E3%80%81%E5%AE%9A%E7%BE%A9%E6%B8%88%E3%81%BF%E3%81%AE%E9%96%A2%E6%95%B0%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81board_early_init_f()%20%E3%81%AF%E3%80%81wdog%20%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%20uart%20%E3%83%94%E3%83%B3%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%A7%E3%81%8D%E3%82%8B%E5%88%9D%E6%9C%9F%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%E3%81%A7%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82board_init()%20%E3%81%A8%20board_late_init()%20%E3%81%AF%20%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%20board_early_init_f()%3C%2FSPAN%3E%20%E3%81%AE%E5%BE%8C%E3%81%AB%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3EUDOO%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%E5%A4%96%E9%83%A8%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81GPIO%E3%81%A7%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%86%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81U-Boot%E3%81%AF%E6%95%B0%E7%A7%92%E5%BE%8C%E3%81%AB%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111736iFD93345DA9FCC5AF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_12.png%22%20alt%3D%22pastedImage_12.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_13.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_13.png%22%20style%3D%22width%3A%20975px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111735iB64D3C7D61E497D3%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_13.png%22%20alt%3D%22pastedImage_13.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EWDOG%20%E3%83%94%E3%83%B3%E3%81%AF%E3%80%81mx6_udoo.c%20%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AE%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E6%A7%8B%E9%80%A0%E4%BD%93%E6%A7%8B%E6%88%90%E3%81%8C%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%BB%E3%81%8B%E3%80%81%E5%90%84%E3%83%94%E3%83%B3%E3%81%AE%E3%83%9E%E3%82%AF%E3%83%AD%E3%82%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%23define%20WDT_EN%20IMX_GPIO_NR(5%E3%80%814)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%23define%20WDT_TRG%20IMX_GPIO_NR(3%2C%2019)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Eiomux_v3_cfg_t%20%E5%AE%9A%E6%95%B0%20wdog_pads%5B%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6_PAD_EIM_A24__GPIO5_IO04%20%7C%20MUX_PAD_CTRL(NO_PAD_CTRL)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6_PAD_EIM_D19__GPIO3_IO19%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Estatic%20void%20setup_iomux_wdog(void)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Eimx_iomux_v3_setup_multiple_pads(wdog_pads%2C%20ARRAY_SIZE(wdog_pads))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Egpio_direction_output(WDT_TRG%2C%200)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Egpio_direction_output(WDT_EN%2C%201)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Egpio_direction_input(WDT_TRG)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%E3%81%93%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%80%81%20board_early_init_f()%20%E3%81%AE%E3%81%82%E3%82%8B%E6%99%82%E7%82%B9%E3%81%A7%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Eint%20board_early_init_f(void)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233334ca%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%20setup_iomux_wdog()%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81board_early_init_f()%20%E3%81%AF%E5%A4%96%E9%83%A8%20wdog%20%E3%81%AE%20iomux%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3EUART%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81UART2%E3%80%81EIM_D26%2FUART2_TXD%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3EIM_D27%2FUART2_RXD%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82UART2%20%E3%81%AE%E3%83%94%E3%83%B3%E9%85%8D%E7%BD%AE%E3%81%A7%E3%81%AF%E3%80%81%E7%95%B0%E3%81%AA%E3%82%8B%E6%A7%8B%E9%80%A0%E3%81%8C%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_49.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_49.png%22%20style%3D%22width%3A%20712px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111734iF8F7F31847E81301%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_49.png%22%20alt%3D%22pastedImage_49.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Eiomux_v3_cfg_t%20const%20uart2_pads%5B%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EMX6_PAD_EIM_D26__UART2_TX_DATA%20%7CMUX_PAD_CTRL(UART_PAD_CTRL)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EMX6_PAD_EIM_D27__UART2_RX_DATA%20%7CMUX_PAD_CTRL(UART_PAD_CTRL)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E3%81%93%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%82%E6%97%A9%E3%81%84%E6%AE%B5%E9%9A%8E%E3%81%A7%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Estatic%20void%20setup_iomux_uart(void)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Eimx_iomux_v3_setup_multiple_pads(uart2_pads%2C%20ARRAY_SIZE(uart2_pads))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Eint%20board_early_init_f(void)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Esetup_iomux_wdog()%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20setup_iomux_uart()%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E3%81%BE%E3%81%9F%E3%80%81UART%20BASE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%A8%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81include%2Fconfigs%2Fmx6_udoo.h%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CTABLE%3E%3CTBODY%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%23define%20CONFIG_MXC_UART_BASE%20UART2_BASE%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%23define%20CONFIG_CONSOLE_DEV%20%E3%80%8Cttymxc1%E3%80%8D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3EUDOO%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%E8%B5%B7%E5%8B%95%E7%94%A8%E3%81%AE%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%ADSD%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%81%A8U-Boot%E7%92%B0%E5%A2%83%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%82%921%E3%81%A4%E3%81%A0%E3%81%91%E5%82%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%824%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E8%A8%AD%E5%AE%9A%E3%82%82%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3Einclude%2Fconfigs%2Fmx6_udoo.h%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%80%81USDHC%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A8%20MMC%20%E7%92%B0%E5%A2%83%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_55.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_55.png%22%20style%3D%22width%3A%20733px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F58140i3C9665739A1B0608%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_55.png%22%20alt%3D%22pastedImage_55.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%23define%20CONFIG_SYS_FSL_USDHC_NUM%26nbsp%3B%26nbsp%3B%203%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%23define%20CONFIG_SYS_MMC_ENV_DEV%200%20%2F*%20SDHC3%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3EUSDHC3%20%E3%83%94%E3%83%B3%20%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Eiomux_v3_cfg_t%20%E5%AE%9A%E6%95%B0%20usdhc3_pads%5B%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6_PAD_SD3_CLK__SD3_CLK%26nbsp%3B%26nbsp%3B%20%7C%20MUX_PAD_CTRL(USDHC_PAD_CTRL)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EMX6_PAD_SD3_CMD__SD3_CMD%20%7CMUX_PAD_CTRL(USDHC_PAD_CTRL)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EMX6_PAD_SD3_DAT0__SD3_DATA0%20%7CMUX_PAD_CTRL(USDHC_PAD_CTRL)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EMX6_PAD_SD3_DAT1__SD3_DATA1%20%7CMUX_PAD_CTRL(USDHC_PAD_CTRL)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EMX6_PAD_SD3_DAT2__SD3_DATA2%20%7CMUX_PAD_CTRL(USDHC_PAD_CTRL)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EMX6_PAD_SD3_DAT3__SD3_DATA3%20%7CMUX_PAD_CTRL(USDHC_PAD_CTRL)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6_PAD_NANDF_D0__GPIO2_IO00%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%20MUX_PAD_CTRL(NO_PAD_CTRL)%2C%20%2F*%20CD%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Estruct%20fsl_esdhc_cfg%20usdhc_cfg%5B1%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7BUSDHC3_BASE_ADDR%2C%200%2C%204%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%3C%2FSPAN%3E%3B%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81board_mmc_init()%20%E9%96%A2%E6%95%B0%E3%81%8B%E3%82%89%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Eint%20board_mmc_init(bd_t%20*bis)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3ES32%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Eimx_iomux_v3_setup_multiple_pads(%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Eusdhc3_pads%E3%80%81ARRAY_SIZE(usdhc3_pads))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Eusdhc_cfg%5B0%5D.sdhc_clk%20%3D%20mxc_get_clock(MXC_ESDHC3_CLK)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20status%20%7C%3D%20fsl_esdhc_initialize(bis%2C%20%26amp%3Busdhc_cfg%5B0%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20return%20status%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20PHY%20%E3%81%AF%E3%80%81board_eth_init()%20%E9%96%A2%E6%95%B0%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AF%E3%80%81%E5%A4%96%E9%83%A8%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20phy%E3%80%81mdio%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%20phy%20%E6%A7%8B%E6%88%90%E3%81%AE%E3%83%94%E3%83%B3%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E4%B8%80%E9%83%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Eiomux_v3_cfg_t%20const%20enet_pads1%5B%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6_PAD_ENET_MDIO__ENET_MDIO%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%20MUX_PAD_CTRL(ENET_PAD_CTRL)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EMX6_PAD_ENET_MDC__ENET_MDC%20%7CMUX_PAD_CTRL(ENET_PAD_CTRL)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6_PAD_RGMII_TXC__RGMII_TXC%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%20MUX_PAD_CTRL(ENET_PAD_CTRL)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EMX6_PAD_RGMII_TD0__RGMII_TD0%20%7CMUX_PAD_CTRL(ENET_PAD_CTRL)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EMX6_PAD_RGMII_TD1__RGMII_TD1%20%7CMUX_PAD_CTRL(ENET_PAD_CTRL)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EMX6_PAD_RGMII_TD2__RGMII_TD2%20%7CMUX_PAD_CTRL(ENET_PAD_CTRL)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EMX6_PAD_RGMII_TD3__RGMII_TD3%20%7CMUX_PAD_CTRL(ENET_PAD_CTRL)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EMX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL%20%7CMUX_PAD_CTRL(ENET_PAD_CTRL)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6_PAD_ENET_REF_CLK__ENET_TX_CLK%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%20MUX_PAD_CTRL(ENET_PAD_CTRL)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6_PAD_RGMII_RXC__RGMII_RXC%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%20MUX_PAD_CTRL(ENET_PAD_CTRL)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20RGMII%20reset%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6_PAD_EIM_D23__GPIO3_IO23%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%20MUX_PAD_CTRL(NO_PAD_CTRL)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20alimentazione%20ethernet*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EMX6_PAD_EIM_EB3__GPIO2_IO31%20%7CMUX_PAD_CTRL(NO_PAD_CTRL)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%2F*%20%E3%83%94%E3%83%B3%2032%20-%201%20-%20(MODE0)%20%E3%81%99%E3%81%B9%E3%81%A6%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6_PAD_RGMII_RD0__GPIO6_IO25%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%20MUX_PAD_CTRL(NO_PAD_CTRL)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%2F*%20%E3%83%94%E3%83%B3%2031%20-%201%20-%20(MODE1)%20%E3%81%99%E3%81%B9%E3%81%A6%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6_PAD_RGMII_RD1__GPIO6_IO27%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%20MUX_PAD_CTRL(NO_PAD_CTRL)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%2F*%20%E3%83%94%E3%83%B3%2028%20-%201%20-%20(MODE2)%20%E3%81%99%E3%81%B9%E3%81%A6%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6_PAD_RGMII_RD2__GPIO6_IO28%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%20MUX_PAD_CTRL(NO_PAD_CTRL)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%2F*%20%E3%83%94%E3%83%B3%2027%20-%201%20-%20(MODE3)%20%E3%81%99%E3%81%B9%E3%81%A6%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6_PAD_RGMII_RD3__GPIO6_IO29%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%20MUX_PAD_CTRL(NO_PAD_CTRL)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%2F*%20%E3%83%94%E3%83%B3%2033%20-%201%20-%20(CLK125_EN)%20125Mhz%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%A2%E3%82%A6%E3%83%88%E6%9C%89%E5%8A%B9%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EMX6_PAD_RGMII_RX_CTL__GPIO6_IO24%20%7CMUX_PAD_CTRL(NO_PAD_CTRL)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%E9%9D%99%E7%9A%84iomux_v3_cfg_t%20const%20enet_pads2%5B%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6_PAD_RGMII_RD0__RGMII_RD0%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%20MUX_PAD_CTRL(ENET_PAD_CTRL)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6_PAD_RGMII_RD1__RGMII_RD1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%20MUX_PAD_CTRL(ENET_PAD_CTRL)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6_PAD_RGMII_RD2__RGMII_RD2%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%20MUX_PAD_CTRL(ENET_PAD_CTRL)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6_PAD_RGMII_RD3__RGMII_RD3%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C%20MUX_PAD_CTRL(ENET_PAD_CTRL)%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3EMX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL%20%7CMUX_PAD_CTRL(ENET_PAD_CTRL)%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Estatic%20void%20setup_iomux_enet(void)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Eimx_iomux_v3_setup_multiple_pads(enet_pads1%2C%20ARRAY_SIZE(enet_pads1))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20udelay(20)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Egpio_direction_output(IMX_GPIO_NR(2%2C%2031)%2C%201)%3B%2F*%20enet%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E3%82%8B%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Egpio_direction_output(IMX_GPIO_NR(3%2C%2023)%2C%200)%3B%2F*%20PHY%20rst%20%E3%82%92%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%88%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Egpio_direction_output(IMX_GPIO_NR(6%2C%2024)%2C%201)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Egpio_direction_output(IMX_GPIO_NR(6%2C%2025)%2C%201)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Egpio_direction_output(IMX_GPIO_NR(6%2C%2027)%2C%201)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Egpio_direction_output(IMX_GPIO_NR(6%2C%2028)%2C%201)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Egpio_direction_output(IMX_GPIO_NR(6%2C%2029)%2C%201)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20udelay(1000)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Egpio_set_value(IMX_GPIO_NR(3%2C%2023)%2C%201)%3B%2F*%20PHY%20rst%20%E3%82%92%E3%83%87%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%88%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%2F*%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E7%B5%82%E4%BA%86%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%20100ms%20%E3%81%AE%E9%81%85%E5%BB%B6%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20udelay(1000%20*%20100)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Egpio_free(IMX_GPIO_NR(6%2C%2024))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Egpio_free(IMX_GPIO_NR(6%2C%2025))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Egpio_free(IMX_GPIO_NR(6%2C%2027))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Egpio_free(IMX_GPIO_NR(6%2C%2028))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Egpio_free(IMX_GPIO_NR(6%2C%2029))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Eimx_iomux_v3_setup_multiple_pads(enet_pads2%2C%20ARRAY_SIZE(enet_pads2))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E5%A4%96%E9%83%A8PHY%E3%81%AFSABRESD%20AR8031%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82UDOO%E3%81%AFMICREL%20KSZ9031%20PHY%E3%82%92%E5%82%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%BE%8C%E8%80%85%E3%81%AF%E5%AE%9A%E7%BE%A9%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E5%89%8D%E8%80%85%E3%81%AF%20%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3Einclude%2Fconfigs%2Fmx6_udoo.h%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%23undef%26nbsp%3B%20CONFIG_PHY_ATHEROS%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%23define%20CONFIG_PHY_MICREL%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%23define%20CONFIG_PHY_MICREL_KSZ9031%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E3%81%BE%E3%81%9F%E3%80%81PHY%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%23define%20CONFIG_FEC_MXC_PHYADDR%206%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%81%93%E3%81%AE%E6%99%82%E7%82%B9%E3%81%A7%E3%80%81%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%80%81SD%E3%82%AB%E3%83%BC%E3%83%89%E4%BF%9D%E5%AD%98%E5%BC%95%E6%95%B0%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%E6%9C%80%E5%BE%8C%E3%81%AE%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AF%E3%80%81LVDS%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%99%E3%80%82UDOO%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AELVDS%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AFSABRE-SD%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E5%90%8C%E3%81%98%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%8B%95%E4%BD%9C%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%8C%E7%95%B0%E3%81%AA%E3%82%8B%E3%81%9F%E3%82%81%E3%80%817%E3%82%A4%E3%83%B3%E3%83%81%E3%81%AELVDS%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF~33.26MHz%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3Emx6_udoo.c%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81LDB%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%20setup_display%20%E9%96%A2%E6%95%B0%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AF%20board_early_init_f()%20%E3%81%A7%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%AF%E3%80%81LVDS%20%E3%81%AB%2033.2MHz%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81LDB%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AB%E5%88%A5%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%90%E3%83%83%E3%82%AF%E3%83%A9%E3%82%A4%E3%83%88%E3%81%A8lvds%E9%9B%BB%E6%BA%90%E4%BF%A1%E5%8F%B7%E3%81%8C%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%20style%3D%22width%3A%20626px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F24854iAA30727BB6DF05F3%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_6.png%22%20alt%3D%22pastedImage_6.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%AFmmdc_ch1%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%80%8133.26MHz%E3%81%AB%E8%BF%91%E3%81%A5%E3%81%8F%E3%81%9F%E3%82%81%E3%81%ABPLL2_PFD0%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%20style%3D%22width%3A%20646px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F24784i3E0F27E8E283899F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_11.png%22%20alt%3D%22pastedImage_11.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%20gpio_direction_output(IMX_GPIO_NR(1%2C%202)%2C%201)%3B%2F*%20LVDS%E9%9B%BB%E6%BA%90%E3%82%AA%E3%83%B3%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Egpio_direction_output(IMX_GPIO_NR(1%2C%204)%2C%201)%3B%2F*%20LVDS%E3%83%90%E3%83%83%E3%82%AF%E3%83%A9%E3%82%A4%E3%83%88%E3%82%AA%E3%83%B3%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20imx_iomux_v3_setup_multiple_pads(di0_pads%2C%20ARRAY_SIZE(di0_pads))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Eenable_ipu_clock()%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Eimx_setup_hdmi()%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%2F*%204LDB0%E3%80%81LDB1%E3%80%81IPU%E3%80%81IPU%20DI0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E3%82%AA%E3%83%B3%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Ereg%20%3D%20readl(%26amp%3Bmxc_ccm-%26gt%3BCCGR3)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20reg%20%7C%3D%26nbsp%3B%20MXC_CCM_CCGR3_LDB_DI0_MASK%20%7C%20MXC_CCM_CCGR3_LDB_DI1_MASK%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Ewritel(reg%2C%20%26amp%3Bmxc_ccm-%26gt%3BCCGR3)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%2F*%20LDB0%E3%80%81LDB1%20clk%20select%20%E3%82%92%20011%2F011%20%E3%81%AB%E8%A8%AD%E5%AE%9A%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Ereg%20%3D%20readl(%26amp%3Bmxc_ccm-%26gt%3Bcs2cdr)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Ereg%20%26amp%3B%3D%20~(MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_MASK%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7CMXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_MASK)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Ereg%20%7C%3D%20(1%20%26lt%3B%26lt%3B%20MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_OFFSET)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%7C(1%26lt%3B%26lt%3B%20MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_OFFSET)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Ewritel(reg%2C%20%26amp%3Bmxc_ccm-%26gt%3Bcs2cdr)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E3%81%93%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%20U-Boot%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%20.%2Fbuild_u-boot.sh%20%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%80%81uboot.imx%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%20SD%20%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E6%B8%88%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%3CSTRONG%3E%23%20sudo%20cp%20if%3Duboot.imx%20of%3D%2Fdev%2FsdX%20bs%3D512%20seek%3D%202%20%26amp%3B%26amp%3B%20sync%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%3CSTRONG%3E5.%20%E5%A4%89%E6%9B%B4%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3EU-Boot%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%A7SD%E3%82%92%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%ADSD%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%81%AB%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%91%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AAU-Boot%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_22.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_22.png%22%20style%3D%22width%3A%20507px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111737iEE1F9485D1B34188%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_22.png%22%20alt%3D%22pastedImage_22.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81PING%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%81%A8phy%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_27.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_27.png%22%20style%3D%22width%3A%20290px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111738i3699E4FA0DA30464%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_27.png%22%20alt%3D%22pastedImage_27.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E6%89%8B%E9%A0%86%E3%81%8C%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1105739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1914894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20U-Boot%20%E7%A7%BB%E8%A1%8C%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1914894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22shanthu_1306_0-1721728068260.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shanthu_1306_0-1721728068260.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F289879i44630CCCA7E5B9B0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22shanthu_1306_0-1721728068260.png%22%20alt%3D%22shanthu_1306_0-1721728068260.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105740%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20U-Boot%20%E7%A7%BB%E8%A1%8C%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105740%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B2%B4%E9%87%8D%E3%81%AA%E6%83%85%E5%A0%B1%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E8%AA%A0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%20%3CSPAN%3Eiomux%3C%2FSPAN%3E%20(%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%8B%E3%82%89)%E3%81%AFu-boot%E3%81%AEiomux%E3%82%92%E4%B8%8A%E6%9B%B8%E3%81%8D%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%A9%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-28-2015 02:39 PM
更新者:
