Develop a Simple OpenVG Application Under Linux: Tutorial
This tutorial has been done with an i.MX51 EVK. This example can be easily adapted to i.MX35 or i.MX53 that share the same GPU Core (Z160) and the same API (OpenVG 1.1). This tutorial show you how to do a simple image warp deformation with OpenVG 1.1.
Simple_openVG_roselend_savoie_france.jpg    Simple_openVG_roselend_savoie_france_warp.jpg
Generation of Linux Image with 2D gpu support
To support 2D/3D gpu, you need to select gpu driver in LTIB. In LTIB's "package list" select the following packages:
 [x] amd-gpu-bin-mx51 [x] libz160-bin
Build your Linux Image and copy it to your SD card.
Building OpenVG simple application
  • Download the application (see attached archive)
  • Untar/unbz2 the application source code.
  • To build the simple OpenVG application, you need to adapt the Makerules file.
First you have to indicate where your linux image has been generated withLTIB:
 ROOTFS = /home/fsl/LTIB_1_7/ltib/rootfs
  • You also need to indicate the compiler path (usualy installed in /opt/freescale/usr/local/....):
 GNUTOOL_PATH=/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/
After that you have to copy gpu's driver headers files in the include folder of the project. You will find these header in /opt/freescale/pkgs/amd-gpu-bin-mx51-x.x.x.tar.gz archive:
  • extract all the include folders/files in the include folder of the project.
  • Now you can build the application:
fsl@fsl-laptop:~/SW/openVG_sample$ make
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -mfloat-abi=softfp -mfpu=vfp -Wall -O3 -fsigned-char -D_LINUX -I/home/fsl/SW/openVG_sample/include -c warp.c -o warp.o
In file included from warp.c:37:
roselend_savoie_france_350x350.c:12391:66: warning: trigraph ??) ignored, use -trigraphs to enable
roselend_savoie_france_350x350.c:12964:71: warning: trigraph ??/ ignored, use -trigraphs to enable
roselend_savoie_france_350x350.c:14518:10: warning: trigraph ??- ignored, use -trigraphs to enable
roselend_savoie_france_350x350.c:15118:67: warning: trigraph ??) ignored, use -trigraphs to enable
roselend_savoie_france_350x350.c:15327:67: warning: trigraph ??' ignored, use -trigraphs to enable roselend_savoie_france_350x350.c:15795:62: warning: trigraph ??! ignored, use -trigraphs to enable /opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -I/home/fsl/SW/openVG_sample/include -lOpenVG -legl13 -Wl,--library-path=/home/fsl/LTIB_1_7/ltib/rootfs/usr/lib,-rpath-link=/home/fsl/LTIB_1_7/ltib/rootfs/usr/lib -o warp warp.o
  • Copy the application on your SD card
  • Put the SD card in the i.MX51 and run the gpu drivers
$ login:root
$ modprobe gpu
  • Run the application
 $ ./warp
Modifying the image
A simple way to modify the image, is to use The Gimp. When you want to save your image, choose "C source code format":
Then choose the prefix name (here "roselend"):
Click on "Save". The "C" file of your image is generated:
/* GIMP RGBA C-Source image dump (roselend_savoie_france.c) */
static const struct {
  guint        width;
  guint        height;
  guint        bytes_per_pixel; /* 3:RGB, 4:RGBA */
  guint8       pixel_data[350 * 350 * 4 + 1];
} roselend = {
  350, 350, 4,
  "\265\303\357\376\264\304\357\376\262\304\357\376\260\304\356\376\260\303"
  "\356\376\257\303\356\376\257\302\355\376\257\301\355\376\257\302\355\376"
  "\257\302\355\377\256\302\356\376\256\302\357\376\256\302\356\377\255\302"
"\357\376\254\302\360\376\253\302\357\376\254\302\355\376\255\302\357\376"
添付
コメント
Do anybody has the files included in this tutorial? I have been trying to download it, but the link seems to be not working.
Hi Jose,
Archive is attached now.
Vincent
%3CLINGO-SUB%20id%3D%22lingo-sub-1121288%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELinux%E3%81%A7%E7%B0%A1%E5%8D%98%E3%81%AAOpenVG%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E7%99%BA%E3%81%99%E3%82%8B%3A%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121288%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%81%AF%E3%80%81i.MX51EVK%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%AF%E3%80%81%E5%90%8C%E3%81%98GPU%E3%82%B3%E3%82%A2(Z160)%E3%81%A8%E5%90%8C%E3%81%98API(OpenVG%201.1)%E3%82%92%E5%85%B1%E6%9C%89%E3%81%99%E3%82%8Bi.MX35%E3%81%BE%E3%81%9F%E3%81%AFi.MX53%E3%81%AB%E7%B0%A1%E5%8D%98%E3%81%AB%E9%81%A9%E5%BF%9C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81OpenVG%201.1%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%8D%98%E7%B4%94%E3%81%AA%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20%E3%83%AF%E3%83%BC%E3%83%97%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%A1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A1%8C%E3%81%86%E6%96%B9%E6%B3%95%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Simple_openVG_roselend_savoie_france.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Simple_openVG_roselend_savoie_france.jpg%22%20style%3D%22width%3A%20350px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F37775iB7AF34A228C78526%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Simple_openVG_roselend_savoie_france.jpg%22%20alt%3D%22Simple_openVG_roselend_savoie_france.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Simple_openVG_roselend_savoie_france_warp.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Simple_openVG_roselend_savoie_france_warp.jpg%22%20style%3D%22width%3A%20350px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111693i9ED184BEADE474DC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Simple_openVG_roselend_savoie_france_warp.jpg%22%20alt%3D%22Simple_openVG_roselend_savoie_france_warp.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1414587373%22%20id%3D%22toc-hId--1414587373%22%20id%3D%22toc-hId--493593997%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E2D%20GPU%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8BLinux%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E7%94%9F%E6%88%90%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E2D%2F3D%20GPU%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81LTIB%E3%81%A7GPU%20%3CA%20href%3D%22http%3A%2F%2Fwww.imxdev.org%2Fwiki%2Findex.php%3Ftitle%3DDevelop_a_simple_OpenVG_application_under_Linux_tutorial%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22text-decoration%3A%20underline%3B%22%20title%3D%22Powered%20by%20Text-Enhance%22%20target%3D%22_blank%22%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FA%3E%20%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82LTIB%E3%81%AE%E3%80%8C%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%83%AA%E3%82%B9%E3%83%88%E3%80%8D%E3%81%A7%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%20%5Bx%5D%20amd-gpu-bin-mx51%20%5Bx%5D%20libz160-bin%20%3C%2FPRE%3E%3CP%3ELinux%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%80%81SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1072925460%22%20id%3D%22toc-hId-1072925460%22%20id%3D%22toc-hId-1993918836%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId--734529003%22%20id%3D%22toc-hId--734529003%22%20id%3D%22toc-hId-186464373%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EOpenVG%E3%81%AE%E7%B0%A1%E5%8D%98%E3%81%AA%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FSPAN%3E%3C%2FH2%3E%3CUL%3E%3CLI%3E%3CA%20href%3D%22http%3A%2F%2Fwww.imxdev.org%2Fwiki%2Findex.php%3Ftitle%3DDevelop_a_simple_OpenVG_application_under_Linux_tutorial%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22text-decoration%3A%20underline%3B%22%20title%3D%22Powered%20by%20Text-Enhance%22%20target%3D%22_blank%22%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FA%3E%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99(%E6%B7%BB%E4%BB%98%E3%81%AE%E3%82%A2%E3%83%BC%E3%82%AB%E3%82%A4%E3%83%96%E3%82%92%E5%8F%82%E7%85%A7)%3C%2FLI%3E%3CLI%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92untar%2Funbz2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%8D%98%E7%B4%94%E3%81%AAOpenVG%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81Makerules%20%3CA%20href%3D%22http%3A%2F%2Fwww.imxdev.org%2Fwiki%2Findex.php%3Ftitle%3DDevelop_a_simple_OpenVG_application_under_Linux_tutorial%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22text-decoration%3A%20underline%3B%22%20title%3D%22Powered%20by%20Text-Enhance%22%20target%3D%22_blank%22%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%3C%2FA%3E%E9%81%A9%E5%BF%9C%E3%81%95%E3%81%9B%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81Linux%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8CLTIB%E3%81%A7%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E6%89%80%E3%82%92%E7%A4%BA%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%20ROOTFS%20%3D%20%2Fhome%2Ffsl%2FLTIB_1_7%2Fltib%2Frootfs%20%3C%2FPRE%3E%3CUL%3E%3CLI%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AE%E3%83%91%E3%82%B9%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99(%E9%80%9A%E5%B8%B8%E3%81%AF%2Fopt%2Ffreescale%2Fusr%2Flocal%2F....%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20class%3D%22jive-pre%22%3E%20GNUTOOL_PATH%3D%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.1.2-glibc-2.5-nptl-3%2Farm-none-linux-gnueabi%2Fbin%2F%20%3C%2FPRE%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81GPU%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AEinclude%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%AF%E3%80%81%2Fopt%2Ffreescale%2Fpkgs%2Famd-gpu-bin-mx51-x.x.x.tar.gz%E3%82%A2%E3%83%BC%E3%82%AB%E3%82%A4%E3%83%96%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot-amd-gpu-bin-mx51-4.5.1.tar.gz_.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot-amd-gpu-bin-mx51-4.5.1.tar.gz_.png%22%20style%3D%22width%3A%20651px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111694iF6D4E5B1EA548CE2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot-amd-gpu-bin-mx51-4.5.1.tar.gz_.png%22%20alt%3D%22Screenshot-amd-gpu-bin-mx51-4.5.1.tar.gz_.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E5%86%85%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%2F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%8A%BD%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20class%3D%22jive-pre%22%3Efsl%40fsl-%E3%83%A9%E3%83%83%E3%83%97%E3%83%88%E3%83%83%E3%83%97%3A~%2FSW%2FopenVG_sample%24%20make%0A%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.1.2-glibc-2.5-nptl-3%2Farm-none-linux-gnueabi%2Fbin%2Farm-none-linux-gnueabi-gcc-mfloat-abi%3Dsoftfp%20-mfpu%3Dvfp%20-Wall%20-O3%20-fsigned-char%20-D_LINUX%20-I%2Fhome%2Ffsl%2FSW%2FopenVG_sample%2Finclude%20-c%20warp.c-o%20%E3%83%AF%E3%83%BC%E3%83%97warp.c%3A37%E3%81%8B%E3%82%89%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%0Aroselend_savoie_france_350x350.c%3A12391%3A66%3A%E8%AD%A6%E5%91%8A%3A%E3%83%88%E3%83%AA%E3%82%B0%E3%83%A9%E3%83%95%3F%3F)%E7%84%A1%E8%A6%96%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81-trigraphs%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%0Aroselend_savoie_france_350x350.c%3A12964%3A71%3A%E8%AD%A6%E5%91%8A%3A%E3%83%88%E3%83%AA%E3%82%B0%E3%83%A9%E3%83%95%3F%3F%2F%20ignored%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81-trigraphs%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%0Aroselend_savoie_france_350x350.c%3A14518%3A10%3A%E8%AD%A6%E5%91%8A%3A%E3%83%88%E3%83%AA%E3%82%B0%E3%83%A9%E3%83%95%3F%3F-%20%E7%84%A1%E8%A6%96%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81-trigraphs%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%0Aroselend_savoie_france_350x350.c%3A15118%3A67%3A%E8%AD%A6%E5%91%8A%3A%E3%83%88%E3%83%AA%E3%82%B0%E3%83%A9%E3%83%95%3F%3F)%E7%84%A1%E8%A6%96%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81-trigraphs%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%0Aroselend_savoie_france_350x350.c%3A15327%3A67%3A%E8%AD%A6%E5%91%8A%3A%20trigraph%20%3F%3F'%20%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82-trigraphs%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20roselend_savoie_france_350x350.c%3A15795%3A62%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E8%AD%A6%E5%91%8A%3A%E3%83%88%E3%83%AA%E3%82%B0%E3%83%A9%E3%83%95%3F%3F!%E7%84%A1%E8%A6%96%E3%81%97%E3%81%A6%E3%80%81-trigraphs%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.1.2-glibc-2.5-nptl-3%2Farm-none-linux-gnueabi%2Fbin%2Farm-none-linux-gnueabi-gcc%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82-I%2Fhome%2Ffsl%2FSW%2FopenVG_sample%2Finclude%20-lOpenVG%20-legl13%20-Wl%2C--library-path%3D%2Fhome%2Ffsl%2FLTIB_1_7%2Fltib%2Frootfs%2Fusr%2Flib%2C-rpath-link%3D%2Fhome%2Ffsl%2FLTIB_1_7%2Fltib%2Frootfs%2Fusr%2Flib%20-o%20warp%20warp.ofsl%40fsl-%E3%83%A9%E3%83%83%E3%83%97%E3%83%88%E3%83%83%E3%83%97%3A~%2FSW%2FopenVG_sample%24%20%0A%3C%2FPRE%3E%3CUL%3E%3CLI%3ESD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3ESD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92i.MX51%E3%81%AB%E6%8C%BF%E5%85%A5%E3%81%97%E3%80%81GPU%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20class%3D%22jive-pre%22%3E%24%20login%3Aroot%20%0A%24%20modprobe%20gpu%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20class%3D%22jive-pre%22%3E%20%24%20.%2F%E3%83%AF%E3%83%BC%E3%83%97%20%3C%2FPRE%3E%3CH2%20id%3D%22toc-hId-1752983830%22%20id%3D%22toc-hId-1752983830%22%20id%3D%22toc-hId--1620990090%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId--54470633%22%20id%3D%22toc-hId--54470633%22%20id%3D%22toc-hId-866522743%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E5%A4%89%E6%9B%B4%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%E7%94%BB%E5%83%8F%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E7%B0%A1%E5%8D%98%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81Gimp%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E7%94%BB%E5%83%8F%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8CC%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E5%BD%A2%E5%BC%8F%E3%80%8D%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Simple_openVG_1_gimp_c_header.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Simple_openVG_1_gimp_c_header.png%22%20style%3D%22width%3A%20511px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F39295iBA08038BC6883B07%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Simple_openVG_1_gimp_c_header.png%22%20alt%3D%22Simple_openVG_1_gimp_c_header.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%83%97%E3%83%AC%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E5%90%8D(%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%8Croselend%E3%80%8D)%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Simple_openVG_2_gimp_saveas.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Simple_openVG_2_gimp_saveas.png%22%20style%3D%22width%3A%20294px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111695iA3F7B95957D7AD1F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Simple_openVG_2_gimp_saveas.png%22%20alt%3D%22Simple_openVG_2_gimp_saveas.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%80%8C%E4%BF%9D%E5%AD%98%E3%80%8D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E7%94%BB%E5%83%8F%E3%81%AE%E3%80%8CC%E3%80%8D%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%2F*%20GIMP%20RGBA%20C-Source%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%83%80%E3%83%B3%E3%83%97%20(roselend_savoie_france.c)%20*%2F%0A%20%0A%E9%9D%99%E7%9A%84%20const%20%E6%A7%8B%E9%80%A0%E4%BD%93%20%7B%0A%26nbsp%3B%20%E3%82%AE%E3%83%B3%E3%83%88%E5%B9%85%3B%0A%26nbsp%3B%20%E3%82%AE%E3%83%B3%E3%83%88%E3%81%AE%E9%AB%98%E3%81%95%3B%0A%26nbsp%3B%20%E3%82%AE%E3%83%B3%E3%83%88bytes_per_pixel%3B%2F*%203%3ARGB%2C%204%3ARGBA%20*%2F%0A%26nbsp%3B%20guint8%20pixel_data%5B350%20*%20350%20*%204%20%2B%201%5D%3B%0A%7D%20%E3%83%AD%E3%83%BC%E3%82%BA%E3%83%AC%E3%83%B3%E3%83%89%20%3D%20%7B%0A%26nbsp%3B%20350%2C%20350%2C%204%2C%0A%26nbsp%3B%20%E3%80%8C265%5C303%5C357%5C376%5C264%5C304%5C357%5C376%5C262%5C304%5C357%5C376%5C260%5C304%5C356%5C376%5C260%5C303%E3%80%8D%0A%26nbsp%3B%20%E3%80%8C356%5C376%5C257%5C303%5C356%5C376%5C257%5C302%5C355%5C376%5C257%5C301%5C355%5C376%5C257%5C302%5C355%5C376%E3%80%8D%0A%26nbsp%3B%20%E3%80%8C257%5C302%5C355%5C377%5C256%5C302%5C356%5C376%5C256%5C256%5C302%5C357%5C376%5C256%5C302%5C356%5C377%5C255%5C302%E3%80%8D%0A%E3%80%8C357%5C376%5C254%5C302%5C360%5C376%5C253%5C302%5C357%5C376%5C254%5C302%5C355%5C376%5C255%5C302%5C357%5C376%E3%80%8D%0A...%0A%3C%2FPRE%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1121288%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX51%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1121290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ALinux%E3%81%AE%E4%B8%8B%E3%81%A7%E7%B0%A1%E5%8D%98%E3%81%AAOpenVG%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E7%99%BA%E3%81%99%E3%82%8B%3A%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EJose%E6%A7%98%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%BC%E3%82%AB%E3%82%A4%E3%83%96%E3%81%8C%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%B4%E3%82%A1%E3%83%B3%E3%82%B5%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1121289%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ALinux%E3%81%AE%E4%B8%8B%E3%81%A7%E7%B0%A1%E5%8D%98%E3%81%AAOpenVG%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E7%99%BA%E3%81%99%E3%82%8B%3A%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121289%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-10-2020 02:50 AM
更新者:
