Develop a Simple OpenVG Application Under Linux: Tutorial
This tutorial has been done with an i.MX51 EVK. This example can be easily adapted to i.MX35 or i.MX53 that share the same GPU Core (Z160) and the same API (OpenVG 1.1). This tutorial show you how to do a simple image warp deformation with OpenVG 1.1.
Simple_openVG_roselend_savoie_france.jpg    Simple_openVG_roselend_savoie_france_warp.jpg
Generation of Linux Image with 2D gpu support
To support 2D/3D gpu, you need to select gpu driver in LTIB. In LTIB's "package list" select the following packages:
 [x] amd-gpu-bin-mx51 [x] libz160-bin
Build your Linux Image and copy it to your SD card.
Building OpenVG simple application
  • Download the application (see attached archive)
  • Untar/unbz2 the application source code.
  • To build the simple OpenVG application, you need to adapt the Makerules file.
First you have to indicate where your linux image has been generated withLTIB:
 ROOTFS = /home/fsl/LTIB_1_7/ltib/rootfs
  • You also need to indicate the compiler path (usualy installed in /opt/freescale/usr/local/....):
 GNUTOOL_PATH=/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/
After that you have to copy gpu's driver headers files in the include folder of the project. You will find these header in /opt/freescale/pkgs/amd-gpu-bin-mx51-x.x.x.tar.gz archive:
  • extract all the include folders/files in the include folder of the project.
  • Now you can build the application:
fsl@fsl-laptop:~/SW/openVG_sample$ make
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -mfloat-abi=softfp -mfpu=vfp -Wall -O3 -fsigned-char -D_LINUX -I/home/fsl/SW/openVG_sample/include -c warp.c -o warp.o
In file included from warp.c:37:
roselend_savoie_france_350x350.c:12391:66: warning: trigraph ??) ignored, use -trigraphs to enable
roselend_savoie_france_350x350.c:12964:71: warning: trigraph ??/ ignored, use -trigraphs to enable
roselend_savoie_france_350x350.c:14518:10: warning: trigraph ??- ignored, use -trigraphs to enable
roselend_savoie_france_350x350.c:15118:67: warning: trigraph ??) ignored, use -trigraphs to enable
roselend_savoie_france_350x350.c:15327:67: warning: trigraph ??' ignored, use -trigraphs to enable roselend_savoie_france_350x350.c:15795:62: warning: trigraph ??! ignored, use -trigraphs to enable /opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -I/home/fsl/SW/openVG_sample/include -lOpenVG -legl13 -Wl,--library-path=/home/fsl/LTIB_1_7/ltib/rootfs/usr/lib,-rpath-link=/home/fsl/LTIB_1_7/ltib/rootfs/usr/lib -o warp warp.o
  • Copy the application on your SD card
  • Put the SD card in the i.MX51 and run the gpu drivers
$ login:root
$ modprobe gpu
  • Run the application
 $ ./warp
Modifying the image
A simple way to modify the image, is to use The Gimp. When you want to save your image, choose "C source code format":
Then choose the prefix name (here "roselend"):
Click on "Save". The "C" file of your image is generated:
/* GIMP RGBA C-Source image dump (roselend_savoie_france.c) */
static const struct {
  guint        width;
  guint        height;
  guint        bytes_per_pixel; /* 3:RGB, 4:RGBA */
  guint8       pixel_data[350 * 350 * 4 + 1];
} roselend = {
  350, 350, 4,
  "\265\303\357\376\264\304\357\376\262\304\357\376\260\304\356\376\260\303"
  "\356\376\257\303\356\376\257\302\355\376\257\301\355\376\257\302\355\376"
  "\257\302\355\377\256\302\356\376\256\302\357\376\256\302\356\377\255\302"
"\357\376\254\302\360\376\253\302\357\376\254\302\355\376\255\302\357\376"
附件
评论
Do anybody has the files included in this tutorial? I have been trying to download it, but the link seems to be not working.
Hi Jose,
Archive is attached now.
Vincent
%3CLINGO-SUB%20id%3D%22lingo-sub-1121288%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%20Linux%20%E4%B8%8B%E5%BC%80%E5%8F%91%E7%AE%80%E5%8D%95%E7%9A%84%20OpenVG%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E6%95%99%E7%A8%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121288%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%AC%E6%95%99%E7%A8%8B%E6%98%AF%E4%BD%BF%E7%94%A8%20i.MX51%20EVK%20%E5%AE%8C%E6%88%90%E7%9A%84%E3%80%82%E6%AD%A4%E7%A4%BA%E4%BE%8B%E5%8F%AF%E4%BB%A5%E8%BD%BB%E6%9D%BE%E9%80%82%E5%BA%94%E5%85%B1%E4%BA%AB%E7%9B%B8%E5%90%8C%20GPU%20%E6%A0%B8%E5%BF%83%EF%BC%88Z160%EF%BC%89%E5%92%8C%E7%9B%B8%E5%90%8C%20API%EF%BC%88OpenVG%201.1%EF%BC%89%E7%9A%84%20i.MX35%20%E6%88%96%20i.MX53%E3%80%82%E6%9C%AC%E6%95%99%E7%A8%8B%E5%90%91%E6%82%A8%E5%B1%95%E7%A4%BA%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20OpenVG%201.1%20%E8%BF%9B%E8%A1%8C%E7%AE%80%E5%8D%95%E7%9A%84%E5%9B%BE%E5%83%8F%E6%89%AD%E6%9B%B2%E5%8F%98%E5%BD%A2%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Simple_openVG_roselend_savoie_france.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Simple_openVG_roselend_savoie_france.jpg%22%20style%3D%22width%3A%20350px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F37775iB7AF34A228C78526%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Simple_openVG_roselend_savoie_france.jpg%22%20alt%3D%22Simple_openVG_roselend_savoie_france.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESimple_openVG_roselend_savoie_france.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Simple_openVG_roselend_savoie_france_warp.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Simple_openVG_roselend_savoie_france_warp.jpg%22%20style%3D%22width%3A%20350px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111693i9ED184BEADE474DC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Simple_openVG_roselend_savoie_france_warp.jpg%22%20alt%3D%22Simple_openVG_roselend_savoie_france_warp.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESimple_openVG_roselend_savoie_france_warp.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1414587373%22%20id%3D%22toc-hId--1414587373%22%20id%3D%22toc-hId--493593811%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%E7%94%9F%E6%88%90%E6%94%AF%E6%8C%81%202D%20GPU%20%E7%9A%84%20Linux%20%E6%98%A0%E5%83%8F%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%E8%A6%81%E6%94%AF%E6%8C%812D%2F3D%20gpu%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E5%9C%A8LTIB%E4%B8%AD%E9%80%89%E6%8B%A9gpu%3CA%20href%3D%22http%3A%2F%2Fwww.imxdev.org%2Fwiki%2Findex.php%3Ftitle%3DDevelop_a_simple_OpenVG_application_under_Linux_tutorial%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22text-decoration%3A%20underline%3B%22%20title%3D%22%E7%94%B1%20Text-Enhance%20%E6%8F%90%E4%BE%9B%E6%94%AF%E6%8C%81%22%20target%3D%22_blank%22%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FA%3E%E3%80%82%E5%9C%A8LTIB%E7%9A%84%E2%80%9C%E5%8C%85%E5%88%97%E8%A1%A8%E2%80%9D%E4%B8%AD%E9%80%89%E6%8B%A9%E4%BB%A5%E4%B8%8B%E5%8C%85%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%20%5Bx%5D%20amd-gpu-bin-mx51%20%5Bx%5D%20libz160-bin%20%3C%2FPRE%3E%3CP%3E%E6%9E%84%E5%BB%BA%E6%82%A8%E7%9A%84%20Linux%20%E6%98%A0%E5%83%8F%E5%B9%B6%E5%B0%86%E5%85%B6%E5%A4%8D%E5%88%B6%E5%88%B0%E6%82%A8%E7%9A%84%20SD%20%E5%8D%A1%E3%80%82%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1072925460%22%20id%3D%22toc-hId-1072925460%22%20id%3D%22toc-hId-1993919022%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId--734529003%22%20id%3D%22toc-hId--734529003%22%20id%3D%22toc-hId-186464559%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%E6%9E%84%E5%BB%BAOpenVG%E7%AE%80%E5%8D%95%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FH2%3E%3CUL%3E%3CLI%3E%E4%B8%8B%E8%BD%BD%3CA%20href%3D%22http%3A%2F%2Fwww.imxdev.org%2Fwiki%2Findex.php%3Ftitle%3DDevelop_a_simple_OpenVG_application_under_Linux_tutorial%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22text-decoration%3A%20underline%3B%22%20title%3D%22%E7%94%B1%20Text-Enhance%20%E6%8F%90%E4%BE%9B%E6%94%AF%E6%8C%81%22%20target%3D%22_blank%22%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FA%3E%EF%BC%88%E8%A7%81%E9%99%84%E4%BB%B6%EF%BC%89%3C%2FLI%3E%3CLI%3E%E8%A7%A3%E5%8E%8B%2Funbz2%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%BA%90%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FLI%3E%3CLI%3E%E8%A6%81%E6%9E%84%E5%BB%BA%E7%AE%80%E5%8D%95%E7%9A%84%20OpenVG%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E8%B0%83%E6%95%B4%20Makerules%3CA%20href%3D%22http%3A%2F%2Fwww.imxdev.org%2Fwiki%2Findex.php%3Ftitle%3DDevelop_a_simple_OpenVG_application_under_Linux_tutorial%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22text-decoration%3A%20underline%3B%22%20title%3D%22%E7%94%B1%20Text-Enhance%20%E6%8F%90%E4%BE%9B%E6%94%AF%E6%8C%81%22%20target%3D%22_blank%22%3E%E6%96%87%E4%BB%B6%3C%2FA%3E%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E9%A6%96%E5%85%88%EF%BC%8C%E6%82%A8%E5%BF%85%E9%A1%BB%E6%8C%87%E5%87%BA%E4%BD%BF%E7%94%A8%20LTIB%20%E7%94%9F%E6%88%90%20Linux%20%E6%98%A0%E5%83%8F%E7%9A%84%E4%BD%8D%E7%BD%AE%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%20ROOTFS%20%3D%20%2Fhome%2Ffsl%2FLTIB_1_7%2Fltib%2Frootfs%20%3C%2FPRE%3E%3CUL%3E%3CLI%3E%E6%82%A8%E8%BF%98%E9%9C%80%E8%A6%81%E6%8C%87%E7%A4%BA%E7%BC%96%E8%AF%91%E5%99%A8%E8%B7%AF%E5%BE%84%EF%BC%88%E9%80%9A%E5%B8%B8%E5%AE%89%E8%A3%85%E5%9C%A8%20%2Fopt%2Ffreescale%2Fusr%2Flocal%2F....%EF%BC%89%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20class%3D%22jive-pre%22%3E%20GNUTOOL_PATH%20%3D%20%2F%20opt%20%2F%20freescale%20%2F%20usr%20%2F%20local%20%2F%20gcc-4.1.2-glibc-2.5-nptl-3%20%2F%20arm-none-linux-gnueabi%20%2F%20bin%20%2F%20%3C%2FPRE%3E%3CP%3E%E4%B9%8B%E5%90%8E%EF%BC%8C%E6%82%A8%E5%BF%85%E9%A1%BB%E5%B0%86%20gpu%20%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%A4%B4%E6%96%87%E4%BB%B6%E5%A4%8D%E5%88%B6%E5%88%B0%E9%A1%B9%E7%9B%AE%E7%9A%84%E5%8C%85%E5%90%AB%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E3%80%82%E6%82%A8%E5%B0%86%E5%9C%A8%20%2Fopt%2Ffreescale%2Fpkgs%2Famd-gpu-bin-mx51-xxxtar.gz%20%E6%A1%A3%E6%A1%88%E4%B8%AD%E6%89%BE%E5%88%B0%E8%BF%99%E4%BA%9B%E6%A0%87%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot-amd-gpu-bin-mx51-4.5.1.tar.gz_.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot-amd-gpu-bin-mx51-4.5.1.tar.gz_.png%22%20style%3D%22width%3A%20651px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111694iF6D4E5B1EA548CE2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot-amd-gpu-bin-mx51-4.5.1.tar.gz_.png%22%20alt%3D%22Screenshot-amd-gpu-bin-mx51-4.5.1.tar.gz_.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot-amd-gpu-bin-mx51-4.5.1.tar.gz_.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%8F%90%E5%8F%96%E9%A1%B9%E7%9B%AE%E5%8C%85%E5%90%AB%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E7%9A%84%E6%89%80%E6%9C%89%E5%8C%85%E5%90%AB%E6%96%87%E4%BB%B6%E5%A4%B9%2F%E6%96%87%E4%BB%B6%E3%80%82%3C%2FLI%3E%3CLI%3E%E7%8E%B0%E5%9C%A8%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%9E%84%E5%BB%BA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20class%3D%22jive-pre%22%3E%0Afsl%40fsl-laptop%3A~%2FSW%2FopenVG_sample%24%20make%0A%20%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.1.2-glibc-2.5-nptl-3%2Farm-none-linux-gnueabi%2Fbin%2Farm-none-linux-gnueabi-gcc-mfloat-abi%3Dsoftfp%20-mfpu%3Dvfp%20-Wall%20-O3%20-fsigned-char%20-D_LINUX%20-I%2Fhome%2Ffsl%2FSW%2FopenVG_sample%2Finclude%20-c%20warp.c-o%20%E6%89%AD%E6%9B%B2.o%E5%9C%A8%20warp.c%3A37%20%E4%B8%AD%E5%8C%85%E5%90%AB%E7%9A%84%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%9A%0A%20Roselend_savoie_france_350x350.c%3A12391%3A66%3A%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%BF%BD%E7%95%A5%E4%B8%89%E5%AD%97%E6%AF%8D%E7%BB%84%E5%90%88%3F%3F%EF%BC%8C%E4%BD%BF%E7%94%A8-trigraphs%20%E5%90%AF%E7%94%A8%0ARoselend_savoie_france_350x350.c%3A12964%3A71%3A%E8%AD%A6%E5%91%8A%EF%BC%9A%E4%B8%89%E5%AD%97%E6%AF%8D%E7%BB%84%E5%90%88%3F%3F%2F%20%E8%A2%AB%E5%BF%BD%E7%95%A5%EF%BC%8C%E4%BD%BF%E7%94%A8-trigraphs%20%E6%9D%A5%E5%90%AF%E7%94%A8%0ARoselend_savoie_france_350x350.c%3A14518%3A10%3A%E8%AD%A6%E5%91%8A%EF%BC%9A%E4%B8%89%E5%AD%97%E6%AF%8D%E7%BB%84%E5%90%88%20%3F%3F-%20%E8%A2%AB%E5%BF%BD%E7%95%A5%EF%BC%8C%E4%BD%BF%E7%94%A8%20-trigraphs%20%E6%9D%A5%E5%90%AF%E7%94%A8%0ARoselend_savoie_france_350x350.c%3A15118%3A67%3A%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%BF%BD%E7%95%A5%E4%B8%89%E5%AD%97%E6%AF%8D%E7%BB%84%E5%90%88%3F%3F%EF%BC%8C%E4%BD%BF%E7%94%A8-trigraphs%20%E5%90%AF%E7%94%A8%0ARoselend_savoie_france_350x350.c%3A15327%3A67%3A%E8%AD%A6%E5%91%8A%EF%BC%9A%E4%B8%89%E5%AD%97%E6%AF%8D%E7%BB%84%E5%90%88%3F%3F'%20%E8%A2%AB%E5%BF%BD%E7%95%A5%EF%BC%8C%E4%BD%BF%E7%94%A8%20-trigraphs%20%E6%9D%A5%E5%90%AF%E7%94%A8%20roselend_savoie_france_350x350.c%3A15795%3A62%3A%E8%AD%A6%E5%91%8A%EF%BC%9A%E4%B8%89%E5%AD%97%E6%AF%8D%E7%BB%84%E5%90%88%EF%BC%9F%EF%BC%81%E5%B7%B2%E5%BF%BD%E7%95%A5%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%20-trigraphs%20%E5%90%AF%E7%94%A8%20%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.1.2-glibc-2.5-nptl-3%2Farm-none-linux-gnueabi%2Fbin%2Farm-none-linux-gnueabi-gcc-I%2Fhome%2Ffsl%2FSW%2FopenVG_sample%2Finclude%20-lOpenVG%20-legl13%20-Wl%EF%BC%8C--library-path%3D%2Fhome%2Ffsl%2FLTIB_1_7%2Fltib%2Frootfs%2Fusr%2Flib%EF%BC%8C-rpath-link%3D%2Fhome%2Ffsl%2FLTIB_1_7%2Fltib%2Frootfs%2Fusr%2Flib%20-o%20warp%20warp.ofsl%40fsl-laptop%3A~%2FSW%2FopenVG_sample%24%20%0A%3C%2FPRE%3E%3CUL%3E%3CLI%3E%E5%B0%86%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%A4%8D%E5%88%B6%E5%88%B0%20SD%20%E5%8D%A1%E4%B8%8A%3C%2FLI%3E%3CLI%3E%E5%B0%86%20SD%20%E5%8D%A1%E6%94%BE%E5%85%A5%20i.MX51%20%E5%B9%B6%E8%BF%90%E8%A1%8C%20gpu%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20class%3D%22jive-pre%22%3E%24%20login%3Aroot%20%0A%24%20modprobe%20gpu%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E8%BF%90%E8%A1%8C%E5%BA%94%E7%94%A8%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20class%3D%22jive-pre%22%3E%20%24.%2Fwarp%20%3C%2FPRE%3E%3CH2%20id%3D%22toc-hId-1752983830%22%20id%3D%22toc-hId-1752983830%22%20id%3D%22toc-hId--1620989904%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId--54470633%22%20id%3D%22toc-hId--54470633%22%20id%3D%22toc-hId-866522929%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%E4%BF%AE%E6%94%B9%E5%9B%BE%E5%83%8F%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%E4%BF%AE%E6%94%B9%E5%9B%BE%E5%83%8F%E7%9A%84%E4%B8%80%E4%B8%AA%E7%AE%80%E5%8D%95%E6%96%B9%E6%B3%95%E6%98%AF%E4%BD%BF%E7%94%A8%20Gimp%E3%80%82%E5%BD%93%E6%82%A8%E6%83%B3%E8%A6%81%E4%BF%9D%E5%AD%98%E5%9B%BE%E5%83%8F%E6%97%B6%EF%BC%8C%E8%AF%B7%E9%80%89%E6%8B%A9%E2%80%9CC%20%E6%BA%90%E4%BB%A3%E7%A0%81%E6%A0%BC%E5%BC%8F%E2%80%9D%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Simple_openVG_1_gimp_c_header.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Simple_openVG_1_gimp_c_header.png%22%20style%3D%22width%3A%20511px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F39295iBA08038BC6883B07%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Simple_openVG_1_gimp_c_header.png%22%20alt%3D%22Simple_openVG_1_gimp_c_header.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESimple_openVG_1_gimp_c_header.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E9%80%89%E6%8B%A9%E5%89%8D%E7%BC%80%E5%90%8D%E7%A7%B0%EF%BC%88%E8%BF%99%E9%87%8C%E6%98%AF%E2%80%9Croselend%E2%80%9D%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Simple_openVG_2_gimp_saveas.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Simple_openVG_2_gimp_saveas.png%22%20style%3D%22width%3A%20294px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111695iA3F7B95957D7AD1F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Simple_openVG_2_gimp_saveas.png%22%20alt%3D%22Simple_openVG_2_gimp_saveas.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESimple_openVG_2_gimp_saveas.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%82%B9%E5%87%BB%E2%80%9C%E4%BF%9D%E5%AD%98%E2%80%9D%E3%80%82%E6%82%A8%E7%9A%84%E5%9B%BE%E5%83%8F%E7%9A%84%E2%80%9CC%E2%80%9D%E6%96%87%E4%BB%B6%E5%B7%B2%E7%94%9F%E6%88%90%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%2F*%20GIMP%20RGBA%20C-Source%20%E5%9B%BE%E5%83%8F%E8%BD%AC%E5%82%A8%EF%BC%88roselend_savoie_france.c%EF%BC%89%20*%2F%0A%0A%E9%9D%99%E6%80%81%20const%20%E7%BB%93%E6%9E%84%20%7B%0A%E5%AE%BD%E5%BA%A6%EF%BC%9B%0A%E9%AB%98%E5%BA%A6%EF%BC%9B%0A%20guint%20bytes_per_pixel%3B%20%2F*%203%3ARGB%EF%BC%8C4%3ARGBA%20*%2F%0A%20guint8%E5%83%8F%E7%B4%A0%E6%95%B0%E6%8D%AE%5B350*350*4%2B1%5D%EF%BC%9B%0A%20%7D%20%E7%BD%97%E6%96%AF%E5%85%B0%E5%BE%B7%20%3D%20%7B%0A%20350%EF%BC%8C350%EF%BC%8C4%EF%BC%8C%0A%20%E2%80%9C%5C265%5C303%5C357%5C376%5C264%5C304%5C357%5C376%5C262%5C304%5C357%5C376%5C260%5C304%5C356%5C376%5C260%5C303%E2%80%9D%0A%20%E2%80%9C%5C356%5C376%5C257%5C303%5C356%5C376%5C257%5C302%5C355%5C376%5C257%5C301%5C355%5C376%5C257%5C302%5C355%5C376%E2%80%9D%0A%20%E2%80%9C%5C257%5C302%5C355%5C377%5C256%5C302%5C356%5C376%5C256%5C302%5C357%5C376%5C256%5C302%5C356%5C377%5C255%5C302%E2%80%9D%0A%20%E2%80%9C%5C357%5C376%5C254%5C302%5C360%5C376%5C253%5C302%5C357%5C376%5C254%5C302%5C355%5C376%5C255%5C302%5C357%5C376%E2%80%9D%0A%20...%0A%3C%2FPRE%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1121288%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX51%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1121290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Linux%20%E4%B8%8B%E5%BC%80%E5%8F%91%E4%B8%80%E4%B8%AA%E7%AE%80%E5%8D%95%E7%9A%84%20OpenVG%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E6%95%99%E7%A8%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8CJose%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%A1%A3%E6%A1%88%E7%8E%B0%E5%B7%B2%E9%99%84%E4%B8%8A%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%96%87%E6%A3%AE%E7%89%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1121289%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Linux%20%E4%B8%8B%E5%BC%80%E5%8F%91%E4%B8%80%E4%B8%AA%E7%AE%80%E5%8D%95%E7%9A%84%20OpenVG%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%E6%95%99%E7%A8%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121289%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%89%E4%BA%BA%E6%9C%89%E6%9C%AC%E6%95%99%E7%A8%8B%E4%B8%AD%E5%8C%85%E5%90%AB%E7%9A%84%E6%96%87%E4%BB%B6%E5%90%97%EF%BC%9F%E6%88%91%E4%B8%80%E7%9B%B4%E8%AF%95%E5%9B%BE%E4%B8%8B%E8%BD%BD%E5%AE%83%EF%BC%8C%E4%BD%86%E9%93%BE%E6%8E%A5%E4%BC%BC%E4%B9%8E%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-10-2020 02:50 AM
更新人:
