How to Enable Second Display Showing Different Things on JB4.2.2 SabreSD
This is the prototype solution to enable second display showing different things on JB4.2.2 SabreSD.
Make use of Class Presentation provided by android to be embedded into Status bar.
When unlock the screen, the Presentation will show on second display.
Now, the solution requires one .mp4 video placed in root sdcard.
Of course, you may change it to show anything.
The attached Files are a layout xml file, a patch and a recorded video.
The layout file should be put into android/frameworks/base/packages/SystemUI/res/layout/ folder.
The patch should be applied to frameworks/base.git.
The recorded video shows the dual display demo as a reference.
添付
コメント
I used lvds + hdmi  display port , but it is diplay identical content still. do you have change other configs? How can i control respectively control screen?
Hi Herman,
First make sure the system is upgraded to android 4.2.2.
Patch, build and re-install systemui.apk.
Can you check if the video placed on /sdcard root directory.
It shows different content when the key guard is unlock.
Xiaowen,
Following is i change:
1. bsp is jb4.2.2.
2. uboot configs:
                "bootargs=console=ttymxc3,115200 androidboot.console=ttymxc3 init=/init rw video=mxcfb0:dev=ldb,LDB-XGA if=RGB666 bpp=32 video=mxcfb1:dev=hdmi,1920x1080M@60 fbmem=15M,28M vmalloc=400M fb0base=0x27b00000 enable_wait_mode=off androidboot.hardware=freescale ldo_active=on\0"
3. copy presentation_with_media_router_content.xml into frameworks/base/packages/SystemUI/res/layout/
4. git apply systemui_presentation.patch.
5. build myandroid
6. burn system.img to SD card.
7. Restart system.
    the system present "Unfortunately, System UI has stopped". can't entry home screen.
Have you put a .mp4 file to /sdcard directory? The error is due to missing .mp4 file.
Copy a .mp4 file into /sdcard, work fine. thanks all.
How can we have this feature on ICS for iMX6?
hi, this is the new feature provided by jb4.2
any solution on ICS platform? I also found iMX53 had this feature.
hi, ICS does not support this feature itself. And it is not customized to support it.
What kind of processor are you using now? Have you verified on iMX6 solo platform? Will it have any performance issue?
I had tried this thing, working fine for me.
I am a Java beginner and checking for the feasibility of running an android application on the separate display while keeping the other display for normal use.
Please suggest any method for doing so!!
Thanks for your time, in advance!!!
AD
Hello Ivan,
     According to your instruction,My HDMI Display Different Things.
     But,I found a issure, if the mp4 file have the audio,The Video player will be stoped,Print the following information,Continuously.
D/MediaPlayer( 3387): getMetadata
I/ActivityManager( 2904): Displayed com.advantech.advpresentation/.AdvPresentation: +609ms
I/vpu-lib ( 2612): Product Info: i.MX6Q/D/S
I/vpu-lib ( 2612): <gpu> alloc handle: 0x40f8f180, paddr: 0x20800000, vaddr: 0x4dc89000
I/vpu-lib ( 2612): <gpu> alloc handle: 0x40f8f1a8, paddr: 0x42ba1000, vaddr: 0x437fd000
I/vpu-lib ( 2612): bitstreamMode 1, chromaInterleave 0, mapType 0, tiled2LinearEnable 0
I/OMXCodec( 2612): [OMX.Freescale.std.video_decoder.avc.v3.hw-based] video dimensions are 480 x 288
I/OMXCodec( 2612): [OMX.Freescale.std.video_decoder.avc.v3.hw-based] Crop rect is 480 x 270 @ (0, 0)
I/vpu-lib ( 2612): <gpu> alloc handle: 0x40089e20, paddr: 0x42fbc000, vaddr: 0x43c18000
E/OMXCodec( 2612): [OMX.google.aac.decoder] ERROR(0x80001001, 8195)
W/MediaPlayer( 3387): info/warning (3, 0)
E/OMXCodec( 2612): [OMX.Freescale.std.video_decoder.avc.v3.hw-based] dequeueBuffer failed w/ error 0xfffffff0
E/MediaPlayer( 3387): error (1, -2147483648)
E/MediaPlayer( 3387): Error (1,-2147483648)
D/VideoView( 3387): Error: 1,-2147483648
I/vpu-lib ( 2612): <gpu> free handle: 0x40f8f1a8, paddr: 0x42ba1000, vaddr: 0x437fd000
I/vpu-lib ( 2612): <gpu> free handle: 0x40f8f180, paddr: 0x20800000, vaddr: 0x4dc89000
I/vpu-lib ( 2612): <gpu> free handle: 0x40089e20, paddr: 0x42fbc000, vaddr: 0x43c18000
W/AudioFlinger( 2612): session id 139 not found for pid 3387
I/OMXCodec( 2612): [OMX.Freescale.std.video_decoder.avc.v3.hw-based] AVC profile = 100 (High), level = 12
I/OMXCodec( 2612): [OMX.Freescale.std.video_decoder.avc.v3.hw-based] video dimensions are 480 x 270
Are you encounter this problem?Can you give me some suggestions,Thanks!
HaHa:smileygrin:...The problem has been resolved!
I reFormat conversion,the issure is resolved.
Hi yixuan.guo,
Could you please help me to overcome the dequeueBuffer failed w/ error 0xfffffff0.
thanks
Rakesh
Can we use the Kitkat 4.4 for this dual viewing feature in imx6 sabresd?
can the same patch file and the xml fles be used for the kitkat version also?
Please help us on this.
Thanks in advance
Hi juvin
Yes,This patch file can use in KK4.4.
I has try.
Thanks Yasin.
I integrated the patch and found this working. :smileylaugh:
i have another query on this.
Suppose my primary display is on RGB and secondary on the HDMI.
Currently i get the media playback on the HDMI. but i want to know how can i access the media player controls(play, stop,pause etc )there?(currently while the media player is played on the HDMI , the mouse and other input devices can control only the RGB screen).
Thanks in advance.
Hi Juvin,
We tried applying the patch and found that its not working for us. i.e. the video is not getting displayed on the HDMI monitor.
Can you please share your presentation.java file(after patch applied), so that we can also find out where we are wrong?
Thanks in advance.
Rabiammal A
Hi Juvin,
I have tried it on android Kitkat 4.4.3
We have ready-to-use solution for secondary display supported by i.MX6DL/ i.MX6Q. showing same or different frames/ pictures are both well supported by board with OS Android 4.4 or Linux
%3CLINGO-SUB%20id%3D%22lingo-sub-1105117%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EJB4.2.2%20SabreSD%E3%81%A7%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%89%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105117%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81JB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%89%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%99%E3%82%8B%E3%83%97%E3%83%AD%E3%83%88%E3%82%BF%E3%82%A4%E3%83%97%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EAndroid%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8BClass%20Presentation%E3%82%92%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%83%90%E3%83%BC%E3%81%AB%E5%9F%8B%E3%82%81%E8%BE%BC%E3%82%80%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%94%BB%E9%9D%A2%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%97%E3%83%AC%E3%82%BC%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%AF%201%20%E3%81%A4%E3%81%AE.mp4%E3%83%93%E3%83%87%E3%82%AA%E3%81%AF%E3%83%AB%E3%83%BC%E3%83%88%20SD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%A1%E3%82%8D%E3%82%93%E3%80%81%E4%BD%95%E3%81%8B%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88xml%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E3%83%91%E3%83%83%E3%83%81%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E9%8C%B2%E7%94%BB%E3%81%95%E3%82%8C%E3%81%9F%E3%83%93%E3%83%87%E3%82%AA%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81android%2Fframeworks%2Fbase%2Fpackages%2FSystemUI%2Fres%2Flayout%2F%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%20frameworks%2Fbase.git%20%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E9%8C%B2%E7%94%BB%E3%81%95%E3%82%8C%E3%81%9F%E3%83%93%E3%83%87%E3%82%AA%E3%81%AF%E3%80%81%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E3%83%87%E3%83%A2%E3%82%92%E5%8F%82%E8%80%83%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1105117%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6DL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105137%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AJB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105137%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3Ei.MX6DL%2F%20i.MX6Q%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E7%94%A8%E3%81%AE%E3%81%99%E3%81%90%E3%81%AB%E4%BD%BF%E3%81%88%E3%82%8B%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E7%94%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%90%8C%E3%81%98%E3%81%BE%E3%81%9F%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%2F%E7%94%BB%E5%83%8F%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81OS%20Android%204.4%E3%81%BE%E3%81%9F%E3%81%AFLinux%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E5%8D%81%E5%88%86%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105136%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AJB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105136%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Juvin%2C%20%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%82%A2%E3%83%B3%E3%83%89%E3%83%AD%E3%82%A4%E3%83%89Kitkat%204.4.3%E3%81%A7%E3%81%9D%E3%82%8C%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105135%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AJB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105135%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Juvin%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8B%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E3%81%8CHDMI%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%BC%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3Epresentation.java%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB(%E3%83%91%E3%83%83%E3%83%81%E9%81%A9%E7%94%A8%E5%BE%8C)%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%80%81%E3%81%A9%E3%81%93%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%82%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%89%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%A9%E3%83%93%E3%82%A2%E3%83%9E%E3%83%ABA%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105134%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AJB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105134%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86Yasin%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E7%B5%B1%E5%90%88%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3Asmileylaugh%3A%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E5%88%A5%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%97%E3%83%A9%E3%82%A4%E3%83%9E%E3%83%AA%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%8CRGB%E3%81%A7%E3%80%81%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%8CHDMI%E3%81%AB%E3%81%82%E3%82%8B%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81HDMI%E3%81%A7%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%82%92%E5%86%8D%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%9D%E3%81%93%E3%81%A7%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%83%97%E3%83%AC%E3%83%BC%E3%83%A4%E3%83%BC%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB(%E5%86%8D%E7%94%9F%E3%80%81%E5%81%9C%E6%AD%A2%E3%80%81%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E3%81%AA%E3%81%A9)%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F(%E7%8F%BE%E5%9C%A8%E3%80%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%83%97%E3%83%AC%E3%83%BC%E3%83%A4%E3%83%BC%E3%81%8CHDMI%E3%81%A7%E5%86%8D%E7%94%9F%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E9%96%93%E3%80%81%E3%83%9E%E3%82%A6%E3%82%B9%E3%82%84%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E5%85%A5%E5%8A%9B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AFRGB%E7%94%BB%E9%9D%A2%E3%81%AE%E3%81%BF%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99)%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105133%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AJB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105133%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20juvin%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AFKK4.4%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AJB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3Eimx6%20sabresd%20%E3%81%AE%E3%81%93%E3%81%AE%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E8%A1%A8%E7%A4%BA%E6%A9%9F%E8%83%BD%E3%81%AB%20Kitkat%204.4%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E5%90%8C%E3%81%98%E3%83%91%E3%83%83%E3%83%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8XML%20FLE%E3%82%92KitKat%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%82%82%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E7%A7%81%E3%81%9F%E3%81%A1%E3%82%92%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105131%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AJB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105131%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fyixuan.guo%22%20target%3D%22_blank%22%3Eyixuan.guo%3C%2FA%3E%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E3%82%A8%E3%83%A9%E3%83%BC%200xfffffff0%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9FdequeueBuffer%3C%2FSPAN%3E%E3%82%92%E5%85%8B%E6%9C%8D%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%AC%9D%3C%2FP%3E%3CP%3E%E3%83%A9%E3%82%B1%E3%82%B7%E3%83%A5%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105130%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AJB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105130%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AF%E3%81%AF%E3%81%AF%3Asmileygrin%3A...%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F!%3C%2FP%3E%3CP%3E%E5%A4%89%E6%8F%9B%E3%82%92%E5%86%8D%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AJB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Ivan%2C%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%E7%A7%81%E3%81%AEHDMI%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AF%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%82%82%E3%81%AE%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E5%95%8F%E9%A1%8C%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81mp4%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E9%9F%B3%E5%A3%B0%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E3%83%97%E3%83%AC%E3%83%BC%E3%83%A4%E3%83%BC%E3%81%AF%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-family%3A%20arial%3B%20font-size%3A%2014px%3B%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-family%3A%20arial%3B%20font-size%3A%2014px%3B%22%3E%20%E6%83%85%E5%A0%B1%E3%82%92%E5%8D%B0%E5%88%B7%E3%81%97%E7%B6%9A%E3%81%91%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ED%2FMediaPlayer(%203387)%3A%20getMetadata%3C%2FP%3E%3CP%3EI%20%2F%20ActivityManager(2904)%3Acom.advantech.advpresentation%2F%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82AdvPresentation%3A%2B609%E3%83%9F%E3%83%AA%E7%A7%92%3C%2FP%3E%3CP%3EI%2FVPU-LIB%20(%202612)%3A%20%E8%A3%BD%E5%93%81%E6%83%85%E5%A0%B1%3A%20i.MX6Q%2FD%2FS%3C%2FP%3E%3CP%3EI%2FVPU-LIB%20(%202612)%3A%20%3CGPU%3E%20alloc%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%3A%200x40f8f180%2C%20paddr%3A%200x20800000%2C%20vaddr%3A%200x4dc89000%3C%2FGPU%3E%3C%2FP%3E%3CP%3EI%2FVPU-LIB%20(%202612)%3A%20%3CGPU%3E%20alloc%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%3A%200x40f8f1a8%2C%20paddr%3A%200x42ba1000%2C%20vaddr%3A%200x437fd000%3C%2FGPU%3E%3C%2FP%3E%3CP%3EI%2FVPU-LIB%20(%202612)%3A%20bitstreamMode%201%2C%20chromaInterleave%200%2C%20mapType%200%2C%20tiled2LinearEnable%200%3C%2FP%3E%3CP%3EI%20%2F%20OMX%E3%82%B3%E3%83%BC%E3%83%89(2612)%3A%5BOMX%E3%80%82Freescale.std.video_decoder.avc.v3.hw-based%5D%20%E3%83%93%E3%83%87%E3%82%AA%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%20480%20x%20288%20%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3EI%20%2F%20OMX%E3%82%B3%E3%83%BC%E3%83%89(2612)%3A%5BOMX%E3%80%82Freescale.std.video_decoder.avc.v3.hw%E3%83%99%E3%83%BC%E3%82%B9%5D%E3%82%AF%E3%83%AD%E3%83%83%E3%83%97%20rect%20%E3%81%AF%20480%20x%20270%20%40%20(0%2C%200)%20%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3EI%2Fvpu-lib%20(%202612)%3A%20%3CGPU%3E%20alloc%20handle%3A%200x40089e20%2C%20paddr%3A%200x42fbc000%2C%20vaddr%3A%200x43c18000%3C%2FGPU%3E%3C%2FP%3E%3CP%3EE%2FOMXCodec(%202612)%3A%20%5BOMX.google.aac.decoder%5D%20ERROR(0x80001001%2C%208195)%3C%2FP%3E%3CP%3EW%20%2F%20MediaPlayer(%203387)%20%3A%20%E6%83%85%E5%A0%B1%2F%E8%AD%A6%E5%91%8A%20(%203%2C%200%20)%3C%2FP%3E%3CP%3EE%2FOMXCodec(%202612)%3A%20%5BOMX.Freescale.std.video_decoder.avc.v3.hw-based%5D%20dequeueBuffer%20%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%200xfffffff0%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EE%2FMediaPlayer(%203387)%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%20(1%2C%20-2147483648)%3C%2FP%3E%3CP%3EE%20%2F%20MediaPlayer(3387)%3A%E3%82%A8%E3%83%A9%E3%83%BC(1%E3%80%81-2147483648)%3C%2FP%3E%3CP%3ED%2FVideoView(%203387)%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%201%2C-2147483648%3C%2FP%3E%3CP%3EI%2FVPU-LIB%20(%202612)%3A%20%3CGPU%3E%20%E3%83%95%E3%83%AA%E3%83%BC%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%3A%200x40f8f1a8%2C%20paddr%3A%200x42ba1000%2C%20vaddr%3A%200x437fd000%3C%2FGPU%3E%3C%2FP%3E%3CP%3EI%2FVPU-LIB%20(%202612)%3A%20%3CGPU%3E%20%E3%83%95%E3%83%AA%E3%83%BC%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%3A%200x40f8f180%2C%20paddr%3A%200x20800000%2C%20vaddr%3A%200x4dc89000%3C%2FGPU%3E%3C%2FP%3E%3CP%3EI%2FVPU-LIB%20(%202612)%3A%20%3CGPU%3E%20%E3%83%95%E3%83%AA%E3%83%BC%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%3A%200x40089e20%2C%20paddr%3A%200x42fbc000%2C%20vaddr%3A%200x43c18000%3C%2FGPU%3E%3C%2FP%3E%3CP%3EW%2FAudioFlinger(%202612)%3A%20PID%203387%20%E3%81%AE%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%20ID%20139%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3EI%20%2F%20OMX%E3%82%B3%E3%83%BC%E3%83%89(2612)%3A%5BOMX%E3%80%82Freescale.std.video_decoder.avc.v3.hw%E3%83%99%E3%83%BC%E3%82%B9%5DAVC%20%E3%83%97%E3%83%AD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3D%20100%20(%E9%AB%98)%E3%80%81%E3%83%AC%E3%83%99%E3%83%AB%20%3D%2012%3C%2FP%3E%3CP%3EI%20%2F%20OMX%E3%82%B3%E3%83%BC%E3%83%89(2612)%3A%5BOMX%E3%80%82Freescale.std.video_decoder.avc.v3.hw-based%5D%20%E3%83%93%E3%83%87%E3%82%AA%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%20480%20x%20270%20%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3ED%2FMediaPlayer(%203387)%3A%20getMetadata%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E7%A7%81%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E6%8F%90%E6%A1%88%E3%82%92%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AJB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%82%8C%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFJava%E3%81%AE%E5%88%9D%E5%BF%83%E8%80%85%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E4%BB%96%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E9%80%9A%E5%B8%B8%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E4%BF%9D%E6%8C%81%E3%81%97%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E5%88%A5%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A7Android%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E6%8F%90%E6%A1%88%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84!!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99!!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AJB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3FiMX6%E3%82%BD%E3%83%AD%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AJB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81ICS%20%E3%81%AF%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E8%87%AA%E4%BD%93%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105125%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AJB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105125%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EICS%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E4%B8%8A%E3%81%AE%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3FiMX53%E3%81%AB%E3%82%82%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105124%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AJB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105124%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%81%AFJB4.2%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E6%96%B0%E6%A9%9F%E8%83%BD%E3%81%A7%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105123%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AJB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105123%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EiMX6%E3%81%AEICS%E3%81%A7%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AJB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E.mp4%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%2F%20sdcard%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%97%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105121%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AJB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105121%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E.mp4%E3%82%92%E5%85%A5%E3%82%8C%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%2Fsdcard%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%3F%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF.mp4%E3%81%8C%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AJB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EXiaowen%2C%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E7%A7%81%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CP%3E1.%20BSP%E3%81%AFJB4.2.2%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E2.%20uboot%E3%81%AE%E8%A8%AD%E5%AE%9A%3A%20%3CBR%20%2F%3E%22bootargs%3Dconsole%3Dttymxc3%2C115200%20androidboot.console%3Dttymxc3init%3D%2Finit%20rw%20video%3Dmxcfb0%3Adev%3Dldb%2CLDB-XGA%20if%3DRGB666%20bpp%3D32%20video%3Dmxcfb1%3Adev%3Dhdmi%2C1920x1080M%4060%20fbmem%3D15M%2C28M%20vmalloc%3D400M%20fb0base%3D0x27b00000%20enable_wait_mode%3Doff%20androidboot.hardware%3Dfreescaleldo_active%3Don%5C0%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.%20presentation_with_media_router_content.xml%E3%82%92frameworks%2Fbase%2Fpackages%2FSystemUI%2Fres%2Flayout%2F%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E4.%20git%20apply%20systemui_presentation.patch%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E5.MyAndroid%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E6.%20system.img%E3%82%92SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E7.%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%8C%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20UI%20%E3%81%AF%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%8D%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%9B%E3%83%BC%E3%83%A0%E7%94%BB%E9%9D%A2%E3%81%AB%E5%85%A5%E3%82%89%E3%81%AA%E3%81%84%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105119%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AJB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105119%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Herman%2C%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8CAndroid%204.2.2%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3Esystemui.apk%E3%81%AB%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E5%86%8D%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%87%E3%82%AA%E3%81%8C%2F%20sdcard%E3%83%AB%E3%83%BC%E3%83%88%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AD%E3%83%BC%E3%82%AC%E3%83%BC%E3%83%89%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E8%A7%A3%E9%99%A4%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E3%80%81%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AJB4.2.2%20SabreSD%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B2%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Elvds%20%2B%20hdmi%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E5%90%8C%E3%81%98%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%81%A7%E3%81%99%E3%80%82%E4%BB%96%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E5%88%B6%E5%BE%A1%E7%94%BB%E9%9D%A2%E3%82%92%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E5%88%B6%E5%BE%A1%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎03-21-2013 07:36 PM
更新者:
