Qt 5.3.0 release on i.MX6 using fsl-community-bsp and meta-qt5
These are my notes for compiling Qt 5.3.0 release using the fsl-community-bsp and the meta-qt5 layer graciously provided by the much lauded Otavio and Martin Jansa.  My test board is the wandboard solo.  My original procedure was based on this document: Compiling Qt5.3.0-beta1 on Yocto which was in turn based on this tutorial: Building Qt5 using yocto on Wandboard - Wandboard Wiki
Steps to build:
repo init -u https://github.com/Freescale/fsl-community-bsp-platform -b daisy; repo sync
cd sources; git clone https://github.com/cetola/meta-qt5.git
**as of this commit:
https://github.com/meta-qt5/meta-qt5/commit/e9ad98bbed6065989ef4648e724f27275b35b838
the meta-qt5 official repo is now using qt 5.3.  I won't be updating my layer, and I suggesting using theirs.
add to bblayers.conf:
  ${BSPDIR}/sources/meta-openembedded/meta-ruby \
  ${BSPDIR}/sources/meta-qt5 \
add to local.conf:
DISTRO_FEATURES_remove = "x11 wayland"
PACKAGECONFIG_append_pn-qtmultimedia = " gstreamer010 "
bitbake wandboard-image-qt5
I will do my best to keep this working with the latest in daisy. Current functionality includes playing hardware accellerated video in QML.  However, examples such as multimediawidgets/player,  multimediawidgets/videowidget do not play video. Also qtwebkit/browser, qtwebkit/youtubeview qtwebkit/fanicybrowser do not support HTML5 video.
Comments welcome.
Cheers,
Stephano
コメント
Thanks for sharing this!
I'm in the process of switching back to Yocto after a brief stint working with LTIB..... I'll let you know how this works on my system.
add to local.conf:
core-image-minimal builds fine for me..
But without adding qtmodules in local.conf, am wondering whether if it would appear in image.
I have updated meta-qt5 today.
You must delete this file from meta-fsl-arm:
meta-fsl-arm/qt5-layer/recipes-qt/qt5/qtmultimedia_%.bbappend
Freescale is backporting features from qt 5.3.0 that already exist if using this layer.
Let me know if you see any more issues.
I need qtconnectivity,qtlocation and qtquickcontrols apart from qtmultimedia.
If I add below to local.conf, whether the qtmodules including above be part of final image using bitbake core-image-minimal?
am getting below error. Please let me know how to resolve this.
ERROR: qtconnectivity: md5 data is not matching for file://LICENSE.LGPL;md5=2abca611d56c23eb99943bde21c80a0d
ERROR: qtconnectivity: The new md5 checksum is 4193e7f1d47a858f6b7c0f1ee66161de
ERROR: qtconnectivity: Check if the license information has changed in /home/ramakanth/fsl-community-bsp/build/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/qtconnectivity/5.3.0-r0/git/LICENSE.LGPL to verify that the LICENSE value "GFDL-1.3 & LGPL-2.1 | GPL-3.0" remains valid
ERROR: Licensing Error: LIC_FILES_CHKSUM does not match, please fix
ERROR: Function failed: do_qa_configure
ERROR: Logfile of failure stored in: /home/ramakanth/fsl-community-bsp/build/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/qtconnectivity/5.3.0-r0/temp/log.do_configure.21742
ERROR: Task 582 (/home/ramakanth/fsl-community-bsp/sources/meta-qt5/recipes-qt/qt5/qtconnectivity_5.3.0.bb, do_configure) failed with exit code '1'
I've updated the license hash in my qt5.3 repo. Do a 'git pull' inside meta-qt5 and you should be fine now.
ERROR: qtbase-native: md5 data is not matching for file://LICENSE.LGPL;md5=4193e7f1d47a858f6b7c0f1ee66161de
ERROR: qtbase-native: The new md5 checksum is 2abca611d56c23eb99943bde21c80a0d
am getting this error after git pull in meta-qt5 and bitbake core-image-minimal.
ERROR: qtbase-native: Check if the license information has changed in /home/ramakanth/fsl-community-bsp/build/tmp/work/i686-linux/qtbase-native/5.3.0-r0/git/LICENSE.LGPL to verify that the LICENSE value "GFDL-1.3 & LGPL-2.1 | GPL-3.0" remains valid
ERROR: Logfile of failure stored in: /home/ramakanth/fsl-community-bsp/build/tmp/work/i686-linux/qtbase-native/5.3.0-r0/temp/log.do_configure.22997
ERROR: Task 1651 (/home/ramakanth/fsl-community-bsp/sources/meta-qt5/recipes-qt/qt5/qtbase-native_5.3.0.bb, do_configure) failed with exit code '1'
Seems like the license CHKSUM values are different for qtbase and qtconnectivity. I have rolled back the change I made. You may have to add a CHKSUM value explicitly for qtconnectivity.
ok thanks..
am using below local.conf.Does it creates any issues?
BB_NUMBER_THREADS ?= "${@oe.utils.cpu_count()}"
PARALLEL_MAKE ?= "-j ${@oe.utils.cpu_count()}"
MACHINE ??= 'imx6qsabreauto'
DISTRO ?= 'poky'
PACKAGE_CLASSES ?= "package_rpm"
EXTRA_IMAGE_FEATURES = "debug-tweaks"
USER_CLASSES ?= "buildstats image-mklibs image-prelink"
PATCHRESOLVE = "noop"
BB_DISKMON_DIRS = "\
    STOPTASKS,${TMPDIR},1G,100K \
    STOPTASKS,${DL_DIR},1G,100K \
    STOPTASKS,${SSTATE_DIR},1G,100K \
    ABORT,${TMPDIR},100M,1K \
    ABORT,${DL_DIR},100M,1K \
    ABORT,${SSTATE_DIR},100M,1K"
PACKAGECONFIG_pn-qemu-native = "sdl"
ASSUME_PROVIDED += "libsdl-native"
CONF_VERSION = "1"
BB_NUMBER_THREADS = '2'
PARALLEL_MAKE = '-j 2'
DL_DIR ?= "${BSPDIR}/downloads/"
ACCEPT_FSL_EULA = ""
EXTRA_IMAGE_FEATURES = "debug-tweaks ssh-server-openssh tools-profile dbg-pkgs tools-debug"
IMAGE_INSTALL_append = " \
    firmware-imx-vpu-imx6q \
    firmware-imx-vpu-imx6d \
    cpufrequtils \
    binutils \
    nano \
    gdb \
    openssh-sftp-server \
    packagegroup-fsl-gstreamer \
    packagegroup-fsl-tools-testapps \
    packagegroup-fsl-tools-benchmark \
    gstreamer \
    gst-plugins-base-app \
    gst-plugins-base \
    gst-plugins-good \
    gst-plugins-good-rtsp \
    gst-plugins-good-udp \
    gst-plugins-good-rtpmanager \
    gst-plugins-good-rtp \
    gst-plugins-good-video4linux2 \
    qtbase-fonts \
    qtbase-plugins \
    qtbase-tools \
    qtbase-examples \
    qtdeclarative \
    qtdeclarative-plugins \
    qtdeclarative-tools \
    qtdeclarative-examples \
    qtdeclarative-qmlplugins \
    qtmultimedia \
    qtmultimedia-plugins \
    qtmultimedia-examples \
    qtmultimedia-qmlplugins \
    qtlocation \
    qtlocation-plugins \
    qtlocation-qmlplugins \
    qtlocation-examples \
    qtsvg \
    qtsvg-plugins \
    qtsensors \
    qtsensors-plugins \
    qtsensors-qmlplugins \
    qtimageformats-plugins \
    qtsystems \
    qtsystems-tools \
    qtsystems-examples \
    qtsystems-qmlplugins \
    qtscript \
    qtquick1 \
    qt3d \
    qt3d-examples \
    qt3d-qmlplugins \
    qt3d-tools \
    qtconnectivity \
    qtconnectivity-examples \
    qtconnectivity-qmlplugins \
    qtserialport \
    qtquickcontrols \
    qtquickcontrols-qmlplugins \
    cinematicexperience \
    cairo pango fontconfig freetype pulseaudio dbus taglib zlib \
    alsa-lib alsa-tools alsa-state alsa-utils-alsaconf \
    tslib evtest tslib-conf tslib-tests tslib-calibrate \
    gcc g++ libgcc libgcc-dev libstdc++ libstdc++-dev libstdc++-staticdev \
PACKAGECONFIG_append_pn-qtbase = " accessibility gles2 openssl"
Could you please check as am getting same error after git pull in meta-qt5 and bitbake core-image-minimal.
ERROR: Logfile of failure stored in: /home/ramakanth/fsl-community-bsp/build/tmp/work/i686-linux/qtbase-native/5.3.0-r0/temp/log.do_configure.25371
Thanks for your great work!
I have a problem with compiling the sdk from your source. bitbake wandboard-image-qt5 worked as expected, but bitbake meta-toolchain-qt5 errored out:
WARNING: Failed to fetch URL git://qt.gitorious.org/qt/qtbase.git;branch=5.3.0, attempting MIRRORS if available
ERROR: Fetcher failure: Unable to find revision 207598fd8e69be34e8ba2c9db7720cb6003ea114 in branch 5.3.0 even from upstream
ERROR: Function failed: Fetcher failure for URL: 'git://qt.gitorious.org/qt/qtbase.git;branch=5.3.0'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/ttodorov/Work/yocto/fsl-community-bsp-image/build/tmp/work/x86_64-nativesdk-pokysdk-linux/nativesdk-qtbase/5.3.0-r1/temp/log.do_fetch.7617
ERROR: Task 1024 (/home/ttodorov/Work/yocto/fsl-community-bsp-image/sources/meta-qt5/recipes-qt/qt5/nativesdk-qtbase_5.3.0.bb, do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1473 tasks of which 1350 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
I also have similar problems with qttools:
WARNING: Failed to fetch URL git://qt.gitorious.org/qt/qttools.git;branch=5.3.0, attempting MIRRORS if available
ERROR: Fetcher failure: Unable to find revision e7b791c8bb5e64a4c786bf370b10366815af704f in branch 5.3.0 even from upstream
ERROR: Function failed: Fetcher failure for URL: 'git://qt.gitorious.org/qt/qttools.git;branch=5.3.0'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/ttodorov/Work/yocto/fsl-community-bsp-image/build/tmp/work/x86_64-nativesdk-pokysdk-linux/nativesdk-qttools/5.3.0-r0/temp/log.do_fetch.31774
ERROR: Task 1037 (/home/ttodorov/Work/yocto/fsl-community-bsp-image/sources/meta-qt5/recipes-qt/qt5/nativesdk-qttools_5.3.0.bb, do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1634 tasks of which 1583 didn't need to be rerun and 1 failed.
What I did try, is to clone the 5.3.0 branches of qtbase and qttools in a temp directory and get the hashes of the last commits for the SRCREVs, which produced errors. It did pass the previous errors, but produced quite a few patching and compiling errors. Could you please help resolve that? Or is the standard fsl toolchain enough to compile Qt 5.3.0 apps without the need to build the meta-toolchain-qt5 target?
Thanks in advance for everyone's help and input!
Todor
I've been able to get Yocto to build with Qt5.3 following your instructions but 'bitbake meta-toolchain-qt5' is giving me a small mountain of errors.
I haven't been able to cross-compile any version of Qt5.X using poky 1.6.1 either.
I think I'm going to be stuck with Qt5.2.1 for a while.
I haven't had any luck with the toolchain either, however I'm currently working on other projects.
I'll post when I get back to this, though for now we're using 5.2.1.
Thanks for sharing your work and the reply.
I'll check back some other time to see if you've made any progress.
I am currently working on other projects, so I have not had time to look at the meta-toolchain-qt5.
You will need this Qt toolchain to compile Qt5 apps, as the fsl-toolchain lacks the Qt libraries needed (and qmake).
You could cross compile Qt 5.3.0 outside of Yocto and use those libraries / qmake to compile your app. However, I am not sure which would be easier, fixing meta-toolchain-qt5 or cross compilling Qt 5.3.0 from source.  :smileyhappy:
Bob (and everyone else interested),
I progressed past the errors... Both QT 5.3.0 and the Toolchain SDK were built without problems.
Because Qt 5.3.0 was officially released and merged into the main repo, what I did was to download the fsl-community-bsp using repo, then I got Qt meta sources from the official repository on GitHub, instead of Stephano's: [git|https]://github.com/meta-qt5/meta-qt5.git. I did remove the sources/meta-fsl-arm/qt5-layer/recepies-qt/qt5/qtmultimedia_%.bbappend file, then loosly followed the intstuctions on building Qt5 from the Wandboard.org WIKI (Building Qt5 using yocto on Wandboard - Wandboard Wiki). I added both the ruby and meta-qt5 layers to bblayers.conf; skipped the openssh from the extra image features; added the whole of install_append as suggested; added the remove features line to the local.conf.
Since this was not the repo from Stephano, I did not have his wandboard-image-qt5 recipe, but building the minimal image worked for testing purposes. Maybe one day soon I will clone his repository and/or make my own wandboard image... After the minimal image was built, I had no problem with meta-toolchain-qt5 from the main repository either - it builds everything.
Todor
I also successfully built Qt 5.3.0 from the main repo (github.com/meta-qt5/meta-qt5.git) with yocto 1.6.1 for imx53qsb, but haven't tested it out yet - I am currently at work and my board is at home... Just FYI.
Nicely done!
I just saw the commit on the official repo:
That's awesome. I should look and see how the pros did it :smileywink: .
Thanks, but yours is the more important contribution! ;-)
BTW, while I was trying to fix my build using your meta-qt5 layer repo, I think I figured where the cause of the build failure is. In your sources, for the package that errors our, there are both <folder_basename> and <folder_basename-5.3.0> directories: e.g. sources/meta-qt5/recipes-qt/qt5/qttools and sources/meta-qt5/recipes-qt/qt5/qttools-5.3.0. When I compared the included patches, they are mostly 1-to-1 the same, but the build system seems to prefer the folder with the version over the generic name. Unfortunately these did not fit the source code, so the build failed. My guess is that the folders names with the version string are older and were the only one when you tested out your repository. At a later point the other ones were added to the source tree, when you synced with the master repo... Too bad I am too new and inexperienced with bitbake, so I could not find a fix on my own. Hence my (fortunately successful) try to use the master repository again.
Just a shot note for people, who want to try the master repo. When I cloned it locally, I did not checkout a specific branch as suggested by multiple websites, so no -b 5.3.0 or -b daisy when you are cloning meta-qt5! The other branches will not fit with yocto 1.6.1, I believe.
Thanks Todor. I did that.
I followed the Wandboard Wiki for building Yocto/Qt5.
Instead of checking out the version specified in the wiki, I got the master repo.
I had also added a few more packages than the ones specified in the Wandboard wiki (local.conf).... perhaps that's why I couldn't successfully run 'bitbake meta-toolchain-qt5'.
I've removed a bunch of the things that I've added in my local.conf so that it matches what's specified in the wiki. As soon as the image is built, I'll try to build the toolchain again and post my results.
Yup. Same errors....
ERROR: Command Error: exit status: 1  Output:
Applying patch add-imx6-support.patch
patching file src/plugins/plugins.pro
Hunk #1 FAILED at 6.
1 out of 1 hunk FAILED -- rejects in file src/plugins/plugins.pro
The next patch would create the file src/plugins/videonode/imx6/imx6.json,
which already exists!  Applying it anyway.
patching file src/plugins/videonode/imx6/imx6.json
Hunk #1 FAILED at 1.
1 out of 1 hunk FAILED -- rejects in file src/plugins/videonode/imx6/imx6.json
The next patch would create the file src/plugins/videonode/imx6/imx6.pro,
patching file src/plugins/videonode/imx6/imx6.pro
1 out of 1 hunk FAILED -- rejects in file src/plugins/videonode/imx6/imx6.pro
The next patch would create the file src/plugins/videonode/imx6/qsgvivantevideomaterial.cpp,
patching file src/plugins/videonode/imx6/qsgvivantevideomaterial.cpp
1 out of 1 hunk FAILED -- rejects in file src/plugins/videonode/imx6/qsgvivantevideomaterial.cpp
The next patch would create the file src/plugins/videonode/imx6/qsgvivantevideomaterial.h,
patching file src/plugins/videonode/imx6/qsgvivantevideomaterial.h
1 out of 1 hunk FAILED -- rejects in file src/plugins/videonode/imx6/qsgvivantevideomaterial.h
The next patch would create the file src/plugins/videonode/imx6/qsgvivantevideomaterialshader.cpp,
patching file src/plugins/videonode/imx6/qsgvivantevideomaterialshader.cpp
1 out of 1 hunk FAILED -- rejects in file src/plugins/videonode/imx6/qsgvivantevideomaterialshader.cpp
The next patch would create the file src/plugins/videonode/imx6/qsgvivantevideomaterialshader.h,
patching file src/plugins/videonode/imx6/qsgvivantevideomaterialshader.h
1 out of 1 hunk FAILED -- rejects in file src/plugins/videonode/imx6/qsgvivantevideomaterialshader.h
The next patch would create the file src/plugins/videonode/imx6/qsgvivantevideonode.cpp,
patching file src/plugins/videonode/imx6/qsgvivantevideonode.cpp
1 out of 1 hunk FAILED -- rejects in file src/plugins/videonode/imx6/qsgvivantevideonode.cpp
The next patch would create the file src/plugins/videonode/imx6/qsgvivantevideonode.h,
patching file src/plugins/videonode/imx6/qsgvivantevideonode.h
1 out of 1 hunk FAILED -- rejects in file src/plugins/videonode/imx6/qsgvivantevideonode.h
The next patch would create the file src/plugins/videonode/imx6/qsgvivantevideonodefactory.cpp,
patching file src/plugins/videonode/imx6/qsgvivantevideonodefactory.cpp
1 out of 1 hunk FAILED -- rejects in file src/plugins/videonode/imx6/qsgvivantevideonodefactory.cpp
The next patch would create the file src/plugins/videonode/imx6/qsgvivantevideonodefactory.h,
patching file src/plugins/videonode/imx6/qsgvivantevideonodefactory.h
1 out of 1 hunk FAILED -- rejects in file src/plugins/videonode/imx6/qsgvivantevideonodefactory.h
The next patch would create the file src/plugins/videonode/videonode.pro,
patching file src/plugins/videonode/videonode.pro
1 out of 1 hunk FAILED -- rejects in file src/plugins/videonode/videonode.pro
Patch add-imx6-support.patch does not apply (enforce with -f)
ERROR: Function failed: patch_do_patch
ERROR: Logfile of failure stored in: /home/bob/Projects/M821/Yocto/fsl-community-bsp/build/tmp/work/cortexa9hf-vfp-neon-mx6-poky-linux-gnueabi/qtmultimedia/5.3.0-r0/temp/log.do_patch.6597
ERROR: Task 759 (/home/bob/Projects/M821/Yocto/fsl-community-bsp/sources/meta-qt5/recipes-qt/qt5/qtmultimedia_5.3.0.bb, do_patch) failed with exit code '1'
Bob,
I believe you forgot to remove the file sources/meta-fsl-arm/qt5-layer/recipes-qt/qt5/qtmultimedia_%.bbappend prior to bitbaking the image. It tries to apply exactly the patch that is failing your build.
Todor
That's good info! Thanks! I'll remove that and rebuild and see what happens.
Well...it will be a couple of hours before it's done but it's already gotten further than it has before. I'm optimisitc now.
thank you Todor and Stephano!
I've tested this now and, for the most part, I'm pleased to see that it compiled just fine.
One problem I'm having is with Qt Multimedia....
Whenever I run this code
Rectangle {
        width: 1280
        height: 800
        color: "black"
        MediaPlayer {
            source: "/home/root/big_buck_bunny_720p_surround.avi"
            autoPlay: true
        VideoOutput {
            source: player
            anchors.fill: parent
I get the following error.....
defaultServiceProvider::requestService(): no service found for - "org.qt-project.qt.mediaplayer"
Anybody else encounter this and have a workaround?
I have seen that error before and have resolved it in the past by adding this line to my local.conf:
Do you already have that line? If not give that a try and let me know if it helps.
p.s. Three cheers for Big Buck Bunny!
Iam still getting the below error in qtbase when I did bitbake core-image-minimal.
ERROR: Logfile of failure stored in: /home/ramakanth/fsl-community-bsp/build/tmp/work/i686-linux/qtbase-native/5.3.0-r0/temp/log.do_configure.7527
NOTE: Tasks Summary: Attempted 3371 tasks of which 3000 didn't need to be rerun and 1 failed.
I added CHKSUM explicitly and got way with the above error. However, not able to get away with Qtquickcontrols not found in base feeds error. Perhaps, I need to try with master branch as Qt5.3 is officially integrated in main respository.
Probably the below should do the trick instead of cloning to specific branch.
repo init -u https://github.com/Freescale/fsl-community-bsp-platform -b master; repo sync
cd sources; git clone https://github.com/meta-qt5/meta-qt5.git
please change QT_MODULE_BRANCH in file meta-qt5 / recipes-qt / qt5 / qt5-5.3.0.inc from 5.3.0 to 5.3, because it changed in Qt repository.
Hip, hip hooray! For big buck bunny!
Now I'm battling THIS error....
Error: /fsl-community-bsp/sources/poky/meta/recipes-multimedia/alsa/alsa-utils_1.0.27.2.bb, do_configure) failed with exit code '1'
Am I missing a package? Is this just a bug with the 'master' branch?
I had the same issue. I could not figure out the cause, but I know how to go past it:
The alsa-utils use ncurses for the mixer and some such, and ncurses is built before that, but for some reason the libs are overwritten later with the SDK version from the host (which is Intel and not ARM) so the configure script cannot link against them anymore.
When the bitbake command fails, just do a “bitbake –c build ncurses” again, and when that is done repeat “bitbake <your-target>” or “bitbake –c cleanall alsa-utils && bitbake –c build alsa-utils; bitbake <your-target>” and it will continue from where it stopped before.
Thanks Todor!
What's weird is, I swear, it seems like it builds just fine sometimes and other times it decides to generate this alsa error.
It looks like I'm past this error now.
Thank you very much for the tip.
This combination of bitbake commands  (appears) to have gotten me past this point.
bitbake -c cleanall ncurses
bitbake -c cleanall alsa-utils
bitbake -c build ncurses
bitbake -c build alsa-utils
then
bitbake <your target>
Thanks again sir!
I tried with below but still getting ERROR: qtquickcontrols not found in the base feeds. Is there any solution for the same?
cd sources; git clone -b master https://github.com/meta-qt5/meta-qt5.git
Added even PACKAGECONFIG_append_pn-qtbase = "accessibility gles2 openssl" but no luck.
Stephano,
Now I'm stuck again.
Been trying to debug qml video and neither of the two videos I have want to play! I decided to just use gstreamer directly to debug this.
Whenever I try to play Big Buck Bunny, I get the following error...
'Missing element: AC-3 (ATSC A/52) decoder'
I launch it with the following command...
gst-launch playbin2 uri=file:///home/root/big_buck_bunny_720p_surround.avi
I can see that the decoder for that is available in the gst-plugins-ugly plugin..... when I try to add gst-plugins-ugly to my local.conf I get an error saying that nothing provides for it....
Any ideas on what I should do next?
Thanks!
-Bob
I've found a disconnect here.....
The problem I've been having with videos is because I didn't have vpu_fw_imx6d.bin in the /lib/firmware/vpu directory...... I didn't even have a /lib/fiirmware/vpu directory in my Yocto system.
I found vpu_fw_imx6d.bin in one of my android build directories that I was able to use and then I was able to play Big Buck Bunny.
Digging into this.....
I've got the vpu_fw_imx6d.bin to build and install into the correct directory!
Just needed to add these lines to my local.conf
I've been working with core-image-minimal..... I guess that file doesn't get built unless specified.
I'm back to battling QML video...... as far as I can tell, I'll need to write my own C++ wrapper to play video in QML. I keep getting the following error...
GStreamer; Unable to play - ""
Error: "No URI set"
It's like Qt QML doesn't want to pass the filename and path to gstreamer.
Thanks again for the help!
Please let me know if there is a solution for the above QtQuickcontrols error.
I tried with PACKAGECONFIG_append_pn-qtbase = " accessibility" a suggested in other forum but still the problem exists.
Please let me know if we need to build QtQuickcontrols only through source but not through bitbake to resolve the issue
"QtQuickcontrols not found in base feeds"
As i wrote i my config at https://community.freescale.com/docs/DOC-100419 I figured out that one has to add
to local.conf in IMAGE_INSTALL_append
to get the QuickControls added to the image.
I tried to switch from 5.3.0 beta to 5.3.0 using master branch. But when I bitbake core-image-minimal, it gives below error in qtmultimedia.
/home/ramakanth/Yocto/build/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/qtmultimedia/5.3.0+gitAUTOINC+b99a4b3025-r0/git/src/gsttools/gstvideoconnector.c:467:32: error: 'GST_PAD_PROBE_DROP' undeclared (first use in this function)
Am I missing anything?
Thanks and Regards,
Ramakanth
Looks like GST_CHECK_VERSION(1,0,0) working wrong.
Adding gstreamer1.0 support break qtmultimedia recipe. If you don't use gstreamer1.0 you must replace your meta-qt5/recipes-qt/qt5/qtmultimedia.inc by this code (and rebuild)
require qt5.inc
DEPENDS += "qtdeclarative alsa-lib"
PACKAGECONFIG ??= ""
PACKAGECONFIG[openal] = ",,openal-soft"
PACKAGECONFIG[gstreamer010] = ",,gstreamer gst-plugins-base"
do_configure_prepend() {
# disable openal test if it isn't enabled by PACKAGECONFIG
sed -i 's/^qtCompileTest(openal)/OE_OPENAL_ENABLED:qtCompileTest(openal)/g' ${S}/qtmultimedia.pro
# disable gstreamer-0.10 test if it isn't enabled by PACKAGECONFIG
sed -i 's/^\( *\)qtCompileTest(gstreamer) {/\1OE_GSTREAMER010_ENABLED:qtCompileTest(gstreamer) {/g' ${S}/qtmultimedia.pro
EXTRA_QMAKEVARS_PRE += "${@base_contains('PACKAGECONFIG', 'openal', 'CONFIG+=OE_OPENAL_ENABLED', '', d)}"
EXTRA_QMAKEVARS_PRE += "${@base_contains('PACKAGECONFIG', 'gstreamer010', 'CONFIG+=OE_GSTREAMER010_ENABLED', '', d)}"
# older copyright year than what e.g. qtbase is using now
LIC_FILES_CHKSUM = "file://LICENSE.LGPL;md5=4193e7f1d47a858f6b7c0f1ee66161de \
                    file://LICENSE.GPL;md5=d32239bcb673463ab874e80d47fae504 \
                    file://LGPL_EXCEPTION.txt;md5=0145c4d1b6f96a661c2c139dfb268fb6 \
                    file://LICENSE.FDL;md5=6d9f2a9af4c8b8c3c769f6cc1b6aaf7e"
For Qt5.2 and Qt5.3 i have problem when playing video. I use Video, MediaPlayer items in Qml. Video file played without problem. but if i use stop() or seek method everything hangs. Pause() method works fine. did you have problems like that?
Am sorry for the delayed reply.
Iam unable to make my application work due to dependencies on graphicaleffects and qtquickcontrols.
If add entries of qtgraphicaleffects and qtquickcontrols in local.conf, it throws error.
qtgraphicaleffects and qtquickcontrols are not found in base feeds.
Did anyone face these issues? Please let me know how to overcome the same.
    qtgraphicaleffects-qmlplugins \
to get the qtgraphicaleffects added to the image. Thanks Gunnar Roth for the hint.
When I tried to play audio, it throws error "Unable to create connection to pulse audio context". If I use dbus service UDisks, it gives error
response is: QDBusMessage(type=Error, service="", error name="org.freedesktop.DBus.Error.ServiceUnknown", error message="The name org.freedesktop.UDisks was not provided by any .service files", signature="", contents=() )
When I tried to play audio,Please let me know if anyone has experienced these issues with latest Qt5.3.
As I found that udisks service is not available, Please let me know how can I add udisks and their dependent packages in local.conf.
what would be the entry for udisks in local.conf?
No I didnot experience these problems. Play(), Pause() or Seek() works fine but audio is not heard while playing video.
Any reasons for this?
If I use stop() or seek() method, everything hangs though audio is being heard with Play().
%3CLINGO-SUB%20id%3D%22lingo-sub-1099303%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099303%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E3%80%81%E9%9D%9E%E5%B8%B8%E3%81%AB%E7%A7%B0%E8%B3%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BOtavio%E3%81%A8Martin%20Jansa%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%80%81fsl-community-bsp%E3%81%A8%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Emeta-qt5%3C%2FA%3E%20%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6Qt%205.3.0%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E7%A7%81%E3%81%AE%E3%83%A1%E3%83%A2%E3%81%A7%E3%81%99%E3%80%82%20%E7%A7%81%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%20%3CA%20href%3D%22http%3A%2F%2Fwww.wandboard.org%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%83%AF%E3%83%B3%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89%E3%82%BD%E3%83%AD%3C%2FA%3E%E3%81%A7%E3%81%99%E3%80%82%20%E7%A7%81%E3%81%AE%E5%85%83%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100419%22%20target%3D%22_blank%22%3EYocto%20%E3%81%A7%E3%81%AE%20Qt5.3.0-beta1%20%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%3C%2FA%3E%20%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%3A%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20data-content-finding%3D%22Community%22%20href%3D%22http%3A%2F%2Fwiki.wandboard.org%2Findex.php%2FBuilding_Qt5_using_yocto_on_Wandboard%22%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EWandboard%20%E3%81%A7%20yocto%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20Qt5%20%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%20-%20Wandboard%20Wiki%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E6%89%8B%E9%A0%86%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%20init%20-u%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%22%20style%3D%22color%3A%20%234183c4%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%3C%2FA%3E-b%E3%83%87%E3%82%A4%E3%82%B8%E3%83%BC%3B%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E5%90%8C%E6%9C%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECD%E3%82%BD%E3%83%BC%E3%82%B9%3Bgit%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fcetola%2Fmeta-qt5.git%22%20style%3D%22color%3A%20%234183c4%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fcetola%2Fmeta-qt5.git%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E**%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E3%81%AE%E6%99%82%E7%82%B9%E3%81%A7%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5%2Fcommit%2Fe9ad98bbed6065989ef4648e724f27275b35b838%22%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5%2Fcommit%2Fe9ad98bbed6065989ef4648e724f27275b35b838%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5%2Fcommit%2Fe9ad98bbed6065989ef4648e724f27275b35b838%3C%2FA%3E%3C%2FP%3E%3CP%3EMeta-QT5%20%E3%81%AE%E5%85%AC%E5%BC%8F%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AF%20Qt%205.3%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AF%E8%87%AA%E5%88%86%E3%81%AE%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E7%A7%81%E3%81%AF%E5%BD%BC%E3%82%89%E3%81%AE%E3%82%82%E3%81%AE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ebblayers.conf%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%20%24%7BBSPDIR%7D%2Fsources%2Fmeta-openembedded%2Fmeta-ruby%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%24%7BBSPDIR%7D%2Fsources%2Fmeta-qt5%20%5C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Elocal.conf%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3EDISTRO_FEATURES_remove%20%3D%20%22x11%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%83%A9%E3%83%B3%E3%83%89%22%3C%2FP%3E%3CP%3EPACKAGECONFIG_append_pn-QTmultimedia%20%3D%20%22%20gstreamer010%20%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBitbake%E3%83%AF%E3%83%B3%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89-%E7%94%BB%E5%83%8F-QT5%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%82%8C%E3%82%92%E6%9C%80%E6%96%B0%E3%81%AE%E3%83%87%E3%82%A4%E3%82%B8%E3%83%BC%E3%81%A7%E6%A9%9F%E8%83%BD%E3%81%95%E3%81%9B%E7%B6%9A%E3%81%91%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E6%9C%80%E5%96%84%E3%82%92%E5%B0%BD%E3%81%8F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%AB%E3%81%AF%E3%80%81QML%E3%81%A7%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%93%E3%83%87%E3%82%AA%E3%81%AE%E5%86%8D%E7%94%9F%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81multimediawidgets%2Fplayer%E3%80%81multimediawidgets%2Fvideowidget%20%E3%81%AA%E3%81%A9%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E3%81%AF%E5%86%8D%E7%94%9F%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81qtwebkit%2Fbrowser%E3%80%81qtwebkit%2Fyoutubeview%E3%80%81qtwebkit%2Ffanicybrowser%E3%81%AFHTML5%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E5%A4%A7%E6%AD%93%E8%BF%8E%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A7%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3EStephano%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%9D%E3%82%8C%E3%81%BB%E3%81%A9%E9%AB%98%E3%81%84%E3%83%AC%E3%83%99%E3%83%AB%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%20Qt%205.8%2F5.11%2F5.12%20%E3%82%92%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E4%B8%8A%E3%81%AE%20IMX6%20%E3%81%A8%E4%B8%80%E7%B7%92%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81Qt%20%E3%82%92%E9%81%A9%E5%88%87%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81Yocto%20%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E8%A8%80%E3%81%86%E3%81%BE%E3%81%A7%E3%82%82%E3%81%AA%E3%81%8F%E3%80%81%E3%81%9D%E3%82%8C%E8%87%AA%E4%BD%93%E3%81%8C%E5%8A%AA%E5%8A%9B%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E5%80%8B%E4%BA%BA%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81Yocto%E3%82%92%E8%90%BD%E3%81%A8%E3%81%99%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Qt%E3%82%92%E9%81%A9%E5%88%87%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E5%A4%A7%E3%81%8D%E3%81%AA%E5%8A%AA%E5%8A%9B%E3%80%81%E9%81%A9%E5%88%87%E3%81%AAHW%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E5%88%A5%E3%81%AE%E5%8A%AA%E5%8A%9B%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6Vivante%E3%81%A7%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%82%92%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E7%B6%9A%E3%81%91%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E5%88%A5%E3%81%AE%E5%8A%AA%E5%8A%9B%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EQT%205.5%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8Fyocto%20project%202.0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E4%BB%8A%E3%80%81QT%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%925.8%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%82%84%E3%81%A3%E3%81%A6%E3%81%99%E3%82%8B%E3%81%AE%3F%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E3%81%94%E6%8F%90%E6%A1%88%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Emeta-qt%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%A7rocko%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%20margin%3A%205px%2015px%200px%200px%3B%20padding-bottom%3A%205px%3B%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20dir%3D%22ltr%22%3E%3CDIV%3E%3CEM%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Aqtbase-5.9.2%20%2B%20gitAUTOINC%2Bec16ba393b-r0%20do_prepare_recipe_sysroot%3A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%2Fusr%2Flib%2Fpkgconfig%2Fwayland-egl.pc%E3%81%AFmesa%E3%81%A8imx-gpu-viv%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%80%81%E4%B8%AD%E6%AD%A2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FEM%3E%3C%2FDIV%3E%3CDIV%3E%3CEM%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Aqtbase-5.9.2%20%2B%20gitAUTOINC%20%2B%20ec16ba393b-r0%20do_prepare_recipe_sysroot%3A%E9%96%A2%E6%95%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3Aextend_recipe_sysroot%3C%2FEM%3E%3C%2FDIV%3E%3CDIV%3E%3CEM%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%9A%9C%E5%AE%B3%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%2Fhome%2Fsandeep%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-neon-mx6qdl-poky-linux-gnueabi%2Fqtbase%2F5.9.2%2BgitAUTOINC%2Bec16ba393b-r0%2Ftemp%2Flog.do_prepare_recipe_sysroot.14279%3C%2FEM%3E%3C%2FDIV%3E%3CDIV%3E%3CEM%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF(%2Fhome%2Fsandeep%2Ffsl-community-bsp%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fqtbase_git.bb%3Ado_prepare_recipe_sysroot)%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8C1%E3%80%8D%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FEM%3E%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%22%3Ebblayers.conf%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%26nbsp%3B%20%24%7BBSPDIR%7D%2Fsources%2Fmeta-openembedded%2Fmeta-ruby%20%5C%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%26nbsp%3B%20%24%7BBSPDIR%7D%2Fsources%2Fmeta-qt5%20%5C%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%22%3Elocal.conf%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%22%3EDISTRO_FEATURES_remove%20%3D%20%22x11%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%83%A9%E3%83%B3%E3%83%89%22%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%22%3EPACKAGECONFIG_append_pn-QTmultimedia%20%3D%20%22%20gstreamer010%20%22%3C%2FP%3E%3C%2FDIV%3E%3CDIV%3E%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3Ebitbake%E3%83%A1%E3%82%BF%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3-qt%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81sysroot%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9A%E3%80%81Qt%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E4%BD%95%E3%81%8B%E5%8A%A9%E3%81%91%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi!%26nbsp%3B%20Stephano%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%A1%E3%82%87%E3%81%86%E3%81%A9%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%A1%E3%83%A2%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81Yocto%203.14.28%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6imx6solosabresd%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6fsl-community-bsp%E3%81%AEQT5.3%E3%81%A7%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%20%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%7Cmake%3A%20***%20%5Bsub-src-make_first%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%202%3C%2FP%3E%3CP%3E%7C%E3%82%A8%E3%83%A9%E3%83%BC%3A%20oe_runmake%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%7C%E8%AD%A6%E5%91%8A%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8B%E3%82%89%E3%82%B3%E3%83%BC%E3%83%89%201%20%E3%82%92%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%7C%E3%82%A8%E3%83%A9%E3%83%BC%3A%E6%A9%9F%E8%83%BD%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3Ado_compile(%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%2Fhome%2Fradiant%2Ffsl-community-bsp%2Fsolo%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-poky-linux-gnueabi%2Fqtmultimedia%2F5.3.2-r0%2Ftemp%2Flog.do_compile.11611%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF793(%2F%20home%20%2F%20radiant%20%2F%20fsl-community-bsp%20%2F%20sources%20%2F%20meta-qt5%20%2F%20recipes-qt%20%2F%20qt5%20%2F%20qtmultimedia_5.3.2.bb%E3%80%81do_compile)%E3%81%AF%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8C1%E3%80%8D%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81qtmultimedia%E3%81%AEbb%E3%81%BE%E3%81%9F%E3%81%AFinc%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%B4%E3%82%A1%E3%83%B3%E3%82%B5%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099357%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099357%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EQt%E3%81%AF%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E5%8B%95%E4%BD%9C%E3%82%92%E5%A6%A8%E3%81%92%E3%82%8BEGL%E6%A7%8B%E6%88%90%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%20imx6%20%E3%81%A8%20yocto%20%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%AF%E3%80%81%E8%BF%94%E3%81%95%E3%82%8C%E3%81%9F%E8%A8%AD%E5%AE%9A%20ID%20%E3%82%92%E3%83%8F%E3%83%BC%E3%83%89%E3%82%B3%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%20Qt%20%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%81%93%E3%81%93%E3%81%A7%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fbugreports.qt.io%2Fbrowse%2FQTBUG-44290%22%20title%3D%22https%3A%2F%2Fbugreports.qt.io%2Fbrowse%2FQTBUG-44290%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%5BQTBUG-44290%5DIMX6%20-%20EGLConfig%20%E3%81%A8%20X%20%E3%81%AE%E4%B8%80%E8%87%B4%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81Visual%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E6%B7%B1%E5%BA%A6%E3%81%8C%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E3%82%A2%E3%83%97%E3%83%AA%20-%20Qt%20Bug%20Tracker%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%90%E3%82%B0%E4%BF%AE%E6%AD%A3%E3%81%AF%20Qt%205.5%20%E3%82%92%E5%AF%BE%E8%B1%A1%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099356%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099356%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F(BoundaryDevices%20Nitrogen6x%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8)%E3%80%82Qt5%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6Ubuntu%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AB%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81SSH%E7%B5%8C%E7%94%B1%E3%81%A7Qt5%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%82%B8%E3%82%AA%E3%82%B3%E3%83%BC%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%A8%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AB%E3%81%AF%E3%80%81qtlocation%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AEmap%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%82%92geoservices%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3(nokia%E3%81%A8osm%E3%81%AE%E4%B8%A1%E6%96%B9%E3%82%92%E4%BD%BF%E7%94%A8)%E3%81%A8%E3%81%A8%E3%82%82%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AFYocto%20meta-qt5%20recepie%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%20-%20%E5%87%BA%E5%8A%9B%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB%E3%81%AF%2F%20usr%20%2F%20lib%20%2F%20qt5%20%2F%20plugins%20%2F%20geoservices%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82dizzy%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%8B%E3%82%89qtlocation%E3%80%81qtlocation-examples%E3%80%81qtlocation-plugins%E3%80%81qtlocation-qmlplugins%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9Fcore-image-base%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97IMAGE_INSTALL_append%E3%80%82%3C%2FP%3E%3CP%3E%E8%AA%B0%E3%81%8B%E3%81%8Cqtlocation%E3%81%AE%E3%82%B8%E3%82%AA%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82QRC%E3%81%AB%E5%9F%8B%E3%82%81%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9FQML%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8B%E3%82%89%E3%83%93%E3%83%87%E3%82%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AF%E3%80%81%E3%80%8C%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%91%E3%82%B9%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E5%8D%81%E5%88%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%A0%E3%81%8B%E3%82%89%E7%A7%81%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%81%93%E3%81%A8%E3%82%92%E3%81%97%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%83%97%E3%83%AC%E3%83%BC%E3%83%A4%E3%83%BC%20%7B%3C%2FP%3E%3CP%3EID%3AmediaPlayer2%3C%2FP%3E%3CP%3E%E5%87%BA%E5%85%B8%3A%E3%80%8Cfile%3A%2F%2F%2Fhome%2Fuser%2Fbigbuck1080.mov%E3%80%8D%3C%2FP%3E%3CP%3E%E8%87%AA%E5%8B%95%E5%86%8D%E7%94%9F%3A%20true%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%83%97%E3%83%AC%E3%83%BC%E3%83%A4%E3%83%BC%20%7B%3C%2FP%3E%3CP%3EID%3AmediaPlayer2%3C%2FP%3E%3CP%3E%E5%87%BA%E5%85%B8%3A%20%22%2Fhome%2Fuser%2Fbigbuck1080.mov%22%3C%2FP%3E%3CP%3E%E8%87%AA%E5%8B%95%E5%86%8D%E7%94%9F%3A%20true%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%9C%E3%83%96%E3%80%81%E7%A7%81%E3%81%AF%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%AB%E5%9B%BA%E5%9F%B7%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%22GStreamer%3B%E5%86%8D%E7%94%9F%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20-%20%22%22%20%2F%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%22URI%20%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%22...%E3%81%9D%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099353%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099353%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Estop()%E3%81%BE%E3%81%9F%E3%81%AFseek()%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81Play()%E3%81%A7%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%8C%E8%81%9E%E3%81%93%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099352%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099352%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%84%E3%81%84%E3%81%88%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82Play()%E3%80%81Pause()%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AFSeek()%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E3%81%AE%E5%86%8D%E7%94%9F%E4%B8%AD%E3%81%AB%E9%9F%B3%E5%A3%B0%E3%81%8C%E8%81%9E%E3%81%93%E3%81%88%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E4%BD%95%E3%81%8B%E7%90%86%E7%94%B1%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099351%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099351%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Eudisks%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%8C%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81local.conf%E3%81%ABudisks%E3%81%A8%E3%81%9D%E3%81%AE%E4%BE%9D%E5%AD%98%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3Elocal.conf%20%E3%81%AE%20udisks%20%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%92%E5%86%8D%E7%94%9F%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%80%8C%E3%83%91%E3%83%AB%E3%82%B9%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E3%82%B9%E3%83%AD%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82dbus%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9UDisks%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%20%3C%2FP%3E%3CDIV%20class%3D%22rpHighlightAllClass%20_rp_O3%20rpHighlightBodyClass%22%3E%3CDIV%3E%3CDIV%3E%3CDIV%20style%3D%22background-color%3A%20white%3B%22%3E%3CDIV%20style%3D%22text-indent%3A%200%3B%20margin%3A%200%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23be1414%3B%20font-size%3A%209pt%3B%20font-family%3A%20monospace%3B%22%3E%E5%BF%9C%E7%AD%94%3A%20QDBusMessage(type%3DError%2C%20service%3D%22%22%2C%20error%20name%3D%22org.freedesktop.DBus.Error.ServiceUnknown%22%2C%20error%20message%3D%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23be1414%3B%20font-size%3A%209pt%3B%20font-family%3A%20monospace%3B%22%3E%3CSTRONG%3EThe%20name%20org.freedesktop.UDisks%20was%20not%20provided%20by%20any%20.service%20files%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23be1414%3B%20font-size%3A%209pt%3B%20font-family%3A%20monospace%3B%22%3E%22%2C%20signature%3D%22%22%2C%20contents%3D()%20)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22text-indent%3A%200%3B%20margin%3A%200%3B%22%3E%3CBR%20%2F%3E%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%92%E5%86%8D%E7%94%9F%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%80%81%E6%9C%80%E6%96%B0%E3%81%AEQt5.3%E3%81%A7%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E6%96%B9%E3%81%8C%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FDIV%3E%3CDIV%20style%3D%22text-indent%3A%200%3B%20margin%3A%200%3B%22%3E%20%3C%2FDIV%3E%3CDIV%20style%3D%22text-indent%3A%200%3B%20margin%3A%200%3B%22%3E%20%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF1%E3%81%A4%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%89%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eqtgraphicaleffects-qmlplugins%20%5C%3C%2FP%3E%3CP%3E%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EIMAGE_INSTALL_append%3C%2FSPAN%3E%20%E3%81%AE%20local.conf%20%E3%81%B8%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E7%94%BB%E5%83%8F%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%9FQtgraphicalEffects%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%92%E3%83%B3%E3%83%88%E3%82%92%E3%81%8F%E3%82%8C%E3%81%9F%20%3CSTRONG%3E%3CEM%3EGunnar%20Roth%3C%2FEM%3E%3C%2FSTRONG%3E%20%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%8C%E9%81%85%E3%81%8F%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFgraphicaleffects%E3%81%A8qtquickcontrols%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3Elocal.conf%20%E3%81%AB%20qtgraphicaleffects%20%E3%81%A8%20qtquickcontrols%20%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E3%82%B9%E3%83%AD%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EQtgraphicalEffects%20%E3%81%A8%20QtQuickControls%20%E3%81%AF%E3%83%99%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A3%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%9F%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E5%90%8C%E3%81%98%E3%81%93%E3%81%A8%E3%82%92%E5%85%8B%E6%9C%8D%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EQt5.2%20%E3%81%A8%20Qt5.3%20%E3%81%A7%E3%83%93%E3%83%87%E3%82%AA%E3%81%AE%E5%86%8D%E7%94%9F%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AFQml%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%80%81MediaPlayer%E3%82%A2%E3%82%A4%E3%83%86%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%87%E3%82%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%86%8D%E7%94%9F%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%20stop()%E3%81%BE%E3%81%9F%E3%81%AFseek%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82Pause()%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%93%E3%81%AA%E3%81%8A%E6%82%A9%E3%81%BF%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099346%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099346%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSTRONG%3Egstreamer1.0%3C%2FSTRONG%3E%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E4%B8%AD%E6%96%AD%20qtmultimedia%20%E3%83%AC%E3%82%B7%E3%83%94%E3%81%AE%E8%BF%BD%E5%8A%A0%E3%80%82%3CSTRONG%3Egstreamer1.0%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E3%82%8F%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%3CSTRONG%3Emeta-qt5%2Frecipes-qt%2Fqt5%2Fqtmultimedia.inc%3C%2FSTRONG%3E%20%E3%82%92%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20(%E3%81%9D%E3%81%97%E3%81%A6%E5%86%8D%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eqt5.inc%E3%81%8C%E5%BF%85%E8%A6%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BE%9D%E5%AD%98%20%2B%3D%20%22qtdeclarative%20alsa-lib%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPACKAGECONFIG%20%3F%3F%3D%20%22%22%3C%2FP%3E%3CP%3EPACKAGECONFIG%5Bopenal%5D%20%3D%20%22%2C%2Copenal-soft%22%3C%2FP%3E%3CP%3EPACKAGECONFIG%5Bgstreamer010%5D%20%3D%20%22%2C%2Cgstreamer%20gst-plugins-base%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Edo_configure_prepend()%20%7B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%23%20openal%20test%20%E3%81%8C%20PACKAGECONFIG%20%E3%81%A7%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%20%3C%2FP%3E%3CP%3Esed%20-i%20's%2F%5EqtCompileTest(openal)%2FOE_OPENAL_ENABLED%3AqtCompileTest(openal)%2Fg'%20%24%7BS%7D%2Fqtmultimedia.pro%20%3C%2FP%3E%3CP%3E%23%20gstreamer-0.10%20test%E3%81%8CPACKAGECONFIG%E3%81%A7%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%20%3C%2FP%3E%3CP%3Esed%20-i%20's%2F%5E%5C(%20*%5C)qtCompileTest(gstreamer)%20%7B%2F%5C1OE_GSTREAMER010_ENABLED%3AqtCompileTest(gstreamer)%20%7B%2Fg'%20%24%7BS%7D%2Fqtmultimedia.pro%20%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EEXTRA_QMAKEVARS_PRE%20%2B%3D%20%22%24%7B%40base_contains('PACKAGECONFIG'%2C%20'openal'%2C%20'CONFIG%2B%3DOE_OPENAL_ENABLED'%2C%20''%2C%20d)%7D%22%3C%2FP%3E%3CP%3EEXTRA_QMAKEVARS_PRE%20%2B%3D%20%22%24%7B%40base_contains('PACKAGECONFIG'%2C%20'gstreamer010'%2C%20'CONFIG%2B%3DOE_GSTREAMER010_ENABLED'%2C%20''%2C%20d)%7D%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%20%E8%91%97%E4%BD%9C%E6%A8%A9%E3%81%AE%E5%B9%B4%E3%81%8C%E4%BD%95%E3%82%88%E3%82%8A%E5%8F%A4%E3%81%84%20(%E4%BE%8B%3AQtbase%E3%81%8C%E7%8F%BE%E5%9C%A8%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%82%E3%81%AE%3C%2FP%3E%3CP%3ELIC_FILES_CHKSUM%20%3D%20%22file%3A%2F%2FLICENSE%E3%80%82LGPL%E3%81%AE%3Bmd5%3D4193e7f1d47a858f6b7c0f1ee66161de%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20file%3A%2F%2FLICENSE.GPL%3Bmd5%3Dd32239bcb673463ab874e80d47fae504%20%5C%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%2F%2FLGPL_EXCEPTION.txt%3Bmd5%3D0145c4d1b6f96a661c2c139dfb268fb6%20%5C%3C%2FP%3E%3CP%3Efile%3A%2F%2FLICENSE%E3%80%82FDL%E3%81%AE%3Bmd5%3D6d9f2a9af4c8b8c3c769f6cc1b6aaf7e%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EGST_CHECK_VERSION(1%2C0%2C0)%20%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A65.3.0%E3%83%99%E3%83%BC%E3%82%BF%E3%81%8B%E3%82%895.3.0%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81core-image-minimal%E3%82%92%E3%83%93%E3%83%83%E3%83%88%E3%83%99%E3%82%A4%E3%82%AF%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81qtmultimedia%E3%81%A7%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2Fhome%2Framakanth%2FYocto%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-poky-linux-gnueabi%2Fqtmultimedia%2F5.3.0%2BgitAUTOINC%2Bb99a4b3025-r0%2Fgit%2Fsrc%2Fgsttools%2Fgstvideoconnector.c%3A467%3A32%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20'GST_PAD_PROBE_DROP'%20%E3%81%8C%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%A7%E6%9C%80%E5%88%9D%E3%81%AB%E4%BD%BF%E7%94%A8)%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8B%E8%B6%B3%E3%82%8A%E3%81%AA%E3%81%84%E3%82%82%E3%81%AE%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%A9%E3%83%9E%E3%82%AB%E3%83%B3%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099343%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099343%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%8C%E6%9B%B8%E3%81%84%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100419%22%20target%3D%22_blank%22%3E%E7%A7%81%E3%81%AF%20https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-100419%3C%2FA%3E%20%E3%81%A7%E7%A7%81%E3%81%AE%E6%A7%8B%E6%88%90%E7%A7%81%E3%81%AF1%E3%81%A4%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%89%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eqtquickcontrols-qmlplugins%20%5C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EIMAGE_INSTALL_append%3C%2FSPAN%3E%20%E3%81%AE%20local.conf%20%E3%81%B8%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%80%81QuickControls%20%E3%82%92%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CBR%20%2F%3E%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6QtQuickcontrols%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81bitbake%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E3%80%8CQtQuickcontrols%20%E3%81%8C%E3%83%99%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A3%E3%83%BC%E3%83%89%E3%81%AB%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%8D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AEQtQuickcontrols%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AE%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%E3%81%A7%E6%8F%90%E6%A1%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BPACKAGECONFIG_append_pn-qtbase%20%3D%20%22accessibility%22%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%AF%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8Bvpu_fw_imx6d.bin%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E8%A1%8C%E3%82%92%E7%A7%81%E3%81%AElocal.conf%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EIMAGE_INSTALL_append%20%3D%20%22%20%5C%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20firmware-imx-vpu-imx6d%20%5C%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%22%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFcore-image-minimal%E3%81%A7%E4%BD%9C%E6%A5%AD%E3%81%97%E3%81%A6%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F.....%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%E3%80%81%E3%81%9D%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EQML%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%AE%E6%88%A6%E3%81%84%E3%81%AB%E6%88%BB%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F......%E7%A7%81%E3%81%8C%E7%9F%A5%E3%82%8B%E9%99%90%E3%82%8A%E3%80%81QML%E3%81%A7%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E5%86%8D%E7%94%9F%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E7%8B%AC%E8%87%AA%E3%81%AEC%20%2B%2B%E3%83%A9%E3%83%83%E3%83%91%E3%83%BC%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Monospace'%3B%20font-size%3A%209pt%3B%20color%3A%20%23be1414%3B%22%3EGStreamer%3B%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20-%20%22%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Monospace'%3B%20font-size%3A%209pt%3B%20color%3A%20%23be1414%3B%22%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%22URI%20%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EQt%20QML%E3%81%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%E3%81%A8%E3%83%91%E3%82%B9%E3%82%92gstreamer%E3%81%AB%E6%B8%A1%E3%81%97%E3%81%9F%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%93%E3%81%A7%E6%96%AD%E7%B5%B6%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F.....%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E3%83%93%E3%83%87%E3%82%AA%E3%81%A7%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%2F%20lib%20%2F%20firmware%20%2F%20vpu%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%ABvpu_fw_imx6d.bin%E3%81%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99......Yocto%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E3%81%AF%2Flib%2Ffiirmware%2Fvpu%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%95%E3%81%88%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E7%A7%81%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%9F%E7%A7%81%E3%81%AEAndroid%E3%83%93%E3%83%AB%E3%83%89%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AE1%E3%81%A4%E3%81%A7vpu_fw_imx6d.bin%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81Big%20Buck%20Bunny%E3%82%92%E3%83%97%E3%83%AC%E3%82%A4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E6%8E%98%E3%82%8A%E4%B8%8B%E3%81%92%E3%81%BE%E3%81%99.....%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099338%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099338%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EStephano%2C%3C%2FP%3E%3CP%3E%E4%BB%8A%E3%80%81%E7%A7%81%E3%81%AF%E5%86%8D%E3%81%B3%E7%AB%8B%E3%81%A1%E5%BE%80%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Eqml%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82%E5%86%8D%E7%94%9F%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81gstreamer%E3%82%92%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBig%20Buck%20Bunny%E3%82%92%E3%83%97%E3%83%AC%E3%82%A4%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3E'%3CSTRONG%3EMissing%20element%3A%20AC-3%20(ATSC%20A%2F52)%20decoder%3C%2FSTRONG%3E'%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3E%3CSTRONG%3Egst-launch%20playbin2%20uri%3Dfile%3A%2F%2F%2Fhome%2Froot%2Fbig_buck_bunny_720p_surround.avi%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E3%81%8Cgst-plugins-ugly%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%A7%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99.....gst-plugins-ugly%E3%82%92local.conf%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BD%95%E3%82%82%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E4%BD%95%E3%82%92%E3%81%99%E3%81%B9%E3%81%8D%E3%81%8B%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E4%BD%95%E3%81%8B%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3E-%E3%83%9C%E3%83%96%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%3A%E3%83%99%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A3%E3%83%BC%E3%83%89%E3%81%ABqtquickcontrols%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%90%8C%E3%81%98%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%20init%20-u%20%3CA%20class%3D%22jive-link-external-small%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%3C%2FA%3E-b%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%3B%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E5%90%8C%E6%9C%9F%3C%2FP%3E%3CP%3E%20CD%E3%82%BD%E3%83%BC%E3%82%B9%3Bgit%20clone%20-b%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%20%3CA%20class%3D%22jive-link-external-small%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5.git%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5.git%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPACKAGECONFIG_append_pn-qtbase%20%3D%20%22accessibility%20gles2%20openssl%22%20%E3%82%82%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099336%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099336%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%83%88%E3%83%BC%E3%83%AB!%3C%2FP%3E%3CP%3E%E5%A5%87%E5%A6%99%E3%81%AA%E3%81%AE%E3%81%AF%E3%80%81%E8%AA%93%E3%81%A3%E3%81%A6%E8%A8%80%E3%81%86%E3%81%A8%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E6%A7%8B%E7%AF%89%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E3%81%8D%E3%82%82%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%81%93%E3%81%AEalsa%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%B1%BA%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%82%82%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E4%BB%8A%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E9%81%8E%E3%81%8E%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%92%E3%83%B3%E3%83%88%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E8%AA%A0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AEbitbake%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B(%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%82%8B)%E3%81%AF%E3%80%81%E7%A7%81%E3%82%92%E3%81%93%E3%81%AE%E6%99%82%E7%82%B9%E3%82%92%E4%B9%97%E3%82%8A%E8%B6%8A%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Ebitbake%20-c%20%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%AA%E3%83%BC%E3%83%AB%20ncurses%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Ebitbake%20-c%20cleanall%20alsa-utils%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Ebitbake%20-c%20%E3%83%93%E3%83%AB%E3%83%89%20ncurses%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Ebitbake%20-c%20build%20alsa-utils%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%AB%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Ebitbake%20%3CYOUR%20target%3D%22%22%3E%3C%2FYOUR%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%94%B9%E3%82%81%E3%81%A6%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%231f497d%3B%22%3E%E7%A7%81%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8E%9F%E5%9B%A0%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%B9%97%E3%82%8A%E8%B6%8A%E3%81%88%E3%82%8B%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%231f497d%3B%22%3Ealsa-utils%20%E3%81%AF%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%E3%81%AA%E3%81%A9%E3%81%AB%20ncurses%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81ncurses%20%E3%81%AF%E3%81%9D%E3%82%8C%E4%BB%A5%E5%89%8D%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E7%90%86%E7%94%B1%E3%81%A7%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AF%E5%BE%8C%E3%81%A7%E3%83%9B%E3%82%B9%E3%83%88%20(ARM%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%20Intel)%20%E3%81%AE%20SDK%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E4%B8%8A%E6%9B%B8%E3%81%8D%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81configure%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%231f497d%3B%22%3Ebitbake%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%20%22bitbake%20-c%20build%20ncurses%22%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E7%B5%82%E3%82%8F%E3%81%A3%E3%81%9F%E3%82%89%20%22bitbake%20%3CYOUR-TARGET%3E%22%20%E3%81%BE%E3%81%9F%E3%81%AF%20%22bitbake%20-c%20cleanall%20alsa-utils%20%26amp%3B%26amp%3B%20bitbake%20%E2%80%93c%20build%20alsa-utils%3Bbitbake%20%3CYOUR-TARGET%3E%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BB%A5%E5%89%8D%E3%81%AB%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%81%8B%E3%82%89%E7%B6%9A%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FYOUR-TARGET%3E%3C%2FYOUR-TARGET%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099334%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099334%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%92%E3%83%83%E3%83%97%E3%80%81%E3%83%92%E3%83%83%E3%83%97%E4%B8%87%E6%AD%B3!%E5%A4%A7%E9%87%91%E3%81%AE%E3%82%A6%E3%82%B5%E3%82%AE%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB!%3C%2FP%3E%3CP%3E%E4%BB%8A%E3%80%81%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A8%E6%88%A6%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99....%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%2Ffsl-community-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-multimedia%2Falsa%2Falsa-utils_1.0.27.2.bb%2C%20do_configure)%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%20'1'%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%8D%B7%E7%89%A9%E3%81%8C%E8%B6%B3%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%E3%81%93%E3%82%8C%E3%81%AF%20'master'%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AE%E3%83%90%E3%82%B0%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%81%8B%3F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22js-repo-root%20repo-root%22%3E%3CSPAN%3E%3CA%20data-branch%3D%22qt5-5.3.0%22%20data-direction%3D%22back%22%20data-pjax%3D%22true%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fcetola%2Fmeta-qt5%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%ABmeta-qt5%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22separator%22%3E%20%2F%3C%2FSPAN%3E%3CSPAN%3E%3CA%20data-branch%3D%22qt5-5.3.0%22%20data-direction%3D%22back%22%20data-pjax%3D%22true%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fcetola%2Fmeta-qt5%2Ftree%2Fqt5-5.3.0%2Frecipes-qt%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%3E%20recipes-qt%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22separator%22%3E%20%2F%3C%2FSPAN%3E%3CSPAN%3E%3CA%20data-branch%3D%22qt5-5.3.0%22%20data-direction%3D%22back%22%20data-pjax%3D%22true%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fcetola%2Fmeta-qt5%2Ftree%2Fqt5-5.3.0%2Frecipes-qt%2Fqt5%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%3E%20qt5%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22separator%22%3E%20%2F%3C%2FSPAN%3E%3CSTRONG%20class%3D%22final-path%22%3E%20qt5-5.3.0.inc%3C%2FSTRONG%3E%20%E3%81%AEQT_MODULE_BRANCH%E3%81%AF%E3%80%81Qt%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%815.3.0%E3%81%8B%E3%82%895.3%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099332%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099332%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ECHKSUM%E3%82%92%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%83%99%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A3%E3%83%BC%E3%83%89%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%ABQtquickcontrols%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E5%9B%9E%E9%81%BF%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81Qt5.3%E3%81%8C%E6%AD%A3%E5%BC%8F%E3%81%AB%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AB%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%A7%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8F%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%20init%20-u%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%3C%2FA%3E-b%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%3B%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E5%90%8C%E6%9C%9F%3C%2FP%3E%3CP%3E%20cd%20sources%3B%20git%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5.git%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5.git%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099331%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099331%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%BE%E3%81%A0bitbake%20core-image-minimal%E3%82%92%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%ABqtbase%E3%81%A7%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Aqtbase-native%3Amd5%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%20file%3A%2F%2FLICENSE%20%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82LGPL%E3%81%AE%3Bmd5%3D4193e7f1d47a858f6b7c0f1ee66161de%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Aqtbase-native%3A%E6%96%B0%E3%81%97%E3%81%84md5%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B5%E3%83%A0%E3%81%AF2abca611d56c23eb99943bde21c80a0d%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Aqtbase-native%3A%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E6%83%85%E5%A0%B1%E3%81%8C%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fi686-linux%2Fqtbase-native%2F5.3.0-r0%2Fgit%2FLICENSE%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%9F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82LGPL%E3%81%AF%E3%80%81LICENSE%E5%80%A4%E3%80%8CGFDL-1.3%26amp%3B%20LGPL-2.1%20%7CGPL-3.0%E3%80%8D%E6%9C%89%E5%8A%B9%E3%81%AA%E3%81%BE%E3%81%BE%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%82%A8%E3%83%A9%E3%83%BC%3ALIC_FILES_CHKSUM%E3%81%8C%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E9%96%A2%E6%95%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20do_qa_configure%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%9A%9C%E5%AE%B3%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fi686-linux%2Fqtbase-native%2F5.3.0-r0%2Ftemp%2Flog.do_configure.7527%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF1651(%2F%20home%20%2F%20ramakanth%20%2F%20fsl-community-bsp%20%2F%20sources%20%2F%20meta-qt5%20%2F%20recipes-qt%20%2F%20qt5%20%2F%20qtbase-native_5.3.0.bb%E3%80%81do_configure)%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8C1%E3%80%8D%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E6%B3%A8%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%3A%203371%20%E5%80%8B%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%203000%20%E5%80%8B%E3%81%AF%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%811%20%E5%80%8B%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E4%BB%A5%E5%89%8D%E3%81%AB%E3%81%9D%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E8%A6%8B%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E9%81%8E%E5%8E%BB%E3%81%AB%E3%81%93%E3%81%AE%E8%A1%8C%E3%82%92%E7%A7%81%E3%81%AElocal.conf%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3EPACKAGECONFIG_append_pn-QTmultimedia%20%3D%20%22%20gstreamer010%20%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%81%9D%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E3%82%82%E3%81%86%E3%81%8A%E6%8C%81%E3%81%A1%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A7%81%E3%81%AB%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3Ep.s.%20%E3%83%93%E3%83%83%E3%82%B0%E3%83%90%E3%83%83%E3%82%AF%E3%83%90%E3%83%8B%E3%83%BC%E3%81%AB%E4%B9%BE%E6%9D%AF!%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099329%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099329%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E4%BB%8A%E3%81%93%E3%82%8C%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E3%81%86%E3%81%BE%E3%81%8F%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E3%81%AE%E3%82%92%E8%A6%8B%E3%81%A6%E3%81%86%E3%82%8C%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%AE1%E3%81%A4%E3%81%AF%E3%80%81Qt%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%81%B3%E3%81%AB%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ERectangle%20%7B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%B9%85%3A1280%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E9%AB%98%E3%81%95%3A800%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%82%AB%E3%83%A9%E3%83%BC%3A%E3%80%8C%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%80%8D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%83%97%E3%83%AC%E3%83%BC%E3%83%A4%E3%83%BC%20%7B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EID%3A%E3%83%97%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%87%BA%E5%85%B8%3A%20%22%2Fhome%2Froot%2Fbig_buck_bunny_720p_surround.avi%22%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%87%AA%E5%8B%95%E5%86%8D%E7%94%9F%3A%20true%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%93%E3%83%87%E3%82%AA%E5%87%BA%E5%8A%9B%20%7B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Eid%3A%E3%83%93%E3%83%87%E3%82%AA%E5%87%BA%E5%8A%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%82%BD%E3%83%BC%E3%82%B9%3A%20Player%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20anchors.fill%3A%20parent%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%7D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99.....%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Monospace'%3B%20font-size%3A%209pt%3B%20color%3A%20%23be1414%3B%22%3Ed%3CSTRONG%3EefaultServiceProvider%3A%3ArequestService()%3A%20%22org.qt-project.qt.mediaplayer%22%20%E3%81%AE%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Monospace'%3B%20font-size%3A%209pt%3B%20color%3A%20%23be1414%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Monospace'%3B%20font-size%3A%209pt%3B%20color%3A%20%23be1414%3B%22%3E%3CSTRONG%3E%E4%BB%96%E3%81%AE%E8%AA%B0%E3%81%8B%E3%81%8C%E3%81%93%E3%82%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%80%81%E5%9B%9E%E9%81%BF%E7%AD%96%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Monospace'%3B%20font-size%3A%209pt%3B%20color%3A%20%23be1414%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Monospace'%3B%20font-size%3A%209pt%3B%20color%3A%20%23be1414%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Monospace'%3B%20font-size%3A%209pt%3B%20color%3A%20%23be1414%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%BE%E3%81%81%E3%80%82%E3%80%82%E3%80%82%E5%AE%8C%E4%BA%86%E3%81%99%E3%82%8B%E3%81%BE%E3%81%A7%E3%81%AB%E6%95%B0%E6%99%82%E9%96%93%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%99%E3%81%A7%E3%81%AB%E4%BB%A5%E5%89%8D%E3%82%88%E3%82%8A%E3%82%82%E9%80%B2%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%8A%E3%81%AF%E6%A5%BD%E8%A6%B3%E7%9A%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%88%E3%83%89%E3%83%BC%E3%83%AB%E3%81%A8%E3%82%B9%E3%83%86%E3%83%95%E3%82%A1%E3%83%8E%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099327%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099327%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AF%E8%89%AF%E3%81%84%E6%83%85%E5%A0%B1%E3%81%A7%E3%81%99!%E6%84%9F%E8%AC%9D%EF%BC%81%E3%81%9D%E3%82%8C%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E5%86%8D%E6%A7%8B%E7%AF%89%E3%81%97%E3%80%81%E4%BD%95%E3%81%8C%E8%B5%B7%E3%81%93%E3%82%8B%E3%81%8B%E8%A6%8B%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099326%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099326%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%9C%E3%83%96%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%ABsources%2Fmeta-fsl-arm%2Fqt5-layer%2Frecipes-qt%2Fqt5%2Fqtmultimedia_%25.bbappend%E3%82%92%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E5%BF%98%E3%82%8C%E3%81%9F%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%94%BB%E5%83%8F%E3%82%92%E3%83%93%E3%83%83%E3%83%88%E3%83%99%E3%82%A4%E3%82%AF%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E6%AD%A3%E7%A2%BA%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETodor%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%86%E3%82%93%E3%80%82%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC...%E3%80%82%3C%2FP%3E%3CP%3E%22%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%201%20%E5%87%BA%E5%8A%9B%3A%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E9%81%A9%E7%94%A8%20add-imx6-support.patch%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E9%81%A9%E7%94%A8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20src%2Fplugins%2Fplugins.pro%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%B3%E3%82%AF%231%E3%81%AF6%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E1%20of%201%20hunk%20FAILED%20--%20src%2Fplugins%2Fplugins.pro%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E6%8B%92%E5%90%A6%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E3%81%AF%E3%80%81src%2Fplugins%2Fvideonode%2Fimx6%2Fimx6.json%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99!%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E3%81%9D%E3%82%8C%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E9%81%A9%E7%94%A8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20src%2Fplugins%2Fvideonode%2Fimx6%2Fimx6.json%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%B3%E3%82%AF%20%231%20%E3%81%AF%201%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E1%20of%201%20hunk%20FAILED%20--%20src%2Fplugins%2Fvideonode%2Fimx6%2Fimx6.json%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E6%8B%92%E5%90%A6%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E3%81%AF%E3%80%81src%2Fplugins%2Fvideonode%2Fimx6%2Fimx6.pro%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99!%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E3%81%9D%E3%82%8C%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E9%81%A9%E7%94%A8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20src%2Fplugins%2Fvideonode%2Fimx6%2Fimx6.pro%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%B3%E3%82%AF%20%231%20%E3%81%AF%201%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E1%20of%201%20hunk%20FAILED%20--%20src%2Fplugins%2Fvideonode%2Fimx6%2Fimx6.pro%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E6%8B%92%E5%90%A6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E3%81%AF%E3%80%81src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterial.cpp%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99!%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E3%81%9D%E3%82%8C%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E9%81%A9%E7%94%A8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterial.cpp%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%B3%E3%82%AF%20%231%20%E3%81%AF%201%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E1%20out%20of%201%20hunk%20FAILED%20--%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterial.cpp%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E6%8B%92%E5%90%A6%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterial.h%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99!%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E3%81%9D%E3%82%8C%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E9%81%A9%E7%94%A8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterial.h%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%B3%E3%82%AF%20%231%20%E3%81%AF%201%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E1%20hunk%20%E3%81%AE%E3%81%86%E3%81%A1%201%20%E3%81%A4%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20--%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterial.h%20%E3%81%A7%E6%8B%92%E5%90%A6%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E3%81%AF%E3%80%81src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterialshader.cpp%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99!%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E3%81%9D%E3%82%8C%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E9%81%A9%E7%94%A8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterialshader.cpp%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%B3%E3%82%AF%20%231%20%E3%81%AF%201%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E1%20out%20of%201%20hunk%20FAILED%20--%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterialshader.cpp%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E6%8B%92%E5%90%A6%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E3%81%AF%E3%80%81src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterialshader.h%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99!%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E3%81%9D%E3%82%8C%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E9%81%A9%E7%94%A8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterialshader.h%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%B3%E3%82%AF%20%231%20%E3%81%AF%201%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E1%20hunk%20%E3%81%AE%E3%81%86%E3%81%A1%201%20%E3%81%A4%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20--%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterialshader.h%20%E3%81%A7%E6%8B%92%E5%90%A6%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E3%81%AF%E3%80%81src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonode.cpp%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99!%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E3%81%9D%E3%82%8C%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E9%81%A9%E7%94%A8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonode.cpp%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%B3%E3%82%AF%20%231%20%E3%81%AF%201%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E1%20of%201%20hunk%20FAILED%20--%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonode.cpp%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E6%8B%92%E5%90%A6%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonode.h%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99!%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E3%81%9D%E3%82%8C%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E9%81%A9%E7%94%A8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonode.h%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%B3%E3%82%AF%20%231%20%E3%81%AF%201%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E1%20hunk%20%E3%81%AE%E3%81%86%E3%81%A1%201%20%E3%81%A4%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20--%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonode.h%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E6%8B%92%E5%90%A6%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E3%81%AF%E3%80%81src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonodefactory.cpp%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99!%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E3%81%9D%E3%82%8C%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E9%81%A9%E7%94%A8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonodefactory.cpp%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%B3%E3%82%AF%20%231%20%E3%81%AF%201%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E1%20out%20of%201%20hunk%20FAILED%20--%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonodefactory.cpp%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E6%8B%92%E5%90%A6%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonodefactory.h%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99!%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E3%81%9D%E3%82%8C%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E9%81%A9%E7%94%A8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonodefactory.h%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%B3%E3%82%AF%20%231%20%E3%81%AF%201%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E1%20hunk%20%E3%81%AE%E3%81%86%E3%81%A1%201%20%E3%81%A4%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20--%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonodefactory.h%20%E3%81%A7%E6%8B%92%E5%90%A6%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E3%81%AF%E3%80%81src%2Fplugins%2Fvideonode%2Fvideonode.pro%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99!%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E3%81%9D%E3%82%8C%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E9%81%A9%E7%94%A8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20src%2Fplugins%2Fvideonode%2Fvideonode.pro%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%B3%E3%82%AF%20%231%20%E3%81%AF%201%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E1%20of%201%20hunk%20FAILED%20--%20src%2Fplugins%2Fvideonode%2Fvideonode.pro%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E6%8B%92%E5%90%A6%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%20add-imx6-support.patch%20%E3%81%AF%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%20(-f%20%E3%81%A7%E5%BC%B7%E5%88%B6%E3%81%97%E3%81%BE%E3%81%99)%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E9%96%A2%E6%95%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20patch_do_patch%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%9A%9C%E5%AE%B3%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%2F%20home%20%2F%20bob%20%2F%20Projects%20%2F%20M821%20%2F%20Yocto%20%2F%20fsl-community-bsp%20%2F%20build%20%2F%20tmp%20%2F%20work%20%2F%20cortexa9hf-vfp-neon-mx6-poky-linux-gnueabi%20%2F%20qtmultimedia%20%2F%205.3.0-r0%20%2F%20temp%20%2F%20log.do_patch.6597%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF759(%2F%20home%20%2F%20bob%20%2F%20Projects%20%2F%20M821%20%2F%20Yocto%20%2F%20fsl-community-bsp%20%2F%20sources%20%2F%20meta-qt5%20%2F%20recipes-qt%20%2F%20qt5%20%2F%20qtmultimedia_5.3.0.bb%E3%80%81do_patch)%E3%81%AF%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8C1%E3%80%8D%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%83%88%E3%83%83%E3%83%89%E3%80%82%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFYocto%2FQt5%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABWandboard%20Wiki%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Ewiki%E3%81%A7%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%A2%E3%82%A6%E3%83%88%E3%81%99%E3%82%8B%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%80%81%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81Wandboard%20wiki(local.conf)%E3%81%A7%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%82%E3%81%AE%E3%82%88%E3%82%8A%E3%82%82%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%81%9D%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%8C%E3%80%8Cbitbake%20meta-toolchain-qt5%E3%80%8D%E3%82%92%E3%81%86%E3%81%BE%E3%81%8F%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E7%90%86%E7%94%B1%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%80%81wiki%E3%81%A7%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81local.conf%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E3%82%82%E3%81%AE%E3%81%AE%E6%9D%9F%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E3%81%99%E3%81%90%E3%81%AB%E3%80%81%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E5%86%8D%E5%BA%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E7%B5%90%E6%9E%9C%E3%82%92%E6%8A%95%E7%A8%BF%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%9F%E3%81%84%E4%BA%BA%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%83%8E%E3%83%BC%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%81%A7%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%80%81%E8%A4%87%E6%95%B0%E3%81%AEWeb%E3%82%B5%E3%82%A4%E3%83%88%E3%81%A7%E6%8F%90%E6%A1%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81meta-qt5%E3%82%92%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB-b%205.3.0%E3%81%BE%E3%81%9F%E3%81%AF-b%20daisy%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E4%BB%96%E3%81%AE%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AFyocto%201.6.1%E3%81%AB%E9%81%A9%E5%90%88%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AF%E4%BF%A1%E3%81%98%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%81%97%E3%81%8B%E3%81%97%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%88%E3%82%8A%E9%87%8D%E8%A6%81%E3%81%AA%E8%B2%A2%E7%8C%AE%E3%81%A7%E3%81%99!%3B-)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%80%81%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AEmeta-qt5%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E5%A4%B1%E6%95%97%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%8C%E3%81%A9%E3%81%93%E3%81%AB%E3%81%82%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%81%9F%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%AF%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E5%87%BA%E3%81%99%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3CFOLDER_BASENAME%3E%E3%81%A8%3CFOLDER_BASENAME-5.3.0%3E%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%3A%20%E4%BE%8B%3Asources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fqttools%20%E3%81%A8%20sources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fqttools-5.3.0%20%E3%81%A7%E3%81%99%E3%80%82%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A91%E5%AF%BE1%E3%81%A7%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E5%90%8D%E5%89%8D%E3%82%88%E3%82%8A%E3%82%82%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%82%92%E5%A5%BD%E3%82%80%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E9%81%A9%E5%90%88%E3%81%97%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%81%AF%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AE%E6%8E%A8%E6%B8%AC%E3%81%A7%E3%81%AF%E3%80%81%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E6%96%87%E5%AD%97%E5%88%97%E3%82%92%E6%8C%81%E3%81%A4%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E5%90%8D%E3%81%AF%E5%8F%A4%E3%81%8F%E3%80%81%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E5%94%AF%E4%B8%80%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A0%E3%81%A3%E3%81%9F%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%BE%8C%E3%81%A7%E3%80%81%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%A8%E5%90%8C%E6%9C%9F%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81%E4%BB%96%E3%81%AE%E3%82%82%E3%81%AE%E3%81%8C%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F...%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%93%E3%81%A8%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AF%E6%96%B0%E4%BA%BA%E3%81%99%E3%81%8E%E3%81%A6%E3%83%93%E3%83%83%E3%83%88%E3%83%99%E3%82%A4%E3%82%AF%E3%81%AE%E7%B5%8C%E9%A8%93%E3%81%8C%E6%B5%85%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E8%87%AA%E5%88%86%E3%81%A7%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E7%A7%81%E3%81%AE(%E5%B9%B8%E3%81%84%E3%81%AA%E3%81%93%E3%81%A8%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%9F)%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E5%86%8D%E5%BA%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FFOLDER_BASENAME-5.3.0%3E%3C%2FFOLDER_BASENAME%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%88%E3%81%8F%E3%82%84%E3%81%A3%E3%81%9F!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%85%AC%E5%BC%8F%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%A7%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E3%82%92%E8%A6%8B%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5%2Fcommit%2Fe9ad98bbed6065989ef4648e724f27275b35b838%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5%2Fcommit%2Fe9ad98bbed6065989ef4648e724f27275b35b838%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5%2Fcommit%2Fe9ad98bbed6065989ef4648e724f27275b35b838%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%99%E3%81%94%E3%81%84%E3%81%A7%E3%81%99%E3%81%AD%E3%80%82%E7%A7%81%E3%81%AF%E8%A6%8B%E3%81%A6%E3%80%81%E3%83%97%E3%83%AD%E3%81%8C%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%9D%E3%82%8C%E3%82%92%E3%81%97%E3%81%9F%E3%81%8B%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%3CIMG%20id%3D%22smileywink%22%20class%3D%22emoticon%20emoticon-smileywink%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-wink.png%22%20alt%3D%22Smiley%20Wink%22%20title%3D%22Smiley%20Wink%22%20%2F%3E%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA(github.com%2Fmeta-qt5%2Fmeta-qt5.git)%E3%81%8B%E3%82%89imx53qsb%E7%94%A8%E3%81%AEyocto%201.6.1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6Qt%205.3.0%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%BE%E3%81%A0%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93-%E7%8F%BE%E5%9C%A8%E4%BB%95%E4%BA%8B%E4%B8%AD%E3%81%A7%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E5%AE%B6%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99...%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%9C%E3%83%96(%E3%81%9D%E3%81%97%E3%81%A6%E4%BB%96%E3%81%AE%E8%88%88%E5%91%B3%E3%81%AE%E3%81%82%E3%82%8B%E3%81%BF%E3%82%93%E3%81%AA)%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E4%B9%97%E3%82%8A%E8%B6%8A%E3%81%88%E3%81%A6%E9%80%B2%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F...QT%205.3.0%20%E3%81%A8%20Toolchain%20SDK%20%E3%81%AF%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EQt%205.3.0%E3%81%8C%E6%AD%A3%E5%BC%8F%E3%81%AB%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%95%E3%82%8C%E3%80%81%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%95%E3%82%8C%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E7%A7%81%E3%81%8C%E8%A1%8C%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81repo%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6fsl-community-bsp%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81Stephano%E3%81%AE%5Bgit%7Chttps%5D%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5.git%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81GitHub%E3%81%AE%E5%85%AC%E5%BC%8F%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%8B%E3%82%89Qt%E3%83%A1%E3%82%BF%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82sources%2Fmeta-fsl-arm%2Fqt5-layer%2Frecepies-qt%2Fqt5%2Fqtmultimedia_%25.bbappend%20%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81Wandboard.org%20WIKI%20%E3%81%8B%E3%82%89%20Qt5%20%E3%81%AE%E6%A7%8B%E7%AF%89%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%AA%AC%E6%98%8E%E3%81%AB%E3%81%A0%E3%82%89%E3%81%97%E3%81%AA%E3%81%8F%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%20(%3CA%20href%3D%22http%3A%2F%2Fwiki.wandboard.org%2Findex.php%2FBuilding_Qt5_using_yocto_on_Wandboard%22%20title%3D%22http%3A%2F%2Fwiki.wandboard.org%2Findex.php%2FBuilding_Qt5_using_yocto_on_Wandboard%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EWandboard%20%E3%81%A7%20yocto%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20Qt5%20%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%20-%20Wandboard%20Wiki%3C%2FA%3E)%E3%80%82ruby%E3%81%A8meta-qt5%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%82%92bblayers.conf%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%BF%BD%E5%8A%A0%E3%81%AE%E7%94%BB%E5%83%8F%E6%A9%9F%E8%83%BD%E3%81%8B%E3%82%89openssh%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%8F%90%E6%A1%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%ABinstall_append%E5%85%A8%E4%BD%93%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82local.conf%20%E3%81%AB%20remove%20features%20%E8%A1%8C%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%82%B9%E3%83%86%E3%83%95%E3%82%A1%E3%83%8E%E3%81%8B%E3%82%89%E3%81%AE%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E5%BD%BC%E3%81%AEwandboard-image-qt5%E3%83%AC%E3%82%B7%E3%83%94%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E6%A7%8B%E7%AF%89%E3%81%AF%E3%83%86%E3%82%B9%E3%83%88%E7%9B%AE%E7%9A%84%E3%81%A7%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9F%E3%81%B6%E3%82%93%E8%BF%91%E3%81%84%E3%81%86%E3%81%A1%E3%81%AB%E3%80%81%E5%BD%BC%E3%81%AE%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%81%9F%E3%82%8A%E3%80%81%E8%87%AA%E5%88%86%E3%81%AE%E3%83%AF%E3%83%B3%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%9C%E3%81%A3%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93...%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AEmeta-toolchain-qt5%E3%81%AB%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20-%20%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETodor%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099318%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099318%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%80%81%E4%BB%96%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81meta-toolchain-qt5%E3%82%92%E8%A6%8B%E3%82%8B%E6%99%82%E9%96%93%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EQt5%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81fsl-toolchain%20%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%20Qt%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%20(%E3%81%8A%E3%82%88%E3%81%B3%20qmake)%20%E3%81%8C%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%81%AE%20Qt%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYocto%E3%81%AE%E5%A4%96%E9%83%A8%E3%81%A7Qt%205.3.0%E3%82%92%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%2F%20qmake%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%A2%E3%83%97%E3%83%AA%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81meta-toolchain-qt5%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A8%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89Qt%205.3.0%E3%82%92%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A8%E3%80%81%E3%81%A9%E3%81%A1%E3%82%89%E3%81%8C%E7%B0%A1%E5%8D%98%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E4%BB%95%E4%BA%8B%E3%81%A8%E8%BF%94%E4%BF%A1%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E5%88%A5%E3%81%AE%E6%A9%9F%E4%BC%9A%E3%81%AB%E3%80%81%E4%BD%95%E3%81%8B%E9%80%B2%E5%B1%95%E3%81%8C%E3%81%82%E3%81%A3%E3%81%9F%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%82%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E7%8F%BE%E5%9C%A8%E4%BB%96%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E6%88%BB%E3%81%A3%E3%81%9F%E3%82%89%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BB%8A%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%81%AF5.2.1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6Yocto%E3%82%92Qt5.3%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%80%8Cbitbake%20meta-toolchain-qt5%E3%80%8D%E3%81%AF%E7%A7%81%E3%81%AB%E5%B0%8F%E3%81%95%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E5%B1%B1%E3%82%92%E4%B8%8E%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFpoky%201.6.1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6Qt5.X%E3%81%AE%E3%81%A9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%82%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%B0%E3%82%89%E3%81%8FQt5.2.1%E3%81%AB%E5%9B%BA%E5%9F%B7%E3%81%99%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E4%BB%95%E4%BA%8B%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89sdk%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CSTRONG%3Ebitbake%20wandboard-image-qt5%3C%2FSTRONG%3E%20%E3%81%AF%E6%9C%9F%E5%BE%85%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%20%3CSTRONG%3Ebitbake%20meta-toolchain-qt5%3C%2FSTRONG%3E%20%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%3AURL%20git%3A%2F%2Fqt.gitorious.org%2Fqt%2Fqtbase.git%3Bbranch%3D5.3.0%20%E3%81%AE%E5%8F%96%E5%BE%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8F%AF%E8%83%BD%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%20MIRRORS%20%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%83%A3%E3%83%BC%E3%81%AE%E5%A4%B1%E6%95%97%3A%E3%82%A2%E3%83%83%E3%83%97%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%8B%E3%82%89%E3%81%A7%E3%82%82%E3%83%96%E3%83%A9%E3%83%B3%E3%83%815.3.0%E3%81%A7%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3207598fd8e69be34e8ba2c9db7720cb6003ea114%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E9%96%A2%E6%95%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20URL%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%83%A3%E3%83%BC%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20'git%3A%2F%2Fqt.gitorious.org%2Fqt%2Fqtbase.git%3Bbranch%3D5.3.0'%E3%81%A9%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%E3%82%82%20URL%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%9A%9C%E5%AE%B3%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%2Fhome%2Fttodorov%2FWork%2Fyocto%2Ffsl-community-bsp-image%2Fbuild%2Ftmp%2Fwork%2Fx86_64-nativesdk-pokysdk-linux%2Fnativesdk-qtbase%2F5.3.0-r1%2Ftemp%2Flog.do_fetch.7617%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF1024%EF%BC%88%2Fhome%2Fttodorov%2FWork%2Fyocto%2Ffsl-community-bsp-image%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fnativesdk-qtbase_5.3.0.bb%2C%20do_fetch)%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8C1%E3%80%8D%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E6%B3%A8%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%3A%201473%20%E5%80%8B%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%201350%20%E5%80%8B%E3%82%92%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%811%20%E5%80%8B%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E0%E5%80%8B%E3%81%AE%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E5%BE%85%E6%A9%9F%E4%B8%AD%E3%81%A7%E3%81%99%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%A6%82%E8%A6%81%EF%BC%9A1%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%3C%2FP%3E%3CP%3E%2Fhome%2Fttodorov%2F%E4%BB%95%E4%BA%8B%2Fyocto%2Ffsl-community-bsp-image%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fnativesdk-qtbase_5.3.0.bb%2C%20do_fetch%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%BE%E3%81%9F%E3%80%81qttools%E3%81%A7%E5%90%8C%E6%A7%98%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%3AURL%20git%3A%2F%2Fqt.gitorious.org%2Fqt%2Fqttools.git%3Bbranch%3D5.3.0%20%E3%81%AE%E5%8F%96%E5%BE%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8F%AF%E8%83%BD%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%20MIRRORS%20%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%83%A3%E3%83%BC%E3%81%AE%E5%A4%B1%E6%95%97%3A%E3%82%A2%E3%83%83%E3%83%97%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%8B%E3%82%89%E3%81%A7%E3%82%82%E3%83%96%E3%83%A9%E3%83%B3%E3%83%815.3.0%E3%81%AE%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3e7b791c8bb5e64a4c786bf370b10366815af704f%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E9%96%A2%E6%95%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20URL%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%83%A3%E3%83%BC%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20'git%3A%2F%2Fqt.gitorious.org%2Fqt%2Fqttools.git%3Bbranch%3D5.3.0'%E3%81%A9%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%E3%82%82%20URL%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E5%A4%B1%E6%95%97%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%2Fhome%2Fttodorov%2FWork%2Fyocto%2Ffsl-community-bsp-image%2Fbuild%2Ftmp%2Fwork%2Fx86_64-nativesdk-pokysdk-linux%2Fnativesdk-qttools%2F5.3.0-r0%2Ftemp%2Flog.do_fetch.31774%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF1037(%2F%20home%20%2F%20ttodorov%20%2F%20Work%20%2F%20yoc%20%2F%20fsl-community-bsp-image%20%2F%20sources%20%2F%20meta-qt5%20%2F%20recipes-qt%20%2F%20qt5%20%2F%20nativesdk-qttools_5.3.0.bb%E3%80%81do_fetch)%E3%81%AF%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8C1%E3%80%8D%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E6%B3%A8%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%3A%201634%20%E5%80%8B%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%201583%20%E5%80%8B%E3%82%92%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%811%20%E5%80%8B%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E0%E5%80%8B%E3%81%AE%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E5%BE%85%E6%A9%9F%E4%B8%AD%E3%81%A7%E3%81%99%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%A6%82%E8%A6%81%EF%BC%9A1%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%3C%2FP%3E%3CP%3E%2Fhome%2Fttodorov%2FWork%2Fyocto%2Ffsl-community-bsp-image%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fnativesdk-qttools_5.3.0.bb%2C%20do_fetch%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E8%A9%A6%E3%81%BF%E3%81%9F%E3%81%AE%E3%81%AF%E3%80%81%E4%B8%80%E6%99%82%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E5%86%85%E3%81%AEqtbase%E3%81%A8qttools%E3%81%AE5.3.0%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%82%92%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%9FSRCREV%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E3%81%AE%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E5%89%8D%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E5%90%88%E6%A0%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%91%E3%83%83%E3%83%81%E9%81%A9%E7%94%A8%E3%81%A8%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E3%81%8B%E3%81%AA%E3%82%8A%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%82%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%E6%A8%99%E6%BA%96%E3%81%AE%20fsl%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AF%E3%80%81meta-toolchain-qt5%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%AA%E3%81%8F%E3%81%A6%E3%82%82%20Qt%205.3.0%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%8D%81%E5%88%86%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%9A%86%E3%81%95%E3%82%93%E3%81%AE%E5%8A%A9%E3%81%91%E3%81%A8%E6%84%8F%E8%A6%8B%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETodor%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099313%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099313%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Egit%20pull%20in%20meta-qt5%20%E3%81%A8%20bitbake%20core-image-minimal%20%E3%81%AE%E5%BE%8C%E3%81%AB%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Aqtbase-native%3Amd5%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%20file%3A%2F%2FLICENSE%20%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82LGPL%E3%81%AE%3Bmd5%3D4193e7f1d47a858f6b7c0f1ee66161de%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Aqtbase-native%3A%E6%96%B0%E3%81%97%E3%81%84md5%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B5%E3%83%A0%E3%81%AF2abca611d56c23eb99943bde21c80a0d%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Aqtbase-native%3A%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E6%83%85%E5%A0%B1%E3%81%8C%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fi686-linux%2Fqtbase-native%2F5.3.0-r0%2Fgit%2FLICENSE%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%9F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82LGPL%E3%81%AF%E3%80%81LICENSE%E5%80%A4%E3%80%8CGFDL-1.3%26amp%3B%20LGPL-2.1%20%7CGPL-3.0%E3%80%8D%E6%9C%89%E5%8A%B9%E3%81%AA%E3%81%BE%E3%81%BE%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%82%A8%E3%83%A9%E3%83%BC%3ALIC_FILES_CHKSUM%E3%81%8C%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E9%96%A2%E6%95%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20do_qa_configure%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%9A%9C%E5%AE%B3%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fi686-linux%2Fqtbase-native%2F5.3.0-r0%2Ftemp%2Flog.do_configure.25371%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF1651(%2F%20home%20%2F%20ramakanth%20%2F%20fsl-community-bsp%20%2F%20sources%20%2F%20meta-qt5%20%2F%20recipes-qt%20%2F%20qt5%20%2F%20qtbase-native_5.3.0.bb%E3%80%81do_configure)%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8C1%E3%80%8D%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099312%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099312%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AElocal.conf%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BD%95%E3%81%8B%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBB_NUMBER_THREADS%20%3F%3D%20%22%24%7B%40oe.utils.cpu_count()%7D%22%3C%2FP%3E%3CP%3EPARALLEL_MAKE%20%3F%3D%20%22-j%20%24%7B%40oe.utils.cpu_count()%7D%22%3C%2FP%3E%3CP%3EMACHINE%20%3F%3F%3D%20'imx6qsabreauto'%3C%2FP%3E%3CP%3EDISTRO%20%3F%3D%20'poky'%3C%2FP%3E%3CP%3EPACKAGE_CLASSES%20%3F%3D%20%22package_rpm%22%3C%2FP%3E%3CP%3EEXTRA_IMAGE_FEATURES%20%3D%20%22%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%AA%BF%E6%95%B4%22%3C%2FP%3E%3CP%3EUSER_CLASSES%20%3F%3D%20%22buildstats%20image-mklibs%20image-prelink%22%3C%2FP%3E%3CP%3EPATCHRESOLVE%20%3D%20%22noop%22%3C%2FP%3E%3CP%3EBB_DISKMON_DIRS%20%3D%20%22%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20STOPTASKS%2C%24%7BTMPDIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20STOPTASKS%2C%24%7BDL_DIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20STOPTASKS%2C%24%7BSSTATE_DIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ABORT%2C%24%7BTMPDIR%7D%2C100M%2C1K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ABORT%2C%24%7BDL_DIR%7D%2C100M%2C1K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ABORT%2C%24%7BSSTATE_DIR%7D%2C100M%2C1K%22%20%3C%2FP%3E%3CP%3EPACKAGECONFIG_pn-qemu-native%20%3D%20%22sdl%22%3C%2FP%3E%3CP%3EASSUME_PROVIDED%20%2B%3D%20%22libsdl-native%22%3C%2FP%3E%3CP%3ECONF_VERSION%20%3D%20%221%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBB_NUMBER_THREADS%20%3D%20'2'%3C%2FP%3E%3CP%3EPARALLEL_MAKE%20%3D%20'-j%202'%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDL_DIR%20%3F%3D%20%22%24%7BBSPDIR%7D%2Fdownloads%2F%22%3C%2FP%3E%3CP%3EACCEPT_FSL_EULA%20%3D%20%22%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDISTRO_FEATURES_remove%20%3D%20%22x11%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%83%A9%E3%83%B3%E3%83%89%22%3C%2FP%3E%3CP%3EEXTRA_IMAGE_FEATURES%20%3D%20%22debug-tweaks%20ssh-server-openssh%20tools-profile%20dbg-pkgs%20tools-debug%22%3C%2FP%3E%3CP%3EIMAGE_INSTALL_append%20%3D%20%22%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20firmware-imx-vpu-imx6q%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20firmware-imx-vpu-imx6d%20%5C%3C%2FP%3E%3CP%3E%22%3C%2FP%3E%3CP%3EIMAGE_INSTALL_append%20%3D%20%22%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cpufrequtils%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20binutils%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20nano%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gdb%20%5C%3C%2FP%3E%3CP%3Eopenssh-sftp-server%20%5C%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97-FSL-gstreamer%20%5C%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%20%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%20FSL%20%E3%83%84%E3%83%BC%E3%83%AB%20%E3%83%86%E3%82%B9%E3%83%88%20%E3%82%A2%E3%83%97%E3%83%AA%20%5C%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97-fsl-tools-benchmark%20%5C%3C%2FP%3E%3CP%3Egstreamer%20%5C%3C%2FP%3E%3CP%3Egst-plugins-base-app%20%5C%3C%2FP%3E%3CP%3Egst-plugins-base%20%5C%3C%2FP%3E%3CP%3Egst-plugins-good%20%5C%3C%2FP%3E%3CP%3Egst-plugins-good-rtsp%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gst-plugins-good-udp%20%5C%3C%2FP%3E%3CP%3Egst-plugins-good-rtpmanager%20%5C%3C%2FP%3E%3CP%3Egst-plugins-good-rtp%20%5C%3C%2FP%3E%3CP%3Egst-plugins-good-video4linux2%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtbase-fonts%20%5C%3C%2FP%3E%3CP%3Eqtbase-plugins%20%5C%3C%2FP%3E%3CP%3Eqtbase-tools%20%5C%3C%2FP%3E%3CP%3Eqtbase-examples%20%5C%3C%2FP%3E%3CP%3Eqtdeclarative%20%5C%3C%2FP%3E%3CP%3Eqtdeclarative-plugins%20%5C%3C%2FP%3E%3CP%3Eqtdeclarative-tools%20%5C%3C%2FP%3E%3CP%3Eqtdeclarative-examples%20%5C%3C%2FP%3E%3CP%3Eqtdeclarative-qmlplugins%20%5C%3C%2FP%3E%3CP%3EQT%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%20%5C%3C%2FP%3E%3CP%3EQT%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%20%5C%3C%2FP%3E%3CP%3EQT%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%81%AE%E4%BE%8B%20%5C%3C%2FP%3E%3CP%3EQT%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2-QML%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%20%5C%3C%2FP%3E%3CP%3Eqtlocation%20%5C%3C%2FP%3E%3CP%3Eqtlocation-plugins%20%5C%3C%2FP%3E%3CP%3Eqtlocation-qmlplugins%20%5C%3C%2FP%3E%3CP%3Eqtlocation-examples%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtsvg%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtsvg-plugins%20%5C%3C%2FP%3E%3CP%3EQT%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtsensors-plugins%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtsensors-qmlplugins%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtimageformats-plugins%20%5C%3C%2FP%3E%3CP%3EQTSoms%E3%81%AE%3C%2FP%3E%3CP%3EQTSystems-%E3%83%84%E3%83%BC%E3%83%AB%20%5C%3C%2FP%3E%3CP%3Eqtsystems-examples%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtsystems-qmlplugins%20%5C%3C%2FP%3E%3CP%3Eqtscript%20%5C%3C%2FP%3E%3CP%3EQTQUICK1%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qt3d%20%5C%3C%2FP%3E%3CP%3Eqt3d-examples%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qt3d-qmlplugins%20%5C%3C%2FP%3E%3CP%3EQT3D-%E3%83%84%E3%83%BC%E3%83%AB%20%5C%3C%2FP%3E%3CP%3EQT%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%20%5C%3C%2FP%3E%3CP%3Eqtconnectivity-examples%20%5C%3C%2FP%3E%3CP%3Eqtconnectivity-qmlplugins%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtserialport%20%5C%3C%2FP%3E%3CP%3EQTquickcontrols%20%5C%3C%2FP%3E%3CP%3Eqtquickcontrols-qmlplugins%20%5C%3C%2FP%3E%3CP%3E%E3%82%B7%E3%83%8D%E3%83%9E%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%AA%E3%82%A8%E3%83%B3%E3%82%B9%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cairo%20pango%20fontconfig%20freetype%20pulseaudio%20dbus%20taglib%20zlib%20%5C%3C%2FP%3E%3CP%3Ealsa-lib%20alsa-tools%20alsa-state%20alsa-utils-alsaconf%20%5C%3C%2FP%3E%3CP%3Etslib%20evtest%20tslib-conf%20tslib-tests%20tslib-calibrate%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gcc%20g%2B%2B%20libgcc%20libgcc-dev%20libstdc%2B%2B%20libstdc%2B%2B-dev%20libstdc%2B%2B-staticdev%20%5C%3C%2FP%3E%3CP%3E%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPACKAGECONFIG_append_pn-QTase%20%3D%20%22%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B7%E3%83%93%E3%83%AA%E3%83%86%E3%82%A3GLES2%20OpenSSL%22%3C%2FP%3E%3CP%3EPACKAGECONFIG_append_pn-QTmultimedia%20%3D%20%22%20gstreamer010%20%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099311%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099311%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AECHKSUM%E5%80%A4%E3%81%AF%E3%80%81qtbase%E3%81%A8qtconnectivity%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E8%A1%8C%E3%81%A3%E3%81%9F%E5%A4%89%E6%9B%B4%E3%82%92%E3%83%AD%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82qtconnectivity%20%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%20CHKSUM%20%E5%80%A4%E3%82%92%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099310%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099310%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Aqtbase-native%3Amd5%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%20file%3A%2F%2FLICENSE%20%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82LGPL%E3%81%AE%3Bmd5%3D4193e7f1d47a858f6b7c0f1ee66161de%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Aqtbase-native%3A%E6%96%B0%E3%81%97%E3%81%84md5%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B5%E3%83%A0%E3%81%AF2abca611d56c23eb99943bde21c80a0d%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3Egit%20pull%20in%20meta-qt5%20%E3%81%A8%20bitbake%20core-image-minimal%20%E3%81%AE%E5%BE%8C%E3%81%AB%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Aqtbase-native%3A%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E6%83%85%E5%A0%B1%E3%81%8C%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fi686-linux%2Fqtbase-native%2F5.3.0-r0%2Fgit%2FLICENSE%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%9F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82LGPL%E3%81%AF%E3%80%81LICENSE%E5%80%A4%E3%80%8CGFDL-1.3%26amp%3B%20LGPL-2.1%20%7CGPL-3.0%E3%80%8D%E6%9C%89%E5%8A%B9%E3%81%AA%E3%81%BE%E3%81%BE%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%82%A8%E3%83%A9%E3%83%BC%3ALIC_FILES_CHKSUM%E3%81%8C%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E9%96%A2%E6%95%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20do_qa_configure%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%9A%9C%E5%AE%B3%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%2F%20home%20%2F%20ramakanth%20%2F%20fsl-community-bsp%20%2F%20build%20%2F%20tmp%20%2F%20work%20%2F%20i686-linux%20%2F%20qtbase-native%20%2F%205.3.0-r0%20%2F%20temp%20%2F%20log.do_configure.22997%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF1651(%2F%20home%20%2F%20ramakanth%20%2F%20fsl-community-bsp%20%2F%20sources%20%2F%20meta-qt5%20%2F%20recipes-qt%20%2F%20qt5%20%2F%20qtbase-native_5.3.0.bb%E3%80%81do_configure)%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8C1%E3%80%8D%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099309%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099309%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Eqt5.3%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AE%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82meta-qt5%E5%86%85%E3%81%A7%E3%80%8Cgit%20pull%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%82%8C%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%84%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Aqtconnectivity%3Amd5%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%20file%3A%2F%2FLICENSE%20%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82LGPL%E3%81%AE%3Bmd5%3D2abca611d56c23eb99943bde21c80a0d%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Aqtconnectivity%3A%E6%96%B0%E3%81%97%E3%81%84md5%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B5%E3%83%A0%E3%81%AF4193e7f1d47a858f6b7c0f1ee66161de%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3Aqtconnectivity%3A%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E6%83%85%E5%A0%B1%E3%81%8C%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-poky-linux-gnueabi%2Fqtconnectivity%2F5.3.0-r0%2Fgit%2FLICENSE%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%9F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82LGPL%E3%81%AF%E3%80%81LICENSE%E5%80%A4%E3%80%8CGFDL-1.3%26amp%3B%20LGPL-2.1%20%7CGPL-3.0%E3%80%8D%E6%9C%89%E5%8A%B9%E3%81%AA%E3%81%BE%E3%81%BE%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%82%A8%E3%83%A9%E3%83%BC%3ALIC_FILES_CHKSUM%E3%81%8C%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E9%96%A2%E6%95%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20do_qa_configure%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%9A%9C%E5%AE%B3%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%2F%20home%20%2F%20ramakanth%20%2F%20fsl-community-bsp%20%2F%20build%20%2F%20tmp%20%2F%20work%20%2F%20cortexa9hf-vfp-neon-poky-linux-gnueabi%20%2F%20qtconnectivity%20%2F%205.3.0-r0%20%2F%20temp%20%2F%20log.do_configure.21742%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%82%BF%E3%82%B9%E3%82%AF582(%2F%20home%20%2F%20ramakanth%20%2F%20fsl-community-bsp%20%2F%20sources%20%2F%20meta-qt5%20%2F%20recipes-qt%20%2F%20qt5%20%2F%20qtconnectivity_5.3.0.bb%E3%80%81do_configure)%E3%81%AF%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8C1%E3%80%8D%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099307%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099307%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Eqtmultimedia%E3%81%A8%E3%81%AF%E5%88%A5%E3%81%AB%E3%80%81qtconnectivity%E3%80%81qtlocation%E3%80%81qtquickcontrols%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Elocal.conf%E3%81%AB%E4%BB%A5%E4%B8%8B%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%B8%8A%E8%A8%98%E3%82%92%E5%90%AB%E3%82%80QTulles%E3%81%AF%E3%80%81bitbake%20core-image-minimal%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%9C%80%E7%B5%82%E7%94%BB%E5%83%8F%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDISTRO_FEATURES_remove%20%3D%20%22x11%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%83%A9%E3%83%B3%E3%83%89%22%3C%2FP%3E%3CP%3EPACKAGECONFIG_append_pn-QTmultimedia%20%3D%20%22%20gstreamer010%20%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099306%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099306%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%AC%E6%97%A5%E3%80%81meta-qt5%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%20meta-fsl-arm%20%E3%81%8B%E3%82%89%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Emeta-fsl-arm%2Fqt5-layer%2Frecipes-qt%2Fqt5%2Fqtmultimedia_%25.bbappend%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%99%E3%81%A7%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8Bqt%205.3.0%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E3%83%90%E3%83%83%E3%82%AF%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%81%95%E3%82%89%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099305%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099305%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Elocal.conf%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3EDISTRO_FEATURES_remove%20%3D%20%22x11%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%83%A9%E3%83%B3%E3%83%89%22%3C%2FP%3E%3CP%3EPACKAGECONFIG_append_pn-QTmultimedia%20%3D%20%22%20gstreamer010%20%22%3C%2FP%3E%3CP%3E%3CBR%20%2F%3Ecore-image-minimal%E3%81%AF%E7%A7%81%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99..%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81local.conf%20%E3%81%AB%20qtmodules%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%AA%E3%81%8F%E3%81%A6%E3%82%82%E3%80%81%E7%94%BB%E5%83%8F%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%96%91%E5%95%8F%E3%81%AB%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099304%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20%E3%81%A7%E3%81%AE%20Qt%205.3.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(fsl-community-bsp%20%E3%81%A8%20meta-qt5%20%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099304%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFLTIB%E3%81%A7%E3%81%AE%E7%9F%AD%E3%81%84%E6%9C%9F%E9%96%93%E3%81%AE%E5%BE%8C%E3%80%81Yocto%E3%81%AB%E6%88%BB%E3%82%8B%E9%81%8E%E7%A8%8B%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99.....%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%8B%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎06-05-2014 08:25 AM
更新者:
