GStreamer i.MX6 Encoding
Audio, from a filegst-launch filesrc location=test.wav ! wavparse ! mfw_mp3encoder ! filesink location=output.mp3
Audio Recording
gst-launch alsasrc num-buffers=$NUMBER blocksize=$SIZE ! mfw_mp3encoder ! filesink
location=output.mp3
# where
#     duration = $NUMBER*$SIZE*8 / (samplerate *channel *bitwidth)
# Example: 60 seconds recording
gst-launch alsasrc num-buffers=240 blocksize=44100 ! mfw_mp3encoder ! filesink location=output.mp3
# To verify that is correct, do a normal audio playback
gst-launch filesrc location=output.mp3 typefind=true ! beepdec ! audioconvert ! 'audio/x-raw-int,channels=2' ! alsasink
Video, from a test sourcegst-launch videotestsrc ! queue ! vpuenc ! matroskamux ! filesink location=./test.avi
Video, from a file
gst-launch filesrc location=sample.yuv blocksize=$BLOCK_SIZE ! 'video/x-raw-yuv,format=(fourcc)I420, width=$WIDTH, height=$HEIGHT, framerate=(fraction)30/1' ! vpuenc codec=$CODEC ! matroskamux ! filesink location=output.mkv sync=false
# where
#     BLOCK_SIZE = WIDTH * HEIGHT * 1.5
#     CODEC = 0(MPEG4), 5(H263), 6(H264) or 12(MJPG).
# For example, encoding a CIF raw file
gst-launch filesrc location=sample.yuv blocksize=152064 ! 'video/x-raw-yuv,format=(fourcc)I420, width=352, height=288, framerate=(fraction)30/1' ! vpuenc codec=0 ! matroskamux ! filesink location=sample.mkv sync=false
Video, from Web camera
# when the web cam is connected, the device node /dev/video0 should be present. In order to test the camera, without encoding
gst-launch v4l2src ! mfw_v4lsink
# in recording, run:
gst-launch v4l2src num-buffers=-1 ! queue max-size-buffers=2 ! vpuenc codec=0 ! matroskamux ! filesink location=output.mkv sync=false
# where sync=false indicates filesink to to use a clock sync
# In case a specific width/height is needed, just add the filter caps
gst-launch v4l2src num-buffers=-1  ! 'video/x-raw-yuv,format=(fourcc)I420, width=352, height=288, framerate=(fraction)30/1' ! queue ! vpuenc codec=0 ! matroskamux ! filesink location=output.mkv sync=false
# In case you want to see in the screen what the camera is capturing, add a tee element
gst-launch v4l2src num-buffers=-1 ! tee name=t ! queue ! mfw_v4lsink t. ! queue ! vpuenc codec=0 ! matroskamux ! filesink location=output.mkv sync=false
Video, from Parallel/MIPI camera
# The camera driver needs to be loaded before executing the pipeline, refer to the BSP document to see which driver to load
# MIPI (J5 port):
modprobe ov5640_camera_mipi
modprobe mxc_v4l2_capture
# Parallel (J9 port):
modprobe ov5642_camera
gst-launch mfw_v4lsrc ! queue ! vpuenc codec=0 ! matroskamux ! filesink location=output.mkv sync=false
# Do a 'gst-inspect mfw_v4lsrc' or 'gst-inspect vpuenc' to see other possible settings (resolution, fps, codec, etc.)
标签 (3)
评论
I'm using boundary device sabreLite and when trying to record video from ov5640 mipi,Its show some error.
command:
output msg:
MFW_GST_V4LSRC_PLUGIN 3.0.8 build on Sep 23 2014 05:49:17.
[INFO] Product Info: i.MX6Q/D/S
vpuenc versions :smileyhappy:
  plugin: 3.0.8
  wrapper: 1.0.38(VPUWRAPPER_ARM_LINUX Build on Sep 23 2014 05:42:43)
  vpulib: 5.4.15
  firmware: 2.3.10.40778
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/MFWGstV4LSrc:mfwgstv4lsrc0: Internal data flow error.
Additional debug info:
gstbasesrc.c(2625): gst_base_src_loop (): /GstPipeline:pipeline0/MFWGstV4LSrc:mfwgstv4lsrc0:
streaming task paused, reason error (-5)
Execution ended after 9999770667 ns.
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
But when i include capture-mode
gst-launch mfw_v4lsrc  capture-mode=4 ! queue ! vpuenc codec=0 ! matroskamux ! filesink location=output.mkv sync=false
ls -al
-rwxr-xr-x  1 root root 10476028 Oct 13  2014 output.mkv
When i try to open in vlc, its showing like a image(photo) not a running video.
Please hep me out.
-Sridhar
Strange. Do you see the same behavior using gplay to reproduced the recorded video? gplay runs on target.
Is there command for Video/Audio recording? Thank you.
%3CLINGO-SUB%20id%3D%22lingo-sub-1123743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGStreamer%20i.MX6%E7%BC%96%E7%A0%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CTABLE%20border%3D%221%22%20class%3D%22jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20width%3A%20100%25%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%20valign%3D%22middle%22%3E%3C%2FTH%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%20valign%3D%22middle%22%3E%3C%2FTH%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%3CSTRONG%3E%E9%9F%B3%E9%A2%91%EF%BC%8C%E6%9D%A5%E8%87%AA%E6%96%87%E4%BB%B6%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3Egst-%E5%90%AF%E5%8A%A8%E6%96%87%E4%BB%B6%20rc%20%E4%BD%8D%E7%BD%AE%3Dtest.wav%EF%BC%81wavparse%EF%BC%81mfw_mp3%E7%BC%96%E7%A0%81%E5%99%A8%EF%BC%81%E6%96%87%E4%BB%B6%E6%8E%A5%E6%94%B6%E5%99%A8%E4%BD%8D%E7%BD%AE%3Doutput.mp3%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%3CSTRONG%3E%E5%BD%95%E9%9F%B3%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3Egst-launch%20alsasrc%20num-buffers%3D%24NUMBER%20%E5%9D%97%E5%A4%A7%E5%B0%8F%3D%24SIZE%EF%BC%81mfw_mp3%E7%BC%96%E7%A0%81%E5%99%A8%EF%BC%81%E6%96%87%E4%BB%B6%E6%8E%A5%E6%94%B6%E5%99%A8%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%E4%BD%8D%E7%BD%AE%3D%E8%BE%93%E5%87%BA.mp3%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%EF%BC%83%20%E5%9C%A8%E5%93%AA%E9%87%8C%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E6%8C%81%E7%BB%AD%E6%97%B6%E9%97%B4%20%3D%20%24NUMBER*%24SIZE*8%20%2F%20(%E9%87%87%E6%A0%B7%E7%8E%87%20*%E9%80%9A%E9%81%93%20*%E4%BD%8D%E5%AE%BD)%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E7%A4%BA%E4%BE%8B%EF%BC%9A60%E7%A7%92%E5%BD%95%E9%9F%B3%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3Egst-launch%20alsasrc%20num-buffers%3D240%20%E5%9D%97%E5%A4%A7%E5%B0%8F%3D44100%EF%BC%81mfw_mp3%E7%BC%96%E7%A0%81%E5%99%A8%EF%BC%81%E6%96%87%E4%BB%B6%E6%8E%A5%E6%94%B6%E5%99%A8%E4%BD%8D%E7%BD%AE%3Doutput.mp3%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E4%B8%BA%E4%BA%86%E9%AA%8C%E8%AF%81%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%EF%BC%8C%E8%AF%B7%E8%BF%9B%E8%A1%8C%E6%AD%A3%E5%B8%B8%E7%9A%84%E9%9F%B3%E9%A2%91%E6%92%AD%E6%94%BE%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3Egst-launch%20filesrc%20%E4%BD%8D%E7%BD%AE%3Doutput.mp3%20typefind%3Dtrue%EF%BC%81%E5%93%94%E5%93%94%EF%BC%81%E9%9F%B3%E9%A2%91%E8%BD%AC%E6%8D%A2%EF%BC%81'%E9%9F%B3%E9%A2%91%2Fx-raw-int%EF%BC%8C%E9%80%9A%E9%81%93%3D2'%EF%BC%81%E9%98%BF%E5%B0%94%E8%90%A8%E6%96%AF%E5%85%8B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%3CSTRONG%3E%E8%A7%86%E9%A2%91%EF%BC%8C%E6%9D%A5%E8%87%AA%E6%B5%8B%E8%AF%95%E6%BA%90%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3Egst-%E5%90%AF%E5%8A%A8%E8%A7%86%E9%A2%91%E6%B5%8B%E8%AF%95src%EF%BC%81%E9%98%9F%E5%88%97%EF%BC%81vpuenc%EF%BC%81mat%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3Eroskamux%EF%BC%81%E6%96%87%E4%BB%B6%E6%8E%A5%E6%94%B6%E5%99%A8%E4%BD%8D%E7%BD%AE%3D.%2Ftest.avi%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22color%3A%20%23333399%3B%22%3E%3CSTRONG%3E%E8%A7%86%E9%A2%91%EF%BC%8C%E6%9D%A5%E8%87%AA%E6%96%87%E4%BB%B6%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3Egst-%E5%90%AF%E5%8A%A8%20filesrc%20%E4%BD%8D%E7%BD%AE%3Dsample.yuv%20%E5%9D%97%E5%A4%A7%E5%B0%8F%3D%24BLOCK_SIZE%EF%BC%81'video%2Fx-raw-yuv%EF%BC%8C%E6%A0%BC%E5%BC%8F%3D(fourcc)I420%EF%BC%8C%E5%AE%BD%E5%BA%A6%3D%24WIDTH%EF%BC%8C%E9%AB%98%E5%BA%A6%3D%24HEIGHT%EF%BC%8C%E5%B8%A7%E9%80%9F%E7%8E%87%3D(%E5%88%86%E6%95%B0)30%2F1'%EF%BC%81vpuenc%20%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%3D%24CODEC%EF%BC%81matroskamux%EF%BC%81%E6%96%87%E4%BB%B6%E6%8E%A5%E6%94%B6%E5%99%A8%E4%BD%8D%E7%BD%AE%3D%E8%BE%93%E5%87%BA.mkv%20%E5%90%8C%E6%AD%A5%3Dfalse%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%EF%BC%83%20%E5%9C%A8%E5%93%AA%E9%87%8C%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E5%9D%97%E5%A4%A7%E5%B0%8F%20%3D%20%E5%AE%BD%E5%BA%A6%20*%20%E9%AB%98%E5%BA%A6%20*%201.5%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%20%3D%200%EF%BC%88MPEG4%EF%BC%89%E3%80%815%EF%BC%88H263%EF%BC%89%E3%80%816%EF%BC%88H264%EF%BC%89%E6%88%96%2012%EF%BC%88MJPG%EF%BC%89%E3%80%82%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E4%BE%8B%E5%A6%82%EF%BC%8C%E7%BC%96%E7%A0%81%20CIF%20%E5%8E%9F%E5%A7%8B%E6%96%87%E4%BB%B6%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3Egst%E5%90%AF%E5%8A%A8filesrc%E4%BD%8D%E7%BD%AE%3Dsample.yuv%E5%9D%97%E5%A4%A7%E5%B0%8F%3D152064%EF%BC%81'video%2Fx-raw-yuv%EF%BC%8C%E6%A0%BC%E5%BC%8F%3D(fourcc)I420%EF%BC%8C%E5%AE%BD%E5%BA%A6%3D352%EF%BC%8C%E9%AB%98%E5%BA%A6%3D288%EF%BC%8C%E5%B8%A7%E9%80%9F%E7%8E%87%3D(%E5%88%86%E6%95%B0)30%2F1'%EF%BC%81vpuenc%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%3D0%EF%BC%81matroskamux%EF%BC%81%E6%96%87%E4%BB%B6%E6%8E%A5%E6%94%B6%E5%99%A8%E4%BD%8D%E7%BD%AE%3Dsample.mkv%20sync%3Dfalse%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%3CSTRONG%3E%E8%A7%86%E9%A2%91%EF%BC%8C%E6%9D%A5%E8%87%AA%E7%BD%91%E7%BB%9C%E6%91%84%E5%83%8F%E5%A4%B4%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E5%BD%93%E7%BD%91%E7%BB%9C%E6%91%84%E5%83%8F%E5%A4%B4%E8%BF%9E%E6%8E%A5%E6%97%B6%EF%BC%8C%E8%AE%BE%E5%A4%87%E8%8A%82%E7%82%B9%20%2Fdev%2Fvideo0%20%E5%BA%94%E8%AF%A5%E5%AD%98%E5%9C%A8%E3%80%82%E4%B8%BA%E4%BA%86%E6%B5%8B%E8%AF%95%E7%9B%B8%E6%9C%BA%EF%BC%8C%E6%97%A0%E9%9C%80%E7%BC%96%E7%A0%81%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3Egst-%E5%90%AF%E5%8A%A8%20v4l2src%EF%BC%81mfw_v4lsink%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E5%9C%A8%E5%BD%95%E9%9F%B3%E4%B8%AD%EF%BC%8C%E8%BF%90%E8%A1%8C%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%3CBR%20%2F%3E%20gst%E5%90%AF%E5%8A%A8v4l2src%20num%E7%BC%93%E5%86%B2%E5%8C%BA%3D-1%EF%BC%81%E9%98%9F%E5%88%97%E6%9C%80%E5%A4%A7%E5%A4%A7%E5%B0%8F%E7%BC%93%E5%86%B2%E5%8C%BA%3D2%EF%BC%81vpuenc%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%3D0%EF%BC%81matroskamux%EF%BC%81%E6%96%87%E4%BB%B6%E6%8E%A5%E6%94%B6%E5%99%A8%E4%BD%8D%E7%BD%AE%3D%E8%BE%93%E5%87%BA.mkv%20%E5%90%8C%E6%AD%A5%3Dfalse%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E5%85%B6%E4%B8%AD%20sync%3Dfalse%20%E8%A1%A8%E7%A4%BA%E6%96%87%E4%BB%B6%E6%8E%A5%E6%94%B6%E5%99%A8%E4%BD%BF%E7%94%A8%E6%97%B6%E9%92%9F%E5%90%8C%E6%AD%A5%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E5%A6%82%E6%9E%9C%E9%9C%80%E8%A6%81%E7%89%B9%E5%AE%9A%E7%9A%84%E5%AE%BD%E5%BA%A6%2F%E9%AB%98%E5%BA%A6%EF%BC%8C%E5%8F%AA%E9%9C%80%E6%B7%BB%E5%8A%A0%E8%BF%87%E6%BB%A4%E5%B8%BD%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%3CSTRONG%3Egst-launch%20v4l2src%20num-buffers%3D-1%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E!'video%2Fx-raw-yuv%2C%E6%A0%BC%E5%BC%8F%3D(fourcc)I420%2C%E5%AE%BD%E5%BA%A6%3D352%2C%E9%AB%98%E5%BA%A6%3D288%2C%E5%B8%A7%E9%80%9F%E7%8E%87%3D(%E5%88%86%E6%95%B0)30%2F1'!%3C%2FSTRONG%3E%3C%2FSPAN%3E%E9%98%9F%E5%88%97%20%EF%BC%81vpuenc%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%3D0%EF%BC%81matroskamux%EF%BC%81%E6%96%87%E4%BB%B6%E6%8E%A5%E6%94%B6%E5%99%A8%E4%BD%8D%E7%BD%AE%3D%E8%BE%93%E5%87%BA.mkv%20%E5%90%8C%E6%AD%A5%3Dfalse%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E5%A6%82%E6%9E%9C%E4%BD%A0%E6%83%B3%E5%9C%A8%E5%B1%8F%E5%B9%95%E4%B8%8A%E7%9C%8B%E5%88%B0%E7%9B%B8%E6%9C%BA%E6%AD%A3%E5%9C%A8%E6%8D%95%E6%8D%89%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%8C%E8%AF%B7%E6%B7%BB%E5%8A%A0%E4%B8%80%E4%B8%AA%20tee%20%E5%85%83%E7%B4%A0%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3Egst%E5%90%AF%E5%8A%A8v4l2src%20num%E7%BC%93%E5%86%B2%E5%8C%BA%3D-1%EF%BC%81tee%20%E5%90%8D%E7%A7%B0%3Dt%EF%BC%81%E9%98%9F%E5%88%97%20%EF%BC%81mfw_v4lsink%20t.%EF%BC%81%E9%98%9F%E5%88%97%20%EF%BC%81vpuenc%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%3D0%EF%BC%81matroskamux%EF%BC%81%E6%96%87%E4%BB%B6%E6%8E%A5%E6%94%B6%E5%99%A8%E4%BD%8D%E7%BD%AE%3D%E8%BE%93%E5%87%BA.mkv%20%E5%90%8C%E6%AD%A5%3Dfalse%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%3CSTRONG%3E%E8%A7%86%E9%A2%91%EF%BC%8C%E6%9D%A5%E8%87%AA%E5%B9%B6%E8%A1%8C%2FMIPI%20%E6%91%84%E5%83%8F%E5%A4%B4%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E5%9C%A8%E6%89%A7%E8%A1%8C%E7%AE%A1%E9%81%93%E4%B9%8B%E5%89%8D%E9%9C%80%E8%A6%81%E5%8A%A0%E8%BD%BD%E6%91%84%E5%83%8F%E5%A4%B4%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85BSP%E6%96%87%E6%A1%A3%E4%BB%A5%E4%BA%86%E8%A7%A3%E9%9C%80%E8%A6%81%E5%8A%A0%E8%BD%BD%E5%93%AA%E4%B8%AA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20MIPI%EF%BC%88J5%E7%AB%AF%E5%8F%A3%EF%BC%89%EF%BC%9A%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3Emodprobe%20ov5640_camera_mipi%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3Emodprobe%20mxc_v4l2_capture%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E5%B9%B6%E8%A1%8C%EF%BC%88J9%20%E7%AB%AF%E5%8F%A3%EF%BC%89%EF%BC%9A%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3Emodprobe%20ov5642_camera%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3Emodprobe%20mxc_v4l2_capture%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3EGST%E5%90%AF%E5%8A%A8mfw_v4lsrc%EF%BC%81%E9%98%9F%E5%88%97%20%EF%BC%81vpuenc%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%3D0%EF%BC%81matroskamux%EF%BC%81%E6%96%87%E4%BB%B6%E6%8E%A5%E6%94%B6%E5%99%A8%E4%BD%8D%E7%BD%AE%3D%E8%BE%93%E5%87%BA.mkv%20%E5%90%8C%E6%AD%A5%3Dfalse%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%23%20%E6%89%A7%E8%A1%8C%E2%80%9Cgst-inspect%20mfw_v4lsrc%E2%80%9D%E6%88%96%E2%80%9Cgst-inspect%20vpuenc%E2%80%9D%E6%9D%A5%E6%9F%A5%E7%9C%8B%E5%85%B6%E4%BB%96%E5%8F%AF%E8%83%BD%E7%9A%84%E8%AE%BE%E7%BD%AE%EF%BC%88%E5%88%86%E8%BE%A8%E7%8E%87%E3%80%81fps%E3%80%81%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E7%AD%89%EF%BC%89%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1123743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_%E5%85%A8%E9%83%A8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E5%A4%9A%E5%AA%92%E4%BD%93%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AGStreamer%20i.MX6%E7%BC%96%E7%A0%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E8%A7%86%E9%A2%91%2F%E9%9F%B3%E9%A2%91%E5%BD%95%E5%88%B6%E7%9A%84%E5%91%BD%E4%BB%A4%EF%BC%9F%E8%B0%A2%E8%B0%A2%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AGStreamer%20i.MX6%E7%BC%96%E7%A0%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%87%E6%80%AA%E7%9A%84%E3%80%82%E4%BD%BF%E7%94%A8%20gplay%20%E9%87%8D%E7%8E%B0%E5%BD%95%E5%88%B6%E7%9A%84%E8%A7%86%E9%A2%91%E6%97%B6%E6%82%A8%E6%98%AF%E5%90%A6%E7%9C%8B%E5%88%B0%E4%BA%86%E7%9B%B8%E5%90%8C%E7%9A%84%E8%A1%8C%E4%B8%BA%EF%BC%9Fgplay%20%E5%9C%A8%E7%9B%AE%E6%A0%87%E4%B8%8A%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1123744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AGStreamer%20i.MX6%E7%BC%96%E7%A0%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1123744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3EHi%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%20%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E8%BE%B9%E7%95%8C%E8%AE%BE%E5%A4%87%20sabreLite%EF%BC%8C%E5%BD%93%E5%B0%9D%E8%AF%95%E4%BB%8E%20ov5640%20mipi%20%E5%BD%95%E5%88%B6%E8%A7%86%E9%A2%91%E6%97%B6%EF%BC%8C%E6%98%BE%E7%A4%BA%E4%BA%86%E4%B8%80%E4%BA%9B%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSTRONG%3EGST%E5%90%AF%E5%8A%A8mfw_v4lsrc%EF%BC%81%E9%98%9F%E5%88%97%20%EF%BC%81vpuenc%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%3D0%EF%BC%81matroskamux%EF%BC%81%E6%96%87%E4%BB%B6%E6%8E%A5%E6%94%B6%E5%99%A8%E4%BD%8D%E7%BD%AE%3D%E8%BE%93%E5%87%BA.mkv%20%E5%90%8C%E6%AD%A5%3Dfalse%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eoutput%20msg%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMFW_GST_V4LSRC_PLUGIN%203.0.8%E6%9E%84%E5%BB%BA%E4%BA%8E%202014%20%E5%B9%B4%209%20%E6%9C%88%2023%20%E6%97%A5%2005%3A49%3A17%E3%80%82%3C%2FP%3E%3CP%3E%E5%B0%86%E7%AE%A1%E9%81%93%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%9A%82%E5%81%9C%E7%8A%B6%E6%80%81...%3C%2FP%3E%3CP%3E%5BINFO%5D%20%E4%BA%A7%E5%93%81%E4%BF%A1%E6%81%AF%EF%BC%9Ai.MX6Q%2FD%2FS%3C%2FP%3E%3CP%3Evpuenc%20%E7%89%88%E6%9C%AC%3C%2FP%3E%3CP%3E%26nbsp%3B%20plugin%3A%203.0.8%3C%2FP%3E%3CP%3E%E5%8C%85%E8%A3%85%E5%99%A8%EF%BC%9A1.0.38%EF%BC%88VPUWRAPPER_ARM_LINUX%E6%9E%84%E5%BB%BA%E4%BA%8E%202014%20%E5%B9%B4%209%20%E6%9C%88%2023%20%E6%97%A5%2005%3A42%3A43)%3C%2FP%3E%3CP%3E%26nbsp%3B%20vpulib%3A%205.4.15%3C%2FP%3E%3CP%3E%E5%9B%BA%E4%BB%B6%EF%BC%9A2.3.10.40778%3C%2FP%3E%3CP%3E%E7%AE%A1%E9%81%93%E6%98%AF%E6%B4%BB%E7%9A%84%EF%BC%8C%E4%B8%8D%E9%9C%80%E8%A6%81%E9%A2%84%E6%BB%9A......%3C%2FP%3E%3CP%3E%E5%B0%86%E7%AE%A1%E9%81%93%E8%AE%BE%E7%BD%AE%E4%B8%BAPLAYING%20...%3C%2FP%3E%3CP%3E%E6%96%B0%E6%97%B6%E9%92%9F%EF%BC%9AGstSystemClock%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%9D%A5%E8%87%AA%E5%85%83%E7%B4%A0%2FGstPipeline%EF%BC%9Apipeline0%2FMFWGstV4LSrc%EF%BC%9Amfwgstv4lsrc0%EF%BC%9A%E5%86%85%E9%83%A8%E6%95%B0%E6%8D%AE%E6%B5%81%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E9%99%84%E5%8A%A0%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3Egstbasesrc.c(2625)%3A%20gst_base_src_loop()%3A%2FGstPipeline%3Apipeline0%2FMFWGstV4LSrc%3Amfwgstv4lsrc0%3A%3C%2FP%3E%3CP%3E%E6%B5%81%E4%BB%BB%E5%8A%A1%E6%9A%82%E5%81%9C%EF%BC%8C%E5%8E%9F%E5%9B%A0%E9%94%99%E8%AF%AF%EF%BC%88-5%EF%BC%89%3C%2FP%3E%3CP%3E%E6%89%A7%E8%A1%8C%E5%9C%A8%209999770667%20%E7%BA%B3%E7%A7%92%E5%90%8E%E7%BB%93%E6%9D%9F%E3%80%82%3C%2FP%3E%3CP%3E%E5%B0%86%E7%AE%A1%E9%81%93%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%9A%82%E5%81%9C%E7%8A%B6%E6%80%81...%3C%2FP%3E%3CP%3E%E5%B0%86%E7%AE%A1%E9%81%93%E8%AE%BE%E7%BD%AE%E4%B8%BA%E2%80%9C%E5%B0%B1%E7%BB%AA%E2%80%9D...%3C%2FP%3E%3CP%3E%E5%B0%86%E7%AE%A1%E9%81%93%E8%AE%BE%E7%BD%AE%E4%B8%BA%20NULL%20...%3C%2FP%3E%3CP%3E%E9%87%8A%E6%94%BE%E7%AE%A1%E9%81%93...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-----------------------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E5%8C%85%E5%90%AB%E6%8D%95%E8%8E%B7%E6%A8%A1%E5%BC%8F%E6%97%B6%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egst%E5%90%AF%E5%8A%A8mfw_v4lsrc%3CSTRONG%3E%E6%8D%95%E8%8E%B7%E6%A8%A1%E5%BC%8F%3D4%3C%2FSTRONG%3E%20%EF%BC%81%E9%98%9F%E5%88%97%20%EF%BC%81vpuenc%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%3D0%EF%BC%81matroskamux%EF%BC%81%E6%96%87%E4%BB%B6%E6%8E%A5%E6%94%B6%E5%99%A8%E4%BD%8D%E7%BD%AE%3D%E8%BE%93%E5%87%BA.mkv%20%E5%90%8C%E6%AD%A5%3Dfalse%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Els%20-al%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-rwxr-xr-x%201%20root%20root%2010476028%202014%E5%B9%B410%E6%9C%8813%E6%97%A5%20%E8%BE%93%E5%87%BA.mkv%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%20vlc%20%E4%B8%AD%E6%89%93%E5%BC%80%E6%97%B6%EF%BC%8C%E5%AE%83%E6%98%BE%E7%A4%BA%E7%9A%84%E5%83%8F%E5%9B%BE%E5%83%8F%EF%BC%88%E7%85%A7%E7%89%87%EF%BC%89%E8%80%8C%E4%B8%8D%E6%98%AF%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E7%9A%84%E8%A7%86%E9%A2%91%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E5%B8%AE%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E2%80%94%E6%96%AF%E9%87%8C%E8%BE%BE%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-28-2012 01:04 PM
更新人:
