Lighting Control Philips Hue Light Through KW20(Zigbee Coordinator) with i.MX6Q
Hi all,
Most of IoT customers request to enable/demo i.MX EVK with FSL Zigbee solution. In default i.MX Linux/Android BSP, Zigbee function is not enabled. Here we make a lighting demo setup through i.MX6Q SabreSD, KW20 USB dongle and Philips Hue light. KW20 is configured as Zigbee coordinator, connected with USB OTG in i.MX6Q, then i.MX6Q can issue On/Off, brightness and color control commands through KW20 to toggle Philips Hue light directly.
Please find the attachment for details.
Carl
Comments
Good share!!
This is very helpful.
Thanks a lot!!
Thanks for your share!
Hello!
I tried to follow this guide but gets stuck on when to use Test Tool to send commands, I can't find the ZTC_ZllTouchLink...  commands. Are there something missing in my ZigBeePro.xml file, or what do I need to do?
Mattias
    ZTC_ZllTouchLink is not supported at existing released xml file. You may contact your local sales/FAE to get the xml version which support ZTC_ZllTouchLink command sets.
%3CLINGO-SUB%20id%3D%22lingo-sub-1111157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELighting%20Control%20Philips%20Hue%20Light%20Through%20KW20(Zigbee%20Coordinator)%20with%20i.MX6Q%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20all%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMost%20of%20IoT%20customers%20request%20to%20enable%2Fdemo%20i.MX%20EVK%20with%20FSL%20Zigbee%20solution.%20In%20default%20i.MX%20Linux%2FAndroid%20BSP%2C%20Zigbee%20function%20is%20not%20enabled.%20Here%20we%20make%20a%20lighting%20demo%20setup%20through%20i.MX6Q%20SabreSD%2C%20KW20%20USB%20dongle%20and%20Philips%20Hue%20light.%20KW20%20is%20configured%20as%20Zigbee%20coordinator%2C%20connected%20with%20USB%20OTG%20in%20i.MX6Q%2C%20then%20i.MX6Q%20can%20issue%20On%2FOff%2C%20brightness%20and%20color%20control%20commands%20through%20KW20%20to%20toggle%20Philips%20Hue%20light%20directly.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPlease%20find%20the%20attachment%20for%20details.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3ECarl%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1111157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20all%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMost%20of%20IoT%20customers%20request%20to%20enable%2Fdemo%20i.MX%20EVK%20with%20FSL%20Zigbee%20solution.%20In%20default%20i.MX%20Linux%2FAndroid%20BSP%2C%20Zigbee%20function%20is%20not%20enabled.%20Here%20we%20make%20a%20lighting%20demo%20setup%20through%20i.MX6Q%20SabreSD%2C%20KW20%20USB%20dongle%20and%20Philips%20Hue%20light.%20KW20%20is%20configured%20as%20Zigbee%20coordinator%2C%20connected%20with%20USB%20OTG%20in%20i.MX6Q%2C%20then%20i.MX6Q%20can%20issue%20On%2FOff%2C%20brightness%20and%20color%20control%20commands%20through%20KW20%20to%20toggle%20Philips%20Hue%20light%20directly.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPlease%20find%20the%20attachment%20for%20details.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3ECarl%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Lighting%20Control%20Philips%20Hue%20Light%20Through%20KW20(Zigbee%20Coordinator)%20with%20i.MX6Q%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ZTC_ZllTouchLink%26nbsp%3Bis%20not%20supported%20at%20existing%20released%20xml%20file.%20You%20may%20contact%20your%20local%20sales%2FFAE%20to%20get%20the%20xml%20version%20which%20support%20ZTC_ZllTouchLink%20command%20sets.%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111161%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Lighting%20Control%20Philips%20Hue%20Light%20Through%20KW20(Zigbee%20Coordinator)%20with%20i.MX6Q%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111161%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello!%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20tried%20to%20follow%20this%20guide%20but%20gets%20stuck%20on%20when%20to%20use%20Test%20Tool%20to%20send%20commands%2C%20I%20can't%20find%20the%20ZTC_ZllTouchLink...%20%26nbsp%3Bcommands.%20Are%20there%20something%20missing%20in%20my%20ZigBeePro.xml%20file%2C%20or%20what%20do%20I%20need%20to%20do%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20Regards%2C%3C%2FP%3E%3CP%3EMattias%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111160%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Lighting%20Control%20Philips%20Hue%20Light%20Through%20KW20(Zigbee%20Coordinator)%20with%20i.MX6Q%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111160%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20your%20share!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111159%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Lighting%20Control%20Philips%20Hue%20Light%20Through%20KW20(Zigbee%20Coordinator)%20with%20i.MX6Q%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111159%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20is%20very%20helpful.%3C%2FP%3E%3CP%3EThanks%20a%20lot!!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Lighting%20Control%20Philips%20Hue%20Light%20Through%20KW20(Zigbee%20Coordinator)%20with%20i.MX6Q%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGood%20share!!%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎10-09-2014 12:25 AM
Updated by:
