DRM framebuffer capture tool
On behalf of Gopise Yuan.
This is an update for the DRM framebuffer capture tool I used to share with the team. Some enhancement added.
Might be useful for debugging some display related issues.
Some special notes:
  1. Behavior of DRM subsystem is different between L4.x and L5.x.
For L4.x, you can capture the RGB buffer without any problem. But, there’s no API for YUV (multi-plane) buffer. To capture YUV, need to apply “kernel_0001-drm-Add-getfb2-ioctl_L4.14.98.patch”.
For L5.x, mapping/capturing the internal buffer is not allowed by default due to security reason. A simple change in “0001-drm-enable-mapping-of-internal-object-for-debugging_L5.x.patch” can disable this guard.
  1. Capture raw data only. RGB and YUV (packed/planar, 420/422) supported.
  2. Support de-tile on “Amphion tile” (VPU, NV12 only) and “Super tile” (Vivante GPU). Please use “-t” to enable this. Other tile might not be supported.
  3. This is a static linked binary. You can run it on any ARM64 based Linux/Android system in theory (prerequisites in item #1). If you need source code, come to me.
To get more details on how to use it, use “-?” option:
DRM screen capture
DRM based screen capture program
Usage:
    ./drmfbcap [OP] [ARG]
[OP] OPeration (optional):
    -v Show version.
    -? Show help information.
    -i Show information about target DRM device only (no capture).
    -t Perform de-tile for tile format.
    -d DRM device to open. [ARG] should contain the path to the device node. Default: '/dev/dri/card0'
    -o Output folder. [ARG] should contain the path to the output folder. Default: '.'
    -p Specific plane # to capture. [ARG] should contain the plane number. If no '-p' specified, capture all planes
Example:
    ./drmfbcap
  Capture all planes on default DRM device.
    ./drmfbcap -d /dev/dri/controlD64
  Capture all planes on '/dev/dri/controlD64' device.
    ./drmfbcap -p 44 -t -o /sdcard
  Capture plane 44, do de-tile after capture and then output to /sdcard/.
Raw buffer capture will be done for each enabled/target plane and one file for each.
Captured file will be saved to './' if not specified.
--- By Gopise, 2022/08
Updated_2023_10_16:
continuous capture (repeat mode) support with this link:
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/DRM-screen-capture-tool/ta-p/1725363
添付
%3CLINGO-SUB%20id%3D%22lingo-sub-1523863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDRM%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%83%84%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1523863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3EGopise%20Yuan%E3%82%92%E4%BB%A3%E8%A1%A8%E3%81%97%E3%81%A6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%A7%E3%81%AF%E3%80%81%E3%83%81%E3%83%BC%E3%83%A0%E3%81%A8%E3%81%AE%E5%85%B1%E6%9C%89%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FDRM%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%BB%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%83%BB%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E6%9B%B4%E6%96%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%A9%9F%E8%83%BD%E5%BC%B7%E5%8C%96%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E9%96%A2%E9%80%A3%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A4%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3E%E7%89%B9%E5%88%A5%E3%81%AA%E6%B3%A8%E6%84%8F%E4%BA%8B%E9%A0%85%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3EDRM%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E5%8B%95%E4%BD%9C%E3%81%AF%E3%80%81L4.x%E3%81%A8L5.x%E3%81%A7%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3EL4.x%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81RGB%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%3CSPAN%3EYUV%EF%BC%88%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%EF%BC%89%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AEAPI%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82YUV%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%3C%2FSPAN%3E%E3%80%8C%3CSPAN%3Ekernel_0001-drm-Add-getfb2-ioctl_L4.14.98.patch%3C%2FSPAN%3E%E3%80%8D%3CSPAN%3E%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EL5.x%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E4%B8%8A%E3%81%AE%E7%90%86%E7%94%B1%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E5%86%85%E9%83%A8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%2F%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%AF%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E4%BF%9D%E8%AD%B7%E3%81%AF%E3%80%81%E3%80%8C%3CSPAN%3E0001-drm-enable-mapping-of-internal-object-for-debugging_L5.x.patch%3C%2FSPAN%3E%E3%80%8D%3CSPAN%3E%E3%81%AB%E7%B0%A1%E5%8D%98%E3%81%AA%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E8%A7%A3%E9%99%A4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3COL%20start%3D%222%22%3E%0A%3CLI%3E%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AFRAW%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E3%81%BF%E3%81%A7%E3%80%81RGB%E3%81%A8YUV%EF%BC%88%E3%83%91%E3%83%83%E3%82%AF%2F%E3%83%97%E3%83%AC%E3%83%BC%E3%83%8A%E3%83%BC%E3%80%81420%2F422%EF%BC%89%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3ESupport%20de-tile%E3%80%8C%3CSPAN%3EAmphion%E3%82%BF%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%E3%80%8D%3CSPAN%3E%EF%BC%88VPU%E3%80%81NV12%E3%81%AE%E3%81%BF%EF%BC%89%E3%81%A8%3C%2FSPAN%3E%E3%80%8C%3CSPAN%3ESuper%E3%82%BF%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%E3%80%8D%3CSPAN%3E%EF%BC%88Vivante%20GPU%EF%BC%89%E3%81%A7%E3%82%BF%E3%82%A4%E3%83%AB%E3%81%AE%E8%A7%A3%E9%99%A4%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%3C%2FSPAN%3E%E2%80%9C%3CSPAN%3E-t%3C%2FSPAN%3E%E2%80%9D%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E4%BB%96%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%AB%E3%81%AF%E8%A7%A3%E9%99%A4%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%E3%81%93%E3%81%AE%E6%9B%B4%E6%96%B0%E3%81%AF%E9%9D%99%E7%9A%84%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9F%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%A7%E3%81%99%E3%80%82%E7%90%86%E8%AB%96%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AEARM64%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AELinux%2FAndroid%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%EF%BC%88%E5%89%8D%E6%8F%90%E6%9D%A1%E4%BB%B6%E3%81%AF%E3%82%A2%E3%82%A4%E3%83%86%E3%83%A0%231%E3%81%AB%E8%A8%98%E8%BC%89%EF%BC%89%E3%80%82%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%BB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%94%E9%80%A3%E7%B5%A1%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E2%80%9C%3CSPAN%3E-%3F%3C%2FSPAN%3E%E2%80%9D%3CSPAN%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EDRM%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%3C%2FP%3E%0A%3CP%3EDRM%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E7%94%BB%E9%9D%A2%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%83%BB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%3C%2FP%3E%0A%3CP%3E%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%3A%3C%2FP%3E%0A%3CP%3E.%2Fdrmfbcap%20%5BOP%5D%20%5BARG%5D%3C%2FP%3E%0A%3CP%3E%5BOP%5D%20OPeration%EF%BC%88%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%89%EF%BC%9A%3C%2FP%3E%0A%3CP%3E-v%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%3F%20%E3%83%98%E3%83%AB%E3%83%97%E6%83%85%E5%A0%B1%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-i%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88DRM%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%83%85%E5%A0%B1%E3%81%AE%E3%81%BF%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%EF%BC%88%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%AA%E3%81%97%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-t%20%E3%82%BF%E3%82%A4%E3%83%AB%E3%83%BB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%AE%E8%A7%A3%E9%99%A4%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E-d%20DRM%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E9%96%8B%E3%81%8F%E3%80%82%5BARG%5D%20%E3%81%AB%E3%81%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AE%E3%83%91%E3%82%B9%E3%82%92%E5%90%AB%E3%82%81%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3A%20'%2Fdev%2Fdri%2Fcard0'%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-o%20%E5%87%BA%E5%8A%9B%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%80%82%5BARG%5D%E3%81%AB%E3%81%AF%E5%87%BA%E5%8A%9B%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AE%E3%83%91%E3%82%B9%E3%82%92%E5%90%AB%E3%82%81%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AF'%E3%80%8C.%E3%80%8D%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-p%20%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%99%E3%82%8B%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E7%95%AA%E5%8F%B7%E3%81%A7%E3%81%99%E3%80%82%5BARG%5D%E3%81%AB%E3%81%AF%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E7%95%AA%E5%8F%B7%E3%82%92%E5%90%AB%E3%82%81%E3%81%BE%E3%81%99%E3%80%82%E3%80%8C-p%E3%80%8D%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BE%8B%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.%2Fdrmfbcap%3C%2FP%3E%0A%3CP%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEDRM%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E5%85%A8%E3%81%A6%E3%81%AE%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E.%2Fdrmfbcap%20-d%20%2Fdev%2Fdri%2FcontrolD64%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%20%E3%80%8C%2Fdev%2Fdri%2FcontrolD64%E3%80%8D%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%81%82%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E.%2Fdrmfbcap%20-p%2044%20-t%20-o%20%2Fsdcard%3C%2FP%3E%0A%3CP%3E%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%2044%20%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%80%81%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E5%BE%8C%E3%81%AB%E3%82%BF%E3%82%A4%E3%83%AB%E8%A7%A3%E9%99%A4%E3%82%92%E8%A1%8C%E3%81%84%E3%80%81%2Fsdcard%2F%20%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%9C%AA%E5%8A%A0%E5%B7%A5%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%BB%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%AF%E6%9C%89%E5%8A%B9%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%2F%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%BB%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E3%81%94%E3%81%A8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C1%E3%81%A4%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%8C.%2F%E3%80%8D%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E---%20%E5%9F%B7%E7%AD%86%E8%80%85%EF%BC%9AGopise%E3%80%812022%E5%B9%B408%E6%9C%88%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EUpdated_2023_10_16%3A%3C%2FP%3E%0A%3CP%3E%E9%80%A3%E7%B6%9A%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%EF%BC%88%E5%8F%8D%E5%BE%A9%E3%83%A2%E3%83%BC%E3%83%89%EF%BC%89%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%A8%98%E4%BA%8B%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FDRM-screen-capture-tool%2Fta-p%2F1725363%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FDRM-screen-capture-tool%2Fta-p%2F1725363%3C%2FA%3E%3C%2FP%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1523863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%20%7C%20i.MX%208QuadMax%E2%80%AF(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎10-13-2023 07:18 AM
更新者:
