All Board Android ADB
ADB
ADB is a tool for Android debugging. With ADB, you can install applications from you PC, copy files to/from your device, access console. You can access your device using an USB Cable, or through network (using an IP address).
You can take ADB from SDK [1] or inside <my_android>/out/host/linux-x86/bin/adb
I cannot see my device
  1. First checkpoint must be for ADBD. It´s the ADB daemon, and if it´s not running on your device, you will not be able to access it.
  2. Install and configure any USB driver [2] [3]
  3. Double check connection (USB cable, ethernet)
  4. Double check if debugging is on
  5. Double check if USB config is right (see how on User Guide)
Tips and Tricks
Turning on
Remember to turn debugging mode on:
Settings->Applications->Development->USB debugging
No Permission
When you get "no permissions" from ADB, you need to start server with your root user:
$ sudo /usr/share/android-sdk-linux_86/tools/adb devices
List of devices attached
????????????    no permissions
$ sudo /usr/share/android-sdk-linux_86/tools/adb shell
error: insufficient permissions for device
$ sudo /usr/share/android-sdk-linux_86/tools/adb kill-server
$ sudo /usr/share/android-sdk-linux_86/tools/adb start-server
* daemon not running. starting it now *
* daemon started successfully *
0123456789ABCDEF    device
# ls
dev
etc
タグ(2)
コメント
mbp
Have updated from R9.3 to R10.4 and cannot connect adb via USB.  WinXP continues to see "MX51 BBG Android" and cannot locate necessary software for this device.  The R9.3 continues to load and connect via USB as Android Phone. - but the R10.4 appears as a new unknown device and cannot connect.  I have been through the R10.4 User Guide and reloaded and modified the .ini (0x15a2) and killed/restarted adb from both the PC and Android (device) in myriad permutations all to no avail.
I have checked getprop's and driver versions.  Nothing.  Simply "adb devices" cannot recognize the R10.4 Android Phone (mx51 BBG).
HELP!!!   :smileyconfused:  :smileycry:   ...any thoughts suggestions would be MOST appreciative.   (been two days on this issue - and still have the SDK update: dex issue to resolve)
THX
mike
%3CLINGO-SUB%20id%3D%22lingo-sub-1115962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%AA%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%BC%E3%83%89%20Android%20ADB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-381566288%22%20id%3D%22toc-hId-1304223410%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EADB%E3%81%AE%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3CSPAN%20class%3D%22mw-headline%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EADB%E3%81%AFAndroid%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E7%94%A8%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82ADB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81PC%E3%81%8B%E3%82%89%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%81%9F%E3%82%8A%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E3%81%AE%E9%96%93%E3%81%A7%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%9F%E3%82%8A%E3%80%81%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%9F%E3%82%8A%20%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%20%E3%80%82%3C%2FSPAN%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%81%AF%E3%80%81USB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF(IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8)%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EADB%E3%81%AFSDK%20%3CA%20class%3D%22autonumber%20external%22%20href%3D%22http%3A%2F%2Fdeveloper.android.com%2Fsdk%2Findex.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%5B1%5D%3C%2FA%3E%20%E3%81%BE%E3%81%9F%E3%81%AFinside%20%3CMY_ANDROID%3E%2Fout%2Fhost%2Flinux-x86%2Fbin%2Fadb%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FMY_ANDROID%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1072127762%22%20id%3D%22toc-hId-1994784884%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FH2%3E%3COL%3E%3CLI%3E%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AF%20ADBD%20%E7%94%A8%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AFADB%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLI%3E%3CLI%3E%E4%BB%BB%E6%84%8F%E3%81%AEUSB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%20%3CA%20class%3D%22autonumber%20external%22%20href%3D%22http%3A%2F%2Fdeveloper.android.com%2Fguide%2Fdeveloping%2Fdevice.html%23setting-up%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%5B2%5D%20%3C%2FA%3E%3CA%20class%3D%22autonumber%20external%22%20href%3D%22http%3A%2F%2Fdeveloper.android.com%2Fsdk%2Fwin-usb.html%23InstallingDriver%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%5B3%5D%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%E6%8E%A5%E7%B6%9A%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99(USB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%80%81%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88)%3C%2FLI%3E%3CLI%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%8C%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3EUSB%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84(%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--735326701%22%20id%3D%22toc-hId-187330421%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%E3%83%92%E3%83%B3%E3%83%88%E3%81%A8%E3%82%B3%E3%83%84%3C%2FSPAN%3E%3C%2FH2%3E%3CH3%20id%3D%22toc-hId--44765227%22%20id%3D%22toc-hId-877891895%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FH3%3E%3CH3%20id%3D%22toc-hId--1852219690%22%20id%3D%22toc-hId--929562568%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E3%82%8B%3C%2FSPAN%3E%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%BF%98%E3%82%8C%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%E8%A8%AD%E5%AE%9A-%26gt%3B%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3-%26gt%3B%E9%96%8B%E7%99%BA-%26gt%3BUSB%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FBLOCKQUOTE%3E%3CH3%20id%3D%22toc-hId-635293143%22%20id%3D%22toc-hId-1557950265%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%E8%A8%B1%E5%8F%AF%E3%81%AA%E3%81%97%20%3C%2FSPAN%3E%3C%2FH3%3E%3CP%3EADB%E3%81%8B%E3%82%89%E3%80%8C%E6%A8%A9%E9%99%90%E3%81%AA%E3%81%97%E3%80%8D%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81root%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%A7%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20sudo%20%2Fusr%2Fshare%2Fandroid-sdk-linux_86%2Ftools%2Fadb%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FP%3E%0A%3CP%3E%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%3C%2FP%3E%0A%3CP%3E%3F%3F%3F%3F%3F%3F%3F%3F%3F%3F%3F%3F%26nbsp%3B%26nbsp%3B%20%E6%A8%A9%E9%99%90%E3%81%AA%E3%81%97%3C%2FP%3E%0A%3CP%3E%24%20sudo%20%2F%20usr%20%2F%20share%20%2F%20android-sdk-linux_86%20%2F%20tools%20%2F%20adb%E3%82%B7%E3%82%A7%E3%83%AB%3C%2FP%3E%0A%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E8%A8%B1%E5%8F%AF%E3%81%8C%E4%B8%8D%E5%8D%81%E5%88%86%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3E%24%20sudo%20%2Fusr%2Fshare%2Fandroid-sdk-linux_86%2Ftools%2Fadb%20kill-server%3C%2FP%3E%0A%3CP%3E%24%20sudo%20%2Fusr%2Fshare%2Fandroid-sdk-linux_86%2Ftools%2Fadb%20start-server%3C%2FP%3E%0A%3CP%3E*%20%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%8A%E3%81%99%E3%81%90%E5%A7%8B%E3%82%81%E3%82%8B%20*%3C%2FP%3E%0A%3CP%3E*%20%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20*%3C%2FP%3E%0A%3CP%3E%24%20sudo%20%2Fusr%2Fshare%2Fandroid-sdk-linux_86%2Ftools%2Fadb%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FP%3E%0A%3CP%3E%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%3C%2FP%3E%0A%3CP%3E0123456789ABCDEF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FP%3E%0A%3CP%3E%24%20sudo%20%2F%20usr%20%2F%20share%20%2F%20android-sdk-linux_86%20%2F%20tools%20%2F%20adb%E3%82%B7%E3%82%A7%E3%83%AB%3C%2FP%3E%0A%3CP%3E%23%20ls%3C%2FP%3E%0A%3CP%3E%E9%96%8B%E7%99%BA%3C%2FP%3E%0A%3CP%3EETC%3C%2FP%3E%0A%0A%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1115962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89Android%E3%81%AEADB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ER9.3%E3%81%8B%E3%82%89R10.4%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%97%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81USB%E7%B5%8C%E7%94%B1%E3%81%A7adb%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82WinXP%E3%81%AF%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E3%80%8CMX51%20BBG%20Android%E3%80%8D%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%80%81%E3%81%93%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82R9.3%E3%81%AF%E3%80%81Android%20Phone%E3%81%A8%E3%81%97%E3%81%A6USB%E7%B5%8C%E7%94%B1%E3%81%A7%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8A%E3%82%88%E3%81%B3%E6%8E%A5%E7%B6%9A%E3%81%97%E7%B6%9A%E3%81%91%E3%81%BE%E3%81%99%E3%80%82-%20%E3%81%97%E3%81%8B%E3%81%97%E3%80%81R10.4%E3%81%AF%E6%96%B0%E3%81%97%E3%81%84%E4%B8%8D%E6%98%8E%E3%81%AA%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82R10.4%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E8%AA%AD%E3%81%BF%E3%80%81.ini%E3%82%92%E5%86%8D%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F(0x15a2)%E3%81%8A%E3%82%88%E3%81%B3PC%E3%81%A8Android(%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9)%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%8B%E3%82%89adb%E3%82%92%E5%BC%B7%E5%88%B6%E7%B5%82%E4%BA%86%2F%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egetprop%E3%81%A8%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BD%95%E3%82%82%E3%81%AA%E3%81%84%E3%80%82%E5%8D%98%E3%81%AB%E3%80%8Cadb%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%80%8D%E3%81%AFR10.4%20Android%20Phone(mx51%20BBG)%E3%82%92%E8%AA%8D%E8%AD%98%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%98%E3%83%AB%E3%83%97%EF%BC%81%EF%BC%81%EF%BC%81%26nbsp%3B%20%3Asmileyconfused%3A%20%3Asmileycry%3A%20...%E3%81%A9%E3%82%93%E3%81%AA%E8%80%83%E3%81%88%E3%81%AE%E6%8F%90%E6%A1%88%E3%82%82%E6%9C%80%E3%82%82%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82(%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB2%E6%97%A5%E3%81%8C%E7%B5%8C%E9%81%8E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81SDK%E3%81%AE%E6%9B%B4%E6%96%B0%3ADEX%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETHX%E3%81%AE%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%A4%E3%82%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎08-03-2012 03:26 PM
更新者:
