Q&A: Why is CAAM Driver Not Functioning in Linux for iMX6?
Question:
Using Linux SDK 4.1.0, with CAAM drivers enabled, there is little noticeable difference in the performance of openssd compared to a kernel without the CAAM drivers.
Tests were done using openssd.
Test image
AES-128 8192 byte block (M Bytes/sec)
“openssl speed –evp aes-128-cbc”
With /dev/crypto
“openssl speed –evp aes-128-cbc -engine cryptodev”
Ubuntu 11.04 Image
19.010
N/A
Timesys
20.518
N/A
SDK 4.1.0 LTIB
22.013
21.984 (errors reported)
One can see that with SDK 4.1.0, performance is worse with crypto enabled.  This is probably due to the overhead of a faulty driver or incorrect implementation.
The lowest number is for Ubuntu which could be attributed to the Unity GUI.
Conclusion:
CAAM driver is not functional or I am using an improper testing procedure.
Test Procedure:
Board used is iMX6Q Sabre SDP
Openssl was used for testing.
Two command line commands were used, with and without the cryptodev engine.
Openssl versions used in each build are slightly different:
Ubuntu:              openssl 1.0.0e
Timesys:              openssl  1.0.1e
SDK 4.1.0:            openssl  1.0.1c
Three versions of Linux were tested.
  1. Default kernel  4.0.0 with Ubuntu rootfs form image tarballs.
  2. Timesys kernel and root file system
  3. Kernel built with SDK 4.1.0 using LTIB with hardware crypto enabled
Both 1 and 2 above did not have CRYPTODEV set in .config which contains the line
“# CONFIG_CRYPTO_CRYPTODEV is not set”
Option 3 had the line in .config as,
“CONFIG_CRYPTO_CRYPTODEV=y”
All three builds generate “/proc/crypto”  whose contents are attached.  A partial listing of /proc/crypto lists “caam” as a driver for all encryption methods supported.  Example printout for aes shown below:
ame         : cbc(aes)
driver       : cbc-aes-caam
module       : kernel
priority     : 3000
refcnt       : 1
selftest     : passed
type         : ablkcipher
async        : yes
blocksize    : 16
min keysize  : 16
max keysize  : 32
ivsize       : 16
geniv        : eseqiv
All three builds have “caam” and “enable_wait_mode=off” in the kernel command line in u-boot.
Only option #3 contains both device file in “/dev/crypto” and an entry in “/proc/crypto”
root@freescale ~$ cd /
root@freescale /$ ls /proc/cr*
/proc/crypto
root@freescale /$ ls /dev/cr*
/dev/crypto
root@freescale /$
Test #1—Kernel build 4.1.0 openssl speed test without caam engine
root@freescale ~$ openssl speed -evp aes-128-cbc
Doing aes-128-cbc for 3s on 16 size blocks: 3471184 aes-128-cbc's in 2.94s
Doing aes-128-cbc for 3s on 64 size blocks: 986286 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 256 size blocks: 249743 aes-128-cbc's in 2.93s
Doing aes-128-cbc for 3s on 1024 size blocks: 64343 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 8192 size blocks: 7954 aes-128-cbc's in 2.96s
OpenSSL 1.0.1c 10 May 2012
built on: Sat Sep 7 18:47:34 PDT 2013
options:bn(64,32) rc4(ptr,char) des(idx,cisc,16,long) aes(partial) idea(int) blowfish(ptr)
compiler: gcc -fPIC -DOPENSSL_PIC -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -DL_ENDIAN -DTERMIO -O3 -fomit-frame-pointer -Wall
The 'numbers' are in 1000s of bytes per second processed.
type 16 bytes     64 bytes    256 bytes 1024 bytes   8192 bytes
aes-128-cbc 18890.80k    21040.77k    21820.55k 21962.41k    22013.23k
root@freescale ~$
Test #2—Timesys kernel build of openssd without /dev/crypto
# openssl speed -evp aes-128-cbc
Doing aes-128-cbc for 3s on 16 size blocks: 3361305 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 64 size blocks: 924423 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 256 size blocks: 236623 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 1024 size blocks: 59967 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 8192 size blocks: 7514 aes-128-cbc's in 3.00s
OpenSSL 1.0.1e 11 Feb 2013
built on: Thu Sep 5 21:54:37 EDT 2013
options:bn(64,32) rc4(ptr,char) des(idx,cisc,16,long) aes(partial) blowfish(ptr)
compiler: armv7l-timesys-linux-gnueabi-gcc -fPIC -DOPENSSL_PIC -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -I/here/workdir/factory/build_armv7l-times
ys-linux-gnueabi/toolchain/usr/include -DL_ENDIAN -DTERMIO -DOPENSSL_NO_KRB5 -DOPENSSL_NO_IDEA -DOPENSSL_NO_MDC2 -DOPENSSL_NO_RC5 -Os -pipe -Wa,--noexecstack -Wall
aes-128-cbc 17926.96k    19721.02k    20191.83k 20468.74k    20518.23k
Test #3—Ubuntu rootfs and kernel image
root@linaro-ubuntu-desktop:/# openssl speed -evp aes-128-cbc
Doing aes-128-cbc for 3s on 16 size blocks: 3030128 aes-128-cbc's in 2.98s
Doing aes-128-cbc for 3s on 64 size blocks: 852897 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 256 size blocks: 220572 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 1024 size blocks: 55534 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 8192 size blocks: 6846 aes-128-cbc's in 2.95s
OpenSSL 1.0.0e 6 Sep 2011
built on: Wed Oct 5 01:45:02 UTC 2011
compiler: cc -fPIC -DOPENSSL_PIC -DZLIB -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -DL_ENDIAN -DTERMIO -O2 -Wa,--noexecstack -g -Wall
aes-128-cbc 16269.14k    18195.14k    18822.14k 18955.61k    19010.99k
Test #4—SDK 4.1.0 openssl speed test with “/dev/crypto” .  Note errors.
root@freescale ~$ openssl speed -evp aes-128-cbc -engine cryptodev
invalid engine "cryptodev"
716715216:error:25066067:DSO support routines:DLFCN_LOAD:could not load the shared library:dso_dlfcn.c:187:filename(/usr/lib/engines/libcryptodev.so): /usr/lib/eng
ines/libcryptodev.so: cannot open shared object file: No such file or directory
716715216:error:25070067:DSO support routines:DSO_load:could not load the shared library:dso_lib.c:244:
716715216:error:260B6084:engine routines:DYNAMIC_LOAD:dso not found:eng_dyn.c:450:
716715216:error:2606A074:engine routines:ENGINE_by_id:no such engine:eng_list.c:417:id=cryptodev
716715216:error:25066067:DSO support routines:DLFCN_LOAD:could not load the shared library:dso_dlfcn.c:187:filename(libcryptodev.so): libcryptodev.so: cannot open
Doing aes-128-cbc for 3s on 16 size blocks: 3572980 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 64 size blocks: 966002 aes-128-cbc's in 2.94s
Doing aes-128-cbc for 3s on 256 size blocks: 255307 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 1024 size blocks: 62967 aes-128-cbc's in 2.93s
Doing aes-128-cbc for 3s on 8192 size blocks: 7890 aes-128-cbc's in 2.94s
aes-128-cbc 19055.89k    21028.61k    21786.20k 22006.21k    21984.65k
root@freescale ~$
Answer:
I do not know what is recent state of official Freescale BSP regarding CAAM, but to get OpenSSL working under CAAM support with reasonable acceleration  :
https://community.freescale.com/message/318188#318188
The patches was used below :
http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/log/?h=imx_3.0.35_4.0.0
Direct link to the patches:
http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/commit/?h=imx_3.0.35_4.0.0&id=6068d7a77b...
http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/commit/?h=imx_3.0.35_4.0.0&id=b30237c790...
ラベル(2)
タグ(1)
添付
%3CLINGO-SUB%20id%3D%22lingo-sub-1122946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EQ%26amp%3BA%3AiMX6%E3%81%AELinux%E3%81%A7CAAM%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%E8%B3%AA%E5%95%8F%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ELinux%20SDK%204.1.0%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81CAAM%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81CAAM%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%81%AA%E3%81%84%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E3%80%81openssd%20%E3%81%AE%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%AB%E7%9B%AE%E7%AB%8B%E3%81%A3%E3%81%9F%E9%81%95%E3%81%84%E3%81%AF%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E3%81%AF%20openssd%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%20align%3D%22left%22%20border%3D%221%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20height%3D%22149%22%20jive-data-cell%3D%22%7B%22%20color%3D%22%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22border%3A%201pt%20solid%20windowtext%3B%20padding%3A%200px%205.4pt%3B%20color%3A%20%23575757%3B%20text-align%3A%20left%3B%20background-color%3A%20transparent%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20vertical-align%3A%20baseline%3B%22%20valign%3D%22top%22%20width%3D%22255%22%3E%3CP%3E%3CSTRONG%3E%E3%83%86%E3%82%B9%E3%83%88%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-style%3A%20solid%20solid%20solid%20none%3B%20border-top-color%3A%20windowtext%3B%20border-right-color%3A%20windowtext%3B%20border-bottom-color%3A%20windowtext%3B%20border-top-width%3A%201pt%3B%20border-right-width%3A%201pt%3B%20border-bottom-width%3A%201pt%3B%20padding%3A%200px%205.4pt%3B%20color%3A%20%23575757%3B%20text-align%3A%20left%3B%20background-color%3A%20transparent%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20vertical-align%3A%20baseline%3B%22%20valign%3D%22top%22%20width%3D%22255%22%3E%3CP%3E%3CSTRONG%3EAES-128%208192%E3%83%90%E3%82%A4%E3%83%88%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF(M%E3%83%90%E3%82%A4%E3%83%88%2F%E7%A7%92)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%E3%80%8COpenSSL%20%E9%80%9F%E5%BA%A6%20%E2%80%93%20EVP%20AES-128-CBC%3CSTRONG%3E%E3%80%8D%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-style%3A%20solid%20solid%20solid%20none%3B%20border-top-color%3A%20windowtext%3B%20border-right-color%3A%20windowtext%3B%20border-bottom-color%3A%20windowtext%3B%20border-top-width%3A%201pt%3B%20border-right-width%3A%201pt%3B%20border-bottom-width%3A%201pt%3B%20padding%3A%200px%205.4pt%3B%20color%3A%20%23575757%3B%20text-align%3A%20left%3B%20background-color%3A%20transparent%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20vertical-align%3A%20baseline%3B%22%20valign%3D%22top%22%20width%3D%22255%22%3E%3CP%3E%3CSTRONG%3EAES-128%208192%E3%83%90%E3%82%A4%E3%83%88%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF(M%E3%83%90%E3%82%A4%E3%83%88%2F%E7%A7%92)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%2Fdev%2Fcrypto%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%E3%80%8COpenSSL%20Speed%20%E2%80%93EVP%20AES-128-CBC%20-Engine%20CryptoDev%E3%80%8D%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-style%3A%20none%20solid%20solid%3B%20border-right-color%3A%20windowtext%3B%20border-bottom-color%3A%20windowtext%3B%20border-left-color%3A%20windowtext%3B%20border-right-width%3A%201pt%3B%20border-bottom-width%3A%201pt%3B%20border-left-width%3A%201pt%3B%20padding%3A%200px%205.4pt%3B%20color%3A%20%23575757%3B%20text-align%3A%20left%3B%20background-color%3A%20transparent%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20vertical-align%3A%20baseline%3B%22%20valign%3D%22top%22%20width%3D%22255%22%3E%3CP%3EUbuntu%2011.04%20Image%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-style%3A%20none%20solid%20solid%20none%3B%20border-bottom-color%3A%20windowtext%3B%20border-bottom-width%3A%201pt%3B%20border-right-color%3A%20windowtext%3B%20border-right-width%3A%201pt%3B%20padding%3A%200px%205.4pt%3B%20color%3A%20%23575757%3B%20text-align%3A%20left%3B%20background-color%3A%20transparent%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20vertical-align%3A%20baseline%3B%22%20valign%3D%22top%22%20width%3D%22255%22%3E%3CP%3E19.010%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-style%3A%20none%20solid%20solid%20none%3B%20border-bottom-color%3A%20windowtext%3B%20border-bottom-width%3A%201pt%3B%20border-right-color%3A%20windowtext%3B%20border-right-width%3A%201pt%3B%20padding%3A%200px%205.4pt%3B%20color%3A%20%23575757%3B%20text-align%3A%20left%3B%20background-color%3A%20transparent%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20vertical-align%3A%20baseline%3B%22%20valign%3D%22top%22%20width%3D%22255%22%3E%3CP%3EN%2FA%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-style%3A%20none%20solid%20solid%3B%20border-right-color%3A%20windowtext%3B%20border-bottom-color%3A%20windowtext%3B%20border-left-color%3A%20windowtext%3B%20border-right-width%3A%201pt%3B%20border-bottom-width%3A%201pt%3B%20border-left-width%3A%201pt%3B%20padding%3A%200px%205.4pt%3B%20color%3A%20%23575757%3B%20text-align%3A%20left%3B%20background-color%3A%20transparent%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20vertical-align%3A%20baseline%3B%22%20valign%3D%22top%22%20width%3D%22255%22%3E%3CP%3ETimesys%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-style%3A%20none%20solid%20solid%20none%3B%20border-bottom-color%3A%20windowtext%3B%20border-bottom-width%3A%201pt%3B%20border-right-color%3A%20windowtext%3B%20border-right-width%3A%201pt%3B%20padding%3A%200px%205.4pt%3B%20color%3A%20%23575757%3B%20text-align%3A%20left%3B%20background-color%3A%20transparent%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20vertical-align%3A%20baseline%3B%22%20valign%3D%22top%22%20width%3D%22255%22%3E%3CP%3E20.518%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-style%3A%20none%20solid%20solid%20none%3B%20border-bottom-color%3A%20windowtext%3B%20border-bottom-width%3A%201pt%3B%20border-right-color%3A%20windowtext%3B%20border-right-width%3A%201pt%3B%20padding%3A%200px%205.4pt%3B%20color%3A%20%23575757%3B%20text-align%3A%20left%3B%20background-color%3A%20transparent%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20vertical-align%3A%20baseline%3B%22%20valign%3D%22top%22%20width%3D%22255%22%3E%3CP%3EN%2FA%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border-style%3A%20none%20solid%20solid%3B%20border-right-color%3A%20windowtext%3B%20border-bottom-color%3A%20windowtext%3B%20border-left-color%3A%20windowtext%3B%20border-right-width%3A%201pt%3B%20border-bottom-width%3A%201pt%3B%20border-left-width%3A%201pt%3B%20padding%3A%200px%205.4pt%3B%20color%3A%20%23575757%3B%20text-align%3A%20left%3B%20background-color%3A%20transparent%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20vertical-align%3A%20baseline%3B%22%20valign%3D%22top%22%20width%3D%22255%22%3E%3CP%3ESDK%204.1.0%20LTIB%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-style%3A%20none%20solid%20solid%20none%3B%20border-bottom-color%3A%20windowtext%3B%20border-bottom-width%3A%201pt%3B%20border-right-color%3A%20windowtext%3B%20border-right-width%3A%201pt%3B%20padding%3A%200px%205.4pt%3B%20color%3A%20%23575757%3B%20text-align%3A%20left%3B%20background-color%3A%20transparent%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20vertical-align%3A%20baseline%3B%22%20valign%3D%22top%22%20width%3D%22255%22%3E%3CP%3E22.013%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22color%3A%20%23575757%3B%20text-align%3A%20left%3B%20background-color%3A%20transparent%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20vertical-align%3A%20baseline%3B%22%3E%3CP%3E21.984%20(%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F)%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3ESDK%204.1.0%E3%81%A7%E3%81%AF%E3%80%81%E6%9A%97%E5%8F%B7%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%8E%E4%B8%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E9%9A%9C%E5%AE%B3%E3%81%BE%E3%81%9F%E3%81%AF%E5%AE%9F%E8%A3%85%E3%81%AE%E8%AA%A4%E3%82%8A%E3%81%AB%E3%82%88%E3%82%8B%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%98%E3%83%83%E3%83%89%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E3%82%82%E4%BD%8E%E3%81%84%E6%95%B0%E5%80%A4%E3%81%AFUbuntu%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%80%81%E3%81%93%E3%82%8C%E3%81%AFUnityGUI%E3%81%AB%E8%B5%B7%E5%9B%A0%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSTRONG%3E%E7%B5%90%E8%AB%96%EF%BC%9A%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ECAAM%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%8B%E3%80%81%E4%B8%8D%E9%81%A9%E5%88%87%E3%81%AA%E3%83%86%E3%82%B9%E3%83%88%E6%89%8B%E9%A0%86%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSTRONG%3E%E3%83%86%E3%82%B9%E3%83%88%E6%89%8B%E9%A0%86%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AFiMX6Q%20Sabre%20SDP%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E3%81%AF%20Openssl%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Ecryptodev%20%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%81%AE%E6%9C%89%E7%84%A1%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%812%20%E3%81%A4%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3EOpenSSL%E3%82%B9%E3%83%94%E3%83%BC%E3%83%89%20%E2%80%93%20EVP%20AES-128-CBC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3EOpenSSL%20Speed%20%E2%80%93EVP%20AES-128-CBC%20-%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%20cryptodev%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%90%84%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8BOpenssl%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E8%8B%A5%E5%B9%B2%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUbuntu%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20openssl%201.0.0e%3C%2FP%3E%3CP%3ETimesys%3A%20openssl%201.0.1e%20(%E8%8B%B1%E8%AA%9E)%3C%2FP%3E%3CP%3ESDK%204.1.0%20%E3%81%AE%E5%A0%B4%E5%90%88%3AOpenSSL%E3%81%AE1.0.1c%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELinux%20%E3%81%AE%203%20%E3%81%A4%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%E3%83%86%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%204.0.0%20%E3%81%A8%20Ubuntu%20rootfs%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%20tarball%E3%80%82%3C%2FLI%3E%3CLI%3ETimesys%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A8%E3%83%AB%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FLI%3E%3CLI%3ESDK%204.1.0%20%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E6%9A%97%E5%8F%B7%E5%8C%96%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%9F%20LTIB%20%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%201%20%E3%81%A8%202%20%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%E3%80%81.config%20%E3%81%AB%20CRYPTODEV%20%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E8%A1%8C%E3%82%92%E5%90%AB%E3%82%80%3C%2FP%3E%3CP%3E%E3%80%8C%23CONFIG_CRYPTO_CRYPTODEV%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%8D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%203%20%E3%81%AB%E3%81%AF%20.config%20%E3%81%AE%E8%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%A8%E3%81%97%E3%81%A6%3C%2FP%3E%3CP%3E%E2%80%9CCONFIG_CRYPTO_CRYPTODEV%3Dy%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3%E3%81%A4%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%80%81%E5%86%85%E5%AE%B9%E3%81%8C%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%9F%E3%80%8C%2Fproc%2Fcrypto%E3%80%8D%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%2Fproc%2Fcrypto%20%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AB%E3%81%AF%E3%80%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%9A%97%E5%8F%B7%E5%8C%96%E6%96%B9%E5%BC%8F%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%20%22caam%22%20%E3%81%8C%E3%83%AA%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82aes%20%E3%81%AE%E5%8D%B0%E5%88%B7%E5%87%BA%E5%8A%9B%E4%BE%8B%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3EAME%20%3A%20CBC(AES)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%3A%20CBC-AES-CAAM%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3Emodule%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%20kernel%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%E5%84%AA%E5%85%88%E5%BA%A6%20%3A%203000%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%E5%8F%82%E7%85%A7CNT%3A1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%E3%82%BB%E3%83%AB%E3%83%95%E3%83%86%E3%82%B9%E3%83%88%3A%E5%90%88%E6%A0%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%E3%82%BF%E3%82%A4%E3%83%97%20%3A%20ABLKCIPHER%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%E9%9D%9E%E5%90%8C%E6%9C%9F%20%3A%20%E3%81%AF%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%82%A4%E3%82%BA%20%3A%2016%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%E6%9C%80%E5%B0%8F%E3%82%AD%E3%83%BC%E3%82%B5%E3%82%A4%E3%82%BA%20%3A%2016%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%E6%9C%80%E5%A4%A7%E3%82%AD%E3%83%BC%E3%82%B5%E3%82%A4%E3%82%BA%20%3A%2032%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3EIV%E3%82%B5%E3%82%A4%E3%82%BA%3A16%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3Egeniv%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%20eseqiv%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3%E3%81%A4%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AB%E3%80%81u-boot%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E3%80%8Ccaam%E3%80%8D%E3%81%A8%E3%80%8Cenable_wait_mode%3Doff%E3%80%8D%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20%233%20%E3%81%AE%E3%81%BF%E3%81%AB%E3%80%81%22%2Fdev%2Fcrypto%22%20%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%20%22%2Fproc%2Fcrypto%22%20%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%20%3CSTRONG%3E%E3%81%AE%E4%B8%A1%E6%96%B9%3C%2FSTRONG%3E%20%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3Eroot%40freescale%20~%24%20cd%20%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3Eroot%40freescale%20%2F%24%20ls%20%2Fproc%2Fcr*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%2Fproc%2Fcrypto%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3Eroot%40freescale%20%2F%24%20ls%20%2Fdev%2Fcr*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%2Fdev%2Fcrypto%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3Eroot%40freescale%20%2F%24%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%86%E3%82%B9%E3%83%88%20%231%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%83%93%E3%83%AB%E3%83%89%204.1.0CAAM%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84OpenSSL%E9%80%9F%E5%BA%A6%E3%83%86%E3%82%B9%E3%83%88%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eroot%40freescale%20~%24%20openssl%20%E9%80%9F%E5%BA%A6%20-evp%20AES-128-CBC%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eaes-128-cbc%20%E3%82%92%2016%20%E3%82%B5%E3%82%A4%E3%82%BA%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%203%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3A%20aes-128-cbc%20%E3%82%92%202.94%20%E7%A7%92%E3%81%A7%203471184%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eaes-128-cbc%20%E3%82%92%2064%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%203%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3A%20aes-128-cbc%20%E3%82%92%203.00%20%E7%A7%92%E3%81%A7986286%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eaes-128-cbc%20%E3%82%92%20256%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%203%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81aes-128-cbc%20%E3%81%AF%202.93%20%E7%A7%92%E3%81%A7%20249743%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E1024%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%20aes-128-cbc%20%E3%82%92%203%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3A%2064343%20aes-128-cbc%20%E3%82%92%203.00%20%E7%A7%92%E3%81%A7%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E8192%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%20aes-128-cbc%20%E3%82%92%203%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%817954%20aes-128-cbc%20%E3%81%8C%202.96%20%E7%A7%92%E3%81%A7%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3EOpenSSL%201.0.1c%202012%E5%B9%B45%E6%9C%8810%E6%97%A5%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E6%A7%8B%E7%AF%89%E6%97%A5%3A%20Sat%20Sep%207%2018%3A47%3A34%20PDT%202013%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3ABN(64%2C32)%20rc4(ptr%2Cchar)%20des(idx%2Ccisc%2C16%2Clong)%20AES(%E9%83%A8%E5%88%86)%20idea(int)%20Blowfish(ptr)%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3A%20gcc%20-fPIC%20-DOPENSSL_PIC%20-DOPENSSL_THREADS%20-D_REENTRANT%20-DDSO_DLFCN%20-DHAVE_DLFCN_H%20-DL_ENDIAN%20-DTERMIO%20-O3%20-fomit-frame-pointer%20-Wall%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E3%80%8C%E6%95%B0%E5%80%A4%E3%80%8D%E3%81%AF%E3%80%81%E6%AF%8E%E7%A7%92%E6%95%B0%E5%8D%83%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E3%82%BF%E3%82%A4%E3%83%97%2016%20%E3%83%90%E3%82%A4%E3%83%88%2064%20%E3%83%90%E3%82%A4%E3%83%88%20256%20%E3%83%90%E3%82%A4%E3%83%88%201024%20%E3%83%90%E3%82%A4%E3%83%88%208192%20%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eaes-128-cbc%2018890.80k%26nbsp%3B%26nbsp%3B%26nbsp%3B%2021040.77k%26nbsp%3B%26nbsp%3B%26nbsp%3B%2021820.55k%2021962.41k%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSTRONG%3E22013.23k%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eroot%40freescale%20~%24%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%86%E3%82%B9%E3%83%88%20%232%20-%20%2Fdev%2Fcrypto%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%20openssd%20%E3%81%AE%20Timesys%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%93%E3%83%AB%E3%83%89%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%23%20OpenSSL%E3%81%AE%E9%80%9F%E5%BA%A6%20-EVP%20AES-128-CBC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eaes-128-cbc%20%E3%82%92%2016%20%E3%82%B5%E3%82%A4%E3%82%BA%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%203%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3A%20aes-128-cbc%20%E3%82%92%203.00%20%E7%A7%92%E3%81%A7%203361305%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eaes-128-cbc%20%E3%82%92%2064%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%203%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81aes-128-cbc%20924423%203.00%20%E7%A7%92%E3%81%A7%20aes-128-cbc%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eaes-128-cbc%20%E3%82%92%20256%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%203%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81aes-128-cbc%20236623%203.00%20%E7%A7%92%E3%81%A7%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E1024%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%20aes-128-cbc%20%E3%82%92%203%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%8159967%20aes-128-cbc%20%E3%81%8C%203.00%20%E7%A7%92%E3%81%A7%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E8192%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%20aes-128-cbc%20%E3%82%92%203%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%817514%20aes-128-cbc%20%E3%81%8C%203.00%20%E7%A7%92%E3%81%A7%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3EOpenSSL%201.0.1e2013%E5%B9%B42%E6%9C%8811%E6%97%A5%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E6%A7%8B%E7%AF%89%E6%97%A5%3A%20Thu%20Sep%205%2021%3A54%3A37%20EDT%202013%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3ABN(64%2C32)%20RC4(PTR%2CChar)%20DES(IDX%2CCISC%2C16%2CLONG)%20AES(%E3%83%91%E3%83%BC%E3%82%B7%E3%83%A3%E3%83%AB)%20Blowfish(PTR)%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3A%20armv7l-timesys-linux-gnueabi-gcc%20-fPIC%20-DOPENSSL_PIC%20-DOPENSSL_THREADS%20-D_REENTRANT%20-DDSO_DLFCN%20-DHAVE_DLFCN_H%20-I%2Fhere%2Fworkdir%2Ffactory%2Fbuild_armv7l-times%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eys-linux-gnueabi%2Ftoolchain%2Fusr%2Finclude%20-DL_ENDIAN%20-DTERMIO%20-DOPENSSL_NO_KRB5%20-DOPENSSL_NO_IDEA%20-DOPENSSL_NO_MDC2%20-DOPENSSL_NO_RC5%20-os%20-pipe%20-Wa%2C--noexecstack%20-Wall%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E3%80%8C%E6%95%B0%E5%80%A4%E3%80%8D%E3%81%AF%E3%80%81%E6%AF%8E%E7%A7%92%E6%95%B0%E5%8D%83%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E3%82%BF%E3%82%A4%E3%83%97%2016%20%E3%83%90%E3%82%A4%E3%83%88%2064%20%E3%83%90%E3%82%A4%E3%83%88%20256%20%E3%83%90%E3%82%A4%E3%83%88%201024%20%E3%83%90%E3%82%A4%E3%83%88%208192%20%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eaes-128-cbc%2017926.96k%26nbsp%3B%26nbsp%3B%26nbsp%3B%2019721.02k%26nbsp%3B%26nbsp%3B%26nbsp%3B%2020191.83k%2020468.74k%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSTRONG%3E20518.23k%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%23%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%86%E3%82%B9%E3%83%88%20%233%20-%20Ubuntu%20rootfs%20%E3%81%A8%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eroot%40linaro-ubuntu-desktop%3A%2F%23%20openssl%20%E9%80%9F%E5%BA%A6%20-evp%20AES-128-CBC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E16%20%E3%82%B5%E3%82%A4%E3%82%BA%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%20aes-128-cbc%20%E3%82%92%203%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3A%20aes-128-cbc%20%E3%82%92%202.98%20%E7%A7%92%E3%81%A7%203030128%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eaes-128-cbc%20%E3%82%92%2064%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%203%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3A%20aes-128-cbc%20%E3%82%92%203.00%20%E7%A7%92%E3%81%A7%20852897%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E256%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7aes-128-cbc%E3%82%923%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3A3.00%E7%A7%92%E3%81%A7aes-128-cbc%E3%82%92220572%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E1024%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%20aes-128-cbc%20%E3%82%92%203%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3A%2055534%20aes-128-cbc%20%E3%82%92%203.00%20%E7%A7%92%E3%81%A7%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E8192%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%20aes-128-cbc%20%E3%82%92%203%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%816846%20aes-128-cbc%20%E3%81%8C%202.95%20%E7%A7%92%E3%81%A7%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3EOpenSSL%201.0.0e2011%E5%B9%B49%E6%9C%886%E6%97%A5%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E4%BD%9C%E6%88%90%E6%97%A5%3A%20Wed%20Oct%205%2001%3A45%3A02%20UTC%202011%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3ABN(64%2C32)%20RC4(PTR%2CChar)%20DES(IDX%2CCISC%2C16%2CLONG)%20AES(%E3%83%91%E3%83%BC%E3%82%B7%E3%83%A3%E3%83%AB)%20Blowfish(PTR)%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3A%20cc%20-fPIC%20-DOPENSSL_PIC%20-DZLIB%20-DOPENSSL_THREADS%20-D_REENTRANT%20-DDSO_DLFCN%20-DHAVE_DLFCN_H%20-DL_ENDIAN%20-DTERMIO%20-O2%20-Wa%2C--noexecstack%20-g%20-Wall%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E3%80%8C%E6%95%B0%E5%80%A4%E3%80%8D%E3%81%AF%E3%80%81%E6%AF%8E%E7%A7%92%E6%95%B0%E5%8D%83%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E3%82%BF%E3%82%A4%E3%83%97%2016%20%E3%83%90%E3%82%A4%E3%83%88%2064%20%E3%83%90%E3%82%A4%E3%83%88%20256%20%E3%83%90%E3%82%A4%E3%83%88%201024%20%E3%83%90%E3%82%A4%E3%83%88%208192%20%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eaes-128-cbc%2016269.14k%26nbsp%3B%26nbsp%3B%26nbsp%3B%2018195.14k%26nbsp%3B%26nbsp%3B%26nbsp%3B%2018822.14k%2018955.61k%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSTRONG%3E19010.99k%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eroot%40linaro-ubuntu-desktop%3A%2F%23%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%86%E3%82%B9%E3%83%88%20%234%20-%20SDK%204.1.0openssl%20%E9%80%9F%E5%BA%A6%E3%83%86%E3%82%B9%E3%83%88%20with%20%22%2Fdev%2Fcrypto%22%20.%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eroot%40freescale%20~%24%20openssl%20%E9%80%9F%E5%BA%A6%20-EVP%20AES-128-CBC%20-%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3cryptodev%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E7%84%A1%E5%8A%B9%E3%81%AA%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%20%22cryptodev%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E716715216%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A25066067%3ADSO%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%3ADLFCN_LOAD%3A%E5%85%B1%E6%9C%89%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%81%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3Adso_dlfcn.c%3A187%3A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D(%2Fusr%2Flib%2Fengines%2Flibcryptodev.so)%3A%2Fusr%2Flib%2Fja%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eines%2Flibcryptodev.so%3A%20%E5%85%B1%E6%9C%89%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E716715216%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A25070067%3ADSO%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%3ADSO_load%3A%E5%85%B1%E6%9C%89%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%81%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3Adso_lib.c%3A244%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E716715216%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A260B6084%3A%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%3ADYNAMIC_LOAD%3ADSO%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3Aeng_dyn.c%3A450%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E716715216%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A2606A074%3A%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%3AENGINE_by_id%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3Aeng_list.c%3A417%3Aid%3Dcryptodev%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E716715216%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A25066067%3ADSO%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%3ADLFCN_LOAD%3A%E5%85%B1%E6%9C%89%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%81%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3Adso_dlfcn.c%3A187%3Afilename(libcryptodev.so)%3Alibcryptodev.so%3A%E9%96%8B%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E5%85%B1%E6%9C%89%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E716715216%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A25070067%3ADSO%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%3ADSO_load%3A%E5%85%B1%E6%9C%89%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%81%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3Adso_lib.c%3A244%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E716715216%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A260B6084%3A%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%3ADYNAMIC_LOAD%3ADSO%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3Aeng_dyn.c%3A450%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eaes-128-cbc%20%E3%82%92%2016%20%E3%82%B5%E3%82%A4%E3%82%BA%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%203%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3A%20aes-128-cbc%20%E3%82%92%203.00%20%E7%A7%92%E3%81%A7%203572980%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eaes-128-cbc%20%E3%82%92%2064%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%203%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81aes-128-cbc%20%E3%81%AF%202.94%20%E7%A7%92%E3%81%A7%20966002%20%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eaes-128-cbc%20%E3%82%92%20256%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%203%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3A%20aes-128-cbc%20%E3%82%92%203.00%20%E7%A7%92%E3%81%A7255307%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E1024%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%20aes-128-cbc%20%E3%82%92%203%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%8162967%20aes-128-cbc%20%E3%81%8C%202.93%20%E7%A7%92%E3%81%A7%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E8192%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%20aes-128-cbc%20%E3%82%92%203%20%E7%A7%92%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%817890%20aes-128-cbc%20%E3%81%8C%202.94%20%E7%A7%92%E3%81%A7%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3EOpenSSL%201.0.1c%202012%E5%B9%B45%E6%9C%8810%E6%97%A5%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E6%A7%8B%E7%AF%89%E6%97%A5%3A%20Sat%20Sep%207%2018%3A47%3A34%20PDT%202013%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3ABN(64%2C32)%20rc4(ptr%2Cchar)%20des(idx%2Ccisc%2C16%2Clong)%20AES(%E9%83%A8%E5%88%86)%20idea(int)%20Blowfish(ptr)%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3A%20gcc%20-fPIC%20-DOPENSSL_PIC%20-DOPENSSL_THREADS%20-D_REENTRANT%20-DDSO_DLFCN%20-DHAVE_DLFCN_H%20-DL_ENDIAN%20-DTERMIO%20-O3%20-fomit-frame-pointer%20-Wall%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E3%80%8C%E6%95%B0%E5%80%A4%E3%80%8D%E3%81%AF%E3%80%81%E6%AF%8E%E7%A7%92%E6%95%B0%E5%8D%83%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3E%E3%82%BF%E3%82%A4%E3%83%97%2016%20%E3%83%90%E3%82%A4%E3%83%88%2064%20%E3%83%90%E3%82%A4%E3%83%88%20256%20%E3%83%90%E3%82%A4%E3%83%88%201024%20%E3%83%90%E3%82%A4%E3%83%88%208192%20%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eaes-128-cbc%2019055.89k%26nbsp%3B%26nbsp%3B%26nbsp%3B%2021028.61k%26nbsp%3B%26nbsp%3B%26nbsp%3B%2021786.20k%2022006.21k%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSTRONG%3E21984.65k%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Courier%20New'%3B%22%3Eroot%40freescale%20~%24%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%E7%AD%94%E3%81%88%3A%3C%2FP%3E%3CP%3ECAAM%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%85%AC%E5%BC%8F%E3%81%AEFreescale%20BSP%E3%81%AE%E6%9C%80%E8%BF%91%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81OpenSSL%E3%82%92CAAM%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E4%B8%8B%E3%81%A7%E5%A6%A5%E5%BD%93%E3%81%AA%E9%80%9F%E3%81%95%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AB%E3%81%AF%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F318188%23318188%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F318188%23318188%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Flog%2F%3Fh%3Dimx_3.0.35_4.0.0%22%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Flog%2F%3Fh%3Dimx_3.0.35_4.0.0%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%E3%83%91%E3%83%83%E3%83%81%E3%81%B8%E3%81%AE%E7%9B%B4%E6%8E%A5%E3%83%AA%E3%83%B3%E3%82%AF%3A%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Fcommit%2F%3Fh%3Dimx_3.0.35_4.0.0%26amp%3Bid%3D6068d7a77b2101c172fc2f003f90b1febbf99505%22%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%20text-decoration%3A%20underline%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Fcommit%2F%3Fh%3Dimx_3.0.35_4.0.0%26amp%3Bid%3D6068d7a77b2101c172fc2f003f90b1febbf99505%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Fcommit%2F%3Fh%3Dimx_3.0.35_4.0.0%26amp%3Bid%3Db30237c79003223c6e8035d5be183cd4f0b469f9%22%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Fcommit%2F%3Fh%3Dimx_3.0.35_4.0.0%26amp%3Bid%3Db30237c79003223c6e8035d5be183cd4f0b469f9%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1122946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎09-17-2013 01:55 AM
更新者:
