Prevent PMIC PF0100 Backfeed on i.MX6 Designs
Freescale's PF0100 PMIC should have VDDIO power tied to the same supply as the associated I2C supply on MX6.
There is a momentary on-chip sneak path on power-up if VDDIO is wired per the i.MX6 SABRE-AI automotive development platform. As a result, I2C power rail P3V3_DELAYED rises prematurely due to backfeed from P3V3 through the I2C port.
Note that on SABRE-AI, P3V3 powers up before P3V3_DELAYED.
Existing SABRE-AI design: PF0100 VDDIO is wired to P3V3.
Corrective action for mass production: Wire PF0100 VDDIO to P3V3_DELAYED; same supply as the associated I2C supplies on MX6 (NVCC_EIM0 and NVCC_GPIO).
Laboratory results attached.
%3CLINGO-SUB%20id%3D%22lingo-sub-1100764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPrevent%20PMIC%20PF0100%20Backfeed%20on%20i.MX6%20Designs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFreescale's%20PF0100%20PMIC%20should%20have%20VDDIO%20power%20tied%20to%20the%20same%20supply%20as%20the%20associated%20I2C%20supply%20on%20MX6.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThere%20is%20a%20momentary%20on-chip%20sneak%20path%20on%20power-up%20if%20VDDIO%20is%20wired%20per%20the%20i.MX6%20SABRE-AI%20automotive%20development%20platform.%20As%20a%20result%2C%20I2C%20power%20rail%20P3V3_DELAYED%20rises%20prematurely%20due%20to%20backfeed%20from%20P3V3%20through%20the%20I2C%20port.%3C%2FP%3E%3CP%3ENote%20that%20on%20SABRE-AI%2C%20P3V3%20powers%20up%20before%20P3V3_DELAYED.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EExisting%20SABRE-AI%20design%3A%20PF0100%20VDDIO%20is%20wired%20to%20P3V3.%3C%2FP%3E%3CP%3ECorrective%20action%20for%20mass%20production%3A%20Wire%20PF0100%20VDDIO%20to%20P3V3_DELAYED%3B%20same%20supply%20as%20the%20associated%20I2C%20supplies%20on%20MX6%20(NVCC_EIM0%20and%20NVCC_GPIO).%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELaboratory%20results%20attached.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1100764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6DL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6S%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6SL%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎11-20-2012 10:56 AM
Updated by:
