OpenCL Hello World
OpenCL Hello World
OpenCL Hello World
Abstract
This is a small tutorial about running a simple OpenCL application in
an i.MX6Q. It covers a very small introduction to OpenCL, the explanation
of the code and how to compile and run it.
Requirements
Any i.MX6Q board.
Linux BSP with the gpu-viv-bin-mx6q package (for instructions on how to build the BSP, check the BSP Users Guide)
OpenCL overview
OpenCL allows any program to use the GPGPU features of the GC2000 (General-Purpose Computing on Graphics Processing Units) that means to use the i.MX6Q GPU processing power in any program.
OpenCL uses kernels which are functions that can be executed in the GPU. These functions must be written in a C99 like code. In our current GPU there
is no scheduling so each kernel will execute in a FIFO fashion. iMx6Q GPU is OpenCL 1.1 EP conformant.
The Code
The example provided here performs a simple addition of arrays in the GPU. The header needed to use openCL is cl.h and is under /usr/include/CL in your BSP
rootfs when you install the gpu-viv-bin-mx6q package. The header is typically included like this: #include <CL/cl.h> The libraries needed to link the program are libGAL.so and libOpenCL.so those are under /usr/lib in your BSP rootfs.
For details on the OpenCL API check the khronos page: http://www.khronos.org/opencl/
Our kernel source is as follows:
__kernel void VectorAdd(__global int* c, __global int* a,__global int* b)
     // Index of the elements to add
     unsigned int n = get_global_id(0);
     // Sum the nth element of vectors a and b and store in c
     c[n] = a[n] + b[n];
The kernel is declared with the signature
    __kernel void VectorAdd(__global int* c, __global int* a,__global int* b).
This takes vectors a and b as arguments adds them and stores the result in
the vector c. It looks like a normal C99 method except for the keywords kernel
and global. kernel tells the compiler this function is a kernel, global tells the
compiler this attributes are of global address space.
get_global_id built-in function
This function will tell us to which index of the vector this kernel corresponds
to. And in the last line the vectors are added. Below is the full source code
commented.
// Demo OpenCL application to compute a simple vector addition
// computation between 2 arrays on the GPU
#include <stdio.h>
#include <stdlib.h>
#include <CL/cl.h>
// OpenCL source code
const char* OpenCLSource[] = {
"__kernel void VectorAdd(__global int* c, __global int* a,__global int* b)",
" // Index of the elements to add \n",
" unsigned int n = get_global_id(0);",
" // Sum the nth element of vectors a and b and store in c \n",
" c[n] = a[n] + b[n];",
// Some interesting data for the vectors
int InitialData1[20] = {37,50,54,50,56,0,43,43,74,71,32,36,16,43,56,100,50,25,15,17};
int InitialData2[20] = {35,51,54,58,55,32,36,69,27,39,35,40,16,44,55,14,58,75,18,15};
// Number of elements in the vectors to be added
#define SIZE 100
// Main function
int main(int argc, char **argv)
     // Two integer source vectors in Host memory
     int HostVector1[SIZE], HostVector2[SIZE];
     //Output Vector
     int HostOutputVector[SIZE];
     // Initialize with some interesting repeating data
     for(int c = 0; c < SIZE; c++)
          HostVector1[c] = InitialData1[c%20];
          HostVector2[c] = InitialData2[c%20];
          HostOutputVector[c] = 0;
     //Get an OpenCL platform
     cl_platform_id cpPlatform;
     clGetPlatformIDs(1, &cpPlatform, NULL);
     // Get a GPU device
     cl_device_id cdDevice;
     clGetDeviceIDs(cpPlatform, CL_DEVICE_TYPE_GPU, 1, &cdDevice, NULL);
     char cBuffer[1024];
     clGetDeviceInfo(cdDevice, CL_DEVICE_NAME, sizeof(cBuffer), &cBuffer, NULL);
     printf("CL_DEVICE_NAME: %s\n", cBuffer);
     clGetDeviceInfo(cdDevice, CL_DRIVER_VERSION, sizeof(cBuffer), &cBuffer, NULL);
     printf("CL_DRIVER_VERSION: %s\n\n", cBuffer);
     // Create a context to run OpenCL enabled GPU
     cl_context GPUContext = clCreateContextFromType(0, CL_DEVICE_TYPE_GPU, NULL, NULL, NULL);
     // Create a command-queue on the GPU device
     cl_command_queue cqCommandQueue = clCreateCommandQueue(GPUContext, cdDevice, 0, NULL);
     // Allocate GPU memory for source vectors AND initialize from CPU memory
     cl_mem GPUVector1 = clCreateBuffer(GPUContext, CL_MEM_READ_ONLY |
     CL_MEM_COPY_HOST_PTR, sizeof(int) * SIZE, HostVector1, NULL);
     cl_mem GPUVector2 = clCreateBuffer(GPUContext, CL_MEM_READ_ONLY |
     CL_MEM_COPY_HOST_PTR, sizeof(int) * SIZE, HostVector2, NULL);
     // Allocate output memory on GPU
     cl_mem GPUOutputVector = clCreateBuffer(GPUContext, CL_MEM_WRITE_ONLY,
     sizeof(int) * SIZE, NULL, NULL);
     // Create OpenCL program with source code
     cl_program OpenCLProgram = clCreateProgramWithSource(GPUContext, 7, OpenCLSource, NULL, NULL);
     // Build the program (OpenCL JIT compilation)
     clBuildProgram(OpenCLProgram, 0, NULL, NULL, NULL, NULL);
     // Create a handle to the compiled OpenCL function (Kernel)
     cl_kernel OpenCLVectorAdd = clCreateKernel(OpenCLProgram, "VectorAdd", NULL);
     // In the next step we associate the GPU memory with the Kernel arguments
     clSetKernelArg(OpenCLVectorAdd, 0, sizeof(cl_mem), (void*)&GPUOutputVector);
     clSetKernelArg(OpenCLVectorAdd, 1, sizeof(cl_mem), (void*)&GPUVector1);
     clSetKernelArg(OpenCLVectorAdd, 2, sizeof(cl_mem), (void*)&GPUVector2);
     // Launch the Kernel on the GPU
     // This kernel only uses global data
     size_t WorkSize[1] = {SIZE}; // one dimensional Range
     clEnqueueNDRangeKernel(cqCommandQueue, OpenCLVectorAdd, 1, NULL,
     WorkSize, NULL, 0, NULL, NULL);
     // Copy the output in GPU memory back to CPU memory
     clEnqueueReadBuffer(cqCommandQueue, GPUOutputVector, CL_TRUE, 0,
     SIZE * sizeof(int), HostOutputVector, 0, NULL, NULL);
     // Cleanup
     clReleaseKernel(OpenCLVectorAdd);
     clReleaseProgram(OpenCLProgram);
     clReleaseCommandQueue(cqCommandQueue);
     clReleaseContext(GPUContext);
     clReleaseMemObject(GPUVector1);
     clReleaseMemObject(GPUVector2);
     clReleaseMemObject(GPUOutputVector);
     for( int i =0 ; i < SIZE; i++)
          printf("[%d + %d = %d]\n",HostVector1[i], HostVector2[i], HostOutputVector[i]);
     return 0;
How to compile in Host
Get to your ltib folder and run
$./ltib m shell
This way you will be using the cross compiler ltib uses and the default include and lib directories will be the ones in your bsp. Then run
LTIB> gcc cl_sample.c -lGAL -lOpenCL -o cl_sample.
How to run in the i.MX6Q
Insert the GPU module
root@freescale/home/user $ modprobe galcore
Copy the compiled CL program and then run
root@freescale /home/user$ ./cl_sample
References
[1] ttp://www.khronos.org/opencl/
Original Attachment has been moved to: libOpenCL.so.zip
Original Attachment has been moved to: libCLC_Android.so.zip
Original Attachment has been moved to: libOpenCL_Android.so.zip
Original Attachment has been moved to: libCLC.so.zip
Labels (2)
Tags (2)
Comments
I am going to check for more information about CL on Android and let you know soon as possible.
Andre
Hi,spark zh:
are you solve this error? I meet this error on imx8 too, can you give me some advices?
Hi ,sateeshpedagadi,
Have you solved this error? I meet this erro on imx8,Can you give me some advices?
%3CLINGO-SUB%20id%3D%22lingo-sub-1113358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%E8%A6%81%E7%B4%84%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E7%B0%A1%E5%8D%98%E3%81%AAOpenCL%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%3C%2FP%3E%3CP%3Ei.MX6Q%E3%81%A7%E3%81%99%E3%80%82OpenCL%E3%81%AE%E3%81%94%E3%81%8F%E5%B0%8F%E3%81%95%E3%81%AA%E7%B4%B9%E4%BB%8B%E3%80%81%E8%AA%AC%E6%98%8E%E3%82%92%E3%82%AB%E3%83%90%E3%83%BC%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%96%B9%E6%B3%95%E3%81%A8%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%E8%A6%81%E4%BB%B6%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E4%BB%BB%E6%84%8F%E3%81%AEi.MX6Q%E3%83%9C%E3%83%BC%E3%83%89%E3%80%82%3C%2FP%3E%3CP%3ELinux%20BSP%20%E3%81%A8%20gpu-viv-bin-mx6q%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%20(BSP%20%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81BSP%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3EOpenCL%20%E3%81%AE%E6%A6%82%E8%A6%81%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EOpenCL%E3%81%AF%E3%80%81GC2000(General-Purpose%20Computing%20on%20Graphics%20Processing%20Units)%E3%81%AEGPGPU%E6%A9%9F%E8%83%BD%E3%82%92%E3%81%A9%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E3%82%82%E5%88%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%80%81i.MX6Q%20GPU%E3%81%AE%E5%87%A6%E7%90%86%E8%83%BD%E5%8A%9B%E3%82%92%E4%BB%BB%E6%84%8F%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EOpenCL%E3%81%AF%E3%80%81GPU%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%E9%96%A2%E6%95%B0%E3%81%A7%E3%81%82%E3%82%8B%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AF%E3%80%81C99%20%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E8%A8%98%E8%BF%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%81%AEGPU%E3%81%A7%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%AF%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E5%90%84%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF%20FIFO%20%E6%96%B9%E5%BC%8F%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82iMx6Q%20GPU%E3%81%AFOpenCL%201.1%20EP%E3%81%AB%E6%BA%96%E6%8B%A0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%E3%82%B3%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E7%A4%BA%E3%81%99%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81GPU%20%E3%81%A7%E9%85%8D%E5%88%97%E3%81%AE%E5%8D%98%E7%B4%94%E3%81%AA%E8%BF%BD%E5%8A%A0%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82openCL%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%98%E3%83%83%E3%83%80%E3%81%AF%20cl.h%20%E3%81%A7%E3%80%81BSP%20%E3%81%AE%20%2Fusr%2Finclude%2FCL%20%E3%81%AE%E4%B8%8B%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Erootfs%20%E3%81%AF%E3%80%81gpu-viv-bin-mx6q%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%A7%E3%81%99%E3%80%82%E9%80%9A%E5%B8%B8%E3%80%81%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%AF%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%23include%20%26lt%3B%20CL%2Fcl.h%20%3C%2FSPAN%3E%20%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%26gt%3B%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AF%20libGAL.so%20%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AE%20libOpenCL.so%20%E3%81%AF%20BSP%20rootfs%20%E3%81%AE%20%2Fusr%2Flib%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EOpenCL%20API%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3CSPAN%3Ekhronos%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%3C%2FSPAN%3E%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.khronos.org%2Fopencl%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.khronos.org%2Fopencl%2F%3C%2FA%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E__kernel%20void%20VectorAdd(__global%20int*%20c%E3%80%81%20__global%20int*%20a%2C__global%20int*%20b)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E8%A6%81%E7%B4%A0%E3%81%AE%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E7%AC%A6%E5%8F%B7%E3%81%AA%E3%81%97%20int%20n%20%3D%20get_global_id(0)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%20a%20%E3%81%A8%20b%20%E3%81%AE%20n%20%E7%95%AA%E7%9B%AE%E3%81%AE%E8%A6%81%E7%B4%A0%E3%82%92%E5%90%88%E8%A8%88%E3%81%97%E3%80%81c%20%E3%81%AB%E6%A0%BC%E7%B4%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Ec%5Bn%5D%20%3D%20a%5Bn%5D%20%2B%20b%5Bn%5D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF%E7%BD%B2%E5%90%8D%E3%81%A7%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E__kernel%20void%20VectorAdd(__global%20int*%20c%E3%80%81__global%20int*%20a%2C__global%20int*%20b)%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%20a%20%E3%81%A8%20b%20%E3%82%92%E5%BC%95%E6%95%B0%E3%81%A8%E3%81%97%E3%81%A6%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8A%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E5%8A%A0%E7%AE%97%E3%81%97%E3%80%81%E7%B5%90%E6%9E%9C%E3%82%92%3C%2FP%3E%3CP%3E%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%20c.%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%82%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%89kernel%E3%82%92%E9%99%A4%E3%81%84%E3%81%A6%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AEC99%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E3%80%82kernel%20%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%8C%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AB%E4%BC%9D%E3%81%88%E3%80%81global%20%E3%81%AF%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%20%E3%81%93%E3%81%AE%E5%B1%9E%E6%80%A7%E3%81%AF%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E7%A9%BA%E9%96%93%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Eget_global_id%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E9%96%A2%E6%95%B0%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%8C%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E3%81%AE%E3%81%A9%E3%81%AE%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%81%8B%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E5%AE%9B%E5%85%88%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E6%9C%80%E5%BE%8C%E3%81%AE%E8%A1%8C%E3%81%AB%E3%81%AF%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E3%81%8C%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AF%E5%AE%8C%E5%85%A8%E3%81%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%2F%2F************************************************************%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E7%B0%A1%E5%8D%98%E3%81%AA%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E5%8A%A0%E7%AE%97%E3%82%92%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%87%E3%83%A2OpenCL%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EGPU%E4%B8%8A%E3%81%AE2%E3%81%A4%E3%81%AE%E9%85%8D%E5%88%97%E9%96%93%E3%81%AE%E8%A8%88%E7%AE%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%2F%2F%20************************************************************%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%23include%20%3CSTDIO.H%3E%3C%2FSTDIO.H%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%23include%20%3CSTDLIB.H%3E%3C%2FSTDLIB.H%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%23include%20%26lt%3B%20CL%2Fcl.h%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%2F%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EOpenCL%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Econst%20char*%20OpenCLSource%5B%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%22__kernel%20void%20VectorAdd(__global%20int*%20c%2C%20__global%20int*%20a%2C__global%20int*%20b)%22%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%22%7B%22%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%22%20%2F%2F%20%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E8%A6%81%E7%B4%A0%E3%81%AE%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%5Cn%22%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%22%20%E7%AC%A6%E5%8F%B7%E3%81%AA%E3%81%97%20int%20n%20%3D%20get_global_id(0)%3B%22%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%22%20%2F%2F%20%E3%83%99%E3%82%AF%E3%83%88%E3%83%ABa%E3%81%A8b%E3%81%AEn%E7%95%AA%E7%9B%AE%E3%81%AE%E8%A6%81%E7%B4%A0%E3%82%92%E5%90%88%E8%A8%88%E3%81%97%E3%80%81c%20%5Cn%22%E3%81%AB%E6%A0%BC%E7%B4%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%22%20c%5Bn%5D%20%3D%20a%5Bn%5D%20%2B%20b%5Bn%5D%3B%22%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%22%7D%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E8%88%88%E5%91%B3%E6%B7%B1%E3%81%84%E3%83%87%E3%83%BC%E3%82%BF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Eint%20InitialData1%5B20%5D%20%3D%20%7B37%2C50%2C54%2C50%2C56%2C0%2C43%2C43%2C74%2C71%2C32%2C36%2C16%2C43%2C56%2C100%2C50%2C25%2C15%2C17%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Eint%20InitialData2%5B20%5D%20%3D%20%7B35%2C51%2C54%2C58%2C55%2C32%2C36%2C69%2C27%2C39%2C35%2C40%2C16%2C44%2C55%2C14%2C58%2C75%2C18%2C15%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E5%86%85%E3%81%AE%E8%A6%81%E7%B4%A0%E3%81%AE%E6%95%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%23define%20%E3%82%B5%E3%82%A4%E3%82%BA%20100%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E4%B8%BB%E3%81%AA%E6%A9%9F%E8%83%BD%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%2F%2F%20************************************************************%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Eint%20main(int%20argc%2C%20char%20**argv)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E3%83%9B%E3%82%B9%E3%83%88%E3%83%A1%E3%83%A2%E3%83%AA%E5%86%85%E3%81%AE2%E3%81%A4%E3%81%AE%E6%95%B4%E6%95%B0%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Eint%20HostVector1%5B%E3%82%B5%E3%82%A4%E3%82%BA%5D%2C%20HostVector2%5B%E3%82%B5%E3%82%A4%E3%82%BA%5D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E5%87%BA%E5%8A%9B%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Eint%20HostOutputVector%5B%E3%82%B5%E3%82%A4%E3%82%BA%5D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E8%88%88%E5%91%B3%E6%B7%B1%E3%81%84%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E3%83%87%E3%83%BC%E3%82%BF%E3%81%A7%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Efor(int%20c%20%3D%200%3B%20c%20%26lt%3B%20%E3%82%B5%E3%82%A4%E3%82%BA%3B%20c%2B%2B)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EHostVector1%5Bc%5D%20%3D%20InitialData1%5Bc%2520%5D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EHostVector2%5Bc%5D%20%3D%20InitialData2%5Bc%2520%5D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E3%83%9B%E3%82%B9%E3%83%88%E5%87%BA%E5%8A%9B%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%5Bc%5D%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EOpenCL%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%92%E5%85%A5%E6%89%8B%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Ecl_platform_id%20cpPlatform%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EclGetPlatformIDs(1%2C%20%26amp%3BcpPlatform%2C%20NULL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EGPU%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E5%85%A5%E6%89%8B%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Ecl_device_id%20cd%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EclGetDeviceIDs(cpPlatform%2C%20CL_DEVICE_TYPE_GPU%2C%201%2C%20%26amp%3BcdDevice%2C%20NULL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Echar%20cBuffer%5B1024%5D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EclGetDeviceInfo(cdDevice%2C%20CL_DEVICE_NAME%2C%20sizeof(cBuffer)%2C%20%26amp%3BcBuffer%2C%20NULL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Eprintf(%22CL_DEVICE_NAME%3A%20%25s%5Cn%22%2C%20cBuffer)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EclGetDeviceInfo(cdDevice%2C%20CL_DRIVER_VERSION%2C%20sizeof(cBuffer)%2C%20%26amp%3BcBuffer%2C%20NULL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Eprintf(%22CL_DRIVER_VERSION%3A%20%25s%5Cn%5Cn%22%2C%20cBuffer)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EOpenCL%20%E5%AF%BE%E5%BF%9C%20GPU%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cl_context%20GPUContext%20%3D%20clCreateContextFromType(0%2C%20CL_DEVICE_TYPE_GPU%2C%20NULL%2C%20NULL%2C%20NULL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EGPU%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%8A%E3%81%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%E3%82%AD%E3%83%A5%E3%83%BC%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Ecl_command_queue%20cqCommandQueue%20%3D%20clCreateCommandQueue(GPUContext%2C%20cdDevice%2C%200%2C%20NULL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%E3%81%AB%20GPU%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%80%81CPU%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%8B%E3%82%89%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Ecl_mem%20GPUVector1%20%3D%20clCreateBuffer(GPUContext%2C%20CL_MEM_READ_ONLY%20%7C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3ECL_MEM_COPY_HOST_PTR%2C%20sizeof(int)%20*%20SIZE%2C%20HostVector1%2C%20NULL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Ecl_mem%20GPUVector2%20%3D%20clCreateBuffer(GPUContext%2C%20CL_MEM_READ_ONLY%20%7C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3ECL_MEM_COPY_HOST_PTR%2C%20sizeof(int)%20*%20SIZE%2C%20HostVector2%2C%20NULL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EGPU%20%E3%81%AB%E5%87%BA%E5%8A%9B%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Ecl_mem%20GPUOutputVector%20%3D%20clCreateBuffer(GPUContext%2C%20CL_MEM_WRITE_ONLY%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Esizeof(int)%20*%20%E3%82%B5%E3%82%A4%E3%82%BA%2C%20null%2C%20null)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7OpenCL%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E4%BD%9C%E6%88%90%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Ecl_program%20OpenCLProgram%20%3D%20clCreateProgramWithSource(GPUContext%2C%207%2C%20OpenCLSource%2C%20NULL%2C%20NULL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B(OpenCL%20JIT%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EclBuildProgram(OpenCLProgram%2C%200%2C%20NULL%2C%20NULL%2C%20NULL%2C%20NULL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9FOpenCL%E9%96%A2%E6%95%B0%E3%81%B8%E3%81%AE%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B(%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Ecl_kernel%20OpenCLVectorAdd%20%3D%20clCreateKernel(OpenCLProgram%2C%20%22VectorAdd%22%2C%20NULL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E6%AC%A1%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A7%E3%81%AF%E3%80%81GPU%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E5%BC%95%E6%95%B0%E3%81%AB%E9%96%A2%E9%80%A3%E4%BB%98%E3%81%91%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EclSetKernelArg(OpenCLVectorAdd%2C%200%2C%20sizeof(cl_mem)%2C%20(void*)%26amp%3BGPUOutputVector)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EclSetKernelArg(OpenCLVectorAdd%2C%201%2C%20sizeof(cl_mem)%2C%20(void*)%26amp%3BGPUVector1)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EclSetKernelArg(OpenCLVectorAdd%2C%202%2C%20sizeof(cl_mem)%2C%20(void*)%26amp%3BGPUVector2)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EGPU%E3%81%A7%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E3%81%93%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Esize_t%20WorkSize%5B1%5D%20%3D%20%7BSIZE%7D%3B1%E6%AC%A1%E5%85%83%E3%81%AE%E7%AF%84%E5%9B%B2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EclEnqueueNDRangeKernel(cqCommandQueue%2C%20OpenCLVectorAdd%2C%201%2C%20NULL%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EWorkSize%2C%20NULL%2C%200%2C%20NULL%2C%20NULL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EGPU%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%20CPU%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E6%88%BB%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EclEnqueueReadBuffer(cqCommandQueue%2C%20GPUOutputVector%2C%20CL_TRUE%2C%200%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3ESIZE%20*%20sizeof(int)%2C%20HostOutputVector%2C%200%2C%20NULL%2C%20NULL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EclReleaseKernel(OpenCLVectorAdd)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EclReleaseProgram(OpenCLProgram)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EclReleaseCommandQueue(cqCommandQueue)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EclReleaseContext(GPUContext)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EclReleaseMemObject(GPUVector1)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EclReleaseMemObject(GPUVector2)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EclReleaseMemObject(GPUOutputVector)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20for(%20int%20i%20%3D0%20%3B%20i%20%26lt%3B%20SIZE%3B%20i%2B%2B)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Eprintf(%22%5B%25d%20%2B%20%25d%20%3D%20%25d%5D%5Cn%22%2CHostVector1%5Bi%5D%2C%20HostVector2%5Bi%5D%2C%20HostOutputVector%5Bi%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20return%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%E3%83%9B%E3%82%B9%E3%83%88%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3Eltib%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%24.%2Fltib%20m%20%E3%82%B7%E3%82%A7%E3%83%AB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81ltib%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEinclude%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%A8lib%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%8Cbsp%E5%86%85%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%3B%22%3ELTIB%26gt%3B%20gcc%20cl_sample.c-lGAL%20-lOpenCL%20-o%20cl_sample.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3Ei.MX6Q%E3%81%A7%E3%81%AE%E5%AE%9F%E8%A1%8C%E6%96%B9%E6%B3%95%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EGPU%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E6%8C%BF%E5%85%A5%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Eroot%40freescale%2F%E3%83%9B%E3%83%BC%E3%83%A0%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%20%24%20modprobe%20galcore%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%B8%88%E3%81%BF%E3%81%AE%20CL%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Eroot%40freescale%20%2Fhome%2Fuser%24%20.%2Fcl_sample%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%E5%8F%82%E8%80%83%E6%83%85%E5%A0%B1%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%5B1%5D%20ttp%3A%2F%2F%3CA%20href%3D%22http%3A%2F%2Fwww.khronos.org%2Fopencl%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ewww.khronos.org%2Fopencl%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%85%83%E3%81%AE%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-339904%22%20target%3D%22_blank%22%3ElibOpenCL.so.zip%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%85%83%E3%81%AE%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-339904%22%20target%3D%22_blank%22%3ElibCLC_Android.so.zip%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%85%83%E3%81%AE%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-339904%22%20target%3D%22_blank%22%3ElibOpenCL_Android.so.zip%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%85%83%E3%81%AE%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-339904%22%20target%3D%22_blank%22%3ElibCLC.so.zip%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1113358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113411%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113411%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%2Csateeshpedagadi%2C%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E7%A7%81%E3%81%AFimx8%E3%81%A7%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E4%BC%9A%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E7%A7%81%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2Cspark%20zh%3A%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3Fimx8%E3%81%A7%E3%82%82%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EAndroid%E3%81%AECL%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%A9%B3%E7%B4%B0%E6%83%85%E5%A0%B1%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A0%E3%81%91%E6%97%A9%E3%81%8F%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EAndre%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Andre%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ei.MX6q%20Android%206.0%20BSP(%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB4.1.15)%E3%81%A7OpenCL%20Hello%20world%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%82%82%E3%80%81%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EAndroid.mk%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AF%3CSPAN%3E%E3%80%81%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%AB%20libVSC.so%20%E3%82%92%E5%90%AB%E3%82%81%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%88objectdump%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%9D%E3%82%8C%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%89%E3%81%9D%E3%81%86%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81gcXXXXX%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%88%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%82%92%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%88%E3%80%8CgcSHADER_Destroy%E3%80%8D%E3%81%8C%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%80%8C%2Fsystem%2Flib%2FlibOpenCL.so%E3%80%8D%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93)%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ELOCAL_SHARED_LIBRARIES%20%3A%3D%20%5C%3CBR%20%2F%3E%20libGAL%20%5C%3CBR%20%2F%3E%20libVSC%20%5C%3CBR%20%2F%3E%20libOpenCL%20%5C%3CBR%20%2F%3E%20libCLC%20%5C%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ElibVSC%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%80%81iMX6%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81i.MX6%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81clBuildProgram%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%8C%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%88%E3%80%8D%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81logcat%E3%81%A7%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%82%E3%81%AE%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E01-01%2018%3A15%3A21.069%203478%203478%20F%20libc%20%3A%20%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E4%BF%A1%E5%8F%B7%2011%20(SIGSEGV)%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%202%E3%80%81tid%203478%20%E3%81%AE%E9%9A%9C%E5%AE%B3%E8%BF%BD%E5%8A%A00xb6dd585c%20(opencl)%3CBR%20%2F%3E01-01%2018%3A15%3A21.171%20218%20218%20F%20DEBUG%20%3A%20***%20***%20***%20***%3CBR%20%2F%3E01-01%2018%3A15%3A21.171%20218%20218%20F%20DEBUG%20%3A%20%E3%83%93%E3%83%AB%E3%83%89%E3%83%95%E3%82%A3%E3%83%B3%E3%82%AC%E3%83%BC%E3%83%97%E3%83%AA%E3%83%B3%E3%83%88%3A%20'Ikegps%2Forca%2Forca%3A6.0.1%2F0.0.1-rc0%2F20171130%3Aeng%2Frelease-keys'%3CBR%20%2F%3E01-01%2018%3A15%3A21.171%20218%20F%20DEBUG%20%3A%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3A%20'0'%3CBR%20%2F%3E01-01%2018%3A15%3A21.171%20218%20F%20DEBUG%20%3A%20ABI%3A%20'arm'%3CBR%20%2F%3E01-01%2018%3A15%3A21.171%20218%20F%20DEBUG%20%3A%20pid%3A%203478%2C%20tid%3A%203478%2C%20name%3A%20opencl%20%26gt%3B%26gt%3B%26gt%3B%20opencl%20%26lt%3B%26lt%3B%26lt%3B%3CBR%20%2F%3E01-01%2018%3A15%3A21.172%20218%20F%20DEBUG%20%3A%20%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB%2011%20(SIGSEGV)%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%202%20(SEGV_ACCERR)%E3%80%81%E9%9A%9C%E5%AE%B3%20addr%200xb6dd585c%3CBR%20%2F%3E01-01%2018%3A15%3A21.177%20218%20F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3A%20r0%20b6a7d748%20r1%20b6ddcdd3%20r2%2000000001%20r3%2000000069%3CBR%20%2F%3E01-01%2018%3A15%3A21.177%20218%20F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3A%20r4%20b6a7d704%20r5%20ae4fc0d4%20r6%20b6dd585c%20r7%2000000000%3CBR%20%2F%3E01-01%2018%3A15%3A21.177%20218%20F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3A%20r8%20beb20550%20r9%20b6ddcdc8%20sl%200000004f%20fp%200000000e%3CBR%20%2F%3E01-01%2018%3A15%3A21.177%20218%20218%20F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3A%20ip%2000000064%20sp%20beb20448%20lr%20b6e66057%20pc%20b6e66066%20cpsr%2000010030%3CBR%20%2F%3E01-01%2018%3A15%3A21.181%20542%20612%20W%20NativeCrashListener%3Apid%203478%E3%81%AEProcessRecord%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E01-01%2018%3A15%3A21.196%20218%20F%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20%3CBR%20%2F%3E01-01%2018%3A15%3A21.196%20218%20F%20DEBUG%20%3A%20backtrace%3A%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20E%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3AAM%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%E5%A3%8A%E3%82%8C%E3%81%9F%E3%83%91%E3%82%A4%E3%83%97%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20DEBUG%20%3A%20%2300%20pc%2000015066%20%2Fsystem%2Flib%2FlibVSC.so%20(gcSHADER_AddAttribute%2B209)%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3A%20%2301%20pc%2000054f51%20%2Fsystem%2Flib%2FlibCLC.so%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3A%20%2302%20pc%2000026e31%20%2Fsystem%2Flib%2FlibCLC.so%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3A%20%2303%20pc%200002722f%20%2Fsystem%2Flib%2FlibCLC.so%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3A%20%2304%20pc%20000d319d%20%2Fsystem%2Flib%2FlibCLC.so%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3A%20%2305%20pc%20000f5913%20%2Fsystem%2Flib%2FlibCLC.so%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3A%20%2306%20pc%2000046e0d%20%2Fsystem%2Flib%2FlibCLC.so%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3A%20%2307%20pc%2000018aa1%20%2Fsystem%2Flib%2FlibCLC.so%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3A%20%2308%20pc%200003a7b7%20%2Fsystem%2Flib%2FlibCLC.so%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3A%20%2309%20pc%2000044d67%20%2Fsystem%2Flib%2FlibCLC.so%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3A%20%2310%20pc%2000018a65%20%2Fsystem%2Flib%2FlibCLC.so%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3A%20%2311%20pc%200003ed03%20%2Fsystem%2Flib%2FlibCLC.so%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20DEBUG%20%3A%20%2312%20pc%2000018435%20%2Fsystem%2Flib%2FlibCLC.so%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3A%20%2313%20pc%200003eba9%20%2Fsystem%2Flib%2FlibCLC.so%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20DEBUG%20%3A%20%2314%20pc%2000018435%20%2Fsystem%2Flib%2FlibCLC.so%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3A%20%2315%20pc%200001711f%20%2Fsystem%2Flib%2FlibCLC.so%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20DEBUG%20%3A%20%2316%20pc%2000017497%20%2Fsystem%2Flib%2FlibCLC.so%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3A%20%2317%20pc%2000015f0f%20%2Fsystem%2Flib%2FlibCLC.so%20(gcCompileKernel%2B42)%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3A%20%2318%20pc%200000bbb9%20%2Fsystem%2Flib%2FlibOpenCL.so%20(clBuildProgram%2B324)%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%3A%20%2319%20pc%2000000da1%20%2Fsystem%2Fbin%2Fopencl%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20DEBUG%20%3A%20%2320%20pc%2000017365%20%2Fsystem%2Flib%2Flibc.so%20(__libc_init%2B44)%3CBR%20%2F%3E01-01%2018%3A15%3A21.197%20218%20F%20DEBUG%20%3A%20%2321%20pc%2000001060%20%2Fsystem%2Fbin%2Fopencl%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%3EgcSHADER_AddAttribute%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%A8%E3%81%8D%E3%81%AB%E9%9A%9C%E5%AE%B3addr%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CSPAN%3E....%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%3E%3CSPAN%3E%20!%E3%81%93%E3%81%93%E3%81%AB%E3%81%82%E3%82%8BlibCLC_Android.so%E3%81%A8%3CSPAN%3E%3CSPAN%3ElibOpenCL_Android.so%3C%2FSPAN%3E%E3%81%8C%E6%96%B0%E3%81%97%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%2F%20Android%20BSP%E3%81%A7%E3%81%BE%E3%81%A0%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E8%AA%B0%E3%81%8B%E3%81%8C%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%B9%E3%83%BC%E3%83%84%E3%82%92%E4%BD%9C%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%3E%3CSPAN%3E%3CSPAN%3E%E7%A7%81%E3%81%AFLinux%204.1.15%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E3%81%A4%E3%82%82%E3%82%8A%E3%81%A7%E3%81%99BSP%E3%80%81%E3%81%97%E3%81%8B%E3%81%97%E3%80%81Android%E3%81%AE%E3%82%88%E3%81%86%E3%81%ABLinux%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%8B%E3%82%89SO%E3%82%92%E5%BC%95%E3%81%8D%E5%87%BA%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E7%A7%81%E3%81%AFAndroid%E3%81%8C%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AAlibc%E3%81%AA%E3%81%A9%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%3E%3CSPAN%3E%3CSPAN%3E%E4%BD%95%E3%81%8B%E6%83%85%E5%A0%B1%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fsuyouxin%2Fopencl-test-imx6%2Fblob%2Fmaster%2Fmain.c%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fsuyouxin%2Fopencl-test-imx6%2Fblob%2Fmaster%2Fmain.c%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%BBsuyouxin%2Fopencl-test-imx6%E3%83%BBGitHub%E3%81%AE%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%3E%3CSPAN%3E%3CSPAN%3E%E3%83%A8%E3%82%A6%E3%82%B7%E3%83%B3%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113407%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113407%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%B0%86%E6%9D%A5%E3%80%81%E4%BB%96%E3%81%AE%E8%AA%B0%E3%81%8B%E3%81%8C%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E7%A7%81%E3%81%AF%E7%A7%81%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%81%9D%E3%82%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%80%E5%88%9D%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%99%E3%81%B9%E3%81%8D%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%20libCLC.so%20%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%20-%20%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E7%97%87%E7%8A%B6%E3%81%AE%E3%82%88%E3%81%86%E3%81%ABclBuildProgram%E3%81%AF%E8%AA%AC%E6%98%8E%E3%81%AA%E3%81%97%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82libCLC.so%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81strace%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%82%E3%81%AE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81libCLC.so%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%A8%E3%81%97%E3%81%A6%E3%82%82%E3%80%81libCLC%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81clBuildProgram%E3%81%AF%E9%9D%99%E3%81%8B%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82ldd%20libCLC.so%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81libstdc%20%2B%2B%E3%82%92%26gt%3B%3D%203.20%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%A4%E3%81%84vivante%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AF%E3%80%81%E5%90%8C%E3%81%98%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%20-%20%E7%A7%81%E3%81%AF%E3%80%81%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E9%96%93%E3%81%A7%E3%81%8B%E3%81%AA%E3%82%8A%E5%A4%9A%E3%81%8F%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%A8%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%AE%E9%9D%9E%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ECL%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%93%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E8%A6%8B%E5%BD%93%E3%81%9F%E3%82%89%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E7%A7%81%E3%81%AE%E5%81%B4%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E7%A4%BA%E3%81%99%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%81%BE%E3%81%A8%E3%82%81%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AF%E3%80%81test.cl%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%A8%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%80%81%E6%9C%89%E5%8A%B9%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AB%E9%96%A2%E4%BF%82%E3%81%AA%E3%81%8F%E3%80%81%E7%A9%BA%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%83%AD%E3%82%B0%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Egpu_viv_bin%203.0.35%E3%81%8B%E3%82%89%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%A8%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A8%E4%BB%96%E3%81%AEOpenCL%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%96%B0%E3%81%97%E3%81%84GPU%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A7%E6%88%90%E5%8A%9F%E8%A3%8F%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99-%E5%8F%A4%E3%81%84%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%ABopencl%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E8%A9%A6%E3%81%BF%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%A8%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E8%89%AF%E3%81%84%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%AC%89%E3%81%97%E3%81%8F%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E----------------------------------------------%3C%2FP%3E%3CP%3E%23include%20%3CFSTREAM%3E%3C%2FFSTREAM%3E%3C%2FP%3E%3CP%3E%23include%20%3CIOSTREAM%3E%3C%2FIOSTREAM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23define%20__CL_ENABLE_EXCEPTIONS%3C%2FP%3E%3CP%3E%23include%20%26lt%3B%20CL%2Fcl.hpp%26gt%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eint%20main(int%20argc%2C%20char**%20argv)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3Estd%3A%3Avector%26lt%3B%3Aplatform%26gt%3B%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CP%3Estd%3A%3Avector%26lt%3B%3Adevice%26gt%3B%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ecl%3A%3AP%20latform%3A%3Aget(%26amp%3Bplatforms)%3B%3C%2FP%3E%3CP%3Eplatforms%5B0%5D.getDevices(CL_DEVICE_TYPE_ALL%2C%20%26amp%3B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ecl%3A%3AContext%20context(%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9)%3B%3C%2FP%3E%3CP%3Ecl%3A%3ACommandQueue%20queue(context%2C%20devices%5B0%5D)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Estd%3A%3Aifstream%20source_file(%22test.cl%22)%3B%3C%2FP%3E%3CP%3Estd%3A%3Astring%20source_string(std%3A%3Aistreambuf_iterator%3CCHAR%3E(source_file)%2C%20(std%3A%3Aistreambuf_iterator%3CCHAR%3E()))%3B%3C%2FCHAR%3E%3C%2FCHAR%3E%3C%2FP%3E%3CP%3Econst%20char*%20program_data%20%3D%20source_string.c_str()%3B%3C%2FP%3E%3CP%3Esize_t%20program_size%20%3D%20source_string.length()%3B%3C%2FP%3E%3CP%3Ecl%3A%3AP%20rogram%3A%3ASources%20source(1%2C%20std%3A%3Amake_pair(program_data%2C%20program_size))%3B%3C%2FP%3E%3CP%3Ecl%3A%3AP%20rogram%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0(%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9)%3B%3C%2FP%3E%3CP%3E%E8%A9%A6%E3%81%BF%E3%82%8B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FP%3E%3CP%3Eprogram.build(%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FP%3E%3CP%3Ecatch%20(cl%3A%3A%E3%82%A8%E3%83%A9%E3%83%BC%20e)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FP%3E%3CP%3Estd%3A%3Acout%20%26lt%3B%26lt%3B%20%22OpenCL%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%22%20%26lt%3B%26lt%3B%20e.what()%20%26lt%3B%26lt%3B%20%22%20%3A%20%22%20%26lt%3B%26lt%3B%20e.err()%20%26lt%3B%26lt%3B%20std%3A%3Aendl%3B%3C%2FP%3E%3CP%3Estd%3A%3Acout%20%26lt%3B%26lt%3B%20%22%E3%83%93%E3%83%AB%E3%83%89%E3%83%AD%E3%82%B0%3A%20%22%20%26lt%3B%26lt%3B%20program.getBuildInfo%3CCL_PROGRAM_BUILD_LOG%3E(devices%5B0%5D)%26lt%3B%26lt%3B%20std%3A%3Aendl%3B%3C%2FCL_PROGRAM_BUILD_LOG%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20return%201%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FP%3E%3CP%3Estd%3A%3Acout%20%26lt%3B%26lt%3B%20%22%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%22%20%26lt%3B%26lt%3B%20std%3A%3Aendl%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20return%200%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113404%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113404%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AE%E5%81%B4%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20-%20clBuildProgram%E3%81%AF%E3%80%81%E5%A4%96%E9%83%A8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%82%E3%82%8D%E3%81%86%E3%81%A8%E3%82%B3%E3%83%BC%E3%83%89%E5%86%85%E3%81%AE%E6%96%87%E5%AD%97%E5%88%97%E3%81%A7%E3%81%82%E3%82%8D%E3%81%86%E3%81%A8%E3%80%81%E7%A7%81%E3%81%8C%E3%81%9D%E3%82%8C%E3%82%92%E4%B8%8E%E3%81%88%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AB%E9%96%A2%E4%BF%82%E3%81%AA%E3%81%8F%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99(-11)%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%20%E3%83%AD%E3%82%B0%E3%81%AF%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82libCLC%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%AF%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%20-%20libCLC.so%20%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%82%82%E4%BD%95%E3%82%82%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%81%AFlibOpenCL%E3%81%A8libGAL%E3%81%AE%E3%81%BF%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFOpenCL%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E5%88%A5%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%B8%88%E3%81%BF%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E4%B8%8A%E3%81%AE%E5%90%8C%E3%81%98%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0ubuntu%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%A7opencl%E3%82%92%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81OpenCL%E5%81%B4%E3%81%A7%E6%AD%A3%E3%81%97%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8B%E3%81%AA%E3%82%8A%E8%87%AA%E4%BF%A1%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Keerecles%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A4%96%E9%83%A8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8B%E3%82%89%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E4%B8%8A%E3%81%AE%E4%BD%99%E5%88%86%E3%81%AA%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%82%84%E8%A1%8C%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%99%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B9%BE%E6%9D%AF%3C%2FP%3E%3CP%3Eandre%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20Andre%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E9%96%A2%E6%95%B0%20clBuildProgram()%3C%2FSPAN%3E%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF-11(%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20verdana%2C%20sans-serif%3B%20font-size%3A%2016px%3B%22%3ECL_BUILD_PROGRAM_FAILURE%3C%2FSPAN%3E)%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E9%96%A2%E6%95%B0%20%22clGetProgramBuildInfo%22%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%83%AD%E3%82%B0%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E7%A9%BA%E3%81%AE%E6%96%87%E5%AD%97%E5%88%97%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81CL_PROGRAM_BUILD_STATUS%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AE%E6%88%BB%E3%82%8A%E5%80%A4%E3%81%AFCL_BUILD_SUCCESS%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E3%80%8CclBuildProgram()%E3%80%8D%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%83%AD%E3%82%B0%E3%81%AF%E7%A9%BA%E3%81%A7%E3%81%82%E3%81%A3%E3%81%A6%E3%81%AF%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8B%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%AD%E3%83%BC%E3%83%AC%E3%83%AB%E3%82%BA%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113400%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113400%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EOpenCL%20%E3%82%A4%E3%83%B3%E3%83%88%E3%83%AD%E3%83%80%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E8%BF%BD%E5%8A%A0%E6%83%85%E5%A0%B1%3A%20%3CA%20href%3D%22http%3A%2F%2Fimxcv.blogspot.com.br%2F2015%2F09%2Fintroduction-to-imx6qd-gc2000-vivante.html%22%20title%3D%22http%3A%2F%2Fimxcv.blogspot.com.br%2F2015%2F09%2Fintroduction-to-imx6qd-gc2000-vivante.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EComputer%20Vision%20on%20i.MX%20Processors%3A%20Introduction%20to%20i.MX6Q%2FD%20(GC2000)%20Vivante%20OpenCL%20Embedded%20Profile%3C%2FA%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113399%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113399%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%82%A2%E3%83%8C%E3%82%B7%E3%83%A5%E3%83%AA%E3%83%BC%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%AF%E3%81%A9%E3%81%86%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%93%E3%82%8C%E3%81%A8%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPS.%20%E7%A7%81%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AFIMx6%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%82%B9%E3%83%91%E3%83%BC%E3%82%AF%E3%80%81%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%97%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%A7%E8%BF%94%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%8C%E3%82%B7%E3%83%A5%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSTRONG%3EHi%2C%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EAndroid%204.2.2%E3%81%A7libOpenCL_Android.so%E3%81%A8libCLC_Android.so%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81clBuildProgram(OpenCLProgram%2C%200%2C%20NULL%2C%20NULL%2C%20NULL%2C%20NULL)%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CEM%3E%5B10%3A28%3A25%5DE%20%2F%20OGL-JNI-Test(3508)%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AE%E6%A7%8B%E7%AF%89(clBuildingProgram)%3A-11%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%5B10%3A28%3A25%5DE%20%2F%20OGL-jni-Test(3508)%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E4%B8%80%E6%99%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB.%2Fcl-0DB401%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E7%AD%86%E8%A8%98%E7%94%A8%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%AA%B0%E3%81%8B%E3%81%8C%E3%81%9D%E3%82%8C%E3%81%AB%E4%BC%9A%E3%81%A3%E3%81%9F%3F%E4%BD%95%E3%81%8B%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CEM%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20clBuildProgram(OpenCLProgram%2C%200%2C%20NULL%2C%20NULL%2C%20NULL%2C%20NULL)%3B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Eif%20(%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20!%3D%20CL_SUCCESS)%20%7B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3ELOGE(%22%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%93%E3%83%AB%E3%83%89%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%20(clBuildingProgram)%3A%20%25d%5Cn%22%2C(int)status)%3B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20size_t%20len%3B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Echar%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%5B8%20*%201024%5D%3B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%3Eprintf(%22%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AE%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F!%5Cn%22)%3B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3EclGetProgramBuildInfo(OpenCLProgram%2C%20cdDevice%2C%20CL_PROGRAM_BUILD_LOG%2C%20sizeof(buffer)%2C%20buffer%2C%20%26amp%3Blen)%3B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3ELOGE(%22%25s%5Cn%22%2C%E3%83%90%E3%83%83%E3%83%95%E3%82%A1)%3B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2Feturn%20%3B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%82%A2%E3%83%B3%E3%82%AD%E3%83%83%E3%83%88%E3%80%81%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E4%BB%96%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%A7%E7%AD%94%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F(%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%A6)%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B9%BE%E6%9D%AF%3C%2FP%3E%3CP%3EAndre%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%94%E4%BF%A1%E3%81%8C%E9%81%85%E3%81%8F%E3%81%AA%E3%81%A3%E3%81%A6%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E6%83%85%E5%A0%B1%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%9F%E3%82%89%E3%81%99%E3%81%90%E3%81%AB%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Eandre%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113394%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113394%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Andre%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%85%A8%E4%BD%93%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3A%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F484166%23484166%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F484166%23484166%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%BF%9C%E7%AD%94%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-Ankit.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113393%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113393%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Ankit%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%87%AA%E5%88%86%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%85%A8%E4%BD%93%E3%82%92%E9%80%81%E3%81%A3%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EAndre%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3EHi%20Cao%2C%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%97%E3%81%A6%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E3%82%A2%E3%83%8C%E3%82%B7%E3%83%A5%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%A7%81%E3%81%AFlibOpenCL_Android.so%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6Android%204.0.4%E3%81%A7%E3%81%93%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E7%A7%81%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%87%BA%E3%81%BE%E3%81%99%3Alink_image%20%5B1936%5D%3A2599%E3%81%AF%20'cl_sample'%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%20'libOpenCL.so'%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%EF%BC%88reloc_library%20%5B1285%5D%3A2599%E3%81%AF%20'gcGetUserDebugOption'%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93...)%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92Android%E7%94%A8%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%80%E3%83%B3%E3%82%B9%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113390%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113390%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%9F%E3%82%B7%E3%82%A7%E3%83%AB%E3%80%81%E7%A7%81%E3%81%AFAndroid%E7%94%A8%E3%81%AE%20libOpenCL.so%20%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%93%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92android%204.0.4%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%87%BA%E3%81%BE%E3%81%99%3Alink_image%20%5B1936%5D%3A2599%E3%81%AF%20'cl_sample'%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%20'libOpenCL.so'%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F(reloc_library%20%5B1285%5D%3A2599%E3%81%AF%20'gcGetUserDebugOption'%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93...)%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%E3%82%92%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BD%95%E3%81%8B%E6%8F%90%E6%A1%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E6%95%AC%E5%85%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%A7%81%E3%81%AFAndroid%E7%94%A8%E3%81%AE%20libOpenCL.so%20%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%93%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92android%204.0.4%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%87%BA%E3%81%BE%E3%81%99%3A%20%3CEM%3Elink_image%20%5B1936%5D%3A2599%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%20'libOpenCL.so'%20for%20'%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Ecl_sample%3C%2FSPAN%3E'%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%EF%BC%88reloc_library%20%5B1285%5D%3A2599%E3%81%AF%20'gcGetUserDebugOption'%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93...)%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%E3%82%92%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FEM%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E4%BD%95%E3%81%8B%E3%81%97%E3%82%89%E3%81%AE%E4%B8%8D%E6%BA%80%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113388%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113388%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%82%B5%E3%83%86%E3%82%A3%E3%83%BC%E3%82%B7%E3%83%A5%E3%80%81%3C%2FP%3E%3CP%3E%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7libOpenCL_Android.so%E3%81%A8libCLC_Android.so%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%A6%E3%80%81%2F%20system%20%2F%20lib%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E5%85%A5%E3%82%8C%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%8C%E3%82%B7%E3%83%A5%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%9A%86%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3EGstreamer%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%ABGstreamer%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8B%E3%82%89OpenCL%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Egst-launch%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E4%BB%BB%E6%84%8F%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81gstreamer%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AEOpenCL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF1%E3%81%A4%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%ABGstreamer%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99(%E4%BE%8B%3Asampleocl-plugin)%20%E3%82%92%20Gstreamer%20%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E5%90%AB%E3%82%81%E3%81%BE%E3%81%99%E3%80%82%E3%80%8Csampleocl-plugin%E3%80%8D%E3%81%8B%E3%82%89%E3%80%81OpenCL%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81clCreateImage2D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A62%E3%81%A4%E3%81%AEImage2D%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%8A%E3%82%88%E3%81%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%AD%E3%83%A5%E3%83%BC%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AEsetargs(clSetKernelArg(.....%2C%20%26amp%3Bsrcimage2D)%2C%20clSetKernelArg(....%2C%20%26amp%3Bdstimage3D))%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20clEnqueueNDRangeKernel%20%E3%82%92%202%20%E6%AC%A1%E5%85%83%E3%81%AE%20NDRangeKernel%20%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E4%BD%9C%E6%A5%AD%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%20global%5B0%5D%3D640%2C%20global%5B1%5D%3D480%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%26amp%3B%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E5%AE%9F%E8%A1%8C%E5%AE%8C%E4%BA%86%E3%82%92%E5%BE%85%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF%E3%80%81SRC%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8B%E3%82%89DST%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%ABmemcpy%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%B9%E3%83%8B%E3%83%9A%E3%83%83%E3%83%88%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%A7%8B%E3%82%81%E3%82%8B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E__constant%20sampler_t%E3%82%B5%E3%83%B3%E3%83%97%E3%83%A9%E3%83%BC%20%3D%20CLK_NORMALIZED_COORDS_FALSE%20%7CCLK_ADDRESS_CLAMP_TO_EDGE%20%7CCLK_FILTER_NEAREST%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22line-height%3A%201.5em%3B%20font-size%3A%2010pt%3B%22%3E_kernel%20%E3%83%9C%E3%82%A4%E3%83%89copy_image%20(%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E__read_only%20image2d_t%E5%85%A5%E5%8A%9B%E3%80%81%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E__write_only%20image2d_t%E5%87%BA%E5%8A%9B)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%7B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%20const%20int2%20pos%20%3D%20%7Bget_global_id(0)%2C%20get_global_id(1)%7D%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Efloat4%20%E5%90%88%E8%A8%88%20%3D%20read_imagef(%E5%85%A5%E5%8A%9B%2C%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%A9%E3%83%BC%2C%20pos)%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22line-height%3A%201.5em%3B%20font-size%3A%2010pt%3B%22%3Ewrite_imagef%20(%E5%87%BA%E5%8A%9B%2C%20(int2)(pos.x%2Cpos.y)%E3%80%81%E5%90%88%E8%A8%88)%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%7D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%20END%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E8%A6%B3%E5%AF%9F%E3%81%95%E3%82%8C%E3%81%9F%E3%81%AE%E3%81%AF%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81SRC%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8B%E3%82%89DST%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB1%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%81%A0%E3%81%91%E3%80%81%E3%81%A4%E3%81%BE%E3%82%8A(x%20%3D%200%E3%80%81y%20%3D%200)%E3%81%8B%E3%82%89%E3%81%AE%E3%81%BF%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E4%BD%9C%E6%A5%AD%E9%A0%85%E7%9B%AE%20%7Bglobal%5B0%5D%3D640%2C%20global%5B0%5D%3D480%20%7D%20%E3%81%AF%E5%90%8C%E3%81%98%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%89%E3%81%9A%E3%80%81%E7%B5%90%E6%9E%9C%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%92%20SRC%20%E3%81%8B%E3%82%89%20DST%20%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF1%E3%81%A4%E3%81%AE%E5%8D%98%E7%B4%94%E3%81%AA%E5%8D%98%E4%BD%93%E3%83%86%E3%82%B9%E3%83%88(%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB)%E3%81%8B%E3%82%89%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E5%90%8C%E3%81%98%E3%81%93%E3%81%A8%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%9F%2F%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%81%9D%E3%82%8C%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%83%8D%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82SRC%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E5%85%A8%E4%BD%93%E3%82%92%20DST%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%A7%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egstreamer%E3%81%A7%E3%81%AF%E3%80%811%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%81%AE%E3%81%BF%E3%81%8C%E3%82%B3%E3%83%94%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E4%BD%95%E3%81%8B%E6%82%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81gstreamer%E3%81%8B%E3%82%89OpenCL%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E4%BB%96%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFYOCTO%E3%83%93%E3%83%AB%E3%83%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-Ankit.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%82%A2%E3%83%8C%E3%82%B7%E3%83%A5%E3%83%AA%E3%83%BC%E3%80%81%E3%83%9F%E3%82%B7%E3%82%A7%E3%83%AB%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E6%9C%80%E6%96%B0%E6%83%85%E5%A0%B1%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%A8%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%86%E3%82%A3%E3%83%BC%E3%82%B7%E3%83%A5%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113385%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113385%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fanushreemoholkar%22%20target%3D%22_blank%22%3E%E3%82%A2%E3%83%8C%E3%82%B7%E3%83%A5%E3%83%AA%E3%83%BC%E3%83%A2%E3%83%9B%E3%83%AB%E3%82%AB%E3%83%AB%3C%2FA%3E%20%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%9F%E3%82%B7%E3%82%A7%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%A7%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BlibOpenCL%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8libCLC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92Android4.3%E3%81%AEimx6Q%E3%83%AF%E3%83%B3%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82OpenCL%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E6%83%85%E5%A0%B1%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E9%80%9A%E5%B8%B8%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81cl%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81clBuildProgram%20%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%AF%E5%A4%B1%E6%95%97%E3%81%97%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%82%AF%E3%82%A8%E3%83%AA%E3%81%AF%20'failed%20to%20open%20temporary%20file.%2Fcl-xxxxxx%20for%20writing'%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E4%BB%A5%E4%B8%8A%E3%81%AF%E9%80%B2%E3%82%81%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%81%93%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AB%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%8C%E4%BD%BF%E7%94%A8%E4%BA%88%E5%AE%9A%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E5%A0%B4%E6%89%80%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%86%E3%82%A3%E3%83%BC%E3%82%B7%E3%83%A5%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EJessie%E3%82%92OpenCL%E7%94%A8%E3%81%AB%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%80%8B%E4%BA%BA%E7%9A%84%E3%81%AB%E3%81%AF%E6%B0%97%E3%81%AB%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AFOpenCL%20EP%E3%81%AE%E5%AE%9F%E8%A3%85%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E6%95%B0%E9%80%B1%E9%96%93%E3%82%92%E8%B2%BB%E3%82%84%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82EP%20(embedded%20profile)%20%E5%AE%9F%E8%A3%85%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%80%83%E3%81%88%E3%82%8B%E3%81%A8%E3%80%81%E5%87%A6%E7%90%86%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%A8%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%20API%20(%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%82%A2%E3%83%88%E3%83%9F%E3%83%83%E3%82%AF%E3%81%AA%E3%81%97)%20%E3%81%AB%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%88%B6%E9%99%90%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFwbquard%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7openCL%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%AA%E3%83%9A%E3%83%AC%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AFdebian%20Jessie%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AEBSP%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AF%E3%81%A9%E3%81%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%82%B8%E3%82%A7%E3%83%AD%E3%83%BC%E3%83%A0%E3%80%81gpu%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E3%81%BE%E3%81%9F%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%8D%E3%82%8B%E4%BB%96%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88(CL%E3%81%BE%E3%81%9F%E3%81%AFGLES)%E3%81%8C%E3%81%99%E3%81%A7%E3%81%AB%E6%A7%8B%E7%AF%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A0%E3%81%91%E3%81%AB%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EAndre%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3suse%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8Bimx6q%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E9%96%A2%E6%95%B0clGetDeviceIds%E3%81%AF%E7%A7%81%E3%81%AB%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E4%B8%8E%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%E3%82%B0%E3%83%A9%E3%82%A4%E3%83%B3%E3%83%89%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E9%96%A2%E6%95%B0%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%A8%E3%81%8D%E3%81%AB%E3%82%A8%E3%83%AD%E3%82%A2%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99(gc_hal_user_query%E3%81%A7gcoHAL_QuerySeparated3D2D)%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFopenCL%E3%81%AE%E5%88%9D%E5%BF%83%E8%80%85%E3%81%A7%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%8A%A9%E3%81%91%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B8%E3%82%A7%E3%83%AD%E3%83%BC%E3%83%A0%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EclBuildProgram%E9%96%A2%E6%95%B0%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E8%A1%8C%E3%82%8F%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%BF%83%E9%85%8D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%A6%8B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%8C%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E7%A7%81%E3%81%8C%E3%81%9D%E3%81%86%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3ElibCLC%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E6%96%B9%E6%B3%95%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%93%E3%81%8B%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B9%BE%E7%87%A5%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100694%22%20target%3D%22_blank%22%3EiMX6.pdf%20%E3%81%A7%E3%81%AE%20OpenCL%20%E3%81%AE%E4%BD%BF%E7%94%A8%E9%96%8B%E5%A7%8B%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%83%9B%E3%83%AF%E3%82%A4%E3%83%88%20%E3%83%9A%E3%83%BC%E3%83%91%E3%83%BC%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113376%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113376%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E8%89%AF%E3%81%84%E3%83%8F%E3%82%A6%E3%83%84%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%93%E3%81%93%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E8%B2%BC%E3%82%8A%E4%BB%98%E3%81%91%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EAndre%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%84%A1%E5%8A%B9%E3%81%AA%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FAndreSilva%22%20target%3D%22_blank%22%3E%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AC%E3%82%B7%E3%83%AB%E3%83%90%E3%80%81%3C%2FA%3E%20%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%9F%E3%82%B7%E3%82%A7%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ElibOpenCL.so%20%E3%81%AB%E3%81%AF%E9%96%A2%E6%95%B0%E3%81%AE%E5%AE%9F%E8%A3%85%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%AF%E5%B8%B8%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99(%E3%81%9F%E3%81%A8%E3%81%88%E7%A7%81%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E4%BE%8B%E3%82%92%3C%2FP%3E%3CP%3EAndroid)%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%8C%20libCLC.so%20%E3%82%92%E4%BD%BF%E3%82%8F%E3%81%AA%E3%81%84%E3%81%8B%E3%82%89%E3%81%AB%E9%81%95%E3%81%84%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AF%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AB%20libCLC.so%20%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%95%E3%81%9B%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%82%92%E6%AD%A3%E3%81%97%E3%81%84%E6%96%B9%E5%90%91%E3%81%AB%E5%B0%8E%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E4%BE%8B%E3%82%84%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B9%BE%E7%87%A5%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113373%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113373%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ElbCLC.so%20%E3%81%AF%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%9F%E3%82%B7%E3%82%A7%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9B%B3%E6%9B%B8%E9%A4%A8%E3%81%AE%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F!libOpenCL.so%20%E3%81%A7OpenCL%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81UDOO%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%93%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fmattscar%2Fopencl_device_test%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fmattscar%2Fopencl_device_test%3C%2FA%3E%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%8C%E8%87%AA%E5%88%86%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81CL_INVALID_KERNEL%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EclSetKernelArg%20%E9%96%A2%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%A0%E3%81%8B%E3%82%89%E3%80%81%E3%81%AA%E3%81%9C%E3%81%9D%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%92%E3%81%BE%E3%81%A0%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ElibCLC.c%E3%81%A8%E3%81%AF%E4%BD%95%E3%81%8B%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3E%E4%B9%BE%E7%87%A5%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113371%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113371%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AEWeb%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AB%E3%81%82%E3%82%8BAndroid%204.3%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81Android%20BSP%E3%81%A7CL%E3%82%92%E5%85%AC%E5%BC%8F%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%9F%E3%82%B7%E3%82%A7%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AFUdoo%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%2B-%E3%81%A8%E5%90%8C%E3%81%98%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E7%A7%81%E3%81%AF%E6%8E%A8%E6%B8%AC%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AF%E9%81%95%E3%81%84%E3%82%92%E7%94%9F%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%91%E3%81%B0%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9FCL%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%80%81%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AD%E3%82%A4%E3%83%89BSP%E3%80%82CL%E3%81%8C%E4%BB%8A%E3%81%AA%E3%81%8F%E3%81%A6%E3%82%82%E3%80%81CL%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E5%B0%86%E6%9D%A5%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AEBSP%E3%81%AF%E3%80%81%E3%83%AF%E3%83%B3%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E5%BD%BC%E3%82%89%E3%81%8C%E3%81%9D%E3%81%86%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AFCL%E3%81%8C%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E3%81%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AFAndroid%20BSP%E3%81%8C%E3%83%AF%E3%83%B3%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AEAndroid%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%9F%E3%82%B7%E3%82%A7%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%93%E3%81%AEudoo%E3%82%A6%E3%82%A7%E3%83%96%E3%82%B5%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89Android%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.udoo.org%2Fdownloads%2F%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.udoo.org%2Fdownloads%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E(%E7%8F%BE%E5%9C%A8%E3%80%814.2%20Android%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3Di.MX6Q%26amp%3Bfpsp%3D1%26amp%3Btab%3DDesign_Tools_Tab%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3Di.MX6Q%26amp%3Bfpsp%3D1%26amp%3Btab%3DDesign_Tools_Tab%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%82%B5%E3%82%B0%E3%82%AC%E3%82%B9%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B9%BE%E7%87%A5%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8BAndroid%20Freescale%20BSP%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%9F%E3%82%B7%E3%82%A7%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0(Ubuntu%2012.04.3%20by%20wandboard)%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Egcc%20-std%3Dc99%20opencl_sample.c-lOpenCL%20-lGAL%20-o%20opencl_sample%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B3%A8%E6%84%8F%3AGAL%E3%81%AE%E5%89%8D%E3%81%ABOpenCL%E3%82%92%E7%BD%AE%E3%81%8F%E3%81%A8%E3%80%81%E3%81%9D%E3%81%86%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%2Fusr%2Flib%2Fgcc%2Farm-linux-gnueabi%2F4.6%2F..%2F..%2F..%2F..%2Flib%2FlibOpenCL.so%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82'gcUNIFORM_SetValueF'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E6%A5%BD%E3%81%97%E3%81%BF%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B9%BE%E7%87%A5%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%ABAndroid%E7%94%A8%E3%81%AEopenCL%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%99%E3%81%90%E3%81%AB%E3%81%94%E9%80%A3%E7%B5%A1%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%9F%E3%82%B7%E3%82%A7%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AFandroid-ndk%E3%81%A7OpenCL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B9%BE%E7%87%A5%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2014-04-16%2016%3A10%20GMT%2B01%3A00%20Guillermo%20Michel%20Jimenez%20%26lt%3B%3C%2FP%3E%3CP%3Eadmin%40community.freescale.com%26gt%3B%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20level%3D%221%22%3E%3CP%3E%20%20%20%20%20%20%20%26lt%3B%26gt%3BOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%20by%20Guillermo%20Michel%20Jimenez%26lt%3B%26gt%3B%E7%9C%BA%E3%82%81%E3%82%8B%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%26lt%3B%26gt%3B%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113362%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113362%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECL%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3ENDK%E3%81%A7CL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82Linux%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%9F%E3%82%B7%E3%82%A7%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%82%82Android%E3%81%A7OpenCL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82(i.MX6%E3%80%81udoo%E3%83%9C%E3%83%BC%E3%83%89)%3C%2FP%3E%3CP%3ELinux%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%20libOpenCL.so%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%80%81Android%E3%81%AEudoo%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F(Android%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%AF%20libOpenCL.so%20%E3%81%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81)%E3%80%82%20%3C%2FP%3E%3CP%3E%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20%3CEM%3Eld-2.15.so%20%2F%20ld-linux.so.3%20%2F%20libc.so.6%20%2F%20libc-2.15.so%20%2F%20librt.so.1%E3%81%8A%E3%82%88%E3%81%B3%20librt-2.15.so%3C%2FEM%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFLinux%20Udoo%E3%81%A7%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92Android%E3%81%AEudoo%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BB%8A%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%87%BA%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-style%3A%20italic%3B%20font-size%3A%2015px%3B%20font-family%3A%20Arial%3B%22%3E01-02%2000%3A01%3A12.810%3AE%20%2F%20dalvikvm(3206)%3Adlopen(%22%2Fsystem%2Flib%2FlibOpenCL.so%22)%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%81%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%9Asoinfo_link_image%EF%BC%9A(linker.cpp%3A1635)%3A%E3%80%8ClibOpenCL.so%E3%80%8D%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%80%8Clibrt.so.1%E3%80%8D%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%81%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82soinfo_link_image(linker.cpp%3A1635)%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%99%3A%E3%80%8Clibrt.so.1%E3%80%8D%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%80%8Clibc.so.6%E3%80%8D%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E5%8E%9F%E5%9B%A0soinfo_relocate(linker.cpp%3A1178)%3A%E4%B8%8D%E6%98%8E%E3%81%AA%E5%86%8D%E9%85%8D%E7%BD%AE%E3%82%BF%E3%82%A4%E3%83%9719%20%40%200x689a13e0(1193)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2015px%3B%20font-family%3A%20Arial%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E3%82%82%E3%81%AE(%E3%81%9D%E3%82%8C%E3%81%BB%E3%81%A9%E5%A4%9A%E3%81%8F%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93)%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE.so%E3%81%8C%E7%A7%81%E3%81%AB%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81Android%20%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%20Linux%20%E7%94%A8%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%82%E3%81%A3%E3%81%A8%E6%83%85%E5%A0%B1%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E6%8C%87%E7%A4%BA%E3%81%A7%E7%A7%81%E3%82%92%E5%B0%8E%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%3CP%3E%E4%B9%BE%E7%87%A5%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ELinux%E7%94%A8%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7Android%E7%94%A8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AD%E3%82%A4%E3%83%89NDK%E4%B8%8A%E3%81%AECL%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%81%9E%E3%81%84%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81NDK-r9c%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81CL%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E4%BB%96%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%94%A8%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81OpenCL%20EP%E3%81%AB%E6%BA%96%E6%8B%A0%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81i.Mx6%20ICS%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBTW.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAndroid%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%ABCL%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%89%8B%E5%8B%95%E3%81%A7%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%9F%E3%82%B7%E3%82%A7%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AOpenCL%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81OpenCL%E3%81%A8%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E4%BE%8B%E3%81%AF%E3%80%81i.MX6%E3%81%AEAndroid%20v4.0.4(ICS)%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E6%84%9F%E8%AC%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎01-18-2013 02:07 PM
Updated by:
