I.MX31 ADS Installing Uboot
If you already followed the i.MX31ADS Compiling Uboot steps or got a compiled U-boot image, copy u-boot.bin to /tftpboot:
 $ cp u-boot.bin /tftpboot
If you have RedBoot on your board follow the "Installing RedBoot using U-Boot", but if you already have been installed U-Boot and are just installing a new version jump to "Installing U-Boot using U-Boot".
Installing U-Boot using RedBoot
Load the U-boot image to board RAM:
 RedBoot> load -v -r -b 0x100000 /tftpboot/u-boot.bin -h 10.29.244.27
Where:
0x100000 is the memory position where the firmware image will be downloaded;
10.29.244.27 is your host IP which is running the TFTP server.
Erase the Flash:
 RedBoot> fis erase -f 0xA0000000 -l 0x00040000
To make sure about what area you should erase, perform the fis list command and compare the areas
Write the image to Flash:
 RedBoot> fis write -f 0xA0000000 -b 0x100000 -l 0x00040000
Reset the board:
 RedBoot> reset
You should see something like this:
U-Boot 1.3.3 (May 26 2008 - 11:19:43)
CPU: Freescale i.MX31 at 531 MHz
Board: MX31ADS
DRAM: 128 MB
Flash: 32 MB
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
First upload the U-Boot firmware using Network (Transferring file over network ) or Serial (Transferring File Over Serial)
This is a common serial transfer output:
=> loady
## Ready for binary (ymodem) download to 0x80800000 at 115200 bps...
CCmode, 1359(SOH)/0(STX)/0(CAN) packets, 9 retries
## Total Size = 0x0002a388 = 172936 Bytes
Unprotect the bootloader flash area:
protect off A0000000 A003FFFF
Erase the flash blocks:
erase A0000000 A003FFFF
Copy from RAM to Flash: If firmware has been thansfered over serial:
cp.b 80800000 A0000000 2a388
If firmware has been transfered over tftp:
cp.b 100000 A0000000 2a388
Installing U-Boot using OpenOCD JTAG/GDB
To do that you need to compile U-Boot with this define:
#define CONFIG_SKIP_LOWLEVEL_INIT 1
Then enter in GDB and execute:
(arm-gdb) restore u-boot.bin binary 0x87f00000
Restoring binary file u-boot.bin into memory (0x87f00000 to 0x87f2c790)
(arm-gdb) set $pc = 0x87f00000
(arm-gdb) c
You will see U-Boot starting in the serial console. Then compile a new U-Boot without the CONFIG_SKIP_LOWLEVEL_INIT and follow the Installing U-Boot using U-Boot to install U-Boot in the flash.
Installing U-Boot using LogicLoader
losh> ifconfig sm0 dhcp
losh> load raw 0x81000000 115764 /tftp/10.29.244.27:u-boot.bin.lite
losh> exec 0x81000000 -
コメント
I'm trying to run U-boot with starting address in middle of DDR RAM, instead of flash ROM.  It starts to run from 0xA0100000 just fine, but somewhere in the relocation code (crt0_64.S) it gets a Sync exception.  I'm going to try the below option tomorrow, hopefully disabling the remap might help.
%3CLINGO-SUB%20id%3D%22lingo-sub-1106624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EI.MX31%20ADS%20Uboot%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-1309%22%20target%3D%22_blank%22%3E%E3%81%99%E3%81%A7%E3%81%AB%20i.MX31ADS%20Uboot%20%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%3C%2FA%3E%20%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%B8%88%E3%81%BF%E3%81%AE%20U-boot%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81u-boot.bin%20%E3%82%92%20%2Ftftpboot%20%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%20%24%20cp%20u-boot.bin%20%2Ftftpboot%20%3C%2FPRE%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABRedBoot%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8CU-Boot%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FRedBoot%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%80%8D%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%81%8C%E3%80%81%E3%81%99%E3%81%A7%E3%81%ABU-Boot%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%A6%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%81%B0%E3%81%8B%E3%82%8A%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8CU-Boot%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FU-Boot%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%80%8D%E3%81%AB%E9%80%B2%E3%82%93%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1081734131%22%20id%3D%22toc-hId-1081734131%22%20id%3D%22toc-hId-2005255229%22%3E%3CSPAN%20class%3D%22mw-headline%22%3ERedBoot%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20U-Boot%20%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%20%3C%2FSPAN%3E%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3EU-boot%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%20RAM%20%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%20RedBoot%26gt%3B%20load%20-v%20-r%20-b%200x100000%20%2Ftftpboot%2Fu-boot.bin%20-h%2010.29.244.27%20%3C%2FPRE%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%80%81%3C%2FP%3E%3CP%3E0x100000%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%82%8B%E3%83%A1%E3%83%A2%E3%83%AA%E4%BD%8D%E7%BD%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E10.29.244.27%20%E3%81%AF%E3%80%81TFTP%20%E3%82%B5%E3%83%BC%E3%83%90%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%9B%E3%82%B9%E3%83%88%20IP%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%B6%88%E5%8E%BB%E3%81%99%E3%82%8B%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%20RedBoot%26gt%3B%20fis%20erase%20-f%200xA0000000%20-l%200x00040000%20%3C%2FPRE%3E%3CP%3E%E6%B6%88%E5%8E%BB%E3%81%99%E3%82%8B%E9%A0%98%E5%9F%9F%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81fis%20list%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81%E9%A0%98%E5%9F%9F%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E7%94%BB%E5%83%8F%E3%82%92Flash%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%20RedBoot%26gt%3B%20fis%20write%20-f%200xA0000000%20-b%200x100000%20-l%200x00040000%20%3C%2FPRE%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%20RedBoot%26gt%3B%20reset%20%3C%2FPRE%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%82%E3%81%AE%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive-quote%22%3E%3CP%3EU%E3%83%96%E3%83%BC%E3%83%88%201.3.3(2008%E5%B9%B45%E6%9C%8826%E6%97%A5%20-%2011%3A19%3A43)%3C%2FP%3E%3CP%3ECPU%3A531MHz%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABi.MX31%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%3AMX31ADS%3C%2FP%3E%3CP%3EDRAM%3A128%E3%83%A1%E3%82%AC%E3%83%90%E3%82%A4%E3%83%88%3C%2FP%3E%3CP%3EFlash%3A%2032%20MB%3C%2FP%3E%3CP%3E%E3%81%A7%3A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FP%3E%3CP%3E%E3%82%A2%E3%82%A6%E3%83%88%3A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FP%3E%3CP%3EErr%3A%20serial%3C%2FP%3E%3CP%3E%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%BE%E3%81%99%3A0%3C%2FP%3E%3CP%3E%3D%26gt%3B%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CH3%20id%3D%22toc-hId--725720332%22%20id%3D%22toc-hId--725720332%22%20id%3D%22toc-hId-197800766%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EU-Boot%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20U-Boot%20%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%20%3C%2FSPAN%3E%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF(%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-1293%22%20target%3D%22_blank%22%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E7%B5%8C%E7%94%B1%E3%81%A7%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E8%BB%A2%E9%80%81%3C%2FA%3E%20)%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB(%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-1292%22%20target%3D%22_blank%22%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%B5%8C%E7%94%B1%E3%81%A7%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E8%BB%A2%E9%80%81%3C%2FA%3E)%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6U-Boot%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%20%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E8%BB%A2%E9%80%81%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive-quote%22%3E%3CP%3E%3D%26gt%3B%20loady%3C%2FP%3E%3CP%3E%23%23%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%20(ymodem)%20%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%82%92%20115200%20bps%20%E3%81%A7%200x80800000%20%E3%81%99%E3%82%8B%E6%BA%96%E5%82%99%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F...%3C%2FP%3E%3CP%3ECCmode%E3%80%811359(SOH)%2F0(STX)%2F0(CAN)%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%80%819%E5%9B%9E%E3%81%AE%E5%86%8D%E8%A9%A6%E8%A1%8C%3C%2FP%3E%3CP%3E%23%23%20%E5%90%88%E8%A8%88%E3%82%B5%E3%82%A4%E3%82%BA%20%3D%200x0002a388%20%3D%20172936%E3%83%90%E3%82%A4%E3%83%88%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E9%A0%98%E5%9F%9F%E3%81%AE%E4%BF%9D%E8%AD%B7%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%E3%83%97%E3%83%AD%E3%83%86%E3%82%AF%E3%83%88%E3%82%AA%E3%83%95A0000000%20A003FFFF%20%3C%2FPRE%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E6%B6%88%E5%8E%BB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%E6%B6%88%E5%8E%BBA0000000%20A003FFFF%20%3C%2FPRE%3E%3CP%3ERAM%20%E3%81%8B%E3%82%89%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%B8%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%3A%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%B5%8C%E7%94%B1%E3%81%A7%E8%BB%A2%E9%80%81%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Ecp.b%2080800000%20A0000000%202a388%20%3C%2FPRE%3E%3CP%3E%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%20TFTP%20%E7%B5%8C%E7%94%B1%E3%81%A7%E8%BB%A2%E9%80%81%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Ecp.b%20100000%20A0000000%202a388%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1761792501%22%20id%3D%22toc-hId-1761792501%22%20id%3D%22toc-hId--1609653697%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EOpenOCD%20JTAG%2FGDB%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20U-Boot%20%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%20%3C%2FSPAN%3E%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%86%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6U-Boot%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%23define%20CONFIG_SKIP_LOWLEVEL_INIT%201%20%3C%2FPRE%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81GDB%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive-quote%22%3E%3CP%3E(arm-gdb)%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA0x87f00000%20u-boot.bin%E5%BE%A9%E5%85%83%3C%2FP%3E%3CP%3E%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20u-boot.bin%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%B8%E3%81%AE%E5%BE%A9%E5%85%83%20(0x87f00000%20%E3%81%8B%E3%82%89%200x87f2c790)%3C%2FP%3E%3CP%3E(arm-gdb)%20%24pc%20%3D%200x87f00000%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E(ARM-GDB)C%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3EU-Boot%20%E3%81%8C%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%A7%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81CONFIG_SKIP_LOWLEVEL_INIT%E3%81%AA%E3%81%97%E3%81%A7%E6%96%B0%E3%81%97%E3%81%84U-Boot%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%80%81%20%3CSTRONG%3EU-Boot%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FU-Boot%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FSTRONG%3E%20%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%ABU-Boot%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--45661962%22%20id%3D%22toc-hId--45661962%22%20id%3D%22toc-hId-877859136%22%3E%3CSPAN%20class%3D%22mw-headline%22%3ELogicLoader%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FU-Boot%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%20%3C%2FSPAN%3E%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Elosh%26gt%3Bifconfig%20sm0%20dhcp%20%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3Elosh%26gt%3B%20raw%200x81000000%20115764%20%2Ftftp%2F10.29.244.27%3Au-boot.bin.lite%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%E3%83%AD%E3%83%83%E3%82%B7%E3%83%A5%26gt%3B%E3%82%A8%E3%82%B0%E3%82%BC%E3%82%AF%E3%83%86%E3%82%A3%E3%83%960x81000000%20-%20%3C%2FPRE%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AI.MX31%20ADS%E3%81%AEUboot%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5ROM%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81DDR%20RAM%E3%81%AE%E4%B8%AD%E5%A4%AE%E3%81%AB%E9%96%8B%E5%A7%8B%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6U-boot%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%820xA0100000%E3%81%8B%E3%82%89%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%AE%9F%E8%A1%8C%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%86%8D%E9%85%8D%E7%BD%AE%E3%82%B3%E3%83%BC%E3%83%89(crt0_64.S)%E3%81%AE%E3%81%A9%E3%81%93%E3%81%8B%E3%81%A7Sync%E4%BE%8B%E5%A4%96%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%98%8E%E6%97%A5%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E3%81%A4%E3%82%82%E3%82%8A%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%91%E3%81%B0%E3%80%81%E5%86%8D%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22%22%3E%23define%20CONFIG_SKIP_LOWLEVEL_INIT%201%20%3C%2FPRE%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-10-2020 02:00 AM
更新者:
