How to enable userdata.img and cache.img in lollipop
1 How to build out userdata.img and cache.img
The default fsl android  bsp don't support userdata.img and cache.img. You need add the below patch to build  out these images.
The hardware for below patch is imx7D. You can adjust your patch according your hardware.
diff --git a/imx7/BoardConfigCommon.mk b/imx7/BoardConfigCommon.mk
index 14e4881..c207727 100644
--- a/imx7/BoardConfigCommon.mk
+++ b/imx7/BoardConfigCommon.mk
@@ -61,7 +61,11 @@ BOARD_BOOTIMAGE_PARTITION_SIZE :=  16777216
BOARD_RECOVERYIMAGE_PARTITION_SIZE := 16777216
BOARD_SYSTEMIMAGE_PARTITION_SIZE := 377487360
+BOARD_USERDATAIMAGE_PARTITION_SIZE := 576716800
+TARGET_USERIMAGES_USE_EXT4 := true
+BOARD_CACHEIMAGE_PARTITION_SIZE := 69206016
+BOARD_CACHEIMAGE_FILE_SYSTEM_TYPE := ext4
BOARD_FLASH_BLOCK_SIZE := 4096
TARGET_RECOVERY_UI_LIB := librecovery_ui_imx
+TARGET_USERIMAGES_SPARSE_EXT_DISABLED := true
2  How to add  pre-install apk.
I add a content pre-app in device/fsl/imx7. helloworld.apk is the added pre-install apk.
diff --git a/imx7/pre-app/AnTutuV2.4.apk b/imx7/pre-app/helloworld.apk
new file mode 100755
index 0000000..a96003a
Binary files /dev/null and b/imx7/pre-app/AnTutuV2.4.apk differ
diff --git a/imx7/sabresd_7d.mk b/imx7/sabresd_7d.mk
index d7c5c76..11be86c 100644
--- a/imx7/sabresd_7d.mk
+++ b/imx7/sabresd_7d.mk
@@ -27,7 +27,8 @@ PRODUCT_COPY_FILES += \
        device/fsl/common/input/20b8000_kpp.idc:system/usr/idc/20b8000_kpp.idc \
        device/fsl/common/input/20b8000_kpp.kl:system/usr/keylayout/20b8000_kpp.kl \
        device/fsl/sabresd_7d/audio_policy.conf:system/etc/audio_policy.conf \
-       device/fsl/sabresd_7d/audio_effects.conf:system/vendor/etc/audio_effects.conf
+       device/fsl/sabresd_7d/audio_effects.conf:system/vendor/etc/audio_effects.conf \
+       device/fsl/imx7/pre-app/*:data/.
3 What are userdata.img and cache.img for?
userdata.img: we need to integrate some customized APKs which should be preinstalled but should be able removed/updated by end user after product delivery. Which means they cannot be installed as system APPs in /system/app folder but User APPs in /data/app folder. At this point, we need compile userimage by ourself.
Cache.img: /cache include the content when apk start running. You may storage some special content which app need. I have not find any advantage to pre-build cache.img.
     a. The  userdata.img and cache.img's format is sparse ext4 image. You need convert it through simg2img.
          The  tool simg2img located at lp5.1_sabresd_7d_4_20/out/host/linux-x86/bin/simg2img
          You can use below command to get raw ext4 userdata.img which can be burned into emmc/sd.
          out/host/linux-x86/bin/simg2img userdata.img userdata_raw.img
    b. BOARD_USERDATAIMAGE_PARTITION_SIZE BOARD_CACHEIMAGE_PARTITION_SIZE define the size of data and cache partition
Reference:
%3CLINGO-SUB%20id%3D%22lingo-sub-1114930%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E5%9C%A8%20Lollipop%20%E4%B8%AD%E5%90%AF%E7%94%A8%20userdata.img%20%E5%92%8C%20cache.img%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114930%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSTRONG%3E1%20%E5%A6%82%E4%BD%95%E6%9E%84%E5%BB%BA%20userdata.img%20%E5%92%8C%20cache.img%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%BB%98%E8%AE%A4%E7%9A%84fsl%20android%20bsp%E4%B8%8D%E6%94%AF%E6%8C%81userdata.img%E5%92%8Ccache.img%E3%80%82%E6%82%A8%E9%9C%80%E8%A6%81%E6%B7%BB%E5%8A%A0%E4%BB%A5%E4%B8%8B%E8%A1%A5%E4%B8%81%E6%9D%A5%E6%9E%84%E5%BB%BA%E8%BF%99%E4%BA%9B%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E8%A1%A5%E4%B8%81%E7%9A%84%E7%A1%AC%E4%BB%B6%E6%98%AF%20imx7D%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%A0%B9%E6%8D%AE%E6%82%A8%E7%9A%84%E7%A1%AC%E4%BB%B6%E8%B0%83%E6%95%B4%E8%A1%A5%E4%B8%81%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B7%AE%E5%BC%82--git%20a%2Fimx7%2FBoardConfigCommon.mk%20b%2Fimx7%2FBoardConfigCommon.mk%3C%2FP%3E%3CP%3Eindex%2014e4881..c207727%20100644%3C%2FP%3E%3CP%3E---%20a%2Fimx7%2FBoardConfigCommon.mk%3C%2FP%3E%3CP%3E%2B%2B%2Bb%2Fimx7%2FBoardConfigCommon.mk%3C%2FP%3E%3CP%3E%40%40%20-61%2C7%20%2B61%2C11%20%40%40%20BOARD_BOOTIMAGE_PARTITION_SIZE%20%3A%3D%2016777216%3C%2FP%3E%3CP%3EBOARD_RECOVERYIMAGE_PARTITION_SIZE%20%3A%3D%2016777216%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBOARD_SYSTEMIMAGE_PARTITION_SIZE%20%3A%3D%20377487360%3C%2FP%3E%3CP%3E%2BBOARD_USERDATAIMAGE_PARTITION_SIZE%20%3A%3D%20576716800%3C%2FP%3E%3CP%3E%2BTARGET_USERIMAGES_USE_EXT4%20%3A%3D%20true%3C%2FP%3E%3CP%3E%2BBOARD_CACHEIMAGE_PARTITION_SIZE%20%3A%3D%2069206016%3C%2FP%3E%3CP%3E%2BBOARD_CACHEIMAGE_FILE_SYSTEM_TYPE%20%3A%3D%20ext4%3C%2FP%3E%3CP%3E%E6%9D%BF%E9%97%AA%E5%AD%98%E5%9D%97%E5%A4%A7%E5%B0%8F%20%3A%3D%204096%3C%2FP%3E%3CP%3ETARGET_RECOVERY_UI_LIB%20%3A%3D%20librecovery_ui_imx%3C%2FP%3E%3CP%3E-%3C%2FP%3E%3CP%3E%2BTARGET_USERIMAGES_SPARSE_EXT_DISABLED%20%3A%3D%20true%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%3CSTRONG%3E%3CSTRONG%3E2%20%E5%A6%82%E4%BD%95%E6%B7%BB%E5%8A%A0%E9%A2%84%E5%AE%89%E8%A3%85%20apk%E3%80%82%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E6%88%91%E5%9C%A8%20device%2Ffsl%2Fimx7%20%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BA%86%E4%B8%80%E4%B8%AA%E5%86%85%E5%AE%B9%E9%A2%84%E5%BA%94%E7%94%A8%E3%80%82%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3Ehelloworld.apk%3C%2FSPAN%3E%E6%98%AF%E6%B7%BB%E5%8A%A0%E7%9A%84%E9%A2%84%E5%AE%89%E8%A3%85apk%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ediff%20--git%20a%2Fimx7%2Fpre-app%2FAnTutuV2.4.apk%20b%2Fimx7%2Fpre-app%2F%20%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3Ehelloworld.apk%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%96%B0%E6%96%87%E4%BB%B6%E6%A8%A1%E5%BC%8F%20100755%3C%2FP%3E%3CP%3Eindex%200000000..a96003a%3C%2FP%3E%3CP%3E%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%20%2Fdev%2Fnull%20%E5%92%8C%20b%2Fimx7%2Fpre-app%2FAnTutuV2.4.apk%20%E4%B8%8D%E5%90%8C%3C%2FP%3E%3CP%3E%E5%B7%AE%E5%BC%82%E2%80%94%E2%80%94git%20a%2Fimx7%2Fsabresd_7d.mk%20b%2Fimx7%2Fsabresd_7d.mk%3C%2FP%3E%3CP%3E%E7%B4%A2%E5%BC%95%20d7c5c76..11be86c%20100644%3C%2FP%3E%3CP%3E---%20a%2Fimx7%2Fsabresd_7d.mk%3C%2FP%3E%3CP%3E%2B%2B%2Bb%2Fimx7%2Fsabresd_7d.mk%3C%2FP%3E%3CP%3E%40%40%20-27%2C7%20%2B27%2C8%20%40%40%20PRODUCT_COPY_FILES%20%2B%3D%20%5C%3C%2FP%3E%3CP%3E%E8%AE%BE%E5%A4%87%2Ffsl%2Fcommon%2F%E8%BE%93%E5%85%A5%2F20b8000_kpp.idc%3A%E7%B3%BB%E7%BB%9F%2Fusr%2Fidc%2F20b8000_kpp.idc%20%5C%3C%2FP%3E%3CP%3E%E8%AE%BE%E5%A4%87%2Ffsl%2Fcommon%2Finput%2F20b8000_kpp.kl%3A%E7%B3%BB%E7%BB%9F%2Fusr%2Fkeylayout%2F20b8000_kpp.kl%20%5C%3C%2FP%3E%3CP%3E%E8%AE%BE%E5%A4%87%2Ffsl%2Fsabresd_7d%2Faudio_policy.conf%3A%E7%B3%BB%E7%BB%9F%2Fetc%2Faudio_policy.conf%20%5C%3C%2FP%3E%3CP%3E-%E8%AE%BE%E5%A4%87%2Ffsl%2Fsabresd_7d%2Faudio_effects.conf%3A%E7%B3%BB%E7%BB%9F%2F%E4%BE%9B%E5%BA%94%E5%95%86%2Fetc%2Faudio_effects.conf%3C%2FP%3E%3CP%3E%2B%E8%AE%BE%E5%A4%87%2Ffsl%2Fsabresd_7d%2Faudio_effects.conf%3A%E7%B3%BB%E7%BB%9F%2F%E4%BE%9B%E5%BA%94%E5%95%86%2Fetc%2Faudio_effects.conf%20%5C%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20device%2Ffsl%2Fimx7%2Fpre-app%2F*%3Adata%2F.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E3%20userdata.img%20%E5%92%8C%20cache.img%20%E6%9C%89%E4%BB%80%E4%B9%88%E7%94%A8%E5%A4%84%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%94%A8%E6%88%B7%E6%95%B0%E6%8D%AE.img%EF%BC%9A%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E5%88%B0%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E6%95%B4%E5%90%88%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E4%B8%80%E4%BA%9B%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E5%AE%9A%E5%88%B6%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3EAPK%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E5%93%AA%E4%B8%AA%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E5%BA%94%E8%AF%A5%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E6%98%AF%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E9%A2%84%E8%A3%85%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E4%BD%86%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E5%BA%94%E8%AF%A5%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E6%98%AF%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E6%9C%89%E8%83%BD%E5%8A%9B%E7%9A%84%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E5%B7%B2%E5%88%A0%E9%99%A4%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%2F%3C%2FSPAN%3E%E5%B7%B2%E6%9B%B4%E6%96%B0%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E7%BB%8F%E8%BF%87%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E7%BB%93%E5%B0%BE%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E7%94%A8%E6%88%B7%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E5%90%8E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E4%BA%A7%E5%93%81%E4%BA%A4%E4%BB%98%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E3%80%82%3C%2FSPAN%3E%E5%93%AA%E4%B8%AA%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E6%96%B9%E6%B3%95%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E4%BB%96%E4%BB%AC%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E4%B8%8D%E8%83%BD%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E6%98%AF%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E5%B7%B2%E5%AE%89%E8%A3%85%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E4%BD%9C%E4%B8%BA%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E7%B3%BB%E7%BB%9F%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E5%9C%A8%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%2F%3C%2FSPAN%3E%E7%B3%BB%E7%BB%9F%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%2F%3C%2FSPAN%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E6%96%87%E4%BB%B6%E5%A4%B9%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E4%BD%86%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E7%94%A8%E6%88%B7%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E5%9C%A8%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%2F%3C%2FSPAN%3E%E6%95%B0%E6%8D%AE%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%2F%3C%2FSPAN%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%E6%96%87%E4%BB%B6%E5%A4%B9%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E3%80%82%E6%AD%A4%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E8%87%AA%E5%B7%B1%E7%BC%96%E8%AF%91%E7%94%A8%E6%88%B7%E6%98%A0%E5%83%8F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3ECache.img%EF%BC%9A%2Fcache%20apk%E5%BC%80%E5%A7%8B%E8%BF%90%E8%A1%8C%E6%97%B6%E5%8C%85%E5%90%AB%E7%9A%84%E5%86%85%E5%AE%B9%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%AD%98%E5%82%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%9C%80%E8%A6%81%E7%9A%84%E4%B8%80%E4%BA%9B%E7%89%B9%E6%AE%8A%E5%86%85%E5%AE%B9%E3%80%82%E6%88%91%E6%B2%A1%E6%9C%89%E5%8F%91%E7%8E%B0%E9%A2%84%E5%85%88%E6%9E%84%E5%BB%BA%20cache.img%20%E6%9C%89%E4%BB%80%E4%B9%88%E5%A5%BD%E5%A4%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%3CSTRONG%3E%E7%AC%94%E8%AE%B0%EF%BC%9A%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E4%B8%80%E4%B8%AA%E3%80%82userdata.img%20%E5%92%8C%20cache.img%E6%A0%BC%E5%BC%8F%E4%B8%BA%E7%A8%80%E7%96%8F%20ext4%20%E5%9B%BE%E5%83%8F%E3%80%82%E6%82%A8%E9%9C%80%E8%A6%81%E9%80%9A%E8%BF%87%20simg2img%20%E8%BF%9B%E8%A1%8C%E8%BD%AC%E6%8D%A2%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E5%B7%A5%E5%85%B7%20simg2img%20%E4%BD%8D%E4%BA%8E%20lp5.1_sabresd_7d_4_20%2Fout%2Fhost%2Flinux-x86%2Fbin%2Fsimg2img%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E8%8E%B7%E5%8F%96%E5%8F%AF%E5%88%BB%E5%BD%95%E5%88%B0%20emmc%2Fsd%20%E7%9A%84%E5%8E%9F%E5%A7%8B%20ext4%20userdata.img%E3%80%82%3C%2FP%3E%3CP%3E%E5%87%BA%2F%E4%B8%BB%E6%9C%BA%2Flinux-x86%2Fbin%2Fsimg2img%20userdata.img%20userdata_raw.img%3C%2FP%3E%3CP%3E%3CSTRONG%3Eb.%20BOARD_USERDATAIMAGE_PARTITION_SIZE%20BOARD_CACHEIMAGE_PARTITION_SIZE%20%E5%AE%9A%E4%B9%89%E6%95%B0%E6%8D%AE%E5%92%8C%E7%BC%93%E5%AD%98%E5%88%86%E5%8C%BA%E7%9A%84%E5%A4%A7%E5%B0%8F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%82%E8%80%83%E8%B5%84%E6%96%99%EF%BC%9A%3C%2FP%3E%3CUL%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-105215%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-105215%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-105215%3C%2FA%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎05-24-2015 05:54 AM
更新人:
