All Boards How To Understand JTAG BSDL
How To Understand JTAG BSDL File
This example explains how to understand the BSDL file in order to create an OpenOCD configure file.
IR Len
That information can be retrieved directly:
attribute INSTRUCTION_LENGTH of imx_device: entity is 5;
This means that IR Len is 5, then in OpenOCD config it will be informed this way:
-irlen 5
IR Capture
The IR Capture also can be retrieved directly:
attribute INSTRUCTION_CAPTURE of imx_device : entity is "XXX01";
This means that IR Capture is 1, then in OpenOCD config it will be informed this way:
-ircapture 0x1
IR Mask
The IR Mask is based on IR Len size. Just create a binary number with "IR Len" bits 1.
If the IR Len is 4 then the IR Mask will be 0xF (1111). Case the IR Len is 5 the IR Mask will be 0x1F (11111).
In this BSDL example (IR Len = 5) the OpenOCD config needs to inform the IR Mask this way:
-irmask 0x1f
TAP ID
attribute IDCODE_REGISTER  of imx_device : entity is     "0010"            & -- Version     "000110"          & -- Design Center Number     "0100000001"      & -- Sequence Number     "00000001110"      & -- Manufacturer Identity     "1";                -- IEEE 1149.1 Requirement
This code can be converted directly to TAP ID:
Binary:
0010-0001-1001-0000-0001-0000-0001-1101
Hexadecimal:
2-1-9-0-1-0-1-D
Then in OpenOCD configure you will create:
if { [info exists SDMATAPID ] } {   set _SDMATAPID $SDMATAPID } else {   set _SDMATAPID 0x2190101d }
The final configure line will be:
jtag newtap $_CHIPNAME smda -irlen 5 -ircapture 0x1 -irmask 0x1f -expected-id $_SDMATAPID
Comments
https://cache.nxp.com/secured/NMG/MAD/IMX6D_IMX6Q_21x21_BSDL.zip?__gda__=1516854170_c0e3cc5142b8f17b...
IMX6D_21x21_BSDL_TO1.2.bsdl
0x2191e01d
# SDMA / no IDCODE
jtag newtap $_CHIPNAME sdma -irlen 4 -ircapture 0x00 -irmask 0x0f
# System JTAG Controller
if { [info exists SJC_TAPID] } {
        set _SJC_TAPID $SJC_TAPID
} else {
        set _SJC_TAPID 0x0191c01d
set _SJC_TAPID2 0x0191e01d
set _SJC_TAPID3 0x2191c01d
set _SJC_TAPID4 0x2191e01d    #here
jtag newtap $_CHIPNAME sjc -irlen 5 -ircapture 0x01 -irmask 0x1f \
        -expected-id $_SJC_TAPID -expected-id $_SJC_TAPID2 \
        -expected-id $_SJC_TAPID3 -expected-id $_SJC_TAPID4
now is set for _SJC_TAPID not _SDMATAPID
%3CLINGO-SUB%20id%3D%22lingo-sub-1120417%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAll%20Boards%20How%20To%20Understand%20JTAG%20BSDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120417%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH1%20id%3D%22toc-hId-382335899%22%20id%3D%22toc-hId-382335899%22%20id%3D%22toc-hId-1298470900%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EHow%20To%20Understand%20JTAG%20BSDL%20File%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3EThis%20example%20explains%20how%20to%20understand%20the%20BSDL%20file%20in%20order%20to%20create%20an%20OpenOCD%20configure%20file.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1425118564%22%20id%3D%22toc-hId--1425118564%22%20id%3D%22toc-hId--508983563%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EIR%20Len%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3EThat%20information%20can%20be%20retrieved%20directly%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Eattribute%20INSTRUCTION_LENGTH%20of%20imx_device%3A%20entity%20is%205%3B%0A%3C%2FPRE%3E%3CP%3EThis%20means%20that%20IR%20Len%20is%205%2C%20then%20in%20OpenOCD%20config%20it%20will%20be%20informed%20this%20way%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E-irlen%205%0A%3C%2FPRE%3E%3CH1%20id%3D%22toc-hId-1062394269%22%20id%3D%22toc-hId-1062394269%22%20id%3D%22toc-hId-1978529270%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EIR%20Capture%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3EThe%20IR%20Capture%20also%20can%20be%20retrieved%20directly%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Eattribute%20INSTRUCTION_CAPTURE%20of%20imx_device%20%3A%20entity%20is%20%22XXX01%22%3B%0A%3C%2FPRE%3E%3CP%3EThis%20means%20that%20IR%20Capture%20is%201%2C%20then%20in%20OpenOCD%20config%20it%20will%20be%20informed%20this%20way%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E-ircapture%200x1%0A%3C%2FPRE%3E%3CH1%20id%3D%22toc-hId--745060194%22%20id%3D%22toc-hId--745060194%22%20id%3D%22toc-hId-171074807%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EIR%20Mask%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3EThe%20IR%20Mask%20is%20based%20on%20IR%20Len%20size.%20Just%20create%20a%20binary%20number%20with%20%22IR%20Len%22%20bits%201.%3C%2FP%3E%3CP%3EIf%20the%20IR%20Len%20is%204%20then%20the%20IR%20Mask%20will%20be%200xF%20(1111).%20Case%20the%20IR%20Len%20is%205%20the%20IR%20Mask%20will%20be%200x1F%20(11111).%3C%2FP%3E%3CP%3EIn%20this%20BSDL%20example%20(IR%20Len%20%3D%205)%20the%20OpenOCD%20config%20needs%20to%20inform%20the%20IR%20Mask%20this%20way%3A%3C%2FP%3E%3CPRE%3E-irmask%200x1f%0A%3C%2FPRE%3E%3CH1%20id%3D%22toc-hId-1742452639%22%20id%3D%22toc-hId-1742452639%22%20id%3D%22toc-hId--1636379656%22%3E%3CSPAN%20class%3D%22mw-headline%22%3ETAP%20ID%3C%2FSPAN%3E%3C%2FH1%3E%3CPRE%20class%3D%22jive-pre%22%3E%0A%3CP%3Eattribute%20IDCODE_REGISTER%26nbsp%3B%20of%20imx_device%20%3A%20entity%20is%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%220010%22%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26amp%3B%20--%20Version%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%22000110%22%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26amp%3B%20--%20Design%20Center%20Number%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%220100000001%22%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26amp%3B%20--%20Sequence%20Number%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2200000001110%22%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26amp%3B%20--%20Manufacturer%20Identity%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%221%22%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20--%20IEEE%201149.1%20Requirement%3C%2FP%3E%0A%0A%3C%2FPRE%3E%3CP%3EThis%20code%20can%20be%20converted%20directly%20to%20TAP%20ID%3A%3C%2FP%3E%3CP%3EBinary%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E0010-0001-1001-0000-0001-0000-0001-1101%0A%3C%2FPRE%3E%3CP%3EHexadecimal%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E2-1-9-0-1-0-1-D%0A%3C%2FPRE%3E%3CP%3EThen%20in%20OpenOCD%20configure%20you%20will%20create%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%0A%3CP%3Eif%20%7B%20%5Binfo%20exists%20SDMATAPID%20%5D%20%7D%20%7B%0A%26nbsp%3B%20set%20_SDMATAPID%20%24SDMATAPID%0A%7D%20else%20%7B%0A%26nbsp%3B%20set%20_SDMATAPID%200x2190101d%0A%7D%3C%2FP%3E%0A%0A%3C%2FPRE%3E%3CP%3EThe%20final%20configure%20line%20will%20be%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Ejtag%20newtap%20%24_CHIPNAME%20smda%20-irlen%205%20-ircapture%200x1%20-irmask%200x1f%20-expected-id%20%24_SDMATAPID%0A%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20All%20Boards%20How%20To%20Understand%20JTAG%20BSDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcache.nxp.com%2Fsecured%2FNMG%2FMAD%2FIMX6D_IMX6Q_21x21_BSDL.zip%3F__gda__%3D1516854170_c0e3cc5142b8f17bc2485159621b771b%26amp%3BfileExt%3D.zip%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcache.nxp.com%2Fsecured%2FNMG%2FMAD%2FIMX6D_IMX6Q_21x21_BSDL.zip%3F__gda__%3D1516854170_c0e3cc5142b8f17bc2485159621b771b%26amp%3BfileExt%3D.zip%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIMX6D_21x21_BSDL_TO1.2.bsdl%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E0x2191e01d%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%20SDMA%20%2F%20no%20IDCODE%3CBR%20%2F%3Ejtag%20newtap%20%24_CHIPNAME%20sdma%20-irlen%204%20-ircapture%200x00%20-irmask%200x0f%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%20System%20JTAG%20Controller%3CBR%20%2F%3Eif%20%7B%20%5Binfo%20exists%20SJC_TAPID%5D%20%7D%20%7B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20set%20_SJC_TAPID%20%24SJC_TAPID%3CBR%20%2F%3E%7D%20else%20%7B%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20set%20_SJC_TAPID%200x0191c01d%3CBR%20%2F%3E%7D%3CBR%20%2F%3Eset%20_SJC_TAPID2%200x0191e01d%3CBR%20%2F%3Eset%20_SJC_TAPID3%200x2191c01d%3CBR%20%2F%3Eset%20_SJC_TAPID4%200x2191e01d%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23here%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ejtag%20newtap%20%24_CHIPNAME%20sjc%20-irlen%205%20-ircapture%200x01%20-irmask%200x1f%20%5C%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-expected-id%20%24_SJC_TAPID%20-expected-id%20%24_SJC_TAPID2%20%5C%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-expected-id%20%24_SJC_TAPID3%20-expected-id%20%24_SJC_TAPID4%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Enow%20is%20set%20for%20_SJC_TAPID%20not%20_SDMATAPID%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎09-10-2020 02:47 AM
Updated by:
