Hi all,
We are looking into porting an old application from an i.MX6 processor to an i.MX8MM or i.MX8MN processor. Currently, we use the IPU on the i.MX6 processor to scale the frames from one resolution to another (potentially higher) resolution in hardware. We also rotate the image. The IPU is no longer available on i.MX8M processors. How could we achieve similar functionality on a i.MX8M processor? Is the 2D GPU suitable?
Thank you.
解決済! 解決策の投稿を見る。
Hi @YoshiDev,
i.MX 8 Series Applications Processors Multicore Arm® Cortex® Processors
Hi @YoshiDev,
