Encrypted boot loader on SabreSD i.MX6q board
     This documents shows how to secure and encrypt boot loader image for i.MX6 processor. Secure boot is necessary to be sure that CPU is allowed to run genuine and authentic images. Encrypted image secures your intellectual property from theft. Both methods secure/encryption can be extended to cover whole software on board.
Boot loader image encryption is easy to do with CST tools and HAB feature build in Freescale processor. Encrypted image preparation is consist of three parts:
    • Encrypt u-boot.imx plain image by CST utility;
    • Wrap DEK to get DEK blob by specific board;
    • Append DEK blob key to the u-boot image.
In this document as reference board we used SABRESD iMX6q. But it's easily to adjust it for any other board based on i.MX6 CPU with HAB4.1 feature.
Encrypted u-boot image consist of: IVT, DCD, u-boot.bin, CSF, dek_blob.bin. In our example finished u-boot_encrypted.imx image looks like:
Address in file
Data
0x000000IVT
0x000020DCD + pad to address 0xC00
0x000C00
u-boot.bin + pad to address* 0x7BC000
0x07DBB8CSF bin data + pad to address** 0x07DBB8 + Wrapped DEK (dek_blob.bin)**
* (IVT + DCD + u-boot.bin) has to be padded to align 0x1000.
** (CSF bin data + padding + dek_blob.bin) has to have size 0x2000
Step-by-step instruction:
  1. Clone u-boot git repository.
    $ mkdir ~/imx6encryption
    $ cd ~/imx6encryption
    $ git clone git://git.denx.de/u-boot.git
    $ cd u-boot
    $ git checkout v2016.03 -b tmp
  2. To enable secure features in u-boot modify the following files:
    • Add function usec2ticks to the end of file timer.c.
      $ nano arch/arm/imx-common/timer.c
      unsigned long usec2ticks(unsigned long usec)
              ulong ticks;
              if (usec < 1000)
                      ticks = ((usec * (get_tbclk()/1000)) + 500) / 1000;
              else
                      ticks = ((usec / 10) * (get_tbclk() / 100000));
              return ticks;
      Press Ctrl+X and Y and Enter to save changes.
    • In file mx6q_4x_mt41j128.cfg add string CSF 0x2000 after string BOOT_FROM sd
      $ nano board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg
    • Add defines in file mx6sabresd.h before string #define CONFIG_MACH_TYPE 3980.
      $ nano include/configs/mx6sabresd.h
      #define CONFIG_SECURE_BOOT
      #define CONFIG_SYS_FSL_SEC_COMPAT    4 /* HAB version */
      #define CONFIG_FSL_CAAM
      #define CONFIG_CMD_DEKBLOB
      #define CONFIG_SYS_FSL_SEC_LE
      #define CONFIG_FAT_WRITE
    • Delete the following strings:
      gpimage.0 \
      gpimage-common.o \
      omapimage.o \
      in Makefile.
      $ nano tools/Makefile
  3. Download Linaro GCC compiler.
    $ wget -c https://releases.linaro.org/components/toolchain/binaries/5.3-2016.02/arm-linux-gnueabihf/gcc-linaro...
    $ tar xf gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf.tar.xz
    $ export CC=`pwd`/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-
    Check compiler version.
    $ ${CC}gcc --version
    Output:
    arm-linux-gnueabihf-gcc (Linaro GCC 5.3-2016.02) 5.3.1 20160113
    Copyright (C) 2015 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions.  There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
  4. Build u-boot image with mx6qsabresd_defconfig.
    $ cd u-boot
    $ make ARCH=arm CROSS_COMPILE=${CC} distclean
    $ make ARCH=arm CROSS_COMPILE=${CC} mx6qsabresd_defconfig
  5. Using mkimage utility build and get information of u-boot.imx image.
    $ ./tools/mkimage -T imximage -n board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg.cfgtmp -e 0x17800000 -d u-boot.bin u-boot.imx
    Output:
    Image Type:   Freescale IMX Boot Image
    Image Ver:    2 (i.MX53/6/7 compatible)
    Data Size:    516096 Bytes = 504.00 kB = 0.49 MB
    Load Address: 177ff420
    Entry Point:  17800000
    HAB Blocks:   177ff400 00000000 0007bc00
  6. Register an account on NXP website to have access to download NXP Code Signing Tool for the High Assurance Boot library. Copy downloaded archive into imx6encryption folder.
    $ tar xf cst-2.3.1.tar.gz
    $ cd cst-2.3.1
    $ chmod u+x linux64/* keys/*
  7. Compile back end sources of CST utility
    $ sudo apt-get install libssl-dev
    $ cd ~/imx6encryption/cst-2.3.1/code/back_end/src
    $ gcc -o cst -I ../hdr -L ../../../linux64/lib *.c -lfrontend -lcrypto
    $ mv cst ../../../linux64
  8. Generate keys and certificates which will be used to sign boot loader image.
    $ cd ~/imx6encryption/cst-2.3.1/keys
    • Create file serial.
      $ nano serial
      Enter 8 random digits, for example:
      12345678
    • Create key_pass.txt
      $ nano key_pass.txt
      Enter two lines of identical text:
      HelloWorld
      HelloWorld
    • Execute hab4_pki_tree.sh.
      $ ./hab4_pki_tree.sh
      Do you want to use an existing CA key (y/n)?: n
      Enter key length in bits for PKI tree: 2048
      Enter PKI tree duration (years): 10
      How many Super Root Keys should be generated? 4
      Do you want the SRK certificates to have the CA flag set? (y/n)?: y
  9. Generate SRK table.
    $ cd ~/imx6encryption/cst-2.3.1/crts
    $ ../linux64/srktool -h 4 -t SRK_1_2_3_4_table.bin -e SRK_1_2_3_4_fuse.bin -d sha256 -c ./SRK1_sha256_2048_65537_v3_ca_crt.pem,./SRK2_sha256_2048_65537_v3_ca_crt.pem,./SRK3_sha256_2048_65537_v3_ca_crt.pem,./SRK4_sha256_2048_65537_v3_ca_crt.pem -f 1
  10. CST utility requires CSF script. This file describes certificates, keys and the data ranges used in sign and encryption functions. Create u-boot.csf file.
    $ cd ~/imx6encryption/cst-2.3.1/linux64
    $ nano u-boot.csf
    And put the following text:
    [Header]
    Version = 4.1
    Hash Algorithm = SHA256
    Engine Configuration = 0
    Certificate Format = X509
    Signature Format = CMS
    Engine = CAAM
    [Install SRK]
    File = "../crts/SRK_1_2_3_4_table.bin"
    # Index of the key location in the SRK table to be installed
    Source index = 0
    [Install CSFK]
    # Key used to authenticate the CSF data
    File = "../crts/CSF1_1_sha256_2048_65537_v3_usr_crt.pem"
    [Authenticate CSF]
    [Unlock]
    Engine = CAAM
    Features = RNG
    [Install Key]
    # Key slot index used to authenticate the key to be installed
    Verification Index = 0
    # Key to install
    Target Index = 2
    File = "../crts/IMG1_1_sha256_2048_65537_v3_usr_crt.pem"
    [Authenticate Data]
    # Key slot index used to authenticate the image data
    Verification Index = 2
    #       Address   Offset        Length      Data File Path
    Blocks = 0x177ff400 0x00000000 0x00000C10 "./u-boot.imx"
    #Encrypt the boot image and create a DEK
    [Install Secret Key]
    Target Index = 0
    Key = "./dek.bin"
    Key Length = 128
    Blob Address = 0x1787CFB8
    #Provide DEK blob location to decrypt
    [Decrypt Data]
    Mac Bytes = 16
    Blocks = 0x17800010 0x00000C10 0x0007AFF0 "./u-boot.imx"
  11. Execute CST utility to encrypt image. Note that after execution u-boot.imx file will be encrypted.
    $ cp ~/imx6encryption/u-boot/u-boot.imx .
    $ ./cst --o u-boot_csf.bin < u-boot.csf
    $ objcopy -I binary -O binary --pad-to=0x1FB8 --gap-fill=0x00 u-boot_csf.bin u-boot_csf.bin
  12. Prepare SD card partition table. Check SD card name in system ($dmesg | tail), for example used /dev/sdb.
    $ echo -e "o""\n""n""\n""p""\n""1""\n""2048""\n""+256M""\n""w" | sudo fdisk /dev/sdb
    $ sudo mkfs.vfat /dev/sdb1
    $ cd ~/imx6encryption/u-boot
    $ sudo dd if=u-boot.imx of=/dev/sdb bs=512 seek=2
    $ sync
  13. Wrap DEK to get DEK blob from i.MX6 CPU. Mount partition 1 and copy dek.bin file to the 1st FAT partition on SD card.
    $ mkdir /tmp/partition0
    $ sudo mount /dev/sdb1 /tmp/partition0
    $ sudo cp dek.bin /tmp/partition0
    $ sudo umount /tmp/partition0
  14. Insert SD card into the board. And press any key to enter into u-boot prompt. Firstly load dek.bin to the RAM memory. Use dek_blob command to wrap dek.bin. Write file from RAM memory to SD card.
    => fatload mmc 1:1 0x10800000 dek.bin
    => dek_blob 0x10800000 0x10801000 128
    => fatwrite mmc 1:1 0x10801000 dek_blob.bin 0x48
  15. Append DEK blob key to the u-boot image. Mount SD card partition 1 and copy dek_blob.bin file to the linux64 folder.
    $ mkdir -p /tmp/partition0
    $ cd /tmp/partition0
    $ cp dek_blob.bin ~/imx6encryption/cst-2.3.1/linux64/
    $ cd ~/imx6encryption/cst-2.3.1/linux64/
    $ cat u-boot_csf.bin >> u-boot.imx
    $ cat dek_blob.bin >> u-boot.imx
  16. Install encrypted u-boot.imx into SD card.
    $ sync
  17. Insert SD card into the board. Press any key to enter into u-boot prompt. And check if hab_status command executes without HAB Event errors.
    => hab_status
  18. Attention, OTP fuses can be programmed once, double check everything before burning. If everything is fine, burn required fuses SRK_HASH, SEC_CONFIG as described in AN4581.
As a result we have encrypted boot image which can be loaded and executed by only current board. Because dek_blob.bin is unique per i.MX6 CPU.
Vitaliy Vasinovich
April 2016
コメント
Hi Vitaliy Vasinovich,
It is useful for me.
I could run u-boot.imx with HAB.
Now i want to load SPL and u-boot.img with HAB on imx6q, i have built SPL and u-boot.img and run successfully without HAB. I have a question: how to run SPL and u-boot.img with HAB?
Thanks you so much.
Dang
Hi Dang,
In my design I use u-boot image without SPL.
Looks like HAB with (SPL + U-boot) has quite different preparation procedure.
I guess you need to attach IVT, DCD, CSF to SPL image.
CPU's ROM will decrypt and verify SPL image and execute SPL.
I tried to attach IVT, DCD, CSF to SPL image but it could not work.
Can you help me??
IVT, device configuration data (DCD in code) are already included in SPL image.
Try sign/encrypt SPL separately, it requires to adjust IVT a little bit, and attach CSF data at the end of SPL.
Please pay attention to u-boot.bin executable address in SPL image.
Hello Vitaliy Vasinovich,
many thanks for this example. It shows all necessary steps.
However, I have a slightly different environment:
6sx sabre-SDB evaluation board, buildroot-2015.11.1, uboot-rel_imx_3.10.53_1.1.0_ga
The steps 1 .. 4 worked with light deviations (tools/Makefile does not reference files gpimages* and without omapimage.o build is not successful).
The first real problem I got with step 5:
./tools/mkimage -T imximage -n board/freescale/mx6sxsabresd/imximage.cfg.cfgtmp -e 0x17800000 -d u-boot.bin u-boot.imx
Image Ver:    2 (i.MX53/6 compatible)
Mode:         DCD
Data Size:    352256 Bytes = 344.00 kB = 0.34 MB
There is no line "HAB Blocks". How can I get it? --help did not help me there.
Steps 6 .. 9 worked perfectly.
Step 10 I used the same values as in your example, which is obviously wrong since in step 11 I get the following error:
Invalid Block arguments, Blocks start offset and length together exceed file size in command AuthenticateData
May you please explain how to get the values for addresses, offset, length? Why is authenticate data address 0x20 different to load address? Why is decrypt data 0x10 different to entry point? ...
Is there already a document where this is captured?
Thank you very much
  Alex
Thank you very much for a very useful document!
However, it's failed to boot encrypted u-boot.
1. I followed all steps that most of them are successful, except step 17, hab_status. Nothing shown, u-boot is not loaded, isn't it? Because the uboot was encrypted, "for i.MX 6 Seriesin Open configuration, the HAB always skips the
verification of the SRK table, regardless of whether the SRK fuse field has been provisioned or not
" (in AN4581, 7.1 SRK Authentication for i.MX 6 Series in Open Configuration). Am I correct?
2. If encryption skipped by removing #Encrypt the boot image and create a DEK till the end of u-boot.csf, the u-boot is only signed, so I can check hab_status and "No HAB Events Found!".
After all, I did Close Configuration (fuse prog 0 6 0x2), only signed u-boot can be loaded. However, encrypted u-boot cann't.
Could you instruct me more?
Thank you!
An.
Thank you for the guide. I have been able to experiment with both signing-only and signing+encryption on my open device, making sure "No HAB Events Found!" was reported in U-Boot.
Then after blowing the fuse to close the device didn't boot. So my first reaction was: "it is very buggy to have HAB reporting no error in open configuration but then fail in close configuration".
I kept digging and found this post:
i.MX6 HAB secure boot fuse problem
Thanks to that undocumented comment, I realized my problem was that I use 4096-bit keys.
So for recovering my board using the Serial Download Protocol (SDP) with imx_usb_loader, I was able to load a signed-only binary by adding this to my signing-only csf:
Engine = CAAM
However I still can't get encryption to work, although, once again, it was working fine in open configuration reporting no HAB Events.
So my question: have 4096-bit keys been tested with encryption on close devices?
Looking at the HABCST_UG.pdf, it seems that a configuration for 4096 keys is provided (section 5.3.5):
  • It doesn't have the [UNLOCK] section
    • Does this configuration force to set the RNG Trim in Fuse?
  • It is providing the .der files instead of the .pem files, is it normal?
Please advise.
Gary
Hi.
Where do you get the signed header length from (0xc10 in the example above)?
Thanks.
I realize this thread is more than a year old, but I've been through the pain-staking process of trying to get encrypted, secure boot working on i.MX6 plus a usable bulk manufacturing production process (which NXP doesn't seem to consider with encrypted boot), and I've learned a lot, including perhaps a reason why your encrypted boot still doesn't work.
If you read this thread:
https://community.nxp.com/thread/308950
you find that the i.MX SoCs use a common test master key when it is not "closed" (booted with secure boot lock) and the unique OTP master key when secure boot is closed.  So if you follow the mostly excellent steps provided by Vitaliy, you get the dek blob of the test key, NOT the OTPMK that is used once the device is closed.  So if you wrapped a DEK using u-boot dek_blob command before closing secure boot, HAB will fail to decrypt the image after secure boot is closed since the DEK is wrapped with a different key.
I understand the point of having test keys versus unique "production" keys in a single SoC (although other SoC vendors use different part numbers for these), but it does mean that a manufacturing process has to burn the hash fuses and secure boot lock fuse, then reboot, and then wrap the DEK for the encrypted image.  The horrible NXP mfgtools doesn't handle multi-step mfg process (with reboot) well, so it's "left to the engineer" to come up with a solution, which I've already had to do to support programming unique MAC addresses.
The forums here are really nice.  I just wish NXP put more effort into accurate and complete documentation and usable tools so each of us doesn't have to spend hours on google trying to find answers that should have been in the application note in the first place.
dek_blob.bin need to generate by u-boot ,  How to do this in production?
You have to get creative.  You can have mfgtool push the DEK to an address before you jump to u-boot, and then have your mfg version of u-boot automatically create a dek_blob from that address and store it somewhere (i.e. some unused / reserved area of RAM or specific block of flash) so that when the mfg linux os runs it can pull the dek blob from there and dynamically append it to the encrypted image before writing.  It's ugly, but unfortunately I don't know how to do this all within linux.
%3CLINGO-SUB%20id%3D%22lingo-sub-1120029%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESabreSD%20i.MX6q%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E6%9A%97%E5%8F%B7%E5%8C%96%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120029%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%20%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81i.MX6%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%20%E3%83%AD%E3%83%BC%E3%83%80%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BF%9D%E8%AD%B7%E3%81%8A%E3%82%88%E3%81%B3%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%81%AF%E3%80%81CPU%E3%81%8C%E6%AD%A3%E8%A6%8F%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%A8%E6%9C%AC%E7%89%A9%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E7%94%BB%E5%83%8F%E3%81%AF%E3%80%81%E7%9F%A5%E7%9A%84%E8%B2%A1%E7%94%A3%E3%82%92%E7%9B%97%E9%9B%A3%E3%81%8B%E3%82%89%E4%BF%9D%E8%AD%B7%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%82%E3%80%81%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%2F%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%AF%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E5%85%A8%E4%BD%93%E3%82%92%E3%82%AB%E3%83%90%E3%83%BC%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E6%8B%A1%E5%BC%B5%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%BB%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%AF%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AB%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9FCST%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A8HAB%E6%A9%9F%E8%83%BD%E3%81%A7%E7%B0%A1%E5%8D%98%E3%81%AB%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E6%BA%96%E5%82%99%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%203%20%E3%81%A4%E3%81%AE%E9%83%A8%E5%88%86%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CUL%20style%3D%22list-style-type%3A%20circle%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3Eu-boot.imx%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92CST%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%E3%81%A7%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3EDEK%E3%82%92%E3%83%A9%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7DEK%E3%83%96%E3%83%AD%E3%83%96%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3EDEK%20BLOB%20%E3%82%AD%E3%83%BC%E3%82%92%20u-boot%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%81%97%E3%81%A6%20%3CSPAN%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%20SABRESD%20iMX6q%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%20HAB4.1%E6%A9%9F%E8%83%BD%E3%82%92%E5%82%99%E3%81%88%E3%81%9Fi.MX6%20CPU%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%97%E3%81%9F%E4%BB%96%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AB%E7%B0%A1%E5%8D%98%E3%81%AB%E8%AA%BF%E6%95%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9Fu-boot%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AF%E3%80%81IVT%E3%80%81DCD%E3%80%81u-boot.bin%E3%80%81CSF%E3%80%81dek_blob.bin%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E5%AE%8C%E6%88%90%E3%81%97%E3%81%9Fu-boot_encrypted.imx%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20class%3D%22jiveBorder%22%20height%3D%22203%22%20jive-data-cell%3D%22%7B%22%20color%3D%22%22%3E%3CTBODY%3E%3CTR%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20color%3A%20%23505050%3B%20padding%3A%206px%3B%20background-color%3A%20%23f2f2f2%3B%22%20valign%3D%22middle%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTH%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20color%3A%20%23505050%3B%20padding%3A%206px%3B%20background-color%3A%20%23f2f2f2%3B%22%20valign%3D%22middle%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3CSTRONG%3E%E3%83%87%E3%83%BC%E3%82%BF%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTH%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%206px%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E0x000000%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%206px%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3EIVT%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%206px%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E0x000020%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%206px%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3EDCD%20%2B%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E6%8C%87%E5%AE%9A%E7%94%A8%E3%83%91%E3%83%83%E3%83%89%200xC00%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%206px%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E0x000C00%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%206px%3B%20text-align%3A%20left%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3Eu-boot.bin%20%2B%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E6%8C%87%E5%AE%9A%E3%81%B8%E3%81%AE%E3%83%91%E3%83%83%E3%83%89*%200x7BC000%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%206px%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E0x07DBB8%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%206px%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3ECSF%20%E3%83%93%E3%83%B3%20%E3%83%87%E3%83%BC%E3%82%BF%20%2B%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%B8%E3%81%AE%E3%83%91%E3%83%83%E3%83%89**%200x%3CSPAN%20style%3D%22font-size%3A%2016px%3B%22%3E07DBB8%3C%2FSPAN%3E%20%2B%20%E3%83%A9%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%81%9F%20DEK%20(dek_blob.bin)**%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3C%2FSPAN%3E%E2%80%BB(IVT%2BDCD%2Bu-boot.bin)0x1000%E3%82%92%E6%8F%83%E3%81%88%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%83%91%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E**%20(CSF%20%E3%83%93%E3%83%B3%E3%83%BB%E3%83%87%E3%83%BC%E3%82%BF%20%2B%20%E3%83%91%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20%2B%20dek_blob.bin)%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C0x2000%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%83%90%E3%82%A4%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AE%E8%AA%AC%E6%98%8E%3A%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSTRONG%3Eu-boot%3C%2FSTRONG%3E%20git%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20mkdir%20~%2Fimx6encryption%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20cd%20~%2Fimx6encryption%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20git%20clone%20git%3A%2F%2Fgit.denx.de%2Fu-boot.git%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20cd%20u-%E3%83%96%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20git%20checkout%20v2016.03%20-b%20tmp%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3Eu-boot%20%E3%81%A7%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E6%A9%9F%E8%83%BD%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSTRONG%3E%E9%96%A2%E6%95%B0%20usec2ticks%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%20%E3%82%92%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSTRONG%3E%20timer.c%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%20%E3%81%AE%E6%9C%AB%E5%B0%BE%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%20%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20nano%20arch%2Farm%2Fimx-common%2Ftimer.c%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3Eunsigned%20long%20usec2ticks(%E7%AC%A6%E5%8F%B7%E3%81%AA%E3%81%97long%20usec)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%82%A6%E3%83%BC%E3%83%AD%E3%83%B3%E3%83%80%E3%83%8B%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3EIF(USEC%20%26lt%3B%201000)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%20%3D%20((usec%20*%20(get_tbclk()%2F1000))%20%2B%20500)%20%2F%201000%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20else%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3Eticks%20%3D%20((usec%20%2F%2010)%20*%20(get_tbclk()%20%2F%20100000))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3ECtrl%2BX%20%E3%82%AD%E3%83%BC%E3%81%A8%20Y%20%E3%82%AD%E3%83%BC%E3%81%A8%20Enter%20%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%80%81%E5%A4%89%E6%9B%B4%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3CSPAN%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSTRONG%3Emx6q_4x_mt41j128.cfg%3C%2FSTRONG%3E%20%E3%81%A7%E3%81%AF%E3%80%81%3C%2FSPAN%3Edd%20%E6%96%87%E5%AD%97%E5%88%97%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSTRONG%3ECSF%200x2000%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%20%E6%96%87%E5%AD%97%E5%88%97%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSTRONG%3EBOOT_FROM%20sd%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%E3%81%AE%E5%BE%8C%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20nano%20board%2Ffreescale%2Fmx6sabresd%2Fmx6q_4x_mt41j128.cfg%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3ECtrl%2BX%20%E3%82%AD%E3%83%BC%E3%81%A8%20Y%20%E3%82%AD%E3%83%BC%E3%81%A8%20Enter%20%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%80%81%E5%A4%89%E6%9B%B4%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSTRONG%3Emx6sabresd.h%3C%2FSTRONG%3E%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%AE%9A%E7%BE%A9%E3%82%92%E8%BF%BD%E5%8A%A0%E6%96%87%E5%AD%97%E5%88%97%20%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%3E%23define%20CONFIG_MACH_TYPE%203980%3C%2FSPAN%3E%3C%2FSTRONG%3E%20%E3%82%88%E3%82%8A%E5%89%8D%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20nano%20include%2Fconfigs%2Fmx6sabresd.h%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%23define%20CONFIG_SECURE_BOOT%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%23define%20CONFIG_SYS_FSL_SEC_COMPAT%26nbsp%3B%26nbsp%3B%26nbsp%3B%204%20%2F*%20HAB%20version%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%23define%20CONFIG_FSL_CAAM%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%23define%20CONFIG_CMD_DEKBLOB%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%23define%20CONFIG_SYS_FSL_SEC_LE%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%23define%20CONFIG_FAT_WRITE%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3ECtrl%2BX%20%E3%82%AD%E3%83%BC%E3%81%A8%20Y%20%E3%82%AD%E3%83%BC%E3%81%A8%20Enter%20%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%80%81%E5%A4%89%E6%9B%B4%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%E6%AC%A1%E3%81%AE%E6%96%87%E5%AD%97%E5%88%97%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3Egpimage.0%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3Egpimage-common.o%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3Eomapimage.o%5C%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%81%A7%20%3CSTRONG%3E%3CSPAN%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E3%83%A1%E3%82%A4%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20nano%20tools%2FMakefile%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3ECtrl%2BX%20%E3%81%A8%20Y%20%E3%82%AD%E3%83%BC%E3%81%A8%20Enter%20%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%80%81%E5%A4%89%E6%9B%B4%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSTRONG%3ELinaro%20GCC%3C%2FSTRONG%3E%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20cd%20~%2Fimx6encryption%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20wget%20-c%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Freleases.linaro.org%252Fcomponents%252Ftoolchain%252Fbinaries%252F5.3-2016.02%252Farm-linux-gnueabihf%252Fgcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf.tar.xz%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Freleases.linaro.org%2Fcomponents%2Ftoolchain%2Fbinaries%2F5.3-2016.02%2Farm-linux-gnueabihf%2Fgcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf.tar.xz%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Freleases.linaro.org%2Fcomponents%2Ftoolchain%2Fbinaries%2F5.3-2016.02%2Farm-linux-gnueabihf%2Fgcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf.tar.xz%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20tar%20xf%20gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf.tar.xz%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20export%20CC%3D%60pwd%60%2Fgcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf%2Fbin%2Farm-linux-gnueabihf-%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20%24%7BCC%7Dgcc%20--version%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CBR%20%2F%3E%E3%82%A2%E3%82%A6%E3%83%88%E3%83%97%E3%83%83%E3%83%88%EF%BC%9A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3Earm-linux-gnueabihf-gcc%20(Linaro%20GCC%205.3-2016.02)%205.3.1%2020160113%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3ECopyright%20(C)%202015%20%E6%A0%AA%E5%BC%8F%E4%BC%9A%E7%A4%BE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E8%B2%A1%E5%9B%A3%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E3%81%99%E3%80%82%E6%9D%A1%E4%BB%B6%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E4%BF%9D%E8%A8%BC%3B%E5%95%86%E5%93%81%E6%80%A7%E3%82%84%E7%89%B9%E5%AE%9A%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%B8%E3%81%AE%E9%81%A9%E5%90%88%E6%80%A7%E3%81%AE%E3%81%9F%E3%82%81%E3%81%A7%E3%81%95%E3%81%88%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSTRONG%3Emx6qsabresd_defconfig%3C%2FSTRONG%3E%E3%81%A7u-boot%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20cd%20u-%E3%83%96%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20make%20ARCH%3Darm%20CROSS_COMPILE%3D%24%7BCC%7D%20distclean%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20make%20ARCH%3Darm%20CROSS_COMPILE%3D%24%7BCC%7D%20mx6qsabresd_defconfig%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20make%20ARCH%3Darm%20CROSS_COMPILE%3D%24%7BCC%7D%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSTRONG%3Emkimage%3C%2FSTRONG%3E%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%3CSTRONG%3Eu-boot.imx%3C%2FSTRONG%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20.%2Ftools%2Fmkimage-t%20imximage%20-n%20%E3%83%9C%E3%83%BC%E3%83%89%2F%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%2Fmx6sabresd%2Fmx6q_4x_mt41j128.cfgtmp%20-e%200x17800000%20-d%20u-boot.bin%20u-boot.imx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%E3%82%A2%E3%82%A6%E3%83%88%E3%83%97%E3%83%83%E3%83%88%EF%BC%9A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%83%BB%E3%82%BF%E3%82%A4%E3%83%97%3A%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABIMX%E3%83%96%E3%83%BC%E3%83%88%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3EImage%20Ver%3A%202%20(i.MX53%2F6%2F7%E5%AF%BE%E5%BF%9C)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%B5%E3%82%A4%E3%82%BA%3A%20516096%20%E3%83%90%E3%82%A4%E3%83%88%20%3D%20504.00%20kB%20%3D%200.49%20MB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%83%AD%E3%83%BC%E3%83%89%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A177ff420%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3A17800000%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3EHAB%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%3A177ff400%2000000000%200007bc00%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3ENXP%20Web%E3%82%B5%E3%82%A4%E3%83%88%E3%81%AB%E3%82%A2%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%A6%20%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%E3%80%81High%20Assurance%20Boot%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E7%94%A8%E3%81%AENXP%E3%82%B3%E3%83%BC%E3%83%89%E7%BD%B2%E5%90%8D%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E3%82%A2%E3%83%BC%E3%82%AB%E3%82%A4%E3%83%96%E3%82%92%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Liberation%20Serif'%2C%20serif%3B%22%3E%E3%80%8C%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3Eimx6encryption%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'Liberation%20Serif'%2C%20serif%3B%22%3E%E3%80%8D%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20cd%20~%2Fimx6encryption%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20tar%20XF%20cst-2.3.1.tar.gz%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20cd%20cst-2.3.1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20chmod%20u%2Bx%20linux64%2F*%20keys%2F*%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3ECST%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AE%E3%83%90%E3%83%83%E3%82%AF%E3%82%A8%E3%83%B3%E3%83%89%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20sudo%20apt-get%20libssl-dev%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20cd%20~%2Fimx6encryption%2Fcst-2.3.1%2Fcode%2Fback_end%2Fsrc%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20gcc%20-o%20cst%20-I%20..%2Fhdr%20-L%20..%2F..%2F..%2Flinux64%2Flib%20*.c%20-lfrontend%20-lcrypto%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20mv%20cst%20..%2F..%2F..%2Flinux64%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E7%BD%B2%E5%90%8D%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%AD%E3%83%BC%E3%81%A8%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%24%20cd%20~%2Fimx6encryption%2Fcst-2.3.1%2Fkeys%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CUL%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSTRONG%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FSTRONG%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%24%20nano%20serial%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%80%818%20%E6%A1%81%E3%81%AE%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%81%AA%E6%95%B0%E5%AD%97%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E12345678%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3ECtrl%2BX%20%E3%82%AD%E3%83%BC%E3%81%A8%20Y%20%E3%82%AD%E3%83%BC%E3%81%A8%20Enter%20%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%80%81%E5%A4%89%E6%9B%B4%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSTRONG%3Ekey_pass.txt%3C%2FSTRONG%3E%E3%82%92%E4%BD%9C%E6%88%90%3CBR%20%2F%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%24%E3%83%8A%E3%83%8Ekey_pass.txt%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%E5%90%8C%E3%81%98%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%82%92%202%20%E8%A1%8C%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%83%8F%E3%83%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3ECtrl%2BX%20%E3%82%AD%E3%83%BC%E3%81%A8%20Y%20%E3%82%AD%E3%83%BC%E3%81%A8%20Enter%20%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%80%81%E5%A4%89%E6%9B%B4%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3CSTRONG%3Ehab4_pki_tree.sh%3C%2FSTRONG%3E%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24.%2Fhab4_pki_tree.sh%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E6%97%A2%E5%AD%98%E3%81%AE%20CA%20%E3%82%AD%E3%83%BC%20(y%2Fn)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3A%20n%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3EPKI%20%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E3%82%AD%E3%83%BC%E3%81%AE%E9%95%B7%E3%81%95%E3%82%92%E3%83%93%E3%83%83%E3%83%88%E5%8D%98%E4%BD%8D%E3%81%A7%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%3A%202048%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3EPKI%20%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E6%9C%9F%E9%96%93%20(%E5%B9%B4)%3A%2010%20%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%83%AB%E3%83%BC%E3%83%88%E3%82%AD%E3%83%BC%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3ESRK%20%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%81%AB%20CA%20%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F(y%2Fn)%3F%3A%20y%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3ESRK%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20cd%20~%2Fimx6encryption%2Fcst-2.3.1%2Fcrts%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20..%2Flinux64%2Fsrktool%20-h%204%20-t%20SRK_1_2_3_4_table.bin%20-e%20SRK_1_2_3_4_fuse.bin%20-d%20sha256%20-c%20.%2FSRK1_sha256_2048_65537_v3_ca_crt.pem%2C.%2FSRK2_sha256_2048_65537_v3_ca_crt.pem%2C.%2FSRK3_sha256_2048_65537_v3_ca_crt.pem%2C.%2FSRK4_sha256_2048_65537_v3_ca_crt.pem%20-f%201%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3ECST%20%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AB%E3%81%AF%20CSF%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81%E7%BD%B2%E5%90%8D%E3%81%A8%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%80%81%E3%82%AD%E3%83%BC%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%83%87%E3%83%BC%E3%82%BF%E7%AF%84%E5%9B%B2%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSTRONG%3Eu-boot.csf%3C%2FSTRONG%3E%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20cd%20~%2Fimx6encryption%2Fcst-2.3.1%2Flinux64%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20nano%20u-boot.csf%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%82%92%E5%85%A5%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%5B%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%5D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20%3D%204.1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%20%3D%20SHA256%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E6%A7%8B%E6%88%90%20%3D%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%81%AE%E5%BD%A2%E5%BC%8F%20%3D%20X509%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E7%BD%B2%E5%90%8D%E5%BD%A2%E5%BC%8F%20%3D%20CMS%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%20%3D%20CAAM%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%5BSRK%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%5D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3D%20%22..%2Fcrts%2FSRK_1_2_3_4_table.bin%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%23%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%20SRK%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E5%86%85%E3%81%AE%E4%B8%BB%E8%A6%81%E3%81%AA%E5%A0%B4%E6%89%80%E3%81%AE%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%5BCSFK%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%5D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%23%20CSF%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E8%AA%8D%E8%A8%BC%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%82%AD%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3D%20%22..%2Fcrts%2FCSF1_1_sha256_2048_65537_v3_usr_crt.pem%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%5BCSF%E3%81%AE%E8%AA%8D%E8%A8%BC%5D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%5B%E3%82%A2%E3%83%B3%E3%83%AD%E3%83%83%E3%82%AF%5D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%20%3D%20CAAM%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E7%89%B9%E5%BE%B4%20%3D%20RNG%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%5B%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%82%AD%E3%83%BC%5D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%23%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%82%AD%E3%83%BC%E3%81%AE%E8%AA%8D%E8%A8%BC%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E6%A4%9C%E8%A8%BC%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%23%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%82%AD%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%202%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3D%20%22..%2Fcrts%2FIMG1_1_sha256_2048_65537_v3_usr_crt.pem%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%5B%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E8%AA%8D%E8%A8%BC%5D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%23%20%E7%94%BB%E5%83%8F%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E8%AA%8D%E8%A8%BC%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E6%A4%9C%E8%A8%BC%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%202%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%23%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E9%95%B7%20%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%E3%83%91%E3%82%B9%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%20%3D%200x177ff400%200x00000000%200x00000C10%20%22.%2Fu-boot.imx%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%83%96%E3%83%BC%E3%83%88%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20%23Encrypt%E3%80%81DEK%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%5B%E3%82%B7%E3%83%BC%E3%82%AF%E3%83%AC%E3%83%83%E3%83%88%E3%82%AD%E3%83%BC%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%5D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E6%A4%9C%E8%A8%BC%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3EKey%20%3D%20%22.%2Fdek.bin%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E3%82%AD%E3%83%BC%E3%81%AE%E9%95%B7%E3%81%95%20%3D%20128%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3EBLOB%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%3D%200x1787CFB8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E5%BE%A9%E5%8F%B7%E5%8C%96%E3%81%99%E3%82%8B%20DEK%20BLOB%20%E3%81%AE%E5%A0%B4%E6%89%80%20%23Provide%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%5B%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E5%BE%A9%E5%8F%B7%E5%8C%96%5D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E6%A4%9C%E8%A8%BC%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%20%3D%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3EMac%E3%83%90%E3%82%A4%E3%83%88%3D%2016%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%20%3D%200x17800010%200x00000C10%200x0007AFF0%20%22.%2Fu-boot.imx%22%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3ECtrl%2BX%20%E3%82%AD%E3%83%BC%E3%81%A8%20Y%20%E3%82%AD%E3%83%BC%E3%81%A8%20Enter%20%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%80%81%E5%A4%89%E6%9B%B4%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3ECST%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20lang%3D%22EN-US%22%3E%E5%AE%9F%E8%A1%8C%E5%BE%8C%E3%80%81u-boot.imx%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20cp%20~%2Fimx6encryption%2Fu-boot%2Fu-boot.imx%20.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20.%2Fcst--o%20u-boot_csf.bin%20%26lt%3B%20u-boot.csf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20objcopy%20-I%20binary%20-O%20binary%20--pad-to%3D0x1FB8%20--gap-fill%3D0x00%20u-boot_csf.bin%20u-boot_csf.bin%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3ESD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E6%BA%96%E5%82%99%E3%81%97%3CSTRONG%3E%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSTRONG%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%86%85%E3%81%AESD%E3%82%AB%E3%83%BC%E3%83%89%E5%90%8D(%24dmesg%20%7C%20tail)%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%20%3CSTRONG%3E%2Fdev%2Fsdb%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20echo%20-e%20%22o%22%22%5Cn%22%22n%22%22%5Cn%22%22p%22%22%5Cn%22%221%22%22%5Cn%22%222048%22%22%5Cn%22%22%2B256M%22%22%5Cn%22%22w%22%20%7C%20sudo%20fdisk%20%2Fdev%2Fsdb%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20sudo%20mkfs.vfat%20%2Fdev%2Fsdb1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20cd%20~%2Fimx6encryption%2Fu-boot%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20sudo%20dd%20if%3Du-boot.imx%20of%3D%2Fdev%2Fsdb%20bs%3D512%20seek%3D2%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20sync%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3EDEK%20%E3%82%92%E3%83%A9%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%80%81i.MX6%20CPU%20%E3%81%8B%E3%82%89%20DEK%20BLOB%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B31%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97dek.bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE1%E7%95%AA%E7%9B%AE%E3%81%AEFAT%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20cd%20~%2Fimx6encryption%2Fcst-2.3.1%2Flinux64%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20mkdir%20%2Ftmp%2Fpartition0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20sudo%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%20%2Fdev%2Fsdb1%20%2Ftmp%2Fpartition0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20sudo%20cp%20dek.bin%20%2Ftmp%2Fpartition0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20sudo%20umount%20%2Ftmp%2Fpartition0%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3ESD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8C%BF%E5%85%A5%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6u-boot%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9A%E3%80%81dek.bin%E3%82%92RAM%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82dek_blob%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6dek.bin%E3%82%92%E3%83%A9%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82RAM%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%8B%E3%82%89SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3D%26gt%3B%20fatload%20mmc%201%3A1%200x10800000%20dek.bin%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3D%26gt%3B%20dek_blob%200x10800000%200x10801000%20128%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3D%26gt%3B%20Fatwrite%20MMC%201%3A1%200x10801000%20dek_blob.bin%200x48%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3EDEK%20BLOB%20%E3%82%AD%E3%83%BC%E3%82%92%20u-boot%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82SD%E3%82%AB%E3%83%BC%E3%83%89%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B31%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%20%3CSTRONG%3Edek_blob.bin%3C%2FSTRONG%3E%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%20%3CSTRONG%3Elinux64%3C%2FSTRONG%3E%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20mkdir%20-p%20%2Ftmp%2Fpartition0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20sudo%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%20%2Fdev%2Fsdb1%20%2Ftmp%2Fpartition0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20cd%20%2Ftmp%2Fpartition0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20cp%20dek_blob.bin%20~%2Fimx6encryption%2Fcst-2.3.1%2Flinux64%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20cd%20~%2Fimx6encryption%2Fcst-2.3.1%2Flinux64%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20sudo%20umount%20%2Ftmp%2Fpartition0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20cat%20u-boot_csf.bin%20%26gt%3B%26gt%3B%20u-boot.imx%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20cat%20dek_blob.bin%20%26gt%3B%26gt%3B%20u-boot.imx%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9Fu-boot.imx%E3%82%92SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20sudo%20dd%20if%3Du-boot.imx%20of%3D%2Fdev%2Fsdb%20bs%3D512%20seek%3D2%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%24%20sync%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3ESD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8C%BF%E5%85%A5%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%80%81u-boot%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%20%3CSTRONG%3Ehab_status%3C%2FSTRONG%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8CHAB%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AA%E3%81%97%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3D%26gt%3B%20hab_status%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E6%B3%A8%E6%84%8F%E3%80%81OTP%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E3%81%AF%E4%B8%80%E5%BA%A6%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E3%81%8D%E3%80%81%E7%87%83%E7%84%BC%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%80%81%20%3CSTRONG%3EAN4581%3C%2FSTRONG%3E%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BASRK_HASH%20SEC_CONFIG%E7%87%83%E3%82%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%E3%81%9D%E3%81%AE%E7%B5%90%E6%9E%9C%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%E3%81%BF%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%96%E3%83%BC%E3%83%88%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82dek_blob.bin%20%E3%81%AF%20i.MX6%20CPU%20%E3%81%94%E3%81%A8%E3%81%AB%E4%B8%80%E6%84%8F%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E%E3%83%B4%E3%82%A3%E3%82%BF%E3%83%AA%E3%83%BC%E3%83%BB%E3%83%B4%E3%82%A1%E3%82%B7%E3%83%8E%E3%83%93%E3%83%83%E3%83%81%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%22%3E2016%E5%B9%B44%E6%9C%88%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120040%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20SabreSD%20i.MX6q%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E6%9A%97%E5%8F%B7%E5%8C%96%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120040%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%AF%E3%83%AA%E3%82%A8%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%AA%E3%82%89%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82u-boot%20%E3%81%AB%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%20mfgtool%20%E3%81%AB%20DEK%20%E3%82%92%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%83%97%E3%83%83%E3%82%B7%E3%83%A5%E3%81%95%E3%81%9B%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81mfg%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%20u-boot%20%E3%81%A7%E3%81%9D%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8B%E3%82%89%20DEK%20%E3%82%92%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6dek_blob%20(%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81RAM%E3%81%AE%E6%9C%AA%E4%BD%BF%E7%94%A8%2F%E4%BA%88%E7%B4%84%E9%A0%98%E5%9F%9F%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF)%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81MFG%20Linux%20OS%E3%81%AE%E5%AE%9F%E8%A1%8C%E6%99%82%E3%81%AB%E3%81%9D%E3%81%93%E3%81%8B%E3%82%89DEK%E3%83%96%E3%83%AD%E3%83%96%E3%82%92%E3%83%97%E3%83%AB%E3%81%97%E3%80%81%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E5%89%8D%E3%81%AB%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB%E5%8B%95%E7%9A%84%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E9%86%9C%E3%81%84%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E7%A7%81%E3%81%AFLinux%E5%86%85%E3%81%A7%E3%81%93%E3%82%8C%E3%82%92%E3%81%99%E3%81%B9%E3%81%A6%E8%A1%8C%E3%81%86%E6%96%B9%E6%B3%95%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20SabreSD%20i.MX6q%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E6%9A%97%E5%8F%B7%E5%8C%96%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23f6f6f6%3B%20font-size%3A%2016px%3B%22%3Edek_blob.bin%20u-boot%E3%81%A7%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%20%3C%2FSPAN%3E%E6%9C%AC%E7%95%AA%E7%92%B0%E5%A2%83%E3%81%A7%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%86%E6%96%B9%E6%B3%95%E3%81%AF%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20SabreSD%20i.MX6q%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E6%9A%97%E5%8F%B7%E5%8C%96%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%AF1%E5%B9%B4%E4%BB%A5%E4%B8%8A%E5%89%8D%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E6%89%BF%E7%9F%A5%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81i.MX6%E3%81%A7%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%95%E3%82%8C%E3%80%81%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%81%95%E3%82%89%E3%81%AB%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E5%A4%A7%E9%87%8F%E7%94%9F%E7%94%A3%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9(NXP%E3%81%AF%E6%9A%97%E5%8F%B7%E5%8C%96%E3%83%96%E3%83%BC%E3%83%88%E3%81%A7%E3%81%AF%E8%80%83%E6%85%AE%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99)%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E9%AA%A8%E3%81%AE%E6%8A%98%E3%82%8C%E3%82%8B%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%92%E7%B5%8C%E9%A8%93%E3%81%97%E3%81%A6%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%96%E3%83%BC%E3%83%88%E3%81%8C%E3%81%BE%E3%81%A0%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%E7%90%86%E7%94%B1%E3%81%AA%E3%81%A9%E3%80%81%E5%A4%9A%E3%81%8F%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E5%AD%A6%E3%81%B3%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%92%E8%AA%AD%E3%82%80%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F308950%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fthread%2F308950%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3Ei.MX%20SoC%20%E3%81%AF%E3%80%81%E9%96%89%E3%81%98%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%20(%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%20%E3%83%96%E3%83%BC%E3%83%88%20%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%E8%B5%B7%E5%8B%95)%20%E5%A0%B4%E5%90%88%E3%81%AF%E5%85%B1%E9%80%9A%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%20%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%20%E3%83%96%E3%83%BC%E3%83%88%E3%81%8C%E9%96%89%E3%81%98%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AF%E4%B8%80%E6%84%8F%E3%81%AE%20OTP%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%20%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81Vitaliy%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E6%9C%80%E3%82%82%E5%84%AA%E3%82%8C%E3%81%9F%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%86%E3%81%A8%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E9%96%89%E3%81%98%E3%82%89%E3%82%8C%E3%81%9F%E5%BE%8C%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8BOTPMK%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E3%82%AD%E3%83%BC%E3%81%AEdek%E3%83%96%E3%83%AD%E3%83%96%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%20%E3%83%96%E3%83%BC%E3%83%88%E3%82%92%E9%96%89%E3%81%98%E3%82%8B%E5%89%8D%E3%81%AB%20u-boot%20dek_blob%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20DEK%20%E3%82%92%E3%83%A9%E3%83%83%E3%83%97%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%20%E3%83%96%E3%83%BC%E3%83%88%E3%81%8C%E9%96%89%E3%81%98%E3%82%89%E3%82%8C%E3%81%9F%E5%BE%8C%E3%80%81DEK%20%E3%81%AF%E5%88%A5%E3%81%AE%E3%82%AD%E3%83%BC%E3%81%A7%E3%83%A9%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81HAB%20%E3%81%AF%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E5%BE%A9%E5%8F%B7%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1%E3%81%A4%E3%81%AESoC%E3%81%AB%E3%83%86%E3%82%B9%E3%83%88%E3%82%AD%E3%83%BC%E3%81%A8%E4%B8%80%E6%84%8F%E3%81%AE%E3%80%8C%E6%9C%AC%E7%95%AA%E3%80%8D%E3%82%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AF%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C(%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E4%BB%96%E3%81%AESoC%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%E3%81%AF%E3%81%93%E3%82%8C%E3%82%89%E3%81%AB%E7%95%B0%E3%81%AA%E3%82%8B%E9%83%A8%E5%93%81%E7%95%AA%E5%8F%B7%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%E3%80%81%E8%A3%BD%E9%80%A0%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%A7%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%83%E3%82%AF%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E3%82%92%E4%BF%9D%E8%AD%B7%E3%81%97%E3%80%81%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AEDEK%E3%82%92%E3%83%A9%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%81%90%E3%82%8D%E3%81%97%E3%81%84NXP%E3%81%AE%E8%A3%BD%E9%80%A0%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AE%E8%A3%BD%E9%80%A0%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9(%E5%86%8D%E8%B5%B7%E5%8B%95%E3%82%92%E4%BC%B4%E3%81%86)%E3%82%92%E3%81%86%E3%81%BE%E3%81%8F%E5%87%A6%E7%90%86%E3%81%97%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E8%80%83%E3%81%88%E5%87%BA%E3%81%99%E3%81%AE%E3%81%AF%E3%80%8C%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%8B%E3%82%A2%E3%81%AB%E4%BB%BB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%80%8D%E3%81%9F%E3%82%81%E3%80%81%E4%B8%80%E6%84%8F%E3%81%AEMAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%99%E3%81%A7%E3%81%AB%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%AE%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%E3%81%AF%E6%9C%AC%E5%BD%93%E3%81%AB%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%80%82NXP%E3%81%8C%E6%AD%A3%E7%A2%BA%E3%81%A7%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A8%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AB%E3%82%82%E3%81%A3%E3%81%A8%E5%8A%9B%E3%82%92%E6%B3%A8%E3%81%84%E3%81%A7%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E4%B8%80%E4%BA%BA%E4%B8%80%E4%BA%BA%E3%81%8C%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AB%E6%9C%80%E5%88%9D%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%82%8B%E3%81%B9%E3%81%8D%E7%AD%94%E3%81%88%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABGoogle%E3%81%AB%E4%BD%95%E6%99%82%E9%96%93%E3%82%82%E8%B2%BB%E3%82%84%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20SabreSD%20i.MX6q%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E6%9A%97%E5%8F%B7%E5%8C%96%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi.%3C%2FP%3E%3CP%3E%E7%AC%A6%E5%8F%B7%E4%BB%98%E3%81%8D%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%AE%E9%95%B7%E3%81%95%E3%81%AF%E3%81%A9%E3%81%93%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%88%E4%B8%8A%E3%81%AE%E4%BE%8B%E3%81%AE0xc10%EF%BC%89%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20SabreSD%20i.MX6q%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E6%9A%97%E5%8F%B7%E5%8C%96%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AC%E3%82%A4%E3%83%89%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E3%80%81%E9%96%8B%E3%81%84%E3%81%A6%E3%81%84%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E7%BD%B2%E5%90%8D%E3%81%AE%E3%81%BF%E3%81%A8%E7%BD%B2%E5%90%8D%2B%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%AE%E4%B8%A1%E6%96%B9%E3%82%92%E8%A9%A6%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%80%81U-Boot%E3%81%A7%E3%80%8CHAB%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F!%E3%80%8D%E3%81%A8%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E3%82%92%E9%A3%9B%E3%81%B0%E3%81%97%E3%81%A6%E9%96%89%E3%81%98%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%A7%E3%81%99%E3%81%8B%E3%82%89%E3%80%81%E7%A7%81%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E5%8F%8D%E5%BF%9C%E3%81%AF%E3%80%81%E3%80%8CHAB%E3%81%8C%E9%96%8B%E3%81%84%E3%81%A6%E3%81%84%E3%82%8B%E6%A7%8B%E6%88%90%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AB%E3%80%81%E8%BF%91%E3%81%84%E6%A7%8B%E6%88%90%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%20%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3E%E9%9D%9E%E5%B8%B8%E3%81%AB%E3%83%90%E3%82%B0%E3%81%8C%E5%A4%9A%E3%81%84%3C%2FSTRONG%3E%20%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%82%E3%81%AE%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E6%8E%98%E3%82%8A%E7%B6%9A%E3%81%91%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F391180%22%20target%3D%22_blank%22%3Ei.MX6%20HAB%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FA%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E6%96%87%E6%9B%B8%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%81%AE%E3%81%8A%E3%81%8B%E3%81%92%E3%81%A7%E3%80%81%E7%A7%81%E3%81%AF%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E5%95%8F%E9%A1%8C%E3%81%8C4096%E3%83%93%E3%83%83%E3%83%88%E3%82%AD%E3%83%BC%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81imx_usb_loader%E3%81%A7%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB(SDP)%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E5%9B%9E%E5%BE%A9%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E7%BD%B2%E5%90%8D%E3%81%AE%E3%81%BF%E3%81%AEcsf%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E7%BD%B2%E5%90%8D%E3%81%AE%E3%81%BF%E3%81%AE%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%20%3D%20CAAM%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E3%81%BE%E3%81%A0%E6%9A%97%E5%8F%B7%E5%8C%96%E3%82%92%E6%A9%9F%E8%83%BD%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E3%80%81%3CSTRONG%3E%3C%2FSTRONG%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3EHAB%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%AA%E3%81%84%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E6%A7%8B%E6%88%90%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A0%E3%81%8B%E3%82%89%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%3A%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E4096%E3%83%93%E3%83%83%E3%83%88%E3%82%AD%E3%83%BC%E3%81%AF%E3%80%81%E8%BF%91%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%83%86%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHABCST_UG.pdf%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%A8%E3%80%814096%E3%82%AD%E3%83%BC%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%EF%BC%88%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B35.3.5%3C%2FSPAN%3E%EF%BC%89%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%5BUNLOCK%5D%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CUL%3E%3CLI%3E%E3%81%93%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%AF%E3%80%81Fuse%20%E3%81%A7%20RNG%20%E3%83%88%E3%83%AA%E3%83%A0%E3%81%8C%E5%BC%B7%E5%88%B6%E7%9A%84%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E.der%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99.pem%20%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EGary%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20SabreSD%20i.MX6q%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E6%9A%97%E5%8F%B7%E5%8C%96%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%20%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22273761%22%20data-username%3D%22vitaliyvasinovich%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fvitaliyvasinovich%22%20style%3D%22font-weight%3A%20600%3B%20font-size%3A%2011.9994px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%23017bba%3B%20text-decoration%3A%20underline%3B%22%20target%3D%22_blank%22%3E%E3%83%B4%E3%82%A3%E3%82%BF%E3%83%AA%E3%83%BC%E3%83%BB%E3%83%B4%E3%82%A1%E3%82%B7%E3%83%8E%E3%83%93%E3%83%83%E3%83%81%3C%2FA%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E3%81%AB%E6%9C%89%E7%94%A8%E3%81%AA%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F!%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9Fu-boot%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%E7%A7%81%E3%81%AF%E3%80%81%3CSTRONG%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%9717%E3%80%81hab_status%E3%82%92%E9%99%A4%E3%81%84%E3%81%A6%3C%2FSTRONG%3E%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AE%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%99%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%3CSTRONG%3E%E3%80%82%E4%BD%95%E3%82%82%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81u-boot%E3%81%AF%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FSTRONG%3Euboot%20%E3%81%AF%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%80%8C%3C%2FSPAN%3Ei.MX%206%20%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%AF%E3%80%81HAB%20%E3%81%AF%E5%B8%B8%E3%81%AB%20%3C%2FP%3E%3CP%3ESRK%20%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%81%8C%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AB%E9%96%A2%E4%BF%82%E3%81%AA%E3%81%8F%E3%80%81SRK%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E6%A4%9C%E8%A8%BC%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2016px%3B%22%3E%E3%80%8D(%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2016px%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3EAN4581%E3%80%81%3C%2FSPAN%3E%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E6%A7%8B%E6%88%90%E3%81%AE%20i.MX%206%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%AE7.1%20SRK%E8%AA%8D%E8%A8%BC)%E3%80%82%E7%A7%81%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20background-color%3A%20%23f6f6f6%3B%22%3E2.%20%E3%83%96%E3%83%BC%E3%83%88%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20%23Encrypt%20%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E6%9A%97%E5%8F%B7%E5%8C%96%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%80%81%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20background-color%3A%20%23f6f6f6%3B%22%3Eu-boot.csf%3C%2FSPAN%3E%3C%2FSPAN%3E%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%BE%E3%81%A7DEK%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81u-boot%E3%81%AF%E7%BD%B2%E5%90%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A0%E3%81%91%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81hab_status%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%80%8CHAB%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93!%E3%80%8D%E3%81%A8%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%E7%B5%90%E5%B1%80%E3%80%81%E7%A7%81%E3%81%AFClose%20Configuration(fuse%20prog%200%206%200x2)%E3%82%92%E8%A1%8C%E3%81%84%E3%80%81%E7%BD%B2%E5%90%8D%E3%81%95%E3%82%8C%E3%81%9Fu-boot%E3%81%AE%E3%81%BF%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9Fu-boot%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%E3%82%82%E3%81%A3%E3%81%A8%E6%95%99%E3%81%88%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Helvetica%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20background-color%3A%20%23f6f6f6%3B%22%3EAn.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20SabreSD%20i.MX6q%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E6%9A%97%E5%8F%B7%E5%8C%96%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%B4%E3%82%A3%E3%82%BF%E3%83%AA%E3%83%BC%E3%83%BB%E3%83%B4%E3%82%A1%E3%82%B7%E3%83%8E%E3%83%93%E3%83%83%E3%83%81%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E7%92%B0%E5%A2%83%E3%81%AF%E5%B0%91%E3%81%97%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E6SX%20sabre-SDB%20%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%E3%80%81buildroot-2015.11.1%E3%80%81uboot-rel_imx_3.10.53_1.1.0_ga%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%971%20..4%E3%81%A4%E3%81%AF%E8%BB%BD%E3%81%84%E5%81%8F%E5%B7%AE%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F(tools%20%2F%20Makefile%E3%81%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%ABgpimages%20*%E3%82%92%E5%8F%82%E7%85%A7%E3%81%9B%E3%81%9A%E3%80%81omapimage.o%E3%81%AA%E3%81%97%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F)%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%975%E3%81%A7%E6%9C%80%E5%88%9D%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%AE%9F%E9%9A%9B%E3%81%AE%E5%95%8F%E9%A1%8C%3A%3C%2FP%3E%3CP%3E.%2Ftools%2Fmkimage%20-T%20imximage%20-n%20board%2Ffreescale%2Fmx6sxsabresd%2Fimximage.cfg.cfgtmp%20-e%200x17800000%20-d%20u-boot.bin%20u-boot.imx%3C%2FP%3E%3CP%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%83%BB%E3%82%BF%E3%82%A4%E3%83%97%3A%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABIMX%E3%83%96%E3%83%BC%E3%83%88%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FP%3E%3CP%3EImage%20Ver%3A%202%20(i.MX53%2F6%E5%AF%BE%E5%BF%9C)%3C%2FP%3E%3CP%3EMode%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20DCD%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%B5%E3%82%A4%E3%82%BA%3A%20352256%20%E3%83%90%E3%82%A4%E3%83%88%20%3D%20344.00%20kB%20%3D%200.34%20MB%3C%2FP%3E%3CP%3E%E3%83%AD%E3%83%BC%E3%83%89%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A177ff420%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3A17800000%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%80%8CHAB%20Blocks%E3%80%8D%E3%81%AE%E8%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E6%89%8B%E3%81%AB%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F--%E5%8A%A9%E3%81%91%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%206%20..9%E3%81%AF%E5%AE%8C%E7%92%A7%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%9710%20%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E4%BE%8B%E3%81%A8%E5%90%8C%E3%81%98%E5%80%A4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%B9%E3%83%86%E3%83%83%E3%83%9711%E3%81%A7%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E6%98%8E%E3%82%89%E3%81%8B%E3%81%AB%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E.%2Fcst%20--o%20u-boot_csf.bin%20%26lt%3B%20u-boot.csf%3C%2FP%3E%3CP%3E%E7%84%A1%E5%8A%B9%E3%81%AA%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E5%BC%95%E6%95%B0%E3%80%81%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E9%96%8B%E5%A7%8B%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%81%A8%E9%95%B7%E3%81%95%E3%81%AE%E5%90%88%E8%A8%88%E3%81%8C%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20AuthenticateData%20%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%B6%85%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%81%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%80%81%E9%95%B7%E3%81%95%E3%81%AE%E5%80%A4%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%83%87%E3%83%BC%E3%82%BF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AE%E8%AA%8D%E8%A8%BC0x20%E3%83%AD%E3%83%BC%E3%83%89%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%A8%E7%95%B0%E3%81%AA%E3%82%8B%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E5%BE%A9%E5%8F%B7%E5%8C%960x10%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%A8%E7%95%B0%E3%81%AA%E3%82%8B%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E6%97%A2%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%26nbsp%3B%20Alex%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20SabreSD%20i.MX6q%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E6%9A%97%E5%8F%B7%E5%8C%96%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EIVT%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E6%A7%8B%E6%88%90%E3%83%87%E3%83%BC%E3%82%BF(%E3%82%B3%E3%83%BC%E3%83%89%E5%86%85%E3%81%AEDCD)%E3%81%AF%E3%80%81SPL%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB%E3%81%99%E3%81%A7%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESPL%E3%81%AE%E7%BD%B2%E5%90%8D%2F%E6%9A%97%E5%8F%B7%E5%8C%96%E3%82%92%E5%88%A5%E3%80%85%E3%81%AB%E8%A9%A6%E3%81%99%E3%81%A8%E3%80%81IVT%E3%82%92%E5%B0%91%E3%81%97%E8%AA%BF%E6%95%B4%E3%81%97%E3%80%81SPL%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%ABCSF%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESPL%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8you-boot.bin%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20SabreSD%20i.MX6q%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E6%9A%97%E5%8F%B7%E5%8C%96%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%B4%E3%82%A3%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E3%82%BF%E3%83%AA%E3%83%BC%E3%83%BB%E3%83%B4%E3%82%A1%E3%82%B7%E3%83%8E%E3%83%93%E3%83%83%E3%83%81%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EIVT%E3%80%81DCD%E3%80%81CSF%E3%82%92SPL%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB%E3%82%A2%E3%82%BF%E3%83%83%E3%83%81%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20SabreSD%20i.MX6q%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E6%9A%97%E5%8F%B7%E5%8C%96%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Dang%2C%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E8%A8%AD%E8%A8%88%E3%81%A7%E3%81%AF%E3%80%81SPL%E3%81%AA%E3%81%97%E3%81%AEu-boot%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EHAB%20with%20(SPL%20%2B%20U-boot)%E3%81%AF%E3%80%81%E6%BA%96%E5%82%99%E6%89%8B%E9%A0%86%E3%81%8C%E3%81%8B%E3%81%AA%E3%82%8A%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EIVT%E3%80%81DCD%E3%80%81CSF%E3%82%92SPL%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB%E3%82%A2%E3%82%BF%E3%83%83%E3%83%81%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ECPU%E3%81%AEROM%E3%81%AFSPL%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E5%BE%A9%E5%8F%B7%E5%8C%96%E3%81%97%E3%81%A6%E6%A4%9C%E8%A8%BC%E3%81%97%E3%80%81SPL%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120030%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20SabreSD%20i.MX6q%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E6%9A%97%E5%8F%B7%E5%8C%96%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120030%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%B4%E3%82%A3%E3%82%BF%E3%83%AA%E3%83%BC%E3%83%BB%E3%83%B4%E3%82%A1%E3%82%B7%E3%83%8E%E3%83%93%E3%83%83%E3%83%81%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%AF%E4%BE%BF%E5%88%A9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFHAB%E3%81%A7u-boot.imx%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%8A%E3%80%81%E7%A7%81%E3%81%AFimx6q%E4%B8%8A%E3%81%AEHAB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6SPL%E3%81%A8u-boot.img%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81SPL%E3%81%A8u-boot.img%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%80%81HAB%E3%81%AA%E3%81%97%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3AHAB%E3%81%A7SPL%E3%81%A8u-boot.img%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%AC%E5%BD%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EDang%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎04-18-2016 01:28 PM
更新者:
