Memory Management on i.MX6 Android
System Memory Usage and Configuration
Introduction
This document describes i.MX android memory usage, layout and configuration for the entire system.
Total DDR memory usage
When i.MX Android is running, the DDR memory will be used by the following components:
  • Linux Kernel reserved space, including:
    • kernel text, data section and initrd
    • kernel page tables
  • Normal zone space managed by kernel’s MM (high memory zone is also included)
    • Used by application by brk() or malloc() in libc
    • Used by kernel by mm api, like: kmalloc, dma_alloc, vmalloc
  • Reserved memory for GPU drivers, used by
    • GPU libs, drivers
    • Android surface view, normal surface buffers
    • VPUs working buffer and bitstream (we allocate the VPU buffer from GPU driver to make a unify method of allocation)
  • Reserved space for framebuffer BG triple buffers
    • Framebuffer display are always required to have triple and large buffers
Memory layout
The following diagram shows the default memory usage and layout on i.MX6Q/DL platform.
Memory configuration
According to different type of product and different hardware configurations (ddr size, screen resolution, camera), customer may do some configurations to the memory layout and usage to optimize their system. Some memory reservation can be configured by command line or modifying the code.
  • The kernel reserved space cannot be adjusted. It is controlled by the kernel and the Normal zone size and it depends on the total DDR size and the reserved spaces.
  • Reserved GPU memory size can be adjusted by adding "gpumem=" parameters in kernel commandline. It's size is highly depends on the screen resolution, the video stream decoding requirement and the camera resolution, fps.
gpumem=<size>M
  • Reserved memory size for BG (background) framebuffer can be configured by command line
fbmem=<fb0 size>,<fb2 size>,<fb4 size>,<fb5 size>
For example:
If you have two display devices, one is XGA LVDS, the other is HDMI 1080p device (default 32bpp), you have to specify the BG buffer size for them:
fbmem=10M,24M
The size is calculated by xres*yres*bpp*3:
10M ~= 1024x768x4(32bpp)x3(triple buffer)
24M ~= 1920x1080x4(32bpp)x3(triple buffer)
タグ(2)
コメント
Can we have more detailed memory breakdown for GPU reserved area?
My customer would like to reduce it as much as possible, even though user guide doesn't recommend it.
For doing this, he need to have generally how much memory is required for each component: GPU, VPU, and others.
Good docment!
Best basic knowledge for all
Can you please give us an example on how to calculate the VPU memory?  gpumem=???
I need to play 4 video streams 1920x1080 each. How do I calculate that?
Each Video stream 1920x1080x30FPS
1920*1080=2073600
*30FPS=62208000 pixels/s
*4 videos= 248832000 pix/s
if using RAW (3bytes x pixel)
Each video
RAW= 178 Mbytes/s
x4 videos: 711Mbytes/s
This is only the DDR used to decode,  DDR is also used to paint background and foreground framebuffers for display,  bytes are loaded into memory after decoding .
A single 30fps h264 full hd video can use 1090 MB/s of DDR if presented in a 60hz screen.
I use imx6DL on our device and the system hang happened randomly without any error logs or kernel panic.
After debugging for one month, we found if we increase the gpu reserved memory from 192M to 256M (described below), system is stable.
My question is, how should I know if the reserved GPU memory size is enough?
And, why there is no any error logs if the reserved memory is not enough?
(the resolution of panel we are using is 2400x1650)
static struct viv_gpu_platform_data imx6q_gpu_pdata __initdata = {
  .reserved_mem_size = SZ_128M + SZ_128M,
It is very hard to calculate exactly how much memory would be used by the GPU. But it is possible to make an approximation .
GPU would need memory to:
  • Store vertex
  • Store textures (this uses lots of memory)
  • Frame buffer Objects (FBO’s)
  • Command Buffer
  • Color and depth buffers
  • Caches
While most of the memory would be used by the FBO’s and the textures, the other items would add a few megabytes .
This could be a simple example:
Textures
10M
FBO1
1024*768*3=2.2M
FBO2
1024*768*3=2.2M
Other
3M
Total
  1. 17.4M
In this example the recommended value will be 32M,  consider that you might be using double or triple buffering, then multiply the FB values.
I want to decode 2 MPEG streams & combinely encode these into 1 H.264 stream. I calculated Frame buffers for 2 MPEG streams (VGA 640*480*30fps*2 Byte per pixel) = 18MB * 2 =36MB. For stable system, we need 128MB GPU & 128MB VPU. Kernel size is fixed ~13MB. Please advice whether it is correct? or still we need allocate memory for DMA.
Vinayak
Does the "gpumem=" kernel parameter work only if galcore is a module?
In my board I haven't galcore.ko so I guess it is compiled inside the kernel...and if I modify "gpumem" from uboot I cannot see any changes.
Hi Everyone,
We are trying porting a 480x272 LCD to our custom i.mx53 board.
This is our LCD structure in mxc_lcdif.c
"0", 60, 480, 272, 111000, 2, 2, 2, 2, 41, 10,
FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT,
FB_VMODE_NONINTERLACED,
0,
We have tried part of this structure and it works on Linux, but when we use it on Android 4.2.2. and Linux 3.0.35, we see some errors like this: (logcat ouput)
I/SurfaceFlinger(15714): SurfaceFlinger is starting
I/SurfaceFlinger(15714): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
D/libEGL (15714): loaded /system/lib/egl/libEGL_imx51.so
D/libEGL (15714): loaded /system/lib/egl/libGLESv1_CM_imx51.so
D/libEGL (15714): loaded /system/lib/egl/libGLESv2_imx51.so
W/imx5x.gralloc(15714): 32bpp setting of Framebuffer catched!
I/imx5x.gralloc(15714): using (fd=16)
I/imx5x.gralloc(15714): id = DISP3 BG
I/imx5x.gralloc(15714): xres = 480 px
I/imx5x.gralloc(15714): yres = 272 px
I/imx5x.gralloc(15714): xres_virtual = 480 px
I/imx5x.gralloc(15714): yres_virtual = 1088 px
I/imx5x.gralloc(15714): bpp = 32
I/imx5x.gralloc(15714): r = 0:8
I/imx5x.gralloc(15714): g = 8:8
I/imx5x.gralloc(15714): b = 16:8
I/imx5x.gralloc(15714): width = 203 mm (60.059113 dpi)
I/imx5x.gralloc(15714): height = 152 mm (45.452629 dpi)
I/imx5x.gralloc(15714): refresh rate = 33.30 Hz
I/hwcomposer(15714): <hwc_get_framebuffer_info,238> Vsync rate 33.299999 fps, frame time 30030030 ns
I/hwcomposer(15714): <hwc_device_open,276>
I/SurfaceFlinger(15714): Using composer version 1.0
W/SurfaceFlinger(15714): getting VSYNC period from fb HAL: 30030030
W/SurfaceFlinger(15714): no suitable EGLConfig found, trying without EGL_FRAMEBUFFER_TARGET_ANDROID
W/SurfaceFlinger(15714): no suitable EGLConfig found, trying without EGL_RECORDABLE_ANDROID
W/GraphicBufferAllocator(15714): WOW! gralloc alloc failed, waiting for pending frees!
W/GraphicBufferAllocator(15714): alloc(480, 272, 1, 00001a00, ...) failed -12 (Out of memory)
D/GraphicBufferAllocator(15714): Allocated buffers:
D/GraphicBufferAllocator(15714): 0x4167b668: 510.00 KiB | 480 ( 480) x 272 | 1 | 0x00001a00
D/GraphicBufferAllocator(15714): 0x4167b7e8: 510.00 KiB | 480 ( 480) x 272 | 1 | 0x00001a00
D/GraphicBufferAllocator(15714): Total allocated (estimate): 1020.00 KB
E/SurfaceFlinger(15714): GraphicBufferAlloc::createGraphicBuffer(w=480, h=272) failed (Out of memory), handle=0x0
E/BufferQueue(15714): [FramebufferSurface] dequeueBuffer: SurfaceComposer::createGraphicBuffer failed
F/libc (15714): Fatal signal 11 (SIGSEGV) at 0x00000020 (code=1), thread 15715 (SurfaceFlinger)
I/DEBUG ( 2350): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
I/DEBUG ( 2350): Build fingerprint: 'Freescale/imx53_smd/imx53_smd:4.2.2/1.1.0-rc3/eng.root.20170203.d2a45e2:eng/dev-keys'
I/DEBUG ( 2350): Revision: '1388577'
I/DEBUG ( 2350): pid: 15714, tid: 15715, name: SurfaceFlinger >>> /system/bin/surfaceflinger <<<
I/DEBUG ( 2350): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 00000020
Could you please share your advice about this problem?
Thanks & Regards,
%3CLINGO-SUB%20id%3D%22lingo-sub-1102563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6%20Android%E3%81%A7%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E7%AE%A1%E7%90%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-380549551%22%20id%3D%22toc-hId-1304184942%22%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E4%BD%BF%E7%94%A8%E9%87%8F%E3%81%A8%E8%A8%AD%E5%AE%9A%3C%2FH1%3E%3CP%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FMemory-Management-on-i-MX6-Android%2Fta-p%2F1102563%23toc-hId-380549551%22%20target%3D%22_blank%22%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E4%BD%BF%E7%94%A8%E9%87%8F%E3%81%A8%E8%A8%AD%E5%AE%9A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FMemory-Management-on-i-MX6-Android%2Fta-p%2F1102563%23toc-hId--736343438%22%20target%3D%22_blank%22%3E%E3%81%AF%E3%81%98%E3%82%81%E3%81%AB%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FMemory-Management-on-i-MX6-Android%2Fta-p%2F1102563%23toc-hId--56285068%22%20target%3D%22_blank%22%3EDDR%20%E3%83%A1%E3%83%A2%E3%83%AA%E4%BD%BF%E7%94%A8%E9%87%8F%E3%81%AE%E5%90%88%E8%A8%88%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FMemory-Management-on-i-MX6-Android%2Fta-p%2F1102563%23toc-hId--1863739531%22%20target%3D%22_blank%22%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FMemory-Management-on-i-MX6-Android%2Fta-p%2F1102563%23toc-hId--1183681161%22%20target%3D%22_blank%22%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%B0%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1071111025%22%20id%3D%22toc-hId-1994746416%22%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId--736343438%22%20id%3D%22toc-hId-187291953%22%3E%E3%81%AF%E3%81%98%E3%82%81%E3%81%AB%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%20i.MX%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%85%A8%E4%BD%93%E3%81%AEAndroid%E3%83%A1%E3%83%A2%E3%83%AA%E4%BD%BF%E7%94%A8%E9%87%8F%E3%80%81%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E6%A7%8B%E6%88%90%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1751169395%22%20id%3D%22toc-hId--1620162510%22%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId--56285068%22%20id%3D%22toc-hId-867350323%22%3EDDR%20%E3%83%A1%E3%83%A2%E3%83%AA%E4%BD%BF%E7%94%A8%E9%87%8F%E3%81%AE%E5%90%88%E8%A8%88%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3Ei.MX%20Android%20%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81DDR%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3ELinux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%82%E3%81%AE%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CUL%3E%3CLI%3E%3CSPAN%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%81initrd%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3Ekernel%20page%20tables%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AEMM%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%AE%A1%E7%90%86%E3%81%95%E3%82%8C%E3%82%8B%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%E3%82%BE%E3%83%BC%E3%83%B3%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9(%E3%83%8F%E3%82%A4%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%BE%E3%83%BC%E3%83%B3%E3%82%82%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99)%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%3Elibc%20%E3%81%AE%20brk()%20%E3%81%BE%E3%81%9F%E3%81%AF%20malloc()%20%E3%81%AB%E3%82%88%E3%82%8B%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3Emm%20api%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%81%E4%BE%8B%E3%81%88%E3%81%B0kmalloc%E3%80%81dma_alloc%E3%80%81vmalloc%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EGPU%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E7%94%A8%E3%81%AB%E4%BA%88%E7%B4%84%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A1%E3%83%A2%E3%83%AA%20(%E4%BB%A5%E4%B8%8B%E3%80%81%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%3EGPU%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EAndroid%20%E3%82%B5%E3%83%BC%E3%83%95%E3%82%A7%E3%82%B9%20%E3%83%93%E3%83%A5%E3%83%BC%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AE%E3%82%B5%E3%83%BC%E3%83%95%E3%82%A7%E3%82%B9%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EVPU%E3%81%AE%E3%83%AF%E3%83%BC%E3%82%AD%E3%83%B3%E3%82%B0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%A8%E3%83%93%E3%83%83%E3%83%88%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0(GPU%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8B%E3%82%89VPU%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%A6%E3%80%81%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AE%E7%B5%B1%E4%B8%80%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99)%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1BG%E3%83%88%E3%83%AA%E3%83%97%E3%83%AB%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E7%94%A8%E3%81%AE%E4%BA%88%E7%B4%84%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%3E%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E8%A1%A8%E7%A4%BA%E3%81%AB%E3%81%AF%E3%80%81%E5%B8%B8%E3%81%AB%E3%83%88%E3%83%AA%E3%83%97%E3%83%AB%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%A8%E3%83%A9%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CH2%20id%3D%22toc-hId--1863739531%22%20id%3D%22toc-hId--940104140%22%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E5%9B%B3%E3%81%AF%E3%80%81i.MX6Q%2FDL%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E4%BD%BF%E7%94%A8%E9%87%8F%E3%81%A8%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1874242635%22%20id%3D%22toc-hId--950607244%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sqUYmnJomglWvrt6ZFUtTRw.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sqUYmnJomglWvrt6ZFUtTRw.png%22%20style%3D%22width%3A%20572px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38384i3BD5D7AE68B08157%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22sqUYmnJomglWvrt6ZFUtTRw.png%22%20alt%3D%22sqUYmnJomglWvrt6ZFUtTRw.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EsqUYmnJomglWvrt6ZFUtTRw.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CH2%20id%3D%22toc-hId--1183681161%22%20id%3D%22toc-hId--260045770%22%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%B0%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A3%BD%E5%93%81%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97%E3%82%84%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E6%A7%8B%E6%88%90(DDR%E3%82%B5%E3%82%A4%E3%82%BA%E3%80%81%E7%94%BB%E9%9D%A2%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9)%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%A8%E4%BD%BF%E7%94%A8%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E4%BA%88%E7%B4%84%E3%81%AF%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AF%E8%AA%BF%E6%95%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A8%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%E3%82%BE%E3%83%BC%E3%83%B3%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%88%B6%E5%BE%A1%E3%81%95%E3%82%8C%E3%80%81%E5%90%88%E8%A8%88DDR%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%A8%E4%BA%88%E7%B4%84%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%E4%BA%88%E7%B4%84%E3%81%95%E3%82%8C%E3%81%9F%20GPU%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%20%22gpumem%3D%22%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E8%AA%BF%E6%95%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%E3%80%81%E7%94%BB%E9%9D%A2%E3%81%AE%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%AE%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E8%A6%81%E4%BB%B6%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%80%81fps%E3%81%AB%E5%A4%A7%E3%81%8D%E3%81%8F%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CBLOCKQUOTE%3E%0A%3CP%3Egpumem%3D%3CSIZE%3EM%3C%2FSIZE%3E%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CUL%3E%3CLI%3EBG(%E3%83%90%E3%83%83%E3%82%AF%E3%82%B0%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89)%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E4%BA%88%E7%B4%84%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FLI%3E%3C%2FUL%3E%3CBLOCKQUOTE%3Efbmem%3D%3CFB0%20size%3D%22%22%3E%2C%3CFB2%20size%3D%22%22%3E%2C%3CFB4%20size%3D%22%22%3E%2C%3CFB5%20size%3D%22%22%3E%3C%2FFB5%3E%3C%2FFB4%3E%3C%2FFB2%3E%3C%2FFB0%3E%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%E4%BE%8B%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E2%E3%81%A4%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%80%811%E3%81%A4%E3%81%AFXGA%20LVDS%E3%81%A7%E3%80%81%E3%82%82%E3%81%861%E3%81%A4%E3%81%AFHDMI%201080p%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AF32bpp)%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AEBG%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Efbmem%3D10M%2C24M%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%20xres*yres*bpp*3%20%E3%81%A7%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E10M%20~%3D%201024x768x4(32bpp)x3(%E3%83%88%E3%83%AA%E3%83%97%E3%83%AB%E3%83%90%E3%83%83%E3%83%95%E3%82%A1)%3C%2FP%3E%0A%3CP%3E24M%20~%3D%201920x1080x4(32bpp)x3(%E3%83%88%E3%83%AA%E3%83%97%E3%83%AB%E3%83%90%E3%83%83%E3%83%95%E3%82%A1)%3C%2FP%3E%0A%0A%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1102563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20Android%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E7%AE%A1%E7%90%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%22%3E%E3%81%AD%E3%81%88%E7%9A%86%E3%81%95%E3%82%93%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%22%3E480x272%20LCD%E3%82%92%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0i.mx53%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%22%3E%E3%81%93%E3%82%8C%E3%81%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2014px%3B%22%3Emxc_lcdif.c%3C%2FSTRONG%3E%E3%81%AELCD%E6%A7%8B%E9%80%A0%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%22%3E%3CSTRONG%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2014px%3B%22%3E...%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%22%3E%E3%80%8C0%E3%80%8D%E3%80%8160%E3%80%81480%E3%80%81272%E3%80%81111000%E3%80%812%E3%80%812%E3%80%812%E3%80%812%E3%80%8141%E3%80%8110%E3%80%81%3CBR%20%2F%3EFB_SYNC_HOR_HIGH_ACT%20%7CFB_SYNC_VERT_HIGH_ACT%E3%80%81%3CBR%20%2F%3EFB_VMODE_NONINTERLACED%E3%80%81%3CBR%20%2F%3E0%2C%3CBR%20%2F%3E%7D%2C%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%22%3E.....%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%22%3E%E3%81%93%E3%81%AE%E6%A7%8B%E9%80%A0%E3%81%AE%E4%B8%80%E9%83%A8%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81Linux%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%20%3CSTRONG%3EAndroid%204.2.2.%E3%81%A8Linux%203.0.35%3C%2FSTRONG%3E%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3A%20(logcat%20%E5%87%BA%E5%8A%9B)%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%22%3EI%2FSurfaceFlinger(15714)%3A%20SurfaceFlinger%20%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3EI%2FSurfaceFlinger(15714)%3A%20SurfaceFlinger%20%E3%81%AE%E3%83%A1%E3%82%A4%E3%83%B3%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E6%BA%96%E5%82%99%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E4%B8%AD%20H%2FW...%3CBR%20%2F%3ED%2FlibEGL%20(15714)%3A%20%E3%83%AD%E3%83%BC%E3%83%89%E6%B8%88%E3%81%BF%20%2Fsystem%2Flib%2Fegl%2FlibEGL_imx51.so%3CBR%20%2F%3ED%2FlibEGL%20(15714)%3A%20%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%20%2Fsystem%2Flib%2Fegl%2FlibGLESv1_CM_imx51.so%3CBR%20%2F%3ED%2FlibEGL%20(15714)%3A%20%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%20%2Fsystem%2Flib%2Fegl%2FlibGLESv2_imx51.so%3CBR%20%2F%3Ew%20%2F%20imx5x.gralloc(15714)%3A%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE32bpp%E8%A8%AD%E5%AE%9A%E3%82%92%E3%82%AD%E3%83%A3%E3%83%83%E3%83%81!%3CBR%20%2F%3EI%2Fimx5x.gralloc(15714)%3A%20(fd%3D16)%20%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3EI%2Fimx5x.gralloc(15714)%3Aid%20%3D%20DISP3%20BG%3CBR%20%2F%3EI%2Fimx5x.gralloc(15714)%3AXRES%20%3D%20480%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%3CBR%20%2F%3EI%2Fimx5x.gralloc(15714)%3A%E5%B9%B4%E6%95%B0%20%3D%20272%20px%3CBR%20%2F%3EI%2Fimx5x.gralloc(15714)%3Axres_virtual%20%3D%20480%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%3CBR%20%2F%3EI%2Fimx5x.gralloc(15714)%3Ayres_virtual%20%3D%201088%20px%3CBR%20%2F%3EI%2Fimx5x.gralloc(15714)%3Abpp%20%3D%2032%3CBR%20%2F%3EI%2Fimx5x.gralloc(15714)%3Ar%20%3D%200%3A8%3CBR%20%2F%3EI%2Fimx5x.gralloc(15714)%3Ag%20%3D%208%3A8%3CBR%20%2F%3EI%2Fimx5x.gralloc(15714)%3Ab%20%3D%2016%3A8%3CBR%20%2F%3EI%2Fimx5x.gralloc(15714)%3A%E5%B9%85%20%3D%20203%20mm%20(60.059113%20dpi)%3CBR%20%2F%3EI%2Fimx5x.gralloc(15714)%3A%E9%AB%98%E3%81%95%20%3D%20152%20mm%20(45.452629%20dpi)%3CBR%20%2F%3EI%2Fimx5x.gralloc(15714)%3A%E3%83%AA%E3%83%95%E3%83%AC%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AC%E3%83%BC%E3%83%88%3D%2033.30%20Hz%3CBR%20%2F%3EI%20%2F%20hwcomposer(15714)%3A%3CHWC_GET_FRAMEBUFFER_INFO%3EVsync%E3%83%AC%E3%83%BC%E3%83%8833.299999%20fps%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E6%99%82%E9%96%9330030030%20ns%3CBR%20%2F%3E%E7%A7%81%2Fhwcomposer(15714)%3A%20%3CHWC_DEVICE_OPEN%3E%3CBR%20%2F%3EI%20%2F%20SurfaceFlinger(15714)%3A%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.0%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3EW%20%2F%20SurfaceFlinger(15714)%3Afb%20HAL%E3%81%8B%E3%82%89VSYNC%E6%9C%9F%E9%96%93%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%3A30030030%3CBR%20%2F%3EW%20%2F%20SurfaceFlinger(15714)%3A%E9%81%A9%E5%88%87%E3%81%AAEGLConfig%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81EGL_FRAMEBUFFER_TARGET_ANDROID%E3%81%AA%E3%81%97%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3EW%20%2F%20SurfaceFlinger(15714)%3A%E9%81%A9%E5%88%87%E3%81%AAEGLConfig%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81EGL_RECORDABLE_ANDROID%E3%81%AA%E3%81%97%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3EW%20%2F%20GraphicBufferAllocator(15714)%3A%E3%81%99%E3%81%94%E3%81%84!gralloc%20alloc%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BF%9D%E7%95%99%E4%B8%AD%E3%81%AE%E8%A7%A3%E6%94%BE%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EW%20%2F%20GraphicBufferAllocator(15714)%3Aalloc(480%E3%80%81272%E3%80%811%E3%80%8100001a00%E3%80%81...)%E5%A4%B1%E6%95%97-12(%E3%83%A1%E3%83%A2%E3%83%AA%E4%B8%8D%E8%B6%B3)%3CBR%20%2F%3ED%2FGraphicBufferAllocator(15714)%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%3A%3CBR%20%2F%3ED%2FGraphicBufferAllocator(15714)%3A%200x4167b668%3A%20510.00%20KiB%20%7C480%20(%20480)%20x%20272%20%7C1%20%7C0x00001a00%3CBR%20%2F%3ED%2FGraphicBufferAllocator(15714)%3A%200x4167b7e8%3A%20510.00%20KiB%20%7C480%20(%20480)%20x%20272%20%7C1%20%7C0x00001a00%3CBR%20%2F%3ED%2FGraphicBufferAllocator(15714)%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E5%90%88%E8%A8%88%20(%E6%8E%A8%E5%AE%9A)%3A%201020.00%20KB%3CBR%20%2F%3E%3CSTRONG%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2014px%3B%22%3EE%20%2F%20SurfaceFlinger(15714)%3AGraphicBufferAlloc%20%3A%3A%20createGraphicBuffer(w%20%3D%20480%E3%80%81h%20%3D%20272)%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F(%E3%83%A1%E3%83%A2%E3%83%AA%E4%B8%8D%E8%B6%B3)%E3%80%81handle%20%3D%200x0%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2014px%3B%22%3EE%20%2F%20BufferQueue(15714)%3A%5BFramebufferSurface%5D%20dequeueBuffer%3ASurfaceComposer%20%3A%3A%20createGraphicBuffer%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2014px%3B%22%3EF%2Flibc%20(15714)%3A%200x00000020%20(code%3D1)%20%E3%81%A7%E3%81%AE%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E4%BF%A1%E5%8F%B7%2011%20(SIGSEGV)%E3%80%81%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%2015715%20(SurfaceFlinger)%3C%2FSTRONG%3E%3CBR%20%2F%3EI%2FDEBUG%20(%202350)%3A%20***%20***%20***%20***%3CBR%20%2F%3EI%20%2F%20DEBUG(2350)%3A%E3%83%95%E3%82%A3%E3%83%B3%E3%82%AC%E3%83%BC%E3%83%97%E3%83%AA%E3%83%B3%E3%83%88%E3%81%AE%E6%A7%8B%E7%AF%89%3A'Freescale%20%2F%20imx53_smd%20%2F%20imx53_smd%3A4.2.2%20%2F%201.1.0-rc3%20%2F%20eng.root.20170203.d2a45e2%3Aeng%20%2F%20dev-keys'%3CBR%20%2F%3EI%20%2F%20DEBUG(2350)%3A%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%3A'1388577'%3CBR%20%2F%3EI%20%2F%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20(%202350)%3A%20pid%3A%2015714%2C%20tid%3A%2015715%2C%20name%3A%20SurfaceFlinger%20%26gt%3B%26gt%3B%26gt%3B%20%2Fsystem%2Fbin%2Fsurfaceflinger%20%26lt%3B%26lt%3B%26lt%3B%3CBR%20%2F%3EI%20%2F%20DEBUG%20(%202350)%3A%20%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB11%20(SIGSEGV)%E3%80%81%E3%82%B3%E3%83%BC%E3%83%891%20(SEGV_MAPERR)%E3%80%81%E9%9A%9C%E5%AE%B3addr%2000000020%3C%2FHWC_DEVICE_OPEN%3E%3C%2FHWC_GET_FRAMEBUFFER_INFO%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%22%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014px%3B%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%26amp%3B%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102572%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20Android%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E7%AE%A1%E7%90%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102572%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%22gpumem%3D%22%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AF%E3%80%81galcore%20%E3%81%8C%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AE%E3%81%BF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%20%3F%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AFgalcore.ko%E3%81%8C%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E5%86%85%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99...%E3%81%BE%E3%81%9F%E3%80%81uboot%20%E3%81%8B%E3%82%89%20%22gpumem%22%20%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E5%A4%89%E6%9B%B4%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20Android%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E7%AE%A1%E7%90%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E2%E3%81%A4%E3%81%AEMPEG%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%82%92%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%82%92%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A61%E3%81%A4%E3%81%AEH.264%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%AB%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%822%E3%81%A4%E3%81%AEMPEG%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0(VGA%20640%20*%20480%20*%2030fps%20*%202%E3%83%90%E3%82%A4%E3%83%88%2F%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB)%3D%2018MB%20*%202%20%3D%2036MB%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E8%A8%88%E7%AE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%9F%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E3%81%AF%E3%80%81128MB%20GPU%E3%81%A8128MB%20VPU%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF~13MB%E5%9B%BA%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81DMA%E3%81%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%8A%E3%83%A4%E3%83%83%E3%82%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20Android%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E7%AE%A1%E7%90%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22margin-left%3A%20.5in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3EGPU%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E9%87%8F%E3%82%92%E6%AD%A3%E7%A2%BA%E3%81%AB%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%9B%B0%E9%9B%A3%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E8%BF%91%E4%BC%BC%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.5in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3EGPU%20%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%A7%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E3%82%B9%E3%83%88%E3%82%A2%E9%A0%82%E7%82%B9%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E3%83%86%E3%82%AF%E3%82%B9%E3%83%81%E3%83%A3%E3%82%92%E6%A0%BC%E7%B4%8D%E3%81%97%E3%81%BE%E3%81%99(%E3%81%93%E3%82%8C%E3%81%AF%E5%A4%A7%E9%87%8F%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99)%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88(FBO)%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E3%82%AB%E3%83%A9%E3%83%BC%E3%81%A8%E6%B7%B1%E5%BA%A6%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22margin-left%3A%20.5in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AFFBO%E3%81%A8%E3%83%86%E3%82%AF%E3%82%B9%E3%83%81%E3%83%A3%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BB%96%E3%81%AE%E3%82%A2%E3%82%A4%E3%83%86%E3%83%A0%E3%81%AF%E6%95%B0%E3%83%A1%E3%82%AC%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.5in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E7%B0%A1%E5%8D%98%E3%81%AA%E4%BE%8B%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%20border%3D%220%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20style%3D%22margin-left%3A%200.5in%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22139%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E3%83%86%E3%82%AF%E3%82%B9%E3%83%81%E3%83%A3%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22499%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E10%20M%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22139%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3EFBO1%E3%81%AE%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22499%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E1024*768*3%3D2.2M%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22139%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3EFBO2%E3%81%AE%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22499%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E1024*768*3%3D2.2M%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22139%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E3%81%9D%E3%81%AE%E4%BB%96%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22499%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E3%E3%83%A1%E3%83%BC%E3%83%88%E3%83%AB%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22139%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E5%90%88%E8%A8%88%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22499%22%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E17.4M%20%E9%96%B2%E8%A6%A7%E6%95%B0%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.5in%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.5in%3B%22%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E6%8E%A8%E5%A5%A8%E5%80%A4%E3%81%AF%2032M%20%E3%81%A7%E3%80%81%E3%83%80%E3%83%96%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%88%E3%83%AA%E3%83%97%E3%83%AB%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%80%83%E6%85%AE%E3%81%97%E3%80%81FB%20%E5%80%A4%E3%82%92%E4%B9%97%E7%AE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102569%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20Android%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E7%AE%A1%E7%90%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102569%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7imx6DL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%AD%E3%82%B0%E3%82%84%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%91%E3%83%8B%E3%83%83%E3%82%AF%E3%81%AA%E3%81%97%E3%81%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%81%AB%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1%E3%83%B6%E6%9C%88%E9%96%93%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AE%E5%BE%8C%E3%80%81GPU%E3%81%AE%E4%BA%88%E7%B4%84%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92192M%E3%81%8B%E3%82%89256M(%E5%BE%8C%E8%BF%B0)%E3%81%AB%E5%A2%97%E3%82%84%E3%81%99%E3%81%A8%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E3%80%81%E4%BA%88%E7%B4%84%E3%81%95%E3%82%8C%E3%81%9FGPU%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E5%8D%81%E5%88%86%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E7%9F%A5%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%81%BE%E3%81%9F%E3%80%81%E4%BA%88%E7%B4%84%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%8C%E5%8D%81%E5%88%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%AD%E3%82%B0%E3%81%8C%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E(%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AE%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%AF2400x1650%E3%81%A7%E3%81%99)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9D%99%E7%9A%84%E6%A7%8B%E9%80%A0%E4%BD%93%20viv_gpu_platform_data%20imx6q_gpu_pdata%20__initdata%20%3D%20%7B%3C%2FP%3E%3CP%3E.reserved_mem_size%20%3D%20SZ_128M%20%2B%20SZ_128M%E3%80%81%3C%2FP%3E%3CP%3E%7D%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20Android%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E7%AE%A1%E7%90%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%90%84%E3%83%93%E3%83%87%E3%82%AA%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A01920x1080x30FPS%3C%2FP%3E%3CP%3E1920*1080%3D2073600%3C%2FP%3E%3CP%3E*30FPS%3D62208000%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%2F%E7%A7%92%3C%2FP%3E%3CP%3E*4%20videos%3D%20248832000%20pix%2Fs%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERAW%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88(3%E3%83%90%E3%82%A4%E3%83%88%C3%97%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%90%84%E5%8B%95%E7%94%BB%3C%2FP%3E%3CP%3ERAW%3D%20178%20MB%2F%E7%A7%92%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ex4%E3%83%93%E3%83%87%E3%82%AA%3A711M%E3%83%90%E3%82%A4%E3%83%88%2F%E7%A7%92%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8BDDR%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81DDR%E3%81%AF%E8%A1%A8%E7%A4%BA%E7%94%A8%E3%81%AE%E8%83%8C%E6%99%AF%E3%81%8A%E3%82%88%E3%81%B3%E3%83%95%E3%82%A9%E3%82%A2%E3%82%B0%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E3%83%9A%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AB%E3%82%82%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%80%81%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E5%BE%8C%E3%81%AB%E3%83%90%E3%82%A4%E3%83%88%E3%81%8C%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1%20%E3%81%A4%E3%81%AE%2030fps%20h264%20%E3%83%95%E3%83%AB%20HD%20%E3%83%93%E3%83%87%E3%82%AA%E3%81%AF%E3%80%8160%20Hz%20%E3%81%AE%E7%94%BB%E9%9D%A2%E3%81%A7%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%811090%20MB%2Fs%20%E3%81%AE%20DDR%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20Android%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E7%AE%A1%E7%90%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EVPU%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E8%A8%88%E7%AE%97%E6%96%B9%E6%B3%95%E3%81%AE%E4%BE%8B%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3Egpumem%3D%3F%3F%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C1920x1080%E3%81%AE4%E3%81%A4%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%82%92%E5%86%8D%E7%94%9F%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20Android%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E7%AE%A1%E7%90%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E4%BA%BA%E3%81%AB%E6%9C%80%E9%AB%98%E3%81%AE%E5%9F%BA%E7%A4%8E%E7%9F%A5%E8%AD%98%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20Android%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E7%AE%A1%E7%90%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CBR%20%2F%3E%E8%89%AF%E3%81%84%E3%83%89%E3%82%AF%E3%82%BF%E3%83%BC!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1102564%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Ai.MX6%20Android%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E7%AE%A1%E7%90%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102564%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EGPU%E4%BA%88%E7%B4%84%E9%A0%98%E5%9F%9F%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E5%86%85%E8%A8%B3%E3%82%92%E3%82%88%E3%82%8A%E8%A9%B3%E7%B4%B0%E3%81%AB%E6%8A%8A%E6%8F%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E9%A1%A7%E5%AE%A2%E3%81%AF%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%81%8C%E6%8E%A8%E5%A5%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A0%E3%81%91%E6%B8%9B%E3%82%89%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%86%E3%81%AB%E3%81%AF%E3%80%81GPU%E3%80%81VPU%E3%81%AA%E3%81%A9%E3%81%AE%E5%90%84%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E9%87%8F%E3%82%92%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AB%E7%94%A8%E6%84%8F%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎10-09-2012 10:30 PM
更新者:
