Building Linux Kernel
Building using Yocto
1 - Baking (building) the kernel
When an image is built using Yocto (for more details about how to build an image, check the Yocto training home: https://community.nxp.com/docs/DOC-94849) the kernel is automatically built and the kernel image is located at /fsl-community-bsp/build/tmp/deploy/images/<your_target>/uImage
If you want to build only the kernel, the following command can be used:
$ bitbake linux-imx
2 - Configuring the kernel
To call the kernel menuconfig, run the command:
$ bitbake -c menuconfig linux-imx
A new terminal window will open with the kernel menuconfig. Make changes if needed, exit the configmenu and copy the .config generated file to defconfig as following:
$ cp tmp/work/imx6qsabresd-poky-linux-gnueabi/linux-imx/3.0.35-r33.10/git/.config
../sources/meta-fsl-arm/recipes-kernel/linux/linux-imx-3.0.35/mx6/defconfig
Note that the kernel version, in this case "3.0.35-r33.10" may change.
3 - Cleaning and building again with the new configuration
With the new defconfig saved on the correct folder (step 2), it's time to clear all previous kernel and build it again:
$ bitbake -c cleansstate linux-imx
$ bitbake <your_image>       or         $ bitbake linux-imx
The uImage will be under tmp/deploy/image
Building without a BSP
1- Downloading the kernel source code
Choose what kernel you will build. Usually, the NXP kernel or mainline (kernel.org) kernel:
For NXP kernel (more details on https://source.codeaurora.org/external/imx/linux-imx/ ) use:
$ git clone https://source.codeaurora.org/external/imx/linux-imx
For Mainline kernel (more details on https://www.kernel.org/ ) use:
$ git clone git://git.kernel.org/pub/scm/linux/kernel/git/stable/linux-stable.git
2 - Choose which branch will you use
Once downloaded, check the available branches by using:
$ git branch -a
  master
  remotes/origin/HEAD -> origin/master
  remotes/origin/imx_4.9.123_imx8mm_ga
  remotes/origin/imx_4.9.51_imx8_beta1
  remotes/origin/imx_4.9.51_imx8_beta2
  remotes/origin/imx_4.9.51_imx8m_beta
  remotes/origin/imx_4.9.51_imx8m_ga
  remotes/origin/imx_4.9.88_2.0.0_ga
  remotes/origin/imx_4.9.88_imx8mm_alpha
  remotes/origin/imx_4.9.88_imx8qxp_beta2
  remotes/origin/master
Make a local branch, based on a branch you choose from the list:
$ git checkout -b local_branch origin/imx_4.9.88_2.0.0_ga
*NOTES:      On command above my local branch name is "local_branch". You can choose this name as you prefer
                    The chosen branch was origin/imx_4.9.88_2.0.0_ga. You can choose another one, always starting by origin/.......
3 - Setting the environment variables
3.1 - Using Yocto Toolchain
If you're using the Yocto SDK (Check the Yocto training at NXP community: https://community.nxp.com/docs/DOC-94849 ), just execute the script to export the needed environment variables, e.g.:
$ source /opt/poky/1.6+snapshot/environment-setup-cortexa9hf-vfp-neon-poky-linux-gnueabi
unset LDFLAGS
If you're using another toolchain, the common environment variables to set are the following:
$ export PATH=$PATH:/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/
$ export TOOLCHAIN=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/
$ export CROSS_COMPILE=arm-none-linux-gnueabi-
$ export ARCH=arm
IMPORTANT: Change the variables above according your installed toolchain.
3.2 - Using Ubuntu Toolchain
For 64-bits processors (i.MX8 family)
Install the GCC toolchain for 64 bits:
sudo apt-get install gcc-aarch64-linux-gnu
Export the environment variables:
$ export ARCH=arm64
$ export CROSS_COMPILE=/usr/bin/aarch64-linux-gnu-
For 32-bits processors (i.MX2, i.MX3, i.MX5 and i.MX6 families)
Install the GCC toolchain for 32 bits:
sudo apt-get install gcc-arm-linux-gnueabi
export ARCH=arm
export CROSS_COMPILE=/usr/bin/arm-linux-gnueabi-
4 - Configuring the kernel
If you're building for i.MX6 and i.MX5, configure the kernel options based on file imx_v7_defconfig:
$ cp arch/arm/configs/imx_v7_defconfig .config
$ make menuconfig
$ make
If you're building for i.MX8 family, configure the kernel options based on file arm64/defconfig:
      $ cp arch/arm64/configs/defconfig .config
      $ make menuconfig
      $ make
5 - Building the modules
After step 4, only the kernel (uImage file) was generated. The kernel modules must be built and installed in a known path. First, build the modules:
$ make modules
And install them:
$ make modules_install INSTALL_MOD_PATH=/path_where_you_want_to_install
Comments
I followed the steps for building the kernel by building using Yocto and building without a BSP, but the driver I added in the menuconfig did not appear in the target filesystem, what could be the problem?
Alvin
If you driver is configured as a module than you need build using make modules command.
And install it using
make modules_install INSTALL_MOD_PATH=~/module
Hello Saurabh,
I tried building without a BSP, and configured the drivers as modules. I successfully got the .ko files for my drivers, thanks to your tip. But what about using Yocto? I also tried adding a driver to ther kernel via bitbake, and I also followed the steps in this document, but the drivers did not appear in my target filesystem. I am trying to add the USB bluetooth driver btusb, btw. Any ideas about what could cause the problem?
Again thanks for your help
It should work with yocto also.
bitback linux-imx should build your updated kernel
and bitback rootfs should build the modules for you.
Hello Saurabh,
After menuconfig, do I still need to run bitbake -c cleansstate linux-imx? Or do I go straight to bitbake linux-imx? And what do you mean by bitbake rootfs, do you mean the recipe for my image such as "fsl-image-x11" or is it a recipe?
Thanks for your answers!
I can't find the file named imx_v6_v7_defconfig ?
could you tell me where can find it?
Hi Ronglin,
If you're using a recent freescale kernel, the config file name was moved to imx_v7_defconfig. You can use this one.
Hi rogeriopimentel
Thank for your reply.
When I copy the .config file to imx_v7_defconfig in the file named ltib ,Then copy imx_v7_defconfig to .config and make uImage LOADADDR=0x10008000. Some problem have happened like "prompt for development and/or incomplete code/drivers (EXPERIMENTAL) [N/y/?] (NEW)".
I was infered that some drives have build at first time,so we should choice the drives'status in kernel??
It is right or not ? if not,Please tell me how can I do?
Hi rogeriopimentel
I complete the problem.  Thank you again.
But I have the other question. What's the role of step 6?
Ronglin
If you defined the driver as a module than it will build the modules for you.
Default kernel build doesn't build any modules.
Saurabh
Saurabh Patel
I got it !  Thanks very much!
Best for you
ronglin
This is really a nice article. I tried to build the kernel with the steps mentioned for 'Build kernel without BSP'. I have already created images using Yocto, thus I already have kernel source available at "<build dir>/tmp/work/imx6slevk-poky-linux-gnueabi/linux-imx/3.14.28-r0/git". I have followed below steps to build the kernel:
# make imx_v6_v7_defconfig
# make uImage
But I got following errors:
arch/arm/mach-imx/built-in.o: In function `clk_pllv3_do_shared_clks':
:(.text+0x1780): undefined reference to `imx_sema4_mutex_lock'
:(.text+0x17a8): undefined reference to `imx_sema4_mutex_unlock'
:(.text+0x17e0): undefined reference to `imx_update_shared_mem'
:(.text+0x17fc): undefined reference to `amp_power_mutex'
:(.text+0x1800): undefined reference to `shared_mem'
arch/arm/mach-imx/built-in.o: In function `clk_gate2_do_shared_clks':
:(.text+0x1a30): undefined reference to `imx_sema4_mutex_lock'
:(.text+0x1a58): undefined reference to `imx_sema4_mutex_unlock'
:(.text+0x1a98): undefined reference to `imx_update_shared_mem'
:(.text+0x1ab8): undefined reference to `amp_power_mutex'
:(.text+0x1abc): undefined reference to `shared_mem'
arch/arm/mach-imx/built-in.o: In function `clk_pfd_do_shared_clks':
:(.text+0x1e24): undefined reference to `imx_sema4_mutex_lock'
:(.text+0x1e4c): undefined reference to `imx_sema4_mutex_unlock'
:(.text+0x1e8c): undefined reference to `imx_update_shared_mem'
:(.text+0x1eac): undefined reference to `amp_power_mutex'
:(.text+0x1eb0): undefined reference to `shared_mem'
arch/arm/mach-imx/built-in.o: In function `imx6sl_set_wait_clk':
:(.text+0x61f8): undefined reference to `low_bus_freq_mode'
arch/arm/mach-imx/built-in.o: In function `imx6q_pm_enter':
:(.text+0x6d64): undefined reference to `imx_mu_enable_m4_irqs_in_gic'
:(.text+0x6de0): undefined reference to `imx_mu_is_m4_in_low_freq'
:(.text+0x6df4): undefined reference to `imx_mu_enable_m4_irqs_in_gic'
arch/arm/mach-imx/built-in.o: In function `imx6q_map_io':
:(.init.text+0xe7a4): undefined reference to `imx6_busfreq_map_io'
arch/arm/mach-imx/built-in.o: In function `imx6sl_map_io':
:(.init.text+0x115e0): undefined reference to `imx6_busfreq_map_io'
drivers/built-in.o: In function `fec_runtime_resume':
:(.text+0x119f00): undefined reference to `request_bus_freq'
drivers/built-in.o: In function `fec_runtime_suspend':
:(.text+0x119f1c): undefined reference to `release_bus_freq'
drivers/built-in.o: In function `imx_controller_resume':
:(.text+0x1666d4): undefined reference to `request_bus_freq'
:(.text+0x1666f4): undefined reference to `release_bus_freq'
:(.text+0x166788): undefined reference to `release_bus_freq'
drivers/built-in.o: In function `imx_controller_suspend':
:(.text+0x16685c): undefined reference to `release_bus_freq'
drivers/built-in.o: In function `ci_hdrc_imx_remove':
:(.text+0x166954): undefined reference to `release_bus_freq'
drivers/built-in.o: In function `ci_hdrc_imx_probe':
:(.text+0x166d10): undefined reference to `request_bus_freq'
:(.text+0x166d30): undefined reference to `release_bus_freq'
:(.text+0x166e1c): undefined reference to `release_bus_freq'
drivers/built-in.o: In function `sdhci_esdhc_runtime_resume':
:(.text+0x1c82d0): undefined reference to `request_bus_freq'
drivers/built-in.o: In function `sdhci_esdhc_runtime_suspend':
:(.text+0x1c8344): undefined reference to `release_bus_freq'
drivers/built-in.o: In function `sdhci_esdhc_imx_probe':
:(.text+0x1c8fdc): undefined reference to `release_bus_freq'
:(.text+0x1c9004): undefined reference to `request_bus_freq'
drivers/built-in.o: In function `vpu_runtime_resume':
:(.text+0x1c949c): undefined reference to `request_bus_freq'
drivers/built-in.o: In function `vpu_runtime_suspend':
:(.text+0x1c94b8): undefined reference to `release_bus_freq'
sound/built-in.o: In function `fsl_ssi_runtime_resume':
:(.text+0x2f160): undefined reference to `request_bus_freq'
sound/built-in.o: In function `fsl_ssi_runtime_suspend':
:(.text+0x2f17c): undefined reference to `release_bus_freq'
sound/built-in.o: In function `fsl_spdif_runtime_resume':
:(.text+0x30e08): undefined reference to `request_bus_freq'
sound/built-in.o: In function `fsl_spdif_runtime_suspend':
:(.text+0x30e24): undefined reference to `release_bus_freq'
make: *** [vmlinux] Error 1
Can someone please help me to resolve this?
Appreciate your quick help.
Dhaval
Hi Dhaval,
Could you try to use the following defconfig?
make imx_v7_defconfig
Rgds
Rogerio
Hi Rogerio,
Thanks for your quick reply!
I already tried with that configuration, but even with that I am getting following errors:
drivers/usb/chipidea/ci_hdrc_imx.c: In function 'ci_hdrc_imx_notify_event':
drivers/usb/chipidea/ci_hdrc_imx.c:226:4: error: implicit declaration of function 'pinctrl_select_state' [-Werror=implicit-function-declaration]
    ret = pinctrl_select_state(data->pinctrl,
drivers/usb/chipidea/ci_hdrc_imx.c: In function 'ci_hdrc_imx_probe':
drivers/usb/chipidea/ci_hdrc_imx.c:278:2: error: implicit declaration of function 'devm_pinctrl_get' [-Werror=implicit-function-declaration]
  data->pinctrl = devm_pinctrl_get(&pdev->dev);
drivers/usb/chipidea/ci_hdrc_imx.c:278:16: warning: assignment makes pointer from integer without a cast
drivers/usb/chipidea/ci_hdrc_imx.c:283:3: error: implicit declaration of function 'pinctrl_lookup_state' [-Werror=implicit-function-declaration]
   pinctrl_hsic_idle = pinctrl_lookup_state(data->pinctrl, "idle");
drivers/usb/chipidea/ci_hdrc_imx.c:283:21: warning: assignment makes pointer from integer without a cast
drivers/usb/chipidea/ci_hdrc_imx.c:299:29: warning: assignment makes pointer from integer without a cast
   data->pinctrl_hsic_active = pinctrl_lookup_state(data->pinctrl,
cc1: some warnings being treated as errors
make[3]: *** [drivers/usb/chipidea/ci_hdrc_imx.o] Error 1
make[2]: *** [drivers/usb/chipidea] Error 2
make[1]: *** [drivers/usb] Error 2
make: *** [drivers] Error 2
Dhaval
Hi Dhaval
You can try following steps
make  imx_v7_defconfig ARCH=arm CROSS_COMPILE=/opt/poky/1.5.1/sysroots/x86_64-pokysdk-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi- -j16 uImage LOADADDR=0x10008000
I can make kernel successfully with "bitbake -c compile -f linux-imx".  but I tried to enter kernel-source folder to build only kernel, always fail, any suggest is welcome. Thanks.
source /opt/poky/1.8+snapshot/environment-setup-cortexa7hf-vfp-neon-poky-linux-gnueabi
make zImage  LOADADDR=0x10008000
OR:
make imx_v7_defconfig ARCH=arm CROSS_COMPILE=/opt/poky/1.8+snapshot/sysroots/x86_64-pokysdk-linux/usr/bin/arm-poky-linux/arm-poky-linux- zImage LOADADDR=0x10008000
Both ways fail logs:
  CC      init/main.o
  CHK     include/generated/compile.h
  CC      init/version.o
  CC      init/do_mounts.o
  CC      init/do_mounts_rd.o
  CC      init/do_mounts_initrd.o
  LD      init/mounts.o
init/do_mounts_rd.o: In function `nop_flush_icache_all':
do_mounts_rd.c:(.text+0x0): multiple definition of `nop_flush_icache_all'
init/do_mounts.o:do_mounts.c:(.text+0x94): first defined here
init/do_mounts_rd.o: In function `nop_flush_kern_cache_all':
do_mounts_rd.c:(.text+0x4): multiple definition of `nop_flush_kern_cache_all'
init/do_mounts.o:do_mounts.c:(.text+0x98): first defined here
init/do_mounts_rd.o: In function `nop_flush_kern_cache_louis':
do_mounts_rd.c:(.text+0x8): multiple definition of `nop_flush_kern_cache_louis'
init/do_mounts.o:do_mounts.c:(.text+0x9c): first defined here
init/do_mounts_rd.o: In function `nop_flush_user_cache_all':
do_mounts_rd.c:(.text+0xc): multiple definition of `nop_flush_user_cache_all'
init/do_mounts.o:do_mounts.c:(.text+0xa0): first defined here
init/do_mounts_rd.o: In function `nop_flush_user_cache_range':
do_mounts_rd.c:(.text+0x10): multiple definition of `nop_flush_user_cache_range'
init/do_mounts.o:do_mounts.c:(.text+0xa4): first defined here
init/do_mounts_rd.o: In function `nop_coherent_kern_range':
Hi Ding
make imx_v7a_defconfig ARCH=arm CROSS_COMPILE=/opt/poky/1.5.1/sysroots/x86_64-pokysdk-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi- -j16 uImage LOADADDR=0x10008000
I am using above command, you should use poky version number accordingly.
Saurabh
The step below did not work for me. Copying the .config into the defconfig is probably not enough. My kernel baked the same with no modifications.
I tried to rename the defconfig into _defconfig under the sources path to see if bitbake would complain during the build. I did not get any errors.
I build the toolchain and downloaded the kernel source directly doing my own build (see here: https://community.freescale.com/docs/DOC-95096#comment-33274 ) as suggested by many on this forum. It works OK now.
I believe there is a mistake in the documentation:
$ git branch -b local_branch origin/imx_3.10.17_1.0.0_ga
is actually:
$ git checkout -b local_branch origin/imx_3.10.17_1.0.0_ga
Updated the doc. Thanks!
Hello Saurabh
    I followed the steps for building the kernel by building using Yocto,but the rebuild zImage  the driver:
│ -> Device Drivers
│ -> Network device support (NETDEVICES [=y])
│ -> USB Network Adapters │
│ -> Multi-purpose USB Networking Framework (y)   │
| -> Host for RNDIS and activeSync devices  (y)   |
│ -> Device Drivers
| ->USB support   (y)   |
| ->USB Gadget Support  (y) |
| ->USB Gadget Drivers (Ethernet Gadget (with CDC Ethernet support)) (y)  |
| ->RNDIS support (y) |
I added in the menuconfig did not appear in the target. If I direct use
and
$ bitbake linux-imx
it is ok
Hi All,
I tried to build kernel with below steps,
export ARCH=arm
export CROSS_COMPILE=arm-poky-linux-gnueabi-
PATH=/opt/poky/1.8/sysroots/x86_64-pokysdk-linux/usr/bin/arm-poky-linux-gnueabi:$PATH
make imx_v7_defconfig,
I got uImage , zimage and .o file for rpmsg but not .ko files.
I am using IMX7d board . please could any one tell me where i did mistake .
build completed without problem .
zimage is not working as original image .it stops in middle. log is below.
CPU:   Freescale i.MX7D rev1.0 at 792 MHz
CPU:   Temperature: can't get valid data!
Reset cause: POR
Board: i.MX7D SABRESD
I2C:   ready
DRAM:  1 GiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
*** Warning - bad CRC, using default environment
No panel detected: default to TFT43AB
Display: TFT43AB (480x272)
Video: 480x272x24
In:    serial
Out:   serial
Err:   serial
Found PFUZE300! deviceid 0x30, revid 0x10
mmc0 is current device
Net:   FEC0
Normal Boot
Hit any key to stop autoboot:  0
=> boot
reading boot.scr
** Unable to read file boot.scr **
reading zImage
6025008 bytes read in 528 ms (10.9 MiB/s)
Booting from mmc ...
reading imx7d-sdb.dtb
39438 bytes read in 20 ms (1.9 MiB/s)
Kernel image @ 0x80800000 [ 0x000000 - 0x5bef30 ]
## Flattened Device Tree blob at 83000000
   Booting using the fdt blob at 0x83000000
   Using Device Tree in place at 83000000, end 8300ca0d
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 3.14.52 (basavarajuc@UKCTS-012052-linux) (gcc version 4.9.2 (GCC) ) #1 SMP PREEMPT Thu Jan 28 16:37:39 GMT 2016
CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine model: Freescale i.MX7 SabreSD Board
cma: CMA: reserved 320 MiB at ac000000
Memory policy: Data cache writealloc
PERCPU: Embedded 8 pages/cpu @ab736000 s8320 r8192 d16256 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260096
Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk0p2 rootwait rw
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 699680K/1048576K available (7499K kernel code, 460K rwdata, 2592K rodata, 392K init, 433K bss, 348896K reserved, 0K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xc0800000 - 0xff000000   (1000 MB)
    lowmem  : 0x80000000 - 0xc0000000   (1024 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .text : 0x80008000 - 0x809e2f54   (10092 kB)
      .init : 0x809e3000 - 0x80a45080   ( 393 kB)
      .data : 0x80a46000 - 0x80ab92c0   ( 461 kB)
       .bss : 0x80ab92cc - 0x80b2591c   ( 434 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Preemptible hierarchical RCU implementation.
        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
Switching to timer-based delay loop
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655765682ns
Architected cp15 timer(s) running at 8.00MHz (phys).
sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2147483648000ns
Ignoring duplicate/late registration of read_current_timer delay
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
CPU: Testing write buffer coherency: ok
/cpus/cpu@0 missing clock-frequency property
/cpus/cpu@1 missing clock-frequency property
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x80723b58 - 0x80723bb0
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (12.00 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
pinctrl core: initialized pinctrl subsystem
regulator-dummy: no parameters
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
cpuidle: using governor menu
Use WDOG1 as reset source
syscon 30340000.iomuxc-gpr: regmap [mem 0x30340000-0x3034ffff] registered
syscon 30360000.anatop: regmap [mem 0x30360000-0x3036ffff] registered
vdd1p0d: 800 <--> 1200 mV at 1000 mV
syscon 30390000.src: regmap [mem 0x30390000-0x3039ffff] registered
DDR type is DDR3!
------------[ cut here ]------------
WARNING: CPU: 0 PID: 1 at arch/arm/mach-imx/pm-imx7.c:1097 imx7d_pm_init+0x5c0/0x66c()
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.14.52 #1
[<80014a68>] (unwind_backtrace) from [<80011758>] (show_stack+0x10/0x14)
[<80011758>] (show_stack) from [<8071d978>] (dump_stack+0x7c/0xbc)
[<8071d978>] (dump_stack) from [<80032100>] (warn_slowpath_common+0x70/0x8c)
[<80032100>] (warn_slowpath_common) from [<800321b8>] (warn_slowpath_null+0x1c/0x24)
[<800321b8>] (warn_slowpath_null) from [<80a0aa34>] (imx7d_pm_init+0x5c0/0x66c)
[<80a0aa34>] (imx7d_pm_init) from [<80a09a84>] (imx7d_init_machine+0x3c/0xe4)
[<80a09a84>] (imx7d_init_machine) from [<809e62d8>] (customize_machine+0x20/0x40)
[<809e62d8>] (customize_machine) from [<8000889c>] (do_one_initcall+0xf8/0x154)
[<8000889c>] (do_one_initcall) from [<809e3c54>] (kernel_init_freeable+0x138/0x1d8)
[<809e3c54>] (kernel_init_freeable) from [<80719df0>] (kernel_init+0x8/0xe8)
[<80719df0>] (kernel_init) from [<8000e500>] (ret_from_fork+0x14/0x34)
---[ end trace 9e8be753475f047d ]---
WARNING: CPU: 0 PID: 1 at arch/arm/mach-imx/pm-imx7.c:1098 imx7d_pm_init+0x5e8/0x66c()
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Tainted: G        W    3.14.52 #1
[<800321b8>] (warn_slowpath_null) from [<80a0aa5c>] (imx7d_pm_init+0x5e8/0x66c)
[<80a0aa5c>] (imx7d_pm_init) from [<80a09a84>] (imx7d_init_machine+0x3c/0xe4)
---[ end trace 9e8be753475f047e ]---
WARNING: CPU: 0 PID: 1 at mm/page_alloc.c:2566 __alloc_pages_nodemask+0x42c/0x974()
Modules linked in:
[<800321b8>] (warn_slowpath_null) from [<800a6a04>] (__alloc_pages_nodemask+0x42c/0x974)
[<800a6a04>] (__alloc_pages_nodemask) from [<800a6f5c>] (__get_free_pages+0x10/0x24)
[<800a6f5c>] (__get_free_pages) from [<80a0aa78>] (imx7d_pm_init+0x604/0x66c)
[<80a0aa78>] (imx7d_pm_init) from [<80a09a84>] (imx7d_init_machine+0x3c/0xe4)
---[ end trace 9e8be753475f047f ]---
WARNING: CPU: 0 PID: 1 at arch/arm/mach-imx/pm-imx7.c:1101 imx7d_pm_init+0x620/0x66c()
Modules linked in:
[<800321b8>] (warn_slowpath_null) from [<80a0aa94>] (imx7d_pm_init+0x620/0x66c)
[<80a0aa94>] (imx7d_pm_init) from [<80a09a84>] (imx7d_init_machine+0x3c/0xe4)
---[ end trace 9e8be753475f0480 ]---
failed to find ocotp node
hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 8 bytes.
imx7d-pinctrl 302c0000.iomuxc-lpsr: initialized IMX pinctrl driver
imx7d-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
303a0000.gpc supply mipi-phy not found, using dummy regulator
303a0000.gpc supply vcc not found, using dummy regulator
MU is ready for cross core communication!
bio: create slab <bio-0> at 0
mxs-dma: probe of 33000000.dma-apbh failed with error -2
usb_otg1_vbus: 5000 mV
usb_otg2_vbus: 5000 mV
can2-3v3: 3300 mV
vref-1v8: 1800 mV
wlreg_on: 5000 mV
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
usbphy_nop1.5 supply vcc not found, using dummy regulator
usbphy_nop2.6 supply vcc not found, using dummy regulator
usbphy_nop3.7 supply vcc not found, using dummy regulator
i2c i2c-0: IMX I2C adapter registered
i2c i2c-1: IMX I2C adapter registered
i2c i2c-2: IMX I2C adapter registered
i2c i2c-3: IMX I2C adapter registered
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.18
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
cfg80211: Calling CRDA to update world regulatory domain
Switched to clocksource arch_sys_counter
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
imx rpmsg driver is registered.
Bus freq driver module loaded
futex hash table entries: 512 (order: 3, 32768 bytes)
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.22)
msgmni has been set to 2006
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
backlight.8 supply power not found, using dummy regulator
MIPI DSI driver module loaded
sii902x 2-0039: No reset pin found
sii902x 2-0039: Can not read edid
30730000.lcdif supply lcd not found, using dummy regulator
mxsfb 30730000.lcdif: failed to find mxc display driver
Console: switching to colour frame buffer device 60x34
mxsfb 30730000.lcdif: initialized
imx-sdma 30bd0000.sdma: no iram assigned, using external mem
imx-sdma 30bd0000.sdma: no event needs to be remapped
imx-sdma 30bd0000.sdma: loaded firmware 4.1
imx-sdma 30bd0000.sdma: initialized
pfuze100-regulator 0-0008: Full layer: 1, Metal layer: 0
pfuze100-regulator 0-0008: FAB: 0, FIN: 0
pfuze100-regulator 0-0008: pfuze3000 found.
SW1A: 700 <--> 1425 mV at 1100 mV
SW1B: 700 <--> 1475 mV at 1000 mV
SW2: 1500 <--> 1850 mV at 1800 mV
SW3: 900 <--> 1650 mV at 1350 mV
SWBST: 5000 <--> 5150 mV at 5000 mV
VSNVS: 1000 <--> 3000 mV at 3000 mV
VREFDDR: 750 mV
VLDO1: 1800 <--> 3300 mV at 1800 mV
VLDO2: 800 <--> 1550 mV at 1500 mV
VCCSD: 2850 <--> 3300 mV at 3300 mV
V33: 2850 <--> 3300 mV at 3300 mV
VLDO3: 1800 <--> 3300 mV at 3300 mV
VLDO4: 1800 <--> 3300 mV at 2800 mV
Serial: IMX driver
30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 58, base_baud = 5000000) is a IMX
console [ttymxc0] enabled
30a70000.serial: ttymxc4 at MMIO 0x30a70000 (irq = 62, base_baud = 5000000) is a IMX
30a80000.serial: ttymxc5 at MMIO 0x30a80000 (irq = 48, base_baud = 5000000) is a IMX
serial: Freescale lpuart driver
imx sema4 driver is registered.
[drm] Initialized drm 1.1.0 20060810
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
spi_gpio spi4.16: gpio-miso property not found, switching to no-rx mode
CAN device driver interface
flexcan 30a10000.can: device registered (reg_base=f5a10000, irq=143)
30be0000.ethernet supply phy not found, using dummy regulator
pps pps0: new PPS source ptp0
libphy: fec_enet_mii_bus: probed
fec 30be0000.ethernet eth0: registered PHC device 0
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-mxc: Freescale On-Chip EHCI Host driver
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usb_ehset_test
30b10200.usbmisc supply vbus-wakeup not found, using dummy regulator
30b20200.usbmisc supply vbus-wakeup not found, using dummy regulator
30b30200.usbmisc supply vbus-wakeup not found, using dummy regulator
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
snvs_pwrkey 30370000.snvs-pwrkey: can't get snvs clock
input: 30370000.snvs-pwrkey as /devices/soc.2/30000000.aips-bus/30370000.snvs-pwrkey/input/input0
snvs_pwrkey 30370000.snvs-pwrkey: i.MX snvs powerkey probed
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
snvs_rtc 30370034.snvs-rtc-lp: can't get snvs-rtc clock
snvs_rtc 30370034.snvs-rtc-lp: rtc core: registered 30370034.snvs-rtc-l as rtc0
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
IR SANYO protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
pxp-v4l2 pxp_v4l2_out.9: initialized
i2c-core: driver [mag3110] using legacy suspend method
i2c-core: driver [mag3110] using legacy resume method
imx2-wdt 30280000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCI H4 protocol initialized
Bluetooth: HCI BCSP protocol initialized
Bluetooth: HCIATH3K protocol initialized
usbcore: registered new interface driver bcm203x
usbcore: registered new interface driver btusb
usbcore: registered new interface driver ath3k
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
sdhci-esdhc-imx 30b40000.usdhc: could not get ultra high speed state, work on normal mode
mmc0: no vqmmc regulator found
mmc0: no vmmc regulator found
mmc0: SDHCI controller on 30b40000.usdhc [30b40000.usdhc] using ADMA
sdhci-esdhc-imx 30b50000.usdhc: assigned as wifi host
mmc1: no vqmmc regulator found
mmc1: no vmmc regulator found
mmc0: new SD card at address a77f
mmcblk0: mmc0:a77f SU01G 968 MiB
mmcblk0: p1 p2
mmc1: SDHCI controller on 30b50000.usdhc [30b50000.usdhc] using ADMA
mmc2: no vqmmc regulator found
mmc2: no vmmc regulator found
mmc2: SDHCI controller on 30b60000.usdhc [30b60000.usdhc] using ADMA
Job Ring Device allocation for transform failed
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
Thanks in advance .
To build module use following command.
make ARCH=arm  CROSS_COMPILE=arm-poky-linux-gnueabi- modules_install INSTALL_MOD_PATH=../modules
Hi saurabh
Thanks for your replay .but zImage not running in my board [I am using IMX7D]
I followed following steps
1.clean evertthing
$ make distclean
2.install variables .
$ source /opt/poky/1.8/environment-setup-armv7a-vfp-neon-poky-linux-gnueabi
3.configuration written to .config
$ make imx_v7_defconfig
4.run make
$ make ARCH=arm  CROSS_COMPILE=arm-poky-linux-gnueabi-
I got zImage , i copied to my sd card and it start running but stops below
Starting kernel ...
PERCPU: Embedded 8 pages/cpu @ab734000 s8320 r8192 d16256 u32768
Memory: 699668K/1048576K available (7499K kernel code, 460K rwdata, 2592K rodata, 392K init, 433K bss, 348908K reserved, 0K highmem)
Brought up 2 CPUs
syscon 30350000.ocotp-ctrl: regmap [mem 0x30350000-0x3035ffff] registered
DDR type is DDR3!
mxs-dma 33000000.dma-apbh: initialized
can2-3v3: 3300 mV
vref-1v8: 1800 mV
platform 4.regulator: Driver reg-fixed-voltage requests probe deferral
VDD_SD1: 3300 mV
wlreg_on: 5000 mV
usbphy_nop1.8 supply vcc not found, using dummy regulator
usbphy_nop2.9 supply vcc not found, using dummy regulator
usbphy_nop3.10 supply vcc not found, using dummy regulator
backlight.11 supply power not found, using dummy regulator
SW1A: 700 <--> 3300 mV at 1100 mV
VREFDDR: 750 mV
Serial: IMX driver
30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 58, base_baud = 1500000) is a IMX
brd: module loaded
loop: module loaded
input: fxos8700 as /devices/soc.2/30800000.aips-bus/30a30000.i2c/i2c-1/1-001e/input/input0
fxos8700 device driver probe successfully
input: fxas2100x as /devices/soc.2/30800000.aips-bus/30a30000.i2c/i2c-1/1-0020/input/input1
fxas2100x 1-0020: fxas2100x device driver probe successfully
spi_gpio spi4.20: gpio-miso property not found, switching to no-rx mode
input: 30370000.snvs-pwrkey as /devices/soc.2/30000000.aips-bus/30370000.snvs-pwrkey/input/input2
read mpl3115 chip id 0xc4
input: mpl3115 as /devices/virtual/input/input3
mpl3115 device driver probe successfully
pxp-v4l2 pxp_v4l2_out.12: initialized
mmcblk0: p1 p2
caam 30900000.caam: Instantiated RNG4 SH0
caam 30900000.caam: Instantiated RNG4 SH1
caam 30900000.caam: device ID = 0x0a160300 (Era 8)
caam 30900000.caam: job rings = 3, qi = 0
caam algorithms registered in /proc/crypto
caam_jr 30901000.jr0: registering rng-caam
platform caam_sm: blkkey_ex: 8 keystore units available
platform caam_sm: 64-bit clear key:
platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
platform caam_sm: 64-bit black key:
platform caam_sm: [0000] 93 cb b6 73 c2 c1 dc e7
platform caam_sm: [0008] 99 7b 89 07 71 73 e3 24
platform caam_sm: 128-bit clear key:
platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
platform caam_sm: 128-bit black key:
platform caam_sm: [0000] 9b 3d 8e 22 13 79 04 8d
platform caam_sm: [0008] f7 57 10 07 f5 b9 75 fc
platform caam_sm: 192-bit clear key:
platform caam_sm: [0016] 10 11 12 13 14 15 16 17
platform caam_sm: 192-bit black key:
platform caam_sm: [0000] 20 5f 25 0a 39 d1 23 40
platform caam_sm: [0008] d6 65 be 13 03 53 02 53
platform caam_sm: [0016] 14 7c 71 e2 cd 18 e2 e5
platform caam_sm: [0024] f9 90 88 a3 e8 16 01 b8
platform caam_sm: 256-bit clear key:
platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
platform caam_sm: 256-bit black key:
platform caam_sm: [0000] 0f 23 ef 13 93 96 c1 70
platform caam_sm: [0008] 4b f9 2c 20 81 90 20 ea
platform caam_sm: [0016] 10 ab 2b 88 85 f8 9e b1
platform caam_sm: [0024] 31 ed a7 77 5b e3 5d dd
platform caam_sm: 64-bit unwritten blob:
platform caam_sm: [0000] 00 00 00 00 00 00 00 00
platform caam_sm: [0008] 00 00 00 00 00 00 00 00
platform caam_sm: [0016] 00 00 00 00 00 00 00 00
platform caam_sm: [0024] 00 00 00 00 00 00 00 00
platform caam_sm: [0032] 00 00 00 00 00 00 00 00
platform caam_sm: [0040] 00 00 00 00 00 00 00 00
platform caam_sm: [0048] 00 00 00 00 00 00 00 00
platform caam_sm: [0056] 00 00 00 00 00 00 00 00
platform caam_sm: [0064] 00 00 00 00 00 00 00 00
platform caam_sm: [0072] 00 00 00 00 00 00 00 00
platform caam_sm: [0080] 00 00 00 00 00 00 00 00
platform caam_sm: [0088] 00 00 00 00 00 00 00 00
platform caam_sm: 128-bit unwritten blob:
platform caam_sm: 196-bit unwritten blob:
platform caam_sm: 256-bit unwritten blob:
platform caam_sm: 64-bit black key in blob:
platform caam_sm: [0000] af 46 8f 41 c4 31 42 ec
platform caam_sm: [0008] b3 96 0b 74 7e 68 05 b6
platform caam_sm: [0016] 27 91 f4 22 39 38 f4 33
platform caam_sm: [0024] 00 4c 65 ca 2c ed 21 b2
platform caam_sm: [0032] 4f cf 06 a6 9e 9f 25 fe
platform caam_sm: [0040] d0 8c 01 10 fd b0 7f f6
platform caam_sm: [0048] 79 c4 42 bb 02 2e dd c2
platform caam_sm: 128-bit black key in blob:
platform caam_sm: [0000] ad 07 f1 a8 87 71 86 38
platform caam_sm: [0008] f4 62 6e c7 c7 f0 74 69
platform caam_sm: [0016] 73 c7 f7 92 0c 43 e1 2d
platform caam_sm: [0024] 17 50 3b 74 f4 e7 4c 89
platform caam_sm: [0032] 45 62 fb ba 59 bc 9e ea
platform caam_sm: [0040] 91 56 f3 91 97 03 2b a3
platform caam_sm: [0048] 1b c7 3f b3 11 46 2a a9
platform caam_sm: [0056] 6f af e5 4c f0 76 72 8e
platform caam_sm: 192-bit black key in blob:
platform caam_sm: [0000] b6 ea c9 44 1b 06 01 4a
platform caam_sm: [0008] d2 5a a0 61 e0 56 0f ff
platform caam_sm: [0016] db b6 b8 78 da 63 52 e6
platform caam_sm: [0024] 23 5c f7 97 3d af e2 60
platform caam_sm: [0032] aa 57 3c f0 5d 40 54 c3
platform caam_sm: [0040] 44 b3 4f 05 3b 76 16 e6
platform caam_sm: [0048] d7 74 9c a0 62 0f 2f dc
platform caam_sm: [0056] 03 53 96 9e 34 00 55 93
platform caam_sm: [0064] d0 b0 b4 fd 5b 66 58 93
platform caam_sm: 256-bit black key in blob:
platform caam_sm: [0000] 76 46 0f f3 de 76 ef b0
platform caam_sm: [0008] 4e 4a 27 d5 7f 1b 0b f2
platform caam_sm: [0016] 9a 5d e1 6d b4 f9 df 21
platform caam_sm: [0024] 8b 94 77 80 d7 cb dc 34
platform caam_sm: [0032] 93 82 83 b5 02 52 53 82
platform caam_sm: [0040] 33 15 31 11 67 48 57 f3
platform caam_sm: [0048] e1 4d 78 20 1c ec fe d5
platform caam_sm: [0056] 2b d2 28 79 35 01 91 3d
platform caam_sm: [0064] 6e f8 3c 0e 1e 23 63 8d
platform caam_sm: [0072] 47 2a 09 24 a1 a3 ba 1d
platform caam_sm: restored 64-bit black key:
platform caam_sm: [0000] 6e dc c9 9d e2 d9 99 9e
platform caam_sm: [0008] fb ef 17 6a ff 72 e8 a1
platform caam_sm: restored 128-bit black key:
platform caam_sm: restored 192-bit black key:
platform caam_sm: [0016] 23 ea 1f 67 b1 4d 98 1a
platform caam_sm: [0024] 1c f8 ed d5 30 96 07 fe
platform caam_sm: restored 256-bit black key:
snvs-secvio 30370000.caam-snvs: can't get snvs clock
snvs-secvio 30370000.caam-snvs: violation handlers armed - non-secure state
coresight-tmc 30086000.etr: TMC initialized
coresight-tmc 30084000.etf: TMC initialized
coresight-tpiu 30087000.tpiu: TPIU initialized
coresight-funnel 30083000.funnel: FUNNEL initialized
coresight-funnel 30041000.funnel: FUNNEL initialized
coresight-replicator replicator.1: REPLICATOR initialized
coresight-etm3x 3007c000.etm: ETM initialized
coresight-etm3x 3007d000.etm: ETM initialized
imx-wm8960 sound.18: wm8960-hifi <-> 308a0000.sai mapping ok
imx-sii902x sound-hdmi.19: snd-soc-dummy-dai <-> 308a0000.sai mapping ok
NET: Registered protocol family 26
TCP: cubic registered
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
SWBST: disabling
wlreg_on: disabling
can2-3v3: disabling
usb_otg1_vbus: disabling
regulator-dummy: disabling
imx mcc test is registered.
MPCIE_3V3: 3300 mV
snvs_rtc 30370034.snvs-rtc-lp: setting system clock to 1970-01-01 00:00:01 UTC (1)
ALSA device list:
  #0: wm8960-audio
  #1: sii902x-audio
random: nonblocking pool is initialized
kjournald starting.  Commit interval 5 seconds
EXT3-fs (mmcblk0p2): using internal journal
EXT3-fs (mmcblk0p2): recovery complete
EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
VFS: Mounted root (ext3 filesystem) on device 179:2.
devtmpfs: mounted
Freeing unused kernel memory: 392K (809e3000 - 80a45000)
INIT: version 2.88 booting
Starting udev
udev: Not using udev cache because of changes detected in the following files:
udev:     /proc/version /proc/cmdline /proc/devices
udev:     lib/udev/rules.d/* etc/udev/rules.d/*
udev: The udev cache will be regenerated. To identify the detected changes,
udev: compare the cached sysconf at   /etc/udev/cache.data
udev: against the current sysconf at  /dev/shm/udev.cache
udevd[170]: starting version 182
bootlogd: cannot allocate pseudo tty: No such file or directory
Populating dev cache
ALSA: Restoring mixer settings..
have any idea about this problem ?
how can i get working zImage .?
Thanks in advance
I got it working .
Problem was i was using old build dtb files ..
now SCP is not working .
$ scp /mnt/hgfs/VM_SHARE1/hello/hello root@10.29.99.114:/home/root
ssh: connect to host 10.29.99.114 port 22: Connection refused
lost connection.
any one have idea about this.
I am going to compile kernel manually for yocto Linux environment.
1. I download recipe file from  https://github.com/Freescale/meta-fsl-arm-extra
and bitbake 3.14.28 kernel without any problem and install it to on sabre lite board.
2. Then i try to compile 3.14.28 kernel manually.
     . Install toolchain to YOCT environment
     . get linux-3.14.tar.xz source from ~/fsl-release-bsp/downloads
     .Extract it
     . go to linux-3.14 directory and run following commands
          $export ARCH=arm
          $export CROSS_COMPILE=arm-poky-linux-gnueabi-
          $make imx_v6_v7_defconfig
          $export PATH=$PATH:/opt/poky/1.6.2/sysroots/x86_64-pokysdk-linux/usr/bin/arm-poky-linux-gnueabi
          $make
          $make uImage LOADADDR=0x10008000
     . Copy images to boot partition of SD card of sabre lite device.
     $cp arch/arm/boot/uImage arch/arm/boot/dts/imx6q-sabrelite.dtb <boot partition>
All steps work fine and but have a problem with a display.
I have 2 display units (sabre lite display and HDMI monitor )
In step 1 we have display on HDMI monitor only.
In step 2 we have display on sabre lite display only.
I need to get display on HDMI monitor in step 2 .
Ultimate goal of my work is compile latest kernel and install it on SD card of sabre lite device with a  HDMI monitor.
In step 1 there are 2 Framebuffer device under /dev folder(fb0 and fb1) but in step 2 there is only one.
campier the configuration of above two steps and found that there is no "MXC support drivers setting" on step 2 configuration.
Seems that "MXC support drivers" setting is need in configuration to get display on HDMI monitor in step 2 .
How should i get MXC support drivers setting in step 2 configuration or Get display on HDMI monitor in step 2.
Thanks in advance
I'm having trouble determining where to copy my customized ".config" to in the "Building using Yocto / 2. Configuring the kernel" step above.
I'm building the "fsl-imx-fb" distribution for an i.MX6 UltraLite Evaluation Kit ("imx6ulevk") per the instructions in the "Freescale_Yocto_Project_User's_Guide.pdf" contained within the "Freescale Document Archive - L4.1.15_1.2.0_LINUX_DOCS" ("fsl-yocto-L4.1.15_1.2.0-ga.tar.gz").
repo init -u git://git.freescale.com/imx/fsl-arm-yocto-bsp.git -b imx-4.1.15-1.0.0_ga
DISTRO=fsl-imx-fb MACHINE=imx6ulevk source fsl-setup-release.sh
bitbake core-image-base
Any suggestions? Thanks!
How can I get access to https://community.nxp.com/docs/DOC-94035?
This is mentioned under "1 - Baking (building) the kernel" and "3 - Setting the environment variables".
I clicked on that and it says, "Access to this place or content is restricted. If you think this is a mistake, please contact your administrator or the person who directed you here."
I have sent You the information via e-mail.
Yuri.
i wave the same problem accessing this file...
Please, can you help me too?
Andreas Schneider
Sorry the bad link. I just updated the page.
The correct link is: https://community.nxp.com/docs/DOC-94849
Rogerio
Do you have any defconfig which is not related to Board which is just specific to IMX6 families. Like if i refer  imx_v7_defconfig it has extra defconfigs like Sound driver, MMC, MTD which is not used for my board. So i need a defconfig which is based on 4.1.15 Kernel and purely has necessary configs related to IMX6 and Interfaces like IPU,I2C,Thermal,SPI, etc
No. My suggestion is to use the imx_v7_defconfig and remove all items that are not necessary to your project.
Rogerio
Does anyone knows the difference between /work/../git and /work-shared/ folder ?
Seems that both showing kernel source files, so I don't understand the difference,
Thank you,
Ran
%3CLINGO-SUB%20id%3D%22lingo-sub-1110576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELinux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-381413524%22%20id%3D%22toc-hId-1304215752%22%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FBuilding-Linux-Kernel%2Fta-p%2F1110576%23toc-hId--745982569%22%20target%3D%22_blank%22%3EYocto%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%9F%E5%BB%BA%E7%89%A9%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FBuilding-Linux-Kernel%2Fta-p%2F1110576%23toc-hId--1862875558%22%20target%3D%22_blank%22%3E1%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%99%E3%82%A4%E3%82%AF%20(%E3%83%93%E3%83%AB%E3%83%89)%20%E3%81%99%E3%82%8B%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FBuilding-Linux-Kernel%2Fta-p%2F1110576%23toc-hId-624637275%22%20target%3D%22_blank%22%3E2%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FBuilding-Linux-Kernel%2Fta-p%2F1110576%23toc-hId--1182817188%22%20target%3D%22_blank%22%3E3%20-%20%E6%96%B0%E3%81%97%E3%81%84%E6%A7%8B%E6%88%90%E3%81%A7%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%97%E3%81%A6%E5%86%8D%E5%BA%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FBuilding-Linux-Kernel%2Fta-p%2F1110576%23toc-hId-1294192541%22%20target%3D%22_blank%22%3EBSP%20%E3%81%AA%E3%81%97%E3%81%AE%E5%BB%BA%E7%89%A9%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FBuilding-Linux-Kernel%2Fta-p%2F1110576%23toc-hId--636443542%22%20target%3D%22_blank%22%3E1-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FBuilding-Linux-Kernel%2Fta-p%2F1110576%23toc-hId-1851069291%22%20target%3D%22_blank%22%3E2%20-%20%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FBuilding-Linux-Kernel%2Fta-p%2F1110576%23toc-hId--1763839635%22%20target%3D%22_blank%22%3E3%20-%20%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FBuilding-Linux-Kernel%2Fta-p%2F1110576%23toc-hId-852755917%22%20target%3D%22_blank%22%3E3.1%20-%20Yocto%20Toolchain%20%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FBuilding-Linux-Kernel%2Fta-p%2F1110576%23toc-hId--954698546%22%20target%3D%22_blank%22%3E3.2%20-%20Ubuntu%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A75px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FBuilding-Linux-Kernel%2Fta-p%2F1110576%23toc-hId-1661897006%22%20target%3D%22_blank%22%3E64%E3%83%93%E3%83%83%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E7%94%A8(i.MX8%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA)%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A75px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FBuilding-Linux-Kernel%2Fta-p%2F1110576%23toc-hId--1953011920%22%20target%3D%22_blank%22%3E32%E3%83%93%E3%83%83%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E7%94%A8(i.MX2%E3%80%81i.MX3%E3%80%81i.MX5%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3i.MX6%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA)%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FBuilding-Linux-Kernel%2Fta-p%2F1110576%23toc-hId-276335475%22%20target%3D%22_blank%22%3E4%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A25px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FBuilding-Linux-Kernel%2Fta-p%2F1110576%23toc-hId--832957047%22%20target%3D%22_blank%22%3E5%20-%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FH1%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH1%20id%3D%22toc-hId--1426040939%22%20id%3D%22toc-hId--503238711%22%3E%3CBR%20%2F%3E%3C%2FH1%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH1%20id%3D%22toc-hId-1061471894%22%20id%3D%22toc-hId-1984274122%22%3E%3CBR%20%2F%3E%3C%2FH1%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH1%20id%3D%22toc-hId--745982569%22%20id%3D%22toc-hId-176819659%22%3EYocto%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%9F%E5%BB%BA%E7%89%A9%3C%2FH1%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH2%20id%3D%22toc-hId--55421095%22%20id%3D%22toc-hId-867381133%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH2%20id%3D%22toc-hId--1862875558%22%20id%3D%22toc-hId--940073330%22%3E1%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%99%E3%82%A4%E3%82%AF%20(%E3%83%93%E3%83%AB%E3%83%89)%20%E3%81%99%E3%82%8B%3C%2FH2%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EYocto%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%20(%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%96%B9%E6%B3%95%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81Yocto%20%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%20%E3%83%9B%E3%83%BC%E3%83%A0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%20%3CA%20_jive_internal%3D%22true%22%20class%3D%22jivelink3%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%22%20title%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%3C%2FA%3E)%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AF%20%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fdeploy%2Fimages%2F%3CYOUR_TARGET%3E%2FuImage%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FYOUR_TARGET%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%81%BF%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20bitbake%20linux-imx%3C%2FP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FBLOCKQUOTE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH2%20id%3D%22toc-hId-624637275%22%20id%3D%22toc-hId-1547439503%22%3E2%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FH2%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%20menuconfig%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20bitbake%20-c%20menuconfig%20linux-imx%3C%2FP%3E%26nbsp%3B%26nbsp%3B%20%3C%2FBLOCKQUOTE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%8C%E9%96%8B%E3%81%8D%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%80%81configmenu%E3%82%92%E7%B5%82%E4%BA%86%E3%81%97%E3%81%A6.config%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%20defconfig%20%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20cp%20tmp%2Fwork%2Fimx6qsabresd-poky-linux-gnueabi%2Flinux-imx%2F3.0.35-r33.10%2Fgit%2F.config%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E..%2Fsources%2Fmeta-fsl-arm%2Frecipes-kernel%2Flinux%2Flinux-imx-3.0.35%2Fmx6%2Fdefconfig%3C%2FP%3E%26nbsp%3B%26nbsp%3B%20%3C%2FBLOCKQUOTE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%80%81%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%8C3.0.35-r33.10%E3%80%8D%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH2%20id%3D%22toc-hId--1182817188%22%20id%3D%22toc-hId--260014960%22%3E3%20-%20%E6%96%B0%E3%81%97%E3%81%84%E6%A7%8B%E6%88%90%E3%81%A7%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%97%E3%81%A6%E5%86%8D%E5%BA%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%3C%2FH2%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH2%20id%3D%22toc-hId-1304695645%22%20id%3D%22toc-hId--2067469423%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%20defconfig%20%E3%82%92%E6%AD%A3%E3%81%97%E3%81%84%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%9F%E3%82%89%20(%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%202)%E3%80%81%E4%BB%A5%E5%89%8D%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%81%99%E3%81%B9%E3%81%A6%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%97%E3%81%A6%E5%86%8D%E5%BA%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%3E%24%20bitbake%20-c%20cleansstate%20linux-imx%3C%2FP%3E%3CP%3E%24%20bitbake%20%3CYOUR_IMAGE%3E%20%E3%81%BE%E3%81%9F%E3%81%AF%20%24%20bitbake%20linux-imx%3C%2FYOUR_IMAGE%3E%3C%2FP%3E%26nbsp%3B%26nbsp%3B%20%3C%2FBLOCKQUOTE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EuImage%20%E3%81%AF%20tmp%2Fdeploy%2Fimage%20%E3%81%AE%E4%B8%8B%E3%81%AB%E7%BD%AE%E3%81%8B%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH1%20id%3D%22toc-hId-1294192541%22%20id%3D%22toc-hId--2077972527%22%3EBSP%20%E3%81%AA%E3%81%97%E3%81%AE%E5%BB%BA%E7%89%A9%3C%2FH1%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH2%20id%3D%22toc-hId--636443542%22%20id%3D%22toc-hId-286358686%22%3E1-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%3C%2FH2%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%80%9A%E5%B8%B8%E3%80%81NXP%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3(kernel.org)%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%EF%BC%9A%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3ENXP%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E5%A0%B4%E5%90%88(%20%3CA%20class%3D%22jivelink3%22%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Flinux-imx%2F%22%20title%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Flinux-imx%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Flinux-imx%2F%3C%2FA%3E%26nbsp%3B)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20git%20clone%20%3CA%20class%3D%22link-bare%22%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Flinux-imx%22%20title%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Flinux-imx%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Flinux-imx%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FBLOCKQUOTE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB(%20%3CA%20class%3D%22unlinked%22%20title%3D%22https%3A%2F%2Fwww.kernel.org%2F%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.kernel.org%2F%3C%2FA%3E%20%E3%81%AE%E8%A9%B3%E7%B4%B0)%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20git%20clone%20git%3A%2F%2Fgit.kernel.org%2Fpub%2Fscm%2Flinux%2Fkernel%2Fgit%2Fstable%2Flinux-stable.git%3C%2FP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FBLOCKQUOTE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH2%20id%3D%22toc-hId-1851069291%22%20id%3D%22toc-hId--1521095777%22%3E2%20-%20%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%3C%2FH2%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E4%BB%A5%E4%B8%8B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20git%20branch%20-a%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2060px%3B%22%3E%E4%B8%BB%E4%BA%BA%3CBR%20%2F%3Eremotes%2Forigin%2FHEAD%20-%26gt%3B%20origin%2Fmaster%3CBR%20%2F%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%2Forigin%2Fimx_4.9.123_imx8mm_ga%3CBR%20%2F%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%2Forigin%2Fimx_4.9.51_imx8_beta1%3CBR%20%2F%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%2Forigin%2Fimx_4.9.51_imx8_beta2%3CBR%20%2F%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%2Forigin%2Fimx_4.9.51_imx8m_beta%3CBR%20%2F%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%2Forigin%2Fimx_4.9.51_imx8m_ga%3CBR%20%2F%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%2Forigin%2Fimx_4.9.88_2.0.0_ga%3CBR%20%2F%3Eremotes%2Forigin%2Fimx_4.9.88_imx8mm_alpha%3CBR%20%2F%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%2Forigin%2Fimx_4.9.88_imx8qxp_beta2%3CBR%20%2F%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%2F%E3%82%AA%E3%83%AA%E3%82%B8%E3%83%B3%2F%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E3%83%AA%E3%82%B9%E3%83%88%E3%81%8B%E3%82%89%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%80%81%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20git%20checkout%20-b%20local_branch%20origin%2Fimx_4.9.88_2.0.0_ga%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSTRONG%3E*%E7%AD%86%E8%A8%98%EF%BC%9A%3C%2FSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%E7%A7%81%E3%81%AE%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E5%90%8D%E3%81%AF%E3%80%8Clocal_branch%E3%80%8D%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%AF%E3%81%8A%E5%A5%BD%E3%81%BF%E3%81%A7%E9%81%B8%E3%81%B6%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%9F%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AF%20origin%2Fimx_4.9.88_2.0.0_ga%20%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E5%B8%B8%E3%81%ABorigin%2F.......%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%8B%E5%88%A5%E3%81%AE%E3%82%82%E3%81%AE%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH1%20id%3D%22toc-hId--85467891%22%20id%3D%22toc-hId-837334337%22%3E%3CBR%20%2F%3E%3C%2FH1%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH2%20id%3D%22toc-hId--1763839635%22%20id%3D%22toc-hId--841037407%22%3E3%20-%20%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FH2%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH3%20id%3D%22toc-hId-852755917%22%20id%3D%22toc-hId-1775558145%22%3E3.1%20-%20Yocto%20Toolchain%20%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FH3%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EYocto%20SDK%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88(NXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AEYocto%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%20%3CA%20_jive_internal%3D%22true%22%20class%3D%22jivelink5%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%22%20title%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%3C%2FA%3E%20)%E3%80%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E5%BF%85%E8%A6%81%E3%81%AA%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%82%92%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20source%20%2Fopt%2Fpoky%2F1.6%2Bsnapshot%2Fenvironment-setup-cortexa9hf-vfp-neon-poky-linux-gnueabi%20%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%22%3E%24%20%3C%2FSPAN%3E%E6%9C%AA%E8%A8%AD%E5%AE%9A%E3%81%AELDFLAGS%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E5%88%A5%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20export%20PATH%3D%24PATH%EF%BC%9A%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%2Ffsl-linaro-toolchain%2Fbin%2F%3CBR%20%2F%3E%20%24%20export%20TOOLCHAIN%3D%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%2Ffsl-linaro-toolchain%2F%3CBR%20%2F%3E%20%24%20export%20CROSS_COMPILE%3Darm-none-linux-gnueabi-%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20export%20ARCH%3Darm%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E9%87%8D%E8%A6%81%3A%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E5%A4%89%E6%95%B0%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH3%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2018px%3B%22%20id%3D%22toc-hId--954698546%22%20id%3D%22toc-hId--31896318%22%3E3.2%20-%20Ubuntu%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FH3%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH4%20id%3D%22toc-hId-1661897006%22%20id%3D%22toc-hId--1710268062%22%3E%3CSTRONG%3E64%E3%83%93%E3%83%83%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E7%94%A8(i.MX8%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA)%3C%2FSTRONG%3E%3C%2FH4%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E64%E3%83%93%E3%83%83%E3%83%88%E7%94%A8%E3%81%AEGCC%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%20%20%20%3CP%3Esudo%20apt-get%20install%20gcc-aarch64-linux-gnu%3C%2FP%3E%20%3C%2FBLOCKQUOTE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%82%92%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%20%20%20%3CP%3E%24%20export%20ARCH%3Darm64%3CBR%20%2F%3E%24%20export%20CROSS_COMPILE%3D%2Fusr%2Fbin%2Faarch64-linux-gnu-%3C%2FP%3E%20%3C%2FBLOCKQUOTE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH4%20id%3D%22toc-hId--145557457%22%20id%3D%22toc-hId-777244771%22%3E%3CBR%20%2F%3E%3C%2FH4%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH4%20id%3D%22toc-hId--1953011920%22%20id%3D%22toc-hId--1030209692%22%3E%3CSTRONG%3E32%E3%83%93%E3%83%83%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E7%94%A8(i.MX2%E3%80%81i.MX3%E3%80%81i.MX5%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3i.MX6%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA)%3C%2FSTRONG%3E%3C%2FH4%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22font-weight%3A%20400%3B%22%3E32%E3%83%93%E3%83%83%E3%83%88%E7%94%A8%E3%81%AEGCC%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%20style%3D%22background%3A%20none%20%23f6f6f6%3B%20border-left%3A%202px%20solid%20%23cccccc%3B%20font-weight%3A%20400%3B%20margin%3A%2010px%200px%3B%20padding%3A%2010px%2020px%3B%22%3E%20%20%20%3CP%3Esudo%20apt-get%20install%20gcc-arm-linux-gnueabi%3C%2FP%3E%20%3C%2FBLOCKQUOTE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22font-weight%3A%20400%3B%22%3E%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%82%92%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%20style%3D%22background%3A%20none%20%23f6f6f6%3B%20border-left%3A%202px%20solid%20%23cccccc%3B%20font-weight%3A%20400%3B%20margin%3A%2010px%200px%3B%20padding%3A%2010px%2020px%3B%22%3E%20%20%20%3CP%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20ARCH%3Darm%3CBR%20%2F%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20CROSS_COMPILE%3D%2Fusr%2Fbin%2Farm-linux-gnueabi-%3C%2FP%3E%20%3C%2FBLOCKQUOTE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH2%20id%3D%22toc-hId-276335475%22%20id%3D%22toc-hId-1199137703%22%3E4%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FH2%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3Ei.MX6%20%E3%81%8A%E3%82%88%E3%81%B3%20i.MX5%20%E7%94%A8%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20imx_v7_defconfig%20%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20cp%20arch%2Farm%2Fconfigs%2F%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%22%3Eimx_v7_defconfig%26nbsp%3B.config%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%22%3E%24%20make%20menuconfig%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%22%3E%24%20make%3C%2FSPAN%3E%3C%2FP%3E%20%20%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3C%2FBLOCKQUOTE%3E%3C%2FBLOCKQUOTE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3Ei.MX8%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E7%94%A8%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20arm64%2Fdefconfig%20%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%20%20%20%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%24%20cp%20arch%2Farm64%2Fconfigs%2Fdefconfig%20.config%3C%2FP%3E%20%20%20%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%24%20make%20menuconfig%3C%2FP%3E%20%20%20%3CP%3E%24%E4%BD%9C%E3%82%8B%3C%2FP%3E%20%3C%2FBLOCKQUOTE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH2%20id%3D%22toc-hId--832957047%22%20id%3D%22toc-hId-89845181%22%3E5%20-%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FH2%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E6%89%8B%E9%A0%86%204%20%E3%81%AE%E5%BE%8C%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20(uImage%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB)%20%E3%81%AE%E3%81%BF%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E6%97%A2%E7%9F%A5%E3%81%AE%E3%83%91%E3%82%B9%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%8A%E3%82%88%E3%81%B3%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9A%E3%80%81%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20make%20modules%3C%2FP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FBLOCKQUOTE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CBLOCKQUOTE%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20make%20modules_install%20INSTALL_MOD_PATH%3D%2Fpath_where_you_want_to_install%3C%2FP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AA%B0%E3%81%8B%E3%81%8C%2F%20work%20%2F.%E3%81%AE%E9%81%95%E3%81%84%E3%82%92%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%2Fgit%20%E3%81%A8%20%2Fwork-shared%2F%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%3F%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E9%81%95%E3%81%84%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%A9%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%84%E3%81%84%E3%81%88%E3%80%82%E7%A7%81%E3%81%AE%E6%8F%90%E6%A1%88%E3%81%AF%E3%80%81imx_v7_defconfig%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E4%B8%8D%E8%A6%81%E3%81%AA%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%A2%E3%82%A4%E3%83%86%E3%83%A0%E3%82%92%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ERogerio%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110608%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110608%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EIMX6%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%83%BC%E3%81%AB%E5%9B%BA%E6%9C%89%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%AA%E3%81%84defconfig%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E7%A7%81%E3%81%8C%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Eimx_v7_defconfig%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%80%81MMC%E3%80%81MTD%E3%81%AA%E3%81%A9%E3%81%AE%E8%BF%BD%E5%8A%A0%E3%81%AEdefconfigs%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%814.1.15%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81IMX6%E3%81%8A%E3%82%88%E3%81%B3IPU%E3%80%81I2C%E3%80%81Thermal%E3%80%81SPI%E3%81%AA%E3%81%A9%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AA%E6%A7%8B%E6%88%90%E3%82%92%E7%B4%94%E7%B2%8B%E3%81%AB%E6%8C%81%E3%81%A4defconfig%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%AA%E3%81%84%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%A7%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A1%E3%82%87%E3%81%86%E3%81%A9%E3%83%9A%E3%83%BC%E3%82%B8%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A3%E3%81%97%E3%81%84%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ERogerio%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A8%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%82%92%E6%8C%AF%E3%82%8A%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E7%A7%81%E3%82%82%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EAndreas%20Schneider%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AB%E9%9B%BB%E5%AD%90%E3%83%A1%E3%83%BC%E3%83%AB%E3%81%A7%E6%83%85%E5%A0%B1%E3%82%92%E9%80%81%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EYuri.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20_jive_internal%3D%22true%22%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94035%22%20title%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94035%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94035%3C%2FA%3E%20%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%80%8C1%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%99%E3%82%A4%E3%82%AF%20(%E3%83%93%E3%83%AB%E3%83%89)%E3%80%8D%E3%81%8A%E3%82%88%E3%81%B3%E3%80%8C3%20-%20%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%80%8D%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%80%8C%E3%81%93%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%81%B8%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AF%E5%88%B6%E9%99%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%8C%E9%96%93%E9%81%95%E3%81%84%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%86%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E7%AE%A1%E7%90%86%E8%80%85%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%93%E3%81%93%E3%81%AB%E3%81%82%E3%81%AA%E3%81%9F%E3%82%92%E6%A1%88%E5%86%85%E3%81%97%E3%81%9F%E4%BA%BA%E3%81%AB%E9%80%A3%E7%B5%A1%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%81%97%E3%81%9F%E3%80%8C.config%E3%80%8D%E3%82%92%E3%80%8CBuilding%20using%20Yocto%20%2F%202.%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%80%8D%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%80%8CFreescale_Yocto_Project_User's_Guide.pdf%E3%80%8D%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81i.MX6%20Ultra%20Light%20%E8%A9%95%E4%BE%A1%E3%82%AD%E3%83%83%E3%83%88%20(%22imx6ulevk%22)%20%E3%81%AE%20%22fsl-imx-fb%22%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%80%8CFreescale%20Document%20Archive%20-%20L4.1.15_1.2.0_LINUX_DOCS%E3%80%8D(%E4%BB%A5%E4%B8%8B%E3%80%8Cfsl-yocto-L4.1.15_1.2.0-ga.tar.gz%E3%80%8D)%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%20init%20-u%20git%3A%2F%2Fgit.freescale.com%2Fimx%2Ffsl-arm-yocto-bsp.git%20-b%20imx-4.1.15-1.0.0_ga%3CBR%20%2F%3EDISTRO%3Dfsl-imx-fb%20MACHINE%3Dimx6ulevk%20%E3%82%BD%E3%83%BC%E3%82%B9%20fsl-setup-release.sh%3CBR%20%2F%3Ebitbake%20%E3%82%B3%E3%82%A2%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20%E3%83%99%E3%83%BC%E3%82%B9%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8B%E6%8F%90%E6%A1%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E6%84%9F%E8%AC%9D%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3Eyocto%20Linux%E7%92%B0%E5%A2%83%E7%94%A8%E3%81%AB%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E1.%3CA%20class%3D%22jive-link-external-small%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fgithub.com%252FFreescale%252Fmeta-fsl-arm-extra%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%23017bba%3B%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%2Fmeta-fsl-arm-extra%20%3C%2FA%3E%20%E3%81%8B%E3%82%89%E3%83%AC%E3%82%B7%E3%83%94%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81bitbake%203.14.28%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E3%80%81Sabre%20Lite%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E2.%E6%AC%A1%E3%81%AB%E3%80%813.14.28%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E.%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92YOCT%E7%92%B0%E5%A2%83%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E.linux-3.14.tar.xz%20%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%20~%2Ffsl-release-bsp%2Fdownloads%20%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E.%E6%8A%BD%E5%87%BA%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E.linux-3.14%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%24export%20ARCH%3Darm%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%24export%20CROSS_COMPILE%3Darm-poky-linux-gnueabi-%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24make%20imx_v6_v7_defconfig%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24export%20PATH%3D%24PATH%3A%2Fopt%2Fpoky%2F1.6.2%2Fsysroots%2Fx86_64-pokysdk-linux%2Fusr%2Fbin%2Farm-poky-linux-gnueabi%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%24make%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%24make%20uImage%20LOADADDR%3D0x10008000%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E.sabre%20lite%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AESD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%24cp%20arch%2Farm%2Fboot%2FuImage%20arch%2Farm%2Fboot%2Fdts%2Fimx6q-sabrelite.dtb%3CBOOT%20partition%3D%22%22%3E%3C%2FBOOT%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%82%922%E5%8F%B0(%E3%82%BB%E3%82%A4%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%88%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A8HDMI%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%BC)%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%971%E3%81%A7%E3%81%AF%E3%80%81HDMI%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%BC%E3%81%AE%E3%81%BF%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%972%E3%81%A7%E3%81%AF%E3%80%81%E3%82%BB%E3%82%A4%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%88%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E3%81%BF%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E6%89%8B%E9%A0%862%E3%81%A7HDMI%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%BC%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E7%A7%81%E3%81%AE%E4%BB%95%E4%BA%8B%E3%81%AE%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AA%E7%9B%AE%E6%A8%99%E3%81%AF%E3%80%81%E6%9C%80%E6%96%B0%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%80%81HDMI%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%BC%E4%BB%98%E3%81%8D%E3%81%AE%E3%82%BB%E3%82%A4%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AESD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%201%20%E3%81%A7%E3%81%AF%E3%80%81%2Fdev%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%20(fb0%20%E3%81%A8%20fb1)%20%E3%81%AE%E4%B8%8B%E3%81%AB%202%20%E3%81%A4%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%202%20%E3%81%A7%E3%81%AF%201%20%E3%81%A4%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3ECampier%E4%B8%8A%E8%A8%98%E3%81%AE2%E3%81%A4%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%82%B9%E3%83%86%E3%83%83%E3%83%972%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%80%8CMXC%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E8%A8%AD%E5%AE%9A%E3%80%8D%E3%81%8C%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E6%89%8B%E9%A0%862%E3%81%A7HDMI%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%BC%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%80%8CMXC%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%80%8D%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E6%89%8B%E9%A0%862%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%A7MXC%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E8%A8%AD%E5%AE%9A%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E6%89%8B%E9%A0%862%E3%81%A7HDMI%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%BC%E3%81%AE%E8%A1%A8%E7%A4%BA%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E6%A9%9F%E8%83%BD%E3%81%95%E3%81%9B%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E5%8F%A4%E3%81%84%E3%83%93%E3%83%AB%E3%83%89%E3%81%AEDTB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%93%E3%81%A8%E3%81%A7%E3%81%97%E3%81%9F..%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81SCP%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%3E%24%20scp%20%2Fmnt%2Fhgfs%2FVM_SHARE1%2Fhello%2Fhello%20root%4010.29.99.114%3A%2Fhome%2Froot%20%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Essh%3A%E3%83%9B%E3%82%B9%E3%83%8810.29.99.114%E3%83%9D%E3%83%BC%E3%83%8822%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3A%E6%8E%A5%E7%B6%9A%E3%81%8C%E6%8B%92%E5%90%A6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E6%8E%A5%E7%B6%9A%E3%81%8C%E5%A4%B1%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%8A%E8%80%83%E3%81%88%E3%81%AE%E6%96%B9%E3%81%AF%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22line-height%3A%201.5%3B%22%3E%20%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFsaurabh%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22line-height%3A%201.5%3B%22%3E%E3%83%AA%E3%83%97%E3%83%AC%E3%82%A4%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82zImage%E3%81%8C%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%84%5BIMX7D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%5D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%3CSPAN%20style%3D%22line-height%3A%201.5%3B%22%3E%20%E6%89%8B%E9%A0%86%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%201.5%3B%22%3E%20%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22line-height%3A%201.5%3B%22%3E1.%E3%81%8D%E3%82%8C%E3%81%84%E3%81%AAevertthing%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22line-height%3A%201.5%3B%22%3E%24%20make%20distclean%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22line-height%3A%201.5%3B%22%3E2.%E5%A4%89%E6%95%B0%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22line-height%3A%201.5%3B%22%3E%24%20source%20%2Fopt%2Fpoky%2F1.8%2Fenvironment-setup-armv7a-vfp-neon-poky-linux-gnueabi%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22line-height%3A%201.5%3B%22%3E3.config%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9F%E6%A7%8B%E6%88%90%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22%3A%20%3B%20font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20line-height%3A%201.5%3B%22%3E%24%20make%20imx_v7_defconfig%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22%3A%20%3B%20font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20line-height%3A%201.5%3B%22%3E4.make%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22%3A%20%3B%20color%3A%20%2351626f%3B%20font-size%3A%2011.0pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20line-height%3A%201.5%3B%22%3E%24%20make%20ARCH%3Darm%20CROSS_COMPILE%3Darm-poky-linux-gnueabi-%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-size%3A%2011.0pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20line-height%3A%201.5%3B%22%3E%E7%A7%81%E3%81%AFzImage%E3%82%92%E6%89%8B%E3%81%AB%E5%85%A5%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E7%A7%81%E3%81%AF%E7%A7%81%E3%81%AESD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%81%9D%E3%82%8C%E3%81%AF%E5%AE%9F%E8%A1%8C%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%E2%80%A6%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%89%A9%E7%90%86%20CPU%200x0%20%E3%81%A7%E3%81%AE%20Linux%20%E3%81%AE%E8%B5%B7%E5%8B%95%3C%2FP%3E%3CP%3ELinux%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B33.14.52(basavarajuc%40UKCTS-012052-linux)(gcc%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B34.9.2(GCC))%231%20SMP%20PREEMPT%20Thu%2C%20Jan%2028%2016%3A37%3A39%20GMT%202016%3C%2FP%3E%3CP%3ECPU%3A%20ARMv7%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20%5B410fc075%5D%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%205%20(ARMv7)%E3%80%81cr%3D10c53c7d%3C%2FP%3E%3CP%3ECPU%3APIPT%20%2F%20VIPT%20nonaliasing%20data%20cache%E3%80%81VIPT%20aliasing%20instruction%20cache%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%B7%E3%83%B3%E3%83%A2%E3%83%87%E3%83%AB%3AFreescale%20i.MX7%20SabreSD%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3Ecma%3A%20CMA%3A%20ac000000%20%E3%81%A7%20320%20MiB%20%E3%82%92%E4%BA%88%E7%B4%84%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20writealloc%3C%2FP%3E%3CP%3EPERCPU%3A%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF8%E3%83%9A%E3%83%BC%E3%82%B8%2F%20CPU%20%40ab734000%20s8320%20r8192%20d16256%20u32768%3C%2FP%3E%3CP%3E%E3%82%BE%E3%83%BC%E3%83%B3%E9%A0%86%E3%81%AB1%E3%81%A4%E3%81%AE%E3%82%BE%E3%83%BC%E3%83%B3%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%83%A2%E3%83%93%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E5%8C%96%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%B7%8F%E3%83%9A%E3%83%BC%E3%82%B8%E6%95%B0%3A260096%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3A%20console%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fmmcblk0p2%20rootwait%20rw%3C%2FP%3E%3CP%3EPID%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%204096%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3EDentry%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20131072%20(%E9%A0%86%E5%BA%8F%3A%207%E3%80%81524288%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3Einode-cache%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2065536%20(%E9%A0%86%E5%BA%8F%3A%206%E3%80%81262144%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%3A699668K%20%2F%201048576K%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD(7499K%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%80%81460K%20rwdata%E3%80%812592K%20rodata%E3%80%81392K%20init%E3%80%81433K%20bss%E3%80%81348908K%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%80%810K%20highmem)%3C%2FP%3E%3CP%3E%E4%BB%AE%E6%83%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3A%3C%2FP%3E%3CP%3E%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%20%3A%200xffff0000%20-%200xffff1000%20(%204%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fixmap%26nbsp%3B%20%3A%200xfff00000%20-%200xfffe0000%26nbsp%3B%26nbsp%3B%20(%20896%20kB)%3C%2FP%3E%3CP%3Evmalloc%20%3A%200xc0800000%20-%200xff000000%20(1000%20MB)%3C%2FP%3E%3CP%3Elowmem%20%3A%200x80000000%20-%200xc0000000%20(1024%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pkmap%26nbsp%3B%26nbsp%3B%20%3A%200x7fe00000%20-%200x80000000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%202%20MB)%3C%2FP%3E%3CP%3E%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20%3A%200x7f000000%20-%200x7fe00000%20(%2014%20MB)%3C%2FP%3E%3CP%3E%E3%80%82%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%3A%200x80008000%20-%200x809e2f54%20(10092%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.init%20%3A%200x809e3000%20-%200x80a45080%26nbsp%3B%26nbsp%3B%20(%20393%20kB)%3C%2FP%3E%3CP%3E%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%3A%200x80a46000%20-%200x80ab92c0%20(%20461%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.bss%20%3A%200x80ab92cc%20-%200x80b2591c%26nbsp%3B%26nbsp%3B%20(%20434%20kB)%3C%2FP%3E%3CP%3ESLUB%3A%20HWalign%3D64%E3%80%81Order%3D0-3%E3%80%81MinObjects%3D0%E3%80%81CPUs%3D2%E3%80%81Nodes%3D1%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%83%86%E3%82%A3%E3%83%96%E3%81%AA%E9%9A%8E%E5%B1%A4%E5%9E%8B%20RCU%20%E3%81%AE%E5%AE%9F%E8%A3%85%E3%80%82%3C%2FP%3E%3CP%3ERCU%20%E3%81%AF%20CPU%20%E3%82%92%20NR_CPUS%3D4%20%E3%81%8B%E3%82%89%20nr_cpu_ids%3D2%20%E3%81%AB%E5%88%B6%E9%99%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ERCU%3Arcu_fanout_leaf%3D16%E3%80%81nr_cpu_ids%3D2%E3%81%AE%E3%82%B8%E3%82%AA%E3%83%A1%E3%83%88%E3%83%AA%E3%81%AE%E8%AA%BF%E6%95%B4%3C%2FP%3E%3CP%3ENR_IRQS%3A16%20nr_irqs%3A16%2016%3C%2FP%3E%3CP%3E%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E9%81%85%E5%BB%B6%E3%83%AB%E3%83%BC%E3%83%97%E3%81%B8%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FP%3E%3CP%3Esched_clock%3A3000kHz%E3%81%A732%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6333ns%E3%80%811431655765682ns%E3%81%94%E3%81%A8%E3%81%AB%E3%83%A9%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3E%E8%A8%AD%E8%A8%88%E4%B8%8A%E3%81%AE%20cp15%20%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%AF%208.00MHz%20(phys)%20%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Esched_clock%3A8MHz%E3%81%A756%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6125ns%E3%80%812147483648000ns%E3%81%94%E3%81%A8%E3%81%AB%E3%83%A9%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3Eread_current_timer%E9%81%85%E5%BB%B6%E3%81%AE%E9%87%8D%E8%A4%87%2F%E9%81%85%E5%BB%B6%E7%99%BB%E9%8C%B2%E3%82%92%E7%84%A1%E8%A6%96%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B980x30%3C%2FP%3E%3CP%3E%E9%81%85%E5%BB%B6%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AE%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3(%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97)%E3%80%81%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%9F%E5%80%A4..6.00%20%E3%83%9C%E3%82%B4%E3%83%9F%E3%83%83%E3%83%97%E3%82%B9%20(lpj%3D30000)%3C%2FP%3E%3CP%3Epid_max%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3A%2032768%20%E6%9C%80%E5%B0%8F%3A%20301%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A2048(%E9%A0%86%E5%BA%8F%3A1%E3%80%818192%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%83%BB%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%3A%202048%20(%E9%A0%86%E5%BA%8F%3A%201%2C%208192%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ECPU%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E3%82%B3%E3%83%92%E3%83%BC%E3%83%AC%E3%83%B3%E3%82%B7%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3AOK%3C%2FP%3E%3CP%3E%2Fcpus%2Fcpu%400%20clock-frequency%20%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%2Fcpus%2Fcpu%401%20clock-frequency%20%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3ECPU0%3A%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%20-1%E3%80%81CPU%200%E3%80%81%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%200%E3%80%81mpidr%2080000000%3C%2FP%3E%3CP%3E0x80723b58%20%E3%81%AE%E9%9D%99%E7%9A%84%20ID%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E8%A8%AD%E5%AE%9A%20-%200x80723bb0%3C%2FP%3E%3CP%3ECPU1%3A%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FP%3E%3CP%3ECPU1%3A%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%20-1%E3%80%81CPU%201%E3%80%81%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%200%E3%80%81mpidr%2080000001%3C%2FP%3E%3CP%3E2%E3%81%A4%E3%81%AECPU%E3%82%92%E8%B5%B7%E5%8B%95%3C%2FP%3E%3CP%3ESMP%3A%E5%90%88%E8%A8%882%E3%81%A4%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F(12.00%20BogoMIPS)%E3%80%82%3C%2FP%3E%3CP%3ECPU%3A%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20CPU%20%E3%81%8C%20SVC%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Edevtmpfs%3A%20%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3EVFP%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20v0.3%3A%20implementor%2041%20architecture%202%20part%2030%20variant%207%20rev%205%3C%2FP%3E%3CP%3EPinCtrl%20Core%3A%20%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%20PinCtrl%20%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FP%3E%3CP%3E%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%3A%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AA%E3%81%97%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2016%3C%2FP%3E%3CP%3EDMA%3A%20%E5%8E%9F%E5%AD%90%E3%82%B3%E3%83%92%E3%83%BC%E3%83%AC%E3%83%B3%E3%83%88%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E7%94%A8%E3%81%AB%E4%BA%8B%E5%89%8D%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%20256%20KiB%20%E3%83%97%E3%83%BC%E3%83%AB%3C%2FP%3E%3CP%3Ecpuidle%3A%E3%82%AC%E3%83%90%E3%83%8A%E3%83%BC%E3%83%A9%E3%83%80%E3%83%BC%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Ecpuidle%3A%20%E3%82%AC%E3%83%90%E3%83%8A%E3%83%BC%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EWDOG1%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Esyscon%2030340000.iomuxc-gpr%3Aregmap%20%5Bmem%200x30340000-0x3034ffff%5D%20%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Esyscon%2030350000.ocotp-ctrl%3Aregmap%20%5Bmem%200x30350000-0x3035ffff%5D%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3Esyscon%2030360000.anatop%3Aregmap%20%5Bmem%200x30360000-0x3036ffff%5D%20%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Evdd1p0d%3A800%26lt%3B--%26gt%3B%3C%2FP%3E%3CP%3Esyscon%2030390000.src%20%E3%81%A7%E3%81%99%E3%80%82regmap%20%5Bmem%200x30390000-0x3039ffff%5D%20%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3EDDR%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AFDDR3!%3C%2FP%3E%3CP%3EOCOTP%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EOCOTP%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EHW-BREAKPOINT%3A%205%20(%2B1%20%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF)%20%E3%81%AE%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%A8%204%20%E3%81%A4%E3%81%AE%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Ehw-breakpoint%3A%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%9C%80%E5%A4%A7%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%208%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EIMX7D-PINCTRL%20302C0000.IOMUXC-LPSR%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9FIMX%20pinctrl%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FP%3E%3CP%3Eimx7d-pinctrl%2030330000.iomuxc%3A%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9FIMX%20pinctrl%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FP%3E%3CP%3E303A0000.GPC%20%E4%BE%9B%E7%B5%A6%20VCC%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EMU%E3%81%AF%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%B3%E3%82%A2%E9%80%9A%E4%BF%A1%E3%81%AE%E6%BA%96%E5%82%99%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3EBIO%3A0%E3%81%AB%E3%82%B9%E3%83%A9%E3%83%96%3CBIO-0%3E%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3EMXS-DMA%2033000000.dma-apbh%3A%E5%88%9D%E6%9C%9F%E5%8C%96%3C%2FP%3E%3CP%3Eusb_otg1_vbus%3A%205000%20mV%3C%2FP%3E%3CP%3Eusb_otg2_vbus%3A%205000%20mV%3C%2FP%3E%3CP%3ECAN2-3V3%3A%203300%20mV%3C%2FP%3E%3CP%3Evref-1v8%3A%201800%20mV%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A04.regulator%3A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCreg-fixed-voltage%E3%81%AF%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AE%E5%BB%B6%E6%9C%9F%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EVDD_SD1%3A%203300%20mV%3C%2FP%3E%3CP%3Ewlreg_on%3A%205000%20mV%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BMAX17135%5D%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BMAX17135%5D%3C%2FP%3E%3CP%3ESCSI%20%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20usbfs%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%8F%E3%83%96%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20USB%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbphy_nop1.8%20%E9%9B%BB%E6%BA%90%20VCC%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Eusbphy_nop2.9%20%E9%9B%BB%E6%BA%90%20VCC%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Eusbphy_nop3.10%20%E9%9B%BB%E6%BA%90%20VCC%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Ei2c%20i2c-0%3A%20IMX%20I2C%20%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3Ei2c%20i2c-1%3A%20IMX%20I2C%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Ei2c%20i2c-2%3A%20IMX%20I2C%20%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3Ei2c%20i2c-3%3A%20IMX%20I2C%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3ELinux%E3%83%93%E3%83%87%E3%82%AA%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3Av2.00%3C%2FP%3E%3CP%3Epps_core%3ALinuxPPS%20API%20ver.1%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%3CSPAN%3Epps_core%3A%20Software%20ver.%205.3.6%20-%20Copyright%202005-2007%20Rodolfo%20Giometti%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Agiometti%40linux.it%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Egiometti%40linux.it%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EPTP%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EMIPI%20CSI2%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%BB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EAdvanced%20Linux%20Sound%20Architecture%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EBluetooth%3A%E3%82%B3%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B32.18%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2031%3C%2FP%3E%3CP%3EBluetooth%3AHCI%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E6%8E%A5%E7%B6%9A%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3AHCI%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3AL2CAP%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3ASCO%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Ecfg80211%3A%20CRDA%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A6%E4%B8%96%E7%95%8C%E3%81%AE%E8%A6%8F%E5%88%B6%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9arch_sys_counter%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%202%3C%2FP%3E%3CP%3ETCP%20%E7%A2%BA%E7%AB%8B%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%208192%20(%E9%A0%86%E5%BA%8F%3A%203%E3%80%8132768%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ETCP%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A8192(%E9%A0%86%E5%BA%8F%3A4%E3%80%8165536%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ETCP%3A%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99(8192%20%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%208192%20%E3%81%8C%E7%A2%BA%E7%AB%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%3C%2FP%3E%3CP%3ETCP%3A%20reno%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EUDP%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3EUDP-Lite%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%201%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E5%90%8D%E5%89%8D%E3%81%AE%20UNIX%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E8%BB%A2%E9%80%81%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%20UDP%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%20tcp%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%20tcp%20NFSv4.1%20%E3%83%90%E3%83%83%E3%82%AF%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3Eimx%20rpmsg%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%90%E3%82%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EFutex%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%203%2C%2032768%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3EVFS%3A%20Disk%20quotas%20dquot_6.5.2%3C%2FP%3E%3CP%3EDquot-cache%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%201024%20(%E9%A0%86%E5%BA%8F%200%E3%80%814096%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ENFS%3Aid_resolver%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%E3%82%AD%E3%83%BC%E3%81%AE%E7%A8%AE%E9%A1%9E%20id_resolver%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%AD%E3%83%BC%E3%81%AE%E7%A8%AE%E9%A1%9E%20id_legacy%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EJFFS2%3A%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.2.(NAND)%20%C2%A9%202001-2006%20%E3%83%AC%E3%83%83%E3%83%89%E3%83%8F%E3%83%83%E3%83%88%E6%A0%AA%E5%BC%8F%E4%BC%9A%E7%A4%BE%3C%2FP%3E%3CP%3Efuse%20init%20(API%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%207.22)%3C%2FP%3E%3CP%3Emsgmni%20%E3%81%AF%202006%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9NOOP%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%E3%81%AE%E7%B7%A0%E5%88%87%E6%97%A5%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9CFQ%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88)%3C%2FP%3E%3CP%3E%E3%83%90%E3%83%83%E3%82%AF%E3%83%A9%E3%82%A4%E3%83%88.11%20%E9%9B%BB%E6%BA%90%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EMIPI%20DSI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EMIPI%20DSI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Esii902x%202-0039%3A%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%83%94%E3%83%B3%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Esii902x%202-0039%3A%20edid%20%E3%81%8C%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E30730000.lcdif%20%E4%BE%9B%E7%B5%A6%20LCD%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EMXSFB%2030730000.lcdif%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%87%E3%83%90%E3%82%A4%E3%82%B960x34%E3%81%B8%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FP%3E%3CP%3EMXSFB%2030730000.lcdif%3A%E5%88%9D%E6%9C%9F%E5%8C%96%3C%2FP%3E%3CP%3EIMX-SDMA%2030BD0000.sdma%3A%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%E5%86%8D%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3EIMX-SDMA%2030BD0000.sdma%3A%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A24.1%3C%2FP%3E%3CP%3EIMX-SDMA%2030BD0000.sdma%3A%E5%88%9D%E6%9C%9F%E5%8C%96%3C%2FP%3E%3CP%3Epfuze100-regulator%200-0008%3A%E3%83%95%E3%83%AB%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%3A1%E3%80%81%E3%83%A1%E3%82%BF%E3%83%AB%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%3A0%3C%2FP%3E%3CP%3Epfuze100-regulator%200-0008%3A%20FAB%3A%200%2C%20FIN%3A%200%3C%2FP%3E%3CP%3EPFUze100-REGULATOR%200-0008%3A%20PFUZE3000%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3ESW1A%3A700%20%26lt%3B--%26gt%3B%201100%20mV%E3%81%A73300%20mV%3C%2FP%3E%3CP%3ESW1B%3A700%26lt%3B--%26gt%3B%201475%20mV%3C%2FP%3E%3CP%3ESW2%3A1500%26lt%3B--%26gt%3B%201850%20mV%3C%2FP%3E%3CP%3ESW3%3A900%20%26lt%3B--%26gt%3B%201350%20mV%E3%81%A71650%20mV%3C%2FP%3E%3CP%3ESWBST%3A5000%26lt%3B--%26gt%3B%205150%20mV%3C%2FP%3E%3CP%3EVSNVS%3A1000%26lt%3B--%26gt%3B%203000%20mV%3C%2FP%3E%3CP%3EVREFDDR%3A%20750%20mV%3C%2FP%3E%3CP%3EVLDO1%3A%201800%20%26lt%3B--%26gt%3B%201800%20mV%20%E3%81%A7%203300%20mV%3C%2FP%3E%3CP%3EVLDO2%3A800%26lt%3B--%26gt%3B%201550%20mV%3C%2FP%3E%3CP%3EVCCSD%3A2850%26lt%3B--%26gt%3B%203300%20mV%3C%2FP%3E%3CP%3EV33%3A%202850%26lt%3B--%26gt%3B%3C%2FP%3E%3CP%3EVLDO3%3A%201800%26lt%3B--%26gt%3B%3C%2FP%3E%3CP%3EVLDO4%3A%201800%26lt%3B--%26gt%3B%3C%2FP%3E%3CP%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3AIMX%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3E30860000.%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3AMMIO%200x30860000%20(irq%20%3D%2058%2C%20base_baud%20%3D%201500000)%20%E3%81%AE%20ttymxc0%20%E3%81%AF%20IMX%20%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc0%5D%20%E6%9C%89%E5%8A%B9%3C%2FP%3E%3CP%3E30a70000.%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3AMMIO%200x30a70000%20(irq%20%3D%2062%2C%20base_baud%20%3D%205000000)%20%E3%81%AE%20ttymxc4%20%E3%81%AF%20IMX%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E30a80000.%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3AMMIO%200x30a80000%20(irq%20%3D%2048%2C%20base_baud%20%3D%205000000)%20%E3%81%AE%20ttymxc5%20%E3%81%AF%20IMX%20%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3A%20Freescale%20lpuart%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FP%3E%3CP%3EIMX%20SEMA4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%5BDRM%E3%81%AE%5D%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9Fdrm%201.1.020060810%3C%2FP%3E%3CP%3E%5BDRM%E3%81%AE%5D%E3%83%9E%E3%82%A4%E3%83%8A%E3%83%BC%200%20%E3%81%A7%20vivante%201.0.0%2020120216%20%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBRD%3A%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3C%2FP%3E%3CP%3Eloop%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%3AFXOS8700%20AS%20%2Fdevices%2Fsoc.2%2F30800000.aips-bus%2F30a30000.i2c%2Fi2c-1%2F1-001e%2Finput%2Finput0%3C%2FP%3E%3CP%3EFXOS8700%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%3AFXAS2100X%20AS%20%2Fdevices%2Fsoc.2%2F30800000.aips-bus%2F30a30000.i2c%2Fi2c-1%2F1-0020%2Finput%2Finput1%3C%2FP%3E%3CP%3EFXAS2100X%201-0020%3A%20FXAS2100x%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Espi_gpio%20SPI4.20%3Agpio-miso%20%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81no-rx%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3ECAN%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FP%3E%3CP%3EFlexcan%2030A10000.can%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(reg_base%3DF5A10000%2C%20IRQ%3D143)%3C%2FP%3E%3CP%3E30BE0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E4%BE%9B%E7%B5%A6PHY%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Epps%20pps0%3A%20%E6%96%B0%E3%81%97%E3%81%84%20PPS%20%E3%82%BD%E3%83%BC%E3%82%B9%20ptp0%3C%2FP%3E%3CP%3Elibphy%3A%20fec_enet_mii_bus%3A%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3Efec%2030be0000.ethernet%20eth0%3A%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AEPHC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B90%3C%2FP%3E%3CP%3Eehci_hcd%3A%20USB%202.0%20%E3%80%8C%E6%8B%A1%E5%BC%B5%E3%80%8D%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20(EHCI)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3Eehci-mxc%3A%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97EHCI%E3%83%9B%E3%82%B9%E3%83%88%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FP%3E%3CP%3Eusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AEusb-storage%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20usb_ehset_test%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E30B10200.USBMISC%20%E9%9B%BB%E6%BA%90%20VBUS-Wakeup%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E30b20200.usbmisc%20%E4%BE%9B%E7%B5%A6%20VBUS-%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E30b30200.usbmisc%20%E9%9B%BB%E6%BA%90%20vbus-wakeup%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Eci_hdrc%20ci_hdrc.1%3AEHCI%20%E3%83%9B%E3%82%B9%E3%83%88%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%3C%2FP%3E%3CP%3Eci_hdrc%20ci_hdrc.1%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B71%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Eci_hdrc%20ci_hdrc.1%3AUSB%202.0%20%E9%96%8B%E5%A7%8B%E3%80%81EHCI%201.00%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%96%201-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%96%201-0%3A1.0%3A%201%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Emousedev%3A%20PS%2F2%20%E3%83%9E%E3%82%A6%E3%82%B9%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20(%E5%85%A8%E3%83%9E%E3%82%A6%E3%82%B9%E5%85%B1%E9%80%9A)%3C%2FP%3E%3CP%3Esnvs_pwrkey%2030370000.snvs-pwrkey%3ASNVS%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%3A%2030370000.snvs-pwrkey%2Fdevices%2Fsoc.2%2F30000000.aips-bus%2F30370000.snvs-pwrkey%2Finput%2Finput2%E3%81%A8%E3%81%97%E3%81%A6%3C%2FP%3E%3CP%3Esnvs_pwrkey%2030370000.snvs-pwrkey%3Ai.MX%20SNVS%20PowerKey%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3EI2C-Core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BISL29023%5D%20%E3%81%8C%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BISL29023%5D%3C%2FP%3E%3CP%3Empl3115%20%E3%83%81%E3%83%83%E3%83%97%20ID%200xc4%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%3A%20mpl3115%20as%20%2Fdevices%2Fvirtual%2Finput%2Finput3%3C%2FP%3E%3CP%3EMPL3115%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Esnvs_rtc%2030370034.snvs-rtc-lp%3ASNVS-RTC%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Esnvs_rtc%2030370034.snvs-rtc-lp%3ARTC%E3%82%B3%E3%82%A2%3A%E7%99%BB%E9%8C%B230370034.snvs-rtc-lRTC0%E3%81%A8%E3%81%97%E3%81%A6%3C%2FP%3E%3CP%3Ei2c%20%2Fdev%20entries%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3EIR%20NEC%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIR%20RC5(x)%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIR%20RC6%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIR%20JVC%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%BB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIR%20Sony%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIR%20RC5%20(streamzap)%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIR%20SANYO%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIR%20MCE%20%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%2F%E3%83%9E%E3%82%A6%E3%82%B9%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EPXP-V4L2%20pxp_v4l2_out.12%3A%E5%88%9D%E6%9C%9F%E5%8C%96%3C%2FP%3E%3CP%3EI2C-Core%3A%20%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BMAG3110%5D%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BMAG3110%5D%3C%2FP%3E%3CP%3EIMX2-WDT%2030280000.wdog%3AIMX2%2B%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3D60%E7%A7%92%20(nowayout%3D0)%3C%2FP%3E%3CP%3EBluetooth%3AHCI%20UART%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCver%202.2%3C%2FP%3E%3CP%3EBluetooth%3AHCI%20H4%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3AHCI%20BCSP%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3A%20HCIATH3K%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E8%A6%8F%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20BCM203x%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20btusb%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20ath3k%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Esdhci%3A%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%BB%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%BB%E3%83%9B%E3%82%B9%E3%83%88%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3Esdhci%3A%20Copyright(c)%20Pierre%20Ossman%20(%E8%8B%B1%E8%AA%9E)%3C%2FP%3E%3CP%3Esdhci-pltfm%3A%20SDHCI%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A8%20OF%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%98%E3%83%AB%E3%83%91%E3%83%BC%3C%2FP%3E%3CP%3EMMC0%20%3A%20VQMMC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Emmc0%3A%2030b40000.usdhc%20%5B30b40000.usdhc%5D%20%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCADMA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Esdhci-esdhc-imx%2030b50000.usdhc%3AWiFi%E3%83%9B%E3%82%B9%E3%83%88%E3%81%A8%E3%81%97%E3%81%A6%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%3C%2FP%3E%3CP%3EMMC1%20%3A%20VQMMC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3EMMC1%3A%20VMMC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Emmc1%3A%2030b50000.usdhc%20%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20%5B30b50000.usdhc%5DADMA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EMMC2%20%3A%20VQMMC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3EMMC2%3A%20VMMMC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Emmc0%3A%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9a77f%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84SD%E3%82%AB%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3Emmcblk0%3A%20mmc0%3Aa77f%20SU01G%20968%20MiB%3C%2FP%3E%3CP%3E%20mmcblk0%3A%20p1%20p2%3C%2FP%3E%3CP%3Emmc2%3A%2030b60000.usdhc%20%5B30b60000.usdhc%5D%20%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCADMA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3ECAAM%2030900000.caam%3A%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%20RNG4%20SH0%3C%2FP%3E%3CP%3ECAAM%2030900000.caam%3A%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%20RNG4%20SH1%3C%2FP%3E%3CP%3ECAAM%2030900000.caam%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20ID%20%3D%200x0a160300%20(%E6%99%82%E4%BB%A3%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3ECAAM%2030900000.caam%3A%E3%82%B8%E3%83%A7%E3%83%96%E3%83%AA%E3%83%B3%E3%82%B0%3D%203%E3%80%81%E6%B0%97%3D%200%3C%2FP%3E%3CP%3E%2Fproc%2Fcrypto%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BCAAM%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%3C%2FP%3E%3CP%3Ecaam_jr%2030901000.jr0%3ARNG-CAAM%E3%81%AE%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3Ablkkey_ex%3A8%E3%81%A4%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%88%E3%82%A2%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A64%E3%83%93%E3%83%83%E3%83%88%E3%82%AF%E3%83%AA%E3%82%A2%E3%82%AD%E3%83%BC%3A%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A64%E3%83%93%E3%83%83%E3%83%88%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%3A%3C%2FP%3E%3CP%3Ecaam_sm%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%3A%20%5B0000%5D%2093%20CB%20B6%2073%20C2%20C1%20DC%20E7%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0008%5D%2099%207b%2089%2007%2071%2073%20e3%2024%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A128%E3%83%93%E3%83%83%E3%83%88%E3%82%AF%E3%83%AA%E3%82%A2%E3%82%AD%E3%83%BC%3A%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3C%2FP%3E%3CP%3E%E3%83%9B%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0008%5D%2008%2009%200A%200B%200C%200D%200E%200F%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20128%20%E3%83%93%E3%83%83%E3%83%88%20%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%20%E3%82%AD%E3%83%BC%3A%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0000%5D%209B%203D%208E%2022%2013%2079%2004%208D%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0008%5D%20F7%2057%2010%2007%20F5%20B9%2075%20FC%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A192%E3%83%93%E3%83%83%E3%83%88%E3%82%AF%E3%83%AA%E3%82%A2%E3%82%AD%E3%83%BC%3A%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3C%2FP%3E%3CP%3E%E3%83%9B%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0008%5D%2008%2009%200A%200B%200C%200D%200E%200F%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0016%5D%2010%2011%2012%2013%2014%2015%2016%2017%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A192%E3%83%93%E3%83%83%E3%83%88%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AD%E3%83%BC%3A%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0000%5D%2020%205F%2025%200A%2039%20D1%2023%2040%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0008%5D%20D6%2065%20BE%2013%2003%2053%2002%2053%3C%2FP%3E%3CP%3Eplatform%20caam_sm%3A%20%5B0016%5D%2014%207c%2071%20e2%20cd%2018%20e2%20e5%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0024%5D%20F9%2090%2088%20A3%20E8%2016%2001%20B8%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A256%E3%83%93%E3%83%83%E3%83%88%E3%82%AF%E3%83%AA%E3%82%A2%E3%82%AD%E3%83%BC%3A%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0000%5D%2000%2001%2002%2003%2004%200f%2006%2007%3C%2FP%3E%3CP%3E%E3%83%9B%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0008%5D%2008%2009%200A%200B%200C%200D%200E%200F%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0016%5D%2010%2011%2012%2013%2014%2015%2016%2017%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0024%5D%2018%2019%201A%201B%201C%201D%201E%201F%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20256%20%E3%83%93%E3%83%83%E3%83%88%20%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%20%E3%82%AD%E3%83%BC%3A%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0000%5D%200F%2023%20EF%2013%2093%2096%20C1%2070%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0008%5D%204b%20f9%202c%2020%2081%2090%2020%20ea%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0016%5D%2010%20AB%202B%2088%2085%20F8%209E%20B1%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0024%5D%2031%20ED%20A7%2077%205B%20E3%205D%20DD%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%2064%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E6%9C%AA%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%20BLOB%3A%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%83%9B%E3%83%BC%E3%83%A0%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0040%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%9B%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20128%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E6%9C%AA%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%20BLOB%3A%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%83%9B%E3%83%BC%E3%83%A0%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0040%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%9B%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20196%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E6%9C%AA%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%20BLOB%3A%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%83%9B%E3%83%BC%E3%83%A0%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0040%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%9B%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20256%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E6%9C%AA%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%20BLOB%3A%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0000%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0008%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%83%9B%E3%83%BC%E3%83%A0%3A%20%5B0016%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0024%5D%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0032%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0040%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%9B%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0048%5D%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20BLOB%20%E3%81%AE%2064%20%E3%83%93%E3%83%83%E3%83%88%E9%BB%92%E3%82%AD%E3%83%BC%3A%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0000%5D%20AF%2046%208F%2041%20C4%2031%2042%20EC%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0008%5D%20B3%2096%200B%2074%207E%2068%2005%20B6%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0016%5D%2027%2091%20F4%2022%2039%2038%20F4%2033%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0024%5D%2000%204C%2065%20CA%202C%20Ed%2021%20B2%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0032%5D%204F%20CF%2006%20A6%209E%209F%2025%20FE%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0040%5D%20D0%208C%2001%2010%20FD%20B0%207F%20F6%3C%2FP%3E%3CP%3Eplatform%20caam_sm%3A%20%5B0048%5D%2079%20c4%2042%20bb%2002%202e%20dd%20c2%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0056%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20BLOB%20%E5%86%85%E3%81%AE%20128%20%E3%83%93%E3%83%83%E3%83%88%E9%BB%92%E3%82%AD%E3%83%BC%3A%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0000%5D%20AD%2007%20F1%20A8%2087%2071%2086%2038%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0008%5D%20F4%2062%206E%20C7%20C7%20F0%2074%2069%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0016%5D%2073%20C7%20F7%2092%200C%2043%20E1%202D%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0024%5D%2017%2050%203B%2074%20F4%20E7%204C%2089%3C%2FP%3E%3CP%3Eplatform%20caam_sm%3A%20%5B0032%5D%2045%2062%20fb%20ba%2059%20bc%209e%20ea%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0040%5D%2091%2056%20F3%2091%2097%2003%202B%20A3%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0048%5D%201b%20c7%203f%20b3%2011%2046%202a%20a9%3C%2FP%3E%3CP%3Eplatform%20caam_sm%3A%20%5B0056%5D%206f%20af%20e5%204c%20f0%2076%2072%208e%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0064%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20BLOB%20%E5%86%85%E3%81%AE%20192%20%E3%83%93%E3%83%83%E3%83%88%E9%BB%92%E3%82%AD%E3%83%BC%3A%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0000%5D%20B6%20EA%20C9%2044%201B%2006%2001%204A%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0008%5D%20D2%205A%20A0%2061%20E0%2056%200F%20FF%3C%2FP%3E%3CP%3Eplatform%20caam_sm%3A%20%5B0016%5D%20db%20b6%20b8%2078%20da%2063%2052%20e6%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0024%5D%2023%205C%20F7%2097%203D%20AF%20E2%2060%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0032%5D%20AA%2057%203C%20F0%205D%2040%2054%20C3%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0040%5D%2044%20B3%204F%2005%203B%2076%2016%20E6%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0048%5D%20D7%2074%209C%20A0%2062%200F%202F%20DC%3C%2FP%3E%3CP%3E%E3%83%9B%E3%83%BC%E3%83%A0caam_sm%3A%5B0056%5D%2003%2053%2096%209E%2034%2000%2055%2093%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0064%5D%20D0%20B0%20B4%20FD%205B%2066%2058%2093%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0072%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20BLOB%20%E3%81%AE%20256%20%E3%83%93%E3%83%83%E3%83%88%E9%BB%92%E3%82%AD%E3%83%BC%3A%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0000%5D%2076%2046%200F%20F3%20DE%2076%20EF%20B0%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0008%5D%204E%204A%2027%20D5%207F%201B%200B%20F2%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0016%5D%209A%205D%20E1%206D%20B4%20F9%20DF%2021%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0024%5D%208B%2094%2077%2080%20D7%20CB%20DC%2034%3C%2FP%3E%3CP%3E%E3%83%9B%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0032%5D%2093%2082%2083%20B5%2002%2052%2053%2082%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0040%5D%2033%2015%2031%2011%2067%2048%2057%20F3%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0048%5D%20E1%204D%2078%2020%201C%20EC%20FE%20D5%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0056%5D%202b%20d2%2028%2079%2035%2001%2091%203d%3C%2FP%3E%3CP%3Eplatform%20caam_sm%3A%20%5B0064%5D%206e%20f8%203c%200e%201e%2023%2063%208d%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0072%5D%2047%202A%2009%2024%20A1%20A3%20BA%201D%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0080%5D%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0088%5D%2000%2000%2000%2000%2000%2000%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%E5%BE%A9%E5%85%83%E3%81%95%E3%82%8C%E3%81%9F%2064%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E9%BB%92%E3%82%AD%E3%83%BC%3A%3C%2FP%3E%3CP%3Eplatform%20caam_sm%3A%20%5B0000%5D%206e%20dc%20c9%209d%20e2%20d9%2099%209e%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0008%5D%20FB%20EF%2017%206A%20FF%2072%20E8%20A1%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%E5%BE%A9%E5%85%83%E3%81%95%E3%82%8C%E3%81%9F%20128%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E9%BB%92%E3%82%AD%E3%83%BC%3A%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0000%5D%209B%203D%208E%2022%2013%2079%2004%208D%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0008%5D%20F7%2057%2010%2007%20F5%20B9%2075%20FC%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%E5%BE%A9%E5%85%83%E3%81%95%E3%82%8C%E3%81%9F%20192%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E9%BB%92%E3%82%AD%E3%83%BC%3A%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0000%5D%2020%205F%2025%200A%2039%20D1%2023%2040%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0008%5D%20D6%2065%20BE%2013%2003%2053%2002%2053%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0016%5D%2023%20EA%201F%2067%20B1%204D%2098%201A%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0024%5D%201C%20F8%20Ed%20D5%2030%2096%2007%20FE%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20caam_sm%3A%20%E5%BE%A9%E5%85%83%E3%81%95%E3%82%8C%E3%81%9F%20256%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E9%BB%92%E3%82%AD%E3%83%BC%3A%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0000%5D%200F%2023%20EF%2013%2093%2096%20C1%2070%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%20%5B0008%5D%204b%20f9%202c%2020%2081%2090%2020%20ea%3C%2FP%3E%3CP%3Ecaam_sm%E7%95%AA%E3%81%AE%E3%82%8A%E3%81%B0%3A%20%5B0016%5D%2010%20AB%202B%2088%2085%20F8%209E%20B1%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0caam_sm%3A%5B0024%5D%2031%20ED%20A7%2077%205B%20E3%205D%20DD%3C%2FP%3E%3CP%3Esnvs-secvio%2030370000.caam-snvs%3ASNVS%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Esnvs-secvio%2030370000.caam-snvs%3AViolation%20Handlers%20Armed%20-%20%E9%9D%9E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E7%8A%B6%E6%85%8B%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20usbhid%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbhid%3A%20USB%20HID%20%E3%82%B3%E3%82%A2%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3Ecoresight-tmc%2030086000.etr%3ATMC%20%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Ecoresight-tmc%2030084000.etf%3ATMC%20%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Ecoresight-tpiu%2030087000.tpiu%3ATPIU%20%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Ecoresight-funnel%2030083000.funnel%3AFUNNEL%20%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Ecoresight-funnel%2030041000.funnel%3AFUNNEL%20%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Ecoresight-replicator%20replicator.1%3AREPLICATOR%20%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Ecoresight-etm3x%203007c000.etm%3AETM%20%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Ecoresight-etm3x%203007d000.etm%3AETM%20%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIMX-WM8960%20%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89.18%3AWM8960-HIFI%20%26lt%3B-%26gt%3B%20308A0000.sai%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%20OK%3C%2FP%3E%3CP%3EIMX-SII902X%20%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89-HDMI.19%3ASND-SOC-DUMMY-DAI%20%26lt%3B-%26gt%3B%20308A0000.sai%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0OK%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2026%3C%2FP%3E%3CP%3ETCP%3A%E3%82%AD%E3%83%A5%E3%83%BC%E3%83%93%E3%83%83%E3%82%AF%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2010%3C%2FP%3E%3CP%3Esit%3A%20IPv6%20over%20IPv4%20%E3%83%88%E3%83%B3%E3%83%8D%E3%83%AA%E3%83%B3%E3%82%B0%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2017%3C%2FP%3E%3CP%3ECAN%3A%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%A8%E3%83%AA%E3%82%A2%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B3%E3%82%A2(%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%2020120528%20ABI%209)%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2029%3C%2FP%3E%3CP%3ECAN%3ARAW%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB(%E6%94%B9%E8%A8%82%E7%89%8820120528)%3C%2FP%3E%3CP%3ECAN%3A%20%E3%83%96%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%20%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20(%E6%94%B9%E8%A8%82%E7%89%88%2020120528%20T)%3C%2FP%3E%3CP%3ECAN%3A%20NetLink%20%E3%82%B2%E3%83%BC%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A4%20(%E6%94%B9%E8%A8%82%E7%89%88%2020130117)%20max_hops%3D1%3C%2FP%3E%3CP%3EBluetooth%3ARFCOMM%20TTY%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3ARFCOMM%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3ARFCOMM%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.11%3C%2FP%3E%3CP%3EBluetooth%3ABNEP(%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)ver%201.3%3C%2FP%3E%3CP%3EBluetooth%3ABNEP%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3A%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%9E%E3%83%AB%E3%83%81%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%3C%2FP%3E%3CP%3EBluetooth%3ABNEP%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3AHIDP(%E3%83%92%E3%83%A5%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)ver%201.2%3C%2FP%3E%3CP%3EBluetooth%3AHIDP%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E8021q%3A802.1Q%20VLAN%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88v1.8%3C%2FP%3E%3CP%3E%E3%82%AD%E3%83%BC%E3%81%AE%E7%A8%AE%E9%A1%9E%20dns_resolver%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Ecpu%20cpu0%3Adev_pm_opp_get_opp_count%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9OPP%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93(-19)%3C%2FP%3E%3CP%3ESWBST%3A%E7%84%A1%E5%8A%B9%E5%8C%96%3C%2FP%3E%3CP%3Ewlreg_on%3A%E7%84%A1%E5%8A%B9%E5%8C%96%3C%2FP%3E%3CP%3ECAN2-3V3%3A%E7%84%A1%E5%8A%B9%E5%8C%96%3C%2FP%3E%3CP%3Eusb_otg1_vbus%3A%E7%84%A1%E5%8A%B9%E5%8C%96%3C%2FP%3E%3CP%3Eregulator-dummy%3A%20%E7%84%A1%E5%8A%B9%E5%8C%96%3C%2FP%3E%3CP%3EIMX%20MCC%E3%83%86%E3%82%B9%E3%83%88%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EMPCIE_3V3%3A%203300%20mV%3C%2FP%3E%3CP%3Esnvs_rtc%2030370034.snvs-rtc-lp%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%201970-01-01%2000%3A00%3A01%20UTC%20(1)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3EALSA%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%80%E8%A6%A7%3A%3C%2FP%3E%3CP%3E%230%3AWM8960-%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%3C%2FP%3E%3CP%3E%231%3ASII902X%20-%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%3C%2FP%3E%3CP%3E%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%3A%20%E3%83%8E%E3%83%B3%E3%83%96%E3%83%AD%E3%83%83%E3%82%AD%E3%83%B3%E3%82%B0%20%E3%83%97%E3%83%BC%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Ekjournald%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E9%96%93%E9%9A%94%205%20%E7%A7%92%3C%2FP%3E%3CP%3EEXT3-fs%20(mmcblk0p2)%3A%20%E5%86%85%E9%83%A8%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%8A%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EEXT3-fs%20(mmcblk0p2)%3A%20%E5%BE%A9%E6%97%A7%E5%AE%8C%E4%BA%86%3C%2FP%3E%3CP%3EEXT3-fs%20(mmcblk0p2)%3A%20%E9%A0%86%E5%BA%8F%E4%BB%98%E3%81%91%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%83%BB%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FP%3E%3CP%3EVFS%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20179%3A2%20%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%88%20(ext3%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0)%20%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EDevtmpfs%3A%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3E%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E8%A7%A3%E6%94%BE%3A%20392K%20(809e3000%20-%2080a45000)%3C%2FP%3E%3CP%3EINIT%3A%20version%202.88%20%E3%81%AE%E8%B5%B7%E5%8B%95%3C%2FP%3E%3CP%3Eudev%20%E3%81%AE%E8%B5%B7%E5%8B%95%3C%2FP%3E%3CP%3Eudev%3A%20%E6%AC%A1%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81udev%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3Eudev%3A%20%2Fproc%2Fversion%20%2Fproc%2Fcmdline%20%2Fproc%2Fdevices%3C%2FP%3E%3CP%3Eudev%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lib%2Fudev%2Frules.d%2F*%20etc%2Fudev%2Frules.d%2F*%3C%2FP%3E%3CP%3Eudev%3A%20udev%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E5%86%8D%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%9F%E5%A4%89%E6%9B%B4%E3%82%92%E7%89%B9%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3Eudev%3A%20%2Fetc%2Fudev%2Fcache.data%20%E3%81%AB%E3%81%82%E3%82%8B%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%95%E3%82%8C%E3%81%9F%20sysconf%20%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3Eudev%3A%20%2Fdev%2Fshm%2Fudev.cache%20%E3%81%AB%E3%81%82%E3%82%8B%E7%8F%BE%E5%9C%A8%E3%81%AE%20sysconf%20%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%3C%2FP%3E%3CP%3Eudevd%5B170%5D%3A%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20182%20%E4%BB%A5%E9%99%8D%3C%2FP%3E%3CP%3Ebootlogd%3A%20%E7%96%91%E4%BC%BC%20tty%20%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%84%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E9%96%8B%E7%99%BA%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3EALSA%3A%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%E8%A8%AD%E5%AE%9A%E3%81%AE%E5%BE%A9%E5%85%83..%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E4%BD%95%E3%81%8B%E8%80%83%E3%81%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0zImage%E3%82%92%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B.%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EARCH%3Darm%20CROSS_COMPILE%3Darm-poky-linux-gnueabi-%20modules_install%20INSTALL_MOD_PATH%3D..%2F%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110598%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110598%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%9A%86%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%A7%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%3C%2FP%3E%3CP%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20ARCH%3Darm%3C%2FP%3E%3CP%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20CROSS_COMPILE%3Darm-poky-linux-gnueabi-%3C%2FP%3E%3CP%3EPATH%3D%2Fopt%2Fpoky%2F1.8%2Fsysroots%2Fx86_64-pokysdk-linux%2Fusr%2Fbin%2Farm-poky-linux-gnueabi%3A%24PATH%3C%2FP%3E%3CP%3Emake%20imx_v7_defconfig%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFuImage%E3%80%81zimage%E3%80%81.o%E3%82%92%E6%89%8B%E3%81%AB%E5%85%A5%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9Frpmsg%20%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81.ko%20%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIMX7d%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E7%A7%81%E3%81%8C%E3%81%A9%E3%81%93%E3%81%A7%E9%96%93%E9%81%95%E3%81%88%E3%81%9F%E3%81%AE%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%20%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20820px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F36273i79252E040382761E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Ezimage%E3%81%AF%E5%85%83%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%A8%E3%81%97%E3%81%A6%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93.%E3%81%9D%E3%82%8C%E3%81%AF%E4%BB%A5%E4%B8%8Bmiddle.%20log%E3%81%A7%E5%81%9C%E6%AD%A2%3C%2FSTRONG%3E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECPU%3A%20Freescale%20i.MX7D%20rev1.0%20(792%20MHz)%3C%2FP%3E%3CP%3ECPU%3A%E6%B8%A9%E5%BA%A6%3A%E6%9C%89%E5%8A%B9%E3%81%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93!%3C%2FP%3E%3CP%3EReset%20cause%3A%20POR%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%3Ai.MX7D%20SABRESD%3C%2FP%3E%3CP%3EI2C%3A%20%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%3C%2FP%3E%3CP%3EDRAM%3A%201%20GiB%3C%2FP%3E%3CP%3EMMC%3AFSL_SDHC%3A0%E3%80%81FSL_SDHC%3A1%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%20-%20%E4%B8%8D%E6%AD%A3%E3%81%AACRC%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E7%92%B0%E5%A2%83%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%8D%E3%83%AB%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AFTFT43AB%3C%2FP%3E%3CP%3EDisplay%3A%20TFT43AB%20(480x272)%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%87%E3%82%AA%3A%20480x272x24%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FP%3E%3CP%3E%E5%87%BA%E5%8A%9B%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FP%3E%3CP%3EErr%3A%26nbsp%3B%26nbsp%3B%20serial%3C%2FP%3E%3CP%3EPFUZE300%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F!deviceid%200x30%E3%80%81revid%200x10%3C%2FP%3E%3CP%3Emmc0%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3ENet%3A%26nbsp%3B%26nbsp%3B%20FEC0%3C%2FP%3E%3CP%3E%E9%80%9A%E5%B8%B8%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%3C%2FP%3E%3CP%3E%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%9A0%3C%2FP%3E%3CP%3E%3D%26gt%3B%20%E3%83%96%E3%83%BC%E3%83%88%3C%2FP%3E%3CP%3Emmc0%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3Emmc0%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3Eboot.scr%20%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3C%2FP%3E%3CP%3E**%20boot.scr%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%20**%3C%2FP%3E%3CP%3EzImage%20%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3C%2FP%3E%3CP%3E6025008%E3%83%90%E3%82%A4%E3%83%88%E3%82%92528%E3%83%9F%E3%83%AA%E7%A7%92(10.9MiB%2F%E7%A7%92)%E3%81%A7%E8%AA%AD%E3%81%BF%E5%8F%96%E3%81%A3%E3%81%9F%3C%2FP%3E%3CP%3Emmc%20%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20...%3C%2FP%3E%3CP%3Ereading%20imx7d-sdb.dtb%3C%2FP%3E%3CP%3E39438%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%2020%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%20(1.9%20MiB%2F%E7%A7%92)%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20%40%200x80800000%20%5B%200x000000%20-%200x5bef30%20%5D%3C%2FP%3E%3CP%3E%23%23%2083000000%20%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%83%88%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%83%96%E3%83%AD%E3%83%96%3C%2FP%3E%3CP%3Efdt%20blob%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%200x83000000%20%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%82%92%2083000000%20%E3%81%AE%E4%BD%8D%E7%BD%AE%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%818300ca0d%20%E3%82%92%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%E2%80%A6%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%89%A9%E7%90%86%20CPU%200x0%20%E3%81%A7%E3%81%AE%20Linux%20%E3%81%AE%E8%B5%B7%E5%8B%95%3C%2FP%3E%3CP%3ELinux%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B33.14.52(basavarajuc%40UKCTS-012052-linux)(gcc%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B34.9.2(GCC))%231%20SMP%20PREEMPT%20Thu%2C%20Jan%2028%2016%3A37%3A39%20GMT%202016%3C%2FP%3E%3CP%3ECPU%3A%20ARMv7%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20%5B410fc075%5D%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%205%20(ARMv7)%E3%80%81cr%3D10c53c7d%3C%2FP%3E%3CP%3ECPU%3APIPT%20%2F%20VIPT%20nonaliasing%20data%20cache%E3%80%81VIPT%20aliasing%20instruction%20cache%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%B7%E3%83%B3%E3%83%A2%E3%83%87%E3%83%AB%3AFreescale%20i.MX7%20SabreSD%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3Ecma%3A%20CMA%3A%20ac000000%20%E3%81%A7%20320%20MiB%20%E3%82%92%E4%BA%88%E7%B4%84%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20writealloc%3C%2FP%3E%3CP%3EPERCPU%3A%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF8%E3%83%9A%E3%83%BC%E3%82%B8%2F%20CPU%20%40ab736000%20s8320%20r8192%20d16256%20u32768%3C%2FP%3E%3CP%3E%E3%82%BE%E3%83%BC%E3%83%B3%E9%A0%86%E3%81%AB1%E3%81%A4%E3%81%AE%E3%82%BE%E3%83%BC%E3%83%B3%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%83%A2%E3%83%93%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E5%8C%96%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%B7%8F%E3%83%9A%E3%83%BC%E3%82%B8%E6%95%B0%3A260096%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3A%20console%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fmmcblk0p2%20rootwait%20rw%3C%2FP%3E%3CP%3EPID%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%204096%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3EDentry%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20131072%20(%E9%A0%86%E5%BA%8F%3A%207%E3%80%81524288%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3Einode-cache%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2065536%20(%E9%A0%86%E5%BA%8F%3A%206%E3%80%81262144%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%3A699680K%20%2F%201048576K%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD(7499K%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%80%81460K%20rwdata%E3%80%812592K%20rodata%E3%80%81392K%20init%E3%80%81433K%20bss%E3%80%81348896K%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%80%810K%20highmem)%3C%2FP%3E%3CP%3E%E4%BB%AE%E6%83%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3A%3C%2FP%3E%3CP%3E%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%20%3A%200xffff0000%20-%200xffff1000%20(%204%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fixmap%26nbsp%3B%20%3A%200xfff00000%20-%200xfffe0000%26nbsp%3B%26nbsp%3B%20(%20896%20kB)%3C%2FP%3E%3CP%3Evmalloc%20%3A%200xc0800000%20-%200xff000000%20(1000%20MB)%3C%2FP%3E%3CP%3Elowmem%20%3A%200x80000000%20-%200xc0000000%20(1024%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pkmap%26nbsp%3B%26nbsp%3B%20%3A%200x7fe00000%20-%200x80000000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%202%20MB)%3C%2FP%3E%3CP%3E%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20%3A%200x7f000000%20-%200x7fe00000%20(%2014%20MB)%3C%2FP%3E%3CP%3E%E3%80%82%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%3A%200x80008000%20-%200x809e2f54%20(10092%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.init%20%3A%200x809e3000%20-%200x80a45080%26nbsp%3B%26nbsp%3B%20(%20393%20kB)%3C%2FP%3E%3CP%3E%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%3A%200x80a46000%20-%200x80ab92c0%20(%20461%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.bss%20%3A%200x80ab92cc%20-%200x80b2591c%26nbsp%3B%26nbsp%3B%20(%20434%20kB)%3C%2FP%3E%3CP%3ESLUB%3A%20HWalign%3D64%E3%80%81Order%3D0-3%E3%80%81MinObjects%3D0%E3%80%81CPUs%3D2%E3%80%81Nodes%3D1%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%83%86%E3%82%A3%E3%83%96%E3%81%AA%E9%9A%8E%E5%B1%A4%E5%9E%8B%20RCU%20%E3%81%AE%E5%AE%9F%E8%A3%85%E3%80%82%3C%2FP%3E%3CP%3ERCU%20%E3%81%AF%20CPU%20%E3%82%92%20NR_CPUS%3D4%20%E3%81%8B%E3%82%89%20nr_cpu_ids%3D2%20%E3%81%AB%E5%88%B6%E9%99%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ERCU%3Arcu_fanout_leaf%3D16%E3%80%81nr_cpu_ids%3D2%E3%81%AE%E3%82%B8%E3%82%AA%E3%83%A1%E3%83%88%E3%83%AA%E3%81%AE%E8%AA%BF%E6%95%B4%3C%2FP%3E%3CP%3ENR_IRQS%3A16%20nr_irqs%3A16%2016%3C%2FP%3E%3CP%3E%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E9%81%85%E5%BB%B6%E3%83%AB%E3%83%BC%E3%83%97%E3%81%B8%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FP%3E%3CP%3Esched_clock%3A3000kHz%E3%81%A732%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6333ns%E3%80%811431655765682ns%E3%81%94%E3%81%A8%E3%81%AB%E3%83%A9%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3E%E8%A8%AD%E8%A8%88%E4%B8%8A%E3%81%AE%20cp15%20%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%AF%208.00MHz%20(phys)%20%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Esched_clock%3A8MHz%E3%81%A756%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6125ns%E3%80%812147483648000ns%E3%81%94%E3%81%A8%E3%81%AB%E3%83%A9%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3Eread_current_timer%E9%81%85%E5%BB%B6%E3%81%AE%E9%87%8D%E8%A4%87%2F%E9%81%85%E5%BB%B6%E7%99%BB%E9%8C%B2%E3%82%92%E7%84%A1%E8%A6%96%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B980x30%3C%2FP%3E%3CP%3E%E9%81%85%E5%BB%B6%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AE%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3(%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97)%E3%80%81%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%9F%E5%80%A4..6.00%20%E3%83%9C%E3%82%B4%E3%83%9F%E3%83%83%E3%83%97%E3%82%B9%20(lpj%3D30000)%3C%2FP%3E%3CP%3Epid_max%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3A%2032768%20%E6%9C%80%E5%B0%8F%3A%20301%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A2048(%E9%A0%86%E5%BA%8F%3A1%E3%80%818192%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%83%BB%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%3A%202048%20(%E9%A0%86%E5%BA%8F%3A%201%2C%208192%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ECPU%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E3%82%B3%E3%83%92%E3%83%BC%E3%83%AC%E3%83%B3%E3%82%B7%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3AOK%3C%2FP%3E%3CP%3E%2Fcpus%2Fcpu%400%20clock-frequency%20%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%2Fcpus%2Fcpu%401%20clock-frequency%20%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3ECPU0%3A%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%20-1%E3%80%81CPU%200%E3%80%81%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%200%E3%80%81mpidr%2080000000%3C%2FP%3E%3CP%3E0x80723b58%20%E3%81%AE%E9%9D%99%E7%9A%84%20ID%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E8%A8%AD%E5%AE%9A%20-%200x80723bb0%3C%2FP%3E%3CP%3ECPU1%3A%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FP%3E%3CP%3ECPU1%3A%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%20-1%E3%80%81CPU%201%E3%80%81%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%200%E3%80%81mpidr%2080000001%3C%2FP%3E%3CP%3E2%E3%81%A4%E3%81%AECPU%E3%82%92%E8%B5%B7%E5%8B%95%3C%2FP%3E%3CP%3ESMP%3A%E5%90%88%E8%A8%882%E3%81%A4%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F(12.00%20BogoMIPS)%E3%80%82%3C%2FP%3E%3CP%3ECPU%3A%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20CPU%20%E3%81%8C%20SVC%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Edevtmpfs%3A%20%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3EVFP%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20v0.3%3A%20implementor%2041%20architecture%202%20part%2030%20variant%207%20rev%205%3C%2FP%3E%3CP%3EPinCtrl%20Core%3A%20%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%20PinCtrl%20%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FP%3E%3CP%3E%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%3A%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AA%E3%81%97%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2016%3C%2FP%3E%3CP%3EDMA%3A%20%E5%8E%9F%E5%AD%90%E3%82%B3%E3%83%92%E3%83%BC%E3%83%AC%E3%83%B3%E3%83%88%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E7%94%A8%E3%81%AB%E4%BA%8B%E5%89%8D%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%20256%20KiB%20%E3%83%97%E3%83%BC%E3%83%AB%3C%2FP%3E%3CP%3Ecpuidle%3A%E3%82%AC%E3%83%90%E3%83%8A%E3%83%BC%E3%83%A9%E3%83%80%E3%83%BC%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Ecpuidle%3A%20%E3%82%AC%E3%83%90%E3%83%8A%E3%83%BC%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EWDOG1%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Esyscon%2030340000.iomuxc-gpr%3Aregmap%20%5Bmem%200x30340000-0x3034ffff%5D%20%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Esyscon%2030360000.anatop%3Aregmap%20%5Bmem%200x30360000-0x3036ffff%5D%20%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Evdd1p0d%3A800%26lt%3B--%26gt%3B%3C%2FP%3E%3CP%3Esyscon%2030390000.src%20%E3%81%A7%E3%81%99%E3%80%82regmap%20%5Bmem%200x30390000-0x3039ffff%5D%20%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3EDDR%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AFDDR3!%3C%2FP%3E%3CP%3E------------%5B%20%E3%81%93%E3%81%93%E3%82%92%E5%88%87%E3%82%8B%20%5D------------%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%3ACPU%3A0%20PID%3A1%20at%20arch%20%2F%20arm%20%2F%20mach-imx%20%2F%20pm-imx7.c%3A1097%20imx7d_pm_init%20%2B%200x5c0%20%2F%200x66c()%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3A%3C%2FP%3E%3CP%3ECPU%3A0%20PID%3A1%E9%80%9A%E4%BF%A1%3A%E3%82%B9%E3%83%AF%E3%83%83%E3%83%91%E3%83%BC%2F%200%E6%B1%9A%E6%9F%93%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%843.14.52%20%231%3C%2FP%3E%3CP%3E%5B%26lt%3B80014a68%26gt%3B%5D(unwind_backtrace)%20%E3%80%8C%26lt%3B80011758%26gt%3B%E3%80%8D%E3%82%88%E3%82%8A%20(show_stack%2B0x10%2F0x14)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B80011758%26gt%3B%E3%80%91(show_stack)%20from%20%5B%26lt%3B8071d978%26gt%3B%5D%20(dump_stack%2B0x7c%2F0xbc)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B8071d978%26gt%3B%E3%80%91(dump_stack)%20%E3%80%8C%26lt%3B80032100%26gt%3B%E3%80%8D%E3%82%88%E3%82%8A%20(warn_slowpath_common%2B0x70%2F0x8c)%3C%2FP%3E%3CP%3E%5B%26lt%3B80032100%26gt%3B%5D(warn_slowpath_common)%20from%20%5B%26lt%3B800321b8%26gt%3B%5D%20(warn_slowpath_null%2B0x1c%2F0x24)%3C%2FP%3E%3CP%3E%5B%26lt%3B800321b8%26gt%3B%5D(warn_slowpath_null)%20from%20%5B%26lt%3B80a0aa34%26gt%3B%5D%20(imx7d_pm_init%2B0x5c0%2F0x66c)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B80a0aa34%26gt%3B%E3%80%91(imx7d_pm_init)%20from%20%5B%26lt%3B80a09a84%26gt%3B%5D%20(imx7d_init_machine%2B0x3c%2F0xe4)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B80a09a84%26gt%3B%E3%80%91(imx7d_init_machine)%20from%20%5B%26lt%3B809e62d8%26gt%3B%5D%20(customize_machine%2B0x20%2F0x40)%3C%2FP%3E%3CP%3E%5B%26lt%3B809e62d8%26gt%3B%5D(customize_machine)%20from%20%5B%26lt%3B8000889c%26gt%3B%5D%20(do_one_initcall%2B0xf8%2F0x154)%3C%2FP%3E%3CP%3E%5B%26lt%3B8000889c%26gt%3B%5D(do_one_initcall)%20from%20%5B%26lt%3B809e3c54%26gt%3B%5D%20(kernel_init_freeable%2B0x138%2F0x1d8)%3C%2FP%3E%3CP%3E%5B%26lt%3B809e3c54%26gt%3B%5D(kernel_init_freeable)%20%5B%26lt%3B80719df0%26gt%3B%5D%20(kernel_init%2B0x8%2F0xe8)%20%E3%82%88%E3%82%8A%3C%2FP%3E%3CP%3E%5B%26lt%3B80719df0%26gt%3B%5D(kernel_init)%20%E3%80%8C%26lt%3B8000e500%26gt%3B%E3%80%8D%E3%82%88%E3%82%8A%20(ret_from_fork%2B0x14%2F0x34)%3C%2FP%3E%3CP%3E---%5B%20%E3%82%A8%E3%83%B3%E3%83%89%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%209E8BE753475F047D%20%5D---%3C%2FP%3E%3CP%3E------------%5B%20%E3%81%93%E3%81%93%E3%82%92%E5%88%87%E3%82%8B%20%5D------------%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%3ACPU%3A0%20PID%3A1%20at%20arch%20%2F%20arm%20%2F%20mach-imx%20%2F%20pm-imx7.c%3A1098%20imx7d_pm_init%20%2B%200x5e8%20%2F%200x66c()%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3A%3C%2FP%3E%3CP%3ECPU%3A0%20PID%3A1%E9%80%9A%E4%BF%A1%3A%E3%82%B9%E3%83%AF%E3%83%83%E3%83%91%E3%83%BC%2F%200%E6%B1%9A%E6%9F%93%3AG%20W%203.14.52%20%231%3C%2FP%3E%3CP%3E%5B%26lt%3B80014a68%26gt%3B%5D(unwind_backtrace)%20%E3%80%8C%26lt%3B80011758%26gt%3B%E3%80%8D%E3%82%88%E3%82%8A%20(show_stack%2B0x10%2F0x14)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B80011758%26gt%3B%E3%80%91(show_stack)%20from%20%5B%26lt%3B8071d978%26gt%3B%5D%20(dump_stack%2B0x7c%2F0xbc)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B8071d978%26gt%3B%E3%80%91(dump_stack)%20%E3%80%8C%26lt%3B80032100%26gt%3B%E3%80%8D%E3%82%88%E3%82%8A%20(warn_slowpath_common%2B0x70%2F0x8c)%3C%2FP%3E%3CP%3E%5B%26lt%3B80032100%26gt%3B%5D(warn_slowpath_common)%20from%20%5B%26lt%3B800321b8%26gt%3B%5D%20(warn_slowpath_null%2B0x1c%2F0x24)%3C%2FP%3E%3CP%3E%5B%26lt%3B800321b8%26gt%3B%5D(warn_slowpath_null)%20from%20%5B%26lt%3B80a0aa5c%26gt%3B%5D%20(imx7d_pm_init%2B0x5e8%2F0x66c)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B80a0aa5c%26gt%3B%E3%80%91(imx7d_pm_init)%20from%20%5B%26lt%3B80a09a84%26gt%3B%5D%20(imx7d_init_machine%2B0x3c%2F0xe4)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B80a09a84%26gt%3B%E3%80%91(imx7d_init_machine)%20from%20%5B%26lt%3B809e62d8%26gt%3B%5D%20(customize_machine%2B0x20%2F0x40)%3C%2FP%3E%3CP%3E%5B%26lt%3B809e62d8%26gt%3B%5D(customize_machine)%20from%20%5B%26lt%3B8000889c%26gt%3B%5D%20(do_one_initcall%2B0xf8%2F0x154)%3C%2FP%3E%3CP%3E%5B%26lt%3B8000889c%26gt%3B%5D(do_one_initcall)%20from%20%5B%26lt%3B809e3c54%26gt%3B%5D%20(kernel_init_freeable%2B0x138%2F0x1d8)%3C%2FP%3E%3CP%3E%5B%26lt%3B809e3c54%26gt%3B%5D(kernel_init_freeable)%20%5B%26lt%3B80719df0%26gt%3B%5D%20(kernel_init%2B0x8%2F0xe8)%20%E3%82%88%E3%82%8A%3C%2FP%3E%3CP%3E%5B%26lt%3B80719df0%26gt%3B%5D(kernel_init)%20%E3%80%8C%26lt%3B8000e500%26gt%3B%E3%80%8D%E3%82%88%E3%82%8A%20(ret_from_fork%2B0x14%2F0x34)%3C%2FP%3E%3CP%3E---%5B%20end%20trace%209e8be753475f047e%20%5D---%3C%2FP%3E%3CP%3E------------%5B%20%E3%81%93%E3%81%93%E3%82%92%E5%88%87%E3%82%8B%20%5D------------%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%3ACPU%3A0%20PID%3A1%20at%20mm%20%2F%20page_alloc.c%3A2566%20__alloc_pages_nodemask%20%2B%200x42c%20%2F%200x974()%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3A%3C%2FP%3E%3CP%3ECPU%3A0%20PID%3A1%E9%80%9A%E4%BF%A1%3A%E3%82%B9%E3%83%AF%E3%83%83%E3%83%91%E3%83%BC%2F%200%E6%B1%9A%E6%9F%93%3AG%20W%203.14.52%20%231%3C%2FP%3E%3CP%3E%5B%26lt%3B80014a68%26gt%3B%5D(unwind_backtrace)%20%E3%80%8C%26lt%3B80011758%26gt%3B%E3%80%8D%E3%82%88%E3%82%8A%20(show_stack%2B0x10%2F0x14)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B80011758%26gt%3B%E3%80%91(show_stack)%20from%20%5B%26lt%3B8071d978%26gt%3B%5D%20(dump_stack%2B0x7c%2F0xbc)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B8071d978%26gt%3B%E3%80%91(dump_stack)%20%E3%80%8C%26lt%3B80032100%26gt%3B%E3%80%8D%E3%82%88%E3%82%8A%20(warn_slowpath_common%2B0x70%2F0x8c)%3C%2FP%3E%3CP%3E%5B%26lt%3B80032100%26gt%3B%5D(warn_slowpath_common)%20from%20%5B%26lt%3B800321b8%26gt%3B%5D%20(warn_slowpath_null%2B0x1c%2F0x24)%3C%2FP%3E%3CP%3E%5B%26lt%3B800321b8%26gt%3B%5D(warn_slowpath_null)%20from%20%5B%26lt%3B800a6a04%26gt%3B%5D%20(__alloc_pages_nodemask%2B0x42c%2F0x974)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B800a6a04%26gt%3B%E3%80%91(__alloc_pages_nodemask)%20from%20%5B%26lt%3B800a6f5c%26gt%3B%5D%20(__get_free_pages%2B0x10%2F0x24)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B800a6f5c%26gt%3B%E3%80%91(__get_free_pages)%20from%20%5B%26lt%3B80a0aa78%26gt%3B%5D%20(imx7d_pm_init%2B0x604%2F0x66c)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B80a0aa78%26gt%3B%E3%80%91(imx7d_pm_init)%20from%20%5B%26lt%3B80a09a84%26gt%3B%5D%20(imx7d_init_machine%2B0x3c%2F0xe4)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B80a09a84%26gt%3B%E3%80%91(imx7d_init_machine)%20from%20%5B%26lt%3B809e62d8%26gt%3B%5D%20(customize_machine%2B0x20%2F0x40)%3C%2FP%3E%3CP%3E%5B%26lt%3B809e62d8%26gt%3B%5D(customize_machine)%20from%20%5B%26lt%3B8000889c%26gt%3B%5D%20(do_one_initcall%2B0xf8%2F0x154)%3C%2FP%3E%3CP%3E%5B%26lt%3B8000889c%26gt%3B%5D(do_one_initcall)%20from%20%5B%26lt%3B809e3c54%26gt%3B%5D%20(kernel_init_freeable%2B0x138%2F0x1d8)%3C%2FP%3E%3CP%3E%5B%26lt%3B809e3c54%26gt%3B%5D(kernel_init_freeable)%20%5B%26lt%3B80719df0%26gt%3B%5D%20(kernel_init%2B0x8%2F0xe8)%20%E3%82%88%E3%82%8A%3C%2FP%3E%3CP%3E%5B%26lt%3B80719df0%26gt%3B%5D(kernel_init)%20%E3%80%8C%26lt%3B8000e500%26gt%3B%E3%80%8D%E3%82%88%E3%82%8A%20(ret_from_fork%2B0x14%2F0x34)%3C%2FP%3E%3CP%3E---%5B%20%E3%82%A8%E3%83%B3%E3%83%89%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%209E8BE753475F047F%20%5D---%3C%2FP%3E%3CP%3E------------%5B%20%E3%81%93%E3%81%93%E3%82%92%E5%88%87%E3%82%8B%20%5D------------%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%3ACPU%3A0%20PID%3A1%20at%20arch%20%2F%20arm%20%2F%20mach-imx%20%2F%20pm-imx7.c%3A1101%20imx7d_pm_init%20%2B%200x620%20%2F%200x66c()%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3A%3C%2FP%3E%3CP%3ECPU%3A0%20PID%3A1%E9%80%9A%E4%BF%A1%3A%E3%82%B9%E3%83%AF%E3%83%83%E3%83%91%E3%83%BC%2F%200%E6%B1%9A%E6%9F%93%3AG%20W%203.14.52%20%231%3C%2FP%3E%3CP%3E%5B%26lt%3B80014a68%26gt%3B%5D(unwind_backtrace)%20%E3%80%8C%26lt%3B80011758%26gt%3B%E3%80%8D%E3%82%88%E3%82%8A%20(show_stack%2B0x10%2F0x14)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B80011758%26gt%3B%E3%80%91(show_stack)%20from%20%5B%26lt%3B8071d978%26gt%3B%5D%20(dump_stack%2B0x7c%2F0xbc)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B8071d978%26gt%3B%E3%80%91(dump_stack)%20%E3%80%8C%26lt%3B80032100%26gt%3B%E3%80%8D%E3%82%88%E3%82%8A%20(warn_slowpath_common%2B0x70%2F0x8c)%3C%2FP%3E%3CP%3E%5B%26lt%3B80032100%26gt%3B%5D(warn_slowpath_common)%20from%20%5B%26lt%3B800321b8%26gt%3B%5D%20(warn_slowpath_null%2B0x1c%2F0x24)%3C%2FP%3E%3CP%3E%5B%26lt%3B800321b8%26gt%3B%5D(warn_slowpath_null)%20from%20%5B%26lt%3B80a0aa94%26gt%3B%5D%20(imx7d_pm_init%2B0x620%2F0x66c)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B80a0aa94%26gt%3B%E3%80%91(imx7d_pm_init)%20from%20%5B%26lt%3B80a09a84%26gt%3B%5D%20(imx7d_init_machine%2B0x3c%2F0xe4)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B80a09a84%26gt%3B%E3%80%91(imx7d_init_machine)%20from%20%5B%26lt%3B809e62d8%26gt%3B%5D%20(customize_machine%2B0x20%2F0x40)%3C%2FP%3E%3CP%3E%5B%26lt%3B809e62d8%26gt%3B%5D(customize_machine)%20from%20%5B%26lt%3B8000889c%26gt%3B%5D%20(do_one_initcall%2B0xf8%2F0x154)%3C%2FP%3E%3CP%3E%5B%26lt%3B8000889c%26gt%3B%5D(do_one_initcall)%20from%20%5B%26lt%3B809e3c54%26gt%3B%5D%20(kernel_init_freeable%2B0x138%2F0x1d8)%3C%2FP%3E%3CP%3E%5B%26lt%3B809e3c54%26gt%3B%5D(kernel_init_freeable)%20%5B%26lt%3B80719df0%26gt%3B%5D%20(kernel_init%2B0x8%2F0xe8)%20%E3%82%88%E3%82%8A%3C%2FP%3E%3CP%3E%5B%26lt%3B80719df0%26gt%3B%5D(kernel_init)%20%E3%80%8C%26lt%3B8000e500%26gt%3B%E3%80%8D%E3%82%88%E3%82%8A%20(ret_from_fork%2B0x14%2F0x34)%3C%2FP%3E%3CP%3E---%5B%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E7%B5%82%E4%BA%86%209E8BE753475F0480%20%5D---%3C%2FP%3E%3CP%3EOCOTP%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EOCOTP%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EHW-BREAKPOINT%3A%205%20(%2B1%20%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF)%20%E3%81%AE%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%A8%204%20%E3%81%A4%E3%81%AE%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Ehw-breakpoint%3A%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%9C%80%E5%A4%A7%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%208%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EIMX7D-PINCTRL%20302C0000.IOMUXC-LPSR%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9FIMX%20pinctrl%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FP%3E%3CP%3Eimx7d-pinctrl%2030330000.iomuxc%3A%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9FIMX%20pinctrl%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FP%3E%3CP%3E303A0000.GPC%20%E9%9B%BB%E6%BA%90%20MIPI-PHY%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E303A0000.GPC%20%E4%BE%9B%E7%B5%A6%20VCC%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EMU%E3%81%AF%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%B3%E3%82%A2%E9%80%9A%E4%BF%A1%E3%81%AE%E6%BA%96%E5%82%99%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3EBIO%3A0%E3%81%AB%E3%82%B9%E3%83%A9%E3%83%96%3CBIO-0%3E%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3EMXS-DMA%3A33000000.dma-apbh%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%82%A8%E3%83%A9%E3%83%BC%20-2%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eusb_otg1_vbus%3A%205000%20mV%3C%2FP%3E%3CP%3Eusb_otg2_vbus%3A%205000%20mV%3C%2FP%3E%3CP%3ECAN2-3V3%3A%203300%20mV%3C%2FP%3E%3CP%3Evref-1v8%3A%201800%20mV%3C%2FP%3E%3CP%3Ewlreg_on%3A%205000%20mV%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BMAX17135%5D%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BMAX17135%5D%3C%2FP%3E%3CP%3ESCSI%20%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20usbfs%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%8F%E3%83%96%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20USB%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbphy_nop1.5%20%E9%9B%BB%E6%BA%90%20VCC%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Eusbphy_nop2.6%20%E9%9B%BB%E6%BA%90%20VCC%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Eusbphy_nop3.7%20%E9%9B%BB%E6%BA%90%20VCC%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Ei2c%20i2c-0%3A%20IMX%20I2C%20%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3Ei2c%20i2c-1%3A%20IMX%20I2C%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Ei2c%20i2c-2%3A%20IMX%20I2C%20%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3Ei2c%20i2c-3%3A%20IMX%20I2C%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3ELinux%E3%83%93%E3%83%87%E3%82%AA%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3Av2.00%3C%2FP%3E%3CP%3Epps_core%3ALinuxPPS%20API%20ver.1%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%3CSPAN%3Epps_core%3A%20Software%20ver.%205.3.6%20-%20Copyright%202005-2007%20Rodolfo%20Giometti%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Agiometti%40linux.it%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Egiometti%40linux.it%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EPTP%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EMIPI%20CSI2%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%BB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EAdvanced%20Linux%20Sound%20Architecture%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EBluetooth%3A%E3%82%B3%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B32.18%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2031%3C%2FP%3E%3CP%3EBluetooth%3AHCI%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E6%8E%A5%E7%B6%9A%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3AHCI%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3AL2CAP%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3ASCO%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Ecfg80211%3A%20CRDA%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A6%E4%B8%96%E7%95%8C%E3%81%AE%E8%A6%8F%E5%88%B6%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9arch_sys_counter%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%202%3C%2FP%3E%3CP%3ETCP%20%E7%A2%BA%E7%AB%8B%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%208192%20(%E9%A0%86%E5%BA%8F%3A%203%E3%80%8132768%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ETCP%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A8192(%E9%A0%86%E5%BA%8F%3A4%E3%80%8165536%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ETCP%3A%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99(8192%20%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%208192%20%E3%81%8C%E7%A2%BA%E7%AB%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%3C%2FP%3E%3CP%3ETCP%3A%20reno%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EUDP%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3EUDP-Lite%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%201%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E5%90%8D%E5%89%8D%E3%81%AE%20UNIX%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E8%BB%A2%E9%80%81%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%20UDP%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%20tcp%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%20tcp%20NFSv4.1%20%E3%83%90%E3%83%83%E3%82%AF%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3Eimx%20rpmsg%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%90%E3%82%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EFutex%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%203%2C%2032768%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3EVFS%3A%20Disk%20quotas%20dquot_6.5.2%3C%2FP%3E%3CP%3EDquot-cache%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%201024%20(%E9%A0%86%E5%BA%8F%200%E3%80%814096%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ENFS%3Aid_resolver%E3%82%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%E3%82%AD%E3%83%BC%E3%81%AE%E7%A8%AE%E9%A1%9E%20id_resolver%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%AD%E3%83%BC%E3%81%AE%E7%A8%AE%E9%A1%9E%20id_legacy%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EJFFS2%3A%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.2.(NAND)%20%C2%A9%202001-2006%20%E3%83%AC%E3%83%83%E3%83%89%E3%83%8F%E3%83%83%E3%83%88%E6%A0%AA%E5%BC%8F%E4%BC%9A%E7%A4%BE%3C%2FP%3E%3CP%3Efuse%20init%20(API%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%207.22)%3C%2FP%3E%3CP%3Emsgmni%20%E3%81%AF%202006%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9NOOP%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%E3%81%AE%E7%B7%A0%E5%88%87%E6%97%A5%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9CFQ%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88)%3C%2FP%3E%3CP%3E%E3%83%90%E3%83%83%E3%82%AF%E3%83%A9%E3%82%A4%E3%83%88.8%E9%9B%BB%E6%BA%90%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EMIPI%20DSI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EMIPI%20DSI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Esii902x%202-0039%3A%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%83%94%E3%83%B3%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Esii902x%202-0039%3A%20edid%20%E3%81%8C%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E30730000.lcdif%20%E4%BE%9B%E7%B5%A6%20LCD%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EMXSFB%2030730000.lcdif%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%87%E3%83%90%E3%82%A4%E3%82%B960x34%E3%81%B8%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FP%3E%3CP%3EMXSFB%2030730000.lcdif%3A%E5%88%9D%E6%9C%9F%E5%8C%96%3C%2FP%3E%3CP%3EIMX-SDMA%2030BD0000.sdma%3AIRAM%20%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%80%81%E5%A4%96%E9%83%A8%20MEM%20%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EIMX-SDMA%2030BD0000.sdma%3A%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%E5%86%8D%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3EIMX-SDMA%2030BD0000.sdma%3A%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A24.1%3C%2FP%3E%3CP%3EIMX-SDMA%2030BD0000.sdma%3A%E5%88%9D%E6%9C%9F%E5%8C%96%3C%2FP%3E%3CP%3Epfuze100-regulator%200-0008%3A%E3%83%95%E3%83%AB%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%3A1%E3%80%81%E3%83%A1%E3%82%BF%E3%83%AB%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%3A0%3C%2FP%3E%3CP%3Epfuze100-regulator%200-0008%3A%20FAB%3A%200%2C%20FIN%3A%200%3C%2FP%3E%3CP%3EPFUze100-REGULATOR%200-0008%3A%20PFUZE3000%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3ESW1A%3A700%20%26lt%3B--%26gt%3B%201100%20mV%E3%81%A71425%20mV%3C%2FP%3E%3CP%3ESW1B%3A700%26lt%3B--%26gt%3B%201475%20mV%3C%2FP%3E%3CP%3ESW2%3A1500%26lt%3B--%26gt%3B%201850%20mV%3C%2FP%3E%3CP%3ESW3%3A900%20%26lt%3B--%26gt%3B%201350%20mV%E3%81%A71650%20mV%3C%2FP%3E%3CP%3ESWBST%3A5000%26lt%3B--%26gt%3B%205150%20mV%3C%2FP%3E%3CP%3EVSNVS%3A1000%26lt%3B--%26gt%3B%203000%20mV%3C%2FP%3E%3CP%3EVREFDDR%3A%20750%20mV%3C%2FP%3E%3CP%3EVLDO1%3A%201800%20%26lt%3B--%26gt%3B%201800%20mV%20%E3%81%A7%203300%20mV%3C%2FP%3E%3CP%3EVLDO2%3A800%26lt%3B--%26gt%3B%201550%20mV%3C%2FP%3E%3CP%3EVCCSD%3A2850%26lt%3B--%26gt%3B%203300%20mV%3C%2FP%3E%3CP%3EV33%3A%202850%26lt%3B--%26gt%3B%3C%2FP%3E%3CP%3EVLDO3%3A%201800%26lt%3B--%26gt%3B%3C%2FP%3E%3CP%3EVLDO4%3A%201800%26lt%3B--%26gt%3B%3C%2FP%3E%3CP%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3AIMX%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3E30860000.%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3AMMIO%200x30860000%20(irq%20%3D%2058%2C%20base_baud%20%3D%205000000)%20%E3%81%AE%20ttymxc0%20%E3%81%AF%20IMX%20%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc0%5D%20%E6%9C%89%E5%8A%B9%3C%2FP%3E%3CP%3E30a70000.%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3AMMIO%200x30a70000%20(irq%20%3D%2062%2C%20base_baud%20%3D%205000000)%20%E3%81%AE%20ttymxc4%20%E3%81%AF%20IMX%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E30a80000.%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3AMMIO%200x30a80000%20(irq%20%3D%2048%2C%20base_baud%20%3D%205000000)%20%E3%81%AE%20ttymxc5%20%E3%81%AF%20IMX%20%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3A%20Freescale%20lpuart%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FP%3E%3CP%3EIMX%20SEMA4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%5BDRM%E3%81%AE%5D%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9Fdrm%201.1.020060810%3C%2FP%3E%3CP%3E%5BDRM%E3%81%AE%5D%E3%83%9E%E3%82%A4%E3%83%8A%E3%83%BC%200%20%E3%81%A7%20vivante%201.0.0%2020120216%20%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBRD%3A%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3C%2FP%3E%3CP%3Eloop%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ESPI4.16%20spi_gpio%3Agpio-miso%20%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81no-rx%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3ECAN%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FP%3E%3CP%3EFlexcan%2030A10000.can%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(reg_base%3DF5A10000%2C%20IRQ%3D143)%3C%2FP%3E%3CP%3E30BE0000.%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E4%BE%9B%E7%B5%A6PHY%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Epps%20pps0%3A%20%E6%96%B0%E3%81%97%E3%81%84%20PPS%20%E3%82%BD%E3%83%BC%E3%82%B9%20ptp0%3C%2FP%3E%3CP%3Elibphy%3A%20fec_enet_mii_bus%3A%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3Efec%2030be0000.ethernet%20eth0%3A%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AEPHC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B90%3C%2FP%3E%3CP%3Eehci_hcd%3A%20USB%202.0%20%E3%80%8C%E6%8B%A1%E5%BC%B5%E3%80%8D%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20(EHCI)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3Eehci-mxc%3A%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97EHCI%E3%83%9B%E3%82%B9%E3%83%88%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FP%3E%3CP%3Eusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AEusb-storage%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20usb_ehset_test%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E30B10200.USBMISC%20%E9%9B%BB%E6%BA%90%20VBUS-Wakeup%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E30b20200.usbmisc%20%E4%BE%9B%E7%B5%A6%20VBUS-%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E30b30200.usbmisc%20%E9%9B%BB%E6%BA%90%20vbus-wakeup%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Eci_hdrc%20ci_hdrc.1%3AEHCI%20%E3%83%9B%E3%82%B9%E3%83%88%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%3C%2FP%3E%3CP%3Eci_hdrc%20ci_hdrc.1%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B71%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Eci_hdrc%20ci_hdrc.1%3AUSB%202.0%20%E9%96%8B%E5%A7%8B%E3%80%81EHCI%201.00%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%96%201-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%96%201-0%3A1.0%3A%201%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Emousedev%3A%20PS%2F2%20%E3%83%9E%E3%82%A6%E3%82%B9%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20(%E5%85%A8%E3%83%9E%E3%82%A6%E3%82%B9%E5%85%B1%E9%80%9A)%3C%2FP%3E%3CP%3Esnvs_pwrkey%2030370000.snvs-pwrkey%3ASNVS%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%3A%2030370000.snvs-pwrkey%2Fdevices%2Fsoc.2%2F30000000.aips-bus%2F30370000.snvs-pwrkey%2Finput%2Finput0%20%E3%81%A8%E3%81%97%E3%81%A6%3C%2FP%3E%3CP%3Esnvs_pwrkey%2030370000.snvs-pwrkey%3Ai.MX%20SNVS%20PowerKey%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3EI2C-Core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BISL29023%5D%20%E3%81%8C%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BISL29023%5D%3C%2FP%3E%3CP%3Esnvs_rtc%2030370034.snvs-rtc-lp%3ASNVS-RTC%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Esnvs_rtc%2030370034.snvs-rtc-lp%3ARTC%E3%82%B3%E3%82%A2%3A%E7%99%BB%E9%8C%B230370034.snvs-rtc-lRTC0%E3%81%A8%E3%81%97%E3%81%A6%3C%2FP%3E%3CP%3Ei2c%20%2Fdev%20entries%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3EIR%20NEC%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIR%20RC5(x)%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIR%20RC6%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIR%20JVC%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%BB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIR%20Sony%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIR%20RC5%20(streamzap)%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIR%20SANYO%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIR%20MCE%20%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%2F%E3%83%9E%E3%82%A6%E3%82%B9%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EPXP-V4L2%20pxp_v4l2_out.9%3A%E5%88%9D%E6%9C%9F%E5%8C%96%3C%2FP%3E%3CP%3EI2C-Core%3A%20%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BMAG3110%5D%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BMAG3110%5D%3C%2FP%3E%3CP%3EIMX2-WDT%2030280000.wdog%3AIMX2%2B%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3D60%E7%A7%92%20(nowayout%3D0)%3C%2FP%3E%3CP%3EBluetooth%3AHCI%20UART%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCver%202.2%3C%2FP%3E%3CP%3EBluetooth%3AHCI%20H4%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3AHCI%20BCSP%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3A%20HCIATH3K%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E8%A6%8F%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20BCM203x%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20btusb%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20ath3k%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Esdhci%3A%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%BB%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%BB%E3%83%9B%E3%82%B9%E3%83%88%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3Esdhci%3A%20Copyright(c)%20Pierre%20Ossman%20(%E8%8B%B1%E8%AA%9E)%3C%2FP%3E%3CP%3Esdhci-pltfm%3A%20SDHCI%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A8%20OF%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%98%E3%83%AB%E3%83%91%E3%83%BC%3C%2FP%3E%3CP%3Esdhci-esdhc-imx%2030b40000.usdhc%3A%E8%B6%85%E9%AB%98%E9%80%9F%E7%8A%B6%E6%85%8B%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%80%81%E9%80%9A%E5%B8%B8%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3EMMC0%20%3A%20VQMMC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3EMMC0%20%3A%20VMMC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Emmc0%3A%2030b40000.usdhc%20%5B30b40000.usdhc%5D%20%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCADMA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Esdhci-esdhc-imx%2030b50000.usdhc%3AWiFi%E3%83%9B%E3%82%B9%E3%83%88%E3%81%A8%E3%81%97%E3%81%A6%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%3C%2FP%3E%3CP%3EMMC1%20%3A%20VQMMC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3EMMC1%3A%20VMMC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Emmc0%3A%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9a77f%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84SD%E3%82%AB%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3Emmcblk0%3A%20mmc0%3Aa77f%20SU01G%20968%20MiB%3C%2FP%3E%3CP%3E%20mmcblk0%3A%20p1%20p2%3C%2FP%3E%3CP%3Emmc1%3A%2030b50000.usdhc%20%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20%5B30b50000.usdhc%5DADMA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EMMC2%20%3A%20VQMMC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3EMMC2%3A%20VMMMC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Emmc2%3A%2030b60000.usdhc%20%5B30b60000.usdhc%5D%20%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCADMA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E%E5%A4%89%E6%8F%9B%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B8%E3%83%A7%E3%83%96%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20usbhid%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbhid%3A%20USB%20HID%20%E3%82%B3%E3%82%A2%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFSaurabh%3C%2FP%3E%3CP%3EYocto%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AEzImage%E3%82%92%E5%86%8D%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%E2%94%82%20-%26gt%3B%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%3C%2FTD%3E%3CTD%3E%E2%94%82%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E2%94%82%20-%26gt%3B%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E5%AF%BE%E5%BF%9C%20(NETDEVICES%20%5B%3Dy%5D)%20%3C%2FTD%3E%3CTD%3E%E2%94%82%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%E2%94%82%20-%26gt%3B%20USB%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%20%E2%94%82%3C%2FP%3E%3CP%3E%E2%94%82%20-%26gt%3B%20%E5%A4%9A%E7%9B%AE%E7%9A%84USB%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%20(y)%20%E2%94%82%3C%2FP%3E%3CP%3E%7C-%26gt%3B%20RNDIS%E3%81%8A%E3%82%88%E3%81%B3activeSync%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%94%A8%E3%83%9B%E3%82%B9%E3%83%88(y)%20%7C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E2%94%82%20-%26gt%3B%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3E%7C%E3%83%BB%26gt%3BUSB%E5%AF%BE%E5%BF%9C(y)%20%7C%3C%2FP%3E%3CP%3E%7C-%26gt%3BUSB%E3%82%AC%E3%82%B8%E3%82%A7%E3%83%83%E3%83%88%E5%AF%BE%E5%BF%9C(y)%20%7C%3C%2FP%3E%3CP%3E%7C%E3%83%BB%26gt%3BUSB%20Gadget%20Drivers%20(Ethernet%20Gadget%20(with%20CDC%20Ethernet%20Support))%20(y)%20%7C%3C%2FP%3E%3CP%3E%7C%E2%97%8F%26gt%3BRNDIS%E5%AF%BE%E5%BF%9C(y)%20%7C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9Fconfig%E3%81%8C%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20%E5%A0%B4%E5%90%88%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%24%20bitbake%20-c%20menuconfig%20linux-imx%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%E5%8F%8A%E3%81%B3%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%24%20bitbake%20-c%20cleansstate%20linux-imx%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%24%20bitbake%20linux-imx%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%E3%81%BE%E3%81%82%E3%81%BE%E3%81%82%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%84%9F%E8%AC%9D%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E9%96%93%E9%81%95%E3%81%84%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%24%20git%20branch%20-b%20local_branch%20origin%2Fimx_3.10.17_1.0.0_ga%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23f6f6f6%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%24%20git%20%3CSTRONG%3Echeckout%3C%2FSTRONG%3E%20-b%20local_branch%20origin%2Fimx_3.10.17_1.0.0_ga%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AF%E7%A7%81%E3%81%AB%E3%81%AF%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82.config%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%82%92%20defconfig%20%E3%81%AB%E5%85%A5%E5%8A%9B%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%AF%E3%80%81%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E5%8D%81%E5%88%86%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF%E3%80%81%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%9A%E3%81%AB%E5%90%8C%E3%81%98%E3%82%82%E3%81%AE%E3%82%92%E7%84%BC%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E3%83%93%E3%83%AB%E3%83%89%E4%B8%AD%E3%81%ABbitbake%E3%81%8C%E6%96%87%E5%8F%A5%E3%82%92%E8%A8%80%E3%81%86%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81defconfig%E3%81%AE%E5%90%8D%E5%89%8D%E3%82%92%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%91%E3%82%B9%E3%81%AE%E4%B8%8B%E3%81%AE_defconfig%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E7%A7%81%E3%81%AF%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E7%9B%B4%E6%8E%A5%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%E3%81%AE%E5%A4%9A%E3%81%8F%E3%81%8C%E6%8F%90%E6%A1%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E7%8B%AC%E8%87%AA%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89(%E3%81%93%E3%81%93%E3%82%92%E5%8F%82%E7%85%A7%EF%BC%88%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95096%23comment-33274%22%20title%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-95096%23comment-33274%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-95096%23comment-33274%3C%2FA%3E%20)%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E------%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%8C%E9%96%8B%E3%81%8D%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%80%81configmenu%E3%82%92%E7%B5%82%E4%BA%86%E3%81%97%E3%81%A6.config%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%20defconfig%20%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive-quote%22%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%24%20cp%20tmp%2Fwork%2Fimx6qsabresd-poky-linux-gnueabi%2Flinux-imx%2F3.0.35-r33.10%2Fgit%2F.config%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E..%2Fsources%2Fmeta-fsl-arm%2Frecipes-kernel%2Flinux%2Flinux-imx-3.0.35%2Fmx6%2Fdefconfig%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E4%B8%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emake%20imx_v7a_defconfig%20ARCH%3Darm%20CROSS_COMPILE%3D%2Fopt%2Fpoky%2F1.5.1%2Fsysroots%2Fx86_64-pokysdk-linux%2Fusr%2Fbin%2Farm-poky-linux-gnueabi%2F%3CSTRONG%3Earm-poky-linux-gnueabi%3C%2FSTRONG%3E-%20-j16%20uImage%20LOADADDR%3D0x10008000%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%83%9D%E3%83%83%E3%82%AD%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E7%95%AA%E5%8F%B7%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%B5%E3%82%A6%E3%83%A9%E3%83%96%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110592%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110592%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%80%8Cbitbake%20-c%20compile%20-f%20linux-imx%E3%80%8D%E3%81%A7%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%81%86%E3%81%BE%E3%81%8F%E4%BD%9C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A0%E3%81%91%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABkernel-source%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E5%85%A5%E3%82%8D%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%B8%B8%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%80%81%E3%81%A9%E3%82%93%E3%81%AA%E6%8F%90%E6%A1%88%E3%82%82%E5%A4%A7%E6%AD%93%E8%BF%8E%E3%81%A7%E3%81%99%E3%80%82%E6%84%9F%E8%AC%9D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%BD%E3%83%BC%E3%82%B9%3A%20%2Fopt%2Fpoky%2F1.8%2Bsnapshot%2Fenvironment-setup-cortexa7hf-vfp-neon-poky-linux-gnueabi%3C%2FP%3E%3CP%3EzImage%20LOADADDR%3D0x10008000%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%88%E3%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emake%20imx_v7_defconfig%20ARCH%3Darm%20CROSS_COMPILE%3D%2Fopt%2Fpoky%2F1.8%2Bsnapshot%2Fsysroots%2Fx86_64-pokysdk-linux%2Fusr%2Fbin%2Farm-poky-linux%2Farm-poky-linux-%20zImage%20LOADADDR%3D0x10008000%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E3%82%82%E5%A4%B1%E6%95%97%E3%83%AD%E3%82%B0%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20CC%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20init%2Fmain.o%3C%2FP%3E%3CP%3ECHK%20include%2Fgenerated%2Fcompile.h%20(%E8%8B%B1%E8%AA%9E)%3C%2FP%3E%3CP%3E%26nbsp%3B%20CC%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20init%2Fversion.o%3C%2FP%3E%3CP%3E%26nbsp%3B%20CC%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20init%2Fdo_mounts.o%3C%2FP%3E%3CP%3E%26nbsp%3B%20CC%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20init%2Fdo_mounts_rd.o%3C%2FP%3E%3CP%3ECC%E3%81%AEinit%2Fdo_mounts_initrd.o%3C%2FP%3E%3CP%3ELD%20init%2Fmounts.o%3C%2FP%3E%3CP%3Einit%2Fdo_mounts_rd.o%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%96%A2%E6%95%B0%20'nop_flush_icache_all'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Edo_mounts_rd.c%3A(.text%2B0x0)%3A%E3%80%8Cnop_flush_icache_all%E3%80%8D%E3%81%AE%E8%A4%87%E6%95%B0%E3%81%AE%E5%AE%9A%E7%BE%A9%3C%2FP%3E%3CP%3Einit%2Fdo_mounts.o%3Ado_mounts.c%3A(.text%2B0x94)%3A%E3%81%93%E3%81%93%E3%81%A7%E6%9C%80%E5%88%9D%E3%81%AB%E5%AE%9A%E7%BE%A9%3C%2FP%3E%3CP%3Einit%2Fdo_mounts_rd.o%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%96%A2%E6%95%B0%20'nop_flush_kern_cache_all'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Edo_mounts_rd.c%3A(.text%2B0x4)%3A%E3%80%8Cnop_flush_kern_cache_all%E3%80%8D%E3%81%AE%E8%A4%87%E6%95%B0%E3%81%AE%E5%AE%9A%E7%BE%A9%3C%2FP%3E%3CP%3Einit%2Fdo_mounts.o%3Ado_mounts.c%3A(.text%2B0x98)%3A%E3%81%93%E3%81%93%E3%81%A7%E6%9C%80%E5%88%9D%E3%81%AB%E5%AE%9A%E7%BE%A9%3C%2FP%3E%3CP%3Einit%2Fdo_mounts_rd.o%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%96%A2%E6%95%B0%20'nop_flush_kern_cache_louis'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Edo_mounts_rd.c%3A(.text%2B0x8)%3A%E3%80%8Cnop_flush_kern_cache_louis%E3%80%8D%E3%81%AE%E8%A4%87%E6%95%B0%E3%81%AE%E5%AE%9A%E7%BE%A9%3C%2FP%3E%3CP%3Einit%2Fdo_mounts.o%3Ado_mounts.c%3A(.text%2B0x9c)%3A%E3%81%93%E3%81%93%E3%81%A7%E6%9C%80%E5%88%9D%E3%81%AB%E5%AE%9A%E7%BE%A9%3C%2FP%3E%3CP%3Einit%2Fdo_mounts_rd.o%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%96%A2%E6%95%B0%20'nop_flush_user_cache_all'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Edo_mounts_rd.c%3A(.text%2B0xc)%3A%E3%80%8Cnop_flush_user_cache_all%E3%80%8D%E3%81%AE%E8%A4%87%E6%95%B0%E3%81%AE%E5%AE%9A%E7%BE%A9%3C%2FP%3E%3CP%3Einit%2Fdo_mounts.o%3Ado_mounts.c%3A(.text%2B0xa0)%3A%E3%81%93%E3%81%93%E3%81%A7%E6%9C%80%E5%88%9D%E3%81%AB%E5%AE%9A%E7%BE%A9%3C%2FP%3E%3CP%3Einit%2Fdo_mounts_rd.o%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%96%A2%E6%95%B0%20'nop_flush_user_cache_range'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Edo_mounts_rd.c%3A(.text%2B0x10)%3A%E3%80%8Cnop_flush_user_cache_range%E3%80%8D%E3%81%AE%E8%A4%87%E6%95%B0%E3%81%AE%E5%AE%9A%E7%BE%A9%3C%2FP%3E%3CP%3Einit%2Fdo_mounts.o%3Ado_mounts.c%3A(.text%2B0xa4)%3A%E3%81%93%E3%81%93%E3%81%A7%E6%9C%80%E5%88%9D%E3%81%AB%E5%AE%9A%E7%BE%A9%3C%2FP%3E%3CP%3Einit%2Fdo_mounts_rd.o%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%96%A2%E6%95%B0%20'nop_coherent_kern_range'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Dhaval%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E8%A9%A6%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emake%26nbsp%3B%20imx_v7_defconfig%20ARCH%3Darm%20CROSS_COMPILE%3D%2Fopt%2Fpoky%2F1.5.1%2Fsysroots%2Fx86_64-pokysdk-linux%2Fusr%2Fbin%2Farm-poky-linux-gnueabi%2Farm-poky-linux-gnueabi-%20-j16%20uImage%20LOADADDR%3D0x10008000%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Rogerio%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%97%A9%E9%80%9F%E3%81%AE%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%81%9D%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E***************************************************************************************************************************%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3Edrivers%2Fusb%2Fchipidea%2Fci_hdrc_imx.c%3A%E9%96%A2%E6%95%B0%20'ci_hdrc_imx_notify_event'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3Edrivers%2Fusb%2Fchipidea%2Fci_hdrc_imx.c%3A226%3A4%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%96%A2%E6%95%B0%20'pinctrl_select_state'%E3%81%AE%E6%9A%97%E9%BB%99%E7%9A%84%E3%81%AA%E5%AE%A3%E8%A8%80%20%5B-Werror%3Dimplicit-function-declaration%5D%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3Eret%20%3D%20pinctrl_select_state(%E3%83%87%E3%83%BC%E3%82%BF%26gt%3B%E3%83%94%E3%83%B3%E5%88%B6%E5%BE%A1%2C%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3Edrivers%2Fusb%2Fchipidea%2Fci_hdrc_imx.c%3A%E9%96%A2%E6%95%B0%20'ci_hdrc_imx_probe'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3Edrivers%2Fusb%2Fchipidea%2Fci_hdrc_imx.c%3A278%3A2%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%96%A2%E6%95%B0%20'devm_pinctrl_get'%E3%81%AE%E6%9A%97%E9%BB%99%E5%AE%A3%E8%A8%80%20%5B-Werror%3Dimplicit-function-declaration%5D%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E3%83%87%E3%83%BC%E3%82%BF-%26gt%3Bpinctrl%20%3D%20devm_pinctrl_get(%26amp%3Bpdev-%26gt%3Bdev)%3B%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%26nbsp%3B%20%5E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3Edrivers%2Fusb%2Fchipidea%2Fci_hdrc_imx.c%3A278%3A16%3A%E8%AD%A6%E5%91%8A%3A%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AF%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%E3%81%AA%E3%81%97%E3%81%A7%E6%95%B4%E6%95%B0%E3%81%8B%E3%82%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E3%83%87%E3%83%BC%E3%82%BF-%26gt%3Bpinctrl%20%3D%20devm_pinctrl_get(%26amp%3Bpdev-%26gt%3Bdev)%3B%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3Edrivers%2Fusb%2Fchipidea%2Fci_hdrc_imx.c%3A283%3A3%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%E9%96%A2%E6%95%B0%20'pinctrl_lookup_state'%E3%81%AE%E6%9A%97%E9%BB%99%E7%9A%84%E3%81%AA%E5%AE%A3%E8%A8%80%20%5B-Werror%3Dimplicit-function-declaration%5D%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3Epinctrl_hsic_idle%20%3D%20pinctrl_lookup_state(%E3%83%87%E3%83%BC%E3%82%BF%26gt%3Bpinctrl%2C%20%22%E3%82%A2%E3%82%A4%E3%83%89%E3%83%AB%22)%3B%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%26nbsp%3B%26nbsp%3B%20%5E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3Edrivers%2Fusb%2Fchipidea%2Fci_hdrc_imx.c%3A283%3A21%3A%E8%AD%A6%E5%91%8A%3A%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AF%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%E3%81%AA%E3%81%97%E3%81%A7%E6%95%B4%E6%95%B0%E3%81%8B%E3%82%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3Epinctrl_hsic_idle%20%3D%20pinctrl_lookup_state(%E3%83%87%E3%83%BC%E3%82%BF%26gt%3Bpinctrl%2C%20%22%E3%82%A2%E3%82%A4%E3%83%89%E3%83%AB%22)%3B%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3Edrivers%2Fusb%2Fchipidea%2Fci_hdrc_imx.c%3A299%3A29%3A%E8%AD%A6%E5%91%8A%3A%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AF%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%E3%81%AA%E3%81%97%E3%81%A7%E6%95%B4%E6%95%B0%E3%81%8B%E3%82%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E3%83%87%E3%83%BC%E3%82%BF%26gt%3Bpinctrl_hsic_active%20%3D%20pinctrl_lookup_state(%E3%83%87%E3%83%BC%E3%82%BF%26gt%3B%E3%83%94%E3%83%B3%E5%88%B6%E5%BE%A1%E3%80%81%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3Ecc1%3A%20%E4%B8%80%E9%83%A8%E3%81%AE%E8%AD%A6%E5%91%8A%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E6%89%B1%E3%82%8F%E3%82%8C%E3%82%8B%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E3%83%A1%E3%83%BC%E3%82%AB%E3%83%BC%5B3%5D%3A%20***%20%5B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%2FUSB%2F%E3%83%81%E3%83%83%E3%83%97%E3%82%A4%E3%83%87%E3%82%A2%2Fci_hdrc_imx.o%5D%E3%82%A8%E3%83%A9%E3%83%BC%201%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3Emake%5B2%5D%3A%20***%20%5Bdrivers%2Fusb%2Fchipidea%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%202%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3Emake%5B1%5D%3A%20***%20%5Bdrivers%2Fusb%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%202%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3Emake%3A%20***%20%5Bdrivers%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%202%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E***************************************************************************************************************************%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E3%83%80%E3%83%B4%E3%82%A1%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Dhaval%2C%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AEdefconfig%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3Emake%20imx_v7_defconfig%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3ERogerio%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E6%9C%AC%E5%BD%93%E3%81%AB%E3%81%84%E3%81%84%E8%A8%98%E4%BA%8B%E3%81%A7%E3%81%99%E3%80%82%E3%80%8CBSP%E3%81%AA%E3%81%97%E3%81%A7%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%80%8D%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%A7%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AF%E3%81%99%E3%81%A7%E3%81%ABYocto%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AF%E3%80%8C%3CBUILD%20dir%3D%22%22%3E%2Ftmp%2Fwork%2Fimx6slevk-poky-linux-gnueabi%2Flinux-imx%2F3.14.28-r0%2Fgit%E3%80%8D%E3%81%A7%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FBUILD%3E%3C%2FP%3E%3CP%3E%23%20make%20imx_v6_v7_defconfig%3C%2FP%3E%3CP%3E%23%20uImage%20%E3%82%92%E4%BD%9C%E3%82%8B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E5%BE%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Earch%2Farm%2Fmach-imx%2Fbuilt-in.o%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%96%A2%E6%95%B0%20'clk_pllv3_do_shared_clks'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.text%2B0x1780)%3A%20'imx_sema4_mutex_lock'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3E%3A(.text%2B0x17a8)%3A%20'imx_sema4_mutex_unlock'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3E%3A(.text%2B0x17e0)%3A%20'imx_update_shared_mem'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3E%3A(.text%2B0x17fc)%3A%20'amp_power_mutex'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3E%3A(.text%2B0x1800)%3A%20'shared_mem'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Earch%2Farm%2Fmach-imx%2Fbuilt-in.o%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%96%A2%E6%95%B0%20'clk_gate2_do_shared_clks'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.text%2B0x1a30)%3A%20'imx_sema4_mutex_lock'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3E%3A(.text%2B0x1a58)%3A%20'imx_sema4_mutex_unlock'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3E%3A(.text%2B0x1a98)%3A%20'imx_update_shared_mem'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3E%3A(.text%2B0x1ab8)%3A%20'amp_power_mutex'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3E%3A(.text%2B0x1abc)%3A%20'shared_mem'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Earch%2Farm%2Fmach-imx%2Fbuilt-in.o%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%96%A2%E6%95%B0%20'clk_pfd_do_shared_clks'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.text%2B0x1e24)%3A%20'imx_sema4_mutex_lock'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3E%3A(.text%2B0x1e4c)%3A%20'imx_sema4_mutex_unlock'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3E%3A(.text%2B0x1e8c)%3A%20'imx_update_shared_mem'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3E%3A(.text%2B0x1eac)%3A%20'amp_power_mutex'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3E%3A(.text%2B0x1eb0)%3A%20'shared_mem'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Earch%2Farm%2Fmach-imx%2Fbuilt-in.o%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%96%A2%E6%95%B0%20'imx6sl_set_wait_clk'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.text%2B0x61f8)%3A%20'low_bus_freq_mode'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Earch%2Farm%2Fmach-imx%2Fbuilt-in.o%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%96%A2%E6%95%B0%20'imx6q_pm_enter'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.text%2B0x6d64)%3A%20'imx_mu_enable_m4_irqs_in_gic'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3E%3A(.text%2B0x6de0)%3A%20'imx_mu_is_m4_in_low_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3E%3A(.text%2B0x6df4)%3A%20'imx_mu_enable_m4_irqs_in_gic'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Earch%2Farm%2Fmach-imx%2Fbuilt-in.o%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%96%A2%E6%95%B0%20'imx6q_map_io'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.init.text%2B0xe7a4)%3A'imx6_busfreq_map_io'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Earch%2Farm%2Fmach-imx%2Fbuilt-in.o%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%96%A2%E6%95%B0%20'imx6sl_map_io'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.init.text%2B0x115e0)%3A'imx6_busfreq_map_io'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Edrivers%2Fbuilt-in.o%3A%E9%96%A2%E6%95%B0%20'fec_runtime_resume'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.text%2B0x119f00)%3A%20'request_bus_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Edrivers%2Fbuilt-in.o%3A%E9%96%A2%E6%95%B0%20'fec_runtime_suspend'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.text%2B0x119f1c)%3A%20'release_bus_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Edrivers%2Fbuilt-in.o%3A%E9%96%A2%E6%95%B0%20'imx_controller_resume'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.text%2B0x1666d4)%3A%20'request_bus_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3E%3A(.text%2B0x1666f4)%3A%20'release_bus_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3E%3A(.text%2B0x166788)%3A%20'release_bus_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Edrivers%2Fbuilt-in.o%3A%E9%96%A2%E6%95%B0%20'imx_controller_suspend'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.text%2B0x16685c)%3A%20'release_bus_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Edrivers%2Fbuilt-in.o%3A%E9%96%A2%E6%95%B0%20'ci_hdrc_imx_remove'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.text%2B0x166954)%3A%20'release_bus_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Edrivers%2Fbuilt-in.o%3A%E9%96%A2%E6%95%B0%20'ci_hdrc_imx_probe'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.text%2B0x166d10)%3A%20'request_bus_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3E%3A(.text%2B0x166d30)%3A%20'release_bus_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3E%3A(.text%2B0x166e1c)%3A%20'release_bus_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Edrivers%2Fbuilt-in.o%3A%E9%96%A2%E6%95%B0%20'sdhci_esdhc_runtime_resume'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.text%2B0x1c82d0)%3A%20'request_bus_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Edrivers%2Fbuilt-in.o%3A%E9%96%A2%E6%95%B0%20'sdhci_esdhc_runtime_suspend'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.text%2B0x1c8344)%3A%20'release_bus_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Edrivers%2Fbuilt-in.o%3A%E9%96%A2%E6%95%B0%20'sdhci_esdhc_imx_probe'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.text%2B0x1c8fdc)%3A%20'release_bus_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3E%3A(.text%2B0x1c9004)%3A%20'request_bus_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Edrivers%2Fbuilt-in.o%3A%E9%96%A2%E6%95%B0%20'vpu_runtime_resume'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.text%2B0x1c949c)%3A%20'request_bus_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Edrivers%2Fbuilt-in.o%3A%E9%96%A2%E6%95%B0%20'vpu_runtime_suspend'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.text%2B0x1c94b8)%3A%20'release_bus_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Esound%2Fbuilt-in.o%3A%E9%96%A2%E6%95%B0%20'fsl_ssi_runtime_resume'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.text%2B0x2f160)%3A%20'request_bus_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Esound%2Fbuilt-in.o%3A%E9%96%A2%E6%95%B0%20'fsl_ssi_runtime_suspend'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.text%2B0x2f17c)%3A%20'release_bus_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Esound%2Fbuilt-in.o%3A%E9%96%A2%E6%95%B0%20'fsl_spdif_runtime_resume'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.text%2B0x30e08)%3A%20'request_bus_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Esound%2Fbuilt-in.o%3A%E9%96%A2%E6%95%B0%20'fsl_spdif_runtime_suspend'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3A(.text%2B0x30e24)%3A%20'release_bus_freq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Emake%3A%20***%20%5Bvmlinux%5D%20Error%201%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AA%B0%E3%81%8B%E3%81%8C%E3%81%93%E3%82%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%BF%85%E9%80%9F%E3%81%AA%E5%8A%A9%E3%81%91%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%80%E3%83%B4%E3%82%A1%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-avatarid%3D%221002%22%20data-externalid%3D%22%22%20data-online%3D%22false%22%20data-presence%3D%22null%22%20data-userid%3D%2226994%22%20data-username%3D%22saurabh206%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fsaurabh206%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2012px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%238b8b8b%3B%20background-color%3A%20%23f6f6f6%3B%22%20target%3D%22_blank%22%3E%E3%82%B5%E3%82%A6%E3%83%A9%E3%83%96%E3%83%BB%E3%83%91%E3%83%86%E3%83%AB%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E6%89%8B%E3%81%AB%E5%85%A5%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%81%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AB%E3%83%99%E3%82%B9%E3%83%88%3C%2FP%3E%3CP%3E%E3%83%AD%E3%83%B3%E3%83%AA%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3C%2FP%3E%3CP%3E%E3%83%AD%E3%83%B3%E3%82%B0%E3%83%AA%E3%83%B3%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AF%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%B5%E3%82%A6%E3%83%A9%E3%83%96%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2013px%3B%22%3EHi%20%3C%2FSPAN%3E%3CA%20_jive_internal%3D%22true%22%20class%3D%22jiveTT-hover-user%20jive-link-profile-small%22%20data-containerid%3D%22-1%22%20data-containertype%3D%22-1%22%20data-objectid%3D%222014%22%20data-objecttype%3D%223%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frogeriopimentel%22%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%236a737b%3B%22%20target%3D%22_blank%22%3Erogeriopimentel%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%82%92%E5%AE%8C%E6%88%90%E3%81%95%E3%81%9B%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AB%E3%81%AF%E5%88%A5%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%206%20%E3%81%AE%E5%BD%B9%E5%89%B2%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110584%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110584%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frogeriopimentel%22%20target%3D%22_blank%22%3Erogeriopimentel%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E.config%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8Dltib%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7imx_v7_defconfig%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81imx_v7_defconfig%E3%82%92.config%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%80%81%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2013px%3B%22%3E%20uImage%20LOADADDR%3D0x10008000%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%80%8C%E9%96%8B%E7%99%BA%E3%81%8A%E3%82%88%E3%81%B3%2F%E3%81%BE%E3%81%9F%E3%81%AF%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E3%82%B3%E3%83%BC%E3%83%89%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%20(%E5%AE%9F%E9%A8%93%E7%9A%84)%20%5BN%2Fy%2F%3F%5D(NEW)%E3%80%8D%E3%81%A8%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%81%8C%E6%9C%80%E5%88%9D%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%8E%A8%E6%B8%AC%E3%81%95%E3%82%8C%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A7%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%81%AE%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110583%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110583%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Ronglin%2C%3C%2FP%3E%3CP%3E%E6%9C%80%E8%BF%91%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%AF%20imx_v7_defconfig%20%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%26nbsp%3B%20%3C%2FP%3E%3CP%3Eimx_v6_v7_defconfig%20%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2013px%3B%22%3E%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2013px%3B%22%3E%E3%81%A9%E3%81%93%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%89%E3%82%8C%E3%82%8B%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110581%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110581%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFSaurabh%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emenuconfig%E3%81%AE%E5%BE%8C%E3%82%82bitbake%20-c%20cleansstate%20linux-imx%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81bitbake%20linux-imx%E3%81%AB%E7%9B%B4%E6%8E%A5%E8%A1%8C%E3%81%8F%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81bitbake%20rootfs%E3%81%A8%E3%81%AF%E3%81%A9%E3%81%86%E3%81%84%E3%81%86%E6%84%8F%E5%91%B3%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%80%8Cfsl-image-x11%E3%80%8D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E7%A7%81%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E3%83%AC%E3%82%B7%E3%83%94%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%83%AC%E3%82%B7%E3%83%94%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eyocto%E3%81%A7%E3%82%82%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBitback%20linux-imx%20%E3%81%AF%E3%80%81%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81bitback%20rootfs%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110579%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110579%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFSaurabh%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBSP%E3%81%AA%E3%81%97%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB.ko%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%92%E3%83%B3%E3%83%88%E3%81%AE%E3%81%8A%E3%81%8B%E3%81%92%E3%81%A7%E3%80%81%E7%A7%81%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81Yocto%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%AF%E3%81%A9%E3%81%86%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81bitbake%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%80%81%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E3%82%82%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%80%81USB%20Bluetooth%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCbtusb%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%95%8F%E9%A1%8C%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E4%BD%95%E3%81%8B%E8%80%83%E3%81%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3C%2FP%3E%3CP%3EAlvin%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81make%20modules%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Emake%20modules_install%20INSTALL_MOD_PATH%3D~%2Fmodule%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1110577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYocto%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%80%81BSP%E3%81%AA%E3%81%97%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81menuconfig%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎05-14-2014 11:47 AM
Updated by:
