Hi all,
Most of IoT customers request to enable/demo i.MX EVK with FSL Zigbee solution. In default i.MX Linux/Android BSP, Zigbee function is not enabled. Here we make a lighting demo setup through i.MX6Q SabreSD, KW20 USB dongle and Philips Hue light. KW20 is configured as Zigbee coordinator, connected with USB OTG in i.MX6Q, then i.MX6Q can issue On/Off, brightness and color control commands through KW20 to toggle Philips Hue light directly.
Please find the attachment for details.
Carl
Good share!!
This is very helpful.
Thanks a lot!!
Thanks for your share!
Hello!
I tried to follow this guide but gets stuck on when to use Test Tool to send commands, I can't find the ZTC_ZllTouchLink... commands. Are there something missing in my ZigBeePro.xml file, or what do I need to do?
Mattias
ZTC_ZllTouchLink is not supported at existing released xml file. You may contact your local sales/FAE to get the xml version which support ZTC_ZllTouchLink command sets.
