Dual video with single UI on i.MX53 SMD with Android R10.4
Hi all,
I shared my test results and solutions in attachments.
Carl
ラベル(2)
添付
コメント
Dear Carl,
Our application is same as yours, but a little different.
LCD 800 X 480
TVE  TV-NTSC
I followed the user guide to modify the init.rc and complie and replace the files: overlay.imx5x.so, gralloc.imx5x.so.
The result is LCD display not normal, TVE is green.
Uboot cmd:
console=ttymxc0,115200 init=/init quiet lpj=4997120 pmem=32M,64M fbmem=10M gpu_memory=96M vmalloc=512M video=mxcdi1fb:YUV444,TV-NTSC tve androidboot.console=ttymxc0 di0_primary video=mxcdi0fb:RGB24,CLAA-WVGA
init.rc
on early-init
    start ueventd
on logo
mkdir /bootlogo 0771 system system
exec /sbin/fsck_msdos /dev/block/mmcblk0p7
# mount ext4 /dev/block/mmcblk0p7 /bootlogo rw
mount vfat /dev/block/mmcblk0p7 /bootlogo uid=1000,gid=1000,fmask=0007,dmask=0007
on init
sysclktz 0
loglevel 3
# setup the global environment
    export PATH /sbin:/vendor/bin:/system/sbin:/system/bin:/system/xbin
    export LD_LIBRARY_PATH /vendor/lib:/system/lib
    export ANDROID_BOOTLOGO 1
    export ANDROID_ROOT /system
    export ANDROID_ASSETS /system/app
    export ANDROID_DATA /data
    export EXTERNAL_STORAGE /mnt/inand
export EXTERNAL_STORAGE_SD /mnt/inand/sdcard
    export EXTERNAL_STORAGE_EXTSD /mnt/sdnavi
    export EXTERNAL_STORAGE_UDISK /mnt/udisk
    export EXTERNAL_STORAGE_INAND /mnt/inand
export EXTERNAL_STORAGE_NAVICARD /mnt/sdnavi
    export USB_DISK_STORAGE /mnt/udisk
    export ASEC_MOUNTPOINT /mnt/asec
    export LOOP_MOUNTPOINT /mnt/obb
    export SHM_MOUNTPOINT /mnt/shm
    export BOOTCLASSPATH /system/framework/core.jar:/system/framework/bouncycastle.jar:/system/framework/ext.jar:/system/framework/framework.jar:/system/framework/android.policy.jar:/system/framework/services.jar:/system/framework/core-junit.jar
    export LIGHTSENSOR_PATH /sys/class/i2c-adapter/i2c-1/1-0044
    export VPU_FW_PATH /system/lib/firmware/vpu
    export CODEC_SHM_PATH /mnt/shm
    export GST_PLUGIN_PATH /system/lib/gst_plugins
    export CORE_REGISTER_FILE /system/etc/core_register
    export COMPONENT_REGISTER_FILE /system/etc/component_register
    export CONTENTPIPE_REGISTER_FILE /system/etc/contentpipe_register
# Backward compatibility
    symlink /system/etc /etc
    symlink /sys/kernel/debug /d
# Right now vendor lives on the same filesystem as system,
# but someday that may change.
    symlink /system/vendor /vendor
# power on modem
    write /sys/devices/platform/u6300_modem/power_state 1
# create mountpoints
    mkdir /mnt 0775 root system
# mkdir /mnt/sdcard 0000 system system
    mkdir /mnt/sdnavi 0000 system system
    mkdir /mnt/udisk 0000 system system
    mkdir /mnt/inand 0771 system system
# Create cgroup mount point for cpu accounting
    mkdir /acct
    mount cgroup none /acct cpuacct
    mkdir /acct/uid
# Backwards Compat - XXX: Going away in G*
    symlink /mnt/sdnavi /sdnavi
    symlink /mnt/udisk /udisk
    symlink /mnt/inand /mnt/sdcard
    symlink /mnt/sdcard /sdcard
    mkdir /system
    mkdir /data 0771 system system
    mkdir /cache 0770 system cache
    mkdir /config 0500 root root
#liyuqiang 20111022 begin: add database mounting point
    mkdir /database 0771 system system
#liyuqiang 20111022 end: add database mounting point
#liyuqiang 20110922 begin: add cmmb firmware deposit point
    mkdir /system/etc/firmware 0771 system system
#liyuqiang 20110922 end: add cmmb firmware deposit point
    # Directory for putting things only root should see.
    mkdir /mnt/secure 0700 root root
    # Directory for staging bindmounts
    mkdir /mnt/secure/staging 0700 root root
    # Directory-target for where the secure container
    # imagefile directory will be bind-mounted
    mkdir /mnt/secure/asec  0700 root root
    # Secure container public mount points.
    mkdir /mnt/asec  0700 root system
    mount tmpfs tmpfs /mnt/asec mode=0755,gid=1000
    # Filesystem image public mount points.
    mkdir /mnt/obb 0700 root system
    mount tmpfs tmpfs /mnt/obb mode=0755,gid=1000
    # shared memory used by middleware
    mkdir /mnt/shm  0775 system graphics
    mount tmpfs tmpfs /mnt/shm mode=0775,uid=1000,gid=1003,size=1m
    write /proc/sys/kernel/panic_on_oops 1
    write /proc/sys/kernel/hung_task_timeout_secs 0
    write /proc/cpu/alignment 4
    write /proc/sys/kernel/sched_latency_ns 10000000
    write /proc/sys/kernel/sched_wakeup_granularity_ns 2000000
    write /proc/sys/kernel/sched_compat_yield 1
    write /proc/sys/kernel/sched_child_runs_first 0
# Create cgroup mount points for process groups
    mkdir /dev/cpuctl
    mount cgroup none /dev/cpuctl cpu
    chown system system /dev/cpuctl
    chown system system /dev/cpuctl/tasks
    chmod 0777 /dev/cpuctl/tasks
    write /dev/cpuctl/cpu.shares 1024
    mkdir /dev/cpuctl/fg_boost
    chown system system /dev/cpuctl/fg_boost/tasks
    chmod 0777 /dev/cpuctl/fg_boost/tasks
    write /dev/cpuctl/fg_boost/cpu.shares 1024
    mkdir /dev/cpuctl/bg_non_interactive
    chown system system /dev/cpuctl/bg_non_interactive/tasks
    chmod 0777 /dev/cpuctl/bg_non_interactive/tasks
    # 5.0 %
    write /dev/cpuctl/bg_non_interactive/cpu.shares 52
on post-fs
    # change power_state user
    chown radio /sys/devices/platform/u6300_modem/power_state
    # once everything is setup, no need to modify /
    mount rootfs rootfs / ro remount
    # We chown/chmod /data again so because mount is run as root + defaults
    chown system system /data
    chmod 0771 /data
    # Create dump dir and collect dumps.
    # Do this before we mount cache so eventually we can use cache for
    # storing dumps on platforms which do not have a dedicated dump partition.
    mkdir /data/dontpanic
    chown root log /data/dontpanic
    chmod 0750 /data/dontpanic
    # Collect apanic data, free resources and re-arm trigger
    copy /proc/apanic_console /data/dontpanic/apanic_console
    chown root log /data/dontpanic/apanic_console
    chmod 0640 /data/dontpanic/apanic_console
    copy /proc/apanic_threads /data/dontpanic/apanic_threads
    chown root log /data/dontpanic/apanic_threads
    chmod 0640 /data/dontpanic/apanic_threads
    write /proc/apanic_console 1
    # Same reason as /data above
    chown system cache /cache
    chmod 0770 /cache
    # This may have been created by the recovery system with odd permissions
    chown system cache /cache/recovery
    chmod 0770 /cache/recovery
    #change permissions on vmallocinfo so we can grab it from bugreports
    chown root log /proc/vmallocinfo
    chmod 0440 /proc/vmallocinfo
    #change permissions on kmsg & sysrq-trigger so bugreports can grab kthread stacks
    chown root system /proc/kmsg
    chmod 0440 /proc/kmsg
    chown root system /proc/sysrq-trigger
    chmod 0220 /proc/sysrq-trigger
# create basic filesystem structure
    mkdir /data/misc 01771 system misc
    mkdir /data/misc/bluetoothd 0770 bluetooth bluetooth
    mkdir /data/misc/bluetooth 0770 system system
    mkdir /data/misc/keystore 0700 keystore keystore
    mkdir /data/misc/vpn 0770 system system
    mkdir /data/misc/systemkeys 0700 system system
    mkdir /data/misc/vpn/profiles 0770 system system
    # give system access to wpa_supplicant.conf for backup and restore
    mkdir /data/misc/wifi 0777 wifi wifi
    chmod 0777 /data/misc/wifi
    chown wifi wifi /data/misc/wifi
    mkdir /data/local 0771 shell shell
    mkdir /data/local/tmp 0771 shell shell
    mkdir /data/data 0771 system system
    mkdir /data/app-private 0771 system system
    mkdir /data/app 0771 system system
    mkdir /data/property 0700 root root
#create fs for wlan
    # power control
    chown system system /sys/devices/platform/ar6103-wifi/power_state
    chmod 0666 /sys/devices/platform/ar6103-wifi/power_state
    # original configuration
    #chmod 0777 /system/etc/wifi
    #chmod 0660 /system/etc/wifi/wpa_supplicant.conf
    #chown wifi wifi /system/etc/wifi/wpa_supplicant.conf
    # wpa_supplicant control interface
    mkdir /data/misc/wifi/wpa_supplicant 0777 wifi wifi
    chmod 0777 /data/misc/wifi/wpa_supplicant
    chown wifi wifi /data/misc/wifi/wpa_supplicant
    # written to the file based on the actual configuration
    chmod 0666 /data/misc/wifi/wpa_supplicant.conf
    chown wifi wifi /data/misc/wifi/wpa_supplicant.conf
    # wpa_ctrl local socket
    mkdir /data/misc/wifi/sockets 0777 wifi wifi
    # hostapd
    mkdir /data/misc/wifi/hostapd 0777 wifi wifi
    chmod 0660 /data/misc/wifi/hostapd.conf
    chown wifi wifi /data/misc/wifi/hostapd.conf
    # dhcp
    mkdir /data/misc/dhcp 0777 dhcp dhcp
    chmod 0777 /system/etc/dhcpcd/dhcpcd-run-hooks
#zhangxiaoxu 20111130 modify permission for BT.
    chmod 0777 /dev/ttymxc2
    # create dalvik-cache and double-check the perms
    mkdir /data/dalvik-cache 0771 system system
    chown system system /data/dalvik-cache
    chmod 0771 /data/dalvik-cache
    # create the lost+found directories, so as to enforce our permissions
    mkdir /data/lost+found 0770
    mkdir /cache/lost+found 0770
    # double check the perms, in case lost+found already exists, and set owner
    chown root root /data/lost+found
    chmod 0770 /data/lost+found
    chown root root /cache/lost+found
    chmod 0770 /cache/lost+found
on boot
# basic network init
    ifup lo
    hostname localhost
    domainname localdomain
    mkdir /data/system 0775 system system
#exec /sbin/ts_calibrator
# set RLIMIT_NICE to allow priorities from 19 to -20
    setrlimit 13 40 40
# Define the oom_adj values for the classes of processes that can be
# killed by the kernel.  These are used in ActivityManagerService.
    setprop ro.FOREGROUND_APP_ADJ 0
    setprop ro.VISIBLE_APP_ADJ 1
    setprop ro.PERCEPTIBLE_APP_ADJ 2
    setprop ro.HEAVY_WEIGHT_APP_ADJ 3
    setprop ro.SECONDARY_SERVER_ADJ 4
    setprop ro.BACKUP_APP_ADJ 5
    setprop ro.HOME_APP_ADJ 6
    setprop ro.HIDDEN_APP_MIN_ADJ 7
    setprop ro.EMPTY_APP_ADJ 15
# Define the memory thresholds at which the above process classes will
# be killed.  These numbers are in pages (4k).
    setprop ro.FOREGROUND_APP_MEM 2048
    setprop ro.VISIBLE_APP_MEM 3072
    setprop ro.PERCEPTIBLE_APP_MEM 4096
    setprop ro.HEAVY_WEIGHT_APP_MEM 4096
    setprop ro.SECONDARY_SERVER_MEM 6144
    setprop ro.BACKUP_APP_MEM 6144
    setprop ro.HOME_APP_MEM 6144
    setprop ro.HIDDEN_APP_MEM 7168
    setprop ro.EMPTY_APP_MEM 8192
# Default backlight device
    setprop hw.backlight.dev "pwm-backlight.0"
# Write value must be consistent with the above properties.
# Note that the driver only supports 6 slots, so we have combined some of
# the classes into the same memory level; the associated processes of higher
# classes will still be killed first.
    write /sys/module/lowmemorykiller/parameters/adj 0,1,2,4,7,15
    write /proc/sys/vm/lowmem_reserve_ratio 1
    write /proc/sys/vm/overcommit_memory 1
    write /proc/sys/vm/min_free_order_shift 4
    write /sys/module/lowmemorykiller/parameters/minfree 2048,3072,4096,6144,7168,8192
    # Set init its forked children's oom_adj.
    write /proc/1/oom_adj -16
    # Tweak background writeout
    write /proc/sys/vm/dirty_expire_centisecs 200
    write /proc/sys/vm/dirty_background_ratio  5
    # Change sync time to 2s, default is 5s
    write /proc/sys/vm/dirty_writeback_centisecs 200
    # Permissions for System Server and daemons.
    chown radio system /sys/android_power/state
    chown radio system /sys/android_power/request_state
    chown radio system /sys/android_power/acquire_full_wake_lock
    chown radio system /sys/android_power/acquire_partial_wake_lock
    chown radio system /sys/android_power/release_wake_lock
    chown radio system /sys/power/state
    chown radio system /sys/power/wake_lock
    chown radio system /sys/power/wake_unlock
    chmod 0660 /sys/power/state
    chmod 0660 /sys/power/wake_lock
    chmod 0660 /sys/power/wake_unlock
    chown system system /sys/class/timed_output/vibrator/enable
    chown system system /sys/class/leds/keyboard-backlight/brightness
    chown system system /sys/class/leds/lcd-backlight/brightness
    chown system system /sys/class/leds/button-backlight/brightness
    chown system system /sys/class/leds/jogball-backlight/brightness
    chown system system /sys/class/leds/red/brightness
    chown system system /sys/class/leds/green/brightness
    chown system system /sys/class/leds/blue/brightness
    chown system system /sys/class/leds/red/device/grpfreq
    chown system system /sys/class/leds/red/device/grppwm
    chown system system /sys/class/leds/red/device/blink
    chown system system /sys/module/sco/parameters/disable_esco
    chown system system /sys/kernel/ipv4/tcp_wmem_min
    chown system system /sys/kernel/ipv4/tcp_wmem_def
    chown system system /sys/kernel/ipv4/tcp_wmem_max
    chown system system /sys/kernel/ipv4/tcp_rmem_min
    chown system system /sys/kernel/ipv4/tcp_rmem_def
    chown system system /sys/kernel/ipv4/tcp_rmem_max
    chown root radio /proc/cmdline
#ningfeiyi 20110829 begin : add for gps
    chown system system /dev/neo_6m
    chmod 0660 /dev/neo_6m
    chown system system /dev/radio0
    chmod 0666 /dev/radio0
#ningfeiyi 20110829 end : add for gps
# Chmod/chown FSL specific sys entry
    chown system system /sys/class/backlight/pwm-backlight.0/brightness
    chmod 0660 /sys/class/backlight/pwm-backlight.0/brightness
# Define TCP buffer sizes for various networks
#   ReadMin, ReadInitial, ReadMax, WriteMin, WriteInitial, WriteMax,
    setprop net.tcp.buffersize.default 4096,87380,110208,4096,16384,110208
    setprop net.tcp.buffersize.wifi    4095,87380,110208,4096,16384,110208
    setprop net.tcp.buffersize.umts    4094,87380,110208,4096,16384,110208
    setprop net.tcp.buffersize.edge    4093,26280,35040,4096,16384,35040
    setprop net.tcp.buffersize.gprs    4092,8760,11680,4096,8760,11680
# Set property for FSL specific feature
# Init second display connection state
    setprop rw.secfb.disable-overlay 1
    setprop rw.SIN_VIDEO_DUAL_UI 0
    setprop rw.DUAL_VIDEO_SIN_UI 1
#    setprop rw.SECOND_DISPLAY_CONNECTED 0
# Define gst player property
    setprop media.gstreamer.enable-player 0
# Comment the usage of stageflight media framework
    setprop  media.stagefright.enable-scan 0
    setprop  media.stagefright.enable-player 0
    setprop  media.stagefright.enable-record 1
    setprop  media.stagefright.enable-http 0
    setprop  media.stagefright.enable-meta 0
    setprop  media.stagefright.enable-vpuenc 1
# Define fsl avi/aac/asf/mkv/flv/flac format support
    setprop ro.FSL_AVI_PARSER 1
    setprop ro.FSL_AAC_PARSER 1
    setprop ro.FSL_ASF_PARSER 1
    setprop ro.FSL_FLV_PARSER 1
    setprop ro.FSL_MKV_PARSER 1
    setprop ro.FSL_FLAC_PARSER 1
    setprop ro.FSL_MPG2_PARSER 1
# Define fsl display init mode
    setprop ro.FSL_LANDSCAPE_MODE 1
# Define fsl xec mode
    setprop xec.dls.enabled 1
    setprop xec.aa.enabled 1
    setprop xec.dls.rate 0
    setprop xec.aa.rate 100
# Define UI to TVOUT,change this setting to 1 and uncomment below write commands
    setprop ro.UI_TVOUT_DISPLAY 0
    #write /sys/class/graphics/fb0/blank 1
    #write /sys/class/graphics/fb1/blank 1
    #write /sys/class/graphics/fb2/blank 1
    #write /sys/class/graphics/fb0/fsl_disp_property 1-layer-fb
    #write /sys/class/graphics/fb1/mode U:720x480i-60\n
    #write /sys/class/graphics/fb1/blank 0
# ALSA mixer naming define
    setprop alsa.mixer.playback.master Playback
    setprop alsa.mixer.capture.master Capture
    setprop alsa.mixer.playback.speaker Playback
    setprop alsa.mixer.playback.headset Headphone
    setprop alsa.mixer.capture.headset Capture
# Prepare for wifi
    setprop wifi.interface wlan0
# Prepare for bluetooth
    chmod 665 /sys/class/rfkill/rfkill0/state
    chown bluetooth bluetooth /sys/class/rfkill/rfkill0/state
    write /sys/class/rfkill/rfkill0/state 0
# Enable USB host1'remote wakeup event wakeup android system
    write /sys/bus/platform/drivers/fsl-ehci/fsl-ehci.1/power/wakeup enabled
# Prepare for RIL
    setprop gsm.ril.delay 15
    setprop ro.ril.wake_lock_timeout 300
    class_start default
## Daemon processes to be run by init.
service dispd /system/bin/dispd
    socket dispd stream 0660 root system
# liudongxing 20110922 begin: start cmmbserver
service cmmb /system/bin/cmmbserver
    user root
    disabled
# liudongxing 20110922 end: start cmmbserver
service ueventd /sbin/ueventd
    critical
service console /system/bin/sh
    console
    user root
    group log
on property:ro.secure=0
    start console
# adbd is controlled by the persist.service.adb.enable system property
service adbd /sbin/adbd
    disabled
# adbd on at boot in emulator
on property:ro.kernel.qemu=1
    start adbd
on property:persist.service.adb.enable=1
    start adbd
on property:persist.service.adb.enable=0
    stop adbd
service servicemanager /system/bin/servicemanager
    user system
    critical
    onrestart restart zygote
    onrestart restart media
service vold /system/bin/vold
    socket vold stream 0660 root mount
    ioprio be 2
service netd /system/bin/netd
    socket netd stream 0660 root system
service debuggerd /system/bin/debuggerd
service zygote /system/bin/app_process -Xzygote /system/bin --zygote --start-system-server
    socket zygote stream 666
    onrestart write /sys/android_power/request_state wake
    onrestart write /sys/power/state on
    onrestart restart netd
service media /system/bin/mediaserver
    user media
    group system audio camera graphics inet net_bt net_bt_admin net_raw
    ioprio rt 4
service bootanim /system/bin/bootanimation
    user graphics
    group graphics
    disabled
    oneshot
service dbus /system/bin/dbus-daemon --system --nofork
    socket dbus stream 660 bluetooth bluetooth
    user bluetooth
    group bluetooth net_bt_admin
# xiaoping.zhang 2011-11-10 begin: add for bluetooth
service hciattach /system/bin/logwrapper /system/bin/brcm_patchram_plus --enable_hci --baudrate 460800 --patchram /system/data/bcm4329_bt.hcd /dev/ttymxc2
        disabled
service bluetoothd /system/bin/logwrapper /system/bin/bluetoothd -n -d
    socket bluetooth stream 660 bluetooth bluetooth
    socket dbus_bluetooth stream 660 bluetooth bluetooth
    # init.rc does not yet support applying capabilities, so run as root and
    # let bluetoothd drop uid to bluetooth with the right linux capabilities
    group bluetooth net_bt_admin misc
    disabled
service obex_client /system/bin/logwrapper /system/bin/obex_client
    disabled
service hf /system/bin/sdptool add --channel=7 HF
    user bluetooth
    disabled
    oneshot
#service opush /system/bin/sdptool add --channel=12 OPUSH
#    user bluetooth
#    group bluetooth net_bt_admin
#    disabled
#    oneshot
#xiaoping.zhang 2011-11-10 end: add for bluetooth
service installd /system/bin/installd
    socket installd stream 600 system system
#service flash_recovery /system/etc/install-recovery.sh
#    oneshot
service racoon /system/bin/racoon
    socket racoon stream 600 system system
    # racoon will setuid to vpn after getting necessary resources.
    group net_admin
    disabled
    oneshot
service mtpd /system/bin/mtpd
    socket mtpd stream 600 system system
    user root
    group vpn net_admin net_raw
    disabled
    oneshot
service keystore /system/bin/keystore /data/misc/keystore
    user keystore
    group keystore
    socket keystore stream 666
service dumpstate /system/bin/dumpstate -s
    socket dumpstate stream 0660 shell log
    disabled
    oneshot
service wpa_supplicant /system/bin/wlan_tool wpa_supplicant
    user root
    group wifi inet
    socket wpa_wlan0 dgram 660 wifi wifi
    oneshot
service hostapd /system/bin/wlan_tool hostapd
    socket hostapd_wlap0 dgram 660 root wifi
    user root
    group wifi
    oneshot
service dhcpcd_wlan0 /system/bin/wlan_tool dhcpcd
    user root
    group wifi inet
    disabled
    oneshot
service wlan_tool /system/bin/wlan_tool
    oneshot
#There is no modem on ec7 project
service ril-daemon /system/bin/rild
    socket rild stream 660 root radio
    socket rild-debug stream 660 radio system
    socket rild-ppp stream 660 radio system
    user root
    group radio cache inet misc audio sdcard_rw system
service pppd_gprs /etc/init.gprs-pppd
    user root
    group radio cache inet misc system
    disabled
oneshot
#add by dcc 2011/11/02 for start mcud
service mcu-daemon /system/bin/mcud
user root
# add by wangwang 20111029 for cmmb switch on or off
on property:persist.cmmb.switch=1
    start cmmb
on property:persist.cmmb.switch=0
    stop cmmb
# end add by wangwang 20111029
#add by lei.xiong 20111109, set cmmb on
setprop persist.cmmb.switch 1
#end add by lei.xiong 20111109
#add by hujun 20120518,logcat_sdcard
service logcat_sdcard /system/bin/init.logcat.sh
    disabled
service logcat_radio /system/bin/init.logradio.sh
    disabled
on property:persist.service.logcat.enable=1
    start logcat_sdcard
on property:persist.service.logcat.enable=0
    stop logcat_sdcard
    start logcat_radio
    stop logcat_radio
hi Terry,
The patch only works for HDMI output.
Could you try the following modification with an extra property to rollback TV conf to original BSP?
diff --git a/libgralloc/framebuffer.cpp b/libgralloc/framebuffer.cpp
index e2f19e2..f9ab189 100755
--- a/libgralloc/framebuffer.cpp
+++ b/libgralloc/framebuffer.cpp
@@ -380,7 +380,7 @@ static void setOverlayOutput(fb_context_t* dev)
    char value[PROPERTY_VALUE_MAX];
    //Make the overlay to use FB1 for output
    if(dev->sec_disp_connected&&dev->to_disable_overlay){
-        property_get("rw.DUAL_VIDEO_SIN_UI", value, "0");
+        property_get("rw.DUAL_VIDEO_FOR_HDMI", value, "0");
         if (!strcmp(value, "1")) {
                 property_set("sys.VIDEO_TVOUT_DISPLAY", "0");
                 dev->to_tvout_display = 0;
Dear Max,
Tested, but TVE output green, and it has picture sometime. But LCD doesn't have output.
Terry
hi Terry,
Can I know if the TVE feature is normal on your board based on original BSP?
Max
Dear Max,
The original BSP can output normal TVE NTSC.
Terry
发件人: MaxTsai [email protected]
发送时间: 2013年6月24日 10:12
收件人: Tan, Terry
主题: Re: https://community.nxp.com/community/imx - Dual video with single UI on i.MX53 SMD with Android R10.4
new comment by MaxTsai<https://community.freescale.com/people/MaxTsai> View all comments on this document<https://community.freescale.com/docs/DOC-94879#comment-5071>
hi Terry,
ok. I have no board with TVOUT, but please let me prepare the environment for TVOUT & LCD. I will update later.
Max
Dear Alex,
I.MX53 QSB has both VGA and LCD output.
You can get the TVE from VGA port.
Terry
发送时间: 2013年6月24日 11:09
收件人: Tan, Terry
new comment by MaxTsai<https://community.freescale.com/people/MaxTsai> View all comments on this document<https://community.freescale.com/docs/DOC-94879#comment-5073>
hi Terry,
We have a workaround to force dual video of MX53QSD work for legacy TVout.
You may reach Carl for the workaround.
%3CLINGO-SUB%20id%3D%22lingo-sub-1126481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAndroid%20R10.4%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9Fi.MX53%20SMD%E3%81%AE%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%ABUI%E3%81%AE%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%93%E3%83%87%E3%82%AA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E7%B5%90%E6%9E%9C%E3%81%A8%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E5%85%B1%E6%9C%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ECarl%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1126481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX53%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126490%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AAndroid%20R10.4%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9Fi.MX53%20SMD%E3%81%AE%E5%8D%98%E4%B8%80%E3%81%AEUI%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%93%E3%83%87%E3%82%AA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126490%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%86%E3%83%AA%E3%83%BC%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BE%93%E6%9D%A5%E3%81%AETVout%E3%81%AE%E4%BD%9C%E6%A5%AD%E3%81%AE%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E5%BC%B7%E5%88%B6%E3%81%99%E3%82%8B%E5%9B%9E%E9%81%BF%E7%AD%96MX53QSD%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81Carl%20%E3%81%AB%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126489%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AAndroid%20R10.4%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9Fi.MX53%20SMD%E3%81%AE%E5%8D%98%E4%B8%80%E3%81%AEUI%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%93%E3%83%87%E3%82%AA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126489%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%E3%82%A2%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI.MX53%20QSB%E3%81%AF%E3%80%81VGA%E5%87%BA%E5%8A%9B%E3%81%A8LCD%E5%87%BA%E5%8A%9B%E3%81%AE%E4%B8%A1%E6%96%B9%E3%82%92%E5%82%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETVE%E3%81%AFVGA%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ETerry%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%91%E4%BB%B6%E4%BA%BA%3A%20MaxTsai%20%3CA%20href%3D%22mailto%3Aadmin%40community.freescale.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eadmin%40community.freescale.com%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%8F%91%E9%80%81%E6%97%B6%E9%97%B4%3A%202013%E5%B9%B46%E6%9C%8824%E6%97%A5%2011%3A09%3C%2FP%3E%3CP%3E%E6%94%B6%E4%BB%B6%E4%BA%BA%3A%20Tan%2C%20Terry%3C%2FP%3E%3CP%3E%E4%B8%BB%E3%81%AA%E9%A2%98%3A%20Re%3A%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fimx%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fimx%3C%2FA%3E%20-%20Android%20R10.4%20%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%20i.MX53%20SMD%20%E3%81%AE%201%20%E3%81%A4%E3%81%AE%20UI%20%E3%82%92%E6%8C%81%E3%81%A4%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%20%E3%83%93%E3%83%87%E3%82%AA%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2F%22%20title%3D%22https%3A%2F%2Fcommunity.nxp.com%2F%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2F%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAndroid%20R10.4%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9Fi.MX53%20SMD%E3%81%AE%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%ABUI%E3%81%AE%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%93%E3%83%87%E3%82%AA%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%20by%20MaxTsai%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fcommunity.freescale.com%252Fpeople%252FMaxTsai%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fpeople%2FMaxTsai%3C%2FA%3E%3CSPAN%3E%26gt%3B%20%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E8%A1%A8%E7%A4%BA%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-anchor-small%22%20href%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-94879%23comment%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-94879%23comment-5073%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AAndroid%20R10.4%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9Fi.MX53%20SMD%E3%81%AE%E5%8D%98%E4%B8%80%E3%81%AEUI%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%93%E3%83%87%E3%82%AA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%86%E3%83%AA%E3%83%BC%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82TVOUT%E4%BB%98%E3%81%8D%E3%81%AE%E5%9F%BA%E6%9D%BF%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81TVOUT%E3%81%A8LCD%E3%81%AE%E7%92%B0%E5%A2%83%E3%82%92%E6%95%B4%E3%81%88%E3%81%95%E3%81%9B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%BE%8C%E6%97%A5%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E5%A4%A7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126487%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AAndroid%20R10.4%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9Fi.MX53%20SMD%E3%81%AE%E5%8D%98%E4%B8%80%E3%81%AEUI%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%93%E3%83%87%E3%82%AA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126487%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%E3%83%9E%E3%83%83%E3%82%AF%E3%82%B9%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%85%83%E3%81%AEBSP%E3%81%AF%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AETVE%20NTSC%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ETerry%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%91%E4%BB%B6%E4%BA%BA%3A%20MaxTsai%20%3CA%20href%3D%22mailto%3Aadmin%40community.freescale.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eadmin%40community.freescale.com%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%8F%91%E9%80%81%E6%97%B6%E9%97%B4%3A%202013%E5%B9%B46%E6%9C%8824%E6%97%A5%2010%3A12%3C%2FP%3E%3CP%3E%E6%94%B6%E4%BB%B6%E4%BA%BA%3A%20Tan%2C%20Terry%3C%2FP%3E%3CP%3E%E4%B8%BB%E3%81%AA%E9%A2%98%3A%20Re%3A%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fimx%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fimx%3C%2FA%3E%20-%20Android%20R10.4%20%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%20i.MX53%20SMD%20%E3%81%AE%201%20%E3%81%A4%E3%81%AE%20UI%20%E3%82%92%E6%8C%81%E3%81%A4%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%20%E3%83%93%E3%83%87%E3%82%AA%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2F%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAndroid%20R10.4%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9Fi.MX53%20SMD%E3%81%AE%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%ABUI%E3%81%AE%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%93%E3%83%87%E3%82%AA%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%20by%20MaxTsai%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fcommunity.freescale.com%252Fpeople%252FMaxTsai%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fpeople%2FMaxTsai%3C%2FA%3E%3CSPAN%3E%26gt%3B%20%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E8%A1%A8%E7%A4%BA%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-anchor-small%22%20href%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-94879%23comment%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-94879%23comment-5071%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126486%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AAndroid%20R10.4%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9Fi.MX53%20SMD%E3%81%AE%E5%8D%98%E4%B8%80%E3%81%AEUI%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%93%E3%83%87%E3%82%AA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126486%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%86%E3%83%AA%E3%83%BC%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETVE%20%E6%A9%9F%E8%83%BD%E3%81%8C%E5%85%83%E3%81%AE%20BSP%20%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%80%E5%A4%A7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126485%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AAndroid%20R10.4%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9Fi.MX53%20SMD%E3%81%AE%E5%8D%98%E4%B8%80%E3%81%AEUI%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%93%E3%83%87%E3%82%AA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126485%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%E3%83%9E%E3%83%83%E3%82%AF%E3%82%B9%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81TVE%E5%87%BA%E5%8A%9B%E3%81%AF%E7%B7%91%E8%89%B2%E3%81%A7%E3%80%81%E3%81%84%E3%81%A4%E3%81%8B%E7%94%BB%E5%83%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81LCD%E3%81%AB%E3%81%AF%E5%87%BA%E5%8A%9B%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3ETerry%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126484%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AAndroid%20R10.4%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9Fi.MX53%20SMD%E3%81%AE%E5%8D%98%E4%B8%80%E3%81%AEUI%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%93%E3%83%87%E3%82%AA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126484%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%86%E3%83%AA%E3%83%BC%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AFHDMI%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%AE%E3%81%BF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ETV%20conf%E3%82%92%E5%85%83%E3%81%AEBSP%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E---%3C%2FP%3E%3CP%3E%E5%B7%AE%E5%88%86%20--git%20a%2Flibgralloc%2Fframebuffer.cpp%20b%2Flibgralloc%2Fframebuffer.cpp%3C%2FP%3E%3CP%3Eindex%20e2f19e2..f9ab189%20100755%3C%2FP%3E%3CP%3E---%20a%2Flibgralloc%2Fframebuffer.cpp%3C%2FP%3E%3CP%3E%2B%2B%2B%20b%2Flibgralloc%2Fframebuffer.cpp%3C%2FP%3E%3CP%3E%40%40%20-380%2C7%20%2B380%2C7%20%40%40%20static%20void%20setOverlayOutput(fb_context_t*%20dev)%3C%2FP%3E%3CP%3Echar%20%E5%80%A4%20%5BPROPERTY_VALUE_MAX%5D%3B%3C%2FP%3E%3CP%3EFB1%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Eif(%E9%96%8B%E7%99%BA-%26gt%3Bsec_disp_connected%26amp%3B%26amp%3B%E9%96%8B%E7%99%BA-%26gt%3Bto_disable_overlay)%7B%3C%2FP%3E%3CP%3E-%20property_get(%E3%80%8CRW.DUAL_VIDEO_SIN_UI%22%2C%20%E5%80%A4%2C%20%220%22)%3B%3C%2FP%3E%3CP%3E%2B%20property_get(%22RW.DUAL_VIDEO_FOR_HDMI%22%2C%20%E5%80%A4%2C%20%220%22)%3B%3C%2FP%3E%3CP%3Eif%20(!strcmp(%E5%80%A4%2C%20%221%22))%20%7B%3C%2FP%3E%3CP%3Eproperty_set(%22sys.VIDEO_TVOUT_DISPLAY%22%2C%20%220%22)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20dev-%26gt%3Bto_tvout_display%20%3D%200%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AAndroid%20R10.4%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9Fi.MX53%20SMD%E3%81%AE%E5%8D%98%E4%B8%80%E3%81%AEUI%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%93%E3%83%87%E3%82%AA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22LCD%E6%98%BE%E7%A4%BA%E8%8A%B1%E5%B1%8F.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22LCD%26amp%3B%2326174%3B%26amp%3B%2331034%3B%26amp%3B%2333457%3B%26amp%3B%2323631%3B.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117656iDA3AEED007AAB344%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22LCD%26amp%3B%2326174%3B%26amp%3B%2331034%3B%26amp%3B%2333457%3B%26amp%3B%2323631%3B.jpg%22%20alt%3D%22LCD%26amp%3B%2326174%3B%26amp%3B%2331034%3B%26amp%3B%2333457%3B%26amp%3B%2323631%3B.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ELCD%26amp%3B%2326174%3B%26amp%3B%2331034%3B%26amp%3B%2333457%3B%26amp%3B%2323631%3B.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126482%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AAndroid%20R10.4%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9Fi.MX53%20SMD%E3%81%AE%E5%8D%98%E4%B8%80%E3%81%AEUI%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%93%E3%83%87%E3%82%AA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126482%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%E3%82%AB%E3%83%BC%E3%83%AB%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%B0%91%E3%81%97%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B6%B2%E6%99%B6%20800%20X%20480%3C%2FP%3E%3CP%3ETVE%26nbsp%3B%20TV-NTSC%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6init.rc%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%80%81%20%3CSPAN%20style%3D%22font-family%3A%20%E5%AE%8B%E4%BD%93%3B%20font-size%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20%E5%AE%8B%E4%BD%93%3B%20font-size%3A%2012pt%3B%22%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB(overlay.imx5x.so%E3%80%81%20%3C%2FSPAN%3Egralloc.imx5x.so)%E3%81%AB%E6%BA%96%E6%8B%A0%E3%81%97%E3%81%A6%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20%E5%AE%8B%E4%BD%93%3B%20font-size%3A%2012pt%3B%22%3E%E3%81%9D%E3%81%AE%E7%B5%90%E6%9E%9C%E3%80%81LCD%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81TVE%E3%81%AF%E7%B7%91%E8%89%B2%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20%E5%AE%8B%E4%BD%93%3B%20font-size%3A%2012pt%3B%22%3EUboot%20cmd%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20%E5%AE%8B%E4%BD%93%3B%20font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3Econsole%3Dttymxc0%2C115200%20init%3D%2Finit%20quiet%20lpj%3D4997120%20pmem%3D32M%2C64M%20fbmem%3D10M%20gpu_memory%3D96M%20vmalloc%3D512M%20%3CSPAN%20style%3D%22color%3A%20red%3B%22%3Evideo%3Dmxcdi1fb%3AYUV444%2CTV-NTSC%20tve%20%3C%2FSPAN%3Eandroidboot.console%3Dttymxc0%20di0_primary%20video%3Dmxcdi0fb%3ARGB24%2CCLAA-WVGA%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20%E5%AE%8B%E4%BD%93%3B%20font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20%E5%AE%8B%E4%BD%93%3B%20font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3Einit.rc%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20%E5%AE%8B%E4%BD%93%3B%20font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3C%2FP%3E%3CP%3Eearly-init%20%E3%81%A7%3CBR%20%2F%3Eueventd%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%AD%E3%82%B4%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3CBR%20%2F%3E%20mkdir%20%2Fbootlogo%200771%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3E%20exec%20%2Fsbin%2Ffsck_msdos%20%2Fdev%2Fblock%2Fmmcblk0p7%3CBR%20%2F%3E%23%20ext4%20%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%20%2Fdev%2Fblock%2Fmmcblk0p7%20%2Fbootlogo%20rw%3CBR%20%2F%3E%20vfat%20%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%20%2Fdev%2Fblock%2Fmmcblk0p7%20%2Fbootlogo%20uid%3D1000%2Cgid%3D1000%2Cfmask%3D0007%2Cdmask%3D0007%3C%2FP%3E%3CP%3Einit%20%E3%81%A7%3C%2FP%3E%3CP%3Esysclktz%200%3C%2FP%3E%3CP%3E%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%99%E3%83%AB%203%3C%2FP%3E%3CP%3E%23%20%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E7%92%B0%E5%A2%83%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3CBR%20%2F%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%91%E3%82%B9%20%2Fsbin%3A%2Fvendor%2Fbin%3A%2Fsystem%2Fsbin%3A%2Fsystem%2Fbin%3A%2Fsystem%2Fxbin%3CBR%20%2F%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88LD_LIBRARY_PATH%20%2Fvendor%2Flib%3A%2Fsystem%2Flib%3CBR%20%2F%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88ANDROID_BOOTLOGO%201%3CBR%20%2F%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20ANDROID_ROOT%20%2Fsystem%3CBR%20%2F%3E%2Fsystem%2Fapp%20ANDROID_ASSETS%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20ANDROID_DATA%20%2Fdata%3CBR%20%2F%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20EXTERNAL_STORAGE%20%2Fmnt%2Finand%3CBR%20%2F%3E%20%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88EXTERNAL_STORAGE_SD%20%2Fmnt%2Finand%2Fsdcard%3CBR%20%2F%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88EXTERNAL_STORAGE_EXTSD%2Fmnt%2Fsdnavi%3CBR%20%2F%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88EXTERNAL_STORAGE_UDISK%20%2Fmnt%2Fudisk%3CBR%20%2F%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20EXTERNAL_STORAGE_INAND%20%2Fmnt%2Finand%3CBR%20%2F%3E%20%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88EXTERNAL_STORAGE_NAVICARD%2Fmnt%2Fsdnavi%3CBR%20%2F%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20USB_DISK_STORAGE%20%2Fmnt%2Fudisk%3C%2FP%3E%3CP%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20ASEC_MOUNTPOINT%20%2Fmnt%2Fasec%3CBR%20%2F%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88LOOP_MOUNTPOINT%20%2Fmnt%2Fobb%3CBR%20%2F%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88SHM_MOUNTPOINT%20%2Fmnt%2Fshm%3CBR%20%2F%3Eexport%20BOOTCLASSPATH%20%2Fsystem%2Fframework%2Fcore.jar%3A%2Fsystem%2Fframework%2Fbouncycastle.jar%3A%2Fsystem%2Fframework%2Fext.jar%3A%2Fsystem%2Fframework%2Fframework.jar%3A%2Fsystem%2Fframework%2Fandroid.policy.jar%3A%2Fsystem%2Fframework%2Fservices.jar%3A%2Fsystem%2Fframework%2Fcore-junit.jar%3C%2FP%3E%3CP%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20LIGHTSENSOR_PATH%20%2Fsys%2Fclass%2Fi2c-adapter%2Fi2c-1%2F1-0044%3CBR%20%2F%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88VPU_FW_PATH%20%2Fsystem%2Flib%2Ffirmware%2Fvpu%3CBR%20%2F%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20CODEC_SHM_PATH%20%2Fmnt%2Fshm%3CBR%20%2F%3E%2Fsystem%2Flib%2Fgst_plugins%20GST_PLUGIN_PATH%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%2Fsystem%2Fetc%2Fcore_register%20CORE_REGISTER_FILE%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%2Fsystem%2Fetc%2Fcomponent_register%20COMPONENT_REGISTER_FILE%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%2Fsystem%2Fetc%2Fcontentpipe_register%20CONTENTPIPE_REGISTER_FILE%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%3C%2FP%3E%3CP%3E%23%20%E4%B8%8B%E4%BD%8D%E4%BA%92%E6%8F%9B%E6%80%A7%3CBR%20%2F%3E%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AA%E3%83%83%E3%82%AF%E3%83%AA%E3%83%B3%E3%82%AF%20%2Fsystem%2Fetc%20%2Fetc%3CBR%20%2F%3E%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AA%E3%83%83%E3%82%AF%E3%83%AA%E3%83%B3%E3%82%AF%20%2Fsys%2Fkernel%2Fdebug%20%2Fd%3C%2FP%3E%3CP%3E%23%20%E7%8F%BE%E5%9C%A8%E3%80%81%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%E3%81%AF%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A8%E5%90%8C%E3%81%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%23%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%84%E3%81%A4%E3%81%8B%E3%81%9D%E3%82%8C%E3%81%AF%E5%A4%89%E3%82%8F%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AA%E3%83%83%E3%82%AF%E3%83%AA%E3%83%B3%E3%82%AF%20%2Fsystem%2Fvendor%20%2Fvendor%3C%2FP%3E%3CP%3E%23%20%E3%83%A2%E3%83%87%E3%83%A0%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E3%82%8B%3CBR%20%2F%3E%2Fsys%2Fdevices%2Fplatform%2Fu6300_modem%2Fpower_state%201%20%E3%82%92%E6%9B%B8%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%23%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E4%BD%9C%E6%88%90%3CBR%20%2F%3Emkdir%20%2Fmnt%200775%20%E3%83%AB%E3%83%BC%E3%83%88%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3E%23%20mkdir%20%2Fmnt%2Fsdcard%200000%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3EMKDIR%2FMNT%2FSDNAVI%200000%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3Emkdir%20%2Fmnt%2Fudisk%200000%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%BB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FP%3E%3CP%3Emkdir%20%2Fmnt%2Finand%200771%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FP%3E%3CP%3E%23%20cpu%20%E3%82%A2%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E7%94%A8%E3%81%AE%20cgroup%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%3CBR%20%2F%3Emkdir%20%2Facct%3CBR%20%2F%3Emount%20cgroup%20none%20%2Facct%20cpuacct%3CBR%20%2F%3Emkdir%20%2Facct%2Fuid%3C%2FP%3E%3CP%3E%23%E5%BE%8C%E6%96%B9%E4%BA%92%E6%8F%9B%E6%80%A7%20-%20XXX%3AG%20*%E3%81%A7%E9%9B%A2%E3%82%8C%E3%82%8B%3CBR%20%2F%3E%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AA%E3%83%83%E3%82%AF%E3%83%AA%E3%83%B3%E3%82%AF%20%2Fmnt%2Fsdnavi%20%2Fsdnavi%3CBR%20%2F%3E%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AA%E3%83%83%E3%82%AF%E3%83%AA%E3%83%B3%E3%82%AF%20%2Fmnt%2Fudisk%20%2Fudisk%3CBR%20%2F%3E%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AA%E3%83%83%E3%82%AF%E3%83%AA%E3%83%B3%E3%82%AF%20%2Fmnt%2Fin%E3%81%8A%E3%82%88%E3%81%B3%20%2Fmnt%2Fsdcard%3CBR%20%2F%3E%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AA%E3%83%83%E3%82%AF%E3%83%AA%E3%83%B3%E3%82%AF%20%2Fmnt%2Fsdcard%20%2Fsdcard%3C%2FP%3E%3CP%3Emkdir%20%2F%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3Emkdir%20%2Fdata%200771%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3Emkdir%20%2Fcache%200770%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3CBR%20%2F%3Emkdir%20%2Fconfig%200500%20%E3%83%AB%E3%83%BC%E3%83%88%E3%83%AB%E3%83%BC%E3%83%88%3C%2FP%3E%3CP%3E%23liyuqiang%2020111022%20%E9%96%8B%E5%A7%8B%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E3%83%99%E3%83%BC%E3%82%B9%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%20%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%3CBR%20%2F%3Emkdir%20%2Fdatabase%200771%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%BB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3E%23liyuqiang%2020111022%20%E7%B5%82%E4%BA%86%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%20%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%23liyuqiang%2020110922%20%E9%96%8B%E5%A7%8B%3A%20CMMB%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%87%E3%83%9D%E3%82%B8%E3%83%83%E3%83%88%20%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Emkdir%20%2Fsystem%2Fetc%2Ffirmware%200771%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3E%23liyuqiang%2020110922%20%E7%B5%82%E4%BA%86%3ACMMB%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%87%E3%83%9D%E3%82%B8%E3%83%83%E3%83%88%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%23%20%E3%83%AB%E3%83%BC%E3%83%88%E3%81%A0%E3%81%91%E3%81%8C%E8%A6%8B%E3%82%8B%E3%81%B9%E3%81%8D%E3%82%82%E3%81%AE%E3%82%92%E7%BD%AE%E3%81%8F%E3%81%9F%E3%82%81%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3Bmkdir%20%2Fmnt%2Fsecure%200700%20%E3%83%AB%E3%83%BC%E3%83%88%E3%83%AB%E3%83%BC%E3%83%88%3C%2FP%3E%3CP%3E%23%20bindmounts%E3%82%92%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%3CBR%20%2F%3Emkdir%20%2Fmnt%2Fsecure%2Fstaging%200700%20%E3%83%AB%E3%83%BC%E3%83%88%E3%83%AB%E3%83%BC%E3%83%88%3C%2FP%3E%3CP%3E%23%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20where%20%E5%AE%89%E5%85%A8%E3%81%AA%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%3CBR%20%2F%3E%23%20imagefile%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3CBR%20%2F%3Emkdir%20%2Fmnt%2Fsecure%2Fasec%200700%20%E3%83%AB%E3%83%BC%E3%83%88%E3%83%AB%E3%83%BC%E3%83%88%3C%2FP%3E%3CP%3E%23%20%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%E3%81%AE%E3%83%91%E3%83%96%E3%83%AA%E3%83%83%E3%82%AF%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E4%BF%9D%E8%AD%B7%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3Bmkdir%20%2Fmnt%2Fasec%200700%20%E3%83%AB%E3%83%BC%E3%83%88%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3ETMPFS%20TMPFS%20%2FMNT%2FASEC%20%E3%83%A2%E3%83%BC%E3%83%89%3D0755%2CGID%3D1000%3C%2FP%3E%3CP%3E%23%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E3%83%91%E3%83%96%E3%83%AA%E3%83%83%E3%82%AF%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3Bmkdir%20%2Fmnt%2Fobb%200700%20%E3%83%AB%E3%83%BC%E3%83%88%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3ETMPFS%20TMPFS%20%2FMNT%2FOBB%20%E3%83%A2%E3%83%BC%E3%83%89%3D0755%2CGID%3D1000%3C%2FP%3E%3CP%3E%23%20%E3%83%9F%E3%83%89%E3%83%AB%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%85%B1%E6%9C%89%E3%83%A1%E3%83%A2%E3%83%AA%3CBR%20%2F%3Emkdir%20%2Fmnt%2Fshm%200775%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%3CBR%20%2F%3E%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%20TMPFS%20TMPFS%20%2FMNT%2FSHM%20MODE%3D0775%2CUID%3D1000%2CGID%3D1003%2C%E3%82%B5%E3%82%A4%E3%82%BA%3D1M%3C%2FP%3E%3CP%3E%2Fproc%2Fsys%2Fkernel%2Fpanic_on_oops%201%20%E3%82%92%E6%9B%B8%E3%81%8D%E3%81%BE%E3%81%99%3CBR%20%2F%3E%2Fproc%2Fsys%2Fkernel%2Fhung_task_timeout_secs%200%20%E3%81%A8%E6%9B%B8%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Ewrite%20%2Fproc%2Fcpu%2Falignment%204%3CBR%20%2F%3E%2Fproc%2Fsys%2Fkernel%2Fsched_latency_ns%2010000000%20%E3%82%92%E6%9B%B8%E3%81%8D%E3%81%BE%E3%81%99%3CBR%20%2F%3E%2Fproc%2Fsys%2Fkernel%2Fsched_wakeup_granularity_ns%202000000%20%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3CBR%20%2F%3E%2Fproc%2Fsys%2Fkernel%2Fsched_compat_yield%201%20%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3CBR%20%2F%3E%2Fproc%2Fsys%2Fkernel%2Fsched_child_runs_first%200%20%E3%81%A8%E6%9B%B8%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%23%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AE%20cgroup%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%3CBR%20%2F%3Emkdir%20%2Fdev%2Fcpuctl%3CBR%20%2F%3Emount%20cgroup%20none%20%2Fdev%2Fcpuctl%20cpu%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fdev%2Fcpuctl%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fdev%2Fcpuctl%2Ftasks%3CBR%20%2F%3Echmod%200777%20%2Fdev%2Fcpuctl%2Ftasks%3CBR%20%2F%3E%2Fdev%2Fcpuctl%2Fcpu.shares%201024%20%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3C%2FP%3E%3CP%3Emkdir%20%2Fdev%2Fcpuctl%2Ffg_boost%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fdev%2Fcpuctl%2Ffg_boost%2Ftasks%3CBR%20%2F%3Echmod%200777%20%2Fdev%2Fcpuctl%2Ffg_boost%2Ftasks%3CBR%20%2F%3E%2Fdev%2Fcpuctl%2Ffg_boost%2Fcpu.shares%201024%20%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3C%2FP%3E%3CP%3Emkdir%20%2Fdev%2Fcpuctl%2Fbg_non_interactive%3CBR%20%2F%3Echown%20system%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fdev%2Fcpuctl%2Fbg_non_interactive%2Ftasks%3CBR%20%2F%3Echmod%200777%20%2Fdev%2Fcpuctl%2Fbg_non_interactive%2Ftasks%3CBR%20%2F%3E%23%205.0%20%25%3CBR%20%2F%3E%2Fdev%2Fcpuctl%2Fbg_non_interactive%2Fcpu.shares%2052%20%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3C%2FP%3E%3CP%3E%E3%83%9D%E3%82%B9%E3%83%88FS%E3%81%A7%3CBR%20%2F%3E%23%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AE%E5%A4%89%E6%9B%B4%20power_state%3CBR%20%2F%3Echown%20%E3%83%A9%E3%82%B8%E3%82%AA%20%2Fsys%2Fdevices%2Fplatform%2Fu6300_modem%2Fpower_state%3C%2FP%3E%3CP%3E%23%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20%2F%3CBR%20%2F%3Emount%20rootfs%20rootfs%20%2F%20ro%20remount%3C%2FP%3E%3CP%3E%23%20mount%20%E3%81%8C%20root%20%2B%20defaults%20%E3%81%A8%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%86%8D%E5%BA%A6%20chown%2Fchmod%20%2Fdata%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fdata%3CBR%20%2F%3ECHMOD%200771%20%2F%E3%83%87%E3%83%BC%E3%82%BF%3C%2FP%3E%3CP%3E%23%20dump%20dir%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%83%80%E3%83%B3%E3%83%97%E3%82%92%E5%8F%8E%E9%9B%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%23%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%84%E3%80%81%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AB%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%3CBR%20%2F%3E%23%20%E5%B0%82%E7%94%A8%E3%81%AE%E3%83%80%E3%83%B3%E3%83%97%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E6%8C%81%E3%81%9F%E3%81%AA%E3%81%84%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AB%E3%83%80%E3%83%B3%E3%83%97%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%99%E3%82%8B%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3Emkdir%20%2Fdata%2Fdontpanic%3CBR%20%2F%3Echown%20root%20log%20%2Fdata%2Fdontpanic%3CBR%20%2F%3ECHMOD%200750%20%2F%E3%83%87%E3%83%BC%E3%82%BF%2F%E3%83%89%E3%83%B3%E3%83%88%E3%83%91%E3%83%8B%E3%83%83%E3%82%AF%3C%2FP%3E%3CP%3E%23%20%E3%83%91%E3%83%8B%E3%83%83%E3%82%AF%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%8E%E9%9B%86%E3%81%97%E3%80%81%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E8%A7%A3%E6%94%BE%E3%81%97%E3%80%81%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%82%92%E5%86%8D%E6%AD%A6%E8%A3%85%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%2Fproc%2Fapanic_console%20%2Fdata%2Fdontpanic%2Fapanic_console%20%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Echown%20root%20log%20%2Fdata%2Fdontpanic%2Fapanic_console%3CBR%20%2F%3ECHMOD%200640%20%2F%E3%83%87%E3%83%BC%E3%82%BF%2Fdontpanic%2Fapanic_console%3C%2FP%3E%3CP%3E%2Fproc%2Fapanic_threads%20%2Fdata%2Fdontpanic%2Fapanic_threads%20%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Echown%20root%20log%20%2Fdata%2Fdontpanic%2Fapanic_threads%3CBR%20%2F%3ECHMOD%200640%20%2F%E3%83%87%E3%83%BC%E3%82%BF%2Fdontpanic%2Fapanic_threads%3C%2FP%3E%3CP%3E%2Fproc%2Fapanic_console%201%20%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3C%2FP%3E%3CP%3E%23%20%E4%B8%8A%E8%A8%98%E3%81%AE%20%2Fdata%20%E3%81%A8%E5%90%8C%E3%81%98%E7%90%86%E7%94%B1%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%2F%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3CBR%20%2F%3Echmod%200770%20%2F%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3C%2FP%3E%3CP%3E%23%20%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%A5%87%E5%A6%99%E3%81%AA%E6%A8%A9%E9%99%90%E3%81%A7%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%2F%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%2F%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%3CBR%20%2F%3Echmod%200770%20%2F%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%2F%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%3C%2FP%3E%3CP%3Evmallocinfo%E3%81%AE%E6%A8%A9%E9%99%90%20%23change%20%E3%81%97%E3%81%A6%E3%80%81%E3%83%90%E3%82%B0%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Echown%20root%20log%20%2Fproc%2Fvmallocinfo%3CBR%20%2F%3Echmod%200440%20%2Fproc%2Fvmallocinfo%3C%2FP%3E%3CP%3Ekmsg%20%E3%81%A8%20sysrq-trigger%20%E3%81%AE%E3%83%91%E3%83%BC%E3%83%9F%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%20%23change%E3%80%81%E3%83%90%E3%82%B0%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%20kthread%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Echown%20%E3%83%AB%E3%83%BC%E3%83%88%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fproc%2Fkmsg%3CBR%20%2F%3Echmod%200440%20%2Fproc%2Fkmsg%3CBR%20%2F%3Echown%20%E3%83%AB%E3%83%BC%E3%83%88%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fproc%2Fsysrq-trigger%3CBR%20%2F%3ECHMOD%200220%20%2Fproc%2Fsysrq-trigger%3C%2FP%3E%3CP%3E%23%20%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E6%A7%8B%E9%80%A0%E3%82%92%E4%BD%9C%E6%88%90%3CBR%20%2F%3Emkdir%20%2Fdata%2Fmisc%2001771%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%9D%E3%81%AE%E4%BB%96%3CBR%20%2F%3Emkdir%20%2Fdata%2Fmisc%2Fbluetoothd%200770%20%E3%83%96%E3%83%AB%E3%83%BC%E3%83%88%E3%82%A5%E3%83%BC%E3%82%B9%3CBR%20%2F%3Emkdir%20%2Fdata%2Fmisc%2Fbluetooth%200770%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3Emkdir%20%2Fdata%2Fmisc%2Fkeystore%200700%20%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%88%E3%82%A2%20%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%88%E3%82%A2%3CBR%20%2F%3Emkdir%20%2Fdata%2Fmisc%2Fvpn%200770%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3Emkdir%20%2Fdata%2Fmisc%2Fsystemkeys%200700%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3Emkdir%20%2Fdata%2Fmisc%2Fvpn%2Fprofiles%200770%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3E%23%20%E3%83%90%E3%83%83%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%A8%E5%BE%A9%E5%85%83%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%20wpa_supplicant.conf%20%E3%81%B8%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E6%A8%A9%E3%82%92%E4%BB%98%E4%B8%8E%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Emkdir%20%2Fdata%2Fmisc%2Fwifi%200777%20wifi%20wifi%3CBR%20%2F%3ECHMOD%200777%20%2F%E3%83%87%E3%83%BC%E3%82%BF%2F%E3%81%9D%E3%81%AE%E4%BB%96%2Fwifi%3CBR%20%2F%3ECHOWN%20WiFi%20WiFi%20%2F%E3%83%87%E3%83%BC%E3%82%BF%2F%E3%81%9D%E3%81%AE%E4%BB%96%2Fwifi%3CBR%20%2F%3Emkdir%20%2Fdata%2Flocal%200771%20%E3%82%B7%E3%82%A7%E3%83%AB%E3%82%B7%E3%82%A7%E3%83%AB%3CBR%20%2F%3Emkdir%20%2Fdata%2Flocal%2Ftmp%200771%20%E3%82%B7%E3%82%A7%E3%83%AB%E3%82%B7%E3%82%A7%E3%83%AB%3CBR%20%2F%3Emkdir%20%2Fdata%2Fdata%200771%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3Emkdir%20%2Fdata%2Fapp-private%200771%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3Emkdir%20%2Fdata%2Fapp%200771%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3Emkdir%20%2Fdata%2Fproperty%200700%20%E3%83%AB%E3%83%BC%E3%83%88%E3%83%AB%E3%83%BC%E3%83%88%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%23create%20FS%20for%20WLAN%3CBR%20%2F%3E%23%20%E9%9B%BB%E6%BA%90%E5%88%B6%E5%BE%A1%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fdevices%2Fplatform%2Far6103-wifi%2Fpower_state%3CBR%20%2F%3ECHMOD%200666%20%2Fsys%2Fdevices%2Fplatform%2Far6103-wifi%2Fpower_state%3C%2FP%3E%3CP%3E%23%E5%85%83%E3%81%AE%E6%A7%8B%E6%88%90%3CBR%20%2F%3E%23chmod%200777%20%2Fsystem%2Fetc%2Fwifi%3CBR%20%2F%3E%23chmod%200660%20%2Fsystem%2Fetc%2Fwifi%2Fwpa_supplicant.conf%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%23chown%20wifi%20%2Fsystem%2Fetc%2Fwifi%2Fwpa_supplicant.conf%3C%2FP%3E%3CP%3E%23%20wpa_supplicant%E5%88%B6%E5%BE%A1%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3CBR%20%2F%3EMKDIR%20%2F%E3%83%87%E3%83%BC%E3%82%BF%2F%E3%81%9D%E3%81%AE%E4%BB%96%2FWiFi%2Fwpa_supplicant%200777%20WiFi%20WiFi%3CBR%20%2F%3ECHMOD%200777%20%2F%E3%83%87%E3%83%BC%E3%82%BF%2F%E3%81%9D%E3%81%AE%E4%BB%96%2FWiFi%2Fwpa_supplicant%3CBR%20%2F%3ECHOWN%20WiFi%20WiFi%20%2F%E3%83%87%E3%83%BC%E3%82%BF%2F%E3%81%9D%E3%81%AE%E4%BB%96%2FWiFi%2Fwpa_supplicant%3C%2FP%3E%3CP%3E%23%20%E5%AE%9F%E9%9A%9B%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%3CBR%20%2F%3Echmod%200666%20%2Fdata%2Fmisc%2Fwifi%2Fwpa_supplicant.conf%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3Bchown%20wifi%20wifi%20%2F%E3%83%87%E3%83%BC%E3%82%BF%2F%E3%81%9D%E3%81%AE%E4%BB%96%2Fwifi%2Fwpa_supplicant.conf%3C%2FP%3E%3CP%3E%23%20wpa_ctrl%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%3CBR%20%2F%3EMKDIR%20%2F%E3%83%87%E3%83%BC%E3%82%BF%2F%E3%81%9D%E3%81%AE%E4%BB%96%2FWiFi%2F%E3%82%BD%E3%82%B1%E3%83%83%E3%83%880777%20WiFi%20WiFi%3C%2FP%3E%3CP%3E%23%20hostapd%20%E3%81%AE%3CBR%20%2F%3Emkdir%20%2Fdata%2Fmisc%2Fwifi%2Fhostapd%200777%20wifi%20wifi%3CBR%20%2F%3Echmod%200660%20%2Fdata%2Fmisc%2Fwifi%2Fhostapd.conf%3CBR%20%2F%3Echown%20wifi%20wifi%20%2F%E3%83%87%E3%83%BC%E3%82%BF%2F%E3%81%9D%E3%81%AE%E4%BB%96%2Fwifi%2Fhostapd.conf%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23%20dhcp%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20mkdir%20%2Fdata%2Fmisc%2Fdhcp%200777%20dhcp%20dhcp%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20chmod%200777%20%2Fsystem%2Fetc%2Fdhcpcd%2Fdhcpcd-run-hooks%3C%2FP%3E%3CP%3E%23zhangxiaoxu%2020111130%20BT%20%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E8%A8%B1%E5%8F%AF%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Echmod%200777%20%2Fdev%2Fttymxc2%3C%2FP%3E%3CP%3E%23%20dalvik-cache%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81perm%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Emkdir%20%2Fdata%2Fdalvik-cache%200771%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fdata%2Fdalvik-cache%3CBR%20%2F%3Echmod%200771%20%2Fdata%2Fdalvik-cache%3C%2FP%3E%3CP%3E%23%20Lost%2BFound%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E6%A8%A9%E9%99%90%E3%82%92%E5%BC%B7%E5%88%B6%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Emkdir%20%2Fdata%2Flost%2Bfound%200770%3CBR%20%2F%3Emkdir%20%2Fcache%2Flost%2Bfound%200770%3C%2FP%3E%3CP%3E%23%20lost%2Bfound%20%E3%81%8C%E3%81%99%E3%81%A7%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81perms%20%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E6%89%80%E6%9C%89%E8%80%85%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Echown%20root%20root%20%2Fdata%2Flost%2Bfound%3CBR%20%2F%3ECHMOD%200770%20%2F%E3%83%87%E3%83%BC%E3%82%BF%2F%E7%B4%9B%E5%A4%B1%2B%E7%99%BA%E8%A6%8B%3CBR%20%2F%3Echown%20root%20root%20%2Fcache%2Flost%2Bfound%3CBR%20%2F%3Echmod%200770%20%2F%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%2Flost%2Bfound%3C%2FP%3E%3CP%3E%E8%B5%B7%E5%8B%95%E6%99%82%3CBR%20%2F%3E%23%20%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%20init%3CBR%20%2F%3EIFUP%E3%81%AELO%3CBR%20%2F%3E%E3%83%9B%E3%82%B9%E3%83%88%E5%90%8D%20localhost%3CBR%20%2F%3E%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E5%90%8D%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%3C%2FP%3E%3CP%3Emkdir%20%2Fdata%2Fsystem%200775%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3E%20%23exec%20%2Fsbin%2Fts_calibrator%3C%2FP%3E%3CP%3E%23%2019%20%E3%81%8B%E3%82%89%20-20%20%E3%81%BE%E3%81%A7%E3%81%AE%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%92%E8%A8%B1%E5%8F%AF%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%20RLIMIT_NICE%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Esetrlimit%2013%2040%2040%3C%2FP%3E%3CP%3E%23%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AE%E3%82%AF%E3%83%A9%E3%82%B9%E3%81%AEoom_adj%E5%80%A4%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%23%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%BC%B7%E5%88%B6%E7%B5%82%E4%BA%86%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%20ActivityManagerService%20%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Esetprop%20ro.FOREGROUND_APP_ADJ%200%3CBR%20%2F%3Esetprop%20ro.VISIBLE_APP_ADJ%201%3CBR%20%2F%3Esetprop%20ro.PERCEPTIBLE_APP_ADJ%202%3CBR%20%2F%3Esetprop%20ro.HEAVY_WEIGHT_APP_ADJ%203%3CBR%20%2F%3Esetprop%20ro.SECONDARY_SERVER_ADJ%204%3CBR%20%2F%3Esetprop%20ro.BACKUP_APP_ADJ%205%3CBR%20%2F%3Esetprop%20ro.HOME_APP_ADJ%206%3CBR%20%2F%3Esetprop%20ro.HIDDEN_APP_MIN_ADJ%207%3CBR%20%2F%3Esetprop%20ro.EMPTY_APP_ADJ%2015%3C%2FP%3E%3CP%3E%23%20%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%AF%E3%83%A9%E3%82%B9%E3%81%8C%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%97%E3%81%8D%E3%81%84%E5%80%A4%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%99%E3%82%8B%3CBR%20%2F%3E%23%E6%AE%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%95%B0%E5%80%A4%E3%81%AF%E3%83%9A%E3%83%BC%E3%82%B8%E6%95%B0%20(4k)%20%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3Bsetprop%20ro.FOREGROUND_APP_MEM%202048%3CBR%20%2F%3Esetprop%20ro.VISIBLE_APP_MEM%203072%3CBR%20%2F%3Esetprop%20ro.PERCEPTIBLE_APP_MEM%204096%3CBR%20%2F%3Esetprop%20ro.HEAVY_WEIGHT_APP_MEM%204096%3CBR%20%2F%3Esetprop%20ro.SECONDARY_SERVER_MEM%206144%3CBR%20%2F%3Esetprop%20ro.BACKUP_APP_MEM%206144%3CBR%20%2F%3Esetprop%20ro.HOME_APP_MEM%206144%3CBR%20%2F%3Esetprop%20ro.HIDDEN_APP_MEM%207168%3CBR%20%2F%3Esetprop%20ro.EMPTY_APP_MEM%208192%3C%2FP%3E%3CP%3E%23%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%90%E3%83%83%E3%82%AF%E3%83%A9%E3%82%A4%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3CBR%20%2F%3Esetprop%20hw.backlight.dev%20%22pwm-backlight.0%22%3C%2FP%3E%3CP%3E%23%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E5%80%A4%E3%81%AF%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%23%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%206%20%E3%81%A4%E3%81%AE%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%81%97%E3%81%8B%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E4%B8%80%E9%83%A8%E3%82%92%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%23%20%E3%82%AF%E3%83%A9%E3%82%B9%E3%82%92%E5%90%8C%E3%81%98%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AB%E3%80%82%E9%AB%98%E6%AC%A1%E3%81%AE%E9%96%A2%E9%80%A3%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%3CBR%20%2F%3E%23%20%E3%82%AF%E3%83%A9%E3%82%B9%E3%81%AF%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E6%9C%80%E5%88%9D%E3%81%AB%E5%BC%B7%E5%88%B6%E7%B5%82%E4%BA%86%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%2Fsys%2Fmodule%2Flowmemorykiller%2Fparameters%2Fadj%200%2C1%2C2%2C4%2C7%2C15%20%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3C%2FP%3E%3CP%3E%2Fproc%2Fsys%2Fvm%2Flowmem_reserve_ratio%201%20%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3CBR%20%2F%3E%2Fproc%2Fsys%2Fvm%2Fovercommit_memory%201%20%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3CBR%20%2F%3Ewrite%20%2Fproc%2Fsys%2Fvm%2Fmin_free_order_shift%204%3CBR%20%2F%3E%2Fsys%2Fmodule%2Flowmemorykiller%2Fparameters%2Fminfree%202048%2C3072%2C4096%2C6144%2C7168%2C8192%20%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3C%2FP%3E%3CP%3E%23%20init%20%E3%82%92%E3%83%95%E3%82%A9%E3%83%BC%E3%82%AF%E3%81%97%E3%81%9F%E5%AD%90%E3%81%AEoom_adj%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3Bwrite%20%2Fproc%2F1%2Foom_adj%20-16%3C%2FP%3E%3CP%3E%23%20%E8%83%8C%E6%99%AF%E3%81%AE%E6%9B%B8%E3%81%8D%E5%87%BA%E3%81%97%E3%82%92%E5%BE%AE%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%3CBR%20%2F%3E%2Fproc%2Fsys%2Fvm%2Fdirty_expire_centisecs%20200%20%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3CBR%20%2F%3Ewrite%20%2Fproc%2Fsys%2Fvm%2Fdirty_background_ratio%205%3C%2FP%3E%3CP%3E%23%20%E5%90%8C%E6%9C%9F%E6%99%82%E9%96%93%E3%82%92%202%20%E7%A7%92%E3%81%AB%E5%A4%89%E6%9B%B4%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AF%205%20%E7%A7%92%3CBR%20%2F%3E%2Fproc%2Fsys%2Fvm%2Fdirty_writeback_centisecs%20200%20%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3C%2FP%3E%3CP%3E%23%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%A8%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E3%81%AE%E3%83%91%E3%83%BC%E3%83%9F%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3Bchown%20%E7%84%A1%E7%B7%9A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fandroid_power%2Fstate%3CBR%20%2F%3Echown%E3%83%A9%E3%82%B8%E3%82%AA%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%2F%20sys%20%2F%20android_power%20%2F%20request_state%3CBR%20%2F%3Echown%20%E7%84%A1%E7%B7%9A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fandroid_power%2Facquire_full_wake_lock%3CBR%20%2F%3Echown%20%E7%84%A1%E7%B7%9A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fandroid_power%2Facquire_partial_wake_lock%3CBR%20%2F%3Echown%20%E3%83%A9%E3%82%B8%E3%82%AA%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fandroid_power%2Frelease_wake_lock%3CBR%20%2F%3Echown%20radio%20system%20%2Fsys%2Fpower%2Fstate%3CBR%20%2F%3Echown%20%E7%84%A1%E7%B7%9A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fpower%2Fwake_lock%3CBR%20%2F%3Echown%20%E3%83%A9%E3%82%B8%E3%82%AA%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fpower%2Fwake_unlock%3CBR%20%2F%3ECHMOD%200660%20%2Fsys%2Fpower%2Fstate%3CBR%20%2F%3ECHMOD%200660%20%2Fsys%2Fpower%2Fwake_lock%3CBR%20%2F%3ECHMOD%200660%20%2Fsys%2Fpower%2Fwake_unlock%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fclass%2Ftimed_output%2Fvibrator%2Fenable%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fclass%2Fleds%2Fkeyboard-backlight%2Fbrightness%3CBR%20%2F%3ECHOWN%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%2Fsys%2Fclass%2Fleds%2Flcd-backlight%2Fbrightness%3CBR%20%2F%3ECHOWN%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fclass%2Fleds%2F%E3%83%9C%E3%82%BF%E3%83%B3%E3%83%90%E3%83%83%E3%82%AF%E3%83%A9%E3%82%A4%E3%83%88%2F%E6%98%8E%E3%82%8B%E3%81%95%3CBR%20%2F%3Echown%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%2Fsys%2Fclass%2Fleds%2F%E3%82%B8%E3%83%A7%E3%82%B0%E3%83%9C%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%83%A9%E3%82%A4%E3%83%88%2F%E6%98%8E%E3%82%8B%E3%81%95%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fclass%2Fleds%2Fred%2Fbrightness%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fclass%2Fleds%2Fgreen%2Fbrightness%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fclass%2Fleds%2Fblue%2Fbrightness%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fclass%2Fleds%2Fred%2Fdevice%2Fgrpfreq%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fclass%2Fleds%2Fred%2Fdevice%2Fgrppwm%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fclass%2Fleds%2Fred%2Fdevice%2Fblink%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fclass%2Fleds%2Fred%2Fbrightness%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fclass%2Fleds%2Fgreen%2Fbrightness%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fclass%2Fleds%2Fblue%2Fbrightness%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fclass%2Fleds%2Fred%2Fdevice%2Fgrpfreq%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fclass%2Fleds%2Fred%2Fdevice%2Fgrppwm%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fclass%2Fleds%2Fred%2Fdevice%2Fblink%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fclass%2Ftimed_output%2Fvibrator%2Fenable%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fmodule%2Fsco%2Fparameters%2Fdisable_esco%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fkernel%2Fipv4%2Ftcp_wmem_min%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fkernel%2Fipv4%2Ftcp_wmem_def%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fkernel%2Fipv4%2Ftcp_wmem_max%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fkernel%2Fipv4%2Ftcp_rmem_min%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fkernel%2Fipv4%2Ftcp_rmem_def%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fkernel%2Fipv4%2Ftcp_rmem_max%3CBR%20%2F%3Echown%20%E3%83%AB%E3%83%BC%E3%83%88%E3%83%A9%E3%82%B8%E3%82%AA%20%2Fproc%2Fcmdline%3CBR%20%2F%3E%23ningfeiyi%2020110829%20%E9%96%8B%E5%A7%8B%20%3A%20GPS%E7%94%A8%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fdev%2Fneo_6m%3CBR%20%2F%3Echmod%200660%20%2Fdev%2Fneo_6m%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fdev%2Fradio0%3CBR%20%2F%3Echmod%200666%20%2Fdev%2Fradio0%3CBR%20%2F%3E%23ningfeiyi%2020110829%20%E7%AB%AF%3AGPS%E7%94%A8%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E%23%20Chmod%2Fchown%20FSL%E5%9B%BA%E6%9C%89%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3CBR%20%2F%3Echown%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%2Fsys%2Fclass%2Fbacklight%2Fpwm-backlight.0%2Fbrightness%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3Bchmod%200660%20%2Fsys%2Fclass%2Fbacklight%2Fpwm-backlight.0%2Fbrightness%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%23%20%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AETCP%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%99%E3%82%8B%3CBR%20%2F%3E%23%20ReadMin%E3%80%81ReadInitial%E3%80%81ReadMax%E3%80%81WriteMin%E3%80%81WriteInitial%E3%80%81WriteMax%E3%80%81%3CBR%20%2F%3Esetprop%20net.tcp.buffersize.default%204096%2C87380%2C110208%2C4096%2C16384%2C110208%3CBR%20%2F%3Esetprop%20net.tcp.buffersize.wifi4095%2C87380%2C110208%2C4096%2C16384%2C110208%3CBR%20%2F%3Esetprop%20net.tcp.buffersize.umts4094%2C87380%2C110208%2C4096%2C16384%2C110208%3CBR%20%2F%3Esetprop%20net.tcp.buffersize.edge4093%2C26280%2C35040%2C4096%2C16384%2C35040%3CBR%20%2F%3Esetprop%20net.tcp.buffersize.gprs4092%2C8760%2C11680%2C4096%2C8760%2C11680%3C%2FP%3E%3CP%3E%23%20FSL%E5%9B%BA%E6%9C%89%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%20%3CBR%20%2F%3E%23%202%20%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E6%8E%A5%E7%B6%9A%E7%8A%B6%E6%85%8B%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%99%E3%82%8B%3CBR%20%2F%3Esetprop%20rw.secfb.disable-overlay1%3CBR%20%2F%3Esetprop%20rw%E3%81%A7%E3%81%99%E3%80%82SIN_VIDEO_DUAL_UI%200%3CBR%20%2F%3Esetprop%20rw%E3%81%A7%E3%81%99%E3%80%82DUAL_VIDEO_SIN_UI%201%3CBR%20%2F%3E%23%20setprop%20rw.SECOND_DISPLAY_CONNECTED%200%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CBR%20%2F%3E%23%20gst%20player%20%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%99%E3%82%8B%3CBR%20%2F%3Esetprop%20media.gstreamer.enable-player0%3C%2FP%3E%3CP%3E%23%20stageflight%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%99%E3%82%8B%3CBR%20%2F%3Esetprop%20media.stagefright.enable-scan0%3CBR%20%2F%3Esetprop%20media.stagefright.enable-player0%3CBR%20%2F%3Esetprop%20media.stagefright.enable-record1%20%3CBR%20%2F%3Esetprop%20media.stagefright.enable-http0%3CBR%20%2F%3Esetprop%20media.stagefright.enable-meta0%3CBR%20%2F%3Esetprop%20media.stagefright.enable-vpuenc%201%20%3C%2FP%3E%3CP%3E%23%20Define%20fsl%20avi%2Faac%2Fasf%2Fmkv%2Fflv%2Fflac%20format%20support%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20setprop%20ro.FSL_AVI_PARSER%201%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20setprop%20ro.FSL_AAC_PARSER%201%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20setprop%20ro.FSL_ASF_PARSER%201%20%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20setprop%20ro.FSL_FLV_PARSER%201%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20setprop%20ro.FSL_MKV_PARSER%201%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20setprop%20ro.FSL_FLAC_PARSER%201%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20setprop%20ro.FSL_MPG2_PARSER%201%3C%2FP%3E%3CP%3E%23%20fsl%20display%20init%20%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%99%E3%82%8B%3CBR%20%2F%3Esetprop%20ro.FSL_LANDSCAPE_MODE%201%3C%2FP%3E%3CP%3E%23%20fsl%20xec%20%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%99%E3%82%8B%3CBR%20%2F%3Esetprop%20xec.dls.enabled%201%3CBR%20%2F%3Esetprop%20xec.aa.enabled%201%3CBR%20%2F%3Esetprop%20xec.dls.rate%200%3CBR%20%2F%3Esetprop%20xec.aa.rate%20100%3C%2FP%3E%3CP%3E%23%20UI%E3%82%92TVOUT%E3%81%AB%E5%AE%9A%E7%BE%A9%E3%81%97%E3%80%81%E3%81%93%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%921%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Esetprop%20ro.UI_TVOUT_DISPLAY%200%3CBR%20%2F%3E%23write%20%2Fsys%2Fclass%2Fgraphics%2Ffb0%2Fblank%201%3CBR%20%2F%3E%23write%20%2Fsys%2Fclass%2Fgraphics%2Ffb1%2Fblank%201%3CBR%20%2F%3E%23write%20%2Fsys%2Fclass%2Fgraphics%2Ffb2%2Fblank%201%3CBR%20%2F%3E%23write%20%2Fsys%2Fclass%2Fgraphics%2Ffb0%2Ffsl_disp_property%201%20%E5%B1%A4%20fb%3CBR%20%2F%3E%23write%20%2Fsys%2Fclass%2Fgraphics%2Ffb1%2Fmode%20U%3A720x480i-60%5Cn%3CBR%20%2F%3E%23write%20%2Fsys%2Fclass%2Fgraphics%2Ffb1%2Fblank%200%3C%2FP%3E%3CP%3E%23%20ALSA%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%E3%81%AE%E3%83%8D%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E5%AE%9A%E7%BE%A9%3CBR%20%2F%3Esetprop%20alsa.mixer.playback.master%20%E5%86%8D%E7%94%9F%3CBR%20%2F%3Esetprop%20alsa.mixer.capture.master%20%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%3CBR%20%2F%3Esetprop%20alsa.mixer.playback.speaker%20%E5%86%8D%E7%94%9F%3CBR%20%2F%3Esetprop%20alsa.mixer.playback.headset%E3%83%98%E3%83%83%E3%83%89%E3%83%95%E3%82%A9%E3%83%B3%3CBR%20%2F%3Esetprop%20alsa.mixer.capture.headset%20%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%3C%2FP%3E%3CP%3E%23%20Wi-Fi%E3%81%AE%E6%BA%96%E5%82%99%3CBR%20%2F%3Esetprop%20wifi.interface%20wlan0%3C%2FP%3E%3CP%3E%23%20Bluetooth%E3%81%AE%E6%BA%96%E5%82%99%3CBR%20%2F%3Echmod%20665%20%2Fsys%2Fclass%2Frfkill%2Frfkill0%2F%E7%8A%B6%E6%85%8B%3CBR%20%2F%3Echown%20%E3%83%96%E3%83%AB%E3%83%BC%E3%83%88%E3%82%A5%E3%83%BC%E3%82%B9%20%E3%83%96%E3%83%AB%E3%83%BC%E3%83%88%E3%82%A5%E3%83%BC%E3%82%B9%20%2Fsys%2Fclass%2Frfkill%2Frfkill0%2Fstate%3CBR%20%2F%3E%2Fsys%2Fclass%2Frfkill%2Frfkill0%2Fstate%200%20%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3C%2FP%3E%3CP%3E%23%20USB%20host1'remote%20wakeup%20event%20wakeup%20android%20system%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%2Fsys%2Fbus%2Fplatform%2Fdrivers%2Ffsl-ehci%2Ffsl-ehci.1%2Fpower%2Fwakeup%20%E3%82%92%E6%9B%B8%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E6%9C%89%E5%8A%B9%3C%2FP%3E%3CP%3E%23%20RIL%E3%81%AE%E6%BA%96%E5%82%99%3CBR%20%2F%3Esetprop%20gsm.ril.%E9%81%85%E5%BB%B6%2015%3CBR%20%2F%3Esetprop%20ro.ril.wake_lock_timeout300%3C%2FP%3E%3CP%3Eclass_start%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3C%2FP%3E%3CP%3E%23%23%20Daemon%20processes%20to%20be%20run%20by%20init.%3CBR%20%2F%3E%23%23%3CBR%20%2F%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9dispd%20%2F%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%2F%E3%83%93%E3%83%B3%2Fdispd%3CBR%20%2F%3E%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%20Dispd%20%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%200660%20%E3%83%AB%E3%83%BC%E3%83%88%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FP%3E%3CP%3E%23%20Liudongxing%2020110922%20%E9%96%8B%E5%A7%8B%3A%20CMMBServer%3CBR%20%2F%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9cmmb%20%2Fsystem%2Fbin%2Fcmmbserver%3CBR%20%2F%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%AB%E3%83%BC%E3%83%88%3CBR%20%2F%3E%E7%84%A1%E5%8A%B9%3CBR%20%2F%3E%23%20Liudongxing%2020110922%20%E7%B5%82%E4%BA%86%3A%20CMMBServer%20%E3%81%AE%E8%B5%B7%E5%8B%95%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%20ueventd%20%2Fsbin%2Fueventd%3CBR%20%2F%3E%E5%8D%B1%E3%81%86%E3%81%84%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%2Fsystem%2Fbin%2Fsh%3CBR%20%2F%3E%E6%85%B0%E3%82%81%E3%82%8B%3CBR%20%2F%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%AB%E3%83%BC%E3%83%88%3CBR%20%2F%3E%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%83%AD%E3%82%B0%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%3Aro.secure%3D0%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3C%2FP%3E%3CP%3E%23%20adbd%20%E3%81%AF%20persist.service.adb.enable%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%88%B6%E5%BE%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%3A%20adbd%20%2Fsbin%2Fadbd%3CBR%20%2F%3E%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3E%23%20%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%AE%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%20adbd%20%E3%82%92%E3%82%AA%E3%83%B3%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%3Aro.kernel.qemu%3D1%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3BADBD%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%3Apersist.service.adb.enable%3D1%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3BADBD%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%3Apersist.service.adb.enable%3D0%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3BADBD%E3%81%AE%E5%81%9C%E6%AD%A2%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%83%BB%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%83%BB%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%20%2F%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%2Fbin%2F%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%3CBR%20%2F%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%BB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3E%E5%8D%B1%E3%81%86%E3%81%84%3CBR%20%2F%3Eonrestart%20restart%20zygote%3CBR%20%2F%3Eonrestart%20restart%20%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9vold%20%2Fsystem%2Fbin%2Fvold%3CBR%20%2F%3E%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%20vold%20stream%200660%20%E3%83%AB%E3%83%BC%E3%83%88%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%3CBR%20%2F%3Eioprio%20be%202%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%83%8D%E3%83%83%E3%83%88%20%2F%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%2F%E3%83%93%E3%83%B3%2F%E3%83%8D%E3%83%83%E3%83%88%3CBR%20%2F%3E%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%20netd%20%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%200660%20%E3%83%AB%E3%83%BC%E3%83%88%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%20%2Fsystem%2Fbin%2Fdebuggerd%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E6%8E%A5%E5%90%88%E5%AD%90%20%2Fsystem%2Fbin%2Fapp_process%20-Xzygote%20%2Fsystem%2Fbin%20--zygote%20--start-system-server%3CBR%20%2F%3E%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E6%8E%A5%E5%90%88%E5%AD%90%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%20666%3CBR%20%2F%3Eonrestart%20write%20%2Fsys%2Fandroid_power%2Frequest_state%20wake%3CBR%20%2F%3Eonrestart%20write%20%2Fsys%2Fpower%2Fstate%20on%3CBR%20%2F%3Eonrestart%20restart%20%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3CBR%20%2F%3Eonrestart%20restart%20netd%20%E3%81%AE%E5%86%8D%E8%B5%B7%E5%8B%95%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%20%2Fsystem%2Fbin%2Fmediaserver%3CBR%20%2F%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3CBR%20%2F%3E%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%80%81%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%80%81%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%80%81INET%E3%80%81net_bt%20net_bt_admin%20net_raw%3CBR%20%2F%3E%E3%82%A4%E3%82%AA%E3%83%97%E3%83%AA%E3%82%AART%204%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%83%96%E3%83%BC%E3%83%88%E3%82%A2%E3%83%8B%E3%83%A1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2F%20system%20%2F%20bin%20%2F%20bootanimation%3CBR%20%2F%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%3CBR%20%2F%3E%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%3CBR%20%2F%3E%E7%84%A1%E5%8A%B9%3CBR%20%2F%3E%E3%83%AF%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%20dbus%20%2Fsystem%2Fbin%2Fdbus-daemon%20--system%20--nofork%3CBR%20%2F%3E%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%80%81DBUS%E3%80%81%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%80%81660%E3%80%81Bluetooth%E3%80%81Bluetooth%3CBR%20%2F%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BCBluetooth%E3%81%AE%E5%A0%B4%E5%90%88%3CBR%20%2F%3E%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97Bluetooth%20net_bt_admin%3C%2FP%3E%3CP%3E%23xiaoping.zhang%202011%E5%B9%B411%E6%9C%8810%E6%97%A5%E9%96%8B%E5%A7%8B%3ABluetooth%E7%94%A8%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3Eservice%20hciattach%20%2Fsystem%2Fbin%2Flogwrapper%20%2Fsystem%2Fbin%2Fbrcm_patchram_plus%20--enable_hci%20--baudrate%20460800%20--patchram%20%2Fsystem%2Fdata%2Fbcm4329_bt.hcd%20%2Fdev%2Fttymxc2%3CBR%20%2F%3E%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97Bluetooth%20net_bt_admin%3CBR%20%2F%3E%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%20Bluetoothd%20%2Fsystem%2Fbin%2Flogwrapper%20%2Fsystem%2Fbin%2Fbluetoothd%20-n%20-d%3CBR%20%2F%3E%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%80%81Bluetooth%E3%80%81%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0660%E3%80%81Bluetooth%E3%80%81Bluetooth%3CBR%20%2F%3E%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88dbus_bluetooth%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0660%E3%80%81Bluetooth%E3%80%81Bluetooth%3CBR%20%2F%3E%23%20init.rc%20%E3%81%AF%E3%81%BE%E3%81%A0%E6%A9%9F%E8%83%BD%E3%81%AE%E9%81%A9%E7%94%A8%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81root%20%E3%81%A8%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81%3CBR%20%2F%3E%23%20Bluetoothd%E3%81%8C%E9%81%A9%E5%88%87%E3%81%AALinux%E6%A9%9F%E8%83%BD%E3%82%92%E6%8C%81%E3%81%A4Bluetooth%E3%81%ABuid%E3%82%92%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97Bluetooth%20net_bt_admin%E3%81%9D%E3%81%AE%E4%BB%96%3CBR%20%2F%3E%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9obex_client%20%2Fsystem%2Fbin%2Flogwrapper%20%2Fsystem%2Fbin%2Fobex_client%3CBR%20%2F%3E%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97Bluetooth%20net_bt_admin%E3%81%9D%E3%81%AE%E4%BB%96%3CBR%20%2F%3E%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3Eservice%20hf%20%2Fsystem%2Fbin%2Fsdptool%20add%20--channel%3D7%20HF%3CBR%20%2F%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BCBluetooth%E3%81%AE%E5%A0%B4%E5%90%88%3CBR%20%2F%3E%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97Bluetooth%20net_bt_admin%3CBR%20%2F%3E%E7%84%A1%E5%8A%B9%3CBR%20%2F%3E%E3%83%AF%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3E%23service%20opush%20%2Fsystem%2Fbin%2Fsdptool%20add%20--channel%3D12%20OPUSH%3CBR%20%2F%3E%23%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BCBluetooth%E3%81%AE%E5%A0%B4%E5%90%88%3CBR%20%2F%3E%23%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97Bluetooth%20net_bt_admin%3CBR%20%2F%3E%23%20%E7%84%A1%E5%8A%B9%3CBR%20%2F%3E%23%E3%83%AF%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3E%23xiaoping.zhang%202011-11-10%20end%3A%20Bluetooth%E7%94%A8%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%20%2Fsystem%2Fbin%2Finstalld%3CBR%20%2F%3E%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0600%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FP%3E%3CP%3E%23service%20flash_recovery%20%2Fsystem%2Fetc%2Finstall-recovery.sh%3CBR%20%2F%3E%23%E3%83%AF%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%83%A9%E3%82%AF%E3%83%BC%E3%83%B3%2F%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%2F%E3%83%93%E3%83%B3%2F%E3%83%A9%E3%82%AF%E3%83%BC%E3%83%B3%3CBR%20%2F%3E%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%A9%E3%82%AF%E3%83%BC%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0600%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3E%23%20Racoon%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81VPN%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97net_admin%3CBR%20%2F%3E%E7%84%A1%E5%8A%B9%3CBR%20%2F%3E%E3%83%AF%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9MTPD%20%2F%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%2F%E3%83%93%E3%83%B3%2FMTPD%3CBR%20%2F%3E%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88MTPD%20Stream%20600%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%AB%E3%83%BC%E3%83%88%3CBR%20%2F%3E%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97VPN%20net_admin%20net_raw%3CBR%20%2F%3E%E7%84%A1%E5%8A%B9%3CBR%20%2F%3E%E3%83%AF%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%88%E3%82%A2%20%2Fsystem%2Fbin%2Fkeystore%20%2Fdata%2Fmisc%2Fkeystore%3CBR%20%2F%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%88%E3%82%A2%3CBR%20%2F%3E%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%83%BB%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%88%E3%82%A2%3CBR%20%2F%3E%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%BB%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%88%E3%82%A2%E3%83%BB%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%20666%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%83%80%E3%83%B3%E3%83%97%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%2F%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%2F%E3%83%93%E3%83%B3%2F%E3%83%80%E3%83%B3%E3%83%97%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88-s%3CBR%20%2F%3E%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%20%E3%83%80%E3%83%B3%E3%83%97%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%20%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%200660%20%E3%82%B7%E3%82%A7%E3%83%AB%20%E3%83%AD%E3%82%B0%3CBR%20%2F%3E%E7%84%A1%E5%8A%B9%3CBR%20%2F%3E%E3%83%AF%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9wpa_supplicant%20%2Fsystem%2Fbin%2Fwlan_tool%20wpa_supplicant%3CBR%20%2F%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%AB%E3%83%BC%E3%83%88%3CBR%20%2F%3E%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97WiFi%20inet%3CBR%20%2F%3E%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88wpa_wlan0%20dgram%20660%20wifi%20wifi%3CBR%20%2F%3E%E3%83%AF%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%20hostapd%20%2Fsystem%2Fbin%2Fwlan_tool%20hostapd%3CBR%20%2F%3E%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88hostapd_wlap0%20dgram%20660%E3%83%AB%E3%83%BC%E3%83%88wifi%3CBR%20%2F%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%AB%E3%83%BC%E3%83%88%3CBR%20%2F%3E%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97WiFi%3CBR%20%2F%3E%E3%83%AF%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9dhcpcd_wlan0%20%2Fsystem%2Fbin%2Fwlan_tool%20dhcpcd%3CBR%20%2F%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%AB%E3%83%BC%E3%83%88%3CBR%20%2F%3E%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97WiFi%20inet%3CBR%20%2F%3E%E7%84%A1%E5%8A%B9%3CBR%20%2F%3E%E3%83%AF%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9wlan_tool%20%2Fsystem%2Fbin%2Fwlan_tool%3CBR%20%2F%3E%E3%83%AF%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3E%23There%20ec7%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E3%83%A2%E3%83%87%E3%83%A0%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%20ril-daemon%20%2Fsystem%2Fbin%2Frild%20%3CBR%20%2F%3E%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%20RILD%20%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%20660%20%E3%83%AB%E3%83%BC%E3%83%88%20%E3%83%A9%E3%82%B8%E3%82%AA%3CBR%20%2F%3Esocket%20rild-debug%20stream%20660%20%E7%84%A1%E7%B7%9A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3E%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88RILD-PPP%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0660%E7%84%A1%E7%B7%9A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%AB%E3%83%BC%E3%83%88%3CBR%20%2F%3E%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%83%A9%E3%82%B8%E3%82%AA%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5INET%E3%81%9D%E3%81%AE%E4%BB%96%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AAsdcard_rw%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9pppd_gprs%20%2Fetc%2Finit.gprs-pppd%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%AB%E3%83%BC%E3%83%88%3CBR%20%2F%3E%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E7%84%A1%E7%B7%9A%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20INET%20MISC%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3E%E7%84%A1%E5%8A%B9%3CBR%20%2F%3E%20%E3%83%AF%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3E%23add%20by%20dcc%202011%2F11%2F02%20for%20%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88MCUD%3CBR%20%2F%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%20MCU%20%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%20%2Fsystem%2Fbin%2Fmcud%3CBR%20%2F%3E%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%AB%E3%83%BC%E3%83%88%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CBR%20%2F%3E%23Wangwang%2020111029%E3%81%AB%E3%82%88%E3%82%8BCMMB%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AE%E3%82%AA%E3%83%B3%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%AA%E3%83%95%E3%81%AE%E8%BF%BD%E5%8A%A0%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%3Apersist.cmmb.switch%3D1%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3BCMMB%E3%81%AE%E8%B5%B7%E5%8B%95%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%3Apersist.cmmb.switch%3D0%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3BCMMB%E3%81%AE%E5%81%9C%E6%AD%A2%3CBR%20%2F%3E%23%E3%83%AF%E3%83%B3%E3%83%AF%E3%83%B320111029%E3%81%AB%E3%82%88%E3%82%8B%E8%BF%BD%E5%8A%A0%E7%B5%82%E4%BA%86%20%3C%2FP%3E%3CP%3ELei.xiong%2020111109%E3%81%AB%E3%82%88%E3%82%8B%20%23add%E3%80%81CMMB%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Esetprop%20persist.cmmb.%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%201%3CBR%20%2F%3E%23end%20Lei.xiong%2020111109%20%E3%81%AB%E3%82%88%E3%82%8B%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%3E%23add%20%E4%BD%9C%E6%88%90%E8%80%85%3A%20hujun%2020120518%2Clogcat_sdcard%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9logcat_sdcard%20%2Fsystem%2Fbin%2Finit.logcat.sh%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9logcat_radio%20%2Fsystem%2Fbin%2Finit.logradio.sh%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%3Apersist.service.logcat.enable%3D1%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88logcat_sdcard%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%3Apersist.service.logcat.enable%3D0%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E3%82%B9%E3%83%88%E3%83%83%E3%83%97logcat_sdcard%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%3Apersist.service.logcat.enable%3D1%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88logcat_radio%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%3Apersist.service.logcat.enable%3D0%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E3%82%B9%E3%83%88%E3%83%83%E3%83%97logcat_radio%3CBR%20%2F%3E%23add%20%E4%BD%9C%E6%88%90%E8%80%85%3A%20hujun%2020120518%2Clogcat_sdcard%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22TVout%E4%B8%BA%E5%85%A8%E7%BB%BF%E6%95%B0%E6%8D%AE.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22TVout%26amp%3B%2320026%3B%26amp%3B%2320840%3B%26amp%3B%2332511%3B%26amp%3B%2325968%3B%26amp%3B%2325454%3B.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117655i7C15A9FCCA89A2C0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22TVout%26amp%3B%2320026%3B%26amp%3B%2320840%3B%26amp%3B%2332511%3B%26amp%3B%2325968%3B%26amp%3B%2325454%3B.jpg%22%20alt%3D%22TVout%26amp%3B%2320026%3B%26amp%3B%2320840%3B%26amp%3B%2332511%3B%26amp%3B%2325968%3B%26amp%3B%2325454%3B.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ETVout%26amp%3B%2320026%3B%26amp%3B%2320840%3B%26amp%3B%2332511%3B%26amp%3B%2325968%3B%26amp%3B%2325454%3B.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎05-30-2013 01:04 AM
更新者:
