How to change kernel configuration on Android build
Tested on Android 10 (android_Q10.0.0_1.0.0)
After your the first BSP build the kernel sources are at:
${MY_ANDROID}/vendor/nxp-opensource/kernel_imx/
For the i.MX8M Mini, You can check the defconfig files being used on:
${MY_ANDROID}/device/fsl/imx8m/evk_8mm/UbootKernelBoardConfig.mk
# imx8mm kernel defconfig
TARGET_KERNEL_DEFCONFIG := android_defconfig
TARGET_KERNEL_ADDITION_DEFCONF := android_addition_defconfig
You could change one of them to add the desired configuration.
- android_defconfig - is ${MY_ANDROID}/vendor/nxp-opensource/kernel_imx/arch/arm64/configs/android_defconfig
- android_addition_defconfig - is on the same folder ${MY_ANDROID}/device/fsl/imx8m/evk_8mm/
"merge_config.sh" is called to generate the final defconfig file prior to building the kernel
Check out: https://source.android.com/devices/architecture/kernel/config
For example, I want to add DEVMEM support on my build:
1. Change the defconfig
I add the line below to android_addition_defconfig
CONFIG_DEVMEM=y
(Or could have added it android_defconfig)
2. Build the kernel
./imx-make.sh kernel -c -j8
3. Verify your change
After compiling, you can confirm your change by reading:
${MY_ANDROID}/out/target/product/evk_8mm/obj/KERNEL_OBJ/.config
Then rebuild boot.img and reprogram the target.
%3CLINGO-SUB%20id%3D%22lingo-sub-1114245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E5%9C%A8%20Android%20%E6%9E%84%E5%BB%BA%E4%B8%AD%E6%9B%B4%E6%94%B9%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9C%A8%20Android%2010%EF%BC%88android_Q10.0.0_1.0.0%EF%BC%89%E4%B8%8A%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%82%A8%E6%9E%84%E5%BB%BA%E7%AC%AC%E4%B8%80%E4%B8%AA%20BSP%20%E4%B9%8B%E5%90%8E%EF%BC%8C%E5%86%85%E6%A0%B8%E6%BA%90%E4%BB%A3%E7%A0%81%E4%BD%8D%E4%BA%8E%EF%BC%9A%24%7BMY_ANDROID%7D%2Fvendor%2Fnxp-opensource%2Fkernel_imx%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%20i.MX8M%20Mini%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E4%BB%A5%E4%B8%8B%E4%BD%8D%E7%BD%AE%E6%9F%A5%E7%9C%8B%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9A%84%20defconfig%20%E6%96%87%E4%BB%B6%EF%BC%9A%24%7BMY_ANDROID%7D%2Fdevice%2Ffsl%2Fimx8m%2Fevk_8mm%2FUbootKernelBoardConfig.mk%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%23%20imx8mm%20kernel%20defconfig%3CBR%20%2F%3ETARGET_KERNEL_DEFCONFIG%20%3A%3D%20android_defconfig%3CBR%20%2F%3ETARGET_KERNEL_ADDITION_DEFCONF%20%3A%3D%20android_addition_defconfig%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%9B%B4%E6%94%B9%E5%85%B6%E4%B8%AD%E4%B8%80%E4%B8%AA%E4%BB%A5%E6%B7%BB%E5%8A%A0%E6%89%80%E9%9C%80%E7%9A%84%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-%20android_defconfig%20-%20%E8%B7%AF%E5%BE%84%E4%B8%BA%20%24%7BMY_ANDROID%7D%2Fvendor%2Fnxp-opensource%2Fkernel_imx%2Farch%2Farm64%2Fconfigs%2Fandroid_defconfig-%20android_addition_defconfig%20-%20%E5%9C%A8%E5%90%8C%E4%B8%80%E4%B8%AA%E6%96%87%E4%BB%B6%E5%A4%B9%20%24%7BMY_ANDROID%7D%2Fdevice%2Ffsl%2Fimx8m%2Fevk_8mm%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%83%E7%94%A8%20%22merge_config.sh%22%20%E4%BB%A5%E7%94%9F%E6%88%90%E6%9C%80%E7%BB%88%E7%9A%84%20defconfig%20%E6%96%87%E4%BB%B6%EF%BC%8C%E7%84%B6%E5%90%8E%E5%86%8D%E6%9E%84%E5%BB%BA%E5%86%85%E6%A0%B8%E3%80%82%E5%8F%82%E8%80%83%E6%96%87%E6%A1%A3%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fsource.android.com%2Fdevices%2Farchitecture%2Fkernel%2Fconfig%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fsource.android.com%2Fdevices%2Farchitecture%2Fkernel%2Fconfig%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%E6%88%91%E9%9C%80%E8%A6%81%E4%B8%BA%E6%9E%84%E5%BB%BA%E6%B7%BB%E5%8A%A0%20DEVMEM%20%E6%94%AF%E6%8C%81%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1415421648%22%20id%3D%22toc-hId--493771746%22%3E1.%20%E6%9B%B4%E6%94%B9%20defconfig%E3%80%82%3C%2FH2%3E%3CP%3E%E6%88%91%E5%B0%86%E4%BB%A5%E4%B8%8B%E8%A1%8C%E6%B7%BB%E5%8A%A0%E5%88%B0%20android_addition_defconfig%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3ECONFIG_DEVMEM%3Dy%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%EF%BC%88%E6%88%96%E8%80%85%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%85%B6%E6%B7%BB%E5%8A%A0%E5%88%B0%20android_defconfig%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1072091185%22%20id%3D%22toc-hId-1993741087%22%3E2.%20%E6%9E%84%E5%BB%BA%E5%86%85%E6%A0%B8%E3%80%82%3C%2FH2%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E.%2Fimx-make.sh%20kernel%20-c%20-j8%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--735363278%22%20id%3D%22toc-hId-186286624%22%3E3.%20%E9%AA%8C%E8%AF%81%E6%82%A8%E7%9A%84%E6%9B%B4%E6%94%B9%E3%80%82%3C%2FH2%3E%3CP%3E%E7%BC%96%E8%AF%91%E5%AE%8C%E6%88%90%E5%90%8E%EF%BC%8C%E5%8F%AF%E9%80%9A%E8%BF%87%E8%AF%BB%E5%8F%96%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%E9%AA%8C%E8%AF%81%E4%BF%AE%E6%94%B9%EF%BC%9A%3C%2FP%3E%3CP%3E%24%7BMY_ANDROID%7D%2Fout%2Ftarget%2Fproduct%2Fevk_8mm%2Fobj%2FKERNEL_OBJ%2F.config%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9A%8F%E5%90%8E%E9%87%8D%E6%96%B0%E6%9E%84%E5%BB%BA%20boot.img%20%E5%B9%B6%E7%BC%96%E7%A8%8B%E8%87%B3%E7%9B%AE%E6%A0%87%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1114245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
无评分
版本历史
最后更新:
‎02-10-2020 04:41 PM
更新人:
