How to enable sparse image in android
There are two format system image(ext4): raw and sparse. The raw image is  larger, you can mount it to ext4 directly(mount -t ext4 system.img system). The sparse image is supported lp5.0, it is a bit smaller. The below part will take IMX7D SDB board as example. You can change the setting according your platform hardware.
1 generate sparse image
In Lollipop 5.0 and 5.1, both raw image and sparse image will be generated by default.
sparse system image is located in: out/target/product/sabresd_7d/system_sparse.img
raw system image is located in:out/target/product/sabresd_7d/system.img
Below are the steps used in android build system to generate system.img
  • build out sparse image(-s means the building system image is sparse)
          make_ext4fs -s -T -1 -S out/target/product/sabresd_7d/root/file_contexts -l 374476800 -a system           out/target/product/sabresd_7d/obj/PACKAGING/systemimage_intermediates/system.img out/target/product/sabresd_7d/system
  • transform sparse image to raw image
          simg2img out/target/product/sabresd_7d/system_sparse.img out/target/product/sabresd_7d/system.img
2 burn sparse image to sd/emmc
     There are two ways to program the sparse image into android boot storage
  • Transform the sparse image into raw image in host Linux PC. And use the commands dd commands to program the raw image into the boot storage.
  • Program the sparse image with MFG Tool in i.MX Android release package.
               Steps:
      • copy system_sparse.img to files/android/sabresd/.
      • copy simg2img binary (in simg2img.zip) to files/android/.
      • You also need update mfgtools-without-rootfs.tar\mfgtools\Profiles\Linux\OS Firmware\ucl2.xml
     diff --git a/Profiles/Linux/OS Firmware/ucl2.xml b/Profiles/Linux/OS Firmware/ucl2.xml      index 3b15ddd..3c3d2ae 100755      --- a/Profiles/Linux/OS Firmware/ucl2.xml      +++ b/Profiles/Linux/OS Firmware/ucl2.xml        @@ -621,8 +621,12 @@              <CMD state="Updater" type="push" body="$ mkfs.ext4 /dev/mmcblk%mmc%p6">Formatting cache partition</CMD>                <CMD state="Updater" type="push" body="$ mkfs.ext4 /dev/mmcblk%mmc%p7">Formatting device partition</CMD>      -       <CMD state="Updater" type="push" body="pipe dd of=/dev/mmcblk%mmc%p5 bs=512" file="files/android/sabresd/system.img">Sending and writting system.img</CMD>      -      +       <CMD state="Updater" type="push" body="send" file="files/android/simg2img" ifdev="MX7D">Sending simg2img</CMD>      +       <CMD state="Updater" type="push" body="$ cp $FILE /tmp/simg2img ">cp simg2img</CMD>      +       <CMD state="Updater" type="push" body="$ chmod  777 /tmp/simg2img ">chmod 777</CMD>      +       <CMD state="Updater" type="push" body="$  mount -o remount,size=512M rootfs /">change size of tmpfs</CMD>      +       <CMD state="Updater" type="push" body="send" file="files/android/sabresd/system_sparse.img" ifdev="MX7D">Sending system_sparse.img</CMD>      +       <CMD state="Updater" type="push" body="$ /tmp/simg2img $FILE /dev/mmcblk%mmc%p5">Sending and writting system_sparse.img</CMD>              <!-- Write userdata.img is optional, for some customer this is needed, but it's optional. -->              <!-- Also, userdata.img will have android unit test, you can use this to do some auto test. -->              <!--    <CMD state="Updater" type="push" onError="ignore" body="pipe dd of=/dev/mmcblk0p7" file="file/android/userdate.img"> Sending userdata.
3 Support sparse image in uboot(v2014.04)
     Cheery-pick sparse image related patches. Use write_sparse_image to burn sparse system image.
     For detail information, Please check the attached file(uboot(v2014.04)which support sparseimage.zip )
     The step of apply these patches:
  • cd myandroid/bootable/bootloader/uboot-imx/
  • copy uboot(v2014.04) which support sparseimage.zip to myandroid/bootable/bootloader/uboot-imx/
        unzip uboot(v2014.04) which support sparseimage.zip
  • git am 0001-add-header-for-Android-sparse-image-format.patch
        git am 0002-add-code-to-handle-Android-sparse-image-format.patch
        git am 0003-update-code-which-handles-Android-sparse-image-forma.patch
        git am 0004-cleanup-code-which-handles-the-Android-sparse-image-.patch
        git am 0005-implement-the-Android-sparse-image-format.patch
        git am 0006-aboot-fix-block-addressing-for-don-t-care-chunk-type.patch
        git am 0007-MA-6732-Add-sparse-image-flash-support-for-uboot-s-f.patch
The page will keep updating.
Reference:
     How to enable userdata.img and cache.img in lollipop
附件
评论
Hello Sanshan Zhang,
When I building android(Lollipop 5.0.0.1) for imx6slevk board , system.img is not able to generate from system_sparse.img.
Following error is obtained:
Install system fs image: out/target/product/evk_6sl/system_sparse.img
out/target/product/evk_6sl/system_sparse.img+out/target/product/evk_6sl/obj/PACKAGING/recovery_patch_intermediates/recovery_from_boot.p maxsize=481738752 blocksize=4224 total=403801046 reserve=4866048
if [ true = true ]; then \
        simg2img out/target/product/evk_6sl/system_sparse.img out/target/product/evk_6sl/system.img; \
        fi
/bin/bash: line 1: simg2img: command not found
make: *** [out/target/product/evk_6sl/system_sparse.img] Error 127
make: *** Deleting file `out/target/product/evk_6sl/system_sparse.img'
Is their any patches to apply which Support sparse image in android..
please help me sort out this issue...
Kishore P
Hi kishore,
Does you have check whether /out/host/linux-x86/bin/simg2img exist?
If   it exists, you can check if the /out/host/linux-x86/bin/ is export to PATH.
  Thanks for reply, simg2img is exit in /out/host/linux-x86/bin path and it is exported to PATH also.
Any think we have to enable in the kernel extra other than default option given by freescale...?
>$PATH
bash: /usr/lib/jvm/java-7-openjdk-amd64/bin:/home/test/Android_Source/out/host/linux-x86/bin:/home/test/Android_Source/prebuilts/gcc/linux-x86/arm/arm-linux-androideabi-4.8/bin:/home/test/Android_Source/prebuilts/gcc/linux-x86/:/home/test/Android_Source/prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin:/home/test/Android_Source/development/scripts:/home/test/Android_Source/prebuilts/devtools/tools:/home/test/Android_Source/prebuilts/android-emulator/linux-x86_64:/home/test/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games: No such file or directory
Kishore P
If it exist and export it's path, i think you can try "simg2img -h". See what's the log.
Hello Sanshan,
   I replaced "simg2img" with "simg2img -h" , but results is same ,
        simg2img -h out/target/product/evk_6sl/system_sparse.img out/target/product/evk_6sl/system.img; \
        fi
Kishore P
Hello Sanshan,
  If we go for --help following output is showed
...:~/Android_Source$ simg2img --help
    Usage: simg2img <sparse_image_files> <raw_image_file>
But still /bin/bash: line 1: simg2img: command not found
error is got.
Kishore P
%3CLINGO-SUB%20id%3D%22lingo-sub-1113192%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E5%9C%A8%20Android%20%E4%B8%AD%E5%90%AF%E7%94%A8%E7%A8%80%E7%96%8F%E6%98%A0%E5%83%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113192%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Eext4%20%E7%B3%BB%E7%BB%9F%E9%95%9C%E5%83%8F%E6%9C%89%E4%B8%A4%E7%A7%8D%E6%A0%BC%E5%BC%8F%EF%BC%9Araw%20%E5%92%8C%20sparse%E3%80%82%E5%8E%9F%E5%A7%8B%E5%9B%BE%E5%83%8F%E4%BD%93%E7%A7%AF%E8%BE%83%E5%A4%A7%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E7%9B%B4%E6%8E%A5%E5%B0%86%E5%85%B6%E6%8C%82%E8%BD%BD%E5%88%B0%20ext4%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%EF%BC%88mount%20-t%20ext4%20system.img%20system%EF%BC%89%E3%80%82%E7%A8%80%E7%96%8F%E5%9B%BE%E5%83%8F%E6%94%AF%E6%8C%81%20lp5.0%EF%BC%8C%E4%BD%93%E7%A7%AF%E7%9B%B8%E5%AF%B9%E8%BE%83%E5%B0%8F%E3%80%82%E4%BB%A5%E4%B8%8B%E9%83%A8%E5%88%86%E5%B0%86%E4%BB%A5%20IMX7D%20SDB%20%E6%9D%BF%E4%B8%BA%E4%BE%8B%E8%BF%9B%E8%A1%8C%E8%AF%B4%E6%98%8E%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%A0%B9%E6%8D%AE%E8%87%AA%E5%B7%B1%E5%B9%B3%E5%8F%B0%E7%9A%84%E7%A1%AC%E4%BB%B6%E6%9B%B4%E6%94%B9%E7%9B%B8%E5%BA%94%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%94%9F%E6%88%90%E7%A8%80%E7%96%8F%E5%9B%BE%E5%83%8F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20color%3A%20%23303030%3B%22%3E%E5%9C%A8%20Lollipop%205.0%20%E5%92%8C%205.1%20%E4%B8%AD%EF%BC%8C%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%E5%B0%86%E7%94%9F%E6%88%90%E5%8E%9F%E5%A7%8B%E5%9B%BE%E5%83%8F%E5%92%8C%E7%A8%80%E7%96%8F%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%A8%80%E7%96%8F%E7%B3%BB%E7%BB%9F%E6%98%A0%E5%83%8F%E4%BD%8D%E4%BA%8E%EF%BC%9Aout%2Ftarget%2Fproduct%2Fsabresd_7d%2Fsystem_sparse.img%3C%2FP%3E%3CP%3E%E5%8E%9F%E5%A7%8B%E7%B3%BB%E7%BB%9F%E6%98%A0%E5%83%8F%E4%BD%8D%E4%BA%8E%EF%BC%9Aout%2Ftarget%2Fproduct%2Fsabresd_7d%2Fsystem.img%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20color%3A%20%23303030%3B%22%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%20Android%20%E6%9E%84%E5%BB%BA%E7%B3%BB%E7%BB%9F%E4%B8%AD%E7%94%A8%E4%BA%8E%E7%94%9F%E6%88%90%20system.img%20%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3Ebuild%20out%20sparse%20image%EF%BC%88-s%20%E8%A1%A8%E7%A4%BA%E6%9E%84%E5%BB%BA%E7%9A%84%E7%B3%BB%E7%BB%9F%E9%95%9C%E5%83%8F%E6%98%AF%20sparse%20%E6%A0%BC%E5%BC%8F%EF%BC%89%3C%2FLI%3E%3C%2FUL%3E%3CP%3Emake_ext4fs%20-s%20-T%20-1%20-S%20out%2Ftarget%2Fproduct%2Fsabresd_7d%2Froot%2Ffile_contexts%20-l%20374476800%20-a%20system%20out%2Ftarget%2Fproduct%2Fsabresd_7d%2Fobj%2FPACKAGING%2Fsystemimage_intermediates%2Fsystem.img%20out%2Ftarget%2Fproduct%2Fsabresd_7d%2Fsystem%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%B0%86%E7%A8%80%E7%96%8F%E5%9B%BE%E5%83%8F%E8%BD%AC%E6%8D%A2%E4%B8%BA%E5%8E%9F%E5%A7%8B%E5%9B%BE%E5%83%8F%3C%2FLI%3E%3C%2FUL%3E%3CP%3Esimg2img%20out%2Ftarget%2Fproduct%2Fsabresd_7d%2Fsystem_sparse.img%20out%2Ftarget%2Fproduct%2Fsabresd_7d%2Fsystem.img%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E2%20%E5%B0%86%E7%A8%80%E7%96%8F%E9%95%9C%E5%83%8F%E7%83%A7%E5%BD%95%E5%88%B0%20SD%20%E5%8D%A1%2FeMMC%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%20%20%20%20%20%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%E5%B0%86%E7%A8%80%E7%96%8F%E5%9B%BE%E5%83%8F%E7%BC%96%E7%A8%8B%E5%88%B0%20Android%20%E5%90%AF%E5%8A%A8%E5%AD%98%E5%82%A8%E6%9C%89%E4%B8%A4%E7%A7%8D%E6%96%B9%E6%B3%95%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20inherit%3B%20color%3A%20%23303030%3B%22%3E%E5%9C%A8%E4%B8%BB%E6%9C%BA%20Linux%20PC%20%E4%B8%AD%E5%B0%86%E7%A8%80%E7%96%8F%E5%9B%BE%E5%83%8F%E8%BD%AC%E6%8D%A2%E4%B8%BA%20Raw%20%E5%9B%BE%E5%83%8F%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BD%BF%E7%94%A8%20dd%20%E5%91%BD%E4%BB%A4%E5%B0%86%E5%8E%9F%E5%A7%8B%E6%98%A0%E5%83%8F%E7%BC%96%E7%A8%8B%E5%88%B0%E5%90%AF%E5%8A%A8%E5%AD%98%E5%82%A8%E4%B8%AD%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20inherit%3B%20color%3A%20%23303030%3B%22%3E%E4%BD%BF%E7%94%A8%20i.MX%20Android%20%E5%8F%91%E5%B8%83%E5%8C%85%E4%B8%AD%E7%9A%84%20MFG%20%E5%B7%A5%E5%85%B7%E5%AF%B9%E7%A8%80%E7%96%8F%E5%9B%BE%E5%83%8F%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E6%AD%A5%E9%AA%A4%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CUL%3E%3CUL%3E%3CLI%3E%E5%B0%86%20system_sparse.img%20%E5%A4%8D%E5%88%B6%E5%88%B0%20files%2Fandroid%2Fsabresd%2F%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%A4%8D%E5%88%B6%20simg2img%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%88%E5%9C%A8%20simg2img.zip%20%E4%B8%AD%EF%BC%89%E5%88%B0%20files%2Fandroid%2F%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%82%A8%E8%BF%98%E9%9C%80%E8%A6%81%E6%9B%B4%E6%96%B0%20mfgtools-without-rootfs.tar%5Cmfgtools%5CProfiles%5CLinux%5COS%20Firmware%5Cucl2.xml%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3C%2FUL%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CPRE%20class%3D%22c%2B%2B%22%20name%3D%22code%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20diff%20--git%20a%2FProfiles%2FLinux%2FOS%20Firmware%2Fucl2.xml%20b%2FProfiles%2FLinux%2FOS%20Firmware%2Fucl2.xml%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20index%203b15ddd..3c3d2ae%20100755%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20---%20a%2FProfiles%2FLinux%2FOS%20Firmware%2Fucl2.xml%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2B%2B%2B%20b%2FProfiles%2FLinux%2FOS%20Firmware%2Fucl2.xml%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%40%40%20-621%2C8%20%2B621%2C12%20%40%40%20%3CCMD%20state%3D%22Updater%22%20type%3D%22push%22%20body%3D%22%24%20mkfs.ext4%20%2Fdev%2Fmmcblk%25mmc%25p6%22%3E%E6%A0%BC%E5%BC%8F%E5%8C%96%E7%BC%93%E5%AD%98%E5%88%86%E5%8C%BA%3C%2FCMD%3E%20%3CCMD%20state%3D%22Updater%22%20type%3D%22push%22%20body%3D%22%24%20mkfs.ext4%20%2Fdev%2Fmmcblk%25mmc%25p7%22%3E%E6%A0%BC%E5%BC%8F%E5%8C%96%E8%AE%BE%E5%A4%87%E5%88%86%E5%8C%BA%3C%2FCMD%3E%20-%20%3CCMD%20state%3D%22Updater%22%20type%3D%22push%22%20body%3D%22pipe%20dd%20of%3D%2Fdev%2Fmmcblk%25mmc%25p5%20bs%3D512%22%20file%3D%22files%2Fandroid%2Fsabresd%2Fsystem.img%22%3E%E5%8F%91%E9%80%81%E5%B9%B6%E5%86%99%E5%85%A5%20system.img%3C%2FCMD%3E-%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CCMD%20state%3D%22Updater%22%20type%3D%22push%22%20body%3D%22send%22%20file%3D%22files%2Fandroid%2Fsimg2img%22%20ifdev%3D%22MX7D%22%3E%E5%8F%91%E9%80%81%20simg2img%3C%2FCMD%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CCMD%20state%3D%22Updater%22%20type%3D%22push%22%20body%3D%22%24%20cp%20%24FILE%20%2Ftmp%2Fsimg2img%20%22%3Ecp%20simg2img%3C%2FCMD%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CCMD%20state%3D%22Updater%22%20type%3D%22push%22%20body%3D%22%24%20chmod%26nbsp%3B%20777%20%2Ftmp%2Fsimg2img%20%22%3Echmod%20777%3C%2FCMD%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CCMD%20state%3D%22Updater%22%20type%3D%22push%22%20body%3D%22%24%26nbsp%3B%20mount%20-o%20remount%2Csize%3D512M%20rootfs%20%2F%22%3E%E6%9B%B4%E6%94%B9%20tmpfs%20%E5%A4%A7%E5%B0%8F%3C%2FCMD%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CCMD%20state%3D%22Updater%22%20type%3D%22push%22%20body%3D%22send%22%20file%3D%22files%2Fandroid%2Fsabresd%2Fsystem_sparse.img%22%20ifdev%3D%22MX7D%22%3E%E5%8F%91%E9%80%81%20system_sparse.img%3C%2FCMD%3E%2B%20%3CCMD%20state%3D%22Updater%22%20type%3D%22push%22%20body%3D%22%24%20%2Ftmp%2Fsimg2img%20%24FILE%20%2Fdev%2Fmmcblk%25mmc%25p5%22%3E%E5%8F%91%E9%80%81%E5%92%8C%E5%86%99%E5%85%A5%20system_sparse.img%3C%2FCMD%3E%3C!--%20%E5%86%99%E5%85%A5%20userdata.img%20%E6%98%AF%E5%8F%AF%E9%80%89%E7%9A%84%EF%BC%8C%E9%83%A8%E5%88%86%E5%AE%A2%E6%88%B7%E9%9C%80%E8%A6%81%E6%AD%A4%E6%AD%A5%E9%AA%A4%EF%BC%8C%E4%BD%86%E5%AE%83%E6%98%AF%E5%8F%AF%E9%80%89%E7%9A%84%E3%80%82--%3E%20%3C!--%20%E6%AD%A4%E5%A4%96%EF%BC%8Cuserdata.img%20%E5%B0%86%E5%8C%85%E5%90%AB%20Android%20%E5%8D%95%E5%85%83%E6%B5%8B%E8%AF%95%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E5%AE%83%E6%9D%A5%E8%BF%9B%E8%A1%8C%E4%B8%80%E4%BA%9B%E8%87%AA%E5%8A%A8%E6%B5%8B%E8%AF%95%E3%80%82--%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C!--%C2%A0%C2%A0%C2%A0%20%3CCMD%20state%3D%22Updater%22%20type%3D%22push%22%20onError%3D%22ignore%22%20body%3D%22pipe%20dd%20of%3D%2Fdev%2Fmmcblk0p7%22%20file%3D%22file%2Fandroid%2Fuserdate.img%22--%3E%E5%8F%91%E9%80%81%E7%94%A8%E6%88%B7%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FPRE%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E3%20%E5%9C%A8%20uboot%20(v2014.04)%20%E4%B8%AD%E6%94%AF%E6%8C%81%E7%A8%80%E7%96%8F%E5%9B%BE%E5%83%8F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%8C%91%E9%80%89%E4%B8%8E%E7%A8%80%E7%96%8F%E5%9B%BE%E5%83%8F%E7%9B%B8%E5%85%B3%E7%9A%84%E8%A1%A5%E4%B8%81%E3%80%82%E4%BD%BF%E7%94%A8%20write_sparse_image%20%E5%88%BB%E5%BD%95%E7%A8%80%E7%96%8F%E7%B3%BB%E7%BB%9F%E9%95%9C%E5%83%8F%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E9%9C%80%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E6%9F%A5%E9%98%85%E9%99%84%E4%BB%B6%EF%BC%88uboot(v2014.04)%EF%BC%89%E6%94%AF%E6%8C%81%20sparseimage.zip%20)%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%BA%94%E7%94%A8%E8%BF%99%E4%BA%9B%E8%A1%A5%E4%B8%81%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3Ecd%20myandroid%2Fbootable%2Fbootloader%2Fuboot-imx%2F%3C%2FLI%3E%3CLI%3E%E5%B0%86%E6%94%AF%E6%8C%81%20sparse%20image%20%E6%A0%BC%E5%BC%8F%E7%9A%84%20uboot(v2014.04)%E5%A4%8D%E5%88%B6%E5%88%B0%20myandroid%2Fbootable%2Fbootloader%2Fuboot-imx%2F%20%E7%9B%AE%E5%BD%95%E4%B8%8B%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E8%A7%A3%E5%8E%8B%E6%94%AF%E6%8C%81%20sparse%20image%20%E6%A0%BC%E5%BC%8F%E7%9A%84%20uboot(v2014.04)%3C%2FP%3E%3CUL%3E%3CLI%3Egit%20am%200001-add-header-for-Android-sparse-image-format.patch%3C%2FLI%3E%3C%2FUL%3E%3CP%3Egit%20am%200002-add-code-to-handle-Android-sparse-image-format.patch%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Egit%20am%200003-update-code-which-handles-Android-sparse-image-forma.patch%3C%2FP%3E%3CP%3Egit%20am%200004-cleanup-code-which-handles-the-Android-sparse-image-.patch%3C%2FP%3E%3CP%3Egit%20am%200005-implement-the-Android-sparse-image-format.patch%3C%2FP%3E%3CP%3Egit%20am%200006-aboot-fix-block-addressing-for-don-t-care-chunk-type.patch%3C%2FP%3E%3CP%3Egit%20am%200007-MA-6732-Add-sparse-image-flash-support-for-uboot-s-f.patch%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E9%A1%B5%E9%9D%A2%E5%B0%86%E4%BC%9A%E6%8C%81%E7%BB%AD%E6%9B%B4%E6%96%B0%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EReference%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222004%22%20data-containertype%3D%2214%22%20data-objectid%3D%22105198%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-105198%22%20target%3D%22_blank%22%3E%E5%A6%82%E4%BD%95%E5%9C%A8%20Lollipop%20%E4%B8%AD%E5%90%AF%E7%94%A8%20userdata.img%20%E5%92%8C%20cache.img%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20Android%20%E4%B8%AD%E5%90%AF%E7%94%A8%E7%A8%80%E7%96%8F%E9%95%9C%E5%83%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8CSanshan%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%89%A7%E8%A1%8C%20--help%20%E5%8F%82%E6%95%B0%EF%BC%8C%E5%B0%86%E6%98%BE%E7%A4%BA%E5%A6%82%E4%B8%8B%E8%BE%93%E5%87%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSTRONG%3E...%3A~%2FAndroid_Source%24%20simg2img%20--help%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Usage%3A%20simg2img%20%3CSPARSE_IMAGE_FILES%3E%20%3CRAW_IMAGE_FILE%3E%3C%2FRAW_IMAGE_FILE%3E%3C%2FSPARSE_IMAGE_FILES%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E4%BB%8D%E7%84%B6%3CSTRONG%3E%2Fbin%2Fbash%3A%20%E7%AC%AC%201%20%E8%A1%8C%3A%20simg2img%3A%20%E5%91%BD%E4%BB%A4%E6%9C%AA%E6%89%BE%E5%88%B0%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%8F%91%E7%94%9F%E9%94%99%E8%AF%AF%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EKishore%20P%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20Android%20%E4%B8%AD%E5%90%AF%E7%94%A8%E7%A8%80%E7%96%8F%E9%95%9C%E5%83%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8CSanshan%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%20%E2%80%9Csimg2img%E2%80%9D%20%E6%9B%BF%E6%8D%A2%E4%B8%BA%20%E2%80%9Csimg2img%20-h%E2%80%9D%EF%BC%8C%E4%BD%86%E7%BB%93%E6%9E%9C%E7%9B%B8%E5%90%8C%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eout%2Ftarget%2Fproduct%2Fevk_6sl%2Fsystem_sparse.img%2Bout%2Ftarget%2Fproduct%2Fevk_6sl%2Fobj%2FPACKAGING%2Frecovery_patch_intermediates%2Frecovery_from_boot.p%20maxsize%3D481%2C738%2C752%20blocksize%3D4%2C224%20total%3D403%2C801%2C046%20reserve%3D4%2C866%2C048%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%A6%82%E6%9E%9C%20%5B%20true%20%3D%20true%20%5D%3B%20%E9%82%A3%E4%B9%88%20%5C%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20simg2img%20-h%20out%2Ftarget%2Fproduct%2Fevk_6sl%2Fsystem_sparse.img%20out%2Ftarget%2Fproduct%2Fevk_6sl%2Fsystem.img%3B%5C%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fi%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%2Fbin%2Fbash%EF%BC%9A%E7%AC%AC%201%20%E8%A1%8C%EF%BC%9Asimg2img%EF%BC%9A%E5%91%BD%E4%BB%A4%E6%9C%AA%E6%89%BE%E5%88%B0%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Emake%3A%20***%20%5Bout%2Ftarget%2Fproduct%2Fevk_6sl%2Fsystem_sparse.img%5D%E9%94%99%E8%AF%AF%20127%3C%2FP%3E%3CP%3Emake%3A%20***%20%E5%88%A0%E9%99%A4%E6%96%87%E4%BB%B6%20%E2%80%9Cout%2Ftarget%2Fproduct%2Fevk_6sl%2Fsystem_sparse.img%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EKishore%20P%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113196%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20Android%20%E4%B8%AD%E5%90%AF%E7%94%A8%E7%A8%80%E7%96%8F%E9%95%9C%E5%83%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113196%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A6%82%E6%9E%9C%E5%AE%83%E5%AD%98%E5%9C%A8%E5%B9%B6%E5%B7%B2%E5%AF%BC%E5%87%BA%E5%85%B6%E8%B7%AF%E5%BE%84%EF%BC%8C%E6%88%91%E6%83%B3%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%AF%95%E8%AF%95%20%22simg2img%20-h%22%E3%80%82%E6%9F%A5%E7%9C%8B%E6%97%A5%E5%BF%97%E5%86%85%E5%AE%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20Android%20%E4%B8%AD%E5%90%AF%E7%94%A8%E7%A8%80%E7%96%8F%E9%95%9C%E5%83%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3CSPAN%20class%3D%22replyToName%22%3E%E5%BC%A0%E4%B8%89%E5%B1%B1%3C%2FSPAN%3E%EF%BC%8C%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22replyToName%22%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%8C%3CSTRONG%3Esimg2img%20%E4%BD%8D%E4%BA%8E%20%3C%2FSTRONG%3E%3CSTRONG%3E%20%2Fout%2Fhost%2Flinux-x86%2Fbin%3C%2FSTRONG%3E%20%E8%B7%AF%E5%BE%84%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%AE%83%E4%B9%9F%E5%B7%B2%E5%AF%BC%E5%87%BA%E5%88%B0%20PATH%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22replyToName%22%3E%E6%88%91%E4%BB%AC%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%9C%A8%E5%86%85%E6%A0%B8%E4%B8%AD%E5%90%AF%E7%94%A8%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22replyToName%22%3E%E9%A2%9D%E5%A4%96%E7%9A%84%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22replyToName%22%3E%20%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22replyToName%22%3E%E5%8A%9F%E8%83%BD%EF%BC%8C%E9%99%A4%E4%BA%86%20Freescale%20%E6%8F%90%E4%BE%9B%E7%9A%84%E9%BB%98%E8%AE%A4%E9%80%89%E9%A1%B9%E4%B9%8B%E5%A4%96%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22replyToName%22%3E%E2%80%A6%E2%80%A6%EF%BC%9F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22replyToName%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26gt%3B%24PATH%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Ebash%3A%20%2Fusr%2Flib%2Fjvm%2Fjava-7-openjdk-amd64%2Fbin%3A%3CSTRONG%3E%2Fhome%2Ftest%2FAndroid_Source%2Fout%2Fhost%2Flinux-x86%2Fbin%3C%2FSTRONG%3E%3A%2Fhome%2Ftest%2FAndroid_Source%2Fprebuilts%2Fgcc%2Flinux-x86%2Farm%2Farm-linux-androideabi-4.8%2Fbin%3A%2Fhome%2Ftest%2FAndroid_Source%2Fprebuilts%2Fgcc%2Flinux-x86%2F%3A%2Fhome%2Ftest%2FAndroid_Source%2Fprebuilts%2Fgcc%2Flinux-x86%2Farm%2Farm-eabi-4.8%2Fbin%3A%2Fhome%2Ftest%2FAndroid_Source%2Fdevelopment%2Fscripts%3A%2Fhome%2Ftest%2FAndroid_Source%2Fprebuilts%2Fdevtools%2Ftools%3A%2Fhome%2Ftest%2FAndroid_Source%2Fprebuilts%2Fandroid-emulator%2Flinux-x86_64%3A%2Fhome%2Ftest%2Fbin%3A%2Fusr%2Flocal%2Fsbin%3A%2Fusr%2Flocal%2Fbin%3A%2Fusr%2Fsbin%3A%2Fusr%2Fbin%3A%2Fsbin%3A%2Fbin%3A%2Fusr%2Fgames%3A%2Fusr%2Flocal%2Fgames%3A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EKishore%20P%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20Android%20%E4%B8%AD%E5%90%AF%E7%94%A8%E7%A8%80%E7%96%8F%E9%95%9C%E5%83%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8Ckishore%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E6%A3%80%E6%9F%A5%E8%BF%87%20%2Fout%2Fhost%2Flinux-x86%2Fbin%2Fsimg2img%20%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E8%AF%A5%E8%B7%AF%E5%BE%84%E5%AD%98%E5%9C%A8%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%A3%80%E6%9F%A5%20%2Fout%2Fhost%2Flinux-x86%2Fbin%2F%20%E6%98%AF%E5%90%A6%E5%B7%B2%E5%AF%BC%E5%87%BA%E5%88%B0%20PATH%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113193%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20Android%20%E4%B8%AD%E5%90%AF%E7%94%A8%E7%A8%80%E7%96%8F%E9%95%9C%E5%83%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113193%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E5%BC%A0%E4%B8%89%E5%B1%B1%EF%BC%8C%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E5%BD%93%E6%88%91%E4%B8%BA%20imx6slevk%20%E6%9D%BF%E6%9E%84%E5%BB%BA%20Android%EF%BC%88Lollipop%205.0.0.1%EF%BC%89%E6%97%B6%EF%BC%8C%E6%97%A0%E6%B3%95%E4%BB%8E%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3Esystem_sparse.img%3C%2FSPAN%3E%20%E7%94%9F%E6%88%90%20system.img%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E5%AE%89%E8%A3%85%E7%B3%BB%E7%BB%9F%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E6%98%A0%E5%83%8F%EF%BC%9Aout%2Ftarget%2Fproduct%2Fevk_6sl%2Fsystem_sparse.img%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3Eout%2Ftarget%2Fproduct%2Fevk_6sl%2Fsystem_sparse.img%2Bout%2Ftarget%2Fproduct%2Fevk_6sl%2Fobj%2FPACKAGING%2Frecovery_patch_intermediates%2Frecovery_from_boot.p%20maxsize%3D481%2C738%2C752%20blocksize%3D4%2C224%20total%3D403%2C801%2C046%20reserve%3D4%2C866%2C048%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E5%A6%82%E6%9E%9C%20%5B%20true%20%3D%20true%20%5D%3B%20%E9%82%A3%E4%B9%88%20%5C%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3Esimg2img%20out%2Ftarget%2Fproduct%2Fevk_6sl%2Fsystem_sparse.img%20out%2Ftarget%2Fproduct%2Fevk_6sl%2Fsystem.img%EF%BC%9B%5C%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fi%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%2Fbin%2Fbash%EF%BC%9A%E7%AC%AC%201%20%E8%A1%8C%EF%BC%9Asimg2img%EF%BC%9A%E5%91%BD%E4%BB%A4%E6%9C%AA%E6%89%BE%E5%88%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3Emake%3A%20***%20%5Bout%2Ftarget%2Fproduct%2Fevk_6sl%2Fsystem_sparse.img%5D%E9%94%99%E8%AF%AF%20127%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3Emake%3A%20***%20%E5%88%A0%E9%99%A4%E6%96%87%E4%BB%B6%20%E2%80%9Cout%2Ftarget%2Fproduct%2Fevk_6sl%2Fsystem_sparse.img%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E8%A1%A5%E4%B8%81%E5%8F%AF%E4%BB%A5%E5%BA%94%E7%94%A8%E4%BB%A5%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E6%94%AF%E6%8C%81%20Android%20%E4%B8%AD%E7%9A%84%E7%A8%80%E7%96%8F%E5%9B%BE%E5%83%8F%3C%2FSPAN%3E%E2%80%A6%E2%80%A6%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E8%AF%B7%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3EKishore%20P%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-10-2020 02:21 AM
更新人:
