Build Linphone Android for i.MX6
Linphone is an internet phone or Voice Over IP phone (VoIP).
  • With Linphone you can communicate freely with people over the internet, with voice, video, and text instant messaging.
  • Linphone makes use of the SIP protocol, an open standard for internet telephony. You can use Linphone with any SIP VoIP operator, including our free SIP audio/video service.
  • Linphone is free software (or open-source), you can download and redistribute it freely.
  • Linphone is available for desktop computers: Linux, Windows, Mac OSX, and for mobile phones: Android, iPhone, Blackberry.
Linphone-android is a good example to show the integration of Java code based on Android SDK with native CODEC, network protocols. Not like XBMC-Android that is almost total c++/c project.
Perform the following steps to build a linphone-android project:
1. git clone git://git.linphone.org/linphone-android.git --recursive
2. sudo apt-get install autoconf automake libtool pkg-config
3. "cd" to the root of "git clone" : cd /home/user/linphne-android // wherver git'ed linphone-android is
4. export PATH=/home/user/android-ndk:$PATH //wherever your android-ndk, android-sdk tools, and platform-tools, and ANT are stored in.
            For example on my PC.
     export PATH=/home/alanz/android-ndk-r8d:/home/alanz/android-sdk-linux/tools:/home/alanz/android-sdk-linux/platform-     tools:/home/alanz/bin/apache-ant-1.8.4/bin:$PATH
            Note: PATH contains the ndk, sdk, and ant.
5. Make sure the network is working, then execute "./prepare_sources.sh" at the linphone-android root
6. Then, execute "/home/alanz/android-ndk-r8d/ndk-build", it will take a while to be finished
7. Modify Makefile as following example, modify it accordingly.
     NDK_PATH=/home/alanz/android-ndk-r8d
     SDK_PATH=/home/alanz/android-sdk-linux/tools
     SDK_PLATFORM_TOOLS_PATH=/home/alanz/android-sdk-linux/platform-tools
     generate-libs:
          $(NDK_PATH)/ndk-build ....... (remove -j$(NUMCPUS) by the end of this command line)
8. execute "make", after finish, the apk file can be found under bin/ subdirectory.
标签 (4)
评论
Hi thanks for your help but i am getting below error in 5th step, while executing "./prepare_sources.sh"
cp ./patch_pic.diff SILK_SDK_SRC_v1.0.9/SILK_SDK_SRC_ARM_v1.0.9
cd SILK_SDK_SRC_v1.0.9/SILK_SDK_SRC_ARM_v1.0.9 && /usr/bin/patch -p0 < patch_pic.diff
patching file Makefile
Hunk #1 FAILED at 26.
1 out of 1 hunk FAILED -- saving rejects to file Makefile.rej
Makefile:420: recipe for target `SILK_SDK_SRC_v1.0.9/SILK_SDK_SRC_ARM_v1.0.9' failed
make: *** [SILK_SDK_SRC_v1.0.9/SILK_SDK_SRC_ARM_v1.0.9] Error 1
SILK audio plugin prepare state failed.
./prepare_sources.sh: line 41: xxd: command not found
./prepare_sources.sh: line 47: xxd: command not found
Main problem is, when with these errors, i complete all steps and move ahead and import code in eclipse, run then i get java.lang.NoClassDefFoundException in GCMRegister class if i comment this code then same error for LinphoneActivity.java. please guide how i can get rid of this error and successfully run and test this code. Thanks in Advance.
There is no prepare_sources.sh file in the latest linphone-android sources. I was able to build linphone according to the README directions of the linphone-android git sources and run it on an android phone and it works
Is there the Linphone for Android using the CPU's hardware encoder?
If I use it on imx53 or imx6, it will use VPU?
It will not use the VPU. You will have to write a plugin which uses the hardware encoder. You could try using gstreamer appsrc plugin and combining that with a new mediastreamer2 plugin
Do anybody have idea regarding whether we can use i.MX6 for designing Analog telephone adaptors? What kind of SW application we need to implement on i.MX6D?
%3CLINGO-SUB%20id%3D%22lingo-sub-1114630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%B8%BA%20i.MX6%20%E6%9E%84%E5%BB%BA%20Linphone%20Android%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSTRONG%3ELinphone%20%E6%98%AF%E4%B8%80%E6%AC%BE%E7%BD%91%E7%BB%9C%E7%94%B5%E8%AF%9D%E6%88%96%20IP%20%E8%AF%AD%E9%9F%B3%E7%94%B5%E8%AF%9D%20(VoIP)%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E4%BD%BF%E7%94%A8%20Linphone%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E4%BA%92%E8%81%94%E7%BD%91%E4%B8%8E%E4%BA%BA%E4%BB%AC%E8%87%AA%E7%94%B1%E4%BA%A4%E6%B5%81%EF%BC%8C%3CSTRONG%3E%E5%8C%85%E6%8B%AC%E8%AF%AD%E9%9F%B3%E3%80%81%E8%A7%86%E9%A2%91%E5%92%8C%E6%96%87%E6%9C%AC%E5%8D%B3%E6%97%B6%E6%B6%88%E6%81%AF%3C%2FSTRONG%3E%E3%80%82%3C%2FLI%3E%3CLI%3ELinphone%20%E4%BD%BF%E7%94%A8%3CSTRONG%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FSession_Initiation_Protocol%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ESIP%20%E5%8D%8F%E8%AE%AE%3C%2FA%3E%EF%BC%8C%E8%BF%99%E6%98%AF%E4%BA%92%E8%81%94%E7%BD%91%E7%94%B5%E8%AF%9D%E7%9A%84%E5%BC%80%E6%94%BE%E6%A0%87%E5%87%86%3C%2FSTRONG%3E%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%86%20Linphone%3CSTRONG%3E%E4%B8%8E%E4%BB%BB%E4%BD%95%20SIP%20VoIP%20%E8%BF%90%E8%90%A5%E5%95%86%E4%B8%80%E8%B5%B7%3C%2FSTRONG%3E%E4%BD%BF%E7%94%A8%EF%BC%8C%E5%8C%85%E6%8B%AC%E6%88%91%E4%BB%AC%E7%9A%84%3CA%20href%3D%22http%3A%2F%2Fwww.linphone.org%2Feng%2Flinphone%2Fregister-a-linphone-account.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%85%8D%E8%B4%B9%20SIP%20%E9%9F%B3%E9%A2%91%2F%E8%A7%86%E9%A2%91%E6%9C%8D%E5%8A%A1%3C%2FA%3E%E3%80%82%3C%2FLI%3E%3CLI%3ELinphone%20%E6%98%AF%3CSTRONG%3E%E5%85%8D%E8%B4%B9%E8%BD%AF%E4%BB%B6%3C%2FSTRONG%3E%EF%BC%88%E6%88%96%E5%BC%80%E6%BA%90%E8%BD%AF%E4%BB%B6%EF%BC%89%EF%BC%8C%3CSTRONG%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%87%AA%E7%94%B1%E4%B8%8B%E8%BD%BD%E5%92%8C%E9%87%8D%E6%96%B0%E5%88%86%E5%8F%91%E5%AE%83%3C%2FSTRONG%3E%E3%80%82%3C%2FLI%3E%3CLI%3ELinphone%20%E9%80%82%E7%94%A8%E4%BA%8E%E5%8F%B0%E5%BC%8F%E7%94%B5%E8%84%91%EF%BC%9ALinux%E3%80%81Windows%E3%80%81Mac%20OSX%EF%BC%8C%E4%B9%9F%E9%80%82%E7%94%A8%E4%BA%8E%E6%89%8B%E6%9C%BA%EF%BC%9AAndroid%E3%80%81iPhone%E3%80%81Blackberry%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3ELinphone-android%20%E6%98%AF%E4%B8%80%E4%B8%AA%E5%BE%88%E5%A5%BD%E7%9A%84%E4%BE%8B%E5%AD%90%EF%BC%8C%E5%B1%95%E7%A4%BA%E4%BA%86%E5%9F%BA%E4%BA%8E%20Android%20SDK%20%E7%9A%84%20Java%20%E4%BB%A3%E7%A0%81%E4%B8%8E%E5%8E%9F%E7%94%9F%20CODEC%E3%80%81%E7%BD%91%E7%BB%9C%E5%8D%8F%E8%AE%AE%E7%9A%84%E9%9B%86%E6%88%90%E3%80%82%E4%B8%8D%E5%83%8F%20XBMC-Android%20%E9%82%A3%E6%A0%B7%E5%87%A0%E4%B9%8E%E5%AE%8C%E5%85%A8%E6%98%AF%20c%2B%2B%2Fc%20%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%89%A7%E8%A1%8C%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E6%9D%A5%E6%9E%84%E5%BB%BA%20linphone-android%20%E9%A1%B9%E7%9B%AE%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%20git%20clone%20git%3A%2F%2Fgit.linphone.org%2Flinphone-android.git%20--recursive%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E2.%20%3C%2FSPAN%3Esudo%20apt-get%20install%20autoconf%20automake%20libtool%20pkg-config%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.%20%E2%80%9Ccd%E2%80%9D%20%E5%88%B0%E2%80%9Cgit%20clone%E2%80%9D%E7%9A%84%E6%A0%B9%E7%9B%AE%E5%BD%95%EF%BC%9Acd%20%2Fhome%2Fuser%2Flinphne-android%20%2F%2F%20git%20%E7%9A%84%20linphone-android%20%E6%89%80%E5%9C%A8%E4%BD%8D%E7%BD%AE%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E4.%20export%20PATH%3D%2Fhome%2Fuser%2Fandroid-ndk%3A%24PATH%20%2F%2F%E6%82%A8%E7%9A%84%20android-ndk%E3%80%81android-sdk%20%E5%B7%A5%E5%85%B7%E3%80%81platform-tools%20%E5%92%8C%20ANT%20%E5%AD%98%E5%82%A8%E5%9C%A8%E4%BD%95%E5%A4%84%E3%80%82%3C%2FP%3E%3CP%3E%E4%BE%8B%E5%A6%82%E5%9C%A8%E6%88%91%E7%9A%84%20PC%20%E4%B8%8A%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20export%20PATH%3D%2Fhome%2Falanz%2Fandroid-ndk-r8d%3A%2Fhome%2Falanz%2Fandroid-sdk-linux%2Ftools%3A%2Fhome%2Falanz%2Fandroid-sdk-linux%2Fplatform-%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20tools%3A%2Fhome%2Falanz%2Fbin%2Fapache-ant-1.8.4%2Fbin%3A%24PATH%3C%2FP%3E%3CP%3E%E6%B3%A8%E6%84%8F%EF%BC%9APATH%20%E5%8C%85%E5%90%AB%20ndk%E3%80%81sdk%20%E5%92%8C%20ant%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E5.%E7%A1%AE%E4%BF%9D%E7%BD%91%E7%BB%9C%E6%AD%A3%E5%B8%B8%EF%BC%8C%E7%84%B6%E5%90%8E%E5%9C%A8linphone-android%E6%A0%B9%E7%9B%AE%E5%BD%95%E4%B8%8B%E6%89%A7%E8%A1%8C%E2%80%9C.%2Fprepare_sources.sh%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E6.%E7%84%B6%E5%90%8E%E6%89%A7%E8%A1%8C%E2%80%9C%2Fhome%2Falanz%2Fandroid-ndk-r8d%2Fndk-build%E2%80%9D%EF%BC%8C%E9%9C%80%E8%A6%81%E7%AD%89%E5%BE%85%E4%B8%80%E6%AE%B5%E6%97%B6%E9%97%B4%E6%89%8D%E8%83%BD%E5%AE%8C%E6%88%90%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E7.%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E7%A4%BA%E4%BE%8B%E4%BF%AE%E6%94%B9Makefile%EF%BC%8C%E8%BF%9B%E8%A1%8C%E7%9B%B8%E5%BA%94%E4%BF%AE%E6%94%B9%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20NDK_PATH%3D%2Fhome%2Falanz%2Fandroid-ndk-r8d%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20SDK_PATH%3D%2Fhome%2Falanz%2Fandroid-sdk-linux%2Ftools%3C%2FP%3E%3CP%3ESDK_PLATFORM_TOOLS_PATH%3D%2Fhome%2Falanz%2Fandroid-sdk-linux%2Fplatform-tools%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.....................%3C%2FP%3E%3CP%3E%E7%94%9F%E6%88%90%E5%BA%93%EF%BC%9A%3C%2FP%3E%3CP%3E%24(NDK_PATH)%2Fndk-build%20.......%EF%BC%88%E5%88%A0%E9%99%A4%E6%AD%A4%E5%91%BD%E4%BB%A4%E8%A1%8C%E6%9C%AB%E5%B0%BE%E7%9A%84%20-j%24(NUMCPUS)%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E8.%E6%89%A7%E8%A1%8C%E2%80%9Cmake%E2%80%9D%EF%BC%8C%E5%AE%8C%E6%88%90%E5%90%8E%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%9C%A8bin%2F%E5%AD%90%E7%9B%AE%E5%BD%95%E4%B8%8B%E6%89%BE%E5%88%B0apk%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1114630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX53%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6DL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6%20%E5%9B%9B%E6%A0%B8%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114635%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BA%20i.MX6%20%E6%9E%84%E5%BB%BA%20Linphone%20Android%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114635%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E7%9F%A5%E9%81%93%E6%88%91%E4%BB%AC%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20i.MX6%20%E6%9D%A5%E8%AE%BE%E8%AE%A1%E6%A8%A1%E6%8B%9F%E7%94%B5%E8%AF%9D%E9%80%82%E9%85%8D%E5%99%A8%E5%90%97%EF%BC%9F%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E5%9C%A8%20i.MX6D%20%E4%B8%8A%E5%AE%9E%E7%8E%B0%E4%BB%80%E4%B9%88%E6%A0%B7%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BA%20i.MX6%20%E6%9E%84%E5%BB%BA%20Linphone%20Android%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%AE%83%E5%B0%86%E4%B8%8D%E4%BC%9A%E4%BD%BF%E7%94%A8%20VPU%E3%80%82%E6%82%A8%E5%BF%85%E9%A1%BB%E7%BC%96%E5%86%99%E4%B8%80%E4%B8%AA%E4%BD%BF%E7%94%A8%E7%A1%AC%E4%BB%B6%E7%BC%96%E7%A0%81%E5%99%A8%E7%9A%84%E6%8F%92%E4%BB%B6%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20gstreamer%20appsrc%20%E6%8F%92%E4%BB%B6%E5%B9%B6%E5%B0%86%E5%85%B6%E4%B8%8E%E6%96%B0%E7%9A%84%20mediastreamer2%20%E6%8F%92%E4%BB%B6%E7%BB%93%E5%90%88%E4%BD%BF%E7%94%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BA%20i.MX6%20%E6%9E%84%E5%BB%BA%20Linphone%20Android%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%20CPU%20%E7%A1%AC%E4%BB%B6%E7%BC%96%E7%A0%81%E5%99%A8%E7%9A%84%20Android%20%E7%89%88%20Linphone%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E5%9C%A8%20imx53%20%E6%88%96%20imx6%20%E4%B8%8A%E4%BD%BF%E7%94%A8%E5%AE%83%EF%BC%8C%E5%AE%83%E4%BC%9A%E4%BD%BF%E7%94%A8%20VPU%20%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BA%20i.MX6%20%E6%9E%84%E5%BB%BA%20Linphone%20Android%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%80%E6%96%B0%E7%9A%84%20linphone-android%20%E6%BA%90%E4%B8%AD%E6%B2%A1%E6%9C%89%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2012.800000190734863px%3B%22%3Eprepare_sources.sh%3C%2FSPAN%3E%E6%96%87%E4%BB%B6%E3%80%82%E6%88%91%E8%83%BD%E5%A4%9F%E6%A0%B9%E6%8D%AE%20linphone-android%20git%20%E6%BA%90%E7%9A%84%20README%20%E8%AF%B4%E6%98%8E%E6%9E%84%E5%BB%BA%20linphone%EF%BC%8C%E5%B9%B6%E5%9C%A8%20Android%20%E6%89%8B%E6%9C%BA%E4%B8%8A%E8%BF%90%E8%A1%8C%E5%AE%83%EF%BC%8C%E5%AE%83%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BA%20i.MX6%20%E6%9E%84%E5%BB%BA%20Linphone%20Android%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%8C%E4%BD%86%E6%98%AF%E6%88%91%E5%9C%A8%E6%89%A7%E8%A1%8C%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E2%80%9C.%2Fprepare_sources.sh%E2%80%9D%3C%2FSPAN%3E%E7%9A%84%E7%AC%AC%205%20%E6%AD%A5%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3Ecp%20.%2Fpatch_pic.diff%20SILK_SDK_SRC_v1.0.9%2FSILK_SDK_SRC_ARM_v1.0.9%3C%2FP%3E%3CP%3Ecd%20SILK_SDK_SRC_v1.0.9%2FSILK_SDK_SRC_ARM_v1.0.9%20%26amp%3B%26amp%3B%20%2Fusr%2Fbin%2Fpatch%20-p0%20%26lt%3B%20patch_pic.diff%3C%2FP%3E%3CP%3E%E4%BF%AE%E8%A1%A5%E6%96%87%E4%BB%B6%20Makefile%3C%2FP%3E%3CP%3E%E5%B8%85%E5%93%A5%231%20%E5%9C%A8%2026%20%E5%B2%81%E6%97%B6%E5%A4%B1%E8%B4%A5%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E1%2F1%20%E5%9D%97%E5%A4%B1%E8%B4%A5%20-%20%E5%B0%86%E6%8B%92%E7%BB%9D%E4%BF%9D%E5%AD%98%E5%88%B0%E6%96%87%E4%BB%B6%20Makefile.rej%3C%2FP%3E%3CP%3EMakefile%EF%BC%9A420%EF%BC%9A%E7%9B%AE%E6%A0%87%E2%80%9CSILK_SDK_SRC_v1.0.9%2FSILK_SDK_SRC_ARM_v1.0.9%E2%80%9D%E7%9A%84%E9%85%8D%E6%96%B9%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CP%3E%E5%88%B6%E4%BD%9C%EF%BC%9A***%20%5BSILK_SDK_SRC_v1.0.9%2FSILK_SDK_SRC_ARM_v1.0.9%5D%E9%94%99%E8%AF%AF%201%3C%2FP%3E%3CP%3ESILK%20%E9%9F%B3%E9%A2%91%E6%8F%92%E4%BB%B6%E5%87%86%E5%A4%87%E7%8A%B6%E6%80%81%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FP%3E%3CP%3E.%2Fprepare_sources.sh%3A%20%E7%AC%AC%2041%20%E8%A1%8C%EF%BC%9Axxd%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3C%2FP%3E%3CP%3E.%2Fprepare_sources.sh%3A%20%E7%AC%AC%2047%20%E8%A1%8C%EF%BC%9Axxd%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%E4%B8%BB%E8%A6%81%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E5%BD%93%E5%87%BA%E7%8E%B0%E8%BF%99%E4%BA%9B%E9%94%99%E8%AF%AF%E6%97%B6%EF%BC%8C%E6%88%91%E5%AE%8C%E6%88%90%E6%89%80%E6%9C%89%E6%AD%A5%E9%AA%A4%E5%B9%B6%E7%BB%A7%E7%BB%AD%E5%89%8D%E8%BF%9B%E5%B9%B6%E5%9C%A8%20eclipse%20%E4%B8%AD%E5%AF%BC%E5%85%A5%E4%BB%A3%E7%A0%81%EF%BC%8C%E8%BF%90%E8%A1%8C%E7%84%B6%E5%90%8E%E6%88%91%E5%9C%A8%20GCMRegister%20%E7%B1%BB%E4%B8%AD%E5%BE%97%E5%88%B0%20java.lang.NoClassDefFoundException%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E6%B3%A8%E9%87%8A%E6%AD%A4%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%88%99%20LinphoneActivity.java%20%E4%B9%9F%E4%BC%9A%E5%87%BA%E7%8E%B0%E5%90%8C%E6%A0%B7%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%E8%AF%B7%E6%8C%87%E5%AF%BC%E6%88%91%E5%A6%82%E4%BD%95%E6%91%86%E8%84%B1%E6%AD%A4%E9%94%99%E8%AF%AF%E5%B9%B6%E6%88%90%E5%8A%9F%E8%BF%90%E8%A1%8C%E5%92%8C%E6%B5%8B%E8%AF%95%E6%AD%A4%E4%BB%A3%E7%A0%81%E3%80%82%E6%8F%90%E5%89%8D%E8%87%B4%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎02-27-2013 08:58 PM
更新人:
