Patch to enable SSI Master Mode when using ASRC_P2P function based on Kernel 3.0.35 for I.MX6DL/DQ SebreSD boards
When using SSI Slave Mode for ASRC_P2P function (https://community.freescale.com/docs/DOC-95342), the waveform of the converted 24bit data is abnormal(have some values between 0 and 1). When using SSI Master Mode, these abnormal data disappear. This patch shows how to enable SSI Master Mode based on ASRC_P2P patches.
Because SSI Master Mode uses fixed data width for LRCLK(32bits for each L or R), and the SSI Dual FIFO Mode is not supported for ASRC_P2P, the converted 16bit data is not well supported in this patch.
Suggestions:
If you want to convert the audio data to 16bit, you can use SSI Slave Mode; if you want to convert the audio data to 24bit, you can use SSI Master Mode.
添付
コメント
good patch
_at
Hi Lei Ge,
I had used above patch. It is for Normal Audio Playback (ASRC added in between PLAYBACK path & uses only one OUT CLK source i.e OUTCLK_SSI2_TX while IN CLK source is INCLK_NONE) and working perfectly fine!.
Now, I want to use ASRC in between Recording Path.I had tried following setup (taking above patch for reference):
1.  Request DMA channel for P2P:
        - DMA Request-SSI RX0
        - P2P DMA request-ASRC RX1
    Configured abvoe channel as Slave DMA channel. Input src is SSI-1 RX0, output dst is ASRC RX1 & direction is DMA_DEV_TO_DEV
2.  Request DMA channel for P2M:
        - DMA request-ASRC TX1
    Configured abvoe channel as Slave DMA channel. Input src is ASRC TX1, output dst is MEMORY & direction is DMA_FROM_DEV
SSI is configured as SLAVE I2S device.
Configuratin of ASRC:
    config.input_word_width = ASRC_WIDTH_24_BIT;
    config.output_word_width = ASRC_WIDTH_24_BIT;
    config.pair = iprtd->asrc_index; [ASRC_PAIR_A]
    config.channel_num = channel;    [2]
    config.input_sample_rate = 48000;
    config.output_sample_rate = 44100;
    config.inclk = INCLK_SSI1_RX;       [clk coming from SSI RX & its slave device]
    config.outclk = OUTCLK_SSI2_TX;     [clk coming from playback codec, SSI is master I2S (same as above patch)]
I had verified that both clock coming to ASRC.
My Result:
I received 'blank' data from MEMORY
Can you help me out, why i received 'blank' data. Or something is missing in above setup.
-Ankit.
_at
Hello All,
Found the solution: Configure SSI-1  & AUDMUX's ports to ASYNC MODE. Otherwise, SSI-1 never get clock on SRCK.
-Ankit.
Can you attach or share the patch in community?
_at
Hi Lei Ge,
I am attaching patch at following locatin Audio LOST after ~10 hrs on i.MX 6Q for your reference. Please review it & give comments upon it.
Now, We got Audio lost after ~10 hrs after this attached patch. Issue explained in above link.
- We able to play smoothly till 10 hrs.
_at
Hi Lei Ge,
Can you please give a comments over last attached patch here-Audio LOST after ~10 hrs on i.MX 6Q?
-Ankit.
%3CLINGO-SUB%20id%3D%22lingo-sub-1122599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB3.0.35%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8FASRC_P2P%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%ABSSI%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81I.MX6DL%2FDQ%20SebreSD%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EASRC_P2P%E6%A9%9F%E8%83%BD(%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95342%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-95342%3C%2FA%3E)%E3%81%ABSSI%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%A4%89%E6%8F%9B%E3%81%95%E3%82%8C%E3%81%9F24%E3%83%93%E3%83%83%E3%83%88%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E6%B3%A2%E5%BD%A2%E3%81%8C%E7%95%B0%E5%B8%B8%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99(0%E3%81%8B%E3%82%891%E3%81%AE%E9%96%93%E3%81%AE%E5%80%A4%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%E3%80%82SSI%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E7%95%B0%E5%B8%B8%E3%81%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E6%B6%88%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81ASRC_P2P%E3%83%91%E3%83%83%E3%83%81%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6SSI%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESSI%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%20LRCLK%20%E3%81%AB%E5%9B%BA%E5%AE%9A%E3%83%87%E3%83%BC%E3%82%BF%E5%B9%85%20(L%20%E3%81%BE%E3%81%9F%E3%81%AF%20R%20%E3%81%94%E3%81%A8%E3%81%AB%2032%E3%83%93%E3%83%83%E3%83%88)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81SSI%20%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%20FIFO%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%20ASRC_P2P%20%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E5%A4%89%E6%8F%9B%E3%81%95%E3%82%8C%E3%81%9F%2016%20%E3%83%93%E3%83%83%E3%83%88%20%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E5%8D%81%E5%88%86%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8F%90%E6%A1%88%EF%BC%9A%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%82%9216%E3%83%93%E3%83%83%E3%83%88%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81SSI%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%82%9224%E3%83%93%E3%83%83%E3%83%88%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81SSI%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1122599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EASRC_P2P%E6%A9%9F%E8%83%BD(%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95342%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-95342%3C%2FA%3E)%E3%81%ABSSI%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%A4%89%E6%8F%9B%E3%81%95%E3%82%8C%E3%81%9F24%E3%83%93%E3%83%83%E3%83%88%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E6%B3%A2%E5%BD%A2%E3%81%8C%E7%95%B0%E5%B8%B8%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99(0%E3%81%8B%E3%82%891%E3%81%AE%E9%96%93%E3%81%AE%E5%80%A4%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%E3%80%82SSI%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E7%95%B0%E5%B8%B8%E3%81%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E6%B6%88%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81ASRC_P2P%E3%83%91%E3%83%83%E3%83%81%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6SSI%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESSI%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%20LRCLK%20%E3%81%AB%E5%9B%BA%E5%AE%9A%E3%83%87%E3%83%BC%E3%82%BF%E5%B9%85%20(L%20%E3%81%BE%E3%81%9F%E3%81%AF%20R%20%E3%81%94%E3%81%A8%E3%81%AB%2032%E3%83%93%E3%83%83%E3%83%88)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81SSI%20%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%20FIFO%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%20ASRC_P2P%20%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E5%A4%89%E6%8F%9B%E3%81%95%E3%82%8C%E3%81%9F%2016%20%E3%83%93%E3%83%83%E3%83%88%20%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E5%8D%81%E5%88%86%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8F%90%E6%A1%88%EF%BC%9A%3C%2FP%3E%3CP%3E%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%82%9216%E3%83%93%E3%83%83%E3%83%88%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81SSI%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%82%9224%E3%83%93%E3%83%83%E3%83%88%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81SSI%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB3.0.35%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8FASRC_P2P%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%ABSSI%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81I.MX6DL%2FDQ%20SebreSD%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%9F%E3%82%8A%E3%80%81%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%A7%E5%85%B1%E6%9C%89%E3%81%97%E3%81%9F%E3%82%8A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB3.0.35%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8FASRC_P2P%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%ABSSI%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%83%91%E3%83%83%E3%83%81I.MX6DL%2FDQ%20SebreSD%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%89%AF%E3%81%84%E3%83%91%E3%83%83%E3%83%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎08-06-2013 10:56 PM
更新者:
