How to Test Yocto for i.MX6
Join FSL-community-bsp project: https://lists.yoctoproject.org/listinfo/meta-freescale
In order to test Yocto Project for i.MX6 or any other supported board please follow the instructions pointed by FSL Community BSP.
In order to download the source code, please follow this instructions FSL Community BSP.
With the downloaded source code, you can follow the steps from this training: Yocto Training - HOME
If you face a problem, please, send an email to https://lists.yoctoproject.org/listinfo/meta-freescale
This page made sense when there was not other tutorial to point people on how to download and build the very first image using Yocto Project tools for i.MX family boards. Today, FSL Community BSP has become a complete environment with its own landing page (FSL Community BSP) and a collaborative community around meta-freescale mailing list. I encourage you to register in meta-freescale mailing list.
I configured this document to be closed for new comments. In case of any issue or bug, please, send an email to meta-freescale.
评论
Daiane, my "repo sync" failed with this output:
* [new tag]     purple-3.2 -> purple-3.2
* [new tag]     purple-3.2.1 -> purple-3.2.1
Fetching projects: 100% (6/6), done.
error: Exited sync due to gc errors
was you able to take the source code?
Are you under any proxy?
I have a lot of sync errors due to my proxy configurations, and when I try again I can take the source code without errors. Could you try again?
Thanks Daiane,
This is a terrific intro to Yocto.
Note that there is a typo above ("souce" should be "source").
Daiane, after I did "repo sync -j2" the problem went away. Thanks for all your help.
I'm trying to follow the directions listed above by entering the following commands:
  curl https://dl-ssl.google.com/dl/googlesource/git-repo/repo > ./repo
  chmod a+x ./repo
  repo init -u https://github.com/Freescale/fsl-community-bsp-platform -b master
  repo sync
  vi conf/local.conf
  bitbake fsl-image-gui
However, I'm receiving the following error:
Pseudo is not present but is required, building this first before the main build
Loading cache: 100% |###########################################| ETA:  00:00:00
Loaded 1598 entries from dependency cache.
ERROR: No recipes available for:
  /home/vradmin/projects/MOCUPort/YOCTO/rootfs_builder/sources/meta-fsl-arm/recipes-core/udev/udev_173.bbappend
ERROR: Command execution failed: Exited with 1
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
Do you know what might be causing this error?
Seems like adding:
BBMASK = "udev_.*\.bbappend$"
to end of conf/local.conf fixes works around this error.
Yes; I will fix it. The master doesn't need to force udev anymore.
I sent the patch to the mailing list (meta-freescale).
The patches are now merged and it should just work.
I also seem to fail on
source ./setup-environment build
bash: ./setup-environment: No such file or directory
Is there something else that I need to install
You need to be under "rootfs_builder", if you´re following exactly the directory approach from tutorial.
If you:
$ cd rootfs_builder
$ ls
You must see setup-environment as a text file (and repo and README and directory sources)
./repo sync -j2
I only see a repo file and a .repo directory.
So, your problem is during sync.
Are you under a proxy? Can you reach https or only http?
Hi I also have the same issue i.e
./repo sync -j2
and my proxy settings are as fllows:
faisal@faisal-desktop:~$ set | grep -i proxy
            url proxy fetch push mirror skipDefaultUpdate
        core.gitProxy
        http.proxy
                COMPREPLY=($( compgen -W "$opts --percent --force                 --test --replacepkgs --replacefiles --root                 --excludedocs --includedocs --noscripts --ignorearch                 --dbpath --prefix --ignoreos --nodeps --allfiles                 --ftpproxy --ftpport --justdb --httpproxy --httpport                 --noorder --relocate --badreloc --notriggers                 --excludepath --ignoresize --oldpackage                 --queryformat --repackage --nosuggests" -- "$cur" ));
                            COMPREPLY=($( compgen -W "$opts --ftpport --ftpproxy                         --httpport --httpproxy" -- "$cur" ));
        PreferredAuthentications Protocol ProxyCommand \
I just tried on my machine and it does work over here.
You can try this:
repo init -u http://github.com/Freescale/fsl-community-bsp-platform -b master
instead of https.
Could you, please, try again?
I've found that on ubuntu there could be problem with git which causes this error.
To resolve :
sudo apt-add-repository ppa:git-core/ppa
sudo apt-get update
sudo apt-get install git
After that there is no matter are you using https or http.
Hi.... I am running into this basic error.. Looks like repo cannot find the web page.
root@LinuxRig:/home/wintu/YOCTO# repo init -u http://github.com/Freescale/fsl-community-bsp-platform -b danny
... A new repo command ( 1.18) is available.
... You should upgrade soon:
    cp /home/wintu/YOCTO/.repo/repo/repo /bin/repo
fatal: http://github.com/Freescale/fsl-community-bsp-platform/info/refs download error - The requested URL returned error: 403
  Any help....
I just tried it over here and it does work.
Could you, please, test the same again? If you face the error again, try to reach the web page using your browser.
Make sure your proxy allow this operation. (double check if you´re using http or https proxy)
Besides the tests Daiane has asked you please give more details about your host system:
* distribution
* version
Hi Daiane,
    I tried same thing again.. Even i tried with https:// and still same issue.
And when i try it from browser too i get same mesage. ( attached screen shot)
I'm from india... So is that web page not accessible from india ??
Winston
Hi OtavioSalvador,
      I m using Ubuntu 9.04 Jaunty. with kernel 2.6.28-11-generic.
  I guess that web address not accessible in india.
  Winston
I just did a new test here:
~/test% repo init -u https://github.com/Freescale/fsl-community-bsp-platform -b danny
Get https://gerrit.googlesource.com/git-repo/clone.bundle
Get https://github.com/Freescale/fsl-community-bsp-platform
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:--  0:00:09 --:--:--     0
curl: (22) The requested URL returned error: 404 Not Found
Server does not provide clone.bundle; ignoring.
WARNING: gnome-keyring:: couldn't connect to: /run/user/otavio/keyring-q0sd1e/pkcs11: No such file or directory
remote: Counting objects: 69, done.
remote: Compressing objects: 100% (63/63), done.
remote: Total 69 (delta 21), reused 53 (delta 5)
Unpacking objects: 100% (69/69), done.
From https://github.com/Freescale/fsl-community-bsp-platform
* [new branch]      danny      -> origin/danny
* [new branch]      denzil     -> origin/denzil
* [new branch]      master     -> origin/master
* [new tag]         1.2        -> 1.2
Your identity is: Otavio Salvador <[email protected]>
If you want to change this, please re-run 'repo init' with --config-name
repo initialized in /home/otavio/test
So it is clearly something at your side. I once had a problem due curl issues. 'repo' uses curl to fetch some stuff (as git does as well) so maybe you might try to upgrade curl and give it a new try?
Does anyone have any tips for booting the sdcard. I've tried the uboot that comes with it and I've tried known good commands/ similar commands to an ltib generated sd card. However, no luck so far.
I'll I get is a stall at loading uImage, when I run the card (directly burned).
Any thoughts?
Also is there any issue with working off the master branch?
Or is that the most buggy version?
P.S. My board is a SabreSDP, IMX6.
The easiest way of making it to work is to dd the tmp/deploy/images/<image>.sdcard file directly onto your device.
To dd the u-boot.imx binary you should avoid the skip=2 (as the u-boot.imx has no padding).
Hi Otavio,
Thanks for answering.
I followed the instruction above.
"sudo dd if=rootfs_builder/build/tmp/deploy/images/fsl-image-test.sdcard of=/dev/sdb"
It just doesn't seem to boot. Before that I've had no problem getting my ltib images and the ubuntu RFS up.
This is my first foray into Yocto. So I was hoping that I didn't miss anything.
Hum; what is the revision of your board?
I'll have to get back to you on that one. I do know that the box has images on the outside, where the earlier SDP's did not have the box images.
I know that doesn't help much, but I'll have a better answer for you later in the day. I as far as I know it's quite new.
If it is the revision C it might be the problem; I am backporting the fix of U-Boot mainline to the 2012.10 and will post a heads-up when it is done.
So I did the porting of need changes. Could you please give this a try?
Do:
$: git clone --branch patches-2012.10 git://github.com/Freescale/u-boot-imx.git u-boot-imx
Apply the patches:
http://download.ossystems.com.br/~otavio/u-boot-patches/2012.10/0001-COMMON-Add-__stringify-function...
http://download.ossystems.com.br/~otavio/u-boot-patches/2012.10/0002-mx6-Disable-Power-Down-Bit-of-w...
http://download.ossystems.com.br/~otavio/u-boot-patches/2012.10/0003-Backport-environment-changes-fr...
And setup your toolchain. Build: u-boot.imx and put it in a sdcard. I hope it works. If you confirms it to me I will be able to push it so we fix it in danny.
The Revision is: REV C2
I will try this out and get an update back to you.
I'm having difficulties setting up the tool-chain using Yocto. Any advice would be helpful.
Please, create a new topic with your question and some log.
setup tool-chain on yocto is easy, but it´s not trivial, so I believe a new discussion will be more organized for any other person looking for it.
Now the patches otavio posted is already integrated, so if you repo sync your danny branch you will be able to take the patches and test it with no additional steps.
If you create a new topic, please, share it with me
I performed the repo sync
Then I performed a bitbake fsl-image-test
Then wrote the card.
The below log shows a series of boots. With different outcomes.
U-Boot 2012.10-00994-g7e6c682 (Feb 22 2013 - 09:15:52)
CPU:   Freescale i.MX6Q rev1.2 at 792 MHz
Reset cause: POR
Board: MX6Q-SabreSD
DRAM:  1 GiB
WARNING: Caches not enabled
MMC:   FSL_SDHC: 0
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   FEC [PRIME]
Warning: FEC using MAC address from net device
Hit any key to stop autoboot:  0
mmc0 is current device
reading boot.scr
** Unable to read "boot.scr" from mmc 0:1 **
reading uImage
Reset cause: POR
Board: MX6Q-SabreSD
DRAM:  1 GiB
MMC:   FSL_SDHC: 0
In:    serial
Out:   serial
Err:   serial
Net:   FEC [PRIME]
reading boot.scr
reading uImage
Error reading cluster
** Unable to read "uImage" from mmc 0:1 **
Booting from net ...
FEC Waiting for PHY auto negotiation to complete......... TIMEOUT !
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
Retry count exceeded; starting again
BOOTP broadcast 1
Reset cause: POR
Board: MX6Q-SabreSD
DRAM:  1 GiB
MMC:   FSL_SDHC: 0
Reset cause: POR
Board: MX6Q-SabreSD
DRAM:  1 GiB
MMC:   FSL_SDHC: 0
In:    serial
Out:   serial
Err:   serial
Net:   FEC [PRIME]
reading boot.scr
bad MBR sector signature 0x055a
** Partition 1 not valid on device 0 **
** Unable to use mmc 0:1 for fatload **
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
Reset cause: POR
Board: MX6Q-SabreSD
DRAM:  1 GiB
MMC:   FSL_SDHC: 0
Reset cause: POR
Board: MX6Q-SabreSD
DRAM:  1 GiB
MMC:   FSL_SDHC: 0
In:    serial
Out:   serial
Err:   serial
Net:   FEC [PRIME]
reading boot.scr
reading uImage
Reset cause: POR
Board: MX6Q-SabreSD
DRAM:  1 GiB
MMC:   FSL_SDHC: 0
In:    serial
Out:   serial
Err:   serial
Net:   FEC [PRIME]
reading boot.scr
reading uImage
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
Reset cause: POR
Board: MX6Q-SabreSD
DRAM:  1 GiB
MMC:   FSL_SDHC: 0
In:    serial
Out:   serial
Err:   serial
Net:   FEC [PRIME]
reading boot.scr
reading uImage
Reset cause: POR
Board: MX6Q-SabreSD
DRAM:  1 GiB
MMC:   FSL_SDHC: 0
In:    serial
Out:   serial
Err:   serial
Net:   FEC [PRIME]
reading boot.scr
reading uImage
Reset cause: POR
Board: MX6Q-SabreSD
DRAM:  1 GiB
MMC:   FSL_SDHC: 0
In:    serial
Out:   serial
Err:   serial
Net:   FEC [PRIME]
** No partition table - mmc 0 **
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
I haver successfully built the in both master and danny using "LinuxMint-14" as a host os in virtualbox as well as natively on laptop. It would be *nice* to add that as a validated build system. Linux Mint (mate desktop) is a much more productive environment vs some of the "other" popular desktops - and much lighter weight!
I think it's a great idea! Thanks a lot.
Could you, please, share how was you able to achieve it in your side?
The list of validated distros are the ones the active developers use so they keep testing it; I'll bring you the discussion about adding MINT as a valid one as it is based in Ubuntu and thus share most core components (toolchain and like).
Do you think you'll be an active user of Yocto or you're just playing with it for curiosity?
Sorry, but also i trivial problem, probably:
$ repo init -u https://github.com/Freescale/fsl-community-bsp-platform -b danny
...but nothing is fetched. The repo init commands just outputs the line and exits.
So...:
$ repo sync
error: command 'sync' requires repo to be installed first.
        Use "repo init" to install it here.
Same result id http:// is used instead of https:// - in the command, as well as in the REPO_URL inside the repo script.
Sorry I'm no git expert - is there supposed to be a file named "clone.bundle" in the referenced git-repo? I don't see it...
I´m downloading it over here.
Same result.
But in the meantime I tried at home, on my own computer and network: No problem (or not this problem, at least :smileyhappy:).
So the problem is definitely in "my" end. Differences: At work, with the problem, we have CentOS5 + addons, and firewall/proxy. At home: CentOS6 and no proxy. (Needed to install a newer git than the one provided with CentOS6).
Think I tried everything to get the proxy stuff correct; I *was* able to fetch "repo" with curl over https. And also tried git config.... I will investigate further; guess it's hard to figure out from your place what's wrong here!
The build at home ran for most of the night, then bailed out... I'll raise that as a separate question.
And... tnx for you prompt answer!
Trying to build fsl-image-gui. The build runs fine for some time (some hours - does more than 3000 of the app. 6100 tasks, and eats >40GB of disk space!). Then:
WARNING: Failed to fetch URL http://gpe.linuxtogo.org/download/source/xserver-common-1.34.tar.gz, attempting MIRRORS if available
ERROR: Fetcher failure: Fetch command failed with exit code 4, no output
ERROR: Function failed: Fetcher failure for URL: 'http://gpe.linuxtogo.org/download/source/xserver-common-1.34.tar.gz'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/hj/yocto/rootfs_builder/build/tmp/work/all-poky-linux/xserver-common-1.34-r8/temp/log.do_fetch.24584
ERROR: Task 5488 (/home/hj/yocto/rootfs_builder/sources/meta-openembedded/meta-oe/recipes-graphics/xserver-common/xserver-common_1.34.bb, do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3517 tasks of which 3515 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
(This is the output from an attempt to restart the build).
"File not found", it seems... does the recipe need update - or other suggestions?
Seems to be a proxy problem in connection with the "repo" script.
Hacked the script; the clone.bundle file is created with the content: <HTML></HTML>
clone.bundle is created by the _DownloadBundle function in "repo". It uses urllib to retrieve the data.
With wireshark I can see that the proxy server is accessed with "GET https://gerrit.googlesource.com./(...)", but there is no encrypted session started.
Maybe bad Python version? (It's 2.6).
I always face failed to fetch, then when I try again everything works. I think it´s the network somehow.
Failed to fetch is bitbake trying to download the package from server provider and not being able to complete it.
Due to local firewall restrictions on the use of the git protocol I am experiencing a error during do_fetch for danny udev_173. Removing the bbappend reverts to getting a tar over http but file is missing (the reason why there is a bbappend to change to git I suppose)
Fedora has a copy and this patch seems to resolve the problem:
--- a/meta-fsl-arm/recipes-core/udev/udev_173.bbappend    2013-04-04 22:31:22.006040965 -0700
+++ b/meta-fsl-arm/recipes-core/udev/udev_173.bbappend    2013-04-05 00:09:54.327713016 -0700
@@ -1,8 +1,5 @@
-PRINC := "${@int(PRINC) + 2}"
+PRINC := "${@int(PRINC) + 3}"
-# Switch to git source
-# 173 tag
-SRCREV = "ad667dff51711fed763a23283d973486de3cd6b5"
+# Switch to fedora source
SRC_URI := "${@oe_filter_out('${KERNELORG_MIRROR}/linux/utils/kernel/hotplug/udev-${PV}.tar.bz2', '${SRC_URI}', d)}"
-SRC_URI_prepend = "git://git.kernel.org/pub/scm/linux/hotplug/udev.git;protocol=git "
-S = "${WORKDIR}/git"
+SRC_URI_prepend = "http://pkgs.fedoraproject.org/repo/pkgs/udev/udev-173.tar.bz2/91a88a359b60bbd074b024883cc0dbde/udev-... "
Yes; this is the reason why we moved to the GIT. However I think you do need to fix your firewall as many recipes are using GIT to fetch the sources and you'll have a huge problem to workaround it for every case.
I will try to have the corporate firewall policy changed but I am only a small cog...
In practice the absence of the git protocol does not seem to be a huge problem. I found no other errors for a minimal core image build and only 2 errors when running 'bitbake -c fetchall fsl-image-test'. These were fixed by adding ;protocol=http to the end of the url in the fio_2.0.5 recipe and changing to http://linuxtv.org/downloads/v4l-utils/v4l-utils-0.8.8.tar.bz2 for the v4l-utils_0.8.8 recipe
I am experiencing an error during do_compile of perf_3.4
util/include/linux/compiler.h:8:0: error: "__attribute_const__" redefined
There appears to be a patch available to resolve this problem at https://lists.yoctoproject.org/pipermail/yocto/2012-October/012625.html but it does not seem to have been applied to meta-fsl-arm. Can someone explain to me a possible reason why I am seeing this problem (when I assume others are not). Should I apply the patch or may there be a different cause of the problem
I see the same compile problem with perf. Decided to silently await that someone fixes it :smileyhappy:
Ok I will try adding meta-fsl-arm/recipes-kernel/perf/files/define-attribute-const.patch and meta-fsl-arm/recipes-kernel/perf/perf_3.4.bbappend with the content from Chunrong Guo and see if this resolves it
%3CLINGO-SUB%20id%3D%22lingo-sub-1110838%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110838%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23ff0000%3B%22%3E%E5%8A%A0%E5%85%A5FSL-community-bsp%E9%A1%B9%E7%9B%AE%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Flists.yoctoproject.org%2Flistinfo%2Fmeta-freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Flists.yoctoproject.org%2Flistinfo%2Fmeta-freescale%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BA%86%E6%B5%8B%E8%AF%95%20i.MX6%20%E6%88%96%3CA%20href%3D%22http%3A%2F%2Ffreescale.github.io%2Fdoc%2Frelease-notes%2Fcurrent%2Findex.html%23document-bsp-scope%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E5%8F%97%E6%94%AF%E6%8C%81%E4%B8%BB%E6%9D%BF%3C%2FA%3E%E7%9A%84%20Yocto%20%E9%A1%B9%E7%9B%AE%EF%BC%8C%E8%AF%B7%E6%8C%89%E7%85%A7%20FSL%20%E7%A4%BE%E5%8C%BA%20BSP%20%E6%8C%87%E5%87%BA%E7%9A%84%E8%AF%B4%E6%98%8E%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BA%86%E4%B8%8B%E8%BD%BD%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%8C%E8%AF%B7%E6%8C%89%E7%85%A7%E6%AD%A4%E8%AF%B4%E6%98%8E%3CA%20href%3D%22http%3A%2F%2Ffreescale.github.io%2F%23download%22%20title%3D%22http%3A%2F%2Ffreescale.github.io%2F%23download%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EFSL%20%E7%A4%BE%E5%8C%BA%20BSP%3C%2FA%3E%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E4%B8%8B%E8%BD%BD%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%8C%89%E7%85%A7%E6%9C%AC%E5%9F%B9%E8%AE%AD%E4%B8%AD%E7%9A%84%E6%AD%A5%E9%AA%A4%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%EF%BC%9A%20%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23ff0000%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%22%20target%3D%22_blank%22%3EYocto%20%E5%9F%B9%E8%AE%AD%20-%20%E4%B8%BB%E9%A1%B5%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E9%81%87%E5%88%B0%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%91%E9%80%81%E7%94%B5%E5%AD%90%E9%82%AE%E4%BB%B6%E8%87%B3%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23ff0000%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Flists.yoctoproject.org%2Flistinfo%2Fmeta-freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Flists.yoctoproject.org%2Flistinfo%2Fmeta-freescale%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%B2%A1%E6%9C%89%E5%85%B6%E4%BB%96%E6%95%99%E7%A8%8B%E6%8C%87%E5%AF%BC%E4%BA%BA%E4%BB%AC%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20Yocto%20Project%20%E5%B7%A5%E5%85%B7%E4%B8%BA%20i.MX%20%E7%B3%BB%E5%88%97%E4%B8%BB%E6%9D%BF%E4%B8%8B%E8%BD%BD%E5%92%8C%E6%9E%84%E5%BB%BA%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%9B%BE%E5%83%8F%E6%97%B6%EF%BC%8C%E8%BF%99%E4%B8%AA%E9%A1%B5%E9%9D%A2%E6%98%AF%E6%9C%89%E6%84%8F%E4%B9%89%E7%9A%84%E3%80%82%E5%A6%82%E4%BB%8A%EF%BC%8CFSL%20%E7%A4%BE%E5%8C%BA%20BSP%20%E5%B7%B2%E7%BB%8F%E6%88%90%E4%B8%BA%E4%B8%80%E4%B8%AA%E5%AE%8C%E6%95%B4%E7%9A%84%E7%8E%AF%E5%A2%83%EF%BC%8C%E6%8B%A5%E6%9C%89%E8%87%AA%E5%B7%B1%E7%9A%84%E7%99%BB%E9%99%86%E9%A1%B5%E9%9D%A2%EF%BC%88%20%3CA%20href%3D%22http%3A%2F%2Ffreescale.github.io%2F%22%20title%3D%22http%3A%2F%2Ffreescale.github.io%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EFSL%20%E7%A4%BE%E5%8C%BA%20BSP%3C%2FA%3E%20%EF%BC%89%E5%92%8C%E5%9B%B4%E7%BB%95%3CA%20href%3D%22https%3A%2F%2Flists.yoctoproject.org%2Flistinfo%2Fmeta-freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSTRONG%3Emeta-freescale%3C%2FSTRONG%3E%3C%2FA%3E%E9%82%AE%E4%BB%B6%E5%88%97%E8%A1%A8%E7%9A%84%E5%8D%8F%E4%BD%9C%E7%A4%BE%E5%8C%BA%E3%80%82%E6%88%91%E9%BC%93%E5%8A%B1%E6%82%A8%E5%9C%A8%3CA%20href%3D%22https%3A%2F%2Flists.yoctoproject.org%2Flistinfo%2Fmeta-freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Emeta-freescale%3C%2FA%3E%E9%82%AE%E4%BB%B6%E5%88%97%E8%A1%A8%E4%B8%AD%E6%B3%A8%E5%86%8C%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%E6%AD%A4%E6%96%87%E6%A1%A3%E9%85%8D%E7%BD%AE%E4%B8%BA%E5%85%B3%E9%97%AD%EF%BC%8C%E4%B8%8D%E5%86%8D%E6%8E%A5%E5%8F%97%E6%96%B0%E8%AF%84%E8%AE%BA%E3%80%82%E5%A6%82%E6%9E%9C%E5%87%BA%E7%8E%B0%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%E6%88%96%E9%94%99%E8%AF%AF%EF%BC%8C%E8%AF%B7%E5%8F%91%E9%80%81%E7%94%B5%E5%AD%90%E9%82%AE%E4%BB%B6%E8%87%B3%3CA%20href%3D%22https%3A%2F%2Flists.yoctoproject.org%2Flistinfo%2Fmeta-freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Emeta-freescale%3C%2FA%3E%20%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BA%8B%E5%AE%9E%E4%B8%8A%EF%BC%8C%E6%88%91%E6%83%B3%E5%88%A0%E9%99%A4%E8%BF%99%E4%B8%AA%20DOC%20%E5%B9%B6%E5%B0%86%E6%89%80%E6%9C%89%E5%85%B6%E4%BB%96%E6%96%87%E4%BB%B6%E6%9B%B4%E6%96%B0%E5%88%B0%E6%9C%80%E6%96%B0%E7%9A%84%20cmds%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%A4%9A%E4%B8%AA%E6%96%87%E4%BB%B6%E4%B8%AD%E9%87%8D%E5%A4%8D%E7%9B%B8%E5%90%8C%E7%9A%84%E6%AD%A5%E9%AA%A4%E6%98%AF%E6%B2%A1%E6%9C%89%E6%84%8F%E4%B9%89%E7%9A%84%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111030%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111030%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%BF%AB%E9%80%9F%E5%9B%9E%E5%A4%8D%EF%BC%81%E6%9C%89%E7%94%A8%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPS%20Daiane%EF%BC%8C%E6%82%A8%E8%83%BD%E5%90%A6%E5%B0%86%E4%B8%BB%E5%B8%96%E4%B8%AD%E7%9A%84%E8%BF%99%E4%B8%80%E8%A1%8C%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E2%80%9C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3Ecurl%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fdl-ssl.google.com%2Fdl%2Fgooglesource%2Fgit-repo%2Frepo%22%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fdl-ssl.google.com%2Fdl%2Fgooglesource%2Fgit-repo%2Frepo%3C%2FA%3E%20%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%26gt%3B%20.%2Frepo%20%E2%80%9D%3C%2FSPAN%3E%E9%87%8D%E5%86%99%E4%B8%BA%E6%AD%A3%E7%A1%AE%E7%9A%84%E4%B8%80%E8%A1%8C%E2%80%9C%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20monospace%3B%22%3Ecurl%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fcommondatastorage.googleapis.com%2Fgit-repo-downloads%2Frepo%22%20style%3D%22font-family%3A%20monospace%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fcommondatastorage.googleapis.com%2Fgit-repo-downloads%2Frepo%3C%2FA%3E%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20monospace%3B%22%3E%26gt%3B%20.%2Frepo%3C%2FSPAN%3E%20%E2%80%9D%E3%80%82%E6%88%91%E6%83%B3%E8%BF%99%E5%B0%86%E4%BC%9A%E9%9D%9E%E5%B8%B8%E6%9C%89%E5%B8%AE%E5%8A%A9...%E6%8F%90%E5%89%8D%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111029%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111029%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%E5%BA%B7%E6%96%AF%E5%9D%A6%E4%B8%81%C2%B7%E7%A7%91%E7%93%A6%E5%88%97%E5%A4%AB%E5%86%99%E9%81%93%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%E6%9C%AC%E6%8C%87%E5%8D%97%E7%9B%AE%E5%89%8D%E5%B0%9A%E6%9C%AA%E5%AE%9E%E7%8E%B0%EF%BC%81%E8%87%B3%E5%B0%91%E8%BF%99%E4%B8%AA%E9%93%BE%E6%8E%A5%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E2%80%9C%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3Ecurl%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fdl-ssl.google.com%2Fdl%2Fgooglesource%2Fgit-repo%2Frepo%22%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fdl-ssl.google.com%2Fdl%2Fgooglesource%2Fgit-repo%2Frepo%3C%2FA%3E%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%26gt%3B%20.%2Frepo%E2%80%9D%3C%2FSPAN%3E%20%E3%80%82%E8%AF%B7%E5%B0%86%E5%85%B6%E6%9B%B4%E6%96%B0%E8%87%B3%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E3%80%82%E5%A4%9A%E8%B0%A2%EF%BC%81%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%82%A8%E4%B9%9F%E6%B3%A8%E6%84%8F%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%80%E7%82%B9%E3%80%82%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E4%BB%AC%E7%8E%B0%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9A%84%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20monospace%3B%22%3Ecurl%20%3CA%20href%3D%22http%3A%2F%2Fcommondatastorage.googleapis.com%2Fgit-repo-downloads%2Frepo%22%20style%3D%22color%3A%20%234183c4%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fcommondatastorage.googleapis.com%2Fgit-repo-downloads%2Frepo%3C%2FA%3E%26gt%3B%20.%2Frepo%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%AC%E6%8C%87%E5%8D%97%E7%9B%AE%E5%89%8D%E5%B0%9A%E6%9C%AA%E5%AE%9E%E7%8E%B0%EF%BC%81%E8%87%B3%E5%B0%91%E8%BF%99%E4%B8%AA%E9%93%BE%E6%8E%A5%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E2%80%9C%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3Ecurl%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fdl-ssl.google.com%2Fdl%2Fgooglesource%2Fgit-repo%2Frepo%22%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fdl-ssl.google.com%2Fdl%2Fgooglesource%2Fgit-repo%2Frepo%3C%2FA%3E%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%26gt%3B%20.%2Frepo%E2%80%9D%3C%2FSPAN%3E%20%E3%80%82%E8%AF%B7%E5%B0%86%E5%85%B6%E6%9B%B4%E6%96%B0%E8%87%B3%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E3%80%82%E5%A4%9A%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111027%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111027%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CTT%3Edf%3C%2FTT%3E%E6%98%AF%E7%94%A8%E4%BA%8E%E6%B5%8B%E9%87%8F%E5%AE%89%E8%A3%85%E5%A4%A7%E5%B0%8F%E7%9A%84%E7%B3%9F%E7%B3%95%E5%B7%A5%E5%85%B7%EF%BC%88%3CEM%3E%E9%99%A4%E4%BA%86%3C%2FEM%3E%E5%9C%A8%E7%9B%AE%E6%A0%87%E7%B3%BB%E7%BB%9F%E4%B8%8A%EF%BC%89%E3%80%82%E6%82%A8%E5%9C%A8%2057G%20%E8%BF%99%E4%B8%AA%E6%95%B0%E5%AD%97%E4%B8%AD%E7%9C%8B%E5%88%B0%E7%9A%84%E5%8F%8D%E6%98%A0%E6%98%AF%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%AF%8F%E4%B8%AA%E6%9C%80%E7%BB%88%E6%98%A0%E5%83%8F%E9%87%8D%E5%A4%8D%E4%B8%89%E6%AC%A1%EF%BC%88%E4%B8%80%E6%AC%A1%E4%BD%9C%E4%B8%BA%20.tar.bz2%20%E5%AD%98%E6%A1%A3%EF%BC%8C%E4%B8%80%E6%AC%A1%E4%BD%9C%E4%B8%BA%20ext3%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E6%98%A0%E5%83%8F%EF%BC%8C%E4%B8%80%E6%AC%A1%E4%BD%9C%E4%B8%BA%20.sdcard%E5%9D%97%E5%9B%BE%E5%83%8F%EF%BC%89%EF%BC%8C%3C%2FLI%3E%3CLI%3E%E6%89%80%E6%9C%89%E6%BA%90%E4%BB%A3%E7%A0%81%E6%96%87%E4%BB%B6%EF%BC%8C%3C%2FLI%3E%3CLI%3E%E6%89%80%E6%9C%89%E6%9E%84%E5%BB%BA%E4%BA%A7%E5%93%81%EF%BC%88.o%20%E6%96%87%E4%BB%B6%E7%AD%89%EF%BC%89%EF%BC%8C%3C%2FLI%3E%3CLI%3E%E6%89%80%E6%9C%89%E6%9E%84%E5%BB%BA%E5%B7%A5%E5%85%B7%EF%BC%8C%3C%2FLI%3E%3CLI%3E%E4%B8%8A%E8%BF%B0%E6%89%80%E6%9C%89%E5%86%85%E5%AE%B9%E7%9A%84%E5%88%86%E5%8F%91%E6%A1%A3%E6%A1%88%E5%92%8C%2F%E6%88%96%E6%BA%90%E5%AD%98%E5%82%A8%E5%BA%93%E7%9A%84%E7%BC%93%E5%AD%98%E5%89%AF%E6%9C%AC%EF%BC%88%E6%98%AF%E7%9A%84%EF%BC%8C%E5%AE%8C%E6%95%B4%E7%9A%84%20Git%20%E5%AD%98%E5%82%A8%E5%BA%93%E5%92%8C%E5%AE%8C%E6%95%B4%E7%9A%84%E5%8E%86%E5%8F%B2%E8%AE%B0%E5%BD%95%E9%83%BD%E4%BC%9A%E8%A2%AB%E5%85%8B%E9%9A%86%E2%80%94%E2%80%94%E5%9C%A8%E6%9E%84%E5%BB%BA%E5%86%85%E6%A0%B8%E6%97%B6%E4%BC%9A%E5%BE%88%E6%9C%89%E8%B6%A3%EF%BC%89%EF%BC%8C%3C%2FLI%3E%3CLI%3ELinux%20%E5%AE%89%E8%A3%85%E7%9A%84%E5%85%B6%E4%BD%99%E9%83%A8%E5%88%86%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%E3%80%82%E8%BF%99%E4%B8%AA%E6%95%B0%E5%AD%97%E5%B9%B6%E4%B8%8D%E4%BB%A4%E4%BA%BA%E6%84%8F%E5%A4%96%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111026%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111026%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%B8%8D%E6%98%8E%E7%99%BD%E4%BD%A0%E7%9A%84%E6%84%8F%E6%80%9D%EF%BC%8C%E9%9F%A6%E6%81%A9%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111025%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111025%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%8C%89%E7%85%A7%E4%B8%8A%E9%9D%A2%E6%8F%8F%E8%BF%B0%E7%9A%84%E6%96%B9%E5%BC%8F%E6%9E%84%E5%BB%BA%E4%BA%86%E5%9B%BE%E5%83%8F%EF%BC%8C%E4%BD%86%E6%88%91%E5%AF%B9%20sda1%20%E4%B8%AD%E5%9B%BE%E5%83%8F%E7%9A%84%E5%A4%A7%E5%B0%8F%E6%84%9F%E5%88%B0%E6%83%8A%E8%AE%B6%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%8E%9F%E4%BB%A5%E4%B8%BA%E5%AE%83%E4%BC%9A%E5%B0%8F%E5%BE%97%E5%A4%9A%3C%2FP%3E%3CP%3E%E5%AE%8C%E6%95%B4%E7%9A%84%E5%8F%91%E8%A1%8C%E7%89%88%E5%AE%89%E8%A3%85%E5%8F%AA%E9%9C%80%E8%A6%81%2012Gigs%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BB%80%E4%B9%88%E6%84%8F%E8%A7%81%E5%90%97%EF%BC%9F%EF%BC%9F%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ewayne%40AMILO-2727%3A~%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fdeploy%2Fimages%2Fimx6dlsabresd%24%20df%20-h%3C%2FP%3E%3CP%3E%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E5%A4%A7%E5%B0%8F%E5%B7%B2%E4%BD%BF%E7%94%A8%E5%8F%AF%E7%94%A8%E4%BD%BF%E7%94%A8%E7%8E%87%25%E5%AE%89%E8%A3%85%E4%BA%8E%3C%2FP%3E%3CP%3E%2Fdev%2Fsda1%20457G%2057G%20378G%2013%25%20%2F%3C%2FP%3E%3CP%3E%E6%97%A0%204.0K0%204.0K%200%25%20%2Fsys%2Ffs%2Fcgroup%3C%2FP%3E%3CP%3Eudev%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20995M%26nbsp%3B%204.0K%26nbsp%3B%20995M%26nbsp%3B%26nbsp%3B%201%25%20%2Fdev%3C%2FP%3E%3CP%3Etmpfs%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20201M%26nbsp%3B%201.1M%26nbsp%3B%20200M%26nbsp%3B%26nbsp%3B%201%25%20%2Frun%3C%2FP%3E%3CP%3E%E6%97%A0%205.0M0%205.0M%200%25%20%2F%E8%BF%90%E8%A1%8C%2F%E9%94%81%E5%AE%9A%3C%2FP%3E%3CP%3E%E6%97%A0%201004M%2015M%20990M%202%25%20%2F%E8%BF%90%E8%A1%8C%2Fshm%3C%2FP%3E%3CP%3E%E6%97%A0%20100M%2096K%20100M%201%25%20%2F%E8%BF%90%E8%A1%8C%2F%E7%94%A8%E6%88%B7%3C%2FP%3E%3CP%3Ewayne%40AMILO-2727%3A~%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fdeploy%2Fimages%2Fimx6dlsabresd%24%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%20%3C%2FP%3E%3CP%3E%E9%9F%A6%E6%81%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111024%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111024%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%B8%BB%E6%9D%BF%E7%9A%84%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E8%BF%9B%E8%A1%8C%E7%99%BB%E5%BD%95%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111023%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111023%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%9E%84%E5%BB%BA%E4%BA%86%20qte-in-use-image%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%88%91%E7%9A%84%20Linux%20%E5%B7%B2%E6%88%90%E5%8A%9F%E8%BF%90%E8%A1%8C%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E8%8E%B7%E5%8F%96%20smarthome%20%E6%BC%94%E7%A4%BA%EF%BC%8C%E7%8E%B0%E5%9C%A8%E6%88%91%E6%83%B3%E8%A6%81%E4%B8%80%E4%B8%AA%20root%40imx6qsabre%EF%BC%9A%E5%B9%B6%E7%99%BB%E5%BD%95%E4%BB%A5%E8%BF%90%E8%A1%8C%E6%BC%94%E7%A4%BA%20qt%20%E7%A4%BA%E4%BE%8B%E4%BB%A5%E5%8F%8A%E6%88%91%E8%87%AA%E5%B7%B1%E7%9A%84%20qt%20%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BD%86%E6%98%AF%E5%A6%82%E4%BD%95%E5%9C%A8%20samrthome%20%E6%BC%94%E7%A4%BA%E4%B9%8B%E5%90%8E%E8%8E%B7%E5%8F%96%E8%AF%A5%E7%99%BB%E5%BD%95%E3%80%82%E8%AF%B7%E5%B8%AE%E5%B8%AE%E6%88%91%E5%90%A7%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111022%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111022%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E9%97%AE%E9%A2%98%E8%A7%A3%E5%86%B3%E4%BA%86%E5%90%97%EF%BC%9F%E6%88%91%E4%B9%8B%E5%89%8D%E5%9C%A8%20usbtouchscreen%20%E4%B8%8A%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111021%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111021%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EJoerg%2COtaviosalvador%2C%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82bitbake%20core-image-minimal%20%E6%88%90%E5%8A%9F%EF%BC%9B%E6%88%91%E6%83%B3%E6%92%AD%E6%94%BE%E8%A7%86%E9%A2%91%EF%BC%8C%E5%A6%82%E4%BD%95%E9%80%9A%E8%BF%87%20Yocto%20%E7%94%A8%20gstreamer%20%E6%9E%84%E5%BB%BA%20Qt-x11%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111020%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111020%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%BE%88%E5%8F%AF%E8%83%BD%E9%81%87%E5%88%B0%E4%BA%86%E5%86%85%E5%AD%98%E4%B8%8D%E8%B6%B3%E6%88%96%E7%B1%BB%E4%BC%BC%E9%97%AE%E9%A2%98%EF%BC%9B%E6%97%A0%E8%AE%BA%E5%93%AA%E7%A7%8D%E6%83%85%E5%86%B5%EF%BC%8C%E6%82%A8%E9%83%BD%E5%BF%85%E9%A1%BB%E6%8C%89%E7%85%A7%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FJoerg-SH%22%20target%3D%22_blank%22%3EJoerg-SH%3C%2FA%3E%E7%9A%84%E8%A7%A3%E9%87%8A%E5%86%8D%E6%AC%A1%E8%BF%90%E8%A1%8C%E5%AE%89%E8%A3%85%E7%8E%AF%E5%A2%83%E8%84%9A%E6%9C%AC%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111019%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111019%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E7%8B%AE%E5%AD%90%EF%BC%8C%3C%2FP%3E%3CP%3E%E9%87%8D%E5%90%AF%E8%AE%A1%E7%AE%97%E6%9C%BA%E6%88%96%E6%89%93%E5%BC%80%E6%96%B0%E7%BB%88%E7%AB%AF%E5%90%8E%E4%BD%A0%E5%BF%85%E9%A1%BB%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%BA%90.%2Fsetup-environment%E5%BB%BA%E9%80%A0%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E7%9A%84%E8%AE%A1%E7%AE%97%E6%9C%BA%E5%85%B3%E9%97%AD%E7%9A%84%E5%8E%9F%E5%9B%A0%E5%8F%AF%E8%83%BD%E6%98%AF%E5%9F%BA%E4%BA%8E%E8%8A%82%E8%83%BD%E9%80%89%E9%A1%B9%E3%80%82%E4%BD%A0%E5%BA%94%E8%AF%A5%E5%9C%A8%E4%B8%8B%E4%B8%80%E6%AC%A1%20bitbake%20%E6%97%B6%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EJoerg%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Otaviosalvador%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E6%B5%8B%E8%AF%95%20Yocto%20i.mx6%E3%80%82%E5%90%8E%3C%2FP%3E%3CP%3E%E4%BB%93%E5%BA%93%E5%90%8C%E6%AD%A5%3C%2FP%3E%3CP%3Evi%20conf%2Flocal.conf%20%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive-quote%22%3E%3CP%3E%E6%9C%BA%E5%99%A8%3F%3F%3D'%20%3CSTRONG%3Eimx6qsabrelite%3C%2FSTRONG%3E%20'%3C%2FP%3E%3CP%3EDISTRO%20%3F%3D%20'poky'%3C%2FP%3E%3CP%3EPACKAGE_CLASSES%20%3F%3D%20%22%E8%BD%AF%E4%BB%B6%E5%8C%85_rpm%22%3C%2FP%3E%3CP%3EEXTRA_IMAGE_FEATURES%20%3D%E2%80%9C%E8%B0%83%E8%AF%95%E8%B0%83%E6%95%B4%E2%80%9D%3C%2FP%3E%3CP%3EUSER_CLASSES%20%3F%3D%20%E2%80%9Cbuildstats%20image-mklibs%20image-prelink%E2%80%9D%3C%2FP%3E%3CP%3EPATCHRESOLVE%20%3D%20%22noop%22%3C%2FP%3E%3CP%3ECONF_VERSION%20%3D%20%221%22%3C%2FP%3E%3CP%3EBB_NUMBER_THREADS%20%3D%20'8'%3C%2FP%3E%3CP%3EPARALLEL_MAKE%20%3D%20'-j%208'%3C%2FP%3E%3CP%3E%E6%8E%A5%E5%8F%97FSL_EULA%20%3D%20%221%22%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E7%84%B6%E5%90%8E%E8%BF%90%E8%A1%8C%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FP%3E%3CP%3Ebitbake%20core-image-minimal%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E4%B8%AA%E5%91%BD%E4%BB%A4%E8%BF%90%E8%A1%8C%E4%BA%86%E5%BE%88%E9%95%BF%E6%97%B6%E9%97%B4%EF%BC%8C%E4%BD%86%E6%98%AF%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%E6%88%91%E7%9A%84%E7%94%B5%E8%84%91%E6%96%AD%E7%94%B5%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%86%8D%E6%AC%A1%E6%89%93%E5%BC%80%E7%94%B5%E8%84%91%E6%97%B6%EF%BC%8C%E8%BF%90%E8%A1%8C%E6%AD%A4%E5%91%BD%E4%BB%A4%20bitbake%20core-image-minimal%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A8%8B%E5%BA%8F%E2%80%9Cbitbake%E2%80%9D%E5%BD%93%E5%89%8D%E6%9C%AA%E5%AE%89%E8%A3%85%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E8%BE%93%E5%85%A5%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%E6%9D%A5%E5%AE%89%E8%A3%85%E5%AE%83%EF%BC%9A%3C%2FP%3E%3CP%3Esudo%20apt-get%20install%20bitbake%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%83%BD%E5%B8%AE%E5%8A%A9%E6%88%91%E5%90%97%EF%BC%9F%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%8E%9F%E5%9B%A0%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A6%96%E5%85%88%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E4%BD%BF%E7%94%A8%E8%BE%83%E6%96%B0%E7%9A%84%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E7%89%88%E6%9C%AC%E3%80%82%E5%AF%B9%E4%BA%8E%20Ubuntu%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%2012.04%EF%BC%88%E5%AF%B9%E4%BA%8E%20Debian%EF%BC%8C%E6%88%91%E6%9B%B4%E5%96%9C%E6%AC%A2%E4%BD%BF%E7%94%A8%207.2%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%97%A0%E6%B3%95%E6%9B%B4%E6%96%B0%E7%B3%BB%E7%BB%9F%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E7%82%B9%E5%87%BB%E4%BB%A5%E4%B8%8B%E9%93%BE%E6%8E%A5%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22loading%22%20href%3D%22http%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2F1.5%2Fref-manual%2Fref-manual.html%23required-git-tar-and-python-versions%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2F1.5%2Fref-manual%2Fref-manual.html%23required-git-tar-and-python-versions%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AE%83%E8%A7%A3%E9%87%8A%E4%BA%86%E5%A6%82%E4%BD%95%E5%AE%89%E8%A3%85%E2%80%9Cbuildtools%E2%80%9Dtarball%20%E5%B9%B6%E5%9C%A8%E6%97%A7%E7%B3%BB%E7%BB%9F%E4%B8%AD%E4%BD%BF%E7%94%A8%E5%AE%83%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%85%B3%E4%BA%8E%20fsl-community-bsp%20%E5%88%86%E6%94%AF%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E2%80%9Cdora%E2%80%9D%EF%BC%8C%E5%9B%A0%E4%B8%BA%E2%80%9Cdylan%E2%80%9D%E4%B8%8D%E6%98%AF%E5%BD%93%E5%89%8D%E7%A8%B3%E5%AE%9A%E7%89%88%E6%9C%AC%EF%BC%8C%E5%B9%B6%E4%B8%94%20dora%20%E6%9C%89%E5%BE%88%E5%A5%BD%E7%9A%84%E6%96%B0%E6%94%B9%E8%BF%9B%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111016%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111016%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20OtavioSalvador%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E6%B5%8B%E8%AF%95%20Tocto%20Ubuntu%2010.04%20%E6%97%B6%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Esudo%20apt-get%20install%20gawk%20wget%20git-core%20diffstat%20%E8%A7%A3%E5%8E%8B%E7%BC%A9%20texinfo%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E6%9E%84%E5%BB%BA%E5%BF%85%E9%9C%80%E7%9A%84%20chrpath%20libsdl1.2-devxterm%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%B8%8B%E8%BD%BD%20repo%E3%80%82%E5%AE%83%E5%B0%86%E5%B8%AE%E5%8A%A9%E6%82%A8%E4%B8%8B%E8%BD%BD%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive-quote%22%3E%3CP%3Ecd%20rootfs_builder%3C%2FP%3E%3CP%3Ecurl%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fdl-ssl.google.com%2Fdl%2Fgooglesource%2Fgit-repo%2Frepo%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fdl-ssl.google.com%2Fdl%2Fgooglesource%2Fgit-repo%2Frepo%3C%2FA%3E%20%26gt%3B%20.%2Frepo%3C%2FP%3E%3CP%3Echmod%20a%2Bx%20.%2Frepo%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8B%E8%BD%BDBSP%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ecd%20rootfs_builder%3C%2FP%3E%3CP%3E.%2Frepo%20init%20-u%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%3C%2FA%3E-b%20%E8%BF%AA%E4%BC%A6%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%87%B4%E5%91%BD%EF%BC%9A%E9%9C%80%E8%A6%81%20git%201.7.2%20%E6%88%96%E6%9B%B4%E9%AB%98%E7%89%88%E6%9C%AC%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%83%B3%E8%A6%81%E5%AE%89%E8%A3%85%E5%85%B6%E4%BB%96%E5%BA%93%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%8CDaiane%E3%80%82%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Verdana%2C%20Arial%2C%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012px%3B%20font-style%3A%20normal%3B%20font-weight%3A%20normal%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%22%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111014%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111014%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%93%A6%EF%BC%81%E6%88%91%E7%9C%8B%E5%88%B0%E4%BD%A0%E5%8F%91%E7%BB%99%20meta-freescale%20%E7%9A%84%E9%82%AE%E4%BB%B6%E4%BA%86%EF%BC%81%E6%88%91%E6%9B%B4%E5%96%9C%E6%AC%A2%E5%9C%A8%E9%82%A3%E9%87%8C%E5%9B%9E%E5%A4%8D%E4%BD%A0%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E7%9A%84%E4%B8%BB%E6%9D%BF%E6%98%AF%20MCIMX6Q-SDP%20SCH-27392%20REV%20C3%20700-27392%20REV%20B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%B7%AE%E7%82%B9%E5%BF%98%E4%BA%86%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3Eroot%40imx6qsabresd%3A~%23%20uname%20-a%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3ELinux%20imx6qsabresd%203.0.35-1.1.0%2Byocto%2Bg21304e1%231%20SMP%20PREEMPT%20%E6%98%9F%E6%9C%9F%E4%B8%89%20%E5%8D%81%E6%9C%88%209%2017%3A15%3A15%20MSK%202013%20armv7l%20GNU%2FLinux%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111011%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111011%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E9%82%A3%E4%B8%8D%E6%98%AF%E9%82%A3%E4%B9%88%E9%87%8D%E8%A6%81%E3%80%82%E5%9B%BE%E5%83%8F%E6%AD%A3%E5%9C%A8%E5%B7%A5%E4%BD%9C%E3%80%82%E5%A4%AA%E6%A3%92%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%88%91%E5%AF%B9%E7%BD%91%E7%BB%9C%E5%AD%90%E7%B3%BB%E7%BB%9F%E6%9C%89%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%E5%BD%93%E6%88%91%E6%9E%84%E5%BB%BA%E7%9B%AE%E6%A0%87%20fsl-image-gui%20%E6%97%B6%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E4%BD%BF%E5%85%B6%E5%B7%A5%E4%BD%9C%EF%BC%88%E6%88%91%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%E7%BD%91%E7%BB%9C%EF%BC%89%E3%80%82%20%3C%2FP%3E%3CP%3E%E5%BD%93%E5%86%85%E6%A0%B8%E5%90%AF%E5%8A%A8%E6%97%B6%E6%88%91%E5%BE%97%E5%88%B0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%E9%85%8D%E7%BD%AE%E7%BD%91%E7%BB%9C%E6%8E%A5%E5%8F%A3...eth0%EF%BC%9AFreescale%20FEC%20PHY%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5BGeneric%20PHY%5D%EF%BC%88mii_bus%EF%BC%9Aphy_addr%3D1%3A00%EF%BC%8Cirq%3D-1%EF%BC%89%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3Eudhcpc%EF%BC%88v1.20.2%EF%BC%89%E5%B7%B2%E5%90%AF%E5%8A%A8%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%E6%AD%A3%E5%9C%A8%E5%8F%91%E9%80%81%E5%8F%91%E7%8E%B0...%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3EPHY%EF%BC%9A1%3A00%20-%20%E9%93%BE%E8%B7%AF%E5%B7%B2%E8%BF%9E%E6%8E%A5%20-%20100%2F%E6%BB%A1%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3Enet%20eth0%3A%20FEC%20ENET%3A%20rcv%20%E4%B8%8D%E6%98%AF%20%2Blast%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%E6%AD%A3%E5%9C%A8%E5%8F%91%E9%80%81%E5%8F%91%E7%8E%B0...%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%E6%AD%A3%E5%9C%A8%E5%8F%91%E9%80%81%E5%8F%91%E7%8E%B0...%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%E6%B2%A1%E6%9C%89%E7%A7%9F%E7%BA%A6%EF%BC%8C%E5%A4%B1%E8%B4%A5%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20rpcbind%20%E5%AE%88%E6%8A%A4%E8%BF%9B%E7%A8%8B...rpcbind%EF%BC%9A%E6%97%A0%E6%B3%95%E4%B8%BA%20udp6%20%E5%88%9B%E5%BB%BA%E5%A5%97%E6%8E%A5%E5%AD%97%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3Erpcbind%EF%BC%9A%E6%97%A0%E6%B3%95%E4%B8%BA%20tcp6%20%E5%88%9B%E5%BB%BA%E5%A5%97%E6%8E%A5%E5%AD%97%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%E5%AE%8C%E6%88%90%E3%80%82%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E5%A6%82%E6%9E%9C%E6%88%91%E8%BE%93%E5%85%A5%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3Eroot%40imx6qsabresd%3A~%23%20udhcpc%20-i%20eth0%20-n%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%98%8E%E7%99%BD%E4%BA%86%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3Eudhcpc%EF%BC%88v1.20.2%EF%BC%89%E5%B7%B2%E5%90%AF%E5%8A%A8%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%E6%AD%A3%E5%9C%A8%E5%8F%91%E9%80%81%E5%8F%91%E7%8E%B0...%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%E6%AD%A3%E5%9C%A8%E5%8F%91%E9%80%81%E5%8F%91%E7%8E%B0...%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%E6%AD%A3%E5%9C%A8%E5%8F%91%E9%80%81%E5%8F%91%E7%8E%B0...%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3Enet%20eth0%3A%20FEC%20ENET%3A%20rcv%20%E4%B8%8D%E6%98%AF%20%2Blast%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%E6%B2%A1%E6%9C%89%E7%A7%9F%E7%BA%A6%EF%BC%8C%E5%A4%B1%E8%B4%A5%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3Eroot%40imx6qsabresd%3A~%23%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%80%E6%97%A6%E6%88%91%E8%83%BD%E5%A4%9F%E9%80%9A%E8%BF%87%20ssh%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%88%91%E7%9A%84%E4%B8%BB%E6%9D%BF%E3%80%82%E4%BD%86%E5%BE%88%E5%BF%AB%E8%BF%9E%E6%8E%A5%E5%B0%B1%E8%A2%AB%E6%8B%92%E7%BB%9D%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E6%89%80%E4%BB%A5%E6%88%91%E6%97%A0%E6%B3%95%E4%BB%8E%E6%88%91%E7%9A%84%20dhcp%20%E8%8E%B7%E5%8F%96%E7%A7%9F%E7%BA%A6%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E4%BD%BF%E7%94%A8%E9%9D%99%E6%80%81%20IP%20%E5%92%8C%E7%BD%91%E7%BB%9C%E6%8E%A9%E7%A0%81%EF%BC%8C%E7%BD%91%E7%BB%9C%E4%B9%9F%E6%97%A0%E6%B3%95%E5%B7%A5%E4%BD%9C%E3%80%82%E6%9C%89%E6%97%B6%E6%88%91%E4%BC%9A%E6%94%B6%E5%88%B0%E8%BF%99%E6%A0%B7%E7%9A%84%E6%B6%88%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3Enet%20eth0%3A%20FEC%20ENET%3A%20rcv%20%E4%B8%8D%E6%98%AF%20%2Blast%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3Enet%20eth0%3A%20FEC%20ENET%3A%20rcv%20%E4%B8%8D%E6%98%AF%20%2Blast%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3Enet%20eth0%3A%20FEC%20ENET%3A%20rcv%20%E4%B8%8D%E6%98%AF%20%2Blast%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3Enet%20eth0%3A%20FEC%20ENET%3A%20rcv%20%E4%B8%8D%E6%98%AF%20%2Blast%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3Enet%20eth0%3A%20FEC%20ENET%3A%20rcv%20%E4%B8%8D%E6%98%AF%20%2Blast%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3Enet%20eth0%3A%20FEC%20ENET%3A%20rcv%20%E4%B8%8D%E6%98%AF%20%2Blast%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3Enet%20eth0%3A%20FEC%20ENET%3A%20rcv%20%E4%B8%8D%E6%98%AF%20%2Blast%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3Enet%20eth0%3A%20FEC%20ENET%3A%20rcv%20%E4%B8%8D%E6%98%AF%20%2Blast%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3Enet%20eth0%3A%20FEC%20ENET%3A%20rcv%20%E4%B8%8D%E6%98%AF%20%2Blast%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E9%97%AE%E5%80%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%26gt%3B%26gt%3B%26gt%3B%E9%9D%9E%E5%B8%B8%E6%8A%B1%E6%AD%89%EF%BC%8C%E4%BD%86%E6%88%91%E7%9C%9F%E7%9A%84%E4%B8%8D%E6%98%8E%E7%99%BD%E6%82%A8%E5%9C%A8%E8%AF%B4%E4%BB%80%E4%B9%88%E3%80%82%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E6%B2%A1%E4%BB%80%E4%B9%88%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%BF%99%E5%8F%AA%E6%98%AF%E8%AD%A6%E5%91%8A%E4%BF%A1%E6%81%AF%E3%80%82%E6%98%AF%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%98%AF%E7%9A%84%20%3CIMG%20id%3D%22smileywink%22%20class%3D%22emoticon%20emoticon-smileywink%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-wink.png%22%20alt%3D%22Smiley%20Wink%22%20title%3D%22Smiley%20Wink%22%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%26gt%3B%26gt%3B%26gt%3B%E5%A4%AA%E6%A3%92%E4%BA%86%EF%BC%81%E4%B9%9F%E8%AE%B8%E6%9C%89%E4%B8%80%E5%A4%A9%E6%88%91%E4%BC%9A%E5%8E%BB%E9%82%A3%E9%87%8C%E6%97%85%E8%A1%8C%E3%80%82%E6%88%91%E6%9D%A5%E8%87%AA%E4%BF%84%E7%BD%97%E6%96%AF%E3%80%82%E8%BF%99%E9%87%8C%E5%BE%88%E5%86%B7%EF%BC%88%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%98%8E%E5%B9%B4%E6%88%91%E4%BB%AC%E5%B0%86%E4%B8%BE%E5%8A%9E%E4%B8%96%E7%95%8C%E6%9D%AF%3Asmileygrin%3A%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%AF%B7%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%8C%85%E5%90%AB%E6%82%A8%E7%9A%84%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%E5%92%8C%E4%B8%80%E4%BA%9B%E5%85%B6%E4%BB%96%E5%8F%AF%E4%BE%9B%E4%BA%BA%E4%BB%AC%E5%B0%9D%E8%AF%95%E8%B0%83%E8%AF%95%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E9%9A%8F%E6%84%8F%E6%8F%90%E5%8F%8A%E6%88%91%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111008%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111008%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22jiveTT-hover-user%20jive-username-link%22%3EDaiane%20Angolini%EF%BC%8C%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22jiveTT-hover-user%20jive-username-link%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22jiveTT-hover-user%20jive-username-link%22%3E%3CSTRONG%3E%26gt%3B%26gt%3B%20%E6%88%91%E8%87%AA%E5%B7%B1%E4%BB%8E%E6%9D%A5%E6%B2%A1%E6%9C%89%E6%B5%8B%E8%AF%95%E8%BF%87%E3%80%82%E8%80%8C%E4%B8%94%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E6%88%91%E6%98%AF%E5%90%A6%E8%83%BD%E5%A4%9F*%E7%9C%9F%E6%AD%A3*%E6%B5%8B%E8%AF%95%E5%AE%83%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E6%B2%A1%E6%9C%89%E5%83%8F%E4%BD%A0%E8%BF%99%E6%A0%B7%E7%9A%84%E4%BB%A3%E7%90%86......%E4%BD%86%E6%88%91%E8%AE%A4%E4%B8%BA%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E4%BE%9D%E8%B5%96%20yocto%20%E6%96%87%E6%A1%A3%E3%80%82%E6%9B%B4%E5%9B%B0%E9%9A%BE%E7%9A%84%E6%98%AF%E7%9F%A5%E9%81%93%E8%A6%81%E4%BD%BF%E7%94%A8%E7%9A%84%E9%95%9C%E5%83%8F%20URL%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E8%BF%87%E4%BA%86%EF%BC%8C%E4%BD%86%E5%AE%83%E5%AF%B9%E6%88%91%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E6%88%91%E6%94%B6%E5%88%B0%E4%B8%80%E4%BA%9B%20python%20%E8%AF%AD%E6%B3%95%E9%94%99%E8%AF%AF%E3%80%82%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8%E8%BF%99%E9%87%8C%E5%8F%91%E5%B8%83%E5%AE%83%E3%80%82%E4%B9%9F%E8%AE%B8%E6%88%91%E5%81%9A%E9%94%99%E4%BA%86%E4%BB%80%E4%B9%88%E3%80%82%E6%88%91%E8%AE%A4%E4%B8%BA%E6%B2%A1%E5%85%B3%E7%B3%BB%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E2%80%9C%E6%97%A7%E7%9A%84%E3%80%81%E7%A7%8D%E7%B1%BB%E2%80%9D%E7%BC%96%E8%BE%91%20*.dd%20%E6%96%87%E4%BB%B6%E5%B9%B6%E4%B8%94%E5%AE%83%E5%AF%B9%E6%88%91%E6%9C%89%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%26gt%3B%26gt%3B%3CSTRONG%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2012.8px%3B%20font-family%3A%20'Helvetica%20Neue'%2CHelvetica%2CArial%2C'Lucida%20Grande'%2Csans-serif%3B%22%3E%E5%8F%A6%E4%B8%80%E7%A7%8D%E2%80%9C%E6%AC%BA%E9%AA%97%E2%80%9D%20yocto%20%E7%9A%84%E6%96%B9%E6%B3%95%E6%98%AF%E4%B8%8B%E8%BD%BD%E7%9B%B8%E5%90%8C%E7%9A%84%E5%8C%85%EF%BC%8C%E9%80%9A%E8%BF%87%E8%B0%B7%E6%AD%8C%E6%90%9C%E7%B4%A2%E7%BD%91%E7%BB%9C%EF%BC%8C%E7%84%B6%E5%90%8E%E5%B0%86%20tar.gz%20%E5%A4%8D%E5%88%B6%E5%88%B0%E4%B8%8B%E8%BD%BD%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%88%E5%B9%B6%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%87%E4%BB%B6%E5%90%8D%E5%AE%8C%E5%85%A8%E7%9B%B8%E5%90%8C%E4%B8%94%E6%9C%AB%E5%B0%BE%E5%B8%A6%E6%9C%89%20.done%20%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%88%E4%BE%8B%E5%A6%82%20uuid-1.6.2.tar.gz.done%EF%BC%89%EF%BC%89%E4%BB%A5%E4%BD%BF%20bitbake%20%E7%9B%B8%E4%BF%A1%E5%AE%83%E5%B7%B2%E7%BB%8F%E8%A2%AB%E4%B8%8B%E8%BD%BD%E4%BA%86%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E5%90%AC%E8%B5%B7%E6%9D%A5%E5%BE%88%E6%A3%92%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26gt%3B%26gt%3B%E6%B6%88%E6%81%AF%E8%AF%B4%E6%82%A8%E6%9E%84%E5%BB%BA%E4%BA%86%E8%BF%99%E4%BA%9B%E6%96%87%E4%BB%B6%E4%BD%86%E5%B9%B6%E6%9C%AA%E5%AE%89%E8%A3%85%E5%9C%A8%E4%BB%BB%E4%BD%95%E5%9C%B0%E6%96%B9%E3%80%82%E5%AE%83%E4%BC%9A%E8%AE%A9%E4%BD%A0%E6%80%9D%E8%80%83%E6%98%AF%E5%90%A6%E9%81%97%E6%BC%8F%E4%BA%86%E6%9F%90%E4%BA%9B%E4%B8%9C%E8%A5%BF%E6%88%96%E8%80%85%E6%98%AF%E5%90%A6%E7%9C%9F%E7%9A%84%E5%9C%A8%E9%81%BF%E5%85%8D%E8%BF%99%E4%BA%9B%E6%96%87%E4%BB%B6%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26gt%3B%26gt%3B%20%E8%BF%98%E6%9C%89%E4%B8%80%E4%BA%9B%E4%BD%A0%E6%97%A0%E6%B3%95%E6%8E%A7%E5%88%B6%E7%9A%84%E4%BA%8B%E6%83%85%EF%BC%8C%E6%AF%94%E5%A6%82%20memtool%20%E5%B7%B2%E7%BB%8F%E8%A2%AB%E5%89%A5%E7%A6%BB%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%8A%B1%E6%AD%89%EF%BC%8C%E4%BD%86%E6%88%91%E7%9C%9F%E7%9A%84%E4%B8%8D%E6%98%8E%E7%99%BD%E6%82%A8%E5%9C%A8%E8%AF%B4%E4%BB%80%E4%B9%88%E3%80%82%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E6%B2%A1%E4%BB%80%E4%B9%88%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%BF%99%E5%8F%AA%E6%98%AF%E8%AD%A6%E5%91%8A%E4%BF%A1%E6%81%AF%E3%80%82%E6%98%AF%E5%90%97%EF%BC%9F%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%88%91%E6%9D%A5%E8%87%AA%E5%B7%B4%E8%A5%BF%E3%80%82%E4%BD%A0%E4%BB%8E%E5%93%AA%E6%9D%A5%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E5%A4%AA%E6%A3%92%E4%BA%86%EF%BC%81%E4%B9%9F%E8%AE%B8%E6%9C%89%E4%B8%80%E5%A4%A9%E6%88%91%E4%BC%9A%E5%8E%BB%E9%82%A3%E9%87%8C%E6%97%85%E8%A1%8C%E3%80%82%E6%88%91%E6%9D%A5%E8%87%AA%E4%BF%84%E7%BD%97%E6%96%AF%E3%80%82%E8%BF%99%E9%87%8C%E5%BE%88%E5%86%B7%EF%BC%88%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111007%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111007%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20imx6%20Sabre%20ARD%20%E5%92%8C%20yocto%20%E5%B9%B6%E5%B0%9D%E8%AF%95%E8%AE%A9%E8%A7%A6%E6%91%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E6%88%91%E5%9C%A8%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%E4%B8%AD%E5%90%AF%E7%94%A8%E4%BA%86%203M%20%E5%B9%B6%E7%A6%81%E7%94%A8%E4%BA%86%E6%89%80%E6%9C%89%E5%85%B6%E4%BB%96%E8%A7%A6%E6%91%B8%E3%80%82%E6%88%91%E5%9C%A8%20usbtouchscreen%20%E4%B8%AD%E6%94%B6%E5%88%B0%E9%94%99%E8%AF%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111006%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111006%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%E6%96%87%E6%9C%AC%E4%B8%AD%E4%BB%A5%E7%B2%97%E4%BD%93%E6%98%BE%E7%A4%BA%E7%9A%84%E6%88%91%E7%9A%84%E5%9B%9E%E5%A4%8D%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Ealeksandr%20Muraviov%E5%86%99%E9%81%93%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3EDaiane%20Angolini%EF%BC%8C%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%20%3CYOCTO_ROOT%3E%2Fbuild%2Fconf%2Flocal.conf%20%E5%90%97%EF%BC%9F%3C%2FYOCTO_ROOT%3E%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E6%98%AF%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%E8%87%AA%E4%BB%8E%E6%88%91%E5%8F%91%E5%B8%83%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E4%BB%A5%E6%9D%A5%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E5%AD%A6%E4%BC%9A%E9%80%9A%E8%BF%87%E7%BC%96%E8%BE%91%20%3CYOCTO_ROOT%3E%2Fsource%20%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E7%9A%84%20*.bb%20%E6%96%87%E4%BB%B6%E6%9D%A5%E4%BF%AE%E5%A4%8D%E6%AD%A4%E9%94%99%E8%AF%AF%E3%80%82%3C%2FYOCTO_ROOT%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E6%9B%B4%E5%A5%BD%EF%BC%8C%E5%BD%93%E6%88%91%E4%BB%8E%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%E6%94%B6%E5%88%B0%E4%B8%8B%E4%B8%80%E4%B8%AA%E9%94%99%E8%AF%AF%E6%88%96%E8%AD%A6%E5%91%8A%E6%B6%88%E6%81%AF%E6%97%B6%EF%BC%8C%E6%88%91%E4%BC%9A%E5%B0%9D%E8%AF%95%E5%AE%83%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E4%BD%86%E7%9C%8B%E8%B5%B7%E6%9D%A5%E2%80%9C%3C%2FSPAN%3E%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2F%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2F%3C%2FA%3E%20%3CSPAN%3E..%E2%80%9D%E9%95%9C%E5%83%8F%E5%9C%A8%20Yocto%20%E4%B8%AD%E4%BC%9A%E5%AF%BC%E8%87%B4%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%E3%80%82%E4%BD%A0%E7%A1%AE%E5%AE%9A%E5%AE%83%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSTRONG%3E%E6%88%91%E4%BB%8E%E6%9D%A5%E6%B2%A1%E6%9C%89%E4%BA%B2%E8%87%AA%E6%B5%8B%E8%AF%95%E8%BF%87%E3%80%82%E8%80%8C%E4%B8%94%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E6%88%91%E6%98%AF%E5%90%A6%E8%83%BD%E5%A4%9F*%E7%9C%9F%E6%AD%A3*%E6%B5%8B%E8%AF%95%E5%AE%83%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E6%B2%A1%E6%9C%89%E5%83%8F%E4%BD%A0%E8%BF%99%E6%A0%B7%E7%9A%84%E4%BB%A3%E7%90%86......%E4%BD%86%E6%88%91%E8%AE%A4%E4%B8%BA%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E4%BE%9D%E8%B5%96%20yocto%20%E6%96%87%E6%A1%A3%E3%80%82%E6%9B%B4%E5%9B%B0%E9%9A%BE%E7%9A%84%E6%98%AF%E7%9F%A5%E9%81%93%E8%A6%81%E4%BD%BF%E7%94%A8%E7%9A%84%E9%95%9C%E5%83%8F%20URL%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012.800000190734863px%3B%22%3E%E6%88%91%E7%9A%84%E4%BB%A3%E7%90%86%E6%B2%A1%E6%9C%89%E5%87%BA%E7%8E%B0%E8%8E%B7%E5%8F%96%E9%94%99%E8%AF%AF%E3%80%82%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012.800000190734863px%3B%22%3E%E6%88%91%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%EF%BC%8C%E4%BB%A3%E7%90%86%E6%9C%8D%E5%8A%A1%E5%99%A8%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSPAN%3E%E9%93%BE%E6%8E%A5%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22ftp%3A%2F%2Fftp.ossp.org%2Fpkg%2Flib%2Fuuid%2Fuuid-1.6.2.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eftp%3A%2F%2Fftp.ossp.org%2Fpkg%2Flib%2Fuuid%2Fuuid-1.6.2.tar.gz%3C%2FA%3E%E7%A1%AE%E5%AE%9E%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012.800000190734863px%3B%22%3E%E4%BD%86%E6%84%9F%E8%B0%A2%E6%8F%90%E4%BE%9B%20Yocto%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E7%9A%84%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2012.8px%3B%20font-family%3A%20'Helvetica%20Neue'%2CHelvetica%2CArial%2C'Lucida%20Grande'%2Csans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2012.8px%3B%20font-family%3A%20'Helvetica%20Neue'%2CHelvetica%2CArial%2C'Lucida%20Grande'%2Csans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2012.8px%3B%20font-family%3A%20'Helvetica%20Neue'%2CHelvetica%2CArial%2C'Lucida%20Grande'%2Csans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2012.8px%3B%20font-family%3A%20'Helvetica%20Neue'%2CHelvetica%2CArial%2C'Lucida%20Grande'%2Csans-serif%3B%22%3E%E5%8F%A6%E4%B8%80%E7%A7%8D%E2%80%9C%E6%AC%BA%E9%AA%97%E2%80%9D%20yocto%20%E7%9A%84%E6%96%B9%E6%B3%95%E6%98%AF%E9%80%9A%E8%BF%87%E8%B0%B7%E6%AD%8C%E6%90%9C%E7%B4%A2%E7%BD%91%E9%A1%B5%E4%B8%8B%E8%BD%BD%E7%9B%B8%E5%90%8C%E7%9A%84%E5%8C%85%EF%BC%8C%E7%84%B6%E5%90%8E%E5%B0%86%20tar.gz%20%E5%A4%8D%E5%88%B6%E5%88%B0%E4%B8%8B%E8%BD%BD%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%EF%BC%88%E5%B9%B6%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%85%B7%E6%9C%89%E5%AE%8C%E5%85%A8%E7%9B%B8%E5%90%8C%E6%96%87%E4%BB%B6%E5%90%8D%E5%92%8C%20.done%20%E7%9A%84%E6%96%87%E4%BB%B6%E5%9C%A8%E6%9C%80%E5%90%8E%EF%BC%88%E4%BE%8B%E5%A6%82%20uuid-1.6.2.tar.gz.done%EF%BC%89%E4%BB%A5%E4%BD%BF%20bitbake%20%E7%9B%B8%E4%BF%A1%E5%AE%83%E5%B7%B2%E8%A2%AB%E4%B8%8B%E8%BD%BD%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012.800000190734863px%3B%22%3E%3CSTRONG%3E%E5%BD%93%E7%84%B6%E8%BF%99%E4%B8%8D%E6%98%AF%E7%90%86%E6%83%B3%E7%9A%84%EF%BC%8C%E4%BD%86%E5%8F%AF%E8%83%BD%E4%BC%9A%E7%BB%99%E4%BD%A0%E4%B8%80%E4%BA%9B%E6%97%B6%E9%97%B4......%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012.800000190734863px%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012.800000190734863px%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E5%B0%BD%E7%AE%A1%E6%9C%89%E8%BF%99%E4%BA%9B%E8%AD%A6%E5%91%8A%E4%BF%A1%E6%81%AF%EF%BC%8C%E5%9B%BE%E5%83%8F%E4%BB%8D%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E6%98%AF%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%94%B6%E5%88%B0%E4%BA%86%E6%96%B0%E7%9A%84%E8%AD%A6%E5%91%8A%E3%80%82%E4%BD%A0%E8%83%BD%E5%AF%B9%E6%AD%A4%E5%8F%91%E8%A1%A8%E4%BA%9B%E7%9C%8B%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E8%AF%A5%E6%B6%88%E6%81%AF%E8%A1%A8%E6%98%8E%E6%82%A8%E5%B7%B2%E6%9E%84%E5%BB%BA%E8%BF%99%E4%BA%9B%E6%96%87%E4%BB%B6%E4%BD%86%E5%B9%B6%E6%9C%AA%E5%AE%89%E8%A3%85%E5%9C%A8%E4%BB%BB%E4%BD%95%E5%9C%B0%E6%96%B9%E3%80%82%E5%AE%83%E4%BC%9A%E8%AE%A9%E4%BD%A0%E6%80%9D%E8%80%83%E6%98%AF%E5%90%A6%E9%81%97%E6%BC%8F%E4%BA%86%E4%BB%80%E4%B9%88%E4%B8%9C%E8%A5%BF%E6%88%96%E8%80%85%E6%98%AF%E5%90%A6%E7%9C%9F%E7%9A%84%E5%9C%A8%E9%81%BF%E5%85%8D%E9%82%A3%E4%BA%9B%E6%96%87%E4%BB%B6%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E8%BF%98%E6%9C%89%E4%B8%80%E4%BA%9B%E4%BD%A0%E6%97%A0%E6%B3%95%E6%8E%A7%E5%88%B6%E7%9A%84%E4%BA%8B%E6%83%85%EF%BC%8C%E6%AF%94%E5%A6%82%20memtool%20%E5%B7%B2%E7%BB%8F%E8%A2%AB%E5%89%A5%E7%A6%BB%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CEM%3E%E8%AD%A6%E5%91%8A%EF%BC%9AQA%20%E9%97%AE%E9%A2%98%EF%BC%9Alttng-modules%EF%BC%9A%E6%96%87%E4%BB%B6%2F%E7%9B%AE%E5%BD%95%E5%B7%B2%E5%AE%89%E8%A3%85%E4%BD%86%E6%9C%AA%E5%8F%91%E8%B4%A7%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CEM%3E%26nbsp%3B%20%2Flib%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CEM%3E%26nbsp%3B%20%2Flib%2Fmodules%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CEM%3E%26nbsp%3B%20%2Flib%2Fmodules%2F3.0.35-1.1.0%2Byocto%2Bg21304e1%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CEM%3E%26nbsp%3B%20%2Flib%2Fmodules%2F3.0.35-1.1.0%2Byocto%2Bg21304e1%2Fkernel%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CEM%3E%26nbsp%3B%20%2Flib%2Fmodules%2F3.0.35-1.1.0%2Byocto%2Bg21304e1%2Fkernel%2Flttng-modules%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CEM%3E%E8%AD%A6%E5%91%8A%EF%BC%9Aimx-test%20%E4%B8%AD%E7%9A%84%E6%96%87%E4%BB%B6%E2%80%98%2Funit_tests%2Fmemtool%E2%80%99%E5%B7%B2%E8%A2%AB%E5%89%A5%E7%A6%BB%EF%BC%8C%E8%BF%99%E5%B0%86%E9%98%BB%E6%AD%A2%E5%B0%86%E6%9D%A5%E7%9A%84%E8%B0%83%E8%AF%95%EF%BC%81%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CEM%3E%E8%AD%A6%E5%91%8A%EF%BC%9Adebianutils%EF%BC%9A%E4%BB%BB%E4%BD%95%E6%8F%90%E4%BE%9B%E5%95%86%E4%B8%AD%E5%9D%87%E4%B8%8D%E5%AD%98%E5%9C%A8%E9%80%9A%E7%94%A8%E8%AE%B8%E5%8F%AF%E8%AF%81%E6%96%87%E4%BB%B6%EF%BC%9ASMAIL_GPL%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%8E%9F%E8%B0%85%E6%88%91%E7%9A%84%E8%8B%B1%E8%AF%AD%E4%B8%8D%E5%A5%BD%E3%80%82%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E6%88%91%E7%9A%84%E8%8B%B1%E8%AF%AD%E4%B9%9F%E5%BE%88%E5%B7%AE%E3%80%82%E4%B8%8D%E7%94%A8%E6%8B%85%E5%BF%83%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E6%88%91%E6%9D%A5%E8%87%AA%E5%B7%B4%E8%A5%BF%E3%80%82%E4%BD%A0%E4%BB%8E%E5%93%AA%E6%9D%A5%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%E9%97%AE%E5%80%99%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDaiane%20Angolini%EF%BC%8C%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%20%3CYOCTO_ROOT%3E%2Fbuild%2Fconf%2Flocal.conf%20%E5%90%97%EF%BC%9F%3C%2FYOCTO_ROOT%3E%3C%2FP%3E%3CP%3E%E8%87%AA%E4%BB%8E%E6%88%91%E5%8F%91%E5%B8%83%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E4%BB%A5%E6%9D%A5%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E5%AD%A6%E4%BC%9A%E9%80%9A%E8%BF%87%E7%BC%96%E8%BE%91%20%3CYOCTO_ROOT%3E%2Fsource%20%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E7%9A%84%20*.bb%20%E6%96%87%E4%BB%B6%E6%9D%A5%E4%BF%AE%E5%A4%8D%E6%AD%A4%E9%94%99%E8%AF%AF%E3%80%82%3C%2FYOCTO_ROOT%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E6%9B%B4%E5%A5%BD%EF%BC%8C%E5%BD%93%E6%88%91%E4%BB%8E%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%E6%94%B6%E5%88%B0%E4%B8%8B%E4%B8%80%E4%B8%AA%E9%94%99%E8%AF%AF%E6%88%96%E8%AD%A6%E5%91%8A%E6%B6%88%E6%81%AF%E6%97%B6%EF%BC%8C%E6%88%91%E4%BC%9A%E5%B0%9D%E8%AF%95%E5%AE%83%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%BD%86%E7%9C%8B%E8%B5%B7%E6%9D%A5%E2%80%9C%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2F%3C%2FA%3E%20%3CSPAN%3E..%E2%80%9D%E9%95%9C%E5%83%8F%E5%9C%A8%20Yocto%20%E4%B8%AD%E4%BC%9A%E5%AF%BC%E8%87%B4%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%E3%80%82%E4%BD%A0%E7%A1%AE%E5%AE%9A%E5%AE%83%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012.800000190734863px%3B%22%3E%E6%88%91%E7%9A%84%E4%BB%A3%E7%90%86%E6%B2%A1%E6%9C%89%E5%87%BA%E7%8E%B0%E8%8E%B7%E5%8F%96%E9%94%99%E8%AF%AF%E3%80%82%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012.800000190734863px%3B%22%3E%E6%88%91%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%EF%BC%8C%E4%BB%A3%E7%90%86%E6%9C%8D%E5%8A%A1%E5%99%A8%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSPAN%3E%E9%93%BE%E6%8E%A5%3CA%20href%3D%22ftp%3A%2F%2Fftp.ossp.org%2Fpkg%2Flib%2Fuuid%2Fuuid-1.6.2.tar.gz%22%20title%3D%22ftp%3A%2F%2Fftp.ossp.org%2Fpkg%2Flib%2Fuuid%2Fuuid-1.6.2.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eftp%3A%2F%2Fftp.ossp.org%2Fpkg%2Flib%2Fuuid%2Fuuid-1.6.2.tar.gz%3C%2FA%3E%E7%A1%AE%E5%AE%9E%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012.800000190734863px%3B%22%3E%E4%BD%86%E6%84%9F%E8%B0%A2%E6%8F%90%E4%BE%9B%20Yocto%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E7%9A%84%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E5%B0%BD%E7%AE%A1%E6%9C%89%E8%BF%99%E4%BA%9B%E8%AD%A6%E5%91%8A%E4%BF%A1%E6%81%AF%EF%BC%8C%E5%9B%BE%E5%83%8F%E4%BB%8D%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E6%98%AF%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%94%B6%E5%88%B0%E4%BA%86%E6%96%B0%E7%9A%84%E8%AD%A6%E5%91%8A%E3%80%82%E4%BD%A0%E8%83%BD%E5%AF%B9%E6%AD%A4%E5%8F%91%E8%A1%A8%E4%BA%9B%E7%9C%8B%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%E8%AD%A6%E5%91%8A%EF%BC%9AQA%20%E9%97%AE%E9%A2%98%EF%BC%9Alttng-modules%EF%BC%9A%E6%96%87%E4%BB%B6%2F%E7%9B%AE%E5%BD%95%E5%B7%B2%E5%AE%89%E8%A3%85%E4%BD%86%E6%9C%AA%E5%8F%91%E8%B4%A7%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%26nbsp%3B%20%2Flib%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%26nbsp%3B%20%2Flib%2Fmodules%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%26nbsp%3B%20%2Flib%2Fmodules%2F3.0.35-1.1.0%2Byocto%2Bg21304e1%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%26nbsp%3B%20%2Flib%2Fmodules%2F3.0.35-1.1.0%2Byocto%2Bg21304e1%2Fkernel%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%26nbsp%3B%20%2Flib%2Fmodules%2F3.0.35-1.1.0%2Byocto%2Bg21304e1%2Fkernel%2Flttng-modules%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%E8%AD%A6%E5%91%8A%EF%BC%9Aimx-test%20%E4%B8%AD%E7%9A%84%E6%96%87%E4%BB%B6%E2%80%98%2Funit_tests%2Fmemtool%E2%80%99%E5%B7%B2%E8%A2%AB%E5%89%A5%E7%A6%BB%EF%BC%8C%E8%BF%99%E5%B0%86%E9%98%BB%E6%AD%A2%E5%B0%86%E6%9D%A5%E7%9A%84%E8%B0%83%E8%AF%95%EF%BC%81%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%E8%AD%A6%E5%91%8A%EF%BC%9Adebianutils%EF%BC%9A%E4%BB%BB%E4%BD%95%E6%8F%90%E4%BE%9B%E5%95%86%E4%B8%AD%E5%9D%87%E4%B8%8D%E5%AD%98%E5%9C%A8%E9%80%9A%E7%94%A8%E8%AE%B8%E5%8F%AF%E8%AF%81%E6%96%87%E4%BB%B6%EF%BC%9ASMAIL_GPL%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%8E%9F%E8%B0%85%E6%88%91%E7%9A%84%E8%8B%B1%E8%AF%AD%E4%B8%8D%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E9%97%AE%E5%80%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111004%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111004%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9C%A8%E4%BD%A0%E7%9A%84%20local.conf%20%E4%B8%8A%E5%B0%9D%E8%AF%95%E8%BF%99%E4%B8%AA%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%95%9C%E5%AD%90%20%3D%2B%20%22%20%5C%3C%2FP%3E%3CP%3E%24%7BFSL_MIRROR%7D%26nbsp%3B%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fgnome-build-stage-1.googlecode.com%2Ffiles%2Fuuid-1.6.2.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CEM%3E%3C%2FEM%3E%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fgnome-build-stage-1.googlecode.com%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgnome-build-stage-1.googlecode.com%3C%2FA%3E%20%5Cn%20%5C%3C%2FP%3E%3CP%3E%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B9%B6%E6%9F%A5%E7%9C%8B%E6%AD%A4%E9%93%BE%E6%8E%A5%EF%BC%88%E5%9B%A0%E4%B8%BA%E6%82%A8%E7%9A%84%E4%BB%A3%E7%90%86%E5%AF%BC%E8%87%B4%E6%82%A8%E5%87%BA%E7%8E%B0%E5%BE%88%E5%A4%9A%E8%8E%B7%E5%8F%96%E9%94%99%E8%AF%AF%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2Fcurrent%2Fpoky-ref-manual%2Fpoky-ref-manual.html%23idm425008%22%20title%3D%22https%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2Fcurrent%2Fpoky-ref-manual%2Fpoky-ref-manual.html%23idm425008%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2Fcurrent%2Fpoky-ref-manual%2Fpoky-ref-manual.html%23idm425008%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%92%8C%3C%2FP%3E%3CP%3E%3CA%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2Fcurrent%2Fpoky-ref-manual%2Fpoky-ref-manual.html%23idm425008%2Fpre%22%20title%3D%22https%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2Fcurrent%2Fpoky-ref-manual%2Fpoky-ref-manual.html%23idm425008%2Fpre%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2Fcurrent%2Fpoky-ref-manual%2Fpoky-ref-manual.html%23idm425008%2Fpre%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E6%9C%89%E5%B8%AE%E5%8A%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111003%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111003%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BE%93%E5%85%A5%E2%80%9Cbitbake%20fsl-image-test%E2%80%9D%E5%90%8E%E6%88%91%E5%BE%97%E5%88%B0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%20URL%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22ftp%3A%2F%2Fftp.ossp.org%2Fpkg%2Flib%2Fuuid%2Fuuid-1.6.2.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eftp%3A%2F%2Fftp.ossp.org%2Fpkg%2Flib%2Fuuid%2Fuuid-1.6.2.tar.gz%3C%2FA%3E%20%3CSPAN%3E%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%8F%AF%E7%94%A8%E5%88%99%E5%B0%9D%E8%AF%95%E9%95%9C%E5%83%8F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E8%AF%A5%E5%A6%82%E4%BD%95%E6%94%B9%E5%8F%98%20%3C%2FP%3E%3CP%3E%3CEM%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22ftp%3A%2F%2Fftp.ossp.org%2Fpkg%2Flib%2Fuuid%2Fuuid-1.6.2.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eftp%3A%2F%2Fftp.ossp.org%2Fpkg%2Flib%2Fuuid%2Fuuid-1.6.2.tar.gz%3C%2FA%3E%3C%2FEM%3E%20%3C%2FP%3E%3CP%3E%E8%87%B3%20%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgnome-build-stage-1.googlecode.com%2Ffiles%2Fuuid-1.6.2.tar.gz%22%20title%3D%22https%3A%2F%2Fgnome-build-stage-1.googlecode.com%2Ffiles%2Fuuid-1.6.2.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CEM%3E%3C%2FEM%3E%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fgnome-build-stage-1.googlecode.com%2Ffiles%2Fuuid-1.6.2.tar.gz%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgnome-build-stage-1.googlecode.com%2Ffiles%2Fuuid-1.6.2.tar.gz%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111002%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111002%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E8%AF%B7%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fsbl%22%20target%3D%22_blank%22%3Esbl%3C%2FA%3E%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E7%BA%BF%E7%A8%8B%E5%B9%B6%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%E6%82%A8%E7%9A%84%E7%8E%AF%E5%A2%83%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%88%86%E4%BA%AB%E6%88%96%E6%8F%90%E5%8F%8A%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E7%9F%A5%E9%81%93%E8%BF%99%E4%B8%AA%E6%96%87%E6%A1%A3%E5%90%97%EF%BC%9F%3CA%20_jive_internal%3D%22true%22%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%22%20title%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-94849%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-94849%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111001%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111001%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%9C%A8%E5%8D%95%E7%8B%AC%E7%9A%84%E7%BA%BF%E7%A8%8B%E4%B8%AD%E5%8F%91%E5%B8%83%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E5%8C%85%E6%8B%AC%E8%AF%A6%E7%BB%86%E6%AD%A5%E9%AA%A4%E5%92%8C%E4%BF%AE%E6%94%B9%E5%90%8E%E7%9A%84%20u-boot%20%E9%85%8D%E6%96%B9%EF%BC%8C%E9%82%A3%E5%B0%B1%E6%9B%B4%E5%A5%BD%E4%BA%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%BB%AC%E7%9A%84%E4%B8%BB%E6%9D%BF%E6%98%AF%20SD%20%E7%9A%84%E6%94%B9%E8%89%AF%E7%89%88%E5%85%8B%E9%9A%86%E7%89%88%E3%80%82%E6%88%91%E4%B8%BA%E6%96%B0%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BA%20u-boot%20%E7%9A%84%E6%AD%A3%E5%B8%B8%E6%B5%81%E7%A8%8B%E6%98%AF%E5%9C%A8%20board%2Ffreescale%20%E4%B8%8B%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9B%AE%E5%BD%95%EF%BC%8C%E5%B0%86%20sd%20%E6%96%87%E4%BB%B6%E5%A4%8D%E5%88%B6%E5%88%B0%E5%85%B6%E4%B8%AD%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BF%AE%E6%94%B9%E5%AE%83%E4%BB%AC%E3%80%82%E7%84%B6%E5%90%8E%E6%88%91%E5%B0%86include%2Fconfigs%E4%B8%AD%E7%9A%84sd%E5%A4%B4%E6%96%87%E4%BB%B6%E5%A4%8D%E5%88%B6%2F%E9%87%8D%E5%91%BD%E5%90%8D%E4%B8%BA%E6%88%91%E4%BB%AC%E7%9A%84%E6%9D%BF%E5%90%8D%E5%B9%B6%E8%BF%9B%E8%A1%8C%E4%BF%AE%E6%94%B9%E3%80%82%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%E6%88%91%E6%97%A0%E6%B3%95%E5%81%9A%E4%BB%BB%E4%BD%95%E4%BA%8B%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E4%B8%8D%E5%AD%98%E5%9C%A8%E3%80%82%E6%BA%90%E4%B8%8D%E5%9C%A8%E6%9E%84%E5%BB%BA%E6%A0%91%E4%B8%AD%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%AD%A3%E5%9C%A8%E4%BF%AE%E6%94%B9%20mx6qsabresd.c%E6%96%87%E4%BB%B6%EF%BC%8C%E6%82%A8%E5%BA%94%E8%AF%A5%E5%85%88%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E8%A1%A5%E4%B8%81%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BF%AE%E6%94%B9%E5%BD%93%E5%89%8D%E9%85%8D%E6%96%B9%E4%BB%A5%E6%B7%BB%E5%8A%A0%E8%A1%A5%E4%B8%81%E6%88%96%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%20.bbappend%E5%9C%A8%E6%96%B0%E5%B1%82%E4%B8%AD%E5%88%9B%E5%BB%BA%E6%96%87%E4%BB%B6%E3%80%82%E7%AC%AC%E4%BA%8C%E7%A7%8D%E9%80%89%E6%8B%A9%E6%9B%B4%E5%A5%BD%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E4%B8%8D%E4%BC%9A%E5%BD%B1%E5%93%8D%E5%B7%A5%E4%BD%9C%E9%85%8D%E6%96%B9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110998%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110998%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E7%9A%84%E6%9E%84%E5%BB%BA%E6%A0%91%E4%B8%AD%E7%9A%84%20u-boot%20%E6%98%AF%20u-boot-imx%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20u-boot-fslc%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%E8%AF%A5%E9%85%8D%E6%96%B9%E6%9D%A5%E6%9F%A5%E7%9C%8B%E4%BB%8E%E5%93%AA%E9%87%8C%E6%89%8B%E5%8A%A8%E6%8F%90%E5%8F%96%E6%BA%90%E5%B9%B6%E5%B0%86%E5%85%B6%E6%94%BE%E5%85%A5%E2%80%9Cgit%E2%80%9D%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%8C%E4%BD%86%E5%AE%83%E4%B8%8D%E5%AD%98%E5%9C%A8%E4%BA%8E%E6%9E%84%E5%BB%BA%E6%A0%91%E4%B8%AD%E7%9A%84%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E5%9C%B0%E6%96%B9%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%9E%84%E5%BB%BA%40ubuntu%EF%BC%9A%2Fmedia%2Fi.MX6_ddr3%2Ffsl-community-bsp%2Fbuild.x11%2Ftmp%2Fwork%24%E5%AF%BB%E6%89%BE%20%E3%80%82-iname%20mx6qsabresd.c%3C%2FLI%3E%3CLI%3E.%2Fimx6qsabresd-poky-linux-gnueabi%2Fu-boot-imx%2F2013-04-5%2Fgit%2Fuboot-imx%2Fboard%2Ffreescale%2Fmx6qsabresd%2Fmx6qsabresd.c%3C%2FLI%3E%3CLI%3E%E6%9E%84%E5%BB%BA%40ubuntu%EF%BC%9A%2Fmedia%2Fi.MX6_ddr3%2Ffsl-community-bsp%2Fbuild.x11%2Ftmp%2Fwork%24%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110997%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110997%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%89%80%E6%9C%89%E4%BB%A3%E7%A0%81%E9%83%BD%E4%BD%8D%E4%BA%8E%20tmp%2Fwork%20%E4%B8%8B%EF%BC%8C%E5%9C%A8%E8%AF%A5%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E6%90%9C%E7%B4%A2%E3%80%82%E6%88%91%E5%88%9A%E5%88%9A%E7%83%98%E7%84%99%EF%BC%8C%E5%B9%B6%E4%B8%94%20u-boot%20%E5%9C%A8%E8%BF%99%E6%9D%A1%E8%B7%AF%E5%BE%84%E4%B8%8A%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Etmp%2Fwork%2Fimx6qsabresd-poky-linux-gnueabi%2Fu-boot-fslc%2Fv2013.10-r0%2Fgit%2F%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110996%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110996%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8CSabreSD%20%E7%9A%84%E4%B8%80%E5%88%87%E9%83%BD%E6%9E%84%E5%BB%BA%E5%BE%97%E5%BE%88%E5%A5%BD%EF%BC%8C%E6%88%91%E7%8E%B0%E5%9C%A8%E5%87%86%E5%A4%87%E5%BC%80%E5%A7%8B%E7%A0%B4%E8%A7%A3%E6%88%91%E8%87%AA%E5%B7%B1%E7%9A%84%20BSP%E3%80%81%E5%B1%82%E7%AD%89%E3%80%82%E6%88%91%E5%94%AF%E4%B8%80%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%20u-boot%20%E7%9A%84%E4%BB%A3%E7%A0%81%E3%80%82%E4%BF%AE%E8%A1%A5%E5%86%85%E6%A0%B8%E5%BE%88%E6%A3%92%EF%BC%8C%E4%BD%86%E8%BF%99%E4%B8%8D%E6%98%AF%E5%85%8B%E9%9A%86%E5%B9%B3%E5%8F%B0%E7%9A%84%E7%AC%AC%E4%B8%80%E6%AD%A5%E3%80%82u-boot%20%E5%9C%A8%E5%93%AA%E9%87%8C%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110995%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110995%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Leo%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B7%B2%E7%BB%8F%E5%AF%B9%E5%AE%83%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%EF%BC%8C%E5%88%B0%E7%9B%AE%E5%89%8D%E4%B8%BA%E6%AD%A2%E5%AE%83%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%BE%88%E6%A3%92%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110994%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110994%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%88%9A%E5%88%9A%E6%9F%A5%E7%9C%8B%E4%BA%86%20Github%20%E4%B8%8A%E7%9A%84%20freescale-community-bsp-platform%20%E5%AD%98%E5%82%A8%E5%BA%93%EF%BC%8C%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%A5%BD%E5%83%8F%E5%8F%91%E7%94%9F%E4%BA%86%E4%B8%80%E4%BA%9B%E4%BA%8B%E6%83%85%E3%80%82%E6%98%BE%E7%84%B6%EF%BC%8C%E7%8E%B0%E5%9C%A8%E6%8E%A8%E8%8D%90%E7%9A%84%E5%88%86%E6%94%AF%E5%90%8D%E7%A7%B0%E6%98%AF%E2%80%9Cdora%E2%80%9D%E3%80%82%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E5%AE%98%E6%96%B9%E6%9C%80%E6%96%B0%E6%9C%80%E6%A3%92%E7%9A%84%E5%86%85%E6%A0%B8%E5%B7%B2%E7%BB%8F%E5%8F%91%E5%B8%83%E4%BA%86%E5%90%97%EF%BC%9F%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E5%8D%87%E7%BA%A7%E5%88%B0%E6%96%B0%E5%86%85%E6%A0%B8%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FLeonardoSandovalGonzalez%22%20target%3D%22_blank%22%3ELeonardoSandovalGonzalez%3C%2FA%3E%E6%98%AF%E5%AF%B9%E7%9A%84%EF%BC%8C%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fcontrolhorus%22%20target%3D%22_blank%22%3Econtrolhorus%3C%2FA%3E%20%EF%BC%8C%E8%BF%99%E6%98%AF%E4%B8%80%E4%BB%BD%E9%9D%9E%E5%B8%B8%E5%8F%A4%E8%80%81%E7%9A%84%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E9%9C%80%20Sabre%20Lite%20%E5%B8%AE%E5%8A%A9%EF%BC%8C%E8%AF%B7%E6%9F%A5%E7%9C%8B%E6%9C%AC%E6%96%87%E6%A1%A3%E7%9A%84%E6%B3%A8%E9%87%8A%3CA%20_jive_internal%3D%22true%22%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94989%22%20title%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-94989%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-94989%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%84%BF%E6%84%8F%EF%BC%8C%E8%AF%B7%E8%BF%9B%E5%85%A5%20meta-freescale%20%E9%82%AE%E4%BB%B6%E5%88%97%E8%A1%A8%EF%BC%9A%20%3CA%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Flists.yoctoproject.org%2Flistinfo%2Fmeta-freescale%22%20title%3D%22https%3A%2F%2Flists.yoctoproject.org%2Flistinfo%2Fmeta-freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Flists.yoctoproject.org%2Flistinfo%2Fmeta-freescale%3C%2FA%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDiego%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AF%B9%E6%AD%A4%E6%B7%B1%E8%A1%A8%E6%AD%89%E6%84%8F%EF%BC%81%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FDaianeAngolini%22%20target%3D%22_blank%22%3EDaianeAngolini%3C%2FA%3E%E5%88%B6%E4%BD%9C%E7%9A%84%E8%BF%99%E4%B8%AA%E7%B2%BE%E5%BD%A9%E6%95%99%E7%A8%8B%E6%98%AF%E5%9C%A8%3CSTRONG%3EDanny%3C%2FSTRONG%3E%E6%98%AF%E7%A8%B3%E5%AE%9A%E5%88%86%E6%94%AF%E7%9A%84%E6%97%A7%E9%BB%91%E6%9A%97%E6%97%B6%E4%BB%A3%E5%88%9B%E5%BB%BA%E7%9A%84%E3%80%82%E7%8E%B0%E5%9C%A8%E6%9C%89%E4%BA%86%20Yocto%201.4%EF%BC%8C%20%3CSTRONG%3Edylan%3C%2FSTRONG%3E%E5%B0%B1%E6%98%AF%E6%9C%80%E5%A5%BD%E7%9A%84%E9%80%89%E6%8B%A9%E3%80%82%E8%AF%A5%E6%96%87%E4%BB%B6%E5%B7%B2%E8%A2%AB%E6%9B%B4%E6%AD%A3%E3%80%82%E5%B8%8C%E6%9C%9B%E4%BD%A0%E7%9A%84%E9%A1%B9%E7%9B%AE%E8%83%BD%E5%A4%9F%E8%BF%9B%E5%B1%95%E7%9A%84%E6%9B%B4%E5%BF%AB%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Daiane%20!!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E4%BB%8E%20farnell%20%E8%B4%AD%E4%B9%B0%E4%BA%86%20Sabre%20lite%20MCIMX6Q-SL%EF%BC%88%20%3CA%20href%3D%22http%3A%2F%2Fwww.element14.com%2Fcommunity%2Fcommunity%2Fknode%2Fsingle-board_computers%2Fsabrelite%22%20title%3D%22http%3A%2F%2Fwww.element14.com%2Fcommunity%2Fcommunity%2Fknode%2Fsingle-board_computers%2Fsabrelite%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ESABRE%20Lite%20i.MX6%20%E5%B9%B3%E5%8F%B0%20element14%20%E7%9A%84%20i.MX%206Quad%20%E5%A4%84%E7%90%86%E5%99%A8%E8%AF%84%E4%BC%B0%E6%9D%BF%20-%20element14%3C%2FA%3E%20%EF%BC%89%E3%80%82%E6%88%91%E4%BB%AC%E9%81%B5%E5%BE%AA%E4%BA%86%E6%82%A8%E7%9A%84%E6%89%80%E6%9C%89%E6%AD%A5%E9%AA%A4%EF%BC%8C%E4%BD%86%E6%AF%8F%E6%AC%A1%E9%83%BD%E5%8F%AA%E5%87%BA%E7%8E%B0%E5%86%85%E6%A0%B8%E6%81%90%E6%85%8C%EF%BC%88%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E4%BA%86%E5%A4%9A%E5%B9%85%E5%9B%BE%E5%83%8F%EF%BC%81%EF%BC%89%E3%80%82%E7%84%B6%E8%80%8C%EF%BC%8C%E7%BB%8F%E8%BF%87%E4%B8%80%E5%91%A8%E7%9A%84%E5%8A%AA%E5%8A%9B%EF%BC%8C%E6%88%91%E4%BB%AC%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%E6%9C%80%E7%BB%88%E8%AE%A4%E5%AE%9A%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3EDanny%20%E5%88%86%E6%94%AF%E4%B8%8D%E9%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%E7%94%A8%E4%BA%8E%E8%BF%99%E6%AC%BE%20Sabre%20Lite%E3%80%82%E6%88%91%E4%BB%AC%E5%A4%9A%E6%AC%A1%E5%9C%A8%E8%AE%BA%E5%9D%9B%E4%B8%8A%EF%BC%88yocto%E3%80%81element14%E2%80%A6%E2%80%A6%EF%BC%89%E5%AF%BB%E6%B1%82%E5%B8%AE%E5%8A%A9%EF%BC%8C%E5%B9%B6%E6%8F%90%E4%BE%9B%E4%BA%86%E5%8F%8D%E9%A6%88%E3%80%82%E6%9C%80%E7%BB%88%E7%BB%93%E8%AE%BA%E6%98%AF%EF%BC%9A%E5%A6%82%E6%9E%9C%E8%A6%81%E4%BD%BF%E7%94%A8%E8%BF%99%E6%AC%BE%E4%B8%BB%E6%9D%BF%EF%BC%8C%E6%9C%80%E5%A5%BD%E7%BC%96%E8%AF%91%3CSTRONG%3EDylan%20%E5%88%86%E6%94%AF%EF%BC%81%3C%2FSTRONG%3E%E8%AF%B7%E8%A7%81%E4%B8%8B%E6%96%87%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.element14.com%2Fcommunity%2Fmessage%2F78135%2378135%2Fl%2Fre-yocto-and-imx-6-element14-devlopment-kit%22%20title%3D%22http%3A%2F%2Fwww.element14.com%2Fcommunity%2Fmessage%2F78135%2378135%2Fl%2Fre-yocto-and-imx-6-element14-devlopment-kit%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EYocto%20%E5%92%8C%20IMX%206%20Element14%20%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%20-%20element14%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.element14.com%2Fcommunity%2Fthread%2F26340%3Fstart%3D0%26amp%3Btstart%3D0%22%20title%3D%22http%3A%2F%2Fwww.element14.com%2Fcommunity%2Fthread%2F26340%3Fstart%3D0%26amp%3Btstart%3D0%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.element14.com%2Fcommunity%2Fthread%2F26340%3Fstart%3D0%26amp%3Btstart%3D0%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E8%83%BD%E6%B7%BB%E5%8A%A0%E5%87%A0%E5%8F%A5%E8%AF%9D%EF%BC%88%E5%BD%93%E6%82%A8%E8%A7%A3%E9%87%8A%E5%A6%82%E4%BD%95%E4%B8%8B%E8%BD%BD%20BSP%20%E6%BA%90%E6%97%B6%EF%BC%89%E8%AF%B4%E6%98%8E%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E4%B8%8B%E8%BD%BD%20dylan%20%E5%88%86%E6%94%AF%EF%BC%8C%E9%82%A3%E5%B0%B1%E5%A4%AA%E5%A5%BD%E4%BA%86%E3%80%82%EF%BC%88%20%3CA%20href%3D%22https%3A%2F%2Fwiki.yoctoproject.org%2Fwiki%2FReleases%22%20title%3D%22https%3A%2F%2Fwiki.yoctoproject.org%2Fwiki%2FReleases%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwiki.yoctoproject.org%2Fwiki%2FReleases%3C%2FA%3E%20%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%8F%91%E8%A1%A8%E8%BF%99%E7%AF%87%E6%96%87%E7%AB%A0%E5%B9%B6%E4%BB%98%E5%87%BA%E6%97%B6%E9%97%B4%EF%BC%81%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%E5%91%80%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E2%80%9C%3CA%20href%3D%22http%3A%2F%2Fdocbook.sourceforge.net%2Frelease%2Fxsl%2Fcurrent%2Feclipse%2Feclipse3.xsl%22%20title%3D%22http%3A%2F%2Fdocbook.sourceforge.net%2Frelease%2Fxsl%2Fcurrent%2Feclipse%2Feclipse3.xsl%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3C%2FA%3E%E5%8F%91%E5%87%BA%E2%80%9Cmake%20DOC%3Dadt-manual%E2%80%9D%E6%97%B6%E5%87%BA%E7%8E%B0%E2%80%9C%20%3CA%20href%3D%22http%3A%2F%2Fdocbook.sourceforge.net%2Frelease%2Fxsl%2Fcurrent%2Feclipse%2Feclipse3.xsl%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fdocbook.sourceforge.net%2Frelease%2Fxsl%2Fcurrent%2Feclipse%2Feclipse3.xsl%3C%2FA%3E%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%E2%80%9D%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E6%94%BF%E5%BA%9C%E5%B0%81%E9%94%81%E4%BA%86%20sourceforge%EF%BC%8C%E6%88%91%E8%AF%95%E5%9B%BE%E5%9C%A8%E9%95%9C%E5%83%8F%E7%AB%99%E7%82%B9%E4%B8%8B%E8%BD%BD%E9%82%A3%E4%BA%9B%E7%BC%BA%E5%B0%91%E7%BC%96%E8%AF%91%E7%9A%84%E9%A1%B9%E7%9B%AE%E3%80%82%E4%BD%86%E6%98%AF%E5%AF%B9%E4%BA%8E%E4%B8%8A%E8%BF%B0%E6%B6%88%E6%81%AF%EF%BC%8C%E6%88%91%E5%8F%AA%E6%98%AF%E4%B8%8D%E7%9F%A5%E9%81%93%E6%88%91%E5%BA%94%E8%AF%A5%E4%B8%8B%E8%BD%BD%E5%93%AA%E4%B8%AA%E9%A1%B9%E7%9B%AE%EF%BC%9F%E6%88%91%E5%B0%9D%E8%AF%95%E4%B8%8B%E8%BD%BD%20release.xsl%EF%BC%8C%E4%BD%86%E6%9C%AA%E8%83%BD%E8%8E%B7%E5%8F%96%E6%AD%A3%E7%A1%AE%E7%9A%84%20eclipse3.xsl%20%E6%96%87%E4%BB%B6%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%E4%B8%8D%E7%AE%A1%E6%80%8E%E6%A0%B7%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E4%BB%96%E4%BB%AC%20%E9%83%BD%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E5%9C%A8%E4%B8%8D%E5%81%9C%E5%9C%B0%20%E7%83%98%E7%83%A4%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22hps%22%3E%E4%BD%86%E4%B8%8D%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%20%E7%9F%A5%E9%81%93%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%20%E8%9B%8B%E7%B3%95%E6%98%AF%20%E6%80%8E%E4%B9%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%20%E5%90%83%E7%9A%84%3Asmileycool%3A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E7%9A%84%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FDaianeAngolini%22%20target%3D%22_blank%22%3EDaianeAngolini%3C%2FA%3E%20......%E6%88%91%E5%BF%85%E9%A1%BB%E5%90%8C%E6%84%8F%E4%BD%A0%E7%9A%84%E8%A7%82%E7%82%B9%3A-)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EYocto%20%E7%9A%84%E7%89%B9%E5%88%AB%E4%B9%8B%E5%A4%84%E5%9C%A8%E4%BA%8E%E6%AF%8F%E4%B8%AA%E4%BA%BA%E9%83%BD%E9%9D%9E%E5%B8%B8%E8%AE%A8%E5%8E%8C%E5%AE%83%EF%BC%81%EF%BC%88%E5%A5%A5%E5%A1%94%E7%BB%B4%E5%A5%A5%EF%BC%8C%E8%AF%B7%E4%B8%8D%E8%A6%81%E8%AF%BB%E8%BF%99%E4%B8%AA%EF%BC%9Asmileysilly%EF%BC%9A%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E8%AF%B4%EF%BC%8C%E6%88%91%E4%BB%8E%E5%86%85%E5%BF%83%E6%B7%B1%E5%A4%84%E8%AE%A8%E5%8E%8C%E5%AE%83%E5%A4%A7%E7%BA%A6%E5%85%AD%E4%B8%AA%E6%9C%88%EF%BC%8C%E7%9B%B4%E5%88%B0%E6%88%91%E5%BC%80%E5%A7%8B%E2%80%9C%E6%8E%A5%E5%8F%97%E2%80%9D%E5%AE%83%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%EF%BC%88%E7%BB%8F%E8%BF%87%E4%B8%80%E5%B9%B4%E5%8D%8A%E5%92%8C%202%20%E4%B8%AA%20imx%20%E5%8F%91%E5%B8%83%EF%BC%89%E6%88%91%E5%8F%AF%E4%BB%A5%E8%AF%B4%E6%88%91%E5%87%A0%E4%B9%8E%E7%90%86%E8%A7%A3%E5%AE%83%E4%BA%86%E3%80%82%E6%88%91%E5%87%A0%E4%B9%8E%E5%96%9C%E6%AC%A2%E5%AE%83%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110986%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110986%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Leo%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E8%BF%87%E7%A8%8B%EF%BC%9B%E6%88%91%E4%B8%8D%E4%BD%BF%E7%94%A8%20yocto-bsp%20%E5%B7%A5%E5%85%B7%E5%B9%B6%E6%89%8B%E5%8A%A8%E5%88%B6%E4%BD%9C%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BD%86%E8%BF%99%E6%98%AF%E4%B8%80%E8%88%AC%E8%BF%87%E7%A8%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A5%BD%E5%A4%84%E6%98%AF%EF%BC%8C%E5%9C%A8%E6%8B%A5%E6%9C%89%E8%87%AA%E5%B7%B1%E7%9A%84%E5%B1%82%E4%B9%8B%E5%90%8E%EF%BC%8C%E4%BF%9D%E6%8C%81%E5%85%B6%E6%9B%B4%E6%96%B0%E5%B9%B6%E5%8C%85%E5%90%AB%E6%96%B0%E5%86%85%E5%AE%B9%E5%B0%B1%E5%8F%98%E5%BE%97%E9%9D%9E%E5%B8%B8%E7%AE%80%E5%8D%95%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9F%A5%E9%81%93%20Yocto%20%E4%B8%80%E5%BC%80%E5%A7%8B%E4%BC%9A%E8%AE%A9%E4%BA%BA%E5%9B%B0%E6%83%91%EF%BC%8C%E4%BD%86%E6%98%AF%E4%B8%80%E6%97%A6%E4%BD%A0%E4%B9%A0%E6%83%AF%E4%BA%86%E5%AE%83%EF%BC%8C%E5%B7%A5%E4%BD%9C%E8%B5%B7%E6%9D%A5%E5%B0%B1%E4%BC%9A%E5%BE%88%E6%84%89%E5%BF%AB%E3%80%82%E6%88%91%E7%BB%8F%E5%B8%B8%E4%B8%BA%E5%AE%A2%E6%88%B7%E5%81%9A%E5%AE%9A%E5%88%B6%E7%9A%84%20BSP%EF%BC%8C%E8%80%8C%E5%88%86%E5%B1%82%E7%B3%BB%E7%BB%9F%EF%BC%8C%E5%8D%B3%E4%BD%BF%E4%B8%80%E5%BC%80%E5%A7%8B%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%BE%88%E6%B7%B7%E4%B9%B1%EF%BC%8C%E4%B9%9F%E4%BD%BF%E6%88%91%E4%BB%AC%E8%83%BD%E5%A4%9F%E7%94%A8%E4%B8%80%E4%B8%AA%E9%9D%9E%E5%B8%B8%E5%B0%8F%E7%9A%84%E5%9B%A2%E9%98%9F%E6%9D%A5%E6%94%AF%E6%8C%81%E5%A4%A7%E9%87%8F%E7%9A%84%E5%AE%A2%E6%88%B7%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110985%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110985%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CBLOCKQUOTE%3E%0A%3CP%3EOtavioSalvador%E5%86%99%E9%81%93%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%E6%94%B9%E5%8F%98%E9%85%8D%E6%96%B9%E5%B9%B6%E4%B8%8D%E6%98%AF%E6%9C%80%E5%A5%BD%E7%9A%84%E9%80%89%E6%8B%A9%EF%BC%9B%E6%9C%80%E5%A5%BD%E7%9A%84%E6%96%B9%E6%B3%95%E6%98%AF%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E7%89%B9%E5%AE%9A%E4%BA%8E%E6%82%A8%E9%9C%80%E6%B1%82%E7%9A%84%E5%9B%BE%E5%83%8F%E5%B9%B6%E6%B7%BB%E5%8A%A0%E6%82%A8%E9%9C%80%E8%A6%81%E7%9A%84%E5%8C%85%E3%80%82%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3CIMG%20alt%3D%22%E5%A4%B4%E6%A1%8C.jpg%22%20class%3D%22jive-image%22%20src%3D%22https%3A%2F%2Fdrupal.org%2Ffiles%2Fproject-images%2Fheaddesk.jpg%22%20%2F%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E8%AE%A9%E6%88%91%E4%BB%AC%E5%9B%9E%E6%83%B3%E8%B5%B7%E6%88%91%E4%B9%8B%E5%89%8D%E5%AF%B9%20Yocto%20%E7%9A%84%E5%93%80%E5%8F%B9%EF%BC%8C%E5%AE%83%E4%B8%8E%E4%BC%8F%E5%B0%BC%E5%A5%91%E6%89%8B%E7%A8%BF%E4%B8%80%E6%A0%B7%E6%B8%85%E6%99%B0%E6%98%93%E6%87%82%E3%80%82%E2%80%9C%E6%98%BE%E7%84%B6%E2%80%9D%E6%82%A8%E6%83%B3%E8%A6%81%E5%88%9B%E5%BB%BA%E8%87%AA%E5%B7%B1%E7%9A%84%E5%9B%BE%E5%B1%82%E5%92%8C%E5%9B%BE%E5%83%8F%E9%85%8D%E6%96%B9%E3%80%82%E4%BD%86%3CEM%3E%3CSTRONG%3E%E5%A6%82%E4%BD%95%E5%81%9A%E5%88%B0%E8%BF%99%E4%B8%80%E7%82%B9%3C%2FSTRONG%3E%3C%2FEM%3E%E5%8D%B4%E4%B8%80%E7%82%B9%E4%B9%9F%E4%B8%8D%E6%98%8E%E6%98%BE%E3%80%82%E6%88%91%E8%8A%B1%E4%BA%86%E4%B8%89%E4%B8%AA%E5%A4%9A%E6%98%9F%E6%9C%9F%E4%B8%8D%E6%96%AD%E7%9B%AF%E7%9D%80%E8%BF%99%E4%BA%9B%E8%83%A1%E8%A8%80%E4%B9%B1%E8%AF%AD%E6%89%8D%E8%8E%B7%E5%BE%97%E5%9F%BA%E6%9C%AC%E7%9A%84%E7%90%86%E8%A7%A3%E3%80%82I2C%20%E8%AE%BE%E5%A4%87%EF%BC%9FSPI%20%E8%AE%BE%E5%A4%87%EF%BC%9F%E6%AD%A3%E5%9C%A8%E8%AE%BE%E7%BD%AE%E5%AE%89%E6%8D%B7%E4%BC%A6%E9%80%BB%E8%BE%91%E5%88%86%E6%9E%90%E4%BB%AA%EF%BC%9F%E5%91%B8%EF%BC%81%E8%BF%99%E5%8F%AA%E6%98%AF%E4%BA%9B%E7%90%90%E4%BA%8B%E8%80%8C%E5%B7%B2%E3%80%82%E4%BD%86%E8%BF%99%E4%B8%AA%20Yocto%20%E4%B8%9C%E8%A5%BF%E5%8F%AA%E6%98%AF%E7%BA%BF%E8%B7%AF%E5%99%AA%E9%9F%B3......%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E...%E5%99%93%E3%80%82%E8%AF%9D%E8%99%BD%E5%A6%82%E6%AD%A4%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B0%B1%E6%88%91%E8%80%8C%E8%A8%80%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E4%B8%BA%E6%88%91%E4%BB%AC%E7%9A%84%E8%91%A3%E4%BA%8B%E4%BC%9A%E8%AE%BE%E7%BD%AE%E4%B8%80%E4%B8%AA%E5%B1%82%E3%80%82%E7%9B%AE%E5%89%8D%E5%AE%83%E9%92%88%E5%AF%B9%E7%9A%84%E6%98%AF%20SABRE-SD%20%E6%9D%BF%EF%BC%8C%E4%BD%86%E5%B0%86%E4%B8%8D%E6%96%AD%E5%8F%91%E5%B1%95%E4%BB%A5%E8%A6%86%E7%9B%96%E6%88%91%E4%BB%AC%E7%9A%84%20Shiny%20New%20Thing(TM)%E3%80%82%E4%B8%BA%E6%AD%A4%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E5%91%BD%E4%BB%A4%E2%80%9Cyocto-layer%20create%20%3CLAYER_NAME%3E%E2%80%9D%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E6%96%B0%E5%B1%82%E3%80%82%E5%AE%83%E4%BC%9A%E8%AF%A2%E9%97%AE%E6%82%A8%E4%B8%80%E7%B3%BB%E5%88%97%E9%97%AE%E9%A2%98%EF%BC%9B%E9%BB%98%E8%AE%A4%E8%AE%BE%E7%BD%AE%E5%8F%AF%E8%83%BD%E5%B0%B1%E5%8F%AF%E4%BB%A5%E4%BA%86%E3%80%82%E6%AD%A4%E5%91%BD%E4%BB%A4%E4%BB%85%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%B1%82%E7%9B%AE%E5%BD%95%EF%BC%9B%E5%AE%83%E4%B8%8D%E4%BC%9A%E5%AF%B9%E6%82%A8%E7%9A%84%E7%8E%AF%E5%A2%83%E8%BF%9B%E8%A1%8C%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E6%9B%B4%E6%94%B9%EF%BC%88%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E5%B0%86%E5%85%B6%E5%BC%84%E4%B9%B1%EF%BC%8C%E6%82%A8%E5%8F%AA%E9%9C%80%E5%88%A0%E9%99%A4%E8%AF%A5%E7%9B%AE%E5%BD%95%E5%B9%B6%E9%87%8D%E6%96%B0%E5%BC%80%E5%A7%8B%E5%8D%B3%E5%8F%AF%EF%BC%89%E3%80%82%E5%BD%93%E5%91%BD%E4%BB%A4%E5%AE%8C%E6%88%90%E6%97%B6%EF%BC%8C%E6%82%A8%E5%B0%86%E6%8B%A5%E6%9C%89%E4%B8%80%E4%B8%AA%E5%8F%AA%E5%8C%85%E5%90%AB%E8%84%9A%E6%89%8B%E6%9E%B6%E7%9A%84%E5%B1%82%E7%9B%AE%E5%BD%95%EF%BC%88%E5%8D%B3%E5%AE%83%E5%B0%9A%E6%9C%AA%E6%89%A7%E8%A1%8C%E4%BB%BB%E4%BD%95%E6%93%8D%E4%BD%9C%EF%BC%89%E3%80%82%3C%2FLAYER_NAME%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E6%97%B6%EF%BC%8C%E6%82%A8%E5%87%A0%E4%B9%8E%E5%B7%B2%E7%BB%8F%E5%87%86%E5%A4%87%E5%A5%BD%E5%B0%86%20Yocto%20%E5%8F%91%E8%A1%8C%E7%89%88%E4%B8%AD%E7%9A%84%E5%85%B6%E4%BB%96%E6%96%87%E4%BB%B6%E5%A4%8D%E5%88%B6%E7%B2%98%E8%B4%B4%E5%88%B0%E6%96%B0%E5%B1%82%E5%B9%B6%E8%BF%9B%E8%A1%8C%E4%BF%AE%E6%94%B9%E3%80%82%E5%B0%B1%E6%88%91%E8%80%8C%E8%A8%80%EF%BC%8C%E6%88%91%E5%B0%86%20core-image-minimal%20%E7%9B%AE%E6%A0%87%E7%9A%84%E9%85%8D%E6%96%B9%E5%A4%8D%E5%88%B6%E5%88%B0%E6%88%91%E7%9A%84%E5%B1%82%E4%B8%AD%E5%B9%B6%E5%BC%80%E5%A7%8B%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E7%A0%B4%E8%A7%A3%E3%80%82%E5%81%87%E8%AE%BE%E6%82%A8%E7%9A%84%E6%96%B0%E5%9B%BE%E5%B1%82%E5%90%8D%E4%B8%BA%20meta-belis3%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CTT%3Emkdir%20-p%20%E6%BA%90%2Fmeta-belis3%2Frecipes-core%2Fimages%3C%2FTT%3E%3C%2FP%3E%3CP%3E%3CTT%3Ecp%20%E6%BA%90%2Fpoky%2Fmeta%2Frecipes-core%2Fimages%2Fcore-image-minimal.bb%20%E6%BA%90%2Fmeta-belis3%2Frecipes-core%2Fimages%2Ffoobar.bb%3C%2FTT%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E6%97%B6%EF%BC%8C%E5%B0%86%E6%96%B0%E5%A4%8D%E5%88%B6%E7%9A%84%20foobar.bb%20%E5%8A%A0%E8%BD%BD%E5%88%B0%E6%82%A8%E6%9C%80%E5%96%9C%E6%AC%A2%E7%9A%84%E7%BC%96%E8%BE%91%E5%99%A8%E4%B8%AD%E5%B9%B6%E5%BC%80%E5%A7%8B%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E4%BF%AE%E6%94%B9%E3%80%82%E5%87%A0%E4%B9%8E%E5%8F%AF%E4%BB%A5%E8%82%AF%E5%AE%9A%EF%BC%8C%E6%82%A8%E4%BC%9A%E5%B0%86%E5%8C%85%E6%B7%BB%E5%8A%A0%E5%88%B0%20IMAGE_INSTALL%20%E5%8F%98%E9%87%8F%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%80%E6%97%A6%E6%82%A8%E5%87%86%E5%A4%87%E5%A5%BD%E5%B0%9D%E8%AF%95%E6%9F%90%E4%BA%9B%E4%B8%9C%E8%A5%BF%EF%BC%8C%E8%AF%B7%E8%BF%9B%E5%85%A5%E6%82%A8%E7%9A%84%E6%9E%84%E5%BB%BA%E7%9B%AE%E5%BD%95%E3%80%82%E7%BC%96%E8%BE%91%20conf%2Fbblayers.conf%20%E6%96%87%E4%BB%B6%E4%BB%A5%E5%8C%85%E5%90%AB%E6%82%A8%E6%96%B0%E5%88%9B%E5%BB%BA%E7%9A%84%E5%B1%82%EF%BC%8C%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CTT%3EBBLAYERS%20%3D%20%22%20%5C%3C%2FTT%3E%3C%2FP%3E%3CP%3E%3CTT%3E%24%7BBSPDIR%7D%20%2Fsources%2Fpoky%2Fmeta%20%5C%3C%2FTT%3E%3C%2FP%3E%3CP%3E%5B%20...blah%2C%20blah%2C%20blah...%20%5D%3C%2FP%3E%3CP%3E%3CTT%3E%24%7BBSPDIR%7D%2Fsources%2Fmeta-fsl-demos%20%5C%3C%2FTT%3E%3C%2FP%3E%3CP%3E%3CTT%3E%24%7BBSPDIR%7D%20%2Fsources%2Fmeta-belis3%20%5C%20%23%3C%2FTT%3E%20%26lt%3B--%20%E6%82%A8%E7%9A%84%E6%96%B0%E5%9B%BE%E5%B1%82%E5%B7%B2%E9%99%84%E5%8A%A0%E5%88%B0%E6%AD%A4%E5%A4%84%E3%80%82%3C%2FP%3E%3CP%3E%3CTT%3E%22%3C%2FTT%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%20bitbake%20%E5%B7%A5%E5%85%B7%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E6%82%A8%E7%9A%84%E6%96%B0%E5%B1%82%E3%80%82%E7%8E%B0%E5%9C%A8%E5%91%8A%E8%AF%89%20bitbake%20%E5%A4%84%E7%90%86%E4%BD%A0%E7%9A%84%E6%96%B0%E6%9E%84%E5%BB%BA%E9%85%8D%E6%96%B9%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CTT%3E%24%20bitbake%20foobar%3C%2FTT%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%97%B6%E5%80%99%EF%BC%8C%E5%B0%B1%E4%BC%9A%E6%9C%89%E4%BA%8B%E6%83%85%E5%8F%91%E7%94%9F%E3%80%82%E5%A6%82%E6%9E%9C%E4%BD%A0%E9%9D%9E%E5%B8%B8%E5%B9%B8%E8%BF%90%E7%9A%84%E8%AF%9D%EF%BC%8C%E9%82%A3%E4%B9%88%E4%BD%A0%E6%83%B3%E8%A6%81%E7%9A%84%E4%BA%8B%E6%83%85%E5%B0%B1%E4%BC%9A%E5%8F%91%E7%94%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E6%88%91%E8%83%BD%E6%8F%90%E4%BE%9B%E6%9B%B4%E6%B7%B1%E5%85%A5%E3%80%81%E6%9B%B4%E6%9C%89%E6%84%8F%E4%B9%89%E7%9A%84%E8%A7%81%E8%A7%A3%EF%BC%8C%E4%BD%86%E8%BF%99%E6%98%AF%E6%88%91%E8%BF%84%E4%BB%8A%E4%B8%BA%E6%AD%A2%E6%89%80%E8%83%BD%E8%8E%B7%E5%BE%97%E7%9A%84%E5%85%A8%E9%83%A8%E7%90%86%E8%A7%A3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%94%B9%E5%8F%98%E9%85%8D%E6%96%B9%E5%B9%B6%E4%B8%8D%E6%98%AF%E6%9C%80%E5%A5%BD%E7%9A%84%E9%80%89%E6%8B%A9%EF%BC%9B%E6%9C%80%E5%A5%BD%E7%9A%84%E6%96%B9%E6%B3%95%E6%98%AF%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E7%89%B9%E5%AE%9A%E4%BA%8E%E6%82%A8%E9%9C%80%E6%B1%82%E7%9A%84%E5%9B%BE%E5%83%8F%E5%B9%B6%E6%B7%BB%E5%8A%A0%E6%82%A8%E9%9C%80%E8%A6%81%E7%9A%84%E5%8C%85%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110983%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110983%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%20Leo..%E5%AE%83%E6%9C%89%E6%95%88..%3C%2FP%3E%3CP%3EPavan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E8%B0%A2%E8%B0%A2%EF%BC%8C%E8%BF%99%E6%A0%B7%E5%B0%B1%E8%A1%8C%E4%BA%86%3C%2FP%3E%3CP%3EJoerg%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110981%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110981%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%88%A0%E9%99%A4%20.%2Fmeta-fsl-demos%2Frecipes-fsl%2Fpackagegroup%2Fpackagegroup-fsl.bb%20%E4%B8%8A%E7%9A%84%20fio%20%E5%AD%97%E7%AC%A6%E4%B8%B2%E5%B9%B6%E5%86%8D%E6%AC%A1%E7%83%98%E7%84%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%AF%B9%E4%B8%8D%E8%B5%B7%EF%BC%8C%E4%B9%94%E6%A0%BC%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E4%BF%AE%E5%A4%8D%E4%BA%86%E4%B8%80%E4%BA%9B%20makefile%20%E9%97%AE%E9%A2%98%E3%80%82%E8%AF%B7%E6%89%A7%E8%A1%8C%E2%80%9Cgit%20pull%E2%80%9D%E5%92%8C%E2%80%9Cmake%20-f%20makefile_pdf%E2%80%9D%E3%80%82%E8%BE%93%E5%87%BA%E6%96%87%E4%BB%B6%E5%BA%94%E5%9C%A8%20yocto%2Fyocto_tutorial.pdf%20%E4%B8%8A%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110979%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110979%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E5%9C%A8%E4%B8%8D%E4%BD%BF%E7%94%A8%20hob%20%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E4%BB%8E%E7%8E%B0%E6%9C%89%E7%9A%84%20meta-openembedded%20%E5%B1%82%E6%88%96%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E5%B1%82%E4%B8%AD%E6%8E%92%E9%99%A4%E4%BB%BB%E4%BD%95%E5%8C%85%E9%85%8D%E6%96%B9%EF%BC%9F%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%20hob%20%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E4%BB%8E%20~%2Fsources%2Fmeta-openembedded%2Fmeta-oe%2Frecipe-benchmark%2Ffio%20yocto%20%E6%BA%90%E4%BB%A3%E7%A0%81%E4%B8%AD%E5%88%A0%E9%99%A4%20fio%20%E9%85%8D%E6%96%B9%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110978%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110978%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%94%A8%E9%94%99%E8%AF%AF%E6%9D%A5%E5%88%B9%E8%BD%A6%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Ejoerg%40Ubuntu-ws%3A~%2Fpresentations%24%20make%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%88%B6%E4%BD%9C-C%E5%B7%A5%E5%85%B7%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Emake%5B1%5D%3A%20%E8%BF%9B%E5%85%A5%E7%9B%AE%E5%BD%95%20%60%2Fhome%2Fjoerg%2Fpresentations%2Ftools'%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%88%B6%E4%BD%9C-C%20bash%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Emake%5B2%5D%3A%20%E8%BF%9B%E5%85%A5%E7%9B%AE%E5%BD%95%20%60%2Fhome%2Fjoerg%2Fpresentations%2Ftools%2Fbash'%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Emake%5B2%5D%3A%20%E5%AF%B9%E4%BA%8E%E2%80%98all%E2%80%99%E6%97%A0%E9%9C%80%E6%89%A7%E8%A1%8C%E4%BB%BB%E4%BD%95%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Emake%5B2%5D%3A%20%E7%A6%BB%E5%BC%80%E7%9B%AE%E5%BD%95%20%60%2Fhome%2Fjoerg%2Fpresentations%2Ftools%2Fbash'%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Emake%20-C%20git%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Emake%5B2%5D%3A%20%E8%BF%9B%E5%85%A5%E7%9B%AE%E5%BD%95%20%60%2Fhome%2Fjoerg%2Fpresentations%2Ftools%2Fgit'%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Epandoc%20--offline%20-s%20-t%20slidy%20-o%20basics.html%20basics.md%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Epandoc%EF%BC%9A--offline%20%E5%B7%B2%E5%BC%83%E7%94%A8%E3%80%82%E8%AF%B7%E4%BD%BF%E7%94%A8%20--self-contained%20%E4%BB%A3%E6%9B%BF%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Epandoc%EF%BC%9A%E7%94%A8%E6%88%B7%E9%94%99%E8%AF%AF%EF%BC%88%E4%B8%8D%E6%94%AF%E6%8C%81%20https%EF%BC%89%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Emake%5B2%5D%3A%20***%20%5Bbasics.html%5D%E9%94%99%E8%AF%AF%201%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Emake%5B2%5D%3A%20%E7%A6%BB%E5%BC%80%E7%9B%AE%E5%BD%95%20%60%2Fhome%2Fjoerg%2Fpresentations%2Ftools%2Fgit'%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Emake%5B1%5D%3A%20***%20%5Bgit%5D%20Error%202%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Emake%5B1%5D%3A%20%E7%A6%BB%E5%BC%80%E7%9B%AE%E5%BD%95%20%60%2Fhome%2Fjoerg%2Fpresentations%2Ftools'%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Emake%EF%BC%9A***%20%5B%E5%B7%A5%E5%85%B7%5D%20%E9%94%99%E8%AF%AF%202%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E6%B6%88%E6%81%AF%EF%BC%88%E4%BD%86%E4%B8%BA%E8%8B%B1%E6%96%87%EF%BC%89%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E8%B0%83%E6%9F%A5%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%88%9B%E5%BB%BA%E6%95%B4%E4%B8%AA%20pdf%EF%BC%8C%E5%8F%AA%E9%9C%80%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E8%AF%B4%E6%98%8E%E6%93%8D%E4%BD%9C%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Flsandoval%2Fpresentations%22%20title%3D%22https%3A%2F%2Fgithub.com%2Flsandoval%2Fpresentations%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Elsandoval%2Fpresentations%20%C2%B7%20GitHub%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110976%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110976%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%20PDF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22jive-wiki-body-thumbnail%22%3E%20%3C%2FSPAN%3E%26nbsp%3B%20%3CSPAN%20class%3D%22jive-wiki-body-file%22%3E%20%3CSPAN%20class%3D%22jive-wiki-body-file-info%22%3E%20yocto_tutorial.pdf%20%3CSMALL%20class%3D%22font-color-meta-light%22%3E(264.3%20K)%3C%2FSMALL%3E%26nbsp%3B%20%3CSPAN%20class%3D%22jive-wiki-body-file-actions%22%3E%20%3CSTRONG%3EIN%20DER%20WARTESCHLANGE%3C%2FSTRONG%3E%20%3C%2FSPAN%3E%20%3C%2FSPAN%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110975%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110975%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%AF%B9%20Yocto%20%E5%81%9A%E4%BA%86%E4%B8%80%E4%B8%AA%E9%9D%9E%E5%B8%B8%E7%AE%80%E7%9F%AD%E7%9A%84%E4%BB%8B%E7%BB%8D%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95096%22%20target%3D%22_blank%22%3Ei.MX%20Yocto%EF%BC%9AFreescale%20Yocto%20%E9%A1%B9%E7%9B%AE%E6%95%99%E7%A8%8B%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%E6%82%A8%E7%9A%84%E5%85%B7%E4%BD%93%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%85%88%E6%9F%A5%E7%9C%8B%E6%AD%A4%E5%A4%84%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Flsandoval%2Fpresentations%2Fblob%2Fmaster%2Fyocto%2Flayer.md%22%20title%3D%22https%3A%2F%2Fgithub.com%2Flsandoval%2Fpresentations%2Fblob%2Fmaster%2Fyocto%2Flayer.md%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Epresentations%2Fyocto%2Flayer.md%20at%20master%20%C2%B7%20lsandoval%2Fpresentations%20%C2%B7%20GitHub%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%BF%85%E9%A1%BB%E9%98%85%E8%AF%BB%E4%BB%80%E4%B9%88%E6%89%8D%E8%83%BD%E5%AD%A6%E4%BC%9A%E6%9E%84%E5%BB%BA%E8%87%AA%E5%B7%B1%E7%9A%84%E6%9C%BA%E5%99%A8%E5%B1%82%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110973%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110973%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A5%9D%E4%BD%A0%E5%A5%BD%E8%BF%90%EF%BC%81%20%EF%BC%9A-%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EMarS%20%E6%9D%BF%E5%9C%A8%E8%BF%99%E9%87%8C%EF%BC%8C%E7%9C%8B%E8%B5%B7%E6%9D%A5%E4%B8%8D%E9%94%99%EF%BC%8C%E5%8A%9F%E8%83%BD%E4%B9%9F%E5%BE%88%E6%BC%82%E4%BA%AE%20%3CIMG%20id%3D%22smileywink%22%20class%3D%22emoticon%20emoticon-smileywink%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-wink.png%22%20alt%3D%22Smiley%20Wink%22%20title%3D%22Smiley%20Wink%22%20%2F%3E%20%E7%8E%B0%E5%9C%A8%E6%88%91%E9%9C%80%E8%A6%81%20Yocto%20%E6%94%AF%E6%8C%81%20%3CIMG%20id%3D%22smileywink%22%20class%3D%22emoticon%20emoticon-smileywink%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-wink.png%22%20alt%3D%22Smiley%20Wink%22%20title%3D%22Smiley%20Wink%22%20%2F%3E%3C%2FP%3E%3CP%3Eembest%20%E7%9A%84%E6%94%AF%E6%8C%81%E6%B2%A1%E6%9C%89%E7%AD%94%E5%A4%8D%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Leo%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%96%E5%A4%9A%E6%88%96%E5%B0%91%E3%80%82%E4%BA%8B%E5%AE%9E%E4%B8%8A%EF%BC%8C%E6%88%91%E8%AE%A1%E5%88%92%E5%B0%86%E6%9D%A5%E8%BF%81%E7%A7%BB%E5%88%B0%20linux-yocto%20%E7%B3%BB%E7%BB%9F%EF%BC%8C%E4%BD%86%E7%9B%AE%E5%89%8D%E8%BF%99%E5%A4%AA%E9%9A%BE%E4%BA%86%E3%80%82%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E5%86%85%E6%A0%B8%E8%BE%83%E6%97%A7%EF%BC%882.6.35.3%20%E5%92%8C%203.0.35%EF%BC%89%E7%9B%AE%E5%89%8D%E5%BE%88%E9%9A%BE%E4%B8%8E%20linux-yocto%20%E5%85%B1%E4%BA%AB%E5%B7%A5%E4%BD%9C%E3%80%82%E5%9B%A0%E6%AD%A4%E6%88%91%E4%BB%AC%E6%9A%82%E6%97%B6%E9%80%89%E6%8B%A9%E4%BD%BF%E7%94%A8%E6%9B%B4%E7%AE%80%E5%8D%95%E7%9A%84%E9%85%8D%E6%96%B9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B2%A1%E6%9C%89%E4%BB%80%E4%B9%88%E5%BC%BA%E8%BF%AB%E4%BA%BA%E4%BB%AC%E4%BD%BF%E7%94%A8%20linux-yocto%EF%BC%8C%E6%89%80%E4%BB%A5%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E5%86%B3%E5%AE%9A%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E4%B8%8E%E6%98%AF%E5%90%A6%E8%BF%87%E6%97%B6%E6%9C%89%E5%85%B3%E7%9A%84%E4%BA%8B%E6%83%85%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%83%B3%E6%88%91%E5%B7%B2%E7%BB%8F%E7%9C%8B%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%E7%9A%84%E4%B8%80%E9%83%A8%E5%88%86%E3%80%82%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%88%E6%AC%A2%E8%BF%8E%E9%9A%8F%E6%97%B6%E9%80%9A%E8%BF%87%E7%A4%BC%E8%B2%8C%E7%9A%84%E6%9B%B4%E6%AD%A3%E6%9D%A5%E7%BA%A0%E6%AD%A3%E6%88%91%E7%9A%84%E8%A7%82%E7%82%B9%EF%BC%89%EF%BC%8CYocto%20%E9%A1%B9%E7%9B%AE%E7%9A%84%E6%96%87%E6%A1%A3%E5%8F%8D%E6%98%A0%E4%BA%86%20Yocto%20%E7%B3%BB%E7%BB%9F%E7%9A%84%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E5%92%8C%E5%8A%9F%E8%83%BD%E3%80%82%E7%84%B6%E8%80%8C%EF%BC%8CFSL%20%E5%B1%82%E4%BC%BC%E4%B9%8E%E6%98%AF%E4%BD%BF%E7%94%A8%E6%97%A9%E6%9C%9F%E7%89%88%E6%9C%AC%E7%9A%84%20Yocto%20%E5%88%9B%E5%BB%BA%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E5%B0%9D%E8%AF%95%E4%BF%AE%E6%94%B9%20linux-imx%20%E5%86%85%E6%A0%B8%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%20linux-imx_3.0.35.bbappend%20%E6%96%87%E4%BB%B6%E5%B9%B6%E5%9C%A8%E5%85%B6%E4%B8%AD%E6%94%BE%E5%85%A5%E4%B8%80%E8%A1%8C%E2%80%9CSRC_URI%20%2B%3D%E2%80%9Dfile%3A%2F%2Fenable-pcie.cfg%E2%80%9C%E6%9D%A5%E8%8E%B7%E5%8F%96%E9%85%8D%E7%BD%AE%E7%89%87%E6%AE%B5%EF%BC%8C%E6%82%A8%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E8%8A%B1%E4%B8%80%E5%A4%A9%E6%97%B6%E9%97%B4%E4%BB%94%E7%BB%86%E7%A0%94%E7%A9%B6%20bitbake%20%E8%B0%83%E8%AF%95%E6%97%A5%E5%BF%97%EF%BC%8C%E6%83%B3%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%20Yocto%20%E5%BF%BD%E7%95%A5%E4%BA%86%E6%82%A8%E3%80%82%E6%9C%80%E7%BB%88%E4%BD%A0%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%8F%91%E7%8E%B0%20.bb%E5%92%8C%20.bbappendFSL%20%E5%B1%82%E4%B8%AD%E7%9A%84%E6%96%87%E4%BB%B6%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%87%A0%E4%B9%8E%E4%B8%8E%E5%BD%93%E5%89%8D%20Yocto%20%E6%96%87%E6%A1%A3%E6%89%80%E6%8F%8F%E8%BF%B0%E7%9A%84%E4%B8%8D%E5%90%8C%EF%BC%8C%E4%BD%86%E5%B9%B6%E4%B8%8D%E5%AE%8C%E5%85%A8%E4%B8%8D%E5%90%8C%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%EF%BC%8C%E6%B2%AE%E4%B8%A7%E5%9C%B0%E5%9C%A8%20Google%20%E4%B8%8A%E6%90%9C%E7%B4%A2%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E6%97%B6%EF%BC%8C%E6%82%A8%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%81%B6%E7%84%B6%E5%8F%91%E7%8E%B0%E9%82%AE%E4%BB%B6%E5%88%97%E8%A1%A8%E4%B8%AD%E6%9F%90%E4%B8%AA%E7%BA%BF%E7%A8%8B%E7%9A%84%E7%89%87%E6%AE%B5%EF%BC%8C%E8%AF%A5%E7%89%87%E6%AE%B5%E4%BB%A5%E6%9C%80%E9%9A%90%E6%99%A6%E7%9A%84%E6%96%B9%E5%BC%8F%E6%9A%97%E7%A4%BA%E2%80%9C%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E7%89%87%E6%AE%B5%E2%80%9D%E5%8A%9F%E8%83%BD%E6%98%AF%20Yocto%201.4%20%E7%9A%84%E6%96%B0%E5%8A%9F%E8%83%BD%EF%BC%8C%E8%BF%99%E8%AE%A9%E6%82%A8%E4%B8%8D%E7%A6%81%E7%96%91%E6%83%91%EF%BC%8C%E2%80%9C%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%20FSL%20%E9%85%8D%E6%96%B9%E6%98%AF%E5%90%A6%E6%98%AF%E4%BD%BF%E7%94%A8%E6%97%A9%E6%9C%9F%E8%AF%AD%E6%B3%95%E7%BB%84%E5%90%88%E5%9C%A8%E4%B8%80%E8%B5%B7%E7%9A%84%EF%BC%9F%E2%80%9D%E7%84%B6%E5%90%8E%E4%BD%A0%E5%A4%8D%E5%88%B6%E7%B2%98%E8%B4%B4%E5%85%B6%E4%B8%AD%E4%B8%80%E4%B8%AA%20.bbappendFSL%20%E5%B1%82%E4%B8%8B%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%E8%AF%AD%E6%B3%95%E2%80%9CSRC_URI_append_defconfig%20%3D%20%22%20file%3A%2F%2Fdefconfig%E2%80%9D%E6%8C%87%E5%AE%9A%E5%AE%8C%E6%95%B4%E7%9A%84%20defconfig%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E...%E7%84%B6%E5%90%8E%E5%86%85%E6%A0%B8%E6%9C%80%E7%BB%88%E6%8C%89%E7%85%A7%E6%82%A8%E6%83%B3%E8%A6%81%E7%9A%84%E6%96%B9%E5%BC%8F%E6%9E%84%E5%BB%BA%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E5%90%AC%E8%B5%B7%E6%9D%A5%E6%9C%89%E7%82%B9%E9%81%93%E7%90%86%E5%90%97%EF%BC%9F%E8%BF%98%E6%98%AF%E6%88%91%E5%8F%88%E6%83%B3%E5%A4%AA%E5%A4%9A%E4%BA%86%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%8F%AA%E9%9C%80%E4%BB%8E%20IMAGE_FEATURE%20%E4%B8%AD%E5%88%A0%E9%99%A4%E2%80%9Csplash%E2%80%9D%E5%8D%B3%E5%8F%AF%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110968%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110968%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E7%A0%94%E7%A9%B6%E4%BD%BF%E7%94%A8%20dylan%20%E6%BA%90%E6%9E%84%E5%BB%BA%E7%9A%84%20fsl-image-test%20Yocto%20%E5%9B%BE%E5%83%8F%E3%80%82%E6%88%91%E6%83%B3%E7%A6%81%E7%94%A8%E5%90%AF%E5%8A%A8%E6%97%B6%E5%87%BA%E7%8E%B0%E7%9A%84%E5%90%AF%E5%8A%A8%E7%94%BB%E9%9D%A2%EF%BC%88%E5%B8%A6%E6%9C%89%20Yocto%20%E5%BE%BD%E6%A0%87%E5%92%8C%E8%BF%9B%E5%BA%A6%E6%9D%A1%EF%BC%89%EF%BC%8C%E4%BD%86%E6%B5%8F%E8%A7%88%E7%BD%91%E9%A1%B5%E6%B2%A1%E6%9C%89%E7%BB%99%E6%88%91%E4%BB%BB%E4%BD%95%E7%AD%94%E6%A1%88%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E8%AF%A5%E6%80%8E%E4%B9%88%E5%81%9A%E5%91%A2%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110967%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110967%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CEM%3E%3CSTRONG%3E%3CBIG%3E%E8%BF%99%EF%BC%9A%3C%2FBIG%3E%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.yoctoproject.org%2Ftools-resources%2Fpresentations%2Fworking-kernel%22%20title%3D%22https%3A%2F%2Fwww.yoctoproject.org%2Ftools-resources%2Fpresentations%2Fworking-kernel%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.yoctoproject.org%2Ftools-resources%2Fpresentations%2Fworking-kernel%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%80%90%E6%AD%A5%E4%BB%8B%E7%BB%8D%E5%A6%82%E4%BD%95%E8%AE%BE%E7%BD%AE%E5%86%85%E6%A0%B8%E7%9A%84%E5%B1%82%E5%92%8C%E8%87%AA%E5%AE%9A%E4%B9%89%E9%85%8D%E7%BD%AE%E9%80%89%E9%A1%B9%EF%BC%8C%E4%BB%8E%E9%9B%B6%E5%88%B0%20BSP%20%E7%9A%84%E6%B5%81%E7%A8%8B%E4%B8%8D%E5%88%B0%2040%20%E9%A1%B5%E3%80%82%E5%88%B0%E7%9B%AE%E5%89%8D%E4%B8%BA%E6%AD%A2%EF%BC%8C%E5%AE%83%E5%B7%B2%E8%A2%AB%E8%AF%81%E6%98%8E%E6%9C%89%E5%BE%88%E5%A4%A7%E5%B8%AE%E5%8A%A9%E2%80%A6%E2%80%A6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%9F%A5%E7%9C%8B%20Yocto%20%E6%89%8B%E5%86%8C%E4%BA%86%E8%A7%A3%E5%8F%AF%E7%94%A8%E7%9A%84%E5%8A%9F%E8%83%BD%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110965%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110965%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CBLOCKQUOTE%3E%0A%3CP%3EOtavioSalvador%E5%86%99%E9%81%93%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E6%82%A8%E5%9C%A8%20IMAGE_FEATURES%20%E4%B8%AD%E7%BC%BA%E5%B0%91%E2%80%9Cdebug-tweaks%E2%80%9D%E3%80%82%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%E6%A3%80%E6%9F%A5%E5%AE%83%E6%98%AF%E5%90%A6%E8%83%BD%E8%A7%A3%E5%86%B3%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%E6%88%90%E5%8A%9F%E4%BA%86%EF%BC%81%EF%BC%88%E6%83%B3%E7%9F%A5%E9%81%93%E5%8E%9F%E5%9B%A0%E5%B0%B1%E5%A5%BD%E4%BA%86%E3%80%82%EF%BC%89%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110964%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110964%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Leo%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E6%82%A8%E5%9C%A8%20IMAGE_FEATURES%20%E4%B8%AD%E7%BC%BA%E5%B0%91%E2%80%9Cdebug-tweaks%E2%80%9D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%A3%80%E6%9F%A5%E5%AE%83%E6%98%AF%E5%90%A6%E8%83%BD%E8%A7%A3%E5%86%B3%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E5%85%B7%E4%BD%93%E7%9A%84%E9%97%AE%E9%A2%98%E8%A6%81%E9%97%AE%E4%BD%A0%3A-)%20...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%89%BE%E5%88%B0%E4%BA%86%E4%B8%80%E7%A7%8D%E6%8C%87%E5%AE%9A%E5%9B%BE%E5%83%8F%E9%85%8D%E6%96%B9%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%8C%E5%8C%85%E6%8B%AC%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%E4%BD%BF%E7%94%A8%20yocto-layer%20%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%E9%80%9A%E7%94%A8%E5%B1%82%EF%BC%88%E8%BF%99%E9%87%8C%E6%88%91%E7%A7%B0%E4%B9%8B%E4%B8%BA%20meta-belis3%EF%BC%89%EF%BC%8C%3C%2FLI%3E%3CLI%3E%E9%80%9A%E8%BF%87%E5%B0%86%20imx6dlsabresd.conf%20%E5%A4%8D%E5%88%B6%E5%88%B0%20meta-belis3%2Fconf%2Fmachine%2Fbelis3.conf%20%E6%9D%A5%E5%88%9B%E5%BB%BA%E6%9C%BA%E5%99%A8%E9%85%8D%E7%BD%AE%E3%80%82%E6%88%91%E8%BF%98%E4%BB%8E%20MACHINE_FEATURES%20%E4%B8%AD%E5%88%A0%E9%99%A4%E4%BA%86%E2%80%9C%E8%93%9D%E7%89%99%E2%80%9D%EF%BC%88%E5%9B%A0%E4%B8%BA%E6%88%91%E4%BB%AC%E7%9A%84%E6%9C%BA%E5%99%A8%E6%B2%A1%E6%9C%89%E5%AE%83%EF%BC%89%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E5%9C%A8%E6%88%91%E7%9A%84%E5%B1%82%E4%B8%AD%E5%88%9B%E5%BB%BA%E7%9B%AE%E5%BD%95%20meta-belis3%2Frecipes-core%2Fimages%EF%BC%8C%E5%B9%B6%E5%B0%86%20core-image-minimal.bb%20%E5%A4%8D%E5%88%B6%E5%88%B0%E5%85%B6%E4%B8%AD%E4%BD%9C%E4%B8%BA%20fiat-lux.bb%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E7%BC%96%E8%BE%91%20fiat-lux.bb%20%E4%BB%A5%E5%B0%86%E2%80%9Cpython%E2%80%9D%E6%B7%BB%E5%8A%A0%E5%88%B0%20IMAGE_INSTALL%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E5%9C%A8%E6%9E%84%E5%BB%BA%E7%9B%AE%E5%BD%95%E4%B8%AD%EF%BC%8C%E5%B0%86%E5%B1%82%20meta-belis3%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20conf%2Fbblayers.conf%EF%BC%9B%E5%B9%B6%E6%9B%B4%E6%94%B9%20conf%2Flocal.conf%20%E7%9A%84MACHINE%20%E8%87%B3%E2%80%98belis3%E2%80%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E5%88%B0%E7%9B%AE%E5%89%8D%E4%B8%BA%E6%AD%A2%EF%BC%8C%E2%80%98bitbake%20fiat-lux%E2%80%99%20%E8%AE%A9%E6%88%91%E6%9E%84%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E5%B8%A6%E6%9C%89%20python%20%E7%9A%84%E7%89%88%E6%9C%AC%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E6%89%80%E4%BB%A5%E6%88%91%E6%8E%A5%E4%B8%8B%E6%9D%A5%E8%A6%81%E5%81%9A%E7%9A%84%E5%B0%B1%E6%98%AF%E6%B7%BB%E5%8A%A0%20Dropbear%20SSH%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%9C%A8%20meta-belis3%2Frecipes-core%2Fimages%2Ffiat-lux.bb%20%E4%B8%AD%EF%BC%8C%E6%88%91%E8%A1%A5%E5%85%85%E9%81%93%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3EIMAGE_FEATURES%20%3D%E2%80%9Cssh-%E6%9C%8D%E5%8A%A1%E5%99%A8-dropbear%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E9%87%8D%E6%96%B0%E8%BF%90%E8%A1%8C%20bitbake%EF%BC%8Cdropbear%20%E7%A1%AE%E5%AE%9E%E8%A2%AB%E6%B7%BB%E5%8A%A0%E5%88%B0%E5%9B%BE%E5%83%8F%E4%B8%AD%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%86%8D%E7%99%BB%E5%BD%95%E2%80%94%E2%80%94%E6%9F%90%E4%BA%9B%E4%B8%9C%E8%A5%BF%E6%89%93%E5%8D%B0%E5%87%BA%E6%9C%89%E5%85%B3%E5%BD%B1%E5%AD%90%E5%AF%86%E7%A0%81%E4%B8%8D%E5%8C%B9%E9%85%8D%EF%BC%88%E6%88%96%E5%85%B6%E4%BB%96%EF%BC%89%E7%9A%84%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E2%80%9C%E5%97%AF%EF%BC%8C%E2%80%9D%E6%88%91%E6%83%B3%EF%BC%8C%E2%80%9C%E6%88%91%E7%8C%9C%20dropbear%20%E5%AF%B9%E2%80%98shadow%E2%80%99%20%E6%9C%89%E4%B8%80%E4%B8%AA%E6%9C%AA%E8%AE%B0%E5%BD%95%E7%9A%84%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%EF%BC%8C%E2%80%9D%E6%89%80%E4%BB%A5%E5%9C%A8%20fiat-lux.bb%20%E9%87%8C%E9%9D%A2%EF%BC%8C%E6%88%91%E5%90%91%20IMAGE_INSTALL%20%E6%B7%BB%E5%8A%A0%E4%BA%86%E2%80%9Cshadow%E2%80%9D%E3%80%82%E2%80%9Cshadow%E2%80%9D%E7%A1%AE%E5%AE%9E%E8%A2%AB%E6%B7%BB%E5%8A%A0%E4%BA%86%EF%BC%8C%E4%BD%86%E6%88%91%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E7%99%BB%E5%BD%95%EF%BC%8C%E8%BF%99%E6%AC%A1%E6%B2%A1%E6%9C%89%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E6%88%91%E8%A7%A3%E5%8E%8B%E4%BA%86%20tar.bz2%20%E6%98%A0%E5%83%8F%E6%96%87%E4%BB%B6%EF%BC%8C%E5%8F%91%E7%8E%B0%20%2Fetc%2Fshadow%20%E6%98%BE%E7%A4%BA%20root%20%E4%B8%94%E5%AF%86%E7%A0%81%E4%B8%BA%E7%A9%BA%EF%BC%9B%E4%BD%86%20%2Fetc%2Fpasswd%20%E6%98%BE%E7%A4%BA%20root%20%E4%B8%94%E5%AF%86%E7%A0%81%E5%AD%97%E6%AE%B5%E4%B8%BA%E2%80%9C*%E2%80%9D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E5%A6%82%E6%9E%9C%E6%88%91%E9%87%8D%E5%BB%BA%E6%B2%A1%E6%9C%89%20dropbear%20%E7%9A%84%E5%9B%BE%E5%83%8F%EF%BC%8C%E4%BD%86%E4%BF%9D%E7%95%99%20shadow%EF%BC%8C%E9%82%A3%E4%B9%88%E6%88%91%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E7%99%BB%E5%BD%95%20-%20%2Fetc%2Fshadow%20%E6%9C%89%E4%B8%80%E4%B8%AA%E7%A9%BA%E5%AF%86%E7%A0%81%EF%BC%8C%E5%B9%B6%E4%B8%94%20%2Fetc%2Fpasswd%20%E6%98%BE%E7%A4%BA%E5%AF%86%E7%A0%81%E5%AD%97%E6%AE%B5%E4%B8%BA%E2%80%9Cx%E2%80%9D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E9%82%A3%E4%B9%88....%E5%88%B0%E5%BA%95%E6%98%AF%E6%80%8E%E4%B9%88%E5%9B%9E%E4%BA%8B%EF%BC%9F%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A6%82%E6%9E%9C%E5%86%99%E4%BF%A1%E7%BB%99%E4%BB%96%E4%BB%AC%EF%BC%8C%E6%88%91%E5%B8%8C%E6%9C%9B%E4%BB%96%E4%BB%AC%E4%BC%9A%E8%BF%99%E4%B9%88%E5%81%9A%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110961%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110961%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%B8%8E%20embest%20%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E8%81%94%E7%B3%BB%E3%80%82%3CA%20href%3D%22http%3A%2F%2Fwww.embest-tech.com%2Fshop%2Fstar%2Fmarsboard.html%22%20title%3D%22http%3A%2F%2Fwww.embest-tech.com%2Fshop%2Fstar%2Fmarsboard.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMarS%20Board%3C%2FA%3E%20%EF%BC%8C%E5%B0%B1%E6%98%AF%E8%BF%99%E4%B8%AA%E6%9D%BF%E5%AD%90%EF%BC%8C%E7%9C%8B%E8%B5%B7%E6%9D%A5%E4%B8%8D%E9%94%99%EF%BC%9Asmileyhappy%EF%BC%9A%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110960%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110960%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%E6%B2%A1%E6%9C%89%EF%BC%9B%E8%AF%B7%E6%8E%A8%E5%8A%A8%E4%BB%96%E4%BB%AC%E5%A2%9E%E5%8A%A0%E5%AF%B9%20Yocto%20%E7%9A%84%E6%94%AF%E6%8C%81%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%BB%96%E4%BB%AC%E9%9C%80%E8%A6%81%E5%B8%AE%E5%8A%A9%E6%88%96%E5%92%A8%E8%AF%A2%EF%BC%8C%E8%AF%B7%E8%AE%A9%E4%BB%96%E4%BB%AC%E4%B8%8E%E6%88%91%E8%81%94%E7%B3%BB%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110959%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110959%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%A1%BA%E4%BE%BF%E4%B8%80%E6%8F%90%E3%80%82%E6%98%AF%E5%90%A6%E6%9C%89%E4%BA%BA%E5%9C%A8%E4%B8%BA%E6%96%B0%E7%9A%84%E7%81%AB%E6%98%9F%E6%9D%BF%E8%BF%9B%E8%A1%8C%E6%9C%BA%E5%99%A8%E5%B1%82%E5%B7%A5%E4%BD%9C%EF%BC%9F%E6%88%91%E8%AE%A2%E8%B4%AD%E4%BA%86%202%20%E4%BB%B6%20%3CIMG%20id%3D%22smileywink%22%20class%3D%22emoticon%20emoticon-smileywink%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-wink.png%22%20alt%3D%22Smiley%20Wink%22%20title%3D%22Smiley%20Wink%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%B7%BB%E5%8A%A0%E5%BC%80%E6%94%BE%20ssh%20%E5%B0%B1%E5%8F%AF%E4%BB%A5%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%20dropbear%20%E4%BC%9A%E8%87%AA%E5%8A%A8%E4%BB%8E%E5%9B%BE%E5%83%8F%E4%B8%AD%E5%88%A0%E9%99%A4%E3%80%82%E6%88%96%E8%80%85%E5%90%84%E4%B8%AA%E5%88%86%E6%94%AF%E4%B9%8B%E9%97%B4%E6%9C%89%E5%8C%BA%E5%88%AB%E5%90%97%EF%BC%9F%E6%88%91%E6%9C%80%E5%90%8E%E7%9A%84%E6%9E%84%E5%BB%BA%E4%BD%BF%E7%94%A8%E4%BA%86%20dylan%E3%80%82%E4%B8%8D%E7%A1%AE%E5%AE%9A%E6%88%91%E4%BB%A5%E5%89%8D%E7%94%A8%E8%BF%87%E4%BB%80%E4%B9%88%E3%80%82%E6%88%91%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%20hob%20%E7%9C%8B%E5%88%B0%EF%BC%8C%E5%BD%93%E9%80%9A%E8%BF%87%20local.config%20%E4%B8%AD%E7%9A%84%20extraimagefeature%20%E8%AE%BE%E7%BD%AE%E6%97%B6%EF%BC%8C%E6%89%80%E6%9C%89%E5%9B%BE%E5%83%8F%E9%83%BD%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%89%93%E5%BC%80%20ssh%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110957%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110957%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%BD%93%E7%84%B6%E5%8F%AF%E4%BB%A5%EF%BC%8C%E8%80%8C%E4%B8%94%E5%BE%88%E5%AE%B9%E6%98%93%E3%80%82%E6%82%A8%E6%89%80%E8%A6%81%E5%81%9A%E7%9A%84%E5%B0%B1%E6%98%AF%E9%98%85%E8%AF%BB%E6%AD%A3%E7%A1%AE%E7%9A%84%E6%96%87%E6%A1%A3%EF%BC%9Asmileywink%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2Fcurrent%2Fmega-manual%2Fmega-manual.html%23usingpoky-extend-customimage-imagefeatures%22%20title%3D%22http%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2Fcurrent%2Fmega-manual%2Fmega-manual.html%23usingpoky-extend-customimage-imagefeatures%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2Fcurrent%2Fmega-manual%2Fmega-manual.html%23usingpoky-extend-customimage-imagefeatures%E2%80%9D%E6%A0%87%E9%A2%98%3D%22http%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2Fcurrent%2Fmega-manual%2Fmega-manual.html%23usingpoky-extend-customimage-imagefeatures%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E8%BF%99%E4%BC%9A%E5%AF%B9%E4%BD%A0%E6%9C%89%E5%B8%AE%E5%8A%A9%3CIMG%20id%3D%22smileywink%22%20class%3D%22emoticon%20emoticon-smileywink%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-wink.png%22%20alt%3D%22Smiley%20Wink%22%20title%3D%22Smiley%20Wink%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%83%B3%E7%94%A8%20openssh%20%E8%80%8C%E4%B8%8D%E6%98%AF%20dropbear%20%E6%9D%A5%E6%9E%84%E5%BB%BA%E5%9B%BE%E5%83%8F%E3%80%82%E8%BF%99%E5%87%A0%E4%B9%8E%E6%98%AF%E4%B8%8D%E5%8F%AF%E8%83%BD%E7%9A%84%EF%BC%81%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110955%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110955%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%BC%9A%E4%B8%BA%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%2F%E5%85%AC%E5%8F%B8%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%B1%82%EF%BC%8C%E5%B9%B6%E5%9C%A8%E5%85%B6%E4%B8%AD%E5%86%99%E5%85%A5%E6%96%B0%E7%9A%84%E5%9B%BE%E5%83%8F%E9%85%8D%E6%96%B9%E3%80%82%E8%BF%99%E4%BD%BF%E5%BE%97%E7%BB%B4%E6%8A%A4%E5%8F%98%E5%BE%97%E7%AE%80%E5%8D%95%E5%B9%B6%E4%B8%94%E9%81%BF%E5%85%8D%E4%BA%86%E5%88%86%E5%8F%89%E7%9A%84%E9%9C%80%E8%A6%81%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%B2%A1%E6%9C%89%E5%B0%9D%E8%AF%95%E8%BF%87%20HOB%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E6%97%A0%E6%B3%95%E6%8F%90%E4%BE%9B%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%9B%E5%B7%A5%E4%BD%9C%E6%B5%81%E7%A8%8B%E6%9C%89%E7%82%B9%E9%9A%BE%E4%BB%A5%E7%90%86%E8%A7%A3%EF%BC%8C%E4%BD%86%E4%BD%A0%E4%BC%9A%E4%B9%A0%E6%83%AF%E7%9A%84%EF%BC%9B-)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110954%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110954%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3EOtavio%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E7%A0%94%E7%A9%B6%20imx6q_sabrelite%20%E6%9D%BF%E5%B9%B6%E4%BD%BF%E7%94%A8%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20yocto%20%E9%A1%B9%E7%9B%AE%E6%BA%90%E4%BB%A3%E7%A0%81%E6%9E%84%E5%BB%BA%20fsl-image-gui%20%E5%9B%BE%E5%83%8F%E3%80%82%E6%88%91%E6%83%B3%E4%BB%8E%E5%8F%AF%E7%94%A8%E7%9A%84%20fsl-image-gui%20%E5%9B%BE%E5%83%8F%E4%B8%AD%E6%8E%92%E9%99%A4%E4%B8%80%E4%BA%9B%E9%85%8D%E6%96%B9%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20bitbake%20%E5%88%9B%E5%BB%BA%E5%9B%BE%E5%83%8F%E3%80%82%E6%88%91%E6%80%8E%E6%A0%B7%E6%89%8D%E8%83%BD%E6%8E%92%E9%99%A4%E7%89%B9%E5%AE%9A%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%9A%84%E9%85%8D%E6%96%B9%EF%BC%9F%E5%8F%AF%E4%BB%A5%E6%88%91%E5%AF%B9%E7%8E%B0%E6%9C%89%E5%B1%82%E5%81%9A%E4%BA%86%E6%9B%B4%E6%94%B9%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20hob%20%E6%8E%92%E9%99%A4%E9%85%8D%E6%96%B9%EF%BC%8C%E6%88%91%E7%9A%84%E5%8C%85%E7%BC%96%E8%AF%91%E6%88%90%E5%8A%9F%EF%BC%8C%E4%BD%86%E5%9C%A8%E6%9E%84%E5%BB%BA%E5%9B%BE%E5%83%8F%20hob%20%E4%B9%8B%E5%90%8E%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF......%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHob%20%E5%BC%82%E5%B8%B8%20-%20%E8%BF%90%E8%A1%8C%E5%91%BD%E4%BB%A4%20'%5B'matchFile'%2C%20'hob-image.bb'%5D'%20%E6%97%B6%E5%87%BA%E9%94%99%EF%BC%9A%E5%9B%9E%E6%BA%AF%EF%BC%88%E6%9C%80%E8%BF%91%E4%B8%80%E6%AC%A1%E8%B0%83%E7%94%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fpavan%2Ffsl-community-bsp%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Fcommand.py%E2%80%9D%EF%BC%8C%E7%AC%AC%2068%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%20runCommand%20%E4%B8%AD%3C%2FP%3E%3CP%3E%E7%BB%93%E6%9E%9C%20%3D%20%E5%91%BD%E4%BB%A4%E6%96%B9%E6%B3%95%EF%BC%88%E8%87%AA%E8%BA%AB%EF%BC%8C%E5%91%BD%E4%BB%A4%E8%A1%8C%EF%BC%89%3C%2FP%3E%3CP%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fpavan%2Ffsl-community-bsp%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Fcommand.py%E2%80%9D%EF%BC%8CmatchFile%20%E4%B8%AD%E7%9A%84%E7%AC%AC%20210%20%E8%A1%8C%3C%2FP%3E%3CP%3E%E8%BF%94%E5%9B%9E%E5%91%BD%E4%BB%A4.cooker.matchFile(fMatch)%3C%2FP%3E%3CP%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fpavan%2Ffsl-community-bsp%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Fcooker.py%E2%80%9D%EF%BC%8CmatchFile%20%E4%B8%AD%E7%9A%84%E7%AC%AC%201142%20%E8%A1%8C%3C%2FP%3E%3CP%3E%E5%BC%95%E5%8F%91%20NoSpecificMatch%3C%2FP%3E%3CP%3E%E6%97%A0%E7%89%B9%E5%AE%9A%E5%8C%B9%E9%85%8D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%AC%AC%E4%B8%80%E6%AC%A1%E4%BD%BF%E7%94%A8%20yocto%20%E6%9E%84%E5%BB%BA%EF%BC%8C%E5%AE%83%E7%9A%84%E5%B7%A5%E4%BD%9C%E6%B5%81%E7%A8%8B%E5%BE%88%E9%9A%BE%E7%90%86%E8%A7%A3%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110953%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110953%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%E6%88%91%E7%9F%A5%E9%81%93%E4%BA%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110952%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110952%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%93%A6%EF%BC%81%3Asmileygrin%3A%20%E8%B0%A2%E8%B0%A2%20%3CIMG%20id%3D%22smileywink%22%20class%3D%22emoticon%20emoticon-smileywink%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-wink.png%22%20alt%3D%22Smiley%20Wink%22%20title%3D%22Smiley%20Wink%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110951%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110951%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EMeister%20%E6%98%AF%E4%B8%80%E4%B8%AA%E5%BE%B7%E8%AF%AD%E5%8D%95%E8%AF%8D%EF%BC%8C%E7%B1%BB%E4%BC%BC%E4%BA%8E%20Diane%20%E5%A4%A7%E5%B8%88%20%3CIMG%20id%3D%22smileywink%22%20class%3D%22emoticon%20emoticon-smileywink%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-wink.png%22%20alt%3D%22Smiley%20Wink%22%20title%3D%22Smiley%20Wink%22%20%2F%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110950%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110950%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fteddyzhang%22%20target%3D%22_blank%22%3Eteddyzhang%3C%2FA%3E%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%20lmbench%20%E5%92%8C%20tiobench%20%E6%98%AF%E5%90%A6%E4%BB%8D%E7%84%B6%E5%9C%A8%E8%AF%A5%E7%89%88%E6%9C%AC%2F%E5%AD%98%E5%82%A8%E5%BA%93%E4%B8%AD%E5%8F%AF%E7%94%A8%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E7%9A%84%E6%B5%8B%E8%AF%95%E4%B8%8D%E9%9C%80%E8%A6%81%E5%AE%83%E4%BB%AC%EF%BC%8C%E8%AF%B7%E8%AE%BF%E9%97%AE%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Fmeta-fsl-demos%2Fblob%2Fmaster%2Frecipes-fsl%2Fpackagegroup%2Fpackagegroup-fsl.bb%22%20title%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Fmeta-fsl-demos%2Fblob%2Fmaster%2Frecipes-fsl%2Fpackagegroup%2Fpackagegroup-fsl.bb%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%2Fmeta-fsl-demos%2Fblob%2Fmaster%2Frecipes-fsl%2Fpackagegroup%2Fpackagegroup-fsl.bb%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B9%B6%E5%88%A0%E9%99%A4%E8%A1%8C%EF%BC%9A75%E3%80%8182%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E4%BD%A0%E5%B0%B1%E5%8F%AF%E4%BB%A5%E5%BB%BA%E7%AB%8B%E4%BD%A0%E7%9A%84%E5%BD%A2%E8%B1%A1%E7%9B%B4%E5%88%B0%E6%9C%80%E5%90%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fleoschwab%22%20target%3D%22_blank%22%3Eleoschwab%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%90%8C%E6%84%8F%EF%BC%81%E6%88%91%E4%B9%9F%E4%B8%8D%E5%96%9C%E6%AC%A2%20yocto%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%EF%BC%81%E6%88%91%E8%AE%A4%E4%B8%BA%E5%AE%83%E5%A4%AA%E5%A4%8D%E6%9D%82%E3%80%81%E5%A4%AA%E6%B7%B1%E5%A5%A5%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E4%BD%A0%E7%9A%84%E8%AE%A1%E5%88%92%E5%BE%88%E6%A3%92%EF%BC%81%E5%A6%82%E6%9E%9C%E6%82%A8%E6%84%BF%E6%84%8F%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%B8%8A%E4%BC%A0%E6%82%A8%E7%9A%84%E4%B8%BB%E6%9D%BF%E6%88%96%E4%B8%80%E4%BA%9B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E8%AE%A4%E4%B8%BA%E5%AE%83%E5%8F%AF%E4%BB%A5%E5%85%AC%E5%BC%80%E3%80%82%E5%90%A6%E5%88%99%EF%BC%8C%E6%88%91%E5%B0%86%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%20BSP%20%E5%B1%82%EF%BC%88%E5%8C%85%E5%90%AB%E6%82%A8%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%BD%BF%E7%94%A8%E7%9A%84%E4%BD%BF%E5%85%B6%E6%B4%BB%E8%B7%83%E7%9A%84%E9%83%A8%E4%BB%B6%EF%BC%8C%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%EF%BC%89%E5%92%8C%E4%B8%80%E4%B8%AA%20APP%20%E5%B1%82%EF%BC%88%E5%8C%85%E5%90%AB%E6%82%A8%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%85%8D%E6%96%B9%E5%92%8C%E4%BB%BB%E4%BD%95%E5%9B%BE%E5%83%8F%E5%AE%9A%E5%88%B6%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%80%E4%B9%88%E6%98%AF%E2%80%9Cbuildmeister%E2%80%9D%EF%BC%9F%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E5%AE%83%E7%9A%84%E5%AE%9A%E4%B9%89%EF%BC%8C%E4%BD%86%E6%88%91%E5%8F%91%E7%8E%B0%E6%9C%89%E5%BE%88%E5%A4%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9Asmileysilly%EF%BC%9A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110948%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110948%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20class%3D%22jive-comment-meta%20font-color-meta-light%22%20style%3D%22margin%3A%200px%200px%208px%3B%20font-size%3A%200.9em%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%23a9a9a9%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fteddyzhang%22%20target%3D%22_blank%22%3Eteddyzhang%3C%2FA%3E%20%3CA%20_jive_internal%3D%22true%22%20class%3D%22font-color-meta-light%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93844%23comment-5399%22%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%23a9a9a9%3B%22%20target%3D%22_blank%22%3E2013-7-8%20%E4%B8%8A%E5%8D%8812%3A55%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3Ehi%2C%20daiane%2C%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%22%3E%E4%B8%BA%20sabrelite%20%E6%9D%BF%E6%9E%84%E5%BB%BA%E6%B5%8B%E8%AF%95%E5%9B%BE%E5%83%8F%E2%80%9Cbitbake%20fsl-image-test%E2%80%9D%EF%BC%8C%E5%B9%B6%E6%94%B6%E5%88%B0%E8%8E%B7%E5%8F%96%E6%BA%90%E4%BB%A3%E7%A0%81%E5%8C%85%E7%9A%84%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%EF%BC%8C%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%EF%BC%88%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E5%A4%9A%E6%AC%A1%EF%BC%8C%E4%BD%86%E6%80%BB%E6%98%AF%E5%A4%B1%E8%B4%A5%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%2F%E5%B7%A5%E4%BD%9C%E5%8C%BA%2F%E8%BD%AF%E4%BB%B6%2F%E5%AD%98%E5%82%A8%E5%BA%93%2Ffreescale%2Fyocto_rootfs%2Fsources%2Fmeta-openembedded%2Fmeta-oe%2Frecipes-benchmark%2Flmbench%2Flmbench_3.0-a9.bb%EF%BC%8C%E6%89%A7%E8%A1%8C%E5%8F%96%E5%9B%9E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%2F%E5%B7%A5%E4%BD%9C%E5%8C%BA%2F%E8%BD%AF%E4%BB%B6%2F%E5%AD%98%E5%82%A8%E5%BA%93%2F%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%2Fyocto_rootfs%2Fsources%2Fmeta-openembedded%2Fmeta-oe%2Frecipes-benchmark%2Ftiobench%2Ftiobench_0.3.3.bb%EF%BC%8C%E6%89%A7%E8%A1%8C%E5%8F%96%E5%9B%9E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E8%87%AA%E5%B7%B1%E7%BB%99%E5%87%BA%E7%9A%84%E7%AD%94%E6%A1%88%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E1.%20%E8%AE%BE%E7%BD%AEhttp_prxoy%E3%80%81ftp_proxy....%E6%9D%A5%E8%BF%9B%E8%A1%8C%E8%8E%B7%E5%8F%96%E3%80%82%E6%88%96%E8%80%85...%3C%2FP%3E%3CP%3E2.%E6%9F%A5%E9%98%85%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E4%BB%A5%E8%8E%B7%E5%8F%96%E9%A1%B9%E7%9B%AE%E2%80%9Cyocto%20%E9%A1%B9%E7%9B%AE%E5%A6%82%E4%BD%95%E8%8E%B7%E5%8F%96%E6%BA%90%E4%BB%A3%E7%A0%81%E4%BB%A5%E5%8F%8A%E5%AE%83%E5%B0%86%E5%A6%82%E4%BD%95%E5%9C%A8%E6%88%91%E7%9A%84%E9%98%B2%E7%81%AB%E5%A2%99%E6%88%96%E4%BB%A3%E7%90%86%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%90%8E%E9%9D%A2%E5%B7%A5%E4%BD%9C%E2%80%9D%E3%80%82%E6%88%96%E8%80%85...%3C%2FP%3E%3CP%3E3.%20%E8%87%AA%E8%A1%8C%E4%B8%8B%E8%BD%BD%E8%BD%AF%E4%BB%B6%E5%8C%85%E5%B9%B6%E5%B0%86%E5%AE%83%E4%BB%AC%E6%94%BE%E5%9C%A8%20%24POKY%2Fdownloads%2F%20%E4%B8%8A%EF%BC%8C%E7%84%B6%E5%90%8E%E8%A7%A6%E6%91%B8%20%24(PackageName).done%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110947%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110947%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CBLOCKQUOTE%3E%0A%3CP%3EDaiane%20Angolini%E5%86%99%E9%81%93%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%22-1%22%20data-containertype%3D%22-1%22%20data-objectid%3D%22214005%22%20data-objecttype%3D%223%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fleoschwab%22%20target%3D%22_blank%22%3ELeo%20Schwab%3C%2FA%3E%20%EF%BC%8C%E8%AF%B7%E8%AE%B0%E4%BD%8F%20Poky%20%E6%89%8B%E5%86%8C%E5%B7%B2%E7%BB%8F%E2%80%9C%E8%BF%87%E6%97%B6%E4%BA%86%E2%80%9D%E3%80%82%5B...%5D%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E5%BC%80%E5%A7%8B%E6%B3%A8%E6%84%8F%E5%88%B0%E2%80%94%E2%80%94Poky%20%E6%96%87%E6%A1%A3%E4%B8%AD%E7%9A%84%E5%85%B7%E4%BD%93%E7%A4%BA%E4%BE%8B%E4%B8%8E%E6%88%91%E6%8B%A5%E6%9C%89%E7%9A%84%E6%A0%91%E4%B8%AD%E7%9A%84%E5%86%85%E5%AE%B9%E4%B8%8D%E5%AF%B9%E5%BA%94%EF%BC%8C%E5%B9%B6%E4%B8%94%E7%9C%8B%E8%B5%B7%E6%9D%A5%E6%9C%89%E5%87%A0%E4%BB%B6%E4%B8%9C%E8%A5%BF%E8%A2%AB%E9%87%8D%E5%91%BD%E5%90%8D%E4%BA%86%E3%80%82%E4%BD%86%E4%BB%A4%E4%BA%BA%E6%81%BC%E7%81%AB%E7%9A%84%E6%98%AF%EF%BC%8CYocto%20%E6%96%87%E6%A1%A3%E4%B9%9F%E7%8A%AF%E4%BA%86%E8%BF%99%E6%A0%B7%E7%9A%84%E9%94%99%E8%AF%AF%EF%BC%8C%E5%B9%B6%E4%B8%94%EF%BC%88%E5%9C%A8%E6%88%91%E7%9C%8B%E6%9D%A5%EF%BC%89%E5%9C%A8%E8%A7%A3%E9%87%8A%E5%BA%95%E5%B1%82%E6%A6%82%E5%BF%B5%E6%96%B9%E9%9D%A2%E5%81%9A%E5%BE%97%E5%BE%88%E5%B7%AE%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E4%BB%8D%E5%9C%A8%E9%98%85%E8%AF%BB%20Poky%20%E6%96%87%E6%A1%A3%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%9B%B4%E5%A5%BD%E5%9C%B0%E4%BA%86%E8%A7%A3%20Bitbake%20%E8%AF%95%E5%9B%BE%E4%BD%93%E7%8E%B0%E7%9A%84%E6%A6%82%E5%BF%B5%EF%BC%8C%E7%84%B6%E5%90%8E%E5%BD%93%E6%88%91%E6%83%B3%E4%BA%86%E8%A7%A3%E5%85%B7%E4%BD%93%E5%86%85%E5%AE%B9%E6%97%B6%E5%86%8D%E5%8F%82%E8%80%83%20Yocto%20%E6%96%87%E6%A1%A3%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%9B%AE%E5%89%8D%EF%BC%8C%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20SABRE-SD%20%E6%9D%BF%E6%9D%A5%E5%BC%80%E5%A7%8B%EF%BC%8C%E5%B9%B6%E5%B0%86%E5%9C%A8%E5%85%B6%E4%B8%8A%E5%BC%80%E5%8F%91%E5%8E%9F%E5%9E%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E7%84%B6%E8%80%8C%EF%BC%8C%E6%9C%80%E7%BB%88%E7%9A%84%E7%A1%AC%E4%BB%B6%E4%BC%9A%E6%9C%89%E6%98%BE%E8%91%97%E5%B7%AE%E5%BC%82%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E6%B2%A1%E6%9C%89%E6%98%BE%E7%A4%BA%EF%BC%89%E3%80%82%E6%89%80%E4%BB%A5%E6%88%91%E7%9B%B8%E4%BF%A1%E6%88%91%E9%9C%80%E8%A6%81%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%E4%B8%BASABRE%E6%9D%BF%E6%9E%84%E5%BB%BA%E5%92%8C%E5%BC%80%E5%8F%91%E7%8E%AF%E5%A2%83%EF%BC%8C%3C%2FLI%3E%3CLI%3E%E4%B8%BA%E6%9C%80%E7%BB%88%E4%B8%BB%E6%9D%BF%E6%9E%84%E5%BB%BA%E5%92%8C%E5%BC%80%E5%8F%91%E7%8E%AF%E5%A2%83%EF%BC%8C%3C%2FLI%3E%3CLI%3E%E4%B8%BA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%BC%80%E5%8F%91%E4%BA%BA%E5%91%98%E6%8F%90%E4%BE%9B%E5%8F%AF%E8%83%BD%E7%9A%84%E6%A8%A1%E6%8B%9F%E7%8E%AF%E5%A2%83%EF%BC%8C%E5%9B%A0%E4%B8%BA%E4%B8%BB%E6%9D%BF%E6%9C%80%E5%88%9D%E4%BC%9A%E5%BE%88%E5%B0%91%EF%BC%88%E4%BB%96%E4%BB%AC%E5%8F%AF%E8%83%BD%E5%8F%AF%E4%BB%A5%E5%9C%A8%E9%80%9A%E7%94%A8%20PC%20%E4%B8%8A%E8%BF%9B%E8%A1%8C%E5%BC%80%E5%8F%91%EF%BC%8C%E5%9B%A0%E4%B8%BA%20Linux%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%BA%94%E8%AF%A5%EF%BC%88*%E5%92%B3%E5%97%BD*%EF%BC%89%E5%8F%AA%E6%98%AF%E9%87%8D%E6%96%B0%E7%BC%96%E8%AF%91%E4%B8%BA%20ARM%EF%BC%89%EF%BC%8C%3C%2FLI%3E%3CLI%3E%E4%B8%80%E4%B8%AA%E7%8B%AC%E7%89%B9%E7%9A%84%E6%A0%91%EF%BC%8C%E7%94%A8%E4%BA%8E%E5%B0%86%E6%88%91%E4%BB%AC%E7%9A%84%E6%A8%A1%E5%9D%97%E6%94%BE%E7%BD%AE%E5%88%B0%E7%A4%BE%E5%8C%BA%E9%85%8D%E7%BD%AE%E4%B8%AD%EF%BC%88%E5%81%87%E8%AE%BE%E5%AE%83%E4%BB%AC%E4%B8%8D%E8%83%BD%E4%B8%8E%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%E4%BD%8D%E4%BA%8E%E5%90%8C%E4%B8%80%E4%BD%8D%E7%BD%AE%EF%BC%9A%EF%BC%89%3C%2FLI%3E%3CLI%3E%E4%B8%80%E4%B8%AA%E7%8B%AC%E7%89%B9%E7%9A%84%E6%A0%91%E6%9D%A5%E6%94%BE%E7%BD%AE%E6%88%91%E4%BB%AC%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%98%AF%E5%90%A6%E6%9B%BE%E6%8F%90%E5%88%B0%E8%BF%87%E6%88%91%E6%98%AF%E6%96%B0%E6%9D%A5%E7%9A%84%E5%BB%BA%E9%80%A0%E5%A4%A7%E5%B8%88%20%3A-)%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%BE%88%E9%AB%98%E5%85%B4%E4%BD%A0%E8%83%BD%E5%A4%9F%E7%90%86%E8%A7%A3%20yocto%E3%80%82%E5%AD%A6%E4%B9%A0%E6%9B%B2%E7%BA%BF%E5%B9%B6%E4%B8%8D%E9%82%A3%E4%B9%88%E5%AE%B9%E6%98%93%E3%80%82%E4%BD%86%E6%88%91%E7%A1%AE%E4%BF%A1%E4%BD%A0%E6%9C%80%E7%BB%88%E4%BC%9A%E5%96%9C%E6%AC%A2%E5%AE%83%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fleoschwab%22%20target%3D%22_blank%22%3Eleoschwab%3C%2FA%3E%20%EF%BC%8C%E8%AF%B7%E8%AE%B0%E4%BD%8F%20Poky%20%E6%89%8B%E5%86%8C%E5%B7%B2%E7%BB%8F%E2%80%9C%E8%BF%87%E6%97%B6%E2%80%9D%E4%BA%86%E3%80%82%E8%BF%99%E6%98%AF%202010%20%E5%B9%B4%E7%9A%84%EF%BC%8C%E6%89%80%E6%9C%89%E2%80%9C%E5%BD%93%E5%89%8D%E2%80%9D%E6%96%87%E6%A1%A3%E7%8E%B0%E5%9C%A8%E9%83%BD%E5%9C%A8%20yoctoproject.org%20%E4%B8%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110945%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110945%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%BB%8D%E5%9C%A8%E6%9E%84%E6%80%9D%E5%AF%B9%E6%82%A8%E9%9D%9E%E5%B8%B8%E6%B7%B1%E6%80%9D%E7%86%9F%E8%99%91%E7%9A%84%E5%B8%96%E5%AD%90%E7%9A%84%E9%80%82%E5%BD%93%E5%9B%9E%E5%BA%94%E3%80%82%E7%84%B6%E8%80%8C%EF%BC%8C%E6%98%A8%E5%A4%A9%E6%88%91%E5%8F%91%E7%8E%B0%E4%BA%86%20Poky%20%E7%9A%84%E6%96%87%E6%A1%A3%EF%BC%8COpen%20Embedded%E3%80%81Yocto%20%E5%92%8C%20FSL%20Community%20%E9%83%BD%E6%98%AF%E5%9F%BA%E4%BA%8E%E6%AD%A4%E6%9E%84%E5%BB%BA%E7%9A%84%E3%80%82%E5%87%BA%E4%BA%8E%E6%9F%90%E4%BA%9B%E5%A5%87%E6%80%AA%E7%9A%84%E5%8E%9F%E5%9B%A0%EF%BC%8CPoky%20%E6%96%87%E6%A1%A3%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E6%9B%B4%E6%9C%89%E6%84%8F%E4%B9%89%EF%BC%9B%E4%B9%9F%E8%AE%B8%E5%AE%83%E4%BB%AC%E4%B9%9F%E4%BC%9A%E5%AF%B9%E5%85%B6%E4%BB%96%E4%BA%BA%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fpokylinux.org%2Fdoc%2Fpoky-handbook.html%22%20title%3D%22http%3A%2F%2Fpokylinux.org%2Fdoc%2Fpoky-handbook.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EPoky%20Handbook%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%BE%E4%B8%AA%E4%BE%8B%E5%AD%90%EF%BC%8C%E5%90%91%20bitbake%20%E6%8F%90%E4%BE%9B%E5%8F%82%E6%95%B0%E2%80%9C-DDD%E2%80%9D%E4%BC%9A%E7%94%9F%E6%88%90%E5%A4%A7%E9%87%8F%E7%9A%84%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%EF%BC%8C%E4%B8%8D%E7%AE%A1%E4%BD%A0%E4%BF%A1%E4%B8%8D%E4%BF%A1%EF%BC%8C%E8%BF%99%E8%AE%A9%E6%88%91%E6%9B%B4%E5%8A%A0%E6%8E%A5%E8%BF%91%E7%90%86%E8%A7%A3%E4%BA%8B%E7%89%A9%E7%9A%84%E5%B7%A5%E4%BD%9C%E5%8E%9F%E7%90%86%EF%BC%8C%E4%B8%BB%E8%A6%81%E6%98%AF%E9%80%9A%E8%BF%87%E8%B7%9F%E8%B8%AA%E4%B8%8E%E6%8F%90%E4%BE%9B%E8%80%85%E7%9B%B8%E5%85%B3%E7%9A%84%E6%B6%88%E6%81%AF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110944%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110944%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Leo%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E6%8F%90%E5%87%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E6%9C%89%E8%B6%A3%E7%9A%84%E8%AF%9D%E9%A2%98%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E5%8F%82%E4%B8%8E%20Yocto%20%E6%A1%86%E6%9E%B6%E5%87%A0%E4%B8%AA%E6%9C%88%E4%BA%86%EF%BC%8C%E6%88%91%E8%83%BD%E7%90%86%E8%A7%A3%E6%82%A8%E7%9A%84%E5%9B%B0%E6%83%91%E3%80%82%E7%AE%80%E5%8D%95%E7%9A%84%E7%AD%94%E6%A1%88%E6%98%AF%E2%80%9C%E8%BF%99%E5%8F%96%E5%86%B3%E4%BA%8E%E4%BD%A0%E6%83%B3%E5%81%9A%E4%BB%80%E4%B9%88%E2%80%9D%EF%BC%8C%E4%BD%86%E8%BF%99%E5%BD%93%E7%84%B6%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%B8%AE%E5%8A%A9%E3%80%82%E6%88%91%E4%B8%80%E7%9B%B4%E5%9C%A8%E8%AE%B0%E5%BD%95%E7%9A%84%E6%98%AF%E4%BD%BF%E7%94%A8%E5%B7%A5%E5%85%B7%3CEM%3Eyocto-layer%3C%2FEM%3E%E5%88%9B%E5%BB%BA%E5%B1%82%E7%9A%84%E6%9C%80%E5%B0%8F%E6%96%B9%E6%B3%95%EF%BC%8C%E5%AE%83%E6%AF%94%3CEM%3Eyocto-bsp%3C%2FEM%3E%E7%AE%80%E5%8D%95%E5%BE%97%E5%A4%9A%E3%80%82%E4%B8%A4%E4%B8%AA%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%94%A8%E4%BA%8E%E4%B8%8D%E5%90%8C%E7%9A%84%E7%9B%AE%E7%9A%84%EF%BC%8C%E4%BD%86%E6%9C%80%E7%BB%88%20yocto-bsp%20%E5%B0%86%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%B1%82%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%B7%B2%E7%BB%8F%E4%B8%BA%E6%82%A8%E9%85%8D%E7%BD%AE%E4%BA%86%E6%9B%B4%E5%A4%9A%E5%86%85%E5%AE%B9%EF%BC%88%E8%99%BD%E7%84%B6%E6%88%91%E8%BF%98%E6%B2%A1%E6%9C%89%E5%B0%9D%E8%AF%95%E8%BF%87%E8%AF%A5%E5%B7%A5%E5%85%B7%EF%BC%8C%E4%BD%86%E6%88%91%E5%BE%88%E5%BF%AB%E5%B0%B1%E4%BC%9A%E5%B0%9D%E8%AF%95%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%BB%E8%A6%81%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E6%82%A8%E6%83%B3%E5%81%9A%E4%BB%80%E4%B9%88%EF%BC%9F%E6%AD%A3%E5%A6%82%E6%95%99%E7%A8%8B%E4%B8%AD%E6%8F%90%E5%88%B0%E7%9A%84%EF%BC%8C%E5%A6%82%E6%9E%9C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E*%20%E6%82%A8%E6%83%B3%E4%BF%AE%E6%94%B9%E9%85%8D%E6%96%B9%EF%BC%88.bbappend%EF%BC%89%3C%2FP%3E%3CP%3E*%20%E6%82%A8%E6%83%B3%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E8%8F%9C%E8%B0%B1%20(.bb)%3C%2FP%3E%3CP%3E*%20%E6%82%A8%E6%83%B3%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E5%9B%BE%E5%83%8F%E3%80%82IMAGE_INSTALL_append%20%E5%92%8C%20EXTRA_IMAGE_FEATURES%20%E6%98%AF%E5%B0%86%E5%8C%85%E6%B7%BB%E5%8A%A0%E5%88%B0%E5%9B%BE%E5%83%8F%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%BD%93%E5%89%8D%E5%9B%BE%E5%83%8F%E4%B8%8A%E4%BD%BF%E7%94%A8%E5%AE%83%E4%BB%AC%EF%BC%8C%E4%BD%86%E6%9C%80%E5%A5%BD%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%B1%82%EF%BC%8C%E7%84%B6%E5%90%8E%E5%9C%A8%E9%82%A3%E9%87%8C%E8%BF%9B%E8%A1%8C%E6%89%80%E6%9C%89%E4%BF%AE%E6%94%B9%E3%80%82%E5%8F%AA%E9%9C%80%E7%A1%AE%E4%BF%9D%E6%96%B0%E5%9B%BE%E5%83%8F%E5%90%8D%E7%A7%B0%E4%B8%8E%E7%8E%B0%E6%9C%89%E5%9B%BE%E5%83%8F%E5%90%8D%E7%A7%B0%E4%B8%8D%E5%90%8C%E5%8D%B3%E5%8F%AF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%E5%9F%BA%E4%BA%8E%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E7%9A%84%E6%9C%BA%E5%99%A8%EF%BC%8C%E5%B9%B6%E4%B8%94%E4%B8%8D%E6%83%B3%E4%BD%BF%E7%94%A8%E4%B8%8E%E5%85%B6%E4%BB%96%E6%9C%BA%E5%99%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E5%B1%82%EF%BC%88meta-fsl-arm-extra%EF%BC%89%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%88%9B%E5%BB%BA%E8%87%AA%E5%B7%B1%E7%9A%84%E6%9C%BA%E5%99%A8%E3%80%82%E5%9C%A8%E6%9F%90%E4%B8%AA%E6%97%B6%E5%80%99%EF%BC%8C%E6%82%A8%E6%83%B3%E5%90%91%E4%B8%96%E7%95%8C%E5%B1%95%E7%A4%BA%E6%82%A8%E7%9A%84%E4%BD%9C%E5%93%81%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%82%A8%E7%9A%84%E6%89%80%E6%9C%89%E4%BD%9C%E5%93%81%E9%83%BD%E5%8F%AF%E4%BB%A5%E8%BD%BB%E6%9D%BE%E5%9C%B0%E6%94%BE%E5%9C%A8%E8%BF%99%E4%B8%80%E5%B1%82%E4%B8%8A%E3%80%82%E5%8F%A6%E4%B8%80%E6%96%B9%E9%9D%A2%EF%BC%8Cmeta-fsl-arm-extra%20%E6%98%AF%E5%A6%82%E4%BD%95%E4%B8%8E%20meta-fsl-arm%20%E8%BF%9B%E8%A1%8C%E8%80%A6%E5%90%88%E7%9A%84%E4%B8%80%E4%B8%AA%E5%BE%88%E5%A5%BD%E7%9A%84%E4%BE%8B%E5%AD%90%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%20repo%20%E8%84%9A%E6%9C%AC%EF%BC%8C%E6%9C%89%E4%B8%80%E7%A7%8D%E6%96%B9%E6%B3%95%E5%8F%AF%E4%BB%A5%E6%8C%87%E7%A4%BA%E4%BD%BF%E7%94%A8%E6%9C%AC%E5%9C%B0%3CEM%3Edefault.xml%3C%2FEM%3E%20%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E9%82%A3%E9%87%8C%E6%B7%BB%E5%8A%A0%E6%82%A8%E7%9A%84%20git%20repo%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%BE%88%E5%BF%AB%E4%BC%9A%E5%8F%91%E5%B8%83%E6%9B%B4%E5%A4%9A%E5%B9%BB%E7%81%AF%E7%89%87%E3%80%82%E7%A5%9D%E4%BD%A0%E5%A5%BD%E8%BF%90%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110943%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110943%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E7%AF%87%E6%96%87%E7%AB%A0%E5%8F%AF%E8%83%BD%E5%80%BC%E5%BE%97%E5%8D%95%E7%8B%AC%E5%BC%80%E4%B8%80%E4%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%BD%86%E8%BF%99%E6%AD%A3%E6%98%AF%E6%88%91%E8%BF%99%E6%AC%A1%E6%97%85%E7%A8%8B%E7%9A%84%E8%B5%B7%E7%82%B9%EF%BC%8C%E6%89%80%E4%BB%A5%E5%B0%B1%E5%9C%A8%E8%BF%99%E9%87%8C%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E4%BD%BF%E7%94%A8%E8%BF%99%E4%BA%9B%E8%AF%B4%E6%98%8E%E6%88%90%E5%8A%9F%E6%9E%84%E5%BB%BA%E5%B9%B6%E5%90%AF%E5%8A%A8%E4%BA%86%E2%80%9Cimx6dlsabresd%E2%80%9D%E6%98%A0%E5%83%8F%EF%BC%88%E9%A1%BA%E4%BE%BF%E8%AF%B4%E4%B8%80%E4%B8%8B%EF%BC%8C%E5%9C%A8%20Linux%20Mint%2015%20%E4%B8%8A%EF%BC%89%EF%BC%8C%E7%8E%B0%E5%9C%A8%E6%88%91%E9%9C%80%E8%A6%81%E5%BC%80%E5%A7%8B%E2%80%9C%E8%AE%BE%E8%AE%A1%E2%80%9D%E5%85%B6%E4%BB%96%E4%BA%BA%E5%B0%86%E7%94%A8%E4%BA%8E%E6%88%91%E4%BB%AC%E9%A1%B9%E7%9B%AE%E7%9A%84%E6%9E%84%E5%BB%BA%E7%8E%AF%E5%A2%83%E3%80%82%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8CYocto%20%E4%BC%BC%E4%B9%8E%E6%8B%92%E7%BB%9D%E5%B0%9D%E8%AF%95%E7%90%86%E8%A7%A3%E5%85%B6%E7%BB%93%E6%9E%84%E4%BB%A5%E5%8F%8A%E5%A6%82%E4%BD%95%E4%B8%8E%E5%85%B6%E9%9B%86%E6%88%90%E3%80%82%E6%96%87%E7%8C%AE%E7%89%87%E6%AE%B5%E6%95%A3%E5%B8%83%E4%BA%8E%E5%A4%9A%E4%B8%AA%E6%9D%A5%E6%BA%90%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%AD%98%E5%9C%A8%E8%AE%B8%E5%A4%9A%E7%9C%8B%E4%BC%BC%E7%9F%9B%E7%9B%BE%E4%B9%8B%E5%A4%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%BD%93%E6%8C%89%E7%85%A7%20Yocto%20%E9%A1%B9%E7%9B%AE%E8%AF%B4%E6%98%8E%E5%88%9B%E5%BB%BA%E6%96%B0%E7%9A%84%20BSP%20%E5%B1%82%EF%BC%88%E4%BD%BF%E7%94%A8%20yocto-bsp%20%E5%91%BD%E4%BB%A4%EF%BC%89%E6%97%B6%EF%BC%8C%E7%94%9F%E6%88%90%E7%9A%84%E6%96%87%E4%BB%B6%E7%9C%8B%E8%B5%B7%E6%9D%A5%E4%B8%8E%20meta-fsl*%20%E7%9B%AE%E5%BD%95%E4%B8%AD%E5%B7%B2%E7%BB%8F%E5%AD%98%E5%9C%A8%E7%9A%84%E6%96%87%E4%BB%B6%E5%AE%8C%E5%85%A8%E4%B8%8D%E5%90%8C%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E5%BD%93%20yocto-bsp%20%E8%AF%A2%E9%97%AE%E6%88%91%E6%83%B3%E8%A6%81%E4%BD%BF%E7%94%A8%E4%BB%80%E4%B9%88%E5%86%85%E6%A0%B8%E6%97%B6%EF%BC%8C3.0.35%20%E5%B9%B6%E4%B8%8D%E6%98%AF%E6%98%BE%E7%A4%BA%E7%9A%84%E9%80%89%E9%A1%B9%E4%B9%8B%E4%B8%80%EF%BC%8C%E8%BF%99%E8%A1%A8%E6%98%8E%20FSL%20%E6%9D%90%E6%96%99%E5%9C%A8%E6%9F%90%E7%A7%8D%E7%A8%8B%E5%BA%A6%E4%B8%8A%E5%AF%B9%E4%BA%8E%E6%A0%87%E5%87%86%E5%B7%A5%E5%85%B7%E6%9D%A5%E8%AF%B4%E6%98%AF%E4%B8%8D%E5%8F%AF%E8%A7%81%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E6%9C%89%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Flsandoval%2Fpresentations%2Fblob%2Fmaster%2Fyocto%2Fcommon_tasks%2Flayer.md%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E8%BF%99%E4%B8%AA%E9%A1%B5%E9%9D%A2%3C%2FA%3E%EF%BC%8C%E5%AE%83%E8%A1%A8%E6%98%8E%E5%AE%8C%E6%95%B4%E7%9A%84%20BSP%20%E5%B1%82%E6%98%AF%E6%B2%A1%E6%9C%89%E5%BF%85%E8%A6%81%E7%9A%84%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E9%80%9A%E7%94%A8%E5%B1%82%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E7%AE%80%E8%80%8C%E8%A8%80%E4%B9%8B%EF%BC%8C%E6%88%91%E4%BC%BC%E4%B9%8E%E4%B8%8D%E6%98%8E%E7%99%BD%20Yocto%20%E7%9A%84%E2%80%9C%E5%93%B2%E5%AD%A6%E2%80%9D%E2%80%94%E2%80%94%E5%A6%82%E4%BD%95%E7%9F%A5%E9%81%93%E4%BD%95%E6%97%B6%E9%80%9A%E8%BF%87%E5%88%9B%E5%BB%BA%E6%96%B0%E7%9A%84%20BSP%20%E5%B1%82%E3%80%81%E6%96%B0%E7%9A%84%E9%80%9A%E7%94%A8%E5%B1%82%E3%80%81.bbappend%20%E6%9D%A5%E6%B7%BB%E5%8A%A0%2F%E5%88%A0%E9%99%A4%E5%86%85%E5%AE%B9%E6%96%87%E4%BB%B6%EF%BC%8C%E6%88%96%E8%80%85%E9%80%9A%E8%BF%87%E4%BF%AE%E6%94%B9IMAGE_INSTALL_append%EF%BC%88%E6%88%96EXTRA_IMAGE_FEATURES%EF%BC%89%E3%80%82%E6%88%91%E7%94%9A%E8%87%B3%E4%B8%8D%E7%A1%AE%E5%AE%9A%E6%88%91%E8%AF%95%E5%9B%BE%E5%AE%9A%E4%B9%89%E7%9A%84%E6%98%AF%E2%80%9CBSP%E2%80%9D%E3%80%81%E2%80%9C%E6%9C%BA%E5%99%A8%E2%80%9D%E8%BF%98%E6%98%AF%E2%80%9C%E5%8F%91%E8%A1%8C%E7%89%88%E2%80%9D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E6%9C%80%E7%BB%88%EF%BC%8C%E6%88%91%E6%83%B3%E8%A6%81%E7%9A%84%E6%98%AF%E4%B8%80%E5%A0%86%E5%AE%9A%E4%B9%89%E6%98%8E%E7%A1%AE%E7%9A%84%E6%88%91%E4%BB%AC%E7%9A%84%E8%B5%84%E6%96%99%EF%BC%88TM%EF%BC%89%EF%BC%8C%E5%AE%83%E5%8F%AF%E4%BB%A5%E8%BD%BB%E6%9D%BE%E5%9C%B0%E4%B8%8E%E7%A4%BE%E5%8C%BA%E8%B5%84%E6%96%99%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%EF%BC%8C%E4%BD%86%E5%8F%88%E4%B8%8E%E7%A4%BE%E5%8C%BA%E8%B5%84%E6%96%99%E5%88%86%E5%BC%80%EF%BC%88%E4%BB%A5%E4%BE%BF%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E2%80%9Crepo%E2%80%9D%E6%B8%85%E5%8D%95%E5%B9%B2%E5%87%80%E5%9C%B0%E6%8B%89%E4%B8%8B%E6%89%80%E6%9C%89%E5%86%85%E5%AE%B9%EF%BC%89%E3%80%82%E7%89%B9%E5%88%AB%E6%AC%A2%E8%BF%8E%E6%8F%90%E4%BE%9B%E5%93%B2%E5%AD%A6%E8%AE%BA%E6%96%87%E5%92%8C%2F%E6%88%96%E5%B7%A5%E4%BD%9C%E5%AE%9E%E4%BE%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110942%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110942%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%2C%20daiane%2C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E4%B8%BA%20sabrelite%20%E6%9D%BF%E6%9E%84%E5%BB%BA%E6%B5%8B%E8%AF%95%E5%9B%BE%E5%83%8F%E2%80%9Cbitbake%20fsl-image-test%E2%80%9D%EF%BC%8C%E5%B9%B6%E6%94%B6%E5%88%B0%E8%8E%B7%E5%8F%96%E6%BA%90%E4%BB%A3%E7%A0%81%E5%8C%85%E7%9A%84%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%EF%BC%8C%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%EF%BC%88%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E5%A4%9A%E6%AC%A1%EF%BC%8C%E4%BD%86%E6%80%BB%E6%98%AF%E5%A4%B1%E8%B4%A5%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%2F%E5%B7%A5%E4%BD%9C%E5%8C%BA%2F%E8%BD%AF%E4%BB%B6%2F%E5%AD%98%E5%82%A8%E5%BA%93%2Ffreescale%2Fyocto_rootfs%2Fsources%2Fmeta-openembedded%2Fmeta-oe%2Frecipes-benchmark%2Flmbench%2Flmbench_3.0-a9.bb%EF%BC%8C%E6%89%A7%E8%A1%8C%E5%8F%96%E5%9B%9E%3C%2FP%3E%3CP%3E%2F%E5%B7%A5%E4%BD%9C%E5%8C%BA%2F%E8%BD%AF%E4%BB%B6%2F%E5%AD%98%E5%82%A8%E5%BA%93%2F%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%2Fyocto_rootfs%2Fsources%2Fmeta-openembedded%2Fmeta-oe%2Frecipes-benchmark%2Ftiobench%2Ftiobench_0.3.3.bb%EF%BC%8C%E6%89%A7%E8%A1%8C%E5%8F%96%E5%9B%9E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110941%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110941%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E9%9C%80%E8%A6%81%E6%9C%89%20bbappend%20%E5%B9%B6%E7%94%9F%E6%88%90%E5%9B%BE%E5%83%8F%EF%BC%88%E5%B9%B6%E5%B0%86%E5%85%B6%E8%BD%AC%E6%8D%A2%E4%B8%BA%20.h%E6%96%87%E4%BB%B6%EF%BC%89%E3%80%82%E6%A3%80%E6%9F%A5%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%AE%83%E5%B0%B1%E5%9C%A8%E9%82%A3%E9%87%8C%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110940%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110940%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Otavio%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20PSplash%20%E5%9C%A8%E5%90%AF%E5%8A%A8%E7%94%BB%E9%9D%A2%E4%B8%8A%E6%98%BE%E7%A4%BA%E6%88%91%E8%87%AA%E5%B7%B1%E7%9A%84%E5%BE%BD%E6%A0%87%EF%BC%9F%E6%88%91%E9%98%85%E8%AF%BB%E4%BA%86%E4%B8%80%E4%BA%9B%E5%85%B3%E4%BA%8E%E6%B7%BB%E5%8A%A0%E6%88%91%E8%87%AA%E5%B7%B1%E7%9A%84%E5%B1%82%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E4%BB%BB%E4%BD%95%E5%85%B3%E4%BA%8E%E6%AD%A4%E7%9A%84%E6%B8%85%E6%99%B0%E5%AE%8C%E6%95%B4%E7%9A%84%E6%8C%87%E5%8D%97%E3%80%82%E6%88%91%E5%B0%9D%E8%AF%95%E6%B7%BB%E5%8A%A0%E8%87%AA%E5%B7%B1%E7%9A%84%E5%B1%82%EF%BC%8C%E4%BD%86%E6%98%AF%E5%8D%B4%E6%97%A0%E6%B3%95%E6%9E%84%E5%BB%BA%E4%BB%BB%E4%BD%95%E4%B8%9C%E8%A5%BF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110939%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110939%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%90%AF%E5%8A%A8%E7%94%BB%E9%9D%A2%E5%AE%9A%E5%88%B6%E5%8F%AF%E4%BB%A5%E5%9C%A8%E7%B3%BB%E7%BB%9F%E7%9A%84%E4%B8%8D%E5%90%8C%E9%83%A8%E5%88%86%E5%AE%8C%E6%88%90%EF%BC%9B%E5%9C%A8%20OS%20Systems%20%E7%9A%84%20Yocto%20BSP%20%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BB%AC%E5%9C%A8%20U-Boot%20%E5%92%8C%20PSplash%20%E4%B8%AD%E8%BF%9B%E8%A1%8C%E5%AE%9A%E5%88%B6%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%20PSplash%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%9F%A5%E7%9C%8B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fgit.yoctoproject.org%2Fcgit%2Fcgit.cgi%2Fpoky%2Ftree%2Fmeta-yocto%2Frecipes-core%2Fpsplash%22%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%20title%3D%22http%3A%2F%2Fgit.yoctoproject.org%2Fcgit%2Fcgit.cgi%2Fpoky%2Ftree%2Fmeta-yocto%2Frecipes-core%2Fpsplash%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Epoky%20-%20Poky%20%E6%9E%84%E5%BB%BA%E5%B7%A5%E5%85%B7%E5%92%8C%E5%85%83%E6%95%B0%E6%8D%AE%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110938%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110938%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E6%9B%B4%E6%94%B9%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%88%91%E7%9A%84%20iMX6%20Sabrelite%20%E6%9D%BF%E7%9A%84%20HDMI%20%E6%98%BE%E7%A4%BA%E5%99%A8%E4%B8%8A%E5%90%AF%E5%8A%A8%E5%92%8C%E6%B3%A8%E9%94%80%E6%97%B6%E6%98%BE%E7%A4%BA%E7%9A%84%E5%9B%BE%E5%83%8F%2F%E5%B1%8F%E5%B9%95%EF%BC%88%E5%BD%93%E5%89%8D%EF%BC%9AYocto%20Login%EF%BC%89%E3%80%82%E6%88%91%E9%98%85%E8%AF%BB%E4%BA%86%E4%B8%80%E4%BA%9B%E6%9C%89%E5%85%B3%20psplash%20%E7%9A%84%E7%BD%91%E7%AB%99%EF%BC%8C%E4%BD%86%E6%88%91%E7%9C%9F%E7%9A%84%E4%B8%8D%E7%9F%A5%E9%81%93%E5%BA%94%E8%AF%A5%E6%B7%BB%E5%8A%A0%2F%E5%A4%8D%E5%88%B6%E4%BB%80%E4%B9%88%E6%89%8D%E8%83%BD%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%92%8C%E6%B3%A8%E9%94%80%E6%97%B6%E8%8E%B7%E5%BE%97%E8%87%AA%E5%B7%B1%E7%9A%84%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110937%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110937%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%E6%88%91%E5%9C%A8%E8%BF%99%E9%87%8C%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%96%B0%E7%9A%84%E8%AE%A8%E8%AE%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F308824%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fthread%2F308824%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110936%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110936%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%9Asmileyhappy%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BB%8E%20SataSSD%20%E5%90%AF%E5%8A%A8%20Gui%20%E6%98%A0%E5%83%8F%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%20rootfs%20%E6%8F%90%E5%8F%96%E5%88%B0%20ext3%20%E5%88%86%E5%8C%BA%E5%B9%B6%E5%B0%86%206x_bootscript%20%E5%A4%8D%E5%88%B6%E5%88%B0%E6%A0%B9%E7%9B%AE%E5%BD%95%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%80%E5%88%87%E5%90%AF%E5%8A%A8%E6%AD%A3%E5%B8%B8%EF%BC%8C%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E6%A1%8C%E9%9D%A2%EF%BC%8C%E5%8F%AF%E4%BB%A5%E7%A7%BB%E5%8A%A8%E9%BC%A0%E6%A0%87%EF%BC%8C%E4%BD%86%E9%BC%A0%E6%A0%87%E5%8D%95%E5%87%BB%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%20sudo%20dd%20if%3Dtmp%2Fdeploy%2Fimages%2Fcore-image-sato-nitrogen6x.sdcard%20of%3D%2Fdev%2Fsdb%20bs%3D4M%20%26amp%3B%26amp%3Bsync%20%E6%9E%84%E5%BB%BA%20SSD%20%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%20Nor%20Flash%20%E4%B8%AD%E4%BD%BF%E7%94%A8%20Boundary%20U-Boot%EF%BC%8C%E6%88%91%E4%B8%8D%E6%83%B3%E6%94%B9%E5%8F%98%E5%AE%83%20%3CIMG%20id%3D%22smileywink%22%20class%3D%22emoticon%20emoticon-smileywink%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-wink.png%22%20alt%3D%22Smiley%20Wink%22%20title%3D%22Smiley%20Wink%22%20%2F%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E9%97%AE%E5%80%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EJoerg%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110935%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110935%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Joerg%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E8%BF%90%E8%A1%8C%E2%80%9Cifconfig%20-a%E2%80%9D%E6%9D%A5%E9%AA%8C%E8%AF%81%20CAN%20%E6%98%AF%E5%90%A6%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%E5%A6%82%E6%9E%9C%E5%86%85%E6%A0%B8%E4%B8%AD%E5%90%AF%E7%94%A8%E4%BA%86%20CAN%EF%BC%8C%E6%82%A8%E5%B0%86%E7%9C%8B%E5%88%B0%E2%80%9Ccan0%E2%80%9D%E7%9A%84%E6%8E%A5%E5%8F%A3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110934%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110934%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E6%88%91%E6%98%AF%E5%90%A6%E7%90%86%E8%A7%A3%E4%BA%86%E4%BD%A0%E7%9A%84%E6%84%8F%E6%80%9D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%86%85%E6%A0%B8%20defconfig%20%E4%B8%8A%E5%BA%94%E8%AF%A5%E9%BB%98%E8%AE%A4%E9%80%89%E6%8B%A9%20Flexcan%E3%80%82%E6%88%91%E8%AE%A4%E4%B8%BA%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E8%AF%B7%E6%9F%A5%E7%9C%8B%E6%82%A8%E7%9A%84%E4%B8%BB%E6%9D%BF%E7%9A%84%20defconfig%20%E5%B9%B6%E4%BB%94%E7%BB%86%E6%A3%80%E6%9F%A5%E5%AE%83%E6%98%AF%E5%90%A6%E8%A2%AB%E9%80%89%E4%B8%AD%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110933%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110933%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E4%B9%9F%E9%9D%9E%E5%B8%B8%E6%9C%89%E7%94%A8%EF%BC%81%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fboundarydevices.com%2Fu-boot-on-i-mx6%2F%22%20title%3D%22http%3A%2F%2Fboundarydevices.com%2Fu-boot-on-i-mx6%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fboundarydevices.com%2Fu-boot-on-i-mx6%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%20Eric%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110932%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110932%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDaiane%2C%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E7%A1%AE%E5%AE%9A%20Flexcan%20%E6%94%AF%E6%8C%81%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%E6%88%91%E4%B9%9F%E6%83%B3%E7%94%A8%E5%AE%83%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E9%97%AE%E5%80%99%3C%2FP%3E%3CP%3EJoerg%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110931%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110931%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%BD%93%E7%84%B6%E3%80%82%E5%8D%9A%E5%AE%A2%E6%96%87%E7%AB%A0%E5%A6%82%E4%B8%8B%EF%BC%9A%20%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fboundarydevices.com%2Funbricking-nitrogen6x-sabre-lite-i-mx6-board%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fboundarydevices.com%2Funbricking-nitrogen6x-sabre-lite-i-mx6-board%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eimx_usb%20%E7%9A%84%E6%9D%A5%E6%BA%90%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Fimx_usb_loader%22%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Fimx_usb_loader%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eborderdevices%2Fimx_usb_loader%20%C2%B7%20GitHub%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%A5%E7%A8%8B%E5%BA%8F%E9%80%82%E7%94%A8%E4%BA%8E%E4%BB%BB%E4%BD%95%20i.MX6%20%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%88%E4%B8%8D%E4%BB%85%E4%BB%85%E6%98%AF%E6%88%91%E4%BB%AC%E6%9E%84%E5%BB%BA%E7%9A%84%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%89%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%9C%A8%E6%9E%84%E5%BB%BA%E5%92%8C%E6%B5%8B%E8%AF%95%20U-Boot%20%E6%98%A0%E5%83%8F%E6%97%B6%E6%8F%90%E4%BE%9B%E4%BA%86%E9%9D%9E%E5%B8%B8%E5%A5%BD%E7%9A%84%E7%95%8C%E9%9D%A2%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E5%AE%83%E8%BF%98%E5%85%B7%E6%9C%89%E5%8F%AF%E4%BB%A5%E5%9C%A8%20Linux%20%E6%9C%BA%E5%99%A8%EF%BC%88%E5%8C%85%E6%8B%AC%20i.MX%20%E6%9D%BF%EF%BC%89%E4%B8%8A%E8%BF%90%E8%A1%8C%E7%9A%84%E4%BC%98%E8%89%AF%E7%89%B9%E6%80%A7%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110930%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110930%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%8C%E5%9F%83%E9%87%8C%E5%85%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%8B%E6%9C%89%E5%85%B3%E5%A6%82%E4%BD%95%E8%A7%A3%E5%BC%80%20Sabrelite%20%E7%9A%84%E6%96%87%E6%A1%A3%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110929%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110929%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Daiane%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8CSABRE%20Lite%20%E6%88%96%20Nitrogen6x%20%E4%B8%8D%E6%94%AF%E6%8C%81%20mfgtools%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E4%B8%BB%E7%BA%BF%20U-Boot%EF%BC%8C%E8%80%8C%20USB%20%E4%BB%8E%E5%B1%9E%E8%AE%BE%E5%A4%87%E5%B0%9A%E4%B8%8D%E5%AD%98%E5%9C%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E7%A7%8D%E8%A1%8C%E4%B8%BA%E5%9C%A8%20sabre%20lite%20%E4%B8%AD%E7%BB%9D%E5%AF%B9%E6%AD%A3%E5%B8%B8%EF%BC%9Asmileysilly%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%86%8D%E6%AC%A1%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20mfgtools%EF%BC%8C%E7%9B%B4%E5%88%B0%E6%82%A8%E5%9C%A8%E4%B8%B2%E8%A1%8C%E4%B8%8A%E8%8E%B7%E5%BE%97%E4%B8%80%E4%BA%9B%E6%8E%A7%E5%88%B6%E5%8F%B0%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E4%BD%BF%E7%94%A8%E5%85%81%E8%AE%B8%E6%82%A8%E4%BB%8E%20sdcard%20%E5%90%AF%E5%8A%A8%E7%9A%84%20linaro%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E6%97%B6%EF%BC%8C%E6%88%91%E5%A4%9A%E6%AC%A1%E9%94%99%E8%BF%87%E9%85%8D%E7%BD%AE%EF%BC%8C%E7%9B%B4%E5%88%B0%E5%AE%83%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E8%BF%99%E5%BE%88%E5%8F%AF%E6%80%95%E3%80%82%E5%91%B5%E5%91%B5%E5%91%B5%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E7%BB%A7%E7%BB%AD%E5%B0%9D%E8%AF%95%EF%BC%8C%E8%BF%99%E4%B8%AA%E8%BF%87%E7%A8%8B%E4%B8%8D%E4%BC%9A%E4%BD%BF%E6%82%A8%E7%9A%84%E7%A1%AC%E4%BB%B6%E5%B4%A9%E6%BA%83%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E8%AE%B0%E4%BD%8F%EF%BC%8C%E5%A6%82%E6%9E%9C%20linaro%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%AE%89%E8%A3%85%E6%AD%A3%E7%A1%AE%EF%BC%8C%E6%89%93%E5%BC%80%E4%B8%BB%E6%9D%BF%E6%97%B6%E6%82%A8%E5%B0%86%E7%9C%8B%E4%B8%8D%E5%88%B0%E4%BB%BB%E4%BD%95%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%8C%E9%99%A4%E9%9D%9E%E6%82%A8%E5%9C%A8%E6%AD%A3%E7%A1%AE%E7%9A%84%E6%8F%92%E6%A7%BD%E4%B8%AD%E7%9A%84%20SD%20%E5%8D%A1%E4%B8%8A%E6%9C%89%20u-boot%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%EF%BC%88%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BD%BF%E7%94%A8%E6%9D%A5%E8%87%AA%20linaro%20%E7%9A%84%20sd3%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%8C%E5%88%99%E5%BA%94%E8%AF%A5%E4%BB%8E%20sd3%20%E5%90%AF%E5%8A%A8%E3%80%82sd4%20%E4%B9%9F%E4%B8%80%E6%A0%B7%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110927%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110927%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BA%8B%E5%AE%9E%E4%B8%8A%EF%BC%8Cmeta-fsl-arm%20%E5%B9%B6%E4%B8%8D%E4%BD%BF%E7%94%A8%20yocto-kernel%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYocto-kernel%20%E6%8C%87%E5%90%91%E5%86%85%E6%A0%B8%E4%B8%BB%E7%BA%BF%20(kernel.org)%E5%A6%82%E4%BB%8A%EF%BC%8Cimx%20%E4%B8%BB%E6%9D%BF%E5%AF%B9%20Freescale%20%E5%86%85%E6%A0%B8%E6%9C%89%E4%BA%86%E6%9B%B4%E5%A4%9A%E7%9A%84%E6%94%AF%E6%8C%81%EF%BC%88%E6%9D%A5%E8%87%AA%20git.freescale.com%EF%BC%89yocto-kernel%20%E6%98%AF%203.8%20%E8%BF%98%E6%98%AF%203.9%EF%BC%88%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E4%B8%8D%E8%AE%B0%E5%BE%97%E4%BA%86%EF%BC%89%EF%BC%8CFSL%20%E5%86%85%E6%A0%B8%E6%98%AF%203.0.35%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E5%B7%A5%E4%BD%9C%E5%BE%97%E6%80%8E%E4%B9%88%E6%A0%B7%EF%BC%9F%E6%88%91%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%EF%BC%8C%E4%BD%A0%E6%9C%89%E8%87%AA%E5%B7%B1%E7%9A%84%E5%85%83%E5%B1%82%E5%90%97%EF%BC%9F%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E4%BD%A0%E9%9C%80%E8%A6%81%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%20.bbappend%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E6%83%B3%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%E8%AE%A8%E8%AE%BA%EF%BC%8C%E4%BE%8B%E5%A6%82%E2%80%9C%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20yocto%20%E4%BF%AE%E8%A1%A5%E6%88%91%E7%9A%84%E5%86%85%E6%A0%B8%E2%80%9D%EF%BC%9F%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E5%9C%A8%E9%82%A3%E9%87%8C%E8%AE%A8%E8%AE%BA%E5%A6%82%E4%BD%95%E8%8E%B7%E5%BE%97%E5%AE%83%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110926%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110926%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E5%AF%B9%E6%88%91%E7%9A%84%E4%B8%BB%E6%9D%BF%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%9Asmileysad%EF%BC%9A%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E5%87%A0%E6%AC%A1%E3%80%82%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E4%BB%80%E4%B9%88%E9%83%BD%E4%B8%8D%E5%86%8D%E8%BF%90%E8%A1%8C%E4%BA%86%E3%80%82%E7%94%9A%E8%87%B3%E8%BF%9E%E9%9A%8F%E4%B8%BB%E6%9D%BF%E4%B8%80%E8%B5%B7%E4%BA%A4%E4%BB%98%E7%9A%84%E6%BC%94%E7%A4%BA%E7%89%88%E9%83%BD%E6%B2%A1%E6%9C%89%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E6%88%91%3C%2FSPAN%3E%E4%BD%BF%E7%94%A8%3CSPAN%20class%3D%22hps%22%3EMFG%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E5%B7%A5%E5%85%B7%E8%BF%9B%E8%A1%8C%E5%A4%8D%E5%88%B6%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%E5%9B%A0%E4%B8%BA%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%3CA%20href%3D%22http%3A%2F%2Fwww.eewiki.net%2Fdisplay%2Flinuxonarm%2Fi.MX6x%2BSABRE%2BLite%23i.MX6xSABRELite-Initialboot%3AUpgradeBootloader%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.eewiki.net%2Fdisplay%2Flinuxonarm%2Fi.MX6x%2BSABRE%2BLite%23i.MX6xSABRELite-Initialboot%3AUpgradeBootloader%3C%2FA%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%E4%B9%9F%E8%AE%B8%E6%88%91%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E4%B8%8D%E5%B0%8F%E5%BF%83%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E7%A7%BB%E5%8A%A8%E4%BA%86%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E4%B8%80%E4%BA%9B%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E4%BF%9D%E9%99%A9%E4%B8%9D%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%3E%E6%AD%A4%E8%87%B4%E9%97%AE%E5%80%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%3EJoerg%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110925%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110925%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%BC%84%E6%B8%85%E6%A5%9A%E5%A6%82%E4%BD%95%E6%B7%BB%E5%8A%A0%E5%86%85%E6%A0%B8%E8%A1%A5%E4%B8%81%EF%BC%8C%E4%BD%86%E6%98%AF%E6%88%91%E6%94%B6%E5%88%B0%E4%BA%86%20yocto-kernel%20%E9%94%99%E8%AF%AF%E3%80%82%E6%9C%89%E4%BB%80%E4%B9%88%E6%83%B3%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E~%2Frootfs_builder%24%20%E6%BA%90%E8%AE%BE%E7%BD%AE%E7%8E%AF%E5%A2%83%E6%9E%84%E5%BB%BA%3C%2FP%3E%3CP%3E~%2Frootfs_builder%2Fbuild%24%20yocto-kernel%20%E8%A1%A5%E4%B8%81%E5%88%97%E8%A1%A8%20meta-fsl-arm%3C%2FP%3E%3CP%3E%E5%9B%9E%E6%BA%AF%EF%BC%88%E6%9C%80%E8%BF%91%E4%B8%80%E6%AC%A1%E8%B0%83%E7%94%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Ftravis%2Frootfs_builder%2Fsources%2Fpoky%2Fscripts%2Fyocto-kernel%E2%80%9D%EF%BC%8C%E7%AC%AC%20227%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20%3CMODULE%3E%3C%2FMODULE%3E%3C%2FP%3E%3CP%3Eret%20%3D%20main()%3C%2FP%3E%3CP%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Ftravis%2Frootfs_builder%2Fsources%2Fpoky%2Fscripts%2Fyocto-kernel%E2%80%9D%EF%BC%8C%E7%AC%AC%20222%20%E8%A1%8C%EF%BC%8C%E5%9C%A8%E4%B8%BB%E6%96%87%E4%BB%B6%E4%B8%AD%3C%2FP%3E%3CP%3E%E8%B0%83%E7%94%A8%E5%AD%90%E5%91%BD%E4%BB%A4%EF%BC%88%E5%8F%82%E6%95%B0%E3%80%81%E8%A7%A3%E6%9E%90%E5%99%A8%E3%80%81yocto_kernel_help_usage%E3%80%81%E5%AD%90%E5%91%BD%E4%BB%A4%EF%BC%89%3C%2FP%3E%3CP%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Ftravis%2Frootfs_builder%2Fsources%2Fpoky%2Fscripts%2Flib%2Fbsp%2Fhelp.py%E2%80%9D%EF%BC%8C%E7%AC%AC%2073%20%E8%A1%8C%EF%BC%8C%E5%9C%A8invoke_subcommand%E4%B8%AD%3C%2FP%3E%3CP%3Esubcommands.get(args%5B0%5D%EF%BC%8Csubcommand_error)(0%5D(args%5B1%3A%5D%EF%BC%8C%E7%94%A8%E6%B3%95)%3C%2FP%3E%3CP%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Ftravis%2Frootfs_builder%2Fsources%2Fpoky%2Fscripts%2Fyocto-kernel%E2%80%9D%EF%BC%8C%E7%AC%AC%20123%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20yocto_kernel_patch_list_subcommand%3C%2FP%3E%3CP%3Eyocto_kernel_patch_list%EF%BC%88scripts_path%EF%BC%8Cargs%5B0%5D%EF%BC%89%3C%2FP%3E%3CP%3E%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Ftravis%2Frootfs_builder%2Fsources%2Fpoky%2Fscripts%2Flib%2Fbsp%2Fkernel.py%E2%80%9D%EF%BC%8Cyocto_kernel_patch_list%20%E4%B8%AD%E7%9A%84%E7%AC%AC%20422%20%E8%A1%8C%3C%2FP%3E%3CP%3E(start_line%EF%BC%8Cend_line%EF%BC%8Csrc_uri)%20%3D%20find_bsp_kernel_src_uri(scripts_path%EF%BC%8Cmachine)%3C%2FP%3E%3CP%3EIOError%EF%BC%9A%5BErrno%202%5D%20%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%EF%BC%9A%E2%80%9C%20%24%7BBSPDIR%7D%20%2Fsources%2Fmeta-fsl-arm%2Fconf%2Fmachine%2Fmeta-fsl-arm.conf%E2%80%9D%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110924%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110924%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%AF%B9%E4%BA%8E%E4%BB%BB%E4%BD%95%E8%8E%B7%E5%8F%96%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E*%20%E4%BB%94%E7%BB%86%E6%A3%80%E6%9F%A5%E6%82%A8%E7%9A%84%E8%BF%9E%E6%8E%A5%3C%2FP%3E%3CP%3E*%20%E4%BB%94%E7%BB%86%E6%A3%80%E6%9F%A5%E6%82%A8%E7%9A%84%E6%9C%AC%E5%9C%B0%E4%BB%A3%E7%90%86%E9%85%8D%E7%BD%AE%3C%2FP%3E%3CP%3E*%20%E4%BB%94%E7%BB%86%E6%A3%80%E6%9F%A5%E6%82%A8%E7%9A%84%E5%AE%BD%E4%BB%A3%E7%90%86%E9%85%8D%E7%BD%AE%3C%2FP%3E%3CP%3E*%20%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20http_proxy%20%E8%80%8C%E4%B8%8D%E6%98%AF%20ftp_proxy%3C%2FP%3E%3CP%3E*%20%E5%86%8D%E6%AC%A1%E6%A3%80%E6%9F%A5%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20wget%2Fcurl%20%E8%8E%B7%E5%8F%96%E6%96%87%E4%BB%B6%3C%2FP%3E%3CP%3E*%20%E5%A6%82%E6%9E%9C%E6%BA%90%E5%B7%B2%E5%85%B3%E9%97%AD%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%B2%A1%E6%9C%89%E5%8F%AF%E7%94%A8%E7%9A%84%E9%95%9C%E5%83%8F%EF%BC%9A%E8%AF%B7%E7%AD%89%E5%BE%85%E7%9B%B4%E8%87%B3%E5%85%B6%E4%BF%AE%E5%A4%8D%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ESabrelite%20%E9%80%9A%E5%B8%B8%E6%97%A0%E6%B3%95%E4%BB%8E%20SD%20%E5%8D%A1%E5%90%AF%E5%8A%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B9%B6%E4%B8%94%EF%BC%8C%E4%BB%8E%E6%82%A8%E7%9A%84%E6%97%A5%E5%BF%97%E6%9D%A5%E7%9C%8B%EF%BC%8C%E6%82%A8%E7%9A%84%E4%B8%BB%E6%9D%BF%E6%98%AF%E4%BB%8E%20NOR%20%E5%90%AF%E5%8A%A8%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwiki.linaro.org%2FBoards%2FMX6QSabreLite%22%20title%3D%22https%3A%2F%2Fwiki.linaro.org%2FBoards%2FMX6QSabreLite%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E4%B8%BB%E6%9D%BF%2FMX6QSabreLite%20-%20Linaro%20Wiki%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%3E%E6%88%91%E4%BC%BC%E4%B9%8E%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%EF%BC%88%E6%88%96%E6%B5%8F%E8%A7%88%EF%BC%89URL%EF%BC%9A%E2%80%9C%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fdl.lm-sensors.org%2Fi2c-tools%2Freleases%2Fi2c-tools-3.0.3.tar.bz2%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fdl.lm-sensors.org%2Fi2c-tools%2Freleases%2Fi2c-tools-3.0.3.tar.bz2%3C%2FA%3E%20%3CSPAN%3E%E2%80%9D%E3%80%82%E6%97%A0%E6%B3%95%E4%BB%8E%E4%BB%BB%E4%BD%95%E6%9D%A5%E6%BA%90%E8%8E%B7%E5%8F%96URL%EF%BC%81%E5%9C%A8%E5%85%B6%E4%BB%96%E7%94%B5%E8%84%91%E4%B8%8A%E4%B9%9F%E4%B8%80%E6%A0%B7%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%91%E8%A1%8C%E5%90%8E%3C%2FP%3E%3CP%3Ebitbake%20fsl-image-gui%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BE%97%E5%88%B0%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E8%8E%B7%E5%8F%96%E5%99%A8%E6%95%85%E9%9A%9C%EF%BC%9A%E8%8E%B7%E5%8F%96%E5%91%BD%E4%BB%A4%E6%89%A7%E8%A1%8C%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%204%EF%BC%8C%E8%BE%93%E5%87%BA%EF%BC%9A%20%3C%2FP%3E%3CP%3Ewget%EF%BC%9A%E6%97%A0%E6%B3%95%E8%A7%A3%E6%9E%90%E4%B8%BB%E6%9C%BA%E5%9C%B0%E5%9D%80%E2%80%9Cdl.lm-sensors.org%E2%80%9D%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E5%8A%9F%E8%83%BD%E5%A4%B1%E8%B4%A5%EF%BC%9AURL%E2%80%9C%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fdl.lm-sensors.org%2Fi2c-tools%2Freleases%2Fi2c-tools-3.0.3.tar.bz2%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fdl.lm-sensors.org%2Fi2c-tools%2Freleases%2Fi2c-tools-3.0.3.tar.bz2%3C%2FA%3E%20%3CSPAN%3E%E2%80%9D%E7%9A%84%E8%8E%B7%E5%8F%96%E7%A8%8B%E5%BA%8F%E5%A4%B1%E8%B4%A5%E3%80%82%E6%97%A0%E6%B3%95%E4%BB%8E%E4%BB%BB%E4%BD%95%E6%9D%A5%E6%BA%90%E8%8E%B7%E5%8F%96%20URL%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E5%BD%93%E6%82%A8%E5%88%B7%E6%96%B0%20SD%20%E5%8D%A1%E6%97%B6%EF%BC%8C%E6%82%A8%E6%98%AF%E5%90%A6%E8%BF%9B%E8%A1%8C%E4%BA%86%3CEM%3E%E5%90%8C%E6%AD%A5%3C%2FEM%3E%EF%BC%9F%E6%88%91%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%E2%80%98%20%3CEM%3Edd%20if%3D..%20of%3D..%20%26amp%3B%26amp%3B%20sync%E2%80%99%E3%80%82%3C%2FEM%3E%E4%BD%BF%E7%94%A8%3CEM%3E%E5%90%8C%E6%AD%A5%3C%2FEM%3E%E5%91%BD%E4%BB%A4%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E7%A1%AE%E4%BF%9D%20OS%20%E7%BC%93%E5%86%B2%E5%8C%BA%E4%B8%AD%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%86%85%E5%AE%B9%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%89%80%E6%9C%89%E5%9B%BE%E5%83%8F%E6%95%B0%E6%8D%AE%E9%83%BD%E5%B7%B2%E5%88%B7%E6%96%B0%E5%88%B0%20SD%20%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELeo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E5%B0%9D%E8%AF%95%E8%AE%A9%E5%AE%83%E5%B7%A5%E4%BD%9C%E5%87%A0%E5%A4%A9%E3%80%82U-Boot%20%E6%97%A0%E6%B3%95%E8%BF%90%E8%A1%8C%20Yocto%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20Maschine%20%E4%BD%9C%E4%B8%BA%20sabrelite%20%E5%92%8C%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSTRONG%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3Enitro6x%EF%BC%8C%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E4%BD%86%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E8%BF%99%E6%98%AF%20U-Boot%20%E6%B6%88%E6%81%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EU-Boot%202009.08-dirty%EF%BC%882013%E5%B9%B41%E6%9C%8817%E6%97%A5%20-%2006%3A55%3A57%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECPU%EF%BC%9AFreescale%20i.MX6%E7%B3%BB%E5%88%97TO1.2%EF%BC%8C792MHz%3CBR%20%2F%3E%E6%B8%A9%E5%BA%A6%EF%BC%9A29%E2%84%83%EF%BC%8C%E6%A0%A1%E5%87%86%E6%95%B0%E6%8D%AE0x5894ee7d%3CBR%20%2F%3E%20MX6Q%20PLL1%EF%BC%9A792MHz%3CBR%20%2F%3E%20MX6Q%20PLL2%EF%BC%9A528MHz%3CBR%20%2F%3E%20MX6Q%20PLL3%EF%BC%9A480MHz%3CBR%20%2F%3E%20MX6Q%20PLL8%EF%BC%9A50MHz%3CBR%20%2F%3E%20ipg%E6%97%B6%E9%92%9F%EF%BC%9A66000000Hz%3CBR%20%2F%3E%E6%AF%8F%E6%97%B6%E9%92%9F%20ipg%20%3A%2066000000Hz%3CBR%20%2F%3E%20UART%E6%97%B6%E9%92%9F%EF%BC%9A80000000Hz%3CBR%20%2F%3E%20cspi%E6%97%B6%E9%92%9F%EF%BC%9A60000000Hz%3CBR%20%2F%3E%20ahb%E6%97%B6%E9%92%9F%EF%BC%9A132000000Hz%3CBR%20%2F%3E%E8%BD%B4%E6%97%B6%E9%92%9F%EF%BC%9A264000000Hz%3CBR%20%2F%3E%20emi_slow%E6%97%B6%E9%92%9F%EF%BC%9A29333333Hz%3CBR%20%2F%3E%20DDR%E6%97%B6%E9%92%9F%EF%BC%9A528000000Hz%3CBR%20%2F%3E%20USDHHC1%E6%97%B6%E9%92%9F%EF%BC%9A198000000Hz%3CBR%20%2F%3E%20USDHHC2%E6%97%B6%E9%92%9F%EF%BC%9A198000000Hz%3CBR%20%2F%3E%20USDHC3%E6%97%B6%E9%92%9F%EF%BC%9A198000000Hz%3CBR%20%2F%3E%20USDHC4%E6%97%B6%E9%92%9F%EF%BC%9A198000000Hz%3CBR%20%2F%3E%20NFC%E6%97%B6%E9%92%9F%EF%BC%9A24000000Hz%3CBR%20%2F%3E%E4%B8%BB%E6%9D%BF%EF%BC%9AMX6Q-SABRELITE%3A%5B%20POR%5D%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%E8%AE%BE%E5%A4%87%EF%BC%9AI2C%3CBR%20%2F%3E%20I2C%EF%BC%9A%E5%B0%B1%E7%BB%AA%3CBR%20%2F%3E%E5%86%85%E5%AD%98%EF%BC%9A1%20GB%3CBR%20%2F%3E%20MMC%3AFSL_USDHC%3A0%EF%BC%8CFSL_USDHC%3A1%3CBR%20%2F%3E%20JEDEC%20ID%EF%BC%9A0xbf%EF%BC%9A0x25%EF%BC%9A0x41%3CBR%20%2F%3E%E8%AF%BB%E5%8F%96%20SPI%20NOR%20%E9%97%AA%E5%AD%98%200xc0000%20%5B0x2000%20%E5%AD%97%E8%8A%82%5D%20-%26gt%3B%20RAM%200x276009b8%3CBR%20%2F%3E%E6%88%90%E5%8A%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%EF%BC%9A%E8%BF%9E%E7%BB%AD%E5%89%A7%3CBR%20%2F%3E%E8%BE%93%E5%87%BA%EF%BC%9A%E4%B8%B2%E8%A1%8C%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%B8%B2%E8%A1%8C%3CBR%20%2F%3E%E7%BD%91%E7%BB%9C%EF%BC%9A%E4%BB%8E%20IIM%20%E8%8E%B7%E5%8F%96%20MAC%20%E5%9C%B0%E5%9D%80%EF%BC%9A11%3A23%3A33%3A47%3A55%3A67%3CBR%20%2F%3E%20FEC0%20%5B%E4%B8%BB%E8%A6%81%5D%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%EF%BC%9AFEC0%20MAC%20%E5%9C%B0%E5%9D%80%E4%B8%8D%E5%8C%B9%E9%85%8D%EF%BC%9A%3CBR%20%2F%3E%20SROM%20%E4%B8%AD%E7%9A%84%E5%9C%B0%E5%9D%80%E6%98%AF%2011%3A23%3A33%3A47%3A55%3A67%3CBR%20%2F%3E%E7%8E%AF%E5%A2%83%E4%B8%AD%E7%9A%84%E5%9C%B0%E5%9D%80%E6%98%AF%2000%3A01%3A02%3A03%3A04%3A05%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%81%9C%E6%AD%A2%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%9A0%3CBR%20%2F%3E%20mmc1%E6%98%AF%E5%BD%93%E5%89%8D%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%E4%BB%8E%20mmc%20%E8%AE%BE%E5%A4%87%201%20%E5%8A%A0%E8%BD%BD%E6%96%87%E4%BB%B6%E2%80%9C%2Fboot%2FuImage%E2%80%9D%3CBR%20%2F%3E%E6%97%A0%E6%B3%95%E6%8C%82%E8%BD%BD%20ext2%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%3CBR%20%2F%3E%20**%20%E5%9D%8F%E7%9A%84%20ext2%20%E5%88%86%E5%8C%BA%E6%88%96%E7%A3%81%E7%9B%98%20-%20mmc%201%3A0%20**%3CBR%20%2F%3E%20bootm%20%E5%91%BD%E4%BB%A4%E7%9A%84%E5%9B%BE%E5%83%8F%E6%A0%BC%E5%BC%8F%E9%94%99%E8%AF%AF%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%E5%86%85%E6%A0%B8%E6%98%A0%E5%83%8F%EF%BC%81%3CBR%20%2F%3EMX6Q%20SABRELITE%20U-Boot%20%26gt%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EJoerg%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Elibsocketcan%20%E5%92%8C%20canutils%20%E9%83%BD%E5%9C%A8%E6%BA%90%E4%B8%AD%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%AE%83%E4%BB%AC%E6%B7%BB%E5%8A%A0%E5%88%B0%E6%88%91%E7%9A%84%E6%9E%84%E5%BB%BA%E4%B8%AD%E3%80%82%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%9Asmileyhappy%EF%BC%9A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110918%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110918%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E7%A1%AE%E5%AE%9E%E7%9F%A5%E9%81%93%20libsocktcan%E3%80%82%E4%BD%86%E6%88%91%E7%9F%A5%E9%81%93%20canutils%20%E5%B7%B2%E7%BB%8F%E9%9B%86%E6%88%90%E4%BA%86%EF%BC%88%E5%8C%85%E5%90%8D%E7%A7%B0%E6%98%AF%20canutils%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20CORE_IMAGE_EXTRA_INSTALL%20%2B%3D%20%22drobpbear%20canutils%22%20%E4%BB%A5%E7%9B%B8%E5%90%8C%E7%9A%84%E6%96%B9%E5%BC%8F%E6%B7%BB%E5%8A%A0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BA%86%E7%9F%A5%E9%81%93%E4%B8%80%E4%B8%AA%E5%8C%85%E6%98%AF%E5%90%A6%E9%9B%86%E6%88%90%EF%BC%8C%E6%88%91%E5%81%9A%E7%9A%84%E6%98%AF%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%24%20cd%20%E6%BA%90%3C%2FP%3E%3CP%3E%24%20find%20-name%20%E5%8C%85%E5%90%8D%E7%A7%B0*%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E6%89%BE%E5%88%B0%E8%8F%9C%E8%B0%B1%E5%90%8D%E7%A7%B0%EF%BC%8C%E6%88%91%E7%9F%A5%E9%81%93%E5%AE%83%E5%B7%B2%E8%A2%AB%E8%A6%86%E7%9B%96%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E3%80%82%E6%88%91%E7%94%A8%E8%B0%B7%E6%AD%8C%E6%90%9C%E7%B4%A2%E5%AE%83%EF%BC%88%E5%85%B3%E9%94%AE%E8%AF%8D%EF%BC%9Apachage_name%20yocto%20metaoe%EF%BC%89%E5%AE%83%E5%8F%AF%E8%83%BD%E8%A2%AB%E5%85%B6%E4%BB%96%E5%85%83%E5%B1%82%E8%A6%86%E7%9B%96%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E8%83%BD%E5%A4%9F%E5%B0%86%E5%85%B6%E5%8C%85%E6%8B%AC%E5%9C%A8%E5%86%85%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%84%BF%E6%84%8F%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%87%E6%A1%A3%E6%9D%A5%E6%B3%A8%E5%86%8C%E6%82%A8%E4%BD%BF%E7%94%A8%20meta-fsl-arm%20%E4%BD%BF%20flexcan%20%E5%B7%A5%E4%BD%9C%E6%89%80%E4%BD%BF%E7%94%A8%E7%9A%84%E5%86%85%E5%AE%B9%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E5%88%9B%E4%BD%9C%E4%BA%86%EF%BC%8C%E8%AF%B7%E4%B8%8E%E6%88%91%E5%88%86%E4%BA%AB%E3%80%82%E6%88%91%E6%83%B3%E5%B0%B1%E6%AD%A4%E8%AF%9D%E9%A2%98%E4%BF%9D%E6%8C%81%E8%81%94%E7%B3%BB%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%EF%BC%88%E6%82%A8%E7%9F%A5%E9%81%93%E6%82%A8%E9%9C%80%E8%A6%81%E6%9B%B4%E6%94%B9%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110917%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110917%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%8E%B0%E5%9C%A8%E5%AE%83%E5%8F%AF%E4%BB%A5%E6%8C%89%E9%A2%84%E6%9C%9F%E5%B7%A5%E4%BD%9C%E4%BA%86%EF%BC%9Asmileyhappy%EF%BC%9A%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%AF%B9%20Yocto%20%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9A%E5%A6%82%E4%BD%95%E5%B0%86%E5%8C%85%E6%B7%BB%E5%8A%A0%E5%88%B0%E6%88%91%E7%9A%84%E5%9B%BE%E5%83%8F%E4%B8%AD%EF%BC%88%E6%AF%94%E5%A6%82%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-1437%22%20target%3D%22_blank%22%3E%E9%82%A3%E9%87%8C%3C%2FA%3E%E4%BD%BF%E7%94%A8%E7%9A%84%20libsocketcan%20%E5%92%8C%20canutils%20%E5%8C%85%EF%BC%89%EF%BC%9F%E6%88%91%E9%98%85%E8%AF%BB%E4%BA%86%E4%B8%80%E4%BA%9B%E5%85%B3%E4%BA%8E%E6%B7%BB%E5%8A%A0%E6%96%B0%E9%A3%9F%E8%B0%B1%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%8C%E4%BD%86%E6%89%BE%E4%B8%8D%E5%88%B0%E9%80%82%E5%90%88%E6%88%91%E7%9A%84%E6%83%85%E5%86%B5%E7%9A%84%E7%9C%9F%E6%AD%A3%E6%B8%85%E6%99%B0%E7%9A%84%E6%8C%87%E5%8D%97%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110916%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110916%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%B0%86%E4%BB%A5%E4%B8%8B%E4%BB%A3%E7%A0%81%E6%B7%BB%E5%8A%A0%E5%88%B0%E6%82%A8%E7%9A%84%20conf%2Flocal.conf%20%E4%B8%AD%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECORE_IMAGE_EXTRA_INSTALL%20%2B%3D%20%22dropbear%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E9%87%8D%E5%BB%BA%E4%BD%A0%E7%9A%84%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E6%88%91%E7%9A%84%20iMX6%20Sabre%20Lite%20%E6%9D%BF%E4%B8%8A%E6%B5%8B%E8%AF%95%20fsl-image-test%E3%80%82%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8%E5%85%B6%E4%B8%8A%E8%BF%9B%E8%A1%8C%20ssh%EF%BC%8C%E6%88%91%E6%80%BB%E6%98%AF%E6%94%B6%E5%88%B0%E6%AD%A4%E9%94%99%E8%AF%AF%EF%BC%9A%E2%80%9Cssh%EF%BC%9A%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%B8%BB%E6%9C%BA%20192.168.0.9%20%E7%AB%AF%E5%8F%A3%2022%EF%BC%9A%E8%BF%9E%E6%8E%A5%E8%A2%AB%E6%8B%92%E7%BB%9D%E2%80%9D%E3%80%82%E5%9B%BE%E5%83%8F%E4%B8%8A%E6%B2%A1%E6%9C%89%20ssh%20%E5%91%BD%E4%BB%A4%EF%BC%8C%E5%B9%B6%E4%B8%94%20ssh%20%E6%9C%8D%E5%8A%A1%E4%BC%BC%E4%B9%8E%E6%B2%A1%E6%9C%89%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%80%8E%E6%A0%B7%E6%89%8D%E8%83%BD%E8%AE%A9%20ssh%20%E5%9C%A8%E8%AF%A5%E5%9B%BE%E5%83%8F%E4%B8%8A%E5%B7%A5%E4%BD%9C%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110914%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110914%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%81%9A%E5%BE%97%E5%BE%88%E5%A5%BD%EF%BC%8C%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110913%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110913%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EOtavio%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E6%88%91%E4%BB%AC%E5%BF%85%E9%A1%BB%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%20imx6qsabrelite.conf%20%E6%96%87%E4%BB%B6%E3%80%82%E6%88%91%E4%BB%AC%E6%A0%B9%E6%9C%AC%E4%B8%8D%E6%B8%85%E6%A5%9A%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%20nitro6x%20%E6%9D%A5%E4%BB%A3%E6%9B%BF%E3%80%82%E8%AE%A9%E6%88%91%E4%BB%AC%E5%9C%A8%20meta-freescale%20%E4%B8%AD%E8%AE%A8%E8%AE%BA%E8%BF%99%E4%B8%AA%E8%AF%9D%E9%A2%98%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E5%AE%83%E5%BA%94%E8%AF%A5%E8%83%BD%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%3A-)%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%89%80%E4%BB%A5%E6%88%91%E5%8F%AA%E9%9C%80%E5%9C%A8%20conf%2Flocal.conf%20%E4%B8%AD%E5%B0%86%E7%9B%AE%E6%A0%87%E4%BB%8E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3EMACHINE%20%3F%3F%3D%20'i%3C%2FSPAN%3E%20%3CSTRONG%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3Emx6qsabrelite%3C%2FSTRONG%3E%20%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E'%20%E6%9B%B4%E6%94%B9%E4%B8%BA%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3EMACHINE%20%3F%3F%3D%20'%3C%2FSPAN%3E%20%3CSTRONG%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3Enitro6x%3C%2FSTRONG%3E%20%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSTRONG%3E'%3C%2FSTRONG%3E%20%3F%3F%3F%3F%20%EF%BC%88%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E6%B2%A1%E6%9C%89%E6%98%8E%E7%A1%AE%E8%AF%B4%E6%98%8E%E5%A6%82%E4%BD%95%E6%89%A7%E8%A1%8C%E6%AD%A4%E6%93%8D%E4%BD%9C%EF%BC%89%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E4%BC%BC%E4%B9%8E%E6%AD%A3%E5%9C%A8%E5%B0%86%20SabreLITE%20%E4%B8%8E%20Boundary%20%E7%9A%84%20U-Boot%20%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%EF%BC%9B%E4%B8%BA%E4%BA%86%E4%BD%BF%E5%85%B6%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E8%AF%B7%E4%B8%BA%20Nitrogen6x%20%E6%9E%84%E5%BB%BA%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%E4%B8%A5%E6%A0%BC%3C%2FSPAN%3E%E6%8C%89%E7%85%A7%E6%AD%A5%E9%AA%A4%E6%93%8D%E4%BD%9C%EF%BC%8C%20%3CSTRONG%3Efsl-image-gui%3C%2FSTRONG%3E%E7%9A%84%E4%B8%80%E5%88%87%E9%83%BD%E6%9E%84%E5%BB%BA%E8%89%AF%E5%A5%BD%E3%80%82%3CBR%20%2F%3E%E7%84%B6%E5%90%8E%E5%B0%86%3CSTRONG%3Efsl-image-gui-imx6qsabrelite.sdcard%3C%2FSTRONG%3E%E6%96%87%E4%BB%B6%3CSTRONG%3Edd%3C%2FSTRONG%3E%E5%88%B0%20%2Fdev%2Fsdb%E3%80%82%3CBR%20%2F%3E%E4%B8%BB%E6%9D%BF%E5%90%AF%E5%8A%A8%E5%90%8E%E6%8F%90%E7%A4%BA%3CSTRONG%3E%E6%9C%AA%E6%89%BE%E5%88%B0%206x_bootscript%3C%2FSTRONG%3E%20...%E7%9C%9F%E7%B3%9F%E7%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%82%A3%E4%B9%88...%E5%8C%BB%E7%94%9F%EF%BC%8C%E6%82%A8%E5%A5%BD%E5%90%97%EF%BC%9F%E6%88%91%E9%94%99%E8%BF%87%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%9F%EF%BC%81%EF%BC%9F%EF%BC%81%EF%BC%9F%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E1)%20%3CSTRONG%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CYOCTO-ROOT%3E%2Fsetup-environment%3C%2FYOCTO-ROOT%3E%3C%2FSTRONG%3E%E5%9F%BA%E4%BA%8E%3CSTRONG%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CYOCTO-ROOT%3E%2Fsources%2Fpoky%2F%3C%2FYOCTO-ROOT%3E%3C%2FSTRONG%3E%20%EF%BC%8C%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E4%BB%AC%E6%A0%B9%E6%8D%AE%E6%88%91%E4%BB%AC%E8%AE%A4%E4%B8%BA%E7%9A%84%E2%80%9C%E6%B8%85%E6%99%B0%E2%80%9D%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E4%BA%86%E5%AE%9A%E5%88%B6%EF%BC%8C%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%81%95%E6%88%91%E7%9B%B4%E8%A8%80%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%89%E6%8B%A9%E5%85%B6%E4%B8%AD%E4%B8%80%E4%B8%AA%EF%BC%8C%E5%AE%83%E4%BB%AC%E9%83%BD%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2%EF%BC%89%E5%BD%93%E6%88%91%E6%8C%89%E7%85%A7%E8%87%AA%E5%B7%B1%E7%9A%84%E6%96%B9%E5%BC%8F%E5%81%9A%E8%BF%99%E4%BB%B6%E4%BA%8B%E6%97%B6%EF%BC%9A%3C%2FP%3E%3CP%3E*%20%E6%BA%90%3CSTRONG%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CYOCTO-ROOT%3E%2Fsetup-environment%3C%2FYOCTO-ROOT%3E%3C%2FSTRONG%3E%20%EF%BC%88%E4%BD%BF%E7%94%A8%E4%B8%8E%E6%88%91%E4%B8%80%E7%9B%B4%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E5%AE%8C%E5%85%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E6%9E%84%E5%BB%BA%E7%9B%AE%E5%BD%95%EF%BC%89%3C%2FP%3E%3CP%3E*%20bitbake%20%E5%85%83%E5%B7%A5%E5%85%B7%E9%93%BE%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3)%E5%BD%93%E7%84%B6%EF%BC%8C%E5%9C%A8%20rootfs%20%E6%9E%84%E5%BB%BA%E4%B9%8B%E5%90%8E%E6%82%A8%E5%B0%B1%E5%AE%8C%E6%88%90%E4%BA%86%E3%80%82%E6%9F%A5%E6%89%BE%20x86-*%20%E7%9B%AE%E5%BD%95%EF%BC%8C%E5%AE%83%E5%BA%94%E8%AF%A5%E5%9C%A8%E9%82%A3%E9%87%8C%E3%80%82%EF%BC%88%E5%B7%A5%E5%85%B7%E9%93%BE%E6%98%AF%20x86%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%82%A8%E5%AF%B9%E5%85%83%E5%B7%A5%E5%85%B7%E9%93%BE%E8%BF%9B%E8%A1%8C%20bitbake%20%E6%97%B6%EF%BC%8C%E5%AE%83%E4%BC%9A%E5%AF%BC%E5%87%BA%E6%82%A8%E5%9C%A8*%E4%BB%BB%E4%BD%95*%E4%B8%BB%E6%9C%BA%E4%B8%AD%E6%89%80%E9%9C%80%E7%9A%84%E4%BB%BB%E4%BD%95%E5%86%85%E5%AE%B9%EF%BC%8C%E5%8C%85%E6%8B%AC%E7%8E%AF%E5%A2%83%E8%AE%BE%E7%BD%AE%E8%84%9A%E6%9C%AC%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%9C%A8%20build%2Ftmp%2Fwork%2Fx86*%20%E4%B8%AD%E6%82%A8%E5%B0%86%E6%89%BE%E5%88%B0%20*cross-gcc*%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E4%BD%BF%E7%94%A8%E5%AE%83%EF%BC%8C%E6%82%A8%E5%B0%86%E9%9C%80%E8%A6%81%E6%89%BE%E5%87%BA%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E6%89%80%E9%9C%80%E7%9A%84%E5%8F%82%E6%95%B0%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%E5%91%80%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E7%94%9F%E6%88%90%E4%B8%80%E4%B8%AA%E5%8F%AF%E4%BB%A5%E5%9C%A8%E4%B8%BB%E6%9C%BA%E4%B8%8A%E8%BF%90%E8%A1%8C%E7%9A%84%E5%B7%A5%E5%85%B7%E9%93%BE%20-%20%E5%8D%B3%E6%88%91%E7%94%A8%E6%9D%A5%E7%94%9F%E6%88%90%20rootfs%20%E6%98%A0%E5%83%8F%E7%9A%84%E5%90%8C%E4%B8%80%E5%8F%B0%E7%94%B5%E8%84%91%EF%BC%88%E5%9B%A0%E6%AD%A4%20sysroot%20%E6%96%87%E4%BB%B6%E5%A4%B9%E5%B7%B2%E7%BB%8F%E7%94%9F%E6%88%90%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E4%BB%94%E7%BB%86%E9%98%85%E8%AF%BB%E4%BA%86%E6%96%87%E6%A1%A3%EF%BC%8C%E4%BD%86%E6%88%91%E4%BB%8D%E7%84%B6%E4%B8%8D%E6%B8%85%E6%A5%9A%E5%88%9B%E5%BB%BA%E5%B7%A5%E5%85%B7%E9%93%BE%E6%97%B6%E6%9C%89%E5%93%AA%E4%BA%9B%E4%B8%8D%E5%90%8C%E7%9A%84%E9%80%89%E6%8B%A9%E3%80%82%E5%8D%B3%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%96%87%E6%A1%A3%E4%B8%AD%EF%BC%8C%E5%AE%83%E6%8C%87%E5%87%BA%E6%88%91%E5%BA%94%E8%AF%A5%E8%8E%B7%E5%8F%96%3CSTRONG%3Eoe-init-build-env%20%3CBUILD_DIR%3E%3C%2FBUILD_DIR%3E%3C%2FSTRONG%3E%E6%96%87%E4%BB%B6%EF%BC%8C%E8%AF%A5%E6%96%87%E4%BB%B6%E4%BD%8D%E4%BA%8E%3CSTRONG%3E%3CYOCTO-ROOT%3E%2Fsources%2Fpoky%2F%3C%2FYOCTO-ROOT%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E4%B8%8D%E6%B8%85%E6%A5%9A%20%3CBUILD_DIR%3E%20%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E4%B8%8E%E6%88%91%E7%94%A8%E4%BA%8E%E5%88%9B%E5%BB%BA%20rootfs%20%E5%9B%BE%E5%83%8F%E7%9A%84%E6%9E%84%E5%BB%BA%E7%9B%AE%E5%BD%95%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FBUILD_DIR%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E5%BD%93%E6%88%91%E8%8E%B7%E5%8F%96%3CSTRONG%3E%3CYOCTO-ROOT%3E%2Fsetup-environment%3C%2FYOCTO-ROOT%3E%3C%2FSTRONG%3E%E6%96%87%E4%BB%B6%E6%97%B6%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%E4%BA%86%20bitbake%20%E7%A4%BA%E4%BE%8B%E3%80%82%E6%88%91%E5%9C%A8%E7%A4%BA%E4%BE%8B%E4%B8%AD%E7%9C%8B%E5%88%B0%E4%BA%86%20meta-toolchain%5B-sdk%5D%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E5%BF%BD%E7%95%A5%E6%96%87%E6%A1%A3%EF%BC%8C%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%AA%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BB%8E%E8%80%8C%E5%88%9B%E5%BB%BA%E5%B7%A5%E5%85%B7%E9%93%BE%E7%9A%84%E6%9C%80%E7%BB%88%20.tar%20%E6%96%87%E4%BB%B6%E3%80%82%E5%90%8C%E4%B8%80%E6%9E%84%E5%BB%BA%E7%9B%AE%E5%BD%95%E4%B8%AD%E7%9A%84%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E5%90%8E%EF%BC%8C%E6%96%87%E6%A1%A3%E4%B8%AD%E6%8F%90%E5%88%B0%E5%B7%A5%E5%85%B7%E9%93%BE%E5%8C%85%E5%90%AB%E4%B8%80%E4%B8%AA%E4%B8%8E%20arch%20%E5%AF%B9%E5%BA%94%E7%9A%84%3CSTRONG%3E%E7%8E%AF%E5%A2%83%E8%AE%BE%E7%BD%AE%3C%2FSTRONG%3E*%20%E6%96%87%E4%BB%B6%EF%BC%8C%E6%88%91%E5%BA%94%E8%AF%A5%E8%8E%B7%E5%8F%96%E8%AF%A5%E6%96%87%E4%BB%B6%E6%89%8D%E8%83%BD%E4%BD%BF%E7%94%A8%E8%AF%A5%E5%B7%A5%E5%85%B7%E9%93%BE%E3%80%82%E5%97%AF%EF%BC%8C%E4%B8%80%E4%B8%AA%E5%90%88%E7%90%86%E7%9A%84%E6%80%9D%E8%B7%AF%E6%98%AF%EF%BC%8C%E7%94%B1%E4%BA%8E%E6%88%91%E5%88%9A%E5%88%9A%E5%AE%8C%E6%88%90%E4%BA%86%E6%95%B4%E4%B8%AA%20rootfs%20%E6%98%A0%E5%83%8F%E7%9A%84%E7%BC%96%E8%AF%91%EF%BC%8C%E6%89%80%E4%BB%A5%E9%9C%80%E8%A6%81%E4%B8%80%E4%B8%AA%E5%B7%A5%E5%85%B7%E9%93%BE%EF%BC%8C%E5%B9%B6%E4%B8%94%E8%AF%A5%E5%B7%A5%E5%85%B7%E9%93%BE%E5%BA%94%E8%AF%A5%E4%BD%8D%E4%BA%8E%E6%9E%84%E5%BB%BA%E7%9B%AE%E5%BD%95%E4%B8%AD%E7%9A%84%E6%9F%90%E4%B8%AA%E4%BD%8D%E7%BD%AE%E3%80%82%E4%BD%86%E6%88%91%E6%90%9C%E7%B4%A2%E6%97%B6%E5%8D%B4%E6%B2%A1%E6%89%BE%E5%88%B0%E3%80%82%E6%88%91%E7%9A%84%E6%80%9D%E8%B7%AF%E9%94%99%E8%AF%AF%E5%9C%A8%E5%93%AA%E9%87%8C%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110906%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110906%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%40Nass_sil%20Daiane%20%E6%98%AF%E5%AF%B9%E7%9A%84%E3%80%82%E8%AF%A5%E5%86%85%E6%A0%B8%E4%B8%8D%E9%80%82%E7%94%A8%E4%BA%8E%20QEMU%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E9%80%82%E7%94%A8%E4%BA%8E%E7%89%B9%E5%AE%9A%E7%9A%84%E4%B8%BB%E6%9D%BF%E3%80%82%E5%9B%A0%E6%AD%A4%E9%A2%84%E8%AE%A1%E5%AE%83%E4%BC%9A%E5%A4%B1%E8%B4%A5%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110905%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110905%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E6%98%AF%E4%BB%80%E4%B9%88%E6%84%8F%E6%80%9D%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%20QEMU%EF%BC%8C%E4%BD%86%E6%88%91%E8%AE%A4%E4%B8%BA%E5%9C%A8%E4%BB%BB%E4%BD%95%E6%A8%A1%E6%8B%9F%E5%99%A8%E4%B8%8A%EF%BC%8C%E4%BD%BF%E7%94%A8%20uImage%20for%20imx6%20%E9%83%BD%E8%A1%8C%E4%B8%8D%E9%80%9A%20%3CIMG%20id%3D%22smileywink%22%20class%3D%22emoticon%20emoticon-smileywink%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-wink.png%22%20alt%3D%22Smiley%20Wink%22%20title%3D%22Smiley%20Wink%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110903%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110903%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E9%80%9A%E8%BF%87%E5%87%A0%E7%A7%8D%E6%96%B9%E5%BC%8F%E5%90%AF%E5%8A%A8%E6%88%91%E5%88%9B%E5%BB%BA%E7%9A%84%E5%9B%BE%E5%83%8F%EF%BC%9A%3C%2FP%3E%3CP%3E1%EF%BC%89%E6%8F%90%E5%8F%96%20tar.bz2%20%E6%98%A0%E5%83%8F%E5%B9%B6%E7%9B%B4%E6%8E%A5%E4%BB%8E%20sabrelite%20%E6%9D%BF%E8%BF%9B%E8%A1%8C%20nfs%20%E5%90%AF%E5%8A%A8%EF%BC%81%E8%BF%99%E6%88%90%E5%8A%9F%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E2%EF%BC%89%E5%A4%8D%E5%88%B6.sdcard%E5%9B%BE%E5%83%8F%E5%88%B0%20microSD%20%E5%8D%A1%E5%B9%B6%E5%B0%9D%E8%AF%95%E4%BB%8E%20microSD%20%E6%9C%AC%E5%9C%B0%E5%90%AF%E5%8A%A8%E3%80%82%E8%BF%99%E6%AC%A1%E5%A4%B1%E8%B4%A5%E4%BA%86%EF%BC%8C%E5%9B%A0%E4%B8%BA%E4%B8%BB%E6%9D%BF%E4%B8%8A%E7%9A%84%20uboot%20%E7%89%88%E6%9C%AC%E6%98%AF%20sabrelite%20%E9%99%84%E5%B8%A6%E7%9A%84%E7%89%88%E6%9C%AC%EF%BC%88%E6%88%91%E8%AE%A4%E4%B8%BA%E6%98%AF%202009.08%EF%BC%89%E3%80%82%E6%88%91%E8%AF%A5%E5%A6%82%E4%BD%95%E6%9B%B4%E6%96%B0%E4%BB%8E%20bitbake%20%E8%BF%87%E7%A8%8B%E7%94%9F%E6%88%90%E7%9A%84%20uboot%EF%BC%88.imx%20%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%9F%3C%2FP%3E%3CP%3E3)%20%E6%88%91%E5%BC%80%E5%A7%8B%E9%98%85%E8%AF%BB%20yocto%20%E9%A1%B9%E7%9B%AE%E5%B9%B6%E5%B0%9D%E8%AF%95%E8%BF%90%E8%A1%8C%20qemu%EF%BC%8C%E4%BD%86%E5%A4%B1%E8%B4%A5%E4%BA%86%E3%80%82%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E6%89%80%E5%81%9A%E7%9A%84%EF%BC%9A%3C%2FP%3E%3CP%3Ecd%3CYOCTO%20root%3D%22%22%3E%20%2Fsources%2Fpoky%2F%3C%2FYOCTO%3E%3C%2FP%3E%3CP%3E%E3%80%82.%2Foe-init-build-env%3C%2FP%3E%3CP%3Ecd%20build%23%E9%80%80%E5%87%BA%E4%B8%8A%E8%BF%B0%E8%84%9A%E6%9C%AC%E6%97%B6%E8%87%AA%E5%8A%A8%E5%AE%8C%E6%88%90%3C%2FP%3E%3CP%3Erunqemu%20..%2F..%2F..%2Fbuild%2Ftmp%2Fdeply%2Fimages%2FuImage-blabla.bin%20..%2F..%2F..%2Fbuild%2Ftmp%2Fdeply%2Fimages%2Ffsl-image-test-blabla.ext3%20ext3%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eqemu%20%E5%BC%80%E5%A7%8B%E8%BF%90%E8%A1%8C%EF%BC%8C%20%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Enass%40starland%20~%2Fyocto%2Fsources%2Fpoky%2Fbuild%20%24%20runqemu%20images%2FuImage-imx6qsabrelite.bin%20images%2Ffsl-image-test-imx6qsabrelite-20130515000446.rootfs.ext3%20ext3%3C%2FP%3E%0A%3CP%3E%E6%A0%B9%E6%8D%AE%E5%86%85%E6%A0%B8%5Bimages%2FuImage-imx6qsabrelite.bin%5D%E5%B0%86MACHINE%E8%AE%BE%E7%BD%AE%E4%B8%BA%5BuImage-imx6qsabrelite.bin%5D%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%E7%BB%A7%E7%BB%AD%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%8F%82%E6%95%B0%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%E5%86%85%E6%A0%B8%EF%BC%9A%5Bimages%2FuImage-imx6qsabrelite.bin%5D%3C%2FP%3E%0A%3CP%3E%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%EF%BC%9A%5B%E5%9B%BE%E5%83%8F%2Ffsl-%E5%9B%BE%E5%83%8F-%E6%B5%8B%E8%AF%95-imx6qsabrelite-20130515000446.rootfs.ext3%5D%3C%2FP%3E%0A%3CP%3E%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E7%B1%BB%E5%9E%8B%3A%20%5Bext3%5D%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%E4%BD%86%E8%BF%87%E4%BA%86%E4%B8%80%E4%BC%9A%E5%84%BF%E5%B0%B1%E5%81%9C%E6%AD%A2%E4%BA%86%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%E8%BF%90%E8%A1%8C%20bitbake%20%E6%9D%A5%E7%A1%AE%E5%AE%9A%20TMPDIR%20%E6%97%B6%E5%87%BA%E9%94%99%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E2%80%9Cbitbake%20-e%E2%80%9D%E7%9A%84%E8%BE%93%E5%87%BA%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CHUUUUGE%20dump%3D%22%22%20of%3D%22%22%20exported%3D%22%22%20variables%3D%22%22%20and%3D%22%22%20python%3D%22%22%20code%3D%22%22%20following%3D%22%22%3E%3C%2FHUUUUGE%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%98%AF%E5%90%A6%E9%94%99%E8%AF%AF%E5%9C%B0%E4%BD%BF%E7%94%A8%E4%BA%86%E5%91%BD%E4%BB%A4%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%9C%A8%E8%BF%99%E4%B8%A4%E4%BB%B6%E4%BA%8B%E4%B8%8A%E6%8F%90%E4%BE%9B%E7%9A%84%E5%B8%AE%E5%8A%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110902%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110902%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E6%B6%88%E6%81%AF%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%B9%9F%E5%B0%86%E5%9C%A8%E8%BF%99%E9%87%8C%E5%8F%91%E5%B8%83%E6%88%91%E5%B7%B2%E7%BB%8F%E5%9C%A8%3CSTRONG%3ELinux%20Mint%2014-64%20%E4%BD%8D%3C%2FSTRONG%3E%E8%99%9A%E6%8B%9F%E6%9C%BA%E4%B8%8A%E6%88%90%E5%8A%9F%E5%AF%B9%3CSTRONG%3Efsl-image-test%3C%2FSTRONG%3E%3CSTRONG%3E%E8%BF%9B%E8%A1%8C%E4%BA%86%20bitbaked%3C%2FSTRONG%3E%20%E3%80%82%E8%99%BD%E7%84%B6%E8%8A%B1%E4%BA%86%2030%20%E5%A4%9A%E4%B8%AA%E5%B0%8F%E6%97%B6%EF%BC%88%E8%BF%99%E4%B8%8D%E6%98%AF%E4%B8%80%E5%8F%B0%E7%89%B9%E5%88%AB%E5%BF%AB%E7%9A%84%E7%94%B5%E8%84%91%EF%BC%89%EF%BC%8C%E4%BD%86%E5%B7%A5%E4%BD%9C%E5%AE%8C%E6%88%90%E4%BA%86%E3%80%82%3A%E7%AC%91%E8%84%B8%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%BC%96%E8%BE%91%EF%BC%9A%E6%88%91%E8%BF%98%E8%AE%BE%E6%B3%95%20btibake%20fsl-image-gui%20%E5%B9%B6%E5%9C%A8%E6%88%91%E7%9A%84%20%3CYOCTO_ROOT%3E%2Fbuild%2Flocal.conf%20%E4%B8%AD%E9%99%84%E5%8A%A0%20-dbg%20-dev%20%26amp%3B%20-sdk%20%E9%80%89%E9%A1%B9%E5%B9%B6%E9%87%8D%E5%81%9A%20fsl-image-test%20bitbake%E3%80%82%3C%2FYOCTO_ROOT%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EEXTRA_IMAGE_FEATURES%20%3D%E2%80%9Cdbg-pkgs%20dev-pkgs%E5%B7%A5%E5%85%B7-%E8%B0%83%E8%AF%95%E5%B7%A5%E5%85%B7-%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E5%B7%A5%E5%85%B7-sdk%E8%B0%83%E8%AF%95%E8%B0%83%E6%95%B4%E2%80%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110900%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110900%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%AE%8C%E6%AF%95%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E5%A6%82%E6%9E%9C%E4%BD%A0%E5%8A%A0%E5%85%A5%E9%82%AE%E4%BB%B6%E5%88%97%E8%A1%A8%E4%BC%9A%E6%9B%B4%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Flists.yoctoproject.org%2Flistinfo%2Fmeta-freescale%22%20title%3D%22https%3A%2F%2Flists.yoctoproject.org%2Flistinfo%2Fmeta-freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Flists.yoctoproject.org%2Flistinfo%2Fmeta-freescale%3C%2FA%3E%E8%BF%99%E6%A0%B7%E6%88%91%E4%BB%AC%E5%B0%B1%E5%8F%AF%E4%BB%A5%E5%B8%AE%E5%8A%A9%E6%82%A8%E5%B9%B6%E6%A3%80%E6%9F%A5%E9%82%A3%E9%87%8C%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E5%AE%83%E5%8F%AF%E4%BB%A5%E8%AE%A9%E6%9B%B4%E5%A4%9A%E7%9A%84%E4%BA%BA%E8%BD%BB%E6%9D%BE%E5%9C%B0%E6%94%AF%E6%8C%81%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E5%B9%B6%E6%8A%A5%E5%91%8A%E4%BB%BB%E4%BD%95%E7%B1%BB%E4%BC%BC%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%8A%A0%E5%85%A5%E5%B9%B6%E5%8F%91%E9%80%81%E4%B8%80%E5%B0%81%E5%8C%85%E5%90%AB%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%E5%92%8C%E6%89%80%E6%9C%89%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%E7%9A%84%E7%94%B5%E5%AD%90%E9%82%AE%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110898%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110898%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Edanny%2C%3C%2FP%3E%3CP%3Esabre%20lite%3C%2FP%3E%3CP%3Efsl-image-test%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110897%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110897%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%AF%B7%E5%91%8A%E7%9F%A5%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E5%88%86%E6%94%AF%EF%BC%9F%EF%BC%88%E4%B8%B9%E5%B0%BC%E3%80%81%E8%BF%AA%E4%BC%A6%E3%80%81%E5%A4%A7%E5%B8%88%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%AD%A3%E5%9C%A8%E4%B8%BA%E5%93%AA%E5%8F%B0%E6%9C%BA%E5%99%A8%E5%BB%BA%E9%80%A0%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%AD%A3%E5%9C%A8%E6%9E%84%E5%BB%BA%E5%9B%BE%E5%83%8F%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110896%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110896%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E4%B9%9F%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E6%9E%84%E5%BB%BA%20yocto%E3%80%82%3C%2FP%3E%3CP%3E.%2Frepo*%20%E4%B8%9C%E8%A5%BF%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E2%80%9Cbitbake%20fsl-image-test%E2%80%9D%E6%9C%9F%E9%97%B4%E9%81%87%E5%88%B0%E6%9E%84%E5%BB%BA%E9%94%99%E8%AF%AF%EF%BC%8C%E5%8D%B3%20%3CYOCTO%20root%3D%22%22%3E%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Fcross-localedef-native-2.16-r1%3C%2FYOCTO%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Eglibc%2Flocale%2Fiso-639.def%3A502%3A1%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A%EF%BC%88%E6%8E%A5%E8%BF%91%E2%80%9Ciso639%E2%80%9D%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%89%5B%E9%BB%98%E8%AE%A4%E5%90%AF%E7%94%A8%5D%3C%2FP%3E%0A%3CP%3Eglibc%2Flocale%2Fiso-639.def%3A502%3A1%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%A0%87%E9%87%8F%E5%88%9D%E5%A7%8B%E5%8C%96%E5%99%A8%E4%B8%AD%E7%9A%84%E5%85%83%E7%B4%A0%E8%BF%87%E5%A4%9A%20%5B%E9%BB%98%E8%AE%A4%E5%90%AF%E7%94%A8%5D%3C%2FP%3E%0A%3CP%3Eglibc%2Flocale%2Fiso-639.def%3A502%3A1%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A%EF%BC%88%E6%8E%A5%E8%BF%91%E2%80%9Ciso639%E2%80%9D%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%89%5B%E9%BB%98%E8%AE%A4%E5%90%AF%E7%94%A8%5D%3C%2FP%3E%0A%3CP%3Eglibc%2Flocale%2Fiso-639.def%3A502%3A1%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%A0%87%E9%87%8F%E5%88%9D%E5%A7%8B%E5%8C%96%E5%99%A8%E4%B8%AD%E7%9A%84%E5%85%83%E7%B4%A0%E8%BF%87%E5%A4%9A%20%5B%E9%BB%98%E8%AE%A4%E5%90%AF%E7%94%A8%5D%3C%2FP%3E%0A%3CP%3Eglibc%2Flocale%2Fiso-639.def%3A502%3A1%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A%EF%BC%88%E6%8E%A5%E8%BF%91%E2%80%9Ciso639%E2%80%9D%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%89%5B%E9%BB%98%E8%AE%A4%E5%90%AF%E7%94%A8%5D%3C%2FP%3E%0A%3CP%3Eglibc%2Flocale%2Fprograms%2Fld-address.c%3A73%3A3%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E2%80%98uint32_t%E2%80%99%E4%B9%8B%E5%89%8D%E9%9C%80%E8%A6%81%E8%AF%B4%E6%98%8E%E7%AC%A6%E9%99%90%E5%AE%9A%E7%AC%A6%E5%88%97%E8%A1%A8%3C%2FP%3E%0A%3CP%3Eglibc%2Flocale%2Fprograms%2Fld-address.c%3A66%3A1%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A%E7%A9%BA%E5%A3%B0%E6%98%8E%20%5B%E9%BB%98%E8%AE%A4%E5%90%AF%E7%94%A8%5D%3C%2FP%3E%0A%3CP%3Eglibc%2Flocale%2Fprograms%2Fld-address.c%3A86%3A1%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E5%9C%A8%E2%80%9C%7B%E2%80%9D%E6%A0%87%E8%AE%B0%E4%B9%8B%E5%89%8D%E5%BA%94%E4%B8%BA%E2%80%9C%3D%E2%80%9D%E3%80%81%E2%80%9C%2C%E2%80%9D%E3%80%81%E2%80%9C%3B%E2%80%9D%E3%80%81%E2%80%9Casm%E2%80%9D%E6%88%96%E2%80%9C%20__attribute__%20%E2%80%9D%3C%2FP%3E%0A%3CP%3Eglibc%2Flocale%2Fprograms%2Fld-address.c%3A102%3A1%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E5%9C%A8%E2%80%9C%7B%E2%80%9D%E6%A0%87%E8%AE%B0%E4%B9%8B%E5%89%8D%E5%BA%94%E4%B8%BA%E2%80%9C%3D%E2%80%9D%E3%80%81%E2%80%9C%2C%E2%80%9D%E3%80%81%E2%80%9C%3B%E2%80%9D%E3%80%81%E2%80%9Casm%E2%80%9D%E6%88%96%E2%80%9C%20__attribute__%20%E2%80%9D%3C%2FP%3E%0A%3CP%3Eglibc%2Flocale%2Fprograms%2Fld-address.c%3A349%3A1%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E5%9C%A8%E2%80%9C%7B%E2%80%9D%E6%A0%87%E8%AE%B0%E4%B9%8B%E5%89%8D%E5%BA%94%E4%B8%BA%E2%80%9C%3D%E2%80%9D%E3%80%81%E2%80%9C%2C%E2%80%9D%E3%80%81%E2%80%9C%3B%E2%80%9D%E3%80%81%E2%80%9Casm%E2%80%9D%E6%88%96%E2%80%9C%20__attribute__%20%E2%80%9D%3C%2FP%3E%0A%3CP%3Eglibc%2Flocale%2Fprograms%2Fld-address.c%3A376%3A1%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E5%9C%A8%E2%80%9C%7B%E2%80%9D%E6%A0%87%E8%AE%B0%E4%B9%8B%E5%89%8D%E5%BA%94%E4%B8%BA%E2%80%9C%3D%E2%80%9D%E3%80%81%E2%80%9C%2C%E2%80%9D%E3%80%81%E2%80%9C%3B%E2%80%9D%E3%80%81%E2%80%9Casm%E2%80%9D%E6%88%96%E2%80%9C%20__attribute__%20%E2%80%9D%3C%2FP%3E%0A%3CP%3E%2Fusr%2Finclude%2Fstdio.h%3A54%3A1%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E5%8E%9F%E5%9E%8B%E5%87%BD%E6%95%B0%E5%AE%9A%E4%B9%89%E4%B8%AD%E7%9A%84%E6%97%A7%E5%BC%8F%E5%8F%82%E6%95%B0%E5%A3%B0%E6%98%8E%3C%2FP%3E%0A%3CP%3E%2Fusr%2Finclude%2Fstdio.h%3A54%3A1%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E7%9C%81%E7%95%A5%E5%8F%82%E6%95%B0%E5%90%8D%E7%A7%B0%3C%2FP%3E%0A%3CP%3Eglibc%2Flocale%2Fprograms%2Fld-address.c%3A544%3A1%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E8%BE%93%E5%85%A5%E6%9C%AB%E5%B0%BE%E5%BA%94%E4%B8%BA%E2%80%9C%7B%E2%80%9D%3C%2FP%3E%0A%3CP%3Eglibc%2Flocale%2Fprograms%2Fld-address.c%3A544%3A1%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%8E%A7%E5%88%B6%E5%88%B0%E8%BE%BE%E9%9D%9E%20void%20%E5%87%BD%E6%95%B0%E7%9A%84%E6%9C%AB%E5%B0%BE%20%5B-Wreturn-type%5D%3C%2FP%3E%0A%3CP%3E%E5%88%B6%E4%BD%9C%EF%BC%9A***%20%5Bld-address.o%5D%E9%94%99%E8%AF%AF%201%3C%2FP%3E%0A%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9Aoe_runmake%20%E5%A4%B1%E8%B4%A5%3C%2FP%3E%0A%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E5%87%BD%E6%95%B0%E5%A4%B1%E8%B4%A5%EF%BC%9Ado_compile%EF%BC%88%E6%9C%89%E5%85%B3%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20%2Fopt%2Fslackaloo_nfs%2Fyocto%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Fcross-localedef-native-2.16-r1%2Ftemp%2Flog.do_compile.7844%EF%BC%89%3C%2FP%3E%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E6%98%AF%20Linux%20Mint%2012%EF%BC%8864%20%E4%BD%8D%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E9%81%87%E5%88%B0%E8%BF%87%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110895%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110895%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E4%B8%8D%E5%8F%97%E6%94%AF%E6%8C%81%E3%80%82Yocto%20%E9%80%82%E7%94%A8%E4%BA%8E%E4%B8%BB%E6%9C%BA%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E7%9B%AE%E6%A0%87%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%99%9A%E6%8B%9F%E6%9C%BA%E4%B8%AD%E4%BD%BF%E7%94%A8%20Yocto%E3%80%82%E5%AF%B9%E4%BA%8E%E7%9B%AE%E6%A0%87%E5%BC%80%E5%8F%91%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%9E%84%E5%BB%BA%E4%B8%80%E4%B8%AA%20sdk%20%E6%98%A0%E5%83%8F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A1%AE%E5%AE%9E%E5%A6%82%E6%AD%A4%E3%80%82%E6%88%91%E6%83%B3%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20yocto%20%E8%BF%9B%E8%A1%8C%E6%9E%84%E5%BB%BA%E3%80%82%E6%88%91%E5%AF%B9%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E5%85%B6%E6%BA%90%EF%BC%88%E5%9C%A8%E6%88%91%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E6%98%AF%20vivante%EF%BC%89%E6%9B%B4%E6%96%B0%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%84%9F%E5%85%B4%E8%B6%A3%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%B2%A1%E6%9C%89%E5%8F%A6%E4%B8%80%E5%8F%B0%20Linux%20%E6%9C%BA%E5%99%A8%EF%BC%8C%E6%88%91%E5%8F%AA%E5%9C%A8%20Windows%20%E4%B8%8A%E5%B7%A5%E4%BD%9C%EF%BC%8C%E8%AF%A5%E6%9D%BF%E7%94%A8%E4%BA%8E%E9%83%A8%E7%BD%B2%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110893%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110893%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%9C%A8%E7%9B%AE%E6%A0%87%E4%B8%AD%E4%BD%BF%E7%94%A8%20Yocto%20%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110892%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110892%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9C%A8%20bitbake%20%E4%B9%8B%E5%89%8D%E7%9A%84%E6%AD%A5%E9%AA%A4%E9%83%BD%E6%98%AF%E5%8F%AF%E4%BB%A5%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%20bitbake%20%E5%91%BD%E4%BB%A4%E6%97%B6%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E4%B8%BB%E6%9C%BA%E5%8F%91%E8%A1%8C%E7%89%88%E2%80%9CLinaro-12.03%E2%80%9D%E5%B0%9A%E6%9C%AA%E9%80%9A%E8%BF%87%E6%AD%A4%E7%89%88%E6%9C%AC%E7%9A%84%E6%9E%84%E5%BB%BA%E7%B3%BB%E7%BB%9F%E8%BF%9B%E8%A1%8C%E9%AA%8C%E8%AF%81%EF%BC%9B%E6%82%A8%E5%8F%AF%E8%83%BD%E4%BC%9A%E9%81%87%E5%88%B0%E6%84%8F%E5%A4%96%E7%9A%84%E5%A4%B1%E8%B4%A5%E3%80%82%E5%BB%BA%E8%AE%AE%E6%82%A8%E4%BD%BF%E7%94%A8%E7%BB%8F%E8%BF%87%E6%B5%8B%E8%AF%95%E7%9A%84%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%82%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E7%A1%AE%E5%AE%9A%E6%9E%B6%E6%9E%84%E2%80%9Carmv7l%E2%80%9D%E7%9A%84%E5%AD%97%E8%8A%82%E9%A1%BA%E5%BA%8F%20%7C%20%E9%A2%84%E8%AE%A1%E5%88%B0%E8%BE%BE%E6%97%B6%E9%97%B4%EF%BC%9A00%3A06%3A03%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AF%B7%E5%B0%86%E6%82%A8%E7%9A%84%E6%9E%B6%E6%9E%84%E6%B7%BB%E5%8A%A0%E5%88%B0%20siteinfo.bbclass%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E8%A7%A3%E6%9E%90%2Fhome%2Flinaro%2Frootfs_builder%2Fsources%2Fmeta-openembedded%2Fmeta-oe%2Frecipes-devtools%2Forc%2Forc_0.4.16.bb%EF%BC%9A%E4%BB%A5%E2%80%9C1%E2%80%9D%E9%80%80%E5%87%BA%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E7%A1%AE%E5%AE%9A%E6%9E%B6%E6%9E%84%E2%80%9Carmv7l%E2%80%9D%E7%9A%84%E5%AD%97%E8%8A%82%E9%A1%BA%E5%BA%8F%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AF%B7%E5%B0%86%E6%82%A8%E7%9A%84%E6%9E%B6%E6%9E%84%E6%B7%BB%E5%8A%A0%E5%88%B0%20siteinfo.bbclass%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E7%A1%AE%E5%AE%9A%E6%9E%B6%E6%9E%84%E2%80%9Carmv7l%E2%80%9D%E7%9A%84%E5%AD%97%E8%8A%82%E9%A1%BA%E5%BA%8F%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AF%B7%E5%B0%86%E6%82%A8%E7%9A%84%E6%9E%B6%E6%9E%84%E6%B7%BB%E5%8A%A0%E5%88%B0%20siteinfo.bbclass%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E7%A1%AE%E5%AE%9A%E6%9E%B6%E6%9E%84%E2%80%9Carmv7l%E2%80%9D%E7%9A%84%E5%AD%97%E8%8A%82%E9%A1%BA%E5%BA%8F%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E8%AF%B7%E5%B0%86%E6%82%A8%E7%9A%84%E6%9E%B6%E6%9E%84%E6%B7%BB%E5%8A%A0%E5%88%B0%20siteinfo.bbclass%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E5%91%BD%E4%BB%A4%E6%89%A7%E8%A1%8C%E5%A4%B1%E8%B4%A5%EF%BC%9A%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%201%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%E6%9C%89%E4%BB%80%E4%B9%88%E6%83%B3%E6%B3%95%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110891%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110891%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%AF%A5%E8%A1%A5%E4%B8%81%E6%AD%A3%E5%9C%A8%20Yocto%20%E7%9A%84%E9%82%AE%E4%BB%B6%E5%88%97%E8%A1%A8%E4%B8%AD%E7%AD%89%E5%BE%85%E6%B5%8B%E8%AF%95%EF%BC%9B%E5%AE%8C%E6%88%90%E5%90%8E%E5%B0%86%E8%A2%AB%E5%90%88%E5%B9%B6%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110890%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110890%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E5%AF%B9%E6%88%91%E6%9C%89%E7%94%A8%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%24%20cat%20meta-fsl-arm%2Frecipes-kernel%2Fperf%2Fperf_3.4.bbappend%3CBR%20%2F%3EPRINC%20%EF%BC%9A%3D%E2%80%9C%20%24%7B%40int(PRINC)%20%2B%201%7D%20%E2%80%9D%3CBR%20%2F%3E%20FILESEXTRAPATHS_prepend%20%3A%3D%20%22%20%24%7BTHISDIR%7D%20%2F%E6%96%87%E4%BB%B6%3A%20%22%3CBR%20%2F%3E%20SRC_URI_append%20%3D%20%22%E6%96%87%E4%BB%B6%3A%2F%2Fdefine-attribute-const.patch%22%3CBR%20%2F%3E%20%24%20cat%20meta-fsl-arm%2Frecipes-kernel%2Fperf%2Ffiles%2Fdefine-attribute-const.patch%3CBR%20%2F%3E---%20a%2Ftools%2Fperf%2Futil%2Finclude%2Flinux%2Fcompiler.h2013-04-04%2017%3A55%3A08.000000000%20-0700%3CBR%20%2F%3E%20%2B%2B%2Bb%2F%E5%B7%A5%E5%85%B7%2F%E6%80%A7%E8%83%BD%2F%E5%AE%9E%E7%94%A8%E7%A8%8B%E5%BA%8F%2F%E5%8C%85%E6%8B%AC%2Flinux%2F%E7%BC%96%E8%AF%91%E5%99%A8.h2013-04-10%2007%3A16%3A36.711981928%20-0700%3CBR%20%2F%3E%20%40%40%20-5%2C7%20%2B5%2C9%20%40%40%3CBR%20%2F%3E%20%23define%20__always_inline%20%E5%86%85%E8%81%94%3CBR%20%2F%3E%23%E7%BB%93%E6%9D%9F%3CBR%20%2F%3E%23define%20__user%3CBR%20%2F%3E%2B%23ifndef%20__%20attribute_const%20__%3CBR%20%2F%3E%20%23define%20__%20attribute_const%20__%3CBR%20%2F%3E%2B%23endif%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%23define%20__%E4%BD%BF%E7%94%A8__attribute__%20((%20__unused__%20))%3CBR%20%2F%3E%3CBR%20%2F%3E%20%24%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110889%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110889%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fnicklewis%22%20target%3D%22_blank%22%3Enicklewis%3C%2FA%3E%E5%92%8C%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FHenrikJacobsen%22%20target%3D%22_blank%22%3EHenrikJacobsen%3C%2FA%3E%20%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%BD%A0%E4%BB%AC%E5%B0%86%E8%BF%99%E4%BA%9B%E9%97%AE%E9%A2%98%E5%8F%91%E5%B8%83%E5%9C%A8%E9%82%AE%E4%BB%B6%E5%88%97%E8%A1%A8%E4%B8%AD%EF%BC%8C%E5%8F%AF%E4%BB%A5%E6%9B%B4%E5%A5%BD%E5%9C%B0%E8%AE%A8%E8%AE%BA%E5%92%8C%E5%A4%84%E7%90%86%E8%BF%99%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%E5%9B%A0%E6%AD%A4%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E8%AF%A2%E9%97%AE%E5%A6%82%E4%BD%95%E9%87%8D%E7%8E%B0%E8%AF%A5%E9%97%AE%E9%A2%98%E5%B9%B6%E4%BF%AE%E5%A4%8D%E5%AE%83%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%9C%A8%E9%82%A3%E9%87%8C%E8%AE%A2%E9%98%85%E5%B9%B6%E5%8F%91%E9%80%81%E4%B8%80%E5%B0%81%E7%94%B5%E5%AD%90%E9%82%AE%E4%BB%B6%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%8C%85%E5%90%AB%E9%97%AE%E9%A2%98%E7%9A%84%E6%8F%8F%E8%BF%B0%E3%80%81%E6%82%A8%E6%AD%A3%E5%9C%A8%E6%9E%84%E5%BB%BA%E7%9A%84%E6%9C%BA%E5%99%A8%E4%BB%A5%E5%8F%8A%E5%A6%82%E4%BD%95%E9%87%8D%E7%8E%B0%E5%AE%83%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110888%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110888%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%88%91%E4%BC%9A%E5%B0%9D%E8%AF%95%E5%B0%86%20meta-fsl-arm%2Frecipes-kernel%2Fperf%2Ffiles%2Fdefine-attribute-const.patch%20%E5%92%8C%20meta-fsl-arm%2Frecipes-kernel%2Fperf%2Fperf_3.4.bbappend%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20Chunrong%20Guo%20%E7%9A%84%E5%86%85%E5%AE%B9%E4%B8%AD%EF%BC%8C%E7%9C%8B%E7%9C%8B%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%8F%91%E7%8E%B0%20perf%20%E5%AD%98%E5%9C%A8%E5%90%8C%E6%A0%B7%E7%9A%84%E7%BC%96%E8%AF%91%E9%97%AE%E9%A2%98%E3%80%82%E5%86%B3%E5%AE%9A%E9%BB%98%E9%BB%98%E7%AD%89%E5%BE%85%E6%9C%89%E4%BA%BA%E4%BF%AE%E5%A4%8D%E5%AE%83%EF%BC%9Asmileyhappy%EF%BC%9A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%9C%A8%20perf_3.4%20%E7%9A%84%20do_compile%20%E8%BF%87%E7%A8%8B%E4%B8%AD%E9%81%87%E5%88%B0%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eutil%2Finclude%2Flinux%2Fcompiler.h%3A8%3A0%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E2%80%9C__attribute_const__%E2%80%9D%E9%87%8D%E6%96%B0%E5%AE%9A%E4%B9%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Flists.yoctoproject.org%2Fpipermail%2Fyocto%2F2012-October%2F012625.html%22%20title%3D%22https%3A%2F%2Flists.yoctoproject.org%2Fpipermail%2Fyocto%2F2012-October%2F012625.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Flists.yoctoproject.org%2Fpipermail%2Fyocto%2F2012-October%2F012625.html%3C%2FA%3E%E4%B8%8A%E4%BC%BC%E4%B9%8E%E6%9C%89%E4%B8%80%E4%B8%AA%E8%A1%A5%E4%B8%81%E5%8F%AF%E4%BB%A5%E8%A7%A3%E5%86%B3%E6%AD%A4%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E5%AE%83%E4%BC%BC%E4%B9%8E%E5%B0%9A%E6%9C%AA%E5%BA%94%E7%94%A8%E4%BA%8E%20meta-fsl-arm%E3%80%82%E6%9C%89%E4%BA%BA%E5%8F%AF%E4%BB%A5%E5%90%91%E6%88%91%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%E6%88%91%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BC%9A%E7%9C%8B%E5%88%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%88%E8%80%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E5%85%B6%E4%BB%96%E4%BA%BA%E4%B8%8D%E4%BC%9A%E7%9C%8B%E5%88%B0%EF%BC%89%E7%9A%84%E5%8F%AF%E8%83%BD%E5%8E%9F%E5%9B%A0%E5%90%97%EF%BC%9F%E6%88%91%E5%BA%94%E8%AF%A5%E5%BA%94%E7%94%A8%E8%A1%A5%E4%B8%81%E5%90%97%EF%BC%9F%E6%88%96%E8%80%85%E9%97%AE%E9%A2%98%E5%8F%AF%E8%83%BD%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E5%8E%9F%E5%9B%A0%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%BC%9A%E5%B0%9D%E8%AF%95%E6%94%B9%E5%8F%98%E5%85%AC%E5%8F%B8%E9%98%B2%E7%81%AB%E5%A2%99%E7%AD%96%E7%95%A5%EF%BC%8C%E4%BD%86%E6%88%91%E5%8F%AA%E6%98%AF%E4%B8%80%E4%B8%AA%E5%B0%8F%E9%BD%BF%E8%BD%AE......%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%AE%9E%E9%99%85%E4%B8%8A%EF%BC%8C%E7%BC%BA%E5%B0%91%20git%20%E5%8D%8F%E8%AE%AE%E4%BC%BC%E4%B9%8E%E4%B8%8D%E6%98%AF%E4%BB%80%E4%B9%88%E5%A4%A7%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E5%8F%91%E7%8E%B0%E6%9E%84%E5%BB%BA%E6%9C%80%E5%B0%8F%E6%A0%B8%E5%BF%83%E9%95%9C%E5%83%8F%E6%97%B6%E6%B2%A1%E6%9C%89%E5%85%B6%E4%BB%96%E9%94%99%E8%AF%AF%EF%BC%8C%E8%BF%90%E8%A1%8C%E2%80%9Cbitbake%20-c%20fetchall%20fsl-image-test%E2%80%9D%E6%97%B6%E5%8F%AA%E5%87%BA%E7%8E%B0%E4%BA%86%E4%B8%A4%E4%B8%AA%E9%94%99%E8%AF%AF%E3%80%82%E8%BF%99%E4%BA%9B%E9%97%AE%E9%A2%98%E9%80%9A%E8%BF%87%E5%9C%A8%20fio_2.0.5%20%E9%85%8D%E6%96%B9%E7%9A%84%20URL%20%E6%9C%AB%E5%B0%BE%E6%B7%BB%E5%8A%A0%20%3Bprotocol%3Dhttp%20%E4%BB%A5%E5%8F%8A%E5%B0%86%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Flinuxtv.org%2Fdownloads%2Fv4l-utils%2Fv4l-utils-0.8.8.tar.bz2%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20v4l-utils_0.8.8%3C%2FA%3E%3CSPAN%3E%20%E9%85%8D%E6%96%B9%E7%9A%84%20URL%20%E6%9B%B4%E6%94%B9%E4%B8%BA%20%3CA%20href%3D%22http%3A%2F%2Flinuxtv.org%2Fdownloads%2Fv4l-utils%2Fv4l-utils-0.8.8.tar.bz2%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Flinuxtv.org%2Fdownloads%2Fv4l-utils%2Fv4l-utils-0.8.8.tar.bz2%3C%2FA%3E%20%E6%9D%A5%E8%A7%A3%E5%86%B3%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110884%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110884%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%9B%E8%BF%99%E5%B0%B1%E6%98%AF%E6%88%91%E4%BB%AC%E8%BD%AC%E5%90%91%20GIT%20%E7%9A%84%E5%8E%9F%E5%9B%A0%E3%80%82%E7%84%B6%E8%80%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E4%BD%A0%E7%A1%AE%E5%AE%9E%E9%9C%80%E8%A6%81%E4%BF%AE%E5%A4%8D%E4%BD%A0%E7%9A%84%E9%98%B2%E7%81%AB%E5%A2%99%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%AE%B8%E5%A4%9A%E9%A3%9F%E8%B0%B1%E9%83%BD%E4%BD%BF%E7%94%A8%20GIT%20%E6%9D%A5%E8%8E%B7%E5%8F%96%E6%BA%90%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%9C%A8%E6%AF%8F%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%E4%BD%A0%E9%83%BD%E4%BC%9A%E9%81%87%E5%88%B0%E4%B8%80%E4%B8%AA%E5%B7%A8%E5%A4%A7%E7%9A%84%E9%97%AE%E9%A2%98%E6%9D%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EFedora%20%E6%9C%89%E4%B8%80%E4%B8%AA%E5%89%AF%E6%9C%AC%EF%BC%8C%E5%B9%B6%E4%B8%94%E8%BF%99%E4%B8%AA%E8%A1%A5%E4%B8%81%E4%BC%BC%E4%B9%8E%E5%8F%AF%E4%BB%A5%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E---%20a%2Fmeta-fsl-arm%2Frecipes-core%2Fudev%2Fudev_173.bbappend%26nbsp%3B%26nbsp%3B%26nbsp%3B%202013-04-04%2022%3A31%3A22.006040965%20-0700%3CBR%20%2F%3E%2B%2B%2B%20b%2Fmeta-fsl-arm%2Frecipes-core%2Fudev%2Fudev_173.bbappend%26nbsp%3B%26nbsp%3B%26nbsp%3B%202013-04-05%2000%3A09%3A54.327713016%20-0700%3CBR%20%2F%3E%40%40%20-1%2C8%20%2B1%2C5%20%40%40%3CBR%20%2F%3E-PRINC%20%3A%3D%20%22%24%7B%40int(PRINC)%20%2B%202%7D%22%3CBR%20%2F%3E%2BPRINC%20%3A%3D%20%22%24%7B%40int(PRINC)%20%2B%203%7D%22%3CBR%20%2F%3E%20%3CBR%20%2F%3E-%23%20Switch%20to%20git%20source%3CBR%20%2F%3E-%23%20173%20tag%3CBR%20%2F%3E-SRCREV%20%3D%20%22ad667dff51711fed763a23283d973486de3cd6b5%22%3CBR%20%2F%3E%2B%23%20Switch%20to%20fedora%20source%3CBR%20%2F%3E%20SRC_URI%20%3A%3D%20%22%24%7B%40oe_filter_out('%24%7BKERNELORG_MIRROR%7D%2Flinux%2Futils%2Fkernel%2Fhotplug%2Fudev-%24%7BPV%7D.tar.bz2'%2C%20'%24%7BSRC_URI%7D'%2C%20d)%7D%22%3CBR%20%2F%3E-SRC_URI_prepend%20%3D%20%22git%3A%2F%2Fgit.kernel.org%2Fpub%2Fscm%2Flinux%2Fhotplug%2Fudev.git%3Bprotocol%3Dgit%20%22%3CBR%20%2F%3E-S%20%3D%20%22%24%7BWORKDIR%7D%2Fgit%22%3CBR%20%2F%3E%3CSPAN%3E%2BSRC_URI_prepend%20%3D%20%22%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fpkgs.fedoraproject.org%2Frepo%2Fpkgs%2Fudev%2Fudev-173.tar.bz2%2F91a88a359b60bbd074b024883cc0dbde%2Fudev-173.tar.bz2%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fpkgs.fedoraproject.org%2Frepo%2Fpkgs%2Fudev%2Fudev-173.tar.bz2%2F91a88a359b60bbd074b024883cc0dbde%2Fudev-173.tar.bz2%3C%2FA%3E%3CSPAN%3E%20%22%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110882%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110882%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%94%B1%E4%BA%8E%E6%9C%AC%E5%9C%B0%E9%98%B2%E7%81%AB%E5%A2%99%E5%AF%B9%20git%20%E5%8D%8F%E8%AE%AE%E7%9A%84%E4%BD%BF%E7%94%A8%E7%9A%84%E9%99%90%E5%88%B6%EF%BC%8C%E6%88%91%E5%9C%A8%20danny%20udev_173%20%E7%9A%84%20do_fetch%20%E8%BF%87%E7%A8%8B%E4%B8%AD%E9%81%87%E5%88%B0%E9%94%99%E8%AF%AF%E3%80%82%E5%88%A0%E9%99%A4%20bbappend%20%E4%BC%9A%E6%81%A2%E5%A4%8D%E4%B8%BA%E9%80%9A%E8%BF%87%20http%20%E8%8E%B7%E5%8F%96%20tar%EF%BC%8C%E4%BD%86%E6%96%87%E4%BB%B6%E4%B8%A2%E5%A4%B1%EF%BC%88%E6%88%91%E7%8C%9C%E8%BF%99%E5%B0%B1%E6%98%AF%E4%B8%BA%E4%BB%80%E4%B9%88%E8%A6%81%E5%B0%86%20bbappend%20%E6%9B%B4%E6%94%B9%E4%B8%BA%20git%20%E7%9A%84%E5%8E%9F%E5%9B%A0%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110881%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110881%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%80%BB%E6%98%AF%E9%9D%A2%E4%B8%B4%E8%8E%B7%E5%8F%96%E5%A4%B1%E8%B4%A5%E7%9A%84%E6%83%85%E5%86%B5%EF%BC%8C%E7%84%B6%E5%90%8E%E5%BD%93%E6%88%91%E5%86%8D%E6%AC%A1%E5%B0%9D%E8%AF%95%E6%97%B6%EF%BC%8C%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8%E3%80%82%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E6%98%AF%E7%BD%91%E7%BB%9C%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%E6%98%AF%20bitbake%20%E5%B0%9D%E8%AF%95%E4%BB%8E%E6%9C%8D%E5%8A%A1%E5%99%A8%E6%8F%90%E4%BE%9B%E5%95%86%E4%B8%8B%E8%BD%BD%E5%8C%85%E4%BD%86%E6%97%A0%E6%B3%95%E5%AE%8C%E6%88%90%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BC%BC%E4%B9%8E%E6%98%AF%E4%B8%8E%E2%80%9Crepo%E2%80%9D%E8%84%9A%E6%9C%AC%E7%9B%B8%E5%85%B3%E7%9A%84%E4%BB%A3%E7%90%86%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E7%A0%B4%E8%A7%A3%E4%BA%86%E8%84%9A%E6%9C%AC%EF%BC%9B%E5%88%9B%E5%BB%BA%20clone.bundle%20%E6%96%87%E4%BB%B6%EF%BC%8C%E5%86%85%E5%AE%B9%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3Eclone.bundle%20%E6%98%AF%E7%94%B1%E2%80%9Crepo%E2%80%9D%E4%B8%AD%E7%9A%84%20_DownloadBundle%20%E5%87%BD%E6%95%B0%E5%88%9B%E5%BB%BA%E7%9A%84%E3%80%82%E5%AE%83%E4%BD%BF%E7%94%A8%20urllib%20%E6%9D%A5%E6%A3%80%E7%B4%A2%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%BD%BF%E7%94%A8%20wireshark%20%E6%88%91%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E9%80%9A%E8%BF%87%E2%80%9CGET%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fgerrit.googlesource.com.%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20https%3A%2F%2Fgerrit.googlesource.com.%2F%3C%2FA%3E%3CSPAN%3E%20(...)%E2%80%9D%20%E8%AE%BF%E9%97%AE%E4%BB%A3%E7%90%86%E6%9C%8D%E5%8A%A1%E5%99%A8%20%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E5%90%AF%E5%8A%A8%E5%8A%A0%E5%AF%86%E4%BC%9A%E8%AF%9D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%8F%AF%E8%83%BD%E6%98%AF%20Python%20%E7%89%88%E6%9C%AC%E4%B8%8D%E5%A5%BD%EF%BC%9F%EF%BC%88%E4%B8%BA%202.6%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110879%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110879%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%B0%9D%E8%AF%95%E6%9E%84%E5%BB%BA%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSTRONG%3Efsl-image-gui%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%E3%80%82%E6%9E%84%E5%BB%BA%E8%BF%90%E8%A1%8C%E4%BA%86%E4%B8%80%E6%AE%B5%E6%97%B6%E9%97%B4%EF%BC%88%E5%87%A0%E4%B8%AA%E5%B0%8F%E6%97%B6%20-%20%E5%AE%8C%E6%88%90%E4%BA%86%E8%B6%85%E8%BF%87%203000%20%E4%B8%AA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%89%E3%80%826100%20%E4%B8%AA%E4%BB%BB%E5%8A%A1%EF%BC%8C%E5%8D%A0%E7%94%A8%20%26gt%3B40GB%20%E7%9A%84%E7%A3%81%E7%9B%98%E7%A9%BA%E9%97%B4%EF%BC%81)%E3%80%82%E7%84%B6%E5%90%8E%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%20URL%20%3CA%20href%3D%22http%3A%2F%2Fgpe.linuxtogo.org%2Fdownload%2Fsource%2Fxserver-common-1.34.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgpe.linuxtogo.org%2Fdownload%2Fsource%2Fxserver-common-1.34.tar.gz%3C%2FA%3E%20%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%8F%AF%E7%94%A8%EF%BC%8C%E5%B0%9D%E8%AF%95%E9%95%9C%E5%83%8F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E8%8E%B7%E5%8F%96%E7%A8%8B%E5%BA%8F%E5%A4%B1%E8%B4%A5%EF%BC%9A%E8%8E%B7%E5%8F%96%E5%91%BD%E4%BB%A4%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%204%EF%BC%8C%E6%97%A0%E8%BE%93%E5%87%BA%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E5%87%BD%E6%95%B0%E5%A4%B1%E8%B4%A5%EF%BC%9AURL%E2%80%9C%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fgpe.linuxtogo.org%2Fdownload%2Fsource%2Fxserver-common-1.34.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgpe.linuxtogo.org%2Fdownload%2Fsource%2Fxserver-common-1.34.tar.gz%3C%2FA%3E%20%3CSPAN%3E%E2%80%9D%E7%9A%84%E8%8E%B7%E5%8F%96%E7%A8%8B%E5%BA%8F%E5%A4%B1%E8%B4%A5%E3%80%82%E6%97%A0%E6%B3%95%E4%BB%8E%E4%BB%BB%E4%BD%95%E6%9D%A5%E6%BA%90%E8%8E%B7%E5%8F%96%20URL%E3%80%82%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E5%A4%B1%E8%B4%A5%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E5%AD%98%E5%82%A8%E5%9C%A8%EF%BC%9A%2Fhome%2Fhj%2Fyocto%2Frootfs_builder%2Fbuild%2Ftmp%2Fwork%2Fall-poky-linux%2Fxserver-common-1.34-r8%2Ftemp%2Flog.do_fetch.24584%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%BB%BB%E5%8A%A1%205488%EF%BC%88%2Fhome%2Fhj%2Fyocto%2Frootfs_builder%2Fsources%2Fmeta-openembedded%2Fmeta-oe%2Frecipes-graphics%2Fxserver-common%2Fxserver-common_1.34.bb%EF%BC%8Cdo_fetch%EF%BC%89%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%E2%80%9C1%E2%80%9D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E4%BB%BB%E5%8A%A1%E6%91%98%E8%A6%81%EF%BC%9A%E5%B0%9D%E8%AF%95%E4%BA%86%203517%20%E9%A1%B9%E4%BB%BB%E5%8A%A1%EF%BC%8C%E5%85%B6%E4%B8%AD%203515%20%E9%A1%B9%E6%97%A0%E9%9C%80%E9%87%8D%E6%96%B0%E8%BF%90%E8%A1%8C%EF%BC%8C1%20%E9%A1%B9%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%AD%89%E5%BE%85%200%20%E4%B8%AA%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E7%9A%84%E4%BB%BB%E5%8A%A1%E5%AE%8C%E6%88%90%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%B1%87%E6%80%BB%EF%BC%9A1%20%E4%B8%AA%E4%BB%BB%E5%8A%A1%E5%A4%B1%E8%B4%A5%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%20%2Fhome%2Fhj%2Fyocto%2Frootfs_builder%2Fsources%2Fmeta-openembedded%2Fmeta-oe%2Frecipes-graphics%2Fxserver-common%2Fxserver-common_1.34.bb%EF%BC%8Cdo_fetch%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%91%98%E8%A6%81%EF%BC%9A%E6%98%BE%E7%A4%BA%E4%BA%86%201%20%E6%9D%A1%E8%AD%A6%E5%91%8A%E6%B6%88%E6%81%AF%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%91%98%E8%A6%81%EF%BC%9A%E6%98%BE%E7%A4%BA%E4%BA%862%E6%9D%A1%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%EF%BC%8C%E8%BF%94%E5%9B%9E%E4%BA%86%E9%9D%9E%E9%9B%B6%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%EF%BC%88%E8%BF%99%E6%98%AF%E5%B0%9D%E8%AF%95%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E6%9E%84%E5%BB%BA%E7%9A%84%E8%BE%93%E5%87%BA%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%9C%E6%96%87%E4%BB%B6%E6%9C%AA%E6%89%BE%E5%88%B0%E2%80%9D%EF%BC%8C%E4%BC%BC%E4%B9%8E...%E9%85%8D%E6%96%B9%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E6%9B%B4%E6%96%B0%20-%20%E6%88%96%E8%80%85%E5%85%B6%E4%BB%96%E5%BB%BA%E8%AE%AE%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%BB%93%E6%9E%9C%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E4%B8%8E%E6%AD%A4%E5%90%8C%E6%97%B6%EF%BC%8C%E6%88%91%E5%9C%A8%E5%AE%B6%E9%87%8C%E7%94%A8%E8%87%AA%E5%B7%B1%E7%9A%84%E7%94%B5%E8%84%91%E5%92%8C%E7%BD%91%E7%BB%9C%E5%B0%9D%E8%AF%95%E8%BF%87%EF%BC%9A%E6%B2%A1%E9%97%AE%E9%A2%98%EF%BC%88%E6%88%96%E8%80%85%E8%87%B3%E5%B0%91%E4%B8%8D%E6%98%AF%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9Asmileyhappy%EF%BC%9A%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%89%80%E4%BB%A5%E9%97%AE%E9%A2%98%E8%82%AF%E5%AE%9A%E5%87%BA%E5%9C%A8%E2%80%9C%E6%88%91%E2%80%9D%E8%BF%99%E8%BE%B9%E3%80%82%E5%8C%BA%E5%88%AB%EF%BC%9A%E5%9C%A8%E5%B7%A5%E4%BD%9C%E4%B8%AD%EF%BC%8C%E9%81%87%E5%88%B0%E9%97%AE%E9%A2%98%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E6%9C%89%20CentOS5%20%2B%20%E6%8F%92%E4%BB%B6%E5%92%8C%E9%98%B2%E7%81%AB%E5%A2%99%2F%E4%BB%A3%E7%90%86%E3%80%82%E5%9C%A8%E5%AE%B6%EF%BC%9ACentOS6%20%E4%B8%94%E6%97%A0%E4%BB%A3%E7%90%86%E3%80%82%EF%BC%88%E9%9C%80%E8%A6%81%E5%AE%89%E8%A3%85%E6%AF%94%20CentOS6%20%E6%8F%90%E4%BE%9B%E7%9A%84%E6%9B%B4%E6%96%B0%E7%9A%84%20git%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E6%88%91%E5%B7%B2%E7%BB%8F%E5%B0%9D%E8%AF%95%E4%BA%86%E4%B8%80%E5%88%87%E6%96%B9%E6%B3%95%E6%9D%A5%E4%BD%BF%E4%BB%A3%E7%90%86%E5%86%85%E5%AE%B9%E6%AD%A3%E7%A1%AE%EF%BC%9B%E6%88%91%E8%83%BD%E5%A4%9F%E9%80%9A%E8%BF%87%20https%20%E4%BD%BF%E7%94%A8%20curl%20%E8%8E%B7%E5%8F%96%E2%80%9Crepo%E2%80%9D%E3%80%82%E5%B9%B6%E4%B8%94%E8%BF%98%E5%B0%9D%E8%AF%95%E4%BA%86%20git%20config....%E6%88%91%E4%BC%9A%E8%BF%9B%E4%B8%80%E6%AD%A5%E8%B0%83%E6%9F%A5%EF%BC%9B%E6%88%91%E6%83%B3%E4%BB%8E%E4%BD%A0%E7%9A%84%E8%A7%92%E5%BA%A6%E6%9D%A5%E7%9C%8B%E5%BE%88%E9%9A%BE%E5%BC%84%E6%B8%85%E6%A5%9A%E8%BF%99%E9%87%8C%E5%87%BA%E4%BA%86%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%EF%BC%81%3C%2FP%3E%3CP%3E%E5%AE%B6%E9%87%8C%E7%9A%84%E6%9E%84%E5%BB%BA%E8%BF%90%E8%A1%8C%E4%BA%86%E5%A4%A7%E9%83%A8%E5%88%86%E5%A4%9C%E6%99%9A%EF%BC%8C%E7%84%B6%E5%90%8E%E5%B0%B1%E9%80%80%E5%87%BA%E4%BA%86......%E6%88%91%E5%B0%86%E6%8A%8A%E8%BF%99%E4%BD%9C%E4%B8%BA%E4%B8%80%E4%B8%AA%E5%8D%95%E7%8B%AC%E7%9A%84%E9%97%AE%E9%A2%98%E6%8F%90%E5%87%BA%E6%9D%A5%E3%80%82%3C%2FP%3E%3CP%3E%E8%80%8C%E4%B8%94...%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%8F%8A%E6%97%B6%E5%9B%9E%E7%AD%94%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E8%BF%99%E9%87%8C%E4%B8%8B%E8%BD%BD%E5%AE%83%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%86%8D%E8%AF%95%E4%B8%80%E6%AC%A1%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110876%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110876%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%8A%B1%E6%AD%89%EF%BC%8C%E8%BF%99%E4%B9%9F%E6%98%AF%E4%B8%80%E4%B8%AA%E5%B0%8F%E9%97%AE%E9%A2%98%EF%BC%8C%E5%8F%AF%E8%83%BD%E6%98%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%24%20repo%20init%20-u%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%3C%2FA%3E%20%3CSPAN%3E-b%20danny%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EGet%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fgerrit.googlesource.com%2Fgit-repo%2Fclone.bundle%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgerrit.googlesource.com%2Fgit-repo%2Fclone.bundle%3C%2FA%3E%3C%2FP%3E%3CP%3E%24%3C%2FP%3E%3CP%3E...%E4%BD%86%E4%BB%80%E4%B9%88%E4%B9%9F%E6%B2%A1%E6%9C%89%E8%8E%B7%E5%8F%96%E3%80%82repo%20init%20%E5%91%BD%E4%BB%A4%E4%BB%85%E8%BE%93%E5%87%BA%E8%AF%A5%E8%A1%8C%E5%B9%B6%E9%80%80%E5%87%BA%E3%80%82%3C%2FP%3E%3CP%3ESo...%3A%3C%2FP%3E%3CP%3E%24%20repo%20sync%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E5%91%BD%E4%BB%A4%E2%80%9Csync%E2%80%9D%E9%9C%80%E8%A6%81%E5%85%88%E5%AE%89%E8%A3%85%20repo%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E2%80%9Crepo%20init%E2%80%9D%E5%9C%A8%E8%BF%99%E9%87%8C%E5%AE%89%E8%A3%85%E5%AE%83%E3%80%82%3C%2FP%3E%3CP%3E%24%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%9C%A8%E5%91%BD%E4%BB%A4%E4%B8%AD%E4%BB%A5%E5%8F%8A%E5%9C%A8%20repo%20%E8%84%9A%E6%9C%AC%E5%86%85%E7%9A%84%20REPO_URL%3C%2FSPAN%3E%3CSPAN%3E%20%E4%B8%AD%EF%BC%8C%20%E4%BD%BF%E7%94%A8%3C%2FSPAN%3E%3CSPAN%3E%20%E7%9B%B8%E5%90%8C%E7%9A%84%E7%BB%93%E6%9E%9C%20id%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20http%3A%2F%2F%20%E4%BB%A3%E6%9B%BF%3C%2FA%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20https%3A%2F%2F%20-%E3%80%82%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E4%B8%8D%E6%98%AF%20git%20%E4%B8%93%E5%AE%B6%20-%20%E6%98%AF%E5%90%A6%E5%BA%94%E8%AF%A5%E6%9C%89%E4%B8%80%E4%B8%AA%E5%90%8D%E4%B8%BA%E2%80%9Cclone.bundle%E2%80%9D%E7%9A%84%E6%96%87%E4%BB%B6%E5%9C%A8%E5%BC%95%E7%94%A8%E7%9A%84%20git-repo%20%E4%B8%AD%EF%BC%9F%E6%88%91%E6%B2%A1%E7%9C%8B%E5%88%B0...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110875%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110875%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%BB%8F%E8%BF%87%E9%AA%8C%E8%AF%81%E7%9A%84%E5%8F%91%E8%A1%8C%E7%89%88%E5%88%97%E8%A1%A8%E6%98%AF%E6%B4%BB%E8%B7%83%E5%BC%80%E5%8F%91%E4%BA%BA%E5%91%98%E4%BD%BF%E7%94%A8%E7%9A%84%E5%8F%91%E8%A1%8C%E7%89%88%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%BB%96%E4%BB%AC%E4%BC%9A%E4%B8%8D%E6%96%AD%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%EF%BC%9B%E6%88%91%E5%B0%86%E4%B8%8E%E6%82%A8%E8%AE%A8%E8%AE%BA%E5%A6%82%E4%BD%95%E5%B0%86%20MINT%20%E6%B7%BB%E5%8A%A0%E4%B8%BA%E6%9C%89%E6%95%88%E5%8F%91%E8%A1%8C%E7%89%88%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E5%9F%BA%E4%BA%8E%20Ubuntu%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%85%B1%E4%BA%AB%E5%A4%A7%E5%A4%9A%E6%95%B0%E6%A0%B8%E5%BF%83%E7%BB%84%E4%BB%B6%EF%BC%88%E5%B7%A5%E5%85%B7%E9%93%BE%E7%AD%89%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%AE%A4%E4%B8%BA%E6%82%A8%E4%BC%9A%E6%88%90%E4%B8%BA%20Yocto%20%E7%9A%84%E6%B4%BB%E8%B7%83%E7%94%A8%E6%88%B7%E5%90%97%EF%BC%9F%E8%BF%98%E6%98%AF%E6%82%A8%E5%8F%AA%E6%98%AF%E5%87%BA%E4%BA%8E%E5%A5%BD%E5%A5%87%E8%80%8C%E4%BD%BF%E7%94%A8%E5%AE%83%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E6%98%AF%E4%B8%AA%E5%A5%BD%E4%B8%BB%E6%84%8F%EF%BC%81%E5%A4%9A%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%8B%E6%82%A8%E6%98%AF%E5%A6%82%E4%BD%95%E5%AE%9E%E7%8E%B0%E8%BF%99%E4%B8%80%E7%9B%AE%E6%A0%87%E7%9A%84%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%88%90%E5%8A%9F%E5%9C%B0%E5%9C%A8%20master%20%E5%92%8C%20danny%20%E4%B8%AD%E4%BD%BF%E7%94%A8%E2%80%9CLinuxMint-14%E2%80%9D%E4%BD%9C%E4%B8%BA%E8%99%9A%E6%8B%9F%E6%9C%BA%E4%B8%AD%E7%9A%84%E4%B8%BB%E6%9C%BA%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%BB%A5%E5%8F%8A%E5%9C%A8%E7%AC%94%E8%AE%B0%E6%9C%AC%E7%94%B5%E8%84%91%E4%B8%8A%E6%9C%AC%E5%9C%B0%E6%9E%84%E5%BB%BA%E4%BA%86%E5%AE%83%E3%80%82%E5%B0%86%E5%85%B6%E6%B7%BB%E5%8A%A0%E4%B8%BA%E7%BB%8F%E8%BF%87%E9%AA%8C%E8%AF%81%E7%9A%84%E6%9E%84%E5%BB%BA%E7%B3%BB%E7%BB%9F%E5%B0%86%E4%BC%9A%E9%9D%9E%E5%B8%B8%E5%A5%BD%E3%80%82Linux%20Mint%EF%BC%88mate%20%E6%A1%8C%E9%9D%A2%EF%BC%89%E7%9B%B8%E5%AF%B9%E4%BA%8E%E4%B8%80%E4%BA%9B%E2%80%9C%E5%85%B6%E4%BB%96%E2%80%9D%E6%B5%81%E8%A1%8C%E6%A1%8C%E9%9D%A2%E6%9D%A5%E8%AF%B4%E6%98%AF%E4%B8%80%E4%B8%AA%E6%9B%B4%E9%AB%98%E6%95%88%E7%9A%84%E7%8E%AF%E5%A2%83%20-%20%E8%80%8C%E4%B8%94%E9%87%8D%E9%87%8F%E6%9B%B4%E8%BD%BB%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%89%A7%E8%A1%8C%E4%BA%86%20repo%20sync%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E6%88%91%E6%89%A7%E8%A1%8C%E4%BA%86%20bitbake%20fsl-image-test%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E5%86%99%E4%BA%86%E5%8D%A1%E7%89%87%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8B%E9%9D%A2%E7%9A%84%E6%97%A5%E5%BF%97%E6%98%BE%E7%A4%BA%E4%BA%86%E4%B8%80%E7%B3%BB%E5%88%97%E7%9A%84%E9%9D%B4%E5%AD%90%E3%80%82%E7%BB%93%E6%9E%9C%E5%8D%B4%E4%B8%8D%E5%90%8C%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%202012.10-00994-g7e6c682%EF%BC%882013%E5%B9%B42%E6%9C%8822%E6%97%A5%20-%2009%3A15%3A52%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECPU%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20i.MX6Q%20rev1.2%EF%BC%8C792%20MHz%3C%2FP%3E%3CP%3EReset%20cause%3A%20POR%3C%2FP%3E%3CP%3E%E4%B8%BB%E6%9D%BF%EF%BC%9AMX6Q-SabreSD%3C%2FP%3E%3CP%3EDRAM%EF%BC%9A1%20GiB%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E7%BC%93%E5%AD%98%E6%9C%AA%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3EMMC%EF%BC%9AFSL_SDHC%EF%BC%9A0%3C%2FP%3E%3CP%3E***%20%E8%AD%A6%E5%91%8A%20-%20CRC%20%E9%94%99%E8%AF%AF%EF%BC%8C%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%8E%AF%E5%A2%83%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%EF%BC%9A%E4%B8%B2%E8%A1%8C%3C%2FP%3E%3CP%3E%E8%BE%93%E5%87%BA%EF%BC%9A%E4%B8%B2%E8%A1%8C%3C%2FP%3E%3CP%3EErr%3A%26nbsp%3B%26nbsp%3B%20serial%3C%2FP%3E%3CP%3ENet%3A%26nbsp%3B%26nbsp%3B%20FEC%20%5BPRIME%5D%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9AFEC%20%E4%BD%BF%E7%94%A8%E6%9D%A5%E8%87%AA%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E7%9A%84%20MAC%20%E5%9C%B0%E5%9D%80%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%81%9C%E6%AD%A2%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%9A%200%3C%2FP%3E%3CP%3Emmc0%20is%20current%20device%3C%2FP%3E%3CP%3E%E8%AF%BB%E5%8F%96%20boot.scr%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E**%20%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E2%80%9Cboot.scr%E2%80%9D%E6%9D%A5%E8%87%AA%20mmc%200%3A1**%3C%2FP%3E%3CP%3E%E8%AF%BB%E5%8F%96%20uImage%3C%2FP%3E%3CP%3ECPU%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20i.MX6Q%20rev1.2%EF%BC%8C792%20MHz%3C%2FP%3E%3CP%3EReset%20cause%3A%20POR%3C%2FP%3E%3CP%3E%E4%B8%BB%E6%9D%BF%EF%BC%9AMX6Q-SabreSD%3C%2FP%3E%3CP%3EDRAM%EF%BC%9A1%20GiB%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E7%BC%93%E5%AD%98%E6%9C%AA%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3EMMC%EF%BC%9AFSL_SDHC%EF%BC%9A0%3C%2FP%3E%3CP%3E***%20%E8%AD%A6%E5%91%8A%20-%20CRC%20%E9%94%99%E8%AF%AF%EF%BC%8C%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%8E%AF%E5%A2%83%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%EF%BC%9A%E4%B8%B2%E8%A1%8C%3C%2FP%3E%3CP%3E%E8%BE%93%E5%87%BA%EF%BC%9A%E4%B8%B2%E8%A1%8C%3C%2FP%3E%3CP%3EErr%3A%26nbsp%3B%26nbsp%3B%20serial%3C%2FP%3E%3CP%3ENet%3A%26nbsp%3B%26nbsp%3B%20FEC%20%5BPRIME%5D%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9AFEC%20%E4%BD%BF%E7%94%A8%E6%9D%A5%E8%87%AA%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E7%9A%84%20MAC%20%E5%9C%B0%E5%9D%80%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%81%9C%E6%AD%A2%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%9A%200%3C%2FP%3E%3CP%3Emmc0%20is%20current%20device%3C%2FP%3E%3CP%3E%E8%AF%BB%E5%8F%96%20boot.scr%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E**%20%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E2%80%9Cboot.scr%E2%80%9D%E6%9D%A5%E8%87%AA%20mmc%200%3A1**%3C%2FP%3E%3CP%3E%E8%AF%BB%E5%8F%96%20uImage%3C%2FP%3E%3CP%3E%E8%AF%BB%E5%8F%96%E9%9B%86%E7%BE%A4%E6%97%B6%E5%87%BA%E9%94%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E**%20%E6%97%A0%E6%B3%95%E4%BB%8E%20mmc%200%3A1%20%E8%AF%BB%E5%8F%96%E2%80%9CuImage%E2%80%9D**%3C%2FP%3E%3CP%3E%E4%BB%8E%E7%BD%91%E7%BB%9C%E5%90%AF%E5%8A%A8...%3C%2FP%3E%3CP%3EFEC%20%E7%AD%89%E5%BE%85%20PHY%20%E8%87%AA%E5%8A%A8%E5%8D%8F%E5%95%86%E5%AE%8C%E6%88%90.........%E8%B6%85%E6%97%B6%EF%BC%81%3C%2FP%3E%3CP%3EBOOTP%E5%B9%BF%E6%92%AD1%3C%2FP%3E%3CP%3EBOOTP%20%E5%B9%BF%E6%92%AD%202%3C%2FP%3E%3CP%3EBOOTP%20%E5%B9%BF%E6%92%AD%203%3C%2FP%3E%3CP%3EBOOTP%E5%B9%BF%E6%92%AD4%3C%2FP%3E%3CP%3EBOOTP%E5%B9%BF%E6%92%AD5%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%87%8D%E8%AF%95%E6%AC%A1%E6%95%B0%E5%B7%B2%E8%B6%85%E5%87%BA%EF%BC%9B%E9%87%8D%E6%96%B0%E5%BC%80%E5%A7%8B%3C%2FP%3E%3CP%3EFEC%20%E7%AD%89%E5%BE%85%20PHY%20%E8%87%AA%E5%8A%A8%E5%8D%8F%E5%95%86%E5%AE%8C%E6%88%90.........%E8%B6%85%E6%97%B6%EF%BC%81%3C%2FP%3E%3CP%3EBOOTP%E5%B9%BF%E6%92%AD1%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%202012.10-00994-g7e6c682%EF%BC%882013%E5%B9%B42%E6%9C%8822%E6%97%A5%20-%2009%3A15%3A52%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECPU%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20i.MX6Q%20rev1.2%EF%BC%8C792%20MHz%3C%2FP%3E%3CP%3EReset%20cause%3A%20POR%3C%2FP%3E%3CP%3E%E4%B8%BB%E6%9D%BF%EF%BC%9AMX6Q-SabreSD%3C%2FP%3E%3CP%3EDRAM%EF%BC%9A1%20GiB%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E7%BC%93%E5%AD%98%E6%9C%AA%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3EMMC%EF%BC%9AFSL_SDHC%EF%BC%9A0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%202012.10-00994-g7e6c682%EF%BC%882013%E5%B9%B42%E6%9C%8822%E6%97%A5%20-%2009%3A15%3A52%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECPU%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20i.MX6Q%20rev1.2%EF%BC%8C792%20MHz%3C%2FP%3E%3CP%3EReset%20cause%3A%20POR%3C%2FP%3E%3CP%3E%E4%B8%BB%E6%9D%BF%EF%BC%9AMX6Q-SabreSD%3C%2FP%3E%3CP%3EDRAM%EF%BC%9A1%20GiB%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E7%BC%93%E5%AD%98%E6%9C%AA%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3EMMC%EF%BC%9AFSL_SDHC%EF%BC%9A0%3C%2FP%3E%3CP%3E***%20%E8%AD%A6%E5%91%8A%20-%20CRC%20%E9%94%99%E8%AF%AF%EF%BC%8C%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%8E%AF%E5%A2%83%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%EF%BC%9A%E4%B8%B2%E8%A1%8C%3C%2FP%3E%3CP%3E%E8%BE%93%E5%87%BA%EF%BC%9A%E4%B8%B2%E8%A1%8C%3C%2FP%3E%3CP%3EErr%3A%26nbsp%3B%26nbsp%3B%20serial%3C%2FP%3E%3CP%3ENet%3A%26nbsp%3B%26nbsp%3B%20FEC%20%5BPRIME%5D%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9AFEC%20%E4%BD%BF%E7%94%A8%E6%9D%A5%E8%87%AA%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E7%9A%84%20MAC%20%E5%9C%B0%E5%9D%80%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%81%9C%E6%AD%A2%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%9A%200%3C%2FP%3E%3CP%3Emmc0%20is%20current%20device%3C%2FP%3E%3CP%3E%E8%AF%BB%E5%8F%96%20boot.scr%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E**%20%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E2%80%9Cboot.scr%E2%80%9D%E6%9D%A5%E8%87%AA%20mmc%200%3A1**%3C%2FP%3E%3CP%3E%E5%9D%8F%E7%9A%84%20MBR%20%E6%89%87%E5%8C%BA%E7%AD%BE%E5%90%8D%200x055a%3C%2FP%3E%3CP%3E**%20%E5%88%86%E5%8C%BA%201%20%E5%9C%A8%E8%AE%BE%E5%A4%87%200%20%E4%B8%8A%E6%97%A0%E6%95%88%20**%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E**%20%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%20mmc%200%3A1%20%E8%BF%9B%E8%A1%8C%20fatload%20**%3C%2FP%3E%3CP%3E%E4%BB%8E%E7%BD%91%E7%BB%9C%E5%90%AF%E5%8A%A8...%3C%2FP%3E%3CP%3EFEC%20%E7%AD%89%E5%BE%85%20PHY%20%E8%87%AA%E5%8A%A8%E5%8D%8F%E5%95%86%E5%AE%8C%E6%88%90.........%E8%B6%85%E6%97%B6%EF%BC%81%3C%2FP%3E%3CP%3EBOOTP%E5%B9%BF%E6%92%AD1%3C%2FP%3E%3CP%3EBOOTP%20%E5%B9%BF%E6%92%AD%202%3C%2FP%3E%3CP%3EBOOTP%20%E5%B9%BF%E6%92%AD%203%3C%2FP%3E%3CP%3EBOOTP%E5%B9%BF%E6%92%AD4%3C%2FP%3E%3CP%3EBOOTP%E5%B9%BF%E6%92%AD5%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%202012.10-00994-g7e6c682%EF%BC%882013%E5%B9%B42%E6%9C%8822%E6%97%A5%20-%2009%3A15%3A52%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECPU%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20i.MX6Q%20rev1.2%EF%BC%8C792%20MHz%3C%2FP%3E%3CP%3EReset%20cause%3A%20POR%3C%2FP%3E%3CP%3E%E4%B8%BB%E6%9D%BF%EF%BC%9AMX6Q-SabreSD%3C%2FP%3E%3CP%3EDRAM%EF%BC%9A1%20GiB%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E7%BC%93%E5%AD%98%E6%9C%AA%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3EMMC%EF%BC%9AFSL_SDHC%EF%BC%9A0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%202012.10-00994-g7e6c682%EF%BC%882013%E5%B9%B42%E6%9C%8822%E6%97%A5%20-%2009%3A15%3A52%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECPU%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20i.MX6Q%20rev1.2%EF%BC%8C792%20MHz%3C%2FP%3E%3CP%3EReset%20cause%3A%20POR%3C%2FP%3E%3CP%3E%E4%B8%BB%E6%9D%BF%EF%BC%9AMX6Q-SabreSD%3C%2FP%3E%3CP%3EDRAM%EF%BC%9A1%20GiB%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E7%BC%93%E5%AD%98%E6%9C%AA%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3EMMC%EF%BC%9AFSL_SDHC%EF%BC%9A0%3C%2FP%3E%3CP%3E***%20%E8%AD%A6%E5%91%8A%20-%20CRC%20%E9%94%99%E8%AF%AF%EF%BC%8C%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%8E%AF%E5%A2%83%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%EF%BC%9A%E4%B8%B2%E8%A1%8C%3C%2FP%3E%3CP%3E%E8%BE%93%E5%87%BA%EF%BC%9A%E4%B8%B2%E8%A1%8C%3C%2FP%3E%3CP%3EErr%3A%26nbsp%3B%26nbsp%3B%20serial%3C%2FP%3E%3CP%3ENet%3A%26nbsp%3B%26nbsp%3B%20FEC%20%5BPRIME%5D%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9AFEC%20%E4%BD%BF%E7%94%A8%E6%9D%A5%E8%87%AA%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E7%9A%84%20MAC%20%E5%9C%B0%E5%9D%80%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%81%9C%E6%AD%A2%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%9A%200%3C%2FP%3E%3CP%3Emmc0%20is%20current%20device%3C%2FP%3E%3CP%3E%E8%AF%BB%E5%8F%96%20boot.scr%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E**%20%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E2%80%9Cboot.scr%E2%80%9D%E6%9D%A5%E8%87%AA%20mmc%200%3A1**%3C%2FP%3E%3CP%3E%E8%AF%BB%E5%8F%96%20uImage%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%202012.10-00994-g7e6c682%EF%BC%882013%E5%B9%B42%E6%9C%8822%E6%97%A5%20-%2009%3A15%3A52%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECPU%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20i.MX6Q%20rev1.2%EF%BC%8C792%20MHz%3C%2FP%3E%3CP%3EReset%20cause%3A%20POR%3C%2FP%3E%3CP%3E%E4%B8%BB%E6%9D%BF%EF%BC%9AMX6Q-SabreSD%3C%2FP%3E%3CP%3EDRAM%EF%BC%9A1%20GiB%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E7%BC%93%E5%AD%98%E6%9C%AA%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3EMMC%EF%BC%9AFSL_SDHC%EF%BC%9A0%3C%2FP%3E%3CP%3E***%20%E8%AD%A6%E5%91%8A%20-%20CRC%20%E9%94%99%E8%AF%AF%EF%BC%8C%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%8E%AF%E5%A2%83%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%EF%BC%9A%E4%B8%B2%E8%A1%8C%3C%2FP%3E%3CP%3E%E8%BE%93%E5%87%BA%EF%BC%9A%E4%B8%B2%E8%A1%8C%3C%2FP%3E%3CP%3EErr%3A%26nbsp%3B%26nbsp%3B%20serial%3C%2FP%3E%3CP%3ENet%3A%26nbsp%3B%26nbsp%3B%20FEC%20%5BPRIME%5D%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9AFEC%20%E4%BD%BF%E7%94%A8%E6%9D%A5%E8%87%AA%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E7%9A%84%20MAC%20%E5%9C%B0%E5%9D%80%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%81%9C%E6%AD%A2%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%9A%200%3C%2FP%3E%3CP%3Emmc0%20is%20current%20device%3C%2FP%3E%3CP%3E%E8%AF%BB%E5%8F%96%20boot.scr%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E**%20%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E2%80%9Cboot.scr%E2%80%9D%E6%9D%A5%E8%87%AA%20mmc%200%3A1**%3C%2FP%3E%3CP%3E%E8%AF%BB%E5%8F%96%20uImage%3C%2FP%3E%3CP%3E%E8%AF%BB%E5%8F%96%E9%9B%86%E7%BE%A4%E6%97%B6%E5%87%BA%E9%94%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E**%20%E6%97%A0%E6%B3%95%E4%BB%8E%20mmc%200%3A1%20%E8%AF%BB%E5%8F%96%E2%80%9CuImage%E2%80%9D**%3C%2FP%3E%3CP%3E%E4%BB%8E%E7%BD%91%E7%BB%9C%E5%90%AF%E5%8A%A8...%3C%2FP%3E%3CP%3EFEC%20%E7%AD%89%E5%BE%85%20PHY%20%E8%87%AA%E5%8A%A8%E5%8D%8F%E5%95%86%E5%AE%8C%E6%88%90.........%E8%B6%85%E6%97%B6%EF%BC%81%3C%2FP%3E%3CP%3EBOOTP%E5%B9%BF%E6%92%AD1%3C%2FP%3E%3CP%3EBOOTP%20%E5%B9%BF%E6%92%AD%202%3C%2FP%3E%3CP%3EBOOTP%20%E5%B9%BF%E6%92%AD%203%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%202012.10-00994-g7e6c682%EF%BC%882013%E5%B9%B42%E6%9C%8822%E6%97%A5%20-%2009%3A15%3A52%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECPU%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20i.MX6Q%20rev1.2%EF%BC%8C792%20MHz%3C%2FP%3E%3CP%3EReset%20cause%3A%20POR%3C%2FP%3E%3CP%3E%E4%B8%BB%E6%9D%BF%EF%BC%9AMX6Q-SabreSD%3C%2FP%3E%3CP%3EDRAM%EF%BC%9A1%20GiB%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E7%BC%93%E5%AD%98%E6%9C%AA%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3EMMC%EF%BC%9AFSL_SDHC%EF%BC%9A0%3C%2FP%3E%3CP%3E***%20%E8%AD%A6%E5%91%8A%20-%20CRC%20%E9%94%99%E8%AF%AF%EF%BC%8C%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%8E%AF%E5%A2%83%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%EF%BC%9A%E4%B8%B2%E8%A1%8C%3C%2FP%3E%3CP%3E%E8%BE%93%E5%87%BA%EF%BC%9A%E4%B8%B2%E8%A1%8C%3C%2FP%3E%3CP%3EErr%3A%26nbsp%3B%26nbsp%3B%20serial%3C%2FP%3E%3CP%3ENet%3A%26nbsp%3B%26nbsp%3B%20FEC%20%5BPRIME%5D%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9AFEC%20%E4%BD%BF%E7%94%A8%E6%9D%A5%E8%87%AA%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E7%9A%84%20MAC%20%E5%9C%B0%E5%9D%80%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%81%9C%E6%AD%A2%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%9A%200%3C%2FP%3E%3CP%3Emmc0%20is%20current%20device%3C%2FP%3E%3CP%3E%E8%AF%BB%E5%8F%96%20boot.scr%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E**%20%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E2%80%9Cboot.scr%E2%80%9D%E6%9D%A5%E8%87%AA%20mmc%200%3A1**%3C%2FP%3E%3CP%3E%E8%AF%BB%E5%8F%96%20uImage%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%202012.10-00994-g7e6c682%EF%BC%882013%E5%B9%B42%E6%9C%8822%E6%97%A5%20-%2009%3A15%3A52%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECPU%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20i.MX6Q%20rev1.2%EF%BC%8C792%20MHz%3C%2FP%3E%3CP%3EReset%20cause%3A%20POR%3C%2FP%3E%3CP%3E%E4%B8%BB%E6%9D%BF%EF%BC%9AMX6Q-SabreSD%3C%2FP%3E%3CP%3EDRAM%EF%BC%9A1%20GiB%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E7%BC%93%E5%AD%98%E6%9C%AA%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3EMMC%EF%BC%9AFSL_SDHC%EF%BC%9A0%3C%2FP%3E%3CP%3E***%20%E8%AD%A6%E5%91%8A%20-%20CRC%20%E9%94%99%E8%AF%AF%EF%BC%8C%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%8E%AF%E5%A2%83%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%EF%BC%9A%E4%B8%B2%E8%A1%8C%3C%2FP%3E%3CP%3E%E8%BE%93%E5%87%BA%EF%BC%9A%E4%B8%B2%E8%A1%8C%3C%2FP%3E%3CP%3EErr%3A%26nbsp%3B%26nbsp%3B%20serial%3C%2FP%3E%3CP%3ENet%3A%26nbsp%3B%26nbsp%3B%20FEC%20%5BPRIME%5D%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9AFEC%20%E4%BD%BF%E7%94%A8%E6%9D%A5%E8%87%AA%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E7%9A%84%20MAC%20%E5%9C%B0%E5%9D%80%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%81%9C%E6%AD%A2%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%9A%200%3C%2FP%3E%3CP%3Emmc0%20is%20current%20device%3C%2FP%3E%3CP%3E%E8%AF%BB%E5%8F%96%20boot.scr%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E**%20%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E2%80%9Cboot.scr%E2%80%9D%E6%9D%A5%E8%87%AA%20mmc%200%3A1**%3C%2FP%3E%3CP%3E%E8%AF%BB%E5%8F%96%20uImage%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%202012.10-00994-g7e6c682%EF%BC%882013%E5%B9%B42%E6%9C%8822%E6%97%A5%20-%2009%3A15%3A52%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECPU%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20i.MX6Q%20rev1.2%EF%BC%8C792%20MHz%3C%2FP%3E%3CP%3EReset%20cause%3A%20POR%3C%2FP%3E%3CP%3E%E4%B8%BB%E6%9D%BF%EF%BC%9AMX6Q-SabreSD%3C%2FP%3E%3CP%3EDRAM%EF%BC%9A1%20GiB%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E7%BC%93%E5%AD%98%E6%9C%AA%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3EMMC%EF%BC%9AFSL_SDHC%EF%BC%9A0%3C%2FP%3E%3CP%3E***%20%E8%AD%A6%E5%91%8A%20-%20CRC%20%E9%94%99%E8%AF%AF%EF%BC%8C%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%8E%AF%E5%A2%83%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%EF%BC%9A%E4%B8%B2%E8%A1%8C%3C%2FP%3E%3CP%3E%E8%BE%93%E5%87%BA%EF%BC%9A%E4%B8%B2%E8%A1%8C%3C%2FP%3E%3CP%3EErr%3A%26nbsp%3B%26nbsp%3B%20serial%3C%2FP%3E%3CP%3ENet%3A%26nbsp%3B%26nbsp%3B%20FEC%20%5BPRIME%5D%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9AFEC%20%E4%BD%BF%E7%94%A8%E6%9D%A5%E8%87%AA%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%E7%9A%84%20MAC%20%E5%9C%B0%E5%9D%80%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8C%89%E4%BB%BB%E6%84%8F%E9%94%AE%E5%81%9C%E6%AD%A2%E8%87%AA%E5%8A%A8%E5%90%AF%E5%8A%A8%EF%BC%9A%200%3C%2FP%3E%3CP%3Emmc0%20is%20current%20device%3C%2FP%3E%3CP%3E**%20%E6%97%A0%E5%88%86%E5%8C%BA%E8%A1%A8%20-%20mmc%200%20**%3C%2FP%3E%3CP%3E**%20%E6%97%A0%E5%88%86%E5%8C%BA%E8%A1%A8%20-%20mmc%200%20**%3C%2FP%3E%3CP%3E%E4%BB%8E%E7%BD%91%E7%BB%9C%E5%90%AF%E5%8A%A8...%3C%2FP%3E%3CP%3EFEC%20%E7%AD%89%E5%BE%85%20PHY%20%E8%87%AA%E5%8A%A8%E5%8D%8F%E5%95%86%E5%AE%8C%E6%88%90.........%E8%B6%85%E6%97%B6%EF%BC%81%3C%2FP%3E%3CP%3EBOOTP%E5%B9%BF%E6%92%AD1%3C%2FP%3E%3CP%3EBOOTP%20%E5%B9%BF%E6%92%AD%202%3C%2FP%3E%3CP%3EBOOTP%20%E5%B9%BF%E6%92%AD%203%3C%2FP%3E%3CP%3EBOOTP%E5%B9%BF%E6%92%AD4%3C%2FP%3E%3CP%3EBOOTP%E5%B9%BF%E6%92%AD5%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%87%8D%E8%AF%95%E6%AC%A1%E6%95%B0%E5%B7%B2%E8%B6%85%E5%87%BA%EF%BC%9B%E9%87%8D%E6%96%B0%E5%BC%80%E5%A7%8B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%AF%B7%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%8C%85%E5%90%AB%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E5%92%8C%E4%B8%80%E4%BA%9B%E6%97%A5%E5%BF%97%E7%9A%84%E6%96%B0%E4%B8%BB%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%20yocto%20%E4%B8%8A%E8%AE%BE%E7%BD%AE%E5%B7%A5%E5%85%B7%E9%93%BE%E5%BE%88%E5%AE%B9%E6%98%93%EF%BC%8C%E4%BD%86%E5%B9%B6%E9%9D%9E%E6%98%93%E4%BA%8B%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E7%9B%B8%E4%BF%A1%E5%AF%B9%E4%BA%8E%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E5%AF%BB%E6%89%BE%E5%AE%83%E7%9A%84%E4%BA%BA%E6%9D%A5%E8%AF%B4%EF%BC%8C%E6%96%B0%E7%9A%84%E8%AE%A8%E8%AE%BA%E5%B0%86%E6%9B%B4%E6%9C%89%E6%9D%A1%E7%90%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%EF%BC%8Cotavio%20%E5%8F%91%E5%B8%83%E7%9A%84%E8%A1%A5%E4%B8%81%E5%B7%B2%E7%BB%8F%E9%9B%86%E6%88%90%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%A6%82%E6%9E%9C%E6%82%A8%20repo%20%E5%90%8C%E6%AD%A5%E6%82%A8%E7%9A%84%20danny%20%E5%88%86%E6%94%AF%EF%BC%8C%E6%82%A8%E5%B0%86%E8%83%BD%E5%A4%9F%E8%8E%B7%E5%8F%96%E8%A1%A5%E4%B8%81%E5%B9%B6%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%EF%BC%8C%E8%80%8C%E6%97%A0%E9%9C%80%E6%89%A7%E8%A1%8C%E5%85%B6%E4%BB%96%E6%AD%A5%E9%AA%A4%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%88%9B%E5%BB%BA%E4%BA%86%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E8%AF%B7%E4%B8%8E%E6%88%91%E5%88%86%E4%BA%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110870%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110870%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%9C%A8%E4%BD%BF%E7%94%A8%20Yocto%20%E8%AE%BE%E7%BD%AE%E5%B7%A5%E5%85%B7%E9%93%BE%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E5%9B%B0%E9%9A%BE%E3%80%82%E4%BB%BB%E4%BD%95%E5%BB%BA%E8%AE%AE%E9%83%BD%E4%BC%9A%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110869%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110869%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%BC%9A%E5%B0%9D%E8%AF%95%E4%B8%80%E4%B8%8B%E5%B9%B6%E5%90%91%E6%82%A8%E5%8F%8D%E9%A6%88%E6%9C%80%E6%96%B0%E8%BF%9B%E5%B1%95%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BF%AE%E8%AE%A2%E7%89%88%E6%9C%AC%E4%B8%BA%EF%BC%9AREV%20C2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110867%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110867%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%E6%88%91%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%89%80%E9%9C%80%E6%9B%B4%E6%94%B9%E7%9A%84%E7%A7%BB%E6%A4%8D%E3%80%82%E4%BD%A0%E8%83%BD%E5%B0%9D%E8%AF%95%E4%B8%80%E4%B8%8B%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%81%9A%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%24%3A%20git%20clone%20--branch%20patch-2012.10%20git%3A%2F%2Fgithub.com%2FFreescale%2Fu-boot-imx.git%20u-boot-imx%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BA%94%E7%94%A8%E8%A1%A5%E4%B8%81%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fdownload.ossystems.com.br%2F~otavio%2Fu-boot-patches%2F2012.10%2F0001-COMMON-Add-__stringify-function.patch%22%20title%3D%22http%3A%2F%2Fdownload.ossystems.com.br%2F~otavio%2Fu-boot-patches%2F2012.10%2F0001-COMMON-Add-__stringify-function.patch%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fdownload.ossystems.com.br%2F~otavio%2Fu-boot-patches%2F2012.10%2F0001-COMMON-Add-__stringify-function.patch%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fdownload.ossystems.com.br%2F~otavio%2Fu-boot-patches%2F2012.10%2F0002-mx6-Disable-Power-Down-Bit-of-watchdog.patch%22%20title%3D%22http%3A%2F%2Fdownload.ossystems.com.br%2F~otavio%2Fu-boot-patches%2F2012.10%2F0002-mx6-Disable-Power-Down-Bit-of-watchdog.patch%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fdownload.ossystems.com.br%2F~otavio%2Fu-boot-patches%2F2012.10%2F0002-mx6-Disable-Power-Down-Bit-of-watchdog.patch%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fdownload.ossystems.com.br%2F~otavio%2Fu-boot-patches%2F2012.10%2F0003-Backport-environment-changes-from-patches-2013.01.patch%22%20title%3D%22http%3A%2F%2Fdownload.ossystems.com.br%2F~otavio%2Fu-boot-patches%2F2012.10%2F0003-Backport-environment-changes-from-patches-2013.01.patch%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fdownload.ossystems.com.br%2F~otavio%2Fu-boot-patches%2F2012.10%2F0003-Backport-environment-changes-from-patches-2013.01.p%E2%80%A6%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B9%B6%E8%AE%BE%E7%BD%AE%E6%82%A8%E7%9A%84%E5%B7%A5%E5%85%B7%E9%93%BE%E3%80%82%E6%9E%84%E5%BB%BA%EF%BC%9Au-boot.imx%20%E5%B9%B6%E5%B0%86%E5%85%B6%E6%94%BE%E5%85%A5%20SD%20%E5%8D%A1%E4%B8%AD%E3%80%82%E6%88%91%E5%B8%8C%E6%9C%9B%E5%AE%83%E8%83%BD%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E5%90%91%E6%88%91%E7%A1%AE%E8%AE%A4%EF%BC%8C%E6%88%91%E5%B0%86%E8%83%BD%E5%A4%9F%E6%8E%A8%E5%8A%A8%E5%AE%83%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%88%91%E4%BB%AC%E5%9C%A8%E4%B8%B9%E5%B0%BC%E4%B8%AD%E4%BF%AE%E5%A4%8D%E5%AE%83%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%98%AF%E4%BF%AE%E8%AE%A2%E7%89%88%20C%EF%BC%8C%E5%88%99%E5%8F%AF%E8%83%BD%E6%98%AF%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%EF%BC%9B%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%86%20U-Boot%20%E4%B8%BB%E7%BA%BF%E7%9A%84%E4%BF%AE%E5%A4%8D%E7%A8%8B%E5%BA%8F%E5%8F%8D%E5%90%91%E7%A7%BB%E6%A4%8D%E5%88%B0%202012.10%EF%BC%8C%E5%AE%8C%E6%88%90%E5%90%8E%E4%BC%9A%E5%8F%91%E5%B8%83%E6%8F%90%E9%86%92%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110865%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110865%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%BF%85%E9%A1%BB%E5%B0%B1%E6%AD%A4%E4%BA%8B%E5%9B%9E%E5%A4%8D%E6%82%A8%E3%80%82%E6%88%91%E7%A1%AE%E5%AE%9E%E7%9F%A5%E9%81%93%E7%9B%92%E5%AD%90%E5%A4%96%E9%9D%A2%E6%9C%89%E5%9B%BE%E5%83%8F%EF%BC%8C%E8%80%8C%E6%97%A9%E6%9C%9F%E7%9A%84%20SDP%20%E6%B2%A1%E6%9C%89%E7%9B%92%E5%AD%90%E5%9B%BE%E5%83%8F%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9F%A5%E9%81%93%E8%BF%99%E6%B2%A1%E6%9C%89%E5%A4%9A%E5%A4%A7%E5%B8%AE%E5%8A%A9%EF%BC%8C%E4%BD%86%E6%88%91%E4%BC%9A%E5%9C%A8%E4%BB%8A%E5%A4%A9%E6%99%9A%E4%BA%9B%E6%97%B6%E5%80%99%E7%BB%99%E4%BD%A0%E4%B8%80%E4%B8%AA%E6%9B%B4%E5%A5%BD%E7%9A%84%E7%AD%94%E6%A1%88%E3%80%82%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8C%E5%AE%83%E8%BF%98%E5%BE%88%E6%96%B0%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110864%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110864%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%AF%EF%BC%9B%E4%BD%A0%E7%9A%84%E4%B8%BB%E6%9D%BF%E7%89%88%E6%9C%AC%E6%98%AF%E5%A4%9A%E5%B0%91%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Otavio%2C%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E7%AD%94%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E4%B8%8A%E9%9D%A2%E7%9A%84%E8%AF%B4%E6%98%8E%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%9C%20%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3Esudo%20dd%20if%3Drootfs_builder%2Fbuild%2Ftmp%2Fdeploy%2Fimages%2Ffsl-image-test.sdcard%20of%3D%2Fdev%2Fsdb%3C%2FSPAN%3E%20%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AE%83%E4%BC%BC%E4%B9%8E%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%E3%80%82%E5%9C%A8%E6%AD%A4%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E6%AF%AB%E6%97%A0%E9%97%AE%E9%A2%98%E5%9C%B0%E8%8E%B7%E5%8F%96%E6%88%91%E7%9A%84%20ltib%20%E5%9B%BE%E5%83%8F%E5%92%8C%20ubuntu%20RFS%E3%80%82%20%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%B0%9D%E8%AF%95%20Yocto%E3%80%82%E6%89%80%E4%BB%A5%E6%88%91%E5%B8%8C%E6%9C%9B%E6%88%91%E6%B2%A1%E6%9C%89%E9%94%99%E8%BF%87%E4%BB%BB%E4%BD%95%E4%B8%9C%E8%A5%BF%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110862%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110862%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%BF%E5%85%B6%E5%B7%A5%E4%BD%9C%E7%9A%84%E6%9C%80%E7%AE%80%E5%8D%95%E6%96%B9%E6%B3%95%E6%98%AF%E6%B7%BB%E5%8A%A0%20tmp%2Fdeploy%2Fimages%2F%3CIMAGE%3E.sdcard%E6%96%87%E4%BB%B6%E7%9B%B4%E6%8E%A5%E4%B8%8A%E4%BC%A0%E5%88%B0%E6%82%A8%E7%9A%84%E8%AE%BE%E5%A4%87%E4%B8%8A%E3%80%82%3C%2FIMAGE%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A6%81%E6%B7%BB%E5%8A%A0%20u-boot.imx%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%8C%E6%82%A8%E5%BA%94%E8%AF%A5%E9%81%BF%E5%85%8D%20skip%3D2%EF%BC%88%E5%9B%A0%E4%B8%BA%20u-boot.imx%20%E6%B2%A1%E6%9C%89%E5%A1%AB%E5%85%85%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110861%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110861%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%89%E4%BA%BA%E6%9C%89%E5%90%AF%E5%8A%A8%20SD%20%E5%8D%A1%E7%9A%84%E6%8A%80%E5%B7%A7%E5%90%97%EF%BC%9F%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E9%9A%8F%E9%99%84%E7%9A%84%20uboot%EF%BC%8C%E5%B9%B6%E5%B0%9D%E8%AF%95%E4%BA%86%E5%B7%B2%E7%9F%A5%E8%89%AF%E5%A5%BD%E7%9A%84%E5%91%BD%E4%BB%A4%2F%E4%B8%8E%20ltib%20%E7%94%9F%E6%88%90%E7%9A%84%20SD%20%E5%8D%A1%E7%B1%BB%E4%BC%BC%E7%9A%84%E5%91%BD%E4%BB%A4%E3%80%82%E7%84%B6%E8%80%8C%EF%BC%8C%E8%BF%84%E4%BB%8A%E4%B8%BA%E6%AD%A2%E8%BF%98%E6%B2%A1%E6%9C%89%E8%BF%90%E6%B0%94%E3%80%82%20%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E8%BF%90%E8%A1%8C%E5%8D%A1%EF%BC%88%E7%9B%B4%E6%8E%A5%E5%88%BB%E5%BD%95%EF%BC%89%E6%97%B6%EF%BC%8C%E6%88%91%E4%BC%9A%E5%9C%A8%E5%8A%A0%E8%BD%BD%20uImage%20%E6%97%B6%E9%81%87%E5%88%B0%E5%81%9C%E9%A1%BF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BB%80%E4%B9%88%E6%83%B3%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E4%BD%BF%E7%94%A8%E4%B8%BB%E5%88%86%E6%94%AF%E8%BF%9B%E8%A1%8C%E5%B7%A5%E4%BD%9C%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%96%E8%80%85%E8%BF%99%E6%98%AF%E9%94%99%E8%AF%AF%E6%9C%80%E5%A4%9A%E7%9A%84%E7%89%88%E6%9C%AC%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%81%9A%E8%8B%AF%E4%B9%99%E7%83%AF%E6%88%91%E7%9A%84%E4%B8%BB%E6%9D%BF%E6%98%AFSabreSDP%EF%BC%8CIMX6%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110860%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110860%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%88%9A%E5%88%9A%E5%9C%A8%E8%BF%99%E9%87%8C%E5%81%9A%E4%BA%86%E4%B8%80%E4%B8%AA%E6%96%B0%E6%B5%8B%E8%AF%95%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E~%2Ftest%25%20repo%20init%20-u%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%3C%2FA%3E%20%3CSPAN%3E-b%20danny%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EGet%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fgerrit.googlesource.com%2Fgit-repo%2Fclone.bundle%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgerrit.googlesource.com%2Fgit-repo%2Fclone.bundle%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%8E%B7%E5%8F%96%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%3C%2FA%3E%3C%2FP%3E%3CP%3E%25%20%E6%80%BB%E8%AE%A1%20%25%20%E5%B7%B2%E6%8E%A5%E6%94%B6%20%25%20%E8%BD%AC%E8%BF%90%20%E5%B9%B3%E5%9D%87%E9%80%9F%E5%BA%A6%20%E6%97%B6%E9%97%B4%20%E6%97%B6%E9%97%B4%20%E6%97%B6%E9%97%B4%20%E5%BD%93%E5%89%8D%3C%2FP%3E%3CP%3E%E4%B8%8B%E8%BD%BD%20%E4%B8%8A%E4%BC%A0%20%E6%80%BB%E8%80%97%E6%97%B6%20%E5%89%A9%E4%BD%99%E9%80%9F%E5%BA%A6%3C%2FP%3E%3CP%3E0%200%200%200%200%200%200%200%20--%3A--%3A--%200%3A00%3A09%20--%3A--%3A--%200%3C%2FP%3E%3CP%3Ecurl%EF%BC%9A%EF%BC%8822%EF%BC%89%E8%AF%B7%E6%B1%82%E7%9A%84%20URL%20%E8%BF%94%E5%9B%9E%E9%94%99%E8%AF%AF%EF%BC%9A404%20%E6%9C%AA%E6%89%BE%E5%88%B0%3C%2FP%3E%3CP%3E%E6%9C%8D%E5%8A%A1%E5%99%A8%E4%B8%8D%E6%8F%90%E4%BE%9Bclone.bundle%EF%BC%9B%E5%BF%BD%E7%95%A5%E3%80%82%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9Agnome-keyring%3A%3A%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%E5%88%B0%EF%BC%9A%2Frun%2Fuser%2Fotavio%2Fkeyring-q0sd1e%2Fpkcs11%EF%BC%9A%E6%B2%A1%E6%9C%89%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FP%3E%3CP%3E%E8%BF%9C%E7%A8%8B%EF%BC%9A%E8%AE%A1%E6%95%B0%E5%AF%B9%E8%B1%A1%EF%BC%9A69%EF%BC%8C%E5%AE%8C%E6%88%90%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%9C%E7%A8%8B%EF%BC%9A%E5%8E%8B%E7%BC%A9%E5%AF%B9%E8%B1%A1%EF%BC%9A100%25%20(63%2F63)%EF%BC%8C%E5%AE%8C%E6%88%90%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%9C%E7%A8%8B%EF%BC%9A%E6%80%BB%E8%AE%A1%2069%EF%BC%88%E5%A2%9E%E9%87%8F%2021%EF%BC%89%EF%BC%8C%E9%87%8D%E7%94%A8%2053%EF%BC%88%E5%A2%9E%E9%87%8F%205%EF%BC%89%3C%2FP%3E%3CP%3E%E6%8B%86%E5%BC%80%E7%89%A9%E4%BD%93%EF%BC%9A100%25%20(69%2F69)%EF%BC%8C%E5%AE%8C%E6%88%90%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%9D%A5%E8%87%AA%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%3C%2FA%3E%3C%2FP%3E%3CP%3E*%20%5B%E6%96%B0%E5%88%86%E6%94%AF%5D%20danny%20-%26gt%3B%20origin%2Fdanny%3C%2FP%3E%3CP%3E*%20%5B%E6%96%B0%E5%88%86%E6%94%AF%5D%20denzil%20-%26gt%3B%20origin%2Fdenzil%3C%2FP%3E%3CP%3E*%20%5B%E6%96%B0%E5%88%86%E6%94%AF%5D%20master%20-%26gt%3B%20origin%2Fmaster%3C%2FP%3E%3CP%3E*%20%5B%E6%96%B0%E6%A0%87%E7%AD%BE%5D%201.2-%26gt%3B%201.2%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%82%A8%E7%9A%84%E8%BA%AB%E4%BB%BD%E6%98%AF%EF%BC%9AOtavio%20Salvador%20%26lt%3B%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Aotavio%40ossystems.com.br%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eotavio%40ossystems.com.br%3C%2FA%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E6%9B%B4%E6%94%B9%E6%AD%A4%E8%AE%BE%E7%BD%AE%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%20--config-name%20%E9%87%8D%E6%96%B0%E8%BF%90%E8%A1%8C%E2%80%9Crepo%20init%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Erepo%20%E5%9C%A8%20%2Fhome%2Fotavio%2Ftest%20%E4%B8%AD%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%89%80%E4%BB%A5%E8%BF%99%E6%98%BE%E7%84%B6%E6%98%AF%E4%BD%A0%E8%BA%AB%E8%BE%B9%E7%9A%84%E4%B8%9C%E8%A5%BF%E3%80%82%E6%88%91%E6%9B%BE%E7%BB%8F%E5%9B%A0%E4%B8%BA%E5%8D%B7%E6%9B%B2%E9%97%AE%E9%A2%98%E8%80%8C%E9%81%87%E5%88%B0%E8%BF%87%E9%97%AE%E9%A2%98%E3%80%82'repo'%20%E4%BD%BF%E7%94%A8%20curl%20%E6%9D%A5%E8%8E%B7%E5%8F%96%E4%B8%80%E4%BA%9B%E4%B8%9C%E8%A5%BF%EF%BC%88git%20%E4%B9%9F%E8%BF%99%E4%B9%88%E5%81%9A%EF%BC%89%EF%BC%8C%E6%89%80%E4%BB%A5%E4%B9%9F%E8%AE%B8%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%8D%87%E7%BA%A7%20curl%20%E5%B9%B6%E5%B0%9D%E8%AF%95%E4%B8%80%E4%B8%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110859%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110859%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20OtavioSalvador%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20Ubuntu%209.04%20Jaunty%E3%80%82%E5%86%85%E6%A0%B8%E4%B8%BA%202.6.28-11-generic%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%8C%9C%E8%AF%A5%E7%BD%91%E5%9D%80%E5%9C%A8%E5%8D%B0%E5%BA%A6%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B8%A9%E6%96%AF%E9%A1%BF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110858%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110858%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Daiane%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E5%86%8D%E6%AC%A1%E5%B0%9D%E8%AF%95%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E4%BA%8B%E6%83%85..%E5%8D%B3%E4%BD%BF%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2F%3C%2FA%3E%3CSPAN%3E%E4%BD%86%E9%97%AE%E9%A2%98%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%20%E5%BD%93%E6%88%91%E4%BB%8E%E6%B5%8F%E8%A7%88%E5%99%A8%E5%B0%9D%E8%AF%95%E6%97%B6%EF%BC%8C%E6%88%91%E4%B9%9F%E6%94%B6%E5%88%B0%E4%BA%86%E7%9B%B8%E5%90%8C%E7%9A%84%E6%B6%88%E6%81%AF%E3%80%82%EF%BC%88%E9%99%84%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%EF%BC%89%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117542iD80A3C7535A5C3B8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot.png%22%20alt%3D%22Screenshot.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%20%E6%88%91%E6%9D%A5%E8%87%AA%E5%8D%B0%E5%BA%A6...%E9%82%A3%E4%B9%88%E8%AF%A5%E7%BD%91%E9%A1%B5%E5%9C%A8%E5%8D%B0%E5%BA%A6%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%E6%B8%A9%E6%96%AF%E9%A1%BF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110857%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110857%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%99%A4%E4%BA%86%20Daiane%20%E8%A6%81%E6%B1%82%E6%82%A8%E8%BF%9B%E8%A1%8C%E7%9A%84%E6%B5%8B%E8%AF%95%E4%B9%8B%E5%A4%96%EF%BC%8C%E8%AF%B7%E6%8F%90%E4%BE%9B%E6%9C%89%E5%85%B3%E6%82%A8%E7%9A%84%E4%B8%BB%E6%9C%BA%E7%B3%BB%E7%BB%9F%E7%9A%84%E6%9B%B4%E5%A4%9A%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20*%20%E5%88%86%E9%85%8D%3C%2FP%3E%3CP%3E%20*%20%E7%89%88%E6%9C%AC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%88%9A%E5%88%9A%E5%9C%A8%E8%BF%99%E9%87%8C%E5%B0%9D%E8%AF%95%E8%BF%87%EF%BC%8C%E5%AE%83%E7%A1%AE%E5%AE%9E%E6%9C%89%E6%95%88%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%86%8D%E6%B5%8B%E8%AF%95%E4%B8%80%E4%B8%8B%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E5%86%8D%E6%AC%A1%E9%81%87%E5%88%B0%E9%94%99%E8%AF%AF%EF%BC%8C%E8%AF%B7%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E6%B5%8F%E8%A7%88%E5%99%A8%E8%AE%BF%E9%97%AE%E8%AF%A5%E7%BD%91%E9%A1%B5%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A1%AE%E4%BF%9D%E6%82%A8%E7%9A%84%E4%BB%A3%E7%90%86%E5%85%81%E8%AE%B8%E6%AD%A4%E6%93%8D%E4%BD%9C%E3%80%82%EF%BC%88%E8%AF%B7%E4%BB%94%E7%BB%86%E6%A3%80%E6%9F%A5%E6%82%A8%E6%98%AF%E5%90%A6%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20http%20%E6%88%96%20https%20%E4%BB%A3%E7%90%86%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110855%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110855%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD....%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E5%9F%BA%E6%9C%AC%E9%94%99%E8%AF%AF......%E7%9C%8B%E8%B5%B7%E6%9D%A5%20repo%20%E6%89%BE%E4%B8%8D%E5%88%B0%E7%BD%91%E9%A1%B5%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eroot%40LinuxRig%3A%2Fhome%2Fwintu%2FYOCTO%23%20repo%20init%20-u%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%3C%2FA%3E%20%3CSPAN%3E-b%20danny%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E...%20%E6%96%B0%E7%9A%84%20repo%20%E5%91%BD%E4%BB%A4%EF%BC%881.18%EF%BC%89%E5%8F%AF%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E...%E6%82%A8%E5%BA%94%E8%AF%A5%E5%B0%BD%E5%BF%AB%E5%8D%87%E7%BA%A7%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cp%20%2Fhome%2Fwintu%2FYOCTO%2F.repo%2Frepo%2Frepo%20%2Fbin%2Frepo%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%87%B4%E5%91%BD%EF%BC%9A%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%2Finfo%2Frefs%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%2Finfo%2Frefs%3C%2FA%3E%3CSPAN%3E%E4%B8%8B%E8%BD%BD%E9%94%99%E8%AF%AF%20-%20%E8%AF%B7%E6%B1%82%E7%9A%84%20URL%20%E8%BF%94%E5%9B%9E%E9%94%99%E8%AF%AF%EF%BC%9A403%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%87%B4%E5%91%BD%EF%BC%9A%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%2Finfo%2Frefs%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%2Finfo%2Frefs%3C%2FA%3E%3CSPAN%3E%E4%B8%8B%E8%BD%BD%E9%94%99%E8%AF%AF%20-%20%E8%AF%B7%E6%B1%82%E7%9A%84%20URL%20%E8%BF%94%E5%9B%9E%E9%94%99%E8%AF%AF%EF%BC%9A403%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%E6%9C%89%E4%BB%BB%E4%BD%95%E5%B8%AE%E5%8A%A9%E5%90%97....%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110854%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110854%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%8F%91%E7%8E%B0%E5%9C%A8%20ubuntu%20%E4%B8%8A%20git%20%E5%8F%AF%E8%83%BD%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BB%8E%E8%80%8C%E5%AF%BC%E8%87%B4%E6%AD%A4%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Esudo%20apt-add-repository%20ppa%3Agit-core%2Fppa%3C%2FP%3E%3CP%3Esudo%20apt-get%20update%3C%2FP%3E%3CP%3Esudo%20apt-get%20install%20git%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E5%90%8E%EF%BC%8C%E6%97%A0%E8%AE%BA%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20https%20%E8%BF%98%E6%98%AF%20http%20%E9%83%BD%E6%97%A0%E6%89%80%E8%B0%93%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110853%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110853%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%88%9A%E5%88%9A%E5%9C%A8%E6%88%91%E7%9A%84%E8%AE%A1%E7%AE%97%E6%9C%BA%E4%B8%8A%E5%B0%9D%E8%AF%95%E8%BF%87%EF%BC%8C%E5%AE%83%E7%A1%AE%E5%AE%9E%E5%8F%AF%E4%BB%A5%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E8%BF%99%E4%B8%AA%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3Erepo%20init%20-u%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%22%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233778c7%3B%20background-color%3A%20%23ffffff%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%3C%2FA%3E%20%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E-b%20master%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%80%8C%E4%B8%8D%E6%98%AF%20https%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%82%A8%E8%83%BD%E5%86%8D%E8%AF%95%E4%B8%80%E6%AC%A1%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E4%B9%9F%E6%9C%89%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E.%2Frepo%20sync%20-j2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E7%94%B1%E4%BA%8E%20gc%20%E9%94%99%E8%AF%AF%E8%80%8C%E9%80%80%E5%87%BA%E5%90%8C%E6%AD%A5%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%88%91%E7%9A%84%E4%BB%A3%E7%90%86%E8%AE%BE%E7%BD%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Efaisal%40faisal-desktop%3A~%24%20set%20%7C%20grep%20-i%20proxy%3C%2FP%3E%3CP%3Eurl%20%E4%BB%A3%E7%90%86%E8%8E%B7%E5%8F%96%E6%8E%A8%E9%80%81%E9%95%9C%E5%83%8F%20skipDefaultUpdate%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20core.gitProxy%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20http.proxy%3C%2FP%3E%3CP%3ECOMPREPLY%3D(%24(%20compgen%20-W%20%22%24opts%20--percent%20--force%20--test%20--replacepkgs%20--replacefiles%20--root%20--excludedocs%20--includedocs%20--noscripts%20--ignorearch%20--dbpath%20--prefix%20--ignoreos%20--nodeps%20--allfiles%20--ftpproxy%20--ftpport%20--justdb%20--httpproxy%20--httpport%20--noorder%20--relocate%20--badreloc%20--notriggers%20--excludepath%20--ignoresize%20--oldpackage%20--queryformat%20--repackage%20--nosuggests%22%20--%20%22%24cur%22%20))%3B%3C%2FP%3E%3CP%3ECOMPREPLY%3D(%24(%20compgen%20-W%20%22%24opts%20--ftpport%20--ftpproxy%20--httpport%20--httpproxy%22%20--%20%22%24cur%22%20))%3B%3C%2FP%3E%3CP%3EPreferredAuthentications%20%E5%8D%8F%E8%AE%AE%E4%BB%A3%E7%90%86%E5%91%BD%E4%BB%A4%20%5C%3C%2FP%3E%3CP%3Efaisal%40faisal-desktop%3A~%24%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110851%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110851%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E5%8F%91%E7%94%9F%E5%9C%A8%E5%90%8C%E6%AD%A5%E6%9C%9F%E9%97%B4%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%9C%89%E4%BB%A3%E7%90%86%E4%BA%BA%E5%90%97%EF%BC%9F%E4%BD%A0%E8%83%BD%E8%AE%BF%E9%97%AE%20https%20%E8%BF%98%E6%98%AF%E5%8F%AA%E8%83%BD%E8%AE%BF%E9%97%AE%20http%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110850%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110850%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E.%2Frepo%20sync%20-j2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E7%94%B1%E4%BA%8E%20gc%20%E9%94%99%E8%AF%AF%E8%80%8C%E9%80%80%E5%87%BA%E5%90%8C%E6%AD%A5%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E6%88%91%E5%8F%AA%E7%9C%8B%E5%88%B0%E4%B8%80%E4%B8%AA%20repo%20%E6%96%87%E4%BB%B6%E5%92%8C%E4%B8%80%E4%B8%AA%20.repo%E7%9B%AE%E5%BD%95%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110849%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110849%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%AE%8C%E5%85%A8%E6%8C%89%E7%85%A7%E6%95%99%E7%A8%8B%E4%B8%AD%E7%9A%84%E7%9B%AE%E5%BD%95%E6%96%B9%E6%B3%95%E6%93%8D%E4%BD%9C%EF%BC%8C%E5%88%99%E9%9C%80%E8%A6%81%E4%BD%8D%E4%BA%8E%E2%80%9Crootfs_builder%E2%80%9D%E4%B8%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%EF%BC%9A%3C%2FP%3E%3CP%3E%24%20cd%20rootfs_builder%3C%2FP%3E%3CP%3E%24%20ls%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%BF%85%E9%A1%BB%E5%B0%86%E5%AE%89%E8%A3%85%E7%8E%AF%E5%A2%83%E8%A7%86%E4%B8%BA%E6%96%87%E6%9C%AC%E6%96%87%E4%BB%B6%EF%BC%88%E4%BB%A5%E5%8F%8A%20repo%20%E5%92%8C%20README%20%E5%92%8C%E7%9B%AE%E5%BD%95%E6%BA%90%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110848%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110848%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%BC%BC%E4%B9%8E%E4%B9%9F%E5%A4%B1%E8%B4%A5%E4%BA%86%20%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%BA%90.%2Fsetup-environment%E5%BB%BA%E9%80%A0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3Ebash%EF%BC%9A.%2F%E8%AE%BE%E7%BD%AE%E7%8E%AF%E5%A2%83%EF%BC%9A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E6%88%91%E8%BF%98%E9%9C%80%E8%A6%81%E5%AE%89%E8%A3%85%E5%85%B6%E4%BB%96%E4%B8%9C%E8%A5%BF%E5%90%97%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A1%A5%E4%B8%81%E7%8E%B0%E5%B7%B2%E5%90%88%E5%B9%B6%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%BA%94%E8%AF%A5%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110846%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110846%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%B0%86%E8%A1%A5%E4%B8%81%E5%8F%91%E9%80%81%E5%88%B0%E9%82%AE%E4%BB%B6%E5%88%97%E8%A1%A8%EF%BC%88meta-freescale%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E4%BC%9A%E4%BF%AE%E5%A4%8D%E5%AE%83%E3%80%82%E4%B8%BB%E4%BA%BA%E4%B8%8D%E5%86%8D%E9%9C%80%E8%A6%81%E5%BC%BA%E5%88%B6udev%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E5%83%8F%E6%B7%BB%E5%8A%A0%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBBMASK%20%3D%20%E2%80%9Cudev_.*%5C.bbappend%24%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%88%B0%20conf%2Flocal.conf%20%E7%9A%84%E6%9C%AB%E5%B0%BE%E4%BF%AE%E5%A4%8D%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110843%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110843%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E9%80%9A%E8%BF%87%E8%BE%93%E5%85%A5%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E6%9D%A5%E9%81%B5%E5%BE%AA%E4%B8%8A%E9%9D%A2%E5%88%97%E5%87%BA%E7%9A%84%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20curl%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fdl-ssl.google.com%2Fdl%2Fgooglesource%2Fgit-repo%2Frepo%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fdl-ssl.google.com%2Fdl%2Fgooglesource%2Fgit-repo%2Frepo%3C%2FA%3E%3CSPAN%3E%20%26gt%3B%20.%2Frepo%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Echmod%20a%2Bx%20.%2Frepo%3C%2FP%3E%3CP%3E%3CSPAN%3Erepo%20init%20-u%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%3C%2FA%3E%20%3CSPAN%3E-b%20master%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BB%93%E5%BA%93%E5%90%8C%E6%AD%A5%3C%2FP%3E%3CP%3Evi%20conf%2Flocal.conf%3C%2FP%3E%3CP%3Ebitbake%20fsl-image-gui%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E6%94%B6%E5%88%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BC%AA%E4%B8%8D%E5%AD%98%E5%9C%A8%E4%BD%86%E9%9C%80%E8%A6%81%EF%BC%8C%E5%9C%A8%E4%B8%BB%E6%9E%84%E5%BB%BA%E4%B9%8B%E5%89%8D%E5%85%88%E6%9E%84%E5%BB%BA%E5%AE%83%3C%2FP%3E%3CP%3ELoading%20cache%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20ETA%3A%26nbsp%3B%2000%3A00%3A00%3C%2FP%3E%3CP%3E%E4%BB%8E%E4%BE%9D%E8%B5%96%E7%BC%93%E5%AD%98%E4%B8%AD%E5%8A%A0%E8%BD%BD%E4%BA%86%201598%20%E4%B8%AA%E6%9D%A1%E7%9B%AE%E3%80%82%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%B2%A1%E6%9C%89%E5%8F%AF%E7%94%A8%E7%9A%84%E9%A3%9F%E8%B0%B1%EF%BC%9A%3C%2FP%3E%3CP%3E%2Fhome%2Fvradmin%2Fprojects%2FMOCUPort%2FYOCTO%2Frootfs_builder%2Fsources%2Fmeta-fsl-arm%2Frecipes-core%2Fudev%2Fudev_173.bbappend%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E5%91%BD%E4%BB%A4%E6%89%A7%E8%A1%8C%E5%A4%B1%E8%B4%A5%EF%BC%9A%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%201%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%91%98%E8%A6%81%EF%BC%9A%E6%98%BE%E7%A4%BA%E4%BA%862%E6%9D%A1%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%EF%BC%8C%E8%BF%94%E5%9B%9E%E4%BA%86%E9%9D%9E%E9%9B%B6%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%E6%82%A8%E7%9F%A5%E9%81%93%E4%BB%80%E4%B9%88%E5%8E%9F%E5%9B%A0%E5%8F%AF%E8%83%BD%E5%AF%BC%E8%87%B4%E6%AD%A4%E9%94%99%E8%AF%AF%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDaiane%EF%BC%8C%E5%9C%A8%E6%88%91%E6%89%A7%E8%A1%8C%E2%80%9Crepo%20sync%20-j2%E2%80%9D%E4%B9%8B%E5%90%8E%E9%97%AE%E9%A2%98%E5%B0%B1%E8%A7%A3%E5%86%B3%E4%BA%86%E3%80%82%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%20Daiane%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E5%AF%B9%20Yocto%20%E7%9A%84%E7%B2%BE%E5%BD%A9%E4%BB%8B%E7%BB%8D%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E4%B8%8A%E9%9D%A2%E6%9C%89%E4%B8%80%E4%B8%AA%E6%8B%BC%E5%86%99%E9%94%99%E8%AF%AF%EF%BC%88%E2%80%9Csouce%E2%80%9D%E5%BA%94%E8%AF%A5%E6%98%AF%E2%80%9Csource%E2%80%9D%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110840%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110840%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E8%83%BD%E6%8B%BF%E5%88%B0%E6%BA%90%E4%BB%A3%E7%A0%81%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%82%A8%E6%9C%89%E4%BB%A3%E7%90%86%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%94%B1%E4%BA%8E%E6%88%91%E7%9A%84%E4%BB%A3%E7%90%86%E9%85%8D%E7%BD%AE%EF%BC%8C%E6%88%91%E6%9C%89%E5%BE%88%E5%A4%9A%E5%90%8C%E6%AD%A5%E9%94%99%E8%AF%AF%EF%BC%8C%E5%BD%93%E6%88%91%E5%86%8D%E6%AC%A1%E5%B0%9D%E8%AF%95%E6%97%B6%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E6%AF%AB%E6%97%A0%E9%94%99%E8%AF%AF%E5%9C%B0%E8%8E%B7%E5%8F%96%E6%BA%90%E4%BB%A3%E7%A0%81%E3%80%82%E4%BD%A0%E8%83%BD%E5%86%8D%E8%AF%95%E4%B8%80%E6%AC%A1%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%20i.MX6%20%E7%9A%84%20Yocto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDaiane%EF%BC%8C%E6%88%91%E7%9A%84%E2%80%9Crepo%20sync%E2%80%9D%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%BE%93%E5%87%BA%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%20*%20%5B%E6%96%B0%E6%A0%87%E7%AD%BE%5D%20%3C%2FTD%3E%3CTD%3E%E7%B4%AB%E8%89%B2-3.2-%26gt%3B%20%E7%B4%AB%E8%89%B2-3.2%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%20*%20%5B%E6%96%B0%E6%A0%87%E7%AD%BE%5D%20%3C%2FTD%3E%3CTD%3E%E7%B4%AB%E8%89%B2-3.2.1%20-%26gt%3B%20%E7%B4%AB%E8%89%B2-3.2.1%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%E8%8E%B7%E5%8F%96%E9%A1%B9%E7%9B%AE%EF%BC%9A100%25%20(6%2F6)%EF%BC%8C%E5%AE%8C%E6%88%90%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E7%94%B1%E4%BA%8E%20gc%20%E9%94%99%E8%AF%AF%E8%80%8C%E9%80%80%E5%87%BA%E5%90%8C%E6%AD%A5%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎11-28-2012 10:40 AM
更新人:
