Compiling Qt5.3.0-beta1 on Yocto
Here are my experiences for compiling Qt5.3.0-beta1 on Yocto. Special thanks to Martin Jansa, the maintainer of the meta-qt5 layer and his help on this. My original procedure was based on this tutorial: Building Qt5 using yocto on Wandboard - Wandboard Wiki
Reason:
Qt5.3 contains a nice new plugin that allows the use of gstreamer output for textures without the CPU intensive step of copying them (Gerrit Code Review). This allows to play even full HD videos and apply all the power of Qt5 (e.g. shaders) to them.
Steps:
diff --git a/recipes-qt/qt5/qt5.inc b/recipes-qt/qt5/qt5.inc
index dfc1c76..a2f9a73 100644
--- a/recipes-qt/qt5/qt5.inc
+++ b/recipes-qt/qt5/qt5.inc
@@ -54,6 +54,7 @@ FILES_${PN}-tools-dbg = " \
FILES_${PN}-plugins-dbg = " \
     ${OE_QMAKE_PATH_PLUGINS}/*/.debug/* \
+    ${OE_QMAKE_PATH_PLUGINS}/*/*/.debug/* \
# extra packages
@@ -98,6 +99,7 @@ FILES_${PN}-tools = " \
FILES_${PN}-plugins = " \
     ${OE_QMAKE_PATH_PLUGINS}/*/*${SOLIBSDEV} \
+    ${OE_QMAKE_PATH_PLUGINS}/*/*/*${SOLIBSDEV} \
FILES_${PN}-mkspecs = "\
     ${OE_QMAKE_PATH_ARCHDATA}/mkspecs \
  • Define your machine: export MACHINE=xxx (replace with your board)
  • Setup build environment: cd .. ; . setup-environment build
  • edit your local layer conf ("conf/bblayers.conf") and add the following two lines:
  ${BSPDIR}/sources/meta-openembedded/meta-ruby \
  ${BSPDIR}/sources/meta-qt5 \
  • edit your local.conf and add the following lines:
DISTRO_FEATURES_remove = "x11 wayland"
IMAGE_INSTALL_append = " \
    firmware-imx-vpu-imx6q \
    firmware-imx-vpu-imx6d \
    cpufrequtils \
    nano \
    packagegroup-fsl-gstreamer \
    packagegroup-fsl-tools-testapps \
    packagegroup-fsl-tools-benchmark \
    gstreamer \
    gst-plugins-base-app \
    gst-plugins-base \
    gst-plugins-good \
    gst-plugins-good-rtsp \
    gst-plugins-good-udp \
    gst-plugins-good-rtpmanager \
    gst-plugins-good-rtp \
    gst-plugins-good-video4linux2 \
    qtbase-fonts \
    qtbase-plugins \
    qtbase-tools \
    qtbase-examples \
    qtdeclarative \
    qtdeclarative-plugins \
    qtdeclarative-tools \
    qtdeclarative-examples \
    qtdeclarative-qmlplugins \
    qtmultimedia \
    qtmultimedia-plugins \
    qtmultimedia-examples \
    qtmultimedia-qmlplugins \
    qtsvg \
    qtsvg-plugins \
    qtsensors \
    qtimageformats-plugins \
    qtsystems \
    qtsystems-tools \
    qtsystems-examples \
    qtsystems-qmlplugins \
    qtscript \
    qt3d \
    qt3d-examples \
    qt3d-qmlplugins \
    qt3d-tools \
    qtwebkit \
    qtwebkit-examples-examples \
    qtwebkit-qmlplugins \
    cinematicexperience \
PACKAGECONFIG_append_pn-qtmultimedia = " gstreamer010"
QT5_VERSION = "5.2.1+5.3.0-beta1+git%"
PREFERRED_VERSION_qtbase-native = "${QT5_VERSION}"
PREFERRED_VERSION_qtbase = "${QT5_VERSION}"
PREFERRED_VERSION_qtdeclarative = "${QT5_VERSION}"
PREFERRED_VERSION_qtjsbackend = "${QT5_VERSION}"
PREFERRED_VERSION_qtjsbackend-native = "${QT5_VERSION}"
PREFERRED_VERSION_qtgraphicaleffects = "${QT5_VERSION}"
PREFERRED_VERSION_qtimageformats = "${QT5_VERSION}"
PREFERRED_VERSION_qtmultimedia = "${QT5_VERSION}"
PREFERRED_VERSION_qtquick1 = "${QT5_VERSION}"
PREFERRED_VERSION_qtquickcontrols = "${QT5_VERSION}"
PREFERRED_VERSION_qtsensors = "${QT5_VERSION}"
PREFERRED_VERSION_qtserialport = "${QT5_VERSION}"
PREFERRED_VERSION_qtscript = "${QT5_VERSION}"
PREFERRED_VERSION_qtsvg = "${QT5_VERSION}"
PREFERRED_VERSION_qttools-native = "${QT5_VERSION}"
PREFERRED_VERSION_qtwebkit = "${QT5_VERSION}"
PREFERRED_VERSION_qtwebkit-examples = "${QT5_VERSION}"
PREFERRED_VERSION_qtxmlpatterns = "${QT5_VERSION}"
  • build an image: bitbake core-image-minimal
This image will build QT5.3 for framebuffer. If you want to use it with X11, then adapt according to this tutorial: Integrate Qt5 into yocto sato image on Wandboard - Wandboard Wiki
Please tell me, if I missed something. I wrote this as I remembered the steps.
评论
Fir I'd like to thank you for you description how to build Qt 5.3 for imx6
but I am getting an error when trying your guide.
I started from scratch and did everything as you describe.
But i get an error for qtxmlpatterns saying:
ERROR: QA Issue: qtxmlpatterns: The compile log indicates that host include and/or library paths were used.
         Please check the log '/home/devuser/yocto/build/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/qtxmlpatterns/5.2.1+5.3.0-beta1+gitAUTOINC+d25091bb8b-r0/temp/log.do_compile' for more information.
ERROR: QA run found fatal errors. Please consider fixing them.
ERROR: Function failed: do_package_qa
ERROR: Logfile of failure stored in: /home/devuser/yocto/build/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/qtxmlpatterns/5.2.1+5.3.0-beta1+gitAUTOINC+d25091bb8b-r0/temp/log.do_package.28091
ERROR: Task 1589 (/home/devuser/yocto/sources/meta-qt5/recipes-qt/qt5/qtxmlpatterns_git.bb, do_package) failed with exit code '1'
if i look into the generated Makefile i can see a -L/usr/lib in LDFLAGS.
I removed that and did a bitbake qtxmlpatterns -f -c compile and then a bitbake qtqmlpatterns
this succeeds then and i can continue bitbaking the image.
probably i should have deleted the generated .so, so it is linked without -L/usr/lib, but i am not using qtxmlpatterns right now.
But i have no clue how the  -L/usr/lib comes into the Makefile in LDFLAGS only for qtxmlpatterns module, i searh all files and *.pri and *.pro but have not found anything.
I am still bakingthe image now , so i dont know if will succeed in the end.
Gunnar
The git reposiitory is a moving target. Guess, it would have been best to pin it to a specific commit that I used.
I tried to reproduce the problem, but the current version from git gives me other problems already in the configure step of qtbase.
When I have a running version, I will change the recipe to the specific commit.
ok now i am also getting this for qtdeclarative. this was compiled before but somehow it started getting a new version from git,
i workaround that by doing
bitbake qtdeclarative -f -c compile
and then continuing, that will create a clean compile log as everything is compiled already so the QA dtetction will be tricked into thinking there is no problem.
It seems that are some very strange things happening in this repo. I had a backup from my old compile (only the sources folder) and checked the git revision that I checked out for this howto. It was 0c114f4bcf6bdf5b959ff8821bbbbff2dd1cdccf.
Looking at a new git clone, this commit no longer exists! Something strange is happening here.
Gunnar,
could you try
git checkout 92be18a3a14deed9d38b8fc6e89f09ba4d730597
And then add the patch from me.
This was the version I used (successfully). With the next commit, I get configure problems.
I will now see, If I can reproduce your problem.
Btw. which revision are you using exactly?
m ynext problem was qtlocation, it tries to build the 5.2.1 versin which fails.
i had to add
PREFERRED_VERSION_qtlocation = "${QT5_VERSION}"
to my local.conf.
but then it failed because of license md5 check. i had to copy the license checksum entries from qtsensers_git.bb to qtlocation_git.bb.
then it fails with the known ERROR: QA Issue: qtlocation: The compile log indicates that host include and/or library paths were used.
this i workaround as written above.
continue baking ...
Well, I just tried with the revision 92be18a3a14deed9d38b8fc6e89f09ba4d730597, and I could bake all my modules without problems. I checked qtxmlpatterns, but I do not use qtlocation.
I never had your problem. What is the host you are crosscompiling on?
ubuntu 12.04 32 bit vm
i also didnt explictly enable qtlocation. this is my local.conf
B_NUMBER_THREADS ?= "${@oe.utils.cpu_count()}"
PARALLEL_MAKE ?= "-j ${@oe.utils.cpu_count()}"
MACHINE ??= 'imx6qsabresd'
DISTRO ?= 'poky'
PACKAGE_CLASSES ?= "package_rpm"
EXTRA_IMAGE_FEATURES = "debug-tweaks ssh-server-openssh tools-profile dbg-pkgs tools-debug"
    cpufrequtils \
    nano \
    gdb \
    openssh-sftp-server \
    gstreamer \
    gst-plugins-base \
    gst-plugins-good \
    qtbase-fonts \
    qtbase-plugins \
    qtbase-tools \
    qtbase-examples \
    qtdeclarative \
    qtmultimedia \
    qtquickcontrols-qmlplugins \
    qtsvg \
    qtsvg-plugins \
    qtsensors \
    qtsystems \
    qtsystems-tools \
    qtscript \
    qt3d \
    qt3d-examples \
    qt3d-qmlplugins \
    qt3d-tools \
    qtwebkit \
    cairo pango fontconfig freetype pulseaudio dbus \
    alsa-lib alsa-tools alsa-state alsa-utils-alsaconf \
PACKAGECONFIG_append_pn-qtbase = " accessibility gles2 openssl"
PREFERRED_PROVIDER_jpeg = "libjpeg-turbo"
TOOLCHAIN_HOST_TASK_append = " nativesdk-python-subprocess"
USER_CLASSES ?= "buildstats image-mklibs image-prelink"
PATCHRESOLVE = "noop"
BB_DISKMON_DIRS = "\
    STOPTASKS,${TMPDIR},1G,100K \
    STOPTASKS,${DL_DIR},1G,100K \
    STOPTASKS,${SSTATE_DIR},1G,100K \
    ABORT,${TMPDIR},100M,1K \
    ABORT,${DL_DIR},100M,1K \
    ABORT,${SSTATE_DIR},100M,1K"
PACKAGECONFIG_pn-qemu-native = "sdl"
ASSUME_PROVIDED += "libsdl-native"
CONF_VERSION = "1"
BB_NUMBER_THREADS = '4'
PARALLEL_MAKE = '-j 4'
DL_DIR ?= "${BSPDIR}/downloads/"
ACCEPT_FSL_EULA = "1"
Hmm, similar to me except I'm using 64bit.
But honestly, I have never seen your error message "ERROR: QA Issue: qt...: The compile log indicates that host include and/or library paths were used."
What meta-qt5 git revision have you checked out? Maybe this makes a difference.
Hmm, I'm not a Yocto expert. Just started my work with it. But it seems to be you did not checkout "master-next" for the yocto repo, but you use "dora". I'm not saying that this makes the difference. I have just noted.
What image do you build? core-image-minimal?
Otherwise, there is not much that comes to my mind. Maybe some other Yocto expert can comment on this.
i have fea4eb8fe57fb5dd52ead5a351d4ec0940301443
with this changes:
devuser@ubuntu:~/yocto/sources/meta-qt5$ git diff fea4eb8fe57fb5dd52ead5a351d4ec0940301443
# extra packages
diff --git a/recipes-qt/qt5/qtbase.inc b/recipes-qt/qt5/qtbase.inc
index 89736be..f23236a 100644
--- a/recipes-qt/qt5/qtbase.inc
+++ b/recipes-qt/qt5/qtbase.inc
@@ -126,7 +126,6 @@ PACKAGECONFIG[nis] = "-nis,-no-nis"
PACKAGECONFIG[widgets] = "-widgets,-no-widgets"
QT_CONFIG_FLAGS += " \
-    -reduce-relocations \
     -shared \
     -silent \
     -no-pch \
diff --git a/recipes-qt/qt5/qtlocation_git.bb b/recipes-qt/qt5/qtlocation_git.bb
index d1d2575..87ad63d 100644
--- a/recipes-qt/qt5/qtlocation_git.bb
+++ b/recipes-qt/qt5/qtlocation_git.bb
@@ -2,3 +2,10 @@ require qt5-git.inc
require ${PN}.inc
SRCREV = "9cbddccc24cdd4b51285ea9ecbf851f3eba2cd31"
+# older copyright year than what e.g. qtbase is using now
+LIC_FILES_CHKSUM = "file://LICENSE.LGPL;md5=4193e7f1d47a858f6b7c0f1ee66161de \
+                    file://LICENSE.GPL;md5=d32239bcb673463ab874e80d47fae504 \
+                    file://LGPL_EXCEPTION.txt;md5=0145c4d1b6f96a661c2c139dfb268fb6 \
+                    file://LICENSE.FDL;md5=6d9f2a9af4c8b8c3c769f6cc1b6aaf7e"
O.K., so now I fixed my configure problem with the latest version. Gunnar actually had the solution already in his changes:
  -shared \
  -silent \
  -no-pch \
So, now I indeed get the same "ERROR: QA Issue: qt...: The compile log indicates that host include and/or library paths were used." error.
I don't know where the problem comes from, but I recommend you use revision 92be18a3a14deed9d38b8fc6e89f09ba4d730597, which is a bit older, but otherwise works without problems.
hi,
i found out adding WARN_QA="compile-host-path libdir" to local.conf suppresses the QA errors. but only after doing
bitbake <package> -f -c compile
the baked image runs fine. the only thing is that Qt5CinenmaticExperince does not run, because 5.3 has problems with the property name onText in Switch.qml. It seems as if onXXX is reserved for signal handler names now.
changing it  to  _onText everywhere it is used , makes the demo working again.
creating a toolchain with
bitbake meta-toolchain-qt5
needs some more entries in local.conf and some additional license hash copy paste actions, because the toolchain contains more qt packages than the image.
here my local.conf with debug symbols and gdb on device.
BB_NUMBER_THREADS ?= "${@oe.utils.cpu_count()}"
DISTRO ?= 'poky'
    cpufrequtils \
    nano \
    gdb \
    gstreamer \
    gst-plugins-base \
    gst-plugins-good \
    qtbase-fonts \
    qtbase-plugins \
    qtbase-tools \
    qtbase-examples \
    qtdeclarative \
    qtmultimedia \
    qtsvg \
    qtsvg-plugins \
    qtsensors \
    qtsystems \
    qtsystems-tools \
    qtscript \
    qt3d \
    qt3d-examples \
    qt3d-qmlplugins \
    qt3d-tools \
    qtwebkit \
PREFERRED_VERSION_qttools = "${QT5_VERSION}"
PREFERRED_VERSION_qtconnectivity = "${QT5_VERSION}"
PREFERRED_VERSION_nativesdk-qtbase = "${QT5_VERSION}"
CONF_VERSION = "1"
Are there any changes in the steps that are being posted with the latest qt5 revision from git?
Sorry, I cannot say. I am still using 92be18a3a14deed9d38b8fc6e89f09ba4d730597, as this works flawlessly for me with the original recipe.
So after step git clone -b jansa/qt5-5.3.0-beta1 https://github.com/meta-qt5/meta-qt5.git, I need to try git checkout 92be18a3a14deed9d38b8fc6e89f09ba4d730597 and proceed with the same as described?
Hope it will not have any problems in Qtlocation as I need to use the qtlocation module.
Yeah, that should be the steps.
I can't comment on QtLocation as I am not using it. I only use Qtbase and QtMultimedia.
Otherwise, you can try with the steps posted from Gunnar.
Yes it bit-bakes with these steps without any problems.
Please let me know steps to build and test sample Qt app as the default Qt5_CinematicExperience
didnot run properly with output white screen.
if you would have read my  comments above  you would have found:
so bitbaking meta-toolchain-qt5 gives you a toolchain with qt5 included.
to build you own app is then just a matter of setting up the environment with the script  of the toolchain  and doing qmake and make.
I'm getting below error even after adding "qtquickcontrols-qmlplugins \" to local.conf
ERROR: Unable to install packages. Command '/home/kishore/meta-qt-toolchain/fsl-community-bsp/build/tmp/sysroots/i686-linux/usr/bin/smart --data-dir=/home/kishore/meta-qt-toolchain/fsl-community-bsp/build/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/meta-toolchain-qt5/1.0-r0/sdk/image/opt/poky/1.6+snapshot/sysroots/cortexa9hf-vfp-neon-poky-linux-gnueabi/var/lib/smart install -y packagegroup-core-standalone-sdk-target-dbg@all packagegroup-core-standalone-sdk-target@all packagegroup-qt5-toolchain-target@all' returned 1:
Loading cache...
Updating cache...               ######################################## [100%]
Computing transaction...error: Can't install packagegroup-qt5-toolchain-target-1.0-r0@all: no package provides qtquickcontrols-qmlplugins
ERROR: Function failed: do_populate_sdk
ERROR: Logfile of failure stored in: /home/kishore/meta-qt-toolchain/fsl-community-bsp/build/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/meta-toolchain-qt5/1.0-r0/temp/log.do_populate_sdk.6534
ERROR: Task 7 (/home/kishore/meta-qt-toolchain/fsl-community-bsp/sources/meta-qt5/recipes-qt/meta/meta-toolchain-qt5.bb, do_populate_sdk) failed with exit code '1'
I am using the meta-qt5 branch from git.
Though I check wout with Revision 92be18a3a14deed9d38b8fc6e89f09ba4d730597, it gives below error on my build system.
ERROR: Logfile of failure stored in: /home/ramakanth/fsl-community-bsp/build/tmp/work/cortexa9hf-vfp-neon-mx6-poky-linux-gnueabi/qtbase/5.2.1+5.3.0-beta1+gitAUTOINC+207598fd8e-r0/temp/log.do_configure.29906
Log data follows:
| DEBUG: Executing python function sysroot_cleansstate
| DEBUG: Python function sysroot_cleansstate finished
| DEBUG: Executing shell function qmake5_base_preconfigure
| DEBUG: Shell function qmake5_base_preconfigure finished
| DEBUG: Executing shell function do_configure
| This is the Qt Open Source Edition.
| You are licensed to use this software under the terms of
| the Lesser GNU General Public License (LGPL) versions 2.1.
| You are also licensed to use this software under the terms of
| the GNU General Public License (GPL) versions 3.
| You have already accepted the terms of the Open Source license.
| Performing shadow build...
| Preparing build tree...
| arm-poky-linux-gnueabi-g++ -march=armv7-a -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a9 --sysroot=/home/ramakanth/fsl-community-bsp/build/tmp/sysroots/imx6qsabreauto -c -fvisibility=hidden fvisibility.c
| Symbol visibility control enabled.
| arm-poky-linux-gnueabi-g++ -march=armv7-a -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a9 --sysroot=/home/ramakanth/fsl-community-bsp/build/tmp/sysroots/imx6qsabreauto -o libtest.so -shared -Wl,-Bsymbolic-functions -fPIC bsymbolic_functions.c
| bsymbolic_functions.c:2:2: error: #error "Symbolic function binding on this architecture may be broken, disabling it (see QTBUG-36129)."
| Symbolic function binding disabled.
| -reduce-relocations was requested but this compiler does not support it
| Re-run configure with -v for more information
| WARNING: exit code 1 from a shell command.
| ERROR: Function failed: do_configure (log file is located at /home/ramakanth/fsl-community-bsp/build/tmp/work/cortexa9hf-vfp-neon-mx6-poky-linux-gnueabi/qtbase/5.2.1+5.3.0-beta1+gitAUTOINC+207598fd8e-r0/temp/log.do_configure.29906)
ERROR: Task 680 (/home/ramakanth/fsl-community-bsp/sources/meta-qt5/recipes-qt/qt5/qtbase_git.bb, do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1089 tasks of which 31 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
Summary: There were 3 WARNING messages shown.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
Please let me know if there is a workaround for the same
The above error is thrown when I did bitbake meta-toolchain-qt5
I don't use the toolchain, as I build my app directly in yocto.
But if you get this error, then remove the line containing "-reduce-relocations" from the following files:
recipes-qt/qt5/nativesdk-qtbase.inc
am getting below error even after adding qtquickcontrols-qmlplugins to local.conf. Please let me know how to resolve this.
ERROR: Unable to install packages. Command '/home/ramakanth/fsl-community-bsp/build/tmp/sysroots/i686-linux/usr/bin/smart --data-dir=/home/ramakanth/fsl-community-bsp/build/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/meta-toolchain-qt5/1.0-r0/sdk/image/opt/poky/1.6+snapshot/sysroots/cortexa9hf-vfp-neon-poky-linux-gnueabi/var/lib/smart install -y packagegroup-core-standalone-sdk-target-dbg@all packagegroup-core-standalone-sdk-target@all packagegroup-qt5-toolchain-target@all' returned 1:
Loading cache...
ERROR: Logfile of failure stored in: /home/ramakanth/fsl-community-bsp/build/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/meta-toolchain-qt5/1.0-r0/temp/log.do_populate_sdk.5288
ERROR: Task 7 (/home/ramakanth/fsl-community-bsp/sources/meta-qt5/recipes-qt/meta/meta-toolchain-qt5.bb, do_populate_sdk) failed with exit code '1'
I removed qtquickcontrols-qmlplugins from local.conf and packagegroup-qt5-toolchain-target to get rid of the above error. It generated
poky-eglibc-i686-meta-toolchain-qt5-cortexa9hf-vfp-neon-toolchain-1.6+snapshot.sh in /tmp/deploy/sdk. Please let me know if we run the script, where exactly qmake will be generated so that I would like to build my app.
I got below error when I run bitbake core-image-minimal..However, bitbake meta-toolchain-qt5 was successful and qmake is generated.
Probably it has sth to do picking the latest git version.
Error..qtquickcontrols not found in the base feeds.
Please let me know if there is a workaround for the same.
I just wanted to say thanks. These posts were extremely helpful in getting 5.3 running on the Wandboard.
I've tested QML video with rotating text over top and the CPU usage dropped from 90% in Qt 5.2.1 to 35% in Qt 5.3 beta.  Clearly the VPU is being used now along with the GPU.
Cheers!
If I want to build my app directly in Yocto, where do I need to keep the app sources?
Do I need to mention in local.conf as building through toolchain is not working fine
You need to add a recipe for your app. Have a look at the cinematicexperience recipe. You can copy it, rename it and adapt to your app.
Iam bitbaking but at the end throws below qtquickcontrols error..Atleast in the earlier recipes, this problem didnot occur..
ERROR: qtquickcontrols not found in the base feeds
ERROR: Function failed: do_rootfs
ERROR: Logfile of failure stored in: /home/kishore/Yocto_Qt/fsl-community-bsp/build/tmp/work/imx6qsabreauto-poky-linux-gnueabi/core-image-minimal/1.0-r0/temp/log.do_rootfs.28549
ERROR: Task 7 (/home/kishore/Yocto_Qt/fsl-community-bsp/sources/poky/meta/recipes-core/images/core-image-minimal.bb, do_rootfs) failed with exit code '1'
Do you need qtquickcontrols? If not, a simple solution is, to remove it from your local.conf.
If you need it, you will need to investigate, why it is not built.
Yes I do need qtquickcontrols using splitview qtquickcontrol in my app.. Seems it is a known issue as mentioned in https://community.freescale.com/thread/324000
As i see in qtbase.inc, accessibility is required to compile qtquickcontrols..
I did mention PACKAGECONFIG_append_pn-qtbase = " accessibility gles2 openssl" in local.conf but still the problem is seen.
For now, removing from local.conf..Is it possible to compile qtquickcontrols source separately later? If so, please let me know the steps
Removing qtquickcontrols from local.conf created the image successfully.
so bitbaking meta-toolchain-qt5 created a toolchain with qt5 included.
I tried to set up the environment with the script  of the toolchain setting qmake path to /opt/poky/1.6+snapshot/sysroots/i686-pokysdk-linux/usr/bin/qt5.
But QMAKE_SPEC takes invalid conf i.e. /fsl-community-bsp/build/tmp/sysroots/i686-linux/usr/lib/qt5/mkspecs/linux-oe-g++ which throws an error make:c command not found while building the sample app.
Please let me know how to setup the path and correct sysroot.
Build does not compiled. In Makefiles of qt* packages set wrong library path(/usr/lib instead $(sysroot)//usr/lib). If fixed it packages build, but on board examples programs corrupt with Segmentation Fault message.
Anybody created working build?
Where in Makefile were the library paths set to /usr/lib instead of [sysroot]/usr/lib?
For example in Makefiles in qtxmlpatterns, qtdeclarative, qtwebkit.
Library path set in it by "-L/usr/lib".
find . -name "Makefiles*" -exec grep "-L/usr/lib" '{}' \;
show this.
In qt* 5.1.1 and qt 5.2.1 I have no this problem? but in it examples browsers does not show any html5 videos
https://github.com/meta-qt5/meta-qt5/blob/jansa/qt5-5.3.0-beta1/recipes-qt/qt5/qtbase/0005-qt_module...
That patch needs to be updated for 5.3.0. I'm looking into this but I'm new to mkspecs and qmake, so any advice is welcome.
See also:
https://www.mail-archive.com/openembedded-devel@lists.openembedded.org/msg36039.html
I have got a build working for the wandboard here if anyone is interested:
cetola/meta-qt5 · GitHub
You will need to add the qt5-5.3.0 branch to the fsl-community-bsp daisy branch.  Also add this to your local.conf:
PACKAGECONFIG_append_pn-qtmultimedia = " gstreamer010 "
Then bitbake wandboard-image-qt5.  You can test HDMI video playback with gplay or gst-launch:
gst-launch filesrc location=video.m4v typefind=true \
! aiurdemux \
! vpudec \
! mfw_v4lsink
I've also tested video in QML and hardware video acceleration seems to work fine.  The only issue was that I had to run the following command to display video correctly:
echo -n 32 > /sys/class/graphics/fb0/bits_per_pixel
This may just be a QML or Qt setting that I missed.  Anyway, video worked fine, as did some simple text animations.
Please try to play html5 video in examples test browsers. Is it work?
In my build qt 5.1.1 qml video players work fine, but WebKit show video controls and first frame from video for WebM(from w4c.org site for example), from youtube I see player controls and download circle.
In console i see this messages from Gstreamer like this:
Qt Warning: Could not find a location of the system's Compose files. Consider setting the QTCOMPOSE environment variable.
libpng warning: iCCP: Not recognizing known sRGB profile that has been edited
Received finished signal while progress is still: 10 Url:  QUrl( "http://qt-project.org/" )
Aiur: 3.0.11
Core: MPEG4PARSER_06.07.04  build on Dec  5 2013 11:41:38
  mime: video/quicktime; audio/x-m4a; application/x-3gp
  file: /usr/lib/imx-mm/parser/lib_mp4_parser_arm11_elinux.so.3.2
Content Info:
    URI:
          https://r1---sn-8xb5-px8e.googlevideo.com/videoplayback?ip=212.90.165.14&require
          ssl=yes&mws=yes&source=youtube&upn=4-tA0Ie6tDA&mv=m&sparams=id,ip,ipbits,itag,ra
          tebypass,requiressl,source,upn,expire&key=yt5&ipbits=0&mt=1401803916&id=o-ABczKx
          qqFwtM_XhBgSvGnsGqyiHL18Wy6SqK0BZepcFQ&signature=121A2CB3142FB772CD72A9F1D872603
          C749A2B74.0370EDFC498A96A43C8F8A98C10184E14158A0D2&sver=3&ratebypass=yes&expire=
          1401827798&ms=au&fexp=908548,912321,913434,916611,923341,926122,930008&itag=18&c
          pn=VgAqvxj2iI2hp45w&ptk=youtube_none&pltype=contentugc&c=WEB&cver=html5
    Seekable  : Yes
    Size(byte): 32830110
Movie Info:
    Seekable  : Yes
    Live      : No
    Duration  : 0:11:52.503360000
    ReadMode  : Track
    Track     : 2
Track 00 [video_000000] Enabled
    Duration: 0:11:52.503360000
    Language: und
    Mime:
          video/x-h264, parsed=(boolean)true, width=(int)640, height=(int)360, framerate=(
          fraction)24000/1001
Track 01 [audio_000000] Enabled
    Language: und
    Mime:
          audio/mpeg, mpegversion=(int)4, channels=(int)2, rate=(int)44100, bitrate=(int)9
          6000, framed=(boolean)true, stream-format=(string)raw, codec_data=(buffer)121000
          00000000000000000000000000
Beep: 3.0.11
Core: AAC decoder Wrapper  build on Jan 22 2014 15:42:53
  mime: audio/mpeg, mpegversion=(int){2,4}
  file: /usr/lib/imx-mm/audio-codec/wrap/lib_aacd_wrap_arm12_elinux.so.3
CODEC: BLN_MAD-MMCODECS_AACD_ARM_03.07.00_CORTEX-A8  build on Sep 18 2013 10:29:53.
[--->FINALIZE aiurdemux
Iam getting QtQuickcontrols Not found in base feeds error after adding the qt5-5.3.0 branch to the fsl-community-bsp daisy branch.
Please let me know local.conf to see if anything is missing incase you have added qtquickcontrols and any dependecy.
add qtquick1 into IMAGE_INSTALL_append
Is the below local.conf good enough apart from adding qtquick1:
MACHINE ??= 'imx6qsabreauto'
DISTRO ?= 'poky'
EXTRA_IMAGE_FEATURES = "debug-tweaks"
CONF_VERSION = "1"
ACCEPT_FSL_EULA = ""
PACKAGECONFIG_append_pn-qtbase= "accessibility gles2 openssl"
cpufrequtils \
binutils \
nano \
gdb \
gstreamer \
gst-plugins-base \
gst-plugins-good \
qtbase-fonts \
qtbase-plugins \
qtbase-tools \
qtbase-examples \
qtdeclarative \
qtmultimedia \
qtlocation \
qtlocation-plugins \
qtlocation-qmlplugins \
qtlocation-examples \
qtsvg \
qtsvg-plugins \
qtsystems \
qtsystems-tools \
qtscript \
qt3d \
qt3d-examples \
qt3d-qmlplugins \
qt3d-tools \
qtwebkit \
qtconnectivity \
qtconnectivity-examples \
qtconnectivity-qmlplugins \
qtserialport \
qtquickcontrols \
ivi \
cairo pango fontconfig freetype pulseaudio dbus zlib \
tslib evtest tslib-conf tslib-tests tslib-calibrate \
gcc g++ libgcc libgcc-dev libstdc++ libstdc++-dev libstdc++-staticdev \
It's build ok, but examples, such as multimediawidgets/player,  multimediawidgets/videowidget doesn't play video, qtwebkit/browser, qtwebkit/youtubeview qtwebkit/fanicybrowser does't support HTML5 video and play it.
In 5.1.1 version video is play video in upper players, browsers support HTML5 video, but doesn't play it.
Have you any ideas?
I have not had a chance to look at the examples yet. The big change in 5.3.0 is the way QML renders video (now using hardware decoding).
Since the video works fine in QML, either the examples are not building correctly or the way that the examples play video is now obsolete. My first guess would be to look at the examples code and see the way that they are rendering the video.
I will post again if I have a chance to look at this, though it will probably not be this week.
Many thanks to Michael Banditt for his work getting 5.3.0 beta running. (not to mention Otavio and Martin Jansa for maintaining the meta-qt5 branch).
I seem to be hijacking these comments, so I've created my own document. Anyone interested in chatting about 5.3.0 release can do so here:
Qt 5.3.0 release on i.MX6 using fsl-community-bsp and meta-qt5
Hi my name is Lucas and im new in embedded aplications , i follow all the wiki about how to create a yocto whit qt and how to get a sdk for my qt , but now when i try to compile some features like
QtQuick.Controls 1.2 ,Quick.Controls.Private 1.0, QtQuick.Controls.Styles 1.1 in QML is not working .
Whre could be the possible reason? and how to solve it ?
Lucas
Dear Ramakanth , i[m getting the same problem that you related in your post and id like to know if you already found a solution for that
Lucas Prado Rocha
I got exatctly the same error, however I am not able to find anyline with "-reduce-relocations" in nativesdk-qtbase.inc or qtbase.inc. Is there any other way how to resolve this ?
HI all,
In repository meta-qt5/meta-qt5 · GitHub is absent branch jansa/qt5-5.3.0-beta1.
What branch I should take instead?
Thanks!
%3CLINGO-SUB%20id%3D%22lingo-sub-1105151%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105151%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%20%E7%9A%84%E7%BB%8F%E9%AA%8C%E3%80%82%E7%89%B9%E5%88%AB%E6%84%9F%E8%B0%A2%20meta-qt5%20%E5%B1%82%E7%9A%84%E7%BB%B4%E6%8A%A4%E8%80%85%20Martin%20Jansa%20%E5%8F%8A%E5%85%B6%E5%AF%B9%E6%AD%A4%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%E6%88%91%E6%9C%80%E5%88%9D%E7%9A%84%E7%A8%8B%E5%BA%8F%E6%98%AF%E5%9F%BA%E4%BA%8E%E8%BF%99%E4%B8%AA%E6%95%99%E7%A8%8B%E7%9A%84%EF%BC%9A%3CA%20href%3D%22http%3A%2F%2Fwiki.wandboard.org%2Findex.php%2FBuilding_Qt5_using_yocto_on_Wandboard%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%9C%A8%20Wandboard%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20yocto%20%E6%9E%84%E5%BB%BA%20Qt5%20-%20Wandboard%20Wiki%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20class%3D%22western%22%20id%3D%22toc-hId-1081699625%22%20id%3D%22toc-hId-2005253364%22%3E%E5%8E%9F%E5%9B%A0%EF%BC%9A%3C%2FH3%3E%3CP%3EQt5.3%20%E5%8C%85%E5%90%AB%E4%B8%80%E4%B8%AA%E4%B8%8D%E9%94%99%E7%9A%84%E6%96%B0%E6%8F%92%E4%BB%B6%EF%BC%8C%E5%85%81%E8%AE%B8%E4%BD%BF%E7%94%A8%20gstreamer%20%E8%BE%93%E5%87%BA%E7%BA%B9%E7%90%86%EF%BC%8C%E8%80%8C%E6%97%A0%E9%9C%80%E6%89%A7%E8%A1%8C%E5%8D%A0%E7%94%A8%E5%A4%A7%E9%87%8F%20CPU%20%E7%9A%84%E5%A4%8D%E5%88%B6%E6%AD%A5%E9%AA%A4%EF%BC%88%20%3CA%20href%3D%22https%3A%2F%2Fcodereview.qt-project.org%2F%23change%2C76764%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGerrit%20%E4%BB%A3%E7%A0%81%E5%AE%A1%E6%9F%A5%3C%2FA%3E%EF%BC%89%E3%80%82%E8%BF%99%E6%A0%B7%E5%B0%B1%E5%8F%AF%E4%BB%A5%E6%92%AD%E6%94%BE%E5%85%A8%E9%AB%98%E6%B8%85%E8%A7%86%E9%A2%91%E5%B9%B6%E5%85%85%E5%88%86%E5%88%A9%E7%94%A8%20Qt5%20%E7%9A%84%E5%85%A8%E9%83%A8%E5%8A%9F%E8%83%BD%EF%BC%88%E4%BE%8B%E5%A6%82%E7%9D%80%E8%89%B2%E5%99%A8%EF%BC%89%E7%BB%99%E4%BB%96%E4%BB%AC%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20class%3D%22western%22%20id%3D%22toc-hId--725754838%22%20id%3D%22toc-hId-197798901%22%3E%E6%AD%A5%E9%AA%A4%EF%BC%9A%3C%2FH3%3E%3CUL%3E%3CLI%3E%E8%AE%BE%E7%BD%AE%E4%BD%A0%E7%9A%84%20repo%EF%BC%9A%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Erepo%20init%3C%2FSPAN%3E%20%3CCODE%20class%3D%22western%22%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%3CSPAN%3E-u%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%3C%2FA%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%20%3C%2FSPAN%3E%3CCODE%20class%3D%22western%22%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E-b%20master-next%3B%20repo%20sync%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%E4%B8%8B%E8%BD%BD%20meta-qt5%20%E5%88%86%E6%94%AF%EF%BC%9A%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Ecd%20sources%3B%20git%20clone%20-b%20jansa%2Fqt5-5.3.0-beta1%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5.git%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5.git%3C%2FA%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%3CSTRONG%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%E6%A3%80%E5%87%BA%E7%89%B9%E5%AE%9A%E4%BF%AE%E8%AE%A2%E7%89%88%3C%2FSPAN%3E%EF%BC%9Acd%20meta-qt5%3B%20git%20checkout%2092be18a3a14deed9d38b8fc6e89f09ba4d730597%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%E5%BA%94%E7%94%A8%E4%BB%A5%E4%B8%8B%E8%A1%A5%E4%B8%81%EF%BC%88%E4%BB%A5%E5%90%8E%E5%8F%AF%E8%83%BD%E4%B8%8D%E5%86%8D%E9%9C%80%E8%A6%81%EF%BC%89%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Ediff%20--git%20a%2Frecipes-qt%2Fqt5%2Fqt5.inc%20b%2Frecipes-qt%2Fqt5%2Fqt5.inc%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%E7%B4%A2%E5%BC%95%20dfc1c76..a2f9a73%20100644%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E---%20a%2Frecipes-qt%2Fqt5%2Fqt5.inc%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2B%2B%2Bb%2Frecipes-qt%2Fqt5%2Fqt5.inc%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%40%40%20-54%2C6%20%2B54%2C7%20%40%40%20FILES_%20%24%7BPN%7D%20-tools-dbg%20%3D%E2%80%9C%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%E6%96%87%E4%BB%B6_%20%24%7BPN%7D%20-plugins-dbg%20%3D%E2%80%9C%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%24%7BOE_QMAKE_PATH_PLUGINS%7D%2F*%2F.debug%2F*%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%7BOE_QMAKE_PATH_PLUGINS%7D%2F*%2F*%2F.debug%2F*%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%23%20%E9%A2%9D%E5%A4%96%E7%9A%84%E5%8C%85%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%40%40%20-98%2C6%20%2B99%2C7%20%40%40%20FILES_%20%24%7BPN%7D%20-tools%20%3D%E2%80%9C%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%E6%96%87%E4%BB%B6_%20%24%7BPN%7D%20-%E6%8F%92%E4%BB%B6%3D%E2%80%9C%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%24%7BOE_QMAKE_PATH_PLUGINS%7D%20%2F*%2F*%20%24%7BSOLIBSDEV%7D%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%2B%20%24%7BOE_QMAKE_PATH_PLUGINS%7D%20%2F*%2F*%2F*%20%24%7BSOLIBSDEV%7D%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%22%3C%2FP%3E%3CP%3EFILES_%24%7BPN%7D-mkspecs%20%3D%20%22%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%7BOE_QMAKE_PATH_ARCHDATA%7D%2Fmkspecs%20%5C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CCODE%20class%3D%22western%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3EDefine%20your%20machine%3A%3C%2FSPAN%3E%3C%2FCODE%3E%20%3CCODE%20class%3D%22western%22%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eexport%20MACHINE%3Dxxx%3C%2FSPAN%3E%3C%2FCODE%3E%20%3CCODE%20class%3D%22western%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E(replace%20with%20your%20board)%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FLI%3E%3CLI%3E%E8%AE%BE%E7%BD%AE%E6%9E%84%E5%BB%BA%E7%8E%AF%E5%A2%83%EF%BC%9A%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Ecd%20..%20%3B%20.setup-environment%20build%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E7%BC%96%E8%BE%91%E6%9C%AC%E5%9C%B0%E5%B1%82%E9%85%8D%E7%BD%AE%EF%BC%88%E2%80%9Cconf%2Fbblayers.conf%E2%80%9D%EF%BC%89%E5%B9%B6%E6%B7%BB%E5%8A%A0%E4%BB%A5%E4%B8%8B%E4%B8%A4%E8%A1%8C%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%24%7BBSPDIR%7D%2Fsources%2Fmeta-openembedded%2Fmeta-ruby%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%24%7BBSPDIR%7D%2Fsources%2Fmeta-qt5%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E7%BC%96%E8%BE%91%20local.conf%20%E5%B9%B6%E6%B7%BB%E5%8A%A0%E4%BB%A5%E4%B8%8B%E8%A1%8C%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EDISTRO_FEATURES_remove%20%3D%20%22x11%20wayland%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%E5%9B%BE%E5%83%8F%E5%AE%89%E8%A3%85%E9%99%84%E5%8A%A0%20%3D%20%22%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Efirmware-imx-vpu-imx6q%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Efirmware-imx-vpu-imx6d%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%22%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%E5%9B%BE%E5%83%8F%E5%AE%89%E8%A3%85%E9%99%84%E5%8A%A0%20%3D%20%22%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Ecpufrequtils%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Enano%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%BB%84-fsl-gstreamer%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%BB%84-fsl-tools-testapps%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%BB%84-fsl-%E5%B7%A5%E5%85%B7-%E5%9F%BA%E5%87%86%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Egstreamer%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Egst-%E6%8F%92%E4%BB%B6-%E5%9F%BA%E7%A1%80%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Egst-%E6%8F%92%E4%BB%B6%E5%BA%93%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Egst-%E6%8F%92%E4%BB%B6-%E5%A5%BD%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Egst-%E6%8F%92%E4%BB%B6-good-rtsp%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Egst-plugins-good-udp%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Egst-%E6%8F%92%E4%BB%B6-good-rtpmanager%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Egst-%E6%8F%92%E4%BB%B6-good-rtp%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Egst-%E6%8F%92%E4%BB%B6-good-video4linux2%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqtbase-fonts%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqtbase-%E6%8F%92%E4%BB%B6%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqtbase%20%E5%B7%A5%E5%85%B7%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqtbase%20%E7%A4%BA%E4%BE%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqt%E5%A3%B0%E6%98%8E%E5%BC%8F%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqtdeclarative-%E6%8F%92%E4%BB%B6%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqtdeclarative%E5%B7%A5%E5%85%B7%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqtdeclarative%20%E7%A4%BA%E4%BE%8B%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqtdeclarative-qml%E6%8F%92%E4%BB%B6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqt%E5%A4%9A%E5%AA%92%E4%BD%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqt%E5%A4%9A%E5%AA%92%E4%BD%93%E6%8F%92%E4%BB%B6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqtmultimedia-%E7%A4%BA%E4%BE%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqtmultimedia-qml%E6%8F%92%E4%BB%B6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqtsvg%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqtsvg-plugins%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqt%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqtimageformats-plugins%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqt%E7%B3%BB%E7%BB%9F%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqtsystems%E5%B7%A5%E5%85%B7%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqtsystems-%E7%A4%BA%E4%BE%8B%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqtsystems-qmlplugins%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqtscript%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqt3d%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqt3d%20%E7%A4%BA%E4%BE%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqt3d-qmlplugins%20%5C%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqt3d%E5%B7%A5%E5%85%B7%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqtwebkit%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqtwebkit-%E7%A4%BA%E4%BE%8B-%E7%A4%BA%E4%BE%8B%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eqtwebkit-qmlplugins%20%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%E7%94%B5%E5%BD%B1%E4%BD%93%E9%AA%8C%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%E2%80%9C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EPACKAGECONFIG_append_pn-qtmultimedia%20%3D%E2%80%9Cgstreamer010%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EQT5_VERSION%20%3D%20%225.2.1%2B5.3.0-beta1%2Bgit%25%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EPREFERRED_VERSION_qtbase-native%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EPREFERRED_VERSION_qtbase%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EPREFERRED_VERSION_qtdeclarative%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EPREFERRED_VERSION_qtjsbackend%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EPREFERRED_VERSION_qtjsbackend-native%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EPREFERRED_VERSION_qtgraphicaleffects%20%3D%E2%80%9C%20%24%7BQT5_VERSION%7D%20%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EPREFERRED_VERSION_qtimageformats%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EPREFERRED_VERSION_qtmultimedia%20%3D%E2%80%9C%20%24%7BQT5_VERSION%7D%20%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EPREFERRED_VERSION_qtquick1%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%E9%A6%96%E9%80%89%E7%89%88%E6%9C%AC_qtquickcontrols%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EPREFERRED_VERSION_qtsensors%20%3D%E2%80%9C%20%24%7BQT5_VERSION%7D%20%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EPREFERRED_VERSION_qtserialport%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EPREFERRED_VERSION_qtscript%20%3D%E2%80%9C%20%24%7BQT5_VERSION%7D%20%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%E9%A6%96%E9%80%89%E7%89%88%E6%9C%AC%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%E9%A6%96%E9%80%89%E7%89%88%E6%9C%AC_qttools-native%20%3D%E2%80%9C%20%24%7BQT5_VERSION%7D%20%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EPREFERRED_VERSION_qtwebkit%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%E9%A6%96%E9%80%89%E7%89%88%E6%9C%AC_qtwebkit-%E7%A4%BA%E4%BE%8B%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3E%E9%A6%96%E9%80%89%E7%89%88%E6%9C%AC_qtxmlpatterns%20%3D%E2%80%9C%20%24%7BQT5_VERSION%7D%20%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%9E%84%E5%BB%BA%E5%9B%BE%E5%83%8F%EF%BC%9A%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Ebitbake%20core-image-minimal%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%A5%E5%9B%BE%E5%83%8F%E5%B0%86%E4%B8%BA%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E6%9E%84%E5%BB%BA%20QT5.3%E3%80%82%E5%A6%82%E6%9E%9C%E8%A6%81%E5%B0%86%E5%85%B6%E4%B8%8E%20X11%20%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%EF%BC%8C%E8%AF%B7%E6%A0%B9%E6%8D%AE%E6%9C%AC%E6%95%99%E7%A8%8B%E8%BF%9B%E8%A1%8C%E8%B0%83%E6%95%B4%EF%BC%9A%3CA%20href%3D%22http%3A%2F%2Fwiki.wandboard.org%2Findex.php%2FIntegrate_Qt5_into_yocto_sato_image_on_Wandboard%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%9C%A8%20Wandboard%20%E4%B8%8A%E5%B0%86%20Qt5%20%E9%9B%86%E6%88%90%E5%88%B0%20yocto%20sato%20%E5%9B%BE%E5%83%8F%E4%B8%AD%20-%20Wandboard%20Wiki%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E9%81%97%E6%BC%8F%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%E5%BD%93%E6%88%91%E8%AE%B0%E8%B5%B7%E8%BF%99%E4%BA%9B%E6%AD%A5%E9%AA%A4%E6%97%B6%EF%BC%8C%E6%88%91%E5%B0%B1%E5%86%99%E4%B8%8B%E4%BA%86%E8%BF%99%E4%BA%9B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%AD%98%E5%82%A8%E5%BA%93%3CA%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5.git%22%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%3B%20color%3A%20%236a737b%3B%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5.git%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Emeta-qt5%2Fmeta-qt5%20%C2%B7%20GitHub%3C%2FA%3E%E4%B8%AD%E7%BC%BA%E5%B0%91%E5%88%86%E6%94%AF%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3Ejansa%2Fqt5-5.3.0-beta1%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E6%88%91%E5%BA%94%E8%AF%A5%E9%80%89%E6%8B%A9%E5%93%AA%E4%B8%AA%E5%88%86%E6%94%AF%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%BE%97%E5%88%B0%E4%BA%86%E5%AE%8C%E5%85%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E9%94%99%E8%AF%AF%EF%BC%8C%E4%BD%86%E6%98%AF%E5%9C%A8%20nativesdk-qtbase.inc%20%E6%88%96%20qtbase.inc%20%E4%B8%AD%E6%89%BE%E4%B8%8D%E5%88%B0%E4%BB%BB%E4%BD%95%E5%B8%A6%E6%9C%89%E2%80%9C-reduce-relocations%E2%80%9D%E7%9A%84%E8%A1%8C%E3%80%82%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E6%96%B9%E6%B3%95%E5%8F%AF%E4%BB%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%20Ramakanth%EF%BC%8C%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E5%92%8C%E4%BD%A0%E5%9C%A8%E5%B8%96%E5%AD%90%E4%B8%AD%E6%8F%90%E5%88%B0%E7%9A%84%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E4%BD%A0%E6%98%AF%E5%90%A6%E5%B7%B2%E7%BB%8F%E6%89%BE%E5%88%B0%E4%BA%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELucas%20Prado%20Rocha%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%E6%88%91%E5%8F%AB%20Lucas%EF%BC%8C%E6%88%91%E6%98%AF%E5%B5%8C%E5%85%A5%E5%BC%8F%E5%BA%94%E7%94%A8%E6%96%B9%E9%9D%A2%E7%9A%84%E6%96%B0%E6%89%8B%EF%BC%8C%E6%88%91%E6%8C%89%E7%85%A7%20wiki%20%E4%B8%8A%E5%85%B3%E4%BA%8E%E5%A6%82%E4%BD%95%E5%88%9B%E5%BB%BA%20yocto%20whit%20qt%20%E4%BB%A5%E5%8F%8A%E5%A6%82%E4%BD%95%E4%B8%BA%E6%88%91%E7%9A%84%20qt%20%E8%8E%B7%E5%8F%96%20sdk%20%E7%9A%84%E6%89%80%E6%9C%89%E4%BF%A1%E6%81%AF%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%EF%BC%8C%E4%BD%86%E6%98%AF%E7%8E%B0%E5%9C%A8%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E7%BC%96%E8%AF%91%E4%B8%80%E4%BA%9B%E5%8A%9F%E8%83%BD%E6%97%B6%EF%BC%8C%E4%BE%8B%E5%A6%82%3C%2FP%3E%3CP%3EQML%20%E4%B8%AD%E7%9A%84%20QtQuick.Controls%201.2%E3%80%81Quick.Controls.Private%201.0%E3%80%81QtQuick.Controls.Styles%201.1%20%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%AF%E8%83%BD%E7%9A%84%E5%8E%9F%E5%9B%A0%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%E4%BB%A5%E5%8F%8A%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELucas%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%20Michael%20Banditt%20%E4%B8%BA%205.3.0%20beta%20%E7%89%88%E7%9A%84%E8%BF%90%E8%A1%8C%E6%89%80%E5%81%9A%E7%9A%84%E5%B7%A5%E4%BD%9C%E3%80%82%EF%BC%88%E6%9B%B4%E4%B8%8D%E7%94%A8%E8%AF%B4%20Otavio%20%E5%92%8C%20Martin%20Jansa%20%E7%BB%B4%E6%8A%A4%20meta-qt5%20%E5%88%86%E6%94%AF%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BC%BC%E4%B9%8E%E5%8A%AB%E6%8C%81%E4%BA%86%E8%BF%99%E4%BA%9B%E8%AF%84%E8%AE%BA%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E5%88%9B%E5%BB%BA%E4%BA%86%E8%87%AA%E5%B7%B1%E7%9A%84%E6%96%87%E6%A1%A3%E3%80%82%E4%BB%BB%E4%BD%95%E6%9C%89%E5%85%B4%E8%B6%A3%E8%AE%A8%E8%AE%BA%205.3.0%20%E7%89%88%E6%9C%AC%E7%9A%84%E4%BA%BA%E9%83%BD%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%BF%99%E9%87%8C%E8%BF%9B%E8%A1%8C%E8%AE%A8%E8%AE%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-101118%22%20target%3D%22_blank%22%3E%E4%BD%BF%E7%94%A8%20fsl-community-bsp%20%E5%92%8C%20meta-qt5%20%E5%9C%A8%20i.MX6%20%E4%B8%8A%E5%8F%91%E5%B8%83%20Qt%205.3.0%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105196%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105196%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E8%BF%98%E6%B2%A1%E6%9C%89%E6%9C%BA%E4%BC%9A%E6%9F%A5%E7%9C%8B%E8%BF%99%E4%BA%9B%E4%BE%8B%E5%AD%90%E3%80%825.3.0%20%E4%B8%AD%E6%9C%80%E5%A4%A7%E7%9A%84%E5%8F%98%E5%8C%96%E6%98%AF%20QML%20%E6%B8%B2%E6%9F%93%E8%A7%86%E9%A2%91%E7%9A%84%E6%96%B9%E5%BC%8F%EF%BC%88%E7%8E%B0%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%A1%AC%E4%BB%B6%E8%A7%A3%E7%A0%81%EF%BC%89%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%94%B1%E4%BA%8E%E8%A7%86%E9%A2%91%E5%9C%A8%20QML%20%E4%B8%AD%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%EF%BC%8C%E5%9B%A0%E6%AD%A4%E7%A4%BA%E4%BE%8B%E6%9E%84%E5%BB%BA%E4%B8%8D%E6%AD%A3%E7%A1%AE%EF%BC%8C%E6%88%96%E8%80%85%E7%A4%BA%E4%BE%8B%E6%92%AD%E6%94%BE%E8%A7%86%E9%A2%91%E7%9A%84%E6%96%B9%E5%BC%8F%E5%B7%B2%E7%BB%8F%E8%BF%87%E6%97%B6%E3%80%82%E6%88%91%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E7%8C%9C%E6%B5%8B%E6%98%AF%E6%9F%A5%E7%9C%8B%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E5%B9%B6%E4%BA%86%E8%A7%A3%E5%AE%83%E4%BB%AC%E6%B8%B2%E6%9F%93%E8%A7%86%E9%A2%91%E7%9A%84%E6%96%B9%E5%BC%8F%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E6%9C%89%E6%9C%BA%E4%BC%9A%E7%9C%8B%E8%BF%99%E4%B8%AA%EF%BC%8C%E6%88%91%E4%BC%9A%E5%86%8D%E6%AC%A1%E5%8F%91%E5%B8%96%EF%BC%8C%E5%B0%BD%E7%AE%A1%E5%8F%AF%E8%83%BD%E4%B8%8D%E6%98%AF%E8%BF%99%E5%91%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9E%84%E5%BB%BA%E6%B2%A1%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E6%98%AF%E8%AF%B8%E5%A6%82multimediawidgets%2Fplayer%E3%80%81multimediawidgets%2Fvideowidget%E7%AD%89%E7%A4%BA%E4%BE%8B%E6%97%A0%E6%B3%95%E6%92%AD%E6%94%BE%E8%A7%86%E9%A2%91%EF%BC%8Cqtwebkit%2Fbrowser%E3%80%81qtwebkit%2Fyoutubeview%20qtwebkit%2Ffanicybrowser%E4%B8%8D%E6%94%AF%E6%8C%81HTML5%E8%A7%86%E9%A2%91%E5%B9%B6%E6%92%AD%E6%94%BE%E5%AE%83%E3%80%82%3C%2FP%3E%3CP%3E5.1.1%E7%89%88%E6%9C%AC%E8%A7%86%E9%A2%91%E6%98%AF%E5%9C%A8%E4%B8%8A%E5%B1%82%E6%92%AD%E6%94%BE%E5%99%A8%E4%B8%AD%E6%92%AD%E6%94%BE%E7%9A%84%EF%BC%8C%E6%B5%8F%E8%A7%88%E5%99%A8%E8%99%BD%E7%84%B6%E6%94%AF%E6%8C%81HTML5%E8%A7%86%E9%A2%91%EF%BC%8C%E4%BD%86%E6%98%AF%E6%97%A0%E6%B3%95%E6%92%AD%E6%94%BE%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%A0%E6%9C%89%E4%BB%80%E4%B9%88%E6%83%B3%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%99%A4%E4%BA%86%E6%B7%BB%E5%8A%A0%20qtquick1%20%E4%B9%8B%E5%A4%96%EF%BC%8C%E4%B8%8B%E9%9D%A2%E7%9A%84%20local.conf%20%E6%98%AF%E5%90%A6%E8%B6%B3%E5%A4%9F%E5%A5%BD%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBB_NUMBER_THREADS%20%3F%3D%20%22%20%24%7B%40oe.utils.cpu_count()%7D%20%22%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EPARALLEL_MAKE%20%3F%3D%20%22-j%20%24%7B%40oe.utils.cpu_count()%7D%22%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EMACHINE%20%3F%3F%3D%20'imx6qsabreauto'%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EDISTRO%20%3F%3D%20'poky'%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EPACKAGE_CLASSES%20%3F%3D%20%22%E8%BD%AF%E4%BB%B6%E5%8C%85_rpm%22%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EEXTRA_IMAGE_FEATURES%20%3D%E2%80%9C%E8%B0%83%E8%AF%95%E8%B0%83%E6%95%B4%E2%80%9D%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EUSER_CLASSES%20%3F%3D%20%E2%80%9Cbuildstats%20image-mklibs%20image-prelink%E2%80%9D%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EPATCHRESOLVE%20%3D%20%22noop%22%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EBB_DISKMON_DIRS%20%3D%20%22%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ESTOPTASKS%2C%24%7BTMPDIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ESTOPTASKS%2C%24%7BDL_DIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ESTOPTASKS%2C%24%7BSSTATE_DIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EABORT%2C%24%7BTMPDIR%7D%2C100M%2C1K%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EABORT%2C%24%7BDL_DIR%7D%2C100M%2C1K%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EABORT%2C%24%7BSSTATE_DIR%7D%2C100M%2C1K%22%20%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EPACKAGECONFIG_pn-qemu-native%20%3D%20%22sdl%22%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EASSUME_PROVIDED%20%2B%3D%20%E2%80%9Clibsdl-native%E2%80%9D%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ECONF_VERSION%20%3D%20%221%22%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EBB_NUMBER_THREADS%20%3D%20'4'%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EPARALLEL_MAKE%20%3D%20'-j%204'%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EDL_DIR%20%3F%3D%20%22%24%7BBSPDIR%7D%2Fdownloads%2F%22%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%8E%A5%E5%8F%97%20FSL_EULA%20%3D%20%22%22%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EDISTRO_FEATURES_remove%20%3D%20%22x11%20wayland%22%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EEXTRA_IMAGE_FEATURES%20%3D%E2%80%9C%E8%B0%83%E8%AF%95%E8%B0%83%E6%95%B4ssh%E6%9C%8D%E5%8A%A1%E5%99%A8openssh%E5%B7%A5%E5%85%B7%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6dbg-pkgs%E5%B7%A5%E5%85%B7%E8%B0%83%E8%AF%95%E2%80%9D%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EPACKAGECONFIG_append_pn-qtbase%3D%22%E5%8F%AF%E8%AE%BF%E9%97%AE%E6%80%A7%20gles2%20openssl%22%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EPACKAGECONFIG_append_pn-qtmultimedia%20%3D%E2%80%9Cgstreamer010%E2%80%9D%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%9B%BE%E5%83%8F%E5%AE%89%E8%A3%85%E9%99%84%E5%8A%A0%20%3D%20%22%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Efirmware-imx-vpu-imx6q%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Efirmware-imx-vpu-imx6d%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%22%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%9B%BE%E5%83%8F%E5%AE%89%E8%A3%85%E9%99%84%E5%8A%A0%20%3D%20%22%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Ecpufrequtils%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Ebinutils%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Enano%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Egdb%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eopenssh-sftp%20%E6%9C%8D%E5%8A%A1%E5%99%A8%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%BB%84-fsl-gstreamer%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%BB%84-fsl-tools-testapps%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%BB%84-fsl-%E5%B7%A5%E5%85%B7-%E5%9F%BA%E5%87%86%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Egstreamer%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6-%E5%9F%BA%E7%A1%80%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6%E5%BA%93%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6-%E5%A5%BD%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6-good-rtsp%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Egst-plugins-good-udp%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6-good-rtpmanager%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6-good-rtp%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6-good-video4linux2%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtbase-fonts%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtbase-%E6%8F%92%E4%BB%B6%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtbase%20%E5%B7%A5%E5%85%B7%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtbase%20%E7%A4%BA%E4%BE%8B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqt%E5%A3%B0%E6%98%8E%E5%BC%8F%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtdeclarative-%E6%8F%92%E4%BB%B6%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtdeclarative%E5%B7%A5%E5%85%B7%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtdeclarative%20%E7%A4%BA%E4%BE%8B%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtdeclarative-qml%E6%8F%92%E4%BB%B6%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqt%E5%A4%9A%E5%AA%92%E4%BD%93%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqt%E5%A4%9A%E5%AA%92%E4%BD%93%E6%8F%92%E4%BB%B6%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtmultimedia-%E7%A4%BA%E4%BE%8B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtmultimedia-qml%E6%8F%92%E4%BB%B6%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtlocation%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtlocation%E6%8F%92%E4%BB%B6%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtlocation-qml%E6%8F%92%E4%BB%B6%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtlocation-%E7%A4%BA%E4%BE%8B%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtsvg%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtsvg-plugins%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtimageformats-plugins%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqt%E7%B3%BB%E7%BB%9F%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtsystems%E5%B7%A5%E5%85%B7%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtsystems-qmlplugins%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtscript%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqt3d%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqt3d%20%E7%A4%BA%E4%BE%8B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqt3d-qmlplugins%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqt3d%E5%B7%A5%E5%85%B7%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtwebkit%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtwebkit-qmlplugins%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqt%E8%BF%9E%E6%8E%A5%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtconnectivity-%E7%A4%BA%E4%BE%8B%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtconnectivity-qml%E6%8F%92%E4%BB%B6%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtserialport%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtquickcontrols%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eqtquickcontrols-qml%E6%8F%92%E4%BB%B6%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%94%B5%E5%BD%B1%E4%BD%93%E9%AA%8C%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eivi%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%BC%80%E7%BD%97%20pango%20fontconfig%20freetypepulseaudio%20dbus%20zlib%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Ealsa-lib%20alsa-tools%20alsa-state%20alsa-utils-alsaconf%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Etslib%20evtest%20tslib-conf%20tslib-%E6%B5%8B%E8%AF%95%20tslib-%E6%A0%A1%E5%87%86%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Egcc%20g%2B%2B%20libgcc%20libgcc-dev%20libstdc%2B%2B%20libstdc%2B%2B-dev%20libstdc%2B%2B-staticdev%20%5C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%22%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EWARN_QA%3D%22%E7%BC%96%E8%AF%91%E4%B8%BB%E6%9C%BA%E8%B7%AF%E5%BE%84%20libdir%22%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105193%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105193%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%B0%86%20qtquick1%20%E6%B7%BB%E5%8A%A0%E5%88%B0%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3EIMAGE_INSTALL_append%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105192%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105192%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%B0%86%20qt5-5.3.0%20%E5%88%86%E6%94%AF%E6%B7%BB%E5%8A%A0%E5%88%B0%20fsl-community-bsp%20daisy%20%E5%88%86%E6%94%AF%E5%90%8E%EF%BC%8C%E5%87%BA%E7%8E%B0%E2%80%9C%E5%9C%A8%E5%9F%BA%E6%9C%AC%20feed%20%E4%B8%AD%E6%9C%AA%E6%89%BE%E5%88%B0%20QtQuickcontrols%E2%80%9D%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%B7%BB%E5%8A%A0%E4%BA%86%20qtquickcontrols%20%E5%92%8C%E4%BB%BB%E4%BD%95%E4%BE%9D%E8%B5%96%E9%A1%B9%EF%BC%8C%E8%AF%B7%E8%AE%A9%E6%88%91%E7%9F%A5%E9%81%93%20local.conf%20%E4%BB%A5%E6%9F%A5%E7%9C%8B%E6%98%AF%E5%90%A6%E7%BC%BA%E5%B0%91%E4%BB%BB%E4%BD%95%E5%86%85%E5%AE%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105191%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105191%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E5%9C%A8%E7%A4%BA%E4%BE%8B%E6%B5%8B%E8%AF%95%E6%B5%8F%E8%A7%88%E5%99%A8%E4%B8%AD%E6%92%AD%E6%94%BE%20html5%20%E8%A7%86%E9%A2%91%E3%80%82%E8%BF%99%E6%98%AF%E5%B7%A5%E4%BD%9C%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%88%91%E6%9E%84%E5%BB%BA%E7%9A%84%20qt%205.1.1%20qml%20%E8%A7%86%E9%A2%91%E6%92%AD%E6%94%BE%E5%99%A8%E4%B8%AD%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%EF%BC%8C%E4%BD%86%20WebKit%20%E6%98%BE%E7%A4%BA%E8%A7%86%E9%A2%91%E6%8E%A7%E4%BB%B6%E5%92%8C%20WebM%20%E8%A7%86%E9%A2%91%E7%9A%84%E7%AC%AC%E4%B8%80%E5%B8%A7%EF%BC%88%E4%BE%8B%E5%A6%82%E6%9D%A5%E8%87%AA%20w4c.org%20%E7%BD%91%E7%AB%99%EF%BC%89%EF%BC%8C%E4%BB%8E%20youtube%20%E6%88%91%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E6%92%AD%E6%94%BE%E5%99%A8%E6%8E%A7%E4%BB%B6%E5%92%8C%E4%B8%8B%E8%BD%BD%E5%9C%88%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%B8%AD%E6%88%91%E7%9C%8B%E5%88%B0%E6%9D%A5%E8%87%AA%20Gstreamer%20%E7%9A%84%E6%B6%88%E6%81%AF%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EQt%20%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%97%A0%E6%B3%95%E6%89%BE%E5%88%B0%E7%B3%BB%E7%BB%9F%20Compose%20%E6%96%87%E4%BB%B6%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82%E8%80%83%E8%99%91%E8%AE%BE%E7%BD%AE%20QTCOMPOSE%20%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%E3%80%82%3C%2FP%3E%3CP%3Elibpng%20%E8%AD%A6%E5%91%8A%EF%BC%9AiCCP%EF%BC%9A%E6%97%A0%E6%B3%95%E8%AF%86%E5%88%AB%E5%B7%B2%E7%BC%96%E8%BE%91%E7%9A%84%E5%B7%B2%E7%9F%A5%20sRGB%20%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%BF%9B%E5%BA%A6%E9%9D%99%E6%AD%A2%E6%97%B6%E6%94%B6%E5%88%B0%E5%AE%8C%E6%88%90%E4%BF%A1%E5%8F%B7%EF%BC%9A10%20Url%EF%BC%9AQUrl(%E2%80%9C%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fqt-project.org%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fqt-project.org%2F%3C%2FA%3E%20%3CSPAN%3E%E2%80%9D)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EAiur%3A%203.0.11%3C%2FP%3E%3CP%3E%E6%A0%B8%E5%BF%83%EF%BC%9AMPEG4PARSER_06.07.04%20%E6%9E%84%E5%BB%BA%E4%BA%8E%202013%20%E5%B9%B4%2012%20%E6%9C%88%205%20%E6%97%A5%2011%3A41%3A38%3C%2FP%3E%3CP%3Emime%EF%BC%9A%E8%A7%86%E9%A2%91%2Fquicktime%EF%BC%9B%E9%9F%B3%E9%A2%91%2Fx-m4a%EF%BC%9B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2Fx-3gp%3C%2FP%3E%3CP%3E%E6%96%87%E4%BB%B6%EF%BC%9A%2Fusr%2Flib%2Fimx-mm%2Fparser%2Flib_mp4_parser_arm11_elinux.so.3.2%3C%2FP%3E%3CP%3E%E5%86%85%E5%AE%B9%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20URI%3A%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fr1---sn-8xb5-px8e.googlevideo.com%2Fvideoplayback%3Fip%3D212.90.165.14%26amp%3Brequire%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fr1---sn-8xb5-px8e.googlevideo.com%2Fvideoplayback%3Fip%3D212.90.165.14%26amp%3Brequire%3C%2FA%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ssl%3Dyes%26amp%3Bmws%3Dyes%26amp%3Bsource%3Dyoutube%26amp%3Bupn%3D4-tA0Ie6tDA%26amp%3Bmv%3Dm%26amp%3Bsparams%3Did%2Cip%2Cipbits%2Citag%2Cra%3C%2FP%3E%3CP%3Etebypass%EF%BC%8Crequiressl%EF%BC%8C%E6%BA%90%EF%BC%8Cupn%EF%BC%8C%E8%BF%87%E6%9C%9F%26amp%3Bkey%3Dyt5%26amp%3Bipbits%3D0%26amp%3Bmt%3D1401803916%26amp%3Bid%3Do-ABczKx%3C%2FP%3E%3CP%3EqqFwtM_XhBgSvGnsGqyiHL18Wy6SqK0BZepcFQ%26amp%3B%E7%AD%BE%E5%90%8D%3D121A2CB3142FB772CD72A9F1D872603%3C%2FP%3E%3CP%3EC749A2B74.0370EDFC498A96A43C8F8A98C10184E14158A0D2%26amp%3Bsver%3D3%26amp%3Bratebypass%3Dyes%26amp%3Bexpire%3D%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201401827798%26amp%3Bms%3Dau%26amp%3Bfexp%3D908548%2C912321%2C913434%2C916611%2C923341%2C926122%2C930008%26amp%3Bitag%3D18%26amp%3Bc%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pn%3DVgAqvxj2iI2hp45w%26amp%3Bptk%3Dyoutube_none%26amp%3Bpltype%3Dcontentugc%26amp%3Bc%3DWEB%26amp%3Bcver%3Dhtml5%3C%2FP%3E%3CP%3E%E5%8F%AF%E6%90%9C%E7%B4%A2%EF%BC%9A%E6%98%AF%3C%2FP%3E%3CP%3E%E5%A4%A7%E5%B0%8F%EF%BC%88%E5%AD%97%E8%8A%82%EF%BC%89%EF%BC%9A32830110%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%94%B5%E5%BD%B1%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%8F%AF%E6%90%9C%E7%B4%A2%EF%BC%9A%E6%98%AF%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Live%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%20No%3C%2FP%3E%3CP%3E%E6%97%B6%E9%95%BF%EF%BC%9A0%3A11%3A52.503360000%3C%2FP%3E%3CP%3E%E8%AF%BB%E5%8F%96%E6%A8%A1%E5%BC%8F%EF%BC%9A%E8%BD%A8%E9%81%93%3C%2FP%3E%3CP%3E%E8%BD%A8%E9%81%93%EF%BC%9A2%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9B%B2%E7%9B%AE%2000%20%5Bvideo_000000%5D%20%E5%B7%B2%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3E%E6%97%B6%E9%95%BF%EF%BC%9A0%3A11%3A52.503360000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Language%3A%20und%3C%2FP%3E%3CP%3E%E5%93%91%E5%89%A7%EF%BC%9A%3C%2FP%3E%3CP%3E%E8%A7%86%E9%A2%91%2Fx-h264%EF%BC%8C%E8%A7%A3%E6%9E%90%3D%EF%BC%88%E5%B8%83%E5%B0%94%E5%80%BC%EF%BC%89true%EF%BC%8C%E5%AE%BD%E5%BA%A6%3D%EF%BC%88int%EF%BC%89640%EF%BC%8C%E9%AB%98%E5%BA%A6%3D%EF%BC%88int%EF%BC%89360%EF%BC%8C%E5%B8%A7%E9%80%9F%E7%8E%87%3D%EF%BC%88%3C%2FP%3E%3CP%3E%E5%88%86%E6%95%B0)24000%2F1001%3C%2FP%3E%3CP%3E%E6%9B%B2%E7%9B%AE%2001%20%5Baudio_000000%5D%20%E5%B7%B2%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3E%E6%97%B6%E9%95%BF%EF%BC%9A0%3A11%3A52.503360000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Language%3A%20und%3C%2FP%3E%3CP%3E%E5%93%91%E5%89%A7%EF%BC%9A%3C%2FP%3E%3CP%3E%E9%9F%B3%E9%A2%91%2Fmpeg%EF%BC%8Cmpegversion%3D(int)4%EF%BC%8C%E9%80%9A%E9%81%93%3D(int)2%EF%BC%8C%E9%80%9F%E7%8E%87%3D(int)44100%EF%BC%8C%E6%AF%94%E7%89%B9%E7%8E%87%3D(int)9%3C%2FP%3E%3CP%3E6000%EF%BC%8Cframed%3D%EF%BC%88%E5%B8%83%E5%B0%94%E5%80%BC%EF%BC%89true%EF%BC%8C%E6%B5%81%E6%A0%BC%E5%BC%8F%3D%EF%BC%88%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%89raw%EF%BC%8Ccodec_data%3D%EF%BC%88%E7%BC%93%E5%86%B2%E5%8C%BA%EF%BC%89121000%3C%2FP%3E%3CP%3E00000000000000000000000000%3C%2FP%3E%3CP%3E%E5%93%94%E5%A3%B0%EF%BC%9A3.0.11%3C%2FP%3E%3CP%3E%E6%A0%B8%E5%BF%83%EF%BC%9AAAC%20%E8%A7%A3%E7%A0%81%E5%99%A8%E5%8C%85%E8%A3%85%E5%99%A8%E6%9E%84%E5%BB%BA%E4%BA%8E%202014%20%E5%B9%B4%201%20%E6%9C%88%2022%20%E6%97%A5%2015%3A42%3A53%3C%2FP%3E%3CP%3Emime%EF%BC%9A%E9%9F%B3%E9%A2%91%2Fmpeg%EF%BC%8Cmpegversion%3D(int)%7B2%2C4%7D%3C%2FP%3E%3CP%3E%E6%96%87%E4%BB%B6%EF%BC%9A%2Fusr%2Flib%2Fimx-mm%2Faudio-codec%2Fwrap%2Flib_aacd_wrap_arm12_elinux.so.3%3C%2FP%3E%3CP%3E%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%EF%BC%9ABLN_MAD-MMCODECS_AACD_ARM_03.07.00_CORTEX-A8%EF%BC%8C%E6%9E%84%E5%BB%BA%E4%BA%8E%202013%20%E5%B9%B4%209%20%E6%9C%88%2018%20%E6%97%A5%2010%3A29%3A53%E3%80%82%3C%2FP%3E%3CP%3E%5B---%26gt%3BFINALIZE%20aiurdemux%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%9C%89%E4%BA%BA%E6%84%9F%E5%85%B4%E8%B6%A3%E7%9A%84%E8%AF%9D%EF%BC%8C%E6%88%91%E8%BF%99%E9%87%8C%E6%9C%89%E4%B8%80%E4%B8%AA%E9%80%82%E7%94%A8%E4%BA%8E%E9%AD%94%E6%9D%96%E6%9D%BF%E7%9A%84%E6%9E%84%E5%BB%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fcetola%2Fmeta-qt5%2F%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fcetola%2Fmeta-qt5%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ecetola%2Fmeta-qt5%20%C2%B7%20GitHub%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E9%9C%80%E8%A6%81%E5%B0%86%20qt5-5.3.0%20%E5%88%86%E6%94%AF%E6%B7%BB%E5%8A%A0%E5%88%B0%20fsl-community-bsp%20daisy%20%E5%88%86%E6%94%AF%E3%80%82%E8%BF%98%E8%A6%81%E5%B0%86%E5%85%B6%E6%B7%BB%E5%8A%A0%E5%88%B0%E6%82%A8%E7%9A%84%20local.conf%20%E4%B8%AD%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20class%3D%22line%22%20style%3D%22padding-left%3A%2010px%3B%22%3E%3CSPAN%20class%3D%22nv%22%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%20color%3A%20teal%3B%22%3E%E5%8F%91%E8%A1%8C%E7%89%88%E5%8A%9F%E8%83%BD%E5%88%A0%E9%99%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22o%22%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%20font-weight%3A%20bold%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22s2%22%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%20color%3A%20%23dd1144%3B%22%3E%E2%80%9Cx11%20%E9%9F%A6%E5%85%B0%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22line%22%20style%3D%22padding-left%3A%2010px%3B%22%3E%3CSPAN%20class%3D%22s2%22%20style%3D%22color%3A%20%23dd1144%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22nv%22%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%20color%3A%20teal%3B%22%3EPACKAGECONFIG_append_pn%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22o%22%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%20font-weight%3A%20bold%3B%22%3E-%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22nv%22%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%20color%3A%20teal%3B%22%3Eqtmultimedia%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22o%22%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%20font-weight%3A%20bold%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22s2%22%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%20color%3A%20%23dd1144%3B%22%3E%E2%80%9C%20gstreamer010%20%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Helvetica%2C%20Arial%2C%20'Droid%20Sans'%2C%20sans-serif%3B%20font-size%3A%2014px%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%20bitbake%20wandboard-image-qt5%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20gplay%20%E6%88%96%20gst-launch%20%E6%B5%8B%E8%AF%95%20HDMI%20%E8%A7%86%E9%A2%91%E6%92%AD%E6%94%BE%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egst-%E5%90%AF%E5%8A%A8%E6%96%87%E4%BB%B6%20rc%20%E4%BD%8D%E7%BD%AE%3Dvideo.m4v%20typefind%3Dtrue%20%5C%3C%2FP%3E%3CP%3E%20!%20aiurdemux%20%5C%3C%2FP%3E%3CP%3E%20!%20vpudec%20%5C%3C%2FP%3E%3CP%3E%20mfw_v4lsink%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%B9%9F%E5%9C%A8%20QML%20%E4%B8%AD%E6%B5%8B%E8%AF%95%E4%BA%86%E8%A7%86%E9%A2%91%EF%BC%8C%E7%A1%AC%E4%BB%B6%E8%A7%86%E9%A2%91%E5%8A%A0%E9%80%9F%E4%BC%BC%E4%B9%8E%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%E3%80%82%E5%94%AF%E4%B8%80%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E6%88%91%E5%BF%85%E9%A1%BB%E8%BF%90%E8%A1%8C%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E6%89%8D%E8%83%BD%E6%AD%A3%E7%A1%AE%E6%98%BE%E7%A4%BA%E8%A7%86%E9%A2%91%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eecho%20-n%2032%20%26gt%3B%20%2Fsys%2Fclass%2Fgraphics%2Ffb0%2Fbits_per_pixel%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E5%8F%AF%E8%83%BD%E5%8F%AA%E6%98%AF%E6%88%91%E9%94%99%E8%BF%87%E7%9A%84%20QML%20%E6%88%96%20Qt%20%E8%AE%BE%E7%BD%AE%E3%80%82%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%EF%BC%8C%E8%A7%86%E9%A2%91%E6%95%88%E6%9E%9C%E5%BE%88%E5%A5%BD%EF%BC%8C%E4%B8%80%E4%BA%9B%E7%AE%80%E5%8D%95%E7%9A%84%E6%96%87%E6%9C%AC%E5%8A%A8%E7%94%BB%E4%B9%9F%E6%98%AF%E5%A6%82%E6%AD%A4%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105189%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105189%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5%2Fblob%2Fjansa%2Fqt5-5.3.0-beta1%2Frecipes-qt%2Fqt5%2Fqtbase%2F0005-qt_module-Fix-pkgconfig-replacement.patch%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5%2Fblob%2Fjansa%2Fqt5-5.3.0-beta1%2Frecipes-qt%2Fqt5%2Fqtbase%2F0005-qt_module-Fix-pkgconfig-replacement.patch%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%A5%E8%A1%A5%E4%B8%81%E9%9C%80%E8%A6%81%E6%9B%B4%E6%96%B0%E8%87%B3%205.3.0%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E7%A0%94%E7%A9%B6%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E6%88%91%E5%AF%B9%20mkspecs%20%E5%92%8C%20qmake%20%E8%BF%98%E4%B8%8D%E7%86%9F%E6%82%89%EF%BC%8C%E6%89%80%E4%BB%A5%E6%AC%A2%E8%BF%8E%E4%BB%BB%E4%BD%95%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%A6%E8%AF%B7%E5%8F%82%E8%A7%81%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.mail-archive.com%2Fopenembedded-devel%40lists.openembedded.org%2Fmsg36039.html%22%20title%3D%22https%3A%2F%2Fwww.mail-archive.com%2Fopenembedded-devel%40lists.openembedded.org%2Fmsg36039.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.mail-archive.com%2Fopenembedded-devel%40lists.openembedded.org%2Fmsg36039.html%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BE%8B%E5%A6%82%E5%9C%A8%20qtxmlpatterns%E3%80%81qtdeclarative%E3%80%81qtwebkit%20%E4%B8%AD%E7%9A%84%20Makefile%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%B6%E4%B8%AD%E7%9A%84%E5%BA%93%E8%B7%AF%E5%BE%84%E7%94%B1%E2%80%9C-L%2Fusr%2Flib%E2%80%9D%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%E5%AF%BB%E6%89%BE%20%E3%80%82-name%E2%80%9CMakefiles*%E2%80%9D-exec%20grep%E2%80%9C-L%20%2Fusr%2Flib%E2%80%9D'%7B%7D'%5C%3B%3C%2FP%3E%3CP%3E%E6%98%BE%E7%A4%BA%E8%BF%99%E4%B8%AA%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%20qt*%205.1.1%20%E5%92%8C%20qt%205.2.1%20%E4%B8%AD%E6%88%91%E6%B2%A1%E6%9C%89%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%E4%BD%86%E5%9C%A8%E7%A4%BA%E4%BE%8B%E4%B8%AD%EF%BC%8C%E6%B5%8F%E8%A7%88%E5%99%A8%E4%B8%8D%E6%98%BE%E7%A4%BA%E4%BB%BB%E4%BD%95%20html5%20%E8%A7%86%E9%A2%91%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9C%A8%20Makefile%20%E4%B8%AD%E7%9A%84%E5%93%AA%E4%B8%AA%E4%BD%8D%E7%BD%AE%E5%B0%86%E5%BA%93%E8%B7%AF%E5%BE%84%E8%AE%BE%E7%BD%AE%E4%B8%BA%20%2Fusr%2Flib%20%E8%80%8C%E4%B8%8D%E6%98%AF%20%5Bsysroot%5D%2Fusr%2Flib%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9E%84%E5%BB%BA%E6%9C%AA%E7%BC%96%E8%AF%91%E3%80%82%E5%9C%A8%20qt*%20%E5%8C%85%E7%9A%84%20Makefile%20%E4%B8%AD%E8%AE%BE%E7%BD%AE%E4%BA%86%E9%94%99%E8%AF%AF%E7%9A%84%E5%BA%93%E8%B7%AF%E5%BE%84%EF%BC%88%2Fusr%2Flib%20%E8%80%8C%E4%B8%8D%E6%98%AF%20%24(sysroot)%2F%2Fusr%2Flib%EF%BC%89%E3%80%82%E5%A6%82%E6%9E%9C%E4%BF%AE%E5%A4%8D%E4%BA%86%EF%BC%8C%E8%BD%AF%E4%BB%B6%E5%8C%85%E5%B0%B1%E4%BC%9A%E6%9E%84%E5%BB%BA%EF%BC%8C%E4%BD%86%E6%9D%BF%E4%B8%8A%E7%9A%84%E7%A4%BA%E4%BE%8B%E7%A8%8B%E5%BA%8F%E4%BC%9A%E5%9B%A0%E6%AE%B5%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%E8%80%8C%E6%8D%9F%E5%9D%8F%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E5%88%9B%E5%BB%BA%E4%BA%86%E5%B7%A5%E4%BD%9C%E7%89%88%E6%9C%AC%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BB%8E%20local.conf%20%E4%B8%AD%E5%88%A0%E9%99%A4%20qtquickcontrols%20%E5%B7%B2%E6%88%90%E5%8A%9F%E5%88%9B%E5%BB%BA%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%9B%A0%E6%AD%A4%20bitbaking%20%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3Emeta-toolchain-qt5%3C%2FSPAN%3E%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E5%8C%85%E5%90%AB%20qt5%20%E7%9A%84%E5%B7%A5%E5%85%B7%E9%93%BE%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E5%B7%A5%E5%85%B7%E9%93%BE%E8%84%9A%E6%9C%AC%E8%AE%BE%E7%BD%AE%E7%8E%AF%E5%A2%83%EF%BC%8C%E5%B0%86%20qmake%20%E8%B7%AF%E5%BE%84%E8%AE%BE%E7%BD%AE%E4%B8%BA%20%2Fopt%2Fpoky%2F1.6%2Bsnapshot%2Fsysroots%2Fi686-pokysdk-linux%2Fusr%2Fbin%2Fqt5%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E4%BD%86%E6%98%AF%20QMAKE_SPEC%20%E9%87%87%E7%94%A8%E4%BA%86%E6%97%A0%E6%95%88%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%8C%E5%8D%B3%20%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fsysroots%2Fi686-linux%2Fusr%2Flib%2Fqt5%2Fmkspecs%2Flinux-oe-g%2B%2B%EF%BC%8C%E8%BF%99%E4%BC%9A%E5%9C%A8%E6%9E%84%E5%BB%BA%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%97%B6%E5%BC%95%E5%8F%91%E9%94%99%E8%AF%AF%20make%3Ac%20command%20not%20found%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E5%A6%82%E4%BD%95%E8%AE%BE%E7%BD%AE%E8%B7%AF%E5%BE%84%E5%92%8C%E6%AD%A3%E7%A1%AE%E7%9A%84%20sysroot%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105184%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105184%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E7%A1%AE%E5%AE%9E%E9%9C%80%E8%A6%81%E5%9C%A8%E6%88%91%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E4%BD%BF%E7%94%A8%20splitview%20qtquickcontrol%20%E7%9A%84%20qtquickcontrols%E3%80%82%E8%BF%99%E4%BC%BC%E4%B9%8E%E6%98%AF%E4%B8%80%E4%B8%AA%E5%B7%B2%E7%9F%A5%E9%97%AE%E9%A2%98%EF%BC%8C%E5%A6%82%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F324000%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fthread%2F324000%3C%2FA%3E%E4%B8%AD%E6%89%80%E8%BF%B0%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%A6%82%E6%88%91%E5%9C%A8%20qtbase.inc%20%E4%B8%AD%E7%9C%8B%E5%88%B0%E7%9A%84%EF%BC%8C%E7%BC%96%E8%AF%91%20qtquickcontrols%20%E9%9C%80%E8%A6%81%E5%8F%AF%E8%AE%BF%E9%97%AE%E6%80%A7%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%A1%AE%E5%AE%9E%E5%9C%A8%20local.conf%20%E4%B8%AD%E6%8F%90%E5%88%B0%E4%BA%86%20PACKAGECONFIG_append_pn-qtbase%20%3D%E2%80%9C%20accessibility%20gles2%20openssl%E2%80%9D%EF%BC%8C%E4%BD%86%E9%97%AE%E9%A2%98%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%E4%BB%8E%20local.conf%20%E4%B8%AD%E5%88%A0%E9%99%A4..%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E7%A8%8D%E5%90%8E%E5%8D%95%E7%8B%AC%E7%BC%96%E8%AF%91%20qtquickcontrols%20%E6%BA%90%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%E7%9A%84%E8%AF%9D%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E6%AD%A5%E9%AA%A4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E9%9C%80%E8%A6%81%20qtquickcontrols%20%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%EF%BC%8C%E4%B8%80%E4%B8%AA%E7%AE%80%E5%8D%95%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E6%98%AF%E5%B0%86%E5%85%B6%E4%BB%8E%20local.conf%20%E4%B8%AD%E5%88%A0%E9%99%A4%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E9%9C%80%E8%A6%81%E5%AE%83%EF%BC%8C%E4%BD%A0%E5%B0%B1%E9%9C%80%E8%A6%81%E8%B0%83%E6%9F%A5%E4%B8%BA%E4%BB%80%E4%B9%88%E5%AE%83%E6%B2%A1%E6%9C%89%E8%A2%AB%E5%BB%BA%E9%80%A0%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E8%BF%9B%E8%A1%8C%20bitbaking%EF%BC%8C%E4%BD%86%E6%9C%80%E5%90%8E%E6%8A%9B%E5%87%BA%E4%BA%86%E4%BB%A5%E4%B8%8B%20qtquickcontrols%20%E9%94%99%E8%AF%AF%E3%80%82%E8%87%B3%E5%B0%91%E5%9C%A8%E4%B9%8B%E5%89%8D%E7%9A%84%E9%85%8D%E6%96%B9%E4%B8%AD%EF%BC%8C%E6%B2%A1%E6%9C%89%E5%87%BA%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E5%9C%A8%E5%9F%BA%E6%9C%AC%20feed%20%E4%B8%AD%E6%9C%AA%E6%89%BE%E5%88%B0%20qtquickcontrols%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E5%87%BD%E6%95%B0%E5%A4%B1%E8%B4%A5%EF%BC%9Ado_rootfs%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%95%85%E9%9A%9C%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E5%AD%98%E5%82%A8%E5%9C%A8%EF%BC%9A%2Fhome%2Fkishore%2FYocto_Qt%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fimx6qsabreauto-poky-linux-gnueabi%2Fcore-image-minimal%2F1.0-r0%2Ftemp%2Flog.do_rootfs.28549%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%BB%BB%E5%8A%A1%207%EF%BC%88%2Fhome%2Fkishore%2FYocto_Qt%2Ffsl-community-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-core%2Fimages%2Fcore-image-minimal.bb%EF%BC%8Cdo_rootfs)%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%E2%80%9C1%E2%80%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105181%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105181%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E9%9C%80%E8%A6%81%E4%B8%BA%E6%82%A8%E7%9A%84%E5%BA%94%E7%94%A8%E6%B7%BB%E5%8A%A0%E4%B8%80%E4%B8%AA%E9%85%8D%E6%96%B9%E3%80%82%E7%9C%8B%E4%B8%80%E4%B8%8B%E7%94%B5%E5%BD%B1%E4%BD%93%E9%AA%8C%E9%85%8D%E6%96%B9%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%A4%8D%E5%88%B6%E5%AE%83%E3%80%81%E9%87%8D%E5%91%BD%E5%90%8D%E5%AE%83%E5%B9%B6%E9%80%82%E5%BA%94%E6%82%A8%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E6%83%B3%E7%9B%B4%E6%8E%A5%E5%9C%A8%20Yocto%20%E4%B8%AD%E6%9E%84%E5%BB%BA%E6%88%91%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E5%B0%86%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%BA%90%E4%BF%9D%E5%AD%98%E5%9C%A8%E5%93%AA%E9%87%8C%EF%BC%9F%3C%2FP%3E%3CP%3E%20%E6%88%91%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%9C%A8%20local.conf%20%E4%B8%AD%E6%8F%90%E5%8F%8A%EF%BC%8C%E5%9B%A0%E4%B8%BA%E9%80%9A%E8%BF%87%E5%B7%A5%E5%85%B7%E9%93%BE%E6%9E%84%E5%BB%BA%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%8F%AA%E6%98%AF%E6%83%B3%E8%AF%B4%E5%A3%B0%E8%B0%A2%E8%B0%A2%E3%80%82%E8%BF%99%E4%BA%9B%E5%B8%96%E5%AD%90%E5%AF%B9%E4%BA%8E%E5%9C%A8%20Wandboard%20%E4%B8%8A%E8%BF%90%E8%A1%8C%205.3%20%E9%9D%9E%E5%B8%B8%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%B5%8B%E8%AF%95%E4%BA%86%E5%B8%A6%E6%9C%89%E6%97%8B%E8%BD%AC%E6%96%87%E6%9C%AC%E7%9A%84%20QML%20%E8%A7%86%E9%A2%91%EF%BC%8CCPU%20%E4%BD%BF%E7%94%A8%E7%8E%87%E4%BB%8E%20Qt%205.2.1%20%E4%B8%AD%E7%9A%84%2090%25%20%E4%B8%8B%E9%99%8D%E5%88%B0%20Qt%205.3%20beta%20%E4%B8%AD%E7%9A%84%2035%25%E3%80%82%E6%98%BE%E7%84%B6%EF%BC%8CVPU%20%E7%8E%B0%E5%9C%A8%E4%B8%8E%20GPU%20%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B9%B2%E6%9D%AF!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105178%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105178%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%BD%93%E6%88%91%E8%BF%90%E8%A1%8C%20bitbake%20core-image-minimal%20%E6%97%B6%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8Cbitbake%20meta-toolchain-qt5%20%E6%88%90%E5%8A%9F%E5%B9%B6%E7%94%9F%E6%88%90%E4%BA%86%20qmake%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E5%8F%AF%E8%83%BD%E4%B8%8E%E9%80%89%E6%8B%A9%E6%9C%80%E6%96%B0%E7%9A%84%20git%20%E7%89%88%E6%9C%AC%E6%9C%89%E5%85%B3%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF..%E5%9C%A8%E5%9F%BA%E6%9C%AC%E4%BE%9B%E7%A8%BF%E4%B8%AD%E6%9C%AA%E6%89%BE%E5%88%B0%20qtquickcontrols%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%9C%89%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%BB%8E%20local.conf%20%E5%92%8C%20packagegroup-qt5-toolchain-target%20%E4%B8%AD%E5%88%A0%E9%99%A4%E4%BA%86%20qtquickcontrols-qmlplugins%20%E4%BB%A5%E6%91%86%E8%84%B1%E4%B8%8A%E8%BF%B0%E9%94%99%E8%AF%AF%E3%80%82%E5%AE%83%E4%BA%A7%E7%94%9F%E4%BA%86%20%3C%2FP%3E%3CP%3Epoky-eglibc-i686-meta-toolchain-qt5-cortexa9hf-vfp-neon-toolchain-1.6%2Bsnapshot.sh%20%E5%9C%A8%20%2Ftmp%2Fdeploy%2Fsdk%20%E4%B8%AD%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E4%BB%AC%E8%BF%90%E8%A1%8C%E8%84%9A%E6%9C%AC%EF%BC%8C%E8%AF%B7%E8%AE%A9%E6%88%91%E7%9F%A5%E9%81%93%20qmake%20%E7%A9%B6%E7%AB%9F%E4%BC%9A%E5%9C%A8%E5%93%AA%E9%87%8C%E7%94%9F%E6%88%90%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%88%91%E6%83%B3%E8%A6%81%E6%9E%84%E5%BB%BA%E6%88%91%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105176%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105176%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%8D%B3%E4%BD%BF%E5%B0%86%20qtquickcontrols-qmlplugins%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20local.conf%20%E5%90%8E%E4%BB%8D%E7%84%B6%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E3%80%82%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E5%AE%89%E8%A3%85%E8%BD%AF%E4%BB%B6%E5%8C%85%E3%80%82%E5%91%BD%E4%BB%A4'%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fsysroots%2Fi686-linux%2Fusr%2Fbin%2Fsmart%20--data-dir%3D%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-poky-linux-gnueabi%2Fmeta-toolchain-qt5%2F1.0-r0%2Fsdk%2Fimage%2Fopt%2Fpoky%2F1.6%2Bsnapshot%2Fsysroots%2Fcortexa9hf-vfp-neon-poky-linux-gnueabi%2Fvar%2Flib%2Fsmart%E5%AE%89%E8%A3%85-y%20packagegroup-core-standalone-sdk-target-dbg%40all%20packagegroup-core-standalone-sdk-target%40all%20packagegroup-qt5-toolchain-target%40all'%E8%BF%94%E5%9B%9E1%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%E7%BC%93%E5%AD%98%E2%80%A6%E2%80%A6%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E6%9B%B4%E6%96%B0%E7%BC%93%E5%AD%98%E2%80%A6%E2%80%A6%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B100%25%5D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AE%A1%E7%AE%97%E4%BA%A4%E6%98%93...%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E5%AE%89%E8%A3%85%20packagegroup-qt5-toolchain-target-1.0-r0%40all%EF%BC%9A%E6%B2%A1%E6%9C%89%E8%BD%AF%E4%BB%B6%E5%8C%85%E6%8F%90%E4%BE%9B%20qtquickcontrols-qmlplugins%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E5%87%BD%E6%95%B0%E5%A4%B1%E8%B4%A5%EF%BC%9Ado_populate_sdk%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%95%85%E9%9A%9C%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E5%AD%98%E5%82%A8%E5%9C%A8%EF%BC%9A%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-poky-linux-gnueabi%2Fmeta-toolchain-qt5%2F1.0-r0%2Ftemp%2Flog.do_populate_sdk.5288%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%BB%BB%E5%8A%A1%207%EF%BC%88%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fmeta%2Fmeta-toolchain-qt5.bb%EF%BC%8Cdo_populate_sdk)%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%E2%80%9C1%E2%80%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105175%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105175%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%B8%8D%E4%BD%BF%E7%94%A8%E5%B7%A5%E5%85%B7%E9%93%BE%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E7%9B%B4%E6%8E%A5%E5%9C%A8%20yocto%20%E4%B8%AD%E6%9E%84%E5%BB%BA%E6%88%91%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E5%A6%82%E6%9E%9C%E5%87%BA%E7%8E%B0%E6%AD%A4%E9%94%99%E8%AF%AF%EF%BC%8C%E8%AF%B7%E4%BB%8E%E4%BB%A5%E4%B8%8B%E6%96%87%E4%BB%B6%E4%B8%AD%E5%88%A0%E9%99%A4%E5%8C%85%E5%90%AB%E2%80%9C-reduce-relocations%E2%80%9D%E7%9A%84%E8%A1%8C%EF%BC%9A%3C%2FP%3E%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%E9%A3%9F%E8%B0%B1-qt%2Fqt5%2Fnativesdk-qtbase.inc%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E9%A3%9F%E8%B0%B1-qt%2Fqt5%2Fqtbase.inc%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105174%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105174%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%BD%93%E6%88%91%E6%89%A7%E8%A1%8C%20bitbake%20meta-toolchain-qt5%20%E6%97%B6%E6%8A%9B%E5%87%BA%E4%BA%86%E4%B8%8A%E8%BF%B0%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105173%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105173%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E6%9D%A5%E8%87%AA%20git%20%E7%9A%84%20meta-qt5%20%E5%88%86%E6%94%AF%E3%80%82%3C%2FP%3E%3CP%3E%E5%B0%BD%E7%AE%A1%E6%88%91%E4%BD%BF%E7%94%A8%E4%BF%AE%E8%AE%A2%E7%89%88%2092be18a3a14deed9d38b8fc6e89f09ba4d730597%20%E6%A3%80%E6%9F%A5%E4%BA%86%20wout%EF%BC%8C%E4%BD%86%E5%AE%83%E5%9C%A8%E6%88%91%E7%9A%84%E6%9E%84%E5%BB%BA%E7%B3%BB%E7%BB%9F%E4%B8%8A%E5%87%BA%E7%8E%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%95%85%E9%9A%9C%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E5%AD%98%E5%82%A8%E5%9C%A8%EF%BC%9A%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-mx6-poky-linux-gnueabi%2Fqtbase%2F5.2.1%2B5.3.0-beta1%2BgitAUTOINC%2B207598fd8e-r0%2Ftemp%2Flog.do_configure.29906%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%97%A5%E5%BF%97%E6%95%B0%E6%8D%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%E8%B0%83%E8%AF%95%EF%BC%9A%E6%89%A7%E8%A1%8C%20python%20%E5%87%BD%E6%95%B0%20sysroot_cleansstate%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%E8%B0%83%E8%AF%95%EF%BC%9APython%20%E5%87%BD%E6%95%B0%20sysroot_cleansstate%20%E5%B7%B2%E5%AE%8C%E6%88%90%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%E8%B0%83%E8%AF%95%EF%BC%9A%E6%89%A7%E8%A1%8C%20shell%20%E5%87%BD%E6%95%B0%20qmake5_base_preconfigure%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%E8%B0%83%E8%AF%95%EF%BC%9AShell%20%E5%87%BD%E6%95%B0%20qmake5_base_preconfigure%20%E5%AE%8C%E6%88%90%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%E8%B0%83%E8%AF%95%EF%BC%9A%E6%AD%A3%E5%9C%A8%E6%89%A7%E8%A1%8C%20shell%20%E5%87%BD%E6%95%B0%20do_configure%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%E8%BF%99%E6%98%AF%20Qt%20%E5%BC%80%E6%BA%90%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%E6%82%A8%E6%9C%89%E6%9D%83%E6%A0%B9%E6%8D%AE%E4%BB%A5%E4%B8%8B%E6%9D%A1%E6%AC%BE%E4%BD%BF%E7%94%A8%E8%AF%A5%E8%BD%AF%E4%BB%B6%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%E8%BE%83%E5%AE%BD%E6%9D%BE%E7%9A%84%20GNU%20%E9%80%9A%E7%94%A8%E5%85%AC%E5%85%B1%E8%AE%B8%E5%8F%AF%E8%AF%81%20(LGPL)%20%E7%89%88%E6%9C%AC%202.1%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%E6%82%A8%E8%BF%98%E8%A2%AB%E6%8E%88%E6%9D%83%E6%A0%B9%E6%8D%AE%E4%BB%A5%E4%B8%8B%E6%9D%A1%E6%AC%BE%E4%BD%BF%E7%94%A8%E8%AF%A5%E8%BD%AF%E4%BB%B6%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20GNU%20%E9%80%9A%E7%94%A8%E5%85%AC%E5%85%B1%E8%AE%B8%E5%8F%AF%E8%AF%81%20(GPL)%20%E7%89%88%E6%9C%AC%203%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%E6%82%A8%E5%B7%B2%E7%BB%8F%E6%8E%A5%E5%8F%97%E4%BA%86%E5%BC%80%E6%94%BE%E6%BA%90%E4%BB%A3%E7%A0%81%E8%AE%B8%E5%8F%AF%E7%9A%84%E6%9D%A1%E6%AC%BE%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%E6%89%A7%E8%A1%8C%E9%98%B4%E5%BD%B1%E6%9E%84%E5%BB%BA...%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%E5%87%86%E5%A4%87%E6%9E%84%E5%BB%BA%E6%A0%91...%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20arm-poky-linux-gnueabi-g%2B%2B%20-march%3Darmv7-a%20-mthumb-interwork%20-mfloat-abi%3Dhard%20-mfpu%3Dneon%20-mtune%3Dcortex-a9%20--sysroot%3D%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabreauto%20-c%20-fvisibility%3Dhidden%20fvisibility.c%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%E5%B7%B2%E5%90%AF%E7%94%A8%E7%AC%A6%E5%8F%B7%E5%8F%AF%E8%A7%81%E6%80%A7%E6%8E%A7%E5%88%B6%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20arm-poky-linux-gnueabi-g%2B%2B%20-march%3Darmv7-a%20-mthumb-interwork%20-mfloat-abi%3Dhard%20-mfpu%3Dneon%20-mtune%3Dcortex-a9%20--sysroot%3D%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fsysroots%2Fimx6qsabreauto%20-o%20libtest.so%20-shared%20-Wl%2C-Bsymbolic-functions%20-fPIC%20bsymbolic_functions.c%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20bsymbolic_functions.c%3A2%3A2%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%23error%20%E2%80%9C%E6%AD%A4%E6%9E%B6%E6%9E%84%E4%B8%8A%E7%9A%84%E7%AC%A6%E5%8F%B7%E5%87%BD%E6%95%B0%E7%BB%91%E5%AE%9A%E5%8F%AF%E8%83%BD%E5%B7%B2%E6%8D%9F%E5%9D%8F%EF%BC%8C%E8%AF%B7%E5%B0%86%E5%85%B6%E7%A6%81%E7%94%A8%EF%BC%88%E8%AF%B7%E5%8F%82%E9%98%85%20QTBUG-36129%EF%BC%89%E3%80%82%E2%80%9D%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%23error%E2%80%9C%E6%AD%A4%E6%9E%B6%E6%9E%84%E4%B8%8A%E7%9A%84%E7%AC%A6%E5%8F%B7%E5%87%BD%E6%95%B0%E7%BB%91%E5%AE%9A%E5%8F%AF%E8%83%BD%E5%B7%B2%E6%8D%9F%E5%9D%8F%EF%BC%8C%E8%AF%B7%E7%A6%81%E7%94%A8%E5%AE%83%EF%BC%88%E8%AF%B7%E5%8F%82%E9%98%85%20QTBUG-36129%EF%BC%89%E3%80%82%E2%80%9D%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%5E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%E7%AC%A6%E5%8F%B7%E5%87%BD%E6%95%B0%E7%BB%91%E5%AE%9A%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%E5%B7%B2%E8%AF%B7%E6%B1%82%20-reduce-relocations%EF%BC%8C%E4%BD%86%E6%AD%A4%E7%BC%96%E8%AF%91%E5%99%A8%E4%B8%8D%E6%94%AF%E6%8C%81%E5%AE%83%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%E4%BD%BF%E7%94%A8%20-v%20%E9%87%8D%E6%96%B0%E8%BF%90%E8%A1%8C%20configure%20%E4%BB%A5%E8%8E%B7%E5%8F%96%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%E8%AD%A6%E5%91%8A%EF%BC%9A%E4%BB%8E%20shell%20%E5%91%BD%E4%BB%A4%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%201%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%7C%20%E9%94%99%E8%AF%AF%EF%BC%9A%E5%8A%9F%E8%83%BD%E5%A4%B1%E8%B4%A5%EF%BC%9Ado_configure%EF%BC%88%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E4%BD%8D%E4%BA%8E%20%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-mx6-poky-linux-gnueabi%2Fqtbase%2F5.2.1%2B5.3.0-beta1%2BgitAUTOINC%2B207598fd8e-r0%2Ftemp%2Flog.do_configure.29906%EF%BC%89%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%BB%BB%E5%8A%A1%20680%EF%BC%88%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fqtbase_git.bb%EF%BC%8Cdo_configure)%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%E2%80%9C1%E2%80%9D%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E4%BB%BB%E5%8A%A1%E6%91%98%E8%A6%81%EF%BC%9A%E5%B0%9D%E8%AF%95%E4%BA%86%201089%20%E9%A1%B9%E4%BB%BB%E5%8A%A1%EF%BC%8C%E5%85%B6%E4%B8%AD%2031%20%E9%A1%B9%E6%97%A0%E9%9C%80%E9%87%8D%E6%96%B0%E8%BF%90%E8%A1%8C%EF%BC%8C1%20%E9%A1%B9%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%AD%89%E5%BE%85%200%20%E4%B8%AA%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E7%9A%84%E4%BB%BB%E5%8A%A1%E5%AE%8C%E6%88%90%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%B1%87%E6%80%BB%EF%BC%9A1%20%E4%B8%AA%E4%BB%BB%E5%8A%A1%E5%A4%B1%E8%B4%A5%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fqtbase_git.bb%EF%BC%8Cdo_configure%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%91%98%E8%A6%81%EF%BC%9A%E6%98%BE%E7%A4%BA%E4%BA%86%203%20%E6%9D%A1%E8%AD%A6%E5%91%8A%E6%B6%88%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%91%98%E8%A6%81%EF%BC%9A%E6%98%BE%E7%A4%BA%E4%BA%86%201%20%E6%9D%A1%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%EF%BC%8C%E8%BF%94%E5%9B%9E%E9%9D%9E%E9%9B%B6%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%9C%89%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20lang%3D%22EN%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105172%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105172%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%8D%B3%E4%BD%BF%E5%9C%A8%E5%B0%86%E2%80%9Cqtquickcontrols-qmlplugins%20%5C%E2%80%9D%E6%B7%BB%E5%8A%A0%E5%88%B0%20local.conf%20%E5%90%8E%EF%BC%8C%E6%88%91%E4%BB%8D%E7%84%B6%E6%94%B6%E5%88%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E5%AE%89%E8%A3%85%E8%BD%AF%E4%BB%B6%E5%8C%85%E3%80%82%E5%91%BD%E4%BB%A4'%2Fhome%2Fkishore%2Fmeta-qt-toolchain%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fsysroots%2Fi686-linux%2Fusr%2Fbin%2Fsmart%20--data-dir%3D%2Fhome%2Fkishore%2Fmeta-qt-toolchain%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-poky-linux-gnueabi%2Fmeta-toolchain-qt5%2F1.0-r0%2Fsdk%2Fimage%2Fopt%2Fpoky%2F1.6%2Bsnapshot%2Fsysroots%2Fcortexa9hf-vfp-neon-poky-linux-gnueabi%2Fvar%2Flib%2Fsmart%E5%AE%89%E8%A3%85-y%20packagegroup-core-standalone-sdk-target-dbg%40all%20packagegroup-core-standalone-sdk-target%40all%20packagegroup-qt5-toolchain-target%40all'%E8%BF%94%E5%9B%9E1%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%E7%BC%93%E5%AD%98%E2%80%A6%E2%80%A6%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E6%9B%B4%E6%96%B0%E7%BC%93%E5%AD%98%E2%80%A6%E2%80%A6%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%5B100%25%5D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AE%A1%E7%AE%97%E4%BA%A4%E6%98%93...%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E5%AE%89%E8%A3%85%20packagegroup-qt5-toolchain-target-1.0-r0%40all%EF%BC%9A%E6%B2%A1%E6%9C%89%E8%BD%AF%E4%BB%B6%E5%8C%85%E6%8F%90%E4%BE%9B%20qtquickcontrols-qmlplugins%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E5%87%BD%E6%95%B0%E5%A4%B1%E8%B4%A5%EF%BC%9Ado_populate_sdk%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%95%85%E9%9A%9C%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E5%AD%98%E5%82%A8%E5%9C%A8%EF%BC%9A%2Fhome%2Fkishore%2Fmeta-qt-toolchain%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-poky-linux-gnueabi%2Fmeta-toolchain-qt5%2F1.0-r0%2Ftemp%2Flog.do_populate_sdk.6534%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%BB%BB%E5%8A%A1%207%EF%BC%88%2Fhome%2Fkishore%2Fmeta-qt-toolchain%2Ffsl-community-bsp%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fmeta%2Fmeta-toolchain-qt5.bb%EF%BC%8Cdo_populate_sdk)%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%E2%80%9C1%E2%80%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E8%AF%BB%E4%BA%86%E6%88%91%E4%B8%8A%E9%9D%A2%E7%9A%84%E8%AF%84%E8%AE%BA%EF%BC%8C%E4%BD%A0%E4%BC%9A%E5%8F%91%E7%8E%B0%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E7%83%98%E7%84%99%E7%9A%84%E5%9B%BE%E5%83%8F%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%E3%80%82%E5%94%AF%E4%B8%80%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%20Qt5CinenmaticExperince%20%E6%97%A0%E6%B3%95%E8%BF%90%E8%A1%8C%EF%BC%8C%E5%9B%A0%E4%B8%BA%205.3%20%E5%9C%A8%20Switch.qml%20%E4%B8%AD%E7%9A%84%E5%B1%9E%E6%80%A7%E5%90%8D%E7%A7%B0%20onText%20%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%E3%80%82%E7%8E%B0%E5%9C%A8%E4%BC%BC%E4%B9%8E%20onXXX%20%E5%B7%B2%E4%BF%9D%E7%95%99%E7%94%A8%E4%BA%8E%E4%BF%A1%E5%8F%B7%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%90%8D%E7%A7%B0%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%9C%A8%E6%89%80%E6%9C%89%E4%BD%BF%E7%94%A8%E7%9A%84%E5%9C%B0%E6%96%B9%E5%B0%86%E5%85%B6%E6%9B%B4%E6%94%B9%E4%B8%BA%20_onText%EF%BC%8C%E4%BD%BF%E6%BC%94%E7%A4%BA%E5%86%8D%E6%AC%A1%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%88%9B%E5%BB%BA%E5%B7%A5%E5%85%B7%E9%93%BE%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3Ebitbake%20meta-toolchain-qt5%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E9%9C%80%E8%A6%81%E5%9C%A8%20local.conf%20%E4%B8%AD%E8%BE%93%E5%85%A5%E6%9B%B4%E5%A4%9A%E6%9D%A1%E7%9B%AE%E5%B9%B6%E8%BF%9B%E8%A1%8C%E4%B8%80%E4%BA%9B%E9%A2%9D%E5%A4%96%E7%9A%84%E8%AE%B8%E5%8F%AF%E8%AF%81%E5%93%88%E5%B8%8C%E5%A4%8D%E5%88%B6%E7%B2%98%E8%B4%B4%E6%93%8D%E4%BD%9C%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%B7%A5%E5%85%B7%E9%93%BE%E5%8C%85%E5%90%AB%E7%9A%84%20qt%20%E5%8C%85%E6%AF%94%E5%9B%BE%E5%83%8F%E5%A4%9A%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%9B%A0%E6%AD%A4%20bitbaking%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3Emeta-toolchain-qt5%3C%2FSPAN%3E%E4%B8%BA%E6%82%A8%E6%8F%90%E4%BE%9B%E4%BA%86%E5%8C%85%E5%90%AB%20qt5%20%E7%9A%84%E5%B7%A5%E5%85%B7%E9%93%BE%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E8%A6%81%E6%9E%84%E5%BB%BA%E6%82%A8%E8%87%AA%E5%B7%B1%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%8F%AA%E9%9C%80%E4%BD%BF%E7%94%A8%E5%B7%A5%E5%85%B7%E9%93%BE%E7%9A%84%E8%84%9A%E6%9C%AC%E8%AE%BE%E7%BD%AE%E7%8E%AF%E5%A2%83%E5%B9%B6%E6%89%A7%E8%A1%8C%20qmake%20%E5%92%8C%20make%20%E5%8D%B3%E5%8F%AF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%231f497d%3B%20font-size%3A%2011pt%3B%22%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%8C%89%E7%85%A7%E8%BF%99%E4%BA%9B%E6%AD%A5%E9%AA%A4%E8%BF%9B%E8%A1%8C%E4%BD%8D%E7%83%98%E7%84%99%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%E3%80%82%20%3C%2FSPAN%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%231f497d%3B%20font-size%3A%2011pt%3B%22%3E%E8%AF%B7%E8%AE%A9%E6%88%91%E7%9F%A5%E9%81%93%E6%9E%84%E5%BB%BA%E5%92%8C%E6%B5%8B%E8%AF%95%E7%A4%BA%E4%BE%8B%20Qt%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%BD%9C%E4%B8%BA%E9%BB%98%E8%AE%A4%20Qt5_CinematicExperience%20%E7%9A%84%E6%AD%A5%E9%AA%A4%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%231f497d%3B%20font-size%3A%2011pt%3B%22%3E%E8%BF%90%E8%A1%8C%E4%B8%8D%E6%AD%A3%E5%B8%B8%EF%BC%8C%E8%BE%93%E5%87%BA%E7%99%BD%E5%B1%8F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105169%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105169%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E8%BF%99%E5%BA%94%E8%AF%A5%E6%98%AF%E6%AD%A5%E9%AA%A4%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%97%A0%E6%B3%95%E5%AF%B9%20QtLocation%20%E8%BF%9B%E8%A1%8C%E8%AF%84%E8%AE%BA%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%E5%AE%83%E3%80%82%E6%88%91%E5%8F%AA%E4%BD%BF%E7%94%A8%20Qtbase%20%E5%92%8C%20QtMultimedia%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%90%A6%E5%88%99%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%20Gunnar%20%E5%8F%91%E5%B8%83%E7%9A%84%E6%AD%A5%E9%AA%A4%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9B%A0%E6%AD%A4%E5%9C%A8%E6%AD%A5%E9%AA%A4%20git%20clone%20-b%20jansa%2Fqt5-5.3.0-beta1%20%E4%B9%8B%E5%90%8E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5.git%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5.git%3C%2FA%3E%20%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E5%B0%9D%E8%AF%95%20git%20checkout%2092be18a3a14deed9d38b8fc6e89f09ba4d730597%20%E5%B9%B6%E6%8C%89%E7%85%A7%E6%8F%8F%E8%BF%B0%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AE%83%E5%9C%A8%20Qtlocation%20%E4%B8%AD%E4%B8%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%20qtlocation%20%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E4%B8%8D%E8%83%BD%E8%AF%B4%E3%80%82%E6%88%91%E4%BB%8D%E5%9C%A8%E4%BD%BF%E7%94%A8%2092be18a3a14deed9d38b8fc6e89f09ba4d730597%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E4%B8%8E%E5%8E%9F%E5%A7%8B%E9%85%8D%E6%96%B9%E5%AE%8C%E7%BE%8E%E5%85%BC%E5%AE%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%BF%E7%94%A8%20git%20%E4%B8%AD%E7%9A%84%E6%9C%80%E6%96%B0%20qt5%20%E4%BF%AE%E8%AE%A2%E7%89%88%E5%8F%91%E5%B8%83%E7%9A%84%E6%AD%A5%E9%AA%A4%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E5%8F%98%E5%8C%96%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%91%E7%8E%B0%E5%B0%86%20WARN_QA%3D%22compile-host-path%20libdir%22%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20local.conf%20%E5%8F%AF%E4%BB%A5%E6%8A%91%E5%88%B6%20QA%20%E9%94%99%E8%AF%AF%E3%80%82%E4%BD%86%E5%8F%AA%E6%9C%89%E5%9C%A8%E5%81%9A%E4%BA%86%E4%B9%8B%E5%90%8E%20%3C%2FP%3E%3CP%3Ebitbake%3CPACKAGE%3E%20-f%20-c%20%E7%BC%96%E8%AF%91%3C%2FPACKAGE%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%83%98%E7%84%99%E7%9A%84%E5%9B%BE%E5%83%8F%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%E3%80%82%E5%94%AF%E4%B8%80%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%20Qt5CinenmaticExperince%20%E6%97%A0%E6%B3%95%E8%BF%90%E8%A1%8C%EF%BC%8C%E5%9B%A0%E4%B8%BA%205.3%20%E5%9C%A8%20Switch.qml%20%E4%B8%AD%E7%9A%84%E5%B1%9E%E6%80%A7%E5%90%8D%E7%A7%B0%20onText%20%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%E3%80%82%E7%8E%B0%E5%9C%A8%E4%BC%BC%E4%B9%8E%20onXXX%20%E5%B7%B2%E4%BF%9D%E7%95%99%E7%94%A8%E4%BA%8E%E4%BF%A1%E5%8F%B7%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E5%90%8D%E7%A7%B0%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%89%80%E6%9C%89%E4%BD%BF%E7%94%A8%E7%9A%84%E5%9C%B0%E6%96%B9%E5%B0%86%E5%85%B6%E6%9B%B4%E6%94%B9%E4%B8%BA%20_onText%EF%BC%8C%E4%BD%BF%E6%BC%94%E7%A4%BA%E5%86%8D%E6%AC%A1%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%88%9B%E5%BB%BA%E5%B7%A5%E5%85%B7%E9%93%BE%3C%2FP%3E%3CP%3Ebitbake%20meta-toolchain-qt5%3C%2FP%3E%3CP%3E%E9%9C%80%E8%A6%81%E5%9C%A8%20local.conf%20%E4%B8%AD%E8%BE%93%E5%85%A5%E6%9B%B4%E5%A4%9A%E6%9D%A1%E7%9B%AE%E5%B9%B6%E8%BF%9B%E8%A1%8C%E4%B8%80%E4%BA%9B%E9%A2%9D%E5%A4%96%E7%9A%84%E8%AE%B8%E5%8F%AF%E8%AF%81%E5%93%88%E5%B8%8C%E5%A4%8D%E5%88%B6%E7%B2%98%E8%B4%B4%E6%93%8D%E4%BD%9C%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%B7%A5%E5%85%B7%E9%93%BE%E5%8C%85%E5%90%AB%E7%9A%84%20qt%20%E5%8C%85%E6%AF%94%E5%9B%BE%E5%83%8F%E5%A4%9A%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E9%87%8C%E6%98%AF%E6%88%91%E7%9A%84%20local.conf%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%8C%85%E5%90%AB%E8%AE%BE%E5%A4%87%E4%B8%8A%E7%9A%84%E8%B0%83%E8%AF%95%E7%AC%A6%E5%8F%B7%E5%92%8C%20gdb%E3%80%82%3C%2FP%3E%3CP%3EBB_NUMBER_THREADS%20%3F%3D%20%22%20%24%7B%40oe.utils.cpu_count()%7D%20%22%3C%2FP%3E%3CP%3EPARALLEL_MAKE%20%3F%3D%20%22-j%20%24%7B%40oe.utils.cpu_count()%7D%22%3C%2FP%3E%3CP%3EMACHINE%20%3F%3F%3D%20'imx6qsabresd'%3C%2FP%3E%3CP%3EDISTRO%20%3F%3D%20'poky'%3C%2FP%3E%3CP%3EPACKAGE_CLASSES%20%3F%3D%20%22%E8%BD%AF%E4%BB%B6%E5%8C%85_rpm%22%3C%2FP%3E%3CP%3EDISTRO_FEATURES_remove%20%3D%20%22x11%20wayland%22%3C%2FP%3E%3CP%3EEXTRA_IMAGE_FEATURES%20%3D%E2%80%9C%E8%B0%83%E8%AF%95%E8%B0%83%E6%95%B4ssh%E6%9C%8D%E5%8A%A1%E5%99%A8openssh%E5%B7%A5%E5%85%B7%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6dbg-pkgs%E5%B7%A5%E5%85%B7%E8%B0%83%E8%AF%95%E2%80%9D%3C%2FP%3E%3CP%3E%E5%9B%BE%E5%83%8F%E5%AE%89%E8%A3%85%E9%99%84%E5%8A%A0%20%3D%20%22%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20firmware-imx-vpu-imx6q%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20firmware-imx-vpu-imx6d%20%5C%3C%2FP%3E%3CP%3E%22%3C%2FP%3E%3CP%3E%E5%9B%BE%E5%83%8F%E5%AE%89%E8%A3%85%E9%99%84%E5%8A%A0%20%3D%20%22%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cpufrequtils%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20nano%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gdb%20%5C%3C%2FP%3E%3CP%3Eopenssh-sftp%20%E6%9C%8D%E5%8A%A1%E5%99%A8%20%5C%3C%2FP%3E%3CP%3E%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%BB%84-fsl-gstreamer%20%5C%3C%2FP%3E%3CP%3E%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%BB%84-fsl-tools-testapps%20%5C%3C%2FP%3E%3CP%3E%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%BB%84-fsl-%E5%B7%A5%E5%85%B7-%E5%9F%BA%E5%87%86%20%5C%3C%2FP%3E%3CP%3Egstreamer%20%5C%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6-%E5%9F%BA%E7%A1%80%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%5C%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6%E5%BA%93%20%5C%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6-%E5%A5%BD%20%5C%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6-good-rtsp%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gst-plugins-good-udp%20%5C%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6-good-rtpmanager%20%5C%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6-good-rtp%20%5C%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6-good-video4linux2%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtbase-fonts%20%5C%3C%2FP%3E%3CP%3Eqtbase-%E6%8F%92%E4%BB%B6%20%5C%3C%2FP%3E%3CP%3Eqtbase%20%E5%B7%A5%E5%85%B7%20%5C%3C%2FP%3E%3CP%3Eqtbase%20%E7%A4%BA%E4%BE%8B%3C%2FP%3E%3CP%3Eqt%E5%A3%B0%E6%98%8E%E5%BC%8F%5C%3C%2FP%3E%3CP%3Eqtdeclarative-%E6%8F%92%E4%BB%B6%20%5C%3C%2FP%3E%3CP%3Eqtdeclarative%E5%B7%A5%E5%85%B7%5C%3C%2FP%3E%3CP%3Eqtdeclarative%20%E7%A4%BA%E4%BE%8B%20%5C%3C%2FP%3E%3CP%3Eqtdeclarative-qml%E6%8F%92%E4%BB%B6%3C%2FP%3E%3CP%3Eqt%E5%A4%9A%E5%AA%92%E4%BD%93%3C%2FP%3E%3CP%3Eqt%E5%A4%9A%E5%AA%92%E4%BD%93%E6%8F%92%E4%BB%B6%3C%2FP%3E%3CP%3Eqtmultimedia-%E7%A4%BA%E4%BE%8B%3C%2FP%3E%3CP%3Eqtmultimedia-qml%E6%8F%92%E4%BB%B6%3C%2FP%3E%3CP%3Eqtquickcontrols-qml%E6%8F%92%E4%BB%B6%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtsvg%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtsvg-plugins%20%5C%3C%2FP%3E%3CP%3Eqt%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtimageformats-plugins%20%5C%3C%2FP%3E%3CP%3Eqt%E7%B3%BB%E7%BB%9F%20%5C%3C%2FP%3E%3CP%3Eqtsystems%E5%B7%A5%E5%85%B7%3C%2FP%3E%3CP%3Eqtsystems-%E7%A4%BA%E4%BE%8B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtsystems-qmlplugins%20%5C%3C%2FP%3E%3CP%3Eqtscript%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qt3d%20%5C%3C%2FP%3E%3CP%3Eqt3d%20%E7%A4%BA%E4%BE%8B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qt3d-qmlplugins%20%5C%3C%2FP%3E%3CP%3Eqt3d%E5%B7%A5%E5%85%B7%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtwebkit%20%5C%3C%2FP%3E%3CP%3Eqtwebkit-%E7%A4%BA%E4%BE%8B-%E7%A4%BA%E4%BE%8B%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtwebkit-qmlplugins%20%5C%3C%2FP%3E%3CP%3E%E7%94%B5%E5%BD%B1%E4%BD%93%E9%AA%8C%5C%3C%2FP%3E%3CP%3E%E5%BC%80%E7%BD%97%20pango%20fontconfig%20freetypepulseaudio%20dbus%20%5C%3C%2FP%3E%3CP%3Ealsa-lib%20alsa-tools%20alsa-state%20alsa-utils-alsaconf%20%5C%3C%2FP%3E%3CP%3E%E2%80%9C%3C%2FP%3E%3CP%3EPACKAGECONFIG_append_pn-qtbase%20%3D%20%22%20%E5%8F%AF%E8%AE%BF%E9%97%AE%E6%80%A7%20gles2%20openssl%22%20%3C%2FP%3E%3CP%3EPACKAGECONFIG_append_pn-qtmultimedia%20%3D%E2%80%9Cgstreamer010%E2%80%9D%3C%2FP%3E%3CP%3EPREFERRED_PROVIDER_jpeg%20%3D%20%22libjpeg-turbo%22%3C%2FP%3E%3CP%3ETOOLCHAIN_HOST_TASK_append%20%3D%20%22%20nativesdk-python-%E5%AD%90%E8%BF%9B%E7%A8%8B%22%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EQT5_VERSION%20%3D%20%225.2.1%2B5.3.0-beta1%2Bgit%25%22%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtbase-native%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtbase%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtdeclarative%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtjsbackend%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtjsbackend-native%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtgraphicaleffects%20%3D%E2%80%9C%20%24%7BQT5_VERSION%7D%20%E2%80%9D%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtimageformats%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtmultimedia%20%3D%E2%80%9C%20%24%7BQT5_VERSION%7D%20%E2%80%9D%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtquick1%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3E%E9%A6%96%E9%80%89%E7%89%88%E6%9C%AC_qtquickcontrols%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtsensors%20%3D%E2%80%9C%20%24%7BQT5_VERSION%7D%20%E2%80%9D%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtserialport%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtscript%20%3D%E2%80%9C%20%24%7BQT5_VERSION%7D%20%E2%80%9D%3C%2FP%3E%3CP%3E%E9%A6%96%E9%80%89%E7%89%88%E6%9C%AC%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3E%E9%A6%96%E9%80%89%E7%89%88%E6%9C%AC_qttools-native%20%3D%E2%80%9C%20%24%7BQT5_VERSION%7D%20%E2%80%9D%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtwebkit%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3E%E9%A6%96%E9%80%89%E7%89%88%E6%9C%AC_qtwebkit-%E7%A4%BA%E4%BE%8B%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3E%E9%A6%96%E9%80%89%E7%89%88%E6%9C%AC_qtxmlpatterns%20%3D%E2%80%9C%20%24%7BQT5_VERSION%7D%20%E2%80%9D%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtlocation%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3E%E9%A6%96%E9%80%89%E7%89%88%E6%9C%AC_qttools%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtconnectivity%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3E%E9%A6%96%E9%80%89%E7%89%88%E6%9C%AC_nativesdk-qtbase%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWARN_QA%3D%22%E7%BC%96%E8%AF%91%E4%B8%BB%E6%9C%BA%E8%B7%AF%E5%BE%84%20libdir%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUSER_CLASSES%20%3F%3D%20%E2%80%9Cbuildstats%20image-mklibs%20image-prelink%E2%80%9D%3C%2FP%3E%3CP%3EPATCHRESOLVE%20%3D%20%22noop%22%3C%2FP%3E%3CP%3EBB_DISKMON_DIRS%20%3D%20%22%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20STOPTASKS%2C%24%7BTMPDIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20STOPTASKS%2C%24%7BDL_DIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20STOPTASKS%2C%24%7BSSTATE_DIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ABORT%2C%24%7BTMPDIR%7D%2C100M%2C1K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ABORT%2C%24%7BDL_DIR%7D%2C100M%2C1K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ABORT%2C%24%7BSSTATE_DIR%7D%2C100M%2C1K%22%20%3C%2FP%3E%3CP%3EPACKAGECONFIG_pn-qemu-native%20%3D%20%22sdl%22%3C%2FP%3E%3CP%3EASSUME_PROVIDED%20%2B%3D%20%E2%80%9Clibsdl-native%E2%80%9D%3C%2FP%3E%3CP%3ECONF_VERSION%20%3D%20%221%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBB_NUMBER_THREADS%20%3D%20'4'%3C%2FP%3E%3CP%3EPARALLEL_MAKE%20%3D%20'-j%204'%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDL_DIR%20%3F%3D%20%22%24%7BBSPDIR%7D%2Fdownloads%2F%22%3C%2FP%3E%3CP%3E%E6%8E%A5%E5%8F%97FSL_EULA%20%3D%20%221%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105164%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105164%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E7%8E%B0%E5%9C%A8%E6%88%91%E5%B7%B2%E7%BB%8F%E4%BD%BF%E7%94%A8%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E4%BF%AE%E5%A4%8D%E4%BA%86%E9%85%8D%E7%BD%AE%E9%97%AE%E9%A2%98%E3%80%82Gunnar%20%E5%AE%9E%E9%99%85%E4%B8%8A%E5%9C%A8%E4%BB%96%E7%9A%84%E4%BF%AE%E6%94%B9%E4%B8%AD%E5%B7%B2%E7%BB%8F%E7%BB%99%E5%87%BA%E4%BA%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E---%20a%2Frecipes-qt%2Fqt5%2Fqtbase.inc%3C%2FP%3E%3CP%3E%2B%2B%2Bb%2Frecipes-qt%2Fqt5%2Fqtbase.inc%3C%2FP%3E%3CP%3E%40%40%20-126%2C7%20%2B126%2C6%20%40%40%20PACKAGECONFIG%5Bnis%5D%20%3D%20%22-nis%2C-no-nis%22%3C%2FP%3E%3CP%3E%20PACKAGECONFIG%5Bwidgets%5D%20%3D%20%22-widgets%2C-no-widgets%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20QT_CONFIG_FLAGS%20%2B%3D%20%22%20%5C%3C%2FP%3E%3CP%3E-%20-%E5%87%8F%E5%B0%91%E9%87%8D%E5%AE%9A%E4%BD%8D%5C%3C%2FP%3E%3CP%3E-%E5%85%B1%E4%BA%AB%20%5C%3C%2FP%3E%3CP%3E-%E6%B2%89%E9%BB%98%E7%9A%84%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%20-no-pch%20%5C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%89%80%E4%BB%A5%EF%BC%8C%E7%8E%B0%E5%9C%A8%E6%88%91%E7%A1%AE%E5%AE%9E%E5%BE%97%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E2%80%9C%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E9%94%99%E8%AF%AF%EF%BC%9AQA%20%E9%97%AE%E9%A2%98%EF%BC%9Aqt...%EF%BC%9A%E7%BC%96%E8%AF%91%E6%97%A5%E5%BF%97%E8%A1%A8%E6%98%8E%E4%BD%BF%E7%94%A8%E4%BA%86%E4%B8%BB%E6%9C%BA%E5%8C%85%E5%90%AB%E5%92%8C%2F%E6%88%96%E5%BA%93%E8%B7%AF%E5%BE%84%E3%80%82%E2%80%9D%E9%94%99%E8%AF%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E9%97%AE%E9%A2%98%E5%87%BA%E5%9C%A8%E5%93%AA%E9%87%8C%EF%BC%8C%E4%BD%86%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E4%BD%BF%E7%94%A8%E4%BF%AE%E8%AE%A2%E7%89%88%2092be18a3a14deed9d38b8fc6e89f09ba4d730597%EF%BC%8C%E8%99%BD%E7%84%B6%E7%89%88%E6%9C%AC%E7%A8%8D%E6%97%A7%E4%B8%80%E4%BA%9B%EF%BC%8C%E4%BD%86%E9%99%A4%E6%AD%A4%E4%B9%8B%E5%A4%96%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105163%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105163%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%9C%89%20fea4eb8fe57fb5dd52ead5a351d4ec0940301443%3C%2FP%3E%3CP%3E%E7%BB%8F%E8%BF%87%E8%BF%99%E6%A0%B7%E7%9A%84%E6%94%B9%E5%8F%98%EF%BC%9A%3C%2FP%3E%3CP%3Edevuser%40ubuntu%3A~%2Fyocto%2Fsources%2Fmeta-qt5%24%20git%20diff%20fea4eb8fe57fb5dd52ead5a351d4ec0940301443%3C%2FP%3E%3CP%3Ediff%20--git%20a%2Frecipes-qt%2Fqt5%2Fqt5.inc%20b%2Frecipes-qt%2Fqt5%2Fqt5.inc%3C%2FP%3E%3CP%3E%E7%B4%A2%E5%BC%95%20dfc1c76..a2f9a73%20100644%3C%2FP%3E%3CP%3E---%20a%2Frecipes-qt%2Fqt5%2Fqt5.inc%3C%2FP%3E%3CP%3E%2B%2B%2Bb%2Frecipes-qt%2Fqt5%2Fqt5.inc%3C%2FP%3E%3CP%3E%40%40%20-54%2C6%20%2B54%2C7%20%40%40%20FILES_%20%24%7BPN%7D%20-tools-dbg%20%3D%E2%80%9C%20%5C%3C%2FP%3E%3CP%3E%20%22%3C%2FP%3E%3CP%3E%20%E6%96%87%E4%BB%B6_%20%24%7BPN%7D%20-plugins-dbg%20%3D%E2%80%9C%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%7BOE_QMAKE_PATH_PLUGINS%7D%2F*%2F.debug%2F*%20%5C%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%7BOE_QMAKE_PATH_PLUGINS%7D%2F*%2F*%2F.debug%2F*%20%5C%3C%2FP%3E%3CP%3E%20%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%23%20%E9%A2%9D%E5%A4%96%E7%9A%84%E5%8C%85%3C%2FP%3E%3CP%3E%40%40%20-98%2C6%20%2B99%2C7%20%40%40%20FILES_%20%24%7BPN%7D%20-tools%20%3D%E2%80%9C%5C%3C%2FP%3E%3CP%3E%20%22%3C%2FP%3E%3CP%3E%20%E6%96%87%E4%BB%B6_%20%24%7BPN%7D%20-%E6%8F%92%E4%BB%B6%3D%E2%80%9C%5C%3C%2FP%3E%3CP%3E%24%7BOE_QMAKE_PATH_PLUGINS%7D%20%2F*%2F*%20%24%7BSOLIBSDEV%7D%20%5C%3C%2FP%3E%3CP%3E%2B%20%24%7BOE_QMAKE_PATH_PLUGINS%7D%20%2F*%2F*%2F*%20%24%7BSOLIBSDEV%7D%20%5C%3C%2FP%3E%3CP%3E%20%22%3C%2FP%3E%3CP%3E%20FILES_%24%7BPN%7D-mkspecs%20%3D%20%22%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%7BOE_QMAKE_PATH_ARCHDATA%7D%2Fmkspecs%20%5C%3C%2FP%3E%3CP%3Ediff%20--git%20a%2Frecipes-qt%2Fqt5%2Fqtbase.inc%20b%2Frecipes-qt%2Fqt5%2Fqtbase.inc%3C%2FP%3E%3CP%3E%E7%B4%A2%E5%BC%95%2089736be..f23236a%20100644%3C%2FP%3E%3CP%3E---%20a%2Frecipes-qt%2Fqt5%2Fqtbase.inc%3C%2FP%3E%3CP%3E%2B%2B%2Bb%2Frecipes-qt%2Fqt5%2Fqtbase.inc%3C%2FP%3E%3CP%3E%40%40%20-126%2C7%20%2B126%2C6%20%40%40%20PACKAGECONFIG%5Bnis%5D%20%3D%20%22-nis%2C-no-nis%22%3C%2FP%3E%3CP%3E%20PACKAGECONFIG%5Bwidgets%5D%20%3D%20%22-widgets%2C-no-widgets%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20QT_CONFIG_FLAGS%20%2B%3D%20%22%20%5C%3C%2FP%3E%3CP%3E-%20-%E5%87%8F%E5%B0%91%E9%87%8D%E5%AE%9A%E4%BD%8D%5C%3C%2FP%3E%3CP%3E-%E5%85%B1%E4%BA%AB%20%5C%3C%2FP%3E%3CP%3E-%E6%B2%89%E9%BB%98%E7%9A%84%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-no-pch%20%5C%3C%2FP%3E%3CP%3Ediff%20--git%20a%2Frecipes-qt%2Fqt5%2Fqtlocation_git.bb%20b%2Frecipes-qt%2Fqt5%2Fqtlocation_git.bb%3C%2FP%3E%3CP%3Eindex%20d1d2575..87ad63d%20100644%3C%2FP%3E%3CP%3E---%20a%2Frecipes-qt%2Fqt5%2Fqtlocation_git.bb%3C%2FP%3E%3CP%3E%2B%2B%2B%20b%2Frecipes-qt%2Fqt5%2Fqtlocation_git.bb%3C%2FP%3E%3CP%3E%40%40%20-2%2C3%20%2B2%2C10%20%40%40%20%E9%9C%80%E8%A6%81%20qt5-git.inc%3C%2FP%3E%3CP%3E%20%E9%9C%80%E8%A6%81%24%7BPN%7D%20.inc%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20SRCREV%20%3D%20%E2%80%9C9cbddccc24cdd4b51285ea9ecbf851f3eba2cd31%E2%80%9D%3C%2FP%3E%3CP%3E%2B%3C%2FP%3E%3CP%3E%2B%23%20%E7%89%88%E6%9D%83%E5%B9%B4%E4%BB%BD%E6%AF%94%E4%BE%8B%E5%A6%82qtbase%20%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E%2BLIC_FILES_CHKSUM%20%3D%20%22%E6%96%87%E4%BB%B6%3A%2F%2FLICENSE.LGPL%3Bmd5%3D4193e7f1d47a858f6b7c0f1ee66161de%20%5C%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20file%3A%2F%2FLICENSE.GPL%3Bmd5%3Dd32239bcb673463ab874e80d47fae504%20%5C%3C%2FP%3E%3CP%3E%2B%20%E6%96%87%E4%BB%B6%3A%2F%2FLGPL_EXCEPTION.txt%3Bmd5%3D0145c4d1b6f96a661c2c139dfb268fb6%5C%3C%2FP%3E%3CP%3E%2B%20%E6%96%87%E4%BB%B6%3A%2F%2FLICENSE.FDL%3Bmd5%3D6d9f2a9af4c8b8c3c769f6cc1b6aaf7e%22%3C%2FP%3E%3CP%3E%2B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%AF%EF%BC%8C%E6%88%91%E4%B8%8D%E6%98%AF%20Yocto%20%E4%B8%93%E5%AE%B6%E3%80%82%E6%88%91%E5%88%9A%E5%88%9A%E5%BC%80%E5%A7%8B%E7%94%A8%E5%AE%83%E5%B7%A5%E4%BD%9C%E3%80%82%E4%BD%86%E4%BC%BC%E4%B9%8E%E6%82%A8%E6%B2%A1%E6%9C%89%E6%A3%80%E5%87%BA%20yocto%20repo%20%E7%9A%84%E2%80%9Cmaster-next%E2%80%9D%EF%BC%8C%E8%80%8C%E6%98%AF%E4%BD%BF%E7%94%A8%E4%BA%86%E2%80%9Cdora%E2%80%9D%E3%80%82%E6%88%91%E5%B9%B6%E4%B8%8D%E6%98%AF%E8%AF%B4%E8%BF%99%E4%BC%9A%E4%BA%A7%E7%94%9F%E4%BB%80%E4%B9%88%E4%B8%8D%E5%90%8C%E3%80%82%E6%88%91%E5%88%9A%E6%89%8D%E6%B3%A8%E6%84%8F%E5%88%B0%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%A0%E6%A0%91%E7%AB%8B%E4%BA%86%E4%BB%80%E4%B9%88%E5%BD%A2%E8%B1%A1%EF%BC%9F%E6%A0%B8%E5%BF%83%E5%9B%BE%E5%83%8F%E6%9C%80%E5%B0%8F%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%99%A4%E6%AD%A4%E4%B9%8B%E5%A4%96%EF%BC%8C%E6%88%91%E6%B2%A1%E4%BB%80%E4%B9%88%E5%8F%AF%E6%83%B3%E7%9A%84%E3%80%82%E4%B9%9F%E8%AE%B8%E5%85%B6%E4%BB%96%20Yocto%20%E4%B8%93%E5%AE%B6%E5%8F%AF%E4%BB%A5%E5%AF%B9%E6%AD%A4%E5%8F%91%E8%A1%A8%E8%AF%84%E8%AE%BA%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105161%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105161%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%AF%EF%BC%8C%E5%92%8C%E6%88%91%E7%B1%BB%E4%BC%BC%EF%BC%8C%E5%8F%AA%E6%98%AF%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%2064%20%E4%BD%8D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E8%80%81%E5%AE%9E%E8%AF%B4%EF%BC%8C%E6%88%91%E4%BB%8E%E6%9C%AA%E8%A7%81%E8%BF%87%E6%82%A8%E7%9A%84%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%E2%80%9C%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E9%94%99%E8%AF%AF%EF%BC%9AQA%20%E9%97%AE%E9%A2%98%EF%BC%9Aqt...%EF%BC%9A%E7%BC%96%E8%AF%91%E6%97%A5%E5%BF%97%E8%A1%A8%E6%98%8E%E4%BD%BF%E7%94%A8%E4%BA%86%E4%B8%BB%E6%9C%BA%E5%8C%85%E5%90%AB%E5%92%8C%2F%E6%88%96%E5%BA%93%E8%B7%AF%E5%BE%84%E3%80%82%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%A3%80%E6%9F%A5%E4%BA%86%E5%93%AA%E4%B8%AA%20meta-qt5%20git%20%E4%BF%AE%E8%AE%A2%E7%89%88%EF%BC%9F%E4%B9%9F%E8%AE%B8%E8%BF%99%E4%BC%9A%E6%9C%89%E6%89%80%E4%B8%8D%E5%90%8C%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105160%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105160%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%B9%9F%E6%B2%A1%E6%9C%89%E6%98%8E%E7%A1%AE%E5%90%AF%E7%94%A8%20qtlocation%E3%80%82%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84local.conf%3C%2FP%3E%3CP%3EB_NUMBER_THREADS%20%3F%3D%20%22%20%24%7B%40oe.utils.cpu_count()%7D%20%22%3C%2FP%3E%3CP%3EPARALLEL_MAKE%20%3F%3D%20%22-j%20%24%7B%40oe.utils.cpu_count()%7D%22%3C%2FP%3E%3CP%3EMACHINE%20%3F%3F%3D%20'imx6qsabresd'%3C%2FP%3E%3CP%3EDISTRO%20%3F%3D%20'poky'%3C%2FP%3E%3CP%3EPACKAGE_CLASSES%20%3F%3D%20%22%E8%BD%AF%E4%BB%B6%E5%8C%85_rpm%22%3C%2FP%3E%3CP%3EDISTRO_FEATURES_remove%20%3D%20%22x11%20wayland%22%3C%2FP%3E%3CP%3EEXTRA_IMAGE_FEATURES%20%3D%E2%80%9C%E8%B0%83%E8%AF%95%E8%B0%83%E6%95%B4ssh%E6%9C%8D%E5%8A%A1%E5%99%A8openssh%E5%B7%A5%E5%85%B7%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6dbg-pkgs%E5%B7%A5%E5%85%B7%E8%B0%83%E8%AF%95%E2%80%9D%3C%2FP%3E%3CP%3E%E5%9B%BE%E5%83%8F%E5%AE%89%E8%A3%85%E9%99%84%E5%8A%A0%20%3D%20%22%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20firmware-imx-vpu-imx6q%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20firmware-imx-vpu-imx6d%20%5C%3C%2FP%3E%3CP%3E%22%3C%2FP%3E%3CP%3E%E5%9B%BE%E5%83%8F%E5%AE%89%E8%A3%85%E9%99%84%E5%8A%A0%20%3D%20%22%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cpufrequtils%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20nano%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gdb%20%5C%3C%2FP%3E%3CP%3Eopenssh-sftp%20%E6%9C%8D%E5%8A%A1%E5%99%A8%20%5C%3C%2FP%3E%3CP%3E%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%BB%84-fsl-gstreamer%20%5C%3C%2FP%3E%3CP%3E%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%BB%84-fsl-tools-testapps%20%5C%3C%2FP%3E%3CP%3E%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%BB%84-fsl-%E5%B7%A5%E5%85%B7-%E5%9F%BA%E5%87%86%20%5C%3C%2FP%3E%3CP%3Egstreamer%20%5C%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6-%E5%9F%BA%E7%A1%80%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%5C%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6%E5%BA%93%20%5C%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6-%E5%A5%BD%20%5C%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6-good-rtsp%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gst-plugins-good-udp%20%5C%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6-good-rtpmanager%20%5C%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6-good-rtp%20%5C%3C%2FP%3E%3CP%3Egst-%E6%8F%92%E4%BB%B6-good-video4linux2%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtbase-fonts%20%5C%3C%2FP%3E%3CP%3Eqtbase-%E6%8F%92%E4%BB%B6%20%5C%3C%2FP%3E%3CP%3Eqtbase%20%E5%B7%A5%E5%85%B7%20%5C%3C%2FP%3E%3CP%3Eqtbase%20%E7%A4%BA%E4%BE%8B%3C%2FP%3E%3CP%3Eqt%E5%A3%B0%E6%98%8E%E5%BC%8F%5C%3C%2FP%3E%3CP%3Eqtdeclarative-%E6%8F%92%E4%BB%B6%20%5C%3C%2FP%3E%3CP%3Eqtdeclarative%E5%B7%A5%E5%85%B7%5C%3C%2FP%3E%3CP%3Eqtdeclarative%20%E7%A4%BA%E4%BE%8B%20%5C%3C%2FP%3E%3CP%3Eqtdeclarative-qml%E6%8F%92%E4%BB%B6%3C%2FP%3E%3CP%3Eqt%E5%A4%9A%E5%AA%92%E4%BD%93%3C%2FP%3E%3CP%3Eqt%E5%A4%9A%E5%AA%92%E4%BD%93%E6%8F%92%E4%BB%B6%3C%2FP%3E%3CP%3Eqtmultimedia-%E7%A4%BA%E4%BE%8B%3C%2FP%3E%3CP%3Eqtmultimedia-qml%E6%8F%92%E4%BB%B6%3C%2FP%3E%3CP%3Eqtquickcontrols-qml%E6%8F%92%E4%BB%B6%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtsvg%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtsvg-plugins%20%5C%3C%2FP%3E%3CP%3Eqt%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtimageformats-plugins%20%5C%3C%2FP%3E%3CP%3Eqt%E7%B3%BB%E7%BB%9F%20%5C%3C%2FP%3E%3CP%3Eqtsystems%E5%B7%A5%E5%85%B7%3C%2FP%3E%3CP%3Eqtsystems-%E7%A4%BA%E4%BE%8B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtsystems-qmlplugins%20%5C%3C%2FP%3E%3CP%3Eqtscript%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qt3d%20%5C%3C%2FP%3E%3CP%3Eqt3d%20%E7%A4%BA%E4%BE%8B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qt3d-qmlplugins%20%5C%3C%2FP%3E%3CP%3Eqt3d%E5%B7%A5%E5%85%B7%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtwebkit%20%5C%3C%2FP%3E%3CP%3Eqtwebkit-%E7%A4%BA%E4%BE%8B-%E7%A4%BA%E4%BE%8B%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtwebkit-qmlplugins%20%5C%3C%2FP%3E%3CP%3E%E7%94%B5%E5%BD%B1%E4%BD%93%E9%AA%8C%5C%3C%2FP%3E%3CP%3E%E5%BC%80%E7%BD%97%20pango%20fontconfig%20freetypepulseaudio%20dbus%20%5C%3C%2FP%3E%3CP%3Ealsa-lib%20alsa-tools%20alsa-state%20alsa-utils-alsaconf%20%5C%3C%2FP%3E%3CP%3E%E2%80%9C%3C%2FP%3E%3CP%3EPACKAGECONFIG_append_pn-qtbase%20%3D%20%22%20%E5%8F%AF%E8%AE%BF%E9%97%AE%E6%80%A7%20gles2%20openssl%22%20%3C%2FP%3E%3CP%3EPACKAGECONFIG_append_pn-qtmultimedia%20%3D%E2%80%9Cgstreamer010%E2%80%9D%3C%2FP%3E%3CP%3EPREFERRED_PROVIDER_jpeg%20%3D%20%22libjpeg-turbo%22%3C%2FP%3E%3CP%3ETOOLCHAIN_HOST_TASK_append%20%3D%20%22%20nativesdk-python-%E5%AD%90%E8%BF%9B%E7%A8%8B%22%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EQT5_VERSION%20%3D%20%225.2.1%2B5.3.0-beta1%2Bgit%25%22%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtbase-native%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtbase%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtdeclarative%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtjsbackend%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtjsbackend-native%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtgraphicaleffects%20%3D%E2%80%9C%20%24%7BQT5_VERSION%7D%20%E2%80%9D%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtimageformats%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtmultimedia%20%3D%E2%80%9C%20%24%7BQT5_VERSION%7D%20%E2%80%9D%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtquick1%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3E%E9%A6%96%E9%80%89%E7%89%88%E6%9C%AC_qtquickcontrols%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtsensors%20%3D%E2%80%9C%20%24%7BQT5_VERSION%7D%20%E2%80%9D%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtserialport%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtscript%20%3D%E2%80%9C%20%24%7BQT5_VERSION%7D%20%E2%80%9D%3C%2FP%3E%3CP%3E%E9%A6%96%E9%80%89%E7%89%88%E6%9C%AC%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3E%E9%A6%96%E9%80%89%E7%89%88%E6%9C%AC_qttools-native%20%3D%E2%80%9C%20%24%7BQT5_VERSION%7D%20%E2%80%9D%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtwebkit%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3E%E9%A6%96%E9%80%89%E7%89%88%E6%9C%AC_qtwebkit-%E7%A4%BA%E4%BE%8B%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3E%E9%A6%96%E9%80%89%E7%89%88%E6%9C%AC_qtxmlpatterns%20%3D%E2%80%9C%20%24%7BQT5_VERSION%7D%20%E2%80%9D%3C%2FP%3E%3CP%3EPREFERRED_VERSION_qtlocation%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FP%3E%3CP%3EUSER_CLASSES%20%3F%3D%20%E2%80%9Cbuildstats%20image-mklibs%20image-prelink%E2%80%9D%3C%2FP%3E%3CP%3EPATCHRESOLVE%20%3D%20%22noop%22%3C%2FP%3E%3CP%3EBB_DISKMON_DIRS%20%3D%20%22%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20STOPTASKS%2C%24%7BTMPDIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20STOPTASKS%2C%24%7BDL_DIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20STOPTASKS%2C%24%7BSSTATE_DIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ABORT%2C%24%7BTMPDIR%7D%2C100M%2C1K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ABORT%2C%24%7BDL_DIR%7D%2C100M%2C1K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ABORT%2C%24%7BSSTATE_DIR%7D%2C100M%2C1K%22%20%3C%2FP%3E%3CP%3EPACKAGECONFIG_pn-qemu-native%20%3D%20%22sdl%22%3C%2FP%3E%3CP%3EASSUME_PROVIDED%20%2B%3D%20%E2%80%9Clibsdl-native%E2%80%9D%3C%2FP%3E%3CP%3ECONF_VERSION%20%3D%20%221%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBB_NUMBER_THREADS%20%3D%20'4'%3C%2FP%3E%3CP%3EPARALLEL_MAKE%20%3D%20'-j%204'%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDL_DIR%20%3F%3D%20%22%24%7BBSPDIR%7D%2Fdownloads%2F%22%3C%2FP%3E%3CP%3E%E6%8E%A5%E5%8F%97FSL_EULA%20%3D%20%221%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E5%90%A7%EF%BC%8C%E6%88%91%E5%88%9A%E5%88%9A%E5%B0%9D%E8%AF%95%E4%BA%86%E4%BF%AE%E8%AE%A2%E7%89%88%2092be18a3a14deed9d38b8fc6e89f09ba4d730597%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E6%AF%AB%E6%97%A0%E9%97%AE%E9%A2%98%E5%9C%B0%E7%83%98%E7%84%99%E6%89%80%E6%9C%89%E6%A8%A1%E5%9D%97%E3%80%82%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86%20qtxmlpatterns%EF%BC%8C%E4%BD%86%E6%88%91%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%20qtlocation%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%8E%E6%9D%A5%E6%B2%A1%E6%9C%89%E9%81%87%E5%88%B0%E8%BF%87%E4%BD%A0%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%82%A8%E5%9C%A8%E5%93%AA%E4%B8%AA%E4%B8%BB%E6%9C%BA%E4%B8%8A%E8%BF%9B%E8%A1%8C%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E7%9A%84%E4%B8%8B%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E6%98%AF%20qtlocation%EF%BC%8C%E5%AE%83%E5%B0%9D%E8%AF%95%E6%9E%84%E5%BB%BA%205.2.1%20%E7%89%88%E6%9C%AC%EF%BC%8C%E4%BD%86%E5%A4%B1%E8%B4%A5%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%BF%85%E9%A1%BB%E8%A1%A5%E5%85%85%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3EPREFERRED_VERSION_qtlocation%20%3D%20%22%20%24%7BQT5_VERSION%7D%20%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E5%88%B0%E6%88%91%E7%9A%84local.conf%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E4%BD%86%E9%9A%8F%E5%90%8E%E7%94%B1%E4%BA%8E%E8%AE%B8%E5%8F%AF%E8%AF%81%20md5%20%E6%A3%80%E6%9F%A5%E8%80%8C%E5%A4%B1%E8%B4%A5%E3%80%82%E6%88%91%E5%BF%85%E9%A1%BB%E5%B0%86%E8%AE%B8%E5%8F%AF%E8%AF%81%E6%A0%A1%E9%AA%8C%E5%92%8C%E6%9D%A1%E7%9B%AE%E4%BB%8E%20qtsensers_git.bb%20%E5%A4%8D%E5%88%B6%E5%88%B0%20qtlocation_git.bb%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E7%84%B6%E5%90%8E%E5%AE%83%E4%BC%9A%E5%A4%B1%E8%B4%A5%E5%B9%B6%E5%87%BA%E7%8E%B0%E5%B7%B2%E7%9F%A5%E7%9A%84%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E9%94%99%E8%AF%AF%EF%BC%9AQA%20%E9%97%AE%E9%A2%98%EF%BC%9Aqtlocation%EF%BC%9A%E7%BC%96%E8%AF%91%E6%97%A5%E5%BF%97%E8%A1%A8%E6%98%8E%E4%BD%BF%E7%94%A8%E4%BA%86%E4%B8%BB%E6%9C%BA%E5%8C%85%E5%90%AB%E5%92%8C%2F%E6%88%96%E5%BA%93%E8%B7%AF%E5%BE%84%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E8%BF%99%E6%98%AF%E6%88%91%E4%B8%8A%E9%9D%A2%E5%86%99%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%E7%BB%A7%E7%BB%AD%E7%83%98%E7%83%A4...%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'courier%20new'%2C%20courier%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105156%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105156%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EGunnar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%83%BD%E8%AF%95%E8%AF%95%E5%90%97%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egit%20checkout%2092be18a3a14deed9d38b8fc6e89f09ba4d730597%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E6%B7%BB%E5%8A%A0%E6%88%91%E7%9A%84%E8%A1%A5%E4%B8%81%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%EF%BC%88%E6%88%90%E5%8A%9F%EF%BC%89%E4%BD%BF%E7%94%A8%E7%9A%84%E7%89%88%E6%9C%AC%E3%80%82%E9%9A%8F%E7%9D%80%E4%B8%8B%E4%B8%80%E6%AC%A1%E6%8F%90%E4%BA%A4%EF%BC%8C%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E9%85%8D%E7%BD%AE%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E5%B0%86%E7%9C%8B%E7%9C%8B%E6%88%91%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E9%87%8D%E7%8E%B0%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E4%BE%BF%E9%97%AE%E4%B8%80%E4%B8%8B%EF%BC%8C%E6%82%A8%E5%85%B7%E4%BD%93%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%9C%8B%E8%B5%B7%E6%9D%A5%E8%BF%99%E4%B8%AA%20repo%20%E4%B8%AD%E5%8F%91%E7%94%9F%E4%BA%86%E4%B8%80%E4%BA%9B%E9%9D%9E%E5%B8%B8%E5%A5%87%E6%80%AA%E7%9A%84%E4%BA%8B%E6%83%85%E3%80%82%E6%88%91%E4%BB%8E%E6%88%91%E7%9A%84%E6%97%A7%E7%BC%96%E8%AF%91%E4%B8%AD%E5%A4%87%E4%BB%BD%E4%BA%86%E5%86%85%E5%AE%B9%EF%BC%88%E5%8F%AA%E6%9C%89%E6%BA%90%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%89%EF%BC%8C%E5%B9%B6%E6%A3%80%E6%9F%A5%E4%BA%86%E6%88%91%E4%B8%BA%E6%AD%A4%E6%8C%87%E5%8D%97%E7%AD%BE%E5%87%BA%E7%9A%84%20git%20%E4%BF%AE%E8%AE%A2%E7%89%88%E3%80%82%E5%AE%83%E6%98%AF%200c114f4bcf6bdf5b959ff8821bbbbff2dd1cdccf%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9F%A5%E7%9C%8B%E6%96%B0%E7%9A%84%20git%20clone%EF%BC%8C%E6%AD%A4%E6%8F%90%E4%BA%A4%E4%B8%8D%E5%86%8D%E5%AD%98%E5%9C%A8%EF%BC%81%E8%BF%99%E9%87%8C%E5%8F%91%E7%94%9F%E4%BA%86%E4%B8%80%E4%BA%9B%E5%A5%87%E6%80%AA%E7%9A%84%E4%BA%8B%E6%83%85%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105154%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105154%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E7%8E%B0%E5%9C%A8%E6%88%91%E4%B9%9F%E4%B8%BA%20qtdeclarative%20%E8%8E%B7%E5%BE%97%E4%BA%86%E8%BF%99%E4%B8%AA%E3%80%82%E8%BF%99%E6%98%AF%E4%B9%8B%E5%89%8D%E7%BC%96%E8%AF%91%E8%BF%87%E7%9A%84%EF%BC%8C%E4%BD%86%E4%B8%8D%E7%9F%A5%E4%BD%95%E6%95%85%E5%AE%83%E5%BC%80%E5%A7%8B%E4%BB%8E%20git%20%E8%8E%B7%E5%8F%96%E6%96%B0%E7%89%88%E6%9C%AC%EF%BC%8C%20%3C%2FP%3E%3CP%3E%E6%88%91%E9%80%9A%E8%BF%87%E4%BB%A5%E4%B8%8B%E6%96%B9%E5%BC%8F%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%3C%2FP%3E%3CP%3Ebitbake%20qtdeclarative%20-f%20-c%20%E7%BC%96%E8%AF%91%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E7%BB%A7%E7%BB%AD%EF%BC%8C%E8%BF%99%E5%B0%86%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%B9%B2%E5%87%80%E7%9A%84%E7%BC%96%E8%AF%91%E6%97%A5%E5%BF%97%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%89%80%E6%9C%89%E5%86%85%E5%AE%B9%E9%83%BD%E5%B7%B2%E7%BC%96%E8%AF%91%E5%AE%8C%E6%AF%95%EF%BC%8C%E5%9B%A0%E6%AD%A4%20QA%20%E6%A3%80%E6%B5%8B%E5%B0%86%E8%A2%AB%E6%AC%BA%E9%AA%97%E8%AE%A4%E4%B8%BA%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Egit%20%E5%AD%98%E5%82%A8%E5%BA%93%E6%98%AF%E4%B8%80%E4%B8%AA%E7%A7%BB%E5%8A%A8%E7%9B%AE%E6%A0%87%E3%80%82%E6%88%91%E6%83%B3%EF%BC%8C%E6%9C%80%E5%A5%BD%E5%B0%86%E5%AE%83%E5%9B%BA%E5%AE%9A%E5%88%B0%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E7%89%B9%E5%AE%9A%E6%8F%90%E4%BA%A4%E4%B8%8A%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E8%AF%95%E5%9B%BE%E9%87%8D%E7%8E%B0%E8%AF%A5%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E6%98%AF%20git%20%E7%9A%84%E5%BD%93%E5%89%8D%E7%89%88%E6%9C%AC%E5%9C%A8%20qtbase%20%E7%9A%84%E9%85%8D%E7%BD%AE%E6%AD%A5%E9%AA%A4%E4%B8%AD%E5%B7%B2%E7%BB%8F%E7%BB%99%E6%88%91%E5%B8%A6%E6%9D%A5%E4%BA%86%E5%85%B6%E4%BB%96%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E7%9A%84%E7%89%88%E6%9C%AC%E6%97%B6%EF%BC%8C%E6%88%91%E4%BC%9A%E5%B0%86%E9%85%8D%E6%96%B9%E6%9B%B4%E6%94%B9%E4%B8%BA%E7%89%B9%E5%AE%9A%E7%9A%84%E6%8F%90%E4%BA%A4%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20Yocto%20%E4%B8%8A%E7%BC%96%E8%AF%91%20Qt5.3.0-beta1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%A6%96%E5%85%88%EF%BC%8C%E6%88%91%E8%A6%81%E6%84%9F%E8%B0%A2%E4%BD%A0%E5%AF%B9%E5%A6%82%E4%BD%95%E4%B8%BA%20imx6%20%E6%9E%84%E5%BB%BA%20Qt%205.3%20%E7%9A%84%E6%8F%8F%E8%BF%B0%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E5%9C%A8%E5%B0%9D%E8%AF%95%E6%82%A8%E7%9A%84%E6%8C%87%E5%8D%97%E6%97%B6%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%8E%E9%9B%B6%E5%BC%80%E5%A7%8B%E5%B9%B6%E6%8C%89%E7%85%A7%E4%BD%A0%E6%8F%8F%E8%BF%B0%E7%9A%84%E6%96%B9%E5%BC%8F%E5%81%9A%E4%BA%86%E4%B8%80%E5%88%87%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E6%88%91%E6%94%B6%E5%88%B0%20qtxmlpatterns%20%E7%9A%84%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9AQA%20%E9%97%AE%E9%A2%98%EF%BC%9Aqtxmlpatterns%EF%BC%9A%E7%BC%96%E8%AF%91%E6%97%A5%E5%BF%97%E8%A1%A8%E6%98%8E%E4%BD%BF%E7%94%A8%E4%BA%86%E4%B8%BB%E6%9C%BA%E5%8C%85%E5%90%AB%E5%92%8C%2F%E6%88%96%E5%BA%93%E8%B7%AF%E5%BE%84%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%A3%80%E6%9F%A5%E6%97%A5%E5%BF%97%E2%80%9C%2Fhome%2Fdevuser%2Fyocto%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-poky-linux-gnueabi%2Fqtxmlpatterns%2F5.2.1%2B5.3.0-beta1%2BgitAUTOINC%2Bd25091bb8b-r0%2Ftemp%2Flog.do_compile%E2%80%9D%E4%BB%A5%E8%8E%B7%E5%8F%96%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9AQA%20%E8%BF%90%E8%A1%8C%E5%8F%91%E7%8E%B0%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%E3%80%82%E8%AF%B7%E8%80%83%E8%99%91%E4%BF%AE%E5%A4%8D%E5%AE%83%E4%BB%AC%E3%80%82%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E5%87%BD%E6%95%B0%E5%A4%B1%E8%B4%A5%EF%BC%9Ado_package_qa%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%95%85%E9%9A%9C%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E5%AD%98%E5%82%A8%E5%9C%A8%EF%BC%9A%2Fhome%2Fdevuser%2Fyocto%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-poky-linux-gnueabi%2Fqtxmlpatterns%2F5.2.1%2B5.3.0-beta1%2BgitAUTOINC%2Bd25091bb8b-r0%2Ftemp%2Flog.do_package.28091%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%BB%BB%E5%8A%A1%201589%EF%BC%88%2Fhome%2Fdevuser%2Fyocto%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fqtxmlpatterns_git.bb%EF%BC%8Cdo_package)%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%E2%80%9C1%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E6%9F%A5%E7%9C%8B%E7%94%9F%E6%88%90%E7%9A%84%20Makefile%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%20LDFLAGS%20%E4%B8%AD%E7%9C%8B%E5%88%B0%20-L%2Fusr%2Flib%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%88%A0%E9%99%A4%E4%BA%86%E5%AE%83%E5%B9%B6%E6%89%A7%E8%A1%8C%E4%BA%86%20bitbake%20qtxmlpatterns%20-f%20-c%20compile%EF%BC%8C%E7%84%B6%E5%90%8E%E6%89%A7%E8%A1%8C%E4%BA%86%20bitbake%20qtqmlpatterns%3C%2FP%3E%3CP%3E%E8%BF%99%E6%A0%B7%E5%B0%B1%E6%88%90%E5%8A%9F%E4%BA%86%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E7%BB%A7%E7%BB%AD%E5%AF%B9%E5%9B%BE%E5%83%8F%E8%BF%9B%E8%A1%8C%E4%BD%8D%E7%83%98%E7%84%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%B9%9F%E8%AE%B8%E6%88%91%E5%BA%94%E8%AF%A5%E5%88%A0%E9%99%A4%E7%94%9F%E6%88%90%E7%9A%84.so%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%AE%83%E9%93%BE%E6%8E%A5%E6%97%B6%E6%B2%A1%E6%9C%89%20-L%2Fusr%2Flib%EF%BC%8C%E4%BD%86%E6%88%91%E7%8E%B0%E5%9C%A8%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%20qtxmlpatterns%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%20-L%2Fusr%2Flib%20%E6%98%AF%E5%A6%82%E4%BD%95%E8%BF%9B%E5%85%A5%20LDFLAGS%20%E4%B8%AD%E4%BB%85%E9%80%82%E7%94%A8%E4%BA%8E%20qtxmlpatterns%20%E6%A8%A1%E5%9D%97%E7%9A%84%20Makefile%20%E7%9A%84%EF%BC%8C%E6%88%91%E6%90%9C%E7%B4%A2%E4%BA%86%E6%89%80%E6%9C%89%E6%96%87%E4%BB%B6%E5%92%8C%20*.pri%20%E5%92%8C%20*.pro%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E4%BB%BB%E4%BD%95%E4%B8%9C%E8%A5%BF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E4%BB%8D%E5%9C%A8%E7%83%98%E7%84%99%E5%9B%BE%E5%83%8F%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E6%9C%80%E7%BB%88%E6%98%AF%E5%90%A6%E4%BC%9A%E6%88%90%E5%8A%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3EGunnar%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎04-18-2014 07:49 AM
更新人:
