Build Ubuntu For i.MX8 Series Platform
The Guide is how to use Ubuntu filesystem with i.MX8 series platform.At present, I had try it on i.MX8QXP with 4.14.98 kernel with ubuntu16.04.
The Document will be continuously updated with enable VPU, ubuntu18.04. The desktop we can chose Gnome or weston.  Because driver
support issue, gc7000 series gpu not support render Gnome destop but it can render weston destop.
Update 2019/7/31:
Ubuntu-i.MX8-weston.pdf
Feature:
  • weston + ubuntu18.04 + 4.14.98 kernel
  • VPU (enable with gplay or gst-play)
  • GPU (could render desktop and run GPU demo under root privileges on Weston Desktop)
I also try ubuntu with gnome desktop, ubuntu18.04 can not run gnome, need use ubuntu19.04. But Gnome Desktop just render by CPU.
Update 2020/3/6:
Ubuntu-i.MX8M.pdf
Just a simple guide for IMX8M series, will be  continuously updated.
标记 (1)
附件
评论
Hello Gnar,
Thank you for posting this detailed document. I was trying to follow it for nxp imx8m-mini evk. I have been able to build yocto for this board and that seems to work fine but now want to try ubuntu with weston on this evk. I have these questions for you in your Ubuntu-i.MX8-weston.pdf document.
In section 9 you write:
2)copy libdrm,wayland vpu-firmware from yocto
$sudo cp -Pra libdrm/2.4.91.imx-r0/image/* ubuntu18.04/
$sudo cp -Pra imx-gpu-viv/1_6.2.4.p4.0-aarch64-r0/image/* ubuntu18.04/
$sudo cp -Pra imx-dpu-g2d-1.7.0/imx-dpu-g2d/1.7.0-r0/image/* ubuntu18.04/
$sudo cp -r all-poky-linux/firmware-imx/1_8.1-r0/image/* ubuntu18.04/
Could you tell me from which folder (cd ~/????)  you are running these commands? Also this folder ubuntu 18.04 does not exist anywhere, where does it get used later? I do not see any other reference to "ubuntu 18.04" folder in this document.
Is imx-dpu-g2d a typo, should it be imx-gpu-g2d ?
Also you say:
2.Compile the kernel separately to replace yocto kernel
Do you mean bitbake linux-imx after I have built yocto? Currently in the yocto build I do see that a kernel Image that has been built.
Amrit
Hi, Amrit
1.which folder (cd ~/????)
The command run Host PC side. To  build a ubuntu rootfs, decompression rootfs first such as tar -xvf ubuntu-base-18.04.2-base-arm64.tar.gz -C ubuntu-rootfs, in my case  modify ubuntu-rootfs to ubuntu 18.04, May cause you misunderstand and I will uniform naming. This command purpose
is copy  libraries related GPU to ubuntu-rootfs.
Because the GPU dirver be builded as galcore.ko by yocto default. So compile the kernel separately to make Image include gpu dirver. In kernel source code(I download form linux-imx - i.MX Linux kernel , not use the yocto code), after command $ make menuconfig, you can see the .config
CONFIG_MXC_GPU_VIV=y.
Gnar
Hi Gnar,
i was curious whether you have tested a webcam with ubuntu and seen if it works?  i'm struggling to get a simple logitech webcam to work.  It looks like i'm getting a dmesg alert that "VPU_firmware_download Failed"... so i assume the VPU firmware is messed up.
maybe i copied in the wrong file at some point...
k
Hi, Kyle
     I am not test webcam but other one test it ok. I am not sure he do other config for it. If you webcam is usb camera, may should enable UVC driver in kernel. About VPU firmware, are you copy it under  /lib/firmware ? You also can copy unit_test file form yocto,  use v4l2 to open camera.
Gnar
Hi Gnar,
I think i've gotten a bit confused on what specifically to copy.  From your awesome manual (Ubuntu-imx8-weston.pdf)
there are several commands here:
2) copy libdrm, wayland, vpu-firmware from yocto
$sudo cp -Pra imx-dpu-g2d-1.7.0/imx-dpu-g2d/1.7.0-ro/image/* ubuntu 18.04/
What would help me is to understand the actual folder paths for each of them.
My assumption is that you are copying from the Yocto build... could you give me the full paths to /libdrm/2.4.91.imx-ro/image/,  /imx-gpu-viv/1_6.2.4.p4.0-aarch64-ro/image/, /imx-dpu-g2d-1.7.0/imx-dpu-g2d/1.7.0-ro/image/* and all-poky-linux/firmware-imx/1_8.1-r0/image/*
2nd, when you point out the destination folder of 'ubuntu18.04/'  do i assume that /ubuntu18.04/ is the base of the ubuntu rootfs?
thanks
kylef
Hello Gnar and Kyle,
I am glad to see that more than one person is working on this project. First of all thank you Gnar for creating the documents and outlining the essential steps.
Kyle,
I also went through and located all folder that need to be copied from yocto build folders to ~/rootfs/ubuntu-rootfs (or ~/rootfs/ubuntu18.04). Here are the  the source folder names in each case:
cd ~/imx-yocto-bsp/build/tmp/work/aarch64-mx8mm-poky-linux
sudo cp -Pra libdrm/2.4.91.imx-r0/image/* ~/rootfs/ubuntu-rootfs
sudo cp -Pra imx-gpu-viv/1_6.2.4.p4.0-aarch64-r0/image/* ~/rootfs/ubuntu-rootfs
sudo cp -Pra ~/imx-yocto-bsp/build/tmp/work/aarch64-mx8mm-poky-linux/imx-gpu-g2d/6.2.4.p4.0-r0/image/* ~/rootfs/ubuntu-rootfs
sudo cp -r all-poky-linux/firmware-imx/1_8.1-r0/image/* ~/rootfs/ubuntu-rootfs
In my case rootfs folder is ~/rootfs/ubuntu-rootfs.
Gnar,
I am able to run ubuntu18.04 in basic form with Gnome or xfce4 but still in the process of trying to put all the components in my rootfs. I noticed a weird error in step 3) for weston-imx.
Here is the error log,  when I run autogen for weston-imx:
root@UB160401:~/weston/weston-imx# ./autogen.sh --prefix=/usr --disable-silent-rules --disable-dependency-tracking --enable-setuid-install --disable-rdp-compositor --enable-clients --enable-simple- clients --enable-demo-clients-install --disable-colord --enable-egl --enable- simple-egl-clients --enable-fbdev-compositor --disable-headless-compositor -- enable-drm-compositor --enable-weston-launch --disable-lcms --disable-libunwind --with-pam --disable-vaapi-recorder --enable-wayland-compositor --without-webp --disable-x11-compositor --disable-xwayland
autoreconf: Entering directory `.'
autoreconf: configure.ac: not using Gettext
autoreconf: running: aclocal --force -I m4
autoreconf: configure.ac: tracing
autoreconf: running: libtoolize --copy --force
libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, 'build-aux'.
libtoolize: copying file 'build-aux/ltmain.sh'
libtoolize: putting macros in AC_CONFIG_MACRO_DIRS, 'm4'.
libtoolize: copying file 'm4/libtool.m4'
libtoolize: copying file 'm4/ltoptions.m4'
libtoolize: copying file 'm4/ltsugar.m4'
libtoolize: copying file 'm4/ltversion.m4'
libtoolize: copying file 'm4/lt~obsolete.m4'
autoreconf: running: /usr/bin/autoconf --force
autoreconf: running: /usr/bin/autoheader --force
autoreconf: running: automake --add-missing --copy --force-missing
configure.ac:35: installing 'build-aux/compile'
configure.ac:43: installing 'build-aux/missing'
Makefile.am: installing 'build-aux/depcomp'
autoreconf: Leaving directory `.'
configure: WARNING: you should use --build, --host, --target
configure: WARNING: unrecognized options: --enable-simple-, --enable-
checking for clients-gcc... no
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... no
checking whether sys/types.h defines makedev... no
checking sys/mkdev.h usability... no
checking sys/mkdev.h presence... no
checking for sys/mkdev.h... no
checking sys/sysmacros.h usability... yes
checking sys/sysmacros.h presence... yes
checking for sys/sysmacros.h... yes
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking whether make supports nested variables... yes
checking dependency style of gcc... none
checking whether make supports nested variables... (cached) yes
checking for clients-gcc... gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking whether gcc understands -c and -o together... (cached) yes
checking for a sed that does not truncate output... /bin/sed
checking build system type... Invalid configuration `clients': machine `clients' not recognized
configure: error: /bin/bash build-aux/config.sub clients failed
Any clue what I may be missing?
BTW: I am using imx8m mini evk  - yocto, but that should not make difference as far as these steps are concerned.
Thank you both.
Amrit
Hi Amrit
    1. I am install gnome base ubuntu18.04 meet error on 8QXP but sucessful with ubuntu19.04. At present, gnome not support GPU and use the CPU to render the desktop,
the performance is not very optimistic. so i am try debug GNOME to support GPU but it need some time.
    2. When you build weston-imx meet error.  If you had install gnome or xfce4(BTW: it base on X11, 8 series GPU is only support wayland, but if use CPU to render desktop,
xfce4 is better than gnome because gnome is more complex), please build weston-imx without it because some component of GNOME of xfce4 effect weston-imx build.
if not,try use the command:
#./autogen.sh --prefix=/usr --disable-silent-rules --disable-dependency-tracking  --enable-setuid-install --disable-rdp-compositor --enable-clients --enable-simple-clients --enable-demo-clients-install --disable-colord --enable-egl --enable-simple-egl-clients --enable-fbdev-compositor --disable-headless-compositor --enable-drm-compositor --enable-weston-launch --disable-lcms --disable-libunwind --with-pam --disable-vaapi-recorder --enable-wayland-compositor --without-webp --disable-x11-compositor --enable-xwayland --enable-imxg2d --enable-imxgpu --enable-drm-compositor --enable-opengl
   3. I had not meet the err, you can reference :cross compiling - What's the difference of "./configure" option "--build", "--host" and "--target"? ...  .
Gnar
Hello Gnar,
Thank you for your reply. I think I am now very close to building ubuntu after following your document.
I now have these remaining items.
1. I do not see anything called  imx-dpu-2d in my yocto build folder. So I am not able to run this step in your document:
My DISTRO is fsl-imx-xwayland and MACHINE is imx8mmevk
2.. I tried the new autogen step as you mentioned in your last post for weston-imx but it still does not build. I now get different errors during autogen step. Here is my log:
root@UB160401:~/weston/weston-imx# ./autogen.sh --prefix=/usr --disable-silent-rules --disable-dependency-tracking --enable-setuid-install --disable-rdp-compositor --enable-clients --enable-simple-clients --enable-demo-clients-install --disable-colord --enable-egl --enable-simple-egl-clients --enable-fbdev-compositor --disable-headless-compositor --enable-drm-compositor --enable-weston-launch --disable-lcms --disable-libunwind --with-pam --disable-vaapi-recorder --enable-wayland-compositor --without-webp --disable-x11-compositor --enable-xwayland --enable-imxg2d --enable-imxgpu --enable-drm-compositor --enable-opengl....
checking for OPENGL... yes
checking for GL_RENDERER... yes
checking for XKBCOMMON_COMPOSE... yes
checking for XWAYLAND... no
configure: error: Package requirements (xcb xcb-xfixes xcb-composite xcb-shape xcursor cairo-xcb) were not met:
No package 'xcb-xfixes' found
No package 'xcb-composite' found
No package 'xcb-shape' found
No package 'xcursor' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables XWAYLAND_CFLAGS
and XWAYLAND_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
Any suggestions?
Thank you so much.
Amrit
Hi,Anrit
1.  imx-dpu-2d path in yocto is /buildxwayland/tmp/work/aarch64-mx8mm-poky-linux/imx-gpu-g2d  ,8MM have not DPU.
2.  back to first command:
The error log is :
1)configure: WARNING: you should use --build, --host, --target
2)checking build system type... Invalid configuration `clients': machine `clients' not recognized
Are you build in qemu enviroment ? I had not meet the error in my step and not set any  enviroment variables. Try google how build weston, according to the log you need
add the arguments about  --build, --host, --target.
The second command, try disable xwayland at first.
The xwayland is not necessary.
Gnar
First of all, thank you very much for your proposal。But i have a question that I hope you can help me with this。In Ubuntu-imx8.pdf setp 2 Compile the kernel separately to replace yocto kernel,Specifically which is kernel to replace yocto kernel?
thanks!
Hi, gao
Because in default, GPU driver  galcore is compiled as .ko file, so need compile the kernel separately to make galcore in kernel.
Gnar
thanks for your answer.Can you tell me how to compile the kernel separetely? I use fellowing methods make it :
bitbake -c compile -f -v linux-imx
bitbake linux-imx -c compile_kernelmodules -f -v
bitbake -c deploy -f -v linux-imx
result:
Compare with before:
galcore used numbers different.and no have qca6174 driver.and a lot of drivers have been added。
how to resolve it?
A easy way is download linux-imx for linux-imx - i.MX Linux kernel , Then use command "$ make defconfig,  $ make" to build Image .
Use the Image replace your current Image.
Gnar
Hi nxf47724‌ : The GPU can't render gnome because of limitations in the OpenGL library or is there another reason?
Yes, may GPU dirver not fit.
I am also porting Ubuntu 18.04 to iMX8 Quad Max custom board with 4.14.98 BSP by referring https://community.nxp.com/servlet/JiveServlet/download/343939-3-454211/Ubuntu-i.MX8-weston.pdf  Document.
Till section 9. copy imx-gpu-viv in mentioned document able to understand properly. But after section 10.build weston, its not saying that where need to build weston, wayland, gstreamer and gst-plugins? How to link/add above features with "ubuntu-rootfs" ?
Prashanth Kumar K
Build weston in qemu enviroment.
Gnar
Hi Gnar,
During below make command execution I am getting following header file declaration error message for weston-imx.
From where we can get header files for weston?
#cd ~/weston
#git clone https://source.codeaurora.org/external/imx/weston-imx.git
#cd weston-imx
#git checkout fb563901657b296c7c7c86d26602a622429e334f
#./autogen.sh --prefix=/usr --disable-silent-rules --disable-dependency-tracking  --enable-setuid-install --disable-rdp-compositor --enable-clients --enable-simple-clients --enable-demo-clients-install --disable-colord --enable-egl --enable-simple-egl-clients --enable-fbdev-compositor --disable-headless-compositor --enable-drm-compositor --enable-weston-launch --disable-lcms --disable-libunwind --with-pam--disable-vaapi-recorder --enable-wayland-compositor --without-webp --disable-x11-compositor --enable-xwayland --enable-imxg2d --enable-imxgpu --enable-drm-compositor --enable-opengl
#make
libweston/compositor-drm.c: In function ‘drm_fb_addfb’:
libweston/compositor-drm.c:962:23: error: ‘DRM_FORMAT_MOD_AMPHION_TILED’ undeclared (first use in this function); did you mean ‘DRM_FORMAT_MOD_VIVANTE_TILED’?
if (fb->modifier == DRM_FORMAT_MOD_AMPHION_TILED) {
libweston/compositor-drm.c:962:23: note: each undeclared identifier is reported only once for each function it appears in
libweston/compositor-drm.c: In function ‘drm_clip_overlay_coordinate’:
libweston/compositor-drm.c:1518:36: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if (state->dest_x + state->dest_w > output->base.current_mode->width){
libweston/compositor-drm.c:1526:36: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if (state->dest_y + state->dest_h > output->base.current_mode->height){
libweston/compositor-drm.c: In function ‘drm_get_gbm_alignment’:
libweston/compositor-drm.c:2184:9: error: ‘DRM_FORMAT_MOD_VIVANTE_SUPER_TILED_FC’ undeclared (first use in this function); did you mean ‘DRM_FORMAT_MOD_VIVANTE_SUPER_TILED’?
case DRM_FORMAT_MOD_VIVANTE_SUPER_TILED_FC:
libweston/compositor-drm.c: In function ‘drm_output_apply_state_atomic’:
libweston/compositor-drm.c:2600:4: warning: implicit declaration of function ‘gbm_surface_set_sync_post’; did you mean ‘gbm_surface_destroy’? [-Wimplicit-function-declaration]
gbm_surface_set_sync_post(output->gbm_surface, 0);
gbm_surface_destroy
libweston/compositor-drm.c:2601:18: warning: implicit declaration of function ‘gbm_surface_get_in_fence_fd’; did you mean ‘wl_surface_send_enter’? [-Wimplicit-function-declaration]
in_fence_fd = gbm_surface_get_in_fence_fd(output->gbm_surface);
libweston/compositor-drm.c: In function ‘drm_query_dmabuf_modifiers’:
libweston/compositor-drm.c:3291:49: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if (p->formats[i].format != format)
libweston/compositor-drm.c: In function ‘drm_import_dmabuf’:
libweston/compositor-drm.c:3342:37: error: ‘DRM_FORMAT_P010’ undeclared (first use in this function); did you mean ‘DRM_FORMAT_R16’?
&& dmabuf->attributes.format == DRM_FORMAT_P010)
DRM_FORMAT_R16
libweston/compositor-drm.c: In function ‘drm_output_propose_state’:
libweston/compositor-drm.c:3752:38: error: ‘DRM_FORMAT_P010’ undeclared (first use in this function); did you mean ‘DRM_FORMAT_R16’?
DRM_FORMAT_R16
libweston/compositor-drm.c: In function ‘hdr10_metadata_set_metadata’:
libweston/compositor-drm.c:7250:29: error: storage size of ‘hdr_metadata’ isn’t known
struct hdr_static_metadata hdr_metadata;
Prashanth Kumar K
Hi Gnar,
Thank you for sharing this procedure. I would like to ask you: what is the purpose of the commands "sudo mount -t proc /proc ${2}proc" and the others?
It bring us some problems on the host machines.
I also faced a problem about weston. I followed your procedure, but when i try to execute weston i get this:
sudo -E weston --tty=1
[sudo] password for user:
Date: 2019-10-18 UTC
[08:42:03.809] weston 5.0.0
               https://wayland.freedesktop.org
               Bug reports to: https://gitlab.freedesktop.org/wayland/weston/issues/
               Build: 5.0.0-33-gfb563901 MGS-4627 [#ccc] weston will turn off when panel-psotion=none and use gplay (2019-03-14 11:30:30 +0800)
[08:42:03.816] Command line: weston --tty=1
[08:42:03.816] OS: Linux, 4.14.98-imx_4.14.98_2.0.0_ga+g64ad07d, #1 SMP PREEMPT Tue Aug 13 13:06:25 UTC 2019, aarch64
[08:42:03.816] warning: XDG_RUNTIME_DIR "/run/user/1000" is not configured
correctly.  Unix access mode must be 0700 (current mode is 700),
and must be owned by the user (current owner is UID 1000).
Refer to your distribution on how to get it, or
http://www.freedesktop.org/wiki/Specifications/basedir-spec
on how to implement it.
[08:42:03.826] Starting with no config file.
[08:42:03.839] Output repaint window is 16 ms maximum.
[08:42:03.845] Loading module '/usr/lib/libweston-5/drm-backend.so'
[08:42:03.952] initializing drm backend
[08:42:03.955] using /dev/dri/card0
[08:42:03.955] DRM: supports universal planes
[08:42:03.955] DRM: supports atomic modesetting
[08:42:03.955] DRM: does not support picture aspect ratio
[08:42:03.960] Loading module '/usr/lib/libweston-5/gl-renderer.so'
[08:42:04.302] EGL client extensions: EGL_EXT_device_base
               EGL_EXT_device_enumeration EGL_EXT_device_query
               EGL_EXT_platform_base EGL_KHR_client_get_all_proc_addresses
               EGL_EXT_client_extensions EGL_KHR_debug
               EGL_EXT_platform_wayland EGL_EXT_platform_x11
               EGL_MESA_platform_gbm EGL_MESA_platform_surfaceless
[08:42:04.304] failed to initialize display
[08:42:04.304] EGL error state: EGL_NOT_INITIALIZED (0x3001)
[08:42:04.304] failed to initialize egl
[08:42:04.341] fatal: failed to create compositor backend
Have you ever seen a similar error message?
Thank you.
Lorenzo
Hi Gnar,
I am facing some problem about Weston. While loading below commands,
export XDG_RUNTIME_DIR=/run/user/1000
I am getting following errors.
ubuntu@ubuntu:~$ export XDG_RUNTIME_DIR=/run/user/1000
ubuntu@ubuntu:~$ sudo -E weston --tty=1
[sudo] password for iwave:
Date: 2019-10-20 UTC
[12:05:59.961] weston 5.0.0
[12:05:59.961] Command line: weston --tty=1
[12:05:59.961] OS: Linux, 4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbea, #1 SMP PREEMPT Mon Oct 14 08:11:41 UTC 2019, aarch64
[12:05:59.961] warning: XDG_RUNTIME_DIR "/run/user/1000" is not configured
[12:05:59.961] Starting with no config file.
[12:05:59.962] Output repaint window is 16 ms maximum.
[12:05:59.962] Loading module '/usr/lib/libweston-5/drm-backend.so'
[12:05:59.964] Failed to load module: /usr/lib/libweston-5/drm-backend.so: undefined symbol: gbm_surface_get_in_fence_fd
[12:05:59.964] fatal: failed to create compositor backend
ubuntu@ubuntu:~$
ubuntu@ubuntu:~$
How to copy "weston" libraries from yocto build to ubuntu-rootfs?
Thank you.
Prashanth Kumar K
This is a script to start up arm64-linux simulate environment.
You build weston in the enviroment?
I had not meet the issue. Check if there are /usr/lib/aarch64-xx  libGLES, libEGL。if so, delete them.
BR,
Gnar
According my setp, start simulate ARM64 enviroment on host and build weston.
Then copy whole filesystem, not only copy weston lib.
Gnar
Hi Gnar,
I used section "10.build weston" steps to build Weston in ubuntu-rootfs in qemu enviroment.
Also copying full ubuntu-rootfs to board using below steps mentioned in provided user guide.
12. replace filesystem
$ mkdir mountpoint
$ umount /dev/sdb2
$ mkfs.ext4 /dev/sdb2
$ mount /dev/sdb2 /home/gnar/mountpoint
$ cp -a /home/gnar/rootfs/ubuntu-rootfs /* /home/gnar/mountpoint/
umount /home/gnar/mountpoint
sync
But  still facing same issue.
ubuntu@ubuntu:~$
Can you please suggest how to resolve  "drm-backend.so"  loading issue?
Also kindly provide path to copy "weston" related libraries from yocto build to ubuntu-rootfs.
Prashanth Kumar K
Thank you Gnar, deleting those libraries worked for me.
Several programs downloaded from "apt-get" (like firefox, chromium and others) try to use X11. We see that you disable xwayland during the weston compilation.
What are the reasons for this? Do you think that having xwayland may solve the issue? Do you have any idea of how to get xwayland?
Thank you a lot for your help.
Lorenzo
Hi Gnar,
Can you please provide your built ubuntu-rootfs.tar.gz file system for testing in iMX8QM custom board.
Thanks in advance.
BestRegards,
Prashanth Kumar K
I am  deleted the rootfs form my PC, if you want,create ticket to me.
Gnar
Hi Gnar,
Is there any update regarding above issue for Ubuntu 18.04 using Weston file system nxf47724‌ ?
Thanks in advance.
Prashanth Kumar K
Hi Gnar Fang:
   I'm trying to port the ubuntu 18.04  to my i.mx8mq-evk,I read your document and followed,But I get two errors:
    1. Step 9,part 2: I can't find the targets  "libdrm/2.4.91.imx-r0/image/*"  and  "imx-dpu-g2d-1.7.0/imx-dpu-g2d/1.7.0-r0/image/*" ,I'm sure that these two             target don't exist in my yocto project. I assume that the i.mx8mq-evk does not have dpu,but for libdrm,I'm not sure,So please give me a signal.
               btw, I compile with instructions:
                        DISTRO=fsl-imx-wayland MACHINE=imx8mqevk source fsl-setup-release.sh -b build
                         bitbake fsl-image-qt5-validation-imx
   2.Regardless the error 1 above,I'm trying to continue with the document,but when I compile  weston-imx,some errors occured:
         steps below:
               cd weston-imx
               ./autogen.sh --prefix=/usr --disable-silent-rules --disable-dependency-tracking .........
               make
  This is error message:
  make[1]: Entering directory '/root/weston/weston-imx'
 /bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I./libweston -I./libweston -I./clients -I./tests -I./shared -I./protocol -DLIBWESTON_MODULEDIR='"/usr/lib/libweston-5"' -DLIBEXECDIR='"/usr/libexec"' -DBINDIR='"/usr/bin"' -DIN_WESTON -Wall -Wextra -Wno-unused-parameter -Wno-shift-negative-value -Wno-missing-field-initializers -g -fvisibility=hidden -Wstrict-prototypes -Wmissing-prototypes -Wsign-compare -DLINUX -DEGL_API_FB -DWL_EGL_PLATFORM -I/usr/include/pixman-1 -DLINUX -DEGL_API_FB -DWL_EGL_PLATFORM -I/usr/include/libdrm -g -O2 -c -o libweston/libweston_5_la-pixel-formats.lo `test -f 'libweston/pixel-formats.c' || echo './'`libweston/pixel-formats.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I./libweston -I./libweston -I./clients -I./tests -I./shared -I./protocol -DLIBWESTON_MODULEDIR=\"/usr/lib/libweston-5\" -DLIBEXECDIR=\"/usr/libexec\" -DBINDIR=\"/usr/bin\" -DIN_WESTON -Wall -Wextra -Wno-unused-parameter -Wno-shift-negative-value -Wno-missing-field-initializers -g -fvisibility=hidden -Wstrict-prototypes -Wmissing-prototypes -Wsign-compare -DLINUX -DEGL_API_FB -DWL_EGL_PLATFORM -I/usr/include/pixman-1 -DLINUX -DEGL_API_FB -DWL_EGL_PLATFORM -I/usr/include/libdrm -g -O2 -c libweston/pixel-formats.c -fPIC -DPIC -o libweston/.libs/libweston_5_la-pixel-formats.o
libweston/pixel-formats.c:268:13: error: 'DRM_FORMAT_P010' undeclared here (not in a function); did you mean 'DRM_FORMAT_NV12'?
.format = DRM_FORMAT_P010,  ^~~~~~~~~~~~~~~
DRM_FORMAT_NV12
Makefile:5527: recipe for target 'libweston/libweston_5_la-pixel-formats.lo' failed
Could you please send me some signals to solve these two issues?
Regard
downey
I also found 8mq yocto have not libdrm. I will check it next week.
I think the drm is a necessary component for Linux display.
Gnar
Hi Gnar Fang:
   Thanks for your reply,Looking forward to your updates.
   BTW,Please check the second question above(compile weston-imx errors )
downey
1. libdrm is under buildxwayland/tmp/work/aarch64-poky-linux.
2. The issue may be caused by your rootfs lost libdrm, copy libdrm to your rootfs.
If you have any other question could tell me. These day have too many other case, may reply late.
Gnar
Hi Gnar,
We are able to get GUI with Weston, but this GUI look is not like desktop Ubuntu GUI.
Whether you are getting same GUI?
The terminal showing following output,
# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.2 LTS
Release:        18.04
Codename:    bionic
Prashanth Kumar K
Hi,prashanth
You install weston, so it show weston GUI. I think you want to get Gnome GUI, but I enable it just with CPU sotfware render (just apt-get                install gnome-core).   Gnome GUI with GPU render meet some mistakes.
Gnar
Hi Gnar,
   Thanks for your reply. Is there any updated Documents for building Ubuntu 18.04 on i.MX8 platform.
Prashanth Kumar K
Hi,Prashanth
I have not received new requirement, so there is not any update.
Gnar
Hi Gnar Fang:
      I've found the libdrm/ under aarch64-poky-linux/, and copied it to corresponding directory which you guide in the document.
But , I got another error when I compiled weston-imx :
         In file included from libweston/g2d-renderer.c:44:0:
         libweston/g2d-renderer.h:30:10: fatal error: g2dExt.h: No such file or directory
         #include <g2dExt.h>
         compilation terminated.
         Makefile:5107: recipe for target 'libweston/g2d_renderer_la-g2d-renderer.lo' failed
There seems to be some system libraries(libweston) that are missing, or some packages that I haven't installed but that library depends on that package.
I tried again to build from scratch to avoid an operational error problem, but the problem was the same on both occasions.
Regards.
Downey.
HI  Gnar Fang:
Following your doc, I can success to run the ubuntu18.04 on imx8mq, but I face a problem: the system could not load firmware:
imx-sdma 30bd0000.sdma: external firmware not found, using ROM firmware
I have comfirm the firwmware is in /lib/firmware/ .
Do you have the same problem ? or where should I check ?
Thanks.
Hi jiang yaqiang:
   could you please tell me where do you find the imx-dpu-g2d-1.7.0 directory,I can't find this lib ,So I get an error when I compile weston-imx.
   I put this issue above , But no one replied about this.
Thanks a lot.
downey
Hi Gnar,
   could you please check this issue about the header file <g2dExt.h>,It seems about dpu,But I can't find the dpu lib under my yocto project.
Thanks a lot.
Best Regards.
downey.
Hi downey:
I don't know which platform you are using.
I use imx8md/q , it doesn't support "g2d", so just add "--disable-imxg2d" when config weston-imx with fix the issue.
江亚强
软件工程师
Shenzhen Huameishi Technology Co., Ltd
Mail:[email protected]
Hi Gnar Fang,
      While running the Weston tty im getting error either "No such device or directory" or "Fatal : DRM should run in background". Could you please share some guidance in this. Thanks
Raajesh K
Which platform are you used?
Hi Gnar Fang,
       Currently I am using IM8MM DDR4 EVK.Thanks
Hi Prashanth,
               I am getting a similar error could you please share how you got the "drm need to run on background" error. Thanks
Hi, I will write the guide for 8MM about this week.
Hi Gnar Fang,
            Thanks looking forward to it, kindly let me know once done. I will also update if i make any progress.
Hi, I had update the DOC for enable weston.  See if there is  gpu driver .
root@ubuntu:~# ls /dev/galcore
/dev/galcor
你好,
请问您的问题解决了吗?
我也遇到了相同的问题,我解决的方法是在内核配置的时候只让它编译出模块并不加载。系统起来之后再手动加载。但是这样会有一些依赖问题的错误log打印。虽然能解决,但是我觉得方法不是很好。
您有更好的办法吗?
HI gaobo:
已经解决。关键是下面两个文件,你可以参考一下。
/lib/udev/rules.d/50-firmware.rules
/usr/bin/firmware.sh
cat /lib/udev/rules.d/50-firmware.rules
  1. stub for immediately telling the kernel that userspace firmware loading
  2. failed; necessary to avoid long timeouts with CONFIG_FW_LOADER_USER_HELPER=y
#SUBSYSTEM=="firmware", ACTION=="add", ATTR="-1"
SUBSYSTEM=="firmware", ACTION=="add", RUN+="/bin/sh /usr/bin/firmware.sh"
imx8m@localhost:~$ cat /usr/bin/firmware.sh
#echo 1 > /sys/$DEVPATH/loading
#cat $HOTPLUG_FW_DIR > > /sysfs/$DEVPATH/data
#echo 0 > /sys/$DEVPATH/loading
echo -n 1 > /sys/$DEVPATH/loading
sleep 1
cat /lib/firmware/$FIRMWARE > /sys/$DEVPATH/data
if ; then
  1. echo -n 1 > /sys/$DEVPATH/loading
echo -n 0 > /sys/$DEVPATH/loading
fi
江亚强
软件工程师
深圳市华美视科技有限公司
深圳市南山区科苑路6号科技园工业大厦605
Tel:0755-26037882-616
Hi jiangyaqiang:
非常感谢您的回复。我按照您的步骤进行操作了,
iqi@imx8mqevk:~$ cat /lib/udev/rules.d/50-firmware.rules
# stub for immediately telling the kernel that userspace firmware loading
# failed; necessary to avoid long timeouts with CONFIG_FW_LOADER_USER_HELPER=y
#SUBSYSTEM=="firmware", ACTION=="add", ATTR{loading}="-1"
iqi@imx8mqevk:~$ cat /usr/bin/firmware.sh
#!/bin/sh
sleep 1
if ; then
fi
还是会出现那个问题
iqi@imx8mqevk:~$ dmesg | grep sdma
[ 0.370062] imx-sdma 30bd0000.sdma: no iram assigned, using external mem
[ 0.372372] imx-sdma 30bd0000.sdma: Falling back to user helper
[ 0.375795] imx-sdma 302c0000.sdma: no iram assigned, using external mem
[ 60.385189] imx-sdma 302c0000.sdma: external firmware not found, using ROM firmware
[ 60.385479] imx-sdma 30bd0000.sdma: external firmware not found, using ROM firmware
请问您是怎么调试的呢?(我不确定是否是我的firmware.sh文件是否配置的有问题,脚本文件中的环境变量是否还需要单独配置)
请帮忙指点一下,感谢!!!
%3CLINGO-SUB%20id%3D%22lingo-sub-1128708%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128708%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%AC%E6%8C%87%E5%8D%97%E4%BB%8B%E7%BB%8D%E4%BA%86%E5%A6%82%E4%BD%95%E5%9C%A8i.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E4%B8%8A%E4%BD%BF%E7%94%A8Ubuntu%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%E7%9B%AE%E5%89%8D%EF%BC%8C%E6%88%91%E5%B7%B2%E5%9C%A8i.MX8QXP%E5%B9%B3%E5%8F%B0%E4%B8%8A%E4%BD%BF%E7%94%A84.14.98%E5%86%85%E6%A0%B8%E6%88%90%E5%8A%9F%E6%B5%8B%E8%AF%95%E4%BA%86Ubuntu%2016.04%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%AC%E6%96%87%E6%A1%A3%E5%B0%86%E6%8C%81%E7%BB%AD%E6%9B%B4%E6%96%B0%EF%BC%8C%E4%BB%A5%E6%94%AF%E6%8C%81%20VPU%20%E5%92%8C%20Ubuntu%2018.04%20%E7%B3%BB%E7%BB%9F%E3%80%82%E6%A1%8C%E9%9D%A2%E7%8E%AF%E5%A2%83%E5%8F%AF%E9%80%89%E6%8B%A9%20Gnome%20%E6%88%96%20Weston%E3%80%82%E7%94%B1%E4%BA%8E%E9%A9%B1%E5%8A%A8%3C%2FP%3E%3CP%3E%E6%94%AF%E6%8C%81%E9%97%AE%E9%A2%98%EF%BC%8CGC7000%E7%B3%BB%E5%88%97GPU%E4%B8%8D%E6%94%AF%E6%8C%81%E6%B8%B2%E6%9F%93GNOME%E6%A1%8C%E9%9D%A2%EF%BC%8C%E4%BD%86%E5%8F%AF%E4%BB%A5%E6%B8%B2%E6%9F%93Weston%E6%A1%8C%E9%9D%A2%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUpdate%202019%2F7%2F31%3A%3C%2FP%3E%3CP%3EUbuntu-i.MX8-weston.pdf%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%8A%9F%E8%83%BD%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3Eweston%20%2B%20ubuntu18.04%20%2B%204.14.98%20kernel%3C%2FLI%3E%3CLI%3EVPU%EF%BC%88%E9%80%9A%E8%BF%87gplay%E6%88%96gst-play%E5%90%AF%E7%94%A8%EF%BC%89%26nbsp%3B%3C%2FLI%3E%3CLI%3EGPU%EF%BC%88%E5%8F%AF%E4%BB%A5%E5%9C%A8Weston%E6%A1%8C%E9%9D%A2%E7%8E%AF%E5%A2%83%E4%B8%8B%E4%BB%A5root%E6%9D%83%E9%99%90%E6%B8%B2%E6%9F%93%E6%A1%8C%E9%9D%A2%E5%B9%B6%E8%BF%90%E8%A1%8CGPU%E6%BC%94%E7%A4%BA%EF%BC%89%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E6%88%91%E4%B9%9F%E5%B0%9D%E8%AF%95%E4%BA%86%E6%90%AD%E8%BD%BD%20Gnome%20%E6%A1%8C%E9%9D%A2%E7%9A%84%20Ubuntu%20%E7%B3%BB%E7%BB%9F%EF%BC%8CUbuntu%2018.04%20%E6%97%A0%E6%B3%95%E8%BF%90%E8%A1%8C%20Gnome%EF%BC%8C%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%20Ubuntu%2019.04%E3%80%82%E4%BD%86%20Gnome%20%E6%A1%8C%E9%9D%A2%E5%8F%AA%E8%83%BD%E9%80%9A%E8%BF%87%20CPU%20%E8%BF%9B%E8%A1%8C%E6%B8%B2%E6%9F%93%E3%80%82%3C%2FP%3E%3CP%3E-------------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E%3CSPAN%3EUpdate%202020%2F3%2F6%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EUbuntu-i.MX8M.pdf%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%BF%99%E5%8F%AA%E6%98%AF%E4%B8%80%E4%BB%BD%E9%92%88%E5%AF%B9%20i.MX8M%20%E7%B3%BB%E5%88%97%E7%9A%84%E7%AE%80%E6%98%93%E6%8C%87%E5%8D%97%EF%BC%8C%E5%90%8E%E7%BB%AD%E5%B0%86%E6%8C%81%E7%BB%AD%E6%9B%B4%E6%96%B0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1128708%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20%E7%B3%BB%E5%88%97%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1755142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1755142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%9B%B8%E4%BF%A1%20Google%20Coral%20Dev%20Board%204GB%20%E5%92%8C%20ASUS%20Tinker%20Edge%20T%20%E9%83%BD%E4%BD%BF%E7%94%A8%20NXP%20i.MX%208M%20%E5%A4%84%E7%90%86%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E4%BD%8D%E4%BA%8E%E6%AD%A4%E9%93%BE%E6%9D%A1%E9%A1%B6%E9%83%A8%E7%9A%84%20Ubuntu%20i.MX%208M%20PDF%20%E6%98%AF%E5%90%A6%E9%80%82%E7%94%A8%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E6%8C%87%E4%BB%A4%E6%9C%89%E6%9B%B4%E6%96%B0%E8%BF%87%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E6%9B%B4%E6%96%B0%E8%BF%87%E5%90%97%EF%BC%9F%E6%88%96%E8%80%85%E6%9C%89%E4%BA%BA%E6%84%BF%E6%84%8F%E6%8F%90%E4%BE%9B%E5%B8%AE%E5%8A%A9%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E5%8F%AF%E8%83%BD%E7%9A%84%E8%AF%9D%EF%BC%8C%E6%88%91%E4%BC%9A%E8%80%83%E8%99%91%E4%BD%BF%E7%94%A8Ubuntu%E7%9A%84%E6%9C%80%E6%96%B0LTS%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1723118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1723118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E6%8C%89%E7%85%A7%E9%92%88%E5%AF%B9%20i.MX8MQ%20%E7%9A%84%20Ubuntu%2020.04%20%E6%8C%87%E5%8D%97%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E6%9E%84%E5%BB%BA%20weson-imx%20%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%8C%E9%94%99%E8%AF%AF%E5%A6%82%E4%B8%8B%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3Elibweston%2Fcompositor-drm.c%3A%20In%20function%20%E2%80%98hdr10_metadata_set_metadata%E2%80%99%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Elibweston%2Fcompositor-drm.c%3A7250%3A29%3A%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3Eerror%3A%20storage%20size%20of%20%E2%80%98hdr_metadata%E2%80%99%20isn%E2%80%99t%20known%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSPAN%3Estruct%20hdr_static_metadata%20hdr_metadata%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F74139%22%20target%3D%22_blank%22%3E%40prashanthkumar%20%3C%2FA%3E%E5%B7%B2%E7%BB%8F%E5%9C%A8%E8%BF%99%E4%B8%AA%E5%B8%96%E5%AD%90%E4%B8%AD%E6%8F%90%E5%87%BA%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E5%8F%91%E5%B8%83%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%E9%82%A3%E4%B9%88%E6%88%91%E8%AF%A5%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%91%A2%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1719521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1719521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%20PrashanthKumar%3C%2FP%3E%3CP%3E%E6%82%A8%E5%9C%A8%E8%BF%90%E8%A1%8C%26nbsp%3Bsudo%20-E%20weston%20--tty%3D1%20%E6%97%B6%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E8%83%BD%E5%90%A6%E6%8F%90%E4%BE%9B%E8%A7%A3%E5%86%B3%E4%BB%A5%E4%B8%8B%E9%97%AE%E9%A2%98%E7%9A%84%E6%AD%A5%E9%AA%A4%3C%2FP%3E%3CP%3E%5B13%3A03%3A01.810%5D%20warning%3A%20XDG_RUNTIME_DIR%20%22%2Frun%2Fuser%2F1000%22%20is%20not%20configured%3CBR%20%2F%3Ecorrectly.%20Unix%20access%20mode%20must%20be%200700%20(current%20mode%20is%20755)%2C%3CBR%20%2F%3Eand%20must%20be%20owned%20by%20the%20user%20(current%20owner%20is%20UID%201000).%3CBR%20%2F%3ERefer%20to%20your%20distribution%20on%20how%20to%20get%20it%2C%20or%3CBR%20%2F%3E%3CA%20href%3D%22http%3A%2F%2Fwww.freedesktop.org%2Fwiki%2FSpecifications%2Fbasedir-spec%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.freedesktop.org%2Fwiki%2FSpecifications%2Fbasedir-spec%3C%2FA%3E%3CBR%20%2F%3Eon%20how%20to%20implement%20it.%3CBR%20%2F%3E%5B13%3A03%3A01.817%5D%20Starting%20with%20no%20config%20file.%3CBR%20%2F%3E%5B13%3A03%3A01.821%5D%20Output%20repaint%20window%20is%2016%20ms%20maximum.%3CBR%20%2F%3E%5B13%3A03%3A01.822%5D%20Loading%20module%20'%2Fusr%2Flib%2Flibweston-5%2Fdrm-backend.so'%3CBR%20%2F%3E%5B13%3A03%3A01.830%5D%20Failed%20to%20load%20module%3A%20%2Fusr%2Flib%2Flibweston-5%2Fdrm-backend.so%3A%20undefined%20symbol%3A%20gbm_surface_get_in_fence_fd%3CBR%20%2F%3E%5B13%3A03%3A01.830%5D%20fatal%3A%20failed%20to%20create%20compositor%20backend%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EAbhijeet%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%AF%B7%E5%8F%82%E8%80%83%26nbsp%3Byocto%26nbsp%3B%E7%9A%84weston.ini%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EGnar%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%88%91%E6%83%B3%E8%A6%81%26nbsp%3B%3CSPAN%3E%E5%9C%A8%E8%AE%BE%E5%A4%87%E5%90%AF%E5%8A%A8%E6%97%B6%E8%87%AA%E5%8A%A8%E5%8A%A0%E8%BD%BDweston%EF%BC%8C%E8%AF%B7%E9%97%AE%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%93%AA%E9%87%8C%E6%B7%BB%E5%8A%A0%26nbsp%3B%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3Eweston%20--tty%3D1%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83yocto%E8%84%9A%E6%9C%AC%E6%9D%A5%E6%9E%84%E5%BB%BAxwayland%E3%80%82%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%E4%BD%86%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BD%BF%E7%94%A8LXQT%EF%BC%8C%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8GPU%EF%BC%8C%E8%BF%99%E6%98%AF%E6%9C%80%E5%A5%BD%E7%9A%84%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%E6%88%91%E4%BB%AC%E7%9A%84GPU%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%9E%84%E5%BB%BALXQT%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8apt-get%20LXQT%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128770%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128770%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A6%82%E4%BD%95%E5%9C%A8%20LXQt%20%E4%B8%AD%E5%90%AF%E7%94%A8%20XWayland%EF%BC%9F%E6%88%91%E5%8F%AA%E8%83%BD%E5%AE%89%E8%A3%85%20gnome-wayland%E3%80%82%E5%9C%A8%20LXQt%20%E6%A1%8C%E9%9D%A2%E4%B8%AD%E6%B2%A1%E6%9C%89%E4%B8%8E%20XWayland%20%E7%9B%B8%E5%85%B3%E7%9A%84%E9%85%8D%E7%BD%AE%E9%80%89%E9%A1%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E7%9A%84%20GPU%20%E4%BB%85%E6%94%AF%E6%8C%81%20Wayland%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E5%BA%94%E8%AF%A5%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E6%BA%90%E4%BB%A3%E7%A0%81%E6%9E%84%E5%BB%BA%E6%A1%8C%E9%9D%A2%E5%B9%B6%E5%90%AF%E7%94%A8%20xwayland%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9C%A8%20Ubuntu-i.MX8M.pdf%20%E4%B8%AD%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E5%9C%A8%E6%AD%A5%E9%AA%A4%207%20%E4%B8%AD%E7%BC%96%E8%AF%91%20weston%EF%BC%8C%E8%80%8C%E6%98%AF%E7%94%A8%20apt-get%20%E5%AE%89%E8%A3%85%E4%BA%86%20lxqt%EF%BC%8C%E5%B0%86%20lxqt%20%E7%94%A8%E4%BD%9C%E6%98%BE%E7%A4%BA%E6%A1%8C%E9%9D%A2%E3%80%82%E6%88%91%E5%BE%97%E5%88%B0%E4%BA%86%E5%A6%82%E4%B8%8B%E7%BB%93%E6%9E%9C%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20675px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F108840i7E4281D1019C7D98%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%88%90%E5%8A%9F%E5%8A%A0%E8%BD%BD%E4%BA%86%20GPU%20%E9%A9%B1%E5%8A%A8%EF%BC%8C%E4%BD%86%E4%B8%BA%E4%BB%80%E4%B9%88%E6%B2%A1%E6%9C%89%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%BD%BF%E7%94%A8%20GPU%20%E5%91%A2%EF%BC%9F%E5%BD%93%E6%88%91%E4%B8%8D%E4%BD%BF%E7%94%A8%20Ubuntu%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E6%97%B6%EF%BC%8C%E5%BE%97%E5%88%B0%E4%BA%86%E5%A6%82%E4%B8%8B%E7%BB%93%E6%9E%9C%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22galcore-last.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22galcore-last.png%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F108841i874260C38CB2AD52%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22galcore-last.png%22%20alt%3D%22galcore-last.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%9C%89%2026%20%E4%B8%AA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%BD%BF%E7%94%A8%20GPU%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E6%88%91%E5%9B%9E%E7%AD%94%E4%B8%80%E4%B8%8B%EF%BC%8C%E8%B0%A2%E8%B0%A2%EF%BC%8C%E7%A5%9D%E6%82%A8%E4%B8%80%E5%A4%A9%E6%84%89%E5%BF%AB%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%AC%E6%8C%87%E5%8D%97%E6%94%AF%E6%8C%81%E5%9C%A8%E8%BF%90%E8%A1%8CUbuntu%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E6%97%B6%E4%BD%BF%E7%94%A8GPU%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2CGnar%20Fang%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E5%8F%AA%E8%A6%81%E4%BD%BF%E7%94%A8Ubuntu%E6%96%87%E6%A1%A3%E7%B3%BB%E7%BB%9F%EF%BC%8C%E5%B0%B1%E6%97%A0%E6%B3%95%E5%90%AF%E7%94%A8GPU%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E8%BF%99%E6%98%AF%20Yocto-Wayland%20%E6%A1%8C%E9%9D%A2%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E8%A6%81%E5%85%B6%E4%BB%96%E6%A1%8C%E9%9D%A2%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20apt-get%20%E6%9D%A5%E5%AE%89%E8%A3%85%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B1%9F%E4%BA%9A%E5%BC%BA%3C%2FP%3E%3CP%3E%E8%BD%AF%E4%BB%B6%E5%B7%A5%E7%A8%8B%E5%B8%88%3C%2FP%3E%3CP%3EShenzhen%20Huameishi%20Technology%20Co.%2C%20Ltd%3C%2FP%3E%3CP%3E%E6%B7%B1%E5%9C%B3%E5%B8%82%E5%8D%8E%E7%BE%8E%E8%A7%86%E7%A7%91%E6%8A%80%E6%9C%89%E9%99%90%E5%85%AC%E5%8F%B8%3C%2FP%3E%3CP%3E%E6%B7%B1%E5%9C%B3%E5%B8%82%E5%8D%97%E5%B1%B1%E5%8C%BA%E7%A7%91%E8%8B%91%E8%B7%AF6%E5%8F%B7%E7%A7%91%E6%8A%80%E5%9B%AD%E5%B7%A5%E4%B8%9A%E5%A4%A7%E5%8E%A6605%3C%2FP%3E%3CP%3ETel%EF%BC%9A0755-26037882-616%3C%2FP%3E%3CP%3EMail%3Ayaqiang.jiang%40huameishi.com%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20font-weight%3A%20200%3B%22%3Eprashanth%EF%BC%9A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E6%82%A8%E6%98%AF%E5%A6%82%E4%BD%95%E9%85%8D%E7%BD%AE%E5%87%BA%E8%BF%99%E4%B8%AA%E6%A1%8C%E9%9D%A2%E7%9A%84%EF%BC%9F%E5%9C%A8%E6%88%91%E8%BF%90%E8%A1%8C%E2%80%9Csudo%20-E%20weston%20--tty%3D1%E2%80%9D%E5%90%8E%EF%BC%8C%E6%98%BE%E7%A4%BA%E7%9A%84%E6%A1%8C%E9%9D%A2%E4%B8%8Eyocto-wayland%E6%A1%8C%E9%9D%A2%E7%9B%B8%E5%90%8C%E3%80%82%E6%82%A8%E7%9A%84%E7%B3%BB%E7%BB%9F%E6%98%AF%E5%90%A6%E9%80%9A%E8%BF%87apt-get%E5%AE%89%E8%A3%85%E4%BA%86%E4%B8%80%E4%BA%9B%E8%BD%AF%E4%BB%B6%EF%BC%9F%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20font-weight%3A%20200%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20font-weight%3A%20200%3B%22%3ETks~%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E5%B9%BA%E4%BC%9A%E8%BF%99%E6%A0%B7%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%A3%80%E6%9F%A5%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%2Fusr%2Flib%2Faarch64-xx%26nbsp%3B%20libGLES%E3%80%81libEGL%E3%80%82%E5%A6%82%E6%9E%9C%E5%AD%98%E5%9C%A8%EF%BC%8C%E8%AF%B7%E5%88%A0%E9%99%A4%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128762%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128762%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%20Fang%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%E5%BE%88%E6%8A%B1%E6%AD%89%E5%9B%9E%E5%A4%8D%E6%99%9A%E4%BA%86%E3%80%82%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E7%A1%AE%E5%AE%9E%E6%8C%89%E7%85%A7%E6%96%87%E6%A1%A3%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%E4%BD%BF%E7%94%A8%E4%BA%86%E5%8F%82%E6%95%B0%E6%9D%A5%E6%9E%84%E5%BB%BAWeston%2FWayland%E3%80%82%E5%85%B3%E4%BA%8ErUNTIME_DIR%EF%BC%8C%E6%97%A0%E8%AE%BA%E6%88%91%E5%A6%82%E4%BD%95%E6%9B%B4%E6%94%B9%E4%BD%BF%E7%94%A8%E6%9D%83%E6%88%96%E6%9D%83%E9%99%90%EF%BC%8C%E8%AD%A6%E5%91%8A%E4%BF%A1%E6%81%AF%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%E8%B0%A2%E8%B0%A2%E6%82%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128761%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128761%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E1.%20%E8%AD%A6%E5%91%8A%EF%BC%9AXDG_RUNTIME_DIR%20%22%2Frun%2Fuser%2F1001%22%20%E9%85%8D%E7%BD%AE%E4%B8%8D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%AD%A3%E7%A1%AE%E3%80%82Unix%20%E8%AE%BF%E9%97%AE%E6%9D%83%E9%99%90%E5%BF%85%E9%A1%BB%E4%B8%BA%200700%EF%BC%88%E5%BD%93%E5%89%8D%E6%9D%83%E9%99%90%E4%B8%BA%20700%EF%BC%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%EF%BC%8C%E4%B8%94%E5%BF%85%E9%A1%BB%E5%BD%92%E7%94%A8%E6%88%B7%E6%89%80%E6%9C%89%EF%BC%88%E5%BD%93%E5%89%8D%E6%89%80%E6%9C%89%E8%80%85%E4%B8%BA%20UID%201001%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E2.%3CSPAN%3E%5B17%3A00%3A10.627%5D%20EGL%20%E9%94%99%E8%AF%AF%E7%8A%B6%E6%80%81%EF%BC%9AEGL_BAD_ALLOC%20(0x3003)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%5B17%3A00%3A10.627%5D%20EGL%20%E9%94%99%E8%AF%AF%E7%8A%B6%E6%80%81%EF%BC%9AEGL_SUCCESS%20(0x3000)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%5B17%3A00%3A10.627%5D%20%E6%97%A0%E6%B3%95%E5%88%9D%E5%A7%8B%E5%8C%96%20egl%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%AF%95%E8%AF%95%E7%9C%8B%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%24%20sudo%20su%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%24%26nbsp%3B%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3EXDG_RUNTIME_DIR%20%3D%2Frun%2Fuser%2F1001%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%24%20weston%20--tty%3D1%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%26nbsp%3B%E5%8F%AF%E4%BB%A5%E8%82%AF%E5%AE%9A%E7%9A%84%E6%98%AF%EF%BC%8C%26nbsp%3B%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%E5%9C%A8weston%E7%BC%96%E8%AF%91%E6%9C%9F%E9%97%B4%E9%9C%80%E8%A6%81%E5%90%AF%E7%94%A8%E7%A1%AC%E4%BB%B6%E5%8A%A0%E9%80%9F%E3%80%82build%20weston%E4%B8%AD%E5%93%AA%E4%B8%AA%E9%85%8D%E7%BD%AE%E5%8F%82%E6%95%B0%E4%B8%8E%E6%88%91%E7%9A%84%E6%8C%87%E5%8D%97%E7%9B%B8%E5%90%8C%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%20Fang%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%E5%A6%82%E6%9E%9C%E6%88%91%E8%BF%90%E8%A1%8C%20weston%20--use-pixman%EF%BC%8C%E5%88%99%E6%98%BE%E7%A4%BA%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E7%A1%AC%E4%BB%B6%E5%8A%A0%E9%80%9F%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E8%BF%99%E6%98%AF%E7%94%B1%E4%BA%8EOpenGL%20ES%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%97%AE%E9%A2%98%EF%BC%8C%E8%BF%98%E6%98%AF%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E5%9C%A8Weston%E7%BC%96%E8%AF%91%E6%97%B6%E5%90%AF%E7%94%A8%E7%A1%AC%E4%BB%B6%E5%8A%A0%E9%80%9F%EF%BC%9F%E8%B0%A2%E8%B0%A2%E6%82%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%20Fang%2C%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E6%96%87%E6%A1%A3%E3%80%82%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E5%B7%B2%E9%AA%8C%E8%AF%81%E5%B9%B6%E6%B7%BB%E5%8A%A0%E4%BA%86%20galcore%20%E6%A8%A1%E5%9D%97%E4%BB%A5%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%B6%E8%87%AA%E5%8A%A8%E5%8A%A0%E8%BD%BD%E3%80%82%E4%BD%86%E9%81%97%E6%86%BE%E7%9A%84%E6%98%AF%EF%BC%8C%E6%88%91%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%E6%A1%8C%E9%9D%A2%EF%BC%8C%E5%B9%B6%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3Esudo%20-E%20weston%20--tty%3D1%3CBR%20%2F%3E%E6%97%A5%E6%9C%9F%EF%BC%9A2019%E5%B9%B44%E6%9C%8811%E6%97%A5UTC%3CBR%20%2F%3E%5B17%3A00%3A10.607%5Dweston%205.0.0%3CBR%20%2F%3E%3CSPAN%3E%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fwayland.freedesktop.org%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwayland.freedesktop.org%3C%2FA%3E%3CBR%20%2F%3E%3CSPAN%3E%E9%94%99%E8%AF%AF%E6%8A%A5%E5%91%8A%EF%BC%9A%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fgitlab.freedesktop.org%252Fwayland%252Fweston%252Fissues%252F%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgitlab.freedesktop.org%2Fwayland%2Fweston%2Fissues%2F%3C%2FA%3E%E7%89%88%E6%9C%AC%EF%BC%9A5.0.0-33-gfb563901MGS-4627%20%5B%23ccc%5D%E5%BD%93panel-psotion%3Dnone%E6%97%B6%EF%BC%8Cweston%E5%B0%86%E5%85%B3%E9%97%AD%E5%B9%B6%E4%BD%BF%E7%94%A8gplay%20(2019%E5%B9%B43%E6%9C%8814%E6%97%A511%3A30%3A30%20%2B0800)%3CBR%20%2F%3E%5B17%3A00%3A10.607%5D%E5%91%BD%E4%BB%A4%E8%A1%8C%EF%BC%9Aweston%20--tty%3D1%3CBR%20%2F%3E%5B17%3A00%3A10.607%5D%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%EF%BC%9ALinux%EF%BC%8C4.19.35-1.1.0%2Bg0f9917c56d59%EF%BC%8C%231%20SMP%20PREEMPT%EF%BC%8C2019%E5%B9%B410%E6%9C%8830%E6%97%A5%EF%BC%88%E6%98%9F%E6%9C%9F%E4%B8%89%EF%BC%8913%3A54%3A51%20UTC%202019%2C%20aarch64%3CBR%20%2F%3E%5B17%3A00%3A10.608%5D%E8%AD%A6%E5%91%8A%EF%BC%9AXDG_RUNTIME_DIR%22%2Frun%2Fuser%2F1001%22%20%E6%9C%AA%E6%AD%A3%E7%A1%AE%E9%85%8D%E7%BD%AE%E3%80%82%3CBR%20%2F%3EUnix%E8%AE%BF%E9%97%AE%E6%A8%A1%E5%BC%8F%E5%BF%85%E9%A1%BB%E4%B8%BA0700%EF%BC%88%E5%BD%93%E5%89%8D%E6%A8%A1%E5%BC%8F%E4%B8%BA700%EF%BC%89%EF%BC%8C%3CBR%20%2F%3E%E4%B8%94%E5%BF%85%E9%A1%BB%E7%94%B1%E7%94%A8%E6%88%B7%E6%8B%A5%E6%9C%89%EF%BC%88%E5%BD%93%E5%89%8D%E6%89%80%E6%9C%89%E8%80%85%E4%B8%BAUID%201001%EF%BC%89%E3%80%82%E8%AF%B7%E5%8F%82%E8%80%83%E6%82%A8%E7%9A%84%E5%8F%91%E8%A1%8C%E7%89%88%E4%BB%A5%E4%BA%86%E8%A7%A3%E8%8E%B7%E5%8F%96%E6%96%B9%E6%B3%95%EF%BC%8C%E6%88%96%E8%AE%BF%E9%97%AE%3CBR%20%2F%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freedesktop.org%252Fwiki%252FSpecifications%252Fbasedir-spec%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freedesktop.org%2Fwiki%2FSpecifications%2Fbasedir-spec%3C%2FA%3E%3CBR%20%2F%3E%E5%A6%82%E4%BD%95%E5%AE%9E%E7%8E%B0%E3%80%82%3CBR%20%2F%3E%5B17%3A00%3A10.608%5D%E4%BB%8E%E6%97%A0%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E5%BC%80%E5%A7%8B%E3%80%82%3CBR%20%2F%3E%5B17%3A00%3A10.608%5D%E8%BE%93%E5%87%BA%E9%87%8D%E7%BB%98%E7%AA%97%E5%8F%A3%E7%9A%84%E6%9C%80%E9%95%BF%E6%97%B6%E9%97%B4%E4%B8%BA16%E6%AF%AB%E7%A7%92%E3%80%82%3CBR%20%2F%3E%5B17%3A00%3A10.608%5D%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%E6%A8%A1%E5%9D%97'%2Fusr%2Flib%2Flibweston-5%2Fdrm-backend.so'%3CBR%20%2F%3E%5B17%3A00%3A10.612%5D%E5%88%9D%E5%A7%8B%E5%8C%96drm%E5%90%8E%E7%AB%AF%3CBR%20%2F%3E%5B17%3A00%3A10.614%5D%E4%BD%BF%E7%94%A8%2Fdev%2Fdri%2Fcard0%3CBR%20%2F%3E%5B17%3A00%3A10.614%5DDRM%EF%BC%9A%E6%94%AF%E6%8C%81%E9%80%9A%E7%94%A8%E5%B9%B3%E9%9D%A2%3CBR%20%2F%3E%5B17%3A00%3A10.614%5DDRM%EF%BC%9A%E6%94%AF%E6%8C%81%E5%8E%9F%E5%AD%90%E6%A8%A1%E5%BC%8F%E8%AE%BE%E7%BD%AE%3CBR%20%2F%3E%5B17%3A00%3A10.614%5DDRM%EF%BC%9A%E6%94%AF%E6%8C%81%E5%9B%BE%E7%89%87%E9%AB%98%E5%AE%BD%E6%AF%94%3CBR%20%2F%3E%5B17%3A00%3A10.614%5D%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%E6%A8%A1%E5%9D%97'%2Fusr%2Flib%2Flibweston-5%2Fgl-renderer.so'%5B17%3A00%3A10.626%5DEGL%E5%AE%A2%E6%88%B7%E7%AB%AF%E6%89%A9%E5%B1%95%EF%BC%9AEGL_EXT_client_extensions%3CBR%20%2F%3E%20EGL_EXT_platform_base%20EGL_KHR_platform_wayland%3CBR%20%2F%3E%20EGL_EXT_platform_wayland%20EGL_KHR_platform_gbm%3CBR%20%2F%3E%5B17%3A00%3A10.627%5D%E8%AD%A6%E5%91%8A%EF%BC%9A%E4%B8%8D%E6%94%AF%E6%8C%81%20EGL_EXT_swap_buffers_with_damage%E6%88%96EGL_KHR_swap_buffers_with_damage%E3%80%82%E6%80%A7%E8%83%BD%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%8F%97%E5%88%B0%E5%BD%B1%E5%93%8D%E3%80%82%3CBR%20%2F%3E%5B17%3A00%3A10.627%5DEGL_KHR_surfaceless_context%E5%8F%AF%E7%94%A8%3CBR%20%2F%3E%5B17%3A00%3A10.627%5D%E6%97%A0%E6%B3%95%E5%88%9B%E5%BB%BA%E4%B8%8A%E4%B8%8B%E6%96%87%3CBR%20%2F%3E%5B17%3A00%3A10.627%5DEGL%E9%94%99%E8%AF%AF%E7%8A%B6%E6%80%81%EF%BC%9AEGL_BAD_ALLOC%20(0x3003)%3CBR%20%2F%3E%5B17%3A00%3A10.627%5DEGL%E9%94%99%E8%AF%AF%E7%8A%B6%E6%80%81%EF%BC%9AEGL_SUCCESS%20(0x3000)%3CBR%20%2F%3E%5B17%3A00%3A10.627%5D%E6%97%A0%E6%B3%95%E5%88%9D%E5%A7%8B%E5%8C%96egl%3CBR%20%2F%3E%E6%AE%B5%E9%94%99%E8%AF%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128757%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Build%20Ubuntu%20For%20i.MX8%20Series%20Platform%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128757%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%20gaobo%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B7%B2%E7%BB%8F%E8%A7%A3%E5%86%B3%E3%80%82%E5%85%B3%E9%94%AE%E6%98%AF%E4%B8%8B%E9%9D%A2%E4%B8%A4%E4%B8%AA%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E4%B8%80%E4%B8%8B%E3%80%82%3C%2FP%3E%3CP%3E%20%2Flib%2Fudev%2Frules.d%2F50-firmware.rules%20%3C%2FP%3E%3CP%3E%20%2Fusr%2Fbin%2Ffirmware.sh%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ecat%20%2Flib%2Fudev%2Frules.d%2F50-firmware.rules%20%3C%2FP%3E%3COL%3E%3CLI%20level%3D%221%22%20type%3D%22ol%22%3E%3CP%3Estub%20for%20immediately%20telling%20the%20kernel%20that%20userspace%20firmware%20loading%3C%2FP%3E%3C%2FLI%3E%3CLI%20level%3D%221%22%20type%3D%22ol%22%3E%3CP%3Efailed%3B%20necessary%20to%20avoid%20long%20timeouts%20with%20CONFIG_FW_LOADER_USER_HELPER%3Dy%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%23SUBSYSTEM%3D%3D%22firmware%22%2C%20ACTION%3D%3D%22add%22%2C%20ATTR%3CSPAN%20__jive_macro_name%3D%22loading%22%3E%3C%2FSPAN%3E%3D%22-1%22%3C%2FP%3E%3CP%3ESUBSYSTEM%3D%3D%22firmware%22%2C%20ACTION%3D%3D%22add%22%2C%20RUN%2B%3D%22%2Fbin%2Fsh%20%2Fusr%2Fbin%2Ffirmware.sh%22%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eimx8m%40localhost%3A~%24%20cat%20%2Fusr%2Fbin%2Ffirmware.sh%20%3C%2FP%3E%3CP%3E%23echo%201%20%26gt%3B%20%2Fsys%2F%24DEVPATH%2Floading%3C%2FP%3E%3CP%3E%23cat%20%24HOTPLUG_FW_DIR%20%26gt%3B%20%26gt%3B%20%2Fsysfs%2F%24DEVPATH%2Fdata%3C%2FP%3E%3CP%3E%23echo%200%20%26gt%3B%20%2Fsys%2F%24DEVPATH%2Floading%3C%2FP%3E%3CP%3Eecho%20-n%201%20%26gt%3B%20%2Fsys%2F%24DEVPATH%2Floading%3C%2FP%3E%3CP%3Esleep%201%3C%2FP%3E%3CP%3Ecat%20%2Flib%2Ffirmware%2F%24FIRMWARE%20%26gt%3B%20%2Fsys%2F%24DEVPATH%2Fdata%20%3C%2FP%3E%3CP%3Eif%20%3B%20then%3C%2FP%3E%3COL%3E%3CLI%20level%3D%221%22%20type%3D%22ol%22%3E%3CP%3Eecho%20-n%201%20%26gt%3B%20%2Fsys%2F%24DEVPATH%2Floading%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3Eecho%20-n%200%20%26gt%3B%20%2Fsys%2F%24DEVPATH%2Floading%3C%2FP%3E%3CP%3Efi%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B1%9F%E4%BA%9A%E5%BC%BA%3C%2FP%3E%3CP%3E%E8%BD%AF%E4%BB%B6%E5%B7%A5%E7%A8%8B%E5%B8%88%3C%2FP%3E%3CP%3EShenzhen%20Huameishi%20Technology%20Co.%2C%20Ltd%3C%2FP%3E%3CP%3E%E6%B7%B1%E5%9C%B3%E5%B8%82%E5%8D%8E%E7%BE%8E%E8%A7%86%E7%A7%91%E6%8A%80%E6%9C%89%E9%99%90%E5%85%AC%E5%8F%B8%3C%2FP%3E%3CP%3E%E6%B7%B1%E5%9C%B3%E5%B8%82%E5%8D%97%E5%B1%B1%E5%8C%BA%E7%A7%91%E8%8B%91%E8%B7%AF6%E5%8F%B7%E7%A7%91%E6%8A%80%E5%9B%AD%E5%B7%A5%E4%B8%9A%E5%A4%A7%E5%8E%A6605%3C%2FP%3E%3CP%3ETel%EF%BC%9A0755-26037882-616%3C%2FP%3E%3CP%3EMail%3Ayaqiang.jiang%40huameishi.com%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E6%9B%B4%E6%96%B0%E4%BA%86%E5%90%AF%E7%94%A8%20weston%20%E7%9A%84%E6%96%87%E6%A1%A3%E3%80%82%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E6%98%AF%E5%90%A6%E6%9C%89%20GPU%20%E9%A9%B1%E5%8A%A8%E3%80%82%3C%2FP%3E%3CP%3Eroot%40ubuntu%3A~%23%20ls%20%2Fdev%2Fgalcore%3C%2FP%3E%3CP%3E%2Fdev%2Fgalcor%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128754%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128754%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%20Fang%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%E8%B0%A2%E8%B0%A2%EF%BC%8C%E6%88%91%E5%BE%88%E6%9C%9F%E5%BE%85%EF%BC%8C%E5%AE%8C%E6%88%90%E5%90%8E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%E5%A6%82%E6%9E%9C%E6%9C%89%E4%BB%BB%E4%BD%95%E8%BF%9B%E5%B1%95%EF%BC%8C%E6%88%91%E4%B9%9F%E4%BC%9A%E5%8F%8A%E6%97%B6%E6%9B%B4%E6%96%B0%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128751%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128751%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%20Fang%2C%3C%2FP%3E%3CP%3E%E7%9B%AE%E5%89%8D%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20IM8MM%20DDR4%20EVK%E3%80%82%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128749%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128749%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%20Fang%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E5%9C%A8%E8%BF%90%E8%A1%8CWeston%20tty%E6%97%B6%EF%BC%8C%E6%88%91%E6%94%B6%E5%88%B0%E4%BA%86%E2%80%9C%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E8%AE%BE%E5%A4%87%E6%88%96%E7%9B%AE%E5%BD%95%E2%80%9D%E6%88%96%E2%80%9C%E8%87%B4%E5%91%BD%EF%BC%9ADRM%E5%BA%94%E8%AF%A5%E5%9C%A8%E5%90%8E%E5%8F%B0%E8%BF%90%E8%A1%8C%E2%80%9D%E7%9A%84%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%E3%80%82%E6%82%A8%E8%83%BD%E5%90%A6%E5%B0%B1%E6%AD%A4%E6%8F%90%E4%BE%9B%E4%B8%80%E4%BA%9B%E6%8C%87%E5%AF%BC%E3%80%82%E8%B0%A2%E8%B0%A2%E6%82%A8%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3ERaajesh%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128748%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128748%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8Cdowney%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%E5%B9%B3%E5%8F%B0%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8imx8md%2Fq%EF%BC%8C%E5%AE%83%E4%B8%8D%E6%94%AF%E6%8C%81%E2%80%9Cg2d%E2%80%9D%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%8F%AA%E9%9C%80%E5%9C%A8%E9%85%8D%E7%BD%AEweston-imx%E6%97%B6%E6%B7%BB%E5%8A%A0%E2%80%9C--disable-imxg2d%E2%80%9D%E5%8D%B3%E5%8F%AF%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B1%9F%E4%BA%9A%E5%BC%BA%3C%2FP%3E%3CP%3E%E8%BD%AF%E4%BB%B6%E5%B7%A5%E7%A8%8B%E5%B8%88%3C%2FP%3E%3CP%3EShenzhen%20Huameishi%20Technology%20Co.%2C%20Ltd%3C%2FP%3E%3CP%3EMail%3Ayaqiang.jiang%40huameishi.com%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHI%26nbsp%3B%20Gnar%20Fang%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E6%82%A8%E7%9A%84%E6%96%87%E6%A1%A3%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8imx8mq%E4%B8%8A%E6%88%90%E5%8A%9F%E8%BF%90%E8%A1%8Cubuntu18.04%EF%BC%8C%E4%BD%86%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9A%E7%B3%BB%E7%BB%9F%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%E5%9B%BA%E4%BB%B6%EF%BC%9A%3C%2FP%3E%3CP%3Eimx-sdma%2030bd0000.sdma%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%A4%96%E9%83%A8%E5%9B%BA%E4%BB%B6%EF%BC%8C%E4%BD%BF%E7%94%A8ROM%E5%9B%BA%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E7%A1%AE%E8%AE%A4%E5%9B%BA%E4%BB%B6%E4%BD%8D%E4%BA%8E%2Flib%2Ffirmware%2F%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E6%9C%89%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E6%88%96%E8%80%85%E6%88%91%E5%BA%94%E8%AF%A5%E5%9C%A8%E5%93%AA%E9%87%8C%E6%A3%80%E6%9F%A5%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%26nbsp%3B%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22321819%22%20data-username%3D%22nxf47724%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fnxf47724%22%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20text-decoration%3A%20none%3B%20font-size%3A%201.286rem%3B%22%20target%3D%22_blank%22%3EGnar%20Fang%3C%2FA%3E%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E6%88%91%E5%9C%A8%20%3CSTRONG%3Eaarch64-poky-linux%2F%20%3C%2FSTRONG%3E%E7%9B%AE%E5%BD%95%E4%B8%8B%E6%89%BE%E5%88%B0%E4%BA%86%20%3CSTRONG%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%22%3Elibdrm%2F%3C%2FSTRONG%3E%EF%BC%8C%E5%B9%B6%E6%8C%89%E7%85%A7%E4%BD%A0%E6%96%87%E6%A1%A3%E4%B8%AD%E7%9A%84%E6%8C%87%E5%BC%95%E5%B0%86%E5%85%B6%E5%A4%8D%E5%88%B6%E5%88%B0%E4%BA%86%E5%AF%B9%E5%BA%94%E7%9A%84%E7%9B%AE%E5%BD%95%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%9C%A8%E7%BC%96%E8%AF%91%20%3CSTRONG%3Eweston-imx%3C%2FSTRONG%3E%20%E6%97%B6%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E5%8F%A6%E4%B8%80%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%60%60%60%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B...%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%E5%9C%A8%E6%96%87%E4%BB%B6libweston%2Fg2d-renderer.c%3A44%3A0%E4%B8%AD%E5%8C%85%E5%90%AB%EF%BC%9A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Blibweston%2Fg2d-renderer.h%3A30%3A10%EF%BC%9A%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%EF%BC%9Ag2dExt.h%EF%BC%9A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%23%E5%8C%85%E6%8B%AC%3CG2DEXT.H%3E%3CBR%20%2F%3E%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%5E~~~~~~~~~%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%E7%BC%96%E8%AF%91%E7%BB%88%E6%AD%A2%E3%80%82%3C%2FG2DEXT.H%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3BMakefile%3A5107%3A%20recipe%20for%20target%20'libweston%2Fg2d_renderer_la-g2d-renderer.lo'%20failed%3C%2FP%3E%3CP%3E%60%60%60%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3E%E4%BC%BC%E4%B9%8E%E7%BC%BA%E5%B0%91%E4%BA%86%E4%B8%80%E4%BA%9B%E7%B3%BB%E7%BB%9F%E5%BA%93%EF%BC%88libweston%EF%BC%89%EF%BC%8C%E6%88%96%E8%80%85%E6%9C%89%E4%B8%80%E4%BA%9B%E6%88%91%E5%B0%9A%E6%9C%AA%E5%AE%89%E8%A3%85%E7%9A%84%E5%8C%85%EF%BC%8C%E8%80%8C%E8%AF%A5%E5%BA%93%E4%BE%9D%E8%B5%96%E4%BA%8E%E8%BF%99%E4%BA%9B%E5%8C%85%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E6%88%91%E5%86%8D%E6%AC%A1%E5%B0%9D%E8%AF%95%E4%BB%8E%E5%A4%B4%E5%BC%80%E5%A7%8B%E6%9E%84%E5%BB%BA%E4%BB%A5%E9%81%BF%E5%85%8D%E6%93%8D%E4%BD%9C%E9%94%99%E8%AF%AF%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E4%B8%A4%E6%AC%A1%E5%B0%9D%E8%AF%95%E7%9A%84%E7%BB%93%E6%9E%9C%E9%83%BD%E6%98%AF%E7%9B%B8%E5%90%8C%E7%9A%84%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E6%AD%A4%E8%87%B4%E9%97%AE%E5%80%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3EDowney%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8CPrashanth%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%B2%A1%E6%9C%89%E6%94%B6%E5%88%B0%E6%96%B0%E7%9A%84%E8%A6%81%E6%B1%82%EF%BC%8C%E6%89%80%E4%BB%A5%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E6%9B%B4%E6%96%B0%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3EGnar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%E6%98%AF%E5%90%A6%E6%9C%89%E6%9B%B4%E6%96%B0%E7%9A%84%E6%96%87%E6%A1%A3%E7%94%A8%E4%BA%8E%E5%9C%A8i.MX8%E5%B9%B3%E5%8F%B0%E4%B8%8A%E6%9E%84%E5%BB%BAUbuntu%2018.04%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3EPrashanth%20Kumar%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%201.286rem%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2018.004px%3B%22%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2018.004px%3B%22%3Eprashanth%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%201.286rem%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2018.004px%3B%22%3E%E6%82%A8%E5%AE%89%E8%A3%85%E4%BA%86weston%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%AE%83%E4%BC%9A%E6%98%BE%E7%A4%BAweston%20GUI%E3%80%82%E6%88%91%E8%AE%A4%E4%B8%BA%E6%82%A8%E6%83%B3%E8%8E%B7%E5%BE%97Gnome%20GUI%EF%BC%8C%E4%BD%86%E6%88%91%E4%BB%85%E9%80%9A%E8%BF%87CPU%E8%BD%AF%E4%BB%B6%E6%B8%B2%E6%9F%93%E5%90%AF%E7%94%A8%E5%AE%83%EF%BC%88%E5%8F%AA%E9%9C%80%E6%89%A7%E8%A1%8Capt-get%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Binstall%20gnome-core%EF%BC%89%E3%80%82%26nbsp%3B%26nbsp%3BGnome%20GUI%E5%9C%A8%E4%BD%BF%E7%94%A8GPU%E6%B8%B2%E6%9F%93%E6%97%B6%E9%81%87%E5%88%B0%E4%B8%80%E4%BA%9B%E9%94%99%E8%AF%AF%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%201.286rem%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2018.004px%3B%22%3EBR%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%201.286rem%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2018.004px%3B%22%3EGnar%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%201.286rem%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2018.004px%3B%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128740%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128740%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E8%83%BD%E5%A4%9F%E9%80%9A%E8%BF%87Weston%E8%8E%B7%E5%BE%97%E5%9B%BE%E5%BD%A2%E7%94%A8%E6%88%B7%E7%95%8C%E9%9D%A2%EF%BC%88GUI%EF%BC%89%EF%BC%8C%E4%BD%86%E8%AF%A5GUI%E7%9A%84%E5%A4%96%E8%A7%82%E4%B8%8E%E6%A1%8C%E9%9D%A2%E7%89%88Ubuntu%E7%9A%84GUI%E4%B8%8D%E5%90%8C%E3%80%82%3CBR%20%2F%3E%E6%82%A8%E6%98%AF%E5%90%A6%E4%B9%9F%E9%81%87%E5%88%B0%E7%9B%B8%E5%90%8C%E7%9A%84GUI%EF%BC%9F%3CBR%20%2F%3E%E7%BB%88%E7%AB%AF%E6%98%BE%E7%A4%BA%E4%BB%A5%E4%B8%8B%E8%BE%93%E5%87%BA%EF%BC%8C%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%23%20lsb_release%20-a%3C%2FP%3E%3CP%3E%E6%B2%A1%E6%9C%89%E5%8F%AF%E7%94%A8%E7%9A%84LSB%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3E%E4%BB%A3%E7%90%86%E5%95%86ID%EF%BC%9AUbuntu%3CBR%20%2F%3E%E6%8F%8F%E8%BF%B0%EF%BC%9A%26nbsp%3B%26nbsp%3B%26nbsp%3BUbuntu%2018.04.2LTS%3CBR%20%2F%3E%E7%89%88%E6%9C%AC%EF%BC%9A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2018.04%3CBR%20%2F%3E%E4%BB%A3%E5%8F%B7%EF%BC%9A%26nbsp%3B%26nbsp%3B%26nbsp%3Bbionic%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22wayland-screenshot-2018-01-28_15-59-17.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22wayland-screenshot-2018-01-28_15-59-17.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F95097i602280E3CB27379B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22wayland-screenshot-2018-01-28_15-59-17.png%22%20alt%3D%22wayland-screenshot-2018-01-28_15-59-17.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EPrashanth%20Kumar%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E1.%20libdrm%20%E4%BD%8D%E4%BA%8E%3CSTRONG%3Ebuildxwayland%2Ftmp%2Fwork%2Faarch64-poky-linux%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3CP%3E2.%20%E8%AF%A5%E9%97%AE%E9%A2%98%E5%8F%AF%E8%83%BD%E6%98%AF%E7%94%B1%E4%BA%8E%E6%82%A8%E7%9A%84%20rootfs%20%E4%B8%A2%E5%A4%B1%E4%BA%86%20libdrm%EF%BC%8C%E8%AF%B7%E5%B0%86%20libdrm%20%E5%A4%8D%E5%88%B6%E5%88%B0%E6%82%A8%E7%9A%84%20rootfs%20%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E9%97%AE%E9%A2%98%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%E6%9C%80%E8%BF%91%E5%85%B6%E4%BB%96%E4%BA%8B%E5%8A%A1%E8%BE%83%E5%A4%9A%EF%BC%8C%E5%9B%9E%E5%A4%8D%E5%8F%AF%E8%83%BD%E4%BC%9A%E6%9C%89%E4%BA%9B%E5%BB%B6%E8%BF%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3EGnar%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128738%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128738%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%26nbsp%3B%3CA%20_jive_internal%3D%22true%22%20class%3D%22%22%20data-avatarid%3D%2229594%22%20data-externalid%3D%22%22%20data-online%3D%22false%22%20data-presence%3D%22null%22%20data-userid%3D%22321819%22%20data-username%3D%22nxf47724%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fnxf47724%22%20style%3D%22color%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2014px%3B%22%20target%3D%22_blank%22%3EGnar%20Fang%3C%2FA%3E%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E8%B0%A2%E8%B0%A2%E5%9B%9E%E5%A4%8D%EF%BC%8C%E6%9C%9F%E5%BE%85%E6%82%A8%E7%9A%84%E6%9B%B4%E6%96%B0%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E9%A1%BA%E4%BE%BF%E8%AF%B4%E4%B8%80%E4%B8%8B%EF%BC%8C%E8%AF%B7%E6%A3%80%E6%9F%A5%E4%B8%8A%E9%9D%A2%E7%9A%84%E7%AC%AC%E4%BA%8C%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%88%E7%BC%96%E8%AF%91weston-imx%E9%94%99%E8%AF%AF%EF%BC%89%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3CP%3E%E5%94%90%E5%B0%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E5%8F%91%E7%8E%B08mq%20Yocto%E4%B8%AD%E6%B2%A1%E6%9C%89libdrm%E5%BA%93%E3%80%82%E6%88%91%E4%B8%8B%E5%91%A8%E4%BC%9A%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%20DRM%20%E6%98%AF%20Linux%20%E6%98%BE%E7%A4%BA%E7%9A%84%E5%BF%85%E8%A6%81%E7%BB%84%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3EGnar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22321819%22%20data-username%3D%22nxf47724%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fnxf47724%22%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%201.286rem%3B%22%20target%3D%22_blank%22%3EGnar%20Fang%3C%2FA%3E%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%B0%86%20Ubuntu%2018.04%20%E7%A7%BB%E6%A4%8D%E5%88%B0%E6%88%91%E7%9A%84%20i.mx8mq-evk%E3%80%82%E6%88%91%E5%B7%B2%E9%98%85%E8%AF%BB%E6%82%A8%E7%9A%84%E6%96%87%E6%A1%A3%E5%B9%B6%E6%8C%89%E7%85%A7%E6%AD%A5%E9%AA%A4%E6%93%8D%E4%BD%9C%EF%BC%8C%E4%BD%86%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%A4%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B1.%E6%AD%A5%E9%AA%A4%209%20%E7%9A%84%E7%AC%AC%202%20%E9%83%A8%E5%88%86%EF%BC%9A%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E7%9B%AE%E6%A0%87%20%22libdrm%2F2.4.91.imx-r0%2Fimage%2F*%22%20%E5%92%8C%20%22imx-dpu-g2d-1.7.0%2Fimx-dpu-g2d%2F1.7.0-r0%2Fimage%2F*%22%EF%BC%8C%E6%88%91%E7%A1%AE%E5%AE%9A%E6%88%91%E7%9A%84%20Yocto%20%E9%A1%B9%E7%9B%AE%E4%B8%AD%E4%B8%8D%E5%AD%98%E5%9C%A8%E8%BF%99%E4%B8%A4%E4%B8%AA%E7%9B%AE%E6%A0%87%E3%80%82%E6%88%91%E7%8C%9C%E6%83%B3%20i.MX8MQ-EVK%20%E6%B2%A1%E6%9C%89%20DPU%EF%BC%8C%E4%BD%86%E5%AF%B9%E4%BA%8E%20libdrm%EF%BC%8C%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%EF%BC%8C%E6%89%80%E4%BB%A5%E8%AF%B7%E7%BB%99%E6%88%91%E4%B8%80%E4%BA%9B%E6%8F%90%E7%A4%BA%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%E9%A1%BA%E4%BE%BF%E8%AF%B4%E4%B8%80%E4%B8%8B%EF%BC%8C%E6%88%91%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E6%8C%87%E4%BB%A4%E8%BF%9B%E8%A1%8C%E7%BC%96%E8%AF%91%EF%BC%9A%3C%2FP%3E%3CP%3EDISTRO%3Dfsl-imx-wayland%20MACHINE%3Dimx8mqevk%20source%20fsl-setup-release.sh%20-b%20build%3C%2FP%3E%3CP%3Ebitbake%20fsl-image-qt5-validation-imx%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B2.%20%E6%97%A0%E8%AE%BA%E4%B8%8A%E8%BF%B0%E9%94%99%E8%AF%AF1%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%EF%BC%8C%E6%88%91%E8%AF%95%E5%9B%BE%E7%BB%A7%E7%BB%AD%E5%A4%84%E7%90%86%E6%96%87%E6%A1%A3%EF%BC%8C%E4%BD%86%E5%9C%A8%E7%BC%96%E8%AF%91weston-imx%E6%97%B6%EF%BC%8C%E5%87%BA%E7%8E%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%AD%A5%E9%AA%A4%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bgit%20clone%20%3CA%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Fweston-imx.git%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Fweston-imx.git%3C%2FA%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bcd%20weston-imx%3C%2FP%3E%3CP%3Egit%20checkout%20fb563901657b296c7c7c86d26602a622429e334f%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B.%2Fautogen.sh%20--prefix%3D%2Fusr%20--disable-silent-rules%20--disable-dependency-tracking%20.........%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3Bmake%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%26nbsp%3B%20make%5B1%5D%3A%20Entering%20directory%20'%2Froot%2Fweston%2Fweston-imx'%3CBR%20%2F%3E%26nbsp%3B%2Fbin%2Fbash%20.%2Flibtool%20--tag%3DCC%20--mode%3Dcompile%20gcc%20-DHAVE_CONFIG_H%20-I.%20-I.%2Flibweston%20-I.%2Flibweston%20-I.%2Fclients%20-I.%2Ftests%20-I.%2Fshared%20-I.%2Fprotocol%20-DLIBWESTON_MODULEDIR%3D'%22%2Fusr%2Flib%2Flibweston-5%22'%20-DLIBEXECDIR%3D'%22%2Fusr%2Flibexec%22'%20-DBINDIR%3D'%22%2Fusr%2Fbin%22'%20-DIN_WESTON%20-Wall%20-Wextra%20-Wno-unused-parameter%20-Wno-shift-negative-value%20-Wno-missing-field-initializers%20-g%20-fvisibility%3Dhidden%20-Wstrict-prototypes%20-Wmissing-prototypes%20-Wsign-compare%20-DLINUX%20-DEGL_API_FB%20-DWL_EGL_PLATFORM%20-I%2Fusr%2Finclude%2Fpixman-1%20-DLINUX%20-DEGL_API_FB%20-DWL_EGL_PLATFORM%20-I%2Fusr%2Finclude%2Flibdrm%20-g%20-O2%20-c%20-o%20libweston%2Flibweston_5_la-pixel-formats.lo%20%60test%20-f%20'libweston%2Fpixel-formats.c'%20%7C%7C%20echo%20'.%2F'%60libweston%2Fpixel-formats.c%3CBR%20%2F%3Elibtool%3A%20compile%3A%20gcc%20-DHAVE_CONFIG_H%20-I.%20-I.%2Flibweston%20-I.%2Flibweston%20-I.%2Fclients%20-I.%2Ftests%20-I.%2Fshared%20-I.%2Fprotocol%20-DLIBWESTON_MODULEDIR%3D%5C%22%2Fusr%2Flib%2Flibweston-5%5C%22%20-DLIBEXECDIR%3D%5C%22%2Fusr%2Flibexec%5C%22%20-DBINDIR%3D%5C%22%2Fusr%2Fbin%5C%22%20-DIN_WESTON%20-Wall%20-Wextra%20-Wno-unused-parameter%20-Wno-shift-negative-value%20-Wno-missing-field-initializers%20-g%20-fvisibility%3Dhidden%20-Wstrict-prototypes%20-Wmissing-prototypes%20-Wsign-compare%20-DLINUX%20-DEGL_API_FB%20-DWL_EGL_PLATFORM%20-I%2Fusr%2Finclude%2Fpixman-1%20-DLINUX%20-DEGL_API_FB%20-DWL_EGL_PLATFORM%20-I%2Fusr%2Finclude%2Flibdrm%20-g%20-O2%20-c%20libweston%2Fpixel-formats.c%20-fPIC%20-DPIC%20-o%20libweston%2F.libs%2Flibweston_5_la-pixel-formats.o%3C%2FP%3E%3CP%3E%3CBR%20%2F%3Elibweston%2Fpixel-formats.c%3A268%3A13%3A%20error%3A%20'DRM_FORMAT_P010'%20undeclared%20here%20(not%20in%20a%20function)%3B%20did%20you%20mean%20'DRM_FORMAT_NV12'%3F%3CBR%20%2F%3E%20.format%20%3D%20DRM_FORMAT_P010%2C%20%26nbsp%3B%5E~~~~~~~~~~~~~~%3CBR%20%2F%3E%20DRM_FORMAT_NV12%3CBR%20%2F%3EMakefile%3A5527%3A%20recipe%20for%20target%20'libweston%2Flibweston_5_la-pixel-formats.lo'%20%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%90%91%E6%88%91%E5%8F%91%E9%80%81%E4%B8%80%E4%BA%9B%E4%BF%A1%E5%8F%B7%E6%9D%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%A4%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%97%AE%E5%80%99%3C%2FP%3E%3CP%3E%E5%94%90%E5%B0%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128735%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128735%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%E4%BD%BF%E7%94%A8Weston%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fnxf47724%22%20target%3D%22_blank%22%3Enxf47724%3C%2FA%3E%E2%80%8C%E7%9A%84Ubuntu%2018.04%EF%BC%8C%E6%98%AF%E5%90%A6%E6%9C%89%E5%85%B3%E4%BA%8E%E4%B8%8A%E8%BF%B0%E9%97%AE%E9%A2%98%E7%9A%84%E6%9B%B4%E6%96%B0%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%85%88%E8%A1%8C%E8%87%B4%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EPrashanth%20Kumar%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128734%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128734%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%EF%BC%8C%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E4%BB%8E%E6%88%91%E7%9A%84%E7%94%B5%E8%84%91%E4%B8%AD%E5%88%A0%E9%99%A4%E4%BA%86%20rootfs%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E6%84%BF%E6%84%8F%EF%BC%8C%E8%AF%B7%E4%B8%BA%E6%88%91%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%B7%A5%E5%8D%95%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3EGnar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%82%A8%E6%8F%90%E4%BE%9B%E5%B7%B2%E6%9E%84%E5%BB%BA%E7%9A%84%3CSTRONG%3Eubuntu-rootfs.tar.gz%3C%2FSTRONG%3E%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%9C%A8iMX8QM%E5%AE%9A%E5%88%B6%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%85%88%E8%A1%8C%E8%87%B4%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3EPrashanth%20Kumar%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EGnar%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%88%91%E4%BD%BF%E7%94%A8%E2%80%9C%3CSTRONG%3E10.%E6%9E%84%E5%BB%BAWeston%3C%2FSTRONG%3E%E2%80%9D%E9%83%A8%E5%88%86%E7%9A%84%E6%AD%A5%E9%AA%A4%E5%9C%A8qemu%E7%8E%AF%E5%A2%83%E7%9A%84ubuntu-rootfs%E4%B8%AD%E6%9E%84%E5%BB%BAWeston%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%8C%89%E7%85%A7%E6%8F%90%E4%BE%9B%E7%9A%84%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%E4%B8%AD%E6%8F%90%E5%88%B0%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%8C%E5%B0%86%E5%AE%8C%E6%95%B4%E7%9A%84%20ubuntu-rootfs%20%E5%A4%8D%E5%88%B6%E5%88%B0%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E12.%20%E6%9B%BF%E6%8D%A2%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3CBR%20%2F%3E%24%20mkdir%20mountpoint%3CBR%20%2F%3E%24%20umount%20%2Fdev%2Fsdb2%3CBR%20%2F%3E%24%20mkfs.ext4%20%2Fdev%2Fsdb2%3CBR%20%2F%3E%24%20mount%20%2Fdev%2Fsdb2%20%2Fhome%2Fgnar%2Fmountpoint%3CBR%20%2F%3E%24%20cp%20-a%20%2Fhome%2Fgnar%2Frootfs%2Fubuntu-rootfs%20%2F*%20%2Fhome%2Fgnar%2Fmountpoint%2F%3CBR%20%2F%3Eumount%20%2Fhome%2Fgnar%2Fmountpoint%3CBR%20%2F%3Esync%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E4%BD%86%E4%BB%8D%E7%84%B6%E9%9D%A2%E4%B8%B4%E7%9B%B8%E5%90%8C%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3Eubuntu%40ubuntu%3A~%24%20export%20XDG_RUNTIME_DIR%3D%2Frun%2Fuser%2F1000%3CBR%20%2F%3Eubuntu%40ubuntu%3A~%24%20sudo%20-E%20weston%20--tty%3D1%3CBR%20%2F%3E%5Bsudo%5D%20password%20for%20iwave%3A%20%3CBR%20%2F%3EDate%3A%202019-10-20%20UTC%3CBR%20%2F%3E%5B12%3A05%3A59.961%5D%20weston%205.0.0%3CBR%20%2F%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CA%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fwayland.freedesktop.org%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwayland.freedesktop.org%3C%2FA%3E%3CBR%20%2F%3E%3CSPAN%3E%20Bug%20reports%20to%3A%20%3C%2FSPAN%3E%3CA%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fgitlab.freedesktop.org%252Fwayland%252Fweston%252Fissues%252F%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgitlab.freedesktop.org%2Fwayland%2Fweston%2Fissues%2F%3C%2FA%3E%3CBR%20%2F%3E%20Build%3A%205.0.0-33-gfb563901%20MGS-4627%20%5B%23ccc%5D%20weston%20will%20turn%20off%20when%20panel-psotion%3Dnone%20and%20use%20gplay%20(2019-03-14%2011%3A30%3A30%20%2B0800)%3CBR%20%2F%3E%5B12%3A05%3A59.961%5D%20Command%20line%3A%20weston%20--tty%3D1%3CBR%20%2F%3E%5B12%3A05%3A59.961%5D%20OS%3A%20Linux%2C%204.14.98-imx_4.14.98_2.0.0_ga%2Bg5d6cbea%2C%20%231%20SMP%20PREEMPT%20Mon%20Oct%2014%2008%3A11%3A41%20UTC%202019%2C%20aarch64%3CBR%20%2F%3E%5B12%3A05%3A59.961%5D%20warning%3A%20XDG_RUNTIME_DIR%20%22%2Frun%2Fuser%2F1000%22%20is%20not%20configured%3CBR%20%2F%3Ecorrectly.%20Unix%20access%20mode%20must%20be%200700%20(current%20mode%20is%20700)%2C%3CBR%20%2F%3Eand%20must%20be%20owned%20by%20the%20user%20(current%20owner%20is%20UID%201000).%3CBR%20%2F%3ERefer%20to%20your%20distribution%20on%20how%20to%20get%20it%2C%20or%3CBR%20%2F%3E%3CA%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freedesktop.org%252Fwiki%252FSpecifications%252Fbasedir-spec%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freedesktop.org%2Fwiki%2FSpecifications%2Fbasedir-spec%3C%2FA%3E%3CBR%20%2F%3Eon%20how%20to%20implement%20it.%3CBR%20%2F%3E%5B12%3A05%3A59.961%5D%20Starting%20with%20no%20config%20file.%3CBR%20%2F%3E%5B12%3A05%3A59.962%5D%20Output%20repaint%20window%20is%2016%20ms%20maximum.%3CBR%20%2F%3E%3CSTRONG%3E%5B12%3A05%3A59.962%5D%20Loading%20module%20'%2Fusr%2Flib%2Flibweston-5%2Fdrm-backend.so'%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B12%3A05%3A59.964%5D%20Failed%20to%20load%20module%3A%20%2Fusr%2Flib%2Flibweston-5%2Fdrm-backend.so%3A%20undefined%20symbol%3A%20gbm_surface_get_in_fence_fd%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B12%3A05%3A59.964%5D%20fatal%3A%20failed%20to%20create%20compositor%20backend%3C%2FSTRONG%3E%3CBR%20%2F%3Eubuntu%40ubuntu%3A~%24%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%BB%BA%E8%AE%AE%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%26nbsp%3B%E2%80%9C%3CSTRONG%3Edrm-backend.so%3C%2FSTRONG%3E%E2%80%9D%26nbsp%3B%E5%8A%A0%E8%BD%BD%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%BF%98%E8%AF%B7%E6%8F%90%E4%BE%9B%E4%BB%8Eyocto%20build%E5%90%91ubuntu-rootfs%E5%A4%8D%E5%88%B6%E2%80%9C%3CSTRONG%3Eweston%3C%2FSTRONG%3E%E2%80%9D%E7%9B%B8%E5%85%B3%E5%BA%93%E7%9A%84%E8%B7%AF%E5%BE%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EPrashanth%20Kumar%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E6%88%91%E7%9A%84%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%9C%A8%E4%B8%BB%E6%9C%BA%E4%B8%8A%E5%90%AF%E5%8A%A8ARM64%E7%8E%AF%E5%A2%83%E6%A8%A1%E6%8B%9F%E5%B9%B6%E6%9E%84%E5%BB%BAweston%E3%80%82%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E5%A4%8D%E5%88%B6%E6%95%B4%E4%B8%AA%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%EF%BC%8C%E8%80%8C%E4%B8%8D%E4%BB%85%E4%BB%85%E6%98%AF%E5%A4%8D%E5%88%B6%20weston%20lib%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3EGnar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E7%94%A8%E4%BA%8E%E5%90%AF%E5%8A%A8%20arm64-linux%20%E6%A8%A1%E6%8B%9F%E7%8E%AF%E5%A2%83%E7%9A%84%E8%84%9A%E6%9C%AC%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E5%9C%A8%E7%8E%AF%E5%A2%83%E4%B8%AD%E6%9E%84%E5%BB%BAweston%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E6%B2%A1%E6%9C%89%E9%81%87%E5%88%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E6%A3%80%E6%9F%A5%2Fusr%2Flib%2Faarch64-xx%26nbsp%3B%E7%9B%AE%E5%BD%95%E4%B8%8B%E6%98%AF%E5%90%A6%E6%9C%89libGLES%E3%80%81libEGL%E3%80%82%E5%A6%82%E6%9C%89%EF%BC%8C%E8%AF%B7%E5%88%A0%E9%99%A4%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR%2C%3C%2FP%3E%3CP%3EGnar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EGnar%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E6%88%91%26nbsp%3B%E5%9C%A8%E4%BD%BF%E7%94%A8Weston%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%E5%8A%A0%E8%BD%BD%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E6%97%B6%EF%BC%8C%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3Eexport%20XDG_RUNTIME_DIR%3D%2Frun%2Fuser%2F1000%3CBR%20%2F%3Esudo%20-E%20weston%20--tty%3D1%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3Eubuntu%40ubuntu%3A~%24%20export%20XDG_RUNTIME_DIR%3D%2Frun%2Fuser%2F1000%3CBR%20%2F%3Eubuntu%40ubuntu%3A~%24%20sudo%20-E%20weston%20--tty%3D1%3CBR%20%2F%3E%5Bsudo%5D%20password%20for%20iwave%3A%20%3CBR%20%2F%3EDate%3A%202019-10-20%20UTC%3CBR%20%2F%3E%5B12%3A05%3A59.961%5D%20weston%205.0.0%3CBR%20%2F%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fwayland.freedesktop.org%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwayland.freedesktop.org%3C%2FA%3E%3CBR%20%2F%3E%3CSPAN%3E%20Bug%20reports%20to%3A%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fgitlab.freedesktop.org%252Fwayland%252Fweston%252Fissues%252F%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgitlab.freedesktop.org%2Fwayland%2Fweston%2Fissues%2F%3C%2FA%3E%3CBR%20%2F%3E%20Build%3A%205.0.0-33-gfb563901%20MGS-4627%20%5B%23ccc%5D%20weston%20will%20turn%20off%20when%20panel-psotion%3Dnone%20and%20use%20gplay%20(2019-03-14%2011%3A30%3A30%20%2B0800)%3CBR%20%2F%3E%5B12%3A05%3A59.961%5D%20Command%20line%3A%20weston%20--tty%3D1%3CBR%20%2F%3E%5B12%3A05%3A59.961%5D%20OS%3A%20Linux%2C%204.14.98-imx_4.14.98_2.0.0_ga%2Bg5d6cbea%2C%20%231%20SMP%20PREEMPT%20Mon%20Oct%2014%2008%3A11%3A41%20UTC%202019%2C%20aarch64%3CBR%20%2F%3E%5B12%3A05%3A59.961%5D%20warning%3A%20XDG_RUNTIME_DIR%20%22%2Frun%2Fuser%2F1000%22%20is%20not%20configured%3CBR%20%2F%3Ecorrectly.%20Unix%20access%20mode%20must%20be%200700%20(current%20mode%20is%20700)%2C%3CBR%20%2F%3Eand%20must%20be%20owned%20by%20the%20user%20(current%20owner%20is%20UID%201000).%3CBR%20%2F%3ERefer%20to%20your%20distribution%20on%20how%20to%20get%20it%2C%20or%3CBR%20%2F%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freedesktop.org%252Fwiki%252FSpecifications%252Fbasedir-spec%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freedesktop.org%2Fwiki%2FSpecifications%2Fbasedir-spec%3C%2FA%3E%3CBR%20%2F%3Eon%20how%20to%20implement%20it.%3CBR%20%2F%3E%5B12%3A05%3A59.961%5D%20Starting%20with%20no%20config%20file.%3CBR%20%2F%3E%5B12%3A05%3A59.962%5DOutput%20repaint%20window%20is%2016%20ms%20maximum.%3CBR%20%2F%3E%3CSTRONG%3E%5B12%3A05%3A59.962%5D%20Loading%20module%20'%2Fusr%2Flib%2Flibweston-5%2Fdrm-backend.so'%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B12%3A05%3A59.964%5D%20Failed%20to%20load%20module%3A%20%2Fusr%2Flib%2Flibweston-5%2Fdrm-backend.so%3A%20undefined%20symbol%3A%20gbm_surface_get_in_fence_fd%3C%2FSTRONG%3E%3CBR%20%2F%3E%5B12%3A05%3A59.964%5D%20fatal%3A%20failed%20to%20create%20compositor%20backend%3CBR%20%2F%3Eubuntu%40ubuntu%3A~%24%20%3CBR%20%2F%3Eubuntu%40ubuntu%3A~%24%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E5%A6%82%E4%BD%95%E5%B0%86%20%E2%80%9C%3CSTRONG%3Eweston%3C%2FSTRONG%3E%E2%80%9D%20%E5%BA%93%E4%BB%8E%20yocto%20%E6%9E%84%E5%BB%BA%E5%A4%8D%E5%88%B6%E5%88%B0%20ubuntu-rootfs%EF%BC%9F%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EPrashanth%20Kumar%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%2C%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E5%88%86%E4%BA%AB%E8%BF%99%E4%B8%AA%E6%AD%A5%E9%AA%A4%E3%80%82%E6%88%91%E6%83%B3%E5%90%91%E4%BD%A0%E8%AF%B7%E6%95%99%EF%BC%9A%3CSPAN%20class%3D%22%22%3Esudo%20mount%20-t%20proc%20%2Fproc%20%24%7B2%7Dproc%22%20%E4%BB%A5%E5%8F%8A%E5%85%B6%E4%BB%96%E7%B1%BB%E4%BC%BC%E5%91%BD%E4%BB%A4%E7%9A%84%E4%BD%9C%E7%94%A8%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FSPAN%3E%3CBR%20style%3D%22font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20line-height%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20-webkit-auto%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-size-adjust%3A%20auto%3B%20-webkit-text-stroke-width%3A%200px%3B%22%20%2F%3E%E8%BF%99%E4%BA%9B%E5%91%BD%E4%BB%A4%E7%BB%99%E6%88%91%E4%BB%AC%E7%9A%84%E4%B8%BB%E6%9C%BA%E5%B8%A6%E6%9D%A5%E4%BA%86%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E5%85%B3%E4%BA%8Eweston%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E6%8C%89%E7%85%A7%E6%82%A8%E7%9A%84%E6%AD%A5%E9%AA%A4%E6%93%8D%E4%BD%9C%EF%BC%8C%E4%BD%86%E5%BD%93%E5%B0%9D%E8%AF%95%E6%89%A7%E8%A1%8Cweston%E6%97%B6%EF%BC%8C%E5%8D%B4%E5%BE%97%E5%88%B0%E4%BA%86%E8%BF%99%E6%A0%B7%E7%9A%84%E7%BB%93%E6%9E%9C%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3Esudo%20-E%20weston%20--tty%3D1%3CBR%20%2F%3E%5Bsudo%5D%20password%20for%20user%3A%3CBR%20%2F%3EDate%3A%202019-10-18%20UTC%3CBR%20%2F%3E%5B08%3A42%3A03.809%5D%20weston%205.0.0%3CBR%20%2F%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fwayland.freedesktop.org%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwayland.freedesktop.org%3C%2FA%3E%3CBR%20%2F%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Bug%20reports%20to%3A%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fgitlab.freedesktop.org%252Fwayland%252Fweston%252Fissues%252F%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgitlab.freedesktop.org%2Fwayland%2Fweston%2Fissues%2F%3C%2FA%3E%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Build%3A%205.0.0-33-gfb563901%20MGS-4627%20%5B%23ccc%5D%20weston%20will%20turn%20off%20when%20panel-psotion%3Dnone%20and%20use%20gplay%20(2019-03-14%2011%3A30%3A30%20%2B0800)%3CBR%20%2F%3E%5B08%3A42%3A03.816%5D%20Command%20line%3A%20weston%20--tty%3D1%3CBR%20%2F%3E%5B08%3A42%3A03.816%5D%20OS%3A%20Linux%2C%204.14.98-imx_4.14.98_2.0.0_ga%2Bg64ad07d%2C%20%231%20SMP%20PREEMPT%20Tue%20Aug%2013%2013%3A06%3A25%20UTC%202019%2C%20aarch64%3CBR%20%2F%3E%5B08%3A42%3A03.816%5D%20warning%3A%20XDG_RUNTIME_DIR%20%22%2Frun%2Fuser%2F1000%22%20is%20not%20configured%3CBR%20%2F%3Ecorrectly.%26nbsp%3B%20Unix%20access%20mode%20must%20be%200700%20(current%20mode%20is%20700)%2C%3CBR%20%2F%3Eand%20must%20be%20owned%20by%20the%20user%20(current%20owner%20is%20UID%201000).%3CBR%20%2F%3ERefer%20to%20your%20distribution%20on%20how%20to%20get%20it%2C%20or%3CBR%20%2F%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freedesktop.org%252Fwiki%252FSpecifications%252Fbasedir-spec%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freedesktop.org%2Fwiki%2FSpecifications%2Fbasedir-spec%3C%2FA%3E%3CBR%20%2F%3Eon%20how%20to%20implement%20it.%3CBR%20%2F%3E%5B08%3A42%3A03.826%5D%20Starting%20with%20no%20config%20file.%3CBR%20%2F%3E%5B08%3A42%3A03.839%5D%20Output%20repaint%20window%20is%2016%20ms%20maximum.%3CBR%20%2F%3E%5B08%3A42%3A03.845%5D%20Loading%20module%20'%2Fusr%2Flib%2Flibweston-5%2Fdrm-backend.so'%3CBR%20%2F%3E%5B08%3A42%3A03.952%5D%20initializing%20drm%20backend%3CBR%20%2F%3E%5B08%3A42%3A03.955%5D%20using%20%2Fdev%2Fdri%2Fcard0%3CBR%20%2F%3E%5B08%3A42%3A03.955%5D%20DRM%3A%20supports%20universal%20planes%3CBR%20%2F%3E%5B08%3A42%3A03.955%5D%20DRM%3A%20supports%20atomic%20modesetting%3CBR%20%2F%3E%5B08%3A42%3A03.955%5D%20DRM%3A%20does%20not%20support%20picture%20aspect%20ratio%3CBR%20%2F%3E%5B08%3A42%3A03.960%5D%20Loading%20module%20'%2Fusr%2Flib%2Flibweston-5%2Fgl-renderer.so'%3CBR%20%2F%3E%5B08%3A42%3A04.302%5D%20EGL%20client%20extensions%3A%20EGL_EXT_device_base%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20EGL_EXT_device_enumeration%20EGL_EXT_device_query%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20EGL_EXT_platform_base%20EGL_KHR_client_get_all_proc_addresses%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20EGL_EXT_client_extensions%20EGL_KHR_debug%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20EGL_EXT_platform_wayland%20EGL_EXT_platform_x11%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20EGL_MESA_platform_gbm%20EGL_MESA_platform_surfaceless%3CBR%20%2F%3E%5B08%3A42%3A04.304%5D%20failed%20to%20initialize%20display%3CBR%20%2F%3E%5B08%3A42%3A04.304%5D%20EGL%20error%20state%3A%20EGL_NOT_INITIALIZED%20(0x3001)%3CBR%20%2F%3E%5B08%3A42%3A04.304%5D%20failed%20to%20initialize%20egl%3CBR%20%2F%3E%5B08%3A42%3A04.341%5D%20fatal%3A%20failed%20to%20create%20compositor%20backend%3C%2FP%3E%3C%2FBLOCKQUOTE%3EHave%20you%20ever%20seen%20a%20similar%20error%20message%3F%20%3CBR%20%2F%3EThank%20you.%20%3CBR%20%2F%3E%3CBR%20%2F%3ERegards%2C%3CBR%20%2F%3ELorenzo%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128726%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128726%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%89%A7%E8%A1%8C%E4%BB%A5%E4%B8%8B%3CSTRONG%3Emake%3C%2FSTRONG%3E%E5%91%BD%E4%BB%A4%E6%97%B6%EF%BC%8C%E6%88%91%E6%94%B6%E5%88%B0%E5%85%B3%E4%BA%8E%3CSTRONG%3Eweston-imx%3C%2FSTRONG%3E%E7%9A%84%E5%A4%B4%E6%96%87%E4%BB%B6%E5%A3%B0%E6%98%8E%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E4%BB%8E%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E8%8E%B7%E5%8F%96weston%E7%9A%84%E5%A4%B4%E6%96%87%E4%BB%B6%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23cd%20~%2Fweston%3CBR%20%2F%3E%3CSPAN%3E%23git%20clone%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fsource.codeaurora.org%252Fexternal%252Fimx%252Fweston-imx.git%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Fweston-imx.git%3C%2FA%3E%3CBR%20%2F%3E%23cd%20weston-imx%3CBR%20%2F%3E%23git%20checkout%20fb563901657b296c7c7c86d26602a622429e334f%3CBR%20%2F%3E%23.%2Fautogen.sh%20--prefix%3D%2Fusr%20--disable-silent-rules%20--disable-dependency-tracking%26nbsp%3B%20--enable-setuid-install%20--disable-rdp-compositor%20--enable-clients%20--enable-simple-clients%20--enable-demo-clients-install%20--disable-colord%20--enable-egl%20--enable-simple-egl-clients%20--enable-fbdev-compositor%20--disable-headless-compositor%20--enable-drm-compositor%20--enable-weston-launch%20--disable-lcms%20--disable-libunwind%20--with-pam--disable-vaapi-recorder%20--enable-wayland-compositor%20--without-webp%20--disable-x11-compositor%20--enable-xwayland%20--enable-imxg2d%20--enable-imxgpu%20--enable-drm-compositor%20--enable-opengl%3CBR%20%2F%3E%23make%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3Elibweston%2Fcompositor-drm.c%3A%20In%20function%20%E2%80%98drm_fb_addfb%E2%80%99%3A%3CBR%20%2F%3Elibweston%2Fcompositor-drm.c%3A962%3A23%3A%20%3CSTRONG%3Eerror%3A%20%E2%80%98DRM_FORMAT_MOD_AMPHION_TILED%E2%80%99%20undeclared%3C%2FSTRONG%3E%20(first%20use%20in%20this%20function)%3B%20did%20you%20mean%20%E2%80%98DRM_FORMAT_MOD_VIVANTE_TILED%E2%80%99%3F%3CBR%20%2F%3E%20if%20(fb-%26gt%3Bmodifier%20%3D%3D%20DRM_FORMAT_MOD_AMPHION_TILED)%20%7B%3CBR%20%2F%3EDRM_FORMAT_MOD_VIVANTE_TILED%3CBR%20%2F%3Elibweston%2Fcompositor-drm.c%3A962%3A23%3A%20note%3A%20each%20undeclared%20identifier%20is%20reported%20only%20once%20for%20each%20function%20it%20appears%20in%3CBR%20%2F%3Elibweston%2Fcompositor-drm.c%3A%20In%20function%20%E2%80%98drm_clip_overlay_coordinate%E2%80%99%3A%3CBR%20%2F%3Elibweston%2Fcompositor-drm.c%3A1518%3A36%3A%20warning%3A%20comparison%20between%20signed%20and%20unsigned%20integer%20expressions%20%5B-Wsign-compare%5D%3CBR%20%2F%3E%20if%20(state-%26gt%3Bdest_x%20%2B%20state-%26gt%3Bdest_w%20%26gt%3B%20output-%26gt%3Bbase.current_mode-%26gt%3Bwidth)%7B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3Elibweston%2Fcompositor-drm.c%3A1526%3A36%3A%20warning%3A%20comparison%20between%20signed%20and%20unsigned%20integer%20expressions%20%5B-Wsign-compare%5D%3CBR%20%2F%3E%20if%20(state-%26gt%3Bdest_y%20%2B%20state-%26gt%3Bdest_h%20%26gt%3B%20output-%26gt%3Bbase.current_mode-%26gt%3Bheight)%7B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3Elibweston%2Fcompositor-drm.c%3A%20In%20function%20%E2%80%98drm_get_gbm_alignment%E2%80%99%3A%3CBR%20%2F%3Elibweston%2Fcompositor-drm.c%3A2184%3A9%3A%20%3CSTRONG%3Eerror%3A%20%E2%80%98DRM_FORMAT_MOD_VIVANTE_SUPER_TILED_FC%E2%80%99%20undeclared%3C%2FSTRONG%3E%20(first%20use%20in%20this%20function)%3B%20did%20you%20mean%20%E2%80%98DRM_FORMAT_MOD_VIVANTE_SUPER_TILED%E2%80%99%3F%3CBR%20%2F%3E%20case%20DRM_FORMAT_MOD_VIVANTE_SUPER_TILED_FC%3A%3CBR%20%2F%3EDRM_FORMAT_MOD_VIVANTE_SUPER_TILED%3CBR%20%2F%3Elibweston%2Fcompositor-drm.c%3A%20In%20function%20%E2%80%98drm_output_apply_state_atomic%E2%80%99%3A%3CBR%20%2F%3Elibweston%2Fcompositor-drm.c%3A2600%3A4%3A%20warning%3A%20implicit%20declaration%20of%20function%20%E2%80%98gbm_surface_set_sync_post%E2%80%99%3B%20did%20you%20mean%20%E2%80%98gbm_surface_destroy%E2%80%99%3F%20%5B-Wimplicit-function-declaration%5D%3CBR%20%2F%3E%20gbm_surface_set_sync_post(output-%26gt%3Bgbm_surface%2C%200)%3B%3CBR%20%2F%3Egbm_surface_destroy%3CBR%20%2F%3Elibweston%2Fcompositor-drm.c%3A2601%3A18%3A%20warning%3A%20implicit%20declaration%20of%20function%20%E2%80%98gbm_surface_get_in_fence_fd%E2%80%99%3B%20did%20you%20mean%20%E2%80%98wl_surface_send_enter%E2%80%99%3F%20%5B-Wimplicit-function-declaration%5D%3CBR%20%2F%3E%20in_fence_fd%20%3D%20gbm_surface_get_in_fence_fd(output-%26gt%3Bgbm_surface)%3B%3CBR%20%2F%3Ewl_surface_send_enter%3CBR%20%2F%3Elibweston%2Fcompositor-drm.c%3A%20In%20function%20%E2%80%98drm_query_dmabuf_modifiers%E2%80%99%3A%3CBR%20%2F%3Elibweston%2Fcompositor-drm.c%3A3291%3A49%3A%20warning%3A%20comparison%20between%20signed%20and%20unsigned%20integer%20expressions%20%5B-Wsign-compare%5D%3CBR%20%2F%3E%20if%20(p-%26gt%3Bformats%5Bi%5D.format%20!%3D%20format)%3CBR%20%2F%3Elibweston%2Fcompositor-drm.c%3A%20In%20function%20%E2%80%98drm_import_dmabuf%E2%80%99%3A%3CBR%20%2F%3Elibweston%2Fcompositor-drm.c%3A3342%3A37%3A%20%3CSTRONG%3Eerror%3A%20%E2%80%98DRM_FORMAT_P010%E2%80%99%20undeclared%3C%2FSTRONG%3E%20(first%20use%20in%20this%20function)%3B%20did%20you%20mean%20%E2%80%98DRM_FORMAT_R16%E2%80%99%3F%3CBR%20%2F%3E%20%26amp%3B%26amp%3B%20dmabuf-%26gt%3Battributes.format%20%3D%3D%20DRM_FORMAT_P010)%3CBR%20%2F%3EDRM_FORMAT_R16%3CBR%20%2F%3Elibweston%2Fcompositor-drm.c%3A%20In%20function%20%E2%80%98drm_output_propose_state%E2%80%99%3A%3CBR%20%2F%3Elibweston%2Fcompositor-drm.c%3A3752%3A38%3A%20%3CSTRONG%3Eerror%3A%20%E2%80%98DRM_FORMAT_P010%E2%80%99%20undeclared%3C%2FSTRONG%3E%20(first%20use%20in%20this%20function)%3B%20did%20you%20mean%20%E2%80%98DRM_FORMAT_R16%E2%80%99%3F%3CBR%20%2F%3E%20%7C%7C%20dmabuf-%26gt%3Battributes.format%20%3D%3D%20DRM_FORMAT_P010%3CBR%20%2F%3EDRM_FORMAT_R16%3CBR%20%2F%3Elibweston%2Fcompositor-drm.c%3A%20In%20function%20%E2%80%98hdr10_metadata_set_metadata%E2%80%99%3A%3CBR%20%2F%3Elibweston%2Fcompositor-drm.c%3A7250%3A29%3A%20%3CSTRONG%3Eerror%3A%20storage%20size%20of%20%E2%80%98hdr_metadata%E2%80%99%20isn%E2%80%99t%20known%3C%2FSTRONG%3E%3CBR%20%2F%3E%20struct%20hdr_static_metadata%20hdr_metadata%3B%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3CBR%20%2F%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3CP%3EPrashanth%20Kumar%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3C%2FP%3E%3CP%3E%E5%9C%A8qemu%E7%8E%AF%E5%A2%83%E4%B8%AD%3CSTRONG%3E%E6%9E%84%E5%BB%BAweston%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3EGnar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%8F%82%E8%80%83%26nbsp%3B%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F343939-3-454211%2FUbuntu-i.MX8-weston.pdf%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F343939-3-454211%2FUbuntu-i.MX8-weston.pdf%26nbsp%3B%3C%2FA%3E%26nbsp%3B%E6%96%87%E6%A1%A3%EF%BC%8C%E5%B0%86Ubuntu%2018.04%E7%A7%BB%E6%A4%8D%E5%88%B0%E5%9F%BA%E4%BA%8E4.14.98%20BSP%E7%9A%84iMX8%20Quad%20Max%E5%AE%9A%E5%88%B6%E5%BC%80%E5%8F%91%E6%9D%BF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%E7%9B%B4%E5%88%B0%E4%B8%8A%E8%BF%B0%E6%96%87%E6%A1%A3%E4%B8%AD%E7%9A%84%3CSTRONG%3E%E7%AC%AC9%E8%8A%82%E2%80%9C%E5%A4%8D%E5%88%B6imx-gpu-viv%E2%80%9D%3C%2FSTRONG%3E%26nbsp%3B%E6%89%8D%E8%83%BD%26nbsp%3B%E6%AD%A3%E7%A1%AE%E7%90%86%E8%A7%A3%E3%80%82%E4%BD%86%E5%9C%A8%3CSTRONG%3E%E7%AC%AC10%E8%8A%82%E2%80%9C%E6%9E%84%E5%BB%BAWeston%E2%80%9D%3C%2FSTRONG%3E%E4%B9%8B%E5%90%8E%EF%BC%8C%26nbsp%3B%E5%B9%B6%E6%B2%A1%E6%9C%89%E8%AF%B4%E6%98%8E%E9%9C%80%E8%A6%81%E5%9C%A8%E5%93%AA%E9%87%8C%E6%9E%84%E5%BB%BA%26nbsp%3Bweston%2C%26nbsp%3Bwayland%2C%20gstreamer%20and%20gst-plugins%EF%BC%9F%E5%A6%82%E4%BD%95%E5%B0%86%E4%B8%8A%E8%BF%B0%26nbsp%3B%E5%8A%9F%E8%83%BD%E4%B8%8E%E2%80%9C%3CSTRONG%3Eubuntu-rootfs%3C%2FSTRONG%3E%E2%80%9D%E5%85%B3%E8%81%94%2F%E6%B7%BB%E5%8A%A0%26nbsp%3B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3EPrashanth%20Kumar%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128721%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128721%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%80%E7%A7%8D%E7%AE%80%E5%8D%95%E7%9A%84%E6%96%B9%E6%B3%95%E6%98%AF%E4%B8%8B%E8%BD%BDlinux-imx%26nbsp%3B%EF%BC%88%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Flinux-imx%2F%22%20title%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Flinux-imx%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Elinux-imx%20-%20i.MX%20Linux%E5%86%85%E6%A0%B8%EF%BC%89%3C%2FA%3E%26nbsp%3B%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BD%BF%E7%94%A8%E5%91%BD%E4%BB%A4%E2%80%9C%24%20make%20defconfig%EF%BC%8C%26nbsp%3B%24%20make%E2%80%9D%E6%9D%A5%E6%9E%84%E5%BB%BA%E9%95%9C%E5%83%8F%E3%80%82%3C%2FP%3E%3CP%3E%E7%94%A8%E8%BF%99%E4%B8%AA%E9%95%9C%E5%83%8F%E6%9B%BF%E6%8D%A2%E4%BD%A0%E5%BD%93%E5%89%8D%E7%9A%84%E9%95%9C%E5%83%8F%E5%8D%B3%E5%8F%AF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3EGnar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%E6%82%A8%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E5%A6%82%E4%BD%95%E5%8D%95%E7%8B%AC%E7%BC%96%E8%AF%91%E5%86%85%E6%A0%B8%E5%90%97%EF%BC%9F%E6%88%91%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E6%96%B9%E6%B3%95%E6%9D%A5%E5%AE%9E%E7%8E%B0%EF%BC%9A%3C%2FP%3E%3CP%3Ebitbake%20-c%20compile%20-f%20-v%20linux-imx%26nbsp%3B%3CBR%20%2F%3Ebitbake%20linux-imx%20-c%20compile_kernelmodules%20-f%20-v%3CBR%20%2F%3Ebitbake%20-c%20deploy%20-f%20-v%20linux-imx%20%26nbsp%3B%3C%2FP%3E%3CP%3Eresult%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20637px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F84926i2FE987F365C30814%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%B8%8E%E4%B9%8B%E5%89%8D%E8%BF%9B%E8%A1%8C%E6%AF%94%E8%BE%83%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F84984i550C72CDFC021B7E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Egalcore%20%E4%BD%BF%E7%94%A8%E4%BA%86%E4%B8%8D%E5%90%8C%E7%9A%84%E6%95%B0%E5%AD%97%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%B2%A1%E6%9C%89%20qca6174%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E5%B7%B2%E7%BB%8F%E6%B7%BB%E5%8A%A0%E4%BA%86%E8%AE%B8%E5%A4%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E5%AE%83%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128719%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128719%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20gao%3C%2FP%3E%3CP%3E%E5%9B%A0%E4%B8%BA%E5%9C%A8%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8CGPU%E9%A9%B1%E5%8A%A8%E8%BF%9B%E7%A8%8B%26nbsp%3Bgalcore%E6%98%AF%E4%BB%A5.ko%E6%96%87%E4%BB%B6%E7%BC%96%E8%AF%91%E7%9A%84%EF%BC%8C%E6%89%80%E4%BB%A5%E9%9C%80%E8%A6%81%E5%8D%95%E7%8B%AC%E7%BC%96%E8%AF%91%E5%86%85%E6%A0%B8%E6%89%8D%E8%83%BD%E5%B0%86galcore%E5%8A%A0%E5%85%A5%E5%86%85%E6%A0%B8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3EGnar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128717%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128717%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2CAnrit%3C%2FP%3E%3CP%3E1.%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%9C%A8yocto%E4%B8%AD%EF%BC%8Cimx-dpu-2d%E7%9A%84%E8%B7%AF%E5%BE%84%E6%98%AF%26nbsp%3B%2Fbuildxwayland%2Ftmp%2Fwork%2Faarch64-mx8mm-poky-linux%2Fimx-gpu-g2d%26nbsp%3B%EF%BC%8C8MM%20%E6%B2%A1%E6%9C%89DPU%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E2.%20%26nbsp%3B%E8%BF%94%E5%9B%9E%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%22%3E.%2Fautogen.sh%20--prefix%3D%2Fusr%20--disable-silent-rules%20--disable-dependency-tracking%20--enable-setuid-install%20--disable-rdp-compositor%20--enable-clients%20--enable-simple-clients%20--enable-demo-clients-install%20--disable-colord%20--enable-egl%20--enable-simple-egl-clients%20--enable-fbdev-compositor%20--disable-headless-compositor%20--enable-drm-compositor%20--enable-weston-launch%20--disable-lcms%20--disable-libunwind%20--with-pam%20--disable-vaapi-recorder%20--enable-wayland-compositor%20--without-webp%20--disable-x11-compositor%20--disable-xwayland%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%22%3E%E9%94%99%E8%AF%AF%E6%97%A5%E5%BF%97%E6%98%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%22%3E1%EF%BC%89configure%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%82%A8%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20--build%E3%80%81--host%E3%80%81--target%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%22%3E2%EF%BC%89%3CSPAN%3E%E6%A3%80%E6%9F%A5%E6%9E%84%E5%BB%BA%E7%B3%BB%E7%BB%9F%E7%B1%BB%E5%9E%8B%E2%80%A6%E9%85%8D%E7%BD%AE%E6%97%A0%E6%95%88%E2%80%9C%E5%AE%A2%E6%88%B7%E7%AB%AF%E2%80%9D%EF%BC%9A%E6%9C%AA%E8%AF%86%E5%88%AB%E6%9C%BA%E5%99%A8%E2%80%9C%E5%AE%A2%E6%88%B7%E7%AB%AF%E2%80%9D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%9C%A8qemu%E7%8E%AF%E5%A2%83%E4%B8%AD%E6%9E%84%E5%BB%BA%E7%9A%84%E5%90%97%EF%BC%9F%E6%88%91%E5%9C%A8%E6%93%8D%E4%BD%9C%E8%BF%87%E7%A8%8B%E4%B8%AD%E6%B2%A1%E6%9C%89%E9%81%87%E5%88%B0%E4%BB%BB%E4%BD%95%E9%94%99%E8%AF%AF%EF%BC%8C%E4%B9%9F%E6%B2%A1%E6%9C%89%E8%AE%BE%E7%BD%AE%E4%BB%BB%E4%BD%95%26nbsp%3B%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%E3%80%82%E5%B0%9D%E8%AF%95%E5%9C%A8google%E4%B8%8A%E6%90%9C%E7%B4%A2%E5%A6%82%E4%BD%95%E6%9E%84%E5%BB%BAweston%EF%BC%8C%E6%A0%B9%E6%8D%AE%E6%97%A5%E5%BF%97%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%B7%BB%E5%8A%A0%E5%85%B3%E4%BA%8E%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E--build%E3%80%81--host%E3%80%81--target%3C%2FSPAN%3E%E7%9A%84%E5%8F%82%E6%95%B0%E3%80%82%3C%2FP%3E%3CP%3E%E7%AC%AC%E4%BA%8C%E4%B8%AA%E5%91%BD%E4%BB%A4%EF%BC%8C%E9%A6%96%E5%85%88%E5%B0%9D%E8%AF%95%E7%A6%81%E7%94%A8%20xwayland%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%22%3EXwayland%20%E5%B9%B6%E9%9D%9E%E5%BF%85%E8%A6%81%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%22%3EBR%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23000000%3B%22%3EGnar%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Gnar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%E6%8C%89%E7%85%A7%E4%BD%A0%E7%9A%84%E6%96%87%E6%A1%A3%E6%93%8D%E4%BD%9C%E5%90%8E%EF%BC%8C%E6%88%91%E8%A7%89%E5%BE%97%E8%87%AA%E5%B7%B1%E5%B7%B2%E7%BB%8F%E9%9D%9E%E5%B8%B8%E6%8E%A5%E8%BF%91%E6%88%90%E5%8A%9F%E6%9E%84%E5%BB%BA%20Ubuntu%20%E7%B3%BB%E7%BB%9F%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E6%9C%89%E8%BF%99%E4%BA%9B%E5%89%A9%E4%BD%99%E7%9A%84%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3CP%3E1.%E6%88%91%E5%9C%A8yocto%E6%9E%84%E5%BB%BA%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E6%B2%A1%E6%9C%89%E7%9C%8B%E5%88%B0%E4%BB%BB%E4%BD%95%E5%90%8D%E4%B8%BA%26nbsp%3Bimx-dpu-2d%E7%9A%84%E5%86%85%E5%AE%B9%E3%80%82%26nbsp%3B%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8%E6%82%A8%E7%9A%84%E6%96%87%E6%A1%A3%E4%B8%AD%E8%BF%90%E8%A1%8C%E6%AD%A4%E6%AD%A5%E9%AA%A4%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Esudo%20cp%20-Pra%20imx-dpu-g2d-1.7.0%2Fimx-dpu-g2d%2F1.7.0-r0%2Fimage%2F*%20ubuntu18.04%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%88%91%E7%9A%84%20DISTRO%20%E6%98%AF%20fsl-imx-xwayland%EF%BC%8CMACHINE%20%E6%98%AF%20imx8mmevk%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E2.%3C%2FSPAN%3E.%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E6%82%A8%E5%9C%A8%E4%B8%8A%E4%B8%80%E7%AF%87%E6%96%87%E7%AB%A0%E4%B8%AD%E6%8F%90%E5%88%B0%E7%9A%84%E6%96%B0%E7%9A%84weston-imx%20autogen%E6%AD%A5%E9%AA%A4%EF%BC%8C%E4%BD%86%E5%AE%83%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E6%9E%84%E5%BB%BA%E3%80%82%E6%88%91%E7%8E%B0%E5%9C%A8%E5%9C%A8autogen%E6%AD%A5%E9%AA%A4%E4%B8%AD%E9%81%87%E5%88%B0%E4%B8%8D%E5%90%8C%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%E6%97%A5%E5%BF%97%EF%BC%9A%3C%2FP%3E%3CP%3E.........................%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eroot%40UB160401%3A~%2Fweston%2Fweston-imx%23%20.%2Fautogen.sh%20--prefix%3D%2Fusr%20--disable-silent-rules%20--disable-dependency-tracking%20--enable-setuid-install%20--disable-rdp-compositor%20--enable-clients%20--enable-simple-clients%20--enable-demo-clients-install%20--disable-colord%20--enable-egl%20--enable-simple-egl-clients%20--enable-fbdev-compositor%20--disable-headless-compositor%20--enable-drm-compositor%20--enable-weston-launch%20--disable-lcms%20--disable-libunwind%20--with-pam%20--disable-vaapi-recorder%20--enable-wayland-compositor%20--without-webp%20--disable-x11-compositor%20--enable-xwayland%20--enable-imxg2d%20--enable-imxgpu%20--enable-drm-compositor%20--enable-opengl%3C%2FSPAN%3E....%3C%2FP%3E%3CP%3E..................%3C%2FP%3E%3CP%3E.................%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Echecking%20for%20OPENGL...%20yes%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5GL_RENDERER...%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5XKBCOMMON_COMPOSE...%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%AD%A3%E5%9C%A8%E6%A3%80%E6%9F%A5%20XWAYLAND...%20%E6%B2%A1%E6%9C%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E9%85%8D%E7%BD%AE%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E6%9C%AA%E6%BB%A1%E8%B6%B3%E8%BD%AF%E4%BB%B6%E5%8C%85%E8%A6%81%E6%B1%82%EF%BC%88xcb%20xcb-xfixes%20xcb-composite%20xcb-shape%20xcursor%20cairo-xcb%EF%BC%89%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%9C%AA%E6%89%BE%E5%88%B0%E8%BD%AF%E4%BB%B6%E5%8C%85%E2%80%9Cxcb-xfixes%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%9C%AA%E6%89%BE%E5%88%B0%E5%8C%85%E2%80%9Cxcb-composite%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%9C%AA%E6%89%BE%E5%88%B0%E8%BD%AF%E4%BB%B6%E5%8C%85%E2%80%9Cxcb-shape%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%9C%AA%E6%89%BE%E5%88%B0%E5%8C%85%E2%80%9Cxcursor%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E5%A6%82%E6%9E%9C%E9%9C%80%E8%A6%81%EF%BC%8C%E8%AF%B7%E8%80%83%E8%99%91%E8%B0%83%E6%95%B4PKG_CONFIG_PATH%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E5%9C%A8%E9%9D%9E%E6%A0%87%E5%87%86%E5%89%8D%E7%BC%80%E4%B8%AD%E5%AE%89%E8%A3%85%E4%BA%86%E8%BD%AF%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%88%96%E8%80%85%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%AE%BE%E7%BD%AE%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8FXWAYLAND_CFLAGS%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E5%92%8C%20XWAYLAND_LIBS%20%E4%BB%A5%E9%81%BF%E5%85%8D%E9%9C%80%E8%A6%81%E8%B0%83%E7%94%A8%20pkg-config%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E8%A6%81%E4%BA%86%E8%A7%A3%E6%9B%B4%E5%A4%9A%E8%AF%A6%E6%83%85%EF%BC%8C%E8%AF%B7%E5%8F%82%E8%A7%81pkg-config%E6%89%8B%E5%86%8C%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%82%A8%E6%9C%89%E4%BB%80%E4%B9%88%E5%BB%BA%E8%AE%AE%E5%90%97%EF%BC%9F%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E5%A4%AA%E6%84%9F%E8%B0%A2%E4%BA%86%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EAmrit%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CGnar%20%E5%92%8C%20Kyle%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%BE%88%E9%AB%98%E5%85%B4%E7%9C%8B%E5%88%B0%E6%9C%89%E4%B8%8D%E6%AD%A2%E4%B8%80%E4%B8%AA%E4%BA%BA%E5%9C%A8%E5%8F%82%E4%B8%8E%E8%BF%99%E4%B8%AA%E9%A1%B9%E7%9B%AE%E3%80%82%E9%A6%96%E5%85%88%EF%BC%8C%E6%84%9F%E8%B0%A2Gnar%E5%88%9B%E5%BB%BA%E8%BF%99%E4%BA%9B%E6%96%87%E6%A1%A3%E5%B9%B6%E6%A6%82%E8%BF%B0%E4%BA%86%E5%85%B3%E9%94%AE%E6%AD%A5%E9%AA%A4%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%87%AF%E5%B0%94%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E9%80%90%E4%B8%80%E6%9F%A5%E6%89%BE%E5%B9%B6%E5%AE%9A%E4%BD%8D%E4%BA%86%E6%89%80%E6%9C%89%E9%9C%80%E8%A6%81%E4%BB%8E%20Yocto%20%E6%9E%84%E5%BB%BA%E6%96%87%E4%BB%B6%E5%A4%B9%E5%A4%8D%E5%88%B6%E5%88%B0%20~%2Frootfs%2Fubuntu-rootfs%EF%BC%88%E6%88%96%20~%2Frootfs%2Fubuntu18.04%EF%BC%89%E7%9A%84%E6%96%87%E4%BB%B6%E5%A4%B9%E3%80%82%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%AF%8F%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%E7%9A%84%E6%BA%90%E6%96%87%E4%BB%B6%E5%A4%B9%E5%90%8D%E7%A7%B0%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Ecd%20~%2Fimx-yocto-bsp%2Fbuild%2Ftmp%2Fwork%2Faarch64-mx8mm-poky-linux%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Esudo%20cp%20-Pra%20libdrm%2F2.4.91.imx-r0%2Fimage%2F*%20%3CSPAN%3E~%2Frootfs%2Fubuntu-rootfs%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Esudo%20cp%20-Pra%20imx-gpu-viv%2F1_6.2.4.p4.0-aarch64-r0%2Fimage%2F*%20~%2Frootfs%2Fubuntu-rootfs%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Esudo%20cp%20-Pra%20~%2Fimx-yocto-bsp%2Fbuild%2Ftmp%2Fwork%2Faarch64-mx8mm-poky-linux%2Fimx-gpu-g2d%2F6.2.4.p4.0-r0%2Fimage%2F*%20~%2Frootfs%2Fubuntu-rootfs%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Ecd%20~%2Fimx-yocto-bsp%2Fbuild%2Ftmp%2Fwork%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Esudo%20cp%20-r%20all-poky-linux%2Ffirmware-imx%2F1_8.1-r0%2Fimage%2F*%20~%2Frootfs%2Fubuntu-rootfs%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E5%9C%A8%E6%88%91%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8Crootfs%20%E6%96%87%E4%BB%B6%E5%A4%B9%E6%98%AF%20~%2Frootfs%2Fubuntu-rootfs%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EGnar%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8Gnome%E6%88%96xfce4%E4%BB%A5%E5%9F%BA%E6%9C%AC%E5%BD%A2%E5%BC%8F%E8%BF%90%E8%A1%8Cubuntu18.04%EF%BC%8C%E4%BD%86%E4%BB%8D%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%B0%86%E6%89%80%E6%9C%89%E7%BB%84%E4%BB%B6%E6%94%BE%E5%88%B0rootfs%E4%B8%AD%E3%80%82%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0weston-imx%E5%9C%A8%E7%AC%AC3%E6%AD%A5%E4%B8%AD%E5%87%BA%E7%8E%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E5%A5%87%E6%80%AA%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E5%9C%A8%E8%BF%90%E8%A1%8C%20weston-imx%20%E7%9A%84%20autogen%20%E6%97%B6%E7%9A%84%E9%94%99%E8%AF%AF%E6%97%A5%E5%BF%97%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eroot%40UB160401%3A~%2Fweston%2Fweston-imx%23%20.%2Fautogen.sh%20--prefix%3D%2Fusr%20--disable-silent-rules%20--disable-dependency-tracking%20--enable-setuid-install%20--disable-rdp-compositor%20--enable-clients%20--enable-simple-clients%20--enable-demo-clients-install%20--disable-colord%20--enable-egl%20--enable-simple-egl-clients%20--enable-fbdev-compositor%20--disable-headless-compositor%20--enable-drm-compositor%20--enable-weston-launch%20--disable-lcms%20--disable-libunwind%20--with-pam%20--disable-vaapi-recorder%20--enable-wayland-compositor%20--without-webp%20--disable-x11-compositor%20--disable-xwayland%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eautoreconf%EF%BC%9A%E8%BF%9B%E5%85%A5%E7%9B%AE%E5%BD%95%60.'%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eautoreconf%3A%20configure.ac%3A%20not%20using%20Gettext%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eautoreconf%EF%BC%9A%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%EF%BC%9Aaclocal%20--force%20-I%20m4%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eautoreconf%3A%20configure.ac%3A%20tracing%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eautoreconf%EF%BC%9A%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%EF%BC%9Alibtoolize%20--copy%20--force%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Elibtoolize%EF%BC%9A%E5%B0%86%E8%BE%85%E5%8A%A9%E6%96%87%E4%BB%B6%E6%94%BE%E5%85%A5%20AC_CONFIG_AUX_DIR%EF%BC%8C%E2%80%98build-aux%E2%80%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Elibtoolize%EF%BC%9A%E5%A4%8D%E5%88%B6%E6%96%87%E4%BB%B6%E2%80%9Cbuild-aux%2Fltmain.sh%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Elibtoolize%EF%BC%9A%E5%B0%86%E5%AE%8F%E6%94%BE%E5%85%A5%20AC_CONFIG_MACRO_DIRS%EF%BC%8C%E2%80%9Cm4%E2%80%9D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Elibtoolize%EF%BC%9A%E5%A4%8D%E5%88%B6%E6%96%87%E4%BB%B6%E2%80%9Cm4%2Flibtool.m4%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Elibtoolize%EF%BC%9A%E5%A4%8D%E5%88%B6%E6%96%87%E4%BB%B6%E2%80%9Cm4%2Fltoptions.m4%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Elibtoolize%EF%BC%9A%E5%A4%8D%E5%88%B6%E6%96%87%E4%BB%B6%E2%80%9Cm4%2Fltsugar.m4%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Elibtoolize%EF%BC%9A%E5%A4%8D%E5%88%B6%E6%96%87%E4%BB%B6%20'm4%2Fltversion.m4'%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Elibtoolize%EF%BC%9A%E5%A4%8D%E5%88%B6%E6%96%87%E4%BB%B6%E2%80%9Cm4%2Flt~obsolete.m4%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eautoreconf%EF%BC%9A%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%EF%BC%9A%2Fusr%2Fbin%2Fautoconf%20--force%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eautoreconf%EF%BC%9A%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%EF%BC%9A%2Fusr%2Fbin%2Fautoheader%20--force%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eautoreconf%EF%BC%9A%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%EF%BC%9Aautomake%20--add-missing%20--copy%20--force-missing%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Econfigure.ac%3A35%EF%BC%9A%E5%AE%89%E8%A3%85%E2%80%9Cbuild-aux%2Fcompile%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Econfigure.ac%3A43%EF%BC%9A%E5%AE%89%E8%A3%85%E2%80%9Cbuild-aux%2Fmissing%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EMakefile.am%3A%20installing%20'build-aux%2Fdepcomp'%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Eautoreconf%3A%20Leaving%20directory%20%60.'%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E9%85%8D%E7%BD%AE%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%82%A8%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20--build%E3%80%81--host%E3%80%81--target%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E9%85%8D%E7%BD%AE%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%82%A8%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20--build%E3%80%81--host%E3%80%81--target%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E9%85%8D%E7%BD%AE%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%82%A8%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20--build%E3%80%81--host%E3%80%81--target%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E9%85%8D%E7%BD%AE%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%82%A8%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20--build%E3%80%81--host%E3%80%81--target%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E9%85%8D%E7%BD%AE%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%82%A8%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20--build%E3%80%81--host%E3%80%81--target%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E9%85%8D%E7%BD%AE%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%82%A8%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20--build%E3%80%81--host%E3%80%81--target%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E9%85%8D%E7%BD%AE%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%82%A8%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20--build%E3%80%81--host%E3%80%81--target%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E9%85%8D%E7%BD%AE%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%82%A8%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20--build%E3%80%81--host%E3%80%81--target%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E9%85%8D%E7%BD%AE%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%82%A8%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20--build%E3%80%81--host%E3%80%81--target%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E9%85%8D%E7%BD%AE%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%82%A8%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20--build%E3%80%81--host%E3%80%81--target%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E9%85%8D%E7%BD%AE%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%82%A8%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20--build%E3%80%81--host%E3%80%81--target%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E9%85%8D%E7%BD%AE%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%82%A8%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20--build%E3%80%81--host%E3%80%81--target%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Econfigure%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%9C%AA%E8%AF%86%E5%88%AB%E7%9A%84%E9%80%89%E9%A1%B9%EF%BC%9A--enable-simple-%EF%BC%8C--enable-%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5%E5%AE%A2%E6%88%B7%E7%AB%AF%20-%20gcc...%E5%90%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5%20gcc...%20gcc%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5C%E7%BC%96%E8%AF%91%E5%99%A8%E6%98%AF%E5%90%A6%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C...%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%AD%A3%E5%9C%A8%E6%A3%80%E6%9F%A5%20C%20%E7%BC%96%E8%AF%91%E5%99%A8%E7%9A%84%E9%BB%98%E8%AE%A4%E8%BE%93%E5%87%BA%E6%96%87%E4%BB%B6%E5%90%8D...%20a.out%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Echecking%20for%20suffix%20of%20executables...%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5%E6%88%91%E4%BB%AC%E6%98%AF%E5%90%A6%E5%9C%A8%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91%E2%80%A6%E5%90%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5%E5%AF%B9%E8%B1%A1%E6%96%87%E4%BB%B6%E5%90%8E%E7%BC%80...o%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5%E6%98%AF%E5%90%A6%E4%BD%BF%E7%94%A8GNU%20C%E7%BC%96%E8%AF%91%E5%99%A8...%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5gcc%E6%98%AF%E5%90%A6%E6%8E%A5%E5%8F%97-g...%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5gcc%E9%80%89%E9%A1%B9%E4%BB%A5%E6%8E%A5%E5%8F%97ISO%20C89...%E4%B8%8D%E9%9C%80%E8%A6%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5gcc%E6%98%AF%E5%90%A6%E5%90%8C%E6%97%B6%E7%90%86%E8%A7%A3-c%E5%92%8C-o%E2%80%A6%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Echecking%20how%20to%20run%20the%20C%20preprocessor...%20gcc%20-E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%AD%A3%E5%9C%A8%E6%A3%80%E6%9F%A5%E8%83%BD%E5%A4%9F%E5%A4%84%E7%90%86%E9%95%BF%E8%A1%8C%E5%92%8C%20-e%20%E7%9A%84%20grep...%20%2Fbin%2Fgrep%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5%20egrep...%20%2Fbin%2Fgrep%20-E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Echecking%20for%20ANSI%20C%20header%20files...%20yes%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5sys%2Ftypes.h...%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5sys%2Fstat.h...%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5stdlib.h...%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5string.h...%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5memory.h...%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5strings.h...%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5inttypes.h...%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Echecking%20for%20stdint.h...%20yes%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Echecking%20for%20unistd.h...%20yes%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5minix%2Fconfig.h%E6%98%AF%E5%90%A6%E5%8F%AF%E7%94%A8%E2%80%A6%E5%90%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5minix%2Fconfig.h%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E2%80%A6%E5%90%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5minix%2Fconfig.h...%E5%90%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Echecking%20whether%20it%20is%20safe%20to%20define%20__EXTENSIONS__...%20yes%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5%E5%A4%A7%E6%96%87%E4%BB%B6%E6%89%80%E9%9C%80%E7%9A%84%E7%89%B9%E6%AE%8AC%E7%BC%96%E8%AF%91%E5%99%A8%E9%80%89%E9%A1%B9...%20%E5%90%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5%E5%A4%A7%E6%96%87%E4%BB%B6%E6%89%80%E9%9C%80%E7%9A%84_FILE_OFFSET_BITS%E5%80%BC...%E5%90%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5sys%2Ftypes.h%E6%98%AF%E5%90%A6%E5%AE%9A%E4%B9%89makedev%E2%80%A6%20%E5%90%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5sys%2Fmkdev.h%E6%98%AF%E5%90%A6%E5%8F%AF%E7%94%A8%E2%80%A6%E5%90%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5sys%2Fmkdev.h%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E2%80%A6%E5%90%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5sys%2Fmkdev.h...%E5%90%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Echecking%20sys%2Fsysmacros.h%20usability...%20yes%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5sys%2Fsysmacros.h%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E2%80%A6%E2%80%A6%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5sys%2Fsysmacros.h...%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5%20BSD%20%E5%85%BC%E5%AE%B9%E7%9A%84%E5%AE%89%E8%A3%85...%20%2Fusr%2Fbin%2Finstall%20-c%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5%E6%9E%84%E5%BB%BA%E7%8E%AF%E5%A2%83%E6%98%AF%E5%90%A6%E6%AD%A3%E5%B8%B8...%20%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5thread-safe%20mkdir%20-p...%20%2Fbin%2Fmkdir%20-p%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5gawk...%E5%90%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%AD%A3%E5%9C%A8%E6%A3%80%E6%9F%A5%20mawk...%20mawk%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5make%E6%98%AF%E5%90%A6%E8%AE%BE%E7%BD%AE%20%24(MAKE)...%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5make%E4%BD%BF%E7%94%A8%E7%9A%84%E5%8C%85%E5%90%AB%E6%A0%B7%E5%BC%8F...GNU%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5%20make%20%E6%98%AF%E5%90%A6%E6%94%AF%E6%8C%81%E5%B5%8C%E5%A5%97%E5%8F%98%E9%87%8F...%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Echecking%20dependency%20style%20of%20gcc...%20none%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Echecking%20whether%20make%20supports%20nested%20variables...%20(cached)%20yes%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%AD%A3%E5%9C%A8%E6%A3%80%E6%9F%A5%E5%AE%A2%E6%88%B7%E7%AB%AF-gcc...%20gcc%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5%E6%88%91%E4%BB%AC%E6%98%AF%E5%90%A6%E5%9C%A8%E4%BD%BF%E7%94%A8GNU%20C%E7%BC%96%E8%AF%91%E5%99%A8%E2%80%A6%EF%BC%88%E7%BC%93%E5%AD%98%EF%BC%89%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5gcc%E6%98%AF%E5%90%A6%E6%8E%A5%E5%8F%97-g...%EF%BC%88%E7%BC%93%E5%AD%98%EF%BC%89%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5gcc%E9%80%89%E9%A1%B9%E6%98%AF%E5%90%A6%E6%8E%A5%E5%8F%97ISO%20C89%E2%80%A6%EF%BC%88%E7%BC%93%E5%AD%98%EF%BC%89%E4%B8%8D%E9%9C%80%E8%A6%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3Echecking%20whether%20gcc%20understands%20-c%20and%20-o%20together...%20(cached)%20yes%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5%E4%B8%8D%E6%88%AA%E6%96%AD%E8%BE%93%E5%87%BA%E7%9A%84sed%E2%80%A6%2Fbin%2Fsed%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%A3%80%E6%9F%A5%E7%94%9F%E6%88%90%E7%B3%BB%E7%BB%9F%E7%B1%BB%E5%9E%8B%E2%80%A6%E6%97%A0%E6%95%88%E9%85%8D%E7%BD%AE%E2%80%9C%E5%AE%A2%E6%88%B7%E7%AB%AF%E2%80%9D%EF%BC%9A%E6%9C%AA%E8%AF%86%E5%88%AB%E6%9C%BA%E5%99%A8%E2%80%9C%E5%AE%A2%E6%88%B7%E7%AB%AF%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E9%85%8D%E7%BD%AE%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%2Fbin%2Fbash%20build-aux%2Fconfig.sub%20%E5%AE%A2%E6%88%B7%E7%AB%AF%E5%A4%B1%E8%B4%A5%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E6%82%A8%E7%9F%A5%E9%81%93%E6%88%91%E5%8F%AF%E8%83%BD%E6%BC%8F%E6%8E%89%E4%BA%86%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E9%A1%BA%E4%BE%BF%E8%AF%B4%E4%B8%80%E4%B8%8B%EF%BC%9A%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20imx8m%20mini%20evk%20-%20yocto%EF%BC%8C%E4%BD%86%E5%B0%B1%E8%BF%99%E4%BA%9B%E6%AD%A5%E9%AA%A4%E8%80%8C%E8%A8%80%EF%BC%8C%E8%BF%99%E4%B8%8D%E5%BA%94%E4%BA%A7%E7%94%9F%E5%BD%B1%E5%93%8D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E4%BB%AC%E4%B8%A4%E4%BD%8D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20color%3A%20%23000000%3B%20background-color%3A%20transparent%3B%20font-weight%3A%20400%3B%20text-decoration%3A%20none%3B%22%3EAmrit%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%200pt%3B%20margin-bottom%3A%200pt%3B%22%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E6%88%91%E6%9C%89%E7%82%B9%E6%90%9E%E4%B8%8D%E6%B8%85%E6%A5%9A%E5%85%B7%E4%BD%93%E8%A6%81%E5%A4%8D%E5%88%B6%E4%BB%80%E4%B9%88%E4%BA%86%E3%80%82%E4%BB%8E%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E7%B2%BE%E5%BD%A9%E6%89%8B%E5%86%8C%20(Ubuntu-imx8-weston.pdf)%3CBR%20%2F%3E%E4%B8%AD%EF%BC%8C%E8%BF%99%E9%87%8C%E6%9C%89%E5%87%A0%E4%B8%AA%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FP%3E%3CP%3E2%EF%BC%89%E4%BB%8E%20yocto%20%E5%A4%8D%E5%88%B6%20libdrm%E3%80%81wayland%20%E5%92%8C%20vpu-firmware%3C%2FP%3E%3CP%3E%24sudo%20cp%20-Pra%20libdrm%2F2.4.91.imx-r0%2Fimage%2F*%20ubuntu18.04%2F%3C%2FP%3E%3CP%3E%24sudo%20cp%20-Pra%20imx-gpu-viv%2F1_6.2.4.p4.0-aarch64-r0%2Fimage%2F*%20ubuntu18.04%2F%3C%2FP%3E%3CP%3E%24sudo%20cp%20-Pra%20imx-dpu-g2d-1.7.0%2Fimx-dpu-g2d%2F1.7.0-ro%2Fimage%2F*%20ubuntu%2018.04%2F%3C%2FP%3E%3CP%3E%24sudo%20cp%20-r%20all-poky-linux%2Ffirmware-imx%2F1_8.1-r0%2Fimage%2F*%20ubuntu18.04%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%EF%BC%8C%E4%BA%86%E8%A7%A3%E6%AF%8F%E4%B8%AA%E6%96%87%E4%BB%B6%E7%9A%84%E5%AE%9E%E9%99%85%E6%96%87%E4%BB%B6%E5%A4%B9%E8%B7%AF%E5%BE%84%E5%B0%86%E4%BC%9A%E5%BE%88%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E6%8E%A8%E6%B5%8B%E6%98%AF%E6%82%A8%E6%AD%A3%E5%9C%A8%E4%BB%8Eyocto%E6%9E%84%E5%BB%BA%E4%B8%AD%E5%A4%8D%E5%88%B6%E6%96%87%E4%BB%B6%E2%80%A6%E2%80%A6%E8%83%BD%E5%90%A6%E6%8F%90%E4%BE%9B%E4%BB%A5%E4%B8%8B%E5%AE%8C%E6%95%B4%E8%B7%AF%E5%BE%84%EF%BC%9A%2Flibdrm%2F2.4.91.imx-ro%2Fimage%2F%E3%80%81%26nbsp%3B%2Fimx-gpu-viv%2F1_6.2.4.p4.0-aarch64-ro%2Fimage%2F%E3%80%81%2Fimx-dpu-g2d-1.7.0%2Fimx-dpu-g2d%2F1.7.0-ro%2Fimage%2F*%20%E4%BB%A5%E5%8F%8A%20all-poky-linux%2Ffirmware-imx%2F1_8.1-r0%2Fimage%2F*%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%85%B6%E6%AC%A1%EF%BC%8C%E5%BD%93%E4%BD%A0%E6%8C%87%E5%87%BA%E7%9B%AE%E6%A0%87%E6%96%87%E4%BB%B6%E5%A4%B9%E6%98%AF%20%E2%80%9Cubuntu18.04%2F%E2%80%9D%20%E6%97%B6%EF%BC%8C%E6%88%91%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E8%AE%A4%E4%B8%BA%20%2Fubuntu18.04%20%2F%20%E6%98%AF%20ubuntu%20%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20(rootfs)%20%E7%9A%84%E6%A0%B9%E7%9B%AE%E5%BD%95%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ekylef%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E5%87%AF%E5%B0%94%3C%2FP%3E%3CP%3E%E6%88%91%E6%B2%A1%E6%9C%89%E6%B5%8B%E8%AF%95%E7%BD%91%E7%BB%9C%E6%91%84%E5%83%8F%E5%A4%B4%EF%BC%8C%E4%BD%86%E5%85%B6%E4%BB%96%E4%BA%BA%E6%B5%8B%E8%AF%95%E5%AE%83%E6%B2%A1%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E4%BB%96%E6%98%AF%E5%90%A6%E4%B8%BA%E6%AD%A4%E5%81%9A%E4%BA%86%E5%85%B6%E4%BB%96%E9%85%8D%E7%BD%AE%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E7%9A%84%E7%BD%91%E7%BB%9C%E6%91%84%E5%83%8F%E5%A4%B4%E6%98%AF%20USB%20%E6%91%84%E5%83%8F%E5%A4%B4%EF%BC%8C%E5%8F%AF%E8%83%BD%E5%BA%94%E8%AF%A5%E5%9C%A8%E5%86%85%E6%A0%B8%E4%B8%AD%E5%90%AF%E7%94%A8%20UVC%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E5%85%B3%E4%BA%8E%20VPU%20%E5%9B%BA%E4%BB%B6%EF%BC%8C%E6%82%A8%E6%98%AF%E5%90%A6%E5%B0%86%E5%85%B6%E5%A4%8D%E5%88%B6%E5%88%B0%20%2Flib%2Ffirmware%20%E7%9B%AE%E5%BD%95%E4%B8%8B%EF%BC%9F%E6%82%A8%E4%B9%9F%E5%8F%AF%E4%BB%A5%E4%BB%8E%20Yocto%20%E5%A4%8D%E5%88%B6%20unit_test%20%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BD%BF%E7%94%A8%20v4l2%20%E6%89%93%E5%BC%80%E7%9B%B8%E6%9C%BA%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3EGnar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Gnar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%BE%88%E5%A5%BD%E5%A5%87%EF%BC%8C%E6%82%A8%E6%98%AF%E5%90%A6%E6%B5%8B%E8%AF%95%E8%BF%87%E5%9C%A8Ubuntu%E7%B3%BB%E7%BB%9F%E4%B8%8A%E4%BD%BF%E7%94%A8%E7%BD%91%E7%BB%9C%E6%91%84%E5%83%8F%E5%A4%B4%EF%BC%8C%E5%B9%B6%E7%A1%AE%E8%AE%A4%E5%85%B6%E6%98%AF%E5%90%A6%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%9F%26nbsp%3B%E6%88%91%E6%AD%A3%E5%9C%A8%E5%8A%AA%E5%8A%9B%E8%AE%A9%E4%B8%80%E4%B8%AA%E7%AE%80%E5%8D%95%E7%9A%84%E7%BD%97%E6%8A%80%E7%BD%91%E7%BB%9C%E6%91%84%E5%83%8F%E5%A4%B4%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%26nbsp%3B%E7%9C%8B%E8%B5%B7%E6%9D%A5%E6%88%91%E6%94%B6%E5%88%B0%E7%9A%84dmesg%E6%8F%90%E7%A4%BA%E6%98%AF%E2%80%9CVPU_firmware_download%20%E5%A4%B1%E8%B4%A5%E2%80%9D%E2%80%A6%E2%80%A6%E6%89%80%E4%BB%A5%E6%88%91%E8%AE%A4%E4%B8%BAVPU%E5%9B%BA%E4%BB%B6%E5%87%BA%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B9%9F%E8%AE%B8%E6%88%91%E5%9C%A8%E6%9F%90%E4%B8%AA%E6%97%B6%E5%80%99%E5%A4%8D%E5%88%B6%E9%94%99%E4%BA%86%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ek%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128710%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128710%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20Amrit%3C%2FP%3E%3CP%3E1.%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%93%AA%E4%B8%AA%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%88cd%20~%2F%3F%3F%3F%3F%EF%BC%89%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%91%BD%E4%BB%A4%E5%9C%A8%E4%B8%BB%E6%9C%BAPC%E7%AB%AF%E8%BF%90%E8%A1%8C%E3%80%82%E8%A6%81%26nbsp%3B%E5%88%9B%E5%BB%BAubuntu%20rootfs%EF%BC%8C%E9%A6%96%E5%85%88%E8%A6%81%E8%A7%A3%E5%8E%8Brootfs%EF%BC%8C%E5%A6%82tar%20-xvf%20ubuntu-base-18.04.2-base-arm64.tar.gz%20-C%20ubuntu-rootfs%EF%BC%8C%E5%9C%A8%E6%88%91%E7%9A%84%E4%BE%8B%E5%AD%90%E4%B8%AD%EF%BC%8C%E5%B0%86%3CSPAN%3E%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Eubuntu-rootfs%26nbsp%3B%E4%BF%AE%E6%94%B9%26nbsp%3B%E4%B8%BAubuntu%2018.04%EF%BC%8C%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%BC%95%E8%B5%B7%E8%AF%AF%E8%A7%A3%EF%BC%8C%E6%88%91%E4%BC%9A%E7%BB%9F%E4%B8%80%E5%91%BD%E5%90%8D%E3%80%82%E6%AD%A4%E5%91%BD%E4%BB%A4%E7%9A%84%E7%9B%AE%E7%9A%84%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E5%B0%86%E4%B8%8E%20GPU%20%E7%9B%B8%E5%85%B3%E7%9A%84%E5%BA%93%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3E%E5%A4%8D%E5%88%B6%3C%2FSPAN%3E%E5%88%B0%20ubuntu-rootfs%20%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E2.%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%8D%95%E7%8B%AC%E7%BC%96%E8%AF%91%E5%86%85%E6%A0%B8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%9B%A0%E4%B8%BAyocto%E9%BB%98%E8%AE%A4%E5%B0%86GPU%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%9E%84%E5%BB%BA%E4%B8%BAgalcore.ko%E3%80%82%E5%9B%A0%E6%AD%A4%3CSPAN%3E%EF%BC%8C%E9%9C%80%E8%A6%81%E5%8D%95%E7%8B%AC%E7%BC%96%E8%AF%91%E5%86%85%E6%A0%B8%EF%BC%8C%E4%BB%A5%E4%BD%BF%E6%98%A0%E5%83%8F%E5%8C%85%E5%90%ABGPU%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E5%9C%A8%E5%86%85%E6%A0%B8%E6%BA%90%E4%BB%A3%E7%A0%81%E4%B8%AD%EF%BC%88%E6%88%91%E4%B8%8B%E8%BD%BD%E7%9A%84%E6%98%AF%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Flinux-imx%22%20title%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Flinux-imx%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Elinux-imx%20-%20i.MX%20Linux%E5%86%85%E6%A0%B8%3C%2FA%3E%26nbsp%3B%EF%BC%8C%E8%80%8C%E9%9D%9Eyocto%E4%BB%A3%E7%A0%81%EF%BC%89%EF%BC%8C%26nbsp%3B%E6%89%A7%E8%A1%8C%24%20make%20menuconfig%E5%91%BD%E4%BB%A4%E5%90%8E%EF%BC%8C%E5%8D%B3%E5%8F%AF%E7%9C%8B%E5%88%B0.config%E6%96%87%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3ECONFIG_MXC_GPU_VIV%3Dy.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3EGnar%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX8%E7%B3%BB%E5%88%97%E5%B9%B3%E5%8F%B0%E6%9E%84%E5%BB%BAUbuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Gnar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%8F%91%E5%B8%83%E8%BF%99%E4%BB%BD%E8%AF%A6%E7%BB%86%E7%9A%84%E6%96%87%E6%A1%A3%E3%80%82%E6%88%91%E8%AF%95%E5%9B%BE%E6%8C%89%E7%85%A7%E5%AE%83%E6%9D%A5%E6%93%8D%E4%BD%9C%20NXP%20i.MX8M-Mini%20EVK%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E6%88%90%E5%8A%9F%E5%9C%A8%E8%AF%A5%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E6%9E%84%E5%BB%BA%E4%BA%86Yocto%EF%BC%8C%E7%9B%AE%E5%89%8D%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%E3%80%82%E7%8E%B0%E5%9C%A8%E5%B8%8C%E6%9C%9B%E5%9C%A8%E8%AF%A5EVK%E4%B8%8A%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8Ubuntu%E6%90%AD%E9%85%8DWeston%E3%80%82%E6%88%91%E6%9C%89%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E8%A6%81%E9%97%AE%E6%82%A8%EF%BC%8C%E5%85%B3%E4%BA%8E%E6%82%A8%E7%9A%84%20Ubuntu-i.MX8-weston.pdf%20%E6%96%87%E6%A1%A3%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E7%AC%AC%209%20%E9%83%A8%E5%88%86%E4%B8%AD%E6%82%A8%E5%86%99%E9%81%93%EF%BC%9A%3C%2FP%3E%3CP%3E2)copy%20libdrm%2Cwayland%20vpu-firmware%20from%20yocto%3CBR%20%2F%3E%24sudo%20cp%20-Pra%20libdrm%2F2.4.91.imx-r0%2Fimage%2F*%20ubuntu18.04%2F%3CBR%20%2F%3E%24sudo%20cp%20-Pra%20imx-gpu-viv%2F1_6.2.4.p4.0-aarch64-r0%2Fimage%2F*%20ubuntu18.04%2F%3CBR%20%2F%3E%24sudo%20cp%20-Pra%20imx-dpu-g2d-1.7.0%2Fimx-dpu-g2d%2F1.7.0-r0%2Fimage%2F*%20ubuntu18.04%2F%3CBR%20%2F%3E%24sudo%20cp%20-r%20all-poky-linux%2Ffirmware-imx%2F1_8.1-r0%2Fimage%2F*%20ubuntu18.04%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E6%82%A8%E6%98%AF%E4%BB%8E%E5%93%AA%E4%B8%AA%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%88cd%20~%2F%3F%3F%3F%3F%EF%BC%89%26nbsp%3B%E8%BF%90%E8%A1%8C%E8%BF%99%E4%BA%9B%E5%91%BD%E4%BB%A4%E7%9A%84%E5%90%97%EF%BC%9F%E6%AD%A4%E5%A4%96%EF%BC%8Cubuntu%2018.04%E8%BF%99%E4%B8%AA%E6%96%87%E4%BB%B6%E5%A4%B9%E5%9C%A8%E4%BB%BB%E4%BD%95%E5%9C%B0%E6%96%B9%E9%83%BD%E4%B8%8D%E5%AD%98%E5%9C%A8%EF%BC%8C%E5%90%8E%E6%9D%A5%E8%A2%AB%E7%94%A8%E5%88%B0%E5%93%AA%E9%87%8C%E5%8E%BB%E4%BA%86%EF%BC%9F%E5%9C%A8%E8%BF%99%E4%BB%BD%E6%96%87%E6%A1%A3%E4%B8%AD%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E7%9C%8B%E5%88%B0%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E5%85%B3%E4%BA%8E%E2%80%9Cubuntu%2018.04%E2%80%9D%E6%96%87%E6%A1%A3%E5%A4%B9%E7%9A%84%E5%86%85%E5%AE%B9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3CSPAN%3Eimx-dpu-g2d%E6%98%AF%E5%90%A6%E6%8B%BC%E5%86%99%E9%94%99%E8%AF%AF%EF%BC%8C%E5%BA%94%E8%AF%A5%E6%98%AFimx-gpu-g2d%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%82%A8%E8%BF%98%E8%AF%B4%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E2.%20%E7%8B%AC%E7%AB%8B%E7%BC%96%E8%AF%91%E5%86%85%E6%A0%B8%EF%BC%8C%E6%9B%BF%E6%8D%A2yocto%E5%86%85%E6%A0%B8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%82%A8%E6%98%AF%E6%8C%87%E5%9C%A8%E6%88%91%E6%9E%84%E5%BB%BA%E5%AE%8Cyocto%E5%90%8E%EF%BC%8C%E5%86%8D%E6%89%A7%E8%A1%8Cbitbake%20linux-imx%E5%91%BD%E4%BB%A4%E5%90%97%EF%BC%9F%E7%9B%AE%E5%89%8D%E5%9C%A8yocto%E6%9E%84%E5%BB%BA%E4%B8%AD%EF%BC%8C%E6%88%91%E7%A1%AE%E5%AE%9E%E7%9C%8B%E5%88%B0%E5%B7%B2%E6%9E%84%E5%BB%BA%E7%9A%84%E5%86%85%E6%A0%B8%E6%98%A0%E5%83%8F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EAmrit%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
100% 有帮助 (1/1)
版本历史
最后更新:
‎07-19-2019 12:09 AM
更新人:
