IMX8QM DP++ (DisplayPort Dual-Mode)
david_gounaris
We've a custom (imx8qm) board with an mDP (mini DisplayPort) connector, and I'd like to connect an external HDMI screen using a passive mDP-HDMI adapter. My understanding is that this should be possible if DP++ (DisplayPort Dual-Mode) is supported.
I have a few questions regarding DP++ support on the i.MX8QM:
  1. i.MX8QM DP++ Support: Does the i.MX8QM processor itself support DP++?
  2. Cadence Firmware DP++ Support: Does the Cadence firmware for the i.MX8QM's DisplayPort controller support DP++?
  3. Device Tree Configuration: Are there any necessary device tree (dtb) configurations required to enable and utilize DP++ functionality? If so, could you please provide details on the specific settings?
Thank you for your assistance.
JorgeCas
Unfortunately DisplayPort Dual-Mode is not supported in i.MX8QM, you need to look into another adapter.
I apologize the inconvenience that this may affect your design.
Best regards.
JorgeCas
Best regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-2036085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8QM%20DP%2B%2B%20(DisplayPort%20Dual-Mode)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2036085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EWe've%20a%20custom%20(imx8qm)%20board%20with%20an%20mDP%20(mini%20DisplayPort)%20connector%2C%20and%20I'd%20like%20to%20connect%20an%20external%20HDMI%20screen%20using%20a%20passive%20mDP-HDMI%20adapter.%20My%20understanding%20is%20that%20this%20should%20be%20possible%20if%20DP%2B%2B%20(DisplayPort%20Dual-Mode)%20is%20supported.%3C%2FP%3E%3CP%3EI%20have%20a%20few%20questions%20regarding%20DP%2B%2B%20support%20on%20the%20i.MX8QM%3A%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3E%3CSTRONG%3Ei.MX8QM%20DP%2B%2B%20Support%3A%3C%2FSTRONG%3E%20Does%20the%20i.MX8QM%20processor%20itself%20support%20DP%2B%2B%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3ECadence%20Firmware%20DP%2B%2B%20Support%3A%3C%2FSTRONG%3E%20Does%20the%20Cadence%20firmware%20for%20the%20i.MX8QM's%20DisplayPort%20controller%20support%20DP%2B%2B%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EDevice%20Tree%20Configuration%3A%3C%2FSTRONG%3E%20Are%20there%20any%20necessary%20device%20tree%20(dtb)%20configurations%20required%20to%20enable%20and%20utilize%20DP%2B%2B%20functionality%3F%20If%20so%2C%20could%20you%20please%20provide%20details%20on%20the%20specific%20settings%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3EThank%20you%20for%20your%20assistance.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2036274%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20IMX8QM%20DP%2B%2B%20(DisplayPort%20Dual-Mode)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2036274%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EUnfortunately%20DisplayPort%20Dual-Mode%20is%20not%20supported%20in%20i.MX8QM%2C%20you%20need%20to%20look%20into%20another%20adapter.%3C%2FP%3E%0A%3CP%3EI%20apologize%20the%20inconvenience%20that%20this%20may%20affect%20your%20design.%3C%2FP%3E%0A%3CP%3EBest%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E
